[GRASS-SVN] r43339 - in
grass/branches/releasebranch_6_4/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun Aug 29 12:35:37 EDT 2010
Author: martinl
Date: 2010-08-29 16:35:37 +0000 (Sun, 29 Aug 2010)
New Revision: 43339
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
wxGUI: guess fully qualified map name also when param key is missing
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2010-08-29 15:28:18 UTC (rev 43338)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2010-08-29 16:35:37 UTC (rev 43339)
@@ -326,10 +326,21 @@
message=_("Command '%s' not yet implemented in the GUI. "
"Try adding it as a command layer instead.") % cmdlist[0])
return None
# add layer into layer tree
+ if cmdlist[0] == 'd.rast':
+ lname = utils.GetLayerNameFromCmd(cmdlist, fullyQualified = True,
+ layerType = 'raster')
+ elif cmdlist[0] == 'd.vect':
+ layerType = 'vector')
+ else:
+ lname = None
+ # add layer into layer tree
if self.parent.GetName() == "LayerManager":
self.parent.curr_page.maptree.AddLayer(ltype=layertype,
+ lname=lname,
lcmd=cmdlist)
else:
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2010-08-29 15:28:18 UTC (rev 43338)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2010-08-29 16:35:37 UTC (rev 43339)
@@ -78,7 +78,7 @@
@return '' if no map name found in command
mapname = ''
if len(dcmd) < 1:
return mapname
@@ -101,12 +101,15 @@
'h_map=' in dcmd[idx] or \
'reliefmap' in dcmd[idx]:
break
if idx < len(dcmd):
try:
mapname = dcmd[idx].split('=')[1]
except IndexError:
- return ''
+ if idx == 1:
+ mapname = dcmd[idx]
+ else:
+ return ''
if fullyQualified and '@' not in mapname:
if layerType in ('raster', 'vector', '3d-raster'):
@@ -124,8 +127,11 @@
mapname += '@' + grassenv.GetGRASSVariable('MAPSET')
else:
- dcmd[idx] = dcmd[idx].split('=')[0] + '=' + mapname
+ if '=' in dcmd[idx]:
+ dcmd[idx] = dcmd[idx].split('=')[0] + '=' + mapname
+ else:
+ dcmd[idx] = mapname
return mapname
def GetValidLayerName(name):
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2010-08-29 15:28:18 UTC (rev 43338)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2010-08-29 16:35:37 UTC (rev 43339)
@@ -1511,7 +1511,7 @@
if UserSettings.Get(group='manager', key='askOnRemoveLayer', subkey='enabled'):
layerName = ''
for item in self.curr_page.maptree.GetSelections():
- name = str(self.curr_page.maptree.GetItemText(item))
+ name = self.curr_page.maptree.GetItemText(item)
idx = name.find('(opacity')
if idx > -1:
layerName += '<' + name[:idx].strip(' ') + '>,\n'
