[GRASS-SVN] r42063 - grass-addons/ossim_grass/v.planet
Thu Apr 29 17:56:53 EDT 2010
Author: epifanio
Date: 2010-04-29 17:56:53 -0400 (Thu, 29 Apr 2010)
New Revision: 42063
   grass-addons/ossim_grass/v.planet/v.planet.py
moved code to make omd style inside "if flag"
Modified: grass-addons/ossim_grass/v.planet/v.planet.py
--- grass-addons/ossim_grass/v.planet/v.planet.py	2010-04-29 21:49:30 UTC (rev 42062)
+++ grass-addons/ossim_grass/v.planet/v.planet.py	2010-04-29 21:56:53 UTC (rev 42063)
@@ -134,31 +134,31 @@
         mapfile = os.path.join(vectorpath, 'head')
         vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt', 'vector/')
     except :
-        vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], mappa[0] )
+        vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vector', mappa[0] )
         mapfile = os.path.join(vectorpath, 'head' )
-        vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vector', 'vrt', 'vector/')
+        vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt', 'vector/')
     d = os.path.dirname(vrtdir)
     if not os.path.exists(d):
         os.makedirs(d)
     vrtfilename =  mappa[0] + '.vrt'
     output = os.path.join(vrtdir, vrtfilename)
-    if not os.path.exists(output):
-        ogrvrt(mapfile,output)
-    print 'try to make omd'
-    makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
-    proj_info = projinfo()
-    unit = proj_info['units']
-    if unit.lower() == 'meters':
-        zoom_position = setCPRJ(options['map'])
-    if unit.lower() == 'metres':
-    if unit == 'Degrees':
-        zoom_position = setCLL(options['map'])
-    lat = zoom_position[0]
-    lon = zoom_position[1]
-    distance = zoom_position[2]
     if add :
         try:
+            if not os.path.exists(output):
+                ogrvrt(mapfile,output)
+            print 'try to make omd'
+            makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
+            proj_info = projinfo()
+            unit = proj_info['units']
+            if unit.lower() == 'meters':
+                zoom_position = setCPRJ(options['map'])
+            if unit.lower() == 'metres':
+            if unit == 'Degrees':
+                zoom_position = setCLL(options['map'])
+            lat = zoom_position[0]
+            lon = zoom_position[1]
+            distance = zoom_position[2]
             addzoom(output,lon,lat,distance,host,dport,pport)
             print 'Added vector file :', mappa[0]
             print 'Camera positioned to : '
