[GRASS-SVN] r43338 - in grass/trunk: lib/pngdriver visualization/wximgview
Sun Aug 29 11:28:18 EDT 2010
Author: glynn
Date: 2010-08-29 15:28:18 +0000 (Sun, 29 Aug 2010)
New Revision: 43338
   grass/trunk/lib/pngdriver/Graph_close.c
   grass/trunk/lib/pngdriver/Graph_set.c
   grass/trunk/lib/pngdriver/pngdriver.h
   grass/trunk/visualization/wximgview/main.cc
Add/fix mmap'd BMP support for Windows
Modified: grass/trunk/lib/pngdriver/Graph_close.c
--- grass/trunk/lib/pngdriver/Graph_close.c	2010-08-29 10:56:46 UTC (rev 43337)
+++ grass/trunk/lib/pngdriver/Graph_close.c	2010-08-29 15:28:18 UTC (rev 43338)
@@ -3,11 +3,13 @@
  * termination time.
-#ifndef __MINGW32__
 #include <unistd.h>
 #include <fcntl.h>
 #include <sys/types.h>
 #include <sys/stat.h>
+#ifdef __MINGW32__
+#include <windows.h>
+#else
 #include <sys/mman.h>
 #endif
@@ -16,17 +18,20 @@
 static void unmap_file(void)
     size_t size = HEADER_SIZE + png.width * png.height * sizeof(unsigned int);
     void *ptr = (char *)png.grid - HEADER_SIZE;
     if (!png.mapped)
 	return;
+#ifdef __MINGW32__
+    UnmapViewOfFile(ptr);
+    CloseHandle(png.handle);
+#else
     munmap(ptr, size);
+#endif
     png.mapped = 0;
-#endif
 void PNG_Graph_close(void)
Modified: grass/trunk/lib/pngdriver/Graph_set.c
--- grass/trunk/lib/pngdriver/Graph_set.c	2010-08-29 10:56:46 UTC (rev 43337)
+++ grass/trunk/lib/pngdriver/Graph_set.c	2010-08-29 15:28:18 UTC (rev 43338)
@@ -13,10 +13,12 @@
 #include <string.h>
 #include <stdlib.h>
 #include <unistd.h>
 #include <fcntl.h>
+#ifdef __MINGW32__
+#else
 #endif
@@ -28,7 +30,6 @@
 static void map_file(void)
     void *ptr;
     int fd;
@@ -37,9 +38,20 @@
     if (fd < 0)
 	return;
+#ifdef __MINGW32__
+    png.handle = CreateFileMapping((HANDLE) _get_osfhandle(fd),
+				   NULL, PAGE_READWRITE,
+				   0, size, NULL);
+    if (!png.handle)
+	return;
+    ptr = MapViewOfFile(png.handle, FILE_MAP_WRITE, 0, 0, size);
+    if (!ptr)
+	return;
+#else
     ptr = mmap(NULL, size, PROT_READ | PROT_WRITE, MAP_SHARED, fd, (off_t) 0);
     if (ptr == MAP_FAILED)
 	return;
+#endif
     if (png.grid)
 	G_free(png.grid);
@@ -48,7 +60,6 @@
     close(fd);
     png.mapped = 1;
-#endif
 int PNG_Graph_set(void)
Modified: grass/trunk/lib/pngdriver/pngdriver.h
--- grass/trunk/lib/pngdriver/pngdriver.h	2010-08-29 10:56:46 UTC (rev 43337)
+++ grass/trunk/lib/pngdriver/pngdriver.h	2010-08-29 15:28:18 UTC (rev 43338)
@@ -3,6 +3,10 @@
 #include <stdio.h>
+#ifdef __MINGW32__
+#endif
 #include <grass/config.h>
 #include "driver.h"
 #include "path.h"
@@ -18,6 +22,9 @@
     int true_color;
     int has_alpha;
     int mapped;
+#ifdef __MINGW32__
+    HANDLE handle;
+#endif
     double clip_top, clip_bot, clip_left, clip_rite;
     int width, height;
Modified: grass/trunk/visualization/wximgview/main.cc
--- grass/trunk/visualization/wximgview/main.cc	2010-08-29 10:56:46 UTC (rev 43337)
+++ grass/trunk/visualization/wximgview/main.cc	2010-08-29 15:28:18 UTC (rev 43338)
@@ -187,8 +187,12 @@
     size = HEADER_SIZE + i_width * i_height * 4;
 #ifdef __MINGW32__
-    ptr = MapViewOfFile((HANDLE) _get_osfhandle(fd),
-			FILE_MAP_READ, 0, 0, size);
+    HANDLE handle = CreateFileMapping((HANDLE) _get_osfhandle(fd),
+				      NULL, PAGE_READONLY,
+				      0, size, NULL);
+    if (!handle)
+	return;
+    ptr = MapViewOfFile(handle, FILE_MAP_READ, 0, 0, size);
     if (!ptr)
 	G_fatal_error(_("Unable to map image file"));
 #else
