[GRASS-SVN] r42065 - in grass/trunk/vector/lidar: lidarlib
v.lidar.correction v.lidar.edgedetection v.lidar.growing
v.outlier v.surf.bspline
svn_grass at osgeo.org
Fri Apr 30 11:36:05 EDT 2010
Author: huhabla
Date: 2010-04-30 11:36:04 -0400 (Fri, 30 Apr 2010)
New Revision: 42065
Removed:
grass/trunk/vector/lidar/lidarlib/TcholBand.c
grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
grass/trunk/vector/lidar/lidarlib/zones.c
grass/trunk/vector/lidar/v.lidar.correction/correction.c
grass/trunk/vector/lidar/v.lidar.correction/main.c
grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
grass/trunk/vector/lidar/v.lidar.growing/main.c
grass/trunk/vector/lidar/v.outlier/main.c
grass/trunk/vector/lidar/v.outlier/outlier.c
grass/trunk/vector/lidar/v.outlier/v.outlier.html
grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
grass/trunk/vector/lidar/v.surf.bspline/main.c
grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html
Replaced tcholSolver() with the gmath version
G_math_solver_cholesky_sband(). Removed TcholBand.c. Renamed some
variables to be more descriptive. Added two nc examples from Markus Metz
to the html docs.
Modified: grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
--- grass/trunk/vector/lidar/lidarlib/PolimiFunct.h 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/lidarlib/PolimiFunct.h 2010-04-30 15:36:04 UTC (rev 42065)
@@ -69,11 +69,11 @@
/*STRUCTS DECLARATION */
struct Reg_dimens
- double orlo_h; /*Horizontal tile edge */
- double orlo_v; /*Vertical tile edge */
+ double edge_h; /*Horizontal tile edge */
+ double edge_v; /*Vertical tile edge */
double overlap; /*Tile's overlapping size */
- double latoN; /*South-North side size */
- double latoE; /*East-West side size */
+ double sn_size; /*South-North side size */
+ double ew_size; /*East-West side size */
struct Point
@@ -102,7 +102,7 @@
struct bound_box *, /**/
struct bound_box *, /**/ struct Reg_dimens, /**/ int /**/);
-int P_get_orlo(int, /**/ struct Reg_dimens *, /**/ double, /**/ double /**/);
+int P_get_edge(int, /**/ struct Reg_dimens *, /**/ double, /**/ double /**/);
int P_get_BandWidth(int, /**/ int /**/);
@@ -159,16 +159,6 @@
double **P_Null_Matrix(double ** /**/);
-/*tcholBand */
-void tcholDec(double **N, double **T, int n, int BW);
-void tcholSolve(double **N, double *TN, double *parVect, int n, int BW);
-void tcholSolve2(double **N, double *TN, double **T, double *parVect, int n,
- int BW);
-void tcholInv(double **N, double *invNdiag, int n, int BW);
-void tcholSolveInv(double **N, double *TN, double *invNdiag, double *parVect,
- int n, int BW);
/*interpSpline */
void normalDefBicubic(double **N, double *TN, double *Q, double **obsVect,
Deleted: grass/trunk/vector/lidar/lidarlib/TcholBand.c
--- grass/trunk/vector/lidar/lidarlib/TcholBand.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/lidarlib/TcholBand.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -1,236 +0,0 @@
-#include <stdlib.h> /* imported libraries */
-#include <stdio.h>
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/PolimiFunct.h>
-/* Tcholetsky decomposition -> T= Lower Triangular Matrix */
- int i, j, k, end;
- double somma;
- G_debug(2, "tcholDec(): n=%d BW=%d", n, BW);
- for (i = 0; i < n; i++) {
- G_percent(i, n, 2);
- for (j = 0; j < BW; j++) {
- somma = N[i][j];
- /* start = 1 */
- /* end = BW - j or i + 1 */
- end = ((BW - j) < (i + 1) ? (BW - j) : (i + 1));
- for (k = 1; k < end; k++)
- somma -= T[i - k][k] * T[i - k][j + k];
- if (j == 0) {
- if (somma <= 0.0)
- G_fatal_error(_("Decomposition failed"));
- T[i][0] = sqrt(somma);
- else
- T[i][j] = somma / T[i][0];
- return;
-/* Tcholetsky matrix solution */
- double **T;
- int i, j, start, end;
- T = G_alloc_matrix(n, BW);
- tcholDec(N, T, n, BW); /* T computation */
- /* Forward substitution */
- parVect[0] = TN[0] / T[0][0];
- for (i = 1; i < n; i++) {
- parVect[i] = TN[i];
- /* start = 0 or i - BW + 1 */
- start = ((i - BW + 1) < 0 ? 0 : (i - BW + 1));
- /* end = i */
- for (j = start; j < i; j++)
- parVect[i] -= T[j][i - j] * parVect[j];
- parVect[i] = parVect[i] / T[i][0];
- /* Backward substitution */
- parVect[n - 1] = parVect[n - 1] / T[n - 1][0];
- for (i = n - 2; i >= 0; i--) {
- /* start = i + 1 */
- /* end = n or BW + i */
- end = (n < (BW + i) ? n : (BW + i));
- for (j = i + 1; j < end; j++)
- parVect[i] -= T[i][j - i] * parVect[j];
- G_free_matrix(T);
- return;
-/* Soluzione con Tcholetsky -> la matrice T triangolare viene passata come paramtero e
- non calcolata internamente alla procedura -> T = dmatrix (0, n-1, 0, BW-1) */
- int BW)
- /* end = i */
- return;
-/* Tcholetsky matrix invertion */
- double **T = NULL;
- double *vect = NULL;
- int i, j, k, start;
- double somma;
- vect = G_alloc_vector(n);
- /* T computation */
- /* T Diagonal invertion */
- T[i][0] = 1.0 / T[i][0];
- /* N Diagonal invertion */
- vect[0] = T[i][0];
- invNdiag[i] = vect[0] * vect[0];
- for (j = i + 1; j < n; j++) {
- somma = 0.0;
- /* start = i or j - BW + 1 */
- start = ((j - BW + 1) < i ? i : (j - BW + 1));
- /* end = j */
- for (k = start; k < j; k++) {
- somma -= vect[k - i] * T[k][j - k];
- vect[j - i] = somma * T[j][0];
- invNdiag[i] += vect[j - i] * vect[j - i];
- G_free_matrix(T);
- G_free_vector(vect);
- return;
-/* Tcholetsky matrix solution and invertion */
- int n, int BW)
- int i, j, k, start, end;
- double somma;
- /* end = i */
- somma = 0.0;
- /* end = j */
- G_free_matrix(T);
- return;
Modified: grass/trunk/vector/lidar/lidarlib/zones.c
--- grass/trunk/vector/lidar/lidarlib/zones.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/lidarlib/zones.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -14,11 +14,11 @@
void P_zero_dim(struct Reg_dimens *dim)
- dim->orlo_h = 0.0;
- dim->orlo_v = 0.0;
+ dim->edge_h = 0.0;
+ dim->edge_v = 0.0;
dim->overlap = 0.0;
- dim->latoN = 0.0;
- dim->latoE = 0.0;
+ dim->sn_size = 0.0;
+ dim->ew_size = 0.0;
return;
@@ -69,51 +69,51 @@
switch (type) {
case GENERAL_ROW: /* General case N-S direction */
Elaboration->north =
- Elaboration->south + dim.overlap + (2 * dim.orlo_h);
- Elaboration->south = Elaboration->north - dim.latoN;
- General->N = Elaboration->north - dim.orlo_h;
- General->S = Elaboration->south + dim.orlo_h;
+ Elaboration->south + dim.overlap + (2 * dim.edge_h);
+ Elaboration->south = Elaboration->north - dim.sn_size;
+ General->N = Elaboration->north - dim.edge_h;
+ General->S = Elaboration->south + dim.edge_h;
Overlap->N = General->N - dim.overlap;
Overlap->S = General->S + dim.overlap;
return 0;
case GENERAL_COLUMN: /* General case E-W direction */
Elaboration->west =
- Elaboration->east - dim.overlap - (2 * dim.orlo_v);
- Elaboration->east = Elaboration->west + dim.latoE;
- General->W = Elaboration->west + dim.orlo_v;
- General->E = Elaboration->east - dim.orlo_v;
+ Elaboration->east - dim.overlap - (2 * dim.edge_v);
+ Elaboration->east = Elaboration->west + dim.ew_size;
+ General->W = Elaboration->west + dim.edge_v;
+ General->E = Elaboration->east - dim.edge_v;
Overlap->W = General->W + dim.overlap;
Overlap->E = General->E - dim.overlap;
return 0;
case FIRST_ROW: /* Just started with first row */
- Elaboration->north = orig.north + 2 * dim.orlo_h;
- General->N = Elaboration->north - 2 * dim.orlo_h;
+ Elaboration->north = orig.north + 2 * dim.edge_h;
+ General->N = Elaboration->north - 2 * dim.edge_h;
Overlap->N = General->N;
return 0;
case LAST_ROW: /* Reached last row */
- Elaboration->south = orig.south - 2 * dim.orlo_h;
- General->S = Elaboration->south + 2 * dim.orlo_h;
+ Elaboration->south = orig.south - 2 * dim.edge_h;
+ General->S = Elaboration->south + 2 * dim.edge_h;
Overlap->S = General->S;
return 0;
case FIRST_COLUMN: /* Just started with first column */
- Elaboration->west = orig.west - 2 * dim.orlo_v;
- General->W = Elaboration->west + 2 * dim.orlo_v;
+ Elaboration->west = orig.west - 2 * dim.edge_v;
+ General->W = Elaboration->west + 2 * dim.edge_v;
Overlap->W = General->W;
return 0;
case LAST_COLUMN: /* Reached last column */
- Elaboration->east = orig.east + 2 * dim.orlo_v;
- General->E = Elaboration->east - 2 * dim.orlo_v;
+ Elaboration->east = orig.east + 2 * dim.edge_v;
+ General->E = Elaboration->east - 2 * dim.edge_v;
Overlap->E = General->E;
return 0;
@@ -124,8 +124,8 @@
int P_set_dim(struct Reg_dimens *dim, double pe, double pn, int *nsplx, int *nsply)
- int total_splines, orlo_splines, n_windows, minsplines;
- double E_extension, N_extension, orloE, orloN;
+ int total_splines, edge_splines, n_windows, minsplines;
+ double E_extension, N_extension, edgeE, edgeN;
struct Cell_head orig;
int ret = 0;
@@ -133,67 +133,67 @@
E_extension = orig.east - orig.west;
N_extension = orig.north - orig.south;
- dim->latoE = *nsplx * pe;
- dim->latoN = *nsply * pn;
- orloE = dim->latoE - dim->overlap - 2 * dim->orlo_v;
- orloN = dim->latoN - dim->overlap - 2 * dim->orlo_h;
+ dim->ew_size = *nsplx * pe;
+ dim->sn_size = *nsply * pn;
+ edgeE = dim->ew_size - dim->overlap - 2 * dim->edge_v;
+ edgeN = dim->sn_size - dim->overlap - 2 * dim->edge_h;
- /* number of moving windows: E_extension / orloE */
- /* remaining steps: total steps - (floor(E_extension / orloE) * E_extension) / passoE */
- /* remaining steps must be larger than orlo_v + overlap + half of overlap window */
+ /* number of moving windows: E_extension / edgeE */
+ /* remaining steps: total steps - (floor(E_extension / edgeE) * E_extension) / passoE */
+ /* remaining steps must be larger than edge_v + overlap + half of overlap window */
total_splines = ceil(E_extension / pe);
- orlo_splines = orloE / pe;
- n_windows = floor(E_extension / orloE); /* without last one */
+ edge_splines = edgeE / pe;
+ n_windows = floor(E_extension / edgeE); /* without last one */
if (n_windows > 0) {
- minsplines = ceil((double)(dim->latoE / 2.0 - dim->orlo_v - dim->overlap) / pe);
- while (total_splines - orlo_splines * n_windows < minsplines) {
+ minsplines = ceil((double)(dim->ew_size / 2.0 - dim->edge_v - dim->overlap) / pe);
+ while (total_splines - edge_splines * n_windows < minsplines) {
*nsplx -= 1;
if (ret == 0)
ret = 1;
- while (total_splines - orlo_splines * n_windows < minsplines * 2 && minsplines > 30) {
+ while (total_splines - edge_splines * n_windows < minsplines * 2 && minsplines > 30) {
*nsplx -= 1;
if (ret == 0)
ret = 1;
total_splines = ceil(N_extension / pn);
- orlo_splines = orloN / pn;
- n_windows = floor(N_extension / orloN); /* without last one */
+ edge_splines = edgeN / pn;
+ n_windows = floor(N_extension / edgeN); /* without last one */
- minsplines = ceil((double)(dim->latoN / 2.0 - dim->orlo_h - dim->overlap) / pn);
+ minsplines = ceil((double)(dim->sn_size / 2.0 - dim->edge_h - dim->overlap) / pn);
*nsply -= 1;
if (ret < 2)
ret += 2;
*nsply -= 1;
if (ret < 2)
ret += 2;
@@ -202,20 +202,20 @@
-int P_get_orlo(int interpolator, struct Reg_dimens *dim, double pe, double pn)
+int P_get_edge(int interpolator, struct Reg_dimens *dim, double pe, double pn)
- /* Set the orlo regions dimension
+ /* Set the edge regions dimension
* Returns 1 on success of bilinear; 2 on success of bicubic, 0 on failure */
if (interpolator == P_BILINEAR) {
/* in case of edge artefacts, increase as multiples of 3 */
- dim->orlo_v = 9 * pe;
- dim->orlo_h = 9 * pn;
+ dim->edge_v = 9 * pe;
+ dim->edge_h = 9 * pn;
return 1;
else if (interpolator == P_BICUBIC) {
/* in case of edge artefacts, increase as multiples of 4 */
- dim->orlo_v = 12 * pe; /*3 */
- dim->orlo_h = 12 * pn;
+ dim->edge_v = 12 * pe; /*3 */
+ dim->edge_h = 12 * pn;
return 2;
else
@@ -571,27 +571,6 @@
return;
-#ifdef notdef
-double **P_Null_Matrix(double **matrix)
- int nrows, row, ncols, col;
- struct Cell_head Original;
- G_get_window(&Original);
- Rast_set_window(&Original);
- nrows = Rast_window_rows();
- ncols = Rast_window_cols();
- for (row = 0; row < nrows; row++) {
- for (col = 0; col < ncols; col++) {
- matrix[row][col] = NULL;
-#endif
/*! DEFINITION OF THE SUBZONES
5: inside Overlap region
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -32,7 +32,7 @@
struct Map_info *Terrain, struct Cell_head *Elaboration,
struct bound_box General, struct bound_box Overlap,
double **obs, struct lidar_cat *lcat, double *param,
- int *line_num, double passoN, double passoE,
+ int *line_num, double stepN, double stepE,
double overlap, double HighThresh, double LowThresh,
int nsplx, int nsply, int num_points,
dbDriver * driver, double mean, char *tab_name)
@@ -58,7 +58,7 @@
if (Vect_point_in_box(obs[i][0], obs[i][1], mean, &General)) {
interpolation =
- dataInterpolateBilin(obs[i][0], obs[i][1], passoE, passoN,
+ dataInterpolateBilin(obs[i][0], obs[i][1], stepE, stepN,
nsplx, nsply, Elaboration->west,
Elaboration->south, param);
interpolation += mean;
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -41,9 +41,9 @@
const char *dvr, *db, *mapset;
char table_name[GNAME_MAX];
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- double lambda, ew_resol, ns_resol, mean, passoN, passoE, HighThresh,
+ double lambda, ew_resol, ns_resol, mean, stepN, stepE, HighThresh,
LowThresh;
- double N_extension, E_extension, orloE, orloN;
+ double N_extension, E_extension, edgeE, edgeN;
int i, nterrain, count_terrain;
@@ -54,8 +54,8 @@
double **N, **obsVect, **obsVect_all; /* Interpolation and least-square matrix */
struct Map_info In, Out, Terrain;
- struct Option *in_opt, *out_opt, *out_terrain_opt, *passoE_opt,
- *passoN_opt, *lambda_f_opt, *Thresh_A_opt, *Thresh_B_opt;
+ struct Option *in_opt, *out_opt, *out_terrain_opt, *stepE_opt,
+ *stepN_opt, *lambda_f_opt, *Thresh_A_opt, *Thresh_B_opt;
struct Flag *spline_step_flag;
struct GModule *module;
@@ -98,20 +98,20 @@
out_terrain_opt->description =
_("Only 'terrain' points output vector map");
- passoE_opt = G_define_option();
- passoE_opt->key = "sce";
- passoE_opt->type = TYPE_DOUBLE;
- passoE_opt->required = NO;
- passoE_opt->answer = "25";
- passoE_opt->description =
+ stepE_opt = G_define_option();
+ stepE_opt->key = "sce";
+ stepE_opt->type = TYPE_DOUBLE;
+ stepE_opt->required = NO;
+ stepE_opt->answer = "25";
+ stepE_opt->description =
_("Interpolation spline step value in east direction");
- passoN_opt = G_define_option();
- passoN_opt->key = "scn";
- passoN_opt->type = TYPE_DOUBLE;
- passoN_opt->required = NO;
- passoN_opt->answer = "25";
- passoN_opt->description =
+ stepN_opt = G_define_option();
+ stepN_opt->key = "scn";
+ stepN_opt->type = TYPE_DOUBLE;
+ stepN_opt->required = NO;
+ stepN_opt->answer = "25";
+ stepN_opt->description =
_("Interpolation spline step value in north direction");
lambda_f_opt = G_define_option();
@@ -144,8 +144,8 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- passoN = atof(passoN_opt->answer);
- passoE = atof(passoE_opt->answer);
+ stepN = atof(stepN_opt->answer);
+ stepE = atof(stepE_opt->answer);
lambda = atof(lambda_f_opt->answer);
HighThresh = atof(Thresh_A_opt->answer);
LowThresh = atof(Thresh_B_opt->answer);
@@ -262,7 +262,7 @@
| Each original region will be divided into several subregions.
| Each one will be overlaped by its neighbouring subregions.
| The overlapping is calculated as a fixed OVERLAP_SIZE times
- | the largest spline step plus 2 * orlo
+ | the largest spline step plus 2 * edge
/* Fixing parameters of the elaboration region */
@@ -270,25 +270,25 @@
nsplx_adj = NSPLX_MAX;
nsply_adj = NSPLY_MAX;
- if (passoN > passoE)
- dims.overlap = OVERLAP_SIZE * passoN;
+ if (stepN > stepE)
+ dims.overlap = OVERLAP_SIZE * stepN;
else
- dims.overlap = OVERLAP_SIZE * passoE;
- P_get_orlo(P_BILINEAR, &dims, passoE, passoN);
- P_set_dim(&dims, passoE, passoN, &nsplx_adj, &nsply_adj);
+ dims.overlap = OVERLAP_SIZE * stepE;
+ P_get_edge(P_BILINEAR, &dims, stepE, stepN);
+ P_set_dim(&dims, stepE, stepN, &nsplx_adj, &nsply_adj);
G_verbose_message(_("adjusted EW splines %d"), nsplx_adj);
G_verbose_message(_("adjusted NS splines %d"), nsply_adj);
/* calculate number of subregions */
- orloE = dims.latoE - dims.overlap - 2 * dims.orlo_v;
- orloN = dims.latoN - dims.overlap - 2 * dims.orlo_h;
+ edgeE = dims.ew_size - dims.overlap - 2 * dims.edge_v;
+ edgeN = dims.sn_size - dims.overlap - 2 * dims.edge_h;
N_extension = original_reg.north - original_reg.south;
E_extension = original_reg.east - original_reg.west;
- nsubregion_col = ceil(E_extension / orloE) + 0.5;
- nsubregion_row = ceil(N_extension / orloN) + 0.5;
+ nsubregion_col = ceil(E_extension / edgeE) + 0.5;
+ nsubregion_row = ceil(N_extension / edgeN) + 0.5;
if (nsubregion_col < 0)
nsubregion_col = 0;
@@ -318,7 +318,7 @@
nsply =
ceil((elaboration_reg.north -
- elaboration_reg.south) / passoN) + 0.5;
+ elaboration_reg.south) / stepN) + 0.5;
if (nsply > NSPLY_MAX) {
nsply = NSPLY_MAX;
@@ -350,7 +350,7 @@
nsplx =
- ceil((elaboration_reg.east - elaboration_reg.west) / passoE) +
+ ceil((elaboration_reg.east - elaboration_reg.west) / stepE) +
0.5;
if (nsplx > NSPLX_MAX) {
@@ -403,12 +403,12 @@
G_free(observ);
G_verbose_message(_("Bilinear interpolation"));
- normalDefBilin(N, TN, Q, obsVect, passoE, passoN, nsplx,
+ normalDefBilin(N, TN, Q, obsVect, stepE, stepN, nsplx,
nsply, elaboration_reg.west,
elaboration_reg.south, nterrain, nparameters,
BW);
- nCorrectGrad(N, lambda, nsplx, nsply, passoE, passoN);
- tcholSolve(N, TN, parVect, nparameters, BW);
+ nCorrectGrad(N, lambda, nsplx, nsply, stepE, stepN);
+ G_math_solver_cholesky_sband(N, parVect, TN, nparameters, BW);
G_free_matrix(N);
G_free_vector(TN);
@@ -418,7 +418,7 @@
G_verbose_message( _("Correction and creation of terrain vector"));
P_Sparse_Correction(&In, &Out, &Terrain, &elaboration_reg,
general_box, overlap_box, obsVect_all, lcat,
- parVect, lineVect, passoN, passoE,
+ parVect, lineVect, stepN, stepE,
dims.overlap, HighThresh, LowThresh,
nsplx, nsply, npoints, driver, mean, table_name);
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -45,7 +45,7 @@
int c1, c2;
double g[9][2], gradient[2], gradPto, dirPto;
- extern double passoE, passoN;
+ extern double stepE, stepN;
static struct Cell_head Elaboration;
g[0][0] = partial[0];
@@ -62,13 +62,13 @@
else if ((gradPto > gradLow) && (residual > 0)) { /* Soft condition for 'edge' points */
if (Vect_point_in_box(obsX, obsY, 0.0, &Overlap_Box)) {
- Get_Gradient(Elaboration, obsX + passoE * cos(dirPto),
- obsY + passoN * sin(dirPto), parBilin, gradient);
+ Get_Gradient(Elaboration, obsX + stepE * cos(dirPto),
+ obsY + stepN * sin(dirPto), parBilin, gradient);
g[2][0] = gradient[0];
g[2][1] = gradient[1];
- Get_Gradient(Elaboration, obsX + passoE * cos(dirPto + M_PI),
- obsY + passoN * sin(dirPto + M_PI), parBilin, gradient);
+ Get_Gradient(Elaboration, obsX + stepE * cos(dirPto + M_PI),
+ obsY + stepN * sin(dirPto + M_PI), parBilin, gradient);
g[7][0] = gradient[0];
g[7][1] = gradient[1];
@@ -76,43 +76,43 @@
(fabs(atan(g[7][1] / g[7][0]) + M_PI / 2 - dirPto) < alpha)) {
- obsX + passoE * cos(dirPto + M_PI / 4),
- obsY + passoN * sin(dirPto + M_PI / 4),
+ obsX + stepE * cos(dirPto + M_PI / 4),
+ obsY + stepN * sin(dirPto + M_PI / 4),
g[1][0] = gradient[0];
g[1][1] = gradient[1];
- obsX + passoE * cos(dirPto - M_PI / 4),
- obsY + passoN * sin(dirPto - M_PI / 4),
+ obsX + stepE * cos(dirPto - M_PI / 4),
+ obsY + stepN * sin(dirPto - M_PI / 4),
g[3][0] = gradient[0];
g[3][1] = gradient[1];
- obsX + passoE * cos(dirPto + M_PI / 2),
- obsY + passoN * sin(dirPto + M_PI / 2),
+ obsX + stepE * cos(dirPto + M_PI / 2),
+ obsY + stepN * sin(dirPto + M_PI / 2),
g[4][0] = gradient[0];
g[4][1] = gradient[1];
- obsX + passoE * cos(dirPto - M_PI / 2),
- obsY + passoN * sin(dirPto - M_PI / 2),
+ obsX + stepE * cos(dirPto - M_PI / 2),
+ obsY + stepN * sin(dirPto - M_PI / 2),
g[5][0] = gradient[0];
g[5][1] = gradient[1];
- obsX + passoE * cos(dirPto + M_PI * 3 / 4),
- obsY + passoN * sin(dirPto + M_PI * 3 / 4),
+ obsX + stepE * cos(dirPto + M_PI * 3 / 4),
+ obsY + stepN * sin(dirPto + M_PI * 3 / 4),
g[6][0] = gradient[0];
g[6][1] = gradient[1];
- obsX + passoE * cos(dirPto - M_PI * 3 / 4),
- obsY + passoN * sin(dirPto - M_PI * 3 / 4),
+ obsX + stepE * cos(dirPto - M_PI * 3 / 4),
+ obsY + stepN * sin(dirPto - M_PI * 3 / 4),
g[8][0] = gradient[0];
g[8][1] = gradient[1];
@@ -145,13 +145,13 @@
double csi, eta, d, b, a, c;
extern int nsply;
- extern double passoN, passoE;
+ extern double stepN, stepE;
- row = (int)((Y - Elaboration.south) / passoN);
- col = (int)((X - Elaboration.west) / passoE);
+ row = (int)((Y - Elaboration.south) / stepN);
+ col = (int)((X - Elaboration.west) / stepE);
N = nsply * col + row;
- eta = X - (Elaboration.west + (col * passoE));
- csi = Y - (Elaboration.south + (row * passoN));
+ eta = X - (Elaboration.west + (col * stepE));
+ csi = Y - (Elaboration.south + (row * stepN));
d = parVect[N];
b = parVect[N + 1] - d;
a = parVect[N + nsply] - d;
@@ -172,7 +172,7 @@
double interpolation, weight, residual, eta, csi, gradient[2];
extern int nsplx, nsply, line_out_counter;
struct line_pnts *point;
struct line_cats *categories;
@@ -190,7 +190,7 @@
interpolation =
- dataInterpolateBicubic(obs[i][0], obs[i][1], passoE, passoN,
+ dataInterpolateBicubic(obs[i][0], obs[i][1], stepE, stepN,
nsplx, nsply, Elaboration.west,
Elaboration.south, parBicub);
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -35,7 +35,7 @@
#include "edgedetection.h"
int nsply, nsplx, line_out_counter;
-double passoN, passoE;
+double stepN, stepE;
@@ -44,7 +44,7 @@
/* Variables' declarations */
int nsplx_adj, nsply_adj;
int nsubregion_col, nsubregion_row, subregion = 0, nsubregions = 0;
int dim_vect, nparameters, BW, npoints;
double lambda_B, lambda_F, grad_H, grad_L, alpha, mean;
@@ -59,7 +59,7 @@
/* Structs' declarations */
struct Map_info In, Out;
- struct Option *in_opt, *out_opt, *passoE_opt, *passoN_opt,
+ struct Option *in_opt, *out_opt, *stepE_opt, *stepN_opt,
*lambdaF_opt, *lambdaB_opt, *gradH_opt, *gradL_opt, *alfa_opt;
@@ -91,23 +91,23 @@
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
- passoE_opt->key = "see";
- passoE_opt->answer = "4";
+ stepE_opt->key = "see";
+ stepE_opt->answer = "4";
- passoE_opt->guisection = _("Settings");
+ stepE_opt->guisection = _("Settings");
- passoN_opt->key = "sen";
- passoN_opt->answer = "4";
+ stepN_opt->key = "sen";
+ stepN_opt->answer = "4";
- passoN_opt->guisection = _("Settings");
+ stepN_opt->guisection = _("Settings");
lambdaB_opt = G_define_option();
lambdaB_opt->key = "lambda_g";
@@ -160,8 +160,8 @@
exit(EXIT_FAILURE);
line_out_counter = 1;
lambda_F = atof(lambdaF_opt->answer);
lambda_B = atof(lambdaB_opt->answer);
grad_H = atof(gradH_opt->answer);
@@ -282,7 +282,7 @@
@@ -290,25 +290,25 @@
else
- P_get_orlo(P_BICUBIC, &dims, passoE, passoN);
+ P_get_edge(P_BICUBIC, &dims, stepE, stepN);
nsubregion_col = 0;
@@ -337,7 +337,7 @@
nsply =
- ceil((elaboration_reg.north - elaboration_reg.south) / passoN) +
+ ceil((elaboration_reg.north - elaboration_reg.south) / stepN) +
0.5;
@@ -370,7 +370,7 @@
nsplx =
0.5;
@@ -417,12 +417,12 @@
G_free(observ);
elaboration_reg.south, npoints, nparameters,
BW);
- nCorrectGrad(N, lambda_B, nsplx, nsply, passoE, passoN);
- tcholSolve(N, TN, parVect_bilin, nparameters, BW);
+ nCorrectGrad(N, lambda_B, nsplx, nsply, stepE, stepN);
+ G_math_solver_cholesky_sband(N, parVect_bilin, TN, nparameters, BW);
G_free_matrix(N);
for (tn = 0; tn < nparameters; tn++)
@@ -434,12 +434,12 @@
parVect_bicub = G_alloc_vector(nparameters); /* Bicubic parameters vector */
G_verbose_message(_("Bicubic interpolation"));
- normalDefBicubic(N, TN, Q, obsVect, passoE, passoN, nsplx,
+ normalDefBicubic(N, TN, Q, obsVect, stepE, stepN, nsplx,
BW);
- nCorrectLapl(N, lambda_F, nsplx, nsply, passoE, passoN);
- tcholSolve(N, TN, parVect_bicub, nparameters, BW);
+ nCorrectLapl(N, lambda_F, nsplx, nsply, stepE, stepN);
+ G_math_solver_cholesky_sband(N, parVect_bicub, TN, nparameters, BW);
G_free_matrix(N);
G_free_vector(TN);
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -32,7 +32,7 @@
#include "growing.h"
/* GLOBAL DEFINITIONS */
int nsply, nsplx, count_obj;
int main(int argc, char *argv[])
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.outlier/main.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -30,7 +30,7 @@
#include "outlier.h"
/* GLOBAL VARIABLES DEFINITIONS */
int nsply, nsplx;
-double passoN, passoE, Thres_Outlier;
+double stepN, stepE, Thres_Outlier;
@@ -39,7 +39,7 @@
int nsubregion_col, nsubregion_row;
int subregion = 0, nsubregions = 0;
double mean, lambda;
@@ -54,8 +54,8 @@
struct Map_info In, Out, Outlier, Qgis;
- struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *passoE_opt,
- *passoN_opt, *lambda_f_opt, *Thres_O_opt;
+ struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *stepE_opt,
+ *stepN_opt, *lambda_f_opt, *Thres_O_opt;
@@ -100,20 +100,20 @@
qgis_opt->gisprompt = "new,vector,vector";
qgis_opt->description = _("Name of vector map for visualization in QGIS");
- passoE_opt->key = "soe";
- passoE_opt->answer = "10";
+ stepE_opt->key = "soe";
+ stepE_opt->answer = "10";
- passoN_opt->key = "son";
- passoN_opt->answer = "10";
+ stepN_opt->key = "son";
+ stepN_opt->answer = "10";
@@ -142,8 +142,8 @@
if (!(dvr = G__getenv2("DB_DRIVER", G_VAR_MAPSET)))
G_fatal_error(_("Unable to read name of driver"));
Thres_Outlier = atof(Thres_O_opt->answer);
@@ -259,7 +259,7 @@
@@ -267,25 +267,25 @@
else
nsubregion_col = 0;
@@ -314,7 +314,7 @@
nsply =
0.5;
@@ -347,7 +347,7 @@
nsplx =
0.5;
@@ -392,12 +392,12 @@
G_free(observ);
BW);
G_free_matrix(N);
G_free_vector(TN);
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -20,7 +20,7 @@
int i;
double interpolation, weight, residual, eta, csi;
extern int nsplx, nsply;
@@ -36,7 +36,7 @@
interpolation =
Elaboration.south, parBilin);
@@ -123,7 +123,6 @@
else {
Vect_write_line(Outlier, GV_POINT, point,
categories);
- G_message("here we are");
else if ((*point->y < Overlap.S) && (*point->y > General.S)) { /*(2) */
Modified: grass/trunk/vector/lidar/v.outlier/v.outlier.html
--- grass/trunk/vector/lidar/v.outlier/v.outlier.html 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.outlier/v.outlier.html 2010-04-30 15:36:04 UTC (rev 42065)
@@ -32,6 +32,13 @@
an output vector available for visualizaton in QGIS
(<a href="http://www.qgis.org">http://www.qgis.org</a>).
+<h4>North carolina location example</h4>
+<div class="code"><pre>
+v.outlier --o --v input=elev_lid792_bepts at PERMANENT output=elev_lid792_bepts_nooutliers outlier=elev_lid792_bepts_outliers soe=5 son=5 thres_o=0.1
+</pre></div>
<h2>NOTES</h2>
This module is designed to work with LIDAR data, so not topology is
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -47,7 +47,7 @@
int bilin = TRUE; /*booleans */
int nsplx, nsply, nparam_spl, ndata;
- double *mean, *rms, *stdev, rms_min, stdev_min;
+ double *mean, *rms, *stdev;
/* double lambda[PARAM_LAMBDA] = { 0.0001, 0.001, 0.01, 0.1, 1.0, 10.0 }; */ /* Fixed values (by the moment) */
double lambda[PARAM_LAMBDA] = { 0.01, 0.05, 0.1, 0.2, 0.3, 0.4 }; /* Fixed values (by the moment) */
@@ -94,7 +94,7 @@
if (ndata > 0) { /* If at least one point is in the region */
int i, j, lbd; /* lbd: lambda index */
- int BW, lbd_min; /* lbd_min: index where minimun is found */
+ int BW;
double mean_reg, *obs_mean;
int nrec, ctype = 0;
@@ -172,7 +172,7 @@
How cross correlation algorithm is done:
For each cicle, only the first ndata-1 "observ" elements are considered for the
- interpolation. Within every interpolation mean is calculated to lowering border
+ interpolation. Within every interpolation mean is calculated to lowering edge
errors. The point let out will be used for an estimation. The error between the
estimation and the observation is recorded for further statistics.
At the end of the cicle, the last point, that is, the ndata-1 index, and the point
@@ -257,7 +257,7 @@
if (bilin) interpolation (&interp, P_BILINEAR);
else interpolation (&interp, P_BICUBIC);
- tcholSolve(N, TN, parVect, nparam_spl, BW);
+ G_math_solver_cholesky_sband(N, parVect, TN, nparam_spl, BW);
/* Estimation of j-point */
if (bilin)
@@ -335,23 +335,23 @@
if (bilin == P_BILINEAR) { /* Bilinear interpolation */
normalDefBilin(interp->N, interp->TN, interp->Q, interp->obsVect,
- interp->passoE, interp->passoN, interp->nsplx,
+ interp->stepE, interp->stepN, interp->nsplx,
interp->nsply, interp->region.west,
interp->region.south, interp->ndata,
interp->nparam_spl, interp->BW);
nCorrectGrad(interp->N, interp->lambda[lbd], interp->nsplx,
- interp->nsply, interp->passoE, interp->passoN);
+ interp->nsply, interp->stepE, interp->stepN);
else { /* Bicubic interpolation */
normalDefBicubic(interp->N, interp->TN, interp->Q, interp->obsVect,
return TRUE;
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2010-04-30 15:36:04 UTC (rev 42065)
@@ -43,8 +43,8 @@
int nsubregion_col, nsubregion_row, subregion_row, subregion_col;
int last_row, last_column, grid, bilin, ext, flag_auxiliar, cross; /* booleans */
- double passoN, passoE, lambda, mean;
+ double stepN, stepE, lambda, mean;
const char *mapset, *dvr, *db, *vector, *map;
char table_name[GNAME_MAX], title[64];
@@ -62,8 +62,8 @@
struct History history;
- struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *passoE_opt,
- *passoN_opt, *lambda_f_opt, *type_opt, *dfield_opt, *col_opt;
+ struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *stepE_opt,
+ *stepN_opt, *lambda_f_opt, *type_opt, *dfield_opt, *col_opt;
struct Flag *cross_corr_flag, *spline_step_flag, *withz_flag;
struct Reg_dimens dims;
@@ -120,23 +120,23 @@
out_map_opt->key = "raster";
out_map_opt->required = NO;
- passoE_opt->key = "sie";
+ stepE_opt->key = "sie";
_("Length of each spline step in the east-west direction");
- passoN_opt->key = "sin";
+ stepN_opt->key = "sin";
_("Length of each spline step in the north-south direction");
type_opt = G_define_option();
type_opt->key = "method";
@@ -186,8 +186,8 @@
else
bilin = P_BICUBIC;
flag_auxiliar = FALSE;
@@ -259,7 +259,7 @@
/* Cross-correlation begins */
if (cross_corr_flag->answer) {
G_debug(1, "CrossCorrelation()");
- cross = cross_correlation(&In, passoE, passoN);
+ cross = cross_correlation(&In, stepE, stepN);
if (cross != TRUE)
G_fatal_error(_("Cross validation didn't finish correctly"));
@@ -268,7 +268,7 @@
Vect_close(&In);
- G_done_msg(_("Cross validation finished for sie = %f and sin = %f"), passoE, passoN);
+ G_done_msg(_("Cross validation finished for sie = %f and sin = %f"), stepE, stepN);
exit(EXIT_SUCCESS);
@@ -406,7 +406,7 @@
@@ -414,25 +414,25 @@
else
- P_get_orlo(bilin, &dims, passoE, passoN);
+ P_get_edge(bilin, &dims, stepE, stepN);
nsubregion_col = 0;
@@ -470,7 +470,7 @@
nsply =
G_debug(1, "Interpolation: nsply = %d", nsply);
@@ -505,7 +505,7 @@
nsplx =
- elaboration_reg.west) / passoE) + 0.5;
+ elaboration_reg.west) / stepE) + 0.5;
G_debug(1, "Interpolation: nsplx = %d", nsplx);
@@ -601,25 +601,25 @@
G_debug(1,
"Interpolation: (%d,%d): Bilinear interpolation...",
subregion_row, subregion_col);
nparameters, BW);
else {
G_debug(1,
"Interpolation: (%d,%d): Bicubic interpolation...",
nparameters, BW);
G_free_matrix(N);
G_free_vector(TN);
@@ -631,7 +631,7 @@
raster_matrix =
P_Regular_Points(&elaboration_reg, general_box,
overlap_box, raster_matrix, parVect,
- passoN, passoE, dims.overlap, mean,
+ stepN, stepE, dims.overlap, mean,
nsplx, nsply, nrows, ncols, bilin);
else { /* OBSERVATION POINTS INTERPOLATION */
@@ -640,7 +640,7 @@
P_Sparse_Points(&Out, &elaboration_reg, general_box,
overlap_box, obsVect, parVect,
- lineVect, passoE, passoN,
+ lineVect, stepE, stepN,
dims.overlap, nsplx, nsply, npoints,
bilin, Cats, driver, mean,
table_name);
@@ -672,7 +672,7 @@
overlap_box, obsVect_ext, parVect,
- lineVect_ext, passoE, passoN,
+ lineVect_ext, stepE, stepN,
npoints_ext, bilin, Cats, driver,
mean, table_name);
Modified: grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html
--- grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html 2010-04-30 11:10:53 UTC (rev 42064)
+++ grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html 2010-04-30 15:36:04 UTC (rev 42065)
@@ -128,6 +128,12 @@
The interpolation will be done using the values in attrib_column, in the
table associated with layer 1.
+<h4>North carolina location example using Z-coordinates for interpolation</h4>
+v.surf.bspline --o --v input=elev_lid792_bepts at PERMANENT raster=elev_lid792_rast sie=5 sin=5 method=bicubic lambda_i=0.1 -z
+</pre></div>
<h2>BUGS</h2>
Known issues:
<p>
