[GRASS-SVN] r42059 - grass-addons/gui/wxpython/data_catalog
Thu Apr 29 14:49:29 EDT 2010
Author: epifanio
Date: 2010-04-29 14:49:28 -0400 (Thu, 29 Apr 2010)
New Revision: 42059
Added:
   grass-addons/gui/wxpython/data_catalog/conf.xml
   grass-addons/gui/wxpython/data_catalog/tcp4ossim.py
   grass-addons/gui/wxpython/data_catalog/LayerTree.py
   grass-addons/gui/wxpython/data_catalog/catalog.py
   grass-addons/gui/wxpython/data_catalog/mapdisplay.py
Work on code to connetc datacatalog with ossimplanet
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py	2010-04-29 13:12:42 UTC (rev 42058)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py	2010-04-29 18:49:28 UTC (rev 42059)
@@ -55,6 +55,7 @@
         self.ID_COPY = wx.NewId()
         self.ID_DEL = wx.NewId()
         self.ID_OSSIM = wx.NewId()
+        self.ID_OSSIM2 = wx.NewId()
         self.ID_INFO = wx.NewId()
         self.ID_REPORT = wx.NewId()
@@ -93,6 +94,7 @@
         self.Bind(wx.EVT_MENU,self.OnRename,id=self.ID_REN)
         self.Bind(wx.EVT_MENU,self.OnDelete,id=self.ID_DEL)
         self.Bind(wx.EVT_MENU,self.OnOssim,id=self.ID_OSSIM)
+        self.Bind(wx.EVT_MENU,self.OnOssim2,id=self.ID_OSSIM2)
         self.Bind(wx.EVT_MENU,self.OnInfo,id=self.ID_INFO)
         self.Bind(wx.EVT_MENU,self.OnReport,id=self.ID_REPORT)
@@ -289,7 +291,8 @@
             mnuCopy = self.popupmenu.Append(self.ID_COPY,'&Copy\tCtrl+C')
             mnuRename = self.popupmenu.Append(self.ID_REN,'&Rename\tCtrl-R')
             mnuDel = self.popupmenu.Append(self.ID_DEL,'&Delete\tDEL')
-            mnuOssim = self.popupmenu.Append(self.ID_OSSIM,'&send to OssimPlanet')
+            mnuOssim = self.popupmenu.Append(self.ID_OSSIM,'&Send to OssimPlanet')
+            mnuOssim = self.popupmenu.Append(self.ID_OSSIM2,'&Remove from OssimPlanet')
             mnuInfo = self.popupmenu.Append(self.ID_INFO,'&Info')
             mnuReport = self.popupmenu.Append(self.ID_REPORT,'&Report')
             self.PopupMenu(self.popupmenu)
@@ -415,6 +418,25 @@
             current = OssimPlanet(cmdflag)
             current.start()
+    def OnOssim2( self,event ):
+        Performs grass command for deleting a map
+        item =  self.GetSelection()
+        parent  =self.GetItemParent(item)
+        if self.GetItemText(parent) == "Raster Map" :
+            cmdflag = 'r.planet.py -r map=' + str(self.GetItemText(item))
+        elif self.GetItemText(parent) == "Vector Map" :
+            cmdflag = 'v.planet.py -r map=' + str(self.GetItemText(item))
+        if cmdflag:
+            #command = ["r.planet.py", cmdflag]
+            #gcmd.CommandThread(command,stdout=None,stderr=None).run()
+            current = OssimPlanet(cmdflag)
+            current.start()
     def OnDisplay(self, event):
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py	2010-04-29 13:12:42 UTC (rev 42058)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py	2010-04-29 18:49:28 UTC (rev 42059)
@@ -187,8 +187,8 @@
         #setting splitter window
         self.cmbPanel = wx.Panel(self,name="cmbpanel")
         self.maptree = None
         self.pg_panel = None
         self.cb_loclist = []
@@ -197,8 +197,17 @@
         #creating controls
         self.mInfo = wx.TextCtrl(self.cmbPanel, wx.ID_ANY, style = wx.TE_READONLY,size=(300,30))
+        # start radiobutton to activate - deactivate the mouse actions to send position to ossimplanet
+        self.options = ['on', 'off']
+        self.radiobox = wx.RadioBox(self.cmbPanel, wx.ID_ANY, "", pos=(100, 0), choices=self.options, style=wx.HORIZONTAL)
+        self.radiobox.SetSelection(1)
         #self.chkInfo = wx.CheckBox(self.cmbPanel, wx.ID_ANY,"display Info", wx.DefaultPosition, wx.DefaultSize)
         self.treeExpand = wx.CheckBox(self.cmbPanel, wx.ID_ANY,"Expand All", wx.DefaultPosition, wx.DefaultSize)
+        #self.treeExpand2 = wx.CheckBox(self.cmbPanel, wx.ID_ANY,"Expand All 2", wx.DefaultPosition, wx.DefaultSize)
         self.cmbLocation = wx.ComboBox(self.cmbPanel, value = "Select Location",size=wx.DefaultSize, choices=self.loclist)
         self.cmbMapset = wx.ComboBox(self.cmbPanel, value = "Select Mapset", size=wx.DefaultSize)
         #self.tree = wx.TreeCtrl(self.pLeft, wx.ID_ANY, wx.DefaultPosition, wx.DefaultSize, wx.TR_HIDE_ROOT|wx.TR_HAS_BUTTONS|wx.TR_EDIT_LABELS)
@@ -2047,6 +2056,7 @@
         self.cmbSizer.Add(self.cmbLocation)
         self.cmbSizer.Add(self.cmbMapset)
         self.cmbSizer.Add(self.mInfo)
+        self.cmbSizer.Add(self.radiobox)
         #splitter window sizers
         self.mSizer.Add(self.cmbPanel,flag=wx.EXPAND)
         #self.mSizer.Add(self.win, 1, wx.EXPAND)
Added: grass-addons/gui/wxpython/data_catalog/conf.xml
--- grass-addons/gui/wxpython/data_catalog/conf.xml	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/conf.xml	2010-04-29 18:49:28 UTC (rev 42059)
@@ -0,0 +1,8 @@
+<?xml version="1.0"?>
+    <PlanetSashaSettings>
+        <tcp>
+            <host>localhost</host>
+            <dport>8000</dport>
+            <pport>7000</pport>
+        </tcp>
+    </PlanetSashaSettings>
\ No newline at end of file
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py	2010-04-29 13:12:42 UTC (rev 42058)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py	2010-04-29 18:49:28 UTC (rev 42059)
@@ -32,6 +32,7 @@
 import tempfile
 import copy
 import time
+from tcp4ossim import zoomto
@@ -1162,7 +1163,6 @@
         self.Zoom(begin, end, zoomtype)
         # redraw map
-        self.flag=True
         self.UpdateMap()
         ### self.OnPaint(None)
@@ -2082,7 +2082,7 @@
         self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
                          self.Map.region['e'], self.Map.region['w'])
-        self.flag = True
         self.UpdateMap()
         self.parent.StatusbarUpdate()
@@ -2096,9 +2096,7 @@
-        self.flag=True
         self.UpdateMap()
@@ -2436,6 +2434,9 @@
         self.MapWindow = self.MapWindow2D
         self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
         self.MapWindow.Bind(wx.EVT_LEFT_DOWN, self.OnClick)
+        self.MapWindow.Bind(wx.EVT_RADIOBOX, self.printsomething)
+        # test for right click mouse event
+        #self.MapWindow.Bind(wx.EVT_RIGHT_DOWN, self.OnClick3)
         self.MapWindow.SetCursor(self.cursors["default"])
         # used by Nviz (3D display mode)
         self.MapWindow3D = None
@@ -2498,10 +2499,6 @@
         self.viewInfo = True        #to display v/r.info on mapdisplay
         self.gisdbase = self.gisrc['GISDBASE']
-        self.current_zoom = 100
-        self.zoom_step = 10
         parent1 = self.GetParent()
         rightpanel = parent1.GetParent()
@@ -2539,17 +2536,48 @@
         #r.rightSizer.Add(self.maptree)
     def OnClick(self,event):
         x, y = self.MapWindow.Pixel2Cell(event.GetPosition())
-        if self.MapWindow.mouse['use'] == "zoom":
-            self.current_zoom = self.current_zoom + self.zoom_step
-        self.frame.mInfo.SetValue(str(x) + ' , ' + str(y)+ ' , ' + str(self.current_zoom) + '%')
+        out = subprocess.Popen(['m.proj', '-o'], stdout=subprocess.PIPE,  stdin=subprocess.PIPE).communicate("%s %s" % (x,y))[0]
+        f = out.replace("'"," ").replace('d',' ').replace('"',' ').replace('\n','').split('\t')
+        lon = f[0].split(' ')
+        lat = f[1].split(' ')[:-1]
+        if lat[-1] == 'N':
+            signlat = 1
+        if lat[-1] == 'S':
+            signlat = -1
+        if lon[-1] == 'E':
+            signlon = 1
+        if lon[-1] == 'W':
+            signlon = -1
+        lat = (float(lat[0]) + (float(lat[1]) / 60) + float(lat[2]) / 3600) * float(signlat)
+        lon = (float(lon[0]) + (float(lon[1]) / 60) + float(lon[2]) / 3600) * float(signlon)
+        self.frame.mInfo.SetValue(str(lat) + ' , ' + str(lon))
+        zoomto(str(lon),str(lat),15000)
+        event.Skip()
-        #print self.current_zoom
+    def OnClick2(self,event):
+        x, y = self.MapWindow.Pixel2Cell(event.GetPosition())
+        self.frame.mInfo.SetValue(str(x) + ' , ' + str(y))
+        event.Skip()
+    def OnClick3(self,event):
+        event.Skip()
+    # test for radiobox
+    def printsomething(self,event):
+        stringa = 'ffffff'
+        self.frame.mInfo.SetValue(str(stringa))
+        print stringa
         event.Skip()
     def read_gisrc(self):
@@ -2949,9 +2977,6 @@
         Zoom in the map.
         Set mouse cursor, zoombox attributes, and zoom direction
         if self.toolbars['map']:
             self.toolbars['map'].OnTool(event)
             self.toolbars['map'].action['desc'] = ''
@@ -2969,9 +2994,6 @@
         Zoom out the map.
-        self.zoom_step = -10
@@ -3017,7 +3039,6 @@
         self.Map.getRegion()
         self.Map.getResolution()
-        self.flag=True
         self.UpdateMap()
         # event.Skip()
Added: grass-addons/gui/wxpython/data_catalog/tcp4ossim.py
--- grass-addons/gui/wxpython/data_catalog/tcp4ossim.py	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/tcp4ossim.py	2010-04-29 18:49:28 UTC (rev 42059)
@@ -0,0 +1,91 @@
+#!/usr/bin/env python
+import socket
+from xml.dom import minidom
+import os
+import sys
+apppath = os.path.abspath(os.path.dirname(sys.argv[0]))
+configfile = '%s/conf.xml' % (apppath)
+def parseTCPconf():
+    xmldoc = minidom.parse(configfile)
+    tcpconf = {}
+    planetsashaconf = xmldoc.firstChild
+    if planetsashaconf.childNodes[1].childNodes[1].firstChild is not None:
+        tcpconf['tcpHost'] = planetsashaconf.childNodes[1].childNodes[1].firstChild.data
+    else :
+        print 'tcpHost not found'
+        tcpconf['tcpHost'] = 'None'
+    if planetsashaconf.childNodes[1].childNodes[3].firstChild is not None:
+        tcpconf['tcpDport'] = planetsashaconf.childNodes[1].childNodes[3].firstChild.data
+    else :
+        print 'tcpDport not found'
+        tcpconf['tcpDport'] = 'None'
+    if planetsashaconf.childNodes[1].childNodes[5].firstChild is not None:
+        tcpconf['tcpPport'] = planetsashaconf.childNodes[1].childNodes[5].firstChild.data
+    else :
+        print 'tcpPport not found'
+        tcpconf['tcpPport'] = 'None'
+    return tcpconf
+def setparamconnection():
+    try :
+        conf = parseTCPconf()
+        host = conf['tcpHost']
+        nav = conf['tcpPport']
+        data = conf['tcpDport']
+        return host, nav, data
+    except :
+        print 'Use preference Panel to set preference'
+def addfile(output):
+    host = setparamconnection()[0]
+    dport = setparamconnection()[2]
+    ossim_data_xml = "<Add target=':idolbridge'><Image groupType='groundTexture'><filename>%s</filename> <id>%s</id><name>%s</name></Image></Add>" % (output,output,output)
+    ossimdata = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
+    ossimdata.connect((host, int(dport)))
+    try :
+        ossimdata.send(ossim_data_xml)
+        ossimdata.close()
+    except :
+        print "Connection error"
+def zoomto(lon,lat,distance):
+    pport = setparamconnection()[1]
+    ossim_zoom_xml = '<Set target=":navigator" vref="wgs84"><Camera><longitude>%s</longitude><latitude>%s</latitude><altitude>%s</altitude><heading>0</heading><pitch>0</pitch><roll>0</roll><altitudeMode>absolute</altitudeMode><range>%s</range></Camera></Set>' % (lon, lat, distance, distance)
+    ossimposition = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
+    try :
+        ossimposition.connect((host, int(pport)))
+        ossimposition.send(ossim_zoom_xml)
+        ossimposition.close()
+    except :
+def removefile(output):
+    ossim_data_xml = "<Remove target=':idolbridge' id='%s' />" % (output)
+    try :
+        ossimdata.close()
+    except :
+        print 'Connection error'
+def addzoom(output,lon,lat,distance):
+	addfile(output)
+	zoomto(lon,lat,distance)
+#addzoom('/Users/sasha/Desktop/rgb.tif',-81.0009,29.0009,15000)
+#removefile('/data/florida/Brevard.tif','localhost',8000)
