[GRASS-SVN] r43170 - in grass-addons/vector: . v.in.redwg
svn_grass at osgeo.org
Fri Aug 20 18:32:09 EDT 2010
Author: pitanga
Date: 2010-08-20 22:32:09 +0000 (Fri, 20 Aug 2010)
New Revision: 43170
Added:
grass-addons/vector/v.in.redwg/
grass-addons/vector/v.in.redwg/Makefile
grass-addons/vector/v.in.redwg/README
grass-addons/vector/v.in.redwg/entity.c
grass-addons/vector/v.in.redwg/global.h
grass-addons/vector/v.in.redwg/main.c
grass-addons/vector/v.in.redwg/v.in.redwg.html
Initial commit of v.in.redwg - DWG import with no need of proprietary library (could be shipped with GRASS in the future)
Added: grass-addons/vector/v.in.redwg/Makefile
--- grass-addons/vector/v.in.redwg/Makefile (rev 0)
+++ grass-addons/vector/v.in.redwg/Makefile 2010-08-20 22:32:09 UTC (rev 43170)
@@ -0,0 +1,20 @@
+MODULE_TOPDIR = ../..
+PGM=v.in.redwg
+## hard coded
+LIBREDWGLIB=-lredwg
+#LIBREDWGLIBPATH=/usr/local/lib
+#LIBREDWGINCPATH=/usr/local/include/dwg.h
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(LIBREDWGLIBPATH) $(LIBREDWGLIB)
+EXTRA_INC = $(VECT_INC) $(LIBREDWGINCPATH)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+#ifneq ($(USE_LIBREDWG),)
+default: cmd
+#endif
Added: grass-addons/vector/v.in.redwg/README
--- grass-addons/vector/v.in.redwg/README (rev 0)
+++ grass-addons/vector/v.in.redwg/README 2010-08-20 22:32:09 UTC (rev 43170)
@@ -0,0 +1,12 @@
+v.in.redwg requires GNU LibreDWG. To get this library go to
+http://gnu.org/s/libredwg (no official release yet, you need to check out the
+source code and compile).
+Warning: some trick might be needed to build it since I created the Makefile
+while attached to the main grass tree (svn trunk). I did not try to build it
+after committing to the GRASS-Addons-svn, but I will try to fix it and clean up
+the code soon.
+Not to mention that this is still in alpha stage, as LibreDWG, although I
+managed to get some concrete results. Not all entity types are supported
+(warning printed).
Added: grass-addons/vector/v.in.redwg/entity.c
--- grass-addons/vector/v.in.redwg/entity.c (rev 0)
+++ grass-addons/vector/v.in.redwg/entity.c 2010-08-20 22:32:09 UTC (rev 43170)
@@ -0,0 +1,534 @@
+ * MODULE: v.in.redwg
+ * AUTHOR(S): Rodrigo Rodrigues da Silva
+ * based on original code by Radim Blazek
+ * PURPOSE: Import of DWG files (using free software lib)
+ * COPYRIGHT: (C) 2001, 2010 by the GRASS Development Team
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
+ * Unsupported entities must be added in write_entity()
+ * TODO: 3rd dimension is not functional for CIRCLE and ARC
+ * -> required updated of transformation in INSERT
+ * (how to do that??)
+#define AD_PROTOTYPES
+#define AD_VM_PC
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/vector.h>
+#include <dwg.h>
+#include "global.h"
+#define exampleprintf printf
+#define LOCPI M_PI
+char buf[1000];
+char buf2[1000];
+void getEntTypeName(Dwg_Object *obj, char *name)
+ switch (obj->type)
+ case DWG_TYPE_LINE:
+ strcpy(name, "LINE");
+ break;
+ case DWG_TYPE_POINT:
+ strcpy(name, "POINT");
+ break;
+ case DWG_TYPE_CIRCLE:
+ strcpy(name, "CIRCLE");
+ break;
+ case DWG_TYPE_SHAPE:
+ strcpy(name, "SHAPE");
+ break;
+ case DWG_TYPE_ELLIPSE:
+ strcpy(name, "ELLIPSE");
+ break;
+ case DWG_TYPE_SPLINE:
+ strcpy(name, "SPLINE");
+ break;
+ case DWG_TYPE_TEXT:
+ strcpy(name, "TEXT");
+ break;
+ case DWG_TYPE_ARC:
+ strcpy(name, "ARC");
+ break;
+ case DWG_TYPE_TRACE:
+ strcpy(name, "TRACE");
+ break;
+ case DWG_TYPE_SOLID:
+ strcpy(name, "SOLID");
+ break;
+ case DWG_TYPE_BLOCK:
+ strcpy(name, "BLOCK");
+ break;
+ case DWG_TYPE_ENDBLK:
+ strcpy(name, "ENDBLK");
+ break;
+ case DWG_TYPE_INSERT:
+ strcpy(name, "INSERT");
+ break;
+ case DWG_TYPE_ATTDEF:
+ strcpy(name, "ATTDEF");
+ break;
+ case DWG_TYPE_ATTRIB:
+ strcpy(name, "ATTRIB");
+ break;
+ case DWG_TYPE_SEQEND:
+ strcpy(name, "SEQEND");
+ break;
+ case DWG_TYPE_POLYLINE_2D:
+ case DWG_TYPE_POLYLINE_3D:
+ strcpy(name, "POLYLINE");
+ break;
+ case DWG_TYPE_VERTEX_2D:
+ case DWG_TYPE_VERTEX_3D:
+ case DWG_TYPE_VERTEX_MESH:
+ case DWG_TYPE_VERTEX_PFACE:
+ case DWG_TYPE_VERTEX_PFACE_FACE:
+ strcpy(name, "VERTEX");
+ break;
+ case AD_ENT_LINE3D:
+ strcpy(name, "3DLINE");
+ break;
+ case AD_ENT_FACE3D:
+ strcpy(name, "3DFACE");
+ break;
+ case DWG_TYPE_DIMENSION_ORDINATE:
+ case DWG_TYPE_DIMENSION_LINEAR:
+ case DWG_TYPE_DIMENSION_ALIGNED:
+ case DWG_TYPE_DIMENSION_ANG3PT:
+ case DWG_TYPE_DIMENSION_ANG2LN:
+ case DWG_TYPE_DIMENSION_RADIUS:
+ case DWG_TYPE_DIMENSION_DIAMETER:
+ strcpy(name, "DIMENSION");
+ break;
+ case DWG_TYPE_VIEWPORT:
+ strcpy(name, "VIEWPORT");
+ break;
+ case DWG_TYPE_3DSOLID:
+ strcpy(name, "SOLID3D");
+ break;
+ case DWG_TYPE_RAY:
+ strcpy(name, "RAY");
+ break;
+ case DWG_TYPE_XLINE:
+ strcpy(name, "XLINE");
+ break;
+ case DWG_TYPE_MTEXT:
+ strcpy(name, "MTEXT");
+ break;
+ case DWG_TYPE_LEADER:
+ strcpy(name, "LEADER");
+ break;
+ case DWG_TYPE_TOLERANCE:
+ strcpy(name, "TOLERANCE");
+ break;
+ case DWG_TYPE_MLINE:
+ strcpy(name, "MLINE");
+ break;
+ case DWG_TYPE_BODY:
+ strcpy(name, "BODY");
+ break;
+ case DWG_TYPE_REGION:
+ strcpy(name, "REGION");
+ break;
+ default:
+ strcpy(name, "UNKNOWN");
+ if (adenhd->enttype == adOle2frameEnttype(dwghandle))
+ strcpy(name, "OLE2FRAME");
+ else if (adenhd->enttype == adLwplineEnttype(dwghandle))
+ strcpy(name, "LWPOLYLINE");
+ else if (adenhd->enttype == adHatchEnttype(dwghandle))
+ strcpy(name, "HATCH");
+ else if (adenhd->enttype == adImageEnttype(dwghandle))
+ strcpy(name, "IMAGE");
+ else if (adenhd->enttype == adArcAlignedTextEnttype(dwghandle))
+ strcpy(name, "ArcAlignedText");
+ else if (adenhd->enttype == adWipeoutEnttype(dwghandle))
+ strcpy(name, "Wipeout");
+ else if (adenhd->enttype == adRtextEnttype(dwghandle))
+ strcpy(name, "Rtext");
+ else {
+ G_debug(3, "adenhd->enttype: %d", adenhd->enttype);
+ strcpy(name, "Proxy");
+ break;
+int write_line(Dwg_Object * obj, int type, int level)
+ int i, l;
+ double x, y, z, r, ang;
+ adSeekLayer(dwghandle, obj->entlayerobjhandle, Layer);
+ /* Transformation, go up through all levels of transformation */
+ /* not sure what is the right order of transformation */
+ for (l = level; l >= 0; l--) {
+ for (i = 0; i < Points->n_points; i++) {
+ /* scale */
+ x = Points->x[i] * Trans[l].xscale;
+ y = Points->y[i] * Trans[l].yscale;
+ z = Points->z[i] * Trans[l].zscale;
+ /* rotate */
+ r = sqrt(x * x + y * y);
+ ang = atan2(y, x) + Trans[l].rotang;
+ x = r * cos(ang);
+ y = r * sin(ang);
+ /* move */
+ x += Trans[l].dx;
+ y += Trans[l].dy;
+ z += Trans[l].dz;
+ Points->x[i] = x;
+ Points->y[i] = y;
+ Points->z[i] = z;
+ Vect_reset_cats(Cats);
+ Vect_cat_set(Cats, 1, cat);
+ Vect_write_line(&Map, type, Points, Cats);
+ /* Cat */
+ sprintf(buf, "insert into %s values ( %d", Fi->table, cat);
+ db_set_string(&sql, buf);
+ /* Entity name */
+ getEntTypeName(obj, buf2);
+ sprintf(buf, ", '%s'", buf2);
+ db_append_string(&sql, buf);
+ /* Color */
+ sprintf(buf, ", %lu", obj->tio.entity->color.rgb);
+ /* Weight */
+ sprintf(buf, ", %d", obj->tio.entity->lineweight);
+ /* Layer name */
+ /*!Layer->purgedflag && */
+ printf("This should be a layer: " );
+ Dwg_Object * should_be_layer = obj->tio.entity->layer->obj;
+ Dwg_Object_LAYER * layer;
+ unsigned int _type = should_be_layer->type;
+ //dwg_print_object(should_be_layer);
+ printf("type = %u ", _type);
+ if (_type == 51)
+ layer = obj->tio.entity->layer->obj->tio.object->tio.LAYER;
+ printf ("IS A LAYER! name = %s", layer->entry_name);
+ else printf("NOT A LAYER!");
+ printf("\n");
+ if (layer) {
+ if (layer->entry_name) {
+ db_set_string(&str, layer->entry_name);
+ db_double_quote_string(&str);
+ sprintf(buf, ", '%s'", db_get_string(&str));
+ else {
+ sprintf(buf, ", ''");
+ /* Block name */
+ if (Block != NULL) {
+ db_set_string(&str, Block);
+ else {
+ db_set_string(&str, "");
+ /* Text */
+ if (Txt != NULL) {
+ db_set_string(&str, Txt);
+ else {
+ db_append_string(&sql, ")");
+ G_debug(3, db_get_string(&sql));
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ G_fatal_error("Cannot insert new row: %s", db_get_string(&sql));
+ cat++;
+ return 0;
+/* Returns 1 if element has geometry and may be written to vector */
+int is_low_level(Dwg_Object *obj)
+ if (obj->type == DWG_TYPE_BLOCK || obj->type == DWG_TYPE_ENDBLK ||
+ obj->type == DWG_TYPE_SEQEND || obj->type == DWG_TYPE_INSERT)
+ return 0;
+ return 1;
+void write_entity(Dwg_Object *obj, Dwg_Object ** objects,
+ long unsigned int *ent_counter, int level)
+ double x, y, z, ang;
+ int i;
+ /* DWG entity pointers */
+ Dwg_Entity_LINE *line;
+ Dwg_Entity__3DFACE *face3d;
+ Dwg_Entity_SOLID *solid;
+ Dwg_Entity_TEXT *text;
+ Dwg_Entity_POINT *point;
+ Dwg_Entity_ARC *arc;
+ Dwg_Entity_CIRCLE *circle;
+ Dwg_Entity_BLOCK *block;
+ Dwg_Entity_INSERT *insert;
+ Dwg_Object *_obj;
+ Dwg_Object_Object *_obj_obj;
+ Dwg_Object_BLOCK_HEADER *blockhdr;
+ *ent_counter += 1;
+ if (is_low_level(obj))
+ n_elements++;
+ getEntTypeName(obj, buf);
+ G_debug(1, "Entity: %s", buf);
+ fprintf(stdout, "Entity: %s %u\n", buf, obj->type);
+ Txt = NULL;
+ Vect_reset_line(Points);
+ /* Check space for lower level */
+ if (level + 1 == atrans) {
+ atrans += 10;
+ Trans = (TRANS *) G_realloc(Trans, atrans * sizeof(TRANS));
+ switch (obj->type) {
+ line = obj->tio.entity->tio.LINE;
+ Vect_append_point(Points, line->start.x, line->start.y,
+ line->start.z);
+ Vect_append_point(Points, line->end.x, line->end.y,
+ line->end.z);
+ write_line(obj, GV_LINE, level);
+ break;
+ case DWG_TYPE__3DFACE:
+ face3d = obj->tio.entity->tio._3DFACE;
+ Vect_append_point(Points, face3d->corner1.x, face3d->corner1.y,
+ face3d->corner1.z);
+ Vect_append_point(Points, face3d->corner2.x, face3d->corner2.y,
+ face3d->corner2.z);
+ Vect_append_point(Points, face3d->corner3.x, face3d->corner3.y,
+ face3d->corner3.z);
+ Vect_append_point(Points, face3d->corner4.x, face3d->corner4.y,
+ face3d->corner4.z);
+ write_line(obj, GV_FACE, level);
+ break;
+ solid = obj->tio.entity->tio.SOLID;
+ Vect_append_point(Points, solid->corner1.x, solid->corner1.y,
+ solid->elevation);
+ Vect_append_point(Points, solid->corner2.x, solid->corner2.y,
+ Vect_append_point(Points, solid->corner3.x, solid->corner3.y,
+ Vect_append_point(Points, solid->corner4.x, solid->corner4.y,
+ break;
+ text = obj->tio.entity->tio.TEXT;
+ Txt = (char *)text->text_value;
+ Vect_append_point(Points, text->insertion_pt.x, text->insertion_pt.y,
+ 0); // insertion_poin.z ??
+ write_line(obj, GV_POINT, level);
+ break;
+ point = obj->tio.entity->tio.POINT;
+ Vect_append_point(Points, point->x, point->y,
+ point->z);
+ break;
+ arc = obj->tio.entity->tio.ARC;
+ for (ang = arc->start_angle; ang < arc->end_angle;
+ ang += 2 * LOCPI / 360) {
+ x = arc->center.x + arc->radius * cos(ang);
+ y = arc->center.y + arc->radius * sin(ang);
+ z = arc->center.z + arc->radius;
+ Vect_append_point(Points, x, y, z);
+ x = arc->center.x + arc->radius * cos(arc->end_angle);
+ y = arc->center.y + arc->radius * sin(arc->end_angle);
+ break;
+ circle = obj->tio.entity->tio.CIRCLE;
+ if (circle_flag->answer) {
+ Vect_append_point(Points, circle->center.x,
+ circle->center.y, circle->center.z);
+ else {
+ for (ang = 0; ang < 2 * LOCPI; ang += 2 * LOCPI / 360) {
+ x = circle->center.x + circle->radius * cos(ang);
+ y = circle->center.y + circle->radius * sin(ang);
+ z = circle->center.z + circle->radius;
+ Vect_append_point(Points, Points->x[0], Points->y[0],
+ Points->z[0]);
+ break;
+ /* BLOCK starts block of entities but makes no transformation - is it right ?
+ * -> do nothing just warn for xref */
+ block = obj->tio.entity->tio.BLOCK;
+ //FIXME figure out how to do it with LibreDWG
+ if (block->namexrefpath[0]) {
+ G_warning
+ ("External reference for block not supported.\n xref: %s",
+ ent->block.xrefpath);
+ Block = G_store((char*)block->name);
+ break;
+ case DWG_TYPE_ENDBLK: /* endblk - no data */
+ G_free(Block);
+ Block = NULL;
+ break;
+ case DWG_TYPE_INSERT: /* insert */
+ insert = obj->tio.entity->tio.INSERT;
+ /* get transformation */
+ /* TODO: fix rotation for CIRCLE and ARC */
+ G_debug(3, " x,y,z: %f, %f, %f", insert->ins_pt.x,
+ insert->ins_pt.y, insert->ins_pt.z);
+ G_debug(3, " xscale, yscale, zscale: %f, %f, %f", insert->scale.x,
+ insert->scale.y, insert->scale.z);
+ G_debug(3, " rotang: %f", insert->rotation_ang);
+ G_debug(3, " ncols, nrows: %d, %d", ent->insert.numcols,
+ ent->insert.numrows);
+ G_debug(3, " coldist, rowdist: %f, %f", ent->insert.coldist,
+ ent->insert.rowdist);
+ /* write block entities */
+ //FIXME how to check purgedflag?
+ if (!adblkh->purgedflag) {
+ adStartEntityGet(adblkh->entitylist);
+ printf("Handle do insert: %lu ", obj->handle.value);
+ printf("Handle do block header do insert: %lu\n", insert->block_header->absolute_ref);
+ fflush(stdout);
+ //Dwg_Object_BLOCK_HEADER *blockhdr =
+ _obj = insert->block_header->obj;
+ _obj_obj = _obj->tio.object;
+ blockhdr = _obj_obj->tio.BLOCK_HEADER;
+ if (blockhdr->entry_name[0] == ((unsigned char)'*')) //PSPACE OR MSPACE
+ printf("Skipping PSPACE or MSPACE block\n");
+ break;
+ Dwg_Object *ent = blockhdr->first_entity->obj;
+ while(42)
+ printf("Dentro do LOOP42\n");
+ if (ent->type == DWG_TYPE_ENDBLK)
+ printf("Found ENDBLK, breaking\n");
+ break;
+ else
+ Trans[level + 1].dx = insert->ins_pt.x;
+ Trans[level + 1].dy = insert->ins_pt.y;
+ Trans[level + 1].dz = insert->ins_pt.z;
+ Trans[level + 1].xscale = insert->scale.x;
+ Trans[level + 1].yscale = insert->scale.y;
+ Trans[level + 1].zscale = insert->scale.z;
+ Trans[level + 1].rotang = insert->rotation_ang;
+ printf("Writing inserted entity. Level = %d\n", level+1);
+ write_entity(ent, objects, ent_counter, level+1);
+ ent = dwg_next_object(ent);
+ if (!ent) break;
+ break;
+ case DWG_TYPE_SEQEND: /* seqend */
+ break;
+ default:
+ G_warning("%s entity not supported", buf);
+ break;
+ } /* end of switch */
Added: grass-addons/vector/v.in.redwg/global.h
--- grass-addons/vector/v.in.redwg/global.h (rev 0)
+++ grass-addons/vector/v.in.redwg/global.h 2010-08-20 22:32:09 UTC (rev 43170)
@@ -0,0 +1,50 @@
+ * MODULE: v.in.dwg
+ * PURPOSE: Import of DWG/DXF files
+ * for details.
+/* transformation, first level is 0 ( called from main ) and transformation
+ * for this level is 0,0,0, 1,1,1, 0 so that no transformation is done on first level
+ * (not efective but better readable?) */
+typedef struct
+ double dx, dy, dz;
+ double xscale, yscale, zscale;
+ double rotang;
+} TRANS;
+extern int cat;
+extern int n_elements; /* number of processed elements (only low level elements) */
+extern int n_skipped; /* number of skipped low level elements (different layer name) */
+extern struct Map_info Map;
+extern dbDriver *driver;
+extern dbString sql;
+extern dbString str;
+extern struct line_pnts *Points;
+extern struct line_cats *Cats;
+extern char *Txt;
+extern char *Block;
+extern struct field_info *Fi;
+extern TRANS *Trans; /* transformation */
+extern int atrans; /* number of allocated levels */
+extern struct Option *layers_opt;
+extern struct Flag *invert_flag, *circle_flag;
+ long unsigned int *ent_counter, int level);
+int is_low_level(Dwg_Object *obj);
Added: grass-addons/vector/v.in.redwg/main.c
--- grass-addons/vector/v.in.redwg/main.c (rev 0)
+++ grass-addons/vector/v.in.redwg/main.c 2010-08-20 22:32:09 UTC (rev 43170)
@@ -0,0 +1,299 @@
+ * AUTHOR: Rodrigo Rodrigues da Silva
+ * for details.
+#include <stdio.h>
+#include <math.h>
+#include <fcntl.h>
+#include <grass/glocale.h>
+#include <dwg.h>
+int cat;
+int n_elements; /* number of processed elements (only low level elements) */
+int n_skipped; /* number of skipped low level elements (different layer name) */
+struct Map_info Map;
+dbDriver *driver;
+dbString sql;
+dbString str;
+struct line_pnts *Points;
+struct line_cats *Cats;
+char *Txt;
+char *Block;
+struct field_info *Fi;
+TRANS *Trans; /* transformation */
+int atrans; /* number of allocated levels */
+struct Option *layers_opt;
+struct Flag *invert_flag, *circle_flag;
+int import_object(Dwg_Object * obj);
+void list_layers(Dwg_Data * dwg);
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct Option *out_opt, *in_opt;
+ struct Flag *z_flag, *l_flag, *int_flag;
+ char buf[2000];
+ long unsigned int i;
+ short initerror;
+ /* DWG */
+ Dwg_Data dwg;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("vector"));
+ G_add_keyword(_("import"));
+ module->description = _("Converts DWG to GRASS vector map");
+ in_opt = G_define_standard_option(G_OPT_F_INPUT);
+ in_opt->description = _("Name of DWG file");
+ out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ out_opt->required = YES;
+ layers_opt = G_define_option();
+ layers_opt->key = "layers";
+ layers_opt->type = TYPE_STRING;
+ layers_opt->required = NO;
+ layers_opt->multiple = YES;
+ layers_opt->description = _("List of layers to import");
+ invert_flag = G_define_flag();
+ invert_flag->key = 'i';
+ invert_flag->description =
+ _("Invert selection by layers (don't import layers in list)");
+ z_flag = G_define_flag();
+ z_flag->key = 'z';
+ z_flag->description = _("Create 3D vector map");
+ circle_flag = G_define_flag();
+ circle_flag->key = 'c';
+ circle_flag->description = _("Write circles as points (centre)");
+ l_flag = G_define_flag();
+ l_flag->key = 'l';
+ l_flag->description = _("List available layers and exit");
+ int_flag = G_define_flag();
+ int_flag->key = 'n';
+ int_flag->description = _("Use numeric type for attribute \"layer\"");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ db_init_string(&sql);
+ db_init_string(&str);
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Block = NULL;
+ atrans = 20; /* nested, recursive levels */
+ Trans = (TRANS *) G_malloc(atrans * sizeof(TRANS));
+ /* Init LibreDWG, load file */
+ initerror = dwg_read_file(in_opt->answer, &dwg);
+ if(initerror) {
+ sprintf(buf, _("Unable to initialize LibreDWG. Error: %d."),
+ initerror);
+ sprintf(buf, _("Unable to load file %s"), in_opt->answer);
+ G_fatal_error(buf);
+ //List layers (if option chosen)
+ if (l_flag->answer) {
+ list_layers(&dwg);
+ //XXX: should I really exit? maybe other options should be checked
+ exit(EXIT_SUCCESS);
+ /* open output vector */
+ Vect_open_new(&Map, out_opt->answer, z_flag->answer);
+ Vect_hist_command(&Map);
+ /* Add DB link */
+ Fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
+ Vect_map_add_dblink(&Map, 1, NULL, Fi->table, "cat", Fi->database,
+ Fi->driver);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database, &Map));
+ if (driver == NULL) {
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Vect_subst_var(Fi->database, &Map), Fi->driver);
+ db_begin_transaction(driver);
+ /* Create table */
+ if (int_flag->answer) { /* List layers */
+ sprintf(buf,
+ "create table %s ( cat integer, entity_name varchar(20), color int, weight int, "
+ "layer real, block varchar(100), txt varchar(100) )",
+ Fi->table);
+ else {
+ sprintf(buf,
+ "layer varchar(100), block varchar(100), txt varchar(100) )",
+ Fi->table);
+ G_fatal_error(_("Unable to create table: '%s'"), db_get_string(&sql));
+ if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
+ G_warning(_("Unable to create index for table <%s>, key <%s>"),
+ Fi->table, "cat");
+ if (db_grant_on_table
+ (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
+ Fi->table);
+ cat = 1;
+ n_elements = n_skipped = 0;
+ /* Write each entity. Some entities may be composed by other entities (like INSERT or BLOCK) */
+ /* Set transformation for first (index 0) level */
+ Trans[0].dx = Trans[0].dy = Trans[0].dz = 0;
+ Trans[0].xscale = Trans[0].yscale = Trans[0].zscale = 1;
+ Trans[0].rotang = 0;
+ for(i=0; i < dwg_get_object_count(&dwg); i++)
+ fprintf(stdout, "Type: %u\n", dwg.object[i].type);
+ fprintf(stdout, "%lu objects\n", dwg_get_object_count(&dwg));
+ fflush(stdout);
+ for (i = 0; i < dwg_get_object_count(&dwg); i++)
+ if (import_object(&dwg.object[i]))
+ //pass i pointer since write_entity may process more than one entity
+ write_entity(&dwg.object[i], &dwg.object, &i, 0);
+ db_commit_transaction(driver);
+ db_close_database_shutdown_driver(driver);
+ Vect_build(&Map);//, stderr);
+ Vect_close(&Map);
+ if (n_skipped > 0)
+ G_message(_("%d elements skipped (layer name was not in list)"),
+ n_skipped);
+ G_done_msg(_("%d elements processed"), n_elements);
+void
+list_layers(Dwg_Data * dwg)
+ int i;
+ long unsigned int l_count = dwg_get_layer_count(dwg);
+ G_debug(2, "%lu layers\n", l_count);
+ fprintf(stdout, "%lu layers\n", l_count);
+ Dwg_Object_LAYER **layers = dwg_get_layers(dwg);
+ for (i=0; i<l_count; i++) {
+ fprintf(stdout, "NAME: %s COLOR: %lu STATE: ", layers[i]->entry_name,
+ layers[i]->color.rgb);
+ if (layers[i]->on)
+ fprintf(stdout, "ON, ");
+ else
+ fprintf(stdout, "OFF, ");
+ if (layers[i]->frozen)
+ fprintf(stdout, "FROZEN, ");
+ else
+ fprintf(stdout, "THAWED, ");
+ if(layers[i]->locked)
+ fprintf(stdout, "LOCKED\n");
+ else
+ fprintf(stdout, "UNLOCKED\n");
+ G_free(layers);
+int
+import_object(Dwg_Object * obj)
+ if (obj->supertype != DWG_SUPERTYPE_ENTITY)
+ return 0;
+ if (layers_opt->answers)
+ Dwg_Object_LAYER * layer = dwg_get_entity_layer(obj->tio.entity);
+ int i = 0;
+ int layer_found = 0;
+ //FIXME check if layer is purged
+ if (42 /*layer->purgedflag*/)
+ while (layers_opt->answers[i])
+ if (strcmp((char*)layer->entry_name, layers_opt->answers[i]) == 0)
+ layer_found = 1;
+ break;
+ i++;
+ if ((!invert_flag->answer && !layer_found) || (invert_flag->answer
+ && layer_found))
+ n_skipped++;
+ if (obj->type != DWG_TYPE_INSERT &&
+ obj->type != DWG_TYPE_POLYLINE_2D &&
+ obj->type != DWG_TYPE_POLYLINE_3D &&
+ obj->type != DWG_TYPE_POLYLINE_MESH &&
+ obj->type != DWG_TYPE_POLYLINE_PFACE)
+ return 0;
+ return 1;
Added: grass-addons/vector/v.in.redwg/v.in.redwg.html
--- grass-addons/vector/v.in.redwg/v.in.redwg.html (rev 0)
+++ grass-addons/vector/v.in.redwg/v.in.redwg.html 2010-08-20 22:32:09 UTC (rev 43170)
@@ -0,0 +1,37 @@
+<h2>DESCRIPTION</h2>
+<em>v.in.redwg</em> imports DWG files into GRASS.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+v.in.redwg input=map.dwg output=map
+</pre></div>
+<h2>NOTES</h2>
+v.in.redwg <strong>does not require OpenDWG or any proprietary software<strong>.
+It requires <a href="http://www.gnu.org/s/libredwg">LibreDWG</a>, which
+is released under the GNU GPLv3.
+<P>
+You need to download, compile and install (check website) LibreDWG and use the
+related <tt>configure</tt> options to tell GRASS about it (warning: configure
+options not implemented yet)
+ ./configure \
+ --with-libredwg \
+ --with-libredwg-includes=/usr/include \
+</pre></div>
+Then run <i>make</i> to compile this module.
+<P>
+Not all entity types are supported (warning printed).
+<h2>AUTHOR</h2>
+Rodrigo Rodrigues da Silva (pitanga at members dot fsf dot org), São Paulo, Brazil
+<br>based on original code by Radim Blazek, ITC-Irst, Trento, Italy
+<p><i>Last changed: $Date: 2009-12-21 02:09:42 -0300 (Mon, 21 Dec 2009) $</i>
