[GRASS-SVN] r42064 - grass-addons/ossim_grass/r.planet
svn_grass at osgeo.org
Fri Apr 30 07:10:54 EDT 2010
Author: epifanio
Date: 2010-04-30 07:10:53 -0400 (Fri, 30 Apr 2010)
New Revision: 42064
grass-addons/ossim_grass/r.planet/description.html
grass-addons/ossim_grass/r.planet/r.planet.py
added flags to handle mpi, improved description.
Modified: grass-addons/ossim_grass/r.planet/description.html
--- grass-addons/ossim_grass/r.planet/description.html 2010-04-29 21:56:53 UTC (rev 42063)
+++ grass-addons/ossim_grass/r.planet/description.html 2010-04-30 11:10:53 UTC (rev 42064)
@@ -1,12 +1,48 @@
<h2>DESCRIPTION</h2>
-<em><b>r.planet.py : </b></em> Scripts to :
+<em><b>r.planet.py </b></em>
<p>
-- generate vrt layer from a selected grass raster layer and add/zoomTo/remove the data from/to ossimplanet using the ossimplanet tcp listner.
+- Generate vrt layer from a selected grass raster layer and add/zoomTo/remove the data from/to ossimplanet using the ossimplanet tcp listner.
<p>
-- generate ossimplanet 3d tiles from elevation data.
+- Generate ossimplanet 3d tiles from elevation data.
+<p>
+As default the module uses : host = 'localhost', pport = 7000, dport = 8000
+<p>
+The module will generate VRT data inside the directory : $MAPSET/vrt/raster and $MAPSET/vrt/raster/elevetion.
+<p>
+Using the flag "-d" if non name is selected (parameter : elev) the module will use the map's name.
+<h2>Flags:</h2>
+<em><b>-a </b></em> : Add selected map to Ossimplanet
+<p>
+<em><b>-r </b></em> : Remove selected map to Ossimplanet
+<p>
+<em><b>-d </b></em> : Generate 3d Tiles
+<p>
+<em><b>-m </b></em> : Use Open MPI
+<h2>Parameters</h2> :
+<p>
+<em><b>map </b></em> : Input map
+<p>
+<em><b>Host </b></em> : Ossimplanet listener IP
+<p>
+<em><b>dport </b></em> : Ossimplanet listener port to receive position messages
+<p>
+<em><b>pport </b></em> : Ossimplanet listener port to receive datasource
+<p>
+<em><b>np </b></em> : Number of MPI processors
+<p>
+<p>
+<em><b>tile </b></em> : tiles dimension for 3d data
+<p>
+<p>
+<em><b>elev </b></em> : Name for the exporeted elevation
+<p>
<h2>EXAMPLE</h2>
Add selected map to ossimplanet screen and zoom to it :
Modified: grass-addons/ossim_grass/r.planet/r.planet.py
--- grass-addons/ossim_grass/r.planet/r.planet.py 2010-04-29 21:56:53 UTC (rev 42063)
+++ grass-addons/ossim_grass/r.planet/r.planet.py 2010-04-30 11:10:53 UTC (rev 42064)
@@ -71,6 +71,13 @@
#% description: tile
#% required : no
#%end
+#%option
+#% key: elev
+#% type: string
+#% key_desc: elevation name
+#% description: elevation name
+#% required : no
+#%end
#%flag
#% key: a
#% description: Add raster
@@ -97,6 +104,8 @@
import platform
def main():
+ global mpi
+ global np
add = flags['a']
remove = flags['r']
orthoigen = flags['d']
@@ -105,6 +114,7 @@
dport = options['dport']
pport = options['pport']
tile = options['tile']
+ elev = options['elev']
np = options['np']
grassenv = grass.gisenv()
mappa = options['map'].replace("@"," ")
@@ -113,6 +123,7 @@
nflags = len(filter(None, [add, remove, orthoigen]))
if nflags > 1:
grass.run_command('g.message' , message = 'Cannot add & remove a map or use orthoigen at the same time.')
+ sys.exit()
if nflags < 1:
grass.run_command('g.message' , message = 'No action requested , please choose one from "-a : add" or "-r : remove" flags.')
try :
@@ -145,32 +156,34 @@
lat = zoom_position[0]
lon = zoom_position[1]
distance = zoom_position[2]
- if nflags == 1:
- if add :
- try :
- addzoom(output,lon,lat,distance,host,dport,pport)
- print 'Added raster file :', mappa[0]
- print 'Camera positioned to : '
- print 'Longitude = ',lon
- print 'Latitude = ', lat
- print 'Altitude = ' , distance
- except :
- print "conecction error"
- if remove :
- removefile(output,host,dport)
- print 'Removed raster file :', mappa[0]
- if orthoigen :
- if tile != '':
- path = os.path.dirname(output)
+ if add :
+ try :
+ addzoom(output,lon,lat,distance,host,dport,pport)
+ print 'Added raster file :', mappa[0]
+ print 'Camera positioned to : '
+ print 'Longitude = ',lon
+ print 'Latitude = ', lat
+ print 'Altitude = ' , distance
+ except :
+ print "conecction error"
+ if remove :
+ removefile(output,host,dport)
+ print 'Removed raster file :', mappa[0]
+ if orthoigen :
+ if tile != '':
+ path = os.path.dirname(output)
+ if elev == '':
elevdir = os.path.join(path,'elevation',mappa[0]+'/')
- if not os.path.exists(elevdir):
- os.makedirs(elevdir)
- elev = mappa[0]+'.tiff'
- exportiff(output,elev)
- instr = make3d(tile, elev, elevdir)
- os.system(instr)
- if tile == '':
- print 'please set the tile dimension'
+ else :
+ elevdir = os.path.join(path,'elevation',elev+'/')
+ if not os.path.exists(elevdir):
+ os.makedirs(elevdir)
+ elev = mappa[0]+'.tiff'
+ exportiff(output,elev)
+ instr = make3d(tile, elev, elevdir)
+ os.system(instr)
+ if tile == '':
+ print 'please set the tile dimension'
def exportiff(infile,outfile):
gdal.GetDriverByName('GTiff').CreateCopy(outfile,gdal.Open(infile))
@@ -355,16 +368,14 @@
def makeoverview(input):
systemplatform = WhichPlatform()
- mpi = 0
- np = 1
if systemplatform == 'Darwin':
img2rrexec = 'export DYLD_FRAMEWORK_PATH=/Users/sasha/OssimBuilds/Release/ ; /Users/sasha/OssimBuilds/Release/ossim-img2rr'
else :
img2rrexec = 'ossim-img2rr'
- if mpi == 1 :
+ if mpi :
os.system("mpirun -np %s %s %s" % (np, img2rrexec, input))
else :
- os.system('%s %s' % (img2rrexec, input))
+ os.system('%s %s' % (img2rrexec, input))
