[GRASS-SVN] r43337 - grass/trunk/locale/po
svn_grass at osgeo.org
Sun Aug 29 06:56:46 EDT 2010
Author: neteler
Date: 2010-08-29 10:56:46 +0000 (Sun, 29 Aug 2010)
New Revision: 43337
grass/trunk/locale/po/grasslibs_ar.po
grass/trunk/locale/po/grasslibs_cs.po
grass/trunk/locale/po/grasslibs_de.po
grass/trunk/locale/po/grasslibs_el.po
grass/trunk/locale/po/grasslibs_es.po
grass/trunk/locale/po/grasslibs_fr.po
grass/trunk/locale/po/grasslibs_hi.po
grass/trunk/locale/po/grasslibs_it.po
grass/trunk/locale/po/grasslibs_ja.po
grass/trunk/locale/po/grasslibs_ko.po
grass/trunk/locale/po/grasslibs_lv.po
grass/trunk/locale/po/grasslibs_mr.po
grass/trunk/locale/po/grasslibs_pl.po
grass/trunk/locale/po/grasslibs_pt.po
grass/trunk/locale/po/grasslibs_pt_br.po
grass/trunk/locale/po/grasslibs_ru.po
grass/trunk/locale/po/grasslibs_sl.po
grass/trunk/locale/po/grasslibs_th.po
grass/trunk/locale/po/grasslibs_tr.po
grass/trunk/locale/po/grasslibs_vi.po
grass/trunk/locale/po/grasslibs_zh.po
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_hi.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_mr.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
grass/trunk/locale/po/grasswxpy_cs.po
grass/trunk/locale/po/grasswxpy_de.po
grass/trunk/locale/po/grasswxpy_es.po
grass/trunk/locale/po/grasswxpy_fr.po
grass/trunk/locale/po/grasswxpy_it.po
grass/trunk/locale/po/grasswxpy_ja.po
grass/trunk/locale/po/grasswxpy_ml.po
grass/trunk/locale/po/grasswxpy_pl.po
grass/trunk/locale/po/grasswxpy_pt.po
grass/trunk/locale/po/grasswxpy_ru.po
grass/trunk/locale/po/grasswxpy_tr.po
grass/trunk/locale/po/grasswxpy_vi.po
grass/trunk/locale/po/grasswxpy_zh.po
merged in translations from 6.4
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_ar.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2502,7 +2502,7 @@
#: ../lib/vector/diglib/file.c:205
#, fuzzy
msgid "Unable to load file to memory, file not open"
-msgstr "ÙÙ
ÙÙ
Ù٠تÙÙÙØ± Ø°Ø§ÙØ±Ø© ÙØ§ÙÙØ©\n"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
#: ../lib/vector/diglib/file.c:220
msgid "Vector memory mode not supported, using 'AUTO'"
@@ -5655,7 +5655,7 @@
#: ../lib/imagery/points.c:124
#, fuzzy, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr "[%s ÙÙ %s]ÙÙ
ÙÙ
ÙÙ Ø§ÙØ´Ø§Ø¡ Ù
ÙÙ Ø§ÙØ¹ÙÙØ§Ù Ø§ÙØ±Ø¦ÙسÙ"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
#: ../lib/imagery/points.c:132
#, fuzzy, c-format
@@ -5722,6 +5722,46 @@
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
msgstr ""
+#, fuzzy
+msgid "Raster map <%s> - unable to write row %d"
+msgstr "[%s]ÙÙØ®Ø±Ùطة- %d ÙÙ
ÙÙ
ÙÙ ÙØªØ§Ø¨Ø© Ø§ÙØµÙ "
+#, fuzzy
+msgid "Error writing floating point format file for map <%s>"
+msgstr "ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
ÙØ¬Ùدة %d\n"
+#, fuzzy
+msgid "Unable to write feature, OGR layer not defined"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ§Ø¨Ø© Ø§ÙØ®Ø· ØÙØ« Ø§Ù Ø§ÙØ®Ø±Ùطة ØºÙØ± Ù
ÙØªÙØØ©"
+#, fuzzy
+msgid "Unable to create a new process!"
+msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ´Ø§Ø¡ عÙ
ÙÙØ© Ø¬Ø¯ÙØ¯Ø©"
+#, fuzzy
+msgid "Default region %s"
+msgstr "ÙÙ
ÙØØ¯Ø¯ اÙÙ
Ø´ØºÙ Ø§ÙØ£Ø³Ø§Ø³Ù"
+#, fuzzy
+msgid "Unable to set region"
+msgstr " %s ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid "Failed writing raster map"
ÙØ¬Ùدة %d\n"
+#, fuzzy
+msgid "Unable to write color file of raster map <%s>"
+msgstr "[%s ÙÙ %s]ÙÙ
ÙÙ
ÙÙ Ø§ÙØ´Ø§Ø¡ Ù
+#, fuzzy
+msgid "Unable to query drawable"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#, fuzzy
+msgid "Failed to initialize Xlib surface"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
#~ msgid "quantization file [%s] in mapset [%s] %s"
#~ msgstr "[%s] Ù
ÙÙ Ø§ÙØªÙسÙÙ
اÙÙÙ
Ù [%s]ÙÙ Ù
جÙ
ÙØ¹Ø© Ø§ÙØ®Ø±Ø§Ø¦Ø· %s"
@@ -5756,10 +5796,6 @@
#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ´Ø§Ø¡ عÙ
ÙÙØ© Ø¬Ø¯ÙØ¯Ø©"
#, fuzzy
-#~ msgid "Raster map <%s> - unable to write row %d"
-#~ msgstr "[%s]ÙÙØ®Ø±Ùطة- %d ÙÙ
ÙÙ
-#, fuzzy
#~ msgid "Unable to open raster map <%s@%s>"
#~ msgstr " [%s] ØºÙØ± ÙØ§Ø¯Ø± عÙÙ Ø£ÙØ´Ø§Ø¡ Ù
Ù٠عÙÙØ§Ù Ø±Ø¦ÙØ³Ù Ù"
@@ -5776,10 +5812,6 @@
#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ´Ø§Ø¡ عÙ
ÙÙØ© Ø¬Ø¯ÙØ¯Ø©"
#, fuzzy
-#~ msgid "Error writing floating point format file for map <%s>"
-#~ msgstr "ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
ÙØ¬Ùدة %d\n"
-#, fuzzy
#~ msgid " It is a reclass of raster map <%s@%s> "
#~ msgstr "أعادة تصÙÙÙ [%s in %s]"
@@ -5788,14 +5820,6 @@
#~ msgstr "ÙÙ
ÙÙ
#, fuzzy
-#~ msgid "Unable to write feature, OGR layer not defined"
-#~ msgstr "ÙÙ
ÙÙ
ÙØªÙØØ©"
-#, fuzzy
-#~ msgid "Unable to create a new process!"
-#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ´Ø§Ø¡ عÙ
ÙÙØ© Ø¬Ø¯ÙØ¯Ø©"
-#, fuzzy
#~ msgid "Too many arguments"
#~ msgstr "ÙÙØ§Ø´Ø§Øª Ù
تعددة"
@@ -5819,22 +5843,6 @@
#~ msgstr "خط %d: <%s>"
#, fuzzy
-#~ msgid "Default region %s"
-#~ msgstr "ÙÙ
ÙØØ¯Ø¯ اÙÙ
Ø´ØºÙ Ø§ÙØ£Ø³Ø§Ø³Ù"
-#, fuzzy
-#~ msgid "Unable to set region"
-#~ msgstr " %s ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
-#~ msgid "Failed writing raster map"
ÙØ¬Ùدة %d\n"
-#, fuzzy
-#~ msgid "Unable to write color file of raster map <%s>"
-#~ msgstr "[%s ÙÙ %s]ÙÙ
ÙÙ
ÙÙ Ø§ÙØ´Ø§Ø¡ Ù
-#, fuzzy
#~ msgid "Unable to open category index file for vector map <%s@%s>"
#~ msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ø§ÙØªØ§Ø±ÙØ® ÙÙÙÙÙØªÙر"
@@ -5930,14 +5938,6 @@
#~ msgstr "ÙÙ
ÙØªÙ
ÙØªØ§Ø¨Ø© Ø±ÙØ§Ø¨Ø· ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
#, fuzzy
-#~ msgid "Unable to query drawable"
-#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#, fuzzy
-#~ msgid "Failed to initialize Xlib surface"
-#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#, fuzzy
#~ msgid "Cannot describe table <%s>"
#~ msgstr "ÙÙ
ÙØªÙ
@@ -6386,3 +6386,196 @@
#~ msgid "unable to find [%s] in [%s]"
#~ msgstr "[%s] ÙÙ
ÙØªÙ
Ø§ÙØ¬Ø§Ø¯ [%s] ÙÙ"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "ÙÙ
ÙÙ
+#, fuzzy
+#~ msgid "Unable to open file %s"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#, fuzzy
+#~ msgid "Unable to open temporary file"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#~ msgid "Hit RETURN to cancel request\n"
+#~ msgstr "RETURN أضغط ÙØ£Ùغاء Ø§ÙØ£Ù
ر\n"
+#, fuzzy
+#~ msgid "Problem reading raster map"
+#~ msgstr "ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
ÙØ¬Ùدة %d\n"
+#~ msgid " The raster map %s@%s is empty"
+#~ msgstr " ÙØ§Ø±ØºØ© %s@%s Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#~ msgid "Cannot write quant rules: map %s is integer"
+#~ msgstr "صØÙØØ© ÙÙØ§ ÙÙ
ÙÙ ÙØªØ§Ø¨Ø© ÙÙØ§Ø¹Ø¯ Ø§ÙØªÙسÙÙ
%s أعداد Ø§ÙØ®Ø±Ùطة"
+#~ msgid "The floating data range for %s@%s is empty"
+#~ msgstr "ÙØ§Ø±ØºØ© %s@%s ÙØ·Ø§Ù Ø§ÙØ¨ÙØ§ÙØ§Øª Ø§ÙØ¹Ø´Ø±ÙØ© Ù"
+#~ msgid "The integer data range for %s@%s is empty"
+#~ msgstr "ÙØ§Ø±ØºØ© %s@%s ÙØ·Ø§Ù Ø§ÙØ¨ÙØ§ÙØ§Øª Ø§ÙØµØÙØØ© Ù"
+#~ msgid "map [%s] - unable to write row %d"
+#~ msgstr "[%s]ÙÙØ®Ø±Ùطة- %d ÙÙ
ÙÙ
+#, fuzzy
+#~ msgid "unable to find a temporary null file %s"
+#~ msgstr "datum ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠جدÙÙ : %s"
+#~ msgid "error writing null row %d"
+#~ msgstr "%d خطأ ÙÙ ÙØªØ§Ø¨Ø© Ø§ÙØµÙ اÙÙ
ÙØ¹Ø¯Ù
+#~ msgid "category support for [%s] in mapset [%s] %s"
+#~ msgstr "دعÙ
اÙÙØ¦Ø© [%s] ÙÙ Ù
جÙ
ÙØ¹Ø© Ø§ÙØ®Ø±Ø§Ø¦Ø· [%s] %s"
+#~ msgid "category support for vector map [%s] in mapset [%s] %s"
+#~ msgstr "دعÙ
اÙÙØ¦Ø© ÙÙ
ÙÙ ÙÙÙØªÙر٠[%s] Ù
جÙ
+#~ msgid "Cannot open temp file"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ù
Ø¤ÙØª"
+#, fuzzy
+#~ msgid "Name of elevation raster map"
+#~ msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Name of elevation raster map(s)"
+#~ msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
Ø¯Ø®ÙØ©"
+#~ msgid "Layer number"
+#~ msgstr "رÙÙ
Ø§ÙØ·Ø¨ÙØ©"
+#~ msgid ""
+#~ "\n"
+#~ "Description:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ÙØµÙ:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Ø§ÙØ¥Ø³ØªØ®Ø¯Ø§Ù
:\n"
+#~ msgid "to accept the default"
+#~ msgstr "ÙÙØ¨ÙÙ Ø§ÙØ£Ø³Ø§Ø³ اÙÙ
خزÙ"
+#~ msgid "color support for [%s] in mapset [%s] %s"
+#~ msgstr "دعÙ
اÙÙÙÙ [%s] Ù
جÙ
+#, fuzzy
+#~ msgid "Error reading compressed map <%s@%s>, row %d"
+#~ msgstr "دعÙ
اÙÙØ¦Ø© [%s] ÙÙ Ù
جÙ
+#, fuzzy
+#~ msgid "Error reading map <%s@%s>, row %d"
+#~ msgstr "دعÙ
اÙÙØ¦Ø© [%s] ÙÙ Ù
جÙ
+#~ msgid "unable to determine user's home directory"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ØªØØ¯Ùد Ù
ÙØ§Ù Ù
ÙÙØ§Øª اÙÙ
ستخدÙ
+#~ msgid "Unable to create header file for [%s]"
+#~ msgstr " [%s] ØºÙØ± ÙØ§Ø¯Ø± عÙÙ Ø£ÙØ´Ø§Ø¡ Ù
+#, fuzzy
+#~ msgid "Illegal filename. Character <%c> not allowed.\n"
+#~ msgstr " ØºÙØ± Ù
سÙ
ÙØ Ø¨Ù ÙØ§ÙاسÙ
ØºÙØ± صØÙØ <%c> Ø§ÙØØ±Ù"
+#~ msgid "Too many reclass categories for [%s in %s]"
+#~ msgstr "[%s ÙÙ %s]ÙØ¦Ø§Øª Ù
عادة Ø§ÙØªØµÙÙÙ Ù
تعددة "
+#~ msgid "Illegal reclass format in header file for [%s in %s]"
+#~ msgstr "[%s ÙÙ %s]تشÙÙ٠أعادة Ø§ÙØªØµÙÙÙ ØºÙØ± صØÙØ ÙÙ Ù
+#~ msgid "Unable to create dependency file in [%s in %s]"
+#~ msgstr "[%s ÙÙ %s]ÙÙ
ÙÙ
ÙÙ Ø§ÙØ´Ø§Ø¡ Ù
ÙÙ Ø§ÙØ£Ø³ØªÙÙØ§Ù "
+#, fuzzy
+#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
+#~ msgstr "[%s] ÙÙ [%s] - Ø¨ÙØªØ© ÙÙÙ Ø®ÙÙØ© (%d) ÙÙÙ
ÙØ¨Ùرة"
+#, fuzzy
+#~ msgid "Unable to find '%s' in '%s'"
+#~ msgstr "[%s] ÙÙ
ÙØªÙ
Ø§ÙØ¬Ø§Ø¯"
+#, fuzzy
+#~ msgid "Unable to read header file for raster map <%s@%s>."
ÙÙ
ÙÙ Ø§ÙØ´Ø§Ø¡ Ù
+#, fuzzy
+#~ msgid "Unable to add database link, map is not opened in WRITE mode"
+#~ msgstr ""
+#~ "ÙÙ
ÙØªÙ
Ø§Ø¶Ø§ÙØ© رابط ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª ØÙØ« Ø§Ù Ø§ÙØ®Ø±Ùطة ØºÙØ± Ù
ÙØªÙØØ© عÙÙ ÙØ¶Ø¹ اÙÙØªØ§Ø¨Ø©"
+#, fuzzy
+#~ msgid "Unable to add database link"
+#~ msgstr "ÙÙ
ÙØªÙ
Ø§Ø¶Ø§ÙØ© رابط ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
+#~ msgid "Error in rule on row %d in %s"
+#~ msgstr " %s ÙÙ %d خطا Ù٠اÙÙØ§Ø¹Ø¯Ø© عÙÙ Ø§ÙØµÙ"
+#, fuzzy
+#~ msgid "Intersections: %5d"
+#~ msgstr "Ù
Ø³Ø§ÙØ· أخرÙ"
+#, fuzzy
+#~ msgid "Unable to feature %d from vector map <%s>"
+#, fuzzy
+#~ msgid "Programmer requested unknown open level %d"
+#~ msgstr "ØªØØ°Ùر: اÙÙ
برÙ
ج Ø·ÙØ¨ Ù
ستÙÙ ØºÙØ± Ù
عرÙÙ\n"
+#, fuzzy
+#~ msgid "Unable to open layer <%s>"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#, fuzzy
+#~ msgid "Unable to create raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to delete layer/category %d/%d line %d"
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> on topology level %d"
+#~ msgstr "'%s'اÙÙ '%s'ÙÙ
ÙÙ
ÙÙ ÙØ³Ø® ÙÙÙØªÙر"
+#, fuzzy
+#~ msgid "Attempt to delete dead line"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ù
Ø¤ÙØª"
+#, fuzzy
+#~ msgid "Unable to rewrite line %d"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ù
Ø¤ÙØª"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ Ù
ØÙ Ø§ÙØ®Ø·,Ø§ÙØ®Ø±Ùطة ØºÙØ± Ù
ÙØªÙØØ© عÙ٠اÙÙ
ستÙÙ Ø§ÙØ«Ø§ÙÙ"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
+#~ msgstr " ÙÙ
ÙÙ
ÙÙ Ù
ÙØªÙØØ© Ø¨ÙØ¶Ø¹ Ù
ÙÙØ£ ÙÙÙØªØ§Ø¨Ø©"
+#, fuzzy
+#~ msgid "Unable to delete line %d from vector map <%s>"
+#~ msgid "Cannot find input map '%s'"
+#~ msgstr "'%s' ÙÙ
ÙØªÙ
Ø§ÙØ¹Ø«Ùر عÙÙ Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
+#~ msgid "Cannot rewrite line"
+#~ msgstr "ÙÙ
ÙÙ
Ù٠إعادة ÙØªØ§Ø¨Ø© Ø§ÙØ®Ø·"
+#, fuzzy
+#~ msgid "Color file for [%s] not available"
+#~ msgstr "ØºÙØ± Ù
ØªØ§Ø << %s >> اÙÙ
ÙÙØ¹"
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_cs.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5844,77 +5844,76 @@
msgstr "Podskupina <%s>skupiny <%s> okazuja na následující rastrové mapy\n"
#, fuzzy
-#~ msgid "Not enough room in history file to record command line"
-#~ msgstr ""
-#~ "V souboru s historií není dostatek místa, aby pøíkazová øádka mohla být "
-#~ "zaznamenána"
+msgid "Not enough room in history file to record command line"
+msgstr ""
+"V souboru s historií není dostatek místa, aby pøíkazová øádka mohla být "
+"zaznamenána"
#, fuzzy
-#~ msgid "Not enough room in history file for command line (truncated)"
-#~ msgstr ""
-#~ "V souboru s historií není dostatek místa pro pøíkazovou øádku (zkráceno)"
+msgid "Not enough room in history file for command line (truncated)"
+msgstr ""
+"V souboru s historií není dostatek místa pro pøíkazovou øádku (zkráceno)"
-#~ msgid "Invalid view position coordinates, using %f,%f"
-#~ msgstr "Neplatné souøadnice bodu rozhledu, pou¾iji %f,%f"
+msgid "Unknown Location"
+msgstr "Neznámá Location"
-#~ msgid "Unknown Location"
-#~ msgstr "Neznámá Location"
#, fuzzy
-#~ msgid "test, gmath"
-#~ msgstr "test, gpde"
+msgid "test, gmath"
+msgstr "test, gpde"
#, fuzzy
-#~ msgstr "mapa [%s] - nelze pøeèíst øádek %d"
+msgstr "mapa [%s] - nelze pøeèíst øádek %d"
#, fuzzy
-#~ msgstr ""
-#~ "Chyba pøi zapisování souboru s èísly s plovoucí desetinnou èárkou pro "
-#~ "mapu %s"
+msgstr ""
+"Chyba pøi zapisování souboru s èísly s plovoucí desetinnou èárkou pro mapu %s"
#, fuzzy
-#~ msgid "OGR layer cannot be opened for update"
-#~ msgstr "Formát OGR nelze aktualizovat"
+msgid "OGR layer cannot be opened for update"
+msgstr "Formát OGR nelze aktualizovat"
#, fuzzy
-#~ msgstr "Nelze zapsat prvek, vektorová mapa není otevøena"
+msgstr "Nelze zapsat prvek, vektorová mapa není otevøena"
#, fuzzy
-#~ msgstr "Nelze vytvoøit nový proces"
+msgstr "Nelze vytvoøit nový proces"
-#~ msgid "Too many arguments"
-#~ msgstr "Pøíli¹ mnoho argumentù"
+msgid "Too many arguments"
+msgstr "Pøíli¹ mnoho argumentù"
#, fuzzy
-#~ msgid ""
-#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
-#~ msgstr ""
-#~ "region pro aktuální mapset %s\n"
-#~ "spus»te \"g.region\""
+msgid ""
+"Region for current mapset %s. Run \"g.region\" to fix the current region."
+msgstr ""
+"region pro aktuální mapset %s\n"
+"spus»te \"g.region\""
#, fuzzy
-#~ msgstr "výchozí region (zájmové území) %s"
+msgstr "výchozí region (zájmové území) %s"
#, fuzzy
-#~ msgstr "Nelze nastavit zaostøení"
+msgstr "Nelze nastavit zaostøení"
#, fuzzy
-#~ msgstr "Potí¾e pøi ètení rastrové mapy"
+msgstr "Potí¾e pøi ètení rastrové mapy"
#, fuzzy
-#~ msgstr "Nelze èíst soubor s barevnou ¹kálou pro rastrovou mapu <%s>"
+msgstr "Nelze èíst soubor s barevnou ¹kálou pro rastrovou mapu <%s>"
-#~ msgid "Incompatible library version for module"
-#~ msgstr "Nekompatibilní verze knihovny pro modul"
+msgid "Incompatible library version for module"
+msgstr "Nekompatibilní verze knihovny pro modul"
+#~ msgid "Invalid view position coordinates, using %f,%f"
+#~ msgstr "Neplatné souøadnice bodu rozhledu, pou¾iji %f,%f"
#~ msgstr "kvantizaèní soubor [%s] v mapsetu [%s] %s"
@@ -6716,3 +6715,54 @@
#~ msgid "some points outside of region -- will ignore..."
#~ msgstr "nìkteré body mimo region -- budou ignorovány..."
+#~ msgid "Probably program error."
+#~ msgstr "Pravdìpodobnì chyba programu."
+#~ msgstr "Nelze otevøít doèasný soubor"
+#~ msgstr "Potí¾e pøi ètení rastrové mapy"
+#~ msgid ""
+#~ "\n"
+#~ "invalid projection\n"
+#~ msgstr ""
+#~ "\n"
+#~ "neplatná mapová projekce\n"
+#~ msgid "Please advise GRASS developers of this error.\n"
+#~ msgstr "Prosím, oznamte tuto chybu vývojáøùm GRASSu.\n"
+#~ msgstr "Název rastrové vrstvy vý¹kového modelu"
+#~ msgstr "Název rastrové vrstvy/vrstev vý¹kového modelu"
+#~ msgstr "pou¾ít výchozí"
+#~ msgid "hit RETURN to continue -->"
+#~ msgstr "stisknìte RETURN pro pokraèování -->"
+#~ msgid "No help available for command [%s]\n"
+#~ msgstr "Nápovìda pro pøíkaz [%s] není dostupná\n"
+#~ msgstr "Nelze pøidat spojení s databází."
+#~ msgid ""
+#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+#~ "excess)"
+#~ msgstr ""
+#~ "Soubor se souøadnicemi (Coor) vektorové mapy <%s@%s> je vìt¹í ne¾ by mìl "
+#~ "být (%ld bytù pøebývá)"
+#~ msgid ""
+#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+#~ "missing)."
+#~ msgstr ""
+#~ "Soubor se souøadnicemi (Coor) vektorové mapy <%s@%s> je men¹í ne¾ by mìl "
+#~ "být (%ld bytù chybí)"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_de.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5878,272 +5878,270 @@
"Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
#, fuzzy
-#~ msgstr ""
-#~ "Nicht genügend Platz in der History-Datei um die Kommandozeile zu "
-#~ "speichern."
+msgstr ""
+"Nicht genügend Platz in der History-Datei um die Kommandozeile zu speichern."
#, fuzzy
-#~ msgstr ""
-#~ "Nicht genügend Platz in der History-Datei für die Kommandozeile "
-#~ "(angeschnitten)."
+msgstr ""
+"Nicht genügend Platz in der History-Datei für die Kommandozeile "
+"(angeschnitten)."
-#~ msgstr "Ungültige Koordinaten für den Betrachtungspunkt, verwende %f,%f"
#, fuzzy
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Keywords:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Schlüsselwörter:\n"
+msgid ""
+"\n"
+"Keywords:\n"
+msgstr ""
+"\n"
+"Schlüsselwörter:\n"
#, fuzzy
-#~ msgstr "Fehler beim Schreiben der Flißekommakarte %s."
+msgstr "Fehler beim Schreiben der Flißekommakarte %s."
#, fuzzy
-#~ msgstr "Kann keinen neuen Prozess erzeugen."
+msgstr "Kann keinen neuen Prozess erzeugen."
#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "Region des gegenwärtigen Mapsets %s\n"
-#~ "Führen Sie \"g.region\" aus"
+msgid ""
+msgstr ""
+"Region des gegenwärtigen Mapsets %s\n"
+"Führen Sie \"g.region\" aus"
#, fuzzy
-#~ msgstr "Standard Region %s"
+msgstr "Standard Region %s"
#, fuzzy
-#~ msgstr "Kann %s nicht öffnen."
+msgstr "Kann %s nicht öffnen."
#, fuzzy
-#~ msgstr "Karte [%s] - Kann Zeile %d nicht schreiben. "
+msgstr "Karte [%s] - Kann Zeile %d nicht schreiben. "
#, fuzzy
-#~ msgstr "Vektor Karte"
+msgstr "Vektor Karte"
#, fuzzy
-#~ msgstr "Raster Karte"
+msgstr "Raster Karte"
#, fuzzy
-#~ msgid "Type"
-#~ msgstr "Typ"
+msgid "Type"
+msgstr "Typ"
-#~ msgid "Cannot get layer info"
-#~ msgstr "Kann die Layer-Informationen nicht abfragen."
+msgid "Cannot get layer info"
+msgstr "Kann die Layer-Informationen nicht abfragen."
-#~ msgid "Cannot open database %s"
-#~ msgstr "Kann Datenbank '%s' nicht öffnen."
+msgid "Cannot open database %s"
+msgstr "Kann Datenbank '%s' nicht öffnen."
#, fuzzy
-#~ msgstr "Kann Datei %s nicht öffnen."
+msgstr "Kann Datei %s nicht öffnen."
#, fuzzy
-#~ msgstr "Kann Datei %s in %s nicht öffnen"
+msgstr "Kann Datei %s in %s nicht öffnen"
#, fuzzy
-#~ msgid "Registering points"
-#~ msgstr "Registriere Linien..."
+msgid "Registering points"
+msgstr "Registriere Linien..."
#, fuzzy
-#~ msgid "Registered points"
+msgid "Registered points"
#, fuzzy
-#~ msgid "Registered points (unique coordinates)"
+msgid "Registered points (unique coordinates)"
#, fuzzy
-#~ msgid "Duplicates"
-#~ msgstr "Doppeltes Ost-Feld"
+msgid "Duplicates"
+msgstr "Doppeltes Ost-Feld"
-#~ msgid "G_malloc: out of memory"
-#~ msgstr "G_malloc: Kein Speicher mehr da."
+msgid "G_malloc: out of memory"
+msgstr "G_malloc: Kein Speicher mehr da."
-#~ msgid "G_calloc: out of memory"
-#~ msgstr "G_calloc: Kein Speicher mehr da."
+msgid "G_calloc: out of memory"
+msgstr "G_calloc: Kein Speicher mehr da."
-#~ msgid "G_realloc: out of memory"
-#~ msgstr "G_realloc: Kein Speicher mehr da."
+msgid "G_realloc: out of memory"
+msgstr "G_realloc: Kein Speicher mehr da."
#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Kann Tabelle <%s> nicht beschreiben"
+msgid "Cannot describe table <%s>"
+msgstr "Kann Tabelle <%s> nicht beschreiben"
#, fuzzy
-#~ msgid "Attempt to delete dead line"
-#~ msgstr "Versuch, eine tote Fläche zu löschen"
+msgid "Attempt to delete dead line"
+msgstr "Versuch, eine tote Fläche zu löschen"
#, fuzzy
-#~ msgid "Unable to connect lines %d,%d"
-#~ msgstr "Kann Datei head nicht lesen"
+msgid "Unable to connect lines %d,%d"
+msgstr "Kann Datei head nicht lesen"
#, fuzzy
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
+msgid "Output name '%s' is not valid rast name."
+msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
#, fuzzy
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
+msgid "Output map '%s' is used as input"
+msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
#, fuzzy
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "Kann nicht zum Verzeichnis %s wechseln."
+msgid "unable to open raster map [%s in %s]"
+msgstr "Kann nicht zum Verzeichnis %s wechseln."
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "Ungenügend Speicher zum Allokieren der Gausschen..."
+msgid "Insufficent memory for allocation of gaussian"
+msgstr "Ungenügend Speicher zum Allokieren der Gausschen..."
#, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
+msgid "Cannot read topo for line [%d]"
#, fuzzy
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Kann range Datei für [%s in %s] nicht lesen."
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "Kann range Datei für [%s in %s] nicht lesen."
#, fuzzy
-#~ msgid "Can't open header file for [%s in %s]"
+msgid "Can't open header file for [%s in %s]"
#, fuzzy
-#~ msgid "Cannot get field info"
+msgid "Cannot get field info"
#, fuzzy
-#~ msgid "Cannot open database"
+msgid "Cannot open database"
#, fuzzy
-#~ msgid "Building topology ...\n"
-#~ msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
+msgid "Building topology ...\n"
+msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
-#~ msgid ""
-#~ "\r%d areas built \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d Flächen erstellt \n"
-#~ "%d Inselflächen erstellt\n"
+msgid ""
+"\r%d areas built \n"
+"%d isles built\n"
+msgstr ""
+"\r%d Flächen erstellt \n"
+"%d Inselflächen erstellt\n"
#, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
#, fuzzy
-#~ msgid "OGR feature type [%d] not supported"
-#~ msgstr "OGR Feature Typ %d wird nicht unterstützt."
+msgid "OGR feature type [%d] not supported"
+msgstr "OGR Feature Typ %d wird nicht unterstützt."
#, fuzzy
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_write_line() wird für dieses Format/Level nicht unterstützt."
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "Vect_write_line() wird für dieses Format/Level nicht unterstützt."
#, fuzzy
-#~ msgid "Vect_delete_line() for this format/level not supported"
+msgid "Vect_delete_line() for this format/level not supported"
#, fuzzy
-#~ msgid "Output name '%s' is not valid vector name."
+msgid "Output name '%s' is not valid vector name."
#, fuzzy
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
+msgid "Cannot open existing vector map <%s>"
#, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
#, fuzzy
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Kann die Debug-Datei '%s' nicht öffnen."
+msgid "Cannot open new vector %s"
+msgstr "Kann die Debug-Datei '%s' nicht öffnen."
#, fuzzy
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
+msgid "Cannot open history file for vector '%s'"
+msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
#, fuzzy
-#~ msgid "Could not stat file '%s'"
+msgid "Could not stat file '%s'"
#, fuzzy
-#~ msgid "Can't open directory %s"
+msgid "Can't open directory %s"
-#~ msgid "Starting lu solver method"
-#~ msgstr "Starte lu-Solver Methode"
+msgid "Starting lu solver method"
+msgstr "Starte lu-Solver Methode"
#, fuzzy
-#~ msgid "%s - ** illegal name **"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> unerlaubter Name **\n"
+msgid "%s - ** illegal name **"
+msgstr ""
+"\n"
+"**<%s> unerlaubter Name **\n"
#, fuzzy
-#~ msgid "Gauss-Seidel -- iteration %5i error %g\n"
-#~ msgstr "sparse SOR -- Durchlauf %5i Fehler %g\n"
+msgid "Gauss-Seidel -- iteration %5i error %g\n"
+msgstr "sparse SOR -- Durchlauf %5i Fehler %g\n"
#, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
#, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "Bitte benutzen Sie \"d.mon\", um einen Graphik-Monitor auszuwählen."
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr "Bitte benutzen Sie \"d.mon\", um einen Graphik-Monitor auszuwählen."
#, fuzzy
-#~ msgid "Can't stat %s\n"
-#~ msgstr "eine Liste %s ein."
+msgid "Can't stat %s\n"
+msgstr "eine Liste %s ein."
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Fehler - Monitor <%s> wird bereits benutzt.\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Fehler - Monitor <%s> wird bereits benutzt.\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Fehler - Monitor <%s> wird bereits von %s benutzt.\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "Fehler - Monitor <%s> wird bereits von %s benutzt.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Fehler - Kann den Locking-Prozess für Monitor <%s> nicht beenden.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "Fehler - Kann den Locking-Prozess für Monitor <%s> nicht beenden.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Fehler - Kann keine Pipe zum Graphik-Gerät aufbauen.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Fehler - Kann keine Pipe zum Graphik-Gerät aufbauen.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Fehler - Graphik-Monitor <%s> läuft nicht!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Fehler - Graphik-Monitor <%s> läuft nicht!\n"
#, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Nicht verbunden...\n"
+msgid "Not connected...\n"
+msgstr "Nicht verbunden...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr ""
-#~ "Kann nicht mit einem Monitor verbinden. Versuche es noch ein weiteres "
-#~ "Mal.\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr ""
+"Kann nicht mit einem Monitor verbinden. Versuche es noch ein weiteres Mal.\n"
+#~ msgstr "Ungültige Koordinaten für den Betrachtungspunkt, verwende %f,%f"
#~ msgstr "Unbekannte Location"
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_el.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2525,7 +2525,7 @@
#, fuzzy
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ðñïóùñéíÞ åéêüíá"
+msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
@@ -5340,9 +5340,8 @@
msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
#: ../lib/sites/sites.c:1205
-#, fuzzy
msgid "Cannot select attributes"
-msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
+msgstr ""
#: ../lib/cluster/c_exec.c:42
#, c-format
@@ -5820,7 +5819,7 @@
#, fuzzy, c-format
-msgstr "Áäõíáìßá äçìéïõñãßáò êåöáëéêïý áñ÷åßïõ ãéá [%s in %s]"
+msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ [%s] ôïõ ãêñïõð [%s in %s]"
#, fuzzy, c-format
@@ -5889,24 +5888,106 @@
msgstr ""
#, fuzzy
-#~ msgstr ""
-#~ "Äåí õðÜñ÷åé áñêåôüò ÷þñïò óôï áñ÷åßï éóôïñéêïý ãéá åããñáöÞ åíôïëÞò ãñáììÞò"
+msgstr ""
+"Äåí õðÜñ÷åé áñêåôüò ÷þñïò óôï áñ÷åßï éóôïñéêïý ãéá åããñáöÞ åíôïëÞò ãñáììÞò"
#, fuzzy
-#~ msgstr "Not enough room in history file to record command line (ðåñéêïðÞ)."
+msgstr "Not enough room in history file to record command line (ðåñéêïðÞ)."
+#, fuzzy
+msgstr "äïêéìÞ, gpde"
+#, fuzzy
+msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+#, fuzzy
+msgstr "Áäýíáìßá Ýíáñîçò pj åîáéôßáò: %s"
+#, fuzzy
+msgid "Cannot read topo for nodes"
+msgstr "Áäõíáìßá áíÜãíùóçò ôùí ôïðïãñáöéêþí êüìâùí (nodes)"
+#, fuzzy
+msgid "Cannot read topo for node [%d]"
+msgstr "Áäõíáìßá áíÜãíùóçò ôïõ ôïðïãñáöéêïý êüìâïõ (node) %d"
+#, fuzzy
+msgid "Cannot read topo for lines"
+msgstr "Áäõíáìßá áíÜãíùóçò ôïðïãßáò ãéá ãñáììÝò"
+#, fuzzy
+msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßá ãéá ãñáììÞ %d"
+#, fuzzy
+msgid "Cannot read topo for areas"
+msgstr "Áäõíáìßá áíÜãíùóçò topo ôùí ðåñéï÷þí"
+#, fuzzy
+msgid "Cannot read topo for area [%d]"
+msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßáò ôçò ðåñéï÷Þò %d"
+#, fuzzy
+msgid "Cannot read topo for isles"
+msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßáò ãéá íçóßäåò"
+#, fuzzy
+msgid "Cannot read topo for isle [%d]"
+msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßá ãéá íçóßäá %d"
+#, fuzzy
+msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
+msgstr "BUG (Vect_build_sidx_from_topo): ç åðéöÜíåéá äåí õðÜñ÷åé"
+#, fuzzy
+msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
+#, fuzzy
+msgid "Registering lines: "
+msgstr "ÅããñáöÞ óçìåßùí"
+#, fuzzy
+msgid "Unable to rewrite line %d"
+msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
+#, fuzzy
+msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+msgstr ""
+"Áäõíáìßá äéáãñáöÞò feature %d, ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé "
+"áíïéêôüò óå ôïðïëïãéêü åðßðåäï"
+#, fuzzy
+msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
+msgstr ""
+"áíïéêôüò óå 'write' mode"
+#, fuzzy
+msgid "Unable to delete line %d from vector map <%s>"
+msgstr "Áäõíáìßá óå feature %d áðü ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+#, fuzzy
+msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
+#, fuzzy
+msgstr ""
+"Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
+"äåäïìÝíùí."
#~ msgstr "ËÜèïò óõíôåôáãìÝíåò üøçò, ÷ñÞóç %f,%f"
#~ msgstr "¶ãíùóôç ðåñéï÷Þ"
-#, fuzzy
-#~ msgstr "äïêéìÞ, gpde"
#~ msgstr "quantization file [%s] in mapset [%s] %s"
@@ -6194,14 +6275,6 @@
#~ msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
-#, fuzzy
-#~ msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
-#, fuzzy
-#~ msgstr "Áäýíáìßá Ýíáñîçò pj åîáéôßáò: %s"
#~ msgid "Monitor: get_command: Premature EOF"
#~ msgstr "Monitor: get_command: Premature EOF"
@@ -6251,82 +6324,6 @@
#~ msgid "Connection failed."
#~ msgstr "ÓöÜëìá óýíäåóçò."
-#, fuzzy
-#~ msgid "Cannot read topo for nodes"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôùí ôïðïãñáöéêþí êüìâùí (nodes)"
-#, fuzzy
-#~ msgid "Cannot read topo for node [%d]"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïõ ôïðïãñáöéêïý êüìâïõ (node) %d"
-#, fuzzy
-#~ msgid "Cannot read topo for lines"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïðïãßáò ãéá ãñáììÝò"
-#, fuzzy
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßá ãéá ãñáììÞ %d"
-#, fuzzy
-#~ msgid "Cannot read topo for areas"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò topo ôùí ðåñéï÷þí"
-#, fuzzy
-#~ msgid "Cannot read topo for area [%d]"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßáò ôçò ðåñéï÷Þò %d"
-#, fuzzy
-#~ msgid "Cannot read topo for isles"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßáò ãéá íçóßäåò"
-#, fuzzy
-#~ msgid "Cannot read topo for isle [%d]"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßá ãéá íçóßäá %d"
-#, fuzzy
-#~ msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
-#~ msgstr "BUG (Vect_build_sidx_from_topo): ç åðéöÜíåéá äåí õðÜñ÷åé"
-#, fuzzy
-#~ msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
-#, fuzzy
-#~ msgid "Registering lines: "
-#~ msgstr "ÅããñáöÞ óçìåßùí"
-#, fuzzy
-#~ msgid "Unable to rewrite line %d"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
-#~ msgstr ""
-#~ "Áäõíáìßá äéáãñáöÞò feature %d, ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé "
-#~ "áíïéêôüò óå ôïðïëïãéêü åðßðåäï"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
-#~ msgstr ""
-#~ "áíïéêôüò óå 'write' mode"
-#, fuzzy
-#~ msgid "Unable to delete line %d from vector map <%s>"
-#~ msgstr "Áäõíáìßá óå feature %d áðü ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
-#, fuzzy
-#~ msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
-#, fuzzy
-#~ msgstr ""
-#~ "Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
-#~ "äåäïìÝíùí."
#~ msgstr "ÐáôÞóôå ôï ðëÞêôñï RETURN ãéá íá áêõñþóåôå ôçí åíôïëÞ\n"
@@ -6557,3 +6554,311 @@
#~ msgid "ask: can't happen"
#~ msgstr "ask: äåí ìðïñåß íá ãßíåé"
+#~ msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
+#~ msgstr "Ðéèáíü ëÜèïò ôïõ ðñïãñÜììáôïò."
+#~ msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ %s"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
+#~ msgstr "Ðñüâëçìá ìå ôçí áíÜãíùóç ôïõ ñÜóôåñ ÷Üñôç"
+#~ msgstr "Ï ñÜóôåñ ÷Üñôçò %s@%s åßíáé Üäåéïò"
+#~ msgstr "Äåí ìðïñïýí íá åããñáöïýí quant êáíüíåò: Ï ÷Üñôçò %s åßíáé áêÝñáéïò"
+#~ msgid ""
+#~ "G_set_window(): projection/zone differs from that of currently open "
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): ç ðñïâïëÞ/æþíç äéáöÝñåéò áðü ôïõò õöéóôÜìåíá áíïé÷ôïõ "
+#~ "ñáóôåñ ÷Üñôåò"
+#~ msgstr "Ôï ðåäßï õðïäéáóôïëÞò ãéá %s@%s åßíáé Üäåéï"
+#~ msgstr "Ôï ðåäßï áêÝñáéïõ áñéèìïý ãéá %s@%s åßíáé Üäåéï"
+#~ msgid "%s: map [%s] not open for write - request ignored"
+#~ msgstr "%s:÷Üñôçò [%s] äåí åßíáé áíïé÷ôüò ãéá åããñáöÞ - ç åíôïëÞ áãíïåßôáé"
+#~ msgid "%s: unopened file descriptor - request ignored"
+#~ msgstr "%s: ìç áíïéêôÞ ðåñéãñáöÞ áñ÷åßïõ - åíôïëÞ áãíïåßôå"
+#~ msgstr "Áäõíáìßá åããñáöÞò ðñïóùñéíïý êåíïý áñ÷åßïõ %s"
+#~ msgstr "ÓöÜëìá åããñáöÞò êåíÞò ãñáììÞò %d"
+#~ msgstr "ÕðïóôÞñéîç êáôçãïñéþí ãéá [%s] óôï mapset [%s] %s"
+#~ msgstr "ÕðïóôÞñéîç êáôçãïñéþí ãéá äéáíõóìáôéêü ÷Üñôç[%s] óôï mapset [%s] %s"
+#~ msgstr "Äåí ìðïñåß íá áíïßîåé ôï ðñïóùñéíü áñ÷åßï"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ËáíèáóìÝíç ðñïâïëÞ\n"
+#~ msgid "EmbedGivenNulls: wrong data type!"
+#~ msgstr "EmbedGivenNulls: åóöáëìÝíïò ôýðïò äåäïìÝíùí!"
+#~ msgstr ""
+#~ "Ðáñáêáëþ åíçìåñþóôå ôïõò ðñïãñáììáôéóôÝò ôïõ GRASS ãéá áõôü ôï ìÞíõìá "
+#~ "ëÜèïõò.\n"
+#~ msgid "G_set_null_value: wrong data type!"
+#~ msgstr "G_set_null_value: åóöáëìÝíïò ôýðïò äåäïìÝíùí!"
+#~ msgstr "¼íïìá ñÜóôåñ ÷Üñôç õøïìÝôñïõ"
+#~ msgstr "¼íïìá ñÜóôåñ ÷áñôþí õøïìÝôñïõ"
+#~ msgstr "Íïýìåñï åðéðÝäïõ"
+#~ msgid ""
+#~ "A single vector map can be connected to multiple database tables. This "
+#~ "number determines which table to use."
+#~ msgstr ""
+#~ "¸íáò äéáíõóìáôéêüò ÷Üñôçò åßíáé äõíáôüí íá óõíäåèåß ìå ðïëëáðëïýò "
+#~ "ðßíáêåò. Áõôüò áñéèìüò êáèïñßæåé ðïéïò ðßíáêáò èá ÷ñçóéìïðïéçèåß."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ÐåñéãñáöÞ:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ËÝîåéò êëåéäéÜ:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "×ñÞóç:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Flags:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Flags:\n"
+#~ msgid " options: %s\n"
+#~ msgstr " åðéëïãÝò: %s\n"
+#~ msgstr "ãéá íá áðïäåêôåßôå ôï ðñïêáèïñéóìÝíï"
+#~ msgstr "÷ñùìáôéêÞ õðïóôÞñéîç ãéá [%s] óôï mapset [%s] %s"
+#~ msgid "Invalid timestamp specified for %s map %s in mapset %s"
+#~ msgstr "ËÜèïò timestamp êáèïñßóôçêå ãéá %s ÷Üñôç %s óôï mapset %s"
+#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
+#~ msgstr "ËáíèáóìÝíï timestamp áñ÷åßï ãéá %s ÷Üñôç %s óôï mapset %s"
+#~ msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç óõìðéåóìÝíïõ ÷Üñôç <%s@%s>, ãñáììÞ %d"
+#~ msgstr "ÓöÜëìá áíÜãíùóçò ÷Üñôç <%s@%s>, ãñáììÞ %d"
+#~ msgstr "Äåí åßíáé äõíáôüò ï êáèïñéóìïýò ï áñ÷éêüò öÜêåëëïò ôïõ ÷ñÞóôç"
+#~ msgstr "Áäõíáìßá äçìéïõñãßáò êåöáëéêïý áñ÷åßïõ ãéá [%s]"
+#~ msgid ""
+#~ "is invalid\n"
+#~ "%s"
+#~ msgstr ""
+#~ "åßíáé ëáíèáóìÝíç\n"
+#~ "%s"
+#~ msgstr "ÐáôÞóôå RETURN ãéá óõíÝ÷åéá -->"
+#~ msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
+#~ msgstr "Ìç åðéôñåðôü üíïìá. äåí ìðïñåß íá åßíáé '.' Þ 'NULL'\n"
+#~ msgstr "Ìç åðéôñåðôü üíïìá áñ÷åßïõ. Ï ÷áñáêôÞñáò <%c> äåí åðéôñÝðåôáé.\n"
+#~ msgstr "ÐÜñá ðïëëÝò êáôçãïñéïðïéÞóåéò ãéá [%s in %s]"
+#~ msgstr ""
+#~ "ìç áðïäåêôü öïñìÜô êáôçãïñéïðïÞóåùí óôï êåöáëéêü áñ÷åßï ãéá [%s in %s]"
+#~ msgstr "Áäõíáìßá äçìéïõñãßáò áñ÷åßïõ åîÜñôçóçò ãéá óôï [%s in %s]"
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different projection than current region. Found "
+#~ "raster map <%s@%s>, should be <%s>."
+#~ msgstr ""
+#~ "Ï ñÜóôåñ ÷Üñôçò <%s@%s> Ý÷åé äéáöïñåôéêÞ ðñïâïëÞ áðü ôçí ôñÝ÷ïõóá "
+#~ "ðåñéï÷Þ. Ï ÷Üñôçò <%s@%s>, èá Ýðñåðå íá Þôáí <%s>."
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr ""
+#~ "Ï ñÜóôåñ ÷Üñôçò <%s@%s> Ý÷åé äéáöïñåôéêÞ æþíç (%d) áðü ôçí ôñÝ÷ïõóá "
+#~ "ðåñéï÷Þ (%d)"
+#~ msgstr "Ï ñÜóôåñ ÷Üñôçò <%s@%s>: Ý÷åé bytes per cell (%d) ðïëý ìåãÜëï"
+#~ msgid ""
+#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr ""
+#~ "Ï ÷Üñôçò <%s@%s> åßíáé Ýíáò óýíäåóìïò GDAL áëëÜ ôï GRASS Ý÷åé ãßíåé "
+#~ "compiled ÷ùñßò GDAL õðïóôÞñéîç"
+#~ msgid "G__open_raster_new(): no temp files available"
+#~ msgstr "G__open_raster_new(): äåí õðÜñ÷ïõí ðñïóùñéíÜ áñ÷åßá, ìç äéáèÝóéìá"
+#~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+#~ msgstr "G_set_fp_type(): ìðïñåß íá êáëåóôåß ìüíï ìå FCELL_TYPE Þ DCELL_TYPE"
+#~ msgstr "Áäõíáìßá åýñåóçò '%s' óå '%s'"
+#~ msgid ""
+#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr ""
+#~ "G_set_quant_rules() ìðïñåß íá êëçèåß ìüíï ãéá ñÜóôåñ ÷Üñôåò áíïéêôïýò ãéá "
+#~ "áíÜãíùóç"
+#~ msgstr "Äåí õðÜñ÷åé êåßìåíï âïÞèåéáò ãéá ôçí åíôïëÞ [%s]\n"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò êåöáëéêïý áñ÷åßïõ ãéá ñÜóôåñ ÷Üñôç <%s@%s>."
+#~ msgid "can't write history information for [%s]"
+#~ msgstr "äåí åßíáé äõíáôÞ ç åããñáöÞ ôïõ éóôïñéêïý ãéá [%s]"
+#~ msgid "Not enough room in history file to record command line."
+#~ msgstr ""
+#~ "Äåí õðÜñ÷åé áñêåôüò ÷þñïò óôï áñ÷åßï éóôïñéêïý ãéá åããñáöÞ åíôïëÞò ãñáììÞò"
+#~ msgid "Not enough room in history file for command line (truncated)."
+#~ msgstr "Not enough room in history file to record command line (ðåñéêïðÞ)."
+#~ msgid "Unknown command: %d last: %d"
+#~ msgstr "¶ãíùóôç åíôïëÞ: %d last: %d"
+#~ msgid ""
+#~ "Unable to build spatial index from topology, vector map is not opened at "
+#~ "topo level 2"
+#~ msgstr ""
+#~ "Áäõíáìßá äçìéïñãßáò ÷ùñéêïý ðßíáêá áðü ôçí ôïðïëïãßá, ï äéáíõóìáôéêüò "
+#~ "÷Üñôçò äåí åßíáé áíïéêôüò óôï topo level 2"
+#~ msgstr ""
+#~ "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí, ï ÷Üñôçò äåí åßíáé áíïéêôüò óå "
+#~ "êáôÜóôáóç åããñáöÞò (WRITE mode)"
+#~ msgstr "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí"
+#~ msgid ""
+#~ "excess)"
+#~ msgstr ""
+#~ "Ôá áñ÷åßá óõíôåôáãìÝíùí (coor) ôùí äéáíõóìáôéêþí ÷áñôþí <%s@%s> åßíáé "
+#~ "ìåãáëýôåñá áðü üóï èá Ýðñåðå (%ld bytes excess)"
+#~ msgid ""
+#~ "missing)."
+#~ msgstr ""
+#~ "ìéêñüôåñá áðü üóï èá Ýðñåðå (%ld bytes missing)."
+#, fuzzy
+#~ msgstr "¶ëëç ðñïâïëÞ"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò åðéðÝäïõ <%s>"
+#~ msgid "OGR feature without ID ignored"
+#~ msgstr "OGR ÷áñáêôçñéóôéêü ÷ùñßò ID áãíïåßôáé"
+#~ msgid "test, gpde"
+#~ msgstr "äïêéìÞ, gpde"
+#~ msgid ""
+#~ "taking too long to find points for interpolation--please change the "
+#~ "region to area where your points are. Continuing calculations..."
+#~ msgstr ""
+#~ "Ðáßñíåé ðÜñá ðïëý ÷ñüíï íá âñù ôá óçìåßá ãéá ðáñåìâïëÞ -- ðáñáêáëþ "
+#~ "áëëÜîôå ôçí ðåñéï÷Þ óå ìßá Üëëç ðïõ íá âñßóêïíôáé ôá óçìåßá óáò. Óõíå÷ßæù "
+#~ "ôïõò õðïëïãéóìïýò..."
+#~ msgid "Reading lines from vector map ... "
+#~ msgstr "ÄéáâÜæù ãñáììÝò áðü ôïí äéáíõóìáôéêü ÷Üñôç..."
+#~ msgid "Reading nodes from vector map ... "
+#~ msgstr "ÄéáâÜæù ôïõò êüìâïõò áðü ôïí äéáíõóìáôéêü ÷Üñôç..."
+#~ msgid "strip exists with insufficient data"
+#~ msgstr "strip õðÜñ÷åé ìå áíåðáñêÞ äåäïìÝíá"
+#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
+#~ msgstr ""
+#~ "õðÜñ÷ïõí óçìåßá Ýîù áðü ôçí êáèïñéóìÝíç 2Ä/3Ä ðåñéï÷Þ --áãíïïýíôáé %d "
+#~ "óçìåßá"
+#~ msgid "ignoring %d points -- too dense"
+#~ msgstr "áãíïïýíôáé %d óçìåßá -- ðïëý ðõêíÜ"
+#~ msgid "some points outside of region -- will ignore..."
+#~ msgstr "êÜðïéá óçìåßá Ýîù áðü ôçí ðåñéï÷Þ -- èá áãíïçèïýí..."
+#~ msgstr "Áäõíáìßá äéáãñáöÞò óôñþìá/êáôçãïñßá %d/%d ãñáììÞ %d"
+#, fuzzy
+#~ msgid "All vertices"
+#~ msgstr "¼ëá ôá óçìåßá (vertices)"
+#~ msgid "Breaks"
+#~ msgstr "\"Óðáóßìáôá\" (breaks)"
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_es.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -1543,7 +1543,7 @@
#: ../lib/gis/spawn.c:416
#, fuzzy, c-format
msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: no es posible duplicar el descriptor %d a %d"
+msgstr "G_spawn: No es posible duplicar el descriptor de %d a %d."
#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:609
#, c-format
@@ -6105,106 +6105,105 @@
"siguientes mapas raster:\n"
#, fuzzy
-#~ msgstr ""
-#~ "Memoria insuficiente en el historial para guardar la línea de comando."
+msgstr "Memoria insuficiente en el historial para guardar la línea de comando."
#, fuzzy
-#~ msgstr ""
-#~ "Memoria insuficiente en el historial para guardar la línea de comando "
-#~ "(truncada)."
+msgstr ""
+"Memoria insuficiente en el historial para guardar la línea de comando "
+"(truncada)."
-#~ msgstr ""
-#~ "Coordenadas de posición de visualización no válidas, utilizando %f,%f."
-#~ msgstr "Locación desconocida."
#, fuzzy
-#~ msgid "quantization file [%s] in mapset [%s] %s"
-#~ msgstr ""
-#~ "El archivo de cuantización [%s] en el directorio de mapas (mapset) [%s]%s."
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Keywords:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Palabras clave:\n"
+msgid ""
+"\n"
+"Keywords:\n"
+msgstr ""
+"\n"
+"Palabras clave:\n"
-#~ msgid ""
-#~ "\n"
-#~ "Flags:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Opciones:\n"
-#~ msgid ""
-#~ "\n"
-#~ "Parameters:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Parámetros:\n"
#, fuzzy
-#~ msgstr "mapa [%s] - no es posible escribir en la fila %d"
+msgstr "mapa [%s] - no es posible escribir en la fila %d"
#, fuzzy
-#~ msgstr "Error al escribir un archivo del tipo flotante en el mapa %s"
+msgstr "Error al escribir un archivo del tipo flotante en el mapa %s"
#, fuzzy
-#~ msgstr "No se puede actualizar el formato OGR"
+msgstr "No se puede actualizar el formato OGR"
#, fuzzy
-#~ msgstr "No se puede escribir el razgo, el mapa vectorial no está abierto."
+msgstr "No se puede escribir el razgo, el mapa vectorial no está abierto."
#, fuzzy
-#~ msgstr "No se puede crear un nuevo proceso"
+msgstr "No se puede crear un nuevo proceso"
#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "región para directorio de mapas actual %s\n"
-#~ "ejecute \"g.region\""
+msgid ""
+msgstr ""
+"región para directorio de mapas actual %s\n"
+"ejecute \"g.region\""
#, fuzzy
-#~ msgstr "región por defecto %s"
+msgstr "región por defecto %s"
#, fuzzy
-#~ msgstr "No es posible establecer el foco."
+msgstr "No es posible establecer el foco."
#, fuzzy
-#~ msgstr "Problema al leer el mapa ráster"
+msgstr "Problema al leer el mapa ráster"
#, fuzzy
-#~ msgstr "No es posible leer el archivo de color del mapa raster <%s>"
+msgstr "No es posible leer el archivo de color del mapa raster <%s>"
#, fuzzy
-#~ msgstr "No se puede copiar la tabla <%s>"
+msgstr "No se puede copiar la tabla <%s>"
#, fuzzy
-#~ msgstr "No se puede inicializar pj causa: %s"
+msgstr "No se puede inicializar pj causa: %s"
+#~ msgstr ""
+#~ "Coordenadas de posición de visualización no válidas, utilizando %f,%f."
+#~ msgid "Unknown Location"
+#~ msgstr "Locación desconocida."
+#~ msgid "quantization file [%s] in mapset [%s] %s"
+#~ msgstr ""
+#~ "El archivo de cuantización [%s] en el directorio de mapas (mapset) [%s]%s."
+#~ msgid ""
+#~ "\n"
+#~ "Flags:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Opciones:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Parameters:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Parámetros:\n"
#~ msgid "Unable to open raster map <%s>"
#~ msgstr "No ha sido posible abrir el mapa raster <%s>."
@@ -7156,3 +7155,84 @@
#, fuzzy
#~ msgstr "No se puede encontrar o abrir el símbolo '%s'"
+#~ msgstr "Probablemente un error en el programa."
+#~ msgstr "No se puede abrir el archivo temporal."
+#~ msgstr "Problema leyendo el mapa raster."
+#~ msgstr "El rango de datos flotantes para %s@%s está vacío."
+#~ msgstr "El rango de datos enteros para %s@%s esta vacío."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Proyección no válida.\n"
+#~ msgstr ""
+#~ "Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
+#~ msgstr "Nombre del mapa raster de elevación."
+#~ msgstr "Nombre(s) del (los) mapa(s) raster de elevación."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Descripción:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Palabras clave:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Uso:\n"
+#~ msgstr "Aceptar el valor predeterminado."
+#~ msgstr "Presione ENTER para continuar. -->"
+#~ msgstr "No hay ayuda disponible para el comando [%s].\n"
+#~ msgstr "No ha sido posible añadir el enlace a la base de datos."
+#~ msgid ""
+#~ "excess)"
+#~ msgstr ""
+#~ "El archivo de coordenadas del mapa vectorial <%s@%s> es mayor de lo que "
+#~ "debiera (%ld bytes de exceso)."
+#~ msgid ""
+#~ "missing)."
+#~ msgstr ""
+#~ "El archivo de coordenadas del mapa vectorial <%s@%s> es menor de lo que "
+#~ "debería ser (faltan %ld bytes)."
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_fr.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -751,7 +751,7 @@
#: ../lib/raster/color_rules.c:268
#, fuzzy, c-format
msgid "Unable to load color rules <%s>"
-msgstr "Impossible de copier la table <%s>"
+msgstr "Impossible d'ouvrir la couche vectorielle <%s>"
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
@@ -5928,7 +5928,7 @@
#, fuzzy, c-format
-msgstr "Impossible d'ouvrir le fichier %s dans %s"
+msgstr "Impossible d'ouvrir le fichier [%s] du groupe [%s de %s]"
#, fuzzy, c-format
@@ -6000,24 +6000,74 @@
msgstr ""
#, fuzzy
-#~ msgstr ""
-#~ "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la "
-#~ "ligne de commande"
+msgstr ""
+"Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne "
+"de commande"
#, fuzzy
-#~ msgstr ""
-#~ "ligne de commande (tronquée)"
+msgstr ""
+"de commande (tronquée)"
+#, fuzzy
+#, fuzzy
+msgstr "couche [%s] - impossible d'écrire la ligne %d"
+#, fuzzy
+msgstr ""
+"Erreur lors de l'écriture en virgule flottante dans le fichier au format de "
+"la couche %s"
+#, fuzzy
+msgstr "Impossible d'écrire la ligne, la couche n'est pas ouverte"
+#, fuzzy
+msgstr "Impossible de créer un nouveau processus"
+#, fuzzy
+msgid ""
+msgstr ""
+"région pour le jeu de données (mapset) courant %s\n"
+"lancer \"g.region\""
+#, fuzzy
+msgstr "région par défaut %s"
+#, fuzzy
+msgstr "Allocation mémoire impossible\n"
+#, fuzzy
+msgstr "Problème de lecture du fichier de cellules raster"
+#, fuzzy
+msgstr ""
+"Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
+#, fuzzy
+msgstr "Impossible de copier la table <%s>"
+#, fuzzy
+msgstr "Impossible d'initialiser pj cause : %s"
#~ msgstr "Secteur (Location) inconnu"
-#, fuzzy
#~ msgstr ""
#~ "fichier de quantification [%s] dans le jeu de données (mapset) [%s] %s"
@@ -6051,10 +6101,6 @@
#~ msgstr "Impossible d'écrire la ligne matricielle %i"
#, fuzzy
-#~ msgstr "couche [%s] - impossible d'écrire la ligne %d"
-#, fuzzy
#~ msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
@@ -6075,12 +6121,6 @@
#~ "de la couche %s"
#, fuzzy
-#~ msgstr ""
-#~ "Erreur lors de l'écriture en virgule flottante dans le fichier au format "
-#~ "de la couche %s"
-#, fuzzy
#~ msgstr "Impossible de créer l'en-tête de fichier pour [%s dans %s]"
@@ -6103,14 +6143,6 @@
#~ msgstr "Impossible de créer la couche vectorielle <%s>"
-#, fuzzy
-#~ msgstr "Impossible d'écrire la ligne, la couche n'est pas ouverte"
-#, fuzzy
-#~ msgstr "Impossible de créer un nouveau processus"
#~ msgstr "Trop d'arguments"
@@ -6133,17 +6165,6 @@
#~ msgid "line %d: <%s>"
#~ msgstr "ligne %d : <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "région pour le jeu de données (mapset) courant %s\n"
-#~ "lancer \"g.region\""
-#, fuzzy
-#~ msgstr "région par défaut %s"
#~ msgid "is not set"
#~ msgstr "n'est pas définie"
@@ -6154,19 +6175,6 @@
#~ "est invalide\n"
#~ "%s"
-#, fuzzy
-#~ msgstr "Allocation mémoire impossible\n"
-#, fuzzy
-#~ msgstr "Problème de lecture du fichier de cellules raster"
-#, fuzzy
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
#~ msgid "Vector is not 3D"
#~ msgstr "Le vecteur n'est pas 3D"
@@ -6357,14 +6365,6 @@
#~ msgstr "Impossible d'ouvrir la base de données %s"
-#, fuzzy
-#~ msgstr "Impossible de copier la table <%s>"
-#, fuzzy
-#~ msgstr "Impossible d'initialiser pj cause : %s"
#~ msgstr "Impossible de décrire la table <%s>"
@@ -7028,3 +7028,316 @@
#~ msgstr ""
#~ "Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en "
#~ "niveau 2"
+#~ msgstr "Allocation mémoire impossible\n"
+#~ msgstr "Probablement erreur de programmation."
+#~ msgstr "Impossible d'ouvrir le fichier %s"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Problème de lecture du fichier de cellules raster"
+#~ msgstr "La couche raster %s@%s est vide"
+#~ msgstr ""
+#~ "Impossible d'écrire les règles de quantité : la couche %s est un entier"
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window() : projection/zone diffèrent de ceux présents dans le "
+#~ "fichier matriciel actuellement ouvert"
+#~ msgstr "L'intervalle de nombre en virgule flottante pour %s@%s est vide"
+#~ msgstr "L'intervalle des données entières pour %s@%s est vide"
+#~ msgstr "%s : couche [%s] non ouverte en écriture - demande ignorée"
+#~ msgstr "%s : descripteur de fichier non ouvert - demande ignorée"
+#~ msgstr "couche [%s] - impossible d'écrire la ligne %d"
+#~ msgstr "impossible de trouver un fichier temporaire null %s"
+#~ msgstr "erreur lors de l'écriture d'une ligne nulle %d"
+#~ msgstr ""
+#~ "support de la catégorie [%s] dans le jeu de données (mapset) [%s] %s"
+#~ msgstr ""
+#~ "support de la catégorie pour le fichier vecteur [%s] dans le jeu de "
+#~ "données (mapset) [%s] %s"
+#~ msgstr "Impossible d'ouvrir le fichier temporaire"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "projection invalide\n"
+#~ msgstr "EmbedGivenNulls : mauvais type de donnée!"
+#~ msgstr "Veuillez avertir les développeurs GRASS de cette erreur.\n"
+#~ msgstr "G_set_null_value : mauvais type de donnée!"
+#~ msgstr "Nom de la couche matricielle d'élévation"
+#~ msgstr "Nom de(s) couche(s) matricielle(s) d'élévation"
+#~ msgstr "Numéro de la couche"
+#~ msgid ""
+#~ msgstr ""
+#~ "Une seule carte vectorielle peut être connectée à plusieurs tables de "
+#~ "base de données. Ce nombre détermine la table à utiliser."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Description :\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Mots-clés :\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Utilisation :\n"
+#~ msgstr " options : %s\n"
+#~ msgstr "pour accepter le choix par défaut"
+#~ msgstr ""
+#~ "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
+#~ msgstr ""
+#~ "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est "
+#~ "invalide dans le jeu de données (mapset) %s"
+#~ msgstr ""
+#~ "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s "
+#~ "dans le jeu de données (mapset) %s"
+#, fuzzy
+#~ msgstr ""
+#~ "erreur en lisant la couche compressée [%s] dans le jeu de données [%s], "
+#~ "ligne %d"
+#, fuzzy
+#~ msgstr ""
+#~ "erreur en lisant la couche [%s] dans le jeu de données [%s], ligne %d"
+#~ msgstr "impossible d'obtenir le répertoire de l'utilisateur"
+#~ msgstr "Impossible de créer le fichier d'en-tête pour [%s]"
+#~ msgid ""
+#~ "region for current mapset %s\n"
+#~ "run \"g.region\""
+#~ msgstr ""
+#~ "région pour le jeu de données (mapset) courant %s\n"
+#~ "lancer \"g.region\""
+#~ msgid "default region %s"
+#~ msgstr "région par défaut %s"
+#~ msgstr "pressez RETOUR pour continuer -->"
+#~ msgstr "Nom de fichier illégal. Ne peut pas être '.' ou 'NULL'\n"
+#~ msgstr "Nom de fichier illégal. Caractère <%c> interdit.\n"
+#~ msgstr "Trop de catégories de reclassification pour [%s dans %s]"
+#~ msgstr ""
+#~ "Format de reclassification illégal dans l'en-tête de fichier pour [%s "
+#~ "dans %s]"
+#~ msgstr "Impossible de créer le fichier de dépendances dans [%s dans %s]"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "[%s] dans le jeu de données (mapset) [%s] - est dans une projection "
+#~ "différente par rapport à la région courante :\n"
+#~ " la couche [%s] dans: <%s>, devrait être <%s> "
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente "
+#~ "[%d] de celle de la région courante [%d]"
+#, fuzzy
+#~ msgstr "[%s] dans [%s] - octets par cellule (%d) trop grand"
+#, fuzzy
+#~ msgstr "impossible de trouver [%s] dans [%s]"
+#~ msgstr "Aucune aide disponible pour la commande [%s]\n"
+#~ msgstr "impossible d'écrire l'historique pour [%s]"
+#~ msgstr ""
+#~ "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la "
+#~ "ligne de commande"
+#~ msgstr ""
+#~ "ligne de commande (tronquée)"
+#, fuzzy
+#~ msgstr ""
+#~ "Impossible d'ajouter un lien base de données, la couche n'est pas ouverte "
+#~ "en ECRITURE."
+#, fuzzy
+#~ msgstr "Impossible d'ajouter un lien base de données."
+#~ msgstr "Erreur dans la règle à la ligne %d dans %s"
+#, fuzzy
+#~ msgstr "Autre projection"
+#~ msgstr "Le programmeur a demandé un open level inconnu %d"
+#, fuzzy
+#, fuzzy
+#~ msgstr "L'objet OGR sans ID a été ignoré"
+#, fuzzy
+#~ msgstr "Impossible de créer la couche vectorielle <%s>"
+#~ msgstr "test, gpde"
+#~ msgid ""
+#~ msgstr ""
+#~ "la recherche de points pour l'interpolation prend trop de temps -- "
+#~ "veuillez changer la régionpour la zone où se trouvent vos points. Les "
+#~ "calculs se poursuivent..."
+#~ msgstr "Lignes de lecture de la carte vectorielle..."
+#, fuzzy
+#~ msgstr "la bande existe avec des données insuffisantes"
+#~ msgstr ""
+#~ "il y a des points en-dehors de la région 2D/3D spécifiée -- %d points "
+#~ "ignorés"
+#~ msgstr "%d points ignorés -- trop dense"
+#~ msgstr "certains points sont en dehors de la région -- ignorés..."
+#, fuzzy
+#~ msgstr "Impossible de supprimer la couche vectorielle <%s>"
+#~ msgstr "Impossible de trouver la couche d'entrée '%s'"
+#~ msgid "Column type not supported"
+#~ msgstr "Le type de colonne n'est pas supporté"
+#~ msgstr "Impossible de réécrire la ligne"
+#, fuzzy
+#~ msgstr "aucun fichier %s disponible\n"
+#~ msgid "Snapped vertices"
+#~ msgstr "Sommets cassés"
+#~ msgid "New vertices"
+#~ msgstr "Nouveaux sommets"
Modified: grass/trunk/locale/po/grasslibs_hi.po
--- grass/trunk/locale/po/grasslibs_hi.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_hi.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2524,7 +2524,7 @@
#, fuzzy
-msgstr "n"
+msgstr "à¤à¤¾"
@@ -5736,6 +5736,51 @@
msgstr ""
#, fuzzy
+msgstr "नहà¥à¤"
+#, fuzzy
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgstr "हॠनहà¥à¤"
+#, fuzzy
+msgstr "a"
+#, fuzzy
+msgid ""
+msgstr "à¤à¥ लिठà¤à¥"
+#, fuzzy
+msgstr "डिफ़à¥à¤²à¥à¤ हॠनहà¥à¤ सà¥à¤"
+#, fuzzy
+msgstr "à¤à¤¾"
+#, fuzzy
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgstr "à¤à¤¾"
+#, fuzzy
+msgstr "à¤à¤¾"
+#, fuzzy
#~ msgid ""
#~ "\n"
#~ "Flags:\n"
@@ -5764,10 +5809,6 @@
#~ msgstr "a"
#, fuzzy
-#~ msgstr "नहà¥à¤"
-#, fuzzy
#~ msgstr "à¤à¥ लिà¤"
@@ -5784,10 +5825,6 @@
#~ msgstr "a"
#, fuzzy
-#~ msgstr "à¤à¥ लिà¤"
-#, fuzzy
@@ -5804,14 +5841,6 @@
#, fuzzy
-#~ msgstr "हॠनहà¥à¤"
-#, fuzzy
-#~ msgstr "a"
-#, fuzzy
#~ msgid "Unable to open file %s in <%s>"
#~ msgstr "à¤à¤¾"
@@ -5832,15 +5861,6 @@
#~ msgstr "à¤à¤¾"
#, fuzzy
-#~ msgid ""
-#~ msgstr "à¤à¥ लिठà¤à¥"
-#, fuzzy
-#~ msgstr "डिफ़à¥à¤²à¥à¤ हॠनहà¥à¤ सà¥à¤"
-#, fuzzy
#~ msgstr "हॠनहà¥à¤ सà¥à¤"
@@ -5851,18 +5871,6 @@
#~ msgstr "हॠà¤
वà¥à¤§ n"
#, fuzzy
-#~ msgstr "à¤à¤¾"
-#, fuzzy
-#, fuzzy
-#, fuzzy
#~ msgstr "सदिश हॠनहà¥à¤"
@@ -5972,14 +5980,6 @@
#~ msgstr "लिà¤à¤ ."
#, fuzzy
-#~ msgstr "à¤à¤¾"
-#, fuzzy
-#~ msgstr "à¤à¤¾"
-#, fuzzy
#~ msgid "ERROR %s from graphics driver.\n"
#~ msgstr "तà¥à¤°à¥à¤à¤¿ n"
@@ -6515,3 +6515,246 @@
#~ "\n"
#~ "**<%s> illegal name **\n"
#~ msgstr "n n"
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "à¤à¥ लिà¤"
+#, fuzzy
+#~ msgstr "हà¥"
+#, fuzzy
+#~ msgstr "हà¥"
+#, fuzzy
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr "à¤à¥ सà¥à¤ à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¥ लिठहà¥"
+#, fuzzy
+#, fuzzy
+#~ msgstr "तà¥à¤°à¥à¤à¤¿"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "à¤à¤¾ तà¥à¤°à¥à¤à¤¿ n"
+#, fuzzy
+#~ msgstr "à¤à¥ सà¥à¤!"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "सà¤à¤à¥à¤¯à¤¾"
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr "n "
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¥ लिठà¤à¥"
+#, fuzzy
+#~ msgstr "फ़ाà¤à¤²à¤¨à¤¾à¤® n"
+#, fuzzy
+#~ msgstr "फ़ाà¤à¤²à¤¨à¤¾à¤® नहà¥à¤."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "बाà¤à¤à¥à¤¸ बड़ा"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "नहà¥à¤ à¤à¥ लिठn"
+#, fuzzy
+#, fuzzy
+#~ msgstr "लिà¤à¤ हॠनहà¥à¤."
+#, fuzzy
+#~ msgstr "लिà¤à¤ ."
+#, fuzzy
+#~ msgstr "तà¥à¤°à¥à¤à¤¿ à¤à¤¾à¤²à¥"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¥à¤¤à¤¾à¤µà¤¨à¥ n"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "विशà¥à¤·à¤¤à¤¾."
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¥ लिà¤."
+#, fuzzy
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#, fuzzy
+#~ msgstr "नà¤à¤¼à¤²"
+#, fuzzy
+#~ msgstr "à¤à¥ लिठn"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr "हॠनहà¥à¤ à¤à¤¾à¤²à¥"
+#, fuzzy
+#~ msgid ""
+#~ msgstr "हॠनहà¥à¤"
+#, fuzzy
+#, fuzzy
+#~ msgid "Cannot get field info"
+#, fuzzy
+#~ msgstr "विशà¥à¤·à¤¤à¤¾ नहà¥à¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_it.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5817,372 +5817,372 @@
msgstr ""
-#~ msgstr "Posizione sconosciuta"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Keywords:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Parole chiave:\n"
+msgid ""
+"\n"
+"Keywords:\n"
+msgstr ""
+"\n"
+"Parole chiave:\n"
#, fuzzy
-#~ msgstr "mappa [%s] - impossibile scrivere nella riga %d"
+msgstr "mappa [%s] - impossibile scrivere nella riga %d"
#, fuzzy
-#~ msgstr "Errore scrivendo file di formato virgola mobile per mappa %s"
+msgstr "Errore scrivendo file di formato virgola mobile per mappa %s"
#, fuzzy
-#~ msgstr "Non riesco a scrivere la linea, la mappa non è aperta"
+msgstr "Non riesco a scrivere la linea, la mappa non è aperta"
#, fuzzy
-#~ msgstr "impossibile creare un nuovo processo"
+msgstr "impossibile creare un nuovo processo"
#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "regione del mapset in uso %s\n"
-#~ "esegui \"g.region\""
+msgid ""
+msgstr ""
+"regione del mapset in uso %s\n"
+"esegui \"g.region\""
#, fuzzy
-#~ msgstr "regione predefinita %s"
+msgstr "regione predefinita %s"
#, fuzzy
-#~ msgstr "Impossibile aprire %s"
+msgstr "Impossibile aprire %s"
#, fuzzy
-#~ msgstr "problemi leggendo il file di cellule raster"
+msgstr "problemi leggendo il file di cellule raster"
#, fuzzy
-#~ msgstr "Impossibile creare il file di intestazione per [%s in %s]"
+msgstr "Impossibile creare il file di intestazione per [%s in %s]"
#, fuzzy
-#~ msgstr "Linee registrate: "
+msgstr "Linee registrate: "
#, fuzzy
#, fuzzy
#, fuzzy
-#~ msgstr "duplicato campo est"
+msgid "Duplicates"
+msgstr "duplicato campo est"
-#~ msgid "Type"
-#~ msgstr "Tipo"
+msgid "Type"
+msgstr "Tipo"
-#~ msgstr "G_malloc: fuori memoria"
+msgstr "G_malloc: fuori memoria"
-#~ msgstr "G_calloc: fuori memoria"
+msgstr "G_calloc: fuori memoria"
-#~ msgstr "G_realloc: fuori memoria"
+msgstr "G_realloc: fuori memoria"
#, fuzzy
-#~ msgstr "Non posso cancellare la linea"
+msgstr "Non posso cancellare la linea"
#, fuzzy
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgstr "Non posso scrivere i collegamenti del database"
#, fuzzy
-#~ msgstr "Impossibile aprire il file %s in %s"
+msgstr "Impossibile aprire il file %s in %s"
#, fuzzy
#, fuzzy
#, fuzzy
-#~ msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
+msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
-#~ msgstr "Il nome '%s' in output non è un nome di raster valido."
+msgstr "Il nome '%s' in output non è un nome di raster valido."
-#~ msgstr "La mappa '%s' in output è utilizzata come input"
+msgstr "La mappa '%s' in output è utilizzata come input"
-#~ msgstr "impossibile aprire un raster [%s in %s]"
+msgstr "impossibile aprire un raster [%s in %s]"
-#~ msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
+msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
-#~ msgstr "Non riesco ad aprire il file di intestazione per [%s in %s]"
+msgstr "Non riesco ad aprire il file di intestazione per [%s in %s]"
#, fuzzy
#, fuzzy
-#~ msgstr "Creazione topologia...\n"
+msgstr "Creazione topologia...\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "\r%d aree create \n"
-#~ "%d isole create\n"
+msgid ""
+"%d isles built\n"
+msgstr ""
+"\r%d aree create \n"
+"%d isole create\n"
#, fuzzy
-#~ msgstr "Vect_rewrite_line() non supportato per questo formato/livello"
+msgstr "Vect_rewrite_line() non supportato per questo formato/livello"
-#~ msgstr "Vect_delete_line() non supportato per questo formato/livello"
+msgstr "Vect_delete_line() non supportato per questo formato/livello"
#, fuzzy
-#~ msgid "Cannot delete line"
-#~ msgstr "Non riesco a riscrivere la linea"
+msgid "Cannot delete line"
+msgstr "Non riesco a riscrivere la linea"
-#~ msgstr "Il nome '%s' in output non è valido per un vettore."
+msgstr "Il nome '%s' in output non è valido per un vettore."
-#~ msgstr "Non posso copiare il vettore '%s' nel '%s'"
+msgstr "Non posso copiare il vettore '%s' nel '%s'"
#, fuzzy
-#~ msgstr "Non posso cancellare il vettoriale %s"
+msgstr "Non posso cancellare il vettoriale %s"
#, fuzzy
-#~ msgstr "Non posso aprire il nuovo vettoriale %s"
+msgstr "Non posso aprire il nuovo vettoriale %s"
-#~ msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
+msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
-#~ msgstr "Non riesco a trovare il file \"%s\""
+msgstr "Non riesco a trovare il file \"%s\""
#, fuzzy
-#~ msgstr "Non riesco ad aprire il vecchio vettoriale %s"
+msgstr "Non riesco ad aprire il vecchio vettoriale %s"
-#~ msgstr "%s - ** nome illegale **"
+msgstr "%s - ** nome illegale **"
-#~ msgstr "Non trovo un monitor grafico per <%s>.\n"
+msgstr "Non trovo un monitor grafico per <%s>.\n"
-#~ msgstr ""
-#~ "Per piacere avvia \"d.mon\" per selezionare un monitor grafico valido.\n"
+msgstr ""
+"Per piacere avvia \"d.mon\" per selezionare un monitor grafico valido.\n"
#, fuzzy
-#~ msgstr "Non è possibile trovare %s\n"
+msgstr "Non è possibile trovare %s\n"
-#~ msgstr "Errore - Monitor <%s> in uso.\n"
+msgstr "Errore - Monitor <%s> in uso.\n"
-#~ msgstr "Errore - il Monitor <%s> è in uso da %s.\n"
+msgstr "Errore - il Monitor <%s> è in uso da %s.\n"
-#~ msgstr ""
-#~ "Errore - non riesco a completare il blocco del processo per il monitor <%"
-#~ "s>.\n"
+msgstr ""
+"Errore - non riesco a completare il blocco del processo per il monitor <%"
+"s>.\n"
-#~ msgstr "Errore - non riesco a creare una pipe al dispositivo grafico.\n"
+msgstr "Errore - non riesco a creare una pipe al dispositivo grafico.\n"
-#~ msgstr "Errore -il monitor grafico <%s> non è stato avviato!\n"
+msgstr "Errore -il monitor grafico <%s> non è stato avviato!\n"
-#~ msgstr "Per piacere avvia il monitor grafico <%s>.\n"
+msgstr "Per piacere avvia il monitor grafico <%s>.\n"
-#~ msgstr "Non connesso...\n"
+msgstr "Non connesso...\n"
-#~ msgstr "Non riesco a collegarmi al monitor. Provo a farlo ancora.\n"
+msgstr "Non riesco a collegarmi al monitor. Provo a farlo ancora.\n"
#, fuzzy
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "Dimensione della cella delle mappe in fp = %d\n"
+msgid "Size of cell in fp maps = %d"
+msgstr "Dimensione della cella delle mappe in fp = %d\n"
#, fuzzy
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr "per mappe raster presenti %d\n"
+msgid "type for writing floating maps = %d"
+msgstr "per mappe raster presenti %d\n"
#, fuzzy
-#~ msgid "current window = %p"
-#~ msgstr "finestra corrente = %p\n"
+msgid "current window = %p"
+msgstr "finestra corrente = %p\n"
#, fuzzy
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Flag: finestra scelta? %d\n"
+msgid "Flag: window set? %d"
+msgstr "Flag: finestra scelta? %d\n"
#, fuzzy
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Descrizione del file per la maschera automatica %d\n"
+msgid "File descriptor for automatic mask %d"
+msgstr "Descrizione del file per la maschera automatica %d\n"
#, fuzzy
-#~ msgid "Flag denoting automatic masking %d"
+msgid "Flag denoting automatic masking %d"
#, fuzzy
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "CELL maschera del buffer %p\n"
+msgid "CELL mask buffer %p"
+msgstr "CELL maschera del buffer %p\n"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "buffer di lettura delle righe vuote %p"
+msgid "buffer for reading null rows %p"
+msgstr "buffer di lettura delle righe vuote %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Buffer di dati pre/post compressi %p"
+msgid "Pre/post compressed data buffer %p"
+msgstr "Buffer di dati pre/post compressi %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "dimensione del compressed_buf %d"
+msgid "sizeof compressed_buf %d"
+msgstr "dimensione del compressed_buf %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "work data buffer %p"
+msgid "work data buffer %p"
+msgstr "work data buffer %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "dimensione del work_buf %d"
+msgid "sizeof work_buf %d"
+msgstr "dimensione del work_buf %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "dimensione null_buf %d"
+msgid "sizeof null_buf %d"
+msgstr "dimensione null_buf %d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "dimensione mask_buf %d"
+msgid "sizeof mask_buf %d"
+msgstr "dimensione mask_buf %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "Istogramma richiesto %d"
+msgid "Histogram request %d"
+msgstr "Istogramma richiesto %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: file #%d"
+msgid "G_dump: file #%d"
+msgstr "G_dump: file #%d"
-#~ msgid "open mode = %d"
-#~ msgstr "modalità di apertura = %d"
+msgid "open mode = %d"
+msgstr "modalità di apertura = %d"
-#~ msgid "Cell header %p"
-#~ msgstr "Intestazione cella %p"
+msgid "Cell header %p"
+msgstr "Intestazione cella %p"
#, fuzzy
-#~ msgid "Table reclass %p"
-#~ msgstr "Tabella di riclassificazione %p\n"
+msgid "Table reclass %p"
+msgstr "Tabella di riclassificazione %p\n"
#, fuzzy
-#~ msgid "Cell stats %p"
-#~ msgstr "Intestazione cella %p\n"
+msgid "Cell stats %p"
+msgstr "Intestazione cella %p\n"
#, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "Struttura intervallo %p\n"
+msgid "Range structure %p"
+msgstr "Struttura intervallo %p\n"
#, fuzzy
-#~ msgid "float Range structure %p"
+msgid "float Range structure %p"
#, fuzzy
-#~ msgid "want histogram? %d"
-#~ msgstr "vuoi un istogramma? %d\n"
+msgid "want histogram? %d"
+msgstr "vuoi un istogramma? %d\n"
#, fuzzy
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "nbyte per cella nella riga corrente %d\n"
+msgid "nbytes per cell for current row %d"
+msgstr "nbyte per cella nella riga corrente %d\n"
#, fuzzy
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Buffer di dati decompresso %s\n"
+msgid "Decompressed data buffer %s"
+msgstr "Buffer di dati decompresso %s\n"
#, fuzzy
-#~ msgid "bytes per cell %d"
-#~ msgstr "byte per cella %d\n"
+msgid "bytes per cell %d"
+msgstr "byte per cella %d\n"
#, fuzzy
-#~ msgid "type: int, float or double map %d"
-#~ msgstr "tipi: mappa int, float o double %d\n"
+msgid "type: int, float or double map %d"
+msgstr "tipi: mappa int, float o double %d\n"
#, fuzzy
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Nome temporaneo per NUOVI file %s\n"
+msgid "Temporary name for NEW files %s"
+msgstr "Nome temporaneo per NUOVI file %s\n"
#, fuzzy
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Nome temporaneo per NUOVI file VUOTI %s\n"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "Nome temporaneo per NUOVI file VUOTI %s\n"
#, fuzzy
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Mapset del file d'aprire%s\n"
+msgid "Mapset of open file %s"
+msgstr "Mapset del file d'aprire%s\n"
#, fuzzy
-#~ msgid "io error warning given %d"
-#~ msgstr "attenzione ho ricevuto un errore di i/o %d\n"
+msgid "io error warning given %d"
+msgstr "attenzione ho ricevuto un errore di i/o %d\n"
#, fuzzy
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS array[%d] = %p\n"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "NULL_ROWS array[%d] = %p\n"
#, fuzzy
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "buffer di lettura delle righe vuote %p\n"
+msgid "data buffer for reading null rows %p"
+msgstr "buffer di lettura delle righe vuote %p\n"
#, fuzzy
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump: file #%d\n"
+msgid "G_dump: end"
+msgstr "G_dump: file #%d\n"
#, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
#, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
-#~ msgid "Too many open raster maps"
-#~ msgstr "Troppi file raster aperti"
+msgid "Too many open raster maps"
+msgstr "Troppi file raster aperti"
-#~ msgid "Too many open files"
-#~ msgstr "Troppi file aperti"
+msgid "Too many open files"
+msgstr "Troppi file aperti"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ERRORE: GISBASE non definito\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "ERRORE: GISBASE non definito\n"
-#~ msgid "unable to find [%s] in [%s]"
-#~ msgstr "impossibile trovare [%s] in [%s]"
+msgid "unable to find [%s] in [%s]"
+msgstr "impossibile trovare [%s] in [%s]"
+#~ msgstr "Posizione sconosciuta"
#~ msgstr "quantization file [%s] nel mapset [%s] %s"
@@ -6895,3 +6895,42 @@
#~ msgstr "Ignorati %d punti -- densità eccessiva"
+#, fuzzy
+#~ msgid "Unable to open temporary file"
+#~ msgstr "Impossibile aprire il file %s in %s"
+#, fuzzy
+#~ msgid "Problem reading raster map"
+#~ msgstr "problemi leggendo il file di cellule raster"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "proiezione non valida\n"
+#~ msgstr "Per piacere avvisa gli sviluppatori GRASS per questo errore\n"
+#, fuzzy
+#~ msgid "Name of elevation raster map"
+#~ msgstr "Nome della mappa raster in input"
+#, fuzzy
+#~ msgid "Name of elevation raster map(s)"
+#~ msgstr "Nome delle mappe raster in input"
+#~ msgid "to accept the default"
+#~ msgstr "per accettare i valori predefiniti"
+#~ msgstr "premi INVIO per continuare -->"
+#~ msgstr "Nessun aiuto disponibile per il comando [%s]\n"
+#, fuzzy
+#~ msgid "Unable to add database link"
+#~ msgstr "Non riesco ad aggiungere un collegamento database"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_ja.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -13,8 +13,8 @@
"Project-Id-Version: grasslibs_ja\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-08-29 12:41+0200\n"
-"PO-Revision-Date: 2010-02-18 17:47+0900\n"
-"Last-Translator: \n"
+"PO-Revision-Date: 2010-03-03 13:31+0900\n"
+"Last-Translator: AkiraTaniguchi <taniguti at apptec.co.jp>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -1435,12 +1435,12 @@
#: ../lib/gis/spawn.c:385
#, c-format
msgid "CreateProcess() failed: error = %d"
-msgstr ""
+msgstr "CreateProcess()失æãã¾ãã: ã¨ã©ã¼ = %d"
#, c-format
-msgstr ""
+msgstr "G_spawn: è¨è¿°åããªãã¤ã¬ã¯ããããã¨ãã§ããªã%d"
#, c-format
@@ -5140,7 +5140,7 @@
#: ../lib/db/dbmi_base/login.c:111
msgid "Login file corrupted"
-msgstr ""
+msgstr "ãã°ã¤ã³ãã¡ã¤ã«ãç ´æãã¦ãã¾ã"
#: ../lib/db/dbmi_base/default_name.c:127
#, fuzzy
@@ -5186,11 +5186,11 @@
#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:220
#: ../lib/db/dbmi_client/select.c:286
msgid "Missing column name"
-msgstr ""
+msgstr "ã«ã©ã åãããã¾ãã"
#: ../lib/db/dbmi_client/select.c:215 ../lib/db/dbmi_client/select.c:281
msgid "Missing key column name"
-msgstr ""
+msgstr "ãã¼ã«ã©ã åãããã¾ãã"
#: ../lib/db/dbmi_client/select.c:307
#, c-format
@@ -5753,136 +5753,136 @@
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
msgstr "ã°ã«ã¼ã <%s> ã®ãµãã°ã«ã¼ã <%s> ã¯æ¬¡ã®ã©ã¹ã¿ã¼ããããåç
§ãã¾ã\n"
-#~ msgid "Invalid view position coordinates, using %f,%f"
-#~ msgstr "䏿£ãªè¦ç¹ä½ç½®åº§æ¨,ç¨æ³ã¯ %f,%f"
-#~ msgid "Unknown Location"
-#~ msgstr "䏿ãªãã±ã¼ã·ã§ã³"
#, fuzzy
-#~ msgid "Error writing floating point format file for map <%s>"
-#~ msgstr "���"
+msgid "Error writing floating point format file for map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to create a new process!"
-#~ msgstr "�������: ����� �����������n"
+msgid "Unable to create a new process!"
+msgstr "�������: ����� �����������n"
#, fuzzy
-#~ msgid "Unable to set region"
-#~ msgstr "���"
+msgid "Unable to set region"
+msgstr "���"
#, fuzzy
-#~ msgid "Raster map <%s> - unable to write row %d"
-#~ msgstr "���"
+msgid "Raster map <%s> - unable to write row %d"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to write feature, OGR layer not defined"
-#~ msgstr "���"
+msgid "Unable to write feature, OGR layer not defined"
+msgstr "���"
#, fuzzy
-#~ msgid "Failed writing raster map"
-#~ msgstr "���"
+msgid "Failed writing raster map"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to write color file of raster map <%s>"
-#~ msgstr "����� ���� ���\n"
+msgid "Unable to write color file of raster map <%s>"
+msgstr "����� ���� ���\n"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to query drawable"
-#~ msgstr "���"
+msgid "Unable to query drawable"
+msgstr "���"
#, fuzzy
-#~ msgid "Failed to initialize Xlib surface"
-#~ msgstr "���"
+msgid "Failed to initialize Xlib surface"
+msgstr "���"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���."
+msgstr "���."
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���."
+msgstr "���."
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "���"
+msgstr "���"
#, fuzzy
-#~ msgstr "����������<%s> � �����.\n"
+msgstr "����������<%s> � �����.\n"
#, fuzzy
-#~ msgstr "�����\"d.mon\" ����� �����������\n"
+msgstr "�����\"d.mon\" ����� �����������\n"
#, fuzzy
-#~ msgstr "��� - ����<%s> ���\n"
+msgstr "��� - ����<%s> ���\n"
#, fuzzy
-#~ msgstr "��� - � �� ����������(lock) ������<%s>.\n"
+msgstr "��� - � �� ����������(lock) ������<%s>.\n"
#, fuzzy
-#~ msgstr "��� - ����� (pipe) ������� �����.\n"
+msgstr "��� - ����� (pipe) ������� �����.\n"
#, fuzzy
-#~ msgstr "��� - ����������<%s> � ����\n"
+msgstr "��� - ����������<%s> � ����\n"
#, fuzzy
-#~ msgstr "���� ����������<%s>.\n"
+msgstr "���� ����������<%s>.\n"
#, fuzzy
-#~ msgstr "�������...\n"
+msgstr "�������...\n"
#, fuzzy
-#~ msgstr "����� ����� ���� ���� ����\n"
+msgstr "����� ����� ���� ���� ����\n"
#, fuzzy
-#~ msgstr "���: GISBASE � �����\n"
+msgstr "���: GISBASE � �����\n"
#, fuzzy
-#~ msgid "%s/%s' was found in more mapsets (also found in <%s>)"
-#~ msgstr "%s/%s' was found in more mapsets (also found in <%s>) "
+msgid "%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr "%s/%s' was found in more mapsets (also found in <%s>) "
+#~ msgid "Invalid view position coordinates, using %f,%f"
+#~ msgstr "䏿£ãªè¦ç¹ä½ç½®åº§æ¨,ç¨æ³ã¯ %f,%f"
+#~ msgstr "䏿ãªãã±ã¼ã·ã§ã³"
#~ msgstr "éååãã¡ã¤ã« [%s] ãããã»ããå
[%s] %s"
@@ -6692,3 +6692,52 @@
#~ "\n"
#~ "ç¨ä¾:\n"
+#~ msgid "Probably program error."
+#~ msgstr "ããã°ã©ã ã®ã¨ã©ã¼"
+#~ msgstr "䏿ãã¡ã¤ã«ãéãã¾ãã"
+#~ msgstr "ã©ã¹ã¿ã¼ãããã®èªã¿åãã«åé¡ãããã¾ã"
+#~ msgid ""
+#~ "\n"
+#~ "invalid projection\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ç¡å¹ãªæå½±æ³\n"
+#~ msgid "Please advise GRASS developers of this error.\n"
+#~ msgstr "ãã®ã¨ã©ã¼ãGRASSéçºè
ã«å ±åãã¦ãã ãã.\n"
+#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ãããå"
+#~ msgstr "ããã©ã«ãã®è¨±å¯"
+#~ msgid "hit RETURN to continue -->"
+#~ msgstr "ç¶è¡ã®ããã«ãªã¿ã¼ã³ãæ¼ã -->"
+#~ msgid "No help available for command [%s]\n"
+#~ msgstr "ã³ãã³ãã®ãã«ããå©ç¨ã§ãã¾ãã [%s]\n"
+#~ msgstr "ãã¼ã¿ãã¼ã¹ ãªã³ã¯ã追å ã§ãã¾ãã"
+#~ msgid ""
+#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+#~ "excess)"
+#~ msgstr "ãã¯ãã«ããã <%s@%s> ã®åº§æ¨ãã¡ã¤ã«ã大ãããã¾ã(%ld ãã¤ãè¶
é)"
+#~ msgid ""
+#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+#~ "missing)."
+#~ msgstr ""
+#~ "ãã¯ãã« <%s@%s> ã®åº§æ¨ãã¡ã¤ã«ãå°ãããã¾ã (%ld ãã¤ããä¸è¶³ãã¦ãã¾"
+#~ "ã)."
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_ko.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -3426,11 +3426,11 @@
#: ../lib/vector/Vlib/open.c:252 ../lib/vector/Vlib/open.c:339
#: ../lib/vector/Vlib/open.c:360
-#, c-format
+#, fuzzy, c-format
msgid ""
"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
"by v.build."
-msgstr ""
+msgstr "Datum %s í
ì´ë¸íì¼ì ì´ ì ììµëë¤"
#: ../lib/vector/Vlib/open.c:255
#, fuzzy, c-format
@@ -5602,71 +5602,79 @@
msgstr ""
#, fuzzy
-#~ msgid "Unable to open raster map <%s>"
-#~ msgstr "Datum %s í
+msgstr "'%s' ëë²ê·¸íì¼ì ì´ ì ììµëë¤"
#, fuzzy
-#~ msgid "Unable to close input map"
+msgstr "Datum %s í
#, fuzzy
-#~ msgid "Unable to write raster row %i"
-#~ msgstr "ìë MASKíì¼ì ì´ ì ììµëë¤"
+msgstr "Datum %s í
#, fuzzy
-#~ msgstr "'%s' ëë²ê·¸íì¼ì ì´ ì ììµëë¤"
+msgstr "Datum %s í
#, fuzzy
-#~ msgid "Unable to open raster map <%s@%s>"
+msgstr "Datum %s í
#, fuzzy
-#~ msgid "Unable to find <%s@%s>"
+msgstr "Datum %s í
#, fuzzy
-#~ msgid "Unable to open '%s'"
+msgstr "Datum %s í
#, fuzzy
-#~ msgid "unable to write quant file!"
+msgstr "Datum %s í
#, fuzzy
+msgstr "Datum %s í
+#, fuzzy
+#~ msgid "Unable to open raster map <%s>"
#, fuzzy
-#~ msgid " It is a reclass of raster map <%s@%s> "
+#~ msgid "Unable to close input map"
#, fuzzy
-#~ msgid "Unable to realloc buffer"
-#~ msgstr "ììíì¼ì ì´ ì ììµëë¤"
+#~ msgid "Unable to write raster row %i"
+#~ msgstr "ìë MASKíì¼ì ì´ ì ììµëë¤"
#, fuzzy
+#~ msgid "Unable to open raster map <%s@%s>"
#, fuzzy
+#~ msgid "Unable to find <%s@%s>"
#, fuzzy
-#~ msgid "Unable to open file %s in <%s>"
+#~ msgid "Unable to open '%s'"
#, fuzzy
+#~ msgid "unable to write quant file!"
#, fuzzy
+#~ msgid " It is a reclass of raster map <%s@%s> "
#, fuzzy
+#~ msgid "Unable to realloc buffer"
+#~ msgstr "ììíì¼ì ì´ ì ììµëë¤"
+#, fuzzy
+#~ msgid "Unable to open file %s in <%s>"
#, fuzzy
@@ -5694,14 +5702,6 @@
#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -5802,3 +5802,96 @@
#~ msgstr ""
#~ "\n"
#~ "**<%s> ì못ë ì´ë¦ **\n"
+#, fuzzy
+#~ msgid "Unable to open file %s"
+#~ msgstr "Datum %s í
+#, fuzzy
+#~ msgid "Hit RETURN to cancel request\n"
+#~ msgstr "ì·¨ì를 ìíìë©´ RETURNì ë르ì¸ì\n"
+#, fuzzy
+#, fuzzy
+#~ msgid "unable to find a temporary null file %s"
+#~ msgid "category support for [%s] in mapset [%s] %s"
+#~ msgstr "ë§µ [%s], ë§µì
[%s]ì(를) ìí ë¶ë¥ì§ì: %s"
+#~ msgid "category support for vector map [%s] in mapset [%s] %s"
+#~ msgstr "벡í°ë§µ [%s], ë§µì
+#~ msgid "Cannot open temp file"
+#~ msgid "color support for [%s] in mapset [%s] %s"
[%s]ì(를) ìí ììì§ì: %s"
+#, fuzzy
+#~ msgid "Error reading compressed map <%s@%s>, row %d"
+#, fuzzy
+#~ msgid "Error reading map <%s@%s>, row %d"
+#, fuzzy
+#~ msgid "Unable to find '%s' in '%s'"
+#, fuzzy
+#~ msgid "Unable to read header file for raster map <%s@%s>."
+#, fuzzy
+#~ msgid "Unable to add database link, map is not opened in WRITE mode"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to feature %d from vector map <%s>"
+#, fuzzy
+#~ msgid "Unable to open layer <%s>"
+#, fuzzy
+#~ msgid "Unable to create raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to delete layer/category %d/%d line %d"
+#, fuzzy
+#~ msgid "Attempt to delete dead line"
+#, fuzzy
+#~ msgid "Unable to rewrite line %d"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
+#, fuzzy
+#~ msgid "Unable to delete line %d from vector map <%s>"
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_lv.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5796,6 +5796,53 @@
msgstr ""
+#, fuzzy
+msgstr "karte [%s] - neiespÄjami ierakstÄ«t rindu %d"
+#, fuzzy
+msgstr "eksistÄjoÅ¡Äm rastra kartÄm %d"
+#, fuzzy
+msgstr "Nevar ierakstÄ«t lÄ«niju,karte nav atvÄrta"
+#, fuzzy
+msgstr "neiespÄjami izveidot jaunu procesu"
+#, fuzzy
+msgid ""
+"Region for current mapset %s. Run \"g.region\" to fix the current region."
+msgstr ""
+"paÅ¡reizejÄs karÅ¡u biblotÄkas reÄ£ions %s\n"
+"palaižot \"g.region\""
+#, fuzzy
+msgid "Default region %s"
+msgstr "noklusÄtais reÄ£ions %s"
+#, fuzzy
+msgstr "NeisespÄjami atvÄrt %s"
+#, fuzzy
+#, fuzzy
+msgstr "neispÄjami mainÄ«t direktoriju uz %s"
+#, fuzzy
+msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
+#, fuzzy
#~ msgstr "NezinÄma AtraÅ¡anÄs Vieta"
@@ -5830,10 +5877,6 @@
#~ msgstr "neiespÄjami rakstÄ«t quant failu!"
#, fuzzy
-#~ msgstr "karte [%s] - neiespÄjami ierakstÄ«t rindu %d"
-#, fuzzy
#~ msgstr "neispÄjami mainÄ«t direktoriju uz %s"
@@ -5849,10 +5892,6 @@
#, fuzzy
-#~ msgstr "eksistÄjoÅ¡Äm rastra kartÄm %d"
-#, fuzzy
@@ -5868,14 +5907,6 @@
#~ msgstr "nevar izveidot histogrammu priekš [%s iekš %s]"
#, fuzzy
-#~ msgstr "Nevar ierakstÄ«t lÄ«niju,karte nav atvÄrta"
-#, fuzzy
-#~ msgstr "neiespÄjami izveidot jaunu procesu"
-#, fuzzy
#~ msgid "Too many arguments"
#~ msgstr "pÄrÄk daudz argumentu"
@@ -5899,17 +5930,6 @@
#~ msgstr "līnija %d: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
-#~ msgstr ""
-#~ "paÅ¡reizejÄs karÅ¡u biblotÄkas reÄ£ions %s\n"
-#~ "palaižot \"g.region\""
-#, fuzzy
-#~ msgid "Default region %s"
-#~ msgstr "noklusÄtais reÄ£ions %s"
#~ msgstr "nav noteikts"
@@ -5921,18 +5941,6 @@
#~ "%s"
#, fuzzy
-#~ msgstr "NeisespÄjami atvÄrt %s"
-#, fuzzy
-#, fuzzy
-#~ msgstr "neispÄjami mainÄ«t direktoriju uz %s"
-#, fuzzy
#~ msgid "Unable to open category index file for vector map <%s@%s>"
#~ msgstr "Nevar atvÄrt vÄsturi vektoram '%s'"
@@ -6018,14 +6026,6 @@
#~ msgstr "Nevar atvÄrt datubÄzi %s"
#, fuzzy
-#~ msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
-#, fuzzy
-#, fuzzy
#~ msgid "Cannot describe table <%s>"
@@ -6628,3 +6628,242 @@
#~ msgstr "neiespÄjami atrast [%s] iekÅ¡ [%s]"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "NeiespÄjami piešķirt atmiÅu\n"
+#, fuzzy
+#~ msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
+#, fuzzy
+#, fuzzy
+#~ msgstr "eksistÄjoÅ¡Äm rastra kartÄm %d"
+#~ msgid " The raster map %s@%s is empty"
+#~ msgstr " Rastra karte %s@%s ir tukša"
+#, fuzzy
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): projekcija/zona atšķiras no tÄs kas ir tekoÅ¡i "
+#~ "atverajamajiem rastra failiem"
+#~ msgid "The floating data range for %s@%s is empty"
+#~ msgstr "'Peldošo' datu dipazons priekš %s@%s ir tukšs"
+#~ msgid "The integer data range for %s@%s is empty"
+#~ msgstr "Veselo skaitļu datu diapazons priekš %s@%s ir tukšs"
+#~ msgid "map [%s] - unable to write row %d"
+#~ msgstr "karte [%s] - neiespÄjami ierakstÄ«t rindu %d"
+#~ msgstr "neispÄjami atrast pagaidu null failu: %s"
+#~ msgid "error writing null row %d"
+#~ msgstr "Kļūdas rakstīšana null row %d"
+#~ msgstr "kategoriju atbalsts priekÅ¡ [%s] karÅ¡u biblotÄkÄ [%s] %s"
+#~ msgstr "kategoriju atbalsts vektoru failam [%s] karÅ¡u biblotÄkÄ [%s] %s"
+#~ msgstr "Nevar atvÄrt 'temp'/pagaidu failu"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "nederīga projekcija\n"
+#~ msgstr "EmbedGivenNulls: nepareizs datu tips!"
+#~ msgstr "LÅ«dzu dod ziÅu GRASS izstrÄdÄtÄjiem par Å¡o kļūdu.\n"
+#~ msgstr "G_set_null_value: nepareizs datu tips!"
+#~ msgstr "Reljefa rastra faila nosaukums"
+#~ msgstr "Reljefa rastra faila(u) nosaukums(i)"
+#~ msgid "Layer number"
+#~ msgstr "LÄ«meÅa numurs"
+#~ msgid ""
+#~ "\n"
+#~ "Description:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Apraksts:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "AtslÄgvÄrdi:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Pieleitojums:\n"
+#~ msgstr " opcijas: %s\n"
+#~ msgstr "lai apstiprinÄtu noklusÄto"
+#~ msgstr "krÄsu atbalsts [%s] karÅ¡u biblotÄkÄ [%s] %s"
+#~ msgstr ""
+#~ "NederÄ«gs laikspiedols(timestamp) norÄdÄ«ts priekÅ¡ %s kartes %s karÅ¡u "
+#~ "biblotÄkÄ %s"
+#~ msgstr ""
+#~ "Nederīgs liakspiedola(timestamp) fails priekš %s kartes %s karšu "
+#~ "biblotÄkÄ %s"
+#, fuzzy
+#~ msgstr "kļūda nolasot %smap [%s] karÅ¡u biblotÄkÄ [%s], lÄ«nija %d"
+#, fuzzy
+#~ msgid "unable to determine user's home directory"
+#~ msgstr "neiespÄjami noteikt lietotÄja mÄjas direktoriju"
+#~ msgid ""
+#~ msgstr ""
+#~ "paÅ¡reizejÄs karÅ¡u biblotÄkas reÄ£ions %s\n"
+#~ "palaižot \"g.region\""
+#~ msgstr "noklusÄtais reÄ£ions %s"
+#~ msgstr "spied ENTER lai turpinÄtu -->"
+#~ msgstr "Neatļauts faila nosaukums. Nevar būt '.' vai 'NULL'\n"
+#, fuzzy
+#~ msgid "Illegal filename. Character <%c> not allowed.\n"
+#~ msgstr "Neatļauts faila nosaukums. zīme <%c> nav atļauta.\n"
+#~ msgid "Too many reclass categories for [%s in %s]"
+#~ msgstr "PÄrÄk daudz pÄrklasificÄÅ¡anas kategorijas priekÅ¡ [%s iekÅ¡ %s]"
+#~ msgid "Unable to create dependency file in [%s in %s]"
+#~ msgstr "NiespÄjami izveidot atkarÄ«bu failu [%s iekÅ¡ %s]"
+#, fuzzy
+#~ msgstr "neiespÄjami atrast [%s]"
+#~ msgstr "Nav pieejama palīdzība komandai [%s]\n"
+#~ msgstr "nevar ierakstÄ«t vÄstures informÄciju priekÅ¡ [%s]"
+#, fuzzy
+#~ msgstr ""
+#~ "Nevar pievienot datubÄzes saiti,karte nav atvÄrta rakstīšanas 'WRITE' "
+#~ "režijmÄ."
+#, fuzzy
+#~ msgstr "Nevar pievienot datubÄzes saiti"
+#~ msgid "Error in rule on row %d in %s"
+#~ msgstr "Kļūda noteikuma rindÄ %d iekÅ¡ %s "
+#, fuzzy
+#~ msgid "Intersections: %5d"
+#~ msgstr "Cita Projekcija"
+#, fuzzy
+#~ msgstr "neispÄjami mainÄ«t direktoriju uz %s"
+#, fuzzy
+#~ msgid "Programmer requested unknown open level %d"
+#~ msgstr ""
+#~ "BrÄ«dinÄjums. Programma atklÄjusi nezinÄmu atvÄrtolÄ«meni (open_level) \n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> on topology level %d"
+#~ msgstr "neiespÄjami atvÄrt rastra karti [%s iekÅ¡ %s]"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr "Nevar izdzÄst lÄ«niju, karte '%s' karte nav atvÄrta lÄ«menÄ« 2"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "Nevar izdzÄst lÄ«niju, karte '%s' karte nav atvÄrta rakstīšanas 'write' "
+#~ "režijmÄ"
+#, fuzzy
+#~ msgid "Cannot find input map '%s'"
+#~ msgstr "Nevar atrast ieejas karti '%s'"
+#~ msgid "Cannot rewrite line"
+#~ msgstr "Nevar pÄrrakstÄ«t lÄ«niju"
+#~ msgid "Color file for [%s] not available"
+#~ msgstr "KrÄsu fails priekÅ¡ [%s] nav pieejams"
Modified: grass/trunk/locale/po/grasslibs_mr.po
--- grass/trunk/locale/po/grasslibs_mr.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_mr.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -3424,11 +3424,11 @@
-#, c-format
+#, fuzzy, c-format
msgid ""
"by v.build."
-msgstr ""
+msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
#, fuzzy, c-format
@@ -5534,7 +5534,7 @@
#: ../lib/imagery/points.c:124
#, fuzzy, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
+msgstr "à¤à¤à¤¡à¤²à¥à¤²à¥à¤¯à¤¾ फाà¤à¤²à¤à¥ नाव %s\n"
#: ../lib/imagery/points.c:132
#, fuzzy, c-format
@@ -5602,6 +5602,42 @@
msgstr ""
#, fuzzy
+msgstr "%s मिळालॠनाहà¥"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
#~ msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
@@ -5614,10 +5650,6 @@
#, fuzzy
-#~ msgstr "%s मिळालॠनाहà¥"
-#, fuzzy
@@ -5630,10 +5662,6 @@
#, fuzzy
-#~ msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
-#, fuzzy
@@ -5642,14 +5670,6 @@
#~ msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -5658,18 +5678,6 @@
#~ msgstr "%s वाà¤à¤¤à¤¾à¤¨à¤¾ तà¥à¤°à¥à¤à¥"
#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -5698,14 +5706,6 @@
#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -5867,3 +5867,81 @@
#, fuzzy
#~ msgstr "à¤à¤à¤¡à¤²à¥à¤²à¥à¤¯à¤¾ फाà¤à¤²à¤à¥ नाव %s\n"
+#, fuzzy
+#~ msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
+#, fuzzy
+#, fuzzy
+#~ msgstr "%s@%s हा रासà¥à¤à¤° नà¤à¤¾à¤¶à¤¾ रिà¤à¥à¤¤ à¤à¤¹à¥"
+#~ msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
+#~ msgstr "पà¥à¤¢à¥ à¤à¤¾à¤£à¥à¤¯à¤¾à¤¸à¤¾à¤ ॠRETURN à¤à¤¾à¤à¤ª à¤à¤°à¤¾ -->"
+#, fuzzy
+#~ msgstr "[%s] या à¤à¤®à¤¾à¤à¤¡à¤¸à¤¾à¤ ॠà¤à¥à¤£à¤¤à¥à¤¹à¥ मदत à¤à¤ªà¤²à¤¬à¥à¤§ नाहà¥\n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgid ""
+#, fuzzy
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_pl.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5652,16 +5652,16 @@
msgstr "podgrupa <%s> grupy <%s> odnosi siÄ do nastÄpujÄ
cych map rastrowych\n"
#, fuzzy
-#~ msgid "Not enough room in history file to record command line"
-#~ msgstr ""
-#~ "W pliku historii nie ma wystarczajÄ
co dużo miejsca, aby zapisaÄ wiersz "
-#~ "poleceÅ."
+msgid "Not enough room in history file to record command line"
+msgstr ""
+"W pliku historii nie ma wystarczajÄ
+"poleceÅ."
#, fuzzy
-#~ msgid "Not enough room in history file for command line (truncated)"
-#~ msgstr ""
-#~ "poleceÅ."
+msgid "Not enough room in history file for command line (truncated)"
+msgstr ""
+"poleceÅ."
#~ msgstr "Nieznane poÅożenie"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_pt.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5747,7 +5747,7 @@
#, fuzzy, c-format
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "Impossível abrir o arquivo [%s] do grupo [%s em %s]"
#, fuzzy, c-format
@@ -5815,24 +5815,71 @@
msgstr ""
#, fuzzy
-#~ msgstr ""
-#~ "Não há espaço suficiente no arquivo de histórico para gravar a linha de "
-#~ "comando."
+msgstr ""
+"Não há espaço suficiente no arquivo de histórico para gravar a linha de "
+"comando."
#, fuzzy
-#~ msgstr ""
-#~ "Não há espaço suficiente no arquivo de histórico para a linha de comando "
-#~ "(truncada)."
+msgstr ""
+"Não há espaço suficiente no arquivo de histórico para a linha de comando "
+"(truncada)."
+#, fuzzy
+msgid "test, gmath"
+msgstr "teste, gpde"
+#, fuzzy
+msgstr "mapa [%s] - não consegui escrever linha %d"
+#, fuzzy
+msgstr "Erro escrevendo arquivo de ponto flutuante para mapa %s"
+#, fuzzy
+msgstr "não consegui escrever a linha, o mapa não foi aberto"
+#, fuzzy
+msgstr "Impossível criar novo processo"
+#, fuzzy
+msgid ""
+msgstr ""
+"região do mapset atual %s\n"
+"execute \"g.region\""
+#, fuzzy
+msgstr "região padrão (default) %s"
+#, fuzzy
+msgstr "não consegui abrir [%s]"
+#, fuzzy
+msgstr "problema lendo arquivo cell raster"
+#, fuzzy
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+#, fuzzy
+msgstr "Impossível abrir arquivo %s"
+#, fuzzy
+msgstr "não foi possível abrir o arquivo %s em %s"
#~ msgstr "Locação desconhecida"
-#, fuzzy
-#~ msgid "test, gmath"
-#~ msgstr "teste, gpde"
#~ msgstr "Arquivo de quantização para [%s] no mapset [%s] %s"
@@ -5865,10 +5912,6 @@
#~ msgstr "Impossível mudar de diretório para %s"
#, fuzzy
-#~ msgstr "mapa [%s] - não consegui escrever linha %d"
-#, fuzzy
@@ -5887,10 +5930,6 @@
#~ msgstr "Erro escrevendo arquivo de ponto flutuante para mapa %s"
#, fuzzy
-#~ msgstr "Erro escrevendo arquivo de ponto flutuante para mapa %s"
-#, fuzzy
#~ msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
@@ -5913,14 +5952,6 @@
-#, fuzzy
-#~ msgstr "não consegui escrever a linha, o mapa não foi aberto"
-#, fuzzy
-#~ msgstr "Impossível criar novo processo"
#~ msgstr "Argumentos demais"
@@ -5943,17 +5974,6 @@
#~ msgstr "linha %d: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "região do mapset atual %s\n"
-#~ "execute \"g.region\""
-#, fuzzy
-#~ msgstr "região padrão (default) %s"
#~ msgstr "não está inicializado"
@@ -5964,18 +5984,6 @@
#~ "é inválido\n"
#~ "%s"
-#, fuzzy
-#~ msgstr "não consegui abrir [%s]"
-#, fuzzy
-#~ msgstr "problema lendo arquivo cell raster"
-#, fuzzy
-#~ msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
#~ msgstr "Vetor não é 3D"
@@ -6174,14 +6182,6 @@
#~ msgid "Cannot open database %s"
#~ msgstr "não consegui abrir banco de dados %s"
-#, fuzzy
-#~ msgstr "Impossível abrir arquivo %s"
-#, fuzzy
-#~ msgstr "não foi possível abrir o arquivo %s em %s"
#~ msgstr "Impossível descrever tabela <%s>"
@@ -6559,3 +6559,318 @@
#~ msgstr "não consegui encontrar [%s] em [%s]"
+#~ msgstr "não consegui alocar memória\n"
+#~ msgstr "Provável erro no programa."
+#~ msgstr "Impossível abrir arquivo %s"
+#, fuzzy
+#, fuzzy
+#~ msgstr "problema lendo arquivo cell raster"
+#~ msgstr "O raster %s@%s está vazio"
+#~ msgid "Cannot write quant rules: map %s is integer"
+#~ msgstr "não consegui escrever regras de quantização : o mapa %s é inteiro"
+#~ msgid ""
+#~ "G_set_window(): projection/zone differs from that of currently open "
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): projeção/zona difere daquela nos arquivos raster abertos"
+#~ msgstr "O intervalo de dados float para %s@%s está vazio"
+#~ msgstr "O intervalo de dados inteiros para %s@%s está vazio"
+#~ msgid "%s: map [%s] not open for write - request ignored"
+#~ msgstr "%s: map [%s] não está aberto para escrita - pedido ignorado"
+#~ msgid "%s: unopened file descriptor - request ignored"
+#~ msgstr "%s: descritor de arquivo não foi aberto - pedido ignorado"
+#~ msgstr "mapa [%s] - não consegui escrever linha %d"
+#~ msgstr "não foi possível encontrar o arquivo null temporário: %s"
+#~ msgstr "erro escrevendo linha de nulos %d"
+#~ msgstr "suporte para a categoria [%s] no mapset [%s] %s"
+#~ msgstr "suporte da categoria para arquivo de vetores [%s] no mapset [%s] %s"
+#~ msgstr "não consegui abrir arquivo temporário"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "projeção inválida\n"
+#~ msgid "EmbedGivenNulls: wrong data type!"
+#~ msgstr "EmbedGivenNulls: tipo errado de dados!"
+#~ msgstr "Por favor avise aos desenvolvedores do GRASS sobre este erro.\n"
+#~ msgid "G_set_null_value: wrong data type!"
+#~ msgstr "G_set_null_value: tipo errado de dados!"
+#~ msgstr "Nome do mapa raster de elevação"
+#~ msgstr "Nome dos mapas raster de elevação"
+#~ msgstr "Número da camada"
+#~ msgid ""
+#~ "A single vector map can be connected to multiple database tables. This "
+#~ "number determines which table to use."
+#~ msgstr ""
+#~ "Apenas um mapa vetorial pode ser conectado a múltiplas tabelas. Este "
+#~ "número determina qual tabela usar."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Descrição:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Palavras chave:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Uso:\n"
+#~ msgid " options: %s\n"
+#~ msgstr " opções: %s\n"
+#~ msgstr "para aceitar os valores padrão"
+#~ msgstr "suporte das cores [%s] no mapset [%s] %s"
+#~ msgid "Invalid timestamp specified for %s map %s in mapset %s"
+#~ msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
+#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
+#, fuzzy
+#~ msgstr "erro lendo mapa compactado [%s] no mapset [%s], linha %d"
+#, fuzzy
+#~ msgstr "erro lendo mapa [%s] no mapset [%s], linha %d"
+#~ msgstr "não consegui encontrar o diretório do usuário"
+#~ msgid "Unable to create header file for [%s]"
+#~ msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
+#~ msgid ""
+#~ msgstr ""
+#~ "região do mapset atual %s\n"
+#~ "execute \"g.region\""
+#~ msgstr "região padrão (default) %s"
+#~ msgstr "Pressione ENTER para continuar -->"
+#~ msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
+#~ msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
+#~ msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
+#~ msgstr "Categorias de reclassificação demais para [%s em %s]"
+#~ msgid "Illegal reclass format in header file for [%s in %s]"
+#~ msgstr ""
+#~ "Formato de reclassificação ilegal no cabeçalho do arquivo para [%s em %s]"
+#~ msgstr "não é possível criar arquivo de dependência [%s em %s]"
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different projection than current region. Found "
+#~ "raster map <%s@%s>, should be <%s>."
+#~ msgstr ""
+#~ "[%s] no mapset [%s] - está numa projeção diferente da região atual:\n"
+#~ "o mapa [%s] em: <%s>, deveria ser <%s> "
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr ""
+#~ "[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
+#, fuzzy
+#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
+#~ msgstr "[%s] em [%s] - bytes demais por célula (%d)"
+#, fuzzy
+#~ msgstr "não consegui encontrar [%s]"
+#~ msgstr "No há ajuda disponível para o comando [%s]\n"
+#~ msgid "can't write history information for [%s]"
+#~ msgstr "não consegui escrever os dados históricos para [%s]"
+#~ msgid "Not enough room in history file to record command line."
+#~ msgstr ""
+#~ "Não há espaço suficiente no arquivo de histórico para gravar a linha de "
+#~ "comando."
+#~ msgid "Not enough room in history file for command line (truncated)."
+#~ msgstr ""
+#~ "Não há espaço suficiente no arquivo de histórico para a linha de comando "
+#~ "(truncada)."
+#, fuzzy
+#~ msgstr ""
+#~ "não é possível adicionar um link ao banco de dados, o mapa não está "
+#~ "aberto em modo ESCRITA."
+#, fuzzy
+#~ msgstr "não é possível adicionar um link ao banco de dados."
+#~ msgstr "Erro na regra da linha %d em %s"
+#, fuzzy
+#~ msgstr "Outra projeção"
+#, fuzzy
+#~ msgstr "ATENÇÃO: Programador solicitou open_level desconhecido"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ignorando feição OGR sem ID"
+#, fuzzy
+#~ msgstr "Impossível mudar de diretório para %s"
+#~ msgstr "teste, gpde"
+#~ msgid ""
+#~ msgstr ""
+#~ "demorando demais para encontrar pontos para interpolação--favor alterar a "
+#~ "região para a área onde estão os pontos. Continuando cálculos..."
+#~ msgstr "Lendo linhas do mapa vetorial ... "
+#~ msgstr "Lendo nós do mapa vetorial"
+#~ msgstr "há uma faixa com dados insuficientes"
+#~ msgstr "há pontos fora da região 2D/3D especificada-- ignorei %d pontos"
+#~ msgstr "ignorando %d pontos -- muito denso"
+#~ msgstr "alguns pontos fora da região -- vou ignorar..."
+#, fuzzy
+#, fuzzy
+#~ msgstr "não foi possível abrir o mapa raster [%s em %s]"
+#~ msgstr "Vértices encaixados"
+#~ msgstr "Novos vértices"
+#, fuzzy
+#~ msgstr "Impossível ler arquivo de cabeçalho"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "não é possível apagar a linha, o mapa '%s' não está aberto no nível 2"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "não consegui apagar a linha, o mapa '%s' não está aberto em modo de "
+#~ "escrita"
+#, fuzzy
+#~ msgstr "não consegui encontrar mapa de entrada '%s'"
+#~ msgstr "Tipo da coluna não suportado"
+#~ msgstr "não consegui reescrever a linha"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_pt_br.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5706,7 +5706,7 @@
#, fuzzy, c-format
#, fuzzy, c-format
@@ -5774,17 +5774,64 @@
msgstr ""
#, fuzzy
-#~ msgstr ""
-#~ "comando."
+msgstr ""
+"comando."
#, fuzzy
-#~ msgstr ""
-#~ "(truncada)."
+msgstr ""
+"(truncada)."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid ""
+msgstr ""
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
@@ -5822,10 +5869,6 @@
#~ msgstr "não consegui criar novo processo"
#, fuzzy
-#, fuzzy
@@ -5844,10 +5887,6 @@
#, fuzzy
-#, fuzzy
@@ -5862,14 +5901,6 @@
#~ msgid "can't create histogram for [%s in %s]"
#~ msgstr "não consegui criar o histograma para [%s em %s]"
-#, fuzzy
-#, fuzzy
@@ -5892,17 +5923,6 @@
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#, fuzzy
@@ -5913,18 +5933,6 @@
#~ "é inválido\n"
#~ "%s"
-#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -6065,14 +6073,6 @@
-#, fuzzy
-#, fuzzy
@@ -6457,3 +6457,296 @@
+#, fuzzy
+#~ msgstr "não foi possível abrir o arquivo %s em %s"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr ""
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Descrição:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Uso:\n"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#, fuzzy
+#, fuzzy
+#~ msgstr ""
+#~ "comando."
+#~ msgstr ""
+#~ "(truncada)."
+#, fuzzy
+#~ msgstr ""
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "ATENÇÃO: Programador solicitou open_level desconhecido\n"
+#, fuzzy
+#, fuzzy
+#~ msgid "OGR feature without ID ignored"
+#, fuzzy
+#~ msgid ""
+#~ "taking too long to find points for interpolation--please change the "
+#~ "region to area where your points are. Continuing calculations..."
+#~ msgstr ""
+#~ msgid "strip exists with insufficient data"
+#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
+#~ msgid "ignoring %d points -- too dense"
+#~ msgid "some points outside of region -- will ignore..."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "escrita"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Feição OGR tipo %d não suportada)"
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_ru.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5781,7 +5781,7 @@
#, fuzzy, c-format
-msgstr "Ðевозможно ÑоздаÑÑ Ñайл заголовка Ð´Ð»Ñ [%s в %s]"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл [%s] гÑÑÐ¿Ð¿Ñ [%s в %s]"
#, fuzzy, c-format
@@ -5849,24 +5849,75 @@
msgstr "подгÑÑппа <%s> гÑÑÐ¿Ð¿Ñ <%s> ÑÑÑлаеÑÑÑ Ð½Ð° ÑледÑÑÑие ÑаÑÑÑовÑе Ñлои\n"
#, fuzzy
-#~ msgstr "ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки"
+msgstr "ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки"
#, fuzzy
-#~ msgstr ""
-#~ "ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки (truncated)"
+msgstr ""
+"ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки (truncated)"
+#, fuzzy
+msgstr "ÑеÑÑ, gpde"
+#, fuzzy
+msgstr "Ñлой [%s] - невозможно запиÑаÑÑ ÑÑÑÐ¾ÐºÑ %d"
+#, fuzzy
+msgstr "ÐÑибка запиÑи в Ñайл Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой Ð´Ð»Ñ ÑÐ»Ð¾Ñ %s"
+#, fuzzy
+msgid "OGR layer cannot be opened for update"
+msgstr "OGR ÑоÑÐ¼Ð°Ñ Ð½Ðµ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½"
+#, fuzzy
+msgstr "Ðевозможно запиÑаÑÑ Ð¾Ð±ÑекÑ, векÑоÑнÑй Ñлой не оÑкÑÑÑ "
+#, fuzzy
+msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²Ñй пÑоÑеÑÑ"
+#, fuzzy
+msgid ""
+msgstr ""
+"Ñегион Ð´Ð»Ñ ÑекÑÑего набоÑа %s\n"
+"вÑполниÑе \"g.region\""
+#, fuzzy
+msgstr "Ñегион по ÑмолÑÐ°Ð½Ð¸Ñ %s"
+#, fuzzy
+msgstr "Ðевозможно ÑÑÑановиÑÑ ÑокÑÑ"
+#, fuzzy
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑлоÑ"
+#, fuzzy
+msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑвеÑовой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#, fuzzy
+msgstr "Ðевозможно ÑкопиÑоваÑÑ ÑаблиÑÑ <%s>"
+#, fuzzy
+msgstr "Ðевозможно иниÑиализиÑоваÑÑ pj пÑиÑинÑ: %s"
#~ msgstr "ÐепÑавилÑнÑе кооÑдинаÑÑ Ð¿Ð¾Ð·Ð¸Ñии вида, иÑполÑзÑеÑÑÑ %f,%f"
#~ msgstr "ÐблаÑÑÑ Ð½ÐµÐ¸Ð·Ð²ÐµÑÑна"
-#, fuzzy
-#~ msgstr "ÑеÑÑ, gpde"
#~ msgid "quantization file [%s] in mapset [%s] %s"
#~ msgstr "Ñайл ÑÐ°Ð·Ð±Ð¸ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений [%s] в набоÑе [%s] %s"
@@ -5896,10 +5947,6 @@
#~ msgstr "Ðевозможно запиÑаÑÑ ÑÑÑÐ¾ÐºÑ ÑаÑÑÑа %i"
-#, fuzzy
-#~ msgstr "Ñлой [%s] - невозможно запиÑаÑÑ ÑÑÑÐ¾ÐºÑ %d"
#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s@%s>"
@@ -5915,10 +5962,6 @@
#~ msgid "Error writing floating point format file for map %s"
#~ msgstr "ÐÑибка запиÑи в Ñайл Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой Ð´Ð»Ñ ÑÐ»Ð¾Ñ %s"
-#, fuzzy
-#~ msgstr "ÐÑибка запиÑи в Ñайл Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой Ð´Ð»Ñ ÑÐ»Ð¾Ñ %s"
#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл заголовка Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s@%s>."
@@ -5937,18 +5980,6 @@
#~ msgstr "Ðевозможно ÑдалиÑÑ Ð¾Ð±ÑÐµÐºÑ %d из векÑоÑного ÑÐ»Ð¾Ñ <%s>"
-#, fuzzy
-#~ msgid "OGR layer cannot be opened for update"
-#~ msgstr "OGR ÑоÑÐ¼Ð°Ñ Ð½Ðµ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½"
-#, fuzzy
-#~ msgstr "Ðевозможно запиÑаÑÑ Ð¾Ð±ÑекÑ, векÑоÑнÑй Ñлой не оÑкÑÑÑ "
-#, fuzzy
-#~ msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²Ñй пÑоÑеÑÑ"
#~ msgstr "СлиÑком много паÑамеÑÑов"
@@ -5970,17 +6001,6 @@
#~ msgstr "ÑÑÑока %d: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "Ñегион Ð´Ð»Ñ ÑекÑÑего набоÑа %s\n"
-#~ "вÑполниÑе \"g.region\""
-#, fuzzy
-#~ msgstr "Ñегион по ÑмолÑÐ°Ð½Ð¸Ñ %s"
#~ msgstr "не ÑÑÑановлен"
@@ -5991,18 +6011,6 @@
#~ "невеÑно\n"
#~ "%s"
-#, fuzzy
-#~ msgstr "Ðевозможно ÑÑÑановиÑÑ ÑокÑÑ"
-#, fuzzy
-#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑлоÑ"
-#, fuzzy
-#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑвеÑовой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#~ msgstr "ÐекÑÐ¾Ñ Ð½Ðµ 3D "
@@ -6131,14 +6139,6 @@
#~ "ÐаÑамеÑÑ ÑелакÑаÑии иÑполÑзÑемÑй алгоÑиÑмами jacobi и sor Ð´Ð»Ñ ÑÑкоÑÐµÐ½Ð¸Ñ "
#~ "или ÑÑабилизаÑии"
-#, fuzzy
-#~ msgstr "Ðевозможно ÑкопиÑоваÑÑ ÑаблиÑÑ <%s>"
-#, fuzzy
-#~ msgstr "Ðевозможно иниÑиализиÑоваÑÑ pj пÑиÑинÑ: %s"
#~ msgid "Registering points"
#~ msgstr "РегиÑÑÑаÑÐ¸Ñ ÑоÑек"
@@ -6697,3 +6697,318 @@
#~ msgstr "Ðевозможно найÑи иÑÑ
однÑй Ñлой '%s'"
+#~ msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ\n"
+#~ msgstr "ÐÐ¾Ð·Ð¼Ð¾Ð¶Ð½Ð°Ñ Ð¿ÑогÑÐ°Ð¼Ð¼Ð½Ð°Ñ Ð¾Ñибка."
+#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÑеменнÑй Ñайл"
+#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑлоÑ"
+#~ msgstr " РаÑÑÑовÑй Ñлой %s@%s пÑÑÑ"
+#~ msgstr ""
+#~ "Ðевозможно запиÑаÑÑ Ð¿Ñавила ÑÐ°Ð·Ð±Ð¸ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений: Ñлой %s ÑелоÑиÑленнÑй "
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): пÑоекÑиÑ/зона оÑлиÑаеÑÑÑ Ð¾Ñ ÑекÑÑиÑ
оÑкÑÑÑÑÑ
ÑаÑÑÑовÑÑ
+#~ "каÑÑ"
+#~ msgstr "Ðиапазон Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой Ð´Ð»Ñ %s@%s пÑÑÑ"
+#~ msgstr "ЦелоÑиÑленнÑй диапазон Ð´Ð»Ñ %s@%s пÑÑÑ"
+#~ msgstr "%s: Ñлой [%s] не оÑкÑÑÑ Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи - запÑÐ¾Ñ Ð¸Ð³Ð½Ð¾ÑиÑован"
+#~ msgstr "%s: деÑкÑипÑÐ¾Ñ Ñайла не оÑкÑÑÑ - запÑÐ¾Ñ Ð¸Ð³Ð½Ð¾ÑиÑован"
+#~ msgstr "Ñлой [%s] - невозможно запиÑаÑÑ ÑÑÑÐ¾ÐºÑ %d"
+#~ msgstr "невозможно найÑи вÑеменнÑй null-Ñайл %s"
+#~ msgstr "оÑибка пÑи запиÑи нÑлевой ÑÑÑоки %d"
+#~ msgstr "каÑегоÑии [%s] в набоÑе [%s] %s"
+#~ msgstr "каÑегоÑии векÑоÑного ÑÐ»Ð¾Ñ [%s] в набоÑе [%s] %s"
+#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ Ð²ÑеменнÑй Ñайл"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "невеÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ\n"
+#~ msgstr "EmbedGivenNulls: невеÑнÑй Ñип даннÑÑ
+#~ msgstr "СообÑиÑе ÑазÑабоÑÑикам GRASS об ÑÑой оÑибке.\n"
+#~ msgstr "G_set_null_value: невеÑнÑй Ñип даннÑÑ
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð²ÑÑоÑ"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового(Ñз) ÑлоÑ(Ñлоев) вÑÑоÑ"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ"
+#~ msgid ""
+#~ msgstr ""
+#~ "ÐдинÑÑÐ²ÐµÐ½Ð½Ð°Ñ Ð²ÐµÐºÑоÑÐ½Ð°Ñ ÐºÐ°ÑÑа Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¿Ð¾Ð´ÐºÐ»ÑÑена к неÑколÑким ÑаблиÑами "
+#~ "Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. ÐÑо ÑиÑло опÑеделÑÐµÑ ÐºÐ°ÐºÑÑ ÑаблиÑÑ Ð¸ÑполÑзоваÑÑ."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ÐпиÑание:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ÐлÑÑевÑе Ñлова:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ÐÑполÑзование:\n"
+#~ msgstr "ÑÑÐ¾Ð±Ñ ÑÑÑановиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
+#~ msgstr "поддеÑжка ÑвеÑа Ð´Ð»Ñ [%s] в набоÑе [%s] %s"
+#~ msgstr "Ðадана невеÑÐ½Ð°Ñ Ð²ÑÐµÐ¼ÐµÐ½Ð½Ð°Ñ Ð¼ÐµÑка Ð´Ð»Ñ %s каÑÑÑ %s в набоÑе %s"
+#~ msgstr "ÐевеÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла вÑеменной меÑки Ð´Ð»Ñ %s каÑÑÑ %s в набоÑе %s"
+#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑжаÑой ÑÐ»Ð¾Ñ [%s] из набоÑа [%s], ÑÑд %d"
+#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑÐ»Ð¾Ñ <%s@%s>, ÑÑд %d"
+#~ msgstr "невозможно опÑеделиÑÑ Ð´Ð¾Ð¼Ð°Ñний каÑалог полÑзоваÑелÑ"
+#~ msgstr "Ðевозможно ÑоздаÑÑ Ñайл заголовка Ð´Ð»Ñ [%s]"
+#~ msgid ""
+#~ msgstr ""
+#~ "Ñегион Ð´Ð»Ñ ÑекÑÑего набоÑа %s\n"
+#~ "вÑполниÑе \"g.region\""
+#~ msgstr "Ñегион по ÑмолÑÐ°Ð½Ð¸Ñ %s"
+#~ msgstr "нажмиÑе RETURN Ð´Ð»Ñ Ð¿ÑÐ¾Ð´Ð¾Ð»Ð¶ÐµÐ½Ð¸Ñ -->"
+#~ msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ Ñайла. Ðе должно бÑÑÑ '.' или 'NULL'\n"
+#~ msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ Ñайла. Ðнак <%c> недопÑÑÑим.\n"
+#~ msgstr "СлиÑком много каÑегоÑий Ð´Ð»Ñ ÑеклаÑÑиÑикаÑии [%s в %s]"
+#~ msgstr "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ ÑеклаÑÑиÑикаÑии в Ñайле заголовка Ð´Ð»Ñ [%s в %s]"
+#~ msgstr "Ðевозможно ÑоздаÑÑ Ñайл завиÑимоÑÑи Ð´Ð»Ñ [%s в %s]"
+#~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+#~ msgstr "G_malloc: невозможно вÑделиÑÑ %lu Ð±Ð°Ð¹Ñ Ð² %s:%d"
+#~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+#~ msgstr "G_calloc: невозможно вÑделиÑÑ %lu * %lu Ð±Ð°Ð¹Ñ Ð² %s:%d"
+#~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+#~ msgstr "G_realloc: невозможно вÑделиÑÑ %lu Ð±Ð°Ð¹Ñ Ð² %s:%d"
+#~ msgid ""
+#~ msgstr ""
+#~ "РаÑÑÑовÑй Ñлой <%s@%s> в пÑоекÑии оÑлиÑной Ð¾Ñ Ð¿ÑоекÑии ÑекÑÑего Ñегиона. "
+#~ "Ðайден ÑаÑÑÑовÑй Ñлой <%s@%s>, должно бÑÑÑ <%s> ."
+#~ msgid ""
+#~ msgstr "РаÑÑÑовÑй Ñлой <%s@%s> в дÑÑгой зоне (%d) Ñем ÑекÑÑий Ñегион (%d)"
+#~ msgstr "РаÑÑÑовÑй Ñлой <%s@%s>: ÑлиÑком много Ð±Ð°Ð¹Ñ Ð½Ð° ÑÑÐµÐ¹ÐºÑ (%d) "
+#~ msgid ""
+#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr ""
+#~ "Ñлой <%s@%s> ÑвлÑеÑÑÑ ÑвÑзÑÑ GDAL но GRASS ÑкомпилиÑован без поддеÑжки "
+#~ "GDAL"
+#~ msgid "G__open_raster_new(): no temp files available"
+#~ msgstr "G__open_raster_new(): недоÑÑÑÐ¿Ð½Ñ Ð²ÑеменнÑе ÑайлÑ"
+#~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+#~ msgstr ""
+#~ "G_set_fp_type(): Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð²Ñзвано ÑолÑко Ñ FCELL_TYPE или DCELL_TYPE"
+#~ msgstr "Ðевозможно найÑи '%s' в '%s'"
+#~ msgid ""
+#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr ""
+#~ "G_set_quant_rules() Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð²Ñзван ÑолÑко Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев Ð´Ð»Ñ "
+#~ "ÑÑениÑ"
+#~ msgstr "ÐÐµÑ ÑпÑавки Ð´Ð»Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ [%s]\n"
+#~ msgstr "невозможно запиÑаÑÑ Ð¸ÑÑоÑÐ¸Ñ Ð´Ð»Ñ [%s]"
+#~ msgstr "ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки"
+#~ msgstr ""
+#~ "ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки (truncated)"
+#~ msgid ""
+#~ "Unable to build spatial index from topology, vector map is not opened at "
+#~ "topo level 2"
+#~ msgstr ""
+#~ "Ðевозможно поÑÑÑоиÑÑ Ð¿ÑоÑÑÑанÑÑвеннÑй Ð¸Ð½Ð´ÐµÐºÑ Ð¸Ð· Ñопологии, векÑоÑнÑй Ñлой "
+#~ "не оÑкÑÑÑ Ð½Ð° вÑоÑом Ñопо ÑÑовне"
+#~ msgid "%d errors in category string."
+#~ msgstr "%d оÑибок в ÑÑÑоке каÑегоÑии."
+#~ msgstr ""
+#~ "Ðевозможно добавиÑÑ ÑвÑÐ·Ñ Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
, Ñлой не оÑкÑÑÑ Ð² Ñежиме запиÑи"
+#~ msgstr "Ðевозможно ÑвÑÐ·Ñ Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
+#~ msgstr "ÐÑибка в пÑавиле Ð´Ð»Ñ ÑÑда %d в %s"
+#~ msgid ""
+#~ "excess)"
+#~ msgstr ""
+#~ "Ð¤Ð°Ð¹Ð»Ñ coor векÑоÑного ÑÐ»Ð¾Ñ <%s@%s> болÑÑе, Ñем они Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ (на %ld "
+#~ "байÑов)"
+#~ msgid ""
+#~ "missing)."
+#~ msgstr ""
+#~ "Ð¤Ð°Ð¹Ð»Ñ coor векÑоÑного ÑÐ»Ð¾Ñ <%s@%s> менÑÑе, Ñем они Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ (на %ld "
+#~ "байÑов)"
+#~ msgstr "ÐеÑеÑеÑениÑ: %5d"
+#~ msgstr "Programmer requested unknown open level %d"
+#~ msgid "OGR format cannot be updated"
+#~ msgstr "OGR ÑоÑÐ¼Ð°Ñ Ð½Ðµ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½"
+#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ñлой <%s>"
+#~ msgid ""
+#~ "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr "ÐÐ»Ñ ÑÑого ÑÐ»Ð¾Ñ OGR не поддеÑживаеÑÑÑ cлÑÑайное ÑÑение"
+#~ msgstr "OGR обÑÐµÐºÑ Ð±ÐµÐ· ID пÑоигноÑиÑован"
+#~ msgstr "Ðевозможно ÑоздаÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
+#~ msgid "test, gpde"
+#~ msgstr "ÑеÑÑ, gpde"
+#~ msgid ""
+#~ msgstr ""
+#~ "попÑÑка найÑи ÑоÑки Ð´Ð»Ñ Ð¸Ð½ÑеÑполÑÑии занÑла ÑлиÑком много вÑемени -- "
+#~ "попÑобÑйÑе измениÑÑ Ñегион на облаÑÑÑ Ð³Ð´Ðµ ÑоÑки еÑÑÑ. ÐÑÑиÑление "
+#~ "пÑодолжаеÑÑÑ..."
+#~ msgid "Reading lines from vector map ... "
+#~ msgstr "ЧÑение линий из векÑоÑного ÑÐ»Ð¾Ñ ..."
+#~ msgid "Reading nodes from vector map ... "
+#~ msgstr "ЧÑение Ñзлов из векÑоÑного ÑÐ»Ð¾Ñ ..."
+#~ msgstr "еÑÑÑ ÑоÑки вне Ñказанного 2D/3D Ñегиона -- игноÑиÑÑÑÑÑÑ %d ÑоÑек"
+#~ msgstr "ÑоÑки %d игноÑиÑÑÑÑÑÑ -- ÑоÑки ÑÑоÑÑ ÑлиÑком ÑаÑÑо"
+#~ msgstr "некоÑоÑÑе ÑоÑки вне Ñегиона -- бÑдÑÑ Ð¿ÑоигноÑиÑованÑ"
+#~ msgstr "Ðевозможно ÑдалиÑÑ Ñлой/каÑегоÑÐ¸Ñ %d/%d линии %d"
+#~ msgstr "ÐÑилепленнÑе веÑÑинÑ"
+#~ msgstr "ÐовÑе ÑзлÑ"
+#~ msgid "Breaks"
+#~ msgstr "РазÑÑвÑ"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_sl.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5726,7 +5726,7 @@
#, fuzzy, c-format
-msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
+msgstr "Nezmo¾en odpreti datoteko %s v %s"
#, fuzzy, c-format
@@ -5793,6 +5793,53 @@
msgstr ""
+#, fuzzy
+msgstr "sloj [%s] - nezmo¾en zapisati vrstico %d"
+#, fuzzy
+msgstr "za obstojeèe rastrske sloje %d\n"
+#, fuzzy
+msgstr "Ne morem zapisati linije, sloj ni odprt"
+#, fuzzy
+msgstr "ne morem ustvariti novega procesa"
+#, fuzzy
+msgid ""
+msgstr ""
+"regija za trenutni \"mapset\" %s\n"
+"po¾eni \"g.region\""
+#, fuzzy
+msgstr "privzeta regija %s"
+#, fuzzy
+msgstr "Ne morem odpreti %s"
+#, fuzzy
+#, fuzzy
+msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
+#, fuzzy
+#, fuzzy
#~ msgstr "Nepoznan \"location\""
#~ msgstr "ne morem ustvariti novega procesa"
#, fuzzy
-#~ msgstr "sloj [%s] - nezmo¾en zapisati vrstico %d"
-#, fuzzy
#~ msgstr "ne morem spremeniti direktorija v %s"
@@ -5850,10 +5893,6 @@
#, fuzzy
-#~ msgstr "za obstojeèe rastrske sloje %d\n"
-#, fuzzy
#~ msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
@@ -5869,14 +5908,6 @@
#~ msgstr "ne morem ustvariti histograma za [%s v %s]"
#, fuzzy
-#~ msgstr "Ne morem zapisati linije, sloj ni odprt"
-#, fuzzy
-#~ msgstr "ne morem ustvariti novega procesa"
-#, fuzzy
#~ msgstr "preveè argumentov"
@@ -5903,17 +5934,6 @@
#~ msgid "line %d: <%s>"
#~ msgstr "linija %d: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "regija za trenutni \"mapset\" %s\n"
-#~ "po¾eni \"g.region\""
-#, fuzzy
-#~ msgstr "privzeta regija %s"
#~ msgid "is not set"
#~ msgstr "ni nastavljena"
@@ -5925,18 +5945,6 @@
#~ "%s"
#, fuzzy
-#~ msgstr "Ne morem odpreti %s"
-#, fuzzy
-#, fuzzy
-#~ msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
-#, fuzzy
#~ msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
@@ -6048,14 +6056,6 @@
#~ msgstr "Ne morem zapisati povezav z bazo podatkov."
#, fuzzy
-#~ msgstr "Nezmo¾en odpreti datoteko %s v %s"
-#, fuzzy
-#, fuzzy
@@ -6689,3 +6689,259 @@
#~ msgstr "ne najdem [%s] v [%s]"
+#~ msgstr "Nezmo¾en dodeliti spomin\n"
+#, fuzzy
+#~ msgstr "Nezmo¾en odpreti datoteko %s v %s"
+#, fuzzy
+#, fuzzy
+#~ msgstr "za obstojeèe rastrske sloje %d\n"
+#~ msgstr "Rastrski sloj %s@%s je prazen"
+#~ msgstr "Ne morem zapisati \"quant\" pravil: sloj %s je integer"
+#, fuzzy
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): projekcija/cona je razlièna od tiste, ki je doloèena za "
+#~ "trenutno odprte rastrske sloje"
+#~ msgstr "Razpon plavajoèih podatkov za %s@%s je prazen"
+#~ msgstr "Razpon integer podatkov za %s@%s je prazen"
+#~ msgstr "sloj [%s] - nezmo¾en zapisati vrstico %d"
+#, fuzzy
+#~ msgstr "Nezmo¾en odpreti datoteko s tabelo fundamentalne toèke: %s"
+#~ msgstr "napaka pri pisanju \"null\" vrstice %d"
+#~ msgstr "podpora za kategorije za [%s] v \"mapset\" [%s] %s"
+#~ msgstr "podpora za kategorije za vektorski sloj [%s] v \"mapset\" [%s] %s"
+#~ msgstr "Ne morem odpreti temp datoteke"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "neveljavna projekcija\n"
+#~ msgstr "EmbedGivenNulls: napaèen tip podatkov!"
+#~ msgstr "Prosim sporoèite razvijalcem GRASS-a o tej napaki.\n"
+#~ msgstr "G_set_null_value: napaèen tip podatkov!"
+#, fuzzy
+#~ msgstr "Ime vhodnega rastrskega sloja"
+#, fuzzy
+#~ msgstr "©tevilka sloja"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Opis:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Uporaba:\n"
+#~ msgstr "mo¾nosti: %s\n"
+#~ msgstr "za izbrati privzeto"
+#~ msgstr "barvna podpora za [%s] v \"mapset\" [%s] %s"
+#~ msgstr "timestamp doloèen za %s v sloju %s v \"mapset\" %s je neveljaven "
+#~ msgstr "Neveljavna timestamp datoteka za %s sloj %s v \"mapset\" %s"
+#, fuzzy
+#~ msgstr "napaka pri branju %s sloja [%s] v \"mapset\" [%s], vrstica %d"
+#, fuzzy
+#~ msgstr "ne morem doloèiti uporabnikovega domaèega direktorija"
+#~ msgstr "Nezmo¾en ustvariti vzglavno datoteko za [%s]"
+#~ msgid ""
+#~ "region for current mapset %s\n"
+#~ "run \"g.region\""
+#~ msgstr ""
+#~ "regija za trenutni \"mapset\" %s\n"
+#~ "po¾eni \"g.region\""
+#~ msgid "default region %s"
+#~ msgstr "privzeta regija %s"
+#~ msgstr "pritisnite RETURN za nadaljevanje -->"
+#~ msgstr "Neveljavno ime datoteke. Ne more biti '.' ali 'NULL'\n"
+#, fuzzy
+#~ msgstr "Neveljavno ime. Znak <%c> je prepovedan."
+#~ msgstr "Preveè reklasifikacijskih kategorij za [%s v %s]"
+#~ msgstr ""
+#~ "Neveljaven reklasifikacijski format v vzglavni datoteki za [%s v %s]"
+#~ msgstr "Nezmo¾en ustvariti datoteko odvisnosti v [%s v %s]"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "[%s] v \"mapset\" [%s] - je v drugaèni projekciji kot trenutna regija:\n"
+#~ "najden sloj [%s] v: <%s>, moral bi biti <%s> "
+#, fuzzy
+#~ msgid ""
+#~ msgstr "[%s] v \"mapset\" [%s] - v drugi coni [%d] kot trenutna regija [%d]"
+#, fuzzy
+#~ msgstr "[%s] v [%s] - bajtov na celico (%d) preveè"
+#, fuzzy
+#~ msgstr "ne najdem [%s]"
+#~ msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
+#~ msgstr "ne morem zapisati \"history\" podatkov za [%s]"
+#, fuzzy
+#~ msgstr ""
+#~ "Ne morem dodati povezave z bazo podatkov, sloj ni odprt v ZAPISOVALNEM "
+#~ "naèinu."
+#, fuzzy
+#~ msgstr "Ne morem dodati povezave z bazo podatkov."
+#~ msgstr "Napaka v pravilu na vrstici %d v %s"
+#, fuzzy
+#~ msgstr "Druga projekcija"
+#, fuzzy
+#~ msgstr "ne morem spremeniti direktorija v %s"
+#, fuzzy
+#~ msgstr "Opozorilo, Za¾elen programer: nepoznan open_level\n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "ne morem odpreti rastrskega sloja [%s v %s]"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr "Ne morem izbrisati linije, sloj '%s' ni odprt na nivoju 2"
+#, fuzzy
+#~ msgid ""
+#~ msgstr "Ne morem izbrisati linije, sloj '%s' ni odprt v zapisovalnem naèinu"
+#, fuzzy
+#~ msgstr "Ne najdem vhodnega sloja '%s'"
+#~ msgstr "Ne morem prepisati linije"
+#, fuzzy
+#~ msgstr "LOCATION << %s >> ne obstaja"
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_th.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5775,7 +5775,7 @@
#, fuzzy, c-format
-msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹à¸ªà¸³à¸«à¸£à¸±à¸ [%s in %s]"
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ [%s] à¸à¸à¸à¸à¸¥à¸¸à¹à¸¡ [%s à¹à¸ %s]"
#, fuzzy, c-format
@@ -5843,20 +5843,67 @@
msgstr ""
#, fuzzy
-#~ msgstr "à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´à¹à¸à¹à¸¡à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸à¸¶à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¹à¸à¹à¸à¹"
+msgstr "à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´à¹à¸à¹à¸¡à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸à¸¶à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¹à¸à¹à¸à¹"
#, fuzzy
-#~ msgstr "à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´à¹à¸à¹à¸¡à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸à¸¶à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¹à¸à¹à¸à¹(à¸à¸±à¸à¸ªà¸±à¹à¸)"
+msgstr "à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´à¹à¸à¹à¸¡à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸à¸¶à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¹à¸à¹à¸à¹(à¸à¸±à¸à¸ªà¸±à¹à¸)"
+#, fuzzy
+msgstr "à¸à¸à¸ªà¸à¸, gpde"
+#, fuzzy
+msgstr "à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸¡à¹à¹à¸à¹à¸à¸¹à¸à¹à¸à¸´à¸à¹à¸à¸·à¹à¸à¹à¸à¸µà¸¢à¸à¹à¸à¸§à¹à¸à¹ %d"
+#, fuzzy
+msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸à¸à¸²à¸£à¹à¸à¸µà¸¢à¸ floating point format file สำหรัà¸à¹à¸à¸à¸à¸µà¹ %s"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸,à¹à¸à¸à¸à¸µà¹à¹à¸¡à¹à¹à¸à¸à¸¹à¸à¹à¸à¸´à¸"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸à¸²à¸£à¸à¸³à¸à¸²à¸à¹à¸«à¸¡à¹à¹à¸à¹"
+#, fuzzy
+msgid ""
+msgstr ""
+"à¸à¸à¸à¹à¸à¸à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ %s\n"
+"à¸à¸³à¸à¸²à¸ \"g.region\""
+#, fuzzy
+msgstr "à¸à¸à¸à¹à¸à¸à¸à¸±à¹à¸à¸à¹à¸ %s"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¹ %s"
+#, fuzzy
+msgstr "มีà¸à¸±à¸à¸«à¸²à¹à¸à¸à¸²à¸£à¸à¹à¸²à¸ cell à¹à¸à¸¥à¹"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹à¸ªà¸³à¸«à¸£à¸±à¸ [%s in %s]"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸¥à¸à¸à¸à¸²à¸£à¸²à¸à¹à¸à¹ <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸£à¸°à¸à¸¸ pj à¹à¸à¸£à¸²à¸°à¸§à¹à¸²: %s"
#~ msgstr "à¸à¸³à¹à¸«à¸à¹à¸à¸à¸µà¹à¹à¸¡à¹à¸£à¸¹à¹à¸à¸±à¸"
-#, fuzzy
-#~ msgstr "à¸à¸à¸ªà¸à¸, gpde"
#~ msgstr "à¹à¸à¸¥à¹à¸à¸à¸à¸à¸³à¸à¸§à¸ [%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s] %s"
@@ -5888,10 +5935,6 @@
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸§à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ%i"
#, fuzzy
-#~ msgstr "à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸¡à¹à¹à¸à¹à¸à¸¹à¸à¹à¸à¸´à¸à¹à¸à¸·à¹à¸à¹à¸à¸µà¸¢à¸à¹à¸à¸§à¹à¸à¹ %d"
-#, fuzzy
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> "
@@ -5910,10 +5953,6 @@
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸à¸à¸²à¸£à¹à¸à¸µà¸¢à¸ floating point format file สำหรัà¸à¹à¸à¸à¸à¸µà¹ %s"
#, fuzzy
-#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸à¸à¸²à¸£à¹à¸à¸µà¸¢à¸ floating point format file สำหรัà¸à¹à¸à¸à¸à¸µà¹ %s"
-#, fuzzy
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹à¸ªà¸³à¸«à¸£à¸±à¸ [%s in %s]"
@@ -5936,14 +5975,6 @@
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸¥à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¹à¸à¹"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸,à¹à¸à¸à¸à¸µà¹à¹à¸¡à¹à¹à¸à¸à¸¹à¸à¹à¸à¸´à¸"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸à¸²à¸£à¸à¸³à¸à¸²à¸à¹à¸«à¸¡à¹à¹à¸à¹"
#~ msgstr "à¸à¸±à¸§à¹à¸à¸£à¸¡à¸²à¸à¹à¸à¸´à¸à¹à¸"
@@ -5966,17 +5997,6 @@
#~ msgstr "à¸à¸£à¸£à¸à¸±à¸ %d: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "à¸à¸à¸à¹à¸à¸à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ %s\n"
-#~ "à¸à¸³à¸à¸²à¸ \"g.region\""
-#, fuzzy
-#~ msgstr "à¸à¸à¸à¹à¸à¸à¸à¸±à¹à¸à¸à¹à¸ %s"
#~ msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸²à¸£à¸à¸³à¸«à¸à¸"
@@ -5987,18 +6007,6 @@
#~ "à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸\n"
#~ "%s"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¹ %s"
-#, fuzzy
-#~ msgstr "มีà¸à¸±à¸à¸«à¸²à¹à¸à¸à¸²à¸£à¸à¹à¸²à¸ cell à¹à¸à¸¥à¹"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹à¸ªà¸³à¸«à¸£à¸±à¸ [%s in %s]"
#~ msgid "Vector is not 3D"
#~ msgstr "à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¹à¸ªà¹à¸ à¹à¸¡à¹à¹à¸à¹à¹à¸à¸ 3D"
@@ -6196,14 +6204,6 @@
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¹ %s"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸¥à¸à¸à¸à¸²à¸£à¸²à¸à¹à¸à¹ <%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸£à¸°à¸à¸¸ pj à¹à¸à¸£à¸²à¸°à¸§à¹à¸²: %s"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¸£à¸£à¸¢à¸²à¸¢à¸à¸²à¸£à¸²à¸à¸à¸µà¹à¹à¸à¹ <%s>"
@@ -6559,3 +6559,307 @@
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸à¸«à¸² [%s] à¹à¸ [%s]"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸à¸à¸«à¸à¹à¸§à¸¢à¸à¸§à¸²à¸¡à¸à¸³à¹à¸à¹\n"
+#~ msgstr "à¸à¸²à¸à¸à¸°à¹à¸à¸´à¸à¸à¸²à¸à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¸à¸à¸ à¹à¸à¸£à¹à¸à¸£à¸¡"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ %s à¹à¸à¹"
+#, fuzzy
+#, fuzzy
+#~ msgstr "มีà¸à¸±à¸à¸«à¸²à¹à¸à¸à¸²à¸£à¸à¹à¸²à¸ cell à¹à¸à¸¥à¹"
+#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ%s@%s วà¹à¸²à¹à¸à¸¥à¹à¸²"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸à¸à¸à¸à¸à¸à¸à¸£à¸´à¸¡à¸²à¸: à¹à¸à¸à¸à¸µà¹ %s à¸à¸·à¸à¸à¸³à¸à¸§à¸à¹à¸à¹à¸¡"
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr "G_set_window(): à¸à¸²à¸£à¸à¸²à¸¢/à¹à¸à¸ à¹à¸à¸à¸à¹à¸²à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
+#~ msgstr "à¸à¹à¸§à¸à¸à¸à¸¡à¸¹à¸¥ floating สำหรัภ%s@%s วà¹à¸²à¹à¸à¸¥à¹à¸²"
+#~ msgstr "à¸à¹à¸§à¸à¸à¹à¸à¸¡à¸¹à¸¥ à¸à¸³à¸à¸§à¸à¹à¸à¹à¸¡ %s@%s วà¹à¸²à¹à¸à¸¥à¹à¸²"
+#~ msgstr "%s: à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸¡à¹à¹à¸à¹à¸à¸¹à¸à¹à¸à¸´à¸à¹à¸à¸·à¹à¸à¹à¸à¸µà¸¢à¸ - à¸à¸²à¸£à¸£à¹à¸à¸à¸à¸à¸à¸¹à¸à¸¢à¸à¹à¸¥à¸´à¸"
+#~ msgstr "%s: à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¸à¸±à¸§à¸à¸à¸´à¸à¸²à¸¢à¹à¸à¸¥à¹à¹à¸à¹ - à¸à¸²à¸£à¸£à¹à¸à¸à¸à¸à¸à¸¹à¸à¸¢à¸à¹à¸¥à¸´à¸"
+#~ msgstr "à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸¡à¹à¹à¸à¹à¸à¸¹à¸à¹à¸à¸´à¸à¹à¸à¸·à¹à¸à¹à¸à¸µà¸¢à¸à¹à¸à¸§à¹à¸à¹ %d"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸à¸«à¸²à¹à¸à¸¥à¹à¸à¸±à¹à¸à¸£à¸²à¸§à¹à¸à¹ %s"
+#~ msgstr "à¸à¸²à¸£à¹à¸à¸µà¸¢à¸à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸µà¹à¹à¸à¸§à¹à¸à¸¥à¹à¸² %d"
+#~ msgstr "à¸à¸²à¸£à¹à¸à¹à¸à¸à¸¥à¸¸à¹à¸¡à¸£à¸à¸à¸£à¸±à¸à¸ªà¸³à¸«à¸£à¸±à¸ [%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s] %s"
+#~ msgstr "à¸à¸²à¸£à¹à¸à¹à¸à¸à¸¥à¸¸à¹à¸¡à¸£à¸à¸à¸£à¸±à¸à¸ªà¸³à¸«à¸£à¸±à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ [%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s] %s"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ temp à¹à¸à¸¥à¹"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "à¸à¸²à¸£à¸à¸²à¸¢à¸ าà¸à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸\n"
+#~ msgstr "EmbedGivenNulls:à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸´à¸à¸à¸£à¸°à¹à¸ à¸!"
+#~ msgstr "à¹à¸à¸£à¸à¹à¸à¹à¸à¸à¸à¹à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸«à¹à¸à¸±à¸ à¸à¸µà¸à¸±à¸à¸à¸² GRASS\n"
+#~ msgstr "G_set_null_value: à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸´à¸à¸à¸£à¸°à¹à¸ à¸!"
+#~ msgstr "à¸à¸·à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸§à¸²à¸¡à¸ªà¸¹à¸à¹à¸à¸´à¸à¸ าà¸"
+#~ msgstr "à¸à¸³à¸à¸§à¸à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥"
+#~ msgid ""
+#~ msgstr ""
+#~ "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ 1 à¹à¸à¸à¸à¸µà¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸·à¹à¸à¸¡à¸à¹à¸à¸à¸±à¸à¸«à¸¥à¸²à¸¢à¸à¸²à¸£à¸²à¸à¹à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥ "
+#~ "ลำà¸à¸±à¸à¸£à¸°à¸à¸¸à¸à¸²à¸£à¹à¸à¸·à¹à¸à¸¡à¸à¹à¸à¸à¸±à¸à¸à¸²à¸£à¸²à¸à¹à¸"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "à¸à¸³à¸à¸à¸´à¸à¸²à¸¢:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "à¸à¸³à¹à¸à¸à¸²à¸°:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "วิà¸à¸µà¹à¸à¹:\n"
+#~ msgstr "à¹à¸à¸·à¹à¸à¸à¹à¸: %s\n"
+#~ msgstr "à¹à¸à¹à¸à¹à¸²à¸à¸±à¹à¸à¸à¹à¸"
+#~ msgstr "รà¸à¸à¸£à¸±à¸à¸à¸²à¸£à¹à¸à¹à¸ªà¸µà¸ªà¸³à¸«à¸£à¸±à¸ [%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s] %s"
+#~ msgstr "à¹à¸à¸¥à¹à¸¥à¸à¹à¸§à¸¥à¸²à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸ สำหรัภ%s à¹à¸à¸à¸à¸µà¹ %s à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ %s"
+#, fuzzy
+#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸à¸à¸²à¸£à¸à¹à¸²à¸à¸à¸²à¸£à¸à¸µà¸à¸à¸±à¸à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s], à¹à¸à¸§ %d"
+#, fuzzy
+#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸à¸à¸²à¸£à¸à¹à¸²à¸à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s], à¹à¸à¸§ %d"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸² home directory à¸à¸à¸à¸à¸¹à¹à¹à¸à¹"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹ [%s] à¹à¸à¹"
+#~ msgid ""
+#~ msgstr ""
+#~ "à¸à¸à¸à¹à¸à¸à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ %s\n"
+#~ "à¸à¸³à¸à¸²à¸ \"g.region\""
+#~ msgstr "à¸à¸à¸à¹à¸à¸à¸à¸±à¹à¸à¸à¹à¸ %s"
+#~ msgstr "à¸à¸ RETURN à¹à¸à¸·à¹à¸à¸à¸³à¹à¸à¸´à¸à¸à¸²à¸£à¸à¹à¸ -->"
+#~ msgstr "à¸à¸·à¸à¹à¸à¸¥à¹à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸ à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¹ '.' หรืภ'NULL'\n"
+#~ msgstr "à¸à¸·à¸à¹à¸à¸¥à¹à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸ à¸à¸±à¸§à¸à¸±à¸à¸©à¸£ <%c> à¹à¸à¹à¹à¸¡à¹à¹à¸à¹\n"
+#~ msgstr "à¸à¸¥à¸¸à¹à¸¡à¸¡à¸²à¸à¹à¸à¸´à¸à¹à¸ สำหรัภ[%s in %s]"
+#~ msgstr "รูà¸à¹à¸à¸à¸à¸²à¸£à¸à¸±à¸à¸à¸¥à¸¸à¹à¸¡à¹à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸ สำหรัภ[%s à¹à¸ %s]"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸ dependency à¸à¸à¸à¹à¸à¸¥à¹à¸ªà¸³à¸«à¸£à¸±à¸ [%s à¹à¸ %s]"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "[%s] à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s] - à¹à¸à¸à¸²à¸£à¸à¸²à¸¢à¸ าà¸à¸à¸µà¹à¹à¸à¸à¸à¹à¸²à¸à¸à¸²à¸à¸à¸à¸à¹à¸à¸à¸à¸±à¸à¸à¸¸à¸à¸±à¸:\n"
+#~ " à¸à¸à¹à¸à¸à¸à¸µà¹ [%s] à¹à¸: <%s>, à¸à¸§à¸£à¸à¸° <%s> "
+#, fuzzy
+#~ msgid ""
+#~ msgstr "[%s] à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ [%s] - à¹à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸à¸à¹à¸²à¸ [%d] à¸à¸²à¸à¸à¸à¸à¹à¸à¸à¸à¸±à¸à¸à¸¸à¸à¸±à¸ [%d]"
+#, fuzzy
+#~ msgstr "[%s] à¹à¸ [%s] - bytes à¸à¹à¸ cell (%d) à¹à¸«à¸à¹à¹à¸à¸´à¸à¹à¸"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸à¸«à¸² [%s]"
+#~ msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸§à¸²à¸¡à¸à¹à¸§à¸¢à¹à¸«à¸¥à¸·à¸à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¸µà¹ [%s]\n"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸£à¸°à¸§à¸±à¸à¸´ สำหรัภ[%s]"
+#~ msgstr "à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´à¹à¸à¹à¸¡à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸à¸¶à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¹à¸à¹à¸à¹"
+#~ msgstr "à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´à¹à¸à¹à¸¡à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸à¸¶à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¹à¸à¹à¸à¹(à¸à¸±à¸à¸ªà¸±à¹à¸)"
+#~ msgstr "%d à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸à¸«à¸¡à¸§à¸à¸à¸à¸à¸à¸±à¸§à¸à¸±à¸à¸©à¸£"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¹à¸¡à¸à¸²à¸£à¹à¸à¸·à¹à¸à¸¡à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥, à¹à¸à¸à¸à¸µà¹à¹à¸¡à¹à¹à¸à¹à¹à¸à¸´à¸à¹à¸à¸·à¹à¸ à¸à¸²à¸£à¹à¸à¸µà¸¢à¸"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¹à¸¡à¸à¸²à¸£à¹à¸à¸·à¹à¸à¸¡à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥,"
+#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸ à¸à¸ à¸à¸ à¹à¸à¸§ %d à¹à¸ %s"
+#, fuzzy
+#~ msgstr "à¸à¸²à¸£à¸à¸²à¸¢à¹à¸à¸à¸à¸·à¹à¸"
+#~ msgstr "à¹à¸à¸£à¹à¸à¸£à¸¡à¹à¸¡à¸à¸£à¹à¸à¹à¸à¸à¸à¸²à¸£à¸à¸£à¸²à¸à¸£à¸°à¸à¸±à¸à¸à¸µà¹à¸à¸°à¹à¸à¸´à¸ %d"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¸à¹à¸à¸¡à¸¹à¸¥ %d à¹à¸¡à¹à¸¡à¸µ ID à¸à¸±à¸à¸à¸à¸"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> "
+#~ msgstr "à¸à¸à¸ªà¸à¸, gpde"
+#~ msgid ""
+#~ msgstr ""
+#~ "à¹à¸à¹à¹à¸§à¸¥à¸²à¸à¸²à¸à¹à¸à¸à¸²à¸£à¸«à¸²à¸à¸¸à¸à¹à¸à¸·à¹à¸ interpolation--à¹à¸à¸£à¸à¹à¸à¸¥à¸µà¹à¸¢à¸à¸à¸à¸à¹à¸à¸à¸à¸à¸à¸à¸·à¹à¸à¸à¸µà¹à¸à¸²à¸¡à¸à¸¸à¸à¸à¸µà¹à¸à¸¸à¸à¹à¸¥à¸·à¸à¸ "
+#~ "à¹à¸¥à¹à¸§à¸à¸³à¸à¸§à¸à¸à¹à¸..."
+#~ msgstr "à¸à¸³à¸¥à¸±à¸à¸à¹à¸²à¸ à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸²à¸ à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¹à¸ªà¹à¸..."
+#~ msgstr "à¸à¸³à¸¥à¸±à¸à¸à¹à¸²à¸ nodes à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¹à¸ªà¹à¸"
+#~ msgstr "มี strip à¸à¸¢à¸¹à¹à¹à¸à¹à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¹à¹à¸¡à¹à¹à¸à¹"
+#~ msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸¸à¸à¸à¸¢à¸¹à¹à¸à¸à¸à¸à¸à¸à¹à¸à¸2 D/3D --ยà¸à¹à¸¥à¸´à¸ %d à¸à¸¸à¸"
+#~ msgstr "à¸à¸³à¸¥à¸±à¸à¸¢à¸à¹à¸¥à¸´à¸ %d à¸à¸¸à¸ -- à¹à¸à¹à¸à¹à¸à¸´à¸à¹à¸"
+#~ msgstr "à¸à¸²à¸à¸à¸¸à¸à¸à¸¢à¸¹à¹à¸à¸à¸à¸à¸à¸à¹à¸à¸ -- à¸à¸±à¸à¸à¸à¸..."
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸¥à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¹à¸à¹"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸±à¸à¸¥à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¹à¸à¹à¸à¹à¸ <%s>"
+#~ msgid "Snapped vertices"
+#~ msgstr "à¸à¸¹à¸à¹à¸à¹à¸²à¸«à¸² à¸à¸¸à¸à¸«à¸±à¸"
+#~ msgid "New vertices"
+#~ msgstr "à¹à¸à¸´à¹à¸¡ à¸à¸¸à¸à¸«à¸±à¸"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ สà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹à¹à¸à¹"
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸¥à¸,à¹à¸à¸à¸à¸µà¹ '%s à¹à¸¡à¹à¹à¸à¸à¸¹à¸à¹à¸à¸´à¸ à¹à¸à¸£à¸°à¸à¸±à¸ 2"
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸¥à¸,à¹à¸à¸à¸à¸µà¹ '%s à¹à¸¡à¹à¹à¸à¸à¸¹à¸à¹à¸à¸´à¸ à¹à¸à¸·à¹à¸à¹à¸à¸µà¸¢à¸"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸à¸à¹à¸à¸à¸à¸µà¹à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸³à¹à¸à¹à¸² '%s'"
+#~ msgid "Column type not supported"
+#~ msgstr "à¹à¸¡à¹à¸£à¸à¸à¸£à¸±à¸ à¸à¸à¸´à¸ Column à¸à¸µà¹"
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸à¹à¸«à¸¡à¹"
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_tr.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2469,7 +2469,7 @@
#: ../lib/vector/diglib/file.c:205
#, fuzzy
msgid "Unable to load file to memory, file not open"
-msgstr "vektör harita açılamadı"
+msgstr "Geçici dosya açılamıyor"
#: ../lib/vector/diglib/file.c:220
msgid "Vector memory mode not supported, using 'AUTO'"
@@ -2540,8 +2540,9 @@
msgstr ""
#: ../lib/vector/Vlib/write_nat.c:910
+#, fuzzy
msgid "Attempt to restore alive feature"
-msgstr ""
+msgstr "%d çizgisi okunamıyor"
#: ../lib/vector/Vlib/legal_vname.c:45
#, c-format
@@ -5577,7 +5578,7 @@
#, fuzzy, c-format
-msgstr "<%s> için aralık dosyası açılamıyor"
+msgstr "[%s in %s] içindeki [%s] dosyası açılamadı"
#, fuzzy, c-format
@@ -5645,14 +5646,57 @@
msgstr ""
#, fuzzy
-#~ msgstr "Komut satırında kaydetmek için geçmiŠdosyasında yetersiz alan"
+msgstr "Komut satırında kaydetmek için geçmiŠdosyasında yetersiz alan"
#, fuzzy
-#~ msgstr ""
-#~ "Komut satırında kaydetmek için geçmiŠdosyasında yetersiz alan (kesiliyor)"
+msgstr ""
+"Komut satırında kaydetmek için geçmiŠdosyasında yetersiz alan (kesiliyor)"
+#, fuzzy
+msgstr "[%s] haritası - %d satırı yazılamıyor"
+#, fuzzy
+msgstr "Kategori indeks dosyasını yazmada hata <%s>"
+#, fuzzy
+msgstr "vektör harita açılamadı"
+#, fuzzy
+msgstr "Yeni bir süreç oluÅturulamıyor"
+#, fuzzy
+msgid ""
+msgstr ""
+"geçerli %s harita takımı bölgesi\n"
+"\"g.region\" çalıÅtırın"
+#, fuzzy
+msgstr "%s varsayılan bölge"
+#, fuzzy
+msgstr "<%s> vektörü kapatılamıyor"
+#, fuzzy
+msgstr "Girdi raster haritası adı"
+#, fuzzy
+msgstr "<%s> raster haritasının renk dosyası okunamıyor"
+#, fuzzy
+msgstr "<%s> tablosuna kopyalanamıyor"
#~ msgstr "Bilinmeyen Mevki"
@@ -5683,10 +5727,6 @@
#~ msgstr "%i raster satırı yazılamıyor"
-#, fuzzy
-#~ msgstr "[%s] haritası - %d satırı yazılamıyor"
#~ msgstr "<%s@%s> raster haritası açılamıyor"
@@ -5696,24 +5736,12 @@
#~ msgstr "'%s' açılamadı"
-#, fuzzy
-#~ msgstr "Kategori indeks dosyasını yazmada hata <%s>"
#~ msgstr "[%s deki %s] in histogramı oluÅturulamıyor"
#~ msgid "Feature: "
#~ msgstr "Obje: "
-#, fuzzy
-#~ msgstr "vektör harita açılamadı"
-#, fuzzy
-#~ msgstr "Yeni bir süreç oluÅturulamıyor"
#~ msgstr "Ãok fazla parametre"
@@ -5732,17 +5760,6 @@
#~ msgstr "%d çizgi: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "geçerli %s harita takımı bölgesi\n"
-#~ "\"g.region\" çalıÅtırın"
-#, fuzzy
-#~ msgstr "%s varsayılan bölge"
#~ msgstr "ayarlanamadı"
@@ -5753,18 +5770,6 @@
#~ "geçersizdir\n"
#~ "%s"
-#, fuzzy
-#~ msgid "Unable to set region"
-#~ msgstr "<%s> vektörü kapatılamıyor"
-#, fuzzy
-#~ msgstr "Girdi raster haritası adı"
-#, fuzzy
-#~ msgstr "<%s> raster haritasının renk dosyası okunamıyor"
#~ msgstr "Vektör 3B deÄil"
@@ -5883,10 +5888,6 @@
#~ msgstr "%s veritabanı açılamıyor"
-#, fuzzy
-#~ msgstr "<%s> tablosuna kopyalanamıyor"
#~ msgstr "<%s> tablosu tanımlanamıyor"
@@ -6221,3 +6222,249 @@
#, fuzzy
#~ msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
#~ msgstr "%s: Alan %d mevcut deÄil"
+#, fuzzy
+#~ msgstr "Matris için boŠalan ayrılamıyor"
+#~ msgstr "Muhtemelen program hatası."
+#, fuzzy
+#~ msgstr "<%s> katmanı açılamıyor"
+#~ msgid "Unable to open temporary file"
+#~ msgstr "Geçici dosya açılamıyor"
+#~ msgstr " %s@%s için kayar nokta veri aralıÄı boÅ"
+#~ msgstr " %s@%s için tamsayı veri aralıÄı boÅ"
+#~ msgstr "%s: [%s] haritası yazmak için açılamıyor - istek yok sayıldı"
+#~ msgstr "%s: açılamayan dosya tanımlatıcı - istek yok sayıldı"
+#~ msgstr "[%s] haritası - %d satırı yazılamıyor"
+#~ msgstr "%s geçici boŠdosyası bulunamadı"
+#~ msgstr "%d boŠsatırları yazmada hata"
+#~ msgstr "[%s] %s harita takımındaki [%s] in kategori desteÄi"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "geçersiz projeksiyon\n"
+#~ msgid "Name of elevation raster map"
+#~ msgstr "Yükselti raster haritası adı"
+#~ msgstr "Katman numarası"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Tanım:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Anahtar kelimeler:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Kullanım:\n"
+#, fuzzy
+#~ msgstr " geçerli seçenekler: %s\n"
+#~ msgid "to accept the default"
+#~ msgstr "varsayılanı kabul et"
+#~ msgstr "[%s] %s harita takımındaki [%s] için renk desteÄi"
+#~ msgid "Can't create timestamp file for %s map %s in mapset %s"
+#~ msgstr ""
+#~ "%s harita takımındaki %s haritası %s için zaman damgası dosyası "
+#~ "oluÅturulamıyor"
+#~ msgstr ""
+#~ " %s harita takımındaki %s haritası %s için geçersiz zaman damgası dosyası "
+#~ "belirlendi"
+#~ msgstr ""
+#~ " %s harita takımındaki %s haritası %s için geçersiz zaman damgası dosyası"
+#~ msgstr "<%s@%s> sıkıÅtırılmıŠharitasını okumada hata, satır %d"
+#~ msgstr "<%s@%s> haritasını okumada hata, satır %d"
+#~ msgstr "kullanıcı ev dizini belirlenemiyor"
+#~ msgstr "[%s] için üstbilgi dosyası oluÅturulamıyor"
+#~ msgid ""
+#~ msgstr ""
+#~ "geçerli %s harita takımı bölgesi\n"
+#~ "\"g.region\" çalıÅtırın"
+#~ msgstr "%s varsayılan bölge"
+#~ msgstr "Devam etmek için ENTER'a basın -->"
+#~ msgstr "Uygun olmayan dosya adı. '.' veya 'NULL' olmamalı\n"
+#~ msgstr "Uygun olmayan dosya adı. <%c> karakteri kullanılamaz.\n"
+#~ msgstr "[%s in %s] için çok fazla yeniden sınıflandırma kategorisi"
+#~ msgid "Unable to create header file for [%s in %s]"
+#~ msgstr "[%s deki %s] için üst bilgi dosyası oluÅturulamıyor"
+#~ msgstr "[%s deki %s] için baÄımlılık dosyası oluÅturulamıyor"
+#, fuzzy
+#~ msgstr "'%s' bulunamadı"
+#~ msgstr "[%s] komutu için yardım yoktur\n"
+#~ msgstr "[%s] in geçmiŠbilgisi yazılamıyor"
+#~ msgstr "Komut satırında kaydetmek için geçmiŠdosyasında yetersiz alan"
+#~ msgstr ""
+#~ "Komut satırında kaydetmek için geçmiŠdosyasında yetersiz alan (kesiliyor)"
+#~ msgstr "Veritabanı baÄlantısı eklenemiyor, harita WRITE modunda açılmadı"
+#~ msgid "Unable to add database link"
+#~ msgstr "Veritabanı baÄlantısı eklenemiyor"
+#, fuzzy
+#~ msgstr "KesiÅimler:"
+#, fuzzy
+#~ msgstr "<%s> vektör haritası silinemiyor"
+#~ msgstr "ID'si olmayan OGR objesi görmezden gelindi"
+#~ msgstr "<%s> raster haritası oluÅturulamıyor"
+#~ msgid ""
+#~ msgstr ""
+#~ "enterpolasyon için nokta bulmak çok zaman alacak-- lütfen bölgeyi, "
+#~ "noktalarınızın bulunduÄu alana deÄiÅtirn. Hesaplamaya devam ediliyor..."
+#~ msgstr "yetersiz veriye sahip Åerit var"
+#~ msgstr ""
+#~ "Belirlenen 2D/3D bölgenin dıÅında noktalar var -- %d nokta yok sayılıyor"
+#~ msgstr "%d nokta yok sayılıyor -- çok yoÄun"
+#~ msgstr "bazı noktalar bölgenin dıÅında -- yok sayılacak..."
+#, fuzzy
+#, fuzzy
+#~ msgstr "Vektör harita <%s> ten <%s> e kopyalanamıyor"
+#, fuzzy
+#~ msgstr "Tüm kırıklık noktaları"
+#, fuzzy
+#, fuzzy
+#~ msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
+#~ msgstr "%s: Alan %d mevcut deÄil"
+#, fuzzy
+#~ msgstr "%d çizgisi okunamıyor"
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#, fuzzy
+#~ msgstr "Sembol bulunamıyor/açılamıyor: '%s'"
+#~ msgstr "Ãizgi yeniden yazılamıyor"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_vi.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -721,7 +721,7 @@
#: ../lib/raster/color_rules.c:268
#, fuzzy, c-format
msgid "Unable to load color rules <%s>"
-msgstr "không thá» Äá»i thư mục Äến %s"
+msgstr "Không thá» Äóng vec-tÆ¡ <%s>"
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
@@ -5777,7 +5777,7 @@
#, fuzzy, c-format
-msgstr "Không thá» tạo ra táºp tin header cho [%s á» %s]"
+msgstr "Không thá» má» táºp tin [%s] cá»§a nhóm [%s trong %s]"
#, fuzzy, c-format
@@ -5846,24 +5846,75 @@
msgstr "nhóm phụ <%s> cá»§a nhóm <%s> tham chiếu các bản Äá» raster sau\n"
#, fuzzy
-#~ msgstr "Không Äá»§ không gian trong táºp tin lá»ch sá» Äá» lưu dòng lá»nh."
+msgstr "Không Äá»§ không gian trong táºp tin lá»ch sá» Äá» lưu dòng lá»nh."
#, fuzzy
-#~ msgstr ""
-#~ "Không Äá»§ không gian trong táºp tin lá»ch sá» Äá» chứa dòng lá»nh (bá» cắt bá»t)."
+msgstr ""
+"Không Äá»§ không gian trong táºp tin lá»ch sá» Äá» chứa dòng lá»nh (bá» cắt bá»t)."
+#, fuzzy
+msgstr "thá», gpde"
+#, fuzzy
+msgid "Raster map <%s> - unable to write row %d"
+msgstr "bản Äá» [%s] - không thá» ghi hà ng %d"
+#, fuzzy
+msgid "Error writing floating point format file for map <%s>"
+msgstr "Lá»i khi Äá»c táºp tin Äá»nh dạng dấu chấm Äá»ng cho bản Äá» %s"
+#, fuzzy
+msgstr "Không thá» cáºp nháºt ÄÆ°á»£c Äá»nh dạng OGR"
+#, fuzzy
+msgid "Unable to write feature, OGR layer not defined"
+msgstr "Không thá» ghi Äá»i tượng, bản Äá» vec-tÆ¡ không ÄÆ°á»£c má»"
+#, fuzzy
+msgid "Unable to create a new process!"
+msgstr "Không thá» tạo má»t quá trình má»i"
+#, fuzzy
+msgid ""
+msgstr ""
+"vùng cho bá» bản Äá» hiá»n tại %s\n"
+"chạy \"g.region\""
+#, fuzzy
+msgstr "vùng mặc Äá»nh %s"
+#, fuzzy
+msgid "Unable to set region"
+msgstr "không thỠmỠ%s"
+#, fuzzy
+msgid "Failed writing raster map"
+msgstr "Trục trặc khi Äang Äá»c bản Äá» raster"
+#, fuzzy
+msgid "Unable to write color file of raster map <%s>"
+msgstr "Không thá» Äá»c táºp tin mà u cá»§a bản Äá» raster <%s>"
+#, fuzzy
+msgid "Unable to query drawable"
+msgstr "Không thá» má» táºp tin %s trong %s"
+#, fuzzy
+msgid "Failed to initialize Xlib surface"
#~ msgid "Invalid view position coordinates, using %f,%f"
#~ msgstr "Tá»a Äá» vá» trà xem không hợp lá», Äang dùng %f,%f"
#~ msgid "Unknown Location"
#~ msgstr "VỠtrà không biết"
-#, fuzzy
-#~ msgstr "thá», gpde"
#~ msgstr "táºp tin lượng tá» hóa [%s] trong bá» bản Äá» [%s] %s"
@@ -5893,10 +5944,6 @@
#~ msgid "Unable to write raster row %i"
#~ msgstr "Không thỠghi hà ng raster %i"
-#, fuzzy
-#~ msgid "Raster map <%s> - unable to write row %d"
-#~ msgstr "bản Äá» [%s] - không thá» ghi hà ng %d"
#~ msgid "Unable to open raster map <%s@%s>"
#~ msgstr "Không thá» má» bản Äá» raster <%s@%s>"
@@ -5912,10 +5959,6 @@
#~ msgstr "Lá»i khi Äá»c táºp tin Äá»nh dạng dấu chấm Äá»ng cho bản Äá» %s"
-#, fuzzy
-#~ msgid "Error writing floating point format file for map <%s>"
-#~ msgstr "Lá»i khi Äá»c táºp tin Äá»nh dạng dấu chấm Äá»ng cho bản Äá» %s"
#~ msgid "Unable to read header file for raster map <%s@%s>."
#~ msgstr "Không thá» Äá»c táºp tin header cho bản Äá» raster <%s@%s>."
@@ -5935,18 +5978,6 @@
#~ msgid "Unable to feature %d from vector map <%s>"
#~ msgstr "Không thá» vá»i Äá»i tượng %d từ bản Äá» vec-tÆ¡ <%s>"
-#, fuzzy
-#~ msgstr "Không thá» cáºp nháºt ÄÆ°á»£c Äá»nh dạng OGR"
-#, fuzzy
-#~ msgid "Unable to write feature, OGR layer not defined"
-#~ msgstr "Không thá» ghi Äá»i tượng, bản Äá» vec-tÆ¡ không ÄÆ°á»£c má»"
-#, fuzzy
-#~ msgid "Unable to create a new process!"
-#~ msgstr "Không thá» tạo má»t quá trình má»i"
#~ msgstr "Quá nhiá»u Äá»i sá»"
@@ -5968,17 +5999,6 @@
#~ msgstr "dòng %d: <%s>"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "vùng cho bá» bản Äá» hiá»n tại %s\n"
-#~ "chạy \"g.region\""
-#, fuzzy
-#~ msgstr "vùng mặc Äá»nh %s"
#~ msgstr "không ÄÆ°á»£c thiết láºp"
@@ -5989,18 +6009,6 @@
#~ "không hợp lá»\n"
#~ "%s"
-#, fuzzy
-#~ msgstr "không thỠmỠ%s"
-#, fuzzy
-#~ msgid "Failed writing raster map"
-#~ msgstr "Trục trặc khi Äang Äá»c bản Äá» raster"
-#, fuzzy
-#~ msgid "Unable to write color file of raster map <%s>"
-#~ msgstr "Không thá» Äá»c táºp tin mà u cá»§a bản Äá» raster <%s>"
#~ msgstr "Vector không phải 3D"
@@ -6125,14 +6133,6 @@
#~ "hoá"
#, fuzzy
-#~ msgid "Unable to query drawable"
-#~ msgstr "Không thá» má» táºp tin %s trong %s"
-#, fuzzy
-#~ msgid "Failed to initialize Xlib surface"
-#, fuzzy
#~ msgstr "Äang ÄÄng ký các ÄÆ°á»ng:"
@@ -6817,3 +6817,326 @@
#~ msgstr "Không thá» tìm thấy bản Äá» Äầu và o '%s'"
+#~ msgstr "Không thá» cấp phát bá» nhá»\n"
+#~ msgid "Probably program error."
+#~ msgstr "Có thá» là lá»i chương trình."
+#~ msgstr "Không thá» má» táºp tin tạm"
+#~ msgid "Problem reading raster map"
+#~ msgstr "Trục trặc khi Äang Äá»c bản Äá» raster"
+#~ msgstr " Bản Äá» raster %s@%s rá»ng"
+#~ msgstr "Không thá» ghi các quy tắc lượng tá»: bản Äá» %s kiá»u integer"
+#~ msgid ""
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): phép chiếu/múi khác vá»i cá»§a các bản Äá» raster hiá»n Äang má»"
+#~ msgstr "Miá»n dữ liá»u kiá»u float cho %s@%s bá» rá»ng"
+#~ msgstr "Miá»n dữ liá»u sá» kiá»u sá» nguyên cho %s@%s bá» rá»ng"
+#~ msgstr "%s: bản Äá» [%s] không ÄÆ°á»£c má» Äá» ghi - yêu cầu bá» bá» qua"
+#~ msgstr "%s: Mô tả táºp tin không ÄÆ°á»£c má» - yêu cầu bá» bá» qua"
+#~ msgstr "bản Äá» [%s] - không thá» ghi hà ng %d"
+#~ msgid "unable to find a temporary null file %s"
+#~ msgstr "không thá» tìm thấy má»t táºp tin null tạm %s"
+#~ msgstr "lá»i khi Äang ghi hà ng null %d"
+#~ msgid "category support for [%s] in mapset [%s] %s"
+#~ msgstr "há» trợ phạm trù cho [%s] trong bá» bản Äá» [%s] %s"
+#~ msgid "category support for vector map [%s] in mapset [%s] %s"
+#~ msgstr "há» trợ phạm trù cho bản Äá» vec-tÆ¡ [%s] trong bá» bản Äá» [%s] %s"
+#~ msgid "Cannot open temp file"
+#~ msgid ""
+#~ "\n"
+#~ "invalid projection\n"
+#~ msgstr ""
+#~ "\n"
+#~ "phép chiếu không hợp lá»\n"
+#~ msgstr "EmbedGivenNulls: kiá»u dữ liá»u sai!"
+#~ msgid "Please advise GRASS developers of this error.\n"
+#~ msgstr "Vui lòng báo cho các nhà phát triá»n GRASS vá» lá»i nà y.\n"
+#~ msgstr "G_set_null_value: kiá»u dữ liá»u sai!"
+#~ msgstr "Tên cá»§a bản Äá» raster Äá» cao"
+#~ msgid "Name of elevation raster map(s)"
+#~ msgstr "Tên cá»§a (các) bản Äá» raster Äá» cao"
+#~ msgstr "Lá»p sá»"
+#~ msgid ""
+#~ msgstr ""
+#~ "Má»t bản Äá» vec-tÆ¡ duy nhất có thá» ÄÆ°á»£c kết ná»i vá»i nhiá»u bảng csdl. Con "
+#~ "sá» nà y quyết Äá»nh sá» dụng bảng nà o."
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Mô tả:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Các từ khóa:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Cách dùng:\n"
+#~ "â© "
+#~ msgstr "Äá» chấp nháºn mặc Äá»nh"
+#~ msgid "color support for [%s] in mapset [%s] %s"
+#~ msgstr "há» trợ mà u cho [%s] trong bá» bản Äá» [%s] %s"
+#~ msgstr ""
+#~ "Äánh dấu thá»i gian ÄÆ°á»£c chá» Äá»nh cho %s bản Äá» %s trong bá» bản Äá» %s "
+#~ "không hợp lá»"
+#~ msgstr ""
+#~ "Táºp tin Äánh dấu thá»i gian không hợp lá» cho %s bản Äá» %s trong bá» bản Äá» %"
+#~ "s"
+#~ msgid "Error reading compressed map <%s@%s>, row %d"
+#~ msgstr "Lá»i khi Äang Äá»c bản Äá» nén <%s@%s>, hà ng %d"
+#~ msgid "Error reading map <%s@%s>, row %d"
+#~ msgstr "Lá»i khi Äang Äá»c bản Äá» <%s@%s>, hà ng %d"
+#~ msgid "unable to determine user's home directory"
+#~ msgstr "không thá» xác Äá»nh thư mục home cá»§a ngưá»i dùng"
+#~ msgstr "Không thá» tạo ra táºp tin header cho [%s]"
+#~ msgid ""
+#~ msgstr ""
+#~ "vùng cho bá» bản Äá» hiá»n tại %s\n"
+#~ "chạy \"g.region\""
+#~ msgstr "vùng mặc Äá»nh %s"
+#~ msgid "hit RETURN to continue -->"
+#~ msgstr "bấm RETURN Äá» tiếp tục -->"
+#~ msgstr "Tên táºp tin không hợp lá». Không thá» là '.' hay 'NULL'\n"
+#~ msgid "Illegal filename. Character <%c> not allowed.\n"
+#~ msgstr "Tên táºp tin không hợp lá». Ký tá»± <%c> không ÄÆ°á»£c phép.\n"
+#~ msgid "Too many reclass categories for [%s in %s]"
+#~ msgstr "Quá nhiá»u phạm trù phân loại lại cho [%s trong %s]"
+#~ msgstr ""
+#~ "Äá»nh dạng phân loại lại không hợp lá» trong táºp tin header cá»§a [%s trong %"
+#~ "s] "
+#~ msgid "Unable to create dependency file in [%s in %s]"
+#~ msgstr "Không thá» tạo ra táºp tin phụ thuá»c cho [%s trong %s]"
+#~ msgstr "G_malloc: không thỠcấp phát %lu byte tại %s:%d"
+#~ msgstr "G_malloc: không thỠcấp phát %lu* %lu byte tại %s:%d"
+#~ msgstr "G_realloc: không thỠcấp phát %lu byte tại %s:%d"
+#~ msgid ""
+#~ msgstr ""
+#~ "Bản Äá» raster <%s@%s> á» phép chiếu khác vá»i vùng hiá»n hà nh. Tìm thấy bản "
+#~ "Äá» <%s@%s>, lẽ ra phải là <%s>."
+#~ msgid ""
+#~ msgstr "Bản Äá» raster <%s@%s> á» má»t múi (%d) khác vá»i vùng hiá»n hà nh (%d)"
+#~ msgstr "Bản Äá» raster <%s@%s>: sá» byte trên ô (%d) quá lá»n"
+#~ msgid ""
+#~ msgstr ""
+#~ "bản Äá» <%s@%s> là má»t liên kết GDAL nhưng GRASS ÄÆ°á»£c biên dá»ch không có "
+#~ "hỠtrợ GDAL"
+#~ msgstr "G__open_raster_new(): không có táºp tin tạm nà o dùng ÄÆ°á»£c"
+#~ msgstr "G_set_fp_type(): chá» có thá» ÄÆ°á»£c gá»i vá»i FCELL_TYPE hoặc DCELL_TYPE"
+#~ msgid "Unable to find '%s' in '%s'"
+#~ msgstr "Không thỠtìm thấy '%s' trong '%s'"
+#~ msgid ""
+#~ msgstr ""
+#~ "G_set_quant_rules() chá» có thá» ÄÆ°á»£c gá»i cho các bản Äá» raster Äã má» Äá» Äá»c"
+#~ msgid "No help available for command [%s]\n"
+#~ msgstr "Không có trợ giúp cho lá»nh [%s]\n"
+#~ msgstr "không thá» ghi thông tin lá»ch sá» cho [%s]"
+#~ msgstr "Không Äá»§ không gian trong táºp tin lá»ch sá» Äá» lưu dòng lá»nh."
+#~ msgstr ""
+#~ "Không Äá»§ không gian trong táºp tin lá»ch sá» Äá» chứa dòng lá»nh (bá» cắt bá»t)."
+#~ msgid ""
+#~ "topo level 2"
+#~ msgstr ""
+#~ "Không thá» xây dá»±ng chá» mục không gian từ tôpô, bản Äá» vec-tÆ¡ không ÄÆ°á»£c "
+#~ "mỠỠtôpô cấp 2"
+#~ msgstr "%d lá»i trong chuá»i phạm trù."
+#~ msgid "Unable to add database link, map is not opened in WRITE mode"
+#~ msgstr "Không thá» thêm liên kết csdl, bản Äá» không ÄÆ°á»£c má» á» chế Äá» GHI"
+#~ msgstr "Không thỠthêm liên kết csdl"
+#~ msgid "Error in rule on row %d in %s"
+#~ msgstr "Lá»i trong quy tắc tại dòng %d trong %s"
+#~ msgid ""
+#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+#~ "excess)"
+#~ msgstr ""
+#~ "Các táºp tin coor cá»§a bản Äá» vec-tÆ¡ <%s@%s> lá»n hÆ¡n cỡ Äúng cá»§a nó (quá %"
+#~ "ld byte)"
+#~ msgid ""
+#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+#~ "missing)."
+#~ msgstr ""
+#~ "Các táºp tin coor cá»§a bản Äá» vec-tÆ¡ <%s@%s> nhá» hÆ¡n cỡ Äúng cá»§a nó (thiếu %"
+#~ "ld byte)."
+#~ msgid "Intersections: %5d"
+#~ msgstr "Các giao Äiá»m: %5d"
+#~ msgid "Programmer requested unknown open level %d"
+#~ msgstr "Láºp trình viên Äã yêu cầu má» á» cấp %d không biết"
+#~ msgstr "Không thá» cáºp nháºt ÄÆ°á»£c Äá»nh dạng OGR"
+#~ msgid "Unable to open layer <%s>"
+#~ msgstr "Không thá» má» lá»p <%s>"
+#~ msgid ""
+#~ msgstr ""
+#~ "Viá»c Äá»c ngẫu nhiên không ÄÆ°á»£c OGR há» trợ Äá»i vá»i lá»p nà y, không thá» xây "
+#~ "dựng hỠtrợ"
+#~ msgstr "Äá»i tượng OGR không có ID bá» bá» qua"
+#~ msgid "Unable to create raster map <%s>"
+#~ msgstr "Không thá» tạo bản Äá» raster <%s>"
+#~ msgstr "thá», gpde"
+#~ msgid ""
+#~ msgstr ""
+#~ "mất quá lâu Äá» tìm các Äiá»m dùng cho ná»i suy--vui lòng thay Äá»i vùng Äến "
+#~ "khu vá»±c có các Äiá»m cá»§a bạn. Tiếp tục tÃnh toán..."
+#~ msgstr "Äang Äá»c các ÄÆ°á»ng từ bản Äá» vec-tÆ¡..."
+#~ msgstr "Äang Äá»c các ná»t từ bản Äá» vec-tÆ¡..."
+#~ msgstr "viá»c cắt bá» xảy ra vá»i dữ liá»u không Äầy Äá»§"
+#~ msgstr "có các Äiá»m nằm ngoà i vùng 2D/3D Äã chá» Äá»nh--bá» qua %d Äiá»m"
+#~ msgstr "bá» qua %d Äiá»m--quá dà y"
+#~ msgstr "má»t sá» Äiá»m nằm ngoà i vùng -- sẽ bá» qua ..."
+#, fuzzy
+#~ msgid "Unable to delete layer/category %d/%d line %d"
+#~ msgstr "không thá» Äá»i thư mục Äến %s"
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> on topology level %d"
+#~ msgstr "không thá» má» bản Äá» raster [%s in %s]"
+#, fuzzy
+#~ msgstr "Kiá»u Äá»i tượng OGR %d không ÄÆ°á»£c há» trợ"
+#~ msgid "Cannot rewrite line"
+#~ msgstr "Không thá» ghi lại ÄÆ°á»ng"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grasslibs_zh.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5862,20 +5862,67 @@
msgstr ""
#, fuzzy
-#~ msgid "Not enough room in history file to record command line"
-#~ msgstr "åå²ä¿¡æ¯æä»¶æ²¡æè¶³å¤çç©ºé´æ¥è®°å½å½ä»¤è¡ã"
+msgid "Not enough room in history file to record command line"
+msgstr "åå²ä¿¡æ¯æä»¶æ²¡æè¶³å¤çç©ºé´æ¥è®°å½å½ä»¤è¡ã"
#, fuzzy
-#~ msgid "Not enough room in history file for command line (truncated)"
-#~ msgstr "åå²ä¿¡æ¯æä»¶æ²¡æè¶³å¤çç©ºé´æ¥è®°å½å½ä»¤è¡ï¼æªåçï¼ã"
+msgid "Not enough room in history file for command line (truncated)"
+msgstr "åå²ä¿¡æ¯æä»¶æ²¡æè¶³å¤çç©ºé´æ¥è®°å½å½ä»¤è¡ï¼æªåçï¼ã"
+#, fuzzy
+msgstr "æµè¯ï¼gpde"
+#, fuzzy
+msgstr "å°å¾[%s] - æ æ³åå
¥è¡%d"
+#, fuzzy
+msgstr "å°å°å¾ %s åå
¥æµ®ç¹åæéç±»åæä»¶é误"
+#, fuzzy
+msgstr "æ æ³åå
¥çº¿ï¼å°å¾å°æªæå¼"
+#, fuzzy
+msgstr "ä¸è½å建æ°è¿ç¨"
+#, fuzzy
+msgid ""
+"Region for current mapset %s. Run \"g.region\" to fix the current region."
+msgstr ""
+"è¦å¾å°å½åå°å¾é%sçèå´\n"
+"请è¿è¡ \"g.region\""
+#, fuzzy
+msgid "Default region %s"
+msgstr "é»è®¤èå´ %s"
+#, fuzzy
+msgstr "æ æ³æå¼%s"
+#, fuzzy
+msgstr "读åæ
æ ¼åå
æä»¶é®é¢"
+#, fuzzy
+msgstr "æ æ³ä¸º[%så¨%sä¸]å建头æä»¶"
+#, fuzzy
+msgstr "æ æ³æå¼æä»¶ %s å¨ %s ä¸"
+#, fuzzy
#~ msgstr "æªç¥åºå"
-#, fuzzy
-#~ msgstr "æµè¯ï¼gpde"
#~ msgstr "éåæä»¶[%s]å¨å°å¾é[%s]ä¸ %s"
@@ -5893,49 +5940,1175 @@
#~ "\n"
#~ "åæ°ï¼\n"
+#~ msgid "ERROR %s from graphics driver.\n"
+#~ msgstr "é误ç%sæ¥èªå¾å½¢é©±å¨å¨ã\n"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "æ æ³åé
å
å\n"
+#~ msgid "ERROR - eof from graphics monitor.\n"
+#~ msgstr "é误 - å¾å½¢çè§å¨çeofã\n"
+#~ msgid "Warning - no response from graphics monitor <%s>.\n"
+#~ msgstr "è¦å - å¾å½¢çè§å¨<%s>没æååºã\n"
+#~ msgid "Check to see if the mouse is still active.\n"
+#~ msgstr "è¯·æ£æ¥é¼ æ æ¯å¦è¿è½æ´»å¨ã\n"
+#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
+#~ msgstr "é误 - å¾å½¢çè§å¨<%s>没æååºã\n"
#, fuzzy
+#~ msgid "No graphics monitor has been selected for output."
+#~ msgstr "没æéæ©ç¨æ¥è¾åºçå¾å½¢çè§å¨ã\n"
+#, fuzzy
+#~ msgid "Please run \"d.mon\" to select a graphics monitor."
+#~ msgstr "请è¿è¡\"d.mon\"æ¥éæ©ä¸ä¸ªå¾å½¢çè§å¨ã\n"
+#, fuzzy
+#~ msgid "Failed to get socket name for monitor <%s>."
+#~ msgstr "è·åçè§å¨<%s>çsocketå称失败ã\n"
+#, fuzzy
+#~ msgid "No socket to connect to for monitor <%s>."
+#~ msgstr "没æsocketè¿æ¥å°çè§å¨<%s>ã\n"
+#, fuzzy
+#~ msgid "Socket is already in use or not accepting connections."
+#~ msgstr ""
+#~ "Socketå·²ç»å¨ä½¿ç¨ææ¯ä¸æ¥åè¿æ¥ã\n"
+#~ "请使ç¨d.monæ¥éæ©ä¸ä¸ªçè§å¨\n"
+#, fuzzy
+#~ msgid "Use d.mon to select a monitor"
+#, fuzzy
+#~ msgid "Trying to connect to something not a socket."
+#~ msgstr ""
+#~ "å°è¯è¿æ¥å°å«çä¸è¥¿è䏿¯socketã\n"
+#~ "æè®¸æ¯ç¨åºåºéã\n"
+#, fuzzy
+#~ msgid "Probably an error with the server."
+#~ msgstr "å°è¯è¿æ¥è¶
æ¶ãå¯è½æ¯æå¡å¨åºç°é误ã\n"
+#, fuzzy
+#~ msgid "Connection failed."
+#~ msgstr "è¿æ¥å¤±è´¥ã\n"
+#, fuzzy
+#~ msgid "Unable to open file %s"
+#~ msgstr "æ æ³æå¼æä»¶ %s å¨ %s ä¸"
+#, fuzzy
+#~ msgid "Hit RETURN to cancel request\n"
+#~ msgstr "æåè½¦åæ¶è¯·æ±\n"
+#, fuzzy
+#~ msgstr "读åæ
æ ¼åå
æä»¶é®é¢"
+#~ msgid " The raster map %s@%s is empty"
+#~ msgstr " æ
æ ¼å¾%s@%sæ¯ç©ºç"
+#~ msgid ""
+#~ "\n"
+#~ "\n"
+#~ "Color table needed for file [%s] in mapset [%s].\n"
+#~ msgstr ""
+#~ "\n"
+#~ "\n"
+#~ "æä»¶[%s]å¨å°å¾é[%s]ä¸ï¼éè¦è²å½©è¡¨ã\n"
+#~ msgid ""
+#~ "\n"
+#~ "Please identify the type desired:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "请确å®éè¦çç±»åï¼\n"
+#~ msgid " 1: Random colors\n"
+#~ msgstr " 1ï¼ éæºé¢è²\n"
+#~ msgid " 2: Red, green, and blue color ramps\n"
+#~ msgstr " 2ï¼ çº¢ã绿ãèè²é¶\n"
+#~ msgid " 3: Color wave\n"
+#~ msgstr " 3ï¼ è²æ³¢(Color wave)\n"
+#~ msgid " 4: Gray scale\n"
+#~ msgstr " 4ï¼ ç°åº¦\n"
+#~ msgid " 5: Aspect\n"
+#~ msgstr " 5ï¼ è²ç¸(Aspect)\n"
+#~ msgid " 6: Rainbow colors\n"
+#~ msgstr " 6: è²å¸¦(Rainbow colors)\n"
+#~ msgid " 7: Red through yellow to green\n"
+#~ msgstr " 7ï¼ çº¢å°é»åå°ç»¿\n"
+#~ msgid " 8: Green through yellow to red\n"
+#~ msgstr " 8ï¼ ç»¿å°é»åå°çº¢\n"
+#~ msgid "RETURN quit\n"
+#~ msgstr "å车 éåº\n"
+#~ msgid ""
+#~ "\n"
+#~ "%s invalid; Try again > "
+#~ msgstr ""
+#~ "\n"
+#~ "%sæ æï¼éè¯ > "
+#~ msgid "Cannot write quant rules: map %s is integer"
+#~ msgstr "æ æ³åå
¥éåè§åï¼å°å¾ %s æ¯æ´åç"
+#~ msgid "Cannot write quant rules for map %s"
+#~ msgstr "æ æ³ä¸ºå°å¾ %s åå
¥éåè§å"
+#, fuzzy
+#~ msgid ""
+#~ "G_set_window(): projection/zone differs from that of currently open "
+#~ "raster maps"
+#~ msgstr "G_set_window()ï¼æå½±/åºåä¸å½åæå¼çæ
æ ¼æä»¶ä¸å"
+#~ msgid "The floating data range for %s@%s is empty"
+#~ msgstr "%s@%sçæµ®ç¹æ°èå´ä¸ºç©º"
+#~ msgid "The integer data range for %s@%s is empty"
+#~ msgstr "%s@%sçæ´æ°èå´ä¸ºç©º"
+#~ msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
+#~ msgstr "G_put_map_row: %s 䏿¯æ´åï¼è°ç¨G_put_[f/d]_raster_row()ï¼"
+#~ msgid "%s: map [%s] not open for write - request ignored"
+#~ msgstr "%s: å°å¾ [%s] 没ææå¼åæä½ââ忽ç¥è¯·æ±"
+#~ msgid "%s: map [%s] not open for random write - request ignored"
+#~ msgstr "%s: å°å¾ [%s] 没ææå¼éæºåæä½ââ忽ç¥è¯·æ±"
+#~ msgid "%s: map [%s] not open for sequential write - request ignored"
+#~ msgstr "%s: å°å¾ [%s] 没ææå¼é¡ºåºåæä½ââ忽ç¥è¯·æ±"
+#~ msgid "%s: unopened file descriptor - request ignored"
+#~ msgstr "%s: æ æ³æå¼æä»¶æè¿°ç¬¦ââ忽ç¥è¯·æ±"
+#~ msgid "map [%s] - unable to write row %d"
#~ msgstr "å°å¾[%s] - æ æ³åå
¥è¡%d"
+#~ msgstr "æ¾ä¸å°ä¸´æ¶ç©ºæä»¶ï¼%s"
+#~ msgid "error writing null row %d"
+#~ msgstr "åå
¥ç©ºè¡ %d æ¶åºé"
+#~ msgstr "[%s]å¨å°å¾é[%s]ä¸çç±»å« %s"
+#~ msgstr "ç¢éæä»¶[%s]å¨å°å¾é[%s]ä¸çç±»å« %s"
+#~ msgid "%s not found"
+#~ msgstr "æªåç° %s"
+#~ msgid "ERROR in reading %s"
+#~ msgstr "读å %s æ¶åºç°é误"
+#~ msgstr "æ æ³æå¼ä¸´æ¶æä»¶"
+#~ msgid ""
+#~ "\n"
+#~ "\n"
+#~ "Please specify projection name\n"
+#~ msgstr ""
+#~ "\n"
+#~ "\n"
+#~ "请æå®æå½±åç§°\n"
+#~ msgid "Enter 'list' for the list of available projections\n"
+#~ msgstr "è¾å
¥'list'ï¼ååºææå¯ç¨çæå½±\n"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "æ æçæå½±\n"
+#~ msgid "EmbedGivenNulls: wrong data type!"
+#~ msgstr "EmbedGivenNullsï¼éè¯¯çæ°æ®ç±»åï¼"
+#~ msgid "Null values have not been initialized. "
+#~ msgstr "空å¼è¿æªè¢«åå§åã"
+#~ msgid "G_gisinit() must be called first. "
+#~ msgstr "å¿
é¡»å
è°ç¨ G_gisinit()ã "
+#~ msgstr "请å GRASS å¼åäººåæ¥åè¿ä¸é误ã\n"
+#~ msgid "G_set_null_value: wrong data type!"
+#~ msgstr "G_set_null_valueï¼éè¯¯çæ°æ®ç±»åï¼"
#, fuzzy
-#~ msgstr "å°å°å¾ %s åå
+#~ msgstr "è¾å
¥æ
æ ¼çåç§°"
#, fuzzy
-#~ msgstr "æ æ³åå
¥çº¿ï¼å°å¾å°æªæå¼"
+#~ msgstr "è¾å
¥æ
æ ¼çåç§°"
#, fuzzy
-#~ msgstr "ä¸è½å建æ°è¿ç¨"
+#~ msgid "Name of input raster3d map"
+#~ msgstr "è¾å
¥æ
æ ¼çåç§°"
#, fuzzy
+#~ msgid "Name of input raster3d map(s)"
+#~ msgstr "è¾å
¥æ
æ ¼çåç§°"
+#, fuzzy
+#~ msgid "Name for output raster3d map"
+#~ msgstr "è¾åºæ
æ ¼çåç§°"
+#~ msgid "Layer number"
+#~ msgstr "å¾å±å·"
#~ msgid ""
-#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
+#~ "A single vector map can be connected to multiple database tables. This "
+#~ "number determines which table to use."
+#~ msgstr "ä¸ä¸ªç¢éå°å¾è½å¤è¿æ¥å¤ä¸ªæ°æ®åºè¡¨ãè¿ä¸ªæ°åå³å®ä½¿ç¨é£ä¸ªè¡¨ã"
+#~ msgid ""
+#~ "\n"
+#~ "Description:\n"
#~ msgstr ""
+#~ "\n"
+#~ "æè¿°ï¼\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "å
³é®è¯ï¼:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ç¨æ³ï¼\n"
+#~ msgid "Allow overwrite"
+#~ msgstr "å
许è¦ç"
+#~ msgid "Run with minimal output messages"
+#~ msgstr "以æå°ä¿¡æ¯è¾åºæ§è¡"
+#~ msgid "Run quietly"
+#~ msgstr "åå°è¿è¡"
+#, fuzzy
+#~ msgid "Unable to spawn the 'wish' program"
+#~ msgstr "æ æ³æå¼%s"
+#~ msgid ""
+#~ "\n"
+#~ "FLAG: Set the following flag?\n"
+#~ msgstr ""
+#~ "\n"
+#~ "æ è®°ï¼æ¯å¦è®¾ç½®ä¸é¢çæ è®°ï¼\n"
+#~ msgid ""
+#~ "\n"
+#~ "OPTION: %s\n"
+#~ msgstr ""
+#~ "\n"
+#~ "éé¡¹ï¼ %s\n"
+#~ msgid " key: %s\n"
+#~ msgstr " å
³é®åï¼ %s\n"
+#~ msgid " format: %s\n"
+#~ msgstr " æ ¼å¼ï¼ %s\n"
+#~ msgid " default: %s\n"
+#~ msgstr " é»è®¤å¼ï¼ %s\n"
+#~ msgid "required: %s\n"
+#~ msgstr " å¿
é¡»å¼ï¼ %s\n"
+#~ msgid "multiple: %s\n"
+#~ msgstr " åæ°ï¼ %s\n"
+#~ msgid " options: %s\n"
+#~ msgstr " éé¡¹ï¼ %s\n"
+#~ msgid "enter option > "
+#~ msgstr "è¾å
¥é项 > "
+#~ msgid " Try again? "
+#~ msgstr " éè¯ï¼"
+#~ msgid "Sorry, %s is not accepted.\n"
+#~ msgstr "对ä¸èµ·ï¼%s ä¸è½è¢«æ¥åã\n"
+#~ msgid ""
+#~ "\n"
+#~ "You have chosen:\n"
+#~ " %s\n"
+#~ msgstr ""
+#~ "\n"
+#~ "æ¨éæ©äºï¼\n"
+#~ " %s\n"
+#~ msgid "Is this correct? "
+#~ msgstr "æ£ç¡®åï¼"
+#~ msgstr "æ¥åé»è®¤å¼"
+#~ msgstr "[%s] å¨å°å¾é [%s] ä¸çé¢è² %s "
+#~ msgstr "æ æ³ä¸º%så建æ¶é´æ³æä»¶ï¼ å°å¾%s å°å¾é%s"
+#~ msgid "Invalid timestamp specified for %s map %s in mapset %s"
+#~ msgstr "为%sæå®äºæ æçæ¶é´æ³ï¼å°å¾%s å°å¾é%s"
+#~ msgid "Can't open timestamp file for %s map %s in mapset %s"
+#~ msgstr "æ æ³ä¸º%sæå¼æ¶é´æ³æä»¶ï¼å°å¾%s å°å¾é%s"
+#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
+#~ msgstr "对%sæ¯æ æçæ¶é´æ³æä»¶ï¼å°å¾%s å°å¾é%s"
+#~ msgid "Can not create a new process!"
+#~ msgstr "æ æ³å建æ°è¿ç¨!"
+#, fuzzy
+#~ msgstr "读å %s é误ï¼å°å¾[%s] å°å¾é[%s]ï¼ç¬¬ %d è¡"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to realloc buffer"
+#~ msgstr "æ æ³éæ°åé
ç¼å²åº"
+#~ msgstr "æ æ³ç¡®å®ç¨æ·çå®¶ç®å½"
+#~ msgid "Unable to create header file for [%s]"
+#~ msgstr "æ æ³ä¸º[%s]å建头æä»¶"
+#~ msgid "Can't read %s for [%s in %s]"
+#~ msgstr "æ æ³è¯»å[ %s å¨ %s ä¸]ç %s "
+#~ msgid "Can't create %s metadata file for [%s in %s]"
+#~ msgstr "æ æ³ä¸º[%så¨%sä¸]å建 %s å
æ°æ®æä»¶"
+#~ msgid ""
+#~ "\n"
+#~ "Please specify ellipsoid name\n"
+#~ msgstr ""
+#~ "\n"
+#~ "请æå®æ¤çåç§°\n"
+#~ msgid "Enter 'list' for the list of available ellipsoids\n"
+#~ msgstr "è¾å
+#~ msgid ""
+#~ "\n"
+#~ "invalid ellipsoid\n"
+#~ msgstr ""
+#~ "\n"
+#~ "æ æçæ¤ç\n"
+#~ msgid ""
+#~ msgstr ""
#~ "è¦å¾å°å½åå°å¾é%sçèå´\n"
#~ "请è¿è¡ \"g.region\""
-#, fuzzy
-#~ msgid "Default region %s"
#~ msgstr "é»è®¤èå´ %s"
+#~ msgid "is not set"
+#~ msgstr "æªè®¾ç½®"
+#~ msgid ""
+#~ "is invalid\n"
+#~ "%s"
+#~ msgstr ""
+#~ "æ¯æ æç\n"
+#~ "%s"
+#~ msgstr "æå车é®ç»§ç» -->"
+#~ msgid "can't create histogram for [%s in %s]"
+#~ msgstr "æ æ³ä¸º[%s å¨ %s ä¸]åå»ºç´æ¹å¾"
+#~ msgid "to cancel request"
+#~ msgstr "åæ¶è¯·æ±"
+#~ msgid "Enter a new %s file name"
+#~ msgstr "è¾å
¥ä¸ä¸ªæ°ç %s æä»¶å"
+#~ msgid "Enter the name of an existing %s file"
+#~ msgstr "è¾å
¥å·²æ %s æä»¶çåç§°"
+#~ msgid "Enter %s file name"
+#~ msgstr "è¾å
¥ %s æä»¶å"
+#~ msgid "Enter 'list' for a list of existing %s files\n"
+#~ msgstr "è¾å
¥'list'ï¼ååºå·²æç %s æä»¶\n"
+#~ msgid "Enter 'list -f' for "
+#~ msgstr "è¾å
¥'list -f'ï¼å¾å°"
+#~ msgid "a list %s"
+#~ msgstr "å表%s"
+#~ msgid "an extended list"
+#~ msgstr "æ©å±å表"
+#~ msgid "Hit RETURN %s\n"
+#~ msgstr "æå车%s\n"
+#~ msgid ""
+#~ "\n"
+#~ "** %s - not found **\n"
+#~ msgstr ""
+#~ "\n"
+#~ "** %s - æªåç° **\n"
+#~ msgid ""
+#~ "\n"
+#~ "** %s exists. ok to overwrite? "
+#~ msgstr ""
+#~ "\n"
+#~ "** %s å·²ç»åå¨ãæ¨ç¡®å®è¦è¦çï¼ "
+#~ msgid ""
+#~ "\n"
+#~ "**<%s> illegal name **\n"
+#~ msgstr ""
+#~ "\n"
+#~ "**<%s> éæ³çåç§° **\n"
+#~ msgid ""
+#~ "\n"
+#~ "** %s - illegal request **\n"
+#~ msgstr ""
+#~ "\n"
+#~ "** %s - éæ³çè¯·æ± **\n"
+#~ msgid ""
+#~ "\n"
+#~ "** %s - exists, select another name **\n"
+#~ msgstr ""
+#~ "\n"
+#~ "** %s - å·²åå¨ï¼è¯·éæ©å
¶å®çåç§° **\n"
+#~ msgid "ask: can't happen"
+#~ msgstr "æ¥è¯¢ï¼æ æ³å®æ"
+#~ msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
+#~ msgstr "éæ³çæä»¶åãä¸è½æ¯'.'æ'NULL'\n"
+#~ msgstr "éæ³çæä»¶åãä¸å
许å
å«å符<%c>ã\n"
+#~ msgstr "[%så¨%sä¸]æå¤ªå¤çéå类类å«"
+#~ msgid "Illegal reclass format in header file for [%s in %s]"
+#~ msgstr "头æä»¶ä¸éæ³çéåç±»æ ¼å¼ [%så¨%sä¸]"
+#~ msgstr "æ æ³ä¸º[%så¨%sä¸]å建头æä»¶"
+#~ msgstr "æ æ³ä¸º[%så¨%sä¸]å建ä¾èµæä»¶"
#, fuzzy
+#~ msgid "ERROR in reading <%s> file for location <%s>"
+#~ msgstr "读å %s æä»¶é误ï¼ç¨äºåºå %s\n"
+#~ msgid ""
+#~ "closecell: can't move %s\n"
+#~ "to null file %s"
+#~ msgstr ""
+#~ "closecell: æ æ³å° %s\n"
+#~ "ç§»å¨å°ç©ºæä»¶ $s"
+#~ msgid "Error writing floating point format file for map %s"
+#~ msgstr "å°å°å¾ %s åå
+#~ msgid ""
+#~ "to cell file %s"
+#~ msgstr ""
+#~ "closecell: ä¸è½å° %s\n"
+#~ "ç§»å¨å°cellæä»¶ %s"
+#, fuzzy
+#~ msgid "unable to write quant file!"
+#~ msgstr "ä¸è½å建æ°è¿ç¨"
+#, fuzzy
+#~ msgid "Unable to open raster map <%s@%s>"
+#~ msgstr "æ æ³å°ç®å½æ¹åå°%s"
+#, fuzzy
+#~ msgid "Unable to find <%s@%s>"
+#~ msgstr "æ æ³æ¾å°[%s]"
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different projection than current region. Found "
+#~ "raster map <%s@%s>, should be <%s>."
+#~ msgstr ""
+#~ "[%s]å¨å°å¾é[%s]ä¸ - ä¸å½åèå´çæå½±ä¸åï¼\n"
+#~ " æ¾å°çå°å¾[%s]å¨<%s>æå½±ä¸ï¼å½åçæå½±åºè¯¥æ¯<%s> "
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr "[%s]å¨å°å¾é[%s]ä¸ - åºå[%d]ä¸å½åçèå´[%d]ä¸å"
+#, fuzzy
+#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
+#~ msgstr "[%s]å¨[%s]ä¸ - æ¯åå
æå æ¯ç¹æ°(%d)太大"
+#, fuzzy
+#~ msgid "<%s>: bad mapset"
+#~ msgstr "<%s>å¨å°å¾é<%s>ä¸"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to write embedded null values for raster map open for random access"
+#~ msgstr "ä»¥éæºååæå¼çå°å¾ä¸è½åå
¥åµå
¥ç空å¼"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to open '%s'"
+#~ msgid ""
+#~ "\n"
+#~ "Please specify datum name\n"
+#~ msgstr ""
+#~ "\n"
+#~ "请æå®åºåé¢åç§°\n"
+#~ msgid "Enter 'list' for the list of available datums\n"
+#~ msgstr "è¾å
¥'list'ï¼ååºå¯ç¨çåºåé¢\n"
+#~ msgid "or 'custom' if you wish to enter custom parameters\n"
+#~ msgstr "æè¾å
¥'custom'è¿è¡èªå®ä¹åæ°è®¾ç½®\n"
+#~ msgid ""
+#~ "\n"
+#~ "invalid datum\n"
+#~ msgstr ""
+#~ "\n"
+#~ "æ æçåºåé¢\n"
+#~ msgid "one moment...\n"
+#~ msgstr "请ç¨ççå»...\n"
+#~ msgstr "å½ä»¤[%s]没æå¯ç¨ç帮å©\n"
#, fuzzy
-#~ msgstr "读åæ
æ ¼åå
æä»¶é®é¢"
+#~ msgid "Unable to open file %s in <%s>"
+#~ msgid "line %d: <%s>"
+#~ msgstr "è¡ %dï¼ <%s>"
+#~ msgid "can't read f_range file for [%s in %s]"
+#~ msgstr "æ æ³ä¸º[%så¨%sä¸]读å f_range æä»¶"
+#~ msgid "can't read range file for [%s in %s]"
+#~ msgstr "æ æ³ä¸º[%så¨%sä¸]读åèå´æä»¶"
+#~ msgid "can't write range file for [%s in %s]"
+#~ msgstr "æ æ³ä¸º[%så¨%sä¸]åå
¥èå´æä»¶"
+#~ msgid "with titles"
+#~ msgstr "æ é¢"
+#~ msgid "(no title)"
+#~ msgstr "(æ æ é¢)"
#, fuzzy
+#~ msgid "Unable to read header file for raster map <%s@%s>."
#, fuzzy
+#~ msgid " It is a reclass of raster map <%s@%s> "
+#~ msgstr "宿¯[%så¨%sä¸]çä¸ä¸ªéåç±» "
+#, fuzzy
+#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
+#~ msgstr "宿¯[%så¨%sä¸]çä¸ä¸ªéåç±»ï¼å°å¾ç头æä»¶æ æã\n"
+#, fuzzy
+#~ msgid " Invalid format."
+#~ msgstr "æ æçæ ¼å¼\n"
+#~ msgid "can't write history information for [%s]"
+#~ msgstr "æ æ³åå
¥[%s]çåå²ä¿¡æ¯"
+#~ msgid "Not enough room in history file to record command line."
+#~ msgstr "åå²ä¿¡æ¯æä»¶æ²¡æè¶³å¤çç©ºé´æ¥è®°å½å½ä»¤è¡ã"
+#~ msgid "Not enough room in history file for command line (truncated)."
+#~ msgstr "åå²ä¿¡æ¯æä»¶æ²¡æè¶³å¤çç©ºé´æ¥è®°å½å½ä»¤è¡ï¼æªåçï¼ã"
+#, fuzzy
+#~ msgstr "æ æ³æ·»å æ°æ®åºé¾æ¥ï¼å°å¾æ²¡æä»¥åæ¨¡å¼æå¼ã"
+#, fuzzy
+#~ msgstr "æ æ³æ·»å æ°æ®åºé¾æ¥ã"
+#~ msgstr "é误å¨ç¬¬%dè¡%sæä»¶ä¸"
+#, fuzzy
+#~ msgstr "å
¶å®æå½±"
+#, fuzzy
+#~ msgid "Unable to feature %d from vector map <%s>"
+#, fuzzy
+#~ msgstr "è¦åï¼ç¨åºåè¯·æ±æªç¥çopen_level\n"
+#, fuzzy
+#~ msgid "Unable to read head file"
+#, fuzzy
#, fuzzy
+#~ msgid "Unable to open category index file for vector map <%s@%s>"
+#~ msgstr "æ æ³æå¼ç¢é'%s'çåå²è®°å½"
+#, fuzzy
+#~ msgid "Feature: "
+#~ msgstr "è¦ç´ ç±»å"
+#, fuzzy
+#~ msgid "OGR feature without ID ignored"
+#~ msgstr "没æ ID ç OGR è¦ç´ 被忽ç¥ã "
+#, fuzzy
+#~ msgid "Unable to open raster map <%s>"
+#, fuzzy
+#~ msgid "Could not get raster row"
+#~ msgstr "æ æ³ç»è®¡æä»¶'%s'"
+#, fuzzy
+#~ msgid "Unable to close input map"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to write raster row %i"
+#~ msgid "The gauss elimination solver does not work with sparse matrices"
+#~ msgstr "ä¸è½ä½¿ç¨é«æ¯æ¶å
计ç®ç¨çç©éµ"
+#~ msgid "The linear equation system is not quadratic"
+#~ msgstr "çº¿æ§æ¹ç¨å¼ç³»ç»ä¸æ¯äºæ¬¡æ¹ç¨å¼"
+#~ msgid "The lu solver does not work with sparse matrices"
+#~ msgstr "ä¸è½ä½¿ç¨é»è¾åå
è§£ç®ç¨çç©éµ"
+#~ msgid "The cholesky solver does not work with sparse matrices"
+#~ msgstr "ä¸è½ä½¿ç¨choleskyè§£ç®ç¨çç©éµ"
+#~ msgid "Matrix is not symmetric!"
+#~ msgstr "该ç©éµæ¯é对称ç"
+#~ msgid ""
+#~ "The type of solver which should solve the symmetric linear equation system"
+#~ msgstr "åºè¯¥è§£ç®çº¿æ§å¯¹ç§°æ¹ç¨å¼ç³»ç»çè§£ç®ç±»å"
+#~ msgid "The type of solver which should solve the linear equation system"
+#~ msgstr "åºè¯¥è§£ç®çº¿æ§æ¹ç¨å¼ç³»ç»çè§£ç®ç±»å"
+#~ msgid ""
+#~ "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr "è§£ç®çº¿æ§æ¹ç¨å¼ç³»ç»çæå¤§è¿ä»£æ¬¡æ°"
+#~ msgstr "æµè¯ï¼gpde"
+#~ msgid ""
+#~ "taking too long to find points for interpolation--please change the "
+#~ "region to area where your points are. Continuing calculations..."
+#~ msgstr ""
+#~ "寻æ¾å
æçç¹è±è´¹äºå¤ªé¿çæ¶é´ -- 请å°èå´æ¹ä¸ºç¹æå¨çåºåã ç¶åç»§ç»è®¡ç®..."
+#~ msgid "Vector is not 3D"
+#~ msgstr "ç¢é䏿¯3Dç"
+#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
+#~ msgstr "æ æ³æ¾å° z å¼å段 <%s> (请éªè¯åç§°ï¼å¦ä½¿ç¨ v.info)"
+#~ msgid "Column type of z column is not supported (must be integer or double)"
+#~ msgstr "z å¼å段çç±»å䏿¯æ (å¿
须为æ´åæå精度)"
+#~ msgid "Cannot read column type of smooth column"
+#~ msgstr "æ æ³è¯»åå¹³æ»å段çç±»å"
+#~ msgid "Column type of smooth column (datetime) is not supported"
+#~ msgstr "å¹³æ»å段 (æ¥ææ¶é´) çç±»å䏿¯æ"
+#~ msgid "Column type of s column is not supported (must be integer or double)"
+#~ msgstr "s å¼å段çç±»å䏿¯æ (å¿
须为æ´åæå精度)"
+#~ msgstr "ä»ç¢éå°å¾ä¸è¯»å
¥è¡ ..."
+#~ msgstr "读åç¢éå°å¾ä¸çèç¹..."
+#~ msgid "strip exists with insufficient data"
+#~ msgstr "廿ä¸åéçæ°æ®"
+#, fuzzy
+#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
+#~ msgstr "æç¹å¨æå®çèå´ä¹å¤--å¿½ç¥ %d 个ç¹"
+#~ msgid "ignoring %d points -- too dense"
+#~ msgstr "å¿½ç¥ %d ä¸ªç¹ -- è¿äºå¯é"
+#~ msgid "some points outside of region -- will ignore..."
+#~ msgstr "èå´ä¹å¤çç¹ -- å°è¢«å¿½ç¥..."
+#~ msgid "Too many arguments"
+#~ msgstr "åæ°å¤ªå¤"
+#, fuzzy
+#, fuzzy
æ ¼å¾[%så¨%sä¸]"
+#, fuzzy
+#~ msgid "Registering points"
+#~ msgstr "注åçº¿ï¼ "
+#, fuzzy
+#~ msgid "All vertices"
+#~ msgstr "å
许è¦ç"
+#, fuzzy
+#~ msgid "Registered points"
+#, fuzzy
+#~ msgid "Duplicates"
+#~ msgstr "å¤å¶âä¸âåæ®µ"
+#, fuzzy
+#~ msgid "Registered points (unique coordinates)"
+#, fuzzy
+#~ msgid "Attempt to delete dead line"
+#, fuzzy
+#~ msgid "Unable to rewrite line %d"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+#~ msgstr "æ æ³å é¤çº¿ï¼å°å¾'%s'没æå¨çº§å«2䏿å¼"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
+#~ msgstr "æ æ³å é¤çº¿ï¼å°å¾'%s'没æä»¥åæ¨¡å¼æå¼"
+#, fuzzy
+#~ msgid "Unable to delete line %d from vector map <%s>"
+#~ msgid "Type"
+#~ msgstr "ç±»å"
+#~ msgid "G_malloc: out of memory"
+#~ msgstr "G_mallocï¼å
åæº¢åº"
+#, fuzzy
+#~ msgid "G_calloc: out of memory"
+#~ msgstr "æ æ³åé
å
å"
+#~ msgid "G_realloc: out of memory"
+#~ msgstr "G_realloc: å
åæº¢åº"
+#, fuzzy
+#~ msgid "Cannot get layer info"
+#~ msgstr "æ æ³è·åå¾å±ä¿¡æ¯"
+#~ msgid "Cannot open database %s"
+#~ msgstr "æ æ³æå¼æ°æ®åº %s"
+#~ msgid "Cannot describe table <%s>"
+#~ msgstr "æ æ³æå¼æ°æ®åºè¡¨ <%s>"
+#, fuzzy
+#~ msgid "Cannot read topo for line [%d]"
+#~ msgstr "æ æ³è¯»å[ %s å¨ %s ä¸]çç´æ¹å¾"
+#~ msgid "Output name '%s' is not valid rast name."
+#~ msgstr "è¾åºçåç§°'%s'䏿¯ææçæ
æ ¼åç§°ã"
+#~ msgid "Cannot find input map '%s'"
+#~ msgstr "æ æ³æ¾å°è¾å
¥å°å¾'%s'"
+#~ msgid "Output map '%s' is used as input"
+#~ msgstr "è¾åºå°å¾'%s'被ç¨ä½è¾å
+#~ msgid "unable to open raster map [%s in %s]"
æ ¼å¾[%så¨%sä¸]"
+#~ msgid "unable to find [%s] in [%s]"
+#~ msgstr "æ æ³æ¾å°[%s]å¨[%s]ä¸"
+#~ msgid "Can't read header file for [%s in %s]\n"
+#~ msgstr "æ æ³è¯»å[%så¨%sä¸]ç头æä»¶\n"
+#~ msgid "Can't open header file for [%s in %s]"
+#~ msgstr "æ æ³æå¼[%så¨%sä¸]ç头æä»¶"
+#, fuzzy
+#~ msgid "Cannot get field info"
+#, fuzzy
+#~ msgid "Cannot open database"
+#~ msgid "Building topology ...\n"
+#~ msgstr "å»ºç«ææ...\n"
+#~ msgid ""
+#~ "\r%d areas built \n"
+#~ "%d isles built\n"
+#~ msgstr ""
+#~ "\rå»ºç« %d 个åºå \n"
+#~ "å»ºç« %d 个å²\n"
+#, fuzzy
+#~ msgid "Cannot get column info"
+#, fuzzy
+#~ msgstr "䏿¯æç OGR è¦ç´ ç±»å %d"
+#, fuzzy
+#~ msgid "OGR feature type [%d] not supported"
+#~ msgid "Vect_rewrite_line() for this format/level not supported"
+#~ msgstr "è¿ç§æ ¼å¼/级å«ä¸æ¯æ Vect_rewrite_line()"
+#~ msgid "Vect_delete_line() for this format/level not supported"
+#~ msgstr "è¿ç§æ ¼å¼/级å«ä¸æ¯æ Vect_delete_line()"
+#~ msgstr "æ æ³éå线"
+#, fuzzy
+#~ msgid "Cannot delete line"
+#~ msgid "Output name '%s' is not valid vector name."
+#~ msgstr "è¾åºçåç§°'%s'䏿¯ææçç¢éåç§°ã"
+#~ msgid "Cannot copy vector '%s' to '%s'"
+#~ msgstr "æ æ³å°ç¢é'%s'æ·è´ä¸º'%s'"
+#, fuzzy
+#~ msgid "Cannot open existing vector map <%s>"
+#~ msgstr "æ æ³å é¤å·²æç¢é%s"
+#, fuzzy
+#~ msgid "Cannot delete existing vector <%s>"
+#~ msgid "Cannot open new vector %s"
+#~ msgstr "æ æ³æå¼æ°çç¢é%s"
+#~ msgid "Cannot open history file for vector '%s'"
+#~ msgid "Could not stat file '%s'"
+#, fuzzy
+#~ msgid "Can't open directory %s"
+#~ msgstr "æ æ³æå¼æ§çç¢é%s"
+#~ msgid "%s - ** illegal name **"
+#~ msgstr "%s - ** éæ³çåç§° **"
+#~ msgid "No such graphics monitor as <%s>.\n"
+#~ msgstr "没æå为<%s>çå¾å½¢çè§å¨ã\n"
+#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+#~ msgstr "请è¿è¡\"d.mon\"æ¥éæ©ä¸ä¸ªææçå¾å½¢çè§å¨ã\n"
+#~ msgid "Can't stat %s\n"
+#~ msgstr "æ æ³ç»è®¡%s\n"
+#~ msgid "Error - Monitor <%s> is in use.\n"
+#~ msgstr "é误 - çè§å¨<%s>æ£å¨ä½¿ç¨ã\n"
+#~ msgid "Error - Monitor <%s> is in use by %s.\n"
+#~ msgstr "é误 - çè§å¨<%s>æ£å¨è¢«%s使ç¨ã\n"
+#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
+#~ msgstr "é误 - ä¸è½ä¸ºçè§å¨<%s>å®å
¨éå®è¿ç¨ã\n"
+#~ msgid "Error - Can't set up pipe to graphics device.\n"
+#~ msgstr "é误 - æ æ³å»ºç«å°å¾å½¢è®¾å¤ç管éã\n"
+#~ msgid "Error - Graphics monitor <%s> not running!\n"
+#~ msgstr "é误 - å¾å½¢çè§å¨<%s>没æè¿è¡ï¼\n"
+#~ msgid "Please start graphics monitor <%s>.\n"
+#~ msgstr "请å¯å¨å¾å½¢çè§å¨<%s>ã\n"
+#~ msgid "Not connected...\n"
+#~ msgstr "æªè¿æ¥...\n"
+#~ msgid "Couldn't connect to monitor. Will try once more.\n"
+#~ msgstr "ä¸è½è¿æ¥å°çè§å¨ã请åè¯ä¸æ¬¡ã\n"
+#~ msgid "G_dump: memory allocated to G__"
+#~ msgstr "G_dumpï¼ä¸ºG__åé
äºå
å"
+#~ msgid "Size of cell in fp maps = %d"
+#~ msgstr "fp maps ç象å
大å°= %d"
+#~ msgid "current window = %p"
+#~ msgstr "å½åçªå£ = %p"
+#~ msgid "File descriptor for automatic mask %d"
+#~ msgstr "èªå¨æ©æ¨¡çæä»¶æè¿°ç¬¦ %d"
+#~ msgid "Flag denoting automatic masking %d"
+#~ msgstr "èªå¨æ©æ¨¡çæ è®° %d"
+#~ msgid "CELL mask buffer %p"
+#~ msgstr "åå
æ©èçç¼å²åº%p"
+#~ msgid "buffer for reading null rows %p"
+#~ msgstr "读å空è¡çç¼å²åº %p"
+#~ msgid "Pre/post compressed data buffer %p"
+#~ msgstr "ï¼é¢/åï¼åç¼©æ°æ®çç¼å²åº %p"
+#~ msgid "sizeof compressed_buf %d"
+#~ msgstr "åç¼©æ°æ®çç¼å²åºå¤§å° %d"
+#~ msgid "work data buffer %p"
+#~ msgstr "工使°æ®çç¼å²åº %p"
+#~ msgid "sizeof work_buf %d"
+#~ msgstr "工使°æ®çç¼å²åºå¤§å° %d"
+#~ msgid "sizeof null_buf %d"
+#~ msgstr "空å¼ç¼å²åºå¤§å° %d"
+#~ msgid "sizeof mask_buf %d"
+#~ msgstr "æ©æ¨¡ç¼å²åºå¤§å° %d"
+#~ msgid "Histogram request %d"
+#~ msgstr "ç´æ¹å¾éè¦ %d"
+#~ msgid "G_dump: file #%d"
+#~ msgstr "G_dumpï¼æä»¶ #%d"
+#~ msgid "open mode = %d"
+#~ msgstr "æå¼æ¨¡å¼ = %d"
+#~ msgid "Cell header %p"
+#~ msgstr "åå
çå¤´ä¿¡æ¯ %p"
+#~ msgid "Table reclass %p"
+#~ msgstr "è¡¨æ ¼éåç±» %p"
+#~ msgid "Cell stats %p"
+#~ msgstr "åå
çç»è®¡å¼ %p"
+#~ msgid "Range structure %p"
+#~ msgstr "èå´ææ %p"
+#~ msgid "float Range structure %p"
+#~ msgstr "æµ®ç¹èå´ææ %p"
+#~ msgid "want histogram? %d"
+#~ msgstr "éè¦ç´æ¹å¾ï¼ %d"
+#~ msgid "Automatic reclass flag %d"
+#~ msgstr "èªå¨éåç±»æ è®° %d"
+#~ msgid "File row addresses %p"
+#~ msgstr "æä»¶çè¡çå°å %p"
+#~ msgid "Data to window col mapping %p"
+#~ msgstr "æ°æ®å°çªå£åçæ å°%p"
+#~ msgid "Data to window row constants %f,%f"
+#~ msgstr "æ°æ®å°çªå£è¡ç常é %f,%f"
+#~ msgid "Current data row in memory %d"
+#~ msgstr "å½åå
åä¸çæ°æ®è¡ %d"
+#~ msgid "Current null row in memory %d"
+#~ msgstr "å½åå
åä¸çç©ºè¡ %d"
+#~ msgid "nbytes per cell for current row %d"
+#~ msgstr "å½åè¡ä¸æ¯ä¸ªåå
æå çåèæ° %d"
+#~ msgid "Decompressed data buffer %s"
+#~ msgstr "è§£åæ°æ®çç¼å²åº%s"
+#~ msgid "bytes per cell %d"
+#~ msgstr "æ¯ä¸ªåå
æå åèæ° %d"
+#~ msgid "type: int, float or double map %d"
+#~ msgstr "ç±»åï¼æ´åãæµ®ç¹æå精度å°å¾ %d"
+#~ msgid "Temporary name for NEW files %s"
+#~ msgstr "æ°æä»¶ç临æ¶åç§° %s"
+#~ msgid "Temporary name for NEW NULL files %s"
+#~ msgstr "æ°ç空æä»¶ç临æ¶åç§° %s"
+#~ msgid "Mapset of open file %s"
+#~ msgstr "æå¼æä»¶çå°å¾é %s"
+#~ msgid "io error warning given %d"
+#~ msgstr "IOé误è¦å %d"
+#~ msgid "xdr stream for reading fp %p"
+#~ msgstr "读å fp ç xdr æµ %p"
+#~ msgid "data buffer for reading null rows %p"
+#~ msgstr "读å空è¡çæ°æ®ç¼å²åº %p"
+#~ msgid "G_dump: end"
+#~ msgstr "G_dumpï¼ç»æ"
+#, fuzzy
+#~ msgid "Current window not settable"
+#, fuzzy
+#~ msgid "Color file for [%s] not available"
+#~ msgstr "åºå << %s >> æ æ"
+#, fuzzy
+#~ msgid "Cannot use current window"
+#, fuzzy
+#~ msgid "Not able to open cellfile for [%s]"
+#~ msgid "Too many open raster maps"
+#~ msgstr "æå¼å¤ªå¤çæ
æ ¼æä»¶"
+#~ msgid "Too many open files"
+#~ msgstr "æå¼å¤ªå¤æä»¶"
+#~ msgid "ERROR: GISBASE not set\n"
+#~ msgstr "é误ï¼GISBASE没æè®¾ç½®\n"
+#~ msgid "Error reading datum shift parameters for %s from table"
+#~ msgstr "ä»è¡¨ä¸è¯»å %s çåºåé¢åç§»åæ°æ¶åçé误"
+#~ msgid "Error reading ellipsoid parameters for %s from table"
+#~ msgstr "ä»è¡¨ä¸è¯»å %s çæ¤çåæ°æ¶åçé误"
+#~ msgid "No ellipsoid field %s in file %s in %s"
+#~ msgstr "æ²¡ææ¤çä¿¡æ¯å段 %s 卿件%s (å¨%sä¸)"
+#~ msgid "invalid value: field %s in file %s in %s"
+#~ msgstr "æ æçå¼ï¼å段%s æä»¶%s (å¨%sä¸)"
+#~ msgid "No n-dims in site_list"
+#~ msgstr "å¨ç«ç¹åè¡¨ä¸æ²¡æ n-dims"
+#~ msgid "No double attributes in site_list"
+#~ msgstr "å¨ç«ç¹åè¡¨ä¸æ²¡æåç²¾åº¦å±æ§"
+#~ msgid "No string attributes in site_list"
+#~ msgstr "å¨ç«ç¹åè¡¨ä¸æ²¡æåç¬¦ä¸²å±æ§"
+#~ msgid "String attribute index out of range"
+#~ msgstr "åç¬¦ä¸²å±æ§ç´¢å¼è¶ç"
+#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+#~ msgstr "å¨è°ç¨ G_readsites_xyz() æ¶ææªç¥ç屿§ç±»åï¼\n"
+#~ msgid "Failed to convert string attribute."
+#~ msgstr "转æ¢åç¬¦ä¸²å±æ§å¤±è´¥ã"
+#~ msgid "Reading sites list ... "
+#~ msgstr "读åç«ç¹å表 ... "
+#~ msgid "failed to guess format"
+#~ msgstr "æ æ³ç¡®å®æ ¼å¼"
+#~ msgid "decimal field %i not present in sites file"
+#~ msgstr "åè¿å¶å段 %i ä¸å¨ç«ç¹æä»¶ä¸"
+#~ msgid ""
+#~ "I'm finding records that do not have a floating point attributes (fields "
+#~ "prefixed with '%')."
+#~ msgstr "è¿äºè®°å½æ²¡ææµ®ç¹å±æ§(åæ®µä»¥'%'为åç¼)."
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_ar.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -3508,8 +3508,9 @@
msgstr ""
#: ../raster/r.lake/main.c:203
+#, fuzzy
msgid "Both lake and overwrite cannot be specified"
-msgstr ""
+msgstr "!تÙ
ØªØØ¯Ùد Ø¥ØØ¯Ø§Ø«Ù Ø´Ø±Ù ÙØ§Ø±Øº"
#: ../raster/r.lake/main.c:206
msgid "Output lake map or overwrite flag must be set!"
@@ -9213,7 +9214,7 @@
#: ../raster/r.out.gdal/main.c:510 ../raster/r.out.gdal/main.c:514
#, fuzzy
msgid "Raster export aborted."
-msgstr "اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ø§ÙØ·ÙÙØ¨ Ø¥Ø¯Ø®Ø§ÙØ©"
+msgstr "اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙ
دخÙ"
#: ../raster/r.out.gdal/main.c:491
msgid "Checking GDAL data type and nodata value"
@@ -13033,7 +13034,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+msgstr "اسÙ
Ù
جÙ
ÙØ¹Ø© Ø§ÙØ®Ø±Ø§Ø¦Ø· ÙÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -16608,9 +16609,9 @@
msgstr ""
#: ../display/d.vect/plot1.c:616
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr ""
+msgstr "ÙÙ
ØªØØ¯Ø¯ خرائط Ù
Ø¯Ø®ÙØ©"
#: ../display/d.vect/plot1.c:621
#, fuzzy, c-format
@@ -18235,7 +18236,7 @@
#: ../vector/v.in.db/main.c:176
#, fuzzy
msgid "Writing features..."
-msgstr "ÙØªØ§Ø¨Ø© Ù
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+msgstr "ÙØµÙ اÙÙØ¦Ø§Øª...\n"
#: ../vector/v.in.db/main.c:183
msgid "Key column must be integer"
@@ -18794,7 +18795,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+msgstr "Ù
خرج Ù
ØªØ¨Ø§Ø¯Ù Ø§ÙØ¨Ùتات"
#: ../vector/v.random/main.c:111
msgid "Maximum z height (needs -z flag or column name)"
@@ -19121,7 +19122,7 @@
#: ../vector/v.outlier/main.c:240
#, fuzzy, c-format
msgid "It was impossible to create <%s> table."
-msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© Ø§ÙØ¬Ø¯Ùدة"
+msgstr "%s:ÙÙ
ÙØªÙ
Ø¥ÙØ´Ø§Ø¡ Ø§ÙØ¬Ø¯ÙÙ"
#: ../vector/v.outlier/main.c:390 ../vector/v.lidar.edgedetection/main.c:414
#: ../vector/v.lidar.correction/main.c:400
@@ -20659,7 +20660,7 @@
#: ../vector/v.surf.bspline/main.c:176
#, fuzzy
msgid "No raster or vector or cross-validation output"
-msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© ÙÙØ¹Ø±Ø¶ ÙØ®ÙÙÙØ©"
+msgstr "عدد ÙÙØ§Ø· Ø§ÙØ¥Ø³ØªÙÙØ§Ø¡"
#: ../vector/v.surf.bspline/main.c:230
#, fuzzy
@@ -20818,9 +20819,8 @@
msgstr ""
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø¯Ø®ÙØ©"
+msgstr ""
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -24583,9 +24583,8 @@
msgstr "اسÙ
Ø§ÙØ¬Ø¯ÙÙ"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "اسÙ
Ø§ÙØ¬Ø¯ÙÙ"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -24966,9 +24965,8 @@
#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.centrality/main.c:148
-#, fuzzy
msgid "Columns"
-msgstr "عدد Ø§ÙØ£Ø¹Ù
دة"
+msgstr ""
#: ../vector/v.net.centrality/main.c:135
#, fuzzy
@@ -25029,7 +25027,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "اÙÙØ§ØµÙ Ø§ÙØÙÙÙ ÙÙÙ
خرج"
+msgstr "طباعة Ø§ÙØ£ØØµØ§Ø¡ ÙÙ ØµÙØ±Ø© Ø´Ù Ø³ÙØ±Ø¨Øª"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -27098,10 +27096,12 @@
msgstr "اسÙ
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
+#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
msgstr ""
+"Ø®ÙÙ Ø·Ø¨ÙØ© Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© ÙØ®Ø±Ùطة ÙÙØ· ÙÙÙØªÙØ±ÙØ© ØªØØªÙ٠عÙ٠اÙ
اÙÙ Ø¹Ø´ÙØ§Ø¦ÙØ© Ø§ÙØªÙØ²ÙØ¹"
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -27176,8 +27176,9 @@
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#, fuzzy
msgid "Input projection parameters (PROJ.4 style)"
-msgstr ""
+msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ¥ØªØ¬Ø§Ù اÙÙ
خرجة"
#: ../locale/scriptstrings/m.proj_to_translate.c:12
#: ../locale/scriptstrings/m.proj_to_translate.c:14
@@ -27314,17 +27315,20 @@
msgstr "اÙÙ
خرج"
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
+#, fuzzy
msgid "Produces web map server query string output"
-msgstr ""
+msgstr "اÙÙ
خرج"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+#, fuzzy
msgid ""
"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
+msgstr "(Ø¯ÙØ© اÙÙØ¶ÙØ Ø¹Ø¨Ø± Ø§ÙØªØ¶Ø§Ø±Ùس (Ø§ÙØ£Ø³Ø§Ø³ : Ø¯ÙØ© ÙØ¶ÙØ Ø§ÙÙ
ÙØ·ÙØ© Ø§ÙØØ§ÙÙØ©"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#, fuzzy
msgid "Source projection"
-msgstr ""
+msgstr "طباعة ÙÙØ¹ اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù ÙÙØ·"
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
@@ -27370,8 +27374,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
+#, fuzzy
msgid "LANDSAT sensor"
-msgstr ""
+msgstr "Ø§ÙØ´Ø¯"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
@@ -27385,8 +27390,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
+#, fuzzy
msgid "SPOT sensor"
-msgstr ""
+msgstr "Ø§ÙØ´Ø¯"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
#, fuzzy
@@ -27641,8 +27647,9 @@
msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:11
+#, fuzzy
msgid "Value to calculate"
-msgstr ""
+msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
#, fuzzy
@@ -27786,8 +27793,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr ""
+msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
#, fuzzy
@@ -27800,12 +27808,14 @@
msgstr "اسÙ
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr ":اسÙ
ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
msgid "New schema"
-msgstr ""
+msgstr ":اسÙ
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
@@ -27924,9 +27934,8 @@
msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#, fuzzy
msgid "vector, import"
-msgstr "عدÙ
Ø§ÙØ´Ø§Ø¡ جدÙÙ Ø§ÙØ®Ùاص"
+msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
msgid "Create a 3D line from 3 column data"
@@ -28105,8 +28114,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
+#, fuzzy
msgid "Must be expressed as R:G:B triplet"
-msgstr ""
+msgstr "استخداÙ
Ø§ØØ¯Ø§Ø«Ùات Ù
Ø±ÙØ² Ø§ÙØ®Ø±Ùطة\n"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
#, fuzzy
@@ -28175,10 +28185,11 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+#, fuzzy
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
-msgstr ""
+msgstr "اسÙ
Ø¯Ø®ÙØ©"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -28295,8 +28306,9 @@
msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
+#, fuzzy
msgid "Reset to standard color range"
-msgstr ""
+msgstr "Ø¨ÙØ§Ø¡ جدÙÙ Ø§ÙØ£ÙÙØ§Ù Ø§ÙØØ§ÙÙ "
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
@@ -28313,8 +28325,9 @@
msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+#, fuzzy
msgid "Percent to brighten"
-msgstr ""
+msgstr "Ù
ÙÙÙØ¨ ÙØ±Ù Ø§ÙØ¹Ø²Ù
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
#, fuzzy
@@ -28407,8 +28420,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
+#, fuzzy
msgid "Import"
-msgstr ""
+msgstr "Ø§ÙØ®Ø±Ùطة اÙÙÙÙØªÙØ±ÙØ© ÙÙÙØ§Ø· Ø§ÙØ¨Ø¯Ø¡"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Don't reproject the data, just patch it"
@@ -28427,16 +28441,19 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr ""
+msgstr "ÙÙ
ÙÙ
ÙÙ Ø§Ø®ØªÙØ§Ø± Ø§ÙØ¨ÙØ§ÙØ§Øª Ù
Ù Ø§ÙØ¬Ø¯ÙÙ"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#, fuzzy
msgid "Layers to request from map server"
-msgstr ""
+msgstr "طرÙÙØ© Ø§ÙØ§Ø³ØªÙÙØ§Ø¡ اÙÙ
ستخدÙ
Ø©"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#, fuzzy
msgid "Styles to request from map server"
-msgstr ""
ستخدÙ
Ø©"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
#, fuzzy
@@ -28444,28 +28461,32 @@
ستخدÙ
Ø©"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#, fuzzy
msgid "Image format requested from the server"
-msgstr ""
ستخدÙ
Ø©"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
msgid "Addition query options for server"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+#, fuzzy
msgid "Maximum columns to request at a time"
-msgstr ""
+msgstr "اÙÙ
Ø³Ø§ÙØ© Ø§ÙØ¹Ø¸Ù
٠بÙ٠اÙÙÙØ§Ø· Ø¨ÙØØ¯Ø§Øª Ø§ÙØ®Ø±Ùطة"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#, fuzzy
msgid "Maximum rows to request at a time"
-msgstr ""
+msgstr "اÙÙ
Ø³Ø§ÙØ© Ø§ÙØ¹Ø¸Ù
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Additional options for r.tileset"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
+#, fuzzy
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
ÙØ·ÙØ© Ø§ÙØØ§ÙÙØ©"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
@@ -28548,12 +28569,14 @@
msgstr "ÙÙ
ÙØªÙ
ØªØØ¯ÙØ« Ø§ÙØØ¯ÙØ¯"
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#, fuzzy
msgid "Action to be taken"
-msgstr ""
+msgstr "اÙÙ
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
+#, fuzzy
msgid "Category number starting value"
-msgstr ""
+msgstr "اسÙ
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
@@ -28634,8 +28657,9 @@
msgstr "عدÙ
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to drop column"
-msgstr ""
+msgstr "عدÙ
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
@@ -28817,8 +28841,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "<%s> اسÙ
اÙÙ
Ù٠اÙÙ
ستخدÙ
ÙÙ"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#, fuzzy
@@ -28831,8 +28856,9 @@
msgstr "اسÙ
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+#, fuzzy
msgid "Width of display canvas"
-msgstr ""
+msgstr "ØªÙØ±Ùر Ø¹Ù Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
Ø¯Ø®ÙØ© ÙØ§ÙØ®Ø±ÙØ¬"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
#, fuzzy
@@ -28904,8 +28930,9 @@
msgstr "اسÙ
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
+msgstr "<%s> اسÙ
اÙÙ
Ù٠اÙÙ
ستخدÙ
ÙÙ"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
#, fuzzy
@@ -29149,7 +29176,11 @@
#: ../imagery/i.pca/main.c:72
#, fuzzy
msgid "Name of two or more input raster maps"
-msgstr "اسÙ
Ø¯Ø®ÙØ©"
+msgstr ""
+"#-#-#-#-# grassmods_ar.po (grassmods_ar) #-#-#-#-#\n"
+"اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©\n"
+"اسÙ
Ø¯Ø®ÙØ©"
#: ../imagery/i.pca/main.c:75
#, fuzzy
@@ -31254,6 +31285,258 @@
msgstr ""
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "Ø§Ø®ØªÙØ§Ø± Ø§ÙØ®Ø· Ø§ÙØ°Ù Ø³ÙØ¹Ø±Ø¶ ب٠اÙÙØµ عÙÙ Ø§ÙØ´Ø§Ø´Ø©"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "اÙÙ
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "اÙÙ
ÙÙ Ø§ÙØ£Ø³ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙ
Ø·ÙÙØ¨ ادخاÙÙ"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "عدÙ
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr ""
+"Ø£Ù
ÙØ§Ù mi, Ø£Ù
تار me, ÙÙÙÙÙ
ترات k, Ø§ÙØ¯ÙØ© a, ÙÙÙØªØ§Ø±Ø§Øª h, عدات Ø§ÙØ®ÙÙØ© c, p ÙØ³Ø¨Ø© "
+"Ø§ÙØªØºØ·ÙØ©"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "ØªÙØ±Ùر Ø§ÙØ¥ØØµØ§Ø¦Ùات ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "عرض ÙÙ Ø§ÙØ¬Ø¯Ø§ÙÙ ÙÙØ¹Ø¯Ø© Ø¨ÙØ§Ùات Ù
عطاÙ"
+#, fuzzy
+msgid "report"
+msgstr "اÙÙ
دخÙ"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "%s ÙÙ
ÙØªÙ
Ø§ÙØ¹Ø«Ùر عÙÙ Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+msgstr "%s ÙÙ
ÙØªÙ
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "<%s> ÙÙ <%s> ÙÙ
ÙÙ
ÙÙ ÙØ±Ø§Ø¡Ø© اÙÙ
ÙØ·ÙØ©"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "%s ÙÙ
ÙØªÙ
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "استخداÙ
اÙÙ
ÙØ·ÙØ© Ø§ÙØØ§ÙÙØ©"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "اÙÙÙÙ
Ø© Ø§ÙØªÙ تعÙÙ ÙÙÙ
Ø© Ù
ÙØ¹Ø¯Ù
Ø©"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "ÙÙ
ÙÙ
ÙÙ ØØ´Ø± ØµÙ Ø¬Ø¯ÙØ¯: %s"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+msgstr "اسÙ
Ù
ÙÙ Ø§ÙØ¥Ø±ØªÙاعات Ø§ÙØ±Ø§Ø³ØªØ±Ù"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "ØªØºÙØ¨ عÙÙ Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§Ø§Ø±Ø§Ø³ØªØ±ÙØ© اÙÙÙØªÙØ±ÙØ©"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid "Error reading row %d"
خرجة"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙØ§ØªØ¬Ø©"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "%-5d dig_att ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+msgstr "اسÙ
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "بدء باÙÙÙÙ
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "اسÙ
+#, fuzzy
+msgid "Unable to open training map <%s>"
+msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "%s ÙÙ
ÙØªÙ
ÙØªØ ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "اسÙ
خرجة"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+msgstr "بدء باÙÙÙÙ
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+msgstr "اسÙ
+#, fuzzy
+msgid "qcname"
+msgstr "اسÙ
Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+msgid "Name of QC"
+msgstr "اسÙ
Ù
Ù٠اÙÙ
رشØ"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "عدد Ø§ÙØµÙÙÙ"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "Ø§ÙØµÙر ÙÙÙ
Ø© ØÙÙÙÙØ©"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
Ø© ØÙÙÙÙØ©"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø¨Ø¥ØØ¯Ø§Ø«Ùات\n"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> اÙÙ
ÙØ·ÙØ©"
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "ÙØªØ§Ø¨Ø© Ù
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+msgstr "<%s> ÙÙ <%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
ÙÙ ÙÙÙ
ÙØ¸Ø± Ø«ÙØ§Ø«Ù Ø§ÙØ£Ø¨Ø¹Ø§Ø¯"
+#, fuzzy
+msgid "Can't read signature file <%s>"
+msgstr "%s ÙÙ
ÙØªÙ
+#, fuzzy
+msgid "raster, imagery, fusion"
+msgstr "اÙÙ
+#, fuzzy
+msgid "From layer"
+msgstr " nv ÙÙÙ\n"
+#, fuzzy
+msgid "Select type"
+msgstr "ÙÙØ¹ اÙÙ
Ø¸ÙØ±"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ± Ø§ÙØºØ·Ø§Ø¡"
+#, fuzzy
+msgid "Erasing monitors ..."
+#, fuzzy
+msgid "Output terrain only vector map name"
+msgstr "اسÙ
Ø®Ø±ÙØ·Ø© Ø§ØªØ¬Ø§Ù Ø§ÙØ¥ÙØØ¯Ø§Ø±"
+#, fuzzy
#~ msgid "Your mapset search list:\n"
#~ msgstr "طباعة Ø¥ØØ¯Ø§Ø«Ùات Ø§ÙØ¥ØªØµØ§Ù Ø§ÙØÙÙ Ù Ø§ÙØ®Ø±Ùج"
@@ -31266,10 +31549,6 @@
#~ msgstr "اسÙ
Ù
Ù٠اÙÙ
رشØ"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "Ø§Ø®ØªÙØ§Ø± Ø§ÙØ®Ø· Ø§ÙØ°Ù Ø³ÙØ¹Ø±Ø¶ ب٠اÙÙØµ عÙÙ Ø§ÙØ´Ø§Ø´Ø©"
-#, fuzzy
#~ msgid "Failed in attempt to open %s"
#~ msgstr "اسÙ
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
@@ -31340,14 +31619,6 @@
#~ msgid "Layer number of data column"
#~ msgstr "عدÙ
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "اÙÙ
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "اÙÙ
Ø·ÙÙØ¨ ادخاÙÙ"
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Ø§ÙØ´Ø§Ø¡ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ù
ÙØ¶ØØ© Ø§ÙØ£ØÙاض Ø§ÙØªØØªÙØ© ÙÙ
ØØ¯Ø¯Ø§Øª اÙÙ
ÙØ§Ù"
@@ -31454,10 +31725,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr "إخراج ÙØµÙ٠دÙÙÙ Ø·Ø¨ÙØºØ±Ø§ÙÙ Ù
عطÙ"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "عدÙ
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "اسÙ
Ø®Ø±ÙØ·Ø© Ø£Ø³Ø·Ø Ø§ÙØ¥Ø±ØªÙاعات"
@@ -31509,20 +31776,6 @@
#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr ""
-#~ "Ø£Ù
ÙØ§Ù mi, Ø£Ù
تار me, ÙÙÙÙÙ
ترات k, Ø§ÙØ¯ÙØ© a, ÙÙÙØªØ§Ø±Ø§Øª h, عدات Ø§ÙØ®ÙÙØ© c, p "
-#~ "ÙØ³Ø¨Ø© Ø§ÙØªØºØ·ÙØ©"
-#, fuzzy
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "تØÙÙÙ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø¥ÙÙ ÙÙÙØªÙØ±ÙØ©"
@@ -31537,24 +31790,12 @@
#~ msgstr "PPM تØÙÙ٠راستر جراس٠اÙÙ ØµÙØ±Ø© "
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "طباعة Ø§ÙØ£ØØµØ§Ø¡ ÙÙ ØµÙØ±Ø© Ø´Ù Ø³ÙØ±Ø¨Øª"
-#, fuzzy
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "ØªÙØ±Ùر Ø§ÙØ¥ØØµØ§Ø¦Ùات ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
-#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "عرض ÙÙ Ø§ÙØ¬Ø¯Ø§ÙÙ ÙÙØ¹Ø¯Ø© Ø¨ÙØ§Ùات Ù
عطاÙ"
-#, fuzzy
#~ msgid "Unable to close output map"
#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
@@ -31599,20 +31840,12 @@
#~ msgstr "اسÙ
#, fuzzy
-#~ msgid "report"
-#~ msgstr "اÙÙ
دخÙ"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr ""
#~ "Ø£Ù
ÙØ§Ù mi, Ø£Ù
تار me, ÙÙÙÙÙ
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "اÙÙÙÙ
Ø© Ø§ÙØªÙ تعÙÙ ÙÙÙ
Ø© Ù
ÙØ¹Ø¯Ù
Ø©"
@@ -31665,10 +31898,6 @@
#~ msgstr "بدء باÙÙÙÙ
#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "%s ÙÙ
ÙØªÙ
-#, fuzzy
#~ msgid "Reading row %d"
#~ msgstr "dig ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
@@ -31763,10 +31992,6 @@
#~ msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#~ msgstr "%s ÙÙ
ÙØªÙ
-#, fuzzy
#~ msgid "Error opening channel %i"
#~ msgstr "تسجÙÙ Ø§ÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© "
@@ -31803,14 +32028,6 @@
#~ msgstr "اسÙ
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "<%s> ÙÙ <%s> ÙÙ
ÙÙ
ÙÙ ÙØ±Ø§Ø¡Ø© اÙÙ
ÙØ·ÙØ©"
-#, fuzzy
#~ msgid "Unable to get header for %s"
#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
@@ -31819,18 +32036,6 @@
#~ msgstr "استخداÙ
اÙÙ
ÙØ·ÙØ© Ø§ÙØØ§ÙÙØ©"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
@@ -31863,18 +32068,6 @@
#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØ±Ø§Ø¡Ø© ص٠ÙÙ Ø®Ø±ÙØ·Ø© Ø§ÙØ¥Ø±ØªÙاعات اÙÙ
Ø¯Ø®ÙØ©"
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "%s ÙÙ
ÙØªÙ
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "استخداÙ
اÙÙ
ÙØ·ÙØ© Ø§ÙØØ§ÙÙØ©"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
#~ msgstr "اسÙ
@@ -31895,10 +32088,6 @@
#~ msgstr "Ø§ÙØªÙÙÙØ¹ ..."
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "اÙÙÙÙ
Ø© Ø§ÙØªÙ تعÙÙ ÙÙÙ
Ø© Ù
ÙØ¹Ø¯Ù
Ø©"
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr "اسÙ
اÙÙ
ÙØ¬Ùد"
@@ -31915,10 +32104,6 @@
#~ msgstr "%-5d dig_att ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "ÙÙ
ÙÙ
-#, fuzzy
#~ msgid "Invalid region: %s"
#~ msgstr "%s:Ù
ÙØ·ÙØ© ØºÙØ± ØµØ§ÙØØ©"
@@ -31955,14 +32140,6 @@
#~ msgstr "اسÙ
اÙÙ
ÙØ¬Ùد"
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#~ msgstr "اسÙ
Ù
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "ÙØµÙ اÙÙØ¦Ø§Øª...\n"
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
#~ msgstr "%s:ÙÙ
ÙØªÙ
@@ -31983,14 +32160,6 @@
#~ msgstr "اسÙ
اÙÙ
ÙØ¬Ùد"
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "ØªØºÙØ¨ عÙÙ Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "اسÙ
-#, fuzzy
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "عدد Ù
رات ØªÙØ±Ø§Ø± اÙÙ
رشØ"
@@ -32039,14 +32208,6 @@
#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ± ااÙÙØ§ØªØ¬Ø©"
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
-#~ msgid "Error reading row %d"
خرجة"
-#, fuzzy
#~ msgid "Error reading input"
خرجة"
@@ -32195,22 +32356,10 @@
#~ msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "اسÙ
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "%-5d dig_att ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#~ msgstr "اسÙ
-#, fuzzy
#~ msgid "Did not find input cell map MASK."
#~ msgstr "<%s>ÙÙ
ÙØªÙ
Ø§ÙØ¹Ø«Ùر عÙÙ Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©\n"
@@ -32223,34 +32372,10 @@
#~ msgstr "ÙÙ
ÙØªÙ
ØªØØ¯ÙØ« Ø§ÙØØ¯ÙØ¯"
#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "بدء باÙÙÙÙ
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "اسÙ
-#, fuzzy
#~ msgid "Error while reading input raster map."
#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "%s ÙÙ
ÙØªÙ
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
-#, fuzzy
#~ msgid "Could not open <%s>"
#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
@@ -32259,18 +32384,6 @@
#~ msgstr "<%s>ÙÙ
ÙØªÙ
Ø¯Ø®ÙØ©\n"
#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "اسÙ
خرجة"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#~ msgstr "اسÙ
-#, fuzzy
#~ msgid "Error reading intensity data"
#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
@@ -32419,22 +32532,6 @@
#~ msgstr "عدد ÙÙØ§Ø· Ø§ÙØ¥Ø³ØªÙÙØ§Ø¡"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "اسÙ
Ø§ÙØ¬Ø¯ÙÙ"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "اسÙ
Ù
Ù٠اÙÙ
رشØ"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "عدد Ø§ÙØµÙÙÙ"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#~ msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "اسÙ
Ù
ÙÙ ÙØ§ØªØ¬ Ø§ÙØªØµÙÙÙ"
@@ -32661,10 +32758,6 @@
#~ msgstr "اÙÙ
دخÙ"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "Ø§ÙØµÙر ÙÙÙ
Ø© ØÙÙÙÙØ©"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
#~ msgstr "اÙÙ
دخÙ"
@@ -32712,10 +32805,6 @@
#~ msgstr "Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة : Ù
ÙÙØ¯ ÙÙØ¹Ø±Ø¶ اÙÙ
رئ٠ÙÙÙØªØ§Ø¦Ø¬ "
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
Ø© ØÙÙÙÙØ©"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù ÙÙØ³Ø·Ø"
@@ -32827,20 +32916,6 @@
#~ msgstr "ÙØµÙ Ù
بسط ÙÙÙ
خرج"
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "%d راستر%s, %d ÙÙÙØªÙر%s\n"
@@ -32932,10 +33007,6 @@
#~ msgstr "تÙÙÙØ° Ø¨ÙØ¯ÙØ¡"
#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> اÙÙ
ÙØ·ÙØ©"
-#, fuzzy
#~ msgid "Subgroup [%s] not found."
#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> اÙÙ
ÙØ·ÙØ©"
@@ -33005,14 +33076,6 @@
#~ msgstr "Ù
ÙÙÙØ¨ ÙØ±Ù Ø§ÙØ¹Ø²Ù
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "ÙØªØ§Ø¨Ø© Ù
ÙÙ Ø¬Ø¯ÙØ¯...\n"
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
-#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
@@ -33031,14 +33094,6 @@
#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "<%s> ÙÙ <%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
ÙÙ ÙÙÙ
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "%s ÙÙ
ÙØªÙ
-#, fuzzy
#~ msgid "Group of imagery files to be clustered"
#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø·ÙÙØ¨ ترÙÙØ¹Ùا Ø¨Ø¨Ø¹Ø¶ÙØ§ "
@@ -33117,10 +33172,6 @@
#~ msgstr "اسÙ
Ù
#, fuzzy
-#~ msgid "raster, imagery, fusion"
-#~ msgstr "اÙÙ
-#, fuzzy
#~ msgid "Name of GIS manager settings file (.grc)"
#~ msgstr "MAT-File(v4) اسÙ
اÙÙ
ÙÙ"
@@ -33327,18 +33378,10 @@
#~ msgstr "ÙÙØ¹ ØºÙØ± Ù
عرÙÙ"
#, fuzzy
-#~ msgid "From layer"
-#~ msgstr " nv ÙÙÙ\n"
-#, fuzzy
#~ msgid "The column must be type integer or string"
#~ msgstr "ÙÙ
ØªÙØ¬Ø¯<%s>Ø§ÙØ®Ø±Ùطة اÙÙÙÙØªÙØ±ÙØ©"
#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "ÙÙØ¹ اÙÙ
Ø¸ÙØ±"
-#, fuzzy
#~ msgid "Cannot select records from database"
#~ msgstr "ÙÙ
ÙÙ
Ù Ø§ÙØ¬Ø¯ÙÙ"
@@ -33653,10 +33696,6 @@
#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ± Ø§ÙØºØ·Ø§Ø¡"
-#, fuzzy
#~ msgid "Output raster map with lake"
#~ msgstr "اسÙ
Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
خرجة"
@@ -34145,10 +34184,6 @@
#~ msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "Ø§ÙØ®Ø±Ùطة اÙÙÙÙØªÙØ±ÙØ© ÙÙÙØ§Ø· Ø§ÙØ¨Ø¯Ø¡"
-#, fuzzy
#~ msgid "Could not open input file <%s>."
#~ msgstr "<%s>ÙÙ
ÙØªÙ
Ø¯Ø®ÙØ©\n"
@@ -34571,10 +34606,6 @@
#~ msgstr "ÙÙ
ÙØ³ØªØ·Ø¹ عرض ÙÙØ§Ø¹Ø¯ Ø§ÙØ¨ÙØ§ÙØ§Øª"
#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "اسÙ
-#, fuzzy
#~ msgid "Cannot open vector map <%s> at the topological level"
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
@@ -36096,3 +36127,1329 @@
#~ "Displays the rhumbline joining two user-specified points, in the active "
#~ "frame on the user's graphics monitor."
+#, fuzzy
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "ASCII text تØÙÙÙ Ù
Ù٠راستر٠اÙÙ Ù
Ù٠اسÙÙ ÙØµÙ"
+#, fuzzy
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "(تØÙÙ٠اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙØµÙ Ø§ÙØ£Ø³Ù٠اÙÙ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø«ÙØ§Ø¦ÙØ© (ØµÙØ±,ÙØ§ØØ¯"
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "%-5d dig_att ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
+#, fuzzy
+#~ msgid "raster3d, statistics"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "binary MAT-File تØÙÙ٠راستر جراس٠اÙÙ Ù
Ù٠بÙÙØ±Ù Ù
Ù ÙÙØ¹"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "GRIDATB.FOR (TOPMODEL) تØÙÙÙ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø¬Ø±Ø§Ø³ÙØ© اÙÙ Ø®Ø±ÙØ·Ø© Ù
Ù ÙÙØ¹"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "raster, export"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "raster, import"
+#~ msgstr "اÙÙ
دخÙ"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr "POVRAY تØÙÙÙ Ù
Ù٠راستر٠اÙÙ Ù
ÙÙ ØÙÙ Ø§Ø±ØªÙØ§Ø¹Ø§Øª ÙØ³ØªØ®Ø¯Ù
ÙÙ Ø¨Ø±ÙØ§Ù
ج"
+#, fuzzy
+#~ msgid "raster, map algebra"
+#~ msgstr "اÙÙ
دخÙ"
+#~ msgid "Converts a raster map layer into an ASCII text file."
Ù٠راستر٠اÙÙ Ù
Ù٠اسÙÙ ÙØµÙ"
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "ÙØªØ§Ø¨Ø© Ù
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "%s ÙÙ
ÙØªÙ
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "( Ø¥Ø¯Ø®Ø§Ù ÙØ¨ÙØ§ÙØ§Øª Ø¹Ø´Ø±ÙØ© (Ø§ÙØ£Ø³Ø§Ø³ : صØÙØØ©"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr "Ø£Ø¯Ø®Ø§Ù Ø¨ÙØ§Ùات Ù
Ø¶Ø§Ø¹ÙØ© Ø§ÙØ¯ÙØ© ÙØ§Ùأساس Ø¨ÙØ§Ùات صØÙØØ©"
+#, fuzzy
+#~ msgid "Parsing bytes per cell"
+#~ msgstr "عدد Ø§ÙØ¨Ùتات ÙÙ Ø§ÙØ®ÙÙØ© , ÙØ§ØØ¯Ø©, Ø§Ø«ÙØªÙÙ, Ø£Ù
أربعة"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
أربعة"
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ± Ø§ÙØºØ·Ø§Ø¡"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "اسÙ
خرجة"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ± ااÙÙØ§ØªØ¬Ø©"
+#, fuzzy
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "تØÙÙÙ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø¥ÙÙ ÙÙÙØªÙØ±ÙØ©"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "عدد ÙÙØ§Ø· Ø§ÙØ¥Ø³ØªÙÙØ§Ø¡"
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#~ msgstr "<%s>ÙÙ
ÙØªÙ
Ø¯Ø®ÙØ©\n"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "اسÙ
Ù
ÙÙ Ø¥ØªØ¬Ø§Ù Ø§ÙØ¥ÙØØ¯Ø§Ø± Ø§ÙØ±Ø§Ø³ØªØ±Ù"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "اسÙ
Ù
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#~ msgstr "اسÙ
Ù
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "Ù
Ù٠عاÙ
٠اشعاع Ø§ÙØ£Ø´Ø¹Ø© اÙÙ
Ø±Ø³ÙØ© ÙÙØ³Ù
اء Ø§ÙØÙÙÙÙØ©"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "اسÙ
Ù
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "اسÙ
اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ø§ÙØ¬Ø¯Ùد"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ¥ØªØ¬Ø§Ù اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØµØ±Ù اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "اسÙ
Ù
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "ÙØµÙ Ù
بسط ÙÙÙ
خرج"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ§Ø±ØªÙاعات Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
خرجة"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "PPM تØÙÙÙ Ø«ÙØ§Ø« راسترات جراسÙÙ Ù
Ù
Ø«ÙØ© ÙÙØ£ØÙ
ر Ù Ø§ÙØ£Ø®Ø¶Ø± ÙØ§Ùأزر٠اÙÙ ØµÙØ±Ø©"
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
+#, fuzzy
+#~ msgid "raster, buffer"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "raster, series"
+#~ msgstr "Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø·ÙÙØ¨ تسجÙÙÙØ§"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ù
Ø¯Ø®ÙØ©: ÙÙ
ÙØ© Ø§ÙØ³Ø±Ùا٠ÙÙÙ
ÙØ§Ù عÙÙ Ø§ÙØ¨Ø± ÙÙÙ Ø®ÙÙØ©"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "USLE Ø®Ø±ÙØ·Ø© Ù
Ø¯Ø®ÙØ© : Ø§ÙØªØ¶Ø§Ø±Ùس Ø§ÙØØ§Ø¬Ø¨Ø© ÙÙØ³Ø±ÙØ§Ù Ø§ÙØ³Ø·ØÙ عبر Ø§ÙØ¨Ø±, ÙÙ"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة : عدد Ø§ÙØ®ÙØ§ÙØ§ Ø§ÙØªÙ تصب ÙÙ ÙÙ Ø®ÙÙØ©"
+#~ msgid "Output map: unique label for each watershed basin"
خرجة: عÙÙØ§Ù ÙØ±Ùد ÙÙÙ ØÙض Ù
ØØ¯Ø¯Ø§Øª اÙÙ
ÙØ§Ù"
+#~ msgid "Output map: each half-basin is given a unique value"
خرجة : ÙÙ ÙØµÙ ØÙض Ù
عط٠ÙÙÙ
Ø© ÙØ±Ùدة "
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr "USLE ÙÙ (LS)Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة : Ø·ÙÙ Ø§ÙØ¥ÙØØ¯Ø§Ø± ÙÙØ¹ÙرتÙ, عاÙ
Ù"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "USLE ÙÙ (S)Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة : ÙØ¹Ùرة Ø§ÙØ¥ÙØØ¯Ø§Ù, عاÙ
Ù "
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "اÙÙÙÙ
Ø© اÙÙ
Ø¯Ø®ÙØ© : أصغر ØØ¬Ù
Ù
Ù Ù
ØØ¯Ø¯Ø§Øª Ù
ÙØ§Ù Ø§ÙØ£ØÙاض Ø§ÙØ®Ø§Ø±Ø¬ÙØ©"
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr "USLE اÙÙÙÙ
Ø© اÙÙ
Ø¯Ø®ÙØ© : Ø£ÙØ¨Ø± Ø·ÙÙ Ù
Ù ÙÙØ³Ø±ÙØ§Ù Ø§ÙØ³Ø·ØÙ, ÙÙ"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "اسÙ
Ù
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "خطا ÙÙ Ù
ØØ§ÙÙØ© ÙØ±Ø§Ø¡Ø© Ù
ÙÙ ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª dbmscap\n"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "MPEG تØÙÙÙ Ù
جÙ
ÙØ¹Ø© Ù
ÙÙØ§Øª Ø±Ø§Ø³ØªØ±ÙØ© اÙÙ"
+#, fuzzy
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "ØªØ±Ø´ÙØ ÙØ§Ùشاء Ø®Ø±ÙØ·Ø© Ø§Ø±ØªÙØ§Ø¹Ø§Øª عدÙÙ
Ø© اÙÙ
ÙØ®Ùضات ÙØ®Ø±Ùطة Ø§ØªØ¬Ø§Ù Ø§ÙØ³Ø±Ùا٠Ù
Ù Ø®Ø±ÙØ·Ø© "
+#~ "Ø§ÙØ¥Ø±ØªÙاعات اÙÙ
عطاÙ"
+#~ msgid "Output direction raster map"
خرجة"
+#~ msgid "Output raster map of problem areas"
خرجة ÙÙÙ
Ø³Ø§ØØ§Øª ذات Ù
Ø´ÙÙØ©"
+#, fuzzy
+#~ msgid "raster, resample"
Ø·ÙÙØ¨ تسجÙÙÙØ§"
+#, fuzzy
+#~ msgid "Cannot read ew_res value"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØµÙ Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+#~ msgid "Cannot read ns_res value"
+#~ msgstr "ÙÙ
ÙÙ
ÙÙ ÙØµÙ Ø§ÙØ¬Ø¯ÙÙ"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "Ø¨Ø±ÙØ§Ù
ج Ø§ÙØ´Ø§Ø¡ Ø§ÙØ³Ø·Ø Ù
٠اÙÙÙØªÙرات Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Ø¥ÙØ´Ø§Ø¡ ÙØªØ¹Ø¯Ù٠جدÙÙ Ø§ÙØ£ÙÙØ§Ù اÙÙ
ØµØ§ØØ¨ ÙØ·Ø¨ÙØ© Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "اسÙ
ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© Ø§ÙØ³Ø® جدÙ٠أÙÙØ§ÙÙØ§"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "Ø¥Ø¯Ø®Ø§Ù Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© بÙÙØ±ÙØ© "
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ´Ø§Ø¡ Ø§ÙØ¯ÙÙÙ"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "%s:ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#~ msgstr "اÙÙ
+#, fuzzy
+#~ msgid "raster, null data"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "Ø§ÙØ´Ø§Ø¡ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø¨ÙØ§ Ù
Ø³Ø§ØØ§Øª Ù
ØªØ¬Ø§ÙØ±Ø© ÙÙ
ت بخÙÙØ© ÙØ§ØØ¯Ø©"
+#, fuzzy
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(Ù
دخÙ) r.water.outlet Ø®Ø±ÙØ·Ø© Ø§ÙØ£ØÙاض اÙÙØ§ØªØ¬Ø© Ù
Ù"
+#, fuzzy
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ¥ØªØ¬Ø§Ù Ù
ع Ø®Ø±ÙØ·Ø© Ø§ÙØ¥Ø±ØªÙاعات Ø§ÙØ®Ø§ÙÙØ© Ù
٠اÙÙ
ÙØ®Ùضات, Ù
خرج"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "عدد Ø£ØµÙØ§Ù Ø§ÙØ¯ÙÙÙ Ø§ÙØ·Ø¨ÙغراÙÙ,Ù
دخÙ"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "Ù
ÙÙ Ø¥ØØµØ§Ø¦Ùات ÙØ¯ÙÙÙ Ø§ÙØ·Ø¨ÙغراÙÙ,Ù
خرجÙ
دخÙ"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "Ù
ÙÙ Ø¥ØØ¯Ø§Ø«Ùات ØªÙØ¨Ù
ÙØ¯ÙÙ,Ù
دخÙ"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "Ù
ÙÙ Ø¨ÙØ§Ùات اÙÙ
طر Ø§ÙØ³Ø§ÙØ· ÙØ§ÙÙØªØ Ø§ÙØªØ¨Ø®Ø±Ù اÙÙØ¹Ø§Ù,Ù
دخÙ"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
ج ØØ³Ø§Ø¨ اÙ
اÙÙ Ø§ÙØ¸Ùا٠Ù
Ù Ù
ÙØ§Ù Ø§ÙØ´Ù
س ÙÙÙ
ÙØ°Ø¬ Ø§ÙØ¥Ø±ØªÙاعات Ø§ÙØ±ÙÙ
Ù"
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A:Ø§Ø±ØªÙØ§Ø¹ Ø§ÙØ´Ù
س ÙÙÙ Ø§ÙØ£ÙÙ, درجات"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: زاÙÙØ© Ø§ÙØ´Ù
س Ù
ÙØ§Ø³Ø© Ù
Ù Ø§ÙØ´Ù
اÙ, درجات"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: (60..0) Ø§ÙØ¯ÙÙÙØ©"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: (60..0) Ø§ÙØ«Ø§ÙÙØ©"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "(اÙÙØ·Ø§Ù Ø§ÙØ²Ù
ÙÙ (شر٠Ù
ÙØ¬Ø¨,اÙÙØ±Ù Ù
٠ج٠اÙ
تÙ,ÙØ³ØªØ®Ø¯Ù
Ø§ÙØ¶Ø§ ÙØ¶Ø¨Ø· تÙÙÙØ± Ø¶ÙØ¡ "
+#~ "اÙÙÙØ§Ø±"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Ø®ÙÙ Ø·Ø¨ÙØ© Ø®Ø±ÙØ·Ø© Ø¬Ø¯ÙØ¯Ø© تعتÙ
د ÙÙÙ
ÙØ¦Ø§ØªÙا عÙ٠إعادة Ø§ÙØªØµÙÙÙ ÙÙØ¦Ø§Øª Ø®Ø±ÙØ·Ø© "
+#~ "Ø±Ø§Ø³ØªØ±ÙØ© أخرÙ"
+#~ msgid "Raster map to be reclassified"
Ø·ÙÙØ¨ إعادة تصÙÙÙÙØ§"
+#~ msgid "Converts a raster map into a vector map layer."
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "Ø§ÙØ¥ØØ¯Ø§Ø«Ù ااشرÙÙ ÙÙØ®Ø±Ùطة\n"
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "بدء باÙÙÙÙ
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#~ msgstr "fp: Data range is %.25f to %.25f\n"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#~ msgstr " %ld اÙÙ %ld ÙØ·Ø§Ù Ø§ÙØ¨ÙØ§ÙØ§Øª ÙØªØ±Ø§ÙØ Ù
Ù\n"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
خرجة"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#~ msgstr "Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© ÙÙÙØ§Ø· Ø§ÙØ¨Ø¯Ø¡"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr ""
+#~ "(تØÙÙ٠اÙÙ
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "عرض عÙÙØ§Ù اÙÙØ¦Ø© ÙÙ Ø®ÙÙØ© Ø§ÙØ´Ø¨ÙØ©"
+#, fuzzy
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr "ln(a/tan(beta)) تعÙÙÙ Ø§ÙØ¯ÙÙÙ Ø§ÙØ·Ø¨ÙغراÙÙ Ù
Ù Ø®Ø±ÙØ·Ø© Ø§ÙØ¥Ø±ØªÙاعات"
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "ÙÙØ¹ Ø§ÙØ¹Ù
ÙØ¯ ØºÙØ± Ù
دعÙ
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "(تØÙÙ٠اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ù
Ù ÙÙØ¹ Ø¥Ø³Ø±Ù Ø¢Ø±ÙØ¥ÙÙ٠اÙÙ Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø«ÙØ§Ø¦ÙØ© (ØµÙØ±,"
+#~ "ÙØ§ØØ¯"
+#, fuzzy
+#~ msgid "File containing weights"
+#~ msgstr "dig_att عط٠ÙÙ ÙØªØ Ù
Ù٠اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "طباعة ÙÙØ¹ اÙÙ
+#, fuzzy
+#~ msgid "general, settings"
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#~ msgstr "Ø§ÙØ®Ø±Ùطة اÙÙÙÙØªÙØ±ÙØ© ÙÙÙØ§Ø· Ø§ÙØ¨Ø¯Ø¡"
+#, fuzzy
+#~ msgid "format"
خرجة"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "اسÙ
Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Ø§ÙØ´Ø§Ø´Ø©: ÙÙØªØ¨Ø¯: Ù
تÙÙØ¹ %d ÙÙÙ٠تÙ
Ø§ÙØØµÙ٠عÙÙ %d\n"
+#, fuzzy
+#~ msgid "No raster or vector map displayed"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Unable to create face"
+#~ msgstr "ÙÙ
ÙØªÙ
ØªØØ¯ÙØ« Ø§ÙØØ¯ÙØ¯"
+#, fuzzy
+#~ msgid "Unable to set size"
+#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#~ msgstr "ØªØºÙØ¨ عÙÙ Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "اÙÙ
ÙÙØ§Øª Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø·ÙÙØ¨ Ø±Ø¤ÙØªÙا%d"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr "اÙÙ
Ø·ÙÙØ¨ Ø±Ø¤ÙØªÙا%d"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr "Ø§Ø®ØªÙØ§Ø± Ø§ÙØ®Ø· Ø§ÙØ°Ù Ø³ÙØ¹Ø±Ø¶ ب٠اÙÙØµ عÙÙ Ø§ÙØ´Ø§Ø´Ø©"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+#~ msgid "%d new points written to output"
+#~ msgstr "%d ÙÙØ·Ø© ÙØªØ¨Øª ÙÙÙ
خرج\n"
+#, fuzzy
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "تØÙÙ٠راستر جراس٠اÙ٠بÙÙØ±Ù"
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Query layer number (read from)"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "vector, interpolation"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgstr "اسÙ
ØØªÙÙØ© عÙÙ Ù
عÙÙÙ
ات Ø§ÙØªÙÙÙØ© ÙØ®ÙÙØ© Ø§ÙØ´Ø¨ÙØ©"
+#, fuzzy
+#~ msgid "Vector based generalization."
+#, fuzzy
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "ادخا٠Ù
ÙÙ Ø±Ø§Ø³ØªØ±Ù Ø«ÙØ§Ø¦Ù ÙØ·Ø¨ÙØ© Ø®Ø±ÙØ·Ø© Ø±Ø§Ø³ØªØ±ÙØ© Ø¬Ø±Ø§Ø³ÙØ©"
+#, fuzzy
+#~ msgid "Total area: %e (%d areas)"
+#~ msgstr "ÙØµÙ اÙÙØ¦Ø§Øª...\n"
+#, fuzzy
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "%-5d تÙ
ØªØ®Ø·Ù ÙØ¦Ø§Øª اÙÙÙØ· اÙÙ
ÙØª\n"
+#, fuzzy
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "vector, extract"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Layer number (from)"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Layer number (to)"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "[%s]ÙÙ
ÙØªÙ
ÙØªØ Ù
ÙÙ Ø§ÙØ®ÙÙØ© Ù "
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#, fuzzy
+#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#~ msgstr "%d ÙÙØ§Ø· تÙ
تØÙ
ÙÙÙØ§\n"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#, fuzzy
+#~ msgid "Parameter '%s' ignored in standard mode"
+#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© "
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "dig ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
+#, fuzzy
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "Ø·Ø¨ÙØªÙÙ ÙØ¬Ø¨ ØªØØ¯ÙدÙÙ
+#, fuzzy
+#~ msgid "Key column '%s' not found"
+#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> اÙÙ
ÙØ·ÙØ©"
+#, fuzzy
+#~ msgid "Exporting %i points/lines..."
+#, fuzzy
+#~ msgid "%d features written"
خرج\n"
+#, fuzzy
+#~ msgid "vector, projection"
+#, fuzzy
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+#~ msgid "vector, metadata"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Buffer distance in map units"
+#~ msgstr "اÙÙ
Ø³Ø§ÙØ© Ø§ÙØ¹Ø¸Ù
+#, fuzzy
+#~ msgid "vector, querying"
+#, fuzzy
+#~ msgid "Queries a vector map layer at given locations."
+#, fuzzy
+#~ msgid "If not given reads from standard input"
+#~ msgstr "اÙÙ
Ø·ÙÙØ¨ ادخاÙÙ"
+#, fuzzy
+#~ msgid "vector, transformation"
+#, fuzzy
+#~ msgid "Copying vector objects from vector map <%s>..."
ÙÙ...\n"
+#, fuzzy
+#~ msgid "Name of input vector map containing lines"
Ø¯Ø®ÙØ© ØØ§ÙÙØ© Ø§ÙØ®Ø·ÙØ·"
+#, fuzzy
+#~ msgid "Name for output vector map where segments will be written"
خرجة ØÙØ« Ø³ØªÙØªØ¨ اÙÙÙØ§Ø·"
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#~ msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr "Ø¥ÙØ´Ø§Ø¡ ÙÙØ§Ø· عÙÙ Ø§ÙØ®Ø· اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "%d points written to output vector map"
خرج\n"
+#, fuzzy
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "Copying vector lines..."
+#~ msgstr "ÙÙ
ÙØªÙ
ÙØ³Ø® Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+#~ msgid "%d lines / boundaries removed"
+#~ msgstr "اÙÙ
+#, fuzzy
+#~ msgid "Duplicate area centroids: %5d"
+#~ msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
+#, fuzzy
+#~ msgid "Attribute table column with values to interpolate"
+#~ msgstr "اسÙ
ØØªÙÙØ© عÙÙ Ù
عÙÙÙ
+#, fuzzy
+#~ msgid "No data points found"
+#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ«Ùر عÙÙ Ø´ÙØ¦\n"
+#, fuzzy
+#~ msgid "Lines buffers... "
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "Error reading ASCII file: '%s'"
+#~ msgstr "%s ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#~ msgstr "اخراج اÙÙ
عÙÙÙ
ات Ø§ÙØ£Ø³Ø§Ø³ÙØ© ÙØ®Ø±Ø§Ø¦Ø· Ø±Ø§Ø³ØªØ±ÙØ© ÙØØ¯Ø¯ÙØ§ اÙÙ
ستخدÙ
+#, fuzzy
+#~ msgid "Name of creator: %s"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "vector, category"
+#, fuzzy
+#~ msgid "Output surface raster map (elevation)"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ¥Ø±ØªÙاعات"
+#, fuzzy
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr "طباعة Ø¥ØØ¯Ø§Ø«Ùات Ø§ÙØ¥ØªØµØ§Ù Ø§ÙØÙÙ Ù Ø§ÙØ®Ø±Ùج"
+#, fuzzy
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "ÙÙ
+#, fuzzy
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#, fuzzy
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "اسÙ
ÙØ¬Ùدة"
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#~ msgid "Verbose module output"
+#~ msgstr "تÙÙÙØ° Ø¨Ø§Ø³ÙØ§Ø¨"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "اسÙ
Ù
ÙÙ Ø§ÙØªÙØ±ÙØ±"
+#, fuzzy
+#~ msgid "Surface"
+#~ msgstr "تباÙ٠اÙÙ
جÙ
ÙØ¹"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr " ØºÙØ± Ù
دعÙ
%d OGR ÙÙØ¹ ,'%s' عÙ
ÙØ¯:OGR Ù
شغ٠ا٠"
+#, fuzzy
+#~ msgid "Database schema"
+#~ msgstr ":اسÙ
+#, fuzzy
+#~ msgid "database, SQL"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Name of file with sql statement"
+#~ msgstr "اسÙ
اÙÙ
ÙÙ Ø¨ØªØ¹Ø¨ÙØ± اس.ÙÙÙ.اÙ"
+#, fuzzy
+#~ msgid "The password was stored in file"
+#~ msgstr "ØÙظت ÙÙÙ
Ø© اÙÙ
Ø±ÙØ± ÙÙ Ù
ÙÙ"
+#, fuzzy
+#~ msgid "How to split display"
+#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+#~ msgid "Select multiple points"
+#~ msgstr "ÙÙØ¹ اÙÙ
Ø¸ÙØ±"
+#, fuzzy
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#, fuzzy
+#~ msgid "Region sensitive output"
+#, fuzzy
+#~ msgid "raster, elevation"
+#~ msgstr "Ø§ÙØµÙر ÙÙÙ
Ø© ØÙÙÙÙØ©"
+#, fuzzy
+#~ msgid "miscellaneous, projection"
+#, fuzzy
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Ù
Ù٠اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#~ msgstr "اسÙ
Ù
Ù٠اÙÙ
رشØ"
+#, fuzzy
+#~ msgid "PostScript"
+#~ msgstr "اÙÙ
خرج"
+#, fuzzy
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#~ msgstr "اÙÙ
خرج"
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "ÙÙ
ÙØªÙ
ÙØ³Ø® Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+#~ msgid "raster, tiling"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "طباعة Ø§ÙØ¬Ø¯Ø§ÙÙ ÙØ§ÙØ®Ø±ÙØ¬"
+#, fuzzy
+#~ msgid "display, diagram"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "ØªÙØ±Ùر Ø§ÙØ¥ØØµØ§Ø¦Ùات ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "display, export, GPS"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "عدد Ø§ÙØ£Ø¹Ù
دة"
+#, fuzzy
+#~ msgid "general, manual, help"
+#, fuzzy
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "Ø§ÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø·ÙÙØ¨ ÙØ±Ø§Ø¦ØªÙا"
+#, fuzzy
+#~ msgid "Overwrite existing MASK"
+#~ msgstr "%s:ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "display, slideshow"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr "ØØ³Ø§Ø¨ Ø¥ØØµØ§Ø¦Ùات اÙÙ
ØªØºÙØ± Ø§ÙØ£ØØ§Ø¯Ù Ù
Ù Ø®ÙØ§Ùا ذات ÙÙÙ
Ø© Ø¨Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Display manager for GRASS"
دة"
+#, fuzzy
+#~ msgid "GIS manager for GRASS"
دة"
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
Ù Ø®ÙØ§Ùا ذات ÙÙÙ
+#, fuzzy
+#~ msgid "Percentile to calculate (requires -e flag)"
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Do not overwrite existing map"
+#~ msgstr "%s:ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Import track"
+#, fuzzy
+#~ msgid "Name of PNG file"
+#~ msgstr "اسÙ
Ù
Ù٠اÙÙ
رشØ"
+#, fuzzy
+#~ msgid "Configuration editor for r.li.'index'"
+#~ msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "ادخا٠Ù
+#, fuzzy
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Layer where to add column"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Target monitor"
+#, fuzzy
+#~ msgid "Source monitor"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#~ msgstr "ØØ³Ø§Ø¨ Ø§ÙØ¸Ùا٠Ù
Ù ÙÙ
ÙØ°Ø¬ Ø§ÙØ¥Ø±ØªÙاعت Ø§ÙØ±ÙÙ
Ù"
+#, fuzzy
+#~ msgid "imagery, rectify"
+#~ msgstr "اÙÙ
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#~ msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#~ msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
+#, fuzzy
+#~ msgid "imagery, orthorectify"
+#~ msgstr "اÙÙ
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> اÙÙ
ÙØ·ÙØ©"
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "No initial camera exposure station for group [%s]"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
+#, fuzzy
+#~ msgid "Bad format in initial camera exposure station for group [%s]"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
+#, fuzzy
+#~ msgid "No photo points for group [%s]"
+#~ msgstr "ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#~ msgstr "ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Computing equations ..."
+#~ msgstr "ÙÙ
ÙØªÙ
ÙØ³Ø® Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "طباعة Ù
صÙÙÙØ© اÙÙ
Ø¶Ø§ÙØ§Ù"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#~ msgstr "ÙÙ
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#~ msgstr "ÙÙ
+#, fuzzy
+#~ msgid "Interactively select or modify the target elevation model."
+#~ msgstr "Ø¥Ø®ØªÙØ§Ø± اÙÙÙØ§Ø· Ø§ÙØ·Ø±ÙÙØ© ØªÙØ§ØºÙÙØ§"
+#, fuzzy
+#~ msgid "Target information for group [%s] missing\n"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
+#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùد <%s>اÙÙ
ÙÙ ÙÙÙ
ÙØ¸Ø± Ø«ÙØ§Ø«Ù Ø§ÙØ£Ø¨Ø¹Ø§Ø¯ "
+#, fuzzy
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#~ msgstr "%s:ÙÙ
ÙØªÙ
ÙØªØ Ù
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "display, legend"
+#~ msgstr "اÙÙ
دخÙ"
+#, fuzzy
+#~ msgid "Layer to use for thematic display"
+#~ msgstr "اسÙ
+#, fuzzy
+#~ msgid "Mapset(s) to list (default: current mapset search path)"
+#, fuzzy
+#~ msgid "Icon to remove"
+#~ msgstr "اÙÙ
+#, fuzzy
+#~ msgid "Name of the output walkers vector points map"
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+#~ "(ercent_cover)"
+#~ msgstr ""
+#~ "Ø£Ù
ÙØ§Ù mi, Ø£Ù
تار me, ÙÙÙÙÙ
+#~ "ÙØ³Ø¨Ø© Ø§ÙØªØºØ·ÙØ©"
+#, fuzzy
+#~ msgid "Writing %s"
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+#~ msgid "To layer"
+#~ msgstr "اسÙ
Ø§ÙØ·Ø¨ÙØ© اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "vector, attribute table"
+#~ msgstr "عدÙ
+#, fuzzy
+#~ msgid ""
+#~ "Line: %d \n"
+#~ "Type: %s \n"
+#~ "Left: %d \n"
+#~ "Right: %d \n"
+#~ msgstr " %d:ÙÙ
ÙÙ %d:ÙØ³Ø§Ø± %s:ÙÙØ¹ %d: خط "
+#, fuzzy
+#~ msgid ""
+#~ "Node[%d]: %d \n"
+#~ "Number of lines: %d \n"
+#~ "Coordinates: %.6f, %.6f, %.6f\n"
+#~ msgstr "%d : عدد Ø§ÙØ®Ø·ÙØ· %d: [%d] Ø§ÙØ¹Ùدة\n"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %5d \n"
+#~ "Angle: %.8f\n"
+#~ msgstr " Line: %5d Angle: %.8f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Area: %d \n"
+#~ "Number of isles: %d\n"
+#~ msgstr "Ù
Ø³Ø§ØØ©: %d عدد Ø§ÙØ¬Ø²Ø±: %d\n"
+#, fuzzy
+#~ msgid "Type of elements"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the real-image map."
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#~ msgstr "اسÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "Insufficent memory for allocation of data structure"
+#~ msgstr "Ù
ÙÙØ¹ ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
+#, fuzzy
+#~ msgid "Writing data to file..."
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+#~ msgid "Hue map name"
+#~ msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
+#, fuzzy
+#~ msgid "Red input raster map"
+#~ msgstr "Ø§Ø¯Ø®Ù Ø®Ø±ÙØ·Ø© Ø§ÙØ±Ø§Ø³ØªØ±"
+#, fuzzy
+#~ msgid "Output hue raster map"
+#~ msgstr "اسÙ
خرجة"
+#, fuzzy
+#~ msgid "** Can't open seed singature file <%s> **"
+#~ msgstr "<%s> ÙÙ <%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
ÙÙ ÙÙÙ
+#, fuzzy
+#~ msgid "Error writing result map file!"
ØØ§ÙÙØ© ÙØ±Ø§Ø¡Ø© Ù
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#~ msgstr "اسÙ
Ù
+#, fuzzy
+#~ msgid "Name of the resultant map"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙØ§ØªØ¬Ø©"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#~ msgstr "ÙÙ
ÙÙ
Ù Ø§ÙØ¬Ø¯ÙÙ"
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#~ msgstr "%s:ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Done"
+#~ msgstr "Ø§ÙØªÙÙ\n"
+#, fuzzy
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr "%s ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Unable to read category file for raster map <%s>"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
Ù٠اÙÙ
د٠Ù"
+#, fuzzy
+#~ msgid "Reading %s ... "
ÙÙ...\n"
+#, fuzzy
+#~ msgid "%s in %s: %s"
+#~ msgstr "%s:خط %d:%s\n"
+#, fuzzy
+#~ msgid "cannot read head of %s"
+#~ msgstr "ÙÙ
بÙ
ÙÙ ÙØ±Ø§Ø¡Ø© Ù
عÙÙÙ
ات Ø§ÙØÙÙ"
+#, fuzzy
+#~ msgid "Cannot allocate buffer for reading null values."
+#~ msgstr "ÙÙ
ÙØªÙ
ØØ³Ø§Ø¨ شب٠Ù
Ø±ÙØ² اÙÙ
Ø³Ø§ØØ©"
+#, fuzzy
+#~ msgid "Reading raster map <%s> ..."
ÙÙ...\n"
+#, fuzzy
+#~ msgid "No record for cat = %d"
+#~ msgstr "cat = %d ÙØ§ ÙÙØ¬Ø¯ تسجÙÙ ÙÙØ®Ø·"
+#, fuzzy
+#~ msgid "Vector map <%s> not found in current mapset"
+#~ msgstr "ÙÙ
+#, fuzzy
+#~ msgid "Database connection not defined for layer <%d>"
+#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ¥ØªØµØ§Ù Ø¨ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª\n"
+#, fuzzy
+#~ msgid "Editing tool"
ÙÙ Ø¬Ø¯ÙØ¯...\n"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#, fuzzy
+#~ msgid "Database record for cat %d not found"
+#~ msgid "Name of the random surface to be produced"
+#~ msgstr "اسÙ
Ø§ÙØ³Ø·Ø Ø§ÙØ¹Ø´Ùائ٠اÙÙ
Ø·ÙÙØ¨ Ø¥ÙØªØ§Ø¬Ù"
+#, fuzzy
+#~ msgid "Cannot open file [%s]"
+#~ msgstr "%s ÙÙ
ÙØªÙ
+#, fuzzy
+#~ msgid "Read coordinates from standard input"
+#~ msgstr "Ø¥ØØ¯Ø§Ø«Ùات Ø§ÙØ´Ø±Ù ÙØ§ÙØ´Ù
ا٠ÙÙÙØ·Ø© Ø§ÙØ¨Ø¯Ø¡"
+#~ msgid "Name of the new raster map"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "Could not find input vector map %s"
+#~ msgstr "<%s>ÙÙ
ÙØªÙ
Ø¯Ø®ÙØ©\n"
+#, fuzzy
+#~ msgid "Can't create output map"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "name for new vector map"
+#~ msgstr "اسÙ
اÙÙ
+#, fuzzy
+#~ msgid "Cover raster map"
+#~ msgstr "Ø§ÙØ®Ø±Ùطة Ø§ÙØºØ·Ø§Ø¡"
+#~ msgid "Topographic index ln(a/tanB) map"
+#~ msgstr "Ø®Ø±ÙØ·Ø© Ø§ÙØ¯ÙÙÙ Ø§ÙØ·Ø¨ÙغراÙÙ"
+#, fuzzy
+#~ msgid "No input coordinates provided"
+#~ msgstr "Ø§ÙØ¥ØØ¯Ø§Ø«Ù Ø§ÙØ´Ù
اÙÙ ÙÙØ®Ø±Ùطة\n"
+#, fuzzy
+#~ msgid "Name of the output walkers site file"
+#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "Path to the input file"
+#~ msgstr "اÙÙ
دخÙ"
+#~ msgid "Database name:"
+#~ msgstr ":اسÙ
+#, fuzzy
+#~ msgid "column type not supported"
ÙØ¯ ØºÙØ± Ù
دعÙ
+#, fuzzy
+#~ msgid "Unable to find base map <%s>"
+#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
+#, fuzzy
+#~ msgid "Interpolation()"
+#~ msgstr "طرÙÙØ© Ø§ÙØ§Ø³ØªÙÙØ§Ø¡ اÙÙ
ستخدÙ
Ø©"
+#, fuzzy
+#~ msgid "Calculation time"
Ù ÙÙ
Ù"
+#, fuzzy
+#~ msgid "Name of output 3d raster map"
+#~ msgstr "اسÙ
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
+#, fuzzy
+#~ msgid "output layer name"
+#~ msgstr "اسÙ
Ø§ÙØ·Ø¨ÙØ© اÙÙ
خرجة"
+#, fuzzy
+#~ msgid "Name of input map"
+#~ msgstr "اسÙ
Ù
جÙ
Ø¯Ø®ÙØ©"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_cs.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2188,7 +2188,7 @@
#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
#, c-format
msgid "[%s]: No such color"
-msgstr "[%s]: ®ádná taková barva"
+msgstr ""
#: ../raster/r.out.png/main.c:255
#, fuzzy, c-format
@@ -4137,8 +4137,9 @@
#: ../raster/r.sun/main.c:723 ../general/g.region/printwindow.c:248
#: ../general/g.region/printwindow.c:504 ../general/g.region/printwindow.c:623
#: ../display/d.where/main.c:104 ../imagery/i.latlong/main.c:102
+#, fuzzy
msgid "Can't get projection info of current location"
-msgstr "Nelze získat info mapové projekce aktuální location"
+msgstr "Nelze získat jednotky mapové projekce aktuální location"
#: ../raster/r.sun/main.c:727 ../raster/r.horizon/main.c:477
#: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:507
@@ -7781,8 +7782,9 @@
#: ../general/g.region/printwindow.c:551 ../general/g.region/printwindow.c:559
#: ../general/g.region/printwindow.c:677 ../general/g.region/printwindow.c:685
#: ../general/g.region/printwindow.c:693 ../general/g.region/printwindow.c:701
+#, fuzzy
msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr "Chyba v pj_do_proj (projekce vstupního páru souøadnic)"
+msgstr "Chyba v pj_do_proj (nelze reprojekovat GCP %i)"
#: ../raster/r.proj/main.c:421
msgid "Input:"
@@ -8771,8 +8773,9 @@
msgstr "Název rastrové mapy, ze které se má kopírovat tabulka barev"
#: ../raster/r.colors/main.c:191
+#, fuzzy
msgid "Path to rules file"
-msgstr "Cesta k souboru s pravidly"
+msgstr "Cesta k výslednému souboru VTK"
#: ../raster/r.colors/main.c:192
#, fuzzy
@@ -9278,7 +9281,7 @@
#: ../raster/r.out.gdal/main.c:354
#, fuzzy, c-format
msgid "Could not read data range of raster <%s>"
-msgstr "Nelze naèíst rozsah hodnot pro rastrovou mapu s desetinnou èárkou <%s>"
+msgstr "Nelze naèíst rozsah hodnot rastrové mapy <%s>"
#: ../raster/r.out.gdal/main.c:411
#, c-format
@@ -9319,7 +9322,7 @@
#: ../raster/r.out.gdal/main.c:510 ../raster/r.out.gdal/main.c:514
#, fuzzy
msgid "Raster export aborted."
-msgstr "Název rastrového souboru, který má být importován"
+msgstr "rastr, export"
#: ../raster/r.out.gdal/main.c:491
msgid "Checking GDAL data type and nodata value"
@@ -10040,8 +10043,9 @@
#: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
#: ../visualization/nviz2/cmd/args.c:436
+#, fuzzy
msgid "Position"
-msgstr "Umístìní"
+msgstr "Podle_pozice"
#: ../raster/r.sunmask/main.c:150
#, fuzzy
@@ -12710,19 +12714,20 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:3
#: ../locale/scriptstrings/g.manual_to_translate.c:2
msgid "general"
-msgstr "obecné"
+msgstr ""
#: ../general/g.version/main.c:44
msgid "Displays version and copyright information."
-msgstr "Zobrazí verzi a informace o licenci a autorských právech"
+msgstr ""
#: ../general/g.version/main.c:48
msgid "Print the copyright message"
-msgstr "Vytiskni také zprávu o autorských právech"
+msgstr ""
#: ../general/g.version/main.c:52
+#, fuzzy
msgid "Print the GRASS build information"
-msgstr "Vypi¹ informace o zpùsobu sestavení GRASSu"
+msgstr "Vypi¹ informace o atributech"
#: ../general/g.version/main.c:57
msgid "Print the GIS library revision number and time"
@@ -12730,15 +12735,15 @@
#: ../general/g.access/main.c:39
msgid "Controls access to the current mapset for other users on the system."
-msgstr "Øídí pøístup k aktuálnímu mapsetu pro ostatní u¾ivatele v systému."
+msgstr ""
#: ../general/g.access/main.c:46
msgid "Access for group"
-msgstr "Pøístup pro skupinu"
+msgstr ""
#: ../general/g.access/main.c:53
msgid "Access for others"
-msgstr "Pøístup pro ostatní"
+msgstr ""
#: ../general/g.access/main.c:59
msgid "UNIX filesystem access controls are not supported by MS-Windows"
@@ -12746,11 +12751,12 @@
#: ../general/g.access/main.c:67
msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr "Pøístup pro mapset PERMANENT musí být otevøený, nic nemìním."
+msgstr ""
#: ../general/g.access/main.c:71
+#, fuzzy
msgid "Unable to determine mapset permissions"
-msgstr "Nelze zjistit práva k mapsetu"
+msgstr "Nelze zjistit typ rastrové (cell) mapy."
#: ../general/g.access/set_perms.c:26
#, fuzzy
@@ -12800,38 +12806,41 @@
msgstr ""
#: ../general/g.proj/input.c:91
+#, fuzzy
msgid "Error reading WKT projection description"
-msgstr "Chyba pøi ètení popisu projekce ve formátu WKT"
+msgstr "Chyba pøi ètení velikosti horizontálního kroku"
#: ../general/g.proj/input.c:98
-#, c-format
+#, fuzzy, c-format
msgid "Unable to open file [%s] for reading"
-msgstr "Nejsem schopen otevøít soubor [%s] pro ètení"
+msgstr "Nelze otevøít soubor <%s> pro psaní"
#: ../general/g.proj/input.c:143
msgid "Can't parse PROJ.4-style parameter string"
-msgstr "Nelze parsovat PROJ.4 styl parametrù"
+msgstr ""
#: ../general/g.proj/input.c:181
+#, fuzzy
msgid "Unable to translate EPSG code"
-msgstr "Nelze pøelo¾it EPSG kód"
+msgstr "Nelze dostat jedno z rastrových pásem"
#: ../general/g.proj/input.c:218
msgid "Trying to open with OGR..."
-msgstr "Zkou¹ím otevøít pomocí OGR..."
+msgstr ""
#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
+#, fuzzy
msgid "...succeeded."
-msgstr "...uspìl."
+msgstr "úspìch"
#: ../general/g.proj/input.c:239
msgid "Trying to open with GDAL..."
-msgstr "Zkou¹ím otevøít GDALem..."
+msgstr ""
#: ../general/g.proj/input.c:254
#, c-format
msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr "Nelze èíst georeferencovaný soubor %s a» u¾ zkou¹ím GDAL nebo OGR"
+msgstr ""
#: ../general/g.proj/input.c:259
#, c-format
@@ -12839,23 +12848,16 @@
"Read of file %s was successful, but it did not contain projection "
"information. 'XY (unprojected)' will be used"
msgstr ""
-"Ètení souboru %s bylo íºspì¹né. ale tento neobsahuje informace o projekci. "
-"Pou¾iji 'XY (unprojected)'"
#: ../general/g.proj/main.c:64
-#, fuzzy
msgid ""
"Converts co-ordinate system descriptions (i.e. projection information) "
"between various formats (including GRASS format)."
msgstr ""
-"Pøevede popisy souøadných systémù (napø. informace o projekci) mezi rùzné "
-"formáty (vèetnì formátù GRASSu). Lze pou¾ít také pro vytvoøení GRASS "
-"location."
#: ../general/g.proj/main.c:67
-#, fuzzy
msgid "Can also be used to create GRASS locations."
-msgstr "Nelze vytvoøit location: %s"
+msgstr ""
#: ../general/g.proj/main.c:70
#, fuzzy
@@ -12863,48 +12865,57 @@
#: ../general/g.proj/main.c:77
+#, fuzzy
msgid "Print projection information (in conventional GRASS format)"
-msgstr "Vypí¹e informace o projekci (v konvenèním formátu GRASSu)"
+msgstr ""
+"Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro "
+"kontrolu)"
#: ../general/g.proj/main.c:83
+#, fuzzy
msgid "Verify datum information and print transformation parameters"
-msgstr "Ovìø informace o datumu a vypi¹ transformaèní parametry"
+msgstr "Název sloupce obsahujícího hodnoty parametru vyhlazení"
#: ../general/g.proj/main.c:89
+#, fuzzy
msgid "Print projection information in PROJ.4 format"
-msgstr "Vytiskni informace o projekci ve formátu pro PROJ.4"
+msgstr "Vytiskni pouze informace o topologii"
#: ../general/g.proj/main.c:95
msgid ""
"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr ""
-"Vypi¹ 'flat' výstup bez øádkových zlom (pou¾ito pro výstup WKT a PROJ.4)"
#: ../general/g.proj/main.c:105
+#, fuzzy
msgid "Print projection information in WKT format"
-msgstr "Vypi¹ informace o projekci ve formátu WKT"
#: ../general/g.proj/main.c:111
+#, fuzzy
msgid "Use ESRI-style format (applies to WKT output only)"
-msgstr "Pou¾ít styl ESRI formátu (aplikováno pouze na výstup WKT)"
+msgstr ""
+"Pou¾ít styl ESRI - formát souboru .prj (aplikované pouze na výstup SHAPE)"
#: ../general/g.proj/main.c:119
+#, fuzzy
msgid "Georeferenced data file to read projection information from"
-msgstr "Georeferencovaný soubor, ze které se mají pøeèíst informace o projekci"
+msgstr ""
+"Název location, ze které bude naètena mapová projekce pro GCP transformaci"
#: ../general/g.proj/main.c:128
+#, fuzzy
msgid "ASCII file containing a WKT projection description (- for stdin)"
-msgstr ""
-"Soubor ASCII obsahující samostatný popis projekce ve formátu WTK (- pro "
-"standardní vstup)"
+msgstr "ASCII soubor obsahující vstupní data (\"-\" pro standardní vstup)"
#: ../general/g.proj/main.c:137
msgid "PROJ.4 projection description (- for stdin)"
-msgstr "Popis projekce ve stylu PROJ.4 (- pro standardní vstup)"
+msgstr ""
#: ../general/g.proj/main.c:145
+#, fuzzy
msgid "EPSG projection code"
-msgstr "EPSG kód projekce"
+msgstr "Zóna projekce vektorové mapy"
#: ../general/g.proj/main.c:154 ../general/g.proj/main.c:160
msgid "Datum"
@@ -12914,23 +12925,18 @@
#, fuzzy
msgid "Index number of datum transform parameters"
msgstr ""
-"Èíslo indexu parametrù transformace datumu, \"0\" pro nespecifikováno nebo "
-"\"-1\" pro výpis a ukonèení"
+"Není definována ¾ádné èíslo kategorie. pou¾ívám pøednastavené parametry "
+"transformace."
#: ../general/g.proj/main.c:156
-#, fuzzy
msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
#: ../general/g.proj/main.c:162
msgid ""
"Force override of datum transformation information in input co-ordinate "
"system"
msgstr ""
-"Vynutit pøepsání informace o datumu transformace ve vstupním souøadém "
-"systému "
#: ../general/g.proj/main.c:167 ../general/g.proj/main.c:176
#, fuzzy
@@ -12938,25 +12944,28 @@
msgstr "Vytvoøení"
#: ../general/g.proj/main.c:168
+#, fuzzy
msgid ""
"Create new projection files (modifies current location unless 'location' "
"option specified)"
msgstr ""
-"Vytvoø nové soubory s projekcí (zmìní aktuální location, pokud není zadána "
-"volba 'location')"
+"Nelze získat informaci o mapové projekci aktuální location: prosím, nastavte "
+"¹íøkupomocí volby 'lat' nebo 'latin'!"
#: ../general/g.proj/main.c:177
+#, fuzzy
msgid "Name of new location to create"
msgstr "Název nové location, která má být vytvoøena"
#: ../general/g.proj/main.c:193
-#, c-format
+#, fuzzy, c-format
msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr "Pouze jedna volba z '%s', '%s', '%s' nebo '%s' mù¾e být zadána"
+msgstr "Jeden z parametrù [%s] nebo [%s] musí být pou¾it"
#: ../general/g.proj/main.c:222
+#, fuzzy
msgid "Projection files missing"
-msgstr "Soubory s projekcí chybí"
+msgstr "volba 'souøadnice' chybí"
#: ../general/g.proj/main.c:237
#, fuzzy, c-format
@@ -12968,28 +12977,28 @@
msgstr ""
#: ../general/g.proj/output.c:150
-#, c-format
+#, fuzzy, c-format
msgid "%s: Unable to convert to WKT"
-msgstr "%s: Neschopen pøevést WKT"
+msgstr "Nelze vlo¾it nový øádek: %s"
#: ../general/g.proj/output.c:163
-#, c-format
+#, fuzzy, c-format
msgid "Location %s created!"
-msgstr "Location %s vytvoøena!"
+msgstr "Location <%s> vytvoøena"
#: ../general/g.proj/output.c:165
-#, c-format
+#, fuzzy, c-format
msgid "Unable to create location: %s"
+msgstr "Neschopen vytvoøit tabulku: %s"
#: ../general/g.proj/output.c:168
-#, c-format
+#, fuzzy, c-format
msgid "Unable to create projection files: %s"
-msgstr "Nelze vytvoøit soubor s informacemi o mapové projekci: %s"
+msgstr "Nelze vyvoøit soubor pro závìreènou zprávu <%s>"
#: ../general/g.proj/output.c:172
msgid "Unspecified error while creating new location"
-msgstr "Nejasná chyba pøi vytváøení nové location"
+msgstr ""
#: ../general/g.proj/output.c:183
#, c-format
@@ -12997,8 +13006,6 @@
"You must select the PERMANENT mapset before updating the current location's "
"projection. (Current mapset is %s)"
msgstr ""
-"Musíte vybrat mapset PERMANENT, døíve ne¾ aktualizujete projekci aktuální "
-"location (Aktuální mapset je %s)"
#: ../general/g.proj/output.c:215
msgid ""
@@ -13006,94 +13013,102 @@
"multiple mapsets g.region -d should be run in each to update the region from "
"the default."
msgstr ""
-"Pozn. Pøednastavený region byl aktualizován pro novou projekci, ale jestli "
-"máte více mapsetù g.region -d by jste mìli spustit v ka¾dém z nich pro "
-"aktualizaci."
#: ../general/g.proj/output.c:219
msgid "Projection information updated!"
-msgstr "Informace o projekci aktualizovány!"
+msgstr ""
#: ../general/g.dirseps/main.c:36
msgid "Internal GRASS utility for converting directory separator characters."
-msgstr "Vnitøní nástroj GRASSu pro zmìnu oddìlovaèe adresáøù."
+msgstr ""
#: ../general/g.pnmcomp/main.c:37 ../general/g.cairocomp/main.c:147
-#, c-format
+#, fuzzy, c-format
msgid "Invalid color: %s"
-msgstr "Chybná barva :%s"
+msgstr "Neplatná metoda: %s"
#: ../general/g.pnmcomp/main.c:53 ../general/g.pnmcat/main.c:30
+#, fuzzy
msgid "Error reading PPM file"
-msgstr "Chyba pøi ètení souboru PPM"
+msgstr "Chyba pøi ètení doèasného souboru"
#: ../general/g.pnmcomp/main.c:68 ../general/g.pnmcomp/main.c:73
#: ../general/g.pnmcomp/main.c:82 ../general/g.pnmcomp/main.c:133
#: ../general/g.pnmcomp/main.c:146 ../general/g.pnmcat/main.c:46
#: ../general/g.pnmcat/main.c:54 ../general/g.pnmcat/main.c:59
+#, fuzzy
msgid "Invalid PPM file"
-msgstr "©patný soubor PPM"
+msgstr "©patná hùavièka BMP souboru"
#: ../general/g.pnmcomp/main.c:95 ../general/g.pnmcat/main.c:83
-#, c-format
+#, fuzzy, c-format
msgid "File <%s> not found"
-msgstr "Soubor <%s> nebyl nalezen"
+msgstr "GRASS site soubor <%s> nebyl nalezen"
#: ../general/g.pnmcomp/main.c:103
msgid "Expecting PPM but got PGM"
-msgstr "Oèekávám PPM ale dostal jsem PGM"
+msgstr ""
#: ../general/g.pnmcomp/main.c:108
msgid "Expecting PGM but got PPM"
-msgstr "Oèekávám PGM ale dostal jsem PPM"
+msgstr ""
#: ../general/g.pnmcomp/main.c:111
-#, c-format
+#, fuzzy, c-format
msgid "Invalid magic number: 'P%c'"
-msgstr "Chybné magické èíslo: 'P%c'"
+msgstr "Chybný mapový modifikátor: '%c'"
#: ../general/g.pnmcomp/main.c:124 ../general/g.pnmcomp/main.c:141
+#, fuzzy
msgid "Invalid PGM file"
-msgstr "Chybný soubor PGM"
#: ../general/g.pnmcomp/main.c:246
+#, fuzzy
msgid "Error writing PPM file"
-msgstr "Chyba pøi zápisu souboru PPM"
+msgstr "Chyba pøi zápisu souboru se segmenty"
#: ../general/g.pnmcomp/main.c:263
+#, fuzzy
msgid "Error writing PGM file"
-msgstr "Chyba pøi zápisu souboru PGM"
#: ../general/g.pnmcomp/main.c:289 ../general/g.cairocomp/main.c:201
+#, fuzzy
msgid "Names of input files"
-msgstr "Jména vstupních souborù"
+msgstr "Jméno vstupního DXF souboru"
#: ../general/g.pnmcomp/main.c:296
+#, fuzzy
msgid "Names of mask files"
-msgstr "Jména souborù s maskou"
+msgstr "Jméno souboru s barvou"
#: ../general/g.pnmcomp/main.c:303 ../general/g.cairocomp/main.c:227
msgid "Layer opacities"
-msgstr "Prùhlednost vrstev"
+msgstr ""
#: ../general/g.pnmcomp/main.c:309 ../general/g.pnmcat/main.c:134
#: ../general/g.ppmtopng/main.c:132 ../general/g.cairocomp/main.c:208
+#, fuzzy
msgid "Name of output file"
-msgstr "Jméno výstpuního souboru"
+msgstr "Název výstupního souboru"
#: ../general/g.pnmcomp/main.c:316
+#, fuzzy
msgid "Name of output mask file"
-msgstr "Jméno výstupního souboru s maskou"
#: ../general/g.pnmcomp/main.c:323 ../general/g.pnmcat/main.c:153
#: ../general/g.cairocomp/main.c:233
+#, fuzzy
msgid "Image width"
-msgstr "©íøka obrázku"
+msgstr "Neplatná ¹íøka stránky"
#: ../general/g.pnmcomp/main.c:329 ../general/g.pnmcat/main.c:159
#: ../general/g.cairocomp/main.c:239
+#, fuzzy
msgid "Image height"
-msgstr "Vý¹ka obrázku"
+msgstr "Soubory obrazové skupiny"
#: ../general/g.pnmcomp/main.c:334 ../general/g.cairocomp/main.c:244
#: ../display/d.path/main.c:115 ../vector/v.label.sa/main.c:124
@@ -13107,15 +13122,13 @@
msgstr "PostScript"
#: ../general/g.message/main.c:36
-#, fuzzy
msgid ""
"Prints a message, warning, progress info, or fatal error in the GRASS way."
-msgstr "Vytiskni zprávu, varování nebo fatální chybu GRASSovským zpùsobem"
+msgstr ""
#: ../general/g.message/main.c:38
msgid "This module should be used in scripts for messages served to user."
msgstr ""
-"Tento modul by mìl být pou¾it ve skriptech pro zprávy slou¾ící u¾ivateli."
#: ../general/g.message/main.c:42 ../general/g.message/main.c:47
#: ../general/g.message/main.c:52 ../general/g.message/main.c:57
@@ -13124,24 +13137,20 @@
msgstr "Typ: %s"
#: ../general/g.message/main.c:43
-#, fuzzy
msgid "Print message as warning"
-msgstr "Vytiskni zprávu jako GRASS varování"
+msgstr ""
#: ../general/g.message/main.c:48
-#, fuzzy
msgid "Print message as fatal error"
-msgstr "Vytiskni zprávu jako GRASS fatální chyba"
+msgstr ""
#: ../general/g.message/main.c:53
-#, fuzzy
msgid "Print message as debug message"
-msgstr "Vytiskni zprávu jako GRASS ladící zpráva"
+msgstr ""
#: ../general/g.message/main.c:58
-#, fuzzy
msgid "Print message as progress info"
+msgstr ""
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
@@ -13151,30 +13160,28 @@
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
-msgstr "Vytiskni zprávu ve ve¹ech módech, kromì tichého"
+msgstr ""
#: ../general/g.message/main.c:68
-#, fuzzy
msgid "Print message only in verbose mode"
-msgstr "Vytiskni zprávu jenom v mluvícím módu"
+msgstr ""
#: ../general/g.message/main.c:75
msgid "Text of the message to be printed"
-msgstr "Text zprávy který bude vytisknut"
+msgstr ""
#: ../general/g.message/main.c:84
msgid "Level to use for debug messages"
-msgstr "Úroveò pro ladící zprávy"
+msgstr ""
#: ../general/g.message/main.c:92
-#, fuzzy
msgid "Select only one message level"
-msgstr "Vyberte pouze jednu úroveò zpráv."
+msgstr ""
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "Nelze otevøít vstupní soubor <%s>"
+msgstr "Nelze zavøít vstupní mapu"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -13220,18 +13227,21 @@
msgstr "Monitor: waitpid: oèekával jsem %d, ale dostal jsem %d"
#: ../general/g.setproj/main.c:81
+#, fuzzy
msgid "Interactively reset the location's projection settings."
-msgstr "Interaktivnì znovunastavit vlastnosti projekce location"
+msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
#: ../general/g.setproj/main.c:88
msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr "Musíte být v mapsetu PERMANENT pro spu¹tìní g.setproj"
+msgstr ""
#: ../general/g.setproj/main.c:101
+#, fuzzy
msgid "PERMANENT: permission denied"
-msgstr "PERMANENT: Pøístup odepøen"
+msgstr "Pøístup odepøen"
#: ../general/g.setproj/main.c:105
+#, fuzzy
msgid "Current region cannot be set"
msgstr "Nelze nastavit aktuální region."
@@ -13241,11 +13251,12 @@
#: ../general/g.setproj/main.c:135
msgid "Would you still like to change some of the parameters?"
-msgstr "Poøád je¹tì chcete zmìnit nìkteré parametry?"
+msgstr ""
#: ../general/g.setproj/main.c:137
+#, fuzzy
msgid "The projection information will not be updated"
-msgstr "Informace o projekci nebudou aktualizovány"
+msgstr "Pøedpona vstupní mapy s informacemi o horizontu"
#: ../general/g.setproj/main.c:148
#, c-format
@@ -13253,81 +13264,86 @@
"Zone in default geographic region definition: %d\n"
" is different from zone in PROJ_INFO file: %d"
msgstr ""
-"Zóna v základní definici geografického regionu: %d\n"
-"se li¹í od zóny v souboru PROJ_INFO: %d"
#: ../general/g.setproj/main.c:158
msgid "XY-location cannot be projected"
-msgstr "XY-location nemù¾e být promístnuta"
+msgstr ""
#: ../general/g.setproj/main.c:192
+#, fuzzy
msgid "Unknown projection"
-msgstr "Neznámá projekce"
+msgstr "Neznámá operace"
#: ../general/g.setproj/main.c:198
#, c-format
msgid "Projection %s is not specified in the file 'proj-parms.table'"
-msgstr "Projekce %s není specifikována v souboru 'proj-parms.table'"
+msgstr ""
#: ../general/g.setproj/main.c:205
+#, fuzzy
msgid "Do you wish to specify a geodetic datum for this location?"
-msgstr "Pøejete si zadat geodetické datum pro tuto location?"
+msgstr "Musíte zadat cílovou location rùznou od souèasné"
#: ../general/g.setproj/main.c:214
#, c-format
msgid "The current datum is %s (%s)"
-msgstr "Souèasné datum je %s (%s)"
+msgstr ""
#: ../general/g.setproj/main.c:217
+#, fuzzy
msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr "Pøejete si zmìnit datum ( nebo parametry transformace datumu)?"
+msgstr "Název sloupce atributu, pou¾itého jako parametr transformace"
#: ../general/g.setproj/main.c:225
+#, fuzzy
msgid "The datum information has not been changed"
-msgstr "Informace o datumu se nezmìnily"
+msgstr "Informace v hlavièce by také mìly být upraveny."
#: ../general/g.setproj/main.c:288
#, c-format
msgid "The current ellipsoid is %s"
-msgstr "Souèasný elipsoid je %s"
+msgstr ""
#: ../general/g.setproj/main.c:290
msgid "Do you want to change ellipsoid parameter?"
-msgstr "Pøejete si zmìnit parametry elipsoidu?"
+msgstr ""
#: ../general/g.setproj/main.c:294
+#, fuzzy
msgid "The ellipse information has not been changed"
-msgstr "Informace o elipsoidu se nezmìily"
#: ../general/g.setproj/main.c:311
#, c-format
msgid "The radius is currently %f"
-msgstr "Souèasný polomìr je %f"
+msgstr ""
#: ../general/g.setproj/main.c:312
msgid "Do you want to change the radius?"
-msgstr "Oøejete si zmìnit polomìr?"
+msgstr ""
#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
+#, fuzzy
msgid "Enter radius for the sphere in meters"
-msgstr "Vlo¾te polomìr pro kouli v metrech"
+msgstr "Minimální polomìr pro mapu kruhu (v metrech)"
#: ../general/g.setproj/main.c:336
msgid "Invalid input ellipsoid"
-msgstr "Neplatný vstuní elipsoid"
+msgstr ""
#: ../general/g.setproj/main.c:447
-#, c-format
+#, fuzzy, c-format
msgid "The UTM zone is now set to %d"
-msgstr "UTM zóna je nyní nastavena na %d"
+msgstr " poèátek nastaven na %d"
#: ../general/g.setproj/main.c:450
msgid "Do you want to change the UTM zone?"
-msgstr "Pøejete si zmìnit UTM zónu?"
+msgstr ""
#: ../general/g.setproj/main.c:451
+#, fuzzy
msgid "UTM zone information has not been updated"
-msgstr "Informace o UTM zónì nebyly aktualizovány."
#: ../general/g.setproj/main.c:456
msgid ""
@@ -13335,42 +13351,43 @@
"projection software. GRASS will not automatically re-project or even change "
"the headers for existing maps."
msgstr ""
-"Ale jestli¾e zmìníte zónu, v¹echna existující data budou pøekládána "
-"projekèním softwarem. GRASS neumí automaticky znìnit projekci nebo dokonce "
-"zmìnit hlavièky existujících map."
#: ../general/g.setproj/main.c:461
+#, fuzzy
msgid "Would you still like to change the UTM zone?"
-msgstr "Poøád je¹tì si pøejete zmìnit UTM zónu?"
+msgstr ""
+"\n"
+"Data si pøejete uspoøádat: "
#: ../general/g.setproj/main.c:497
-#, c-format
+#, fuzzy, c-format
msgid "Error writing PROJ_INFO file <%s>"
-msgstr "Chyba pøi zápisu PROJ_INFO <%s>"
+msgstr "Chyba pøi zápisu souboru color pro <%s>"
#: ../general/g.setproj/main.c:571
#, c-format
msgid "Enter plural form of units [meters]: "
-msgstr "Vlo¾te mno¾né èíslo jednotek[metry]:"
+msgstr ""
#: ../general/g.setproj/main.c:603
#, c-format
msgid "Enter singular for unit: "
-msgstr "Vlo¾te jednotné èíslo jednotky:"
+msgstr ""
#: ../general/g.setproj/main.c:611
-#, c-format
+#, fuzzy, c-format
msgid "Enter conversion factor from %s to meters: "
-msgstr "Pøevodní faktor z %s na metry:"
+msgstr "Pou¾ívám konverzní faktor %f, krok=%f"
#: ../general/g.setproj/main.c:636
-#, c-format
+#, fuzzy, c-format
msgid "Error writing into UNITS output file <%s>"
-msgstr "Chyba pøi zápisu do výstupního souboru JEDNOTEK: %s"
#: ../general/g.setproj/main.c:643
+#, fuzzy
msgid "Unable to write to DEFAULT_WIND region file"
-msgstr "Nelze zapsat do souboru regionu DEFAULT_WIND"
+msgstr "Nelze zapisovat do rastrového souboru GDAL"
#: ../general/g.setproj/main.c:645
#, c-format
@@ -13379,27 +13396,23 @@
"Projection information has been recorded for this location\n"
"\n"
msgstr ""
-"\n"
-"Informace o projekci pro tuto location byly ulo¾eny\n"
-"\n"
#: ../general/g.setproj/main.c:647
msgid "The geographic region information in WIND is now obsolete"
-msgstr "Informace o geografickém regionu v souboru WIND jsou zastaralé."
+msgstr ""
#: ../general/g.setproj/main.c:648
msgid "Run g.region -d to update it"
-msgstr "Spus»te g.region -d pro aktualizaci"
+msgstr ""
#: ../general/g.setproj/get_stp.c:43
msgid "This should not happen see your system admin"
msgstr ""
-"Toto se nemìlo stát, nav¹tivte prosím va¹eho systémovho administrátora..."
#: ../general/g.setproj/get_stp.c:99
#, fuzzy
msgid "Unable to open FIPS code file"
-msgstr "Nelze otevøít soubor obrazové skupiny"
+msgstr "Nelze otevøít pøechodný soubor."
#: ../general/g.setproj/get_stp.c:125
#, c-format
@@ -13409,12 +13422,12 @@
#: ../general/g.setproj/get_stp.c:179
#, fuzzy
msgid "Reading sf key_value temp file"
-msgstr "Vytváøím nìjaké doèasné soubory"
+msgstr "Naèítám soubor dig_att..."
#: ../general/g.setproj/get_stp.c:212
#, fuzzy
msgid "Invalid State FIPS code"
-msgstr "Chybná vzdálenost"
+msgstr "Chybný typ: %d"
#: ../general/g.setproj/get_stp.c:302
#, fuzzy
@@ -13424,17 +13437,17 @@
#: ../general/g.setproj/get_stp.c:336
#, fuzzy
msgid "Invalid County FIPS code"
-msgstr "Chybné písmo: %s"
#: ../general/g.setproj/proj.c:168
#, c-format
msgid "Unrecognized 'ask' value in proj-parms.table: %s"
-msgstr "Nerozpoznaná hodnota 'ask' v proj-parms.table: %s"
+msgstr ""
#: ../general/g.setproj/proj.c:178
#, c-format
msgid "Unrecognized default value in proj-parms.table: %s"
-msgstr "Nerozpoznaná zíkladní tabulka v proj_parms.tabla: %s"
+msgstr ""
#: ../general/g.list/main.c:46 ../general/g.copy/main.c:41
#: ../general/g.mremove/main.c:60 ../general/g.rename/main.c:44
@@ -13461,12 +13474,14 @@
#: ../general/g.list/main.c:82 ../general/g.mlist/main.c:146
msgid "Verbose listing (also list map titles)"
-msgstr "upovídaný výstup (vypi¹ také titulky map)"
+msgstr ""
#: ../general/g.transform/main.c:97
-#, c-format
+#, fuzzy, c-format
msgid "Not enough points, %d are required"
-msgstr "Nedostatek bodù, je po¾adováno %d"
+msgstr ""
+"Nedostatek aktivnich kontrolních bodù pro zadaný øád rektifikace, je "
+"po¾adováno %d."
#: ../general/g.transform/main.c:101
#, fuzzy, c-format
@@ -13474,20 +13489,23 @@
msgstr "Chyba pøi pøevodu"
#: ../general/g.transform/main.c:199
+#, fuzzy
msgid "Poorly placed control points"
-msgstr "Mizernì umístìné kontrolní body"
+msgstr "Slabì umístìné kontrolní body."
#: ../general/g.transform/main.c:201
msgid "Insufficient memory"
-msgstr "Nedostatek pamìti"
+msgstr ""
#: ../general/g.transform/main.c:203
+#, fuzzy
msgid "Parameter error"
-msgstr "Chyba prametru"
+msgstr "Parametry"
#: ../general/g.transform/main.c:205
+#, fuzzy
msgid "No active control points"
-msgstr "®ádné aktivní kontrolní body"
+msgstr "®ádné aktivní pseudo kontrolní body"
#: ../general/g.transform/main.c:300
#, fuzzy, c-format
@@ -13504,12 +13522,16 @@
msgstr ""
#: ../general/g.transform/main.c:324
+#, fuzzy
msgid "Computes a coordinate transformation based on the control points."
-msgstr "Souøadná transformace na základì vlícovacích bodù"
+msgstr ""
+"Rektifikuje obrazová data na základì vlícovacích bodù pomocí souøadnicové "
+"transformace pro ka¾dý pixel obrazu."
#: ../general/g.transform/main.c:333
+#, fuzzy
msgid "Rectification polynomial order"
-msgstr "Stupeò polynomu rektifikace"
+msgstr "Stupeò polynomu rektifikace (1-3)"
#: ../general/g.transform/main.c:341
msgid ""
@@ -13525,7 +13547,7 @@
#: ../general/g.transform/main.c:355
msgid "Display summary information"
-msgstr "Zobrazit souhrnnou informaci"
+msgstr ""
#: ../general/g.transform/main.c:361
#, fuzzy
@@ -13558,8 +13580,9 @@
msgstr "Nastavení"
#: ../general/g.mapset/main.c:47
+#, fuzzy
msgid "Change current mapset."
-msgstr "Zmìnit souèasný mapset"
+msgstr "Název cílového mapsetu"
#: ../general/g.mapset/main.c:48
msgid "Optionally create new mapset or list available mapsets."
@@ -13582,8 +13605,9 @@
msgstr "nová GISDBASE (celá cesta k adre¹áøi, kde je ulo¾ena nová location)"
#: ../general/g.mapset/main.c:80
+#, fuzzy
msgid "Create mapset if it doesn't exist"
-msgstr "Vytvoøí nový mapset, pokud neexistuje."
+msgstr "Vytvoøí nový soubor, pokud neexistuje."
#: ../general/g.mapset/main.c:82
#: ../locale/scriptstrings/r.mask_to_translate.c:5
@@ -13594,29 +13618,35 @@
msgstr "Vytvoøení"
#: ../general/g.mapset/main.c:86
+#, fuzzy
msgid "List available mapsets"
-msgstr "Vypi¹ v¹echny dostupné mapsety"
+msgstr "Vypi¹ pøítomné vrstvy a ukonèi se"
#: ../general/g.mapset/main.c:93
+#, fuzzy
msgid "Either mapset= or -l must be used"
-msgstr "Buï mapset= nebo -l musí být zadáno"
+msgstr "Buï 'pravidlo' nebo 'sloupec' musí být zadán"
#: ../general/g.mapset/main.c:138
-#, c-format
+#, fuzzy, c-format
msgid "<%s> is already the current mapset"
-msgstr "<%s> ji¾ existuje v souèasném mapsetu "
+msgstr "Skupina musí existovat v souèasném mapsetu"
#: ../general/g.mapset/main.c:146
msgid "You don't have permission to use this mapset"
-msgstr "Nemáte povolení pou¾ívat tento mapset."
+msgstr ""
#: ../general/g.mapset/main.c:155
+#, fuzzy
msgid "The mapset does not exist. Use -c flag to create it."
-msgstr "Mapset neexistuje. Pøidejte pøepínaè -c pro vytvoøení nového mapsetu."
+msgstr ""
+"Mapa <%s> neexistuje v souèasném mapsetu. Pøidejte pøepínaè -n pro vytvoøení "
+"nové mapy."
#: ../general/g.mapset/main.c:164
+#, fuzzy
msgid "Unable to read GIS_LOCK environment variable"
-msgstr "Nelze èíst promìnnou prostøedí GIS_LOCK"
+msgstr "Nelze èíst soubor s rozsahem"
#: ../general/g.mapset/main.c:178
#, c-format
@@ -13624,16 +13654,15 @@
"%s is currently running GRASS in selected mapset or lock file cannot be "
"checked"
msgstr ""
-"%s právì pou¾ívá GRASS s daným mapsetem nebo uzamykací soubor nelze "
-"zkontrolovat."
#: ../general/g.mapset/main.c:183
+#, fuzzy
msgid "Cleaning up temporary files..."
-msgstr "Ma¾u doèasné soubory..."
+msgstr "Vytváøím nìjaké doèasné soubory..."
#: ../general/g.mapset/main.c:197
msgid "Your shell continues to use the history for the old mapset"
-msgstr "Vá¹ shell pokraèuje v pou¾ívání historie pro starý mapset."
+msgstr ""
#: ../general/g.mapset/main.c:201
#, c-format
@@ -13641,8 +13670,6 @@
"You can switch the history by commands:\n"
"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
msgstr ""
-"Mù¾ete zmìnit historii pøíkazy:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
#: ../general/g.mapset/main.c:206
#, c-format
@@ -13650,24 +13677,22 @@
"history -S; history -L %s/.history; setenv histfile=%s/.history"
msgstr ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
#: ../general/g.mapsets/main.c:62
msgid ""
"Modifies the user's current mapset search path, affecting the user's access "
"to data existing under the other GRASS mapsets in the current location."
msgstr ""
-"Mìní nastavení aktuálního mapsetu, mìní pøístup k datùm umístìnýchv jiných "
-"mapsetech GRASSu v aktuální location."
#: ../general/g.mapsets/main.c:71
+#, fuzzy
msgid "Name(s) of existing mapset(s)"
-msgstr "Jméno(a) existující(ch) mapset(ù)"
+msgstr "Jméno existující(ch) rastrové(ých) map(y)"
#: ../general/g.mapsets/main.c:79
+#, fuzzy
msgid "Name(s) of existing mapset(s) to add to search list"
-msgstr "Název existující(ch) rastrové(ých) map(y) pro dotazování."
+msgstr "Název existující(ch) rastrové(ých) map(y) pro dotazování barev."
#: ../general/g.mapsets/main.c:87
#, fuzzy
@@ -13675,40 +13700,41 @@
#: ../general/g.mapsets/main.c:94
+#, fuzzy
msgid "List all available mapsets"
#: ../general/g.mapsets/main.c:98
msgid "Print current mapset search path"
-msgstr "Vypi¹ aktuální cestu k mapsetùm"
+msgstr ""
#: ../general/g.mapsets/main.c:102
msgid "Show mapset selection dialog"
-msgstr "Zobrazit dialog k výbìru mapsetu"
+msgstr ""
#: ../general/g.mapsets/main.c:127 ../general/g.mapsets/main.c:156
-#, c-format
+#, fuzzy, c-format
msgid "Mapset <%s> not found"
-msgstr "Mapset <%s> nebyl nalezen"
+msgstr "%s mapa <%s> nebyla nalezena"
#: ../general/g.mapsets/main.c:158
#, c-format
msgid "Mapset <%s> added to search path"
-msgstr "Mapset <%s> pøidán do cesty vyhledávání"
+msgstr ""
#: ../general/g.mapsets/main.c:184
#, c-format
msgid "Mapset <%s> removed from search path"
-msgstr "Mapset <%s> odstranìn z cesty vyhledávání"
+msgstr ""
#: ../general/g.mapsets/main.c:217
msgid "Cannot open SEARCH_PATH for write"
-msgstr "Nelze otevøít SEARCH_PATH pro zápis"
+msgstr ""
#: ../general/g.mapsets/list.c:10
#, fuzzy
msgid "Available mapsets:"
+msgstr "Pou¾itelné OGR ovladaèe:"
#: ../general/g.mapsets/list.c:35
#, fuzzy
@@ -13721,63 +13747,63 @@
"location to the appropriate element directories under the user's current "
"mapset."
msgstr ""
-"Kopíruje dostupná data z u¾ivatelem zadaného mapsetu a location do "
-"aktuálního mapsetu."
#: ../general/g.copy/main.c:60
-#, c-format
+#, fuzzy, c-format
msgid "%s file(s) to be copied"
-msgstr "%s soubor(y) ke kopírování"
+msgstr "Název rastrového souboru, který má být spojen"
#: ../general/g.copy/main.c:76
-#, c-format
+#, fuzzy, c-format
msgid "<%s> not found"
-msgstr "<%s> nenalezen"
+msgstr "[%s] nenalezen"
#: ../general/g.copy/main.c:81
#, c-format
msgid "%s=%s,%s: files are the same, no copy required"
-msgstr "%s=%s,%s: soubory jsou stejné, není tøeba kopírovat"
+msgstr ""
#: ../general/g.copy/main.c:86
-#, c-format
+#, fuzzy, c-format
msgid "<%s> already exists"
-msgstr "<%s> ji¾ existuje"
+msgstr "Rastrová vrstva <%s> ji¾ existuje."
#: ../general/g.mremove/main.c:62 ../general/g.remove/main.c:104
msgid "Removes data base element files from the user's current mapset."
-msgstr "Ma¾e datové soubory z aktuálního mapsetu"
+msgstr ""
#: ../general/g.mremove/main.c:68 ../general/g.mlist/main.c:125
msgid "Use basic regular expressions instead of wildcards"
-msgstr "Pou¾ijte základní regulární výrazy místo zástupných znakù"
+msgstr ""
#: ../general/g.mremove/main.c:73 ../general/g.mlist/main.c:130
msgid "Use extended regular expressions instead of wildcards"
-msgstr "Pou¾ij regulární výrazy místo zástupných znakù"
+msgstr ""
#: ../general/g.mremove/main.c:78
#: ../locale/scriptstrings/db.droptable_to_translate.c:4
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
msgid "Force removal (required for actual deletion of files)"
-msgstr "Vynutit odstranìní ( po¾adováno pro souèasné mazání souborù)"
+msgstr ""
#: ../general/g.mremove/main.c:82
+#, fuzzy
msgid "Remove base maps"
-msgstr "Odstranìní základní mapy"
+msgstr "Mazání pøívìskù"
#: ../general/g.mremove/main.c:98 ../general/g.remove/main.c:123
-#, c-format
+#, fuzzy, c-format
msgid "%s file(s) to be removed"
-msgstr "%s soubor(y) urèené ke smazání"
+msgstr "Název rastrového souboru, který má být importován"
#: ../general/g.mremove/main.c:106 ../general/g.mlist/main.c:154
+#, fuzzy
msgid "-r and -e are mutually exclusive"
-msgstr "-r a -e se navzájem vyluèují"
+msgstr "-g a -a volby se navzájem vyluèují"
#: ../general/g.mremove/main.c:109
msgid "The following files would be deleted:"
-msgstr "Následující soubory budou vymazány:"
+msgstr ""
#: ../general/g.mremove/main.c:133
#, fuzzy, c-format
@@ -13791,19 +13817,19 @@
#: ../general/g.mremove/check_reclass.c:18 ../general/g.remove/main.c:38
#, c-format
msgid "[%s@%s] is a base map for [%s]. Remove forced."
-msgstr "[%s@%s] je základní mapa pro [%s]. Ma¾u násilím."
+msgstr ""
#: ../general/g.mremove/check_reclass.c:22 ../general/g.remove/main.c:41
#, c-format
msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-msgstr "[%s@%s] je základní mapa. Sma¾te reklasifikovanou mapu %s."
+msgstr ""
#: ../general/g.mremove/check_reclass.c:45
#: ../general/g.mremove/check_reclass.c:59 ../general/g.remove/main.c:63
#: ../general/g.remove/main.c:76
#, c-format
msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr "Mazání informace o reklasifikované mapì z [%s@%s] selhalo."
+msgstr ""
#: ../general/g.ppmtopng/main.c:34
#, fuzzy, c-format
@@ -13837,23 +13863,23 @@
#: ../general/g.gisenv/main.c:40
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr "Vypí¹e a modifikuje u¾ivatelské nastavení promìnných GRASSu."
+msgstr ""
#: ../general/g.gisenv/main.c:45
msgid "GRASS variable to get"
-msgstr "Promìnné GRASSu pro získání"
+msgstr ""
#: ../general/g.gisenv/main.c:52
msgid "GRASS variable to set"
-msgstr "Promìnné GRASSu pro nastavení"
+msgstr ""
#: ../general/g.gisenv/main.c:61
msgid "Where GRASS variable is stored"
-msgstr "Kde jsou ulo¾eny promìnné GRASSu"
+msgstr ""
#: ../general/g.gisenv/main.c:66
msgid "Use shell syntax (for \"eval\")"
-msgstr "Pou¾ít syntaxi shellu (pro \"eval\")"
+msgstr ""
#: ../general/g.gisenv/main.c:70
#, fuzzy
@@ -13861,68 +13887,77 @@
msgstr "Nepou¾ívat syntaxi shellu"
#: ../general/g.gisenv/main.c:76
+#, fuzzy
msgid "-s and -n are mutually exclusive"
-msgstr "-s a -n se navzájem vyluèují"
#: ../general/g.rename/main.c:46
msgid "Renames data base element files in the user's current mapset."
-msgstr "Pøejmenuje data v aktuálním mapsetu"
+msgstr ""
#: ../general/g.rename/main.c:61
-#, c-format
+#, fuzzy, c-format
msgid "%s file(s) to be renamed"
-msgstr "%s soubor(y) k pøejmenování"
#: ../general/g.rename/main.c:79
-#, c-format
+#, fuzzy, c-format
msgid "%s <%s> not found"
-msgstr "%s <%s> nebyl nalezen"
#: ../general/g.rename/main.c:83
-#, c-format
+#, fuzzy, c-format
msgid "<%s> already exists in mapset <%s>"
-msgstr "<%s> ji¾ existuje v mapsetu <%s>"
+msgstr ""
+"Rastrová mapa <%s> ji¾ existuje v mapsetu <%s>, zkuste prosím jiné jméno."
#: ../general/g.rename/main.c:93
#, c-format
msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr "%s=%s,%s: soubory jsou stejné a není potøeba je pøejmenovávat"
+msgstr ""
#: ../general/g.rename/main.c:103
+#, fuzzy
msgid "Renaming reclass maps"
-msgstr "Pøejmenování reklasifikované mapy"
+msgstr "Naèítám rastrovou mapu..."
#: ../general/g.filename/main.c:40
+#, fuzzy
msgid "Prints GRASS data base file names."
-msgstr "Vypí¹e jména souborù v GRASS databázi"
+msgstr "Název vstupní databáze"
#: ../general/g.filename/main.c:48 ../general/g.findfile/main.c:48
+#, fuzzy
msgid "Name of an element"
-msgstr "Jméno prvku"
#: ../general/g.filename/main.c:54
+#, fuzzy
msgid "Name of a database file"
-msgstr "Jméno databázového souboru"
+msgstr "Název souboru s filtrem"
#: ../general/g.filename/main.c:60
+#, fuzzy
msgid "Name of a mapset (default: current)"
-msgstr "Jméno mapsetu (výchozí: souèasný)"
+msgstr "Jméno výstupní rastrové mapy (výchozí: jméno vstupní mapy)"
#: ../general/g.mlist/main.c:66
msgid ""
"Lists available GRASS data base files of the user-specified data type to "
"standard output."
msgstr ""
-"Seznam dostupných souborù u¾ivatelem zadaného typu dat na standardní výstup"
#: ../general/g.mlist/main.c:96
+#, fuzzy
msgid "Map name search pattern (default: all)"
-msgstr "Øìtìzec v názvu mapy, musí být 'uvozen' (výchozí: v¹echny)"
+msgstr "Kanál, který má být vybrán (výchozí: v¹echny kanály)"
#: ../general/g.mlist/main.c:103
#, fuzzy
msgid "Map name exclusion pattern (default: none)"
+msgstr ""
+"Naimportuj jako hodnoty s plovoucí desetinnou èárkou (double) (výchozí: "
+"celoèíselné)"
#: ../general/g.mlist/main.c:112
msgid "One-character output separator, newline, comma, space, or tab"
@@ -13930,52 +13965,59 @@
#: ../general/g.mlist/main.c:120
msgid "Mapset to list (default: current search path)"
-msgstr "mapset, ze kterého má být seznam udìlán (výchozí: aktuální)"
+msgstr ""
#: ../general/g.mlist/main.c:134
+#, fuzzy
msgid "Print data types"
-msgstr "Vypsat typy dat"
+msgstr "Vytiskni pouze typ rastrové mapy"
#: ../general/g.mlist/main.c:138
+#, fuzzy
msgid "Print mapset names"
-msgstr "Vytisknout jméno mapsetu"
+msgstr "Vytiskni pouze titulek rastrové mapy"
#: ../general/g.mlist/main.c:142
+#, fuzzy
msgid "Pretty printing in human readable format"
-msgstr "Hezký výstup ètivý i pro èlovìka"
+msgstr "Potlaè výpis informací z hlavièky"
#: ../general/g.region/main.c:64
+#, fuzzy
msgid "Manages the boundary definitions for the geographic region."
-msgstr "Správuje definice hranic geografického regionu."
+msgstr "Definuje hranice rastrové mapy."
#: ../general/g.region/main.c:71 ../general/g.region/main.c:76
#: ../general/g.region/main.c:164 ../general/g.region/main.c:171
#: ../general/g.region/main.c:180 ../general/g.region/main.c:187
#: ../general/g.region/main.c:197
+#, fuzzy
msgid "Existing"
-msgstr "Existuje"
+msgstr "Konec!"
#: ../general/g.region/main.c:75
+#, fuzzy
msgid "Save as default region"
-msgstr "Nastav jako výchozí region"
+msgstr "Nastav z výchozího regionu"
#: ../general/g.region/main.c:80
+#, fuzzy
msgid "Print the current region"
-msgstr "Vypi¹ aktuální region"
+msgstr "Pou¾ij aktuální region"
#: ../general/g.region/main.c:85
msgid "Print the current region in lat/long using the current ellipsoid/datum"
msgstr ""
-"Vypi¹ aktuální region v zem. délce/¹íøce s pou¾itím souèasného ellipsoidu/"
-"datumu"
#: ../general/g.region/main.c:91
+#, fuzzy
msgid "Print the current region extent"
-msgstr "Vypi¹ rozsah aktuálního regionu"
+msgstr "Pou¾ívám nastavení aktuálního regionu..."
#: ../general/g.region/main.c:97
+#, fuzzy
msgid "Print the current region map center coordinates"
-msgstr "Vypi¹ mapové souøadnice støedu aktuálního regionu"
+msgstr "Zarovnat souèasný region podle vstupní mapy"
#: ../general/g.region/main.c:103
#, fuzzy
@@ -13989,7 +14031,7 @@
#: ../general/g.region/main.c:115
msgid "Print region resolution in meters (geodesic)"
-msgstr "Vypi¹ rozli¹ení regionu v metrech (geodetické)"
+msgstr ""
#: ../general/g.region/main.c:120
msgid "Print the convergence angle (degrees CCW)"
@@ -14002,30 +14044,31 @@
msgstr ""
#: ../general/g.region/main.c:128
+#, fuzzy
msgid "Print also 3D settings"
-msgstr "Vypi¹ také 3D nastavení"
+msgstr "vypi¹ tabulky a ukonèi se."
#: ../general/g.region/main.c:134
msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr "Zobrazí hranièní souøadnice v lat/long na WGS84 "
+msgstr ""
#: ../general/g.region/main.c:139
#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
#: ../locale/scriptstrings/i.oif_to_translate.c:11
+#, fuzzy
msgid "Print in shell script style"
-msgstr "Vypi¹ ve stylu pro shell skript."
+msgstr "Vypi¹ výsledek ve stylu pro shell skript"
#: ../general/g.region/main.c:145
msgid ""
"Align region to resolution (default = align to bounds, works only for 2D "
"resolution)"
msgstr ""
-"Vyrovná region na rozli¹ení (výchozí = vyrovnat na hranice, funguje pouze "
-"pro 2D rozli¹ení)"
#: ../general/g.region/main.c:151
+#, fuzzy
msgid "Do not update the current region"
-msgstr "Neaktualizuj aktuální region"
+msgstr "Poèáteèní bod je mimo souèasný region"
#: ../general/g.region/main.c:152 ../general/g.region/main.c:349
#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
@@ -14034,70 +14077,79 @@
msgstr "Efekty"
#: ../general/g.region/main.c:162
+#, fuzzy
msgid "Set current region from named region"
msgstr "Nastaví aktuální region z pojmenovaného regionu"
#: ../general/g.region/main.c:178
+#, fuzzy
msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Nastav region tak, aby odpovídal této 3D rastrové mapì (obì 2D a 3D hodnoty)"
+msgstr "Nastav region tak, aby odpovídal této rastrové mapì"
#: ../general/g.region/main.c:241
+#, fuzzy
msgid "Value for the top edge"
-msgstr "Horní okraj"
+msgstr "Východní okraj"
#: ../general/g.region/main.c:250
+#, fuzzy
msgid "Value for the bottom edge"
-msgstr "Spodní okraj"
+msgstr "Severní okraj"
#: ../general/g.region/main.c:259
+#, fuzzy
msgid "Number of rows in the new region"
-msgstr "Poèet øádkù v novém regionu"
+msgstr "Poèet øádkù, které mají být ponechány v pamìti"
#: ../general/g.region/main.c:260 ../general/g.region/main.c:269
#: ../general/g.region/main.c:279 ../general/g.region/main.c:289
#: ../general/g.region/main.c:298 ../general/g.region/main.c:307
#: ../general/g.region/main.c:316
+#, fuzzy
msgid "Resolution"
-msgstr "Rozli¹ení"
+msgstr "Výbìr"
#: ../general/g.region/main.c:268
+#, fuzzy
msgid "Number of columns in the new region"
-msgstr "Poèet sloupcù v novém regionu"
+msgstr "Poèet sloupcù se li¹í."
#: ../general/g.region/main.c:278
msgid "Grid resolution 2D (both north-south and east-west)"
-msgstr "2D rozli¹ení (obì severo-ji¾ní a východnì-západní)"
+msgstr ""
#: ../general/g.region/main.c:288
msgid "3D grid resolution (north-south, east-west and top-bottom)"
-msgstr "3D rozli¹ení (severo-ji¾ní, východo-západní a horní-spodní)"
+msgstr ""
#: ../general/g.region/main.c:297
+#, fuzzy
msgid "North-south grid resolution 2D"
-msgstr "Severo-ji¾ní 2D rozli¹ení"
+msgstr "Po¾adované rozli¹ení sever-jih"
#: ../general/g.region/main.c:306
+#, fuzzy
msgid "East-west grid resolution 2D"
-msgstr "HVýchodo-západní 2D rozli¹ení"
+msgstr "Po¾adované rozli¹ení východ-západ"
#: ../general/g.region/main.c:315
msgid "Top-bottom grid resolution 3D"
-msgstr "Horní-spodní 3D rozli¹ení"
+msgstr ""
#: ../general/g.region/main.c:325
+#, fuzzy
msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-"Nastavit region tak, aby ze zadané rastrové mapy nebyly vidìt ¾ádné NULLové "
-"hodnoty"
#: ../general/g.region/main.c:336
+#, fuzzy
msgid "Adjust region cells to cleanly align with this raster map"
-msgstr "Nastavit region tak, aby odpovídal této rastrové mapì"
#: ../general/g.region/main.c:347
+#, fuzzy
msgid "Save current region settings in named region file"
-msgstr "Ulo¾it aktuální region jako region se jménem"
+msgstr "Nastaví aktuální region z pojmenovaného regionu"
#: ../general/g.region/main.c:406
#, c-format
@@ -14125,60 +14177,60 @@
msgstr "Starý soubor 3dview. Region <%s> nebyl nalezen <%s>"
#: ../general/g.region/main.c:487
-#, c-format
+#, fuzzy, c-format
msgid "3D raster map <%s> not found"
msgstr "3D rastrová mapa <%s> nebyla nalezena"
#: ../general/g.region/main.c:490
-#, c-format
+#, fuzzy, c-format
msgid "Unable to read header of 3D raster map <%s@%s>"
-msgstr "Nelze èíst hlavièku 3D rastrové mapy <%s@%s> "
+msgstr "Nelze èíst hlavièku rastrové mapy <%s@%s> "
#: ../general/g.region/main.c:516
-#, c-format
+#, fuzzy, c-format
msgid "Unable to open vector map <%s@%s>"
-msgstr "Nelze otevøít vektorovou mapu <%s@%s>"
+msgstr "Nelze otevøít vektorovou mapu <%s>"
#: ../general/g.region/main.c:803
-#, c-format
+#, fuzzy, c-format
msgid "Unable to set region <%s>"
-msgstr "Nelze nastavit region <%s>"
+msgstr "Nelze pou¾ít sloupec <%s>"
#: ../general/g.region/main.c:809
+#, fuzzy
msgid "Unable to update current region"
-msgstr "Neschopen aktualizovat aktuální region"
+msgstr "Nelze získat aktuální region"
#: ../general/g.region/main.c:817
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr "nelze zmìnit základní region. Souèasný mapset není <PERMANENT>."
+msgstr ""
#: ../general/g.region/main.c:834
-#, c-format
+#, fuzzy, c-format
msgid "Invalid input <%s=%s>"
-msgstr "Neplatný vstup <%s=%s>"
+msgstr "Neplatná mapa <%s>"
#: ../general/g.region/printwindow.c:264 ../general/g.region/printwindow.c:517
#: ../general/g.region/printwindow.c:648
+#, fuzzy
msgid "Unable to update lat/long projection parameters"
msgstr "Nelze nastavit parametry mapové projekce lat/long"
#: ../general/g.region/printwindow.c:411
msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr "Ji¾ jste v lat/long. Pou¾ijte radìji volbu -p."
+msgstr ""
#: ../general/g.region/printwindow.c:413
msgid ""
"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
"the -p flag instead."
-msgstr "Jste v location xy. ®ádná projekce není mo¾ná, pou¾ijte pøepínaè -p"
+msgstr ""
#: ../general/g.region/printwindow.c:638
msgid ""
"WGS84 output not possible as this location does not contain datum "
"transformation parameters. Try running g.setproj."
msgstr ""
-"Výstup WGS84 není mo¾ný, jeliko¾ tato location neobsahujetransformaèní "
-"parametry. Zkuste spustit g.setproj."
#: ../general/g.region/printwindow.c:784
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -14287,11 +14339,12 @@
#: ../general/g.gui/main.c:39
msgid "Launches a GRASS graphical user interface (GUI) session."
-msgstr "Spu¹tí se GRASS grafické prostøedí."
+msgstr ""
#: ../general/g.gui/main.c:44
+#, fuzzy
msgid "GUI type"
-msgstr "Typ grafického prostøedí"
+msgstr "Typ hrany grafu"
#: ../general/g.gui/main.c:45
#, fuzzy
@@ -14308,17 +14361,16 @@
#: ../general/g.gui/main.c:57
msgid "Update default GUI setting"
-msgstr "Aktualizovat základní nastavení grafického prostøedí"
+msgstr ""
#: ../general/g.gui/main.c:62
-#, fuzzy
msgid "Do not launch GUI after updating the default GUI setting"
+msgstr ""
#: ../general/g.gui/main.c:90
#, c-format
msgid "<%s> is now the default GUI"
-msgstr "<%s> je nyní nastaveno jako základní grafické prostøedí"
+msgstr ""
#: ../general/g.gui/main.c:104
#, c-format
@@ -14326,24 +14378,27 @@
msgstr ""
#: ../general/g.remove/main.c:109
+#, fuzzy
msgid "Force remove"
-msgstr "Násilné vyjmutí"
+msgstr "%d lomových bodù smazáno"
#: ../general/g.findfile/main.c:37
msgid "Searches for GRASS data base files and sets variables for the shell."
msgstr ""
#: ../general/g.findfile/main.c:54
+#, fuzzy
msgid "Name of an existing map"
msgstr "Název existující rastrové mapy"
#: ../general/g.findfile/main.c:60
+#, fuzzy
msgid "Name of a mapset"
-msgstr "Jméno mapsetu"
#: ../general/g.findfile/main.c:65
msgid "Don't add quotes"
-msgstr "Nepøidávat uvozovky"
+msgstr ""
#: ../general/g.findfile/main.c:79
#, c-format
@@ -14351,8 +14406,6 @@
"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
"s> does not correspond"
msgstr ""
-"'Soubor' s parametry obsahuje odkaz na <%s> mapset, ale parametry mapsetu <%"
-"s> si neodpovídají "
#: ../display/d.profile/main.c:68
#, fuzzy, c-format
@@ -14395,8 +14448,9 @@
msgstr ""
#: ../display/d.profile/main.c:196
+#, fuzzy
msgid "Raster map to be profiled"
-msgstr "Rastrová mapa pro tvorbu profilu"
+msgstr "Rastrová mapa, která bude dotazována"
#: ../display/d.profile/main.c:208
msgid "Use map's range recorded range"
@@ -14432,61 +14486,66 @@
msgid ""
"Selects the font in which text will be displayed on the user's graphics "
"monitor."
-msgstr "Vybere písmo, kterým bude zobrazen text na u¾ivatelském monitoru."
+msgstr ""
#: ../display/d.font/main.c:56
+#, fuzzy
msgid "Choose new current font"
-msgstr "Pou¾ijte nový aktuální font"
#: ../display/d.font/main.c:63
msgid "Path to Freetype-compatible font including file name"
-msgstr "Cesta k TrueType fontùm vèetnì jména souboru"
+msgstr ""
#: ../display/d.font/main.c:71
msgid "Character encoding"
-msgstr "Kódování znakù"
+msgstr ""
#: ../display/d.font/main.c:75
+#, fuzzy
msgid "List fonts"
-msgstr "Seznam v¹ech fontù"
+msgstr "Seznam vrstevnic (isolinií)"
#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
+#, fuzzy
msgid "List fonts verbosely"
-msgstr "Seznam v¹ech fontù (upovídaný re¾im)"
+msgstr "Roz¹íøený výpis"
#: ../display/d.font/main.c:105
-#, c-format
+#, fuzzy, c-format
msgid "Unable to access font path %s: %s"
-msgstr "Nelze zjistit cestu k fontu %s: %s"
+msgstr "Nelzepøistoupit k tabulce <%s>"
#: ../display/d.font/main.c:109
-#, c-format
+#, fuzzy, c-format
msgid "Font path %s is not a file"
-msgstr "Cesta k fontu %s není soubor"
+msgstr "Font '%s' není font typu FreeType \n"
#: ../display/d.font/main.c:126
#, c-format
msgid ""
"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr "Neplatné jméno fontu <%s>. Zkontrolujte jméno spu¹tìním 'g.mkfontcap'"
+msgstr ""
#: ../display/d.rast.arrow/main.c:97
msgid ""
"Draws arrows representing cell aspect direction for a raster map containing "
"aspect data."
-msgstr "Nakreslí ¹ipky pøedstavující smìr expozice pro rastrové mapy expozice."
+msgstr ""
#: ../display/d.rast.arrow/main.c:101
+#, fuzzy
msgid "Name of raster aspect map to be displayed"
-msgstr "Název rastrové mapy expozice, která bude zobrazena"
+msgstr "Název rastrové mapy která bude zobrazena"
#: ../display/d.rast.arrow/main.c:109
+#, fuzzy
msgid "Type of existing raster aspect map"
-msgstr "Typ existující rastrové mapy expozice"
+msgstr "Název existující rastrové mapy"
#: ../display/d.rast.arrow/main.c:117
msgid "Color for drawing arrows"
-msgstr "Barva pro ¹ipky"
+msgstr ""
#: ../display/d.rast.arrow/main.c:118 ../display/d.rast.arrow/main.c:127
#: ../display/d.rast.arrow/main.c:136 ../display/d.rast.arrow/main.c:145
@@ -14510,7 +14569,7 @@
#: ../display/d.rast.arrow/main.c:126
msgid "Color for drawing grid or \"none\""
-msgstr "Barva pro vykreslení sítì, nebo \"none\""
+msgstr ""
#: ../display/d.rast.arrow/main.c:135
#, fuzzy
@@ -14519,19 +14578,20 @@
#: ../display/d.rast.arrow/main.c:144
msgid "Color for showing unknown information"
-msgstr "Barva pro zobrazení neznámé informace"
+msgstr ""
#: ../display/d.rast.arrow/main.c:152
msgid "Draw arrow every Nth grid cell"
-msgstr "Vykreslit ¹ipku ka¾dou Ntou buòku"
+msgstr ""
#: ../display/d.rast.arrow/main.c:161
msgid "Raster map containing values used for arrow length"
-msgstr "Rastrová mapa obsahující hodnoty pou¾ité pro délku ¹ipek"
+msgstr ""
#: ../display/d.rast.arrow/main.c:168
+#, fuzzy
msgid "Scale factor for arrows (magnitude map)"
-msgstr "Mìøítkový faktor pro ¹ipky (mapa mocnosti)"
+msgstr "Mìøítkový faktor pro vý¹kový model"
#: ../display/d.rast.arrow/main.c:172 ../display/d.rast.num/main.c:107
#, fuzzy
@@ -14539,24 +14599,28 @@
msgstr "Neindexovat body podle rastrových bunìk "
#: ../display/d.rast.arrow/main.c:204
+#, fuzzy
msgid "Illegal value for scale factor"
-msgstr "Neplatná hodnota mìøítkového faktoru"
+msgstr "Neplatná hodnota pro null"
#: ../display/d.rast.arrow/main.c:208
+#, fuzzy
msgid "Illegal value for skip factor"
-msgstr "Neplatná hodnota faktoru pøeskoèení"
+msgstr "Neplatná hodnota pro '%s' (%s)"
#: ../display/d.rast.arrow/main.c:213
msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr "Velikost je podporována pouze pro GRASS a mapy kompasové expozice"
+msgstr ""
#: ../display/d.rast.arrow/main.c:218
+#, fuzzy
msgid "Scale option requires magnitude_map"
-msgstr "volba mìøítka vy¾aduje magnitude_map"
+msgstr "Tato volba vy¾aduje jeden sloupec"
#: ../display/d.rast.arrow/main.c:270
+#, fuzzy
msgid "Problem reading range file"
-msgstr "Problém pøi èetní souboru s rozsahem hodnot"
#: ../display/d.grid/main.c:52 ../display/d.legend/main.c:85
#: ../display/d.vect.chart/main.c:64 ../display/d.barscale/main.c:53
@@ -14570,8 +14634,6 @@
"Overlays a user-specified grid in the active display frame on the graphics "
"monitor."
msgstr ""
-"Zobrazí u¾ivatelem specifikovanou sí» (møí¾ku) v aktivním rámci grafického "
-"monitoru."
#: ../display/d.grid/main.c:62
msgid ""
@@ -14581,14 +14643,14 @@
#: ../display/d.grid/main.c:63
msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
msgstr ""
-"V jednotkách mapy nebo ve formátu DDD:MM:SS. Na pøíklad: \"1000\" nebo \"0:10"
#: ../display/d.grid/main.c:72
+#, fuzzy
msgid "Lines of the grid pass through this coordinate"
-msgstr "Linie sítì procházející tìmito souøadnicemi"
+msgstr "Poèet prùchodù pøes dataset"
#: ../display/d.grid/main.c:76
+#, fuzzy
msgid "Grid color"
msgstr "Barva rámeèku"
@@ -14601,8 +14663,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
+#, fuzzy
msgid "Color"
-msgstr "Barva"
+msgstr "Barvy"
#: ../display/d.grid/main.c:81 ../vector/v.label.sa/main.c:144
#: ../vector/v.lrs/v.lrs.label/main.c:238 ../vector/v.label/main.c:193
@@ -14616,8 +14679,9 @@
msgstr "Barva textu"
#: ../display/d.grid/main.c:96
+#, fuzzy
msgid "Font size for gridline coordinate labels"
-msgstr "Velikost písma pro popisky souøadnicové sítì"
+msgstr "Jedna nebo více souøadnic"
#: ../display/d.grid/main.c:100
#, fuzzy
@@ -14626,110 +14690,115 @@
#: ../display/d.grid/main.c:105
msgid "Draw geographic grid (referenced to current ellipsoid)"
-msgstr "Zobrazit zemìpisnou møí¾ku (na aktuálním ref. elipsoidu)"
+msgstr ""
#: ../display/d.grid/main.c:110
msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
-msgstr "Vykreslí souøadnicovou møí¾ku (vzta¾eno k elipsoidu WGS84)"
+msgstr ""
#: ../display/d.grid/main.c:114
msgid "Draw '+' marks instead of grid lines"
-msgstr "Nakreslit '+' znaèky místo zemìpisných èar"
+msgstr ""
#: ../display/d.grid/main.c:118
msgid "Draw fiducial marks instead of grid lines"
-msgstr "Nakreslí referneèní znaèky místo zemìpisných èar"
+msgstr ""
#: ../display/d.grid/main.c:122
msgid "Disable grid drawing"
-msgstr "Vypnout vykreslení rámeèku"
+msgstr ""
#: ../display/d.grid/main.c:123 ../display/d.grid/main.c:128
#: ../display/d.grid/main.c:133
+#, fuzzy
msgid "Disable"
-msgstr "Zakázat"
+msgstr "Vzdálenost"
#: ../display/d.grid/main.c:127
msgid "Disable border drawing"
+msgstr ""
#: ../display/d.grid/main.c:132
+#, fuzzy
msgid "Disable text drawing"
-msgstr "Vypnout vykreslení textu"
+msgstr "Nelze nastavit okno"
#: ../display/d.grid/main.c:142
msgid "Both grid and border drawing are disabled"
-msgstr "Vykreslení souø. sítì a hranic je znemo¾nìno."
+msgstr ""
#: ../display/d.grid/main.c:146
msgid "Geo-Grid option is not available for LL projection"
-msgstr "Volba Geo-Grid není pro mapovou projekci LL dostupná"
+msgstr ""
#: ../display/d.grid/main.c:148
msgid "Geo-Grid option is not available for XY projection"
-msgstr "Volba Geo-Grid není pro mapovou projekci XY dostupná"
+msgstr ""
#: ../display/d.grid/main.c:159
msgid "Choose a single mark style"
-msgstr "Vybrat jednoduchý styl oznaèování"
+msgstr ""
#: ../display/d.grid/main.c:178
-#, c-format
+#, fuzzy, c-format
msgid "Invalid geo-grid size <%s>"
-msgstr "Neplatná velikost geo-grid <%s>"
#: ../display/d.grid/main.c:183
-#, c-format
+#, fuzzy, c-format
msgid "Invalid grid size <%s>"
-msgstr "Chybná velikost sítì: <%s>"
#: ../display/d.grid/plot.c:309
msgid ""
"WGS84 grid output not possible as this location does not contain\n"
"datum transformation parameters. Try running g.setproj."
msgstr ""
-"Výstup do rastru WGS84 není mo¾ný, jeliko¾ tato location neobsahuje\n"
-"transformaèní parametry. Zkuste spustit g.setproj."
#: ../display/d.grid/plot.c:481
+#, fuzzy
msgid "Error in pj_do_proj1"
-msgstr "Chyba v pj_do_proj1"
+msgstr "Chyba v pj_do_proj"
#: ../display/d.grid/plot.c:487
+#, fuzzy
msgid "Error in pj_do_proj2"
-msgstr "Chyba v pj_do_proj2"
#: ../display/d.grid/plot.c:491
+#, fuzzy
msgid "Error in pj_do_proj3"
-msgstr "Chyba v pj_do_proj3"
#: ../display/d.grid/plot.c:499
+#, fuzzy
msgid "Error in pj_do_proj5"
-msgstr "Chyba v pj_do_proj5"
#: ../display/d.grid/plot.c:503
+#, fuzzy
msgid "Error in pj_do_proj6"
-msgstr "Chyba v pj_do_proj6"
#: ../display/d.grid/fiducial.c:49
+#, fuzzy
msgid "Reading symbol"
-msgstr "Ètu symbol"
+msgstr "Naèítám mapu"
#: ../display/d.erase/main.c:31
msgid "Erase the contents of the active display frame with user defined color"
msgstr ""
-"Vymazat obsah aktivního zobrazovacího zaøízení a vyplnit u¾ivatelem "
-"definovanou barvou"
#: ../display/d.erase/main.c:39
msgid ""
"Color to erase with, either a standard GRASS color or R:G:B triplet "
"(separated by colons)"
-msgstr "Barva pro vymazání, buï standardní GRASS barva nebo trojice R:G:B"
+msgstr ""
#: ../display/d.erase/main.c:44
+#, fuzzy
msgid "Remove all frames and erase the screen"
-msgstr "Odstranit v¹echny rámce a vymazat obrazovku"
+msgstr "Smazání malých úhlù na uzlech"
#: ../display/d.geodesic/main.c:45
msgid ""
@@ -14739,35 +14808,39 @@
#: ../display/d.geodesic/main.c:54 ../display/d.path/main.c:65
#: ../display/d.rhumbline/main.c:52
+#, fuzzy
msgid "Starting and ending coordinates"
-msgstr "Souøadnice poèátku a konce"
+msgstr "Poèáteèní pár souøadnic"
#: ../display/d.geodesic/main.c:60 ../display/d.rhumbline/main.c:58
#: ../display/d.vect/main.c:155
+#, fuzzy
msgid "Line color"
-msgstr "Barva linie"
+msgstr " nv barva\n"
#: ../display/d.geodesic/main.c:68
+#, fuzzy
msgid "Text color or \"none\""
-msgstr "Barva textu \"none\""
+msgstr "Barva textu"
#: ../display/d.geodesic/main.c:76 ../display/d.rhumbline/main.c:75
-#, c-format
+#, fuzzy, c-format
msgid "Location is not %s"
-msgstr "Location není %s"
+msgstr "Location: %s\n"
#: ../display/d.geodesic/main.c:79 ../display/d.path/main.c:140
#: ../display/d.rhumbline/main.c:79
+#, fuzzy
msgid "No coordinates given"
-msgstr "Nezadány ¾ádné mapové souøadnice"
+msgstr "Chyba pøi naèítání souboru se souøadnicemi"
#: ../display/d.geodesic/main.c:82 ../display/d.geodesic/main.c:85
#: ../display/d.geodesic/main.c:88 ../display/d.geodesic/main.c:91
#: ../display/d.rhumbline/main.c:82 ../display/d.rhumbline/main.c:85
#: ../display/d.rhumbline/main.c:88 ../display/d.rhumbline/main.c:91
-#, c-format
+#, fuzzy, c-format
msgid "%s - illegal longitude"
-msgstr "%s - neplatná hodnota zemìpisné délky"
+msgstr "%s: neplatná hodnota pro spec"
#: ../display/d.path/main.c:49 ../vector/v.net.alloc/main.c:61
#: ../vector/v.net/main.c:46 ../vector/v.net.iso/main.c:73
@@ -14781,9 +14854,9 @@
msgstr "vektor, sí»ování"
#: ../display/d.path/main.c:51
+#, fuzzy
msgid "Finds shortest path for selected starting and ending node."
-msgstr ""
-"Nalézá nejkrat¹í cestu ve vektorové síti pro zadaný poèáteèní a koncový bod."
+msgstr "Nalézá nejkrat¹í cestu ve vektorové síti."
#: ../display/d.path/main.c:58 ../vector/v.net.alloc/main.c:75
#: ../vector/v.net.iso/main.c:85 ../vector/v.net.salesman/main.c:110
@@ -14820,16 +14893,18 @@
#: ../display/d.path/main.c:99 ../display/d.extract/main.c:64
msgid "Original line color"
-msgstr "Pùvodní barva linie"
+msgstr ""
#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
+#, fuzzy
msgid "Rendering"
-msgstr "Vykresluji"
+msgstr "Zvìt¹ení regionu"
#: ../display/d.path/main.c:107 ../display/d.extract/main.c:70
+#, fuzzy
msgid "Highlight color"
-msgstr "Barva zvýraznìní"
+msgstr "Zvýrazòující barva textu"
#: ../display/d.path/main.c:122 ../vector/v.net.alloc/main.c:117
#: ../vector/v.net.iso/main.c:127 ../vector/v.net.salesman/main.c:136
@@ -14841,18 +14916,19 @@
msgstr "Pou¾ít geodetický výpoèet pro location se zemìpisných systémem"
#: ../display/d.path/main.c:126
+#, fuzzy
msgid "Render bold lines"
-msgstr "Vykreslit silné linie"
+msgstr "Ignorovat zlomené linie"
#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
-#, c-format
+#, fuzzy, c-format
msgid "%s - illegal x value"
-msgstr "%s - neplatná hodnota x"
#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
-#, c-format
+#, fuzzy, c-format
msgid "%s - illegal y value"
-msgstr "%s - neplatná hodnota y"
#: ../display/d.path/main.c:179 ../vector/v.net.distance/main.c:155
#: ../vector/v.net.allpairs/main.c:120 ../vector/v.net.path/main.c:120
@@ -14862,26 +14938,26 @@
msgstr "Souèasná projekce není longitude-latidude (¹íøka-délka)"
#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, c-format
+#, fuzzy, c-format
msgid "Node %d: %f %f\n"
-msgstr "Uzel %d: %f %f\n"
+msgstr "Sever: %f (%f)"
#: ../display/d.path/select.c:122
-#, c-format
+#, fuzzy, c-format
msgid "Destination unreachable\n"
-msgstr "Místo urèení nedosa¾itelné\n"
+msgstr "Místo urèení [%d] je nedosa¾itelné z místa [%d]"
#: ../display/d.path/select.c:125
#, c-format
msgid "Costs on the network = %f\n"
-msgstr "Náklady v síti = %f\n"
+msgstr ""
#: ../display/d.path/select.c:126
#, c-format
msgid ""
" Distance to the network = %f, distance from the network = %f\n"
"\n"
-msgstr " Vzdálenost k síti = %f, vzdálenost ze sítì = %f\n"
+msgstr ""
#: ../display/d.fontlist/main.c:39
#, fuzzy
@@ -14894,94 +14970,99 @@
msgstr "Pøíkazový mód (kompatibilita s d.text)"
#: ../display/d.info/main.c:33
+#, fuzzy
msgid "Display information about the active display monitor"
-msgstr "Zobraz informace o aktivním monitoru"
+msgstr "Nahla¹ informace o vstupním rastru a ukonèi se"
#: ../display/d.info/main.c:38
msgid "Display screen rectangle (left, right, top, bottom)"
-msgstr "Zobrazit hranice obrazovky (levý, pravý, horní, dolní)"
+msgstr ""
#: ../display/d.info/main.c:42
msgid "Display screen dimensions (width, height)"
-msgstr "Zobrazit rozmìry obrazovky (¹íøka, vý¹ka)"
+msgstr ""
#: ../display/d.info/main.c:46
msgid "Display active frame rectangle"
-msgstr "Zobrazit hranice aktivního rámce"
+msgstr ""
#: ../display/d.info/main.c:50
+#, fuzzy
msgid "Display screen rectangle of current region"
-msgstr "Zobrazit hranice obrazovky aktuálního regionu"
#: ../display/d.info/main.c:55
msgid "Display geographic coordinates and resolution of entire screen"
-msgstr "Zobrazit geografické souøadnice a rozli¹ení celého displeje"
+msgstr ""
#: ../display/d.legend/main.c:87
msgid ""
"Displays a legend for a raster map in the active frame of the graphics "
"monitor."
msgstr ""
-"Zobrazí legendu pro rastrovou mapu v aktivním rámci grafického monitoru."
#: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
+#, fuzzy
msgid "Name of raster map"
-msgstr "Název rastrové mapy"
+msgstr "Název základní rastrové mapy"
#: ../display/d.legend/main.c:98
msgid "Sets the legend's text color"
-msgstr "Nastaví barvu textu legendy"
+msgstr ""
#: ../display/d.legend/main.c:106
msgid "Number of text lines (useful for truncating long legends)"
-msgstr "Poèet øádek textu (vhodné pro zkracování dlouhé legendy)"
+msgstr ""
#: ../display/d.legend/main.c:115
msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr "Faktor kroku (thin=10 dá cats 0,10,20...)"
+msgstr ""
#: ../display/d.legend/main.c:123
msgid "Number of text labels for smooth gradient legend"
-msgstr "Poèet textových ¹títkù pro legendu vyhlazený gradient"
+msgstr ""
#: ../display/d.legend/main.c:133
msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr "Umístìní jako souøadnice procent displeje (0,0 je spodní levý roh)"
+msgstr ""
#: ../display/d.legend/main.c:143
msgid "List of discrete category numbers/values for legend"
-msgstr "Vypsat nespojité èísla/hodnoty kategorií pro legendu"
+msgstr ""
#: ../display/d.legend/main.c:153
msgid "Use a subset of the map range for the legend (min,max)"
-msgstr "Pou¾ít èást rozsahu mapy pro legendu (min,max)"
+msgstr ""
#: ../display/d.legend/main.c:159
+#, fuzzy
msgid "Do not show category labels"
-msgstr "Nezobrazovat ¹títky kategorií"
+msgstr "Vytiskni oznaèení kategorií"
#: ../display/d.legend/main.c:164
+#, fuzzy
msgid "Do not show category numbers"
-msgstr "Nezobrazovat kategorie"
+msgstr "pracuji na souboru <%s> pro èísla kategorií"
#: ../display/d.legend/main.c:169
+#, fuzzy
msgid "Skip categories with no label"
-msgstr "Pøeskoèit kategorie bez ¹títku"
+msgstr "v tabulce existuje %d kategorií "
#: ../display/d.legend/main.c:174
msgid "Draw smooth gradient"
-msgstr "Zobrazit vyhlazený gradient"
+msgstr ""
#: ../display/d.legend/main.c:179
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
msgid "Flip legend"
-msgstr "Obrátit legendu"
+msgstr ""
#: ../display/d.legend/main.c:199
#, c-format
msgid "Don't know the color %s"
-msgstr "Neznám barvu %s"
+msgstr ""
#: ../display/d.legend/main.c:258 ../display/d.histogram/main.c:175
#: ../ps/ps.map/ps_clrtbl.c:36
@@ -14991,109 +15072,112 @@
#: ../display/d.legend/main.c:308
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr "Rámeèek legendy je mimo rámec. Text se mo¾ná nezobrazí správnì."
+msgstr ""
#: ../display/d.legend/main.c:312
msgid "Drawing horizontal legend as box width exceeds height"
-msgstr "Vykreslení horizontální legendy jako rámeèku pøesahující její vý¹ku."
+msgstr ""
#: ../display/d.legend/main.c:323
-#, c-format
+#, fuzzy, c-format
msgid "Range information for <%s> not available (run r.support)"
-msgstr "Informace o rozsahu pro <%s> nejsou dostupné (spus»te r.support)"
+msgstr "Informace o rozsahu není dostupná (spus»te r.support)."
#: ../display/d.legend/main.c:328
+#, fuzzy
msgid "Input map contains no data"
-msgstr "Vstupní mapa neobsahuje ¾ádná data"
+msgstr "Oblast neobsahuje ¾ádná data"
#: ../display/d.legend/main.c:341 ../display/d.legend/main.c:501
msgid "Color range exceeds lower limit of actual data"
-msgstr "Barevný rozsah pøesahuje dolní mez aktuálních dat"
+msgstr ""
#: ../display/d.legend/main.c:347 ../display/d.legend/main.c:505
msgid "Color range exceeds upper limit of actual data"
-msgstr "Barevný rozsah pøesahuje horní mez pro aktuální data"
+msgstr ""
#: ../display/d.legend/main.c:406
#, c-format
msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr "use=%s mimo rozsah [%d,%d]. (zvìt¹it s range= ?)"
+msgstr ""
#: ../display/d.legend/main.c:447
msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr "Nic k vykreslení! (¾ádné kategorie se ¹títky? mimo rozsah?)"
+msgstr ""
#: ../display/d.legend/main.c:457
msgid "Forcing a smooth legend: too many categories for current window height"
msgstr ""
-"Zdùraznìní vyhlazené legendy: pøíli¹ mnoho kategorií pro vý¹ku aktuálního "
-"okna."
#: ../display/d.legend/main.c:487 ../display/d.histogram/main.c:178
-#, c-format
+#, fuzzy, c-format
msgid "Range information for <%s> not available"
-msgstr "Informace o rozsahu pro <%s> nejsou dostupné"
+msgstr "Soubor s kategoriemi pro <%s> není dostupný"
#: ../display/d.legend/main.c:512
#, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-msgstr "use=%s mimo rozsah [%.3f, %.3f]. (zvìt¹it s range= ?)"
+msgstr ""
#: ../display/d.legend/main.c:872
msgid "Nothing to draw! (no categories with labels?)"
-msgstr "Nic k vykreslení! (¾ádné kategorie se ¹títky?)"
+msgstr ""
#: ../display/d.vect.chart/main.c:66
msgid ""
"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr "Zobrazí grafy vektorových dat v aktivním grafickém monitoru."
+msgstr ""
#: ../display/d.vect.chart/main.c:83
+#, fuzzy
msgid "Chart type"
-msgstr "Typ grafu"
#: ../display/d.vect.chart/main.c:84 ../display/d.vect.chart/main.c:98
#: ../display/d.vect.chart/main.c:106 ../display/d.vect.chart/main.c:113
#: ../display/d.vect.chart/main.c:121 ../display/d.vect.chart/main.c:130
#: ../display/d.vect.chart/main.c:136
msgid "Chart properties"
-msgstr "Vlastnosti grafu"
+msgstr ""
#: ../display/d.vect.chart/main.c:91
+#, fuzzy
msgid "Attribute columns containing data"
-msgstr "Atributový sloupec obsahující data"
+msgstr "Jméno sloupce obsahujícího souøadnici x"
#: ../display/d.vect.chart/main.c:97
msgid "Column used for pie chart size"
-msgstr "Sloupec pou¾itý pro velikost koláèového grafu"
+msgstr ""
#: ../display/d.vect.chart/main.c:105
msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr "Velikost grafu (prùmìr koláèe, celková ¹íøka pro sloupce)"
+msgstr ""
#: ../display/d.vect.chart/main.c:112
msgid "Scale for size (to get size in pixels)"
-msgstr "Mìøítko velikosti (pro získání velikosti v pixelech)"
+msgstr ""
#: ../display/d.vect.chart/main.c:119
+#, fuzzy
msgid "Outline color"
+msgstr "Invertovat barvy"
#: ../display/d.vect.chart/main.c:128
msgid "Colors used to fill charts"
-msgstr "Barvy pou¾ité pro výplò grafù"
+msgstr ""
#: ../display/d.vect.chart/main.c:135
msgid "Center the bar chart around a data point"
-msgstr "Vycentruj sloupcový graf okolo datového bodu"
+msgstr ""
#: ../display/d.vect.chart/main.c:144
msgid "Maximum value used for bar plot reference"
-msgstr "Maximální hodnota pou¾itá pro mìøítko sloupcového grafu"
+msgstr ""
#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:158
+#, fuzzy
msgid "Create legend information and send to stdout"
-msgstr "Vytvoøit legendu a poslat ji na standartní výstup"
+msgstr "Vytiskne transfoemaèní matici na standartní výstup"
#: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
#: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
@@ -15119,12 +15203,11 @@
"Displays three user-specified raster map layers as red, green, and blue "
"overlays in the active graphics frame."
msgstr ""
-"Zobrazí tøi u¾ivatelem zadané rastrové mapy jako èerveno-, zeleno-, modrou "
-"kompozici v aktivním monitoru."
#: ../display/d.rgb/main.c:59
+#, fuzzy
msgid "Overlay (non-null values only)"
-msgstr "Pøekrýt (pouze ne-nullové hodnoty)"
+msgstr "Uspoøádat neNULLové hodnoty"
#: ../display/d.where/main.c:45
#, fuzzy
@@ -15147,39 +15230,36 @@
#: ../display/d.where/main.c:64
msgid "Output lat/long in decimal degree"
-msgstr "Výstupní zem. délka/¹íøka v decimálních stupních"
+msgstr ""
#: ../display/d.where/main.c:69
msgid "Output lat/long referenced to current ellipsoid"
-msgstr "Výstupní zem. délka/¹íøka vzta¾ena k aktuálnímu ref. elipsoidu"
+msgstr ""
#: ../display/d.where/main.c:74
msgid ""
"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
"parameters defined in current location (if available)"
msgstr ""
-"Výstupní zem. délka/¹íøka vzta¾ena k elipsoidu WGS84 transformaèníparametry "
-"definované v aktuální location, pokud jsou dostupné"
#: ../display/d.where/main.c:80
msgid "Output frame coordinates of current display monitor (percentage)"
-msgstr "Výstupní souøadnice rámu aktuálnì vybraného monitoru (procentuálnì)"
+msgstr ""
#: ../display/d.where/main.c:88
msgid "Ambiguous request for lat/long ellipsoids"
-msgstr "Nejednoznaèný po¾adavek pro lat/long elipsoidy"
+msgstr ""
#: ../display/d.where/main.c:91
+#, fuzzy
msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr "Prosím, specifikujte elipsoid lat/long pomocí -l nebo -w"
+msgstr "Prosím, zadejte polomìr, kde min < max"
#: ../display/d.where/main.c:133
msgid ""
"WGS84 output not possible as this location does not contain\n"
msgstr ""
-"Výstup WGS84 není mo¾ný, jeliko¾ tato location neobsahuje\n"
#: ../display/d.where/where.c:29
#, fuzzy, c-format
@@ -15192,81 +15272,87 @@
#: ../display/d.barscale/main.c:54
msgid "Displays a barscale on the graphics monitor."
-msgstr "Zobrazí mìøítko v monitoru GRASSu"
+msgstr ""
#: ../display/d.barscale/main.c:58
+#, fuzzy
msgid "Use feet/miles instead of meters"
-msgstr "Pou¾ij stopy/míle místo metrù"
+msgstr "systémové tabulky místo u¾ivatelských"
#: ../display/d.barscale/main.c:62
msgid "Draw a line scale instead of a bar scale"
-msgstr "Nakreslí liniové mìøítko místo páskového"
+msgstr ""
#: ../display/d.barscale/main.c:66
msgid "Write text on top of the scale, not to the right"
-msgstr "Napí¹e text nad mìøítko, místo vpravo."
+msgstr ""
#: ../display/d.barscale/main.c:70
msgid "Draw a north arrow only"
-msgstr "Vykresli pouze severku"
+msgstr ""
#: ../display/d.barscale/main.c:74
msgid "Draw a scale bar only"
-msgstr "Vykresli pouze mìøítko"
+msgstr ""
#: ../display/d.barscale/main.c:91
msgid ""
"The screen coordinates for top-left corner of label ([0,0] is top-left of "
"frame)"
msgstr ""
-"Souøadnice obrazovky pro levý horní roh ¹títku ([0,0] je vlevo nahoøe v rámu)"
#: ../display/d.barscale/main.c:99
-#, c-format
+#, fuzzy, c-format
msgid "%s does not work with a latitude-longitude location"
-msgstr "%s nepracuje v location typu lat/long."
+msgstr "Pou¾ít geodetický výpoèet pro location se zemìpisných systémem"
#: ../display/d.barscale/main.c:107
+#, fuzzy
msgid "Choose either -n or -s flag"
-msgstr "Vyberte pouze jeden z pøepínaèù -n nebo -s"
+msgstr "Vyberte pouze jeden z pøepínaèù -n nebo -s, ne oba"
#: ../display/d.measure/main.c:48
msgid ""
"Measures the lengths and areas of features drawn by the user in the active "
"display frame on the graphics monitor."
-msgstr "Mìøí délky a plochy objektù nakreslených u¾ivatelem do monitoru."
+msgstr ""
#: ../display/d.measure/main.c:54
+#, fuzzy
msgid "Line color 1"
-msgstr "Barva linie 1"
#: ../display/d.measure/main.c:62
+#, fuzzy
msgid "Line color 2"
-msgstr "Barva linie 2"
#: ../display/d.measure/main.c:70
+#, fuzzy
msgid "Suppress clear screen"
-msgstr "Potlaè vymazání obrazovky"
+msgstr "Potlaè varování"
#: ../display/d.measure/main.c:74
+#, fuzzy
msgid "Output in meters only"
-msgstr "Výstup pouze v metrech"
+msgstr "Název výstupního ovladaèe"
#: ../display/d.measure/main.c:78
msgid "Output in kilometers as well"
-msgstr "Výstup také v kilometrech"
+msgstr ""
#: ../display/d.his/main.c:64
+#, fuzzy
msgid ""
"Displays the result obtained by combining hue, intensity, and saturation "
"(his) values from user-specified input raster map layers."
msgstr ""
-"Vytvoøí èervené, zelené a modré(RGB) rastrové mapy kombinací hodnot odstínu,"
+"Vytvoøí èervené, zelené a modré rastrové mapy kombinací hodnot odstínu,"
"intenzity a nasycení (his) z u¾ivatelem zadaných vstupních rastrových map."
#: ../display/d.his/main.c:92
msgid "Percent to brighten intensity channel"
-msgstr "Procent zesvìtlení kanálu intenzity"
+msgstr ""
#: ../display/d.what.rast/main.c:50
msgid ""
@@ -15274,43 +15360,44 @@
"raster map layers at user specified locations within the current geographic "
"region."
msgstr ""
-"Umo¾òí u¾ivateli interaktivní dotaz na kategorii rastrových map pomocí my¹i "
-"v rámci aktuálního regionu."
#: ../display/d.what.rast/main.c:71
+#, fuzzy
msgid "Field separator (terse mode only)"
-msgstr "Oddìlovaè sloupcù (pouze pro struèný výstup)"
+msgstr "Oddìlovaè sloupcù (bodový mód)"
#: ../display/d.what.rast/main.c:76 ../display/d.what.vect/main.c:65
msgid "Identify just one location"
-msgstr "Oznaète pouze jednu oblast"
+msgstr ""
#: ../display/d.what.rast/main.c:80 ../display/d.what.vect/main.c:78
msgid "Terse output. For parsing by programs"
-msgstr "Struèný výstup pro pou¾ití ve skriptech."
+msgstr ""
#: ../display/d.what.rast/main.c:85
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr "Vytiskni sloupec/øádek pro celou mapu v aktuálním rozli¹ení regionu"
+msgstr ""
#: ../display/d.what.rast/what.c:56
+#, fuzzy
msgid "You are clicking outside the map"
-msgstr "Klikáte mimo mapu"
+msgstr "Nemohl jsem uzavøít mapu"
#: ../display/d.thematic.area/main.c:78
msgid ""
"Displays a thematic vector area map in the active frame on the graphics "
"monitor."
msgstr ""
-"Zobrazí plochy tématické vektorové mapy v aktivním rámci grafického monitoru."
#: ../display/d.thematic.area/main.c:88
+#, fuzzy
msgid "Data to be classified: column name or expression"
-msgstr "Data ke klasifikaci: sloupec nebo výraz"
+msgstr "Jméno sloupce nebo výraz"
#: ../display/d.thematic.area/main.c:95
+#, fuzzy
msgid "Class breaks, without minimum and maximum"
-msgstr ""
+msgstr "Vypsat jenom okraje tøíd (bez min a max)"
#: ../display/d.thematic.area/main.c:103 ../vector/v.class/main.c:66
msgid "Algorithm to use for classification"
@@ -15330,11 +15417,13 @@
#: ../display/d.thematic.area/main.c:122
msgid "Colors (one per class)."
-msgstr "Barvy (unikátní pro ka¾dou tøídu)."
+msgstr ""
#: ../display/d.thematic.area/main.c:128
+#, fuzzy
msgid "Layer number. If -1, all layers are displayed."
-msgstr "Èíslo vrstvy. Pokud -1, jsou zobrazeny v¹echny vrstvy."
+msgstr ""
+"Jméno OGR vrstvy, pokud není zadán, jsou pouze vyti¹tìny pøítomné vrstvy"
#: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
@@ -15368,20 +15457,23 @@
msgstr "Výbìr"
#: ../display/d.thematic.area/main.c:138 ../display/d.thematic.area/main.c:146
+#, fuzzy
msgid "Boundaries"
msgstr "Hranice"
#: ../display/d.thematic.area/main.c:139
+#, fuzzy
msgid "Boundary width"
msgstr "©íøka hranice"
#: ../display/d.thematic.area/main.c:145
+#, fuzzy
msgid "Boundary color"
-msgstr "Barva hranice"
+msgstr "Barva rámeèku"
#: ../display/d.thematic.area/main.c:152
msgid "File in which to save d.graph instructions for legend display"
-msgstr "Soubor do kterého chcete ulo¾it instrukce pro zobrazení legendy"
+msgstr ""
#: ../display/d.thematic.area/main.c:163
msgid ""
@@ -15390,17 +15482,19 @@
msgstr ""
#: ../display/d.thematic.area/main.c:167
+#, fuzzy
msgid "Do not draw map, only output the legend"
-msgstr "Nevykraslovat mapu, jako výstup pouze legenda"
+msgstr "Nezarovnávej výstup se vstupem"
#: ../display/d.thematic.area/main.c:186
-#, c-format
+#, fuzzy, c-format
msgid "%s: You must build topology on vector map. Run v.build."
-msgstr "%s: Pro vektorovou mapu musíte vybudovat topologii. Spus»te v.build"
+msgstr "Pro vektorový soubor <%s> musíte vybudovat topologii"
#: ../display/d.thematic.area/main.c:193
+#, fuzzy
msgid "'layer' must be > 0"
-msgstr "'layer' musí být > 0"
+msgstr "'layer' musí být . 0 pro 'where'"
#: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
@@ -15430,9 +15524,9 @@
msgstr "Nelze otevøít databázi <%s>"
#: ../display/d.thematic.area/main.c:219
-#, c-format
+#, fuzzy, c-format
msgid "Data (%s) not numeric. Column must be numeric."
-msgstr "Data (%s) nejsou èísla. sloupec musí být èíslo."
+msgstr "|Sloupec musí být èíselnéh typu"
#: ../display/d.thematic.area/main.c:223
#: ../display/d.thematic.area/plot1.c:134
@@ -15440,14 +15534,14 @@
#: ../display/d.vect/area.c:113 ../display/d.vect/plot1.c:142
#: ../display/d.vect/plot1.c:170 ../display/d.vect/plot1.c:201
#: ../display/d.vect/plot1.c:232
-#, c-format
+#, fuzzy, c-format
msgid "Cannot select data (%s) from table"
-msgstr "Nelze vybrat data (%s) z tabulky"
+msgstr "Nelze vybrat data z tabulky"
#: ../display/d.thematic.area/main.c:286 ../display/d.vect/main.c:424
-#, c-format
+#, fuzzy, c-format
msgid "Unknown color: [%s]"
-msgstr "Neznámá barva: [%s]"
+msgstr "Neznámá metrika: [%s]."
#: ../display/d.thematic.area/main.c:297
msgid ""
@@ -15456,9 +15550,8 @@
msgstr ""
#: ../display/d.thematic.area/main.c:334
-#, fuzzy
msgid "You must either give classbreaks or a classification algorithm"
-msgstr " %s: Chyba v algoritmu clasifikace"
+msgstr ""
#: ../display/d.thematic.area/main.c:347
#, c-format
@@ -15466,36 +15559,36 @@
"Not enough colors or error in color specifications.\n"
"Need %i colors."
msgstr ""
-"Nedostateèný poèet barev v zadávání barev.\n"
-"Je potøeba zadat %i barev."
#: ../display/d.thematic.area/main.c:352
-#, c-format
+#, fuzzy, c-format
msgid "Error interpreting color %s"
-msgstr "Chyba pøi ètení barvy %s"
+msgstr "Chyba pøi ètení souboru color pro <%s>"
#: ../display/d.thematic.area/main.c:370
+#, fuzzy
msgid "Plotting ..."
-msgstr "Tisknu ..."
+msgstr "Pøevádím..."
#: ../display/d.thematic.area/main.c:377 ../display/d.vect/main.c:604
+#, fuzzy
msgid ""
"The bounding box of the map is outside the current region, nothing drawn."
-msgstr "Okraj mapy je mimo souèasný region, nic není vykresleno."
+msgstr "Poèáteèní bod %d je mimo souèasný region"
#: ../display/d.thematic.area/main.c:426
-#, c-format
+#, fuzzy, c-format
msgid ""
"\n"
"Total number of records: %.0f\n"
-msgstr ""
-"\n"
-"Celkový poèet záznamù: %.0f\n"
+msgstr "Neplatné èíslo øádku <%s>"
#: ../display/d.thematic.area/main.c:428
-#, c-format
+#, fuzzy, c-format
msgid "Classification of %s into %i classes\n"
-msgstr "Klasifikace %s do %i tøíd\n"
+msgstr ""
+"\n"
+"Clasifikace %s do %i tøíd\n"
#: ../display/d.thematic.area/main.c:430 ../vector/v.class/main.c:192
#, c-format
@@ -15508,9 +15601,9 @@
msgstr "Prùmìr: %f\tSmìrodatná odchylka =%f\n"
#: ../display/d.thematic.area/main.c:436
-#, c-format
+#, fuzzy, c-format
msgid "Last chi2 = %f\n"
-msgstr "Poslední chi2 = %f\n"
+msgstr "Nejmen¹í chi2 = %f\n"
#: ../display/d.thematic.area/main.c:439 ../vector/v.class/main.c:200
#, c-format
@@ -15518,8 +15611,9 @@
msgstr "Støední odchylka vynásobena %.4f pro urèení kroku\n"
#: ../display/d.thematic.area/plot1.c:119 ../display/d.vect/plot1.c:127
+#, fuzzy
msgid "Color definition column not specified"
-msgstr "Nebyl zadán sloupec s definicí barvy"
+msgstr "Název vstupního zdroje nebyl specifikován"
#: ../display/d.thematic.area/plot1.c:129 ../display/d.vect/area.c:79
#: ../display/d.vect/plot1.c:137
@@ -15528,18 +15622,17 @@
"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
"BBB where RGB values range 0-255."
msgstr ""
-"Sloupec s definicí barvy (%s) není textového typu. Sloupec musí být ve formì "
-"ÈÈÈ:ZZZ:MMM, kde hodnoty barev (èervená, zelená, modrá) jsou v rozmení 0-255"
#: ../display/d.thematic.area/plot1.c:147 ../display/d.vect/area.c:98
#: ../display/d.vect/plot1.c:155
+#, fuzzy
msgid "Line width column not specified."
-msgstr "Nebyl zadán sloupec se ¹íøkou linie."
+msgstr "Nelze pou¾ít zadaný sloupec"
#: ../display/d.thematic.area/plot1.c:158 ../display/d.vect/area.c:109
-#, c-format
+#, fuzzy, c-format
msgid "Line width column (%s) not a number."
-msgstr "sloupec ¹íøky linie (%s) není èíselného typu"
+msgstr "Sloupec s ID linie musí být typu integer"
#: ../display/d.thematic.area/plot1.c:203 ../display/d.vect/topo.c:42
#, c-format
@@ -15547,39 +15640,37 @@
"\n"
"ERROR: vector map - can't read\n"
msgstr ""
-"\n"
-"CHYBA: vektorový soubor - nelze èíst\n"
#: ../display/d.thematic.area/plot1.c:278
-#, c-format
+#, fuzzy, c-format
msgid ""
"Error in color definition column (%s), element %d with cat %d: colorstring [%"
"s]"
msgstr ""
-"Chyba ve sloupci s definicí barvy (%s), prvek %d, kategorie %d: barevný "
-"øetìzec [%s]"
+"Chyba ve sloupci s definicí barvy (%s), kategorie %d: barevný øetìzec [%s]"
#: ../display/d.thematic.area/plot1.c:285
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr "Chyba ve sloupci s definicí barvy (%s), prvek %d, kategorie %d"
+msgstr "Chyba ve sloupci s definicí barvy (%s), kategorie %d"
#: ../display/d.thematic.area/plot1.c:353 ../display/d.vect/area.c:345
#: ../display/d.vect/plot1.c:451
-#, c-format
+#, fuzzy, c-format
msgid ""
"Error in line width column (%s), element %d with cat %d: line width [%d]"
msgstr ""
-"Chyba ve sloupci se ¹íøkou linie (%s), prvek %d, kategorie %d: ¹íøka [%d]"
#: ../display/d.colortable/main.c:63
+#, fuzzy
msgid "Displays the color table associated with a raster map layer."
-msgstr "Vytvoøí/mìní tabulku barev spojenou s rastrovou mapou."
+msgstr "Vytvoøí/upraví tabulku barev spojenou s rastrovou mapou."
#: ../display/d.colortable/main.c:67
#, fuzzy
msgid "Name of raster map whose color table is to be displayed"
#: ../display/d.colortable/main.c:75
msgid "Color of lines separating the colors of the color table"
@@ -15588,12 +15679,12 @@
#: ../display/d.colortable/main.c:81
#, fuzzy
msgid "Number of lines to appear in the color table"
-msgstr "Poèet øádkù v legendì"
+msgstr "Poèet iterací"
#: ../display/d.colortable/main.c:87
#, fuzzy
msgid "Number of columns to appear in the color table"
#: ../display/d.colortable/main.c:92
msgid "Don't draw a collar showing the NULL color in FP maps"
@@ -15618,237 +15709,241 @@
#: ../display/d.extract/main.c:51
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr "Vybere a extrahuje vektory vybrané my¹í do nové mapy"
+msgstr ""
#: ../display/d.extract/main.c:116
+#, fuzzy
msgid "Copying tables..."
-msgstr "Kopírování tabulky ..."
+msgstr "Kopíruji atributy..."
#: ../display/d.extract/main.c:124
+#, fuzzy
msgid "Cannot get db link info -> cannot copy table."
-msgstr ""
-"Nelze získat informace o odkazu na databázi -> nelze kopírovat tabulku."
+msgstr "Nelze dostat informace o odkazu na databázi"
#: ../display/d.extract/extract.c:43
msgid "Select vector(s) with mouse"
-msgstr "Vyberte vektor(y) my¹í"
+msgstr ""
#: ../display/d.extract/extract.c:44
msgid " - L: draw box with left mouse button to select"
-msgstr " - L: nakreslit levým tlaèítkem rámeèek pro výbìr"
+msgstr ""
#: ../display/d.extract/extract.c:45
msgid " - M: draw box with middle mouse button to remove from display"
-msgstr " - M: nakreslit prostøedním tlaèítkem rámeèek pro vyjmutí ze zobrazení"
+msgstr ""
#: ../display/d.extract/extract.c:46
msgid " - R: quit and save selected vectors to new map\n"
-msgstr " - R: ukonèit a ulo¾it vybrané vektory do nové mapy\n"
+msgstr ""
#: ../display/d.extract/extract.c:48
msgid "L: add M: remove R: quit and save\n"
msgstr ""
-"L: pøidat M: odstranit R: ukonèit a ulo¾it\n"
-"\n"
#: ../display/d.histogram/main.c:86
+#, fuzzy
msgid ""
"Displays a histogram in the form of a pie or bar chart for a user-specified "
"raster map."
-msgstr ""
-"Zobrazí histogram ve formì koláèového nebo sloupcového grafu pro zadanou "
-"rastrovou mapu."
+msgstr "Vypí¹e základní informace o u¾ivatelem vybrané 3D rastrové mapì."
#: ../display/d.histogram/main.c:90
+#, fuzzy
msgid "Raster map for which histogram will be displayed"
-msgstr "Rastrová mapa, pro kterou bude vytvoøen histogram"
+msgstr "Rastrová její¾ soubor NULL bude editován"
#: ../display/d.histogram/main.c:94
msgid "Indicate if a pie or bar chart is desired"
-msgstr "Nastavit styl grafu"
+msgstr ""
#: ../display/d.histogram/main.c:103
msgid "Color for text and axes"
-msgstr "Barva pro texr a osy"
+msgstr ""
#: ../display/d.histogram/main.c:111
msgid "Indicate if cell counts or map areas should be displayed"
+msgstr ""
#: ../display/d.histogram/main.c:121
msgid "Number of steps to divide the data range into (fp maps only)"
msgstr ""
-"Poèet krokù do kterých se má rozdìlit rozsah dat (pouze mapy s plovoucí "
-"desetinnou èárkou)"
#: ../display/d.histogram/main.c:128
+#, fuzzy
msgid "Display information for null cells"
-msgstr "Zobraz informace pro prázdné buòky"
+msgstr "Vytiskni pouze informace o topologii"
#: ../display/d.histogram/main.c:132
msgid "Gather the histogram quietly"
-msgstr "Vytvoø histogram potichu"
+msgstr ""
#: ../display/d.histogram/main.c:137
+#, fuzzy
msgid "Report for ranges defined in cats file (fp maps only)"
msgstr ""
-"Zpráva pro rozsahy definované v souboru cats (pouze mapy s plovoucí "
+"Zpráva pro jednotlivé kategorie rastrových map s plovoucí desetinnou èárkou"
#: ../display/d.histogram/main.c:161
-#, c-format
+#, fuzzy, c-format
msgid "Invalid number of steps: %s"
-msgstr "Chybný poèet krokù: %s"
+msgstr "Poèáteèní poèet tøíd"
#: ../display/d.histogram/main.c:166
msgid "When -C flag is set, the nsteps argument is ignored"
-msgstr "Pokud je pou¾ita volba -C, je volba nsteps ignorován"
+msgstr ""
#: ../display/d.linegraph/main.c:121
msgid ""
"Generates and displays simple line graphs in the active graphics monitor "
"display frame."
msgstr ""
-"Vytvoøí a zobrazí jednoduché grafické prvky na mapì vykreslené v aktivním "
-"grafickém monitoru."
#: ../display/d.linegraph/main.c:125
msgid "Name of data file for X axis of graph"
-msgstr "Jméno souboru obsahujícího data osy X grafu"
+msgstr ""
#: ../display/d.linegraph/main.c:131
msgid "Name of data file(s) for Y axis of graph"
-msgstr "Jméno souboru s daty pro osu Y grafu"
+msgstr ""
#: ../display/d.linegraph/main.c:138
+#, fuzzy
msgid "Path to file location"
-msgstr "Cesta k souboru"
+msgstr "Cesta k databázi GRASSu vstupní pro location"
#: ../display/d.linegraph/main.c:145
+#, fuzzy
msgid "Color for Y data"
-msgstr "Barva pro data osy Y"
+msgstr "Tabulka barev pro <%s> byla aktualizována"
#: ../display/d.linegraph/main.c:154
msgid "Color for axis, tics, numbers, and title"
-msgstr "Barva pro osy, znaèky èísla a název"
+msgstr ""
#: ../display/d.linegraph/main.c:162
+#, fuzzy
msgid "Title for X data"
-msgstr "Titulek pro data osy X"
+msgstr "Titulek pro novou rastrovou mapu"
#: ../display/d.linegraph/main.c:169
+#, fuzzy
msgid "Title for Y data"
-msgstr "Titulek pro data osy Y"
#: ../display/d.linegraph/main.c:176
+#, fuzzy
msgid "Title for Graph"
-msgstr "Titulek grafu"
#: ../display/d.linegraph/main.c:215
msgid "Maximum of 10 Y data files exceeded"
-msgstr "maximální poèet souborù (10) byl pøekroèen"
+msgstr ""
#: ../display/d.linegraph/main.c:244
#, c-format
msgid "Only <%d> colors given for <%d> lines"
-msgstr "Jenom <%d> barev pøidìleno <%d> liniím"
+msgstr ""
#: ../display/d.linegraph/main.c:296
#, c-format
msgid "Y input file <%s> contains %s data points than the X input file"
-msgstr "Yvstupní soubor <%s> obsahuje %s data bodù ne¾ X vstupní soubor"
+msgstr ""
#: ../display/d.linegraph/main.c:301
#, c-format
msgid "The last %d point(s) will be ignored"
-msgstr "Poslední %d bod(y) budou ignorovány"
+msgstr ""
#: ../display/d.linegraph/main.c:362
-#, c-format
+#, fuzzy, c-format
msgid "Problem reading X data file at line %d"
-msgstr "Problém pøi ètení øádku %d v souboru s daty osy X"
+msgstr "Problém pøi ètení souboru s hodnotami kategorií"
#: ../display/d.linegraph/main.c:372
#, c-format
msgid "Problem reading <%s> data file at line %d"
-msgstr "Problém pøi ètení souboru s daty <%s> øádku %d"
+msgstr ""
#: ../display/d.title/main.c:51
msgid ""
"Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
-"Vytvoøí titulek rastrové mapy ve formì pou¾itelné pro zobrazení pomocí d."
-"text."
#: ../display/d.title/main.c:62
+#, fuzzy
msgid "Sets the text color"
-msgstr "Nastaví barvu textu"
#: ../display/d.title/main.c:70
msgid "Sets the text size as percentage of the frame's height"
-msgstr "Vý¹ka písmen v procentech vý¹ky rámce"
+msgstr ""
#: ../display/d.title/main.c:74
+#, fuzzy
msgid "Draw title on current display"
-msgstr "Vykreslit titulek mapy do souèasného onka"
+msgstr "Nelze otevøít displej"
#: ../display/d.title/main.c:78
msgid "Do a fancier title"
-msgstr "Vytvoø hezèí titulek"
+msgstr ""
#: ../display/d.title/main.c:83
+#, fuzzy
msgid "Do a simple title"
-msgstr "Vytvoø jednoduchý titulek"
+msgstr "Název vektorové mapy"
#: ../display/d.title/main.c:101
msgid "Title can be fancy or simple, not both"
-msgstr "Titulek mù¾e být buï hezký nebo jednoduchý, ale ne obojí"
+msgstr ""
#: ../display/d.title/main.c:104
msgid "No map name given"
-msgstr "Nebyly specifikovány ¾ádné mapy"
+msgstr ""
#: ../display/d.graph/main.c:61
msgid ""
"Program for generating and displaying simple graphics on the display monitor."
-msgstr "Program pro tvorbu a zobrazení jednoduché grafiky v monitoru."
+msgstr ""
#: ../display/d.graph/main.c:68
+#, fuzzy
msgid ""
"Name of file containing graphics commands, if not given reads from standard "
"input"
msgstr ""
-"Název souboru obsahující grafické pøíkazy, pokud nezadáno, ète se standardní "
-"vstup"
+"Název souboru s pravidly rozdìlení , pokud nezadáno, ète se standardní vstup"
#: ../display/d.graph/main.c:76
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr "Barva kresby, buï standardní GRASS barva nebo trojice R:G:B"
+msgstr ""
#: ../display/d.graph/main.c:83
+#, fuzzy
msgid "Coordinates are given in map units"
-msgstr "Souøadnice jsou zadány v mapových jednotkách"
+msgstr "Tolerance rovnobì¾ek v oblouku v mapových jednotkách"
#: ../display/d.graph/main.c:94
-#, c-format
+#, fuzzy, c-format
msgid "Graph file <%s> not found"
-msgstr "Soubor s grafem <%s> nebyl nalezen"
+msgstr "GRASS site soubor <%s> nebyl nalezen"
#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
-#, c-format
+#, fuzzy, c-format
msgid "Problem parsing coordinates [%s]"
-msgstr "Problém pøi zpracování souøadnice [%s]"
#: ../display/d.graph/do_graph.c:98
+#, fuzzy
msgid "Unable to read color"
-msgstr "Nelze èíst barvu"
+msgstr "Nelze èíst barvy."
#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
#, c-format
msgid "Problem parsing command [%s]"
-msgstr "Problém pøi zpracování pøíkazu [%s]"
+msgstr ""
#: ../display/d.graph/do_graph.c:377 ../imagery/i.vpoints/plot.c:56
#: ../imagery/i.vpoints/plot.c:126
@@ -15860,16 +15955,15 @@
"Allows the user to interactively query a vector map layer at user-selected "
"locations within the current geographic region."
msgstr ""
-"Umo¾òuje u¾ivateli aktivní dotaz na vektorové mapy na místech definovaných "
-"my¹í v rámci aktuálního regionu."
#: ../display/d.what.vect/main.c:74
+#, fuzzy
msgid "Name of existing vector map"
-msgstr "Jméno existující vektorové mapy"
+msgstr "Jméno existující vektorové mapy (to)"
#: ../display/d.what.vect/main.c:83
msgid "Print information as plain text to terminal window"
-msgstr "Vytiskni informace v èistém textu do okna terminálu"
+msgstr ""
#: ../display/d.what.vect/main.c:87 ../vector/v.what/main.c:81
msgid "Print topological information (debugging)"
@@ -15877,12 +15971,12 @@
#: ../display/d.what.vect/main.c:91
msgid "Open form in edit mode"
-msgstr "Otevøi formuláø v editaèním módu"
+msgstr ""
#: ../display/d.what.vect/main.c:133
-#, c-format
+#, fuzzy, c-format
msgid "%s: You must build topology on vector map"
-msgstr "%s: Pro vektorový soubor musíte vybudovat topologii"
#: ../display/d.what.vect/main.c:136
msgid "Building spatial index..."
@@ -15895,9 +15989,13 @@
msgstr "Nic nebylo nalezeno.\n"
#: ../display/d.what.vect/what.c:210
-#, c-format
+#, fuzzy, c-format
msgid "Line: %d Type: %s Left: %d Right: %d "
-msgstr "Linie: %d Typ: %s Nalevo: %d Napravo: %d "
+msgstr ""
+"Linie: %d\n"
+"Typ: %s\n"
+"Nalevo: %d\n"
+"Napravo: %d\n"
#: ../display/d.what.vect/what.c:214 ../vector/v.what/what.c:253
#: ../vector/v.what/what.c:308
@@ -15906,19 +16004,24 @@
msgstr "Délka: %f\n"
#: ../display/d.what.vect/what.c:230
-#, c-format
+#, fuzzy, c-format
msgid " Node[%d]: %d Number of lines: %d Coordinates: %.6f, %.6f, %.6f\n"
-msgstr " Uzel[%d]: %d Poèet linií: %d Souøadnice: %.6f, %.6f, %.6f\n"
+msgstr ""
+"Uzel[%d]: %d\n"
+"Poèet linií: %d\n"
+"Souøadnice: %.6f, %.6f, %.6f\n"
#: ../display/d.what.vect/what.c:239
-#, c-format
+#, fuzzy, c-format
msgid " Line: %5d Angle: %.8f\n"
-msgstr " Linie: %5d Úhel: %.8f\n"
+msgstr ""
+"Linie: %5d\n"
+"Úhel: %.8f\n"
#: ../display/d.what.vect/what.c:248
-#, c-format
+#, fuzzy, c-format
msgid "length %f\n"
-msgstr "délka %f\n"
+msgstr "Délka: %f\n"
#: ../display/d.what.vect/what.c:268 ../vector/v.what/what.c:322
#, c-format
@@ -15931,66 +16034,75 @@
msgstr "Vý¹ka linie: %f\n"
#: ../display/d.what.vect/what.c:295
-#, c-format
+#, fuzzy, c-format
msgid "Line height min: %f max: %f\n"
-msgstr "Vý¹ka linie min: %f max: %f\n"
+msgstr ""
+"Vý¹ka linie min: %f\n"
+"Vý¹ka linie max: %f\n"
#: ../display/d.what.vect/what.c:311
-#, c-format
+#, fuzzy, c-format
msgid "Area height: %f\n"
-msgstr "Vý¹ka plochy: %f\n"
+msgstr "Vý¹ka linie: %f\n"
#: ../display/d.what.vect/what.c:320
-#, c-format
+#, fuzzy, c-format
msgid "Area\n"
-msgstr "Plocha\n"
+msgstr "Plocha"
#: ../display/d.what.vect/what.c:342
-#, c-format
+#, fuzzy, c-format
msgid "Area: %d Number of isles: %d\n"
-msgstr "Plocha: %d Poèet ostrovù: %d\n"
+msgstr ""
+"Plocha: %d\n"
+"Poèet ostrovù: %d\n"
#: ../display/d.what.vect/what.c:347
-#, c-format
+#, fuzzy, c-format
msgid " Isle[%d]: %d\n"
-msgstr " Ostrov[%d]: %d\n"
+msgstr "Ostrov[%d]: %d\n"
#: ../display/d.what.vect/what.c:354
-#, c-format
+#, fuzzy, c-format
msgid "Island: %d In area: %d\n"
-msgstr "Ostrov: %d V plo¹e: %d\n"
+msgstr "Ostrov: %d V plo¹e: %d\n"
#: ../display/d.what.vect/what.c:361 ../display/d.what.vect/what.c:369
-#, c-format
+#, fuzzy, c-format
msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
-msgstr "Výmìra - ètvereèní metry: %.3f\t\thektary: %.3f\n"
+msgstr ""
+"ètvereèní metry: %.3f\n"
+"hektary: %.3f\n"
#: ../display/d.what.vect/what.c:365 ../display/d.what.vect/what.c:373
-#, c-format
+#, fuzzy, c-format
msgid " Acres: %.3f\t\tSq Miles: %.4f\n"
-msgstr " Akry: %.3f\t\tètvereèní míle: %.4f\n"
+msgstr ""
+"Akry: %.3f\n"
+"ètvereèní míle: %.4f\n"
#: ../display/d.what.vect/what.c:396
-#, c-format
+#, fuzzy, c-format
msgid ""
"Layer: %d\n"
"category: %d\n"
msgstr ""
"Vrstva: %d\n"
-"kategorie: %d\n"
+"Kategorie: %d\n"
#: ../display/d.what.vect/what.c:421
-#, c-format
+#, fuzzy, c-format
msgid ""
"driver: %s\n"
"database: %s\n"
"table: %s\n"
"key column: %s\n"
msgstr ""
-"ovladaè: %s\n"
-"databáze: %s\n"
-"tabulka: %s\n"
-"sloupec s klíèem: %s\n"
+"\n"
+"Ovladaè: %s\n"
+"Databáze: %s\n"
+"Tabulka: %s\n"
+"Sloupec s klíèem: %s\n"
#: ../display/d.what.vect/what.c:475
#, c-format
@@ -15999,78 +16111,72 @@
"Click mouse button on desired location\n"
"\n"
msgstr ""
-"\n"
-"Kliknìte my¹í na po¾adované místo\n"
-"\n"
#: ../display/d.what.vect/what.c:480
-#, c-format
+#, fuzzy, c-format
msgid "Buttons\n"
-msgstr "Tlaèítka\n"
+msgstr "Tlaèítka:\n"
#: ../display/d.what.vect/what.c:481
#, c-format
msgid " Left: what's here\n"
-msgstr " Levé: copak je tu\n"
+msgstr ""
#: ../display/d.what.vect/what.c:482
#, c-format
msgid " Right: quit\n"
-msgstr " Pravé: ukonèit\n"
+msgstr ""
#: ../display/d.what.vect/openvect.c:11
-#, c-format
+#, fuzzy, c-format
msgid "warning: %s - vector map not found\n"
-msgstr "varování: %s - vektorový soubor nenalezen\n"
+msgstr "Rastrová mapa nebyla nalezena"
#: ../display/d.text/main.c:141
msgid ""
"Draws text in the active display frame on the graphics monitor using the "
"current font."
msgstr ""
-"Zobrazí text v aktivním rámci grafického monitoru s vyu¾itím aktuálního "
-"písma."
#: ../display/d.text/main.c:147
+#, fuzzy
msgid "Text to display"
-msgstr "Text k zobrazení"
#: ../display/d.text/main.c:156
msgid "Height of letters in percentage of available frame height"
-msgstr "Vý¹ka písmen v procentech dostupné vý¹ky rámce"
+msgstr ""
#: ../display/d.text/main.c:164
msgid "Text color, either a standard GRASS color or R:G:B triplet"
-msgstr "Barva textu, buï standardní GRASS barva nebo trojice R:G:B"
+msgstr ""
#: ../display/d.text/main.c:172
-#, fuzzy
msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
#: ../display/d.text/main.c:181
msgid "The screen line number on which text will begin to be drawn"
-msgstr "Èíslo øádky obrazovky na které bude vykreslen zaèátek textu"
+msgstr ""
#: ../display/d.text/main.c:189
msgid ""
"Screen position at which text will begin to be drawn (percentage, [0,0] is "
"lower left)"
msgstr ""
-"Pozice na obrazovce na které bude vykreslen zaèátek textu (procentuálnì, "
-"[0,0] je vlevo dole)"
#: ../display/d.text/main.c:197
msgid "Text alignment"
-msgstr "Zarovnání textu"
+msgstr ""
#: ../display/d.text/main.c:205
+#, fuzzy
msgid "Rotation angle in degrees (counter-clockwise)"
msgstr "Úhel rotace ve stupních (proti smìru hodinových ruèièek)"
#: ../display/d.text/main.c:212
msgid "Line spacing"
-msgstr "Øádkování"
+msgstr ""
#: ../display/d.text/main.c:218 ../display/d.vect/main.c:296
#: ../vector/v.label/main.c:122
@@ -16078,12 +16184,13 @@
msgstr "Název písma"
#: ../display/d.text/main.c:224
+#, fuzzy
msgid "Path to font file"
-msgstr "Cesta k souboru s fonty"
+msgstr "Cesta k výslednému souboru VTK"
#: ../display/d.text/main.c:232
msgid "Text encoding (only applicable to TrueType fonts)"
-msgstr "Kódování textu (pou¾itelné pouze na TrueType fonty)"
+msgstr ""
#: ../display/d.text/main.c:236
#, fuzzy
@@ -16092,35 +16199,38 @@
#: ../display/d.text/main.c:240
msgid "Screen position in pixels ([0,0] is top left)"
-msgstr "Souøadnice v pixelech ([0,0] vlevo nahoøe)"
+msgstr ""
#: ../display/d.text/main.c:244
+#, fuzzy
msgid "Screen position in geographic coordinates"
-msgstr "Pozice na monitoru v geografických souøadnicích"
+msgstr "Poèáteèní mapové souøadnice"
#: ../display/d.text/main.c:248
msgid "Use bold text"
-msgstr "Pou¾ít tuèné písmo"
+msgstr ""
#: ../display/d.text/main.c:252
+#, fuzzy
msgid "Use radians instead of degrees for rotation"
-msgstr "Pou¾ít pro rotaci radiány namísto stupòù"
+msgstr "Pou¾ít volbu vzdálenosti místo volby buferu"
#: ../display/d.text/main.c:256
msgid "Font size is height in pixels"
-msgstr "Velikost písma je vý¹ka v pixelech"
+msgstr ""
#: ../display/d.text/main.c:260
msgid "Ignored (compatibility with d.text.freetype)"
-msgstr "Ignrováno (kompatibilita s d.text.freetype)"
+msgstr ""
#: ../display/d.text/main.c:270
msgid "Please choose only one placement method"
-msgstr "Prosím, vyberte pouze jeden zpùsob umístìní"
+msgstr ""
#: ../display/d.text/main.c:331
+#, fuzzy
msgid "Invalid coordinates"
-msgstr "Neplatné souøadnice"
+msgstr "Neplatné souøadnice %s %s"
#: ../display/d.text/main.c:374
#, c-format
@@ -16128,51 +16238,47 @@
"\n"
"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
msgstr ""
-"\n"
-"Prosím zadejte textové instrukce. Pro ukonèení vlo¾te EOF (ctrl-d) na "
-"poslední øádek.\n"
#: ../display/d.text/main.c:565
#, c-format
msgid "[%s]: No such color. Use '%s'"
-msgstr "[%s]: Žádná taková barva. Pou¾ijte '%s'"
+msgstr ""
#: ../display/d.labels/main.c:45
msgid ""
"Displays text labels (created with v.label) to the active frame on the "
"graphics monitor."
msgstr ""
-"Zobrazí textové popisky (vytvoøené pomocí v.label) v aktivním rámci "
-"grafického monitoru."
#: ../display/d.labels/main.c:51
msgid "Ignore rotation setting and draw horizontally"
-msgstr "Ignorovat nastavení pro otoèení a vykreslit horizontálnì"
+msgstr ""
#: ../display/d.labels/main.c:58
+#, fuzzy
msgid "Name of label file"
-msgstr "Název souboru s popisky"
+msgstr "Název souboru s filtrem"
#: ../display/d.labels/main.c:65
msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr "Minimální velikost regionu (diagonální), kdy jsou zobrazeny popisky"
+msgstr ""
#: ../display/d.labels/main.c:72
msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr "Maximální velikost regionu (diagonální), kdy jsou zobrazeny popisky"
+msgstr ""
#: ../display/d.labels/main.c:84
-#, c-format
+#, fuzzy, c-format
msgid "Label file <%s> not found"
-msgstr "Soubor s popisky <%s> nebyl nalezen"
#: ../display/d.labels/main.c:96 ../display/d.vect/main.c:386
msgid "Region size is lower than minreg, nothing displayed."
-msgstr "Velikost oblasti je men¹í, ne¾ minreg, nic není zobrazeno."
+msgstr ""
#: ../display/d.labels/main.c:104 ../display/d.vect/main.c:394
msgid "Region size is greater than maxreg, nothing displayed."
-msgstr "Velikost regionu je vìt¹í, ne¾ maxreg, zobrazeno není nic."
+msgstr ""
#: ../display/d.labels/main.c:113 ../vector/v.lrs/v.lrs.label/main.c:300
#, c-format
@@ -16180,9 +16286,9 @@
msgstr "Nelze otevøít soubor s popisky <%s>"
#: ../display/d.labels/do_labels.c:142
-#, c-format
+#, fuzzy, c-format
msgid "Error: %s\n"
-msgstr "Chyba: %s\n"
+msgstr "Chyba: %s"
#: ../display/d.rast/main.c:54
#, fuzzy
@@ -16190,8 +16296,9 @@
msgstr "Zji¹»uje barvy rastrové mapové vrstvy."
#: ../display/d.rast/main.c:58
+#, fuzzy
msgid "Raster map to be displayed"
-msgstr "Rastrová mapa, která má být zobrazena"
+msgstr "Rastrová mapa, která má být vzorkována"
#: ../display/d.rast/main.c:66
#, fuzzy
@@ -16199,12 +16306,13 @@
msgstr "Seznam kategorií, které budou zobrazeny (celoèíselné mapy)"
#: ../display/d.rast/main.c:72
+#, fuzzy
msgid "Background color (for null)"
-msgstr "Barva pozadí (pro hodnoty null)"
+msgstr "Barva pozadí"
#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
msgid "Either a standard color name or R:G:B triplet"
-msgstr "Buï standardní GRASS barva nebo trojice R:G:B"
+msgstr ""
#: ../display/d.rast/main.c:77
msgid "Make null cells opaque"
@@ -16229,33 +16337,33 @@
msgid ""
"Overlays cell category values on a raster map layer displayed to the "
"graphics monitor."
-msgstr "Zobrazí hodnoty bunìk jako èísla v grafickém monitoru."
+msgstr ""
#: ../display/d.rast.num/main.c:85
msgid "Color for drawing grid, or \"none\""
+msgstr ""
#: ../display/d.rast.num/main.c:94
msgid "Color for drawing text"
-msgstr "Barva pro zobrazený text"
+msgstr ""
#: ../display/d.rast.num/main.c:111
msgid "Get text color from cell color value"
-msgstr "Pøevezmi barvu textu z barvy buòky"
+msgstr ""
#: ../display/d.rast.num/main.c:176
msgid "Current window size:"
-msgstr "Velikost aktuálního okna: "
+msgstr ""
#: ../display/d.rast.num/main.c:177
-#, c-format
+#, fuzzy, c-format
msgid "rows: %d"
-msgstr "øádky: %d"
+msgstr "Øádky = %d"
#: ../display/d.rast.num/main.c:178
-#, c-format
+#, fuzzy, c-format
msgid "columns: %d"
-msgstr "sloupce: %d"
+msgstr "Sloupce = %d"
#: ../display/d.rast.num/main.c:180
msgid ""
@@ -16263,201 +16371,203 @@
"Your current window setting may be too large. Cells displayed on your "
"graphics window may be too small for cell category number to be visible."
msgstr ""
-"\n"
-"Va¹e souèasné nastavení regionu je pøíli¹ velké. Buòky jsou tak pøíli¹ malé "
-"aby se v nich daly zobrazit èísla jejich kategorií."
#: ../display/d.rast.num/main.c:186
+#, fuzzy
msgid "Aborting."
-msgstr "Pøeru¹uji."
#: ../display/d.nviz/main.c:69
msgid "Creates fly-through script to run in NVIZ."
-msgstr "Vytvoøit skript pro NVIZ s pøeletem"
+msgstr ""
#: ../display/d.nviz/main.c:74
+#, fuzzy
msgid "Name of output script"
-msgstr "Název výstupního skriptu"
+msgstr "Název výstupního souboru"
#: ../display/d.nviz/main.c:80
+#, fuzzy
msgid "Prefix of output images (default = NVIZ)"
-msgstr "Prefix výstupních obrázkù (výchozí = NVIZ)"
+msgstr "Zapsat výstup ve stupních (výchozí je radiány)"
#: ../display/d.nviz/main.c:88
+#, fuzzy
msgid "Route coordinates (east,north)"
-msgstr "Souøadnice trasy (východ, sever)"
+msgstr "Vytiskni souøadnice rastrového souboru (východní a severní)"
#: ../display/d.nviz/main.c:94
+#, fuzzy
msgid "Camera layback distance (in map units)"
-msgstr "Vzdálenost odstupu kamery (v jednotkách mapy)"
+msgstr "Vzdálenost bufferu v mapových jednotkách"
#: ../display/d.nviz/main.c:100
+#, fuzzy
msgid "Camera height above terrain"
-msgstr "Vý¹ka kamery nad terénem"
+msgstr "%s ¹patnì vý¹e nad poèátkem"
#: ../display/d.nviz/main.c:106
+#, fuzzy
msgid "Number of frames"
-msgstr "Poèet snímkù"
+msgstr "Poèet øádkù"
#: ../display/d.nviz/main.c:112
msgid "Start frame number (default=0)"
-msgstr "Poèáteèní èíslo snímkù (výchozí=0)"
+msgstr ""
#: ../display/d.nviz/main.c:117
msgid "Full render -- Save images"
-msgstr "Plné renderování -- Ulo¾it obrázky"
+msgstr ""
#: ../display/d.nviz/main.c:121
+#, fuzzy
msgid "Fly at constant elevation (ht)"
-msgstr "Let s konstantí vý¹kou (ht)"
+msgstr "nelze zavøít mapu elevace"
#: ../display/d.nviz/main.c:126
msgid "Include command in the script to output a KeyFrame file"
-msgstr "Do skriptu vlo¾it pøíkaz pro vytvoøení souboru KeyFrame"
+msgstr ""
#: ../display/d.nviz/main.c:130
msgid "Render images off-screen"
-msgstr "Vykreslování obrázkù (off-screen)"
+msgstr ""
#: ../display/d.nviz/main.c:134
+#, fuzzy
msgid "Enable vector and sites drawing"
-msgstr "Zapnout vykreslování vektorových a bodových dat"
+msgstr "Nelze momentálnì èíst rastrovou mapu."
#: ../display/d.nviz/main.c:142
+#, fuzzy
msgid "Either -i flag and/or route parameter must be used"
-msgstr "Je potøeba pou¾ít buï pøepínaè -i nebo parametr trasy"
+msgstr "Jeden z parametrù [%s] nebo [%s] musí být pou¾it"
#: ../display/d.nviz/main.c:166
msgid "Off-screen only available with full render mode"
-msgstr "Off-screen je dostupný pouze v módu plné vykreslování"
+msgstr ""
#: ../display/d.nviz/main.c:244
-#, c-format
+#, fuzzy, c-format
msgid "You must provide at least four points %d"
-msgstr "Musíte stanovit alespoò ètyøi body %d."
+msgstr "Musíte vybrat alespoò jeden nástroj"
#: ../display/d.nviz/main.c:318
#, c-format
msgid "Created NVIZ script <%s>."
-msgstr "Vytvoøil jsem skript NVIZ <%s>-"
+msgstr ""
#: ../display/d.nviz/main.c:434
msgid ""
"Skipping this point, selected point is outside region. Perhaps the camera "
"setback distance puts it beyond the edge?"
msgstr ""
-"Vynechávám tento bod, je mimo region. To mù¾e být zpùsobeno nastavením "
-"odstupu kamery."
#: ../display/d.zoom/main.c:63
msgid ""
"Allows the user to change the current geographic region settings "
"interactively, with a mouse."
-msgstr "Dovolí u¾ivateli zmìnit aktuální region interaktivnì pomocí my¹i."
+msgstr ""
#: ../display/d.zoom/main.c:83
#: ../locale/scriptstrings/v.colors_to_translate.c:4
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:4
+#, fuzzy
msgid "Name of vector map"
-msgstr "Jméno vektorové mapy"
+msgstr "Jméno vektorové mapy k editaci"
#: ../display/d.zoom/main.c:91
msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
-msgstr "Zvìt¹ení: >1.0 zvìt¹uje, < 1.0 zmen¹uje"
+msgstr ""
#: ../display/d.zoom/main.c:101
msgid "Full menu (zoom + pan) & Quit menu"
-msgstr "Plné menu (zoom + posun) a Menu ukonèení"
+msgstr ""
#: ../display/d.zoom/main.c:105
msgid "Pan mode"
-msgstr "Mód posunu"
+msgstr ""
#: ../display/d.zoom/main.c:109
msgid "Handheld mode"
-msgstr "Mód pro kapesní poèítaèe"
+msgstr ""
#: ../display/d.zoom/main.c:113
msgid "Return to previous zoom"
-msgstr "Návrat na pøedchozí íºroveò"
+msgstr ""
#: ../display/d.zoom/main.c:119
+#, fuzzy
msgid "Please choose only one mode of operation"
-msgstr "Prosím, vyberte pouze jeden mód operace"
+msgstr "Prosím, vyberte jedenu volbu z nasledujících\n"
#: ../display/d.zoom/main.c:222
-#, c-format
+#, fuzzy, c-format
msgid "%d raster%s, %d vector%s\n"
-msgstr "%d rastr%s, %d vektor%s\n"
+msgstr "%d øádkù, %d sloupcù"
#: ../display/d.zoom/main.c:231
msgid "No previous zoom available"
-msgstr "®ádný pøedchozí stupeò zvìt¹ení nebyl nalezen"
+msgstr ""
#: ../display/d.zoom/main.c:235
msgid "Returning to previous zoom"
-msgstr "Vracím se do pøedchozího zvìt¹ení"
+msgstr ""
#: ../display/d.zoom/main.c:270
+#, fuzzy
msgid "Zooming complete."
-msgstr "Zvìt¹ování dokonèeno"
+msgstr "Hotovo"
#: ../display/d.zoom/zoom.c:14 ../display/d.zoom/pan.c:16
-#, c-format
+#, fuzzy, c-format
msgid ""
"\n"
"\n"
"Buttons:\n"
-msgstr ""
-"\n"
-"\n"
-"Tlaèítka: \n"
#: ../display/d.zoom/zoom.c:15
#, c-format
msgid "Left: Zoom menu\n"
-msgstr "Levé tlaèítko: Menu transfokace\n"
+msgstr ""
#: ../display/d.zoom/zoom.c:16
-#, c-format
+#, fuzzy, c-format
msgid "Middle: Pan\n"
-msgstr "Prostøední tlaèítko: Posun\n"
+msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
#: ../display/d.zoom/zoom.c:17
#, c-format
msgid "Right: Quit menu\n"
-msgstr "Pravé tlaèítko: Menu ukonèení\n"
+msgstr ""
#: ../display/d.zoom/zoom.c:39
-#, c-format
+#, fuzzy, c-format
msgid ""
"This region now saved as current region.\n"
"\n"
-msgstr ""
-"Tento region je nyní ulo¾en jako souèasný region.\n"
-"\n"
+msgstr "Neexistuje ¾ádné správné umístìní v souèasném regioinu"
#: ../display/d.zoom/zoom.c:41
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
msgstr ""
-"Poznámka: pro nový region spus»te 'd.erase', aby se zmìna projevila na "
-"grafice.\n"
#: ../display/d.zoom/pan.c:17
-#, c-format
+#, fuzzy, c-format
msgid "Left: Pan\n"
-msgstr "Levé tlaèítko: Posun\n"
+msgstr "Levé tlaèítko: Oznaè dal¹í bod\n"
#: ../display/d.zoom/pan.c:18
#, c-format
msgid "Right: Quit\n"
-msgstr " Pravé tlaèítko: ukonèit\n"
+msgstr ""
#: ../display/d.vect/label.c:26 ../display/d.vect/dir.c:27
#: ../display/d.vect/attr.c:52
+#, fuzzy
msgid "Can't read vector map"
-msgstr "Nelze èíst vektorovtou mapu"
+msgstr "Nelze èíst vektorovou mapu"
#: ../display/d.vect/main.c:119
#, fuzzy
@@ -16465,61 +16575,68 @@
msgstr "Zobrazit vektorová data v aktivním rámu grafického monitoru."
#: ../display/d.vect/main.c:125
+#, fuzzy
msgid "Layer number (if -1, all layers are displayed)"
-msgstr "Èíslo vrstvy (Pokud -1, jsou zobrazeny v¹echny vrstvy)"
+msgstr "Èíslo vrstvy (Pokud -1, jsou vyjmuty v¹echny prvky ve v¹ech vrstvách.)"
#: ../display/d.vect/main.c:135
+#, fuzzy
msgid "Display"
-msgstr "Zobrazit"
+msgstr "zobrazení"
#: ../display/d.vect/main.c:159 ../display/d.vect/main.c:169
#: ../display/d.vect/main.c:273 ../display/d.vect/main.c:283
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "Buï standardní barva GRASSu nebo nebo trojice R:G:B nebo \"none\""
+msgstr ""
#: ../display/d.vect/main.c:165
+#, fuzzy
msgid "Area fill color"
-msgstr "Barva výplnì plochy"
+msgstr " hodnota barvy\n"
#: ../display/d.vect/main.c:174
+#, fuzzy
msgid "Name of color definition column (for use with -a flag)"
-msgstr "Jméno sloupce s definicí barvy (pou¾it spolu s volbou -a)"
+msgstr "Jméno sloupce s definicí barvy (se vstupem RRR:GGG:BBB)"
#: ../display/d.vect/main.c:182
+#, fuzzy
msgid "Type of color table (for use with -z flag)"
-msgstr "Typ sloupce s definicí barvy (pou¾it spolu s volbou -z)"
+msgstr "Typ tabulky barev"
#: ../display/d.vect/main.c:191 ../display/d.vect/main.c:196
#: ../display/d.vect/main.c:204
+#, fuzzy
msgid "Lines"
msgstr "Linie"
#: ../display/d.vect/main.c:192
+#, fuzzy
msgid "Line width"
-msgstr "©íøka linie"
+msgstr "©íøka linie textu"
#: ../display/d.vect/main.c:198
msgid "Name of column for line widths (these values will be scaled by wscale)"
msgstr ""
-"Jméno sloupce se ¹íøkou linií (tyto hodnoty budou upraveny parametrem wscale)"
#: ../display/d.vect/main.c:205
+#, fuzzy
msgid "Scale factor for wcolumn"
-msgstr "Mìøítkový faktor wcolumn"
+msgstr "Mìøítkový faktor pro vý¹kový model"
#: ../display/d.vect/main.c:213 ../display/d.vect/main.c:223
#: ../display/d.vect/main.c:230 ../display/d.vect/main.c:236
#: ../display/d.vect/main.c:367
msgid "Symbols"
-msgstr "Symboly"
+msgstr ""
#: ../display/d.vect/main.c:217
msgid "Point and centroid symbol"
-msgstr "Bod nebo centroid symbolu"
+msgstr ""
#: ../display/d.vect/main.c:224
msgid "Symbol size"
-msgstr "Velikost symbolu"
+msgstr ""
#: ../display/d.vect/main.c:226
msgid "When used with the size_column option this becomes the scale factor"
@@ -16544,32 +16661,38 @@
#: ../display/d.vect/main.c:279 ../display/d.vect/main.c:289
#: ../display/d.vect/main.c:295 ../display/d.vect/main.c:301
#: ../display/d.vect/main.c:307 ../display/d.vect/main.c:315
+#, fuzzy
msgid "Labels"
-msgstr "©títky"
+msgstr "Úroveò"
#: ../display/d.vect/main.c:248
msgid "Layer number for labels (default: the given layer number)"
-msgstr "Vrstva pro popisování (výchozí: daná vrstva)"
+msgstr ""
#: ../display/d.vect/main.c:254
+#, fuzzy
msgid "Name of column to be displayed"
-msgstr "Název sloupce pro zobrazení"
+msgstr "Název rastrové mapy která bude zobrazena"
#: ../display/d.vect/main.c:260
+#, fuzzy
msgid "Label color"
-msgstr "Barva popiskù"
#: ../display/d.vect/main.c:270
+#, fuzzy
msgid "Label background color"
-msgstr "Barva pozadí popiskù"
#: ../display/d.vect/main.c:280
+#, fuzzy
msgid "Label border color"
-msgstr "Barva rámeèku popiskù"
#: ../display/d.vect/main.c:290
+#, fuzzy
msgid "Label size (pixels)"
-msgstr "Velikost popiskù (v pixelech)"
+msgstr "Velikost ¹títkù (v bodech)"
#: ../display/d.vect/main.c:302
#, fuzzy
@@ -16577,44 +16700,41 @@
msgstr "Kódování znakù"
#: ../display/d.vect/main.c:310
+#, fuzzy
msgid "Label horizontal justification"
-msgstr "Horizontální zarovnání popiskù"
+msgstr "Bodová klasifikace"
#: ../display/d.vect/main.c:318
msgid "Label vertical justification"
-msgstr "Vertikální zarovnání popiskù"
+msgstr ""
#: ../display/d.vect/main.c:325
msgid ""
"Minimum region size (average from height and width) when map is displayed"
msgstr ""
-"Minimální velikost regionu (prùmìr vý¹ky a ¹íøky), kdy¾ je mapa zobrazena"
#: ../display/d.vect/main.c:333
msgid ""
"Maximum region size (average from height and width) when map is displayed"
msgstr ""
-"Maximální velikost regionu (prùmìr vý¹ky a ¹íøky), kdy¾ je mapa zobrazena"
#: ../display/d.vect/main.c:341
msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-msgstr "Získat barvu z atributové tabulky (ve formì RRR:GGG:BBB)"
+msgstr ""
#: ../display/d.vect/main.c:347
msgid ""
"Random colors according to category number (or layer number if 'layer=-1' is "
"given)"
msgstr ""
-"Náhodné barvy podle èísel kategorií (nebo èísla vrstvy, pokud je zadáno "
-"'layer=-1')"
#: ../display/d.vect/main.c:354
msgid "Use values from 'cats' option as feature id"
-msgstr "Pou¾ít hodnoty z 'cats' jako ID prvku"
+msgstr ""
#: ../display/d.vect/main.c:358
msgid "Colorize polygons according to z height"
-msgstr "Zbarvit polygony podle vý¹ky"
+msgstr ""
#: ../display/d.vect/main.c:363
msgid "Use square root of the value of size_column"
@@ -16631,25 +16751,25 @@
"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
"ignored!"
msgstr ""
-"Pøepínaèe '-c' a '-a' nemohou být pou¾ity spolu, ignoruji pøepínaè 'c'!"
#: ../display/d.vect/main.c:439
-#, c-format
+#, fuzzy, c-format
msgid "Unknown color: '%s'"
-msgstr "Neznámá barva: '%s'"
+msgstr "Neznámý barevný po¾adavek '%s'"
#: ../display/d.vect/main.c:454
msgid "'layer' must be > 0 for 'where'."
#: ../display/d.vect/main.c:481
+#, fuzzy
msgid "'layer' must be > 0 for 'cats'."
-msgstr "pøi volbì 'cats' musí být parametr 'layer'> 0"
#: ../display/d.vect/main.c:485
-#, c-format
+#, fuzzy, c-format
msgid "%d errors in cat option"
-msgstr "%d chyb ve volbì cat"
+msgstr "%d chyb ve volbì id"
#: ../display/d.vect/main.c:596
#, fuzzy
@@ -16658,32 +16778,33 @@
#: ../display/d.vect/main.c:638
msgid "Unable to display areas, topology not available"
-msgstr "Nelze zobrazit plochy, topologie není dostupná"
+msgstr ""
#: ../display/d.vect/main.c:643
msgid "Unable to display lines by id, topology not available"
-msgstr "Nelze zobrazit linie podle id, topologie není dostupná"
+msgstr ""
#: ../display/d.vect/main.c:692
+#, fuzzy
msgid "Unable to display topology, not available"
-msgstr "Nelze zobrazit topologii, není dostupná"
+msgstr "Nelze kopírovat tabulku"
#: ../display/d.vect/area.c:69
+#, fuzzy
msgid "Color definition column not specified."
-msgstr "Nebyl zadán sloupec s definicí barvy."
#: ../display/d.vect/area.c:278
-#, c-format
+#, fuzzy, c-format
msgid ""
"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
msgstr ""
-"Chyba ve sloupci s definicí barvy (%s), plocha %d, kategorie %d: barevný "
-"øetìzec [%s]"
#: ../display/d.vect/area.c:284
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column (%s), area %d with cat %d"
-msgstr "Chyba ve sloupci s definicí barvy (%s), plocha %d, kategorie %d"
#: ../display/d.vect/plot1.c:166
#, fuzzy, c-format
@@ -16716,18 +16837,17 @@
msgstr "Nelze naèíst symbol, nemohu zobrazit body"
#: ../display/d.vect/plot1.c:375
-#, c-format
+#, fuzzy, c-format
msgid ""
"Error in color definition column '%s', feature id %d with cat %d: "
"colorstring '%s'"
msgstr ""
-"Chyba ve sloupci s definicí barvy '%s', id prvku %d, kategorie %d: barevný "
-"øetìzec '%s'"
#: ../display/d.vect/plot1.c:383
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column '%s', feature id %d with cat %d"
-msgstr "Chyba ve sloupci s definicí barvy '%s', id prvku %d, kategorie %d"
#: ../display/d.vect/plot1.c:505
#, fuzzy, c-format
@@ -16737,9 +16857,9 @@
#: ../display/d.vect/plot1.c:616
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr "Chyba ve sloupci s definicí barvy '%s':%d prvkù ovlivnìno"
#: ../display/d.vect/plot1.c:621
#, fuzzy, c-format
@@ -16767,13 +16887,14 @@
msgstr "%d prvkù smazáno"
#: ../display/d.vect/attr.c:28
+#, fuzzy
msgid "attrcol not specified, cannot display attributes"
-msgstr "Parametr attrcol nebyl zadán, nemohu zobrazit atributy"
+msgstr "Nelze èíst symbol, nemohu zobrazit body"
#: ../display/d.vect/attr.c:131
-#, c-format
+#, fuzzy, c-format
msgid "No attribute found for cat %d: %s"
-msgstr "®ádné atributy pro kategorii %d nebyly nalezeny: %s"
+msgstr "Nelze získat atributové data pro cat= %d"
#: ../vector/v.sample/main.c:79
msgid "Samples a raster map at vector point locations."
@@ -18925,7 +19046,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "Výstup:"
+msgstr "Vytvoøit 3D výstup"
#: ../vector/v.random/main.c:111
msgid "Maximum z height (needs -z flag or column name)"
@@ -20657,6 +20778,7 @@
#: ../vector/v.out.ogr/args.c:14
#: ../locale/scriptstrings/v.out.gps_to_translate.c:9
+#, fuzzy
msgid "Feature type(s)"
msgstr "Typ prvku"
@@ -20951,9 +21073,8 @@
msgstr "Chyba v pj_do_transform"
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "Vytváøí topologii pro vektorovou mapu GRASSu."
+msgstr ""
#: ../vector/v.hull/main.c:64
msgid "Use all vector points (do not limit to current region)"
@@ -25210,7 +25331,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "Oddìlovaè sloupcù (bodový mód)"
+msgstr "Vypi¹ statistiku ve stylu pro shell skript"
#: ../vector/v.db.connect/main.c:84
msgid "Print all map connection parameters and exit"
@@ -25784,42 +25905,49 @@
#: ../visualization/nviz/src/nvizMain.c:75
msgid "nviz - Visualization and animation tool for GRASS data."
-msgstr "nviz - Vizualizaèní a animaèní nástroj GRASSu"
+msgstr ""
#: ../visualization/nviz/src/nvizMain.c:80
+#, fuzzy
msgid "Name of raster map(s) for Elevation"
-msgstr "Jméno rastrové mapy pro vý¹ku"
+msgstr "Název rastrové mapy pro vlo¾ení do skupiny"
#: ../visualization/nviz/src/nvizMain.c:81
#: ../visualization/nviz/src/nvizMain.c:90
#: ../visualization/nviz/src/nvizMain.c:117
+#, fuzzy
msgid "Raster"
-msgstr "Rastrová mapa"
+msgstr "rastr"
#: ../visualization/nviz/src/nvizMain.c:89
+#, fuzzy
msgid "Name of raster map(s) for Color"
-msgstr "Jméno rastrové mapy pro pokrytí "
#: ../visualization/nviz/src/nvizMain.c:98
+#, fuzzy
msgid "Name of vector lines/areas overlay map(s)"
-msgstr "Vektorové mapy s liniemi/plochami pro zobrazení na terénu"
+msgstr "Jméno existující(ch) rastrové(ých) map(y)"
#: ../visualization/nviz/src/nvizMain.c:99
#: ../visualization/nviz/src/nvizMain.c:108
+#, fuzzy
msgid "Vector"
-msgstr "Vektorová mapa"
+msgstr "vektor"
#: ../visualization/nviz/src/nvizMain.c:107
+#, fuzzy
msgid "Name of vector points overlay file(s)"
-msgstr "Vektorové mapy s body pro zobrazení na terénu"
+msgstr "Jméno vektorové mapy s koncovými body"
#: ../visualization/nviz/src/nvizMain.c:116
+#, fuzzy
msgid "Name of existing 3d raster map"
-msgstr "Jméno existující 3d rastrové mapy"
+msgstr "Název existující 3D rastrové mapy"
#: ../visualization/nviz/src/nvizMain.c:121
msgid "Quickstart - Do not load any data"
-msgstr "Rychlý start - Nenaèítej ¾ádná data"
+msgstr ""
#: ../visualization/nviz/src/nvizMain.c:126
msgid "Exit after completing script launched from the command line"
@@ -25831,23 +25959,26 @@
#: ../visualization/nviz/src/nvizMain.c:137
msgid "Set alternative panel path"
-msgstr "Nastavit alternativní cestu k panelu"
+msgstr ""
#: ../visualization/nviz/src/nvizMain.c:143
msgid "Execute script file at startup"
-msgstr "Proveï skript bìhem startu"
+msgstr ""
#: ../visualization/nviz/src/nvizMain.c:149
msgid "Load previously saved state file"
-msgstr "Naèti pøedchozí ulo¾eny soubor se stavem"
+msgstr ""
#: ../visualization/nviz/src/nviz_init.c:148
+#, fuzzy
msgid "Number of elevation files does not match number of colors files"
-msgstr "Poèet souborù s vý¹kovým modelem neodpovídá poètu souboru s barvami"
+msgstr ""
+"Èíslo sloupce definovaného (%d) nesouhlasí s poètem sloupcù (%d) na vstupu."
#: ../visualization/nviz/src/nviz_init.c:159
+#, fuzzy
msgid "Loading data failed"
-msgstr "Naèítání dat selhalo"
+msgstr "Naèítám data... "
#: ../visualization/nviz2/cmd/main.c:52
msgid "Allows rendering GIS data is a 3D space."
@@ -25870,8 +26001,9 @@
msgstr ""
#: ../visualization/nviz2/cmd/main.c:204
+#, fuzzy
msgid "Unsupported output format"
-msgstr "Nepodporovaný výstupní formát"
+msgstr "Seznam podporovaných výstupních formátù"
#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
#, c-format
@@ -25880,7 +26012,7 @@
#: ../visualization/nviz2/cmd/args.c:49
msgid "Use draw mode for all loaded surfaces"
-msgstr "Po¾ít vykreslovací mód pro v¹echny naètené povrchy"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
@@ -25899,12 +26031,14 @@
#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
#: ../visualization/nviz2/cmd/args.c:106
+#, fuzzy
msgid "Image"
-msgstr "Obrázek"
+msgstr "dpz, obrazové zpracování"
#: ../visualization/nviz2/cmd/args.c:94
+#, fuzzy
msgid "Graphics file format"
-msgstr "Výstupní formát "
+msgstr "Formát vstupního souboru"
#: ../visualization/nviz2/cmd/args.c:104
#, fuzzy
@@ -25912,54 +26046,61 @@
msgstr "©íøka a vý¹ka výstupního obrazu"
#: ../visualization/nviz2/cmd/args.c:121
+#, fuzzy
msgid "Name of raster map(s) for elevation"
-msgstr "Jméno rastrové mapy s vý¹kami"
#: ../visualization/nviz2/cmd/args.c:130
+#, fuzzy
msgid "Elevation value(s)"
-msgstr "Hodnoty vý¹ek"
+msgstr "Chyba v neurèitosti nadmoøských vý¹ek"
#: ../visualization/nviz2/cmd/args.c:137
+#, fuzzy
msgid "Name of raster map(s) for color"
-msgstr "Jméno rastrové mapy pro barvy"
#: ../visualization/nviz2/cmd/args.c:143
+#, fuzzy
msgid "Color value(s)"
-msgstr "Barevné hodnoty"
+msgstr "Barvy"
#: ../visualization/nviz2/cmd/args.c:151
+#, fuzzy
msgid "Name of raster map(s) for mask"
-msgstr "Jméno rastrové mapy pro maskování"
+msgstr "Název rastrového souboru pou¾itého jako maska"
#: ../visualization/nviz2/cmd/args.c:160
+#, fuzzy
msgid "Name of raster map(s) for transparency"
-msgstr "Jméno rastrové mapy pro prùhlednost"
#: ../visualization/nviz2/cmd/args.c:170
msgid "Transparency value(s)"
-msgstr "Prùhlednost"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:178
+#, fuzzy
msgid "Name of raster map(s) for shininess"
-msgstr "Jméno rastrové mapy pro osvìtlení"
+msgstr "Jméno rastrové mapy, obsahující výsledky"
#: ../visualization/nviz2/cmd/args.c:188
msgid "Shininess value(s)"
-msgstr "Hodnoty osvìtlení"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:196
#, fuzzy
msgid "Name of raster map(s) for emission"
#: ../visualization/nviz2/cmd/args.c:206
#, fuzzy
msgid "Emission value(s)"
-msgstr "Eigen hodnoty:"
+msgstr "Postrádám tabulku"
#: ../visualization/nviz2/cmd/args.c:220
msgid "Draw mode"
-msgstr "Mód vykreslení"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
@@ -25967,7 +26108,7 @@
#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
msgid "Draw"
-msgstr "Kreslit"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:232
#, fuzzy
@@ -25980,91 +26121,104 @@
msgstr "Korelace"
#: ../visualization/nviz2/cmd/args.c:254
+#, fuzzy
msgid "Draw style"
-msgstr "Styl vykreslení"
+msgstr "rastr"
#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
msgid "Shading"
-msgstr "stínování"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:275
+#, fuzzy
msgid "Wire color"
-msgstr "Barva sítì"
#: ../visualization/nviz2/cmd/args.c:311
#, fuzzy
msgid "Name of line vector overlay map(s)"
+msgstr "Název vstupní vektorové mapy (A)"
#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
+#, fuzzy
msgid "Vector lines"
-msgstr "Vektorové linie"
+msgstr "vekrotová mapa není 3D"
#: ../visualization/nviz2/cmd/args.c:322
+#, fuzzy
msgid "Vector line width"
-msgstr "©íøka vektorové linie"
+msgstr "©íøka hranice"
#: ../visualization/nviz2/cmd/args.c:331
+#, fuzzy
msgid "Vector line color"
-msgstr "Barva vektorové linie"
+msgstr "vektor, interpolace"
#: ../visualization/nviz2/cmd/args.c:343
-#, fuzzy
msgid "Vector line display mode"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:355
+#, fuzzy
msgid "Vector line height"
-msgstr "Vý¹ka vektorové linie"
+msgstr "Hodnota z-souøadnice pro neznámou vý¹ku"
#: ../visualization/nviz2/cmd/args.c:379
+#, fuzzy
msgid "Name of point vector overlay map(s)"
-msgstr "Jméno vektorové mapy pro pøekryv"
#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
+#, fuzzy
msgid "Vector points"
-msgstr "Vektorové body"
#: ../visualization/nviz2/cmd/args.c:390
msgid "Icon size"
-msgstr "Velikost ikon"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:402
+#, fuzzy
msgid "Icon width"
-msgstr "©íøka ikony"
#: ../visualization/nviz2/cmd/args.c:411
+#, fuzzy
msgid "Icon color"
-msgstr "Barva ikony"
+msgstr " nv barva\n"
#: ../visualization/nviz2/cmd/args.c:423
msgid "Icon marker"
-msgstr "Symbol ikony"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:453
+#, fuzzy
msgid "Viewpoint position (x,y model coordinates)"
-msgstr "Pozice pohledu (x,y souøadnice modelu)"
+msgstr "write_vtk_points: Zapisuji souøadnice bodù"
#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
+#, fuzzy
msgid "Viewpoint"
-msgstr "stanovisko"
+msgstr "Bod"
#: ../visualization/nviz2/cmd/args.c:464
+#, fuzzy
msgid "Viewpoint height (in map units)"
-msgstr "Vý¹ka pohledu (v mapových jednotkách)"
+msgstr "Velikost ikony bodových prvkù (v mapových jednotkách)"
#: ../visualization/nviz2/cmd/args.c:474
msgid "Viewpoint field of view (in degrees)"
-msgstr "Smìr pohledu (ve stupních)"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:486
+#, fuzzy
msgid "Viewpoint twist angle (in degrees)"
-msgstr "otáèení výhledu (ve stupních)"
+msgstr "Úhel anizotropie (ve stupních)"
#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
@@ -26083,16 +26237,17 @@
#: ../visualization/nviz2/cmd/args.c:541
#, fuzzy
msgid "Volume position"
-msgstr "Zdrojová projekce"
+msgstr "Podle_pozice"
#: ../visualization/nviz2/cmd/args.c:552
#, fuzzy
msgid "Volume resolution"
-msgstr "Rozli¹ení"
+msgstr "Neplatné rozli¹ení! [%g]"
#: ../visualization/nviz2/cmd/args.c:563
+#, fuzzy
msgid "Isosurface level"
-msgstr "vý¹ka rovinného povrchu"
+msgstr "Minimální íºroveò isopovrchu"
#: ../visualization/nviz2/cmd/args.c:578
#, fuzzy
@@ -26147,54 +26302,55 @@
#: ../visualization/nviz2/cmd/args.c:679
#, c-format
msgid "At least one <%s> or <%s> required"
-msgstr "Nejménì <%s> nebo <%s> je po¾adován"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
-msgstr "Nesprávný poèet atributù (<%s/%s> %d: <%s> %d)"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:729
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
-msgstr "Nesprávný poèet atributù (<%s/%s> %d: <%s> %d"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
#: ../visualization/nviz2/cmd/args.c:787
#, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
-msgstr "Nesprávný poèet atributù (<%s> %d: <%s> %d)"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:773
#, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
-msgstr "Nesprávný poèet atributù (<%s> %d: <%s> %d"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:799
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
-msgstr "Nesprávný poèet atributù (<%s/%s> %d: <%s> %d, <%s> %d"
+msgstr ""
#: ../visualization/nviz2/cmd/vector.c:179
+#, fuzzy
msgid "Unknown icon marker"
-msgstr "Neznámé oznaèení ikony"
+msgstr "Neznámý typ sloupce"
#: ../visualization/nviz2/cmd/surface.c:71
#, c-format
msgid "Missing topography attribute for surface %d"
-msgstr "Chybí atribut topografie pro povrch %d"
+msgstr ""
#: ../visualization/nviz2/cmd/surface.c:124
-#, c-format
+#, fuzzy, c-format
msgid "Color attribute not defined, using default <%s>"
-msgstr "Barevný atribut nebyl definován, pou¾ívám výchozí <%s>"
+msgstr "Papír '%s' nebyl nalezen, pou¾ívám výchozí"
#: ../visualization/nviz2/cmd/surface.c:201
-#, c-format
+#, fuzzy, c-format
msgid "Surface id %d doesn't exist"
-msgstr "Povrch id %d neexistuje"
+msgstr "Vybraný kanál (%d) neexistuje"
#: ../visualization/nviz2/cmd/surface.c:248
#: ../visualization/nviz2/cmd/surface.c:255
@@ -26205,7 +26361,7 @@
#: ../visualization/nviz2/cmd/volume.c:72
#, fuzzy, c-format
msgid "Error tokenize '%s'"
-msgstr "Chyba pøi ètení mapy '%s'"
+msgstr "Chyba pøi ètení ASCII souboru: '%s'"
#: ../visualization/nviz2/cmd/volume.c:79
#, fuzzy, c-format
@@ -26215,13 +26371,13 @@
#: ../visualization/nviz2/cmd/volume.c:85
#, fuzzy, c-format
msgid "Unable to add isosurface (volume set %d)"
-msgstr "Nelze pøidat rovinou plochu"
+msgstr "Nelze èíst vstup ze standardního vstupu"
#: ../visualization/nviz2/cmd/volume.c:93
#: ../visualization/nviz2/cmd/volume.c:99
-#, c-format
+#, fuzzy, c-format
msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
-msgstr ""
#: ../visualization/ximgview/main.c:84
msgid "Unable to get window attributes"
@@ -27098,7 +27254,6 @@
msgid ""
"Displays spectral response at user specified locations in group or images."
msgstr ""
-"Zobrazí spektrální odrazivost na u¾ivatelem zadaných mapách ve skupinì snímkù"
#: ../locale/scriptstrings/i.spectral_to_translate.c:2
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
@@ -27132,15 +27287,17 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:5
msgid "Group input"
-msgstr "Vstup pro skupinu"
+msgstr ""
#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+#, fuzzy
msgid "Raster input maps"
-msgstr "Vstupní rastrové mapy"
+msgstr "Nelze zavøít vstupní mapu"
#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#, fuzzy
msgid "Write output to PNG image"
-msgstr "Zapsat výstup jako soubor PNG"
+msgstr "Rozsah výstupních dat"
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
#, fuzzy
@@ -27148,8 +27305,9 @@
msgstr "Pøesnost souøadnic"
#: ../locale/scriptstrings/i.spectral_to_translate.c:9
+#, fuzzy
msgid "Label with coordinates instead of numbering"
-msgstr "Oznaè souøadnicemi místo èíslováním"
+msgstr "Pou¾ít mapové souøadnice namísto souøadnic xyz"
#: ../locale/scriptstrings/i.spectral_to_translate.c:10
#, fuzzy
@@ -27167,7 +27325,7 @@
#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Poèítá lineární regresi pro dvì rastrové mapy: y = a + b*x"
+msgstr ""
#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
#, fuzzy
@@ -27177,19 +27335,17 @@
#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
msgid "Map for x coefficient"
-msgstr "Mapa koeficientu x"
+msgstr ""
#: ../locale/scriptstrings/r.regression.line_to_translate.c:7
msgid "Map for y coefficient"
-msgstr "Mapa koeficientu y"
+msgstr ""
#: ../locale/scriptstrings/r.regression.line_to_translate.c:8
msgid ""
"ASCII file for storing regression coefficients (output to screen if file not "
"specified)."
msgstr ""
-"Soubor ASCII, kam se mají ulo¾it koeficienty regrese (výstup na obrazovku, "
-"pokud není zadán)."
#: ../locale/scriptstrings/r.buffer_to_translate.c:1
#, fuzzy
@@ -27201,8 +27357,9 @@
"hodnotou."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+#, fuzzy
msgid "Import E00 file into a vector map."
-msgstr "Importuje soubory ve formátu E00 jako vektorovou mapu."
+msgstr "Importuje star¹í verze GRASS vektorových map."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
msgid "Verbose mode"
@@ -27210,11 +27367,12 @@
#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
msgid "E00 file"
-msgstr "soubor E00"
+msgstr ""
#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
+#, fuzzy
msgid "Input type point, line or area"
-msgstr "Typ vstupu linie nebo plocha"
+msgstr "Vyberte typ: linie nebo plocha"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:7
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:6
@@ -27223,16 +27381,18 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:6
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+#, fuzzy
msgid "Name for output vector map"
-msgstr "Název výstupní vektorové vrstvy"
+msgstr "Název výstupní vektorové vrstvy"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
+#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
msgstr ""
-"Vytvoøí rastrovou mapu plochy pøi zadání ponoru (sklonu), expozice (azimut) "
-"a jednoho bodu."
+"Vytvoøí rastrovou mapu a bodovou vektorovou mapu obsahující náhodnì "
+"rozmístìné body."
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -27241,32 +27401,37 @@
msgstr "Výbìr"
#: ../locale/scriptstrings/r.plane_to_translate.c:4
+#, fuzzy
msgid "Name of raster plane to be created"
-msgstr "Jméno rastru plochy, který má být vytvoøen"
#: ../locale/scriptstrings/r.plane_to_translate.c:5
msgid "Dip of plane. Value must be between -90 and 90 degrees"
-msgstr "Spád plochy. Hodnota musí být mezi -90 a 90 stupni"
+msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:6
msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-msgstr "Úhel plochy. Hodnota musí být mezi 0 a 360 stupni"
+msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:7
+#, fuzzy
msgid "Easting coordinate of a point on the plane"
-msgstr "Souøadnice x bodu na plo¹e"
+msgstr "Východní souøadnice (bod zájmu, výchozí: støed mapy)"
#: ../locale/scriptstrings/r.plane_to_translate.c:8
+#, fuzzy
msgid "Northing coordinate of a point on the plane"
-msgstr "Souøadnice y bodu na plo¹e"
+msgstr "Severní souøadnice (bod zájmu, výchozí: støed mapy)"
#: ../locale/scriptstrings/r.plane_to_translate.c:9
+#, fuzzy
msgid "Elevation coordinate of a point on the plane"
-msgstr "Souøadnice z bodu na plo¹e"
+msgstr "Souøadnice bodu pro zastavení (V,S)"
#: ../locale/scriptstrings/r.plane_to_translate.c:10
+#, fuzzy
msgid "Type of the raster map to be created"
-msgstr "Typ rastru, který bude vytvoøen"
+msgstr "Název rastrové mapy, její¾ mìøítko má být zmìnìno."
#: ../locale/scriptstrings/m.proj_to_translate.c:1
#, fuzzy
@@ -27288,12 +27453,11 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:24
#, fuzzy
msgid "Files & format"
-msgstr "Formát tabulky"
+msgstr "Formát"
#: ../locale/scriptstrings/m.proj_to_translate.c:6
msgid "Output coordinate file (omit to send to stdout)"
msgstr ""
-"Výstup souøadnicového souboru (vynechává se pøi výpisu na standardní výstup)"
#: ../locale/scriptstrings/m.proj_to_translate.c:8
#, fuzzy
@@ -27305,8 +27469,9 @@
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#, fuzzy
msgid "Input projection parameters (PROJ.4 style)"
-msgstr "Parametry vstupní projekce (ve stylu PROJ.4)"
+msgstr "* Vstupní projekce pro GCP tabulku: %s"
#: ../locale/scriptstrings/m.proj_to_translate.c:12
#: ../locale/scriptstrings/m.proj_to_translate.c:14
@@ -27317,25 +27482,23 @@
msgstr "Pøevádím..."
#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#, fuzzy
msgid "Output projection parameters (PROJ.4 style)"
-msgstr "Parametry výstupní projekce (ve stylu PROJ.4)"
+msgstr "á Výstupní projekce pro GCP tabulk: %s"
#: ../locale/scriptstrings/m.proj_to_translate.c:15
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr "Jako vstup pou¾ij LL WGS84 a aktuální location jako výstupní projekci"
+msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:17
msgid "Use current location as input and LL WGS84 as output projection"
-msgstr "Pou¾ij aktuální location jako vstup a LL WGS84 jako výstupní projekci"
+msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:19
-#, fuzzy
msgid ""
"Output long/lat in decimal degrees, or other projections with many decimal "
"places"
msgstr ""
-"Výstup lat/long v decimálních stupních nebo jiné projekce s mnoha "
-"desetinnými místy"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
#, fuzzy
@@ -27423,19 +27586,17 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-"Otestuj ovladaè databáze, databáze musí existovat a nastavena pomocí db."
-"connect"
#: ../locale/scriptstrings/db.test_to_translate.c:4
+#, fuzzy
msgid "Test name"
-msgstr "Jméno testu"
+msgstr "Název písma"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
msgstr ""
-"Vytvoøí dla¾dice zdrojové projekce pro pou¾ití v cílovém regionu a projekci."
#: ../locale/scriptstrings/r.tileset_to_translate.c:3
#, fuzzy
@@ -27443,54 +27604,61 @@
msgstr "rastr, dla¾dice"
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+#, fuzzy
msgid "Produces shell script output"
-msgstr "Výstup ve formátu pro shell skript"
+msgstr "Vypi¹ výsledek ve stylu pro shell skript"
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
msgid "Produces web map server query string output"
-msgstr "Vytvoøí øetìzec urèený pro mapový server"
+msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+#, fuzzy
msgid ""
"Name of region to use instead of current region for bounds and resolution"
msgstr ""
-"Jméno regionu pou¾itého místo aktuálního regionu pro okraje a rozli¹ení"
+"Rozli¹ení rastrové mapy expozice je rùzné od aktuálního rozli¹ení regionu"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#, fuzzy
msgid "Source projection"
+msgstr "raster, projekce"
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+#, fuzzy
msgid "Conversion factor from units to meters in source projection"
-msgstr "Pøevodní faktor z jednotek na metry ve zdrojové projekci"
+msgstr "Pou¾ívám konverzní faktor %f, krok=%f"
#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+#, fuzzy
msgid "Destination projection, defaults to this location's projection"
-msgstr "Cílová projekce, výchozí je projekce aktuální location"
+msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
-msgstr "Maximální poèet sloupcù dla¾dic ve vstupní projekci"
+msgstr "Poèet sloupcù se li¹í."
#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+#, fuzzy
msgid "Maximum number of rows for a tile in the source projection"
-msgstr "Maximální poèet øádkù pro dla¾dice ve zdrojové projekci"
+msgstr "Minimální poèet øádkù, který má být uchován v pamìti je 1"
#: ../locale/scriptstrings/r.tileset_to_translate.c:13
+#, fuzzy
msgid "Number of cells tiles should overlap in each direction"
-msgstr "Poèet dla¾dic by mìl být stejný v obou smìrech"
+msgstr "Poèet úrovní, které budou pou¾ity pro ka¾dou souèást"
#: ../locale/scriptstrings/r.tileset_to_translate.c:15
+#, fuzzy
msgid "Verbosity level"
-msgstr "Úroveò upovídanosti"
+msgstr "Úroveò hladiny"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
msgid ""
"Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
-"Broveyova transformace pro slouèení multispektrálních kanálù s "
-"panchromatickými kanály vy¹¹ího rozli¹ení"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
msgid "fusion"
@@ -27502,25 +27670,26 @@
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
msgid "LANDSAT sensor"
-msgstr "Snímaè LANDSAT"
+msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
msgid "Sensor"
-msgstr "Smínaè"
+msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
msgid "QuickBird sensor"
-msgstr "Snímaè QuickBird"
+msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
msgid "SPOT sensor"
-msgstr "Snímaè SPOT"
+msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
+#, fuzzy
msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "Vstupní rastrová mapa (zelená: tm2 | qbird_green | spot1)"
+msgstr "Název vstupní rastrové mapy(green-zelená)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
#, fuzzy
@@ -27533,12 +27702,14 @@
msgstr "Vstupní rastrová mapa (støední infra èervená: tm5 | qbird_red | spot3)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:14
+#, fuzzy
msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
-msgstr "Vstupní rastrová mapa (etmpan | qbird_pan | spotpan)"
+msgstr "Jméno vstupního rastrového souboru (obraz fft, reálná èást)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:15
+#, fuzzy
msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "Pøedpona výstupního rastru (napø. 'brov')"
+msgstr "Název výstupní rastrové mapy(green-zelená)"
#: ../locale/scriptstrings/g.extension_to_translate.c:1
msgid "Tool to maintain the extensions in local GRASS installation."
@@ -27604,7 +27775,7 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr "Vytiskne graf korelace mezi datovými vrstvami (v párech)"
+msgstr ""
#: ../locale/scriptstrings/d.correlate_to_translate.c:3
#: ../locale/scriptstrings/d.polar_to_translate.c:3
@@ -27613,8 +27784,9 @@
msgstr "zobrazení, diagram"
#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#, fuzzy
msgid "raster input map"
-msgstr "vstupní rastrová mapa"
+msgstr "rastr, import"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
#, fuzzy
@@ -27639,75 +27811,79 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:1
msgid "Blends color components of two raster maps by a given ratio."
-msgstr "Spojí barevné èásti dvou rastrových map zadaným pomìrem."
+msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#, fuzzy
msgid "Name of first raster map for blending"
-msgstr "Jméno nového rastru pro mí¹ení"
+msgstr "Název první rastrové mapy"
#: ../locale/scriptstrings/r.blend_to_translate.c:4
+#, fuzzy
msgid "Name of second raster map for blending"
-msgstr "Jméno druhého rastru pro smí¹ení"
+msgstr "Název druhé rastrové mapy"
#: ../locale/scriptstrings/r.blend_to_translate.c:5
msgid "Base name for red, green and blue output maps containing the blend"
msgstr ""
-"Základní jméno map pro èervenou, zelenou a modrou výstupní mapu spojení"
#: ../locale/scriptstrings/r.blend_to_translate.c:6
msgid "Percentage weight of first map for color blending"
-msgstr "Procenta váhy první mapy barevného spojení"
+msgstr ""
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)."
msgstr ""
-"Reklasifikuje rastrovou mapu vìt¹í nebo men¹í ne¾ u¾ivatelem zadané hranièní "
-"velikosti ploch (v hektarech)"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr "Volba men¹í hodnota, která nastaví <= limit velikosti plochy [hektary]"
+msgstr ""
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr "Volba vìt¹í hodnota, která nastaví >= limit velikosti plochy [hektary]"
+msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-"Ulo¾í hodnoty rastrové mapy na pozicích bodù pøekryvné vektorové mapy do "
-"atributové tabulky."
+"Ulo¾í hodnoty rastru pod vektorovými body do jejich atributové tabulky."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
#, fuzzy
msgid "Vector map to modify"
-msgstr "Bodová mapa, která bude zmìnìna"
+msgstr "Vektorová mapa pro pøekrytí"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#, fuzzy
msgid "Layer in the vector to be modified"
-msgstr "Vektorová vrstva, která bude mìnìna"
+msgstr "Bodová vektorová mapa musí být specifikována"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
msgid "Column to be updated with the query result"
-msgstr "Sloupec který má být aktualizován výsledky dotazu"
+msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+#, fuzzy
msgid "Vector map to be queried"
-msgstr "Vektorová mapa, její¾ hodnoty budou vy¹etøovány"
+msgstr "Rastrová mapa, která bude dotazována"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+#, fuzzy
msgid "Layer of the query vector containing data"
-msgstr "Vrstva dotazovaného vektoru obsahující data"
+msgstr "Vstupní mapa obsahující linie"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+#, fuzzy
msgid "Column to be queried"
-msgstr "Sloupec vektorové mapy, ze kterého se budou brát hodnoty"
+msgstr "|Sloupec musí být èíselnéh typu"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
+#, fuzzy
msgid "Maximum query distance in map units"
-msgstr "Maximání dotazované vzdálenost v mapových jenotkách"
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
#, fuzzy
@@ -27716,15 +27892,16 @@
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
msgid "SRTM input tile (file without .hgt.zip extension)"
-msgstr "Vstupní dla¾dice SRTM (soubor bez koncovky hgt nebo zip)"
+msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr "Výstupní rastrová mapa (výchozí: vstup dla¾dice)"
+msgstr "Jméno výstupní rastrové mapy (výchozí: jméno vstupní mapy)"
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr "Vstup je 1-arcsec dla¾dice (výchozí: 3-arcsec)"
+msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:1
#, fuzzy
@@ -27732,19 +27909,21 @@
msgstr "Vypí¹e íºdaje o geometrii vektorové mapy."
#: ../locale/scriptstrings/v.report_to_translate.c:5
+#, fuzzy
msgid "Reverse sort the result"
-msgstr "Obrácené øazení výsledkù"
+msgstr "obrácený výbìr"
#: ../locale/scriptstrings/v.report_to_translate.c:6
msgid "Sort the result"
-msgstr "Seøadit výsledky"
+msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:7
#: ../locale/scriptstrings/v.out.gps_to_translate.c:8
#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+#, fuzzy
msgid "Name of input vector map"
-msgstr "Název vstupní vektorové vrstvy"
+msgstr "Jméno vstupní 2D vektorové mapy"
#: ../locale/scriptstrings/v.report_to_translate.c:8
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
@@ -27769,27 +27948,28 @@
"èíslo urøuje která tabulka bude pou¾ita."
#: ../locale/scriptstrings/v.report_to_translate.c:11
+#, fuzzy
msgid "Value to calculate"
-msgstr "Hodnota, která se má spoèítat"
+msgstr "Hodnota pro aktualizaci"
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
msgid ""
"Allows to update a column in the attribute table connected to a vector map."
msgstr ""
-"Umo¾ní pøiøadit novou hodnotu sloupci v atributové tabulce pøipojené k "
-"zadané mapì."
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+#, fuzzy
msgid "Vector map to edit the attribute table for"
-msgstr "Vektorová mapa, její¾ atributová tabulka má být editována"
+msgstr "vektor, rastr, tabulka atributù"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid "Layer to which the table to be changed is connected"
-msgstr "Vrstva ke které je zmìnìná tabulka pøipojena"
+msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#, fuzzy
msgid "Column to update"
-msgstr "Sloupeèek, který má být aktualizován"
+msgstr "Typ sloupce není podporován"
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
#, fuzzy
@@ -27800,24 +27980,24 @@
"'uvozeny')"
#: ../locale/scriptstrings/v.db.update_to_translate.c:9
+#, fuzzy
msgid "Column to query"
-msgstr "Sloupeèek, jeho¾ hodnoty mají být zji¹tìny"
#: ../locale/scriptstrings/v.db.update_to_translate.c:10
msgid ""
"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
"col2>1)"
msgstr ""
-"Podmínka SQL WHERE ov¹em bez slova 'where' (napø. 'cat=1' nebo 'sloup1/"
-"sloup2>1')"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
msgid "Displays a raster map and its legend on a graphics window"
-msgstr "Zobrazí rastrovou mapu spolu s legendou"
+msgstr ""
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+#, fuzzy
msgid "Omit entries with missing label"
-msgstr "Pøeskoèit záznamy bez popisku"
+msgstr "v tabulce existuje %d kategorií "
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
#, fuzzy
@@ -27825,12 +28005,14 @@
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+#, fuzzy
msgid "Number of lines to appear in the legend"
-msgstr "Poèet øádkù v legendì"
+msgstr "Poèet iterací"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
+#, fuzzy
msgid "Name of raster map to generate legend from"
-msgstr "Název rastrové mapy, která má být pou¾ita pro legendu"
+msgstr "Název rastrové mapy, která má být pou¾ita pro <%s>"
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
msgid ""
@@ -27872,24 +28054,24 @@
msgstr "Zobraz nápovìdu"
#: ../locale/scriptstrings/g.manual_to_translate.c:5
+#, fuzzy
msgid "Display index"
-msgstr "Zobrazit obsah"
+msgstr "zobrazení"
#: ../locale/scriptstrings/g.manual_to_translate.c:6
msgid "Display as MAN text page instead of HTML page in browser"
msgstr ""
-"Zobrazit jako textovou manuálovou stránku MAN místo formátu HTML v prohlí¾eèi"
#: ../locale/scriptstrings/g.manual_to_translate.c:7
+#, fuzzy
msgid "Manual entry to be displayed"
-msgstr "Záznam manuálu, který chcete zobrazit"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
+#, fuzzy
msgid ""
"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"Pøevede v¹echny staré vektorové mapy (GRASS < 5.7) v bodovém forátu (sites) "
-"na vektorovou mapu."
+msgstr "PøevedeGRASS bodovou vrstvu na vektorovou mapu."
#: ../locale/scriptstrings/r.mask_to_translate.c:1
#, fuzzy
@@ -27922,24 +28104,28 @@
msgstr "Vymazávám existující MASKu (jiné volby budou ignorovány)"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr "Znovu pøipojí vektory k nové databázi."
+msgstr "Odstraòuji databázi."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
+#, fuzzy
msgid "Name of old database"
-msgstr "Jméno staré databáze"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#, fuzzy
msgid "Name of new database"
-msgstr "Jméno nové databáze"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
msgid "Old schema"
-msgstr "Staré schéma"
+msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
msgid "New schema"
-msgstr "Nové schéma"
+msgstr "Schéma databáze."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
@@ -27952,11 +28138,11 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
msgid "Input ASTER image to be georeferenced & rectified"
-msgstr "Vstupní snímek ASTER urèení ke georeferencingu a rektifikaci"
+msgstr ""
#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr "Typ souboru ASTER (Level 1A, Level 1B, nebo pøíbuzný DEM)"
+msgstr ""
#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
#, fuzzy
@@ -27978,22 +28164,23 @@
msgstr "Pøepi¹ existující MASKu"
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Pøejmenuje sloupec v atributové tabulce pøipojené k zadané vektorové mapì."
+msgstr "Nelze kopírovat atributovou tabulku do vektorové mapy <%s>"
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec pøejmenován"
+msgstr "Jméno vstupní vektorové bodové mapy"
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:6
msgid "Layer where to rename column"
-msgstr "Vrstva, ve které bude sloupec pøejmenován"
+msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:7
msgid "Old and new name of the column (old,new)"
-msgstr "Staré a nové jméno slupce (staré,nové)"
+msgstr ""
#: ../locale/scriptstrings/v.colors_to_translate.c:1
#, fuzzy
@@ -28007,7 +28194,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:6
#, fuzzy
msgid "Name of column containing numeric data"
-msgstr "Jméno sloupce obsahujícího numerická data"
+msgstr "Jméno sloupce obsahujícího souøadnici x"
#: ../locale/scriptstrings/v.colors_to_translate.c:7
#, fuzzy
@@ -28015,8 +28202,9 @@
msgstr "Název sloupce s barvami pro zobrazení"
#: ../locale/scriptstrings/v.colors_to_translate.c:9
+#, fuzzy
msgid "Manually set range (min,max)"
-msgstr "Ruènì zadaný rozsah hodnot (min,max)"
+msgstr "Rozsah celoèíselných hodnot: min,max"
#: ../locale/scriptstrings/v.colors_to_translate.c:12
#, fuzzy
@@ -28033,25 +28221,31 @@
msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+#, fuzzy
msgid "Exports attribute tables into various formats."
-msgstr "Exportuje atributové tabulky v rùzných formátech."
+msgstr ""
+"Exportuje GRASS rastrové mapy do jednoho z formátù podporovaných knihovnou "
+"GDAL."
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+#, fuzzy
msgid "GRASS table name"
-msgstr "Jméno vstupní tabulky GRASS"
+msgstr "Jméno vstupní tabulky"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
msgid "Table file to be exported or DB connection string"
-msgstr "Tabulka pro export nebo textový øetìzec databázového spojení"
+msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+#, fuzzy
msgid "Table format"
+msgstr "Formát"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
+#, fuzzy
msgid "Name for output table"
-msgstr "Název výstupní tabulky"
#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
msgid "Import ASCII x,y[,z] coordinates as a series of lines."
@@ -28073,39 +28267,42 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#, fuzzy
msgid "Field separator"
-msgstr "Oddìlovaè sloupcù"
+msgstr "Výstupní oddìlovaè sloupcù"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
msgid ""
"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
msgstr ""
-"Exportuj vektorovou mapu do GPS pøijímaèe nebo do formátu, který podporuje "
-"GpsBabel."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
msgid "GPS"
msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:5
+#, fuzzy
msgid "Export as waypoints"
-msgstr "Exportovat jako waypoints"
+msgstr "Exportuj linie jako polygony"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:6
+#, fuzzy
msgid "Export as routes"
-msgstr "Exportivat jako cesty"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:7
msgid "Export as tracks"
-msgstr "Exportovat jako tracks"
+msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:10
+#, fuzzy
msgid "Name for output file or GPS device"
-msgstr "Název výstupního souboru nebo zaøízení GPS"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:11
+#, fuzzy
msgid "GpsBabel supported output format"
-msgstr "GpsBabel podporované výstupní formáty"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:13
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
@@ -28114,8 +28311,6 @@
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
-"Jedna vektorová mapa m¾e být pøipojena k více databázovým tabulkám. toto "
-"èíslo urøuje která tabulka bude pou¾ita."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:14
#: ../locale/scriptstrings/v.out.gps_to_translate.c:17
@@ -28126,26 +28321,29 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Podmínka SQL WHERE ov¹em bez slova 'where'"
+msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:16
msgid "Example: income < 1000 and inhab >= 10000"
-msgstr "Pøíklad: income < 1000 and inhab >= 10000"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
+#, fuzzy
msgid "Displays thematic vector map"
-msgstr "Zobrazí tématickou vektorovou mapu"
+msgstr "Pøekrytí dvo vektorových map."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
+#, fuzzy
msgid "display, vector, thematic, legend"
-msgstr "zobrazení, vektor, tématicky, legenda"
+msgstr "zobrazení"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
+#, fuzzy
msgid "Files"
-msgstr "Soubory"
+msgstr "Linie"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
@@ -28157,150 +28355,148 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
msgid "Theme"
-msgstr "Téma"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
+#, fuzzy
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Název sloupce atributu, který má být pou¾it pro tématické zobrazení (musí "
-"být èíselný)"
+msgstr "Název sloupce atributu, který má být pou¾it pro ¹títky"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
+#, fuzzy
msgid "Type of thematic display"
-msgstr "Typ tématu"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
msgid "Thematic divisions of data for display"
-msgstr "Zpùsob dìlení celkového rozsahu dat na intervaly pøi zobrazení"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
msgid "Break points for custom breaks option"
-msgstr "Hodnoty rozdìlení (break points)."
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ". Hodnoty oddìlené mezerou (0 10 20 30 ...)"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
+#, fuzzy
msgid "Vector point icon for point data"
-msgstr "Ikona pro bodová data"
+msgstr "Vektorová mapa s bodovými vzorky"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
+#, fuzzy
msgid "Icon size for point data"
-msgstr "Velikost ikony pro bodová data"
+msgstr "Zaokrouhli data s plovoucí desetinnou èárkou"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
msgid "Minimum icon size/line width for graduated points/lines)"
msgstr ""
-"Minimální velikost ikony nebo ¹íøka linie pro zvìt¹ující se body a linie"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
msgid "Maximum icon size/line width for graduated points and lines"
msgstr ""
-"Maximální velikost ikony nebo ¹íøka linie pro zvìt¹ující se body a linie"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
+#, fuzzy
msgid "Number of classes for interval theme (integer)"
-msgstr "Poèet tøíd pro intervalové téma (celé èíslo)"
+msgstr "Poèet tøid "
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
msgid "Color scheme for graduated color mapping"
-msgstr "Barevné schéma pro rostoucí barevné mapování"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
msgid "Select 'single_color' for graduated point/line display"
msgstr ""
-"Vyberte 'single_color' (jednu barvu)pro zobrazení gradujících bodù/linií"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
+#, fuzzy
msgid "Color for graduated points map"
-msgstr "Barva rostoucích bodù mapy"
+msgstr "Tabulka barev pro <%s> byla aktualizována"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
msgstr ""
-"Jména barev definovaných GRASSem nebo triplet R:G:B. Nastaví barevné téma na "
-"jednobarevné."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
msgid "Color for graduated lines or point/area outlines"
-msgstr "BArva pro rostoucí linie nebo body/plochy"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
msgstr ""
-"Jjména barev definovaných GRASSem nebo triplet R:G:B. Nastaví barevné téma "
-"na jednobarevné."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
msgid "Beginning color for custom color gradient"
-msgstr "Poèáteèní barva pro vlastní barevný gradient. "
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
msgid "Must be expressed as R:G:B triplet"
-msgstr "Musí být zadána jako trojce R:G:B."
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
+#, fuzzy
msgid "Ending color for custom color gradient"
-msgstr "Koncová barva pro vlastní barevný gradient."
+msgstr "Mìøítkový faktor souøadnic x"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
#, fuzzy
msgid "Misc"
-msgstr "Rùzné"
+msgstr "Metrický"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
msgid "Select x11 display monitor for legend"
-msgstr "Vybrat pro zobrazení legendy monitor x1"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
msgid "Save thematic map commands to group file for GIS Manager"
msgstr ""
-"Ulo¾ pøíkazy pro vytvoøení tématické mapy do souboru skupiny pro GIS Manager"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr "Koøen názvu souborù psmap pro aktuální adresáø"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
msgid "If not set, no psmap instruction files will be created)"
-msgstr "Pokud není zadáno, nevytvoøí se ¾ádný soubor s instrukcemi)"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Name of group file where thematic map commands will be saved"
msgstr ""
-"Jméno souboru skupiny kam budou ulo¾eny pøíkazy pro tématické zobrazení"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
msgid "Create graphic legend in x11 display monitor"
-msgstr "Vytvoøit grafickou legendu v grafickém monitoru x1"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
msgid "Only draw fills (no outlines) for areas and points"
-msgstr "Kreslit pouze výplnì (bez hranic) ploch a bodù"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
msgid "Update color values to GRASSRGB column in attribute table"
-msgstr "Ulo¾ barevné hodnoty do tabulky do sloupeèku GRASSRGB"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr "Výstupní legenda pro GIS Manager (pouze pøi pou¾ití ve skriptech)"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:62
msgid "Use math notation brackets in legend"
-msgstr "Pou¾ij matematický zápis závorek v legendì"
+msgstr ""
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+#, fuzzy
msgid "Drops an attribute table."
-msgstr "Vyjmout atributovou tabulku."
+msgstr "Zkopíruj také atributovou tabulku."
#: ../locale/scriptstrings/db.droptable_to_translate.c:5
+#, fuzzy
msgid "Table to drop"
-msgstr "Tabulka k vyjmutí"
+msgstr "Nelze vyjmout tabulku: %s"
#: ../locale/scriptstrings/r.grow_to_translate.c:3
msgid "radius is in map units rather than cells"
@@ -28311,8 +28507,6 @@
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
msgstr ""
-"Importuje US-NGA GEOnet jmenný server (GNS) soubory o státech do vektorové "
-"bodové mapy mapy GRASSu"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -28321,7 +28515,7 @@
#: ../locale/scriptstrings/v.in.gns_to_translate.c:5
msgid "Uncompressed GNS file from NGA (with .txt extension)"
-msgstr "Rozbalený soubor GNS z NGA (s koncovkou .txt)"
+msgstr ""
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
@@ -28334,7 +28528,7 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
msgid "Continue if upload column(s) already exist"
-msgstr "Pokraèuj, i kdy¾ sloupec pro ulo¾ení dat ji¾ existuje"
+msgstr ""
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
#, fuzzy
@@ -28347,25 +28541,23 @@
msgstr "Název rastrové mapy, na kterém se bude statistika poèítat"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:12
+#, fuzzy
msgid "Column prefix for new attribute columns"
-msgstr "Pøedpona v názvu nových sloupeèkù"
+msgstr "Mìøítkový faktor pro hodnoty atributù"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
msgid "Uncompressed geonames file from (with .txt extension)"
+msgstr ""
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
msgid ""
"Export a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
-"Exportuje rastrovou mapu do textového souboru jako hodnoty x,y,z dle støedù "
-"bunìk."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
#, fuzzy
@@ -28373,26 +28565,31 @@
msgstr "Importuje vektory ve formátu Mapgen nebo Matlab do GRASSu"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+#, fuzzy
msgid "Input map is in Matlab format"
-msgstr "Vstupní mapa je ve formátu Matlab"
+msgstr "Oblast neobsahuje ¾ádná data"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr "Vytvoøí 3D vektorovou bodovou mapu ze tøí sloupcových dat Matlab"
+msgstr ""
+"Vytvoøí novou vektorovou (bodovou) mapu na základì databázové takulky "
+"obsahující souøadnice."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+#, fuzzy
msgid "Name of input file in Mapgen/Matlab format"
-msgstr "Jméno vstupního souboru ve formátu Mapgen/Matlab"
+msgstr "Název vstupní bodové vektorové vrstvy"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
+#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Jméno nového vektorového souboru (vynechává se pro zobrazení na standardní "
-"výstup)"
+msgstr "Jméno výstupního vektoru pro zarovnané body bystøin"
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+#, fuzzy
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Pøebuduje topologii v¹ech vektorových map v aktuálním mapsetu."
+msgstr "Nelze editovat vektorovou vrstvu ulo¾enou v jiném mapsetu."
#: ../locale/scriptstrings/v.build.all_to_translate.c:2
msgid "vector, topology"
@@ -28400,7 +28597,7 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr "Automatické vyvá¾ení barev pro snímky z dru¾ice LANDSAT."
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
#, fuzzy
@@ -28409,55 +28606,57 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
msgid "LANDSAT red channel"
-msgstr "èervený kanál LANDSAT"
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
msgid "LANDSAT green channel"
-msgstr "zelený kanál LANDSAT"
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
msgid "LANDSAT blue channel"
-msgstr "modrý kanál LANDSAT"
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
msgid "Cropping intensity (upper brightness level)"
-msgstr "Oøezávám intenzitu (horní hodnoty svìtlosti)"
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
msgid "Extend colors to full range of data on each channel"
-msgstr "Na ka¾dém kanálu roztáhne barvy po celé ¹kále "
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:10
msgid "Preserve relative colors, adjust brightness only"
-msgstr "Zachovej relativní barvy, hýbej pouze se svìtlostí"
+msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
+#, fuzzy
msgid "Reset to standard color range"
-msgstr "Nastav zpìt na standardní barevný rozsah"
+msgstr "nelze exportovat dlouhou tabulku barev"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
-msgstr "Pøekrýt barevnou rastrovou mapy pøes stínovaný reliéf s pou¾itím d.his"
+msgstr ""
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
+#, fuzzy
msgid "Name of shaded relief or aspect map"
-msgstr "Jméno mapy stínovaného reliéfu nebo expozice"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
+#, fuzzy
msgid "Name of raster to drape over relief map"
-msgstr "Jméno rastru pro pøeta¾ení pøes mapu reliéfu"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+#, fuzzy
msgid "Percent to brighten"
-msgstr "Procenta zesvìtlení"
+msgstr "Procentuální konvergence"
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
msgstr ""
-"Pøidává jeden nebo více sloupeèkù k atributové tabulce pøipojené k zadané "
-"vektorové mapì."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
#, fuzzy
@@ -28483,25 +28682,28 @@
"v¹echny podporují VARCHAR(), INT, DOUBLE PRECISION a DATE)"
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+#, fuzzy
msgid "Drops a column from selected attribute table"
-msgstr "Sma¾e sloupeèky z vybrané atributové tabulky"
+msgstr "Nevytváøet atributovou tabulku"
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:5
+#, fuzzy
msgid "Table from which to drop attribute column"
-msgstr "Tabulka, ze které mude sloupeèek vymazán"
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:6
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:7
+#, fuzzy
msgid "Name of the column"
-msgstr "Jméno sloupce"
+msgstr "Poèet sloupcù"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
msgid "Downloads and imports data from WMS servers."
-msgstr "Stáhne a importuje data z WMS serverù."
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
msgid "wms"
-msgstr "wms"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
@@ -28517,91 +28719,92 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
+#, fuzzy
msgid "Request"
-msgstr "®ádost"
+msgstr "Po¾adováno"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
msgid "Skip to downloading (to resume downloads faster)"
-msgstr "Pøeskoè ke stahování (aby bylo stahování rychlej¹í)"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
msgid "Download"
-msgstr "Stahuji"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
msgid "Don't request transparent data"
-msgstr "Nevy¾aduji prùhledná data"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
msgid "Clean existing data out of download directory"
-msgstr "Vyma¾ existující data z adresáøe ke sta¾ení"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
msgid "Import"
-msgstr "Importuji"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Don't reproject the data, just patch it"
-msgstr "Neprovádìt reprojekci dat, pouze je spojit"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
msgid "Use GET method instead of POST data method"
-msgstr "Pou¾ít metodu GET místo metody POST"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
msgid "This may be needed to connect to servers which lack POST capability"
msgstr ""
-"TOto mp¾e být potøeba pro spojení se serverem , který nemá schopnost POST"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
msgid "Use GDAL WMS driver"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr "Adresa mapového serveru"
+msgstr "Nelze vybrat data z tabulky"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
msgid "Layers to request from map server"
-msgstr "Vrstvy, které se mají stáhnout"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
msgid "Styles to request from map server"
-msgstr "Styl, ve kterém se mají vrstvy stáhnout"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
msgid "Source projection to request from server"
-msgstr "Zdrojová projekce, kterou máme po¾adovat po serveru"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
msgid "Image format requested from the server"
-msgstr "Formát obrázku, ve kterém se mají data stáhnout"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
msgid "Addition query options for server"
-msgstr "Dal¹í volby pro server"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
msgid "Maximum columns to request at a time"
-msgstr "Maximum sloupcù, které se mají najednou stáhnout"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#, fuzzy
msgid "Maximum rows to request at a time"
-msgstr "Maximum øádkù, které se mají najednou stáhnout"
+msgstr "Maximální vzdálenost k nejbli¾¹ímu prvku"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Additional options for r.tileset"
-msgstr "Dal¹í volby pro r.tileset"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
msgid "Named region to request data for. Current region used if omitted"
msgstr ""
-"Jméno regionu, pro který se mají mapy stánhout. Výchozí je aktuální region."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
#, fuzzy
@@ -28609,16 +28812,18 @@
msgstr "Adresáø, kam se mají sta¾ená data ulo¾it"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
+#, fuzzy
msgid "Reprojection method to use"
-msgstr "Reprojekèní metoda, která má být pou¾ita"
+msgstr "Interpolaèní metoda, která má být pou¾ita"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
msgid "Filename to save capabilities XML file to"
-msgstr "Jméno souboru pro ulo¾ení kapacity XML souboru"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
+#, fuzzy
msgid "Requires list available layers flag"
-msgstr "Vy¾aduje volbu pro seznam pou¾itelných vrstev"
+msgstr "Vypi¹ pøítomné vrstvy a ukonèi se"
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
#, fuzzy
@@ -28627,45 +28832,47 @@
"Nastavit pravidla barev podle smìrodatné odchylky z prùmìrné hodnoty mapy"
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
+#, fuzzy
msgid "Color using standard deviation bands"
-msgstr "Barvy pou¾ívající skupiny smìrodatné odchylky"
+msgstr "prùmìry a smìrodatné odchylky pro %d kanál%s\n"
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:6
msgid "Force center at zero"
-msgstr "Umístit støed na nulu"
+msgstr ""
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
msgid ""
"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
msgstr ""
-"V rastrových mapách vyplní plochy s prázdnými hodnotami za pou¾ití v.surf."
-"rst spline interpolace"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#, fuzzy
msgid "Raster map in which to fill nulls"
-msgstr "Rastrové mapy v nich¾ mají být vyplnìny NULLy"
+msgstr "Rastrová její¾ soubor NULL bude editován"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
msgid ""
"Output raster map with nulls filled by interpolation from surrounding values"
msgstr ""
-"Výstupní rastrová mapa její¾ prázdná místa budou vyplnìna okolními hodnotami"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#, fuzzy
msgid "Spline tension parameter"
msgstr "Parametr pnutí (tension)"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
+#, fuzzy
msgid "Spline smoothing parameter"
msgstr "Parametr vyhlazení (smoothing)"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
+#, fuzzy
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
msgstr ""
-"Rozlo¾í hranice mezi sousedícími plochami, sdílejícími spoleèné èíslo "
-"kategorie nebo atribut."
+"Nebyla nalezena ¾ádná atributová tabulka -> pou¾iji jako atributy pouze "
+"èísla kategorie"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
msgid "dissolve"
@@ -28677,56 +28884,68 @@
msgstr "Èíslo vrstvy. Pokud -1, jsou vyjmuty v¹echny vrstvy."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:9
+#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr "Název sloupce atributu, který má být pou¾it pøi mazání hranic"
+msgstr ""
+"Název sloupce atributu, který má být pou¾it jaok ¹títky pro kategorie "
+"rastrové mapy"
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
msgid "Adds missing centroids to closed boundaries."
-msgstr "K uzavøeným hranicím pøidá chybìjící centroidy."
+msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#, fuzzy
msgid "Action to be taken"
msgstr "Akce, mající být vykonána"
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
+#, fuzzy
msgid "Category number starting value"
-msgstr "Poèáteèní hodnota kategorií"
+msgstr "Re¾im èísel katagorií"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr "Vyma¾e existující atributovou tabulku vektorové mapy."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
-msgstr "Vynucené odstranìní ( po¾adováno pro souèasné mazání tabulek)"
+msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+#, fuzzy
msgid "Vector map from which to remove attribute table"
-msgstr "Vektorová mapa, ze které má být odstranìna atributová tabulka."
+msgstr "Název rastrové mapy, ze které se má kopírovat tabulka kategorií"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:7
+#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr "Jméno existující atributové tabulky (výchozí: jméno vektorové mapy)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:8
+#, fuzzy
msgid "Layer from which to drop linked attribute table"
-msgstr "Vrstva, z ní¾ má být odstranìno spojení s tabulkou"
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr "Umo¾ní spojení tabulky s tabulkou pøipojenou k vektorové mapì."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+#, fuzzy
msgid "Vector map to which to join other table"
-msgstr "Vektorová mapa, k její¾ tabulce bude pøipojena tabulka nová"
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
msgid "layer,column"
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#, fuzzy
msgid "Layer where to join"
-msgstr "Vrstva, na které dojde ke spojení"
+msgstr "Èíslo vrstvy (to)"
#: ../locale/scriptstrings/v.db.join_to_translate.c:8
#, fuzzy
@@ -28734,12 +28953,14 @@
msgstr "sloupec(ce)"
#: ../locale/scriptstrings/v.db.join_to_translate.c:9
+#, fuzzy
msgid "Join column in map table"
-msgstr "Sloupec atributové tabulky mapy, pøes který do jde ke spojení"
+msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
#: ../locale/scriptstrings/v.db.join_to_translate.c:10
+#, fuzzy
msgid "Other table name"
-msgstr "Jméno pøipojované tabulky"
+msgstr "Název výstupní tabulky"
#: ../locale/scriptstrings/v.db.join_to_translate.c:11
#, fuzzy
@@ -28747,94 +28968,98 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+#, fuzzy
msgid "Join column in other table"
-msgstr "Sloupec pøipojované tabulky"
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
msgid ""
"Drops a column from the attribute table connected to a given vector map."
-msgstr "Ma¾e sloupce z tabulky atributù pøipojené k zadané vektorové mapì."
+msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to drop attribute column"
-msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec smazán"
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
msgid "Layer where to drop column"
-msgstr "Vrstva, odkud smazat sloupec"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr "Transformace Cap (Kauth Thomas) pro data LANDSAT-TM"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#, fuzzy
msgid "use transformation rules for LANDSAT-4"
-msgstr "pou¾ít transformaèní pravidla pro LANDSAT-4"
+msgstr "Zpìtná transformave, 3Dvektorové prvky na 2D"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#, fuzzy
msgid "use transformation rules for LANDSAT-5"
-msgstr "pou¾ít pravidla transformace pro LANDSAT-5"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+#, fuzzy
msgid "use transformation rules for LANDSAT-7"
-msgstr "pou¾ít pravidla transformace pro LANDSAT-7"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
msgid "raster input map (LANDSAT channel 1)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 1)"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
msgid "raster input map (LANDSAT channel 2)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 2)"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
msgid "raster input map (LANDSAT channel 3)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 3)"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
msgid "raster input map (LANDSAT channel 4)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 4)"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
msgid "raster input map (LANDSAT channel 5)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 5)"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
msgid "raster input map (LANDSAT channel 7)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 7)"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
+#, fuzzy
msgid "raster output TC maps prefix"
-msgstr "pøedpona výstupního rastru TC"
+msgstr "Pøepsat výstupní soubor mapy"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-#, fuzzy
msgid ""
"Creates and connects a new attribute table to a given layer of an existing "
"vector map."
msgstr ""
-"Vytvoøí a pøidá novou atributovou tabulku k zadané vrstvì existující "
-"vektorové mapy."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to add new attribute table"
-msgstr "Vektorová mapa pro kterou bude pøidána nová atributová tabulka"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
-msgstr "Jméno nové atributové tabulky (výchozí: jméno mapy)"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+#, fuzzy
msgid "Layer where to add new attribute table"
-msgstr "Vrstva, kam bude pøidána nová atributová tabulka"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
msgid ""
"Name and type of the new column(s) (types depend on database backend, but "
"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
msgstr ""
-"Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
-"v¹echny podporují VARCHAR(), INT, DOUBLE PRECISION a DATE)"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
#, fuzzy
@@ -28843,15 +29068,19 @@
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
msgid "GetFeature URL starting with http"
-msgstr "GetFeature startovací adresa URL s http"
+msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#, fuzzy
msgid "Vector output map"
-msgstr "Výstupní vektorová mapa"
+msgstr "®ádné výstupní mapy"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
+#, fuzzy
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "Vytvoøí mapu stínovaného reliéfu ze vstupní mapy elevace (DMT)."
+msgstr ""
+"Vytvoøí mapu topografického indexu, [ln(a/tan(beta))], z rastrové mapy "
+"digitálního modelu terénu."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
#, fuzzy
@@ -28864,21 +29093,24 @@
msgstr "Název výstupní rastrové mapy"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
+#, fuzzy
msgid "Altitude of the sun in degrees above the horizon"
-msgstr "Vý¹ka slunce ve stupních nad horizontem"
+msgstr "A: vý¹ka Slunce nad horizontem, stupnì"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
+#, fuzzy
msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "Azimut slunce ve stupních od serveru (k východu)"
+msgstr "A: azimut Slunce od serveru, stupnì"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
+#, fuzzy
msgid "Factor for exaggerating relief"
-msgstr "Faktor zvýraznìní reliéfu"
+msgstr "Formát sklonu svahu"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
+#, fuzzy
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Mìøítkový faktor pro pøevod horizontálních jednotek na jednotky elevace "
+msgstr "Faktor mìøítka ovlivní vstup (pokud není zadaná mapa elevace)"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
@@ -28890,113 +29122,117 @@
msgid ""
"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
msgstr ""
-"Nastav mìøítkový faktor (bude pou¾ito pouze na location lat/long, nic: "
-"mìøítko=1)"
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr ""
-"Spoèítá tabulku optimálního faktoru indexu pro kanály 1-5 a 7 dru¾ice "
-"LANDSAT TM"
#: ../locale/scriptstrings/i.oif_to_translate.c:5
msgid "LANDSAT TM band 1."
-msgstr "LANDSAT TM kanál 1"
+msgstr ""
#: ../locale/scriptstrings/i.oif_to_translate.c:6
msgid "LANDSAT TM band 2."
-msgstr "LANDSAT TM kanál 2."
+msgstr ""
#: ../locale/scriptstrings/i.oif_to_translate.c:7
msgid "LANDSAT TM band 3."
-msgstr "LANDSAT TM kanál 3."
+msgstr ""
#: ../locale/scriptstrings/i.oif_to_translate.c:8
msgid "LANDSAT TM band 4."
-msgstr "LANDSAT TM kanál 4."
+msgstr ""
#: ../locale/scriptstrings/i.oif_to_translate.c:9
msgid "LANDSAT TM band 5."
-msgstr "LANDSAT TM kanál 5."
+msgstr ""
#: ../locale/scriptstrings/i.oif_to_translate.c:10
msgid "LANDSAT TM band 7."
-msgstr "LANDSAT TM kanál 7."
+msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
msgid "Imports attribute tables in various formats."
-msgstr "Importuje atributové tabulky v rùzných formátech."
+msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
msgid "Table file to be imported or DB connection string"
-msgstr "Tabulka pro import nebo textový øetìzec databázového spojení"
+msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
msgid "Table name of SQL DB table"
-msgstr "Jméno tabulky v SQL DB tabulce"
+msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
msgid "Name for auto-generated unique key column"
-msgstr "Jmémo slooupce s automaticky vytoøeným unikátním klíèem"
+msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
+#, fuzzy
msgid "Interactively edit cell values in a raster map."
-msgstr "Interaktivní editace rastrových bunìk v zadané mapì."
+msgstr "Zaèni s hodnotami v rastrové mapì"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
+#, fuzzy
msgid "Name of aspect raster map"
-msgstr "Název rastrové mapy expozice"
+msgstr "Název základní rastrové mapy"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
msgid "Width of display canvas"
-msgstr "©íøka obrazu"
+msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+#, fuzzy
msgid "Height of display canvas"
-msgstr "Vý¹ka zobrazovacího plátna"
+msgstr "Nelze otevøít displej"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
+#, fuzzy
msgid "Minimum size of each cell"
-msgstr "Minimální velikost ka¾dé buòky"
+msgstr "Minimální íºroveò isopovrchu"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+#, fuzzy
msgid "Maximum number of rows to load"
-msgstr "Maximální poèet øádkù, které budou naèteny"
+msgstr "Minimální poèet sloupcù: %d"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns to load"
-msgstr "Maximální poèet sloupcù, které budou naèteny"
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr "Vykreslí polární diagram íºhlové mapy jako je smìr povrchového odtoku"
+msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:4
+#, fuzzy
msgid "Name of raster angle map"
-msgstr "Jméno rastru s íºhly"
#: ../locale/scriptstrings/d.polar_to_translate.c:5
msgid "Pixel value to be interpreted as undefined (different from NULL)"
msgstr ""
-"Hodnota pixelu, která má být interpretována jako nedefinováno (rùzná od NULL)"
#: ../locale/scriptstrings/d.polar_to_translate.c:6
+#, fuzzy
msgid "Name of optional EPS output file"
-msgstr "Název volitelného výstupního souboru ve formátu EPS"
+msgstr "Název výstupního souboru SVG"
#: ../locale/scriptstrings/d.polar_to_translate.c:7
msgid "Plot using Xgraph"
-msgstr "Vytisknout pomocí Xgraph"
+msgstr ""
+#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
-msgstr "Spoèítá základní statistiku vybraného sloupce tabulky vektorové mapy."
+msgstr "Spoèítá univariantní statistiku z ne-nullových bunìk rastrové mapy."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
msgid "Extended statistics (quartiles and 90th percentile)"
-msgstr "Roz¹íøený výstup (kvartily a 90-té procentily)"
+msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
#, fuzzy
@@ -29004,20 +29240,23 @@
msgstr "Vypi¹ statistiku ve stylu pro shell skript"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#, fuzzy
msgid "Name of data table"
-msgstr "Jméno tabulky"
+msgstr "Název souboru s filtrem"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr "Sloupec na kterém se bude poèítat statistika (musí být èíselného typu)"
+msgstr "Jméno sloupce (musí být èíselného typu)"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
msgid "Database/directory for table"
-msgstr "Databáze nebo adresáø s tabulkou"
+msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#, fuzzy
msgid "Database driver"
-msgstr "Ovladaè databáze"
+msgstr "Vypi¹ v¹echny databázové ovladaèe."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
#, fuzzy
@@ -31338,46 +31577,402 @@
msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr "Nelze oznaèit dal¹í bod. Promiòte, je povoleno pouze %d bodù."
-#~ msgid "Not enough room in history file"
-#~ msgstr "Pro soubor s historií není dost místa"
+#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "Zobrazí a pøekryje rastrovou mapu v aktivním rámu GRASS monitoru"
-#~ msgid "New MAPSET name"
-#~ msgstr "Nové jméno MAPSETU"
+msgid "ASPECT [%s] COMPLETE"
+msgstr "MAPA EXPOZICE [%s] DOKONÈENA"
+msgid "SLOPE [%s] COMPLETE"
+msgstr "MAPA SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+msgid "PROFILE CURVE [%s] COMPLETE"
+msgstr "PROFILOVÁ KØIVOST [%s] DOKONÈENA"
+msgid "TANGENTIAL CURVE [%s] COMPLETE"
+msgstr "TANGENCIÁLNÍ KØIVOST [%s] DOKONÈENA"
+msgid "E-W SLOPE [%s] COMPLETE"
+msgstr "MAPA V-Z SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+msgid "N-S SLOPE [%s] COMPLETE"
+msgstr "MAPA S-J SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+msgid "DXX [%s] COMPLETE"
+msgstr "MAPA DXX [%s] DOKONÈENA"
+msgid "DYY [%s] COMPLETE"
+msgstr "MAPA DYY [%s] DOKONÈENA"
+msgid "DXY [%s] COMPLETE"
+msgstr "MAPA DXY [%s] DOKONÈENA"
#, fuzzy
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "Vypi¹ aktuální cestu k mapsetùm"
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr ""
+"Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
+"v¹echny podporují VARCHAR(), INT, DOUBLE PRECISION a DATE)"
#, fuzzy
+msgid "Raster file to be converted."
+msgstr "Název rastrového souboru, který má být importován"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "Soubor obsahující pravidla pro ¹tíky kategorií (nebo \"-\" pro stdin)"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "rastr, terénní analýza"
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "Nelze otevøít vektorový soubor <%s> v úrovni topologie %d"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr ""
+"mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary),p(procenta)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+msgid "Band to select"
+msgstr "Výbìr vrstvy"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "Statistika pou¾itá pro rastrové hodnoty"
+msgid "It was impossible to create <Auxiliar_outlier_table>."
+msgstr "Bylo mo¾no vytvoøit <Auxiliar_outlier_table>."
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "<%s> vytvoøeno v databázi."
+msgid "M.Q. solution"
+msgstr "Øe¹ení M.Q."
+msgid "3-d data in dxf file. Polyline_flag: %d"
+msgstr "3-d data v souboru dxf. Polyline_flag: %d"
+#, fuzzy
+msgid ""
+"Calculate the groundwater distance velocity vector field \n"
+"and write the x, y, and z components to maps named name_[xyz].\n"
+"Name is basename for the new raster3d maps"
+msgstr ""
+"Vypoèítat prùtokovou rychlost vektorového pole a zapi¹ x,y a z èásti do map "
+"pojmenovaných jmeno_[xyz]. Jméno mapy je základ pro r3d rastrovou mapu."
+#, fuzzy
+msgid "report"
+msgstr "Rozsáhlá zpráva"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Nejsem schopen zapsat hlavièku pro %s"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+msgstr "Nelze otevøít soubor <%s>"
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "Chyba pøi ètení rastrové mapy <%s>"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+#, fuzzy
+msgid "r.li.worker (pid %i) exited with abnormal status: %i"
+msgstr "r.li.worker (pid %i) byl ukonèen s abnormálním statusem %i"
+#, fuzzy
+msgid "r.li.worker (pid %i) terminated successfully"
+msgstr "r.li.worker (pid %i) ukonèen"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Nelze otevøít rastrovou mapu <%s> v <%s>"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "Nelze èíst region <%s> v <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+msgstr "Nelze otevøít rastrovou mapu <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+msgstr "Nelze otevøít vektorovou mapu <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "Nelze otevøít výstupní soubor <%s>"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "Nelze naèíst øádek %d (chyba = %d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "Nelze nastavit region zpìt na poèáteèní rozli¹ení!!!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Nelze èíst øádek %i\n"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Nelze nastavit region <%s>"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+msgstr "nemohu otevøít novou mapu akumulace "
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+msgstr "Extrahuji plochy..."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "Chyba pøi zápisu øádky %d."
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "Název existující rastrové mapy obsahující frikèní hodnoty"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "Nelze otevøít vstupní soubor <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+msgid "<Auxiliar_edge_table> created in database."
+msgstr "<pomocná_tabulka> vytvoøena v databázi."
+#, fuzzy
+msgid "Pass %d:"
+msgstr "Prùchod %d..."
+msgid "Creating auxiliar table for archiving overlapping zones"
+msgstr "Vytvoøení pomocné tabulky pro archivaci pøekrývajících se zón"
+#, fuzzy
+msgid "Unable to open table <%s_edge_Interpolation>"
+msgstr "Nelze otevøít databázi <%s>"
+msgid ""
+"It was not possible to drop <%s> table. Nothing will be done. Try to drop it "
+"manually."
+msgstr ""
+"Nelze vyjmout tabulku <%s>. Nic se nestalo. Zkuste vyjmout tabulku ruènì."
+msgid "Cross Validation was success!"
+msgstr "Køí¾ová validace byla íºspì¹ná!"
+msgid ""
+"Interpolation: The region resolution is too high: %d cells. Consider to "
+"change it."
+msgstr ""
+"Interpolace: Rozli¹ení regionu je pøíli¹ vysoké: %d bunìk. Prosím, zmìòte "
+"jej."
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+msgstr "Nelze èíst rastrovou mapu, øádek %d"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "Selhalo zapisování øádku %d rastrové mapy"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+msgstr "Nelze èíst rastrovou mapu <%s> øádek %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Nelze èíst hlavièku rastrové mapy <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "Nelze zapsat rastrové mapy"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "Nelze otevøít soubor s pravidly <%s>"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "Nelze èíst hlavièku souboru <%s>"
+#, fuzzy
+msgid "Could not open <%s>"
+msgstr "Nelze otevøít mapu %s"
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "Název výstupní rastrové mapy"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "jméno"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Jméno mapsetu"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Poèet hran mimo rozsah"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "general, region"
+msgstr "obecné, projekce"
+msgid "Script kill option"
+msgstr "Volba skriptu kill"
+msgid "Start in Demo mode"
+msgstr "Spustit v módu Demo"
+msgid "Output more comments (default=quiet)"
+msgstr "Více komentáøù na výstup (výchozí=potichu)"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+msgstr "rastr, objem, pøevod"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "rastr, tok erodovaných èástic, eroze, usazování"
+#, fuzzy
+msgid "raster, random, surface"
+msgstr "Rastrový soubor pro povrch"
+#, fuzzy
+msgid "raster, random, cell"
+msgstr "rastr, pøevzorkování"
+msgid "Spline type of interpolation"
+msgstr "Spline typ interpolace"
+msgid "It was impossible to open table"
+msgstr "Nebylo mo¾né otevøít tabulku"
+msgid ""
+"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
+"Display Manager (d.m);wxpython;wxPython based next generation GUI"
+msgstr ""
+"tcltk;Tcl/Tk grafické prostøedí - GIS Manager (gis.m);oldtcltk;Strar¹í Tcl/"
+"Tk grafické prostøedí - Display Manager (d.m);wxpython; Grafické prostøedí "
+"budoucí generace zalo¾ené na WxPyton"
+msgid "Name of output vector area map"
+msgstr "Název výstupní vektorové vrstvy"
+msgid "Do not export long colortable"
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d was "
+"used to represent no-data values in the input map. You can specify nodata "
+"value by %s parameter."
+msgstr ""
+"Vstupní rastrová mapa obsahující NULLové hodnoty (¾ádná data). Pro NULLové "
+"hodnoty byla pou¾ita hodnota %d. Mù¾ete urèit hodnotu reprezentující NULLové "
+"hodnoty parametrem %s."
+msgid "SECTION 3: Accumulating Surface Flow."
+msgstr "ÈÁST 3: Akumulace povrchového odtoku."
+msgid "SECTION 4: Length Slope determination."
+msgstr "ÈÁST 4: Urèuji délku svahu."
+msgid "unable to open new L map layer."
+msgstr "Nelze otevøít novou mapu L (faktoru délky svahu)"
+msgid "unable to open new S map layer."
+msgstr "nemohu otevøít novou mapu S (faktor sklonu svahu)"
+msgid ""
+"Sorry, if any of the following options are set:\n"
+" basin, stream, half.basin, slope, or lS\n"
+" you MUST provide a value for the basin threshold parameter."
+msgstr ""
+"Promiòte, pokud je zadána nìkterá z následujících voleb:\n"
+" basin, stream, half.basin, slope nebo LS\n"
+" MUSÍTE zadat prahovou hodnotu povodí (basin threshold)."
+msgid "Writes Z data to column instead of 3D vector"
+msgstr "Zapí¹e y-souøadnice do sloupce místo vytvoøení 3D vektoru"
+msgid "Convex hull calculation requires at least three points"
+msgstr "Výpoèet konvexního obalu po¾aduje nejménì 3 body"
+#~ msgid "Not enough room in history file"
+#~ msgstr "Pro soubor s historií není dost místa"
+#, fuzzy
#~ msgid "<%s> not found in mapset list"
#~ msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
#, fuzzy
-#~ msgid "** no mapsets **\n"
-#~ msgstr "**¾ádné %s soubory nenalezeny **\n"
#~ msgid "Name of workspace file"
-#~ msgstr "Jméno souboru pracovního prostøedí"
+#~ msgstr "Jméno souboru s barvou"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "Zobrazí a pøekryje rastrovou mapu v aktivním rámu GRASS monitoru"
#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr ""
-#~ "Seznam hodnot, které mají být vykresleny (mapy s plovoucí desetinnou "
-#~ "èárkou)"
+#~ msgstr "Seznam hodnot bunìk pro maskování"
+#, fuzzy
#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr ""
-#~ "Ignoruji seznam kategorií: mapa obsahuje hodnoty s plovoucí desetinnou "
-#~ "èárkou (prosím, pou¾ijte volbu 'val=')"
+#~ msgstr "Exportuji rastr jako mapu s hodnotami s plovoucí desetinnou èárkou"
-#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr ""
-#~ "Ignoruji seznam hodnot: mapa obsahuje celoèíselné hodnoty (prosím, "
-#~ "pou¾ijte volbu 'cat=')"
#~ msgid "Area size [%.1e], area not imported"
#~ msgstr "Velikost plochy [%.1e] plocha nebude importována"
@@ -31391,8 +31986,9 @@
#~ "®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na "
#~ "vektorové mapì <%s>"
+#, fuzzy
#~ msgid "Failed in attempt to open %s"
-#~ msgstr "Chyba pøi otevírání %s"
+#~ msgstr "Selhalo zapisování øádku %d rastrové mapy"
#~ msgid ""
#~ "Generates raster map layers of slope, aspect, curvatures and partial "
@@ -31403,39 +31999,49 @@
#~ "odvozenou z digitálního modelu terénu. Expozice je poèítána proti smìru "
#~ "hodinových ruèièek s poèátkem na východì."
+#, fuzzy
#~ msgid "Raster elevation file name"
-#~ msgstr "Název rastrového souboru s digitálním modelem terénu"
+#~ msgstr "Rastrová mapa %i Název souboru: %s"
+#, fuzzy
#~ msgid "Output slope filename"
-#~ msgstr "Název výstupního souboru sklonù svahù"
+#~ msgstr "Název výstupní tabulky"
+#, fuzzy
#~ msgid "Output aspect filename"
-#~ msgstr "Název výstupního souboru expozic svahù"
+#, fuzzy
#~ msgid "Output profile curvature filename"
#~ msgstr "Název výstupního souboru profilových køivostí"
+#, fuzzy
#~ msgid "Output tangential curvature filename"
#~ msgstr "Název výstupního souboru tangenciálních køivostí"
+#, fuzzy
#~ msgid "Output first order partial derivative dx (E-W slope) filename"
#~ msgstr ""
-#~ "Název výstupního souboru parciálních derivací prvního øádu dx (V - Z "
+#~ "Název výstupní rastrové mapy parciálních derivací prvního øádu dx (V-Z "
#~ "sklon svahu)"
+#, fuzzy
#~ msgid "Output first order partial derivative dy (N-S slope) filename"
#~ msgstr ""
-#~ "Název výstupního souboru parciálních derivací prvního øádu dy (S - J "
+#~ "Název výstupní rastrové mapy parciálních derivací prvního øádu dy (S-J "
#~ "sklon svahu)"
+#, fuzzy
#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Název výstupního souboru parciálních derivací druhého øádu dxx"
+#~ msgstr "Název výstupnírastrové mapy parciálních derivací druhého øádu dxx"
+#, fuzzy
#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "Název výstupního souboru parciálních derivací druhého øádu dyy"
+#~ msgstr "Název výstupnírastrové mapy parciálních derivací druhého øádu dyy"
+#, fuzzy
#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "Název výstupního soubor parciálních derivací druhého øádu dxy"
+#~ msgstr "Název výstupní rastrové mapy parciálních derivací druhého øádu dxy"
#~ msgid ""
#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
@@ -31444,51 +32050,18 @@
#~ "Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, "
#~ "peou¾ijte pøepínaè '--quiet'."
+#, fuzzy
#~ msgid "wrong type: %s"
-#~ msgstr "chybný typ: %s"
+#~ msgstr "Chybný typ rastrové mapy: %s"
+#, fuzzy
#~ msgid "Creating support files..."
-#~ msgstr "Vytváøím podpùrné soubory..."
+#~ msgstr "Vytváøím podpùrné soubory BIL..."
+#, fuzzy
#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "Výsledky z elevace mapsetu [%s] v [%s]"
+#~ msgstr "Vý¹kové produkty pro mapset <%s> v <%s>"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "MAPA EXPOZICE [%s] DOKONÈENA"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "MAPA SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "PROFILOVÁ KØIVOST [%s] DOKONÈENA"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "TANGENCIÁLNÍ KØIVOST [%s] DOKONÈENA"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "MAPA V-Z SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "MAPA S-J SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "MAPA DXX [%s] DOKONÈENA"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "MAPA DYY [%s] DOKONÈENA"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "MAPA DXY [%s] DOKONÈENA"
-#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr ""
-#~ "Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
-#~ "v¹echny podporují VARCHAR(), INT, DOUBLE PRECISION a DATE)"
#~ msgid "Sources and sinks in [m^3/s]"
#~ msgstr "Prameny a jezera v [m^3/s]"
@@ -31498,21 +32071,14 @@
#~ msgid "Input elevation map"
#~ msgstr "Vstupní mapa elevace."
+#, fuzzy
#~ msgid "Output shaded relief map name"
-#~ msgstr "Výstupní mapa stínovaného reliéfu"
+#~ msgstr "Název výstupního ovladaèe"
+#, fuzzy
#~ msgid "Layer number of data column"
-#~ msgstr "Èíslo vrstvy s datovým sloupcem"
+#~ msgstr "Èíslo vrstvy (from)"
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "Název rastrového souboru, který má být importován"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr ""
-#~ "Soubor obsahující pravidla pro ¹tíky kategorií (nebo \"-\" pro stdin)"
#~ msgid "Name of vector input map containing stream(s)"
#~ msgstr "Název vstupní vektorové vrstvy obsahující dráhy odtoku"
@@ -31619,10 +32185,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr "(i) VOLITELNÉ Výstup pro danou tøídu topografického indexu"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "rastr, terénní analýza"
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "Jméno existujícího rastru obsahujícího digitální model terénu."
@@ -31686,135 +32248,10 @@
#~ msgstr "Nelzepøistoupit k tabulce <%s>"
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "Nelze otevøít vektorový soubor <%s> v úrovni topologie %d"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr ""
-#~ "mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary),p(procenta)"
-#~ msgid "Experimental NVIZ CLI prototype."
-#~ msgstr "Experimentální prototyp NVIZ CLI"
-#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "Vypi¹ výsledek ve stylu pro shell skript"
-#~ msgid "Band to select"
-#~ msgstr "Výbìr vrstvy"
-#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Statistika pou¾itá pro rastrové hodnoty"
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "Bylo mo¾no vytvoøit <Auxiliar_outlier_table>."
-#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "<%s> vytvoøeno v databázi."
-#~ msgid "M.Q. solution"
-#~ msgstr "Øe¹ení M.Q."
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "3-d data v souboru dxf. Polyline_flag: %d"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importuje SRTM HGT soubory do GRASSu"
-#, fuzzy
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new raster3d maps"
-#~ msgstr ""
-#~ "Vypoèítat prùtokovou rychlost vektorového pole a zapi¹ x,y a z èásti do "
-#~ "map pojmenovaných jmeno_[xyz]. Jméno mapy je základ pro r3d rastrovou "
-#~ "mapu."
-#, fuzzy
-#~ msgid "report"
-#~ msgstr "Rozsáhlá zpráva"
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgstr ""
+#~ msgstr "mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary)"
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Nejsem schopen zapsat hlavièku pro %s"
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "Nelze otevøít soubor <%s>"
-#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "Chyba pøi ètení rastrové mapy <%s>"
-#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) byl ukonèen s abnormálním statusem %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) ukonèen"
-#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Nelze otevøít rastrovou mapu <%s> v <%s>"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "Nelze èíst region <%s> v <%s>"
-#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#~ msgstr "Nelze otevøít rastrovou mapu <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#~ msgstr "Nelze otevøít vektorovou mapu <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "Nelze otevøít výstupní soubor <%s>"
-#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "Nelze naèíst øádek %d (chyba = %d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "Nelze nastavit region zpìt na poèáteèní rozli¹ení!!!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Nelze èíst øádek %i\n"
-#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Nelze nastavit region <%s>"
-#, fuzzy
#~ msgid "unable to open new LS factor map layer."
#~ msgstr "Nelze otevøít novou mapu L (faktoru délky svahu)"
@@ -31823,1218 +32260,606 @@
#~ msgstr "nemohu otevøít novou mapu S (faktor sklonu svahu)"
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#~ msgstr "nemohu otevøít novou mapu akumulace "
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "Extrahuji plochy..."
-#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "Chyba pøi zápisu øádky %d."
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Název existující rastrové mapy obsahující frikèní hodnoty"
-#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "Nelze otevøít vstupní soubor <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "<pomocná_tabulka> vytvoøena v databázi."
-#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Prùchod %d..."
-#~ msgid "Creating auxiliar table for archiving overlapping zones"
-#~ msgstr "Vytvoøení pomocné tabulky pro archivaci pøekrývajících se zón"
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Nelze otevøít databázi <%s>"
-#~ msgid ""
-#~ "It was not possible to drop <%s> table. Nothing will be done. Try to drop "
-#~ "it manually."
-#~ msgstr ""
-#~ "Nelze vyjmout tabulku <%s>. Nic se nestalo. Zkuste vyjmout tabulku ruènì."
-#~ msgid "Cross Validation was success!"
-#~ msgstr "Køí¾ová validace byla íºspì¹ná!"
-#~ msgid ""
-#~ "Interpolation: The region resolution is too high: %d cells. Consider to "
-#~ "change it."
-#~ msgstr ""
-#~ "Interpolace: Rozli¹ení regionu je pøíli¹ vysoké: %d bunìk. Prosím, zmìòte "
-#~ "jej."
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Nelze èíst rastrovou mapu, øádek %d"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Selhalo zapisování øádku %d rastrové mapy"
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#~ msgstr "Nelze èíst rastrovou mapu <%s> øádek %d"
-#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Nelze èíst hlavièku rastrové mapy <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "Nelze zapsat rastrové mapy"
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "Nelze otevøít soubor s pravidly <%s>"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "Nelze èíst hlavièku souboru <%s>"
-#, fuzzy
-#~ msgid "Could not open <%s>"
+#~ msgid "Could not read from <%s>"
#~ msgstr "Nelze otevøít mapu %s"
-#~ msgid "Could not read from <%s>"
-#~ msgstr "Nelze èíst z <%s>"
#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "Název výstupní rastrové mapy"
+#~ msgid "Error reading row of data"
+#~ msgstr "Chyba pøi ètení divoké karty"
#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#~ msgid "Error reading row of data"
-#~ msgstr "Chyba pøi ètení øádku"
#~ msgid "Error reading intensity data"
#~ msgstr "Chyba pøi ètení mapy intenzity"
+#, fuzzy
#~ msgid "Error reading saturation data"
-#~ msgstr "Chyba pøi ètení mapy nasycení (saturation)"
+#~ msgstr "Chyba pøi ètení mapy nasycení (saturation))"
+#, fuzzy
#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Chyba pøi zápisu PROJ_INFO"
+#~ msgstr "Chuba pøi zápisu dat"
+#, fuzzy
#~ msgid "Error writing PROJ_UNITS"
-#~ msgstr "Chyba pøi zápisu PROJ_UNITS"
+#, fuzzy
#~ msgid "Unable to compile regular expression %s"
-#~ msgstr "Nelze sestavit regulérní výraz %s"
+#~ msgstr "Nelze otevøít soubor s pravidly <%s>"
+#, fuzzy
#~ msgid "Raster map <%s@%s>: %s"
-#~ msgstr "rastrová mapa <%s@%s>: %s"
+#~ msgstr "Rastrová mapa <%s> byla vytvoøena."
+#, fuzzy
#~ msgid "Unable to open raster map <%s> in <%s>"
+#~ msgstr "Nelze otevøít rastrovou mapu <%s> v mapsetu <%s>"
+#, fuzzy
#~ msgid "display, setup"
-#~ msgstr "zobrazení, nastavení"
+#~ msgstr "zobrazení"
+#, fuzzy
#~ msgid "display, raster"
-#~ msgstr "zobrazení, rastr"
+#, fuzzy
#~ msgid "display, networking"
-#~ msgstr "zobrazení, sítì"
+#~ msgstr "vektor, sí»ování"
-#~ msgid "Size of grid to be drawn"
-#~ msgstr "Velikost møí¾ky pro vykreslení"
+#, fuzzy
#~ msgid "display, vector"
-#~ msgstr "zobrazení, vekrotové mapa"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "jméno"
+#~ msgid "general, transformation, GCP"
+#~ msgstr "vektor, transformace, 3D"
#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "Jméno mapsetu"
+#~ msgid "general, settings"
+#~ msgstr "Opravte prosím nastavení."
#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Poèet hran mimo rozsah"
+#~ msgid "general, projection"
+#~ msgstr "raster, projekce"
#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
+#~ msgid "vector, import, GPS"
+#~ msgstr "vektor, import"
#, fuzzy
-#~ msgid "general, region"
-#~ msgstr "obecné, projekce"
-#~ msgid "general, transformation, GCP"
-#~ msgstr "obecné transformace, GCP"
-#~ msgid "general, settings"
-#~ msgstr "obecné, nastavení"
-#~ msgid "general, gui"
-#~ msgstr "obecné, grafické prostøedí"
-#~ msgid "general, projection"
-#~ msgid ""
-#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-#~ "file into a vector map."
-#~ msgstr ""
-#~ "Stáhne Waypoints, Routes a Tracks z pøístroje GPS nebo ze souboru a ulo¾í "
-#~ "je do vektorové mapy."
-#~ msgid "vector, import, GPS"
-#~ msgstr "vektor, import, GPS"
#~ msgid "Import waypoints"
-#~ msgstr "Importovat body"
+#~ msgstr "Importuji body ..."
+#, fuzzy
#~ msgid "Import routes"
-#~ msgstr "Importovat cesty"
-#~ msgid "Import track"
-#~ msgstr "Importovat tracky"
-#~ msgid "Force vertices of track or route data as points"
-#~ msgstr "Pøevézt lomové body tracku nebo cesty na body"
-#~ msgid "Do not attempt projection transform from WGS84"
-#~ msgstr "Neprovádìt pøevod projekce z WGS84"
+#, fuzzy
#~ msgid "Device or file used to import data"
-#~ msgstr "Zaøízení nebo soubor urèený k importu"
+#~ msgstr "Název rastrového souboru, který má být importován"
-#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr "Formát vstupní dat z GPSky (pou¾ij formáty podporované gpsbabel)"
-#~ msgid ""
-#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
-#~ "assumed"
-#~ msgstr ""
-#~ "Projekce vstupních dat (pou¾ijte volby PROJ.4), pokud není nastaveno, "
-#~ "pøedpokládáse, ¾e tato projekce je Lat/Long WGS84"
+#, fuzzy
#~ msgid "raster, imagery, colors"
-#~ msgstr "rastr, dpz, barvy"
+#~ msgstr "rastr, import, pøevod"
+#, fuzzy
#~ msgid "vector, centroid, area"
-#~ msgstr "vektor, centroid, plocha"
+#~ msgstr "vektor, metadata"
+#, fuzzy
#~ msgid "Configuration editor for r.li.'index'"
-#~ msgstr "Konfiguraèní editor pro r.li.'index'"
+#~ msgstr "Neplatný konfiguraèní soubor"
+#, fuzzy
#~ msgid "vector, import, gazetteer"
-#~ msgstr "vektor, import gazetteer"
+#~ msgstr "vektor, import, body"
+#, fuzzy
#~ msgid "vector, export, GPS"
-#~ msgstr "vektor, export, GPS"
+#~ msgstr "vektor, export"
+#, fuzzy
#~ msgid "raster, imagery, import"
-#~ msgstr "rastr, obrazová data, import"
+#~ msgstr "rastr, import"
+#, fuzzy
#~ msgid "raster, statistics, aggregation"
-#~ msgstr "rastr, statistika, agregace"
+#~ msgstr "rastr, statistika, reklasifikace"
+#, fuzzy
#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "obrazová data, fùze, Browey"
+#~ msgstr "obrazová data, ortorektifikace"
+#, fuzzy
#~ msgid "raster, imagery"
-#~ msgstr "rastr, obrazová data"
+#~ msgstr "rastr, mapová algebra"
+#, fuzzy
#~ msgid "vector, area, dissolve"
-#~ msgstr "vektor, plocha, spojení"
+#~ msgstr "vektor, metadata, historie"
+#, fuzzy
#~ msgid "raster, mask"
-#~ msgstr "rastr, maska"
+#~ msgstr "rastr, metadata"
+#, fuzzy
#~ msgid "vector, color table"
-#~ msgstr "vektor, barevná tabulka"
+#~ msgstr "rastr, tabulka barev"
+#, fuzzy
#~ msgid "raster, elevation, interpolation"
-#~ msgstr "rastr, elevace, interpolace"
+#~ msgstr "rastr, interpolace"
-#~ msgid "Additional options for wget"
-#~ msgstr "Dal¹í volby pro wget"
-#~ msgid "Additional options for curl"
-#~ msgstr "Dal¹í volby pro curl"
+#, fuzzy
#~ msgid "vector, report, statistics"
-#~ msgstr "vektor, zpráva, statistika"
+#~ msgstr "vektor, statistika"
-#~ msgid ""
-#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-#~ "vector map."
-#~ msgstr ""
-#~ "Ulo¾ Waypoints, Routes a Tracks z pøístroje GPS Garmin jako vektorovou "
-#~ "mapu."
-#~ msgid "Download Waypoints from GPS"
-#~ msgstr "Stáhni Waypoints z GPSky"
-#~ msgid "Download Routes from GPS"
-#~ msgstr "Stáhni Routes z GPSky"
-#~ msgid "Download Track from GPS"
-#~ msgstr "Stáhni Tracky z GPSky"
-#~ msgid "Force import of track or route data as points"
-#~ msgstr "Importuj tracky a routy jako body"
-#~ msgid "Use gardump instead of gpstrans as the download program"
-#~ msgstr "Pou¾ít gardump místo gpstrans jako stahovací program"
-#~ msgid "Import track in 3D (gardump only)"
-#~ msgstr "Importovat stopu ve 3D ( pouze gardump)"
-#~ msgid "Port Garmin receiver is connected to"
-#~ msgstr "Port, na kterém je Garmina pøipojena"
+#, fuzzy
#~ msgid "sites, vector, import"
-#~ msgstr "body, vektor, import"
+#, fuzzy
#~ msgid "raster, imagery, statistics"
-#~ msgstr "rastr, dpz, statistika"
+#~ msgstr "rastr, statistika"
+#, fuzzy
#~ msgid "vector, raster, statistics"
-#~ msgstr "vektor, rastr, statistika"
-#~ msgid "general, manual, help"
-#~ msgstr "obecné, návod, pomoc"
+#, fuzzy
#~ msgid "raster, imagery, mosaicking"
-#~ msgstr "rastr, dpz, mozaikování"
+#, fuzzy
#~ msgid "miscellaneous, projection"
-#~ msgstr "rùzné, projekce"
+#~ msgstr "rùzné"
+#, fuzzy
#~ msgid "visualization, raster, vector, raster3d"
-#~ msgstr "vizualizace rastr, vektor, 3D rastr"
+#~ msgstr "Organizace, kde byla vektorová mapa vytvoøena"
+#, fuzzy
#~ msgid "raster, vector, visualization"
-#~ msgstr "rastrová mapa, vektorová mapa, zobrazení"
-#~ msgid "Script kill option"
-#~ msgstr "Volba skriptu kill"
-#~ msgid "Start in Demo mode"
-#~ msgstr "Spustit v módu Demo"
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Více komentáøù na výstup (výchozí=potichu)"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#~ msgstr "rastr, objem, pøevod"
+#~ msgid "Path to TrueType font (including file name)"
+#~ msgstr "Jméno TrueType fontu (jak je napsáno v fontcap)"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "rastr, tok erodovaných èástic, eroze, usazování"
+#~ msgid "No font selected"
+#~ msgstr "Nebyl vybán ¾ádný záznam"
#, fuzzy
-#~ msgid "raster, random, surface"
-#~ msgstr "Rastrový soubor pro povrch"
+#~ msgid "Invalid font: %s"
+#~ msgstr "chybný region: %s"
#, fuzzy
-#~ msgid "raster, random, cell"
-#~ msgstr "rastr, pøevzorkování"
-#~ msgid "Spline type of interpolation"
-#~ msgstr "Spline typ interpolace"
-#~ msgid "It was impossible to open table"
-#~ msgstr "Nebylo mo¾né otevøít tabulku"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Prostøední: zmìnit barvu\n"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Umo¾ni probliknutí (pomalej¹í)"
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Vykreslí text v aktivním rámci grafického monitoru s vyu¾itím písma "
-#~ "TrueType"
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Souøadnice v procentech rámce ([0,0] je vlevo dole)"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Cesta k TrueType fontùm (vèetnì jména souboru)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Vý¹ka písmen (v procentech dostupné vý¹ky rámce)"
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Vyberte pro umístìní pouze jeden souøadnicový systém"
-#~ msgid "No font selected"
-#~ msgstr "Nebylo vybráno ¾ádné písmo"
-#~ msgid "Invalid font: %s"
-#~ msgstr "Chybné písmo: %s"
#~ msgid "No current window"
-#~ msgstr "®ádné aktuální okno"
+#~ msgstr "Nelze nastavit výøez"
+#, fuzzy
#~ msgid "Current window not available"
-#~ msgstr "Aktuální okno není dostupné"
+#~ msgstr "Soubor s tabulkou barev pro <%s> není dostupný"
+#, fuzzy
#~ msgid "Unable to create text conversion context"
-#~ msgstr "Nelze vytvoøit textovou konverzi kontextu"
+#~ msgstr "Nelze vytvoøit index"
+#, fuzzy
#~ msgid "Unable to write the temporary file"
-#~ msgstr "Nelze zapisovat do doèasného souboru"
+#~ msgstr "Nelze èíst doèasný soubor"
+#, fuzzy
#~ msgid "No predefined font"
-#~ msgstr "®ádné pøeddefinované písmo"
+#~ msgstr "Nelze èíst informace o vrstvì"
+#, fuzzy
#~ msgid "%s: Unable to read font"
-#~ msgstr "%s: Nelze èíst písmo"
+#~ msgstr "Nelze èíst %s"
+#, fuzzy
#~ msgid "%s: Unable to read FreeType definition file; use the default"
#~ msgstr "%s: Nelze èíst definièní soubor FreeType; pou¾iji výchozí"
+#, fuzzy
#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: Žádný definièní soubor FreeType"
+#~ msgstr "%s: ®ádný definièní soubor FreeType"
+#, fuzzy
#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s: Nelze èíst definièní soubor FreeType"
+#~ msgstr "%s: Nelze èíst definièní soubor FreeType; pou¾iji výchozí"
+#, fuzzy
#~ msgid "Display number of colors"
-#~ msgstr "Zobraz poèet barev"
+#~ msgstr "Poèáteèní poèet tøíd"
+#, fuzzy
#~ msgid "Setting map window"
-#~ msgstr "Nastavuji mapové okno"
+#~ msgstr "Nastavuji hlavièku výøezu"
+#, fuzzy
#~ msgid "Getting screen window"
-#~ msgstr "Získání obrazového okna"
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Chyba pøi pøepoèítávání"
+#, fuzzy
#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Jméno nebo cesta k TTF souboru."
+#~ msgstr "Jméno nového rastrového TIFF souboru."
-#~ msgid "Setting release of FreeType"
-#~ msgstr "Nastavuji verzi FreeType"
-#~ msgid "No current graphics window"
-#~ msgstr "®ádný vybraný monitor"
-#~ msgid "Current graphics window not available"
-#~ msgstr "Aktuální monitor není dostupný"
+#, fuzzy
#~ msgid "No raster or vector map displayed"
-#~ msgstr "Název rastrové nebo vektorové mapy, která bude zobrazena"
+#~ msgstr "Název rastrové mapy která bude zobrazena"
+#, fuzzy
#~ msgid "Current window not settable"
-#~ msgstr "Aktuální okno nelze nastavit"
+#~ msgstr "Nelze nastavit aktuální region."
+#, fuzzy
#~ msgid "No raster map exists in the current window"
-#~ msgstr "V aktuálním oknì neexistuje ¾ádná rastrová mapa"
+#~ msgstr "Vstupní rastrová mapa je mimo aktuální region"
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "Nepøidávat do seznamu rastrù a pøíkazù v monitoru"
+#, fuzzy
#~ msgid "Cannot use current window"
-#~ msgstr "Nelze pou¾ít aktuální okno"
+#~ msgstr "Nelze pøenastavit aktuální region"
+#, fuzzy
#~ msgid "Error reading raster map"
-#~ msgstr "chyba pøi ètení rastrové mapy"
+#~ msgstr "Chyba pøi ètení rastrové mapy <%s>"
-#~ msgid "one moment ..."
-#~ msgstr "momentíèek ..."
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "Nástroj pro interaktivní vytváøení profilù s volitelným výstupem."
-#~ msgid "Optional display raster"
-#~ msgstr "Volitelný rastr, který bude zobrazen"
+#, fuzzy
#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Výstupní data profilu ulo¾it do souboru(ù) s prefixem 'jméno'"
+#~ msgstr "Prefix výstupního rastrového souboru"
-#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Rastr ke zobrazení [%s] nenalezen. Pou¾iji rastr profilu."
+#, fuzzy
#~ msgid ""
#~ "\n"
#~ "\n"
#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Pou¾ít my¹ pro vybraní akce"
+#~ msgstr "Pro výbìr poèáteèního bodu pou¾ijte my¹\n"
-#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr "Pou¾ijte 'd.frame -e' pro smazání zbylých rámcù"
+#, fuzzy
#~ msgid "Error opening cell-file"
-#~ msgstr "Chyba pøi otevírání souboru cell"
+#~ msgstr "Chyba pøi otevírání kanálu %i"
+#, fuzzy
#~ msgid "Error reading from cell-file"
-#~ msgstr "Chyba pøi ètení souboru cell"
+#~ msgstr "Chyba pøi ètení doèasného souboru"
-#~ msgid "Mysterious window inconsistancy error"
-#~ msgstr "Záhadná chyba nekonzistence okna"
+#, fuzzy
#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: Nelze otevøít rastrový soubor <%s@%s>"
+#~ msgstr "Nelze otevøít rastrovou mapu <%s>"
-#~ msgid "%s: 'is_null_value()' got NULL pointer!"
-#~ msgstr "%s: 'is_null_value()' dostala NULLový pointer!"
-#~ msgid "%s: 'is_null_value()' got negative column index"
-#~ msgstr "%s: 'is_null_value()' dostala negativní index sloupeèku"
-#~ msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
-#~ msgstr "%s: 'is_null_value()' Neznámý RASTER_MAP_TYPE '%d'"
+#, fuzzy
#~ msgid "Use mouse to size & place legend"
-#~ msgstr "Pou¾ít my¹ pro velikost a umístìní legendy"
+#~ msgstr ""
+#~ "\n"
+#~ "Pou¾ít my¹ pro kreslení linie profilu\n"
+#, fuzzy
#~ msgid "Interactively select route"
-#~ msgstr "Interaktivní výbìr trasy"
+#~ msgstr "Interaktivní výbìr koncových bodù"
+#, fuzzy
#~ msgid "You must select more than one point"
-#~ msgstr "Je potøeba vybrat více ne¾ jeden bod"
+#~ msgstr "Musíte vybrat alespoò jeden nástroj"
+#, fuzzy
#~ msgid "You must select at least four points"
-#~ msgstr "Musíte vybrat nejménì ètyøi body."
-#~ msgid "Usage: %s monitor_name"
-#~ msgstr "Pou¾ití: %s jmeno_monitoru"
-#~ msgid "%s: -%c unrecognized option"
-#~ msgstr "%s: -%c nerozpoznaná volba"
-#~ msgid "Usage: %s [-f] monitor_name"
-#~ msgstr "Pou¾ití: %s [-f] jmeno_monitoru"
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Monitor '%s' ukonèen"
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Chyba - Monitor '%s' nebì¾í"
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "Monitor <%s> neexistuje"
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Chyba - Monitor '%s' je pou¾íván jiným u¾ivatelem"
+#, fuzzy
#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Chyba - selhal zamykací mechanismus"
+#~ msgstr "Chyba pøi zavírání souboru ASCII"
+#, fuzzy
#~ msgid "Monitor <%s> released"
-#~ msgstr "monitor <%s> byl uvolnìn"
+#~ msgstr "Location <%s> vytvoøena"
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Monitor <%s> je pou¾íván jiným u¾ivatelem"
-#~ msgid "Failed testing lock mechanism"
-#~ msgstr "Testování uzamykacího mechanismu selhalo"
-#~ msgid "Usage: %s [-fv] [name]"
-#~ msgstr "Pou¾ití: %s [-fv] [jmeno]"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Slou¾í k vytvoøení a kontrole grafického monitoru."
+#, fuzzy
#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Jméno grafického monitoru, který bude spu¹tìn"
+#~ msgstr "Jméno rastrové mapy, obsahující výsledky"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Jméno grafického monitoru, který bude vypnut"
+#, fuzzy
#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Jméno grafického monitoru, který bude vybrán"
+#~ msgstr "®ádné grafické zaøízení nebylo vybráno"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Jméno monitoru k odemèení"
+#, fuzzy
#~ msgid "List all monitors"
-#~ msgstr "Seznam v¹ech monitorù"
+#~ msgstr "Seznam vrstevnic (isolinií)"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Seznam monitorù (s aktuálním stavem)"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Vypi¹ jméno aktuálnì vybraného monitoru"
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Uvolni souèasný vybraný monitor"
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "Nevybírej monitor automaticky pøi startu"
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Problém pøi výbìru monitoru %s. Zkusím to je¹tì jednou"
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Nelze vyèistit aktuální okno"
-#~ msgid "One mouse click only"
-#~ msgstr "Pouze jedno kliknutí my¹í"
-#~ msgid "Rendering method for filled polygons"
-#~ msgstr "Vykreslovací metoda pro plné polygony"
#, fuzzy
-#~ msgid ""
-#~ "d;use the display library basic functions (features: polylines);c;use the "
-#~ "display library clipping functions (features: clipping);l;use the display "
-#~ "library culling functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "g;pou¾ití vykreslovacích funkcí(prvky:vystøihování);r;pou¾ití knihovny "
-#~ "funkcí pro rastrovou grafiku (prvky: lomená èára);d;pou¾ití knihovny "
-#~ "základních zobrazovacích funkcí (prvky: lomená èára);c; pou¾ití knihovny "
-#~ "zobrazovacích vystøihovacích funkcí (prvky: vystøihování);l;pou¾ití "
-#~ "knihovny zobrazovacích odstraòovacích funkcí (prvky: odstranìní, lomená "
-#~ "èára)"
#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Neplatná zobrazovací metoda: <%s>"
+#~ msgstr "Neplatná metoda: %s"
#, fuzzy
-#~ msgid ""
-#~ "Displays the rhumbline joining two user-specified points, in the active "
-#~ "frame on the user's graphics monitor."
+#~ msgid "Use mouse to interactively place text"
#~ msgstr ""
-#~ "Zobrazí plochy tématické vektorové mapy v aktivním rámci grafického "
-#~ "monitoru."
+#~ "\n"
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "Pou¾ít my¹ pro umístìní textu"
-#~ msgid "Click!\n"
-#~ msgstr "Klik!\n"
+#, fuzzy
#~ msgid " Left: Place text here\n"
-#~ msgstr " Levé: Vlo¾it text sem\n"
+#~ msgstr "Levé tlaèítko: Oznaè dal¹í bod\n"
-#~ msgid " Right: Quit\n"
-#~ msgstr " Pravé : ukonèit\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Pouze pøekresli zobrazené mapy s výchozími barvami."
+#, fuzzy
#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "CHYBA: nelze získat polo¾ky \"list\""
+#~ msgstr "Nelze získat seznam tabulek:\n"
-#~ msgid "-j flag forced"
-#~ msgstr "volba -j byla nastavena nucenì"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Nebyla zobrazena ¾ádná mapa v monitoru GRASSu"
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "Nepøidávat do seznamu v monitoru pøíkazy"
+#, fuzzy
#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Vytvoøí a zobrazí jednoduché grafické prvky na mapì vykreslené v aktivním "
-#~ "grafickém monitoru."
-#~ msgid ""
#~ "Unix file containg graphing instructions, if not given reads from "
#~ "standard input"
-#~ msgstr ""
-#~ "Soubor (Unix) obsahující grafické instrukce, pokud není zadáno, ète se "
-#~ "standardní vstup"
+#~ msgstr "Soubor ASCII pro import, pokud není zadán, ète se standardní vstup"
+#, fuzzy
#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Barva kresby, buï standardní GRASS barva nebo trojice R:G:B (oddìleno "
-#~ "dvojteèkou)"
-#~ msgid ""
#~ "\n"
#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Tlaèítka my¹i:"
+#~ msgstr "Tlaèítka:\n"
-#~ msgid "Left: Select From\n"
-#~ msgstr " Levé: Vybrat z\n"
+#, fuzzy
#~ msgid "Middle: Select To\n"
-#~ msgstr "Prostøední tlaèítko: Vybrat do\n"
+#~ msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
-#~ msgid ""
-#~ "Right: Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ " Pravé tlaèítko: ukonèit\n"
-#~ "\n"
#, fuzzy
-#~ msgid "Short user prompt message"
-#~ msgstr "Vytiskni také zprávu o autorských právech"
-#~ msgid "Click here to CONTINUE\n"
-#~ msgstr "ZDE kliknìte pro pokraèování\n"
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitor: XgetWMName selhalo"
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitor: XGetWMName: ¹patný výsledek"
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitor: interaktivní pøíkaz v pøekreslení"
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "nalezeno %d zobrazení typu TrueColor"
-#~ msgid "searching for highest bit depth"
-#~ msgstr "hledám nejvìt¹í bitovou hloubku"
#~ msgid "selected %d bit depth"
-#~ msgstr "vybrána hloubka %d bitù"
+#~ msgstr "%d pixelù smazáno "
-#~ msgid "using default visual which is %s"
-#~ msgstr "pou¾ívám výchozí zobrazení, co¾ je %s"
+#, fuzzy
#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Chyba pøi výbìru rámce [%s]\n"
+#~ msgstr "Chyba pøi ètení rozsahu pro [%s]"
+#, fuzzy
#~ msgid ""
#~ "\n"
#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Tlaèítka:\n"
-#~ msgid "Left: Select frame\n"
-#~ msgstr " Levé: Vybrat rámec\n"
-#~ msgid "Middle: Keep original frame\n"
-#~ msgstr "Prostøední: Ponechat pùvodní rám\n"
-#~ msgid "Right: Accept frame\n"
-#~ msgstr "Pravé: Potvrï rámec\n"
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr "Správa rámcù v grafickém monitoru"
+#, fuzzy
#~ msgid "Create a new frame"
-#~ msgstr "Vytvoøit nový rámec"
+#~ msgstr "Vytvoøit celoèíselnou mapu"
+#, fuzzy
#~ msgid "Select a frame"
-#~ msgstr "Vybrat rámec"
+#~ msgstr "Vyber data z tabulky."
-#~ msgid "Print name of current frame"
-#~ msgstr "Vypsat aktuální rámec"
+#, fuzzy
#~ msgid "Print names of all frames"
-#~ msgstr "Vytisknout jména v¹ech rámcù"
+#~ msgstr "Vytiskni celkový rozsah ploch"
-#~ msgid "List map names displayed in GRASS monitor"
-#~ msgstr "Vypi¹ jména map zobrazených v grafickém monitoru"
+#, fuzzy
#~ msgid "Debugging output"
-#~ msgstr "Roz¹íøený výstup"
+#~ msgstr "Zapisuji výstupní vrstvu..."
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Rámec, který má být vytvoøen/vybrán"
-#~ msgid "bottom,top,left,right"
-#~ msgstr "spodní,svrchní,levý,pravý"
-#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "Kam umístit rám, hodnoty v procentech (potøebuje volbu -c)"
+#, fuzzy
#~ msgid "No raster map exists in current window"
-#~ msgstr "V aktuálním oknì není ¾ádná rastrová mapa"
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr "Vytvoøit a zobrazit menu v aktivní rámci grafického monitoru."
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "Nastaví barvu pozadí menu"
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Nastavit barvu textu v menu"
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "Nastaví barvu linií oddìlujících øádky textu"
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "Nastaví velikost písma v menu (procenta)"
+#, fuzzy
#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "Menu musí obsahovat titulek a nejménì jednu volbu"
+#, fuzzy
#~ msgid "No current frame"
-#~ msgstr "®ádný aktuální rámec"
+#~ msgstr "Nastav z aktuálního regionu"
+#, fuzzy
#~ msgid "Current frame not available"
-#~ msgstr "Aktuální rámec není dostupný"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "hodnota [%.0f,%.0f] je mimo interval [0-100]"
-#~ msgid ""
-#~ "g;use the libgis render functions (features: clipping);r;use the raster "
-#~ "graphics library functions (features: polylines);d;use the display "
-#~ "library basic functions (features: polylines);c;use the display library "
-#~ "clipping functions (features: clipping);l;use the display library culling "
-#~ "functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "èára)"
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "Nepøidávej do seznamu vektorù a pøíkazù v monitoru (nebude vykresleno, "
-#~ "pokud monitoru bude pøekreslen)"
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Vytvoøí seznam pøíkazù pro obnovení obsahu monitoru."
+#, fuzzy
#~ msgid "Name of frame(s) to save"
-#~ msgstr "Název rámu(ù) urèeného k ulo¾ení"
+#~ msgstr "Tvùrce mapy: %s"
-#~ msgid ""
-#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
-#~ "the last object."
-#~ msgstr ""
-#~ "Seznam èísel objektù k vyjmutí, které jsou zobrazeny po \"#\" -1 pro "
-#~ "poslední objekt."
-#~ msgid ""
-#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
-#~ "be done first, if any."
-#~ msgstr ""
-#~ "Seznam èísel objektù, které budou pøejmenovány (\"from\" na \"to\"). "
-#~ "Nejprve bude provedena volba remove=."
+#, fuzzy
#~ msgid "Save current frame"
-#~ msgstr "Ulo¾ souèasný rám"
-#~ msgid "Save all the frames"
-#~ msgstr "Ulo¾ v¹echny rámy"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Pouze mapové objekty bez extra hlavièky a patièky"
+#, fuzzy
#~ msgid "No monitor selected"
-#~ msgstr "Nebyl vybrán ¾ádný monitor"
+#, fuzzy
#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Neznámý prvek v podlo¾ce: %s"
+#~ msgstr "Neznámý typ: %d"
+#, fuzzy
#~ msgid "Setting graphics window"
+#, fuzzy
#~ msgid "Can't set current graphics window"
+#, fuzzy
#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Pou¾ívám souøadnice monitoru"
+#~ msgstr "Východní souøadnice mapy"
+#, fuzzy
#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Pou¾ít my¹ pro umístìní mìøítka"
-#~ msgid ""
-#~ "Format error: <%s>\n"
-#~ "Line: %d\n"
-#~ "%s"
#~ msgstr ""
-#~ "Chyba formátu: <%s>\n"
-#~ "Linie: %d\n"
-#~ "%s"
+#~ "\n"
+#, fuzzy
#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> je neplatný název regionu"
+#~ msgstr "<%s> je neplatné jméno souboru"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING! A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "VAROVÁNÍ! V této location ji¾ existuje soubor s projekcí\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr "Stále si pøejete pøepsat aktuální informace o projekci"
+#, fuzzy
#~ msgid "The projection information will not be updated."
-#~ msgstr "Informace o projekci nebudou aktualizovány."
+#~ msgstr "Pøedpona vstupní mapy s informacemi o horizontu"
-#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr "Povolit interaktivní vyzívání (pouze s pou¾itím pøíkazového øádku)"
+#, fuzzy
#~ msgid "Erasing monitors..."
-#~ msgstr "Ma¾u monitory ... "
+#~ msgstr "Extrahuji body..."
-#~ msgid ""
-#~ "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based "
-#~ "GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI"
-#~ msgstr ""
-#~ "tcltk;Tcl/Tk grafické prostøedí - GIS Manager (gis.m);oldtcltk;Strar¹í "
-#~ "Tcl/Tk grafické prostøedí - Display Manager (d.m);wxpython; Grafické "
-#~ "prostøedí budoucí generace zalo¾ené na WxPyton"
+#, fuzzy
#~ msgid "Removing %s <%s>"
-#~ msgstr "Odstraòuji %s <%s>"
+#~ msgstr "Naèítám <%s> v <%s>"
-#~ msgid "couldn't be removed"
-#~ msgstr "nemohu odstranit"
-#~ msgid "%s: couldn't be removed"
-#~ msgstr "%s nelze odstranit"
-#~ msgid "%s: missing"
-#~ msgstr "%s: chybí"
+#, fuzzy
#~ msgid "%s: removed"
-#~ msgstr "%s odstranìn"
+#~ msgstr "%d lomových bodù smazáno"
+#, fuzzy
#~ msgid "<%s> nothing removed"
-#~ msgstr "<%s> není odstranìno"
-#~ msgid ""
-#~ "Divides active display into two frames & displays maps/executes commands "
-#~ "in each frame."
-#~ msgstr ""
-#~ "Rozdìlí aktivní monitor na dva rámy a v ka¾dém rámu zobrazí mapu a pøíkaz "
-#~ "pro její vytvoøení."
+#, fuzzy
#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Rastrová mapa, která má být zobrazena v první rámu"
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Vlo¾te pøíkaz pro vykonání v první rámu"
+#, fuzzy
#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Rastrová mapa, která má být zobrazena v druhém rámu"
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "Vlo¾te pøíkaz pro vykonání v druhém rámu"
+#, fuzzy
#~ msgid "How to split display"
-#~ msgstr "Jak rozdìlit monitor"
+#~ msgstr "Nelze otevøít displej"
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Ulo¾í obsah aktuálního monitoru jako soubor s obrázkem."
+#, fuzzy
#~ msgid "display, export"
-#~ msgstr "zobrazení, export"
+#, fuzzy
#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Jméno obrázku (NEpøidávejte koncovku)"
+#~ msgstr "Jméno výstupního souboru s výsledky chybové matice a kappa index"
-#~ msgid "Dimensions of output file versus current window size"
-#~ msgstr "Rozmìry výstupu versus souèasná velikost okna"
-#~ msgid "(same=1, double size=2, quadruple size=4)"
-#~ msgstr "(stejná velikost=1, dvojitá=2, ètyønásobná=4)"
+#, fuzzy
#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "©íøka a vý¹ka výstupního obrazu (pøepí¹e nastavení rozli¹ení)"
+#~ msgstr "©íøka a vá¹ka oken v møí¾ce"
-#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr "(0=nic, 1=nejrychleji, 9=bezeztrát; pouze èas vs velikost souboru)"
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Velikost/kvalita souboru JPEG"
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "(10=nejmen¹í/nejhor¹í, 100=nejvìt¹í/nejlep¹í)"
+#, fuzzy
#~ msgid "Paper size for PostScript output"
-#~ msgstr "Velikost papíru pro výstup v PostScript."
+#~ msgstr "Výstupní soubor ve formátu PostScript"
-#~ msgid "PostScript level (only limits functionality!)"
-#~ msgstr "Úroveò Postscriptu ( pouze omezuje funkènost!)"
-#~ msgid "GeoTIFF"
-#~ msgstr "GeoTIFF"
+#, fuzzy
#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
-#~ msgstr "GeoTIFF klíèe metadat a hodnoty pro pøidání"
+#~ msgstr "Klíèe metadat a hodnoty pro vlo¾ení"
+#, fuzzy
#~ msgid ""
#~ "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr "Ve formuláøi \"META-TAG=VALUE\", odìlujte násobný vstup teèkou."
+#~ msgstr "Ve výrazu \"NAME=VALUE\", oddìlte více polo¾ek èárkami."
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Nastav barvu pozadí na èernou (bílá je výchozí)"
-#~ msgid "Set transparent background"
-#~ msgstr "Nastavit prùhledné pozadí"
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Pou¾ít ovladaè Cairo pro vykreslení obrazù"
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Nastavit papír na orientaci krajina (pro výstup Postscript)"
+#, fuzzy
#~ msgid "Do not crop away margins"
-#~ msgstr "NEoøezávat okraje"
+#~ msgstr "Nekopírovat atributovou tabulku"
+#, fuzzy
#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Slide show rastrù/vektorù."
+#~ msgstr "Importuje star¹í verze GRASS vektorových map."
+#, fuzzy
#~ msgid "display, slideshow"
-#~ msgstr "zobrazení, prezentace"
+#, fuzzy
#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Zobrazit vektory, místo rastrù"
+#~ msgstr "Nastav region tak, aby odpovídal této rastrové mapì"
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr ""
-#~ "Pøedpona mapy. Zadejte písmeno(na) pro zobrazení pouze vybraných map"
-#~ msgid "Map number show across the monitor"
-#~ msgstr "Poèet map zobrazených na monitoru"
-#~ msgid "Map number show down the monitor"
-#~ msgstr "Poèet map zobrazených pod monitorem"
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "Mapset který bude pou¾it. Více mapsetù lze oddìlit èárkou"
+#, fuzzy
#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Poèet vteøin pro pøestávku mezi slidy."
+#~ msgstr "Poèet bunìk mezi drahami odtoku"
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#~ msgstr "Tvorba nové grid3d volume mapy na základì výrazu pro r3.mapcalc."
+#, fuzzy
#~ msgid "A (grid3D file)"
-#~ msgstr "A (soubor grid3D)"
+#~ msgstr "Vstupní soubor grid3"
+#, fuzzy
#~ msgid "B (grid3D file)"
-#~ msgstr "B (soubor grid3D)"
+#, fuzzy
#~ msgid "C (grid3D file)"
-#~ msgstr "C (soubor grid3D)"
+#, fuzzy
#~ msgid "D (grid3D file)"
-#~ msgstr "D (soubor grid3D)"
+#, fuzzy
#~ msgid "E (grid3D file)"
-#~ msgstr "E (soubor grid3D)"
+#, fuzzy
#~ msgid "F (grid3D file)"
-#~ msgstr "F (soubor grid3D)"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Vzorec (napø. A-B nebo A*C+B)"
+#, fuzzy
#~ msgid "Name for output grid3D volume"
-#~ msgstr "Název výstupního souboru grid3D objem"
+#~ msgstr "Název výstupního souboru"
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Expertní mód (zadejte soubor výrazù pro r3.mapcalc)"
+#, fuzzy
#~ msgid "Do not overwrite existing map"
-#~ msgstr "Nepøepisuj existující mapu"
+#~ msgstr "Pou¾ijte -o k pøepsání existujícího spojení pro vrstvu <%d>"
+#, fuzzy
#~ msgid "Display manager for GRASS"
-#~ msgstr "GIS manager pro GRASS"
+#, fuzzy
#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Jméno souboru s nastavením .dmrc"
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "roz¹íøená statistika (kvartily a percentily)"
+#, fuzzy
#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Percentil, který se má spoèítat (vy¾aduje pøepínaè -e)"
+#~ msgstr ""
+#~ "Percentil, který se má spoèítat (vy¾aduje pøepínaè roz¹íøení statistiky)"
+#, fuzzy
#~ msgid "Resizes active display monitor"
-#~ msgstr "Mìní velikost aktivního monitoru"
+#~ msgstr "Nahla¹ informace o vstupním rastru a ukonèi se"
-#~ msgid "New width for window"
-#~ msgstr "Nová ¹íøka okna"
-#~ msgid "New height for window"
-#~ msgstr "Nová vý¹ka okna"
-#~ msgid ""
-#~ "The database must be in form printed by v.db.connect -g, i.e. with "
-#~ "substituted variables"
-#~ msgstr ""
-#~ "Databáze musí být ve formì vyti¹tìné v.db.connect -g, napø. s vymìnìnými "
-#~ "hodnotami"
-#~ msgid "Use image list and not group"
-#~ msgstr "Pou¾ij seznam snímkù a ne skupinu"
-#~ msgid "Select multiple points"
-#~ msgstr "Vyber více bodù"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Vybere/nastartuje zadaný monitor o zadané velikosti"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "©íøka nového monitoru v pixelech "
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Vý¹ka nového monitoru v pixelech"
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Poèítá novou mapu z výrazu pro r.mapcalc."
-#~ msgid "A"
-#~ msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
-#~ msgid "E"
-#~ msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Expertní mód (zadejte soubor výrazù pro r.mapcalc)"
+#, fuzzy
#~ msgid "Exports GRASS raster into GDAL supported formats."
#~ msgstr ""
-#~ "Exportuje GRASS rastry do jednoho z formátù podporovaných knihovnou GDAL."
+#~ "Exportuje GRASS rastrové mapy do jednoho z formátù podporovaných "
+#~ "knihovnou GDAL."
+#, fuzzy
#~ msgid ""
#~ "Creation option to the output format driver. Multiple options may be "
#~ "listed"
-#~ msgstr "Volby pro ovladaè výstupního formátu. Volby je mo¾no kombinovat."
+#~ msgstr "Vytvoøení mo¾ností pro uspì¹né projítí ovladaèem formátu výstupu"
-#~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr "Pokud je to mo¾né, pøedat na výstup klíè metadat"
+#, fuzzy
#~ msgid "run non-interactively"
-#~ msgstr "spustit neinteraktivnì"
+#~ msgstr "Spustit interaktivnì"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr "Exportuj monitor do souboru kompatibilním s GpsDrive"
+#, fuzzy
#~ msgid "display, export, GPS"
-#~ msgstr "zobrazení, export, GPS"
-#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-#~ msgstr "jméno nového obrázku (bude ulo¾en do ~/.gpsdrive/maps)"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Vytvoø JPEG místo PNG"
+#, fuzzy
#~ msgid "Run non-interactively"
-#~ msgstr "Spustit neinteraktivnì"
-#~ msgid "GIS manager for GRASS"
+#, fuzzy
#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Jméno souboru s nastavením pro GIS manager (.grc)"
+#~ msgstr "Název existujícího MAT-souboru(v4)"
-#~ msgid "1st map for mosaic (top of image stack)."
-#~ msgstr "První mapa pro mozaiku (v seznamu mozaiky zcela nahoøe)"
-#~ msgid "3rd map for mosaic."
-#~ msgstr "tøetí mapa mozaiky"
-#~ msgid "4th map for mosaic."
-#~ msgstr "ètvrtá mapa mozaiky"
+#, fuzzy
#~ msgid "Name of raster map to print in legend"
-#~ msgstr "Název rastrové mapy která bude zobrazena v legendì"
-#~ msgid "Position of vertical map-legend separator (in percent)"
-#~ msgstr "Umístìní vertikálního oddìlovaèe mapové legendy (v procentech)"
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Ulo¾í aktuální obsah monitoru do souboru PNG v domovském adresáøi"
+#, fuzzy
#~ msgid "Name of PNG file"
-#~ msgstr "Jméno souboru PNG"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Rozli¹ení výstupního souboru (1x, 2x, 4x)"
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Pøesune aktuálnì zobrazené mapy do jiného monitoru"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "Vyèisti cílový monitor pøed pøesunem"
-#~ msgid "stay with source monitor"
-#~ msgstr "zùstaò ve zdrojovém monitoru"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "zab zdrojový monitor po pøesunu"
+#, fuzzy
#~ msgid "Target monitor"
-#~ msgstr "Cílový monitor"
-#~ msgid "Source monitor"
-#~ msgstr "Zdrojový monitor"
-#~ msgid "Split the display into subframes."
-#~ msgstr "Rozdìlit diplej do rámù"
+#, fuzzy
#~ msgid "Number of subframes"
-#~ msgstr "Poèet rámù"
+#~ msgstr "Poèet øádkù"
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Pøekreslí aktuálnì zobrazené mapy v monitoru"
+#, fuzzy
#~ msgid "Redraw all frames"
-#~ msgstr "Pøekreslit v¹echny rámy"
-#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr "Nedor¾ovat individuální regiony pokud pøekraslují v¹echny rámy"
-#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr ""
-#~ "Vypovídej se, chlapèe (vytiskni parametry projekce a jména souborù na "
-#~ "standardní chybu)"
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Pøevede 3D rastrové mapy (G3D) do formátu VTK-Ascii"
@@ -33726,9 +33551,6 @@
#~ "POu¾ívám GRASS vektorovou mapu bodù pro vytvoøení vektorové mapy "
#~ "konvexního obalu."
-#~ msgid "Name of output vector area map"
-#~ msgstr "Název výstupní vektorové vrstvy"
#~ msgid "Cannot open vector map <%s>"
@@ -35259,18 +35081,6 @@
#~ msgid "raster, null data"
#~ msgstr "rastr, noullvé data"
-#~ msgid "Do not export long colortable"
-#~ msgstr "nelze exportovat dlouhou tabulku barev"
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %d "
-#~ "was used to represent no-data values in the input map. You can specify "
-#~ "nodata value by %s parameter."
-#~ msgstr ""
-#~ "Vstupní rastrová mapa obsahující NULLové hodnoty (¾ádná data). Pro "
-#~ "NULLové hodnoty byla pou¾ita hodnota %d. Mù¾ete urèit hodnotu "
-#~ "reprezentující NULLové hodnoty parametrem %s."
#~ msgid "Import as Floating Point Data (default: Integer)"
#~ msgstr ""
#~ "Naimportuj jako hodnoty s plovoucí desetinnou èárkou (float) (výchozí: "
@@ -35420,30 +35230,9 @@
#~ "[S=mapa_faktoru_sklonu_svahu] LS=mapa_faktoru_sklonu_a_délky_svahu "
#~ "[r=mapa_stru¾kové_eroze] [sd=hodnota_sklonu_svahu_pøi_depozici]"
-#~ msgid "SECTION 3: Accumulating Surface Flow."
-#~ msgstr "ÈÁST 3: Akumulace povrchového odtoku."
-#~ msgid "SECTION 4: Length Slope determination."
-#~ msgstr "ÈÁST 4: Urèuji délku svahu."
-#~ msgid "unable to open new L map layer."
-#~ msgstr "Nelze otevøít novou mapu L (faktoru délky svahu)"
-#~ msgid "unable to open new S map layer."
-#~ msgstr "nemohu otevøít novou mapu S (faktor sklonu svahu)"
#~ msgid "Input value: maximum length of surface flow, for USLE"
#~ msgstr "Vstupní hodnota: maximální délka povrchového odtoku, pro USLE"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ " basin, stream, half.basin, slope, or lS\n"
-#~ " you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "Promiòte, pokud je zadána nìkterá z následujících voleb:\n"
-#~ " basin, stream, half.basin, slope nebo LS\n"
-#~ " MUSÍTE zadat prahovou hodnotu povodí (basin threshold)."
#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
#~ msgstr "Nastavuji kvant. pravidla pro vstupní map[y] na (%f %f) -> (%d,%d)"
@@ -35734,9 +35523,6 @@
#~ msgid "Randomly generate a 2D/3D vector points map."
#~ msgstr "Náhodnì vytvoøit 2D/3D bodovou vektorovou vrstvu."
-#~ msgid "Writes Z data to column instead of 3D vector"
-#~ msgstr "Zapí¹e y-souøadnice do sloupce místo vytvoøení 3D vektoru"
#~ msgid "v.random can't create 3D vector and attribute table at same time"
#~ msgstr ""
#~ "v.random nemù¾e vytvoøit 3D vektorovou mapu a atributovou tabulku ve "
@@ -35800,9 +35586,6 @@
#~ msgid "Name of input vector points map"
#~ msgstr "Název vstupní bodové vektorové vrstvy"
-#~ msgid "Convex hull calculation requires at least three points"
-#~ msgstr "Výpoèet konvexního obalu po¾aduje nejménì 3 body"
#~ msgid "Exports a GRASS vector map to SVG."
#~ msgstr "Exportuje GRASS vektory jako soubor SVG."
@@ -35970,3 +35753,511 @@
#~ msgid "Unable to determine raster cell type"
#~ msgstr "Nelze zjistit typ rastrové (cell) mapy."
+#~ msgid "The initial piezometric head in [m]"
+#~ msgstr "Poèáteèní piezometrická hodnota v [m]"
+#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgstr ""
+#~ "Status pro ka¾dou buòku, = 0 -neaktivní, 1 - aktivní, 2 - Dirichletovo "
+#~ "¹íøení"
+#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "souøadnice z hydraulického napøimovaèe vodivosti v [m/s]"
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Mapa obohacení v m^3/s "
+#~ msgid ""
+#~ "The piezometric head result of the numerical calculation will be written "
+#~ "to this map"
+#~ msgstr ""
+#~ "Výsledná piezometrická hodnota numerického výpoètu bude zapsána do mapy"
+#~ msgid "Name of base raster map"
+#~ msgstr "Název základní rastrové mapy"
+#~ msgid "Converting %s..."
+#~ msgstr "Pøevádím %s..."
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Název výstupní rastrové mapy s jezery"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgid ""
+#~ "Sediment transport and erosion/deposition simulation using path sampling "
+#~ "method (SIMWE)"
+#~ msgstr ""
+#~ "Simulace transportu sedimentù a eroze/usazování za pou¾ití vzorové cesty "
+#~ "(SIMWE)"
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "Jméno rastrové mapy s vý¹kou vodní hladiny [m]"
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Název rastrové mapy s derivací x [m/m]"
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#~ msgstr "Název rastrové mapy s derivací y [m/m]"
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "Jméno rastrové mapy s koeficientem klidové kapacity [s/m]"
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Jméno rastrové mapy koeficientu transportní kapacity [s]"
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "Jméno rastrové mapy kritických støihù [Pa]"
+#~ msgid "Name of the Mannings n raster map"
+#~ msgstr "Název rastrovéhé mapy drsnosti (Manningovo n)"
+#~ msgid "Name of the Mannings n value"
+#~ msgstr "Název hodnoty Manningova n"
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Výstupní rastrová mapa transportní kapacity [kg/ms]"
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr ""
+#~ "Výstupní rastrová mapa transportem limitované eroze-usazování [kg/m2s]"
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Výstupní rastrová mapa koncentrace sedimentu [èástice/m3]"
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Výstupní rastrová mapa toku sedimentù [kg/ms]"
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#~ msgstr "Výstupní rastrová mapa usazování-eroze [kg/m2s]"
+#~ msgid ""
+#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+#~ msgstr ""
+#~ "Hydrologický model povrchového odtoku s pou¾itím metody vzorové cesty "
+#~ "(SIMWE)"
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr ""
+#~ "Jméno rastrové mapy míry nadbyteènosti srá¾ej (rein-infilt) [mm/hod]"
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "Jméno rastrové mapy pomìru odtoku a infiltrace [mm/hod]"
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr "Jméno rastrového souboru kontroly proudìní (pomìr permeability 0-1)"
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "Název výstupní rastrové mapy vypu¹tìní vody [m3/s]"
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Výstupní rastrová mapa chyb simulace [m]"
+#~ msgid ""
+#~ "Threshold water depth [m] (diffusion increases after this water depth is "
+#~ "reached)"
+#~ msgstr ""
+#~ "Prahová hloubka vody [m] (prostupnost se zvìt¹uje, pokud je tato hloubka "
+#~ "dosa¾ena)"
+#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
+#~ msgstr "Stav hranic, 0-neaktivní, 1-aktivní, 2-dirichlet"
+#~ msgid "Water sources and sinks in [m^3/s]"
+#~ msgstr "Vodní zdroje a jezera v [m^3/s]"
+#~ msgid "Specific yield in [1/m]"
+#~ msgstr "Specifický výnos v [1/m]"
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "Mapa doplnìní napø.: 6*10^-9 na buòku v [m^3/s*m^2]"
+#~ msgid "The map storing the numerical result [m]"
+#~ msgstr "Mpa obsahují poèetní výsledky [m]"
+#~ msgid "The height of the river bed in [m]"
+#~ msgstr "Vý¹ka øeèi¹tì v [m]"
+#~ msgid "Water level (head) of the river with leakage connection in [m]"
+#~ msgstr "Vý¹ka vodní hladiny øeky ve spojení s prùsakem v [m]"
+#~ msgid "The leakage coefficient of the river bed in [1/s]."
+#~ msgstr "Koeficient prùsaku dna øeky v [1/s]."
+#~ msgid "The height of the drainage bed in [m]"
+#~ msgstr "Vý¹ka odvodòovacího kanálu v [m]"
+#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
+#~ msgstr "Koeficient prùsaku dna odvodòovacího kanálu v [1/s]."
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Vstupní mapa: mno¾ství povrchového odtoku na buòku"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "Vstupní mapa: povrchu bránícího povrchovému odtoku, pro USLE"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Výstupní mapa: poèet bunìk, které teèou skrz ka¾dou buòku"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "Výstupní mapa: jednoznaèný ¹títek pro ka¾dé povodí"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "Výstupní mapa: ka¾dému sub-povodí je dána jednoznaèná hodnota"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr "Výstupní mapa: délka svahu a sklon, faktor (LS) pro USLE"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "Výstupní mapa: faktor sklonu svahu (S) pro USLE"
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "Vstupní hodnota: minimální velikost vnìj¹ího povodí"
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "Promiòte, pokud je zadána nìkterá z následujících voleb:\n"
+#~ " basin, stream, half.basin, slope nebo LS\n"
+#~ " MUSÍTE zadat prahovou hodnotu povodí (basin threshold)."
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "nemohu otevøít novou mapu akumulace "
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Z rastrové mapy digitálního modelu terénu odstraní umìle vytvoøené "
+#~ "sní¾eniny a vytvoøí mapu smìru odtoku."
+#~ msgid "Output direction raster map"
+#~ msgstr "Výstupní rastrová mapa orientace"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "Výstupní rastrová mapa problémových oblastí"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "Program pro tvorbu povrchù z vrstevnic ulo¾ených v rastrové podobì."
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "Název existující rastrové mapy obsahující vrstevnice"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Vytvoøí/upraví tabulku barev spojenou s rastrovou mapou."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Název rastrové mapy, ze které se má kopírovat tabulka barev"
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr ""
+#~ "Cesta k souboru s pravidly (\"-\" pro ètení pravidel ze standartního "
+#~ "vstupu)"
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "Vytvoøí rastrovou mapu se vzdáleností k prvkùm ve vstupní vrstvì."
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Mapa povodí vytvoøená r.water.outlet (MASKa)"
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) Mapa smìrù s mapou vý¹ek bez depresí"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) Poèet tøíd topografického indexu"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(i/o) Soubor se statistikou topografického indexu"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) Soubor s parametry pro TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "(i) Soubor srá¾ek a potenciální evapotranspirací"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "Poèítá plnì zastínìné oblasti z polohy Slunce a DMT buï A: je-li "
+#~ "specifikována pøesná pozice Slunce nebo B: pozice je spoèítána samostatnì "
+#~ "z hodnoty datum/èas pomocí r.sunmask."
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: vý¹ka Slunce nad horizontem, stupnì"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: azimut Slunce od serveru, stupnì"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: minuty (0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: vteøiny (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: èasová zóna (východ kladná, vzdálenost od Greewichského støedního èasu "
+#~ "(GMT), lze také zahrnout letní/zimní èas)"
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Vytvoøí novou mapovou vrstvu její¾ hodnoty budou zalo¾eny na "
+#~ "reklasifikaci hodnot výchozí rastrové mapy."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "Rastrová mapa, která má být reklasifikována"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "Pøevede rastrovou mapu na vektorovou."
+#~ msgid ""
+#~ "Do not build vector topology (use with care for massive point export)"
+#~ msgstr ""
+#~ "Nevytváøej vektorovou topologii (pou¾ít opatrnì pøi importu velkého "
+#~ "mno¾ství bodù)b"
+#~ msgid "The map E grid coordinates"
+#~ msgid "Stream width (in meters). Default is raster cell width"
+#~ msgstr "©íøka bystøiny (v metrech). Výchozí je ¹íøka rastrové buòky"
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr ""
+#~ "Konsrukce svahových køivek (drah odtoku), délek odtoku a hustoty odtoku "
+#~ "(do svahu) z rastrové mapy elevace (DMT)"
+#~ msgid "Output flowpath length raster map"
+#~ msgstr "Výstupní rastr délky svahu"
+#~ msgid "Output flowline density raster map"
+#~ msgstr "Výstupní rastr hustoty povrchového odtoku"
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "3-D délky místo 2-D"
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Vytvoøí mapu topografického indexu, [ln(a/tan(beta))], z rastrové mapy "
+#~ "digitálního modelu terénu."
+#~ msgid "Output topographic index map"
+#~ msgstr "Výstupní mapa topografického indexu:"
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "Formát"
+#, fuzzy
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#~ msgstr "Nelze èíst barevnou tabulku pro %s"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "U¾ivatel"
+#, fuzzy
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Mìl by být zadán \"value=\" nebo \"-i\""
+#, fuzzy
+#~ msgid "Unable to create face"
+#, fuzzy
+#~ msgid "Unable to set size"
+#~ msgstr "Nelze nastavit velikost písma"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#~ msgstr "Chyba pøi ètení mapy odstínu (hue)"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr "Soubor s kategoriemi pro <%s> není dostupný"
+#, fuzzy
+#~ msgid "List of categories to be displayed (INT maps)"
+#, fuzzy
+#~ msgid "Invert catlist"
+#~ msgstr "Invertovat barvy"
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "Nelze èíst symbol, nemohu zobrazit body"
+#~ msgid "vector, interpolation"
+#~ msgstr "vektor, interpolace"
+#, fuzzy
+#~ msgid ""
+#~ "If type is not given then DOUBLE PRECISION is used. Writes Z data to "
+#~ "column instead of 3D vector."
+#~ msgstr "Zapí¹e y-souøadnice do sloupce místo vytvoøení 3D vektoru"
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "Nelze pou¾ít sloupec <%s>"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "Výpoèet konvexního obalu po¾aduje nejménì 3 body"
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Vstupní mapa obsahující linie"
+#~ msgid "Area without centroid (may be OK for island)"
+#~ msgstr "Plochy bez centroidù (mù¾e být v poøádku pro ostrovy)"
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr "Vypi¹ parametry souèasného pøipojení ve stylu shellu a ukonèi se."
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "Vektorová mapa <%s> je spojena:"
+#, fuzzy
+#~ msgid "Verbose module output"
+#~ msgstr "Roz¹íøený mód"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#, fuzzy
+#~ msgid "Width and height of output image"
+#, fuzzy
+#~ msgid "Surface"
+#~ msgstr "Suma variance"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "sloupec(ce)"
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr ""
+#~ "Vytisknout/nastavit obecné DB pøipojení aktuálního mapsetu a ukonèit se."
+#~ msgid "Name of file with sql statement"
+#~ msgstr "Název souboru s pøíkazy sql"
+#, fuzzy
+#~ msgid "Region sensitive output"
+#~ msgstr "Ètu výstup z r.stats"
+#, fuzzy
+#~ msgid "raster, elevation"
+#~ msgstr "Sleduj terén"
+#, fuzzy
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#~ msgstr "Jméno vstupního souboru, nebo \"-\" proètení ze standardního vstupu"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "dpz, obrazové zpracování"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#~ msgstr "Hodnota izolinií"
+#, fuzzy
+#~ msgid "PostScript"
+#, fuzzy
+#~ msgid "raster, tiling"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "Název vstupní rastrové mapy(red -èervená)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "Vypi¹ dostupná pravidla barev a ukonèi se"
+#, fuzzy
+#~ msgid "display, diagram"
+#, fuzzy
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Vypí¹e statistiku pro rastrovou mapu."
+#, fuzzy
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "Rastrová mapa, která má být vzorkována"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr "Spoèítá univariantní statistiku z ne-nullových bunìk rastrové mapy."
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#~ msgstr "Jméno vektorové mapy k editaci"
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "Název rastrové mapy pro vlo¾ení do skupiny"
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#, fuzzy
+#~ msgid "Display monitor to start"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr ""
+#~ "Jméno OGR vrstvy, pokud není zadán, jsou pouze vyti¹tìny pøítomné vrstvy"
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#~ msgstr "rastr, analýza krajiny, index místa"
+#, fuzzy
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importuje binární rastrový soubor jako GRASS rastrovou mapu."
+#, fuzzy
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Jméno vstupní vektorové bodové mapy"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_de.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -9649,7 +9649,7 @@
"Parameter %s an."
#: ../raster/r.out.gdal/export_band.c:201
-#, fuzzy, c-format
+#, c-format
msgid ""
"The user given nodata value %g is present in rasterband <%s> and would lead "
"to data loss. Please specify a different nodata value with the %s parameter."
@@ -13085,7 +13085,7 @@
#: ../general/g.proj/main.c:77
msgid "Print projection information (in conventional GRASS format)"
msgstr ""
-"Gebe die Projetkionsinformationen (im konventionellen GRASS-Format) aus."
+"Gebe die Projektionsinformationen (im konventionellen GRASS-Format) aus."
#: ../general/g.proj/main.c:83
msgid "Verify datum information and print transformation parameters"
@@ -13094,7 +13094,7 @@
#: ../general/g.proj/main.c:89
msgid "Print projection information in PROJ.4 format"
-msgstr "Gebe die Projetkionsinformationen im PROJ.4-Format aus."
+msgstr "Gebe die Projektionsinformationen im PROJ.4-Format aus."
#: ../general/g.proj/main.c:95
msgid ""
@@ -13103,7 +13103,7 @@
#: ../general/g.proj/main.c:105
msgid "Print projection information in WKT format"
-msgstr "Gebe die Projetkionsinformationen im WKT-Format aus."
+msgstr "Gebe die Projektionsinformationen im WKT-Format aus."
#: ../general/g.proj/main.c:111
msgid "Use ESRI-style format (applies to WKT output only)"
@@ -31891,17 +31891,102 @@
msgstr ""
"Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
+msgid ""
+"The given nodata value is present in rasterband <%s> and would lead to data "
+"loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+"Der gewählte NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
+"Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
+"Parameter %s an."
+#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr ""
+"Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
+"möglich."
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr ""
+"Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, "
+"aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "Zu importierende Rasterdatei."
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr ""
+"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+#, fuzzy
+msgid "terrain analysis"
+msgstr "Raster, Geländeanalyse"
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "Kann die Vektorkarte <%s> auf dem Topologischen Level %d nicht öffnen."
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
+msgid "Do not export long colortable"
+msgstr "Exportiere keine langen Farbtabellen."
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d was "
+"used to represent no-data values in the input map. You can specify nodata "
+"value by %s parameter."
+msgstr ""
+"Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
+"%d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
+"können Nodata-Wert mit dem Parameter %s bestimmen."
+msgid ""
+"Sorry, if any of the following options are set:\n"
+" basin, stream, half.basin, slope, or lS\n"
+" you MUST provide a value for the basin threshold parameter."
+msgstr ""
+"Wenn eine der folgenden Optionen gesetzt wurde:\n"
+" basin, stream, half.basin, slope oder lS\n"
+" MÜSSEN Sie ein Wert für den Parameter 'basin threshold' angegeben."
+msgid "Writes Z data to column instead of 3D vector"
+msgstr "Schreibt Z Werte in eine Spalte anstelle der 3D Vektorkarte."
+msgid "Convex hull calculation requires at least three points"
+msgstr "Die Berechnung der konvexen Hülle erfordert zumindest drei Punkte."
+msgid "enable MFD flow (default is SFD (D8))"
+msgstr "Aktiviere MFD-Fluss (Standard ist SFD (D8))."
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr "Importiert Mapgen oder Matlab Vektorkarten nach GRASS."
+msgid "Default value: GRASS_GUI if defined otherwise tcltk"
+msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten tcltk"
+msgid ""
+"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
+"Display Manager (d.m);wxpython;wxPython based next generation GUI;text;"
+"command line interface only"
+msgstr ""
+"tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tk "
+"basiertes GUI - Display Manager (d.m);wxpython;wxPython basiertes GUI der "
+"nächsten Generation;text;Nur Kommandozeile"
#~ msgid "Not enough room in history file"
#~ msgstr "Nicht genug Platz in der History-Datei."
-#~ msgid ""
-#~ "The given nodata value is present in rasterband <%s> and would lead to "
-#~ "data loss. Please specify a different nodata value with the %s parameter."
-#~ msgstr ""
-#~ "Der gewählte NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
-#~ "Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
-#~ "Parameter %s an."
#~ msgid "New MAPSET name"
#~ msgstr "Neuer Mapset Name."
@@ -31917,12 +32002,6 @@
#~ msgid "Name of workspace file"
#~ msgstr "Name der Workspace-Datei."
-#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr ""
-#~ "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
-#~ "möglich."
#~ msgid "List of values to be displayed (FP maps)"
#~ msgstr "Liste der Werte die angezeigt werden sollen (FP-Karten)."
@@ -32036,83 +32115,13 @@
#~ msgid "DXY [%s] COMPLETE"
#~ msgstr "DXY [%s] KOMPLETT"
-#, fuzzy
#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr ""
-#~ "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank "
-#~ "ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
-#~ msgid ""
#~ msgstr ""
#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
#~ "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "Zu importierende Rasterdatei."
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr ""
-#~ "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu "
-#~ "lesen)."
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "Raster, Geländeanalyse"
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr ""
-#~ "Kann die Vektorkarte <%s> auf dem Topologischen Level %d nicht öffnen."
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
-#~ msgstr "Exportiere keine langen Farbtabellen."
-#~ msgid ""
-#~ msgstr ""
-#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
-#~ "Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu "
-#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
-#~ msgid ""
-#~ msgstr ""
-#~ "Wenn eine der folgenden Optionen gesetzt wurde:\n"
-#~ " basin, stream, half.basin, slope oder lS\n"
-#~ " MÜSSEN Sie ein Wert für den Parameter 'basin threshold' angegeben."
-#~ msgstr "Schreibt Z Werte in eine Spalte anstelle der 3D Vektorkarte."
-#~ msgstr "Die Berechnung der konvexen Hülle erfordert zumindest drei Punkte."
-#~ msgid "enable MFD flow (default is SFD (D8))"
-#~ msgstr "Aktiviere MFD-Fluss (Standard ist SFD (D8))."
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "Importiert Mapgen oder Matlab Vektorkarten nach GRASS."
#~ msgid "Sources and sinks in [m^3/s]"
#~ msgstr "Quellen und Senken in [m^3/s]"
@@ -36614,18 +36623,6 @@
#~ msgid "general, gui"
#~ msgstr "Allgemein, GUI"
-#~ msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-#~ msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten tcltk"
-#~ msgid ""
-#~ "GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;"
-#~ "text;command line interface only"
-#~ msgstr ""
-#~ "tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tk "
-#~ "basiertes GUI - Display Manager (d.m);wxpython;wxPython basiertes GUI der "
-#~ "nächsten Generation;text;Nur Kommandozeile"
#~ msgid "The old d.m GUI is not available for WinGRASS"
#~ msgstr "Das alte d.m GUI gibt es nicht für WinGRASS."
@@ -37113,3 +37110,64 @@
#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
#~ msgstr "Importiert Mapgen oder Matlab-ASCII Vektorkarten nach GRASS."
+#~ msgid "New LOCATION name (not location path)"
+#~ msgstr "Neuer LOCATION Name (nicht der Pfad zur Location)."
+#~ msgid "New GISDBASE (full path to the directory where the new location is)"
+#~ msgstr ""
+#~ "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die "
+#~ "neue L0cation befindet)."
+#, fuzzy
+#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
+#~ msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten tcltk"
+#, fuzzy
+#~ msgid ""
+#~ "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
+#~ "(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
+#~ "command line interface only"
+#~ msgstr ""
+#~ "tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tk "
+#~ "basiertes GUI - Display Manager (d.m);wxpython;wxPython basiertes GUI der "
+#~ "nächsten Generation;text;Nur Kommandozeile"
+#~ msgstr "Liste der Werte die angezeigt werden sollen (INT-Karten)."
+#~ msgstr "Invertiere Kategorieliste."
+#~ msgstr "Fläche ohne Zentroid (kann für Inseln OK sein)."
+#~ msgstr ""
+#~ "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+#~ msgstr "Vectorkarte <%s> ist verbunden durch:"
+#~ msgstr "Breite und Höhe des Ausgabe-Bildes."
+#~ msgstr ""
+#~ "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
+#~ "beendet sich."
+#~ msgstr "Name der Datei, die SQL-Befehle enthält"
+#~ msgid "Slower but accurate (applies to FP maps only)"
+#~ msgstr "Langsamer aber genau (gilt nur für Fließkomma-Karten)."
+#~ msgid "Set color rules based on stddev from a map's mean value."
+#~ msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
+#~ msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
+#~ msgid "Layer where to add column"
+#~ msgstr "Layer, in dem eine Spalte hinzugefügt werden soll."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_el.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2480,9 +2480,8 @@
msgstr ""
#: ../raster/r.in.gdal/main.c:206
-#, fuzzy
msgid "Available GDAL Drivers:"
-msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
+msgstr ""
#: ../raster/r.in.gdal/main.c:227 ../raster/r.proj/main.c:282
#: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
@@ -3026,7 +3025,7 @@
#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
#, fuzzy
msgid "Writing output..."
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
+msgstr "ÅããñáöÞ %s áðü %s..."
#: ../raster/r.resamp.bspline/crosscorr.c:160
#, c-format
@@ -3132,7 +3131,7 @@
#: ../raster/r.drain/main.c:144
#, fuzzy
msgid "Name of vector map(s) containing starting point(s)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
+msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
#: ../raster/r.drain/main.c:149
msgid "Copy input cell values on output"
@@ -8301,8 +8300,9 @@
msgstr ""
#: ../raster/r.colors/main.c:191
+#, fuzzy
msgid "Path to rules file"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
#: ../raster/r.colors/main.c:192
msgid "\"-\" to read rules from stdin"
@@ -8818,7 +8818,7 @@
#: ../raster/r.out.gdal/main.c:510 ../raster/r.out.gdal/main.c:514
#, fuzzy
msgid "Raster export aborted."
-msgstr "Ôï 3Ä ñÜóôåñ áñ÷åßï èá ìåôáôñáðåß óå ASCII"
+msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
#: ../raster/r.out.gdal/main.c:491
msgid "Checking GDAL data type and nodata value"
@@ -9955,9 +9955,8 @@
msgstr "×ñþìá"
#: ../raster/r.reclass/main.c:65
-#, fuzzy
msgid "File containing reclass rules"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
+msgstr ""
#: ../raster/r.reclass/main.c:66
#, fuzzy
@@ -12459,7 +12458,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -19545,8 +19544,9 @@
#: ../vector/v.out.ogr/args.c:14
#: ../locale/scriptstrings/v.out.gps_to_translate.c:9
+#, fuzzy
msgid "Feature type(s)"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
#: ../vector/v.out.ogr/args.c:16
msgid ""
@@ -19824,9 +19824,8 @@
msgstr ""
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
+msgstr ""
#: ../vector/v.hull/main.c:64
msgid "Use all vector points (do not limit to current region)"
@@ -19839,7 +19838,7 @@
#: ../vector/v.hull/main.c:88
#, fuzzy, c-format
msgid "Error loading vector points from <%s>"
-msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
+msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
#: ../vector/v.hull/main.c:91
#, c-format
@@ -20112,8 +20111,9 @@
#: ../vector/v.lidar.edgedetection/edgedetection.c:233
#: ../vector/v.lidar.edgedetection/edgedetection.c:309
+#, fuzzy
msgid "Impossible to update aux table"
-msgstr ""
+msgstr "Áäõíáìßá ëßóôáò âÜóåùí äåäïìÝíùí"
#: ../vector/v.lidar.edgedetection/edgedetection.c:246
#: ../vector/v.lidar.edgedetection/edgedetection.c:258
@@ -21905,7 +21905,7 @@
#: ../vector/v.to.rast/vect2rast.c:35
#, fuzzy
msgid "Loading data..."
-msgstr "ÅããñáöÞ %s áðü %s..."
+msgstr "Öüñôùóç äåäïìÝíùí... (%dx%dx%d)"
#: ../vector/v.to.rast/vect2rast.c:41
#, c-format
@@ -23409,9 +23409,9 @@
msgstr "ÁíôéãñÜöåé Ýíá ðßíáêá"
#: ../vector/v.category/main.c:554
-#, fuzzy, c-format
+#, c-format
msgid "%d features modified."
-msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr ""
#: ../vector/v.surf.rst/main.c:145
msgid "RST"
@@ -23704,9 +23704,8 @@
msgstr ""
#: ../vector/v.lidar.correction/main.c:369
-#, fuzzy
msgid "Mean calculation"
+msgstr ""
#: ../vector/v.lidar.correction/main.c:383
msgid "Only TERRAIN points"
@@ -25778,11 +25777,12 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:24
#, fuzzy
msgid "Files & format"
-msgstr "Äéáìüñöùóç"
+msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
+msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
#: ../locale/scriptstrings/m.proj_to_translate.c:8
msgid "Field separator (format: input[,output])"
@@ -25800,9 +25800,8 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:14
#: ../locale/scriptstrings/m.proj_to_translate.c:16
#: ../locale/scriptstrings/m.proj_to_translate.c:18
-#, fuzzy
msgid "Projections"
-msgstr "¼íïìá ôïðïèåóßá"
+msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:13
msgid "Output projection parameters (PROJ.4 style)"
@@ -25950,8 +25949,9 @@
msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
-msgstr ""
+msgstr "Íïýìåñï åðéðÝäïõ"
#: ../locale/scriptstrings/r.tileset_to_translate.c:12
msgid "Maximum number of rows for a tile in the source projection"
@@ -25997,8 +25997,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
+#, fuzzy
msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr ""
+msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (NIR: tm4 | qbird_nir | spot2"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
#, fuzzy
@@ -26121,8 +26122,9 @@
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:6
+#, fuzzy
msgid "Percentage weight of first map for color blending"
-msgstr ""
+msgstr "¼íïìá ôïõ ðñþôïõ ñÜóôåñ ÷Üñôç ãéá blending"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
@@ -26161,12 +26163,14 @@
msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+#, fuzzy
msgid "Layer of the query vector containing data"
-msgstr ""
+msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+#, fuzzy
msgid "Column to be queried"
-msgstr ""
+msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
msgid "Maximum query distance in map units"
@@ -26182,8 +26186,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
@@ -26232,21 +26237,24 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+#, fuzzy
msgid ""
"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+#, fuzzy
msgid "Vector map to edit the attribute table for"
-msgstr ""
+msgstr "âÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid "Layer to which the table to be changed is connected"
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#, fuzzy
msgid "Column to update"
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
msgid ""
@@ -26254,8 +26262,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:9
+#, fuzzy
msgid "Column to query"
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:10
msgid ""
@@ -26375,8 +26384,9 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr "Ç äéÜôáîç ôçò âÜóçò äåäïìÝíùí"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
#, fuzzy
@@ -26414,17 +26424,20 @@
msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to rename column"
-msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:7
msgid "Old and new name of the column (old,new)"
@@ -26461,8 +26474,9 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:16
+#, fuzzy
msgid "Save placeholder raster map for use with d.legend"
-msgstr ""
+msgstr "×ñþìá"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
msgid "Exports attribute tables into various formats."
@@ -26478,8 +26492,9 @@
msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+#, fuzzy
msgid "Table format"
-msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
@@ -26491,9 +26506,8 @@
msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#, fuzzy
msgid "vector, import"
-msgstr "raster3d, voxel, åéóÜãåôáé"
+msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
msgid "Create a 3D line from 3 column data"
@@ -26725,18 +26739,20 @@
msgstr "äéáãñáöÞ åíüò ðßíáêá éäéïôÞôùí."
#: ../locale/scriptstrings/db.droptable_to_translate.c:5
+#, fuzzy
msgid "Table to drop"
-msgstr ""
#: ../locale/scriptstrings/r.grow_to_translate.c:3
msgid "radius is in map units rather than cells"
msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+#, fuzzy
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -26768,12 +26784,14 @@
msgstr "Íïýìåñï ôùí õðïðåñéï÷þí ãéá óõëëïãÞ óôáôéóôéêþí áðü áõôÜ"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:12
+#, fuzzy
msgid "Column prefix for new attribute columns"
-msgstr ""
+msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
msgid "Uncompressed geonames file from (with .txt extension)"
@@ -26789,20 +26807,23 @@
msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+#, fuzzy
msgid "Input map is in Matlab format"
-msgstr ""
+msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
msgid "Create a 3D vector points map from 3 column Matlab data"
msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+#, fuzzy
msgid "Name of input file in Mapgen/Matlab format"
-msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
+#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
msgid "Rebuilds topology on all vector maps in the current mapset."
@@ -26868,10 +26889,11 @@
msgstr ""
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
-msgstr ""
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
#, fuzzy
@@ -26894,17 +26916,20 @@
msgstr ""
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+#, fuzzy
msgid "Drops a column from selected attribute table"
-msgstr ""
+msgstr "äéáãñáöÞ åíüò ðßíáêá éäéïôÞôùí."
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:5
+#, fuzzy
msgid "Table from which to drop attribute column"
-msgstr ""
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:6
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:7
+#, fuzzy
msgid "Name of the column"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
msgid "Downloads and imports data from WMS servers."
@@ -27077,8 +27102,9 @@
msgstr ""
#: ../locale/scriptstrings/v.dissolve_to_translate.c:9
+#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr ""
+msgstr "¼íïìá ôïõ äåýôåñïõ ñÜóôåñ ÷Üñôç ãéá blending"
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
msgid "Adds missing centroids to closed boundaries."
@@ -27093,24 +27119,28 @@
msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+#, fuzzy
msgid "Vector map from which to remove attribute table"
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:7
+#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
+msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:8
+#, fuzzy
msgid "Layer from which to drop linked attribute table"
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
#, fuzzy
@@ -27118,16 +27148,18 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+#, fuzzy
msgid "Vector map to which to join other table"
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
msgid "layer,column"
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#, fuzzy
msgid "Layer where to join"
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:8
msgid "column"
@@ -27147,21 +27179,25 @@
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+#, fuzzy
msgid "Join column in other table"
-msgstr ""
+msgstr "Áñéèìüò ãñáììþí ðïõ èá åìöáíßæïíôáé óôï õðüìíçìá."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to drop attribute column"
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to drop column"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
@@ -27180,32 +27216,39 @@
msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+#, fuzzy
msgid "raster input map (LANDSAT channel 1)"
-msgstr ""
+msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#, fuzzy
msgid "raster input map (LANDSAT channel 2)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+#, fuzzy
msgid "raster input map (LANDSAT channel 3)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+#, fuzzy
msgid "raster input map (LANDSAT channel 4)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
+#, fuzzy
msgid "raster input map (LANDSAT channel 5)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
+#, fuzzy
msgid "raster input map (LANDSAT channel 7)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
+#, fuzzy
msgid "raster output TC maps prefix"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
msgid ""
@@ -27214,12 +27257,14 @@
msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to add new attribute table"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
#, fuzzy
@@ -27315,8 +27360,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+#, fuzzy
msgid "Imports attribute tables in various formats."
-msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
msgid "Table file to be imported or DB connection string"
@@ -27327,8 +27373,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "×ñþìá"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
msgid "Interactively edit cell values in a raster map."
@@ -27351,12 +27398,14 @@
msgstr "ÅëÜ÷éóôï ìÝãåèïò êÜèå êåëéïý"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+#, fuzzy
msgid "Maximum number of rows to load"
-msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns to load"
-msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
@@ -27379,10 +27428,11 @@
msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
-msgstr ""
+msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
msgid "Extended statistics (quartiles and 90th percentile)"
@@ -27393,8 +27443,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#, fuzzy
msgid "Name of data table"
-msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
msgid "Column on which to calculate statistics (must be numeric)"
@@ -27681,14 +27732,14 @@
msgstr "Áäõíáìßá ëÞøçò ãñáììÞò õøïìÝôñùí áðü ñÜóôåñ"
#: ../imagery/i.pca/main.c:380
-#, fuzzy, c-format
+#, c-format
msgid "Transforming <%s>..."
-msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
+msgstr ""
#: ../imagery/i.pca/main.c:395
-#, fuzzy, c-format
+#, c-format
msgid "Rescaling <%s> to range %d,%d..."
+msgstr ""
#: ../imagery/i.pca/support.c:44
msgid "Eigen values, (vectors), and [percent importance]:"
@@ -29630,6 +29681,172 @@
msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr ""
+#, fuzzy
+msgstr "Ôï 3Ä ñÜóôåñ áñ÷åßï èá ìåôáôñáðåß óå ASCII"
+#, fuzzy
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "Äßíåé ôç ëßóôá üëùí ôùí ðéíÜêùí ãéá ìßá äåäïìÝíç âÜóç äåäïìÝíùí."
+#, fuzzy
+msgid ""
+"Calculate the groundwater distance velocity vector field \n"
+"and write the x, y, and z components to maps named name_[xyz].\n"
+"Name is basename for the new raster3d maps"
+msgstr ""
+"Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé ãñÜøôå "
+"ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá åßíáé ôï "
+"âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "Êùäéêüò"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>."
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+#, fuzzy
+msgid "Could not open <%s>"
+msgstr "Äåí ìðïñåß íá êëåßóåé ï G3D ÷Üñôçò <%s>"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "Name of QC"
+msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+#, fuzzy
+msgid "Unable to proceed"
+#, fuzzy
+msgid "Unable to read head of %s"
+#, fuzzy
+msgstr "ÐñïåðéëïãÞ"
#~ msgstr "Sources and sinks in [m^3/s]"
@@ -29638,21 +29855,9 @@
#~ msgstr "ÅîáãùãÞ üíïìá ïäçãïý"
#, fuzzy
-#~ msgstr "Ôï 3Ä ñÜóôåñ áñ÷åßï èá ìåôáôñáðåß óå ASCII"
-#, fuzzy
#~ msgid "Unable to access table <%s>"
#~ msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
-#, fuzzy
-#~ msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "Äßíåé ôç ëßóôá üëùí ôùí ðéíÜêùí ãéá ìßá äåäïìÝíç âÜóç äåäïìÝíùí."
#~ msgid ""
#~ "\n"
#~ "Enter database password for connection\n"
@@ -29686,32 +29891,10 @@
#~ msgid "Unable to close elevation map"
#~ msgstr "Áäõíáìßá êëåéóßìáôïò ÷Üñôç õøïìÝôñùí"
-#, fuzzy
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new raster3d maps"
-#~ msgstr ""
-#~ "Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé "
-#~ "ãñÜøôå ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá "
-#~ "åßíáé ôï âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
#~ msgid "unable to close input raster map"
#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç åéóáãùãÞò"
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
-#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
-#, fuzzy
#~ msgid "Horizon file no. %d <%s> not found"
#~ msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
@@ -29724,38 +29907,6 @@
#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#~ msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
#~ msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
@@ -29773,13 +29924,9 @@
#, fuzzy
#~ msgid "Initializing output..."
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
+#~ msgstr "ÅããñáöÞ %s áðü %s..."
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
-#, fuzzy
#~ msgid "Unable to read raster map row %d "
@@ -29788,10 +29935,6 @@
#~ msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
-#, fuzzy
#~ msgid "unable to open new LS factor map layer."
@@ -29800,26 +29943,14 @@
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
-#, fuzzy
#~ msgid "Unable to open raster map <%s@%s>"
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#, fuzzy
#~ msgid "Could not get raster row"
#~ msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Êùäéêüò"
-#, fuzzy
#~ msgid "Unable to open table <%s_edge_Interpolation>"
#~ msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
@@ -29827,54 +29958,6 @@
#~ msgid "Layer is only used for WHERE SQL statement"
#~ msgstr "×ñçóéìïðïéÞóôå sb.select ãéá SELECT SQL åíôïëÝò"
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>."
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#, fuzzy
-#~ msgid "Could not open <%s>"
-#~ msgstr "Äåí ìðïñåß íá êëåßóåé ï G3D ÷Üñôçò <%s>"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
#~ msgid "raster3d, voxel, export"
#~ msgstr "ñÜóôåñ 3D, voxel, åîáãùãÞ"
@@ -29910,10 +29993,6 @@
#~ msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
-#, fuzzy
#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
#~ msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
@@ -29962,14 +30041,6 @@
#~ msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
-#, fuzzy
#~ msgid "Saturation map name"
#~ msgstr "¼íïìá ôïðïèåóßá"
@@ -30002,10 +30073,6 @@
#~ msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
-#, fuzzy
#~ msgid "Subgroup [%s] not found."
@@ -30031,10 +30098,6 @@
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "ÅããñáöÞ %s áðü %s..."
-#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
@@ -30045,10 +30108,6 @@
#, fuzzy
-#~ msgid "Unable to proceed"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
-#, fuzzy
#~ msgid "Output file to contain final report"
@@ -30057,10 +30116,6 @@
#, fuzzy
-#~ msgid "Unable to read head of %s"
-#, fuzzy
#~ msgid "group=[%s] - not found."
@@ -30228,6 +30283,337 @@
#~ msgid "%s@%s: zone doesn't match current settings"
#~ msgstr "Êëåßóéìï åöáñìïãÞò, ÷ùñßò íá áëëÜîïõí ïé ôñÝ÷ïõóåò åðéëïãÝò"
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "ÌåôáôñÝðåé Ýíá 3Ä åðßðåäï ñÜóôåñ ÷Üñôç óå Ýíá ASCII áñ÷åßï êåéìÝíïõ"
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "ÌåôáôñïðÞ åíüò 3Ä ASCII ñÜóôåñ áñ÷åßïõ óå (binary) 3Ä ñÜóôåñ åðßðåäï"
+#~ msgid "raster3d, voxel"
+#~ msgstr "ñÜóôåñ 3Ä, voxel"
+#~ msgid "Unable to create raster map"
+#~ msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+#~ msgstr "Ç áñ÷éêÞ ðéåæïìåôñéêÞ óôÞëç óå [m]"
+#~ msgstr "Ç êáôÜóôáóç êÜèå êåëéïý, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgstr "Ôï z-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
+#~ msgid "Specific yield in 1/m"
+#~ msgstr "Specific yield in 1/m"
+#~ msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
+#~ msgid ""
+#~ "to this map"
+#~ msgstr ""
+#~ "Ç ðéåæïìåôñéêÞ óôÞëç, áðïôÝëåóìá ôùí áñéèìçôéêþí õðïëïãéóìþí èá ãñáöôåß "
+#~ "óå áõôü ôï ÷Üñôç"
+#~ msgid ""
+#~ "Calculate the groundwater distance velocity vector field and write the x, "
+#~ "y, and z components to maps named name_[xyz]. Name is basename for the "
+#~ "new raster3d maps"
+#~ msgstr ""
+#~ "Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé "
+#~ "ãñÜøôå ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá "
+#~ "åßíáé ôï âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
+#~ msgid "raster3d, statistics"
+#~ msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
#, fuzzy
+#~ msgstr "¼íïìá ÷Üñôç õðïâÜèñïõ ñÜóôåñ"
+#, fuzzy
+#~ msgid "Name of the longitude input raster map [decimal degrees]"
+#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#, fuzzy
+#~ msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
+#, fuzzy
+#, fuzzy
+#~ msgstr "ÐáñÜìåôñïé"
+#, fuzzy
+#~ msgid "Name of elevation raster map"
+#~ msgstr "¼íïìá ñÜóôåñ ÷Üñôç õøïìÝôñïõ"
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
#~ msgstr "ÐñïåðéëïãÞ"
+#, fuzzy
+#~ msgstr "ÐñïåðéëïãÞ"
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "×ñþìá ãéá ôïí ó÷åäéáóìü ×'s (Null values)"
+#, fuzzy
+#~ msgstr "×ñþìá"
+#, fuzzy
+#~ msgstr "×ñþìá"
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "Íïýìåñï åðéðÝäïõ"
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#, fuzzy
+#~ msgid "Layer number (from)"
+#, fuzzy
+#~ msgid "Layer number (to)"
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#~ msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "OGR driver: óôÞëç '%s', OGR ôýðïò %d äåí õðïóôçñßæåôáé"
+#~ msgid "database, attribute table"
+#~ msgstr "âÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí"
+#~ msgstr "Åêôõðþíåé/óåôÜñåé ãåíéêÞ DB óýíäåóç ãéá ôï ôñÝ÷ùí maps êáé êëåßíåé"
+#~ msgid "Database schema"
+#~ msgstr "Ç äéÜôáîç ôçò âÜóçò äåäïìÝíùí"
+#~ msgid "database, SQL"
+#~ msgstr "ÂÜóç äåäïìÝíùí, SQL"
+#~ msgstr "¼íïìá áñ÷åßïõ ìå sql åíôïëÞ"
+#~ msgid "The password was stored in file"
+#~ msgstr "Ï êùäéêüò áðïèçêåýôçêå óôï áñ÷åßï"
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò (ÌÇÍ ðñïóèÝóåôå åðÝêôáóç áñ÷åßïõ)"
+#, fuzzy
+#~ msgstr "¼íïìá áñ÷åßïõ PNG."
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, imagery, mosaicking"
+#, fuzzy
+#~ msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
+#, fuzzy
+#~ msgid "display, export, GPS"
+#, fuzzy
+#~ msgid "sites, vector, import"
+#~ msgstr "raster3d, voxel, åéóÜãåôáé"
+#, fuzzy
+#~ msgid "vector, export, GPS"
+#~ msgid "vector, color table"
+#~ msgstr "äéÜíõóìá, ðßíáêáò ÷ñùìÜôùí"
+#, fuzzy
+#~ msgid "Layer number of data column"
+#, fuzzy
+#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
+#, fuzzy
+#~ msgid "Number of seconds to pause between slides"
+#~ msgstr "Áñéèìüò ãñáììþí ðïõ èá åìöáíßæïíôáé óôï õðüìíçìá."
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#, fuzzy
+#~ msgid "Number of subframes"
+#~ msgstr "Íïýìåñï ôùí õðïðåñéï÷þí ãéá óõëëïãÞ óôáôéóôéêþí áðü áõôÜ"
+#, fuzzy
+#~ msgid "vector, import, gazetteer"
+#, fuzzy
+#~ msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
+#, fuzzy
+#~ msgid "Name of .dmrc settings file"
+#~ msgstr "¼íïìá áñ÷åßïõ .dmrc"
+#, fuzzy
+#~ msgid "Name of GIS manager settings file (.grc)"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, imagery, colors"
+#, fuzzy
+#~ msgid "raster, elevation, interpolation"
+#, fuzzy
+#~ msgid "vector, area, dissolve"
+#, fuzzy
+#~ msgid "vector, centroid, area"
+#~ msgid "Name of PNG file"
+#, fuzzy
+#~ msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Writing data..."
+#, fuzzy
+#~ msgid "Name of fractal surface raster layer"
+#, fuzzy
+#~ msgid "File [%s] not found"
+#~ msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
+#, fuzzy
+#~ msgid "Reading sites map (%s) ..."
+#, fuzzy
+#~ msgid "ID values"
+#~ msgstr "×ñþìá"
+#, fuzzy
+#~ msgid "Cannot open database %s"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
+#, fuzzy
+#~ msgid "Cannot insert into table: %s"
+#~ msgstr "Äåí ìðïñþ íá äù ëßóôá ôùí ðéíÜêùí:\n"
+#, fuzzy
+#~ msgid "Type of elements"
+#~ msgstr "Ôýðïò"
+#, fuzzy
+#~ msgid "Rotating data arrays..."
+#, fuzzy
+#~ msgid "Unable to open output file."
+#~ msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
+#, fuzzy
+#~ msgid "Cannot read row from raster map"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#~ msgid "Output hue raster map"
+#~ msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
+#, fuzzy
+#~ msgid "Output saturation raster map"
+#, fuzzy
+#~ msgid "Can't open seed signature file <%s>"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_es.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -13406,7 +13406,7 @@
#, fuzzy
-msgstr "No se puede abrir el archivo de entrada <%s>"
+msgstr "No se puede cerrar el mapa de entrada"
@@ -19331,7 +19331,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "Salida:"
+msgstr "Crear salida 3D"
#: ../vector/v.random/main.c:111
#, fuzzy
@@ -21310,11 +21310,10 @@
msgstr "Interpolación: creando tabla: no se pudo crear la tabla <%s>."
#: ../vector/v.surf.bspline/main.c:395
-#, fuzzy
msgid ""
"Cannot allocate memory for auxiliar matrix.Consider changing region "
"resolution"
-msgstr "No se puede asignar memoria para la cadena"
+msgstr ""
#: ../vector/v.surf.bspline/main.c:593
#, c-format
@@ -21421,9 +21420,8 @@
msgstr "Error en pj_do_transform"
-#, fuzzy
-msgstr "Crea topología para mapa vectorial de GRASS."
+msgstr ""
@@ -25733,9 +25731,8 @@
#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.centrality/main.c:148
-#, fuzzy
msgid "Columns"
-msgstr "Columna(s)"
+msgstr "Columnas"
#: ../vector/v.net.centrality/main.c:135
#, fuzzy
@@ -25798,7 +25795,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "Separador de campos (modo de puntos)"
+msgstr "Imprimir las estadísticas en estilo de script de consola"
#: ../vector/v.db.connect/main.c:84
msgid "Print all map connection parameters and exit"
@@ -28180,16 +28177,18 @@
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
+#, fuzzy
msgid "Sensor"
-msgstr ""
+msgstr "Canal rojo LANDSAT"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
msgid "QuickBird sensor"
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
+#, fuzzy
msgid "SPOT sensor"
-msgstr ""
#, fuzzy
@@ -28967,7 +28966,6 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
-#, fuzzy
msgid "Misc"
msgstr "Miscelánea"
@@ -32193,6 +32191,374 @@
msgstr ""
"No se puede marcar otro punto. Sólo se permiten puntos %d. Lo sentimos."
+#, fuzzy
+msgstr ""
+"Muestra y superpone las capas del mapa ráster en el marco activo de la "
+"pantalla."
+#, fuzzy
+msgstr "Mapa ráster a importar"
+#, fuzzy
+msgstr ""
+"Archivo que contiene reglas de etiquetas de categorías (o \"-\" para leer de "
+"stdin)"
+#, fuzzy
+msgid "GDAL datatype: %s, range: %f - %f"
+msgstr "El mapa ráster <%s> ya existe"
+#, fuzzy
+msgstr "ráster, análisis de estructura del paisaje"
+#, fuzzy
+msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
+#, fuzzy
+#, fuzzy
+msgstr ""
+"mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+msgstr "Imprimir resultados en estilo de script de consola"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "Estadística a utilizar para los valores ráster"
+#, fuzzy
+msgstr "<%s> creado en la base de datos."
+#, fuzzy
+msgid ""
+msgstr "Calcula vectorial a nombre nombre."
+#, fuzzy
+msgid "report"
+msgstr "Informe amplio"
+#, fuzzy
+msgstr "No se puede obtener la cabecera de %s"
+#, fuzzy
+msgstr "No se puede abrir el archivo <%s>"
+#, fuzzy
+msgstr "Error al leer el mapa ráster [%s]."
+#, fuzzy
+#, fuzzy
+msgid "r.li.worker (pid %i) exited with abnormal status: %i"
+msgstr "r.li.worker (pid %i) salió con el estado anormal %i"
+#, fuzzy
+msgid "r.li.worker (pid %i) terminated successfully"
+msgstr "r.li.worker (pid %i) terminado"
+#, fuzzy
+msgstr "No se puede abrir el mapa ráster <%s> en <%s>"
+#, fuzzy
+msgstr "No se puede leer la región <%s> en <%s>"
+#, fuzzy
+msgstr "No se puede abrir el mapa ráster <%s>"
+#, fuzzy
+msgstr "No se puede abrir el mapa vectorial <%s>"
+#, fuzzy
+msgstr "No se puede abrir el archivo de salida <%s>"
+#, fuzzy
+#, fuzzy
+msgstr "No se puede obtener la fila %d (error = %d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "¡No se puede establecer la región para volver a la región inicial!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgstr "No se puede leer la fila %i\n"
+#, fuzzy
+msgstr "No se puede establacer la región <%s>"
+#, fuzzy
+msgstr "no se puede abrir nueva capa de mapa de acumulación."
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+msgstr "Extrayendo áreas..."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "Error al escribir la fila nula [%d]."
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
+#, fuzzy
+msgstr "No se puede abrir el archivo de entrada <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "Pase: %d\n"
+#, fuzzy
+msgstr "No se puede leer la fila %d del mapa ráster"
+#, fuzzy
+msgstr "Fallo al escribir la fila del mapa ráster"
+#, fuzzy
+msgstr "No se puede leer en el mapa ráster <%s> la fila %d"
+#, fuzzy
+msgstr "No se puede leer la cabecera del mapa ráster <%s>"
+#, fuzzy
+msgstr "No se pueden escribir los mapas ráster"
+#, fuzzy
+msgstr "No se puede abrir el archivo de reglas <%s>"
+#, fuzzy
+msgstr "No se puede leer la cabecera del archivo <%s>"
+#, fuzzy
+msgstr "No se pudo abrir el mapa %s"
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "Nombre para el archivo ráster de salida"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid "qcname"
+msgstr "nombre"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Nombre del archivo PNG"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Número de borde fuera de rango"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
+msgstr ""
+"Convierte un mapa vectorial binario de GRASS en una capa de mapa ráster de "
+"GRASS."
+#, fuzzy
+msgid "%d points written to vector map"
+msgstr "%d puntos escritos en mapa vectorial"
+#, fuzzy
+msgid "Traces a flow through an elevation model on a raster map layer."
+msgstr ""
+"Traza un flujo mediante un modelo de elevación sobre una capa de mapa ráster."
+#, fuzzy
+msgid "The E and N coordinates of starting point(s)"
+msgstr "Coordenadas de cuadrícula E y N de mapa de los puntos iniciales"
+#, fuzzy
+msgid "Vector map(s) containing starting point(s)"
+msgstr "Mapa(s) vectorial que contiene el punto(s) de inicio"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "ráster, elevación, interpolación"
+#, fuzzy
+msgid ""
+"Outputs a raster map layer showing the cumulative cost of moving between "
+"different geographic locations on an input raster map layer whose cell "
+"category values represent cost."
+msgstr ""
+"Produce una capa de mapa ráster que muestre el coste acumulado de moverse "
+"entre diferentes localizaciones geográficas en una capa de mapa ráster de "
+"entrada cuyos valores de categoría de celdas representan coste."
+#, fuzzy
+msgid "Bad Start Cell"
+msgstr "Celda de inicio incorrecta"
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD"
+msgstr "SECCIÓN 3: acumulando flujo de superficie."
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+msgstr "ráster, volumen, conversión"
+#, fuzzy
+msgstr "%s: %s - No fue posible encontrar el mapa de imagen real."
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"No fue posible abrir el mapa de imagen real en el directorio cell_misc \n"
+"El mapa de entrada posiblemente no fue creado por ifft"
+#, fuzzy
+msgstr "%s: %s - No se pudo encontrar la imagen imaginaria."
+#, fuzzy
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"No fue posible abrir el mapa de imagen imaginaria en el directorio "
+"cell_misc \n"
+#, fuzzy
+msgid "Range less than or equal to zero not allowed."
+msgstr "Rango menor o igual a cero no permitido."
+#, fuzzy
+msgstr ""
+"Escribiendo versiones visibles de los datos transformados a archivos..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+msgstr "No se puede abrir el archivo en el directorio cell_misc."
+#, fuzzy
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr ""
+"El nombre de la imagen para rectificar que se dibujará inicialmente en "
+"pantalla."
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr ""
+"Nombre de un mapa del conjunto de mapas de destino que se dibujará "
+"inicialmente en pantalla"
+#, fuzzy
+msgid "raster, imagery, fusion"
+msgstr "ráster, imaginería, importar"
+#, fuzzy
+msgid "Can't make random color table for floating point map"
+msgstr ""
+"No se puede hacer tabla de colores logarítmica para mapas de coma flotante"
+#, fuzzy
+msgid "Can't make grey.eq color table for floating point map"
+msgstr ""
+#, fuzzy
+msgid "%s - unknown color request"
+msgstr "%s - solicitud de color desconocido"
+#, fuzzy
+msgid "The column must be type integer or string"
+msgstr "Nombre de columna (debe ser de tipo numérico)"
+#, fuzzy
+msgid "Processing ainput areas ..."
+msgstr "Procesando líneas de la entrada A..."
+#, fuzzy
+msgid ""
+"Elevation raster map <%s> does not cover the entire area of the input vector "
+"map <%s>. "
+msgstr "%d categorías con más de un elemento en el mapa vectorial <%s>"
+#, fuzzy
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
+#, fuzzy
+msgid "Displays thematic vectormap"
+msgstr "Visualizar mapa vectorial temático"
+#, fuzzy
+msgid "Name of input raster map(s)"
+msgstr "Nombre del mapa ráster de entrada"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Mapa ráster de terreno (MDT)"
+#, fuzzy
+msgid "imagery group"
+msgstr "Grupo de imaginería"
#~ msgstr "Espacio insuficiente en archivo histórico"
@@ -32211,12 +32577,6 @@
#~ msgstr "Nombre de archivo de color"
-#, fuzzy
-#~ msgstr ""
-#~ "Muestra y superpone las capas del mapa ráster en el marco activo de la "
-#~ "pantalla."
#~ msgstr "Lista de valores a mostrar (mapas FP)"
@@ -32357,16 +32717,6 @@
#~ msgstr "Capa a la que añadir la columna"
-#, fuzzy
-#~ msgstr "Mapa ráster a importar"
-#, fuzzy
-#~ msgstr ""
-#~ "Archivo que contiene reglas de etiquetas de categorías (o \"-\" para leer "
-#~ "de stdin)"
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Genera una capa de mapa ráster mostrando subcuencas hidrográficas."
@@ -32390,10 +32740,6 @@
#~ "para para las celdas sin datos con el parámetro %s."
#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#~ msgstr "El mapa ráster <%s> ya existe"
-#, fuzzy
#~ msgid "Name of the elevation raster map [m]"
#~ msgstr "Nombre del mapa ráster de elevación"
@@ -32476,10 +32822,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr "(E) Salida OPCIONAL para clase de índice topográfico dada"
-#, fuzzy
-#~ msgstr "ráster, análisis de estructura del paisaje"
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr ""
#~ "Nombre de mapa ráster existente que contiene superficie de elevación"
@@ -32545,19 +32887,6 @@
#~ msgstr "No se puede crear la tabla <%s>"
-#, fuzzy
-#~ msgstr "No se puede abrir el mapa vectorial <%s> en el nivel topológico %d"
-#, fuzzy
-#, fuzzy
-#~ msgstr ""
-#~ "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Convierte mapas ráster 3D (G3D) en formato VTK-ASCII"
@@ -32573,10 +32902,6 @@
#~ "Convierte un mapa ráster de GRASS en un archivo de imagen PPM a la "
#~ "resolución de píxel de la región definida actualmente."
-#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "Imprimir resultados en estilo de script de consola"
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -32588,10 +32913,6 @@
#~ msgid "Band to select"
#~ msgstr " Ningún monitor seleccionado"
-#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Estadística a utilizar para los valores ráster"
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "Fue imposible crear <Auxiliar_outlier_table>."
@@ -32604,10 +32925,6 @@
#~ msgstr ""
#~ "Columna de la tabla de atributos con valores a interpolar (si capa>0)"
-#, fuzzy
-#~ msgstr "<%s> creado en la base de datos."
#~ msgid "M.Q. solution"
#~ msgstr "Solución M.Q."
@@ -32653,14 +32970,7 @@
#~ msgstr "No se puede cerrar el mapa de elevación"
-#, fuzzy
#~ msgid ""
-#~ msgstr "Calcula vectorial a nombre nombre."
-#~ msgid ""
#~ "Use a sparse linear equation system, only available with iterative solvers"
#~ msgstr ""
#~ "Usar un sistema de ecuaciones lineal sparse, sólo disponible con "
@@ -32687,19 +32997,11 @@
#~ msgid "Unable to write raster row"
#~ msgstr "No se puede escribir la fila ráster"
-#, fuzzy
-#~ msgid "report"
-#~ msgstr "Informe amplio"
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr ""
#, fuzzy
-#~ msgstr "No se puede obtener la cabecera de %s"
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "No se puede escribir en el archivo"
@@ -32716,10 +33018,6 @@
#~ msgid "Cannot open raster map <%s>"
#~ msgstr "No se puede abrir el mapa ráster <%s>"
-#, fuzzy
-#~ msgstr "No se puede abrir el archivo <%s>"
#~ msgid "Cannot create category file of <%s>"
#~ msgstr "No se puede crear el archivo de categoría de <%s>"
@@ -32741,10 +33039,6 @@
#~ msgid "Unable to read header of raster map <%s>"
#~ msgstr "No se puede leer la cabecera del mapa ráster <%s>"
-#, fuzzy
-#~ msgstr "Error al leer el mapa ráster [%s]."
#~ msgid "Reading row %d"
#~ msgstr "Leyendo la fila %d"
@@ -32856,24 +33150,12 @@
#~ msgid "Cannot read row"
#~ msgstr "No se puede leer la fila"
-#, fuzzy
#~ msgid "Error in pipe creation"
#~ msgstr "Error en la creación de tubería"
#~ msgid "Error opening channel %i"
#~ msgstr "Error al abrir el canal %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) salió con el estado anormal %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) terminado"
#~ msgid "Cannot close %s file (PIPE)"
#~ msgstr "No se puede cerrar el archivo %s (TUBERÍA)"
@@ -32971,32 +33253,12 @@
#~ " \t\t\t\tpid = %i \n"
-#, fuzzy
-#~ msgstr "No se puede abrir el mapa ráster <%s> en <%s>"
-#, fuzzy
-#~ msgstr "No se puede leer la región <%s> en <%s>"
#~ msgid "Unable to get header for %s"
#~ msgid "Cannot reset current region"
#~ msgstr "No se puede restablecer la región actual"
-#, fuzzy
-#~ msgstr "No se puede abrir el mapa ráster <%s>"
-#, fuzzy
-#~ msgstr "No se puede abrir el mapa vectorial <%s>"
-#, fuzzy
-#~ msgstr "No se puede abrir el archivo de salida <%s>"
#~ msgid "Cannot create category file for <%s>"
#~ msgstr "No se puede crear el archivo de categoría para <%s>"
@@ -33032,22 +33294,6 @@
#~ msgstr "Error al leer el mapa 'saturación'"
#, fuzzy
-#, fuzzy
-#~ msgstr "No se puede obtener la fila %d (error = %d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "¡No se puede establecer la región para volver a la región inicial!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
#~ msgstr "No se puede leer en el mapa ráster <%s> la fila %d"
@@ -33076,10 +33322,6 @@
#~ msgid "Error writing null row [%d]."
#~ msgstr "Error al escribir la fila nula [%d]."
-#, fuzzy
-#~ msgstr "No se puede leer la fila %i\n"
#~ msgid "Swapping header data"
#~ msgstr "Intercambiando datos de cabecera"
@@ -33097,10 +33339,6 @@
#~ msgid "Failed writing raster map row %d"
#~ msgstr "Fallo al escribir la fila del mapa ráster"
-#, fuzzy
-#~ msgstr "No se puede establacer la región <%s>"
#~ msgid "Invalid region: %s"
#~ msgstr "Región no válida: %s"
@@ -33152,14 +33390,6 @@
#~ msgid "unable to open accum file in valid_basins()"
#~ msgstr "no se puede abrir el archivo de acumulación en valid_basins()"
-#, fuzzy
-#~ msgstr "no se puede abrir nueva capa de mapa de acumulación."
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "Extrayendo áreas..."
#~ msgid "Can't create raster map <%s>"
#~ msgstr "No se puede crear el mapa ráster <%s>"
@@ -33176,14 +33406,6 @@
#~ msgid "Unable to close new basin map layer"
#~ msgstr "No se puede cerrar la capa del nuevo mapa de cuenca"
-#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "Error al escribir la fila nula [%d]."
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "Número del segmento a crear (biblioteca de segmento)"
@@ -33297,14 +33519,6 @@
#~ msgid "Use a sparse matrix, only available with iterative solvers"
#~ msgstr "Usar"
-#, fuzzy
-#~ msgstr "No se puede abrir el archivo de entrada <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
#~ msgid "Error reading input"
#~ msgstr "Error al leer la entrada"
@@ -33324,10 +33538,6 @@
#~ msgstr "<Auxiliar_edge_table> creada en la base de datos."
#, fuzzy
-#~ msgstr "Pase: %d\n"
-#, fuzzy
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "Creando tabla auxiliar para archivar zonas solapadas"
@@ -33527,21 +33737,9 @@
#~ msgid "Current region cannot be set."
#~ msgstr "No se puede establecer la región actual."
-#, fuzzy
-#~ msgstr "No se puede leer la fila %d del mapa ráster"
-#, fuzzy
-#~ msgstr "Fallo al escribir la fila del mapa ráster"
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "No se puede asignar el buffer de la fila de entrada"
-#, fuzzy
-#~ msgstr "No se puede leer en el mapa ráster <%s> la fila %d"
#~ msgid "Unable to open the cell map MASK."
#~ msgstr "No se puede abrir la MÁSCARA de mapa de celdas."
@@ -33562,14 +33760,6 @@
#~ msgid "Unable to open band files."
#~ msgstr "No se pueden abrir los archivos de bandas."
-#, fuzzy
-#~ msgstr "No se puede leer la cabecera del mapa ráster <%s>"
-#, fuzzy
-#~ msgstr "No se pueden escribir los mapas ráster"
#~ msgid "Error while reading input raster map."
#~ msgstr "Error al leer el mapa ráster de entrada."
@@ -33587,33 +33777,9 @@
#~ msgstr "No se puede abrir el mapa vectorial <%s> en <%s>"
-#, fuzzy
-#~ msgstr "No se puede abrir el archivo de reglas <%s>"
-#, fuzzy
-#~ msgstr "No se puede leer la cabecera del archivo <%s>"
-#, fuzzy
-#~ msgstr "No se pudo abrir el mapa %s"
#~ msgid "Could not read from <%s>"
#~ msgstr "No fue posible leer desde <%s>"
-#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "Nombre para el archivo ráster de salida"
-#, fuzzy
-#, fuzzy
#~ msgid "Error reading row of data"
#~ msgstr "Error al leer la fila de datos"
@@ -33855,22 +34021,6 @@
#~ msgstr "imaginería"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "nombre"
-#, fuzzy
-#~ msgstr "Nombre del archivo PNG"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Número de borde fuera de rango"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "vectorial, transformación"
@@ -33967,13 +34117,6 @@
#~ msgid "vector, raster, conversion"
#~ msgstr "vectorial, ráster, conversión"
-#, fuzzy
-#~ msgid ""
-#~ "Converts a binary GRASS vector map layer into a GRASS raster map layer."
-#~ msgstr ""
-#~ "Convierte un mapa vectorial binario de GRASS en una capa de mapa ráster "
-#~ "de GRASS."
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
#~ msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas)"
@@ -34101,10 +34244,6 @@
#~ msgid "Unknown keyword <%s> in vector head"
#~ msgstr "Palabra clave <%s> desconocida en la cabecera del vectorial"
-#, fuzzy
-#~ msgid "%d points written to vector map"
-#~ msgstr "%d puntos escritos en mapa vectorial"
#~ msgid "vector, raster, attribute table"
#~ msgstr "vectorial, ráster, tabla de atributos"
@@ -34112,7 +34251,7 @@
#~ msgstr "vectorial, metadatos"
#~ msgid "Tychonov regularization weight"
-#~ msgstr "Peso de regularización Tychonov"
+#~ msgstr "Peso de regularización Tychonov "
#~ msgid "vector, LIDAR"
#~ msgstr "vectorial, LIDAR"
@@ -34300,23 +34439,9 @@
#~ msgid "Selects data from table."
#~ msgstr "Selecciona datos de una tabla."
-#, fuzzy
-#~ msgid "Traces a flow through an elevation model on a raster map layer."
-#~ msgstr ""
-#~ "Traza un flujo mediante un modelo de elevación sobre una capa de mapa "
-#~ "ráster."
#~ msgid "Output drain raster map"
#~ msgstr "Producir mapa ráster de drenaje"
-#, fuzzy
-#~ msgid "The E and N coordinates of starting point(s)"
-#~ msgstr "Coordenadas de cuadrícula E y N de mapa de los puntos iniciales"
-#, fuzzy
-#~ msgid "Vector map(s) containing starting point(s)"
-#~ msgstr "Mapa(s) vectorial que contiene el punto(s) de inicio"
#~ msgid ""
#~ "Unused; retained for compatibility purposes, will be removed in future"
#~ msgstr ""
@@ -34395,10 +34520,6 @@
#~ msgstr "ráster, exportar, VRML"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "ráster, elevación, interpolación"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
#~ msgstr "ráster, goemorfología"
@@ -34409,16 +34530,6 @@
#~ msgid "raster, cost surface, cumulative costs"
#~ msgstr "ráster, superficie de coste, coste acumulado"
-#, fuzzy
-#~ msgid ""
-#~ "Outputs a raster map layer showing the cumulative cost of moving between "
-#~ "different geographic locations on an input raster map layer whose cell "
-#~ "category values represent cost."
-#~ msgstr ""
-#~ "Produce una capa de mapa ráster que muestre el coste acumulado de moverse "
-#~ "entre diferentes localizaciones geográficas en una capa de mapa ráster de "
-#~ "entrada cuyos valores de categoría de celdas representan coste."
#~ msgid "Source map is: Integer cell type"
#~ msgstr "El mapa de origen es: tipo de celda entero"
@@ -34451,10 +34562,6 @@
#~ msgid "Nothing to show"
#~ msgstr "Nada que mostrar"
-#, fuzzy
-#~ msgid "Bad Start Cell"
-#~ msgstr "Celda de inicio incorrecta"
#~ msgid "%s %f-%f lower cost higher or equal"
#~ msgstr "%s %f-%f coste inferior más alto o igual"
@@ -34502,10 +34609,6 @@
#~ msgid "unable to open new S map layer."
#~ msgstr "no se puede abrir nueva capa de mapa S."
-#, fuzzy
-#~ msgid "SECTION 3: Accumulating Surface Flow with MFD"
-#~ msgstr "SECCIÓN 3: acumulando flujo de superficie."
#~ msgid "unable to open MASK"
#~ msgstr "no se puede abrir MÁSCARA"
@@ -34525,10 +34628,6 @@
#~ " DEBE proporcionar un valor para el parámetro de umbral de cuenca."
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#~ msgstr "ráster, volumen, conversión"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "Archivo ráster para superficie"
@@ -34636,31 +34735,6 @@
#~ msgstr "Mostrar más comentarios (por omisión=silencio)"
#, fuzzy
-#~ msgstr "%s: %s - No fue posible encontrar el mapa de imagen real."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "No fue posible abrir el mapa de imagen real en el directorio cell_misc \n"
-#~ "El mapa de entrada posiblemente no fue creado por ifft"
-#, fuzzy
-#~ msgstr "%s: %s - No se pudo encontrar la imagen imaginaria."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "No fue posible abrir el mapa de imagen imaginaria en el directorio "
-#~ "cell_misc \n"
-#, fuzzy
#~ msgid "Subgroup [%s] in group [%s] contains no files."
#~ msgstr "El subgrupo [%s] en el grupo [%s] no contiene archivos."
@@ -34669,19 +34743,6 @@
#~ msgstr "Trasponiendo la matriz de valores propios..."
#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "Rango menor o igual a cero no permitido."
-#, fuzzy
-#~ msgstr ""
-#~ "Escribiendo versiones visibles de los datos transformados a archivos..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "No se puede abrir el archivo en el directorio cell_misc."
-#, fuzzy
#~ msgid "Subgroup [%s] doesn't have any files"
#~ msgstr "El subgrupo [%s] no tiene ningún archivo"
@@ -34711,24 +34772,6 @@
#, fuzzy
#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr ""
-#~ "El nombre de la imagen para rectificar que se dibujará inicialmente en "
-#~ "pantalla."
-#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr ""
-#~ "Nombre de un mapa del conjunto de mapas de destino que se dibujará "
-#~ "inicialmente en pantalla"
-#, fuzzy
-#~ msgid "raster, imagery, fusion"
-#~ msgstr "ráster, imaginería, importar"
-#, fuzzy
-#~ msgid ""
#~ "Name of old database. The database must be in form printed by v.db."
#~ "connect -g, i.e. with substituted variables"
#~ msgstr ""
@@ -34736,50 +34779,14 @@
#~ "forma impresa por v.db.connect -g, esto es, con variables sustituidas"
#, fuzzy
-#~ msgid "Can't make random color table for floating point map"
-#~ msgstr ""
-#~ "No se puede hacer tabla de colores logarítmica para mapas de coma flotante"
-#, fuzzy
-#~ msgid "Can't make grey.eq color table for floating point map"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "%s - unknown color request"
-#~ msgstr "%s - solicitud de color desconocido"
-#, fuzzy
#~ msgid "Could not read range file"
#~ msgstr "No se puede leer el archivo de intervalo"
#, fuzzy
-#~ msgid "The column must be type integer or string"
-#~ msgstr "Nombre de columna (debe ser de tipo numérico)"
-#, fuzzy
#~ msgid "%d update/insert errors"
#~ msgstr "%d errores al insertar"
#, fuzzy
-#~ msgid "Processing ainput areas ..."
-#~ msgstr "Procesando líneas de la entrada A..."
-#, fuzzy
-#~ msgid ""
-#~ "Elevation raster map <%s> does not cover the entire area of the input "
-#~ "vector map <%s>. "
-#~ msgstr "%d categorías con más de un elemento en el mapa vectorial <%s>"
-#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
-#, fuzzy
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "Visualizar mapa vectorial temático"
-#, fuzzy
#~ msgid "display, legend"
#~ msgstr "Dar la vuelta a la leyenda"
@@ -34844,18 +34851,6 @@
#~ msgid "raster input maps"
#~ msgstr "Mapa ráster de entrada"
-#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nombre del mapa ráster de entrada"
-#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Mapa ráster de terreno (MDT)"
-#, fuzzy
-#~ msgid "imagery group"
-#~ msgstr "Grupo de imaginería"
#~ msgid "Cannot open database %s by driver %s"
#~ msgstr "No se puede abrir la base de datos %s por el controlador %s"
@@ -37544,3 +37539,1256 @@
#~ msgid "Create 3D file"
#~ msgstr "Crear archivo 3D"
+#~ msgstr "Convierte una capa de mapa ráster 3D en un archivo de texto ASCII"
+#~ msgid ""
+#~ msgstr ""
+#~ "Convertir un archivo de texto ráster ASCII 3D en una capa de mapa ráster "
+#~ "3D (binaria)"
+#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgstr "Estado para cada celda, = 0 - inactiva, 1 - activa, 2 - dirichlet"
+#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "Parte Z del tensor de conductividad hidráulica en [m/s]"
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Recargar mapa ráster en m^3/s"
+#, fuzzy
+#~ msgid ""
+#~ "The piezometric head result of the numerical calculation will be written "
+#~ "to this map"
+#~ msgstr "a."
+#, fuzzy
+#~ msgid ""
+#~ msgstr "Calcula vectorial a nombre nombre."
+#~ msgstr "Exportar un mapa ráster 3D GRASS a archivo tridimensional Vis5D."
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr ""
+#~ "Exporta mapa ráster de GRASS a archivo de mapa GRIDATB.FOR (TOPMODEL)"
+#~ msgid "Name of base raster map"
+#~ msgstr "Nombre de mapa ráster de base"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr ""
+#~ "Convierte una capa de mapa ráster en un archivo de campo altura para "
+#~ "POVRAY."
+#~ msgid "raster, map algebra"
+#~ msgstr "ráster, álgebra de mapas"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "Convierte una capa de mapa ráster a un archivo de texto ASCII."
+#~ msgid "Converting %s..."
+#~ msgstr "Convirtiendo %s..."
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "No se puede encontrar el vector de fin <%s>"
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "Importar como datos de coma flotante (por omisión: entero)"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr "Importar como datos de precisión doble (por omisión; entero)"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#~ msgstr " Número de bytes por celda"
+#~ msgid "Bytes do not match File size"
+#~ msgstr "Los bytes no corresponden al tamaño de archivo"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Nombre para el mapa ráster de salida"
+#, fuzzy
+#~ msgid "raster, interpolation"
+#~ msgstr "vectorial, interpolación"
+#~ msgid "raster, statistics"
+#~ msgstr "ráster, estadísticas"
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Convierte mapas ráster al formato VTK-ASCII"
+#, fuzzy
+#~ msgid "raster, terrain"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "Nombre del mapa ráster de altura del agua"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Nombre del mapa ráster de derivadas X"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#~ msgstr "Nombre del mapa ráster de derivadas Y"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "Nombre mapa ráster de coeficiente de capacidad de separación"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Nombre del mapa ráster de coeficiente de capacidad de transporte"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "Nombre del mapa ráster de "
+#~ msgid "Name of the Mannings n raster map"
+#~ msgstr "Nombre del mapa ráster n de Mannings"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Producir mapa ráster de capacidad de transporte"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr "Producir mapa ráster de erosión-deposición "
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Producir mapa ráster de concentración de sedimentos"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Producir mapa ráster de flujo de sedimentos"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#~ msgstr "Producir mapa ráster de erosión-deposición"
+#, fuzzy
+#~ msgid ""
+#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+#~ msgstr ""
+#~ "Modelo hidrológico de flujo superficial basado en el concepto de dualidad "
+#~ "partícula-terreno (SIMWE)"
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr ""
+#~ "Nombre del mapa ráster [mm/hr] de tasa de exceso de precipitación (lluvia-"
+#~ "infiltración)"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "Nombre ráster"
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr ""
+#~ "Nombre del mapa ráster de controles de flujo (relación de permeabilidad 0-"
+#~ "1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "Producir mapa ráster de descarga de agua"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Producir mapa ráster de error de simulación"
+#, fuzzy
+#~ msgid ""
+#~ "Threshold water depth [m] (diffusion increases after this water depth is "
+#~ "reached)"
+#~ msgstr ""
+#~ "Profundidad de agua de la cuenca (la difusión aumenta después de alcanzar "
+#~ "esta profundidad)"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Convierte 3 capas ráster de GRASS (R,G,B) a un archivo de imagen PPM a la "
+#~ "resolución de píxel de la REGIÓN ACTUALMENTE DEFINIDA."
+#, fuzzy
+#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
+#~ msgstr ""
+#~ "Estado de la condición de los contornos, 0-inactiva, 1-activa, 2-dirichlet"
+#~ msgid "Water sources and sinks in [m^3/s]"
+#~ msgstr "Fuentes de agua y sumideros en [m³/s]"
+#~ msgid "Specific yield in [1/m]"
+#~ msgstr "Rendimiento específico en [1/m]"
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "Recargar mapa; ejemplo: 6*10^-9 por celda en [m³/s*m²]"
+#~ msgid "The map storing the numerical result [m]"
+#~ msgstr "Mapa que guarda el resultado numérico [m]"
+#, fuzzy
+#~ msgid ""
+#~ "Calculate the groundwater filter velocity vector field [m/s]\n"
+#~ "and write the x, and y components to maps named name_[xy]"
+#~ msgstr "Calcular vectorial a nombre"
+#, fuzzy
+#~ msgid "The height of the river bed in [m]"
+#~ msgstr "La altura de la cuenca del río en [m]"
+#, fuzzy
+#~ msgid "The height of the drainage bed in [m]"
+#~ msgid "raster, buffer"
+#~ msgstr "ráster, buffer"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Mapa de entrada: cantidad de flujo superficial por celda"
+#, fuzzy
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "Mapa de entrada: flujo de superficie "
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Mapa de salida: número de celdas que drenan a través de cada celda"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "Mapa de salida: etiqueta única para cada cuenca hidrográfica"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "Mapa de salida: se da un valor único a cada semicuenca"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr ""
+#~ "Mapa de salida: factor de longitud e inclinación de la pendiente (LS) "
+#~ "para USLE"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "Mapa de salida: factor de inclinación de la pendiente (S) para USLE"
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "Valor de entrada: tamaño mínimo de la cuenca hidrográfica exterior"
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "Lo siento, si alguna de las siguientes opciones es establecida:\n"
+#~ " cuenca, corriente, semicuenca, pendiente o IS\n"
+#~ " DEBE proporcionar un valor para el parámetro de umbral de cuenca."
+#, fuzzy
+#~ msgid ""
+#~ "USAGE for basin delineation:\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "\n"
+#~ "USAGE for ARMSED FILE creation:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "\n"
+#~ "USAGE for slope length determination:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
+#~ msgstr ""
+#~ "USO para delineación de cuenca:\n"
+#~ "%s -4 el= mostrar mostrar nombre mostrar máximo"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "no se puede abrir nueva capa de mapa de acumulación."
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "Error al escribir el archivo de color para <%s>"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programa de conversión de series de archivos ráster a MPEG."
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Filtra y genera un mapa de elevación sin depresiones y un mapa de "
+#~ "dirección de flujo a partir de una capa de elevación dada."
+#~ msgid "Output direction raster map"
+#~ msgstr "Producir mapa ráster de dirección"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "Producir mapa ráster de áreas problemáticas"
+#~ msgid "raster, resample"
+#~ msgstr "ráster, remuestrear"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr ""
+#~ "Programa de generación de superficies a partir de contornos rasterizados."
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "Nombre del mapa ráster existente que contiene los contornos"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr ""
+#~ "Crea/modifica la tabla de colores asociada a una capa de mapa ráster."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Nombre del mapa ráster del que copiar la tabla de colores"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
+#~ msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
+#~ msgstr ""
+#~ "CHILD[pid = %i]: no se puede abrir la máscara %s ... ¡¡¡Se continúa sin "
+#~ "ella!!!"
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "No se puede crear el directorio %s/.r.li/"
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "No se puede crear el directorio %s/.r.li/output/"
+#~ msgid "r.li.worker (pid %i) exited with abnormal status %i"
+#~ msgstr "r.li.worker (pid %i) salió con el estado anormal %i"
+#~ msgid "r.li.worker (pid %i) terminated"
+#~ msgstr "r.li.worker (pid %i) terminado"
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "No se puede la estadística del archivo de configuración %s"
+#, fuzzy
+#~ msgid "raster, null data"
+#~ msgstr "vectorial, metadatos"
+#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+#~ msgstr ""
+#~ "Exportar un mapa ráster al Lenguaje de Modelado de Realidad Virtual (VRML)"
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr ""
+#~ "Genera una capa de mapa ráster con áreas contiguas incrementadas en una "
+#~ "celda."
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Mapa de cuenca creado por r.water.outlet (MÁSCARA)"
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(S) Mapa de dirección para mapa de elevación sin depresiones"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(E) Número de clases de índice topográfico"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(S/E) Archivo de estadísticas de índice topográfico"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(E) Archivo de parámetros TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr ""
+#~ "(E) Archivo de datos de precipitaciones y evotranspiración potencial"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr "Calcula áreas a."
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: altura del sol sobre el horizonte, grados"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: azimut del sol desde el Norte, grados"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: minutos (0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: segundos (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: zona horaria (Este positivo, compensar desde GMT, también uso para "
+#~ "ajustar ahorros de luz solar)"
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Crea una nueva capa de mapa cuyos valores de categorías están basados en "
+#~ "una reclasificación de las categorías de una capa de mapa ráster "
+#~ "existente."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "Mapa por reclasificar"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "Convierte un mapa ráster en una capa de mapa vectorial."
+#~ msgid ""
+#~ "Do not build vector topology (use with care for massive point export)"
+#~ msgstr ""
+#~ "No construir topología vectorial (usar con cuidado para exportación "
+#~ "masiva de puntos)"
+#~ msgid "The map E grid coordinates"
+#~ msgstr "Coordenadas de cuadrícula E del mapa"
+#, fuzzy
+#~ msgstr "No se puede leer el intervalo fp del mapa ráster <%s>"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "Nombre del vectorial de entrada que contiene corriente(s)"
+#~ msgid "Stream width (in meters). Default is raster cell width"
+#~ msgstr ""
+#~ "Anchura de corriente (en metros). Por defecto es la anchura de celda "
+#~ "ráster."
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr ""
+#~ "Construcción de curvas de pendiente (líneas de flujo), longitudes de ruta "
+#~ "de flujo y densidades de líneas de flujo (áreas pendiente arriba) a "
+#~ "partir de un modelo de elevación digital (MDT) ráster"
+#~ msgid "Output flowpath length raster map"
+#~ msgstr "Mapa ráster de longitud de ruta de corriente de salida"
+#~ msgid "Output flowline density raster map"
+#~ msgstr "Mapa ráster de densidad de línea de corriente de salida"
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "Longitudes 3D en vez de 2D"
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr ""
+#~ "Convierte un archivo ráster ASCII en una capa de mapa ráster binaria."
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "Mostrar la etiqueta de categoría en la celda(s) de cuadrícula"
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Crea mapa de índices topográficos [ln(a/tan(beta))] a partir de mapa de "
+#~ "elevación."
+#~ msgid "Output topographic index map"
+#~ msgstr "Producir mapa de índice topográfico"
+#~ msgid "raster, geomorphology"
+#~ msgstr "ráster, goemorfología"
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Convierte un archivo ráster ASCII ARC/INFO de ESRI (GRID) en una capa de "
+#~ "mapa ráster (binario)."
+#~ msgid "File containing weights"
+#~ msgstr "Archivo que contiene pesos"
+#~ msgid "general, map management"
+#~ msgstr "general, gestión de mapas"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "ráster, proyección"
+#~ msgid "New LOCATION name (not location path)"
+#~ msgstr "Nombre de la nueva LOCALIZACIÓN (no ruta de la localización)"
+#~ msgid "New GISDBASE (full path to the directory where the new location is)"
+#~ msgstr ""
+#~ "Nueva BASE DE DATOS (ruta completa al directorio donde se encuentra la "
+#~ "nueva localización)"
+#~ msgid "format"
+#~ msgstr "formato"
+#~ msgstr "Color para dibujar las X (Valores nulos)"
+#~ msgid "display, cartography"
+#~ msgstr "mostrar, cartografía"
+#~ msgid "name"
+#~ msgstr "nombre"
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitor: waitpid: se esperaba %d pero se obtuvo %d"
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Texto o se debe dar -c"
+#~ msgid "Unable to set size"
+#~ msgstr "No se puede establecer el tamaño"
+#~ msgid "Text conversion error"
+#~ msgstr "Error en la conversión de texto"
+#~ msgid "Error reading hue data"
+#~ msgstr "Error al leer datos de tonalidad"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "Archivo de color para <%s> no disponible"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr "Archivo de categoría para <%s> no disponible"
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr ""
+#~ "Muestra y superpone las capas del mapa ráster en el marco activo de la "
+#~ "pantalla."
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr "Lista de categorías para mostrar (mapas INT)"
+#~ msgid "Invert catlist"
+#~ msgstr "Invertir lista de categorías"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#~ msgstr ""
+#~ "Muestra datos vectoriales de GRASS en el marco activo de la pantalla."
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "No se puede leer el símbolo, no se pueden mostrar los puntos"
+#~ msgid "Vector map attribute column to use for comparison"
+#~ msgstr "Columna de atributos del mapa vectorial a usar para comparación"
+#~ msgid "Vector map to store differences"
+#~ msgstr "Mapa vectorial para guardar las diferencias"
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "Opción factor de escala para valores leídos de un mapa ráster. Los "
+#~ "valores muestrados se multiplicarán por este factor"
+#~ msgid "vector, networking"
+#~ msgstr "vectorial, trabajo en red"
+#~ msgid "Required for operation 'connect'"
+#~ msgstr "Requerido para la operación 'conectar'"
+#~ msgid ""
+#~ "nodes;new point is placed on each node (line end) if doesn't exist;"
+#~ "connect;connect still unconnected points to vector network by inserting "
+#~ "new line(s);report;print to standard output {line_category "
+#~ "start_point_category end_point_category};nreport;print to standard output "
+#~ "{point_category line_category[,line_category...]}"
+#~ msgstr ""
+#~ "nodos;el nuevo punto es situado en cada nodo (final de línea) si no "
+#~ "existe;conectar;conecta puntos aún si conectar a la red vectorial "
+#~ "insertando nueva línea(s);informar;imprimir a la salida estándar "
+#~ "{line_category start_point_category end_point_category};nreport;imprimir "
+#~ "a la salida estándar {point_category line_category[,line_category...]}"
+#~ msgid "%d new points written to output"
+#~ msgstr "%d puntos nuevos escritos en la salida"
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "Exporta un mapa vectorial de GRASS a SVG."
+#, fuzzy
+#~ msgstr "Nombre del mapa vectorial de entrada"
+#~ msgid "vector, interpolation"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgstr "Columna de la tabla de atributos con valores a interpolar"
+#~ msgid "Vector based generalization."
+#~ msgstr "Generalización basada en vectoriales."
+#~ msgid "Number of vertices was reduced from %d to %d [%d%%]"
+#~ msgstr "El número de vértices se redujo de %d a %d [%d%%]"
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr "Crea topología para mapa vectorial de GRASS."
+#~ msgid "Vector map <%s> not found in the current mapset"
+#~ msgstr ""
+#~ "No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "Convertir capas vectoriales OGR a mapas vectoriales de GRASS."
+#~ msgid "Total area: %e (%d areas)"
+#~ msgstr "Áreas total: %e (%d áreas)"
+#~ msgid "Overlapping area: %e (%d areas)"
+#~ msgstr "Área solapada: %e (%d áreas)"
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "Área sin categoría: %e (%d áreas)"
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Convierte un mapa vectorial binario de GRASS (sólo puntos) en una capa de "
+#~ "mapa ráster 3D de GRASS."
+#, fuzzy
+#~ msgid "vector, extract"
+#~ msgstr "vectorial, exportar"
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr ""
+#~ "Perturbaciones de localizaciones aleatorias de puntos vectoriales de GRASS"
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "Parámetro(s) de distribución. Se la distribución es uniforme, sólo se "
+#~ "necesita un parámetro, el máximo. Para una distribución normal se "
+#~ "requieren dos parámetros, la media y la desviación estándar."
+#, fuzzy
+#~ msgstr "Número de capa"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr ""
+#~ "Genera un mapa de puntos vectorial 2D/3D de GRASS de forma aleatoria."
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "No se puede usar la columna '%s'"
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "Convierte un mapa vectorial binario de GRASS a salida ASCII VTK."
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr ""
+#~ "Convierte un mapa vectorial binario de GRASS a un mapa vectorial ASCII de "
+#~ "GRASS"
+#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
+#~ msgstr ""
+#~ "Ruta al archivo ASCII resultante o nombre del vectorial ASCII si se "
+#~ "define '-o'"
+#~ msgid "vector, paint labels"
+#~ msgstr "vectorial, etiquetas de pintura"
+#~ msgid "vector, geometry"
+#~ msgstr "vectorial, geometría"
+#, fuzzy
+#~ msgid "Output quadrant centres, number of points is written as category"
+#~ msgstr "Salida puntos"
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "lugares."
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr ""
+#~ "Crea un mapa vectorial de GRASS de una cuadrícula definida por el usuario."
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "Se debe especificar el valor umbral"
+#~ msgid "vector, kernel density"
+#~ msgstr "vectorial, densidad de kernel"
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "Convierte a uno de los formatos vectoriales OGR soportados."
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "Exportar sólo elementos con categoría (etiquetados). En caso contrario se "
+#~ "exportarán todos."
+#~ msgid ""
+#~ "Vector map <%s> is 3D. Use format specific layer creation options "
+#~ "(parameter 'lco') to export in 3D rather than 2D (default)"
+#~ msgstr ""
+#~ "El mapa vectorial <%s> es 3D. Use opciones de creación de capa "
+#~ "específicas para el formato (parámetro 'Ico') para exportar en 3D en vez "
+#~ "de 2D (predeterminado)."
+#~ msgid "Key column '%s' not found"
+#~ msgstr "Columna clave '%s' no encontrada"
+#~ msgid "Exporting %i points/lines..."
+#~ msgstr "Exportando %i puntos/líneas..."
+#~ msgid "%d features written"
+#~ msgstr "%d elementos escritos"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "puntos"
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr ""
+#~ "Crear una capa de mapa vectorial nueva combinando otras capas de mapas "
+#~ "vectoriales."
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Crear un buffer alrededor de los elementos de tipo dado (las áreas deben "
+#~ "contener centroide)."
+#~ msgid "Buffer distance in map units"
+#~ msgstr "Distancia de buffer en unidades de mapa"
+#~ msgid "vector, querying"
+#~ msgstr "vectorial, consultar"
+#~ msgid "Queries a vector map layer at given locations."
+#~ msgstr "Consulta una capa de mapa vectorial en las localizaciones dadas."
+#~ msgid "If not given reads from standard input"
+#~ msgstr "Si no se da lee de la entrada estándar"
+#~ msgid "vector, transformation"
+#~ msgstr "vectorial, transformación"
+#~ msgid "Copying vector objects from vector map <%s>..."
+#~ msgstr "Copiando objetos vectoriales del mapa vectorial <%s>..."
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Nombre del mapa vectorial de entrada que contiene líneas"
+#~ msgid "Name for output vector map where segments will be written"
+#~ msgstr ""
+#~ "Nombre del mapa vectorial de salida en el que se escribirán los segmentos"
+#~ msgid "Tests for normality for points."
+#~ msgstr "Test de normalidad para puntos."
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Calcula estadísticas univariante para atributos. La varianza y la "
+#~ "desviación estándar sólo se calculan para puntos si se especifica."
+#, fuzzy
+#~ msgstr "Imposible calcular el centroide del área"
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#~ msgstr ""
+#~ "Convierte un mapa vectorial binario de GRASS en una capa de mapa ráster "
+#~ "de GRASS."
+#~ msgid "Area without centroid (may be OK for island)"
+#~ msgstr "Área sin centroide (puede ser correcto para islas)"
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr ""
+#~ "Creaa puntos a lo largo de líneas de entrada en un nuevo vectorial con 2 "
+#~ "capas."
+#, fuzzy
+#~ msgid "%d points written to output vector map"
+#~ msgstr "Escritos [%d] puntos en el mapa vectorial de salida"
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr ""
+#~ "Crea un mapa vectorial a partir de archivo de puntos ASCII o archivo "
+#~ "ASCII vectorial."
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr ""
+#~ "Crea un nuevo vectorial como un enlace de sólo lectura a una capa OGR."
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "Umbral en unidades de mapa, un valor para cada herramienta (por omisión: "
+#~ "0.0[,0.0,...])"
+#~ msgid "Copying vector lines..."
+#~ msgstr "Copiando líneas vectoriales..."
+#~ msgid "%d lines / boundaries removed"
+#~ msgstr "%d líneas / contornos eliminados"
+#~ msgid "Duplicate area centroids: %5d"
+#~ msgstr "Centroides de área duplicados: %5d"
+#~ msgid "Attribute table column with values to interpolate"
+#~ msgid "No data points found"
+#~ msgstr "No se han encontrado puntos de datos"
+#~ msgid "Lines buffers... "
+#~ msgstr "Buffers de líneas... "
+#~ msgid "Difference in x,y direction for moving feature or vertex"
+#~ msgstr "Diferencia en dirección X, Y para mover elemento o vértice"
+#~ msgid "Error reading ASCII file: '%s'"
+#~ msgstr "Error al leer el archivo ASCII: '%s'"
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#~ msgstr ""
+#~ "Muestra información básica sobre una capa de mapa vectorial especificada "
+#~ "por el usuario."
+#~ msgid "Displaying column types/names for database connection of layer %d:"
+#~ msgstr ""
+#~ "Mostrando tipos/nombres de columna para la conexión a base de datos de la "
+#~ "capa %d:"
+#~ msgid "Map scale: 1:%d"
+#~ msgstr "Escala del mapa: 1:%d"
+#~ msgid "Map format: %s"
+#~ msgstr "Formato del mapa: %s"
+#~ msgid "Name of creator: %s"
+#~ msgstr "Nombre del creador: %s"
+#~ msgid "Organization: %s"
+#~ msgstr "Organización: %s"
+#~ msgid "Source date: %s"
+#~ msgstr "Fecha del origen: %s"
+#~ msgid " Digitization threshold: %s"
+#~ msgstr " Umbral de digitalización: %s"
+#~ msgid " Comments:"
+#~ msgstr " Comentarios:"
+#~ msgid "Extrudes flat vector object to 3D with defined height."
+#~ msgstr "Eleva objetos vectoriales planos a 3D con alturas definidas."
+#, fuzzy
+#~ msgid "vector, category"
+#~ msgid "Attach, delete or report vector categories to map geometry."
+#~ msgstr ""
+#~ "Acjuntar, borrar o informar categorías del vectorial a la geometría del "
+#~ "mapa."
+#~ msgid "Output surface raster map (elevation)"
+#~ msgstr "Producir mapa ráster de superficie (elevación)"
+#~ msgid "Output cross-validation errors vector point file"
+#~ msgstr ""
+#~ "Producir archivo de puntos vectorial de errores de validación cruzada"
+#, fuzzy
+#~ msgid "Output vector map showing quadtree segmentation"
+#~ msgstr "Producir mapa vectorial que muestre segmentación quadtree"
+#~ msgid "Output vector map showing overlapping windows"
+#~ msgstr "Producir mapa vectorial que muestre ventanas solapadas"
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "Nombre de la columna de atributos con valores a usar para la aproximación "
+#~ "(si capa>0)"
+#~ msgid ""
+#~ "Processing all selected output files\n"
+#~ "will require %d bytes of disk space for temp files"
+#~ msgstr ""
+#~ "Procesar todos los archivos de salida seleccionados\n"
+#~ "necesitará %d bytes en disco para archivos temporales"
+#~ msgid "Cannot write raster maps -- try to increase resolution"
+#~ msgstr ""
+#~ "No se pueden escribir los mapas ráster -- intente aumentar la resolución"
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr ""
+#~ "Imprimir todos los parámetros de conexión del mapa y salir en estilo de "
+#~ "script de consola"
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "El mapa vectorial <%s> está conectado por:"
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#~ msgstr "Exporta capas vectoriales de GRASS a formato de archivo DXF."
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "No se puede determinar el tipo de celda ráster"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "Nombre para el archivo de salida (NO añadir extensión)"
+#, fuzzy
+#~ msgid "Width and height of output image"
+#~ msgstr "Anchura y altura de cuadros en la cuadrícula"
+#, fuzzy
+#~ msgid "Surface"
+#~ msgstr "Varianza de la suma"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "Columnas"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "Controlador OGR: columna '%s', tipo OGR %d no soportado"
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr ""
+#~ "Imprime/establece la conexión general a la base de datos para el "
+#~ "directorio de mapas actual y sale."
+#~ msgid "Database schema"
+#~ msgstr "Esquema de la base de datos"
+#~ msgid "database, SQL"
+#~ msgstr "base de datos, SQL"
+#~ msgid "Name of file with sql statement"
+#~ msgstr "Nombre de archivo con sentencia SQL"
+#~ msgid "The password was stored in file"
+#~ msgstr "La contraseña se guardó en archivo"
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "Convierte todos los mapas vectoriales del antiguo GRASS < Ver5.7 del "
+#~ "directorio de mapas actual al formato actual."
+#~ msgid "raster, elevation"
+#~ msgstr "ráster, elevación"
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#~ msgid "Images"
+#~ msgstr "Imágenes"
+#~ msgid "Compression for PNG files"
+#~ msgstr "Compresión para archivos PNG"
+#~ msgid "PostScript"
+#~ msgstr "PostScript"
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "Imposible copiar la tabla"
+#~ msgid "raster, tiling"
+#~ msgstr "ráster, teselado"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "Listar reglas disponibles y salir"
+#~ msgid "display, diagram"
+#~ msgstr "mostrar, diagrama"
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Informa estadísticas de geometría para vectoriales."
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "Mostrar las páginas man HTML de GRASS"
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr "Crear una MÁSCARA para limitar la operación ráster"
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "Mapa ráster a usar como MÁSCARA"
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "Valores de categoría a usar para MÁSCARA (formato: 1 2 3 thru 7 *)"
+#~ msgid "Create inverse MASK from specified 'maskcats' list"
+#~ msgstr "Crear MASK inversa a partir de la lista 'maskcats' especificada"
+#~ msgid "Remove existing MASK (overrides other options)"
+#~ msgstr "Eliminar MÁSCARA existente (ignora otras opciones)"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "Nombre de la columna a mostrar"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcular estadísticas univariantes a partir de un mapa ráster de GRASS "
+#~ "basadas en polígonos vectoriales y carga las estadísticas en nuevas "
+#~ "columnas de atributos."
+#~ msgid "Name of vector polygon map"
+#~ msgstr "Nombre del mapa de polígono vectorial"
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "Nombre del mapa ráster del que calcular estadísticas"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importar mapas vectoriales Mapgen o Matlab a GRASS."
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr ""
+#~ "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
+#~ msgid "C"
+#~ msgstr "C"
+#~ msgid "D"
+#~ msgstr "D"
+#~ msgid "Show help"
+#~ msgstr "Mostrar ayuda"
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "Carpeta en la que guardar los datos descargados"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr "Número de capa. Si es -1, se extraerán todas las capas"
+#, fuzzy
+#~ msgid "Import GetFeature from WFS"
+#~ msgstr "Importar GetFeature de WFS"
+#~ msgid "raster, landscape structure analysis"
+#~ msgstr "ráster, análisis de estructura del paisaje"
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importar archivo SPOT VGT NDVI a un mapa ráster"
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr ""
+#~ "importar también mapa de calidad (capa de mapa de estado SM) y filtrar "
+#~ "mapa NDVI"
+#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+#~ msgstr "archivo SPOT VGT NDVI HDF existente (0001_NDV.HDF)"
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Mapa vectorial para el que editar la tabla de atributos"
+#~ msgid "Layer where to add column"
+#~ msgstr "Capa a la que añadir la columna"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#~ msgstr "Calculando la fila %d de la matriz de covarianza:"
+#, fuzzy
+#~ msgid "imagery, rectify"
+#~ msgstr "grupo de imaginería"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#~ msgstr "Nombre de la tabla del sistema de referencia"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#~ msgstr "¿Editar el archivo de categorías para [%s]?"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#~ msgid "SECTION 3: Accumulating Surface Flow."
+#~ msgstr "SECCIÓN 3: acumulando flujo de superficie."
+#~ msgid "Name of input vector points map"
+#~ msgstr "Nombre del mapa vectorial de puntos de entrada"
+#~ msgid "Eigen values:"
+#~ msgstr "Valores Eigen:"
+#, fuzzy
+#~ msgid "<%s> vector map will be interpolated"
+#~ msgstr "No se creará ningún dato vectorial."
+#, fuzzy
+#~ msgid "Auto-balancing of colors for LANDSAT images"
+#~ msgstr "Balance automático de colores para imágenes LANDSAT"
+#, fuzzy
+#~ msgid ""
+#~ "displays spectral response at user specified locations in group or images"
+#~ msgstr ""
+#~ "muestra la respuesta espectral en localizaciones especificadas por el "
+#~ "usuario en grupo o imágenes"
+#, fuzzy
+#~ msgid "group input"
+#~ msgstr "entrada de grupo"
+#, fuzzy
+#~ msgid "write output to PNG image"
+#~ msgstr "escribir la salida a imagen PNG"
+#, fuzzy
+#~ msgid "label with coordinates instead of numbering"
+#~ msgstr "Etiquetar con coordenadas en vez de numeración"
+#, fuzzy
+#~ msgid ""
+#~ "Reclasses a raster map greater or less than user specified area size (in "
+#~ "hectares)"
+#~ msgstr ""
+#~ "Reclasifica un mapa ráster mayor o menor que la superficie indicada por "
+#~ "el usuario (en hectáreas)"
+#, fuzzy
+#~ msgid "lesser val option that sets the <= area size limit [hectares]"
+#~ msgstr ""
+#~ "Opción de valor menor que establece el <= límite de tamaño de área "
+#~ "(hectáreas)"
+#, fuzzy
+#~ msgid "greater val option that sets the >= area size limit [hectares]"
+#~ msgstr ""
+#~ "Opción de valor mayor que establece el >= límite de tamaño de área "
+#~ "(hectáreas)"
+#, fuzzy
+#~ msgid "Writing data to file..."
+#~ msgstr "Escribiendo los datos transformados a archivo..."
+#, fuzzy
+#~ msgid "1 class."
+#~ msgstr "%d clases."
+#~ msgid "Writing %s"
+#~ msgstr "Escribiendo %s"
+#~ msgid "ID values"
+#~ msgstr "Valores ID"
+#~ msgid "To_map"
+#~ msgstr "A_mapa"
+#~ msgid "To layer"
+#~ msgstr "A la capa"
+#~ msgid "vector, attribute table"
+#~ msgstr "vectorial, tabla de atributos"
+#, fuzzy
+#~ msgid "Type of elements"
+#~ msgstr "Nombre de un elemento"
+#~ msgid "Output hue raster map"
+#~ msgstr "Mapa ráster de salida de matiz"
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#~ msgstr "Nombre del mapa ráster de derivadas de X [m/m] o [pies/pies]"
+#~ msgid "Multiplier"
+#~ msgstr "Multiplicador"
+#~ msgid "Unable to delete line %d"
+#~ msgstr "No se puede borrar la línea %d"
+#~ msgid "Column(s)"
+#~ msgstr "Columna(s)"
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr "No se puede abrir el origen de datos OGR '%s'"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "<%s> es un nombre de archivo no admitido"
+#, fuzzy
+#~ msgid "Direction raster found <%s>"
+#~ msgstr "Escribiendo mapa ráster <%s>"
+#, fuzzy
+#~ msgid "Input value: maximum length of surface flow in map units, for USLE"
+#~ msgstr "Valor de entrada: longitud máxima de flujo de superficie, para USLE"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d"
+#~ "(egrees)"
+#~ msgstr ""
+#~ "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
+#, fuzzy
+#~ msgid "vector, spatial query"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_fr.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -13985,9 +13985,8 @@
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
-#, fuzzy
msgid "Level"
-msgstr "Niveau d'eau"
+msgstr ""
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
@@ -14011,11 +14010,10 @@
msgid "Select only one message level"
msgstr ""
-# c-format
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "impossible d'ouvrir le fichier en entrée <%s>"
+msgstr "Impossible de fermer la couche source"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -20184,7 +20182,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "couche de sortie"
+msgstr "Crée une sortie 3D"
#: ../vector/v.random/main.c:111
#, fuzzy
@@ -22379,9 +22377,8 @@
msgstr "Erreur dans pj_do_proj"
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "Créer des icones pour le fichier vecteur GRASS et les attributs liés"
+msgstr ""
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -26413,9 +26410,8 @@
msgstr "Afficher"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "nom =%s\n"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -26876,7 +26872,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "Caractère de séparation de champs (en mode 'terse' seulement)"
+msgstr "Produit les statistiques à la façon d'un script shell"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -30211,8 +30207,11 @@
"non indiqué, aucun fichier d'instruction psmap ne sera créé)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
+#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
msgstr ""
+"Racine du nom du fichier d'instruction psmat dans le répertoire courant (si "
+"non indiqué, aucun fichier d'instruction psmap ne sera créé)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Name of group file where thematic map commands will be saved"
@@ -30677,12 +30676,14 @@
msgstr "impossible de mettre à jour les limites"
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#, fuzzy
msgid "Action to be taken"
-msgstr ""
+msgstr "Icone à supprimer"
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
+#, fuzzy
msgid "Category number starting value"
-msgstr ""
+msgstr "Nom de colonne de catégorie"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
@@ -30962,8 +30963,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "Nom de la couche raster à utiliser pour <%s>"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#, fuzzy
@@ -30976,8 +30978,9 @@
msgstr "Nom d'une couche raster"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+#, fuzzy
msgid "Width of display canvas"
-msgstr ""
+msgstr "Texte à afficher"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
#, fuzzy
@@ -33623,6 +33626,327 @@
"Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr ""
+"nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de "
+"données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "Fichier raster à importer"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "Fichier ascii contenant les signatures spectrales"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "Statistiques de transition de classe."
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "Statistique de couches raster."
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "La table <%s> n'existe pas dans la base de données <%s>"
+#, fuzzy
+msgid "report"
+msgstr "Importer"
+# c-format
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Impossible d'écrire l'en-tête de [%s]"
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "Erreur de lecture de la couche %s"
+# c-format
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+msgstr "Erreur de lecture du fichier raster [%s]"
+#, fuzzy
+msgid "r.li.worker (pid %i) exited with abnormal status: %i"
+msgstr "r.li.worker (pid %i) interrompu avec un statut anormal %i"
+#, fuzzy
+msgid "r.li.worker (pid %i) terminated successfully"
+msgstr "r.li.worker (pid %i) achevé\n"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "impossible de lire la région <%s> dans <%s>"
+# c-format
+#, fuzzy
+msgid "Unable to open base map <%s>"
+msgstr "Impossible d'ouvrir la couche raster <%s>"
+# c-format
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+msgstr "Impossible d'ouvrir la couche vecteur [%s]"
+# c-format
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "impossible d'ouvrir le fichier en sortie <%s>"
+# c-format
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "Impossible de récupérer la ligne %d (erreur =%d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "Impossible de reconfigurer la région sur la région initiale !!!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Impossible de lire la ligne %i\n"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Impossible d'insérer une nouvelle ligne : %s"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+msgstr "Impossible d'ouvrir la nouvelle couche d'accumulation."
+# c-format
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+msgstr "Écriture %s..."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "Erreur de lecture de la ligne de données"
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "Nom de la couche en entrée contenant les coûts de rugosité"
+# c-format
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "impossible d'ouvrir le fichier en entrée <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "Masque: %s\n"
+# c-format
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+msgstr "Impossible de créer la couche raster <%s>"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "Lecteur du fichier raster..."
+# c-format
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+# c-format
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Impossible d'écrire la couche raster lac <%s>!"
+# c-format
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "Impossible de créer la couche raster %s"
+# c-format
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+# c-format
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "Impossible d'ouvrir le fichier [%s]"
+# c-format
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
+# c-format
+#, fuzzy
+msgid "Cannot write to output raster file"
+# c-format
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+# c-format
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "nom =%s\n"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Nom du fichier PNG"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Nombre de cadres de l'animation"
+# c-format
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "Nombre de points d'interpolation"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+msgstr "Importation vecteur complète"
+msgid "Use db.select for SELECT SQL statements"
+msgstr "Utiliser db.select pour les déclarations SELECT SQL"
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD"
+msgstr ""
+"\n"
+"SECTION 3: Accumulation du courant de surface. Achevé (pourcentage):"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "%s: %s - impossible de trouver l'image (partie réelle)"
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"Impossible d'ouvrir l'image (partie réelle) dans le répertoire cell_misc.\n"
+"La couche en entrée n'a pas été créée par i.fft"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "%s: %s - impossible de trouver l'image (partie imaginaire)"
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire "
+"cell_misc.\n"
+msgid "Group [%s] not found."
+msgstr "Groupe [%s] non trouvé"
+msgid "Range less than or equal to zero not allowed."
+msgstr "Intervalle inférieur ou égal à zéro non valide"
+msgid "Writing viewable versions of transformed data to files..."
+msgstr ""
+"Ecriture des versions visualisables des données transformées dans les "
+"fichiers..."
+msgid "Unable to open file in the cell_misc directory."
+msgstr "Impossible d'ouvrir le fichier dans le répertoire cell_misc"
+#, fuzzy
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr "Nom de l'image à recaler à afficher à l'écran"
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr ""
+"Nom de la couche de données du jeu de données cible à afficher à l'écran."
+#, fuzzy
+msgid ""
+"Name of old database. The database must be in form printed by v.db.connect -"
+"g, i.e. with substituted variables"
+msgstr ""
+"Nom de l'ancienne base de données, la base de données doit être sous à la "
+"forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
+# c-format
+msgid "Terrain raster map (DEM)"
+msgstr "Couche raster de terrain (MNT)"
+msgid "Use output= option to change vector map name"
+msgstr "Utilisez l'option output= pour changer le nom de la couche vectorielle"
+# c-format
+#, fuzzy
+msgid "Erasing monitors ..."
+msgid "Category file for [%s] not available"
+msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
+msgid "color file for [%s] not available"
+msgstr "Fichier de couleur de [%s] non disponible"
+#, fuzzy
#~ msgid "Not enough room in history file"
#~ msgstr "Pas assez de place dans le fichier historique"
@@ -33639,10 +33963,6 @@
#~ msgid "Name of workspace file"
#~ msgstr "Nom du fichier d'étiquettes"
-#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
#~ msgid "List of values to be displayed (FP maps)"
#~ msgstr "Liste de valeurs à afficher (couche en flottants FP)"
@@ -33747,16 +34067,6 @@
#~ msgstr "DXY [%s] TERMINEE"
#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr ""
-#~ "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base "
-#~ "de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et "
-#~ "DATE)"
-#, fuzzy
#~ msgid "Input elevation map"
#~ msgstr "Fichier d'altitude en entrée"
@@ -33767,14 +34077,6 @@
#~ msgid "Layer number of data column"
#~ msgstr "Couche à laquelle ajouter la colonne"
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "Fichier raster à importer"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "Fichier ascii contenant les signatures spectrales"
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Génère une couche raster montrant les sous-bassins versants."
@@ -33876,10 +34178,6 @@
#~ "(i)\tOPTIONNEL sortie pour une classe de valeurs topographiques indexées "
#~ "données"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "Statistiques de transition de classe."
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "Nom de la couche raster contenant les informations d'altitude"
@@ -33938,18 +34236,6 @@
#~ msgid "Unable to access table <%s>"
#~ msgstr "impossible de créer la sortie <%s>"
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Convertit une couche raster 3D au format VTK-ASCII"
@@ -33965,10 +34251,6 @@
#~ "Exporte une couche Raster GRASS en un fichier TIFF 8/24 bits à la "
#~ "résolution de la région actuelle."
-#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "Produit les statistiques à la façon d'un script shell"
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -33980,10 +34262,6 @@
#~ msgid "Band to select"
#~ msgstr "Pas de moniteur sélectionné"
-#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Statistique de couches raster."
#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
#~ msgstr ""
#~ "Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
@@ -33994,10 +34272,6 @@
#~ "couche>0)"
#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "La table <%s> n'existe pas dans la base de données <%s>"
-#, fuzzy
#~ msgid "M.Q. solution"
#~ msgstr "Résolution"
@@ -34079,19 +34353,10 @@
#~ msgstr "Impossible de lire la ligne raster."
#, fuzzy
-#~ msgid "report"
-#~ msgstr "Importer"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-# c-format
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Impossible d'écrire l'en-tête de [%s]"
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "Impossible d'écrire le fichier temporaire"
@@ -34151,10 +34416,6 @@
#~ msgid "Unable to read header of raster map <%s>"
#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
-#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "Erreur de lecture de la couche %s"
# c-format
#, fuzzy
#~ msgid "Reading row %d"
@@ -34261,25 +34522,12 @@
#~ msgid "Cannot read row"
#~ msgstr "Impossible de lire %s"
-# c-format
-#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#~ msgstr "Erreur de lecture du fichier raster [%s]"
#~ msgid "Error in pipe creation"
#~ msgstr "Erreur dans la création du pipe"
#~ msgid "Error opening channel %i"
#~ msgstr "Erreur à l'ouverture du canal %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) interrompu avec un statut anormal %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) achevé\n"
# c-format
#, fuzzy
#~ msgid "Cannot close %s file (PIPE)"
@@ -34389,14 +34637,6 @@
#~ " \t\t\t\tpid = %i \n"
-#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "impossible de lire la région <%s> dans <%s>"
# c-format
#, fuzzy
#~ msgid "Unable to get header for %s"
@@ -34405,22 +34645,7 @@
#~ msgid "Cannot reset current region"
#~ msgstr "Impossible de réinitialiser la région courante"
-# c-format
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
#~ msgstr "Editer le fichier de catégorie de [%s]?"
@@ -34466,23 +34691,6 @@
# c-format
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "Impossible de récupérer la ligne %d (erreur =%d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "Impossible de reconfigurer la région sur la région initiale !!!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-# c-format
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
#~ msgstr "Impossible de créer la couche raster <%s>"
@@ -34514,10 +34722,6 @@
#~ msgstr "Erreur d'écriture de la ligne null [%d]"
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Impossible de lire la ligne %i\n"
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr ""
#~ "La colonne %d définie comme entier ne contient que des valeurs doubles"
@@ -34535,10 +34739,6 @@
#~ msgstr "Lecteur du fichier raster..."
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Impossible d'insérer une nouvelle ligne : %s"
-#, fuzzy
#~ msgid "Invalid region: %s"
#~ msgstr "région incorrecte : %s"
@@ -34591,17 +34791,8 @@
#~ msgid "unable to open accum file in valid_basins()"
#~ msgstr "Impossible d'ouvrir le fichier d'accumulation dans valid_basins()"
-#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#~ msgstr "Impossible d'ouvrir la nouvelle couche d'accumulation."
# c-format
#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "Écriture %s..."
-# c-format
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
#~ msgstr "Impossible de créer la couche raster %s"
@@ -34622,14 +34813,6 @@
#~ msgid "Unable to close new basin map layer"
#~ msgstr "Impossible d'ouvrir la nouvelle couche L."
-#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "Erreur de lecture de la ligne de données"
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Nom de la couche en entrée contenant les coûts de rugosité"
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "Nombre de segments à créer (bibliothèque segment)"
@@ -34753,16 +34936,7 @@
#~ msgid "Failed writing raster map <%s>"
#~ msgstr "Couche raster %i créée \n"
-# c-format
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "impossible d'ouvrir le fichier en entrée <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
#~ msgstr "Erreur de lecture de la couche Teinte"
@@ -34784,13 +34958,10 @@
#~ msgid "<Auxiliar_edge_table> created in database."
+# c-format
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Masque: %s\n"
-#, fuzzy
#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
+#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
#, fuzzy
#~ msgid "Finding nearest lines..."
@@ -34967,24 +35138,10 @@
#~ msgid "Current region cannot be set."
#~ msgstr "La région courante ne peut être modifiée"
-# c-format
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Impossible de créer la couche raster <%s>"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Lecteur du fichier raster..."
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
#~ msgid "Unable to open the cell map MASK."
#~ msgstr "Impossible d'ouvrir la couche de cellule MASK."
@@ -35008,16 +35165,6 @@
#~ msgid "Unable to open band files."
#~ msgstr "impossible d'ouvrir les fichiers de bandes spectrales"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
-# c-format
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "Impossible de créer la couche raster %s"
#~ msgid "Error while reading input raster map."
#~ msgstr "Erreur de lecture de la couche raster en entrée"
@@ -35030,25 +35177,6 @@
#~ "Erreur dans l'écriture de la couche de cellules durant la transformée"
# c-format
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
-# c-format
#~ msgid "Could not open <%s>"
#~ msgstr "impossible d'ouvrir <%s>"
@@ -35056,21 +35184,6 @@
#~ msgid "Could not read from <%s>"
#~ msgstr "Impossible de lire <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot write to output raster file"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-# c-format
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
#~ msgid "Error reading row of data"
@@ -35215,7 +35328,7 @@
#, fuzzy
#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "Importation vecteur complète"
+#~ msgstr "groupes d'images"
#~ msgid "Additional options for wget"
#~ msgstr "Options additionnelles pour wget"
@@ -35329,23 +35442,6 @@
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "nom =%s\n"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "Nom du fichier PNG"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Nombre de cadres de l'animation"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "Nom de fichier du résultat de la classification"
@@ -35674,10 +35770,6 @@
#~ msgstr "colonnes changées de %d vers %d"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "Nombre de points d'interpolation"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
@@ -35721,10 +35813,6 @@
#~ msgstr "Couche de sortie : pratique pour visualiser les résultats"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "Fichier raster à utiliser comme surface"
@@ -35966,9 +36054,6 @@
#~ "Nombre de colonnes utilisées comme coordonnées x (la première colonne est "
#~ "1) en mode points"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "Utiliser db.select pour les déclarations SELECT SQL"
#~ msgid "Output drain raster map"
#~ msgstr "couche raster de sortie"
@@ -36008,12 +36093,6 @@
#~ msgid "Unable to open MASK"
#~ msgstr "impossible d'ouvrir le MASK"
-#, fuzzy
-#~ msgid "SECTION 3: Accumulating Surface Flow with MFD"
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 3: Accumulation du courant de surface. Achevé (pourcentage):"
#~ msgid "unable to open MASK"
@@ -36057,30 +36136,6 @@
#~ msgid "Output inverse raster map after IFFT"
#~ msgstr "Fichier raster inverse en sortie après ifft"
-#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "%s: %s - impossible de trouver l'image (partie réelle)"
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Impossible d'ouvrir l'image (partie réelle) dans le répertoire "
-#~ "cell_misc.\n"
-#~ "La couche en entrée n'a pas été créée par i.fft"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "%s: %s - impossible de trouver l'image (partie imaginaire)"
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire "
-#~ "cell_misc.\n"
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "2 valeurs : [%d] lignes [%d] colonnes."
@@ -36170,9 +36225,6 @@
#~ msgid "Run quietly"
#~ msgstr "Mode silencieux"
-#~ msgid "Group [%s] not found."
-#~ msgstr "Groupe [%s] non trouvé"
#~ msgid "Subgroup [%s] not found."
#~ msgstr "Sous-groupe [%s] non trouvé"
@@ -36222,9 +36274,6 @@
#~ msgid "Range of values in output display files"
#~ msgstr "Intervalle de valeurs dans les fichiers d'affichage en sortie"
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "Intervalle inférieur ou égal à zéro non valide"
#~ msgid "Initializing data...\n"
#~ msgstr "Initialisation des données...\n"
@@ -36234,14 +36283,6 @@
#~ msgid "FFT completed..."
#~ msgstr "FFT terminée..."
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr ""
-#~ "Ecriture des versions visualisables des données transformées dans les "
-#~ "fichiers..."
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "Impossible d'ouvrir le fichier dans le répertoire cell_misc"
# c-format
#~ msgid ""
#~ "\n"
@@ -36306,17 +36347,6 @@
#~ "Placer des points de contrôle sur une image pour le recalage de "
#~ "l'orthophoto."
-#, fuzzy
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr "Nom de l'image à recaler à afficher à l'écran"
-#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr ""
-#~ "Nom de la couche de données du jeu de données cible à afficher à l'écran."
# c-format
#, fuzzy
#~ msgid "Unable to read head of %s"
@@ -36395,14 +36425,6 @@
#~ msgstr "Exécuter de façon non-interactive"
#, fuzzy
-#~ msgid ""
-#~ "Name of old database. The database must be in form printed by v.db."
-#~ "connect -g, i.e. with substituted variables"
-#~ msgstr ""
-#~ "Nom de l'ancienne base de données, la base de données doit être sous à la "
-#~ "forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
-#, fuzzy
#~ msgid "Run non-interactively"
@@ -36854,9 +36876,6 @@
#~ msgid "display, export, GPS"
#~ msgstr "Afficher l'index"
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
#~ msgid "Make JPEG instead of PNG image"
#~ msgstr "Faire un JPEG à la place d'une image PNG"
@@ -37249,10 +37268,6 @@
#~ msgid "Saving new map"
#~ msgstr "Sauvegarde de la nouvelle couche"
-# c-format
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Couche raster de terrain (MNT)"
#~ msgid "Output raster map with lake"
#~ msgstr "couche raster en sortie contenant le lac"
@@ -37689,10 +37704,6 @@
#~ msgid "Cannot open dxf file <%s>"
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr ""
-#~ "Utilisez l'option output= pour changer le nom de la couche vectorielle"
#, fuzzy
#~ msgid "Cannot open new vector map <%s>"
#~ msgstr "%s: impossible d'ouvrir le nouveau fichier vectoriel"
@@ -38260,12 +38271,7 @@
#~ msgid "No LatLong information for XY-Projection"
#~ msgstr "L'option Geo-Grid n'est pas disponible en projection XY"
-# c-format
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#, fuzzy
#~ msgid "Could not open input file <%s>."
#~ msgstr "impossible d'ouvrir le fichier vecteur <%s>"
@@ -38440,9 +38446,6 @@
#~ msgid "Creating support files for [%s]."
#~ msgstr "Créer des fichiers supports pour [%s]."
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
# c-format
#~ msgid "%s: <%s> raster map not found"
#~ msgstr "%s : fichier de cellules <%s> non trouvé"
@@ -39266,9 +39269,6 @@
#~ msgid "Raster map [%s] not available"
#~ msgstr "La couche raster [%s] n'est pas disponible"
-#~ msgid "color file for [%s] not available"
-#~ msgstr "Fichier de couleur de [%s] non disponible"
# c-format
#~ msgid "Raster file [%s] not available"
#~ msgstr "Fichier(s) raster [%s] non disponible"
@@ -41165,3 +41165,1702 @@
#, fuzzy
#~ msgid "Unable to connect line id %d to line %d"
#~ msgstr "Ne pas afficher les codes de catégories"
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Convertit une couche raster 3D en fichier texte ASCII."
+#, fuzzy
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr "Convertir un fichier raster ASCII en couche raster 3D (binaire)."
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Lecteur du fichier raster..."
+#~ msgid ""
+#~ "Cannot create mask file: G3D_MASK already exists!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+#~ msgstr ""
+#~ "Impossible de créer un fichier masque : G3D_MASK existe déjà!\n"
+#~ "Utilisez 'g.remove rast3d=G3D_MASK' pour supprimer le masque existant."
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "Exporter une couche raster 3D GRASS vers un fichier 3D VIS-5D"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "Exporter une couche raster GRASS en fichier GRIDATB.FOR (TOPMODEL)"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "Nom d'une couche raster"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr "Conertit une couche raster en fichier pour POVRAY"
+#, fuzzy
+#~ msgid "raster, map algebra"
+#~ msgstr "Importation vecteur complète"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "Convertit une couche raster en fichier texte ASCII."
+# c-format
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "Écriture [%s]..."
+# c-format
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "Vecteur d'arrivée introuvable %s"
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "Importer comme données à virgule flottante (par défaut : entier)"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr ""
+#~ "Importer comme virgule flottante en double précision (par défaut : entier)"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#~ msgstr "\t\tNombre de bits par cellule"
+#~ msgid "Update the statistics (histogram, range) for [%s]? "
+#~ msgstr "Mettre à jour les statistiques (histogramme, intervalle) pour [%s]?"
+# c-format
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "Couche raster de terrain (MNT)"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr ""
+#~ "#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
+#~ "Nom de la couche raster cible\n"
+#~ "Nom de la couche raster de sortie"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#~ msgstr "Interpolation de la couche raster <%s>... ligne %d ..."
+#, fuzzy
+#~ msgid "raster, statistics"
+#~ msgstr "Statistiques de transition de classe."
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Convertit une couche raster au format VTK-Ascii"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "Nombre de points d'interpolation"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr ""
+#~ "Nom du fichier raster source\n"
+#~ "Nom de la couche raster source"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Nom du fichier raster source"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Nom de la couche raster source pour le coefficient d'albedo"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "Nom du nouveau fichier raster"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Nom du fichier raster en sortie pour l'aspect"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr "Nom de fichier de sortie pour la section croisée"
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "couche raster de direction à créer"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "couche raster de sortie"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "Nom du fichier raster en sortie pour la courbure moyenne du profil"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Fichier raster en sortie pour la pente"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Convertit trois couches raster R,G,B en un fichier image au format PPM, "
+#~ "avec la résolution de la région actuelle."
+# c-format
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "impossible d'ouvrir le fichier de cellule [%s]"
+#, fuzzy
+#~ msgid "raster, buffer"
+#~ msgstr "couche raster source"
+#, fuzzy
+#~ msgid "raster, series"
+#~ msgstr "couche raster à échantillonner"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "couche d'entrée : quantité de ruissellement par cellule"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr ""
+#~ "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr ""
+#~ "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres "
+#~ "cellules"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "Couche de sortie : étiquette unique pour chaque bassin versant"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "Couche de sortie : valeur unique pour chaque demi-bassin versant"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr ""
+#~ "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) "
+#~ "pour USLE"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "Couche de sortie : facteur d'escarpement (S) pour USLE "
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "Valeur d'entrée : taille minimum de bassin versant"
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr ""
+#~ "Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "\n"
+#~ "Désolé, si aucune des options suivantes n'est fixée:\n"
+#~ "\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope "
+#~ "(pente), ou 1s\n"
+#~ "\tvous DEVEZ fournir une valeur pour le seuil du bassin (basin.threshold)."
+#~ msgid ""
+#~ "USAGE for basin delineation:\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "\n"
+#~ "USAGE for ARMSED FILE creation:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "\n"
+#~ "USAGE for slope length determination:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
+#~ msgstr ""
+#~ "USAGE pour la délimitation du bassin versant:\n"
+#~ "%s -4 el=couche_altitude t=seuil_depression_marecageuse "
+#~ "[ov=couche_courants] [dr=couche_direction_drainage] "
+#~ "[de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] "
+#~ "ba=couche_bassin_versant [se=couche_segment_cours_d_eau]\n"
+#~ "\n"
+#~ "USAGE pour la création du fichier ARMSED:\n"
+#~ "%s [-4] el=couche_altitude t=seuil_depression_marecageuse "
+#~ "[ba=couche_bassin_versant] [se=couche_segment_cours_d_eau] "
+#~ "ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
+#~ "\n"
+#~ "USAGE pour la détermination de longueur de pentes:\n"
+#~ "[dr=couche_direction_drainage] [de=couche_depression] "
+#~ "[ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] "
+#~ "[ob=couche_obstacles] [S=couche_escarpement_pente] "
+#~ "LS=couche_longueur_pentes [r=couche_erosion_ruissellement] "
+#~ "[sd=depot_pente valeur ou couche]"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "Impossible d'ouvrir la nouvelle couche d'accumulation."
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "Erreur d'écriture du fichier colr de <%s>"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programme de conversion d'une série de fichiers raster vers MPEG."
+#, fuzzy
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Filtrer et générer une couche d'altitude sans dépressions et une couche "
+#~ "de direction d'écoulement depuis une couche d'altitude donnée"
+#~ msgid "Output direction raster map"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "couche raster des zones à problèmes"
+#, fuzzy
+#~ msgid "raster, resample"
+#~ msgid "Cannot read ew_res value"
+#~ msgstr "Impossible de lire la valeur ew_res"
+#~ msgid "Cannot read ns_res value"
+#~ msgstr "Impossible de lire la valeur ns_res"
+#~ msgid "[%s]: Map is the wrong resolution"
+#~ msgstr "[%s] : la couche n'a pas la bonne résolution"
+#~ msgid "Cannot get row %d (error = %d)"
+#~ msgstr "Impossible de récupérer la ligne %d (erreur =%d)"
+#~ msgid "Cannot set region to back to the initial region !!!"
+#~ msgstr "Impossible de reconfigurer la région sur la région initiale !!!"
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
+#~ "will be rounded to integer!"
+#~ msgstr ""
+#~ "La couche <%s> du jeu de données <%s> est une couche en point flottant. "
+#~ "Les valeurs décimales seront arrondies à l'entier!"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "Programme de génération de surface à partir de contours rasterisés."
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "Nom de la couche existante contenant les contours"
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Creer/Modifier la table de couleurs associée à une couche raster."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "couche raster source pour la table de couleurs"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "Fichier de coordonnées en entrée (ne pas lire à partir de stdin)"
+#, fuzzy
+#~ msgid ""
+#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
+#~ "be specified!"
+#~ msgstr ""
+#~ "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
+#~ msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
+#~ msgstr ""
+#~ "CHILD[pid = %i] : impossible d'ouvrir le mask %s... continuer sans!!!"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "Impossible de créer le répertoire .r.li"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "Impossible de créer le répertoire .r/li/en sortie"
+#~ msgid "r.li.worker (pid %i) exited with abnormal status %i"
+#~ msgstr "r.li.worker (pid %i) interrompu avec un statut anormal %i"
+#, fuzzy
+#~ msgid "r.li.worker (pid %i) terminated"
+#~ msgstr "r.li.worker (pid %i) achevé\n"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "Impossible de faire les stats du fichier de configuration %s"
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#~ msgstr "Fichier raster à importer"
+#, fuzzy
+#~ msgid "raster, null data"
+#~ msgstr "couche raster en entrée"
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr ""
+#~ "Produit une couche raster où les aires contiguës ont été agrandies d'une "
+#~ "cellule."
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Couche de bassin versant créée par r.water.outlet (MASK)"
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) Couche de gradient à partir d'une couche d'altitudes positives"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) Nombre de classes topographiques indexées"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(o/i) Fichier de statistiques topographiques indexées"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) Fichier de paramètres TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr ""
+#~ "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "Calculer des zones d'ombre portée à partir de la position du soleil et "
+#~ "d'un MNT. A : la position exacte du soleil est donnée. B : date/heure "
+#~ "pour calculer la position du soleil grâce à r.sunmask."
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A : altitude du soleil au dessus de l'horizon, en degrés"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A : angle du soleil par rapport au nord, en degrés"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B : minutes (0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B : secondes (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B : fuseau horaire (positif vers l'est, différence par rapport à GMT)"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Crée une nouvelle couche dont les catégories sont basées sur la "
+#~ "reclassification des catégories d'une couche raster existante."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "couche à reclassifier"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "Convertit une couche raster en couche vectorielle"
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "Coordonnée est"
+# c-format
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#~ msgstr "fp: L'intervalle va de %.25f à %.25f\n"
+# c-format
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#~ msgstr "L'intervalle va de %ld à %ld\n"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#, fuzzy
+#~ msgid "'%s' is not a valid rule"
+#~ msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "Nom de la couche vecteur en entrée contenant les cours d'eau"
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr ""
+#~ "Constructon de courbes de terrain (lignes du courant), longueur des "
+#~ "courants, et densité de lignes de courants (zones amont) à partir d'un "
+#~ "modèle numérique de terrain (MNT) raster"
+#~ msgid "Output flowpath length raster map"
+#~ msgstr "Fichier raster en sortie pour la longueur des courants"
+#~ msgid "Output flowline density raster map"
+#~ msgstr "Fichier raster en sortie pour la densité des courants"
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "Longueurs 3D plutôt que 2D"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "Convertir un fichier raster ASCII en couche raster (binaire)."
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "Montre l'étiquette de catégorie dans la(les) cellule(s) de grille"
+#, fuzzy
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une "
+#~ "couche d'altitude."
+# c-format
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "Type de colonne non géré"
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
+#, fuzzy
+#~ msgid "File containing weights"
+#~ msgstr "Fichier contenant les requêtes SQL"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "Afficher également les paramètres 3D"
+#, fuzzy
+#~ msgid "general, settings"
+# c-format
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#~ msgstr "Écriture %s..."
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "format OGR"
+#, fuzzy
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#~ msgstr "Impossible de lire la table de couleur %s"
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "Couleur pour tracer les X (valeurs Null)"
+#~ msgid "display, cartography"
+#~ msgstr "affichage, cartoraphie"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "nom =%s\n"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Moniteur: waitpid: attendu %d mais reçu %d\n"
+#, fuzzy
+#~ msgid "display, networking"
+#~ msgstr "Afficher l'index"
+#~ msgid ""
+#~ "Identifies the geographic coordinates associated with point locations in "
+#~ "the active frame on the graphics monitor."
+#~ msgstr ""
+#~ "Identifie les coordonnées géographiques associées à l'emplacement d'un "
+#~ "point dans le moniteur actif."
+#~ msgid "Command mode (Compatibility with d.text)"
+#~ msgstr "Mode ligne de commande (compatible avec d.text)"
+#~ msgid "Either text or -c should be given"
+#~ msgstr "L'une des options, soit texte soit -c, doit être sélectionnée."
+#~ msgid "Unable to create face"
+#~ msgstr "Impossible de créer le texte"
+#~ msgid "Unable to set size"
+#~ msgstr "Impossible de paramétrer la taille"
+#~ msgid "Text conversion error"
+#~ msgstr "Erreur de conversion du texte"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#~ msgstr "Erreur de lecture de la couche Teinte"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "Fichier de couleur de [%s] non disponible"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr "Liste de catégories à afficher (couche en entiers INT)"
+#~ msgid "Invert catlist"
+#~ msgstr "Inverser la catlist"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#~ msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "Impossible de lire le symbole, impossible d'afficher les points"
+#~ msgid "Vector map attribute column to use for comparison"
+#~ msgstr ""
+#~ "Nom du champ attributaire de la couche vectorielle à utiliser pour la "
+#~ "comparaison"
+#~ msgid "Vector map to store differences"
+#~ msgstr "Couche vectorielle servant au stockage des différences"
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "Option de facteur d'échelle pour les valeurs lues dans la couche raster. "
+#~ "Les valeurs échantillonnées seront multipliées par ce facteur"
+#, fuzzy
+#~ msgid "%d new points written to output"
+#~ msgstr "%d points écrits vers la couche cible\n"
+#, fuzzy
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "Exporte un raster GRASS vers un tableau binaire."
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "Code de couche"
+#, fuzzy
+#~ msgid "Query layer number (read from)"
+#, fuzzy
+#~ msgid "vector, interpolation"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgstr ""
+#~ "Colonne de la table attributaire avec les valeurs à interpoler (si la "
+#~ "couche>0)"
+#, fuzzy
+#~ msgid "Vector based generalization."
+#, fuzzy
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr ""
+#~ "Créer des icones pour le fichier vecteur GRASS et les attributs liés"
+#, fuzzy
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr ""
+#~ "Convertit des fichiers vecteurs OGR dans GRASS. Pilotes disponibles:\n"
+# c-format
+#, fuzzy
+#~ msgid "Total area: %e (%d areas)"
+# c-format
+#, fuzzy
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "%d points sans catégorie"
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Convertit une couche vecteur GRASS binaire (points seulement) en couche "
+#~ "raster 3D GRASS"
+#, fuzzy
+#~ msgid "vector, extract"
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr ""
+#~ "Génère des perturbations aléatoires sur la position de points vectoriels "
+#~ "GRASS"
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "Paramètre(s) de distribution. Si la distribution est uniforme, seul un "
+#~ "paramètre, le maximum, est nécessaire. Pour une distribution normale, "
+#~ "deux paramètres, la moyenne et l'écart-type, sont nécessaires."
+#, fuzzy
+#~ msgid "Layer number (from)"
+#, fuzzy
+#~ msgid "Layer number (to)"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr ""
+#~ "Génère de façon aléatoire des couches vectorielles points GRASS 2D/3D"
+# c-format
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "Convertit une couche vectorielle binaire GRASS en sortie ASCII VTK"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr ""
+#~ "Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
+#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
+#~ msgstr ""
+#~ "Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si "
+#~ "'-o' est défini"
+#, fuzzy
+#~ msgid "Parameter '%s' ignored in standard mode"
+#~ msgstr "incidout demande de fixer le paramètre d'heure"
+#, fuzzy
+#~ msgid "vector, geometry"
+#~ msgstr "Couche vecteur à supprimer"
+#, fuzzy
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr ""
+#~ "Utilisez l'option output= pour changer le nom de la couche vectorielle"
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "Recherche des classes d'apprentissage..."
+#, fuzzy
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr "Convertit une couche vecteur binaire GRASS en couche raster GRASS"
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "2 couches doivent être spécifiées"
+#, fuzzy
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "Convertir vers un des formats vecteurs gérés par OGR"
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous "
+#~ "les objets sontexportés"
+# c-format
+#~ msgid "Key column '%s' not found"
+#~ msgstr "Clef primaire <%s> non trouvée"
+#, fuzzy
+#~ msgid "Exporting %i points/lines..."
+#~ msgstr "Importation des objets de la couche %d..."
+# c-format
+#, fuzzy
+#~ msgid "%d features written"
+#~ msgstr "%d points écrits dans la couche vecteur"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "Cette option requiert au moins 2 colonnes"
+#, fuzzy
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr ""
+#~ "Convertit une couche vecteur binaire GRASS en la combinant avec d'autres "
+#~ "couches vectorielles binaires."
+# c-format
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#, fuzzy
+#~ msgid "vector, metadata"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "crée une zone-tampon autour d'objet d'un type donné (les entités "
+#~ "surfaciques doivent contenir un centroïde)."
+#~ msgid "Buffer distance in map units"
+#~ msgstr "Distance de zone-tampon en unités carte."
+#, fuzzy
+#~ msgid "Use the distance option instead of the buffer option."
+#~ msgstr ""
+#~ "Utilisez des radians à la place de degrés pour définir l'angle de rotation"
+#, fuzzy
+#~ msgid "vector, querying"
+#, fuzzy
+#~ msgid "Queries a vector map layer at given locations."
+#, fuzzy
+#~ msgid "If not given reads from standard input"
+#~ msgstr ""
+#~ "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est "
+#~ "indiqué prendreles paramètres saisis en ligne de commande"
+#, fuzzy
+#~ msgid "vector, transformation"
+#, fuzzy
+#~ msgid "Copying vector objects from vector map <%s>..."
+#, fuzzy
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Couche en entrée contenant les lignes"
+#, fuzzy
+#~ msgid "Name for output vector map where segments will be written"
+#~ msgstr "Couche en sortie où les points seront écrits"
+#, fuzzy
+#~ msgid "Tests for normality for points."
+#~ msgstr "Trop de points de départ."
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Calcule des statistiques univariées pour un attribut. La variance et "
+#~ "l'écart-type sont calculés uniquement pour les points si cela est "
+#~ "spécifié."
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#~ msgstr "Impossible de calculer le centroïde de l'entité surfacique"
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#, fuzzy
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr "Créer des points le long des lignes en entrée."
+# c-format
+#, fuzzy
+#~ msgid "%d points written to output vector map"
+#, fuzzy
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr ""
+#~ msgid ""
+#~ "Number of column used as y coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Nombre de colonnes utilisées comme coordonnées y (la première colonne est "
+#~ "1) en mode points"
+#, fuzzy
+#~ msgid ""
+#~ "Number of column used as z coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Nombre de colonnes utilisées comme coordonnées x (la première colonne est "
+#, fuzzy
+#~ msgid ""
+#~ "Number of column used as category (first column is 1) for points mode"
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ "If 0, unique category is assigned to each row and written to new column "
+#~ "'cat'"
+#~ msgstr ""
+#~ "Nombre de colonne utilisé comme catégorie (la première colonne est 1) en "
+#~ "mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque "
+#~ "ligne et écrit dans la nouvelle colonne 'cat'."
+#, fuzzy
+#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
+#~ msgstr "Crée une nouvelle couche vide et quitte. Rien n'est lu en entrée."
+#, fuzzy
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr ""
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "Seuillage en unités de la carte, une valeur pour chaque outil (par "
+#~ "défaut : 0.0[,0.0,...])"
+#, fuzzy
+#~ msgid "Copying vector lines..."
+#~ msgstr "Vérification des points vecteurs..."
+#, fuzzy
+#~ msgid "%d lines / boundaries removed"
+#~ msgstr "%s fichier(s) à supprimer"
+#, fuzzy
+#~ msgid "Duplicate area centroids: %5d"
+#~ msgstr "Impossible de calculer le centroïde de la surface"
+#, fuzzy
+#~ msgid "Attribute table column with values to interpolate"
+#~ msgstr ""
+#~ "couche>0)"
+#, fuzzy
+#~ msgid "No data points found"
+#~ msgstr "%s : pas de données points trouvées"
+#, fuzzy
+#~ msgid "Lines buffers... "
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#~ msgstr ""
+#~ "Afficher des informations générales à propos d'une couche vecteur "
+#~ "spécifiée par l'utilisateur."
+#, fuzzy
+#~ msgid "Map format: %s"
+#~ msgstr "\t\t%s"
+#, fuzzy
+#~ msgid "Name of creator: %s"
+#~ msgstr "Nom de la couche raster"
+#, fuzzy
+#~ msgid " Comments:"
+#~ msgstr "moyennes"
+#, fuzzy
+#~ msgid "Extrudes flat vector object to 3D with defined height."
+#~ msgstr ""
+#~ "Mettre en relief des objets vecteurs plats en fonction d'une hauteur "
+#~ "définie"
+#~ msgid "Output surface raster map (elevation)"
+#~ msgstr "Fichier raster de relief Z (altitude) à créer"
+#~ msgid "Output cross-validation errors vector point file"
+#~ msgstr ""
+#~ "Fichier en sortie de validation croisée des erreurs sur vecteurs points"
+#~ msgid "Output vector map showing quadtree segmentation"
+#~ msgstr "Fichier vecteur en sortie montrant la segmentation en quadtree"
+#~ msgid "Output vector map showing overlapping windows"
+#~ msgstr "Fichier vecteur en sortie montrant le recouvrement des fenêtres"
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "Nom de la colonne attributaire où prendre les valeurs à utiliser pour "
+#~ "calculer les valeurs approchées(si couche>0)"
+#~ msgid "Cannot write raster maps -- try to increase resolution"
+#~ msgstr ""
+#~ "Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la "
+#~ "résolution"
+#, fuzzy
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr "Affiche les paramètres de connexion courants et quitte"
+#, fuzzy
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "couche vecteur <%s> introuvable"
+#, fuzzy
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#, fuzzy
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "Impossible de déterminer le type de cellule raster"
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#~ msgid "Verbose module output"
+#~ msgstr "Détails de l'exécution"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "Nom du fichier en sortie (ne PAS ajouter l'extension)"
+#, fuzzy
+#~ msgid "Width and height of output image"
+#~ msgstr "Largeur de la couleur de mise en valeur"
+#, fuzzy
+#~ msgid "Surface"
+#~ msgstr "Variance de la somme"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "colonne(s)"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "Pilote OGR : colonne '%s', le type OGR %d n'est pas géré"
+#, fuzzy
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr ""
+#~ "Affiche/configure la connexion à la base de données du jeu de données "
+#~ "courant"
+#, fuzzy
+#~ msgid "Database schema"
+#~ msgstr "Nom de la base de données"
+#, fuzzy
+#~ msgid "database, SQL"
+#~ msgstr "nom de la base de donnée"
+#, fuzzy
+#~ msgid "Name of file with sql statement"
+#~ msgstr "nom du fichier contenant une commande SQL"
+#, fuzzy
+#~ msgid "The password was stored in file"
+#~ msgstr "Le mot de passe a été stocké dans un fichier."
+#, fuzzy
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "convertit toutes les anciennes couches vectorielles GRASS (versions "
+#~ "antérieures à 5.7) du jeu de données courant au format récent"
+#, fuzzy
+#~ msgid "Region sensitive output"
+#~ msgstr "Problème de lecture de r.stats en sortie"
+#, fuzzy
+#~ msgid "raster, elevation"
+#~ msgstr "Tracer le relief"
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr ""
+#~ "Convertit les coordonnées d'une projection à une autre (interface de "
+#~ "cs2cs)."
+#, fuzzy
+#~ msgid "miscellaneous, projection"
+#~ msgstr "Projection source"
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Groupe de fichiers image"
+#, fuzzy
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#~ msgstr "Compression des fichiers PNG (0=aucun, 1=rapide, 9=maximale)"
+#, fuzzy
+#~ msgid "PostScript"
+#~ msgstr "couche PostScript en sortie"
+#, fuzzy
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#~ msgstr "Produit un script shell en sortie"
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "Impossible de copier la table"
+#, fuzzy
+#~ msgid "raster, tiling"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr ""
+#~ "Couche raster en entrée (Proche Infra Rouge: tm4 | qbird_nir | spot2)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#~ msgstr ""
+#~ "Couche raster en entrée (Moyen Infra Rouge: tm5 | qbird_red | spot3)"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "Lister les couches disponibles et quitter"
+#, fuzzy
+#~ msgid "display, diagram"
+#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+#~ msgstr ""
+#~ "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de "
+#~ "couleurs; créer une couche *.mosaic"
+#, fuzzy
+#~ msgid "raster, imagery, mosaicking"
+#~ msgid "2nd map for mosaic."
+#~ msgstr "2nde couche pour la mosaïque."
+#, fuzzy
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Affiche les statistiques géométriques sur les vecteurs."
+#, fuzzy
+#~ msgid ""
+#~ "Value to update the column with (varchar values have to be in single "
+#~ "quotes, e.g. 'grass')"
+#~ msgstr ""
+#~ "nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être "
+#~ "entre simples guillemets, par exemple : 'grass')"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#~ msgstr "Nom de la couche raster d'aspect à afficher"
+#, fuzzy
+#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+#~ msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
+#, fuzzy
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "Afficher les pages de manuel GRASS au format HTML"
+#, fuzzy
+#~ msgid "general, manual, help"
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr "Créer un MASKER pour limiter l'opération sur le raster"
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "couche raster à utiliser comme MASK"
+#, fuzzy
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr ""
+#~ "Valeur de catégorie à utiliser comme MASK (format: 1 2 3 jusqu'à 7 *)"
+#~ msgid "Overwrite existing MASK"
+#~ msgstr "Ecraser le MASK existant"
+#~ msgid "Remove existing MASK (overrides other options)"
+#~ msgstr "Supprimer le MASK existant (supplante les autres options)"
+#, fuzzy
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr ""
+#~ "Nom de l'ancienne base de données, la base de données doit être sous à la "
+#~ "forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
+#, fuzzy
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER "
+#~ "et de MNT en utilisant gdalwarp"
+#, fuzzy
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
+#~ msgstr ""
+#~ "canal L1A ou L1B à traduire (1, 2,3n,3b,4-14). Il n'est possible de "
+#~ "traduire qu'un seul canal"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "Nom de la colonne à afficher"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcule des statistiques univariées à partir d'une couche raster GRASS "
+#~ "basée sur des objets vecteurs"
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#~ msgstr "Nom de la couche vecteur"
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "Nom de la couche raster qui contiendra les résultats"
+#, fuzzy
+#~ msgid "GIS manager for GRASS"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importer les couches vectorielles Mapgen ou Matlab dans GRASS"
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr ""
+#, fuzzy
+#~ msgid "C"
+#~ msgstr "C :"
+#, fuzzy
+#~ msgid "D"
+#~ msgstr "D :"
+#~ msgid "Show help"
+#~ msgstr "Montrer l'aide"
+#~ msgid "Display monitor to start"
+#~ msgstr "Moniteur d'affichage à démarrer"
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "Répertoire dans lequel sauvegarder les données téléchargées"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr "Code de couche. Si fixé à -1, toutes les couches sont affichées."
+#, fuzzy
+#~ msgid "Configuration editor for r.li.'index'"
+#~ msgstr "Nom du fichier de configuration illégal"
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importer du fichier SPOT VGT NDVI sous forme de couche raster."
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr ""
+#~ "importer aussi la couche de qualité (couche du statut SM) et couche "
+#~ "filtre NDVI"
+#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+#~ msgstr "Fichier SPOT VGT NDVI HDF existant (0001_NDV.HDF)"
+#, fuzzy
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr ""
+#~ "Nom de la couche de points vecteurs en entrée pour laquelle éditer la "
+#~ "table attributaire"
+#~ msgid "Layer where to add column"
+#~ msgstr "Couche à laquelle ajouter la colonne"
+#~ msgid "Source monitor"
+#~ msgstr "Moniteur source"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#~ msgstr "Calcul de la matrice de covariance de classe"
+#, fuzzy
+#~ msgid "imagery, rectify"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#~ msgstr ""
+#~ "Impossible d'ouvrir l'image (partie réelle) dans le répertoire "
+#~ "cell_misc.\n"
+#~ "La couche en entrée n'a pas été créée par i.fft"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#~ msgstr ""
+#~ "Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire "
+#~ "cell_misc.\n"
+#, fuzzy
+#~ msgid "imagery, orthorectify"
+#, fuzzy
+#~ msgid ""
+#~ "Name of image to be rectified which will be initially drawn on screen"
+#~ msgstr "Nom de l'image à recaler à afficher à l'écran"
+#, fuzzy
+#~ msgid ""
+#~ "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgstr ""
+#~ "Nom de la couche de données du jeu de données cible à afficher à l'écran."
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#~ msgstr "Groupe [%s] non trouvé"
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#, fuzzy
+#~ msgid "No initial camera exposure station for group [%s]"
+#~ msgstr "Ajouter les fichiers au groupe [%s]"
+#, fuzzy
+#~ msgid "Bad format in initial camera exposure station for group [%s]"
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#, fuzzy
+#~ msgid "Computing equations ..."
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "Impossible de trouver les informations sur la couche vectorielle"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#~ msgstr "Sortie. Ne pas changer les paramètres actuels"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+#~ msgid "Interactively select or modify the target elevation model."
+#~ msgstr "Sélectionner de façon interactive l'itinéraire"
+#, fuzzy
+#~ msgid "Target information for group [%s] missing\n"
+#~ msgstr ""
+#~ "Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
+#, fuzzy
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#, fuzzy
+#~ msgid "Range less than or equal to zero not allowed"
+#~ msgstr "Intervalle inférieur ou égal à zéro non valide"
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
+#~ msgstr ""
+#~ "Ecriture des versions visualisables des données transformées dans les "
+#~ "fichiers..."
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#~ msgstr "Impossible d'ouvrir le fichier dans le répertoire cell_misc"
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#~ msgstr "Nom de la couche vecteur 2D source"
+#, fuzzy
+#~ msgid "Eigen values:"
+#~ msgstr "Valeur de la chaîne de bit"
+#, fuzzy
+#~ msgid "ID values"
+#, fuzzy
+#~ msgid "To layer"
+#~ msgstr "Requêter la couche"
+#, fuzzy
+#~ msgid "vector, attribute table"
+#~ msgstr "Affiche les attributs des vecteurs"
+#, fuzzy
+#~ msgid "Type of elements"
+#~ msgstr "Nom d'un élément"
+#~ msgid "%s: %s - Unable to find the real-image map."
+#~ msgstr "%s: %s - impossible de trouver l'image (partie réelle)"
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#~ msgstr "%s: %s - impossible de trouver l'image (partie imaginaire)"
+#~ msgid "Writing data to file..."
+#~ msgstr "Écriture des données dans le fichier..."
+#, fuzzy
+#~ msgid "Hue map name"
+#~ msgstr "%s - nom illégal"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#~ msgid "Output hue raster map"
+#~ msgstr "couche raster en sortie"
+#~ msgid "1 class."
+#~ msgstr "1 classe."
+#, fuzzy
+#~ msgid "display, legend"
+#~ msgstr "Faire pivoter le cartouche de légende"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#~ msgid "Skipping [%s]..."
+#~ msgstr "Saut de [%s]..."
+#~ msgid "Multiplier"
+#~ msgstr "Multiplicateur"
+#~ msgid "Name of the resultant map"
+#~ msgstr "Nom de la couche en sortie"
+# c-format
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#~ msgstr "Impossible d'effacer le fichier %s\n"
+#~ msgid "Done"
+#~ msgstr "Terminé"
+# c-format
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr "Impossible d'ouvrir la source de données OGR %s"
+#, fuzzy
+#~ msgid "Column(s)"
+#, fuzzy
+#~ msgid "Unable to read category file for raster map <%s>"
+#~ msgstr "Editer le fichier de catégorie de [%s]?"
+# c-format
+#~ msgid "Reading %s ... "
+#~ msgstr "Lecture de %s..."
+# c-format
+#~ msgid "%s in %s: %s"
+#~ msgstr "%s ligne %s: %s"
+# c-format
+#~ msgid "cannot read head of %s"
+#~ msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
+#, fuzzy
+#~ msgid "Reading raster map <%s> ..."
+# c-format
+#~ msgid "No record for cat = %d"
+#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
+#, fuzzy
+#~ msgid "Vector map <%s> not found in current mapset"
+#~ msgid "Database connection not defined for layer <%d>"
+#~ msgstr ""
+#~ "La connexion à la base de données n'a pas été définie pour la couche <%d>"
+#, fuzzy
+#~ msgid "Close boundaries"
+#~ msgstr "impossible de mettre à jour les limites"
+# c-format
+#, fuzzy
+#~ msgid "Database record for cat %d not found"
+#~ msgstr "Aucun enregistrement pour la catégorie (cat = %d)"
+# c-format
+#, fuzzy
+#~ msgid "Cannot open file for <%s>"
+#~ msgstr "Impossible d'ouvrir le fichier [%s]"
+#~ msgid "Name of the random surface to be produced"
+#~ msgstr "Nom du relief aléatoire à produire"
+# c-format
+#~ msgid "Cannot open file [%s]"
+#, fuzzy
+#~ msgid "Read coordinates from standard input"
+#~ msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
+#~ msgid "Error reading map %s"
+#~ msgstr "Erreur de lecture de la couche %s"
+#, fuzzy
+#~ msgid "Closing raster map"
+#~ msgstr "couche raster de couverture"
+#~ msgid "Name of the new raster map"
+#, fuzzy
+#~ msgid "Could not close the 3d raster map"
+#~ msgstr "Impossible de fermer la nouvelle couche g3d"
+# c-format
+#~ msgid "Could not find input vector map %s"
+#~ msgstr "Couche d'entrée vecteur introuvable %s"
+#~ msgid "Can't create output map"
+#~ msgstr "Impossible de créer la couche en sortie"
+#, fuzzy
+#~ msgid "name for new vector map"
+#~ msgstr "Nom du nouveau fichier vecteur binaire"
+#~ msgid "Topographic index ln(a/tanB) map"
+#~ msgstr "couche d'indice topographique ln(a/tan(beta))"
+#, fuzzy
+#~ msgid "No input coordinates provided"
+#~ msgstr "Coordonnées de la carte"
+#, fuzzy
+#~ msgid "Name of the output walkers site file"
+#~ msgstr "Nom de la nouvelle couche raster"
+#, fuzzy
+#~ msgid "Path to the input file"
+#~ msgid "Database name:"
+#~ msgstr "Nom de la base de donnée :"
+#~ msgid "column type not supported"
+#~ msgid ""
+#~ "Number of column used as z coordinate (first column is 1) for points "
+#~ "mode. If 0, z coordinate is not used."
+#~ msgstr ""
+#~ "1) en mode pointsSi la valeur est 0, les coordonnées z ne sont pas "
+#~ "utilisées."
+#~ msgid "%s - too many patch files. only %d allowed"
+#~ msgstr "%s - trop de fichiers patch. Seul(s) %d autorisé(s)"
+#, fuzzy
+#~ msgid "category [%d]"
+#~ msgstr ""
+#~ "couche: %d\n"
+#~ "catégorie: %d\n"
+#, fuzzy
+#~ msgid "Interpolation()"
+#~ msgstr "Méthode d'interpolation à utiliser"
+# c-format
+#, fuzzy
+#~ msgid "Writing "
+#, fuzzy
+#~ msgid "Calculation time"
+#~ msgstr "Calcul des moyennes de classes..."
+#~ msgid "History line too long: truncating to %d characters"
+#~ msgstr "Ligne d'historique trop longue : tronquée à %d caractères"
+#~ msgid "Name of output 3d raster map"
+#~ msgstr "Nom du fichier grille G3D en sortie"
+#, fuzzy
+#~ msgid "input layer name"
+#~ msgstr "Nom de la couche source"
+#~ msgid "Name of the column with tree height"
+#~ msgstr "Nom de la colonne contenant la hauteur de l'arbre"
+#~ msgid "Name of the column with tree species"
+#~ msgstr "Nom de la colonne contenant les essences d'arbres"
+#, fuzzy
+#~ msgid "Column name (will be updated by qvector values)"
+#~ msgstr "Nom de la colonne (qui sera mise à jour par les valeurs rasters)"
+#, fuzzy
+#~ msgid "Name of input map"
+#~ msgstr "Jeu de données (mapset) de la couche source"
+#, fuzzy
+#~ msgid "Name of the resulting map"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "[%s] n'est pas un nom légal"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_hi.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5613,9 +5613,9 @@
msgstr "à¤à¤¾"
#: ../raster/r.transect/main.c:84
-#, fuzzy, c-format
+#, c-format
msgid "End coordinate: %.15g, %.15g"
-msgstr "à¤à¥ लिà¤"
+msgstr ""
#: ../raster/r.transect/main.c:105
msgid ""
@@ -9439,7 +9439,7 @@
#: ../raster/r.out.gdal/main.c:510 ../raster/r.out.gdal/main.c:514
#, fuzzy
msgid "Raster export aborted."
-msgstr "सदिश"
+msgstr "नहà¥à¤"
#: ../raster/r.out.gdal/main.c:491
msgid "Checking GDAL data type and nodata value"
@@ -13336,7 +13336,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "à¤à¥ लिà¤"
+msgstr "à¤à¤¾"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -17039,9 +17039,9 @@
msgstr ""
#: ../display/d.vect/plot1.c:616
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr ""
+msgstr "नहà¥à¤."
#: ../display/d.vect/plot1.c:621
#, fuzzy, c-format
@@ -18692,7 +18692,7 @@
#: ../vector/v.in.db/main.c:176
#, fuzzy
msgid "Writing features..."
-msgstr "à¤à¤¾à¤ªà¥à¤"
+msgstr "n"
#: ../vector/v.in.db/main.c:183
msgid "Key column must be integer"
@@ -19239,7 +19239,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "नहà¥à¤"
+msgstr "à¤à¥ लिà¤"
#: ../vector/v.random/main.c:111
#, fuzzy
@@ -21291,9 +21291,8 @@
msgstr "तà¥à¤°à¥à¤à¤¿"
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "à¤à¥ लिà¤."
+msgstr ""
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -25092,9 +25091,8 @@
msgstr "फ़à¥à¤¨à¥à¤"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "n"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -25544,7 +25542,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "फà¥à¤²à¥à¤¡"
+msgstr "à¤à¤¾à¤ªà¥à¤"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -27548,9 +27546,8 @@
msgstr "à¤à¤¾"
#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#, fuzzy
msgid "Write output to PNG image"
-msgstr "n"
+msgstr ""
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
#, fuzzy
@@ -27618,8 +27615,9 @@
msgstr ""
#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
+#, fuzzy
msgid "Input type point, line or area"
-msgstr ""
+msgstr "à¤à¤¾"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:7
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:6
@@ -27633,10 +27631,11 @@
msgstr "à¤à¤¾"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
+#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
-msgstr ""
+msgstr "a बिनà¥à¤¦à¥."
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -27697,8 +27696,9 @@
msgstr "à¤à¥ लिà¤"
#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
+msgstr "à¤à¤¤à¥à¤¤à¤° पà¥à¤°à¥à¤µ"
#: ../locale/scriptstrings/m.proj_to_translate.c:8
#, fuzzy
@@ -27842,12 +27842,14 @@
msgstr "à¤à¤¾"
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+#, fuzzy
msgid "Produces shell script output"
-msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
+#, fuzzy
msgid "Produces web map server query string output"
-msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
msgid ""
@@ -28321,8 +28323,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr ""
+msgstr "à¤à¥ लिठn"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
#, fuzzy
@@ -28335,12 +28338,14 @@
msgstr "à¤à¤¾"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr "डाà¤à¤¾à¤¬à¥à¤¸ नाम"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
msgid "New schema"
-msgstr ""
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
@@ -28646,8 +28651,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
+#, fuzzy
msgid "Must be expressed as R:G:B triplet"
-msgstr ""
+msgstr "à¤à¥ लिठà¤à¤¼à¥à¤¡"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
#, fuzzy
@@ -28715,10 +28721,11 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+#, fuzzy
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
-msgstr ""
+msgstr "à¤à¤¾"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -28836,8 +28843,9 @@
msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
+#, fuzzy
msgid "Reset to standard color range"
-msgstr ""
+msgstr "रà¤à¥à¤"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
@@ -28854,8 +28862,9 @@
msgstr "à¤à¤¾"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+#, fuzzy
msgid "Percent to brighten"
-msgstr ""
+msgstr "पà¥à¤°à¥à¤£."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
#, fuzzy
@@ -28947,8 +28956,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
+#, fuzzy
msgid "Import"
-msgstr ""
+msgstr "n"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Don't reproject the data, just patch it"
@@ -28967,16 +28977,19 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr ""
+msgstr "सà¤à¥"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#, fuzzy
msgid "Layers to request from map server"
-msgstr ""
+msgstr "पदà¥à¤§à¤¤à¤¿"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#, fuzzy
msgid "Styles to request from map server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
#, fuzzy
@@ -28984,20 +28997,23 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#, fuzzy
msgid "Image format requested from the server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
msgid "Addition query options for server"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+#, fuzzy
msgid "Maximum columns to request at a time"
-msgstr ""
+msgstr "बिनà¥à¤¦à¥"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#, fuzzy
msgid "Maximum rows to request at a time"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Additional options for r.tileset"
@@ -29085,8 +29101,9 @@
msgstr "à¤à¤¾ à¤à¥ लिà¤"
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#, fuzzy
msgid "Adds missing centroids to closed boundaries."
-msgstr ""
+msgstr "नाम बदला à¤à¤¯à¤¾"
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
#, fuzzy
@@ -29177,24 +29194,29 @@
msgstr "à¤à¤¾ à¤à¥ लिठसà¤à¤ªà¤¾à¤¦à¤¨ (_E)"
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to drop column"
-msgstr ""
+msgstr "नहà¥à¤"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+#, fuzzy
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
+msgstr "à¤à¤à¤à¤¾à¤ à¤à¥ लिà¤"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#, fuzzy
msgid "use transformation rules for LANDSAT-4"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#, fuzzy
msgid "use transformation rules for LANDSAT-5"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+#, fuzzy
msgid "use transformation rules for LANDSAT-7"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
#, fuzzy
@@ -29360,8 +29382,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "à¤à¤¾ à¤à¥ लिà¤"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#, fuzzy
@@ -29750,9 +29773,9 @@
msgstr "n"
#: ../imagery/i.pca/main.c:395
-#, fuzzy, c-format
+#, c-format
msgid "Rescaling <%s> to range %d,%d..."
-msgstr "n"
+msgstr ""
#: ../imagery/i.pca/support.c:44
msgid "Eigen values, (vectors), and [percent importance]:"
@@ -31824,6 +31847,290 @@
msgstr "बिनà¥à¤¦à¥ à¤à¥à¤¦ हà¥."
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "à¤à¤¾à¤²à¥."
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "सदिश"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "वसà¥à¤¤à¥."
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "à¤à¥ लिà¤."
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "f a h"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "सà¤à¥ à¤à¥ लिठa."
+#, fuzzy
+msgid "report"
+msgstr "à¤à¤¾"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "तà¥à¤°à¥à¤à¤¿."
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "à¤à¤¾"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "तà¥à¤°à¥à¤à¤¿"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "सà¥à¤ पà¥à¤·à¥à¤ !"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "i n"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "i n"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+msgstr "n"
+#, fuzzy
+msgid "Error reading row <%d>"
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "à¤à¤¾"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "n"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "n"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "डाà¤à¤¾à¤à¤¾à¤à¤ª."
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "à¤à¤¾ a"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+msgstr "à¤à¥ लिà¤"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "फ़ाà¤à¤²"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "à¤à¤¾"
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "à¤à¤¾"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "n"
+#, fuzzy
+msgid "Name of QC"
+msgstr "à¤à¤¾."
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "à¤à¤¾ फà¥à¤°à¥à¤®à¥à¤¸"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+msgstr "à¤à¤¾"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "à¤à¥à¤°à¥à¤¸"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "à¤à¤µà¤¿."
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr "à¤à¤µà¤¿ i"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "à¤à¤µà¤¿."
+#, fuzzy
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "नहà¥à¤."
+#, fuzzy
+msgid "Range less than or equal to zero not allowed."
+msgstr "सà¥à¤®à¤¾ à¤à¤® à¤à¥ बराबर नहà¥à¤."
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "à¤à¤¾."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+msgstr "नहà¥à¤ n"
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+msgstr "बनाया à¤à¤¾ रहा हà¥."
+#, fuzzy
+msgid "Can't read signature file <%s>"
+msgstr "i n"
+#, fuzzy
+msgid "%d lines converted to boundaries"
+#, fuzzy
+msgid "From layer"
+msgstr "सà¥à¤"
+#, fuzzy
+msgid "Select type"
+msgstr "विशà¥à¤·à¤¤à¤¾"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "i n"
+#, fuzzy
+msgid "Erasing monitors ..."
+msgstr "n"
+#, fuzzy
+msgid "Found file <%s@%s> in group."
+msgstr "समà¥à¤¹."
+#, fuzzy
+msgid "Raster map not found."
+msgstr "नहà¥à¤"
+#, fuzzy
+msgid "Category file for [%s] not available"
+msgstr "à¤à¥ लिठनहà¥à¤"
+#, fuzzy
+msgid "color file for [%s] not available"
+#, fuzzy
+msgid "Verbose mode on."
+msgstr "बà¥à¤¬à¥à¤²à¤¾ à¤à¤¾à¤²à¥."
+#, fuzzy
#~ msgid "Not enough room in history file"
#~ msgstr "à¤à¥ लिà¤"
@@ -31840,10 +32147,6 @@
#~ msgstr "à¤à¤¾"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "à¤à¤¾à¤²à¥."
-#, fuzzy
#~ msgid "List of values to be displayed (FP maps)"
#~ msgstr "à¤à¤¾"
@@ -31919,14 +32222,6 @@
#~ msgstr "नहà¥à¤"
#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "सदिश"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "à¤à¤¤à¥à¤¤à¤° पà¥à¤°à¥à¤µ"
-#, fuzzy
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "a."
@@ -32003,10 +32298,6 @@
#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "वसà¥à¤¤à¥."
-#, fuzzy
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "à¤à¤¾"
@@ -32051,18 +32342,6 @@
#~ msgstr "i n"
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "à¤à¥ लिà¤."
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "f a h"
-#, fuzzy
#~ msgid "Import GDAL supported raster file into a binary raster map layer."
#~ msgstr "à¤à¤¯à¤¾à¤¤ a."
@@ -32073,10 +32352,6 @@
#~ msgstr "a a à¤à¤µà¤¿ पर à¤à¤¾."
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "à¤à¤¾à¤ªà¥à¤"
-#, fuzzy
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -32087,10 +32362,6 @@
#~ msgstr "à¤à¤¾"
#, fuzzy
-#~ msgid "Estimate spline step value"
-#, fuzzy
#~ msgid "If set to 0, z coordinates are used. (3D vector only)"
#~ msgstr "फà¥à¤²à¥à¤¡ सà¥à¤ à¤à¤¼à¥à¤¡"
@@ -32099,10 +32370,6 @@
#~ msgstr "à¤à¤¾ à¤à¥ लिà¤"
#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "सà¤à¥ à¤à¥ लिठa."
-#, fuzzy
#~ msgid "Unable to close output map"
#~ msgstr "i n"
@@ -32155,18 +32422,10 @@
#~ msgstr "à¤à¤¾ a"
#, fuzzy
-#~ msgid "report"
-#~ msgstr "à¤à¤¾"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr "f a h"
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "बनाया à¤à¤¾ रहा हà¥."
@@ -32215,10 +32474,6 @@
#~ msgstr "डाà¤à¤¾à¤à¤¾à¤à¤ª."
#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "तà¥à¤°à¥à¤à¤¿."
-#, fuzzy
#~ msgid "Reading row %d"
#~ msgstr "n"
@@ -32299,10 +32554,6 @@
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#, fuzzy
#~ msgid "Error in pipe creation"
#~ msgstr "तà¥à¤°à¥à¤à¤¿"
@@ -32343,14 +32594,6 @@
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "à¤à¥ लिà¤"
-#, fuzzy
#~ msgid "Unable to get header for %s"
@@ -32359,18 +32602,6 @@
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "à¤à¤¾"
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
#~ msgstr "सà¤à¤ªà¤¾à¤¦à¤¨ à¤à¥ लिठ"
@@ -32415,22 +32646,6 @@
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "तà¥à¤°à¥à¤à¤¿"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "सà¥à¤ पà¥à¤·à¥à¤ !"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
@@ -32463,10 +32678,6 @@
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "i n"
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr "à¤à¤¾"
@@ -32479,10 +32690,6 @@
#~ msgstr "n"
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "i n"
-#, fuzzy
#~ msgid "Invalid region: %s"
#~ msgstr "à¤
वà¥à¤§"
@@ -32539,14 +32746,6 @@
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "n"
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
@@ -32567,14 +32766,6 @@
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "à¤à¤¾"
-#, fuzzy
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "à¤à¤¾ à¤à¤£à¥à¤¡ à¤à¤£à¥à¤¡"
@@ -32685,14 +32876,6 @@
#~ msgstr "i n"
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
@@ -32709,10 +32892,6 @@
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "n"
-#, fuzzy
#~ msgid "Unable to open table <%s_edge_Interpolation>"
#~ msgstr "à¤à¤¾"
@@ -32847,22 +33026,10 @@
#~ msgstr "सà¥à¤."
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "n"
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#, fuzzy
#~ msgid "Did not find input cell map MASK."
#~ msgstr "नहà¥à¤."
@@ -32875,14 +33042,6 @@
#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "डाà¤à¤¾à¤à¤¾à¤à¤ª."
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "à¤à¤¾ a"
-#, fuzzy
#~ msgid "Error while reading input raster map."
@@ -32895,22 +33054,6 @@
#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "फ़ाà¤à¤²"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "à¤à¤¾"
-#, fuzzy
#~ msgid "Could not open <%s>"
#~ msgstr "नहà¥à¤"
@@ -32919,18 +33062,6 @@
#~ msgstr "नहà¥à¤"
#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "à¤à¤¾"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
#~ msgid "Error reading row of data"
@@ -33089,22 +33220,6 @@
#~ msgstr "समà¥à¤¹"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "n"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "à¤à¤¾."
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "à¤à¤¾ फà¥à¤°à¥à¤®à¥à¤¸"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#~ msgstr "à¤à¤¾"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "फ़ाà¤à¤² à¤à¤¾"
@@ -33396,10 +33511,6 @@
#~ msgstr "à¤à¤¾"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "à¤à¥à¤°à¥à¤¸"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
#~ msgstr "à¤à¤¾"
@@ -33456,10 +33567,6 @@
#~ msgstr "à¤à¥ लिठà¤à¤¾"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
@@ -33585,26 +33692,6 @@
#~ msgstr "à¤à¤¨à¤¤à¥à¤µ"
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "à¤à¤µà¤¿."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr "à¤à¤µà¤¿ i"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#, fuzzy
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "पावर."
@@ -33693,10 +33780,6 @@
#~ msgstr "à¤à¤¾ समà¥à¤¹"
#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "नहà¥à¤."
-#, fuzzy
#~ msgid "Subgroup [%s] not found."
#~ msgstr "नहà¥à¤."
@@ -33750,10 +33833,6 @@
#~ msgstr "सà¥à¤®à¤¾ à¤à¤¾"
#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "सà¥à¤®à¤¾ à¤à¤® à¤à¥ बराबर नहà¥à¤."
-#, fuzzy
#~ msgid "Initializing data...\n"
#~ msgstr "n"
@@ -33766,14 +33845,6 @@
#~ msgstr "पà¥à¤°à¥à¤£."
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "à¤à¤¾."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "नहà¥à¤ n"
-#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
@@ -33798,14 +33869,6 @@
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "बनाया à¤à¤¾ रहा हà¥."
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "i n"
-#, fuzzy
#~ msgid "Group of imagery files to be clustered"
#~ msgstr "à¤à¤¾"
@@ -34068,10 +34131,6 @@
#~ msgstr "n"
#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "नाम बदला à¤à¤¯à¤¾"
-#, fuzzy
#~ msgid "%d boundaries converted to lines"
#~ msgstr "n"
@@ -34116,18 +34175,10 @@
#~ msgstr "à¤
à¤à¥à¤à¤¾à¤¤ à¤à¤¼à¤¿à¤¸à¥à¤®"
#, fuzzy
-#~ msgid "From layer"
-#~ msgstr "सà¥à¤"
-#, fuzzy
#~ msgid "The column must be type integer or string"
#~ msgstr "à¤à¤¼à¥à¤¡"
#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "विशà¥à¤·à¤¤à¤¾"
-#, fuzzy
#~ msgid "Cannot select records from database"
@@ -34452,10 +34503,6 @@
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "i n"
-#, fuzzy
#~ msgid "Output raster map with lake"
#~ msgstr "शà¥à¤°à¥à¤·à¤"
@@ -35342,10 +35389,6 @@
#~ msgstr "हॠनहà¥à¤ à¤à¥ लिà¤"
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "n"
-#, fuzzy
#~ msgid "Could not open input file <%s>."
#~ msgstr "नहà¥à¤"
@@ -35376,10 +35419,6 @@
#~ msgstr "समà¥à¤¹"
#, fuzzy
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "समà¥à¤¹."
-#, fuzzy
#~ msgid "Unable to open file: <%s>"
#~ msgstr "à¤à¤¾"
@@ -35394,10 +35433,6 @@
#~ msgstr "नहà¥à¤"
#, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "नहà¥à¤"
-#, fuzzy
#~ msgid "%s: can't read range for [%s]"
@@ -35473,10 +35508,6 @@
#~ msgstr "बनाया à¤à¤¾ रहा हॠà¤à¥ लिà¤."
#, fuzzy
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "à¤à¥ लिठनहà¥à¤"
-#, fuzzy
#~ msgid "%s: <%s> raster map not found"
#~ msgstr "नहà¥à¤"
@@ -36115,10 +36146,6 @@
#~ msgstr "नहà¥à¤"
#, fuzzy
-#~ msgid "color file for [%s] not available"
-#, fuzzy
#~ msgid "Raster file [%s] not available"
#~ msgstr "नहà¥à¤"
@@ -38034,10 +38061,6 @@
#~ msgstr "à¤à¤¯à¤¾à¤¤ à¤à¤µà¤¿."
#, fuzzy
-#~ msgid "Verbose mode on."
-#~ msgstr "बà¥à¤¬à¥à¤²à¤¾ à¤à¤¾à¤²à¥."
-#, fuzzy
#~ msgid "Enable extend memory option: Operation is slow"
#~ msgstr "विसà¥à¤¤à¤¾à¤° दà¥à¤ हà¥"
@@ -38683,3 +38706,1518 @@
#, fuzzy
#~ msgid "Short user prompt message"
+#, fuzzy
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "a पाठ"
+#, fuzzy
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr "a पाठa "
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "raster3d, statistics"
+#~ msgstr "वसà¥à¤¤à¥."
+#, fuzzy
+#~ msgid ""
+#~ "Cannot create mask file: G3D_MASK already exists!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+#~ msgstr ""
+#~ "\n"
+#~ " à¤à¥."
+#, fuzzy
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "निरà¥à¤¯à¤¾à¤¤ à¤à¤¾."
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Unable to read category labels of raster map <%s>"
+#~ msgstr "सà¤à¤ªà¤¾à¤¦à¤¨ à¤à¥ लिठ"
+#, fuzzy
+#~ msgid "raster, import"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr "a a à¤à¤à¤à¤¾à¤ फà¥à¤²à¥à¤¡ à¤à¥ लिà¤."
+#, fuzzy
+#~ msgid "raster, map algebra"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "a पाठ."
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "à¤à¥ लिà¤."
+#, fuzzy
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "à¤à¤¯à¤¾à¤¤ फà¥à¤²à¥à¤à¤¿à¤à¤ बिà¤à¤¦à¥ पà¥à¤°à¥à¤£à¤¾à¤à¤"
+#, fuzzy
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr "à¤à¤¯à¤¾à¤¤ दà¥à¤à¥à¤¨à¤¾ पà¥à¤°à¥à¤£à¤¾à¤à¤"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#~ msgstr "सà¤à¤à¥à¤¯à¤¾ à¤à¤¾ बाà¤à¤à¥à¤¸"
+#, fuzzy
+#~ msgid "Update the statistics (histogram, range) for [%s]? "
+#~ msgstr "à¤à¥ लिठ"
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "i n"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#~ msgstr "i n"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "à¤à¤¾ a"
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr "फ़ाà¤à¤²à¤¨à¤¾à¤® "
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr "R à¤à¥ a à¤à¤µà¤¿ पर à¤à¤¾."
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "à¤à¥ लिà¤"
+#, fuzzy
+#~ msgid "raster, series"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#, fuzzy
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "सà¤à¤à¥à¤¯à¤¾ à¤à¤¾"
+#, fuzzy
+#~ msgid "Output map: unique label for each watershed basin"
+#, fuzzy
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "हॠa"
+#, fuzzy
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr "ढाल à¤à¥ लिà¤"
+#, fuzzy
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#, fuzzy
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "à¤à¤à¤¾à¤° à¤à¤¾"
+#, fuzzy
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr "à¤à¤¾ à¤à¥ लिà¤"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "तà¥à¤°à¥à¤à¤¿ à¤à¥ लिà¤."
+#, fuzzy
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "फ़ाà¤à¤²."
+#, fuzzy
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr "a a a"
+#, fuzzy
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "raster, resample"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "[%s]: Map is the wrong resolution"
+#~ msgstr "हà¥"
+#, fuzzy
+#~ msgid "Cannot get row %d (error = %d)"
+#~ msgstr "तà¥à¤°à¥à¤à¤¿"
+#, fuzzy
+#~ msgid "Cannot set region to back to the initial region !!!"
+#~ msgstr "सà¥à¤ पà¥à¤·à¥à¤ !"
+#, fuzzy
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "सतह पà¥à¤°à¥à¤à¥à¤°à¤¾à¤®."
+#, fuzzy
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "a."
+#, fuzzy
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "नà¤à¤¼à¤²"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "à¤à¤¤à¥à¤¤à¤° पà¥à¤°à¥à¤µ"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "फ़ाà¤à¤²"
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#, fuzzy
+#~ msgid "raster, null data"
+#~ msgstr "à¤à¤¾à¤²à¥"
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "a à¤à¤."
+#, fuzzy
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "i"
+#, fuzzy
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "i à¤à¤¯à¤¤à¤¾à¤à¤¾à¤°"
+#, fuzzy
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "i à¤à¤¾"
+#, fuzzy
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "i"
+#, fuzzy
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "i"
+#, fuzzy
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "i"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr "हà¥."
+#, fuzzy
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "à¤à¤¾ à¤à¥à¤£"
+#, fuzzy
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "à¤à¤¾ à¤à¤¤à¥à¤¤à¤° à¤à¥à¤£"
+#, fuzzy
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr "पà¥à¤°à¥à¤µ à¤à¥à¤à¤®à¤à¥"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr "a à¤à¤¿à¤¸à¤à¤¾ à¤à¤¾."
+#, fuzzy
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "a a."
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "डाà¤à¤¾à¤à¤¾à¤à¤ª."
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#~ msgstr "हॠn"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#~ msgstr "हॠn"
+#, fuzzy
+#~ msgid "'%s' is not a valid rule"
+#~ msgstr "सà¥à¤®à¤¾ à¤à¤® à¤à¥ बराबर नहà¥à¤."
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr "à¤à¤¾ ढाल a."
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#~ msgstr "à¤à¤¨à¤¤à¥à¤µ"
+#, fuzzy
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "पाठa."
+#, fuzzy
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr "a बà¥à¤à¤¾."
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "हॠनहà¥à¤"
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr "a."
+#, fuzzy
+#~ msgid "File containing weights"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "नहà¥à¤ n"
+#, fuzzy
+#~ msgid "general, settings"
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#, fuzzy
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "à¤à¥ लिठशà¥à¤¨à¥à¤¯ (Null)"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid ""
+#~ "Identifies the geographic coordinates associated with point locations in "
+#~ "the active frame on the graphics monitor."
+#~ msgstr "बिनà¥à¤¦à¥ à¤à¤¾à¤²à¥."
+#, fuzzy
+#~ msgid "Command mode (Compatibility with d.text)"
+#~ msgstr "पाठ"
+#, fuzzy
+#~ msgid "Either text or -c should be given"
+#~ msgstr "पाठ"
+#, fuzzy
+#~ msgid "Unable to set size"
+#~ msgstr "सà¥à¤ à¤à¤à¤¾à¤° "
+#, fuzzy
+#~ msgid "Text conversion error"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#~ msgstr "तà¥à¤°à¥à¤à¤¿."
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "à¤à¥ लिठनहà¥à¤"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr "à¤à¤¾à¤²à¥."
+#, fuzzy
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#, fuzzy
+#~ msgid "Vector map attribute column to use for comparison"
+#, fuzzy
+#~ msgid "Vector map to store differences"
+#~ msgstr "सदिश"
+#, fuzzy
+#~ msgid "%d new points written to output"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "a a."
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Query layer number (read from)"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "vector, interpolation"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#, fuzzy
+#~ msgid "Vector based generalization."
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Creates topology for GRASS vector map."
+#, fuzzy
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Total area: %e (%d areas)"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Area without category: %e (%d areas)"
+#, fuzzy
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr "a a."
+#, fuzzy
+#~ msgid "vector, extract"
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#~ msgstr "सदिश"
+#, fuzzy
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr "a."
+#, fuzzy
+#~ msgid "Layer number (from)"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Layer number (to)"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr "a."
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "a."
+#, fuzzy
+#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr "a."
+#, fuzzy
+#~ msgid "Parameter '%s' ignored in standard mode"
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#~ msgid "vector, geometry"
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr "a à¤à¤¾ a."
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "à¤à¤ à¤à¤¾."
+#, fuzzy
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr "निरà¥à¤¯à¤¾à¤¤ सà¤à¥"
+#, fuzzy
+#~ msgid "Key column '%s' not found"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Exporting %i points/lines..."
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "पर"
+#, fuzzy
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr "a à¤
नà¥à¤¯."
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "vector, metadata"
+#, fuzzy
+#~ msgid "vector, buffer"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr "a à¤à¤¾ रà¤à¥ हà¥à¤."
+#, fuzzy
+#~ msgstr "à¤à¤¾ à¤à¥à¤£ à¤à¥ लिà¤"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¥à¤µà¥à¤°à¥ à¤à¤¾ a पर."
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "i n"
+#, fuzzy
+#~ msgstr "à¤à¥à¤®à¤¾à¤à¤"
+#, fuzzy
+#~ msgstr "à¤à¥ लिठn"
+#, fuzzy
+#~ msgstr "a a."
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "a à¤
नà¥à¤¯."
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¤¾ हॠà¤à¥ लिà¤"
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgid ""
+#~ "'cat'"
+#~ msgstr "à¤à¤¾ हॠà¤à¥ लिठहà¥."
+#, fuzzy
+#~ msgstr "a हà¥."
+#, fuzzy
+#~ msgstr "a à¤
नà¥à¤¯."
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¤ à¤à¥ लिà¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "नाम बदला à¤à¤¯à¤¾"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Attribute column to use for buffer distances"
+#, fuzzy
+#~ msgid "Error reading ASCII file: '%s'"
+#, fuzzy
+#~ msgstr "a."
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#, fuzzy
+#~ msgstr "वसà¥à¤¤à¥ à¤à¤à¤à¤¾à¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾ बिनà¥à¤¦à¥"
+#, fuzzy
+#~ msgid ""
+#~ "layer>0)"
+#, fuzzy
+#~ msgstr "à¤à¤¾à¤ªà¥à¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "a a."
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "बà¥à¤¬à¥à¤²à¤¾ à¤à¤¾à¤²à¥."
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¥ लिठa"
+#, fuzzy
+#~ msgstr "डाà¤à¤¾à¤¬à¥à¤¸ नाम"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Enter command to execute in 1st frame"
+#, fuzzy
+#~ msgid "How to split display"
+#, fuzzy
+#~ msgid "Select multiple points"
+#~ msgstr "विशà¥à¤·à¤¤à¤¾"
+#, fuzzy
+#~ msgid ""
+#~ "format"
+#~ msgstr "a a."
+#, fuzzy
+#~ msgstr "à¤à¥à¤°à¥à¤¸"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "समà¥à¤¹"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#~ msgid "Paper size for PostScript output"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#~ msgstr "सà¥à¤°à¥à¤¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾à¤®à¤¾."
+#, fuzzy
+#~ msgid "raster, statistics, aggregation"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "display, export, GPS"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, mask"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "display, slideshow"
+#, fuzzy
+#~ msgid "Map number show across the monitor"
+#~ msgstr "सà¤à¤à¥à¤¯à¤¾ à¤à¤¾ à¤à¤£à¥à¤¡"
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#~ msgstr "सदिश"
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¤¾ a."
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾ रà¤à¥ हà¥à¤"
+#, fuzzy
+#~ msgid "Display manager for GRASS"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Do not overwrite existing map"
+#, fuzzy
+#~ msgstr "à¤à¤¾ पà¥à¤°à¤¾à¤°à¤à¤"
+#, fuzzy
+#~ msgid "Import track"
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "नहà¥à¤ सà¤à¥ n n फ़ाà¤à¤²"
+#, fuzzy
+#~ msgid "Name of PNG file"
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "a a"
+#, fuzzy
+#~ msgstr "à¤à¤¾ à¤à¥ लिठसà¤à¤ªà¤¾à¤¦à¤¨ (_E)"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "stay with source monitor"
+#, fuzzy
+#~ msgid "Target monitor"
+#~ msgstr "n"
+#, fuzzy
+#, fuzzy
+#~ msgstr "माà¤à¥à¤°à¤¿à¤à¥à¤¸."
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¤µà¤¿ i"
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgid "Writing data..."
+#~ msgstr "n"
+#, fuzzy
+#, fuzzy
+#~ msgstr "नहà¥à¤."
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#, fuzzy
+#~ msgid "No files in this group!"
+#~ msgstr "समà¥à¤¹."
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "सà¥à¤®à¤¾ à¤à¥ लिठनहà¥à¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "Color for graduated lines or point/area outlines (grass named color or R:"
+#~ "G:B triplet). Set color scheme to single color."
+#~ msgstr "a R à¤à¥"
+#, fuzzy
+#~ msgid "Icon to remove"
+#, fuzzy
+#~ msgid "Output field seperator"
+#~ msgstr "फà¥à¤²à¥à¤¡"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+#~ "(ercent_cover)"
+#~ msgstr "a h à¤à¤µà¤°"
+#, fuzzy
+#~ msgid "Writing %s"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Run verbosly"
+#~ msgstr "सà¤à¥"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "Node[%d]: %d \n"
+#~ "Number of lines: %d \n"
+#~ "Coordinates: %.6f, %.6f, %.6f\n"
+#~ msgstr "à¤à¤¾ n"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %5d \n"
+#~ "Angle: %.8f\n"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid ""
+#~ "Area: %d \n"
+#~ "Number of isles: %d\n"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤µà¤¿."
+#, fuzzy
+#, fuzzy
+#~ msgid "Reading the raster maps..."
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "हà¥"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "ढाल"
+#, fuzzy
+#~ msgid "** Can't open seed singature file <%s> **"
+#~ msgstr "बनाया à¤à¤¾ रहा हà¥."
+#, fuzzy
+#~ msgid "** Can't read signature file <%s> **"
+#~ msgstr "i n"
+#, fuzzy
+#~ msgid "Error writing result map file!"
+#~ msgstr "तà¥à¤°à¥à¤à¤¿ n"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¥ लिठà¤à¤¼à¥à¤¡"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#~ msgstr "सà¤à¥"
+#, fuzzy
+#, fuzzy
+#~ msgid "Done"
+#~ msgstr "n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Reading raster map"
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "नहà¥à¤ à¤à¥ लिà¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid "Editing tool"
+#~ msgstr "n"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#, fuzzy
+#~ msgstr "बनाया à¤à¤¾ रहा हॠn"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "a"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾ फ़िलà¥à¤à¤°"
+#, fuzzy
+#~ msgstr "डाà¤à¤¾à¤¬à¥à¤¸ à¤à¤¾ नामà¤"
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgid ""
+#~ msgstr "à¤à¤¾ à¤à¤¼à¥à¤¡ हॠà¤à¥ लिठà¤à¤¼à¥à¤¡ हॠनहà¥à¤."
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "पदà¥à¤§à¤¤à¤¿"
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "output layer name"
+#~ msgstr "ढाल फ़ाà¤à¤²à¤¨à¤¾à¤® "
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Compute upslope flowlines"
+#~ msgstr "à¤à¤£à¤¨à¤¾ à¤à¤°à¥à¤"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Name of the output deviations site file"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "Type of attribute to use for labels"
+#, fuzzy
+#~ msgid "Use \"Map Coordinates\" for coordinates"
+#, fuzzy
+#~ msgid "Number of rows to extract."
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#~ msgid "Name of raster map."
+#~ msgstr "à¤à¤¾."
+#, fuzzy
+#~ msgid "Name of the output sites map"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "raster map name from which to copy color table"
+#, fuzzy
+#~ msgid "Name of spheroid to use"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgid "name of painter to select"
+#~ msgstr "à¤à¤¾"
+#, fuzzy
+#~ msgstr "हà¥"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_it.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -9273,9 +9273,9 @@
#: ../raster/r.out.gdal/main.c:634 ../raster/r.out.gdal/main.c:646
#: ../raster/r.out.gdal/main.c:659 ../raster/r.out.gdal/main.c:672
#: ../raster/r.out.gdal/main.c:684 ../raster/r.out.gdal/main.c:697
-#, fuzzy, c-format
+#, c-format
msgid "Range to be exported: %g - %g"
-msgstr "Il file raster da importare"
+msgstr ""
#: ../raster/r.out.gdal/main.c:681 ../raster/r.out.gdal/export_band.c:530
#, c-format
@@ -12961,7 +12961,9 @@
#: ../general/g.message/main.c:52 ../general/g.message/main.c:57
#, fuzzy
msgid "Type"
-msgstr "Tipo sconosciuto"
+msgstr ""
+"Layer: %d\n"
+"categoria: %d\n"
#: ../general/g.message/main.c:43
msgid "Print message as warning"
@@ -12981,9 +12983,8 @@
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
-#, fuzzy
msgid "Level"
-msgstr "Nome mappa raster"
+msgstr ""
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
@@ -13009,7 +13010,7 @@
#, fuzzy
-msgstr "impossibile aprire <%s>"
+msgstr "Nome della mappa di input"
@@ -18786,7 +18787,7 @@
#, fuzzy
msgid "3D output"
-msgstr "Mappa in output"
+msgstr "Crea output 3D"
#, fuzzy
@@ -20822,9 +20823,8 @@
msgstr ""
-#, fuzzy
-msgstr "Crea etichette per vettoriali GRASS e attributi associati"
+msgstr ""
#, fuzzy
@@ -21099,14 +21099,12 @@
msgstr ""
#: ../vector/v.lidar.edgedetection/main.c:393
-#, fuzzy
msgid "Allocating memory for bilinear interpolation"
+msgstr ""
#: ../vector/v.lidar.edgedetection/main.c:426
-#, fuzzy
msgid "Allocating memory for bicubic interpolation"
+msgstr ""
#: ../vector/v.lidar.edgedetection/main.c:431
msgid "Bicubic interpolation"
@@ -21130,20 +21128,20 @@
#: ../vector/v.lidar.edgedetection/edgedetection.c:352
#, fuzzy
msgid "Impossible to read from aux table"
+msgstr "Non riesco a selezionare dati dalla tabella"
#: ../vector/v.lidar.edgedetection/edgedetection.c:233
#: ../vector/v.lidar.edgedetection/edgedetection.c:309
#, fuzzy
msgid "Impossible to update aux table"
+msgstr "Nome del filtro file"
#: ../vector/v.lidar.edgedetection/edgedetection.c:246
#: ../vector/v.lidar.edgedetection/edgedetection.c:258
#: ../vector/v.lidar.edgedetection/edgedetection.c:379
#, fuzzy
msgid "Impossible to write to aux table"
+msgstr "Valore da scrivere per null"
#: ../vector/v.net.timetable/main.c:218
#, fuzzy, c-format
@@ -25015,7 +25013,8 @@
#, fuzzy
-msgstr "campo separatore in output"
+msgstr ""
+"Stampa le impostazioni della region corrente (in stile script per la shell)"
#, fuzzy
@@ -27095,10 +27094,12 @@
+#, fuzzy
msgid ""
"point."
msgstr ""
+"Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
@@ -27817,8 +27818,9 @@
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr "Nome del database"
#, fuzzy
@@ -28236,8 +28238,9 @@
msgstr "Non riesco a descrivere la tabella"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
+msgstr "Importa vecchie versione di vettori GRASS"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
msgid "Uncompressed geonames file from (with .txt extension)"
@@ -28261,8 +28264,9 @@
msgstr "File di input"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
+msgstr "Crea un nuovo vettoriale (punti) da una tabella contenente coordinate"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
#, fuzzy
@@ -28318,8 +28322,9 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "Mantieni la tabella colore esistente"
@@ -28457,12 +28462,14 @@
+#, fuzzy
-msgstr ""
+msgstr "Mostra il titolo del file raster"
+#, fuzzy
-msgstr ""
#, fuzzy
@@ -28470,16 +28477,18 @@
+#, fuzzy
-msgstr ""
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "Distanza massima dal punto più vicino"
#, fuzzy
@@ -28865,8 +28874,9 @@
msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+#, fuzzy
msgid "Height of display canvas"
-msgstr ""
+msgstr "Ridimensiona il monitor attivo visualizzato"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
#, fuzzy
@@ -31248,2925 +31258,2937 @@
msgstr ""
#, fuzzy
-#~ msgid "Not enough room in history file"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgstr ""
+"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
+"nel monitor grafico dell'utente."
-#~ msgid "New MAPSET name"
-#~ msgstr "Nome del nuovo MAPSET"
+#, fuzzy
+msgstr "Il file raster da importare"
#, fuzzy
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "mostra i parametri della connessione in uso ed esce"
+msgstr ""
+"File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
+"stdin)"
#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "raster <%s> non trovato"
+msgstr "Nome della mappa raster da utilizzare per <%s>"
#, fuzzy
-#~ msgid "Name of workspace file"
-#~ msgstr "Nome del filtro file"
+msgstr "impossibile aprire <%s>"
#, fuzzy
-#~ msgstr ""
-#~ "Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-#~ "nel monitor grafico dell'utente."
#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "impossibile aprire <%s>"
+msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Genera raster della pendenza, esposizione, curvature e le derivate "
-#~ "parziali da un raster con valori dell'elevazione. Esposizione è calcolata "
-#~ "in senso antiorario partendo dall'est."
+#, fuzzy
+msgstr ""
#, fuzzy
-#~ msgid "Output slope filename"
-#~ msgstr "Nome della tabella in output"
+msgstr "Nome del raster map esistente"
#, fuzzy
-#~ msgid "Output aspect filename"
+msgstr "La tabella <%s> non esiste nel database <%s>"
#, fuzzy
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nome del driver in output"
+msgid "report"
+msgstr "Importa"
#, fuzzy
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nome del database in output"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
#, fuzzy
-#~ msgid "Creating support files..."
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "Unable to open cellfile for <%s>"
#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
+msgstr "Non riesco a trovare il file raster %s"
#, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#~ msgstr "Non riesco a descrivere la tabella"
#, fuzzy
-#~ msgid "Input elevation map"
-#~ msgstr "Mostra il titolo del file raster"
#, fuzzy
-#~ msgid "Output shaded relief map name"
+msgstr "Impossibile salvare la region <%s>"
#, fuzzy
-#~ msgid "Layer number of data column"
#, fuzzy
-#~ msgid ""
-#~ "Calculates univariate statistics from a raster map based on vector "
-#~ "polygons and uploads statistics to new attribute columns."
#, fuzzy
-#~ msgstr "Il file raster da importare"
#, fuzzy
-#~ msgstr ""
-#~ "File ASCII contenente la singola linea descrivente la proiezione WKT (- "
-#~ "per stdin)"
#, fuzzy
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Nome della mappa raster che contiene i risultati"
#, fuzzy
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "Nome del file raster in input"
+msgstr "Utilizza la regione corrente"
#, fuzzy
-#~ msgid "Output water depth raster map [m]"
+msgstr "Nome del raster"
-#~ msgid "Output elevation raster map"
-#~ msgstr "Output mappa raster dell'elevazione"
+#, fuzzy
#, fuzzy
-#~ msgid "Input elevation raster map"
-#~ msgstr "Mappa raster risultante"
#, fuzzy
-#~ msgid "Input aspect raster map"
+msgstr "Sto disegnando ..."
#, fuzzy
-#~ msgid "Input barrier raster map"
-#~ msgstr "Nome del driver in input"
#, fuzzy
-#~ msgid "Output flowline vector map"
+msgstr "Nome di una mappa raster contenente una superfice di altezze"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Nome della mappa raster dell'elevazione"
#, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "Utilizzando le coordinate del centro della mappa\n"
#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
#, fuzzy
-#~ msgid "(i) Elevation map"
-#~ msgstr "Mappa raster in input"
+msgid "Pass %d:"
+msgstr "Password"
#, fuzzy
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr "Nome della mappa raster risultante"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "Visualizza il raster delle altezze dopo il riempimento"
#, fuzzy
-#~ msgid "Reading map..."
+msgstr "Mappa raster risultante"
#, fuzzy
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "File di input"
-#~ msgid "Name of raster map to contain results"
#, fuzzy
-#~ msgid "The map N grid coordinates"
#, fuzzy
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "La tabella <%s> non esiste nel database <%s>"
#, fuzzy
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "Nome della mappa raster risultante"
#, fuzzy
#, fuzzy
+msgstr "Non riesco ad impostare user/password"
#, fuzzy
-#~ msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Converte raster 3D (G3D) in formato VTK-Ascii"
+msgid "Could not open <%s>"
+msgstr "Impossibile aprire <%s>"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the currently defined region."
-#~ msgstr ""
-#~ "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel "
-#~ "della region corrente"
+#, fuzzy
+msgstr "Nome di un file vettoriale in output"
#, fuzzy
-#~ msgstr ""
-#~ "Stampa le impostazioni della region corrente (in stile script per la "
-#~ "shell)"
-#~ msgid ""
-#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-#~ "resolution of the currently defined region."
-#~ msgstr ""
-#~ "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione "
-#~ "del pixel definita della region corrente"
#, fuzzy
-#~ msgid "Band to select"
-#~ msgstr "Nessun monitor selezionato"
#, fuzzy
-#~ msgstr "Nome del raster map esistente"
+msgid "qcname"
+msgstr "nnome"
#, fuzzy
-#~ msgid "Attribute table column with values to interpolate (if layer>0)"
+msgid "Name of QC"
#, fuzzy
+msgstr "Numero di righe"
#, fuzzy
-#~ msgid "M.Q. solution"
-#~ msgstr "Risoluzione"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importa file SRTM HGT in GRASS"
+msgid "Use db.select for SELECT SQL statements"
+msgstr "Usa db.select per i comandi SELECT SQL"
#, fuzzy
-#~ msgid "report"
-#~ msgstr "Importa"
+msgstr "File di input"
#, fuzzy
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Reading %s"
#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
+msgid "Writing %s"
#, fuzzy
+msgid "Can't find %d,%d:%f"
+msgstr "Non riesco a mostrare i database"
-#, fuzzy
+msgid "Nothing to show"
+msgstr "Niente da mostrare"
#, fuzzy
+msgid "raster, random, cell"
+msgstr "Mappa(e) raster da leggere"
#, fuzzy
-#~ msgstr "Impossibile salvare la region <%s>"
#, fuzzy
+msgid "raster, random, surface"
+msgstr "File raster per superficie"
#, fuzzy
+msgid "Output more comments (default=quiet)"
-#, fuzzy
+msgid "Cannot open database %s by driver %s"
+msgstr "Non riesco ad aprire il database %s col driver %s"
#, fuzzy
+msgid "Cannot select attributes: %s"
#, fuzzy
+msgid "Output inverse raster map after IFFT"
#, fuzzy
-#~ msgstr "Utilizza la regione corrente"
#, fuzzy
-#~ msgstr "Nome del raster"
+msgid ""
#, fuzzy
#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
+msgid "Power 2 values : [%d] rows [%d] columns."
+msgstr "%d raster%s, %d vettoriale%s\n"
+msgid "Reading the raster maps..."
+msgstr "Leggendo la mappa raster"
#, fuzzy
-#~ msgid "unable to open new S factor map layer."
+msgid "Rotating data arrays..."
#, fuzzy
+msgid "Inverse FFT completed..."
+msgstr "Percentuale completa..."
+msgid "Unable to open output file."
+msgstr "Impossibile aprire il file di output"
#, fuzzy
-#~ msgstr "Sto disegnando ..."
+msgid "Transform successful."
+msgstr "Trasformazione completata.\n"
#, fuzzy
+msgid "Intensity map name"
+msgstr "Nome mappa raster"
#, fuzzy
-#~ msgstr "Nome di una mappa raster contenente una superfice di altezze"
+msgid "Saturation map name"
#, fuzzy
+msgid "Output map representing the red"
+msgstr "strighe che rappresentano le celle prive di valori"
#, fuzzy
+msgid "Output map representing the green"
#, fuzzy
-#~ msgstr "Password"
+msgid "Output map representing the blue"
+msgid "Cannot read row from raster map"
+msgstr "Non posso leggere la riga dalla mappa raster"
+msgid "Cannot write row to raster map"
+msgstr "Non posso scrivere la riga alla mappa raster"
#, fuzzy
+msgid "Green input raster map"
+msgstr "Nome del driver in input"
#, fuzzy
+msgid "Blue input raster map"
#, fuzzy
+msgid "Output intensity raster map"
+msgstr "Nome della tabella in output"
#, fuzzy
+msgid "Output saturation raster map"
+msgstr "Visualizza il raster della direzione"
#, fuzzy
+msgid "Class transition statistics."
#, fuzzy
+msgid "get_img: out of memory."
+msgstr "Memoria esaurita!\n"
#, fuzzy
+msgid "Subgroup [%s] in group [%s] contains no files."
+msgstr "Gruppo [%s] non contiene mappe, avvia i.group"
+msgid "Writing [%s] ..."
+msgstr "Sto scrivendo [%s] ..."
#, fuzzy
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Name of imagery signaturefile"
+msgstr "Nome della mappa raster"
#, fuzzy
+msgstr "Gruppo <%s> non trovato"
-#~ msgid "Could not open <%s>"
-#~ msgstr "Impossibile aprire <%s>"
+msgid "Subgroup [%s] not found."
+msgstr "Sottogruppo <%s> non trovato"
#, fuzzy
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "Signature file [%s] is missing or not readable."
+msgstr "raster <%s> non trovato"
#, fuzzy
+msgid "Calculating eigenvalues and eigenvectors..."
#, fuzzy
+msgid "Transposing eigen matrix..."
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "nnome"
+msgid "Cannot write color table of raster map <%s>"
#, fuzzy
+msgid "Calculating class mean ..."
#, fuzzy
-#~ msgstr "Numero di righe"
+msgid "Calculating class covariance matrix..."
+msgid "Imagery group"
+msgstr "Gruppo di immagini"
#, fuzzy
+msgid "Subgroup containing image files"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "Usa db.select per i comandi SELECT SQL"
+#, fuzzy
+msgid "Resultant signature file"
+msgstr "mappa raster con il risultato"
#, fuzzy
+msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
#, fuzzy
-#~ msgid "Reading %s"
+msgid "Input raster map being fft"
#, fuzzy
-#~ msgid "Writing %s"
+msgid "Initializing data...\n"
#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "Non riesco a mostrare i database"
+msgid "Reading the raster map..."
-#~ msgid "Nothing to show"
-#~ msgstr "Niente da mostrare"
+#, fuzzy
+msgid "FFT completed..."
+msgstr "%s: completo ..."
#, fuzzy
-#~ msgid "raster, random, cell"
-#~ msgstr "Mappa(e) raster da leggere"
#, fuzzy
#, fuzzy
-#~ msgid "raster, random, surface"
-#~ msgstr "File raster per superficie"
+msgid ""
+"\n"
+" group <%s> not found"
+msgid "subgroup <%s> not found"
+msgstr "sottogruppo <%s> non trovato"
#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
+msgid "Subgroup [%s] doesn't have any files"
+msgstr "Sottogruppo [%s] non ha alcun file"
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Non riesco ad aprire il database %s col driver %s"
+#, fuzzy
+msgid "Unable to proceed"
#, fuzzy
-#~ msgid "Cannot select attributes: %s"
+msgstr "Nome del file raster in input"
#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
#, fuzzy
+msgid "Group of imagery files to be clustered"
#, fuzzy
-#~ msgid ""
+msgid "File containing initial signatures"
+msgstr "File contenente le direttive SQL"
#, fuzzy
+msgid "Output file to contain final report"
#, fuzzy
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "%d raster%s, %d vettoriale%s\n"
+msgid ""
+"\n"
+"<%s> -- illegal value of min_size"
+msgstr "Valore da impostare a null non valido"
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Leggendo la mappa raster"
+#, fuzzy
+msgid "Can't creat reportfile: "
#, fuzzy
-#~ msgid "Rotating data arrays..."
+msgid "Reading image ... "
#, fuzzy
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "Percentuale completa..."
+msgid "Unable to read head of %s"
+msgstr "Non riesco ad aprire il file header di [%s]"
-#~ msgid "Unable to open output file."
-#~ msgstr "Impossibile aprire il file di output"
+msgid "group=[%s] - not found."
+msgstr "gruppo=[%s] - non trovato"
#, fuzzy
-#~ msgid "Transform successful."
-#~ msgstr "Trasformazione completata.\n"
+msgid "subgroup=[%s] (of group [%s]) - not found."
#, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "Nome mappa raster"
+msgid "Can't read signature file [%s]."
#, fuzzy
-#~ msgid "Saturation map name"
+msgid "Unable to create reject layer [%s]."
#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "strighe che rappresentano le celle prive di valori"
+msgid "Imagery group to be classified"
+msgstr "Mappa raster da riclassificare"
#, fuzzy
-#~ msgid "Output map representing the green"
+msgid "Subgroup containing image files to be classified"
#, fuzzy
-#~ msgid "Output map representing the blue"
+msgid "Signatures to use for classification"
+msgstr "Nome del file con il risultato della classificazione"
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Non posso leggere la riga dalla mappa raster"
+#, fuzzy
+msgid "Raster map to hold classification results"
-#~ msgid "Cannot write row to raster map"
-#~ msgstr "Non posso scrivere la riga alla mappa raster"
+msgid "sensor: LANDSAT"
+msgstr "sensore: LANDSAT"
+msgid "sensor: QuickBird"
+msgstr "sensore: QuickBird"
+msgid "sensor: SPOT"
+msgstr "sensore: SPOT"
#, fuzzy
-#~ msgid "Green input raster map"
+msgid "ERROR: Problem opening output file."
+msgid "Steps=%d"
+msgstr "Scala=%d"
#, fuzzy
-#~ msgid "Blue input raster map"
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr "Crea separatamente un file bitmap 3D di valori nulli"
#, fuzzy
-#~ msgid "Output intensity raster map"
+msgid "Name of the sampling locations vector points map"
#, fuzzy
-#~ msgid "Output saturation raster map"
-#~ msgstr "Visualizza il raster della direzione"
+msgid "Density of output walkers"
+msgstr "Nome del file in output"
#, fuzzy
-#~ msgid "Class transition statistics."
+msgid "File [%s] not found"
#, fuzzy
-#~ msgid "get_img: out of memory."
-#~ msgstr "Memoria esaurita!\n"
+msgid "Unable to open file [%s]"
#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "Gruppo [%s] non contiene mappe, avvia i.group"
+msgid "Reading sites map (%s) ..."
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Sto scrivendo [%s] ..."
+#, fuzzy
+msgid "You are not outputting any raster or vector points maps"
#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "Nome della mappa raster"
+msgid "%s=%s - illegal value"
+msgstr "Nome del raster map in output"
#, fuzzy
-#~ msgstr "Gruppo <%s> non trovato"
+msgid "Unable to read current region parameters"
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Sottogruppo <%s> non trovato"
#, fuzzy
-#~ msgid "Signature file [%s] is missing or not readable."
+msgid "Cannot open cover raster map <%s>"
+msgstr "Non riesco ad aprire il cellfile [%s]"
#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
+msgid "Cannot open database <%s> by driver <%s>"
+msgstr "Non riesco ad eseguire il driver '%s'"
#, fuzzy
-#~ msgid "Transposing eigen matrix..."
+msgid "No map specified"
+msgstr "Nessuna mappa in input specificata"
#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
+msgid "%s - unable to remove color table"
#, fuzzy
-#~ msgid "Calculating class mean ..."
+msgid "%s - color table not found"
#, fuzzy
-#~ msgid "Calculating class covariance matrix..."
+msgid "%s - unknown color request"
+msgstr "%s - colore sconosciuto\n"
-#~ msgid "Imagery group"
-#~ msgstr "Gruppo di immagini"
#, fuzzy
-#~ msgid "Subgroup containing image files"
+msgid "Unable to properly read input raster map"
#, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "mappa raster con il risultato"
+msgid "Unable to properly write output raster map"
+msgstr "Nome del raster in output"
#, fuzzy
-#~ msgid ""
-#~ "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
+msgid "Could not read range file"
#, fuzzy
-#~ msgid "Input raster map being fft"
+msgid "Reading data: "
+msgid "Name of raster map layer to be used for <%s>"
#, fuzzy
-#~ msgid "Initializing data...\n"
+msgid "%d points converted to centroids"
+msgstr "Punti di blocco della mappa vettoriale"
#, fuzzy
-#~ msgid "Reading the raster map..."
+msgid "%d centroids converted to points"
#, fuzzy
-#~ msgid "FFT completed..."
-#~ msgstr "%s: completo ..."
+msgstr "%d linee / confini rimossi"
#, fuzzy
+msgid "%d boundaries converted to lines"
#, fuzzy
+msgid "CrossCorrelation: %d points read in region.\n"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
+msgid "CrossCorrelation: Cannot read field info"
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "sottogruppo <%s> non trovato"
#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "Sottogruppo [%s] non ha alcun file"
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
#, fuzzy
-#~ msgid "Unable to proceed"
+msgid "CrossCorrelation: Column type not supported"
+msgstr "Tipo di colonna non supportata"
#, fuzzy
+msgid "CrossCorrelation: Cannot select data from table"
#, fuzzy
+msgid "CrossCorrelation: %d records selected from table"
#, fuzzy
-#~ msgid "Group of imagery files to be clustered"
+msgid "CrossCorrelation: No record for point (cat = %d)"
+msgstr "Nessun record per la cat = %d"
#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "File contenente le direttive SQL"
+msgid "CrossCorrelation: Mean = %.5lf\n"
#, fuzzy
-#~ msgid "Output file to contain final report"
+msgid "CrossCorrelation: lambda_i = %.3f\n"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr "Valore da impostare a null non valido"
+msgid "From type"
+msgstr "Tipo sconosciuto"
#, fuzzy
-#~ msgid "Can't creat reportfile: "
+msgid "From layer"
+msgstr " nv colore\n"
#, fuzzy
-#~ msgid "Reading image ... "
+msgid "The column must be type integer or string"
#, fuzzy
-#~ msgid "Unable to read head of %s"
-#~ msgstr "Non riesco ad aprire il file header di [%s]"
+msgstr "Tipo di grafico"
-#~ msgid "group=[%s] - not found."
-#~ msgstr "gruppo=[%s] - non trovato"
#, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
+msgid "Cannot select records from database"
#, fuzzy
-#~ msgid "Can't read signature file [%s]."
+msgid "Cannot fetch data"
#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
+msgid "Input vector was not found."
#, fuzzy
-#~ msgid "Imagery group to be classified"
-#~ msgstr "Mappa raster da riclassificare"
+msgid "Cannot open dig_cats file."
#, fuzzy
-#~ msgid "Subgroup containing image files to be classified"
+msgid "Cannot open database %s"
+msgstr "Non posso scrivere i collegamenti del database"
#, fuzzy
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Nome del file con il risultato della classificazione"
+msgid "Cannot insert into table: %s"
#, fuzzy
-#~ msgid "Raster map to hold classification results"
+msgid "Removed vertices: %5d"
+msgstr "Vertici rimossi"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "sensore: LANDSAT"
+msgid "Removed vertices"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "sensore: QuickBird"
+#, fuzzy
+msgid "Node layer (points)"
+msgstr "nome tabella"
-#~ msgid "sensor: SPOT"
-#~ msgstr "sensore: SPOT"
+msgid "Reading data from the map..."
+msgstr "Sto leggendo dati dalla mappa"
#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
+msgid "Query layer (used by 'query' option)"
-#~ msgid "Steps=%d"
-#~ msgstr "Scala=%d"
+msgid "%d categories read from map"
+msgstr "%d categorie caricate dalla mappa"
#, fuzzy
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Crea separatamente un file bitmap 3D di valori nulli"
+msgid "%d update/insert errors"
+msgstr "%s errori di aggiornamento\n"
#, fuzzy
-#~ msgid "Name of the sampling locations vector points map"
-#~ msgstr "Nome della mappa di input"
+msgid "Processing ainput lines ..."
#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nome del file in output"
+msgid "Processing ainput areas ..."
-#, fuzzy
-#~ msgid "File [%s] not found"
+msgid "Writing attributes ..."
+msgstr "Sto scrivendo gli attributi ..."
#, fuzzy
-#~ msgid "Unable to open file [%s]"
+msgid "Current region does not include the entire input vector map <%s>"
#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
+msgid ""
+"Elevation raster map <%s> does not cover the entire area of the input vector "
+"map <%s>. "
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "Nome del raster map in output"
+msgid "Displays thematic vectormap"
+msgstr "Mostra mappa vettoriale tematica"
#, fuzzy
-#~ msgid "Unable to read current region parameters"
+msgid "Vector map to display thematically"
#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr "Non riesco ad aprire il cellfile [%s]"
+msgid "Vector map type"
#, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Non riesco ad eseguire il driver '%s'"
+msgid "Attribute column to use for thematic display (must be numeric)"
#, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "Nessuna mappa in input specificata"
+msgid "Layer to use for thematic display"
#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "Valore da scrivere per null"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
#, fuzzy
-#~ msgid "%s - color table not found"
+msgid "Output separator (default: newline)"
+msgstr "Carattere di separatore in output (predefinito: tab)"
#, fuzzy
-#~ msgid "%s - unknown color request"
-#~ msgstr "%s - colore sconosciuto\n"
+msgid "Raster to remove"
#, fuzzy
-#~ msgid "Unable to properly read input raster map"
+msgid "3d raster to remove"
#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Nome del raster in output"
+msgid "Vector to remove"
#, fuzzy
-#~ msgid "Could not read range file"
+msgid "Region to remove"
#, fuzzy
-#~ msgid "Reading data: "
+msgid "Label to remove"
-#~ msgid "Name of raster map layer to be used for <%s>"
#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "Punti di blocco della mappa vettoriale"
+msgid "3dview to remove"
#, fuzzy
-#~ msgid "%d centroids converted to points"
+msgid "Group to remove"
#, fuzzy
-#~ msgstr "%d linee / confini rimossi"
+msgid "raster input maps"
+msgstr "Mappa raster in input"
#, fuzzy
-#~ msgid "%d boundaries converted to lines"
+msgid "Keep band numbers instead of using band color names."
+msgstr "Usa i numeri delle bande invece che i nomi dei colori"
#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
+msgid "Output field seperator"
+msgstr "Campo separatore in output"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
+msgid "Saving new map"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
+msgid "Terrain raster map (DEM)"
#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Tipo di colonna non supportata"
+msgid "Output raster map with lake"
+msgstr "Nome del driver in output"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Non riesco a selezionare dati dalla tabella"
+msgid "Cannot write lake raster map <%s>!"
#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
+msgid "Terrain raster map <%s> not found!"
#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Nessun record per la cat = %d"
+msgid "Cannot open terrain raster map <%s@%s>!"
#, fuzzy
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
+msgid "Seed map <%s> not found!"
#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
+msgid "Cannot open seed map <%s@%s>!"
#, fuzzy
-#~ msgid "From type"
-#~ msgstr "Tipo sconosciuto"
+msgid "Failure to allocate memory for row pointers"
#, fuzzy
-#~ msgstr " nv colore\n"
+msgid "Loading maps: "
#, fuzzy
-#~ msgid "The column must be type integer or string"
+msgid "Error reading terrain raster map. Probably broken file."
#, fuzzy
-#~ msgstr "Tipo di grafico"
+msgid "Error reading seed raster map. Probably broken file."
#, fuzzy
-#~ msgid "Cannot select records from database"
+msgid "Cannot write lake raster map <%s@%s>!"
#, fuzzy
-#~ msgid "Cannot fetch data"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Errore nella lettura del file dbmscap\n"
#, fuzzy
-#~ msgid "Input vector was not found."
+msgid "All done."
+msgstr "Fatto.\n"
#, fuzzy
-#~ msgid "Cannot open dig_cats file."
+msgid "Name of the vector points map with x,y locations"
#, fuzzy
-#~ msgid "Cannot open database %s"
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgid "Number of time iterations (sec.)"
+msgstr "Numero di passi attraverso il dataset"
#, fuzzy
-#~ msgid "Cannot insert into table: %s"
+msgid "Multiscale simulation"
+msgstr "locazione del database"
#, fuzzy
-#~ msgid "Removed vertices: %5d"
-#~ msgstr "Vertici rimossi"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgid "Removed vertices"
#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "nome tabella"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Reading data from the map..."
-#~ msgstr "Sto leggendo dati dalla mappa"
+msgid "Raster input maps(s)"
+msgstr "Mappe raster in input"
#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
+msgid "Output file name"
+msgstr "Nome del file di output"
-#~ msgid "%d categories read from map"
-#~ msgstr "%d categorie caricate dalla mappa"
#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "%s errori di aggiornamento\n"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "ERRORE: <%s> esiste già \n"
#, fuzzy
-#~ msgid "Processing ainput lines ..."
+msgid "Error reading '%s' map"
#, fuzzy
-#~ msgid "Processing ainput areas ..."
+msgid "Threshold distance"
+msgstr "Unità della distanza"
-#~ msgid "Writing attributes ..."
-#~ msgstr "Sto scrivendo gli attributi ..."
#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
+msgid "Cannot execute: %s"
#, fuzzy
-#~ msgid ""
-#~ "Elevation raster map <%s> does not cover the entire area of the input "
-#~ "vector map <%s>. "
+msgid "Cannot link table: %s"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
#, fuzzy
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "Mostra mappa vettoriale tematica"
+msgid "DXF input file"
#, fuzzy
-#~ msgid "Vector map to display thematically"
+msgid "Cannot open dxf file <%s>"
#, fuzzy
-#~ msgid "Vector map type"
+msgid "Cannot open new vector map <%s>"
#, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
+msgid "Conversion of <%s> to vector map:"
#, fuzzy
-#~ msgid "Layer to use for thematic display"
+msgid "Hilight color for text"
+msgstr "Colore di evidenziazione del testo"
+msgid "Line: %d\n"
+msgstr "Linea: %d\n"
#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
+msgid "output raster map"
#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Carattere di separatore in output (predefinito: tab)"
+msgid "Name of input raster map(s)"
+msgstr "Nome della mappa raster d'inserimento dati"
#, fuzzy
-#~ msgid "Raster to remove"
+msgid "Illegal file name for real part: %s"
#, fuzzy
-#~ msgid "3d raster to remove"
+msgid "Illegal file name for imaginary part: %s"
#, fuzzy
-#~ msgid "Vector to remove"
+msgid "Raster file(s) for Elevation"
+msgstr "file raster per la Vista%d"
#, fuzzy
-#~ msgid "Region to remove"
+msgid "Raster file(s) for Color"
#, fuzzy
-#~ msgid "Label to remove"
+msgid "Raster map to zoom into"
+msgid "Save the current region to region definition file"
+msgstr ""
+"Salva le impostazione della region corrente in un file di definizione della "
+"region"
#, fuzzy
-#~ msgid "3dview to remove"
+msgid "Erasing monitors ..."
#, fuzzy
-#~ msgid "Group to remove"
+msgid "Could not open input file <%s>."
#, fuzzy
-#~ msgid "raster input maps"
+msgid "Unable to open file: <%s>"
#, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Usa i numeri delle bande invece che i nomi dei colori"
+msgid "Raster map not found."
#, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Campo separatore in output"
+msgid "Raster file [%s] not found"
#, fuzzy
-#~ msgid "Saving new map"
+msgid "It was not possible writing in <%s>."
#, fuzzy
+msgid "Cannot create table: '%s'"
+msgstr "Non riesco a descrivere la tabella"
#, fuzzy
-#~ msgid "Output raster map with lake"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Non riesco a leggere da <%s>"
#, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Unable to delete layer/category [%d/%d] line %d"
#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
+msgid "Unable to write line %d"
#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Unknown query tool '%s'"
#, fuzzy
-#~ msgid "Seed map <%s> not found!"
+msgid "No layer database connection"
#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "%d categories loaded from the database"
+msgstr "Estrae dati dal database."
#, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
+msgid "Cannot create layer"
#, fuzzy
-#~ msgid "Loading maps: "
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Impossibile trovare il vettoriale [%s]"
#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
+msgid "Column type [%d] not supported"
#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Cannot read map header for <%s>"
#, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot read category file for <%s>"
+msgid "Print;Shell Script"
+msgstr "Stampa; script per la shell"
+msgid "Category file for [%s] not available"
+msgstr "File category per [%s] non disponibile"
#, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
+msgid "%s: <%s> raster map not found"
#, fuzzy
-#~ msgid "All done."
-#~ msgstr "Fatto.\n"
+msgid "%s: <%s> raster map exists already"
#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
+msgid "Cannot read category file of raster map <%s>"
#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Numero di passi attraverso il dataset"
+msgid "%s - map not found"
#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "locazione del database"
+msgid "%s not found"
#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgid "Could not access %s layer"
#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Vector map %s - not found"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mappe raster in input"
+msgid "Raster map containing elevation data"
+msgstr "Mappa raster che contiene i valori delle altezze"
+msgid "Raster map name for storing results"
+msgstr "Mappa raster con il nome dei risultati archiviati"
+msgid "Height of the viewing location"
+msgstr "Altezza della locazione visualizzata"
#, fuzzy
-#~ msgid "Output file name"
-#~ msgstr "Nome del file di output"
+msgid "%s: <%s> cellfile not found"
#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "ERRORE: <%s> esiste già \n"
+msgid "Cell file [%s] not found\n"
#, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "rgb cell map [%s] not found\n"
#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unità della distanza"
+msgid "vector cell map [%s] not found\n"
#, fuzzy
-#~ msgid "Cannot execute: %s"
+msgid "%s - %s not found"
#, fuzzy
-#~ msgid "Cannot link table: %s"
+msgid "Creating support files"
#, fuzzy
-#~ msgid "DXF input file"
+msgid "%s file [%s] not found!"
#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "%s: %s - map not found"
#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "%s: unable to open %s"
#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
+msgid "%s - not found"
#, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Colore di evidenziazione del testo"
+msgid "Cannot read %s"
-#~ msgid "Line: %d\n"
-#~ msgstr "Linea: %d\n"
+#, fuzzy
+msgid "[%s] map not found."
#, fuzzy
-#~ msgid "output raster map"
+msgid "[%s] map not found"
#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nome della mappa raster d'inserimento dati"
+msgid "elevation file [%s] not found"
#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
+msgid "Cannot describe table <%s>"
#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Cannot insert values: %s"
#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "file raster per la Vista%d"
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s ha dato un numero non valido di sites [%d]"
#, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Unable to open database %s by driver %s"
#, fuzzy
-#~ msgid "Raster map to zoom into"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "Nessuna impostazione definita per il database. Fallo usando db.connect"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr ""
-#~ "Salva le impostazione della region corrente in un file di definizione "
-#~ "della region"
+msgid "Could not find input %s"
+msgstr "Non riesco a trovare l'input %s"
-#, fuzzy
-#~ msgid "Erasing monitors ..."
+msgid "Could not open input"
+msgstr "Non riesco ad aprire l'input"
+msgid "Could not open output"
+msgstr "Non riesco ad aprire l'output"
#, fuzzy
-#~ msgid "Could not open input file <%s>."
+msgid "Could not find input map <%s>"
+msgid "Database connection not defined\n"
+msgstr "Connessione al database non definita\n"
#, fuzzy
-#~ msgid "Unable to open file: <%s>"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
#, fuzzy
-#~ msgid "Raster map not found."
+msgid "Can't read header for 3D raster <%s> in <%s>"
#, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Can't write region <%s>"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** input non valido **"
#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "No graphics device selected."
+msgstr "Nessun device grafico selezionato"
#, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Unable to read raster row."
#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Non riesco a leggere da <%s>"
+msgid "Training map [%s] not found."
#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "%s map not found"
#, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "input raster map"
#, fuzzy
-#~ msgid "Unknown query tool '%s'"
+msgid "Illegal file name: %s"
+msgstr "Nome file non valido [%s]."
+msgid "Cannot get layer info for vector map"
+msgstr "Impossibile ottenere informazioni sul layer vettoriale"
#, fuzzy
-#~ msgid "No layer database connection"
+msgid "Cannot open raster map <%s> in <%s>"
#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "Estrae dati dal database."
+msgid "%s: %s - raster map not found"
#, fuzzy
-#~ msgid "Cannot create layer"
+msgid "%s: %s - illegal name"
#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Impossibile trovare il vettoriale [%s]"
+msgid "%s: ERROR reading category file for %s"
#, fuzzy
-#~ msgid "Column type [%d] not supported"
+msgid "%s: %s - not found"
#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
+msgid "%s: %s - illegal units"
#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
+msgid "%s: %s - can't open"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Stampa; script per la shell"
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "File category per [%s] non disponibile"
#, fuzzy
-#~ msgid "%s: <%s> raster map not found"
+msgid "Reading input map (%s) ... "
#, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
+msgid "%s - ERROR reading %s"
#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "%s: %s - can't create raster map"
#, fuzzy
-#~ msgid "%s - map not found"
+msgid "Writing output map (%s) ... "
#, fuzzy
-#~ msgid "%s not found"
+msgid "%s - ERROR re-reading %s"
#, fuzzy
-#~ msgid "Could not access %s layer"
+msgid "Reading raster map... "
#, fuzzy
-#~ msgid "Vector map %s - not found"
+msgid "Writing raster map... "
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Mappa raster che contiene i valori delle altezze"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Categoria lista: es. 1,3-8,13"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Mappa raster con il nome dei risultati archiviati"
+msgid "Output separator character (default: tab)"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altezza della locazione visualizzata"
+#, fuzzy
+msgid "Cannot read category file of raster map <%s> in <%s>"
#, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "Cannot find file %s"
#, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cannot get header for %s"
#, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "Cannot create raster map %s"
#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "Cannot create vector map %s"
#, fuzzy
-#~ msgid "%s - %s not found"
+msgid "Cannot create raster map '%s'"
#, fuzzy
-#~ msgid "Creating support files"
+msgid "Number of raster rows to hold in memory"
+msgstr "Nume di righe da tenere in memoria"
#, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "Print raster map title only"
+msgstr "Stampa solo il tipo di mappa raster"
#, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "unknown type: %d"
+msgid "Cannot open raster map [%s]"
#, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "Cannot get raster band."
#, fuzzy
-#~ msgid "%s - not found"
+msgid "Cannot read GRASS raster."
#, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot write GDAL raster."
#, fuzzy
-#~ msgid "[%s] map not found."
+msgid "Cannot get [%s] driver"
#, fuzzy
-#~ msgid "[%s] map not found"
+msgid "Couldn't set geo transform."
#, fuzzy
-#~ msgid "elevation file [%s] not found"
+msgid "Couldn't set projection."
#, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot export [%s] raster map."
#, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot create [%s] raster map using [%s] driver."
#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s ha dato un numero non valido di sites [%d]"
+msgid "Cannot read header of raster map <%s>"
#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Cannot open TIFF file <%s>"
#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Nessuna impostazione definita per il database. Fallo usando db.connect"
+msgid "Reading raster map"
-#~ msgid "Could not find input %s"
-#~ msgstr "Non riesco a trovare l'input %s"
+#, fuzzy
+msgid "Cannot open output map."
+msgstr "Nome della mappa di output"
-#~ msgid "Could not open input"
-#~ msgstr "Non riesco ad aprire l'input"
+#, fuzzy
+msgid "Illegal file name. Please try another."
-#~ msgid "Could not open output"
-#~ msgstr "Non riesco ad aprire l'output"
+#, fuzzy
+msgid "%s: can't open %s"
#, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "memory allocation failure"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "Connessione al database non definita\n"
#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
+msgid "Can't find data map."
#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Output terrain only vector map name"
#, fuzzy
-#~ msgid "Can't write region <%s>"
+msgid "Cannot open vector map <%s> at the topological level"
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** input non valido **"
#, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "Nessun device grafico selezionato"
+msgid "Rebuilding topology ..."
#, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Removing duplicates ..."
#, fuzzy
-#~ msgid "Training map [%s] not found."
+msgid "Attaching islands ..."
#, fuzzy
-#~ msgid "%s map not found"
+msgid "Attaching centroids ..."
#, fuzzy
-#~ msgid "input raster map"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Nome di 2-%d mappe raster in input"
#, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "Nome file non valido [%s]."
+msgid "The number of polylines in the output vector map is [%d]"
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Impossibile ottenere informazioni sul layer vettoriale"
#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
+msgid "Cannot open select cursor"
#, fuzzy
-#~ msgid "%s: %s - raster map not found"
+msgid "Cannot get layer info"
#, fuzzy
-#~ msgid "%s: %s - illegal name"
+msgid "cell file [%s] not found"
#, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "can't open raster map [%s]"
#, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "Cannot rewrite line %d"
+msgstr "Impossibile creare l'indice"
#, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "Editing tool"
+msgstr "Esistente"
#, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "Cannot copy line %d, editing terminated"
#, fuzzy
-#~ msgid "Reading input map (%s) ... "
+msgid "No layer database connection."
#, fuzzy
-#~ msgid "%s - ERROR reading %s"
+msgid "Cannot snap lines %d,%d"
#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%d lines modified"
+msgstr "%d categorie duplicate nel vettoriale"
#, fuzzy
-#~ msgid "Writing output map (%s) ... "
+msgid "Could not open ASCII file <%s>"
#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "Print vector map region only"
#, fuzzy
-#~ msgid "Reading raster map... "
+msgid "Cannot open vector map <%s> at topo level [%d]"
#, fuzzy
-#~ msgid "Writing raster map... "
+msgid "Cannot get layer info for vector map <%s>"
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Categoria lista: es. 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot select attribute."
#, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Creating vector grid..."
#, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Could not find vector map <%s> in current mapset"
#, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Could not find input map <%s>."
#, fuzzy
-#~ msgid "Cannot create vector map %s"
+msgid "Parameter <%s> not set"
#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Output map where segments will be written"
+msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Nume di righe da tenere in memoria"
+msgid "<%s> cellfile not found"
#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Stampa solo il tipo di mappa raster"
+msgid "Not able to open vector map <%s>"
#, fuzzy
-#~ msgid "unknown type: %d"
+msgid "Can't read raster"
-#~ msgid "Cannot open raster map [%s]"
+msgid "driver name"
+msgstr "nome driver"
-#, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "database name"
+msgstr "nome database"
#, fuzzy
-#~ msgid "Cannot read GRASS raster."
+msgid "Driver name"
-#, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot list databases."
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "database location"
-#, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Table name, select all from this table"
+msgstr "Nome tabella, seleziona tutto da questa tabella"
-#, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "output field separator"
+msgstr "campo separatore in output"
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "output vertical record separator"
+msgstr "output verticale del separatore di record "
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "null value indicator"
+msgstr "indicatore di valore nullo"
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "do not include column names in output"
+msgstr "non includere i nomi delle colonne nell'output"
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "vertical output (instead of horizontal)"
+msgstr "output verticale (invece che orizzontale)"
#, fuzzy
-#~ msgid "Reading raster map"
+msgid "Cannot find mapset for %s"
#, fuzzy
-#~ msgid "Cannot open output map."
-#~ msgstr "Nome della mappa di output"
+msgid "Cannot open File %s"
#, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Not able to open file for [%s]"
#, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "Can't open label file [%s]"
#, fuzzy
-#~ msgid "memory allocation failure"
+msgid "unable to open [%s] in [%s]"
#, fuzzy
-#~ msgid "Can't find data map."
+msgid "warning: unable to open [%s] in [%s]"
#, fuzzy
-#~ msgid "Output terrain only vector map name"
+msgid "Unable to open raster map [%s] in [%s]"
#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Unable to find input cell map '%s'"
#, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Unable to create raster map [%s]"
#, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Unable to create output <%s>"
#, fuzzy
-#~ msgid "Attaching islands ..."
+msgid "Input file [%s] not found."
#, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Unable to open output file <%s>."
#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Nome di 2-%d mappe raster in input"
+msgid "Could not open temporary file: [%s]"
#, fuzzy
-#~ msgid "The number of polylines in the output vector map is [%d]"
+msgid "Could not open input file [%s]"
#, fuzzy
-#~ msgid "Cannot open select cursor"
+msgid "Unable to create output raster map <%s>"
#, fuzzy
-#~ msgid "Cannot get layer info"
+msgid "%s: Unable to find raster map <%s>"
#, fuzzy
-#~ msgid "cell file [%s] not found"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
#, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "%s: Unable to open output raster map <%s>"
#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossibile creare l'indice"
+msgid "Vector <%s> could not be opened"
#, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Esistente"
+msgid "No db connection for driver <%s> defined. Run db.connect."
#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Table name"
-#, fuzzy
-#~ msgid "No layer database connection."
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat: layer[/layer name] table key database driver"
+msgstr ""
+"Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "x column name"
#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%d categorie duplicate nel vettoriale"
+msgid "z column name"
#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Cannot drop table: %s"
#, fuzzy
-#~ msgid "Print vector map region only"
+msgid "Cannot open labels <%s>"
#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot fetch data from table"
#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
+msgid "SVG file <%s> cannot be opened"
#, fuzzy
-#~ msgid "Cannot select attribute."
+msgid "Querying input '%s' ... "
#, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Copying %s input lines ... "
+msgstr "Non riesco a copiare la tabella"
#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
+msgid "Cannot create table <%s>"
#, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "cannot insert row: %s"
#, fuzzy
-#~ msgid "Parameter <%s> not set"
+msgid "Cannot find line of cat %d"
#, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgid "Unalbe to open vector map <%s>"
#, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Transforms a vector map via a set of tie points."
+msgstr "Esporta un raster grass come array binario"
#, fuzzy
-#~ msgid "Can't read raster"
+msgid "Raster map <%s>] not found"
-#~ msgid "driver name"
-#~ msgstr "nome driver"
+msgid "Cannot start driver '%s'."
-#~ msgid "database name"
-#~ msgstr "nome database"
+msgid "Cannot describe table"
+msgid "Cannot start driver <%s>."
+msgstr "Non riesco ad eseguire il driver <%s>."
#, fuzzy
-#~ msgid "Driver name"
+msgid "[%s] is an illegal name"
+msgstr "[%s] è un nome illegale"
-#~ msgid "Cannot list databases."
+msgid "Cannot write to <%s>"
+msgstr "Non riesco a scrivere su <%s>"
-#~ msgid "database location"
+msgid "Not able to open cellfile for [%s]"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nome tabella, seleziona tutto da questa tabella"
+#, fuzzy
+msgid "Not able to find cellfile [%s]"
-#~ msgid "output field separator"
-#~ msgstr "campo separatore in output"
+#, fuzzy
+msgid "Raster file [%s] not available"
-#~ msgid "output vertical record separator"
-#~ msgstr "output verticale del separatore di record "
+#, fuzzy
+msgid "Raster map [%s] not found"
-#~ msgid "null value indicator"
-#~ msgstr "indicatore di valore nullo"
+#, fuzzy
+msgid "Unable to open raster map [%s]"
-#~ msgid "do not include column names in output"
-#~ msgstr "non includere i nomi delle colonne nell'output"
+msgid "Vector file [%s] not available"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "output verticale (invece che orizzontale)"
#, fuzzy
-#~ msgid "Cannot find mapset for %s"
+msgid "Cannot open driver %s"
#, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "<%s> illegal name"
-#, fuzzy
-#~ msgid "Not able to open file for [%s]"
+msgid "Out of Memory!\n"
#, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "%s: %s - illegal name for output raster map."
#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "Couldn't find raster map %s"
#, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "%s: <%s> not found"
#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "%s: <%s> illegal name"
#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
+msgid "%s: Cannot open <%s>"
#, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "could not read range file"
#, fuzzy
-#~ msgid "Input file [%s] not found."
+msgid "Unable to create raster map [%s]."
#, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Filtering [%s] in [%s]"
#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Open raster map %s in %s = %d"
#, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Swap temp files"
#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Writing [%s]"
#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: illegal map name"
#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: <%s> illegal file name"
#, fuzzy
-#~ msgid "%s: Unable to open output raster map <%s>"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Checking location %s, mapset %s:"
#, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr ""
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
#, fuzzy
-#~ msgid "Table name"
+msgid "Error writing output map"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat: layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
#, fuzzy
-#~ msgid "x column name"
+msgid "<%s> is illegal file name"
#, fuzzy
-#~ msgid "z column name"
+msgid "[%s] is an illegal file name"
#, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "no rules specified"
#, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Can't open temp file [%s]"
#, fuzzy
-#~ msgid "Cannot fetch data from table"
+msgid "Unable to open input map <%s> in mapset <%s>"
#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "%s - illegal name "
#, fuzzy
-#~ msgid "Querying input '%s' ... "
+msgid "Couldn't find raster map [%s]"
#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Non riesco a copiare la tabella"
+msgid "%s in %s -can't open raster map"
#, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "%s - can't create raster map"
#, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "Normalized"
+msgstr "Normalizzata"
#, fuzzy
-#~ msgid "Cannot find line of cat %d"
+msgid "Cell file [%s] not found"
#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Requested 3d raster map not found <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgid "Could not open elevation map"
#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Esporta un raster grass come array binario"
+msgid "Could not open output map"
#, fuzzy
-#~ msgid "Raster map <%s>] not found"
+msgid "unable to close output map"
-#~ msgid "Cannot start driver '%s'."
-#~ msgid "Cannot describe table"
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Non riesco ad eseguire il driver <%s>."
#, fuzzy
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "[%s] è un nome illegale"
+msgid "Cannot create output map [%s]"
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Non riesco a scrivere su <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
#, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Database's name couldn't be read"
#, fuzzy
-#~ msgid "Raster file [%s] not available"
+msgid "Cannot open vector points map <%s>"
#, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Cannot create vector map <%s>"
#, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
-#~ msgid "Vector file [%s] not available"
#, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Could not find input map <%s> in current mapset."
#, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "Vector file [%s] not available in search list"
-#~ msgid "Out of Memory!\n"
#, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "Cannot open database <%s>"
#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Cannot open table <%s>"
-#~ msgid "Couldn't find raster map %s"
#, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "Cannot open driver <%s>"
#, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "Could not find input map '%s'."
#, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "Could not find network input map '%s'."
#, fuzzy
-#~ msgid "could not read range file"
+msgid "error opening raster map [%s]."
+msgstr "Nome di mappa(e) raster esistente(i)"
#, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Topology is not available"
#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Cannot describe table %s"
#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Patching file <%s@%s>"
#, fuzzy
-#~ msgid "Swap temp files"
+msgid "[%d] files patched"
+msgstr "%d records aggiornati"
#, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Column type not supported"
#, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "Could not open vector map <%s>"
#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+msgid "Could not close new 3d raster map"
#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
+msgid "%s: cellfile [%s] not found."
#, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgid "Unable to open cellfile [%s]."
#, fuzzy
-#~ msgid "Error writing output map"
+msgid "Unable to open the temporary file."
#, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "Unable to open raster map [%s]."
#, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "Unable to find raster [%s]."
#, fuzzy
-#~ msgid "no rules specified"
+msgid "name for new raster map"
+msgstr "Nome di un nuovo file raster"
#, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Output GRASS image file"
#, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Resulting output map"
#, fuzzy
-#~ msgid "%s - illegal name "
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Input vector map"
#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
+msgid "%s: ERROR can't open tempfile"
#, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "unable to find raster map [%s]"
#, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "Normalizzata"
+msgid "<%s> raster map not found"
#, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "<%s> unable to open raster map"
#, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
+msgid "Cannot find vector map [%s]"
#, fuzzy
-#~ msgid "Could not open elevation map"
+msgid "%s - can't open raster map"
#, fuzzy
-#~ msgid "Could not open output map"
+msgid "Can't get row %d from raster map %s"
#, fuzzy
-#~ msgid "unable to close output map"
+msgid "%s - raster map not found"
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "string representing no data cell value"
#, fuzzy
-#~ msgid "Database's name couldn't be read"
+msgid "File name of classification result"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
+msgid "quiet"
+msgstr "silenzioso"
#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "<%s> - illegal output file name"
#, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
-#~ msgstr ""
+msgid "%s: <%s> reference map not found"
-#, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "Base raster map"
+msgstr "Mappa raster di base"
#, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "%s: raster map not found"
#, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Problem opening input file [%s]"
#, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Problem opening output file [%s]"
#, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "can't write category file for <%s>"
#, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "%s: can't open tempfile"
#, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Unable to read row %d in raster map [%s]"
#, fuzzy
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Nome di mappa(e) raster esistente(i)"
+msgid "Output verbosely"
#, fuzzy
-#~ msgid "Topology is not available"
+msgid "Can't open raster map %s"
#, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "It could not be find input map <%s>"
#, fuzzy
-#~ msgid "Patching file <%s@%s>"
+msgid "It could not be found input map <%s>"
#, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "%d records aggiornati"
+msgid "Cannot find input map <%s>"
#, fuzzy
-#~ msgid "Column type not supported"
+msgid "Input vector map <%s> not found."
#, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "Category ranges: e.g. 1,3-8,13"
#, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgid "Writing attributes ...\n"
#, fuzzy
-#~ msgid "Could not close new 3d raster map"
+msgid "Could not open ascii file <%s>"
#, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "Could not open temp file <%s>"
#, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "List available formats and exit"
+msgstr "Visualizza i formati supportati ed esci"
#, fuzzy
-#~ msgid "Unable to open the temporary file."
+msgid "Vector map <%s> not fould"
#, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "SVG output file"
#, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Could not find vector '%s'"
#, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "Nome di un nuovo file raster"
+msgid "Could not find vector map %s"
#, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "Unable to get row %d from <%s>"
+msgstr "impossibile aprire <%s>"
-#, fuzzy
-#~ msgid "Resulting output map"
+msgid "Raster output file"
+msgstr "File raster in output"
#, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgid "Writing raster map ... "
-#, fuzzy
-#~ msgid "Input vector map"
+msgid "Keep existing color table"
+msgstr "Mantieni la tabella colore esistente"
+msgid "List rules"
+msgstr "Mostra regole"
#, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
+msgid " %d rows, %d cols."
#, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "%s in %s - can't read header file"
#, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "raster <%s> non trovato"
+msgid "%s - unable to create raster map"
#, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "%s - unable to create category file"
+msgstr "Valore da scrivere per null"
#, fuzzy
-#~ msgid "Cannot find vector map [%s]"
+msgid "Vector map with points for which to modify the attribute table"
#, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr ""
+"Nome della mappa vettoriale di punti della quale editare la tabella attributi"
#, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Path to an output file"
#, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "Name of existing raster map to be displayed"
+msgstr "Nome di una mappa raster esistente"
-#~ msgid "string representing no data cell value"
+msgid "driver name:"
+msgstr "nome del driver:"
#, fuzzy
-#~ msgid "File name of classification result"
+msgid "could not find input map <%s>"
+msgstr "Non riesco a trovare il file raster %s"
-#~ msgid "quiet"
-#~ msgstr "silenzioso"
+#, fuzzy
+msgid "unable to open raster map [%s]"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
#, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "cannot get layer info for vector map"
#, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "cannot open database %s by driver %s"
-#~ msgid "Base raster map"
-#~ msgstr "Mappa raster di base"
+#, fuzzy
+msgid "cannot select data from table"
#, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "cannot create table: %s"
#, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "cannot create index"
#, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "cannot grant privileges on table %s"
#, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "column type not supported"
+msgstr "driver pg: colonna '%s', di tipo %d non supportata"
#, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "Cannot find vector map"
#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Cannot find raster map"
#, fuzzy
-#~ msgid "Output verbosely"
-#~ msgstr "Nome del driver in output"
+msgid "Cannot open raster map"
#, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open temp file %s"
#, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "Error while reading cell map."
#, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "Error while writing new cell map."
+msgstr "Errore nella scrittura della grid. Disco pieno?"
#, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Error in opening output file <%s>"
#, fuzzy
-#~ msgid "Input vector map <%s> not found."
+msgid "Unable to find input cell map <%s>"
#, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Error in opening input file <%s>"
#, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Unable to open cell man <%s> for input.\n"
#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Unable to open cell map <%s> for output.\n"
#, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Unable to read map raster row %d"
+msgstr "Nome del raster"
#, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "Visualizza i formati supportati ed esci"
+msgid "Unable to write color table to raster [%s]"
#, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Cannot find map %s"
#, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "File di input"
+msgid "Cannot open map %s"
+msgstr "Non riesco ad impostare user/password"
+msgid "Name of predefined rules file"
+msgstr "Nome del file con le regole predefinite"
#, fuzzy
-#~ msgid "Could not find vector '%s'"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr ""
+"** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%d:%"
+"d **\n"
#, fuzzy
-#~ msgid "Could not find vector map %s"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr ""
+"** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %d %"
+"d **\n"
#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "no such value"
+msgstr "** attenzione: non trovo il valore **\n"
-#~ msgid "Raster output file"
-#~ msgstr "File raster in output"
+#, fuzzy
+msgid "%s:line %d:%s"
+msgstr "%s:linea %d:%s\n"
#, fuzzy
-#~ msgid "Writing raster map ... "
-#~ msgstr "Nome del driver in input"
+msgid "bad color specification"
+msgstr "** definizione errata del colore **\n"
-#~ msgid "Keep existing color table"
-#~ msgstr "Mantieni la tabella colore esistente"
+#, fuzzy
+msgid "%s - unknown color"
-#~ msgid "List rules"
-#~ msgstr "Mostra regole"
+msgid "Valid colors are:\n"
+msgstr "I colori validi sono:\n"
#, fuzzy
-#~ msgid " %d rows, %d cols."
+msgid "Unable to find cover map <%s>"
#, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s: reading category file for %s"
#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#~ msgstr "Nome della mappa raster risultante"
+msgid "%s: unable to open raster map [%s]"
#, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s: unable to create raster map [%s]"
+msgstr "Nome della mappa raster risultante"
#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "Unable to open database %s with driver %s"
+msgstr "Non riesco ad aprire il database %s col driver %s"
#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nome della mappa vettoriale di punti della quale editare la tabella "
-#~ "attributi"
+msgid "%s: Unable to read raster map [%s]"
#, fuzzy
-#~ msgid "Path to an output file"
+msgid "%s: unable to open raster map <%s>"
#, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Nome di una mappa raster esistente"
+msgid "%s: Failed to read raster row %d"
-#~ msgid "driver name:"
-#~ msgstr "nome del driver:"
#, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "Unable to find [%s]."
#, fuzzy
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Unable to read cats table for %s"
#, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "Could not open raster <%s>"
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr ""
+"Nome del tipo carattere (non supportato in maniera interattiva, in tal caso "
+"vedi il flag -l) oppure percorso del font TrueType (completo del nome del "
+"file)"
#, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "%s: o_open_file: raster map %s not found"
#, fuzzy
-#~ msgid "cannot select data from table"
+msgid "%s: o_open_file: could not open raster map %s in %s"
#, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "No record for category for [%d]"
#, fuzzy
-#~ msgid "cannot create index"
+msgid "Error reading ASCII file <%s>"
#, fuzzy
-#~ msgid "cannot grant privileges on table %s"
+msgid "Error reading categories: <%s>"
#, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgid "No lines found"
+msgstr "Non ho trovato nulla.\n"
#, fuzzy
-#~ msgid "Cannot find vector map"
+msgid "Could not find input vector '%s'"
#, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Failed opening output vector map '%s'"
#, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Error reading ascii file: [%s]"
#, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "%s: <%s> vector map not found"
#, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Vector <%s> could not be open"
#, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Errore nella scrittura della grid. Disco pieno?"
+msgid "Raster <%s> could not be open."
+msgstr "raster <%s> non trovato"
#, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Interpolation: nsply = %d"
+msgstr "Mostra il titolo del file raster"
#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "%s: Dropping <s>"
#, fuzzy
-#~ msgid "Error in opening input file <%s>"
+msgid "Interpolation was a success!"
#, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "Utilizza la regione corrente"
#, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
+msgid "CrossCorrelation: It shouldn't take too long."
+msgstr "Non riesco a selezionare dati dalla tabella"
#, fuzzy
-#~ msgid "Unable to read map raster row %d"
-#~ msgstr "Nome del raster"
+msgid "%s -- illegal output file name"
#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
+msgid "Sorry, with method '%s' you have to define an output map."
#, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Maximum number of iteration"
#, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Existing raster map name"
+msgstr "Nome del raster map esistente"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nome del file con le regole predefinite"
#, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%"
-#~ "d:%d **\n"
+msgid "%s - can't read raster cellhd"
#, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %"
-#~ "d %d **\n"
+msgid "error reading cell data"
#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attenzione: non trovo il valore **\n"
+msgid "Done!"
+msgstr "Fatto.\n"
#, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:linea %d:%s\n"
+msgid "No line found."
#, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** definizione errata del colore **\n"
+msgid "Nothing Found."
#, fuzzy
-#~ msgid "%s - unknown color"
+msgid "Could not open ascii file [%s]"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "I colori validi sono:\n"
+msgid "vector map to be created"
+msgstr "file vettoriale da creare"
#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Conversion of [%s] to vector map ..."
+msgstr "Mappa raster risultante"
#, fuzzy
-#~ msgid "%s: reading category file for %s"
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "EPSG code of projection to be created"
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "must be even number of names"
+msgstr "deve essere un numero pari di nomi"
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
+msgid "ERROR: <%s> not found\n"
+msgstr "ERRORE: <%s> non trovato\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "ERRORE: <%s> nome illegale\n"
#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "Non riesco ad aprire il database %s col driver %s"
+msgid "Cannot open toolbox: %s"
#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "Cannot open toolbox."
#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "Vector map(s) -- source for composite"
+msgstr "File di input"
#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "New vector composite"
+msgstr "Nome di un file vettoriale in output"
#, fuzzy
-#~ msgid "Unable to find [%s]."
+msgid ""
+"Name of output vector points map (if not specified, the program writes to "
+"standard output)"
+msgstr ""
#, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Vector map '%s' not found"
#, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "vector, segment, curvature"
+msgstr "vettore da rimuovere"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nome del tipo carattere (non supportato in maniera interattiva, in tal "
-#~ "caso vedi il flag -l) oppure percorso del font TrueType (completo del "
-#~ "nome del file)"
#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
+msgid "%s\n"
+msgstr "%s Sposta\n"
#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "Raster '%s' not found"
#, fuzzy
-#~ msgid "No record for category for [%d]"
+msgid "Cold not get raster row"
#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
+msgid "ILLEGAL Resolution!"
+msgstr "Risoluzione"
#, fuzzy
-#~ msgid "Error reading categories: <%s>"
+msgid "Error opening raster map %s"
#, fuzzy
-#~ msgid "No lines found"
-#~ msgstr "Non ho trovato nulla.\n"
+msgid "Copy raster map <%s> into the memory"
#, fuzzy
-#~ msgid "Could not find input vector '%s'"
+msgid "Query layer"
#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Query column name"
#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Enter imagery group to be registered"
+msgstr "Nome della mappa raster"
+msgid "L: from M: to R: quit\n"
+msgstr "L: da M: a R: esci\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"Dove %s è uno di:\n"
#, fuzzy
-#~ msgid "%s: <%s> vector map not found"
+msgid "%s: - no such database %s\n"
#, fuzzy
-#~ msgid "Vector <%s> could not be open"
+msgid "No database updates."
#, fuzzy
-#~ msgid "Raster <%s> could not be open."
+msgid "Input aspect file"
+msgstr "Nome della tabella in output"
#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "Mostra il titolo del file raster"
+msgid "Input barrier file"
#, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "Quiet operation"
+msgstr "%s Esce dal menu\n"
#, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "nessuno"
#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "Utilizza la regione corrente"
+msgid ""
+"\n"
+"Done\n"
+msgstr "Fatto\n"
#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "Open vector 3d raster map %s"
#, fuzzy
-#~ msgid "%s -- illegal output file name"
+msgid "Open 3d raster map %s"
#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Vector import complete"
#, fuzzy
-#~ msgid "Maximum number of iteration"
+msgid "Unable to create raster map for [%s]"
+msgid "Done\n"
+msgstr "Fatto\n"
#, fuzzy
-#~ msgid "Existing raster map name"
-#~ msgstr "Nome del raster map esistente"
+msgid "Open Raster file %s in Mapset %s"
#, fuzzy
-#~ msgid "%s - can't read raster cellhd"
+msgid "Open 3d raster map %s\n"
#, fuzzy
-#~ msgid "error reading cell data"
+msgid "Open elev raster map %s\n"
#, fuzzy
-#~ msgid "Done!"
+msgid "Could not open map %s\n"
+msgid "Bin raster map to be imported"
+msgstr "Il file raster bin è stato importato"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr ""
+"La dimensione della regione è inferiore rispetto al valore di minreg, non "
+"verrà visualizzato nulla.\n"
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr ""
+"La dimensione della regione è superiore rispetto al valore di maxreg, non "
#, fuzzy
-#~ msgid "No line found."
+msgid "Maximum distance"
+msgstr "Livello massimo di contorno"
#, fuzzy
-#~ msgid "Nothing Found."
+msgid "Makes 3D trees from input point vector map"
#, fuzzy
-#~ msgid "Could not open ascii file [%s]"
+msgid "Name of the column with tree crown width"
+msgstr "Nome del file raster in input"
-#~ msgid "vector map to be created"
-#~ msgstr "file vettoriale da creare"
#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "Mappa raster risultante"
+msgid "Cannot select attributes for point #%d"
+msgstr "Non riesco a mostrare i database"
#, fuzzy
-#~ msgid "EPSG code of projection to be created"
+msgid "Right: "
+msgstr " Destro: esce\n"
-#~ msgid "must be even number of names"
-#~ msgstr "deve essere un numero pari di nomi"
+msgid "%s Pan\n"
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERRORE: <%s> non trovato\n"
+msgid "%s Quit\n"
+msgstr "%s Esce\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERRORE: <%s> nome illegale\n"
+msgid "Draw geographic grid"
+msgstr "Disegna griglia geografica"
#, fuzzy
-#~ msgid "Cannot open toolbox: %s"
+msgid "Quiet mode"
#, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "%s[%d]: No raster map specified."
#, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
+msgid "done."
+msgstr "Fatto.\n"
#, fuzzy
-#~ msgid "New vector composite"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "name for new binary vector map (omit for display to stdout)"
#, fuzzy
-#~ msgid ""
-#~ "Name of output vector points map (if not specified, the program writes to "
-#~ "standard output)"
-#~ msgstr ""
-#~ "attributi"
+msgid "Name for G3d raster map"
#, fuzzy
-#~ msgid "Vector map '%s' not found"
+msgid "No output maps"
#, fuzzy
-#~ msgid "vector, segment, curvature"
-#~ msgstr "vettore da rimuovere"
+msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
+msgstr ""
+"Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
#, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "%s Sposta\n"
+msgid "Data type"
+msgstr "Tipo di grafico"
#, fuzzy
-#~ msgid "Raster '%s' not found"
+msgid "unable to open new L map layer."
#, fuzzy
-#~ msgid "Cold not get raster row"
+msgid "unable to open new S map layer."
#, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Risoluzione"
+msgid "Do not export long colortable"
#, fuzzy
-#~ msgid "Error opening raster map %s"
+msgid "No raster nor vector output"
+msgstr "Nome del file in output"
+#, fuzzy
+msgid "Bad format in initial exposusre station file for group [%s]"
+#, fuzzy
+#~ msgid "Not enough room in history file"
+#~ msgid "New MAPSET name"
+#~ msgstr "Nome del nuovo MAPSET"
#, fuzzy
-#~ msgid "Copy raster map <%s> into the memory"
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "mostra i parametri della connessione in uso ed esce"
#, fuzzy
-#~ msgid "Query layer"
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "raster <%s> non trovato"
#, fuzzy
-#~ msgid "Query column name"
+#~ msgid "Name of workspace file"
+#~ msgstr "Nome del filtro file"
#, fuzzy
-#~ msgid "Enter imagery group to be registered"
-#~ msgstr "Nome della mappa raster"
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "impossibile aprire <%s>"
-#~ msgid "L: from M: to R: quit\n"
-#~ msgstr "L: da M: a R: esci\n"
#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
#~ msgstr ""
-#~ "\n"
-#~ "Dove %s è uno di:\n"
+#~ "Genera raster della pendenza, esposizione, curvature e le derivate "
+#~ "parziali da un raster con valori dell'elevazione. Esposizione è calcolata "
+#~ "in senso antiorario partendo dall'est."
#, fuzzy
-#~ msgid "%s: - no such database %s\n"
+#~ msgid "Output slope filename"
+#~ msgstr "Nome della tabella in output"
#, fuzzy
-#~ msgid "No database updates."
+#~ msgid "Output aspect filename"
#, fuzzy
-#~ msgid "Input aspect file"
-#~ msgstr "Nome della tabella in output"
+#~ msgid "Output profile curvature filename"
+#~ msgstr "Nome del driver in output"
#, fuzzy
-#~ msgid "Input barrier file"
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "Nome del database in output"
#, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "%s Esce dal menu\n"
+#~ msgid "Creating support files..."
+#~ msgstr "Errore nella lettura del file dbmscap\n"
#, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "nessuno"
+#~ msgid "Elevation products for mapset [%s] in [%s]"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr "Fatto\n"
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Non riesco a descrivere la tabella"
#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+#~ msgid "Input elevation map"
+#~ msgstr "Mostra il titolo del file raster"
#, fuzzy
-#~ msgid "Open 3d raster map %s"
+#~ msgid "Output shaded relief map name"
#, fuzzy
-#~ msgid "Vector import complete"
+#~ msgid "Layer number of data column"
#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcola statistiche univariate da un raster basandosi su poligoni "
+#~ "vettoriale e carica le statistiche in una nuova colonna della tabella "
+#~ "degli attributi."
-#~ msgid "Done\n"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "Nome della mappa raster che contiene i risultati"
#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
+#~ msgid "Name of the elevation raster map [m]"
+#~ msgstr "Nome del file raster in input"
#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+#~ msgid "Output water depth raster map [m]"
+#~ msgid "Output elevation raster map"
+#~ msgstr "Output mappa raster dell'elevazione"
#, fuzzy
-#~ msgid "Open elev raster map %s\n"
+#~ msgid "Input elevation raster map"
+#~ msgstr "Mappa raster risultante"
#, fuzzy
-#~ msgid "Could not open map %s\n"
+#~ msgid "Input aspect raster map"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Il file raster bin è stato importato"
+#, fuzzy
+#~ msgid "Input barrier raster map"
+#~ msgstr "Nome del driver in input"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è inferiore rispetto al valore di minreg, non "
-#~ "verrà visualizzato nulla.\n"
+#, fuzzy
+#~ msgid "Output flowline vector map"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è superiore rispetto al valore di maxreg, non "
+#~ msgid "Name of elevation raster map"
+#~ msgstr "Nome della mappa raster dell'elevazione"
#, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "Livello massimo di contorno"
+#~ msgid "East coordinate (point of interest, default: map center)"
+#~ msgstr "Utilizzando le coordinate del centro della mappa\n"
#, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
+#~ msgid "North coordinate (point of interest, default: map center)"
#, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "Nome del file raster in input"
+#~ msgid "(i) Elevation map"
+#~ msgstr "Mappa raster in input"
+#~ msgid "Output elevation raster map after filling"
+#~ msgstr "Visualizza il raster delle altezze dopo il riempimento"
#, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "Non riesco a mostrare i database"
+#~ msgid "Reading map..."
#, fuzzy
-#~ msgid "Right: "
-#~ msgstr " Destro: esce\n"
+#~ msgid "Failed to guess site file format\n"
+#~ msgstr "File di input"
-#~ msgid "%s Pan\n"
+#~ msgid "Name of raster map to contain results"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s Esce\n"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Disegna griglia geografica"
#, fuzzy
-#~ msgid "Quiet mode"
+#~ msgid "The map N grid coordinates"
#, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
+#~ msgid "<%s> has not been created in database."
+#~ msgstr "La tabella <%s> non esiste nel database <%s>"
#, fuzzy
-#~ msgid "done."
+#~ msgid "Unable to access table <%s>"
+#~ msgstr "Nome della mappa raster risultante"
+#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+#~ msgstr "Converte raster 3D (G3D) in formato VTK-Ascii"
+#~ msgid ""
+#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
+#~ "of the currently defined region."
+#~ msgstr ""
+#~ "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel "
+#~ "della region corrente"
+#~ msgid ""
+#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+#~ "resolution of the currently defined region."
+#~ msgstr ""
+#~ "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione "
+#~ "del pixel definita della region corrente"
#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+#~ msgid "Band to select"
+#~ msgstr "Nessun monitor selezionato"
#, fuzzy
-#~ msgid "Name for G3d raster map"
+#~ msgid "Attribute table column with values to interpolate (if layer>0)"
+#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
#, fuzzy
-#~ msgid "No output maps"
+#~ msgid "M.Q. solution"
+#~ msgstr "Risoluzione"
+#~ msgid "Import SRTM HGT files into GRASS"
+#~ msgstr "Importa file SRTM HGT in GRASS"
#, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr ""
-#~ "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e "
-#~ "255!\n"
+#~ msgid "unable to open new LS factor map layer."
#, fuzzy
-#~ msgid "Data type"
-#~ msgstr "Tipo di grafico"
+#~ msgid "unable to open new S factor map layer."
#~ msgid ""
#~ "\n"
@@ -36248,14 +36270,6 @@
#~ msgstr "Mappa(e) raster da leggere"
#, fuzzy
-#~ msgid "unable to open new L map layer."
-#, fuzzy
-#~ msgid "unable to open new S map layer."
-#, fuzzy
#~ msgid "raster, resample"
@@ -36283,10 +36297,6 @@
#, fuzzy
-#~ msgid "Do not export long colortable"
-#, fuzzy
#~ msgid "raster, null data"
@@ -36401,10 +36411,6 @@
#~ msgid "Query layer number (read from)"
#~ msgstr "Numero di layer"
-#, fuzzy
-#~ msgid "No raster nor vector output"
-#~ msgstr "Nome del file in output"
#~ msgid "Vector based generalization."
#~ msgstr "Generalizzazione vettoriale"
@@ -36865,10 +36871,6 @@
#~ msgstr "Sto copiando le tabelle..."
#, fuzzy
-#~ msgid "Bad format in initial exposusre station file for group [%s]"
-#, fuzzy
#~ msgid "Cannot generate the transformation equation."
#~ msgstr "Stampa matrice di correlazione"
@@ -36887,3 +36889,345 @@
#, fuzzy
#~ msgid "Unable to open file in the 'cell_misc' directory"
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Converte un raster 3D in un file di testo ASCII"
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "Esporta raster GRASS 3D in un file Vis5D tridimensionale"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "Esporta raster GRASS in un file GRIDATB.FOR (TOPMODEL)"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "Nome della mappa raster"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "Converte un raster in un file di testo ASCII"
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgid "Import GDAL supported raster file into a binary raster map layer."
+#~ msgstr "Importa file raster supportato da GDAL in un layer raster binario"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Nome di un file vettoriale in output"
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Converte un raster in formato VTK-Ascii"
+#, fuzzy
+#~ msgid "raster, terrain"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Nome di un nuovo file raster"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Visualizza il raster della direzione"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del "
+#~ "pixel della region corrente"
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+#, fuzzy
+#~ msgid "The height of the river bed in [m]"
+#, fuzzy
+#~ msgid "The height of the drainage bed in [m]"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "Nome del file in output"
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programma di conversione per serie di file raster in MPEG"
+#~ msgid "Name of existing raster map containing elevation surface"
+#~ msgstr "Nome di una mappa raster contenente una superfice di altezze"
+#~ msgid "Output direction raster map"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "Visualizza il raster delle aree problematiche"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "Comando per la generazione di superfice da contorni rasterizzati"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Crea/modifica la tabella dei colori associata a un raster"
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Nome della mappa raster da cui copiare la tabella colore"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "File raster ascii da importare"
+#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+#~ msgstr "Esporta raster in Virtual Reality Modeling Language (VRML)"
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "Genera un raster della distanza dagli elementi del layer di input"
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Crea un nuovo layer dove i valori della categoria sono basati sulla "
+#~ "riclassificazione delle categorie esistenti in un altro raster"
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "Mappa raster da riclassificare"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "Converte un raster in un vettore"
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "Converte un file raster ASCII in un raster binario"
+#, fuzzy
+#~ msgid "Output topographic index map"
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Converte un file raster ESRI ARC/INFO acii (GRID) in un raster (binario)"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "Nome del raster"
+#~ msgid "New LOCATION name (not location path)"
+#~ msgstr "Nome della nuova LOCATION (non il percorso della location)"
+#~ msgid "New GISDBASE (full path to the directory where the new location is)"
+#~ msgstr ""
+#~ "Nuovo GISDBASE (percorso intero della directory dove la nuova location è "
+#~ "situata)"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitor: waitpid: atteso %d ma ricevuto %d\n"
+#, fuzzy
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Devono essere fornite sia l'opzione 'from_table' che 'select' "
+#, fuzzy
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "Nome del raster map in output"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "Converte vettore OGR in vettore GRASS"
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "Impossibile usare la colonna <%s>"
+#, fuzzy
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Inserisci il vettore con i punti di controllo"
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr "Crea un vettore da file ASCI points o ASCII vector"
+#, fuzzy
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#, fuzzy
+#~ msgid "Vector map <%s> is connected by:"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#, fuzzy
+#~ msgid "Width and height of output image"
+#~ msgstr "Spessore dell'evidenziazione"
+#~ msgid "Surface"
+#~ msgstr "Superficie"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "colonne: %d"
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr ""
+#~ "Stampa/imposta la connessione generale al DB per il mapset corrente ed "
+#~ "esce."
+#~ msgid "Name of file with sql statement"
+#~ msgstr "Nome del file con comandi sql"
+#, fuzzy
+#~ msgid "raster, elevation"
+#~ msgstr "Mappa(e) raster da leggere"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "Visualizza i formati supportati ed esci"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "Visualizza la pagina di supporto HTML di GRASS "
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importa vettori Mapgen o Matlab in GRASS"
+#, fuzzy
+#~ msgid "Configuration editor for r.li.'index'"
+#~ msgstr "Nome del file di output"
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importa file SPOT VGT NDVI in un raster"
+#, fuzzy
+#~ msgid "Layer where to add column"
+#, fuzzy
+#~ msgid "stay with source monitor"
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_ja.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -14,7 +14,7 @@
"Project-Id-Version: grassmods_ja\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-08-29 12:41+0200\n"
-"PO-Revision-Date: 2010-02-19 17:56+0900\n"
+"PO-Revision-Date: 2010-03-03 14:00+0900\n"
"Last-Translator: AkiraTaniguchi <taniguti at apptec.co.jp>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -3047,7 +3047,7 @@
#: ../vector/v.lidar.correction/main.c:275
#, c-format
msgid "adjusted EW splines %d"
-msgstr ""
+msgstr "æ±è¥¿ã®ã¹ãã©ã¤ã³ã®èª¿æ´ %d"
#: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
#: ../vector/v.surf.bspline/main.c:420
@@ -3055,7 +3055,7 @@
#: ../vector/v.lidar.correction/main.c:276
#, c-format
msgid "adjusted NS splines %d"
-msgstr ""
+msgstr "ååã®ã¹ãã©ã¤ã³ã®èª¿æ´ %d"
#: ../raster/r.resamp.bspline/main.c:268 ../raster/r.resamp.bspline/main.c:329
#, fuzzy
@@ -3103,9 +3103,9 @@
#: ../vector/v.lidar.edgedetection/main.c:351
#: ../vector/v.lidar.growing/main.c:247
#: ../vector/v.lidar.correction/main.c:331
-#, fuzzy, c-format
+#, c-format
msgid "subregion %d of %d"
-msgstr "åæ ¼, çµé %d of %d: "
+msgstr "ãµããªã¼ã¸ã§ã³ %d ã® %dã"
#: ../raster/r.resamp.bspline/main.c:589
#, fuzzy
@@ -3115,9 +3115,8 @@
"ã. "
#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
-#, fuzzy
msgid "Writing output..."
-msgstr "å°å³ãæ¸åº... "
+msgstr "åºåä¸..."
#: ../raster/r.resamp.bspline/crosscorr.c:160
#, fuzzy, c-format
@@ -6297,7 +6296,7 @@
#: ../raster/r.watershed/front/main.c:181
#, fuzzy
msgid "Convergence factor for MFD (1-10)"
-msgstr "é«ãã®å¼·èª¿"
+msgstr "z-å¤ã®å¤æä¿æ°"
#: ../raster/r.watershed/front/main.c:183
msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
@@ -6378,17 +6377,20 @@
msgstr "ã»ã¯ã·ã§ã³ %d: åæ°´å®ç¾©"
#: ../raster/r.watershed/ram/sg_factor.c:14
+#, fuzzy
msgid "SECTION 4: RUSLE LS and/or S factor determination."
-msgstr ""
+msgstr "ã»ã¯ã·ã§ã³ 4: é·ãã»å¾æã®æ±ºå®"
#: ../raster/r.watershed/ram/do_cum.c:16 ../raster/r.watershed/seg/do_cum.c:20
+#, fuzzy
msgid "SECTION 3: Accumulating Surface Flow with SFD."
-msgstr ""
+msgstr "ã»ã¯ã·ã§ã³ 3: 表層æµã®ç´¯è¨"
#: ../raster/r.watershed/ram/do_cum.c:118
#: ../raster/r.watershed/seg/do_cum.c:138
+#, fuzzy
msgid "SECTION 3: Accumulating Surface Flow with MFD."
-msgstr ""
#: ../raster/r.watershed/ram/do_cum.c:312
#: ../raster/r.watershed/seg/do_cum.c:364
@@ -8945,7 +8947,7 @@
#: ../raster/r.out.gdal/main.c:139
#, fuzzy
msgid "Do not write GDAL standard colortable"
-msgstr "ã«ã©ã¼ãã¼ãã«ã䏿¸ãããªã"
+msgstr "大ãããµã¤ãºã®ã«ã©ã¼ãã¼ãã«ãã¨ã¯ã¹ãã¼ãããªã"
#: ../raster/r.out.gdal/main.c:140
msgid "Only applicable to Byte or UInt16 data types."
@@ -9036,7 +9038,7 @@
#: ../raster/r.out.gdal/main.c:354
#, fuzzy, c-format
msgid "Could not read data range of raster <%s>"
-msgstr "åºåãããã¡ã¤ã«"
+msgstr "ã©ã¹ã¿ã¼ããã <%s> ã®ç¯å²ãèªã¿è¾¼ãã¾ãã"
#: ../raster/r.out.gdal/main.c:411
#, c-format
@@ -9071,13 +9073,13 @@
#: ../raster/r.out.gdal/main.c:465 ../raster/r.out.gdal/main.c:508
#, fuzzy
msgid "Forcing raster export."
-msgstr "å
¥åãããã¡ã¤ã«"
+msgstr "ã©ã¹ã¿ã¼ãã¨ã¯ã¹ãã¼ã"
#: ../raster/r.out.gdal/main.c:467 ../raster/r.out.gdal/main.c:481
#: ../raster/r.out.gdal/main.c:510 ../raster/r.out.gdal/main.c:514
#, fuzzy
msgid "Raster export aborted."
-msgstr "å
¥åãããã¡ã¤ã«"
#: ../raster/r.out.gdal/main.c:491
msgid "Checking GDAL data type and nodata value"
@@ -9086,7 +9088,7 @@
#: ../raster/r.out.gdal/main.c:494
#, fuzzy, c-format
msgid "Checking options for raster map <%s> (band %d)..."
-msgstr "å
¥åãããã¡ã¤ã«"
+msgstr "ã©ã¹ã¿ã¼ããã <%s> ãåºåä¸ (ãã³ã %d)..."
#: ../raster/r.out.gdal/main.c:535
msgid "Output file name not specified"
@@ -9112,7 +9114,7 @@
#: ../raster/r.out.gdal/main.c:579
#, fuzzy
msgid "Exporting to GDAL raster"
+msgstr "GDALãã¼ã¿åã«ã¨ã¯ã¹ãã¼ã: %s"
#: ../raster/r.out.gdal/main.c:582
#, c-format
@@ -9155,9 +9157,9 @@
#: ../raster/r.out.gdal/main.c:634 ../raster/r.out.gdal/main.c:646
#: ../raster/r.out.gdal/main.c:659 ../raster/r.out.gdal/main.c:672
#: ../raster/r.out.gdal/main.c:684 ../raster/r.out.gdal/main.c:697
-#, fuzzy, c-format
+#, c-format
msgid "Range to be exported: %g - %g"
-msgstr "å
¥åãããã¡ã¤ã«"
+msgstr ""
#: ../raster/r.out.gdal/main.c:681 ../raster/r.out.gdal/export_band.c:530
#, c-format
@@ -9211,12 +9213,15 @@
msgstr "ã©ã¹ã¿ã¼ãã³ãããããèªã¿è¾¼ãããã®ãããã¡ãå²ãå½ã¦ããã¾ãã"
#: ../raster/r.out.gdal/export_band.c:179
-#, c-format
+#, fuzzy, c-format
msgid ""
"Input raster map contains cells with NULL-value (no-data). The value %d will "
"be used to represent no-data values in the input map. You can specify a "
"nodata value with the %s option."
msgstr ""
+"å
¥åããã©ã¹ã¿ã¼ãããã¯NULLå¤ï¼ãã¼ã¿ç¡ãï¼ã»ã«ãå«ãã§ãã¾ãï¼ãã®æå®ãã"
+"ããããã§å¤ %d ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤ãæå®"
+"ã§ãã¾ã"
#: ../raster/r.out.gdal/export_band.c:184
#, fuzzy, c-format
@@ -9262,7 +9267,7 @@
#: ../raster/r.out.gdal/export_band.c:560
#, fuzzy, c-format
msgid "Raster map <%s> range: %g - %g"
-msgstr "���."
+msgstr "ã©ã¹ã¿ã¼ããã <%s> ã使ããã¾ãã"
#: ../raster/r.null/main.c:60
#, fuzzy
@@ -10983,7 +10988,6 @@
msgstr "éãã¡ã¤ã«GDAL ãã¼ã¿ã½ã¼ã¹å"
#: ../raster/r.external/main.c:547
-#, fuzzy
msgid "Band to select (default: all)"
msgstr "鏿ãããã³ã(ããã©ã«ã:ãã¹ã¦ã®ãã³ã)"
@@ -12831,7 +12835,7 @@
#: ../general/g.message/main.c:52 ../general/g.message/main.c:57
#, fuzzy
msgid "Type"
-msgstr "ãã¡ã¤ã«ã®ç¨®é¡"
+msgstr "ã¿ã¤ãï¼%s"
#: ../general/g.message/main.c:43
#, fuzzy
@@ -12884,7 +12888,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "å
¥åãããã¡ã¤ã«"
+msgstr "å
¥åããããéããã¾ãã"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -15744,7 +15748,7 @@
#: ../display/d.text/main.c:172
#, fuzzy
msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr "ç·ã®è²"
+msgstr "ããã¹ãã«ã©ã¼, æ¨æºGRASSã«ã©ã¼ã¾ãã¯R:G:B triplet"
#: ../display/d.text/main.c:181
msgid "The screen line number on which text will begin to be drawn"
@@ -18599,7 +18603,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
+msgstr "3Dåºåã使ãã¾ã"
#: ../vector/v.random/main.c:111
msgid "Maximum z height (needs -z flag or column name)"
@@ -18901,9 +18905,8 @@
#: ../vector/v.lidar.edgedetection/main.c:193
#: ../vector/v.lidar.edgedetection/main.c:205
#: ../vector/v.lidar.correction/main.c:169
-#, fuzzy
msgid "Old auxiliar table could not be dropped"
-msgstr "���"
+msgstr "å¤ãAuxiliarãã¼ãã«ãåé¤ã§ãã¾ããã§ãã"
#: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
#: ../vector/v.surf.bspline/main.c:282
@@ -18913,21 +18916,20 @@
#: ../vector/v.outlier/main.c:183 ../vector/v.lidar.edgedetection/main.c:224
#: ../vector/v.lidar.correction/main.c:187
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map <%s> is not 3D!"
msgstr "ãã¯ãã«ããã <%s> 㯠3D ã§ã¯ããã¾ãã"
#: ../vector/v.outlier/main.c:193 ../vector/v.surf.bspline/main.c:246
#: ../vector/v.lidar.edgedetection/main.c:234
#: ../vector/v.lidar.correction/main.c:197
-#, fuzzy
msgid "No points in current region!"
-msgstr "ç¾å¨ã®å°åè¨å®ãä½¿ç¨ "
+msgstr "ã«ã¬ã³ããªã¼ã¸ã§ã³ã«ãã¤ã³ããããã¾ãã"
#: ../vector/v.outlier/main.c:240
-#, fuzzy, c-format
+#, c-format
msgid "It was impossible to create <%s> table."
-msgstr "使ã§ãã¾ããã§ãã <%s>"
+msgstr "ãã¼ãã«ã使ã§ãã¾ããã§ãã <%s>"
#: ../vector/v.outlier/main.c:390 ../vector/v.lidar.edgedetection/main.c:414
#: ../vector/v.lidar.correction/main.c:400
@@ -18936,11 +18938,10 @@
#: ../vector/v.outlier/main.c:402
msgid "Outlier detection"
-msgstr ""
+msgstr "å¤ã夿¤åº"
#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
#: ../vector/v.lidar.correction/main.c:426
-#, fuzzy
msgid "No data within this subregion. Consider changing the spline step."
msgstr ""
"ãã®ãµãã¾ã¼ã³å
ã«ãã¼ã¿ã¯ããã¾ãã. ã¹ãã©ã¤ã³ã¹ãããã夿´ãã¦ã¿ã¦ãã ã"
@@ -20437,9 +20438,8 @@
msgstr "両æ¹ã§ã¯ãªãããã¯ãã«ã¾ãã¯ã©ã¹ã¿ã¼åºåã®ã©ã¡ããã鏿ãã¦ãã ãã"
#: ../vector/v.surf.bspline/main.c:176
-#, fuzzy
msgid "No raster or vector or cross-validation output"
-msgstr "ã©ã¹ã¿ã¼ããã¯ãã«åºåãããã¾ãã"
+msgstr "ã©ã¹ã¿ã¼ããã¯ãã«ãã¯ãã¹æ¤è¨¼ã®åºåããã¾ãã"
#: ../vector/v.surf.bspline/main.c:230
#, fuzzy
@@ -20454,7 +20454,7 @@
#: ../vector/v.surf.bspline/main.c:265
#, c-format
msgid "Cross validation finished for sie = %f and sin = %f"
-msgstr ""
+msgstr "sie=ã%f ã¨sin=ã%f ã®ã¯ãã¹æ¤è¨¼ãçµäº"
#: ../vector/v.surf.bspline/main.c:274
#, c-format
@@ -20600,9 +20600,8 @@
msgstr "pj_do_transform ã«ã¨ã©ã¼"
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "ãã¯ãã«ãããã®ã«ãã´ãªã¼ãç·¨éï¼æ§ç¯ãã¾ã"
+msgstr ""
#: ../vector/v.hull/main.c:64
msgid "Use all vector points (do not limit to current region)"
@@ -20630,7 +20629,7 @@
#: ../vector/v.hull/hull.c:106
#, fuzzy
msgid "Simple planar hulls not implemented yet"
-msgstr "å
¥åãããã¡ã¤ã«"
+msgstr "å¦ç '%s' ã¯å®è¡ããã¾ããã§ãã"
#: ../vector/v.in.dwg/main.c:84
msgid "Converts DWG/DXF to GRASS vector map"
@@ -20859,14 +20858,12 @@
msgstr "ãã¼ã¿ãã¼ã¹ã« <%s> è£éã使ã§ãã¾ããã§ãã. "
#: ../vector/v.lidar.edgedetection/main.c:393
-#, fuzzy
msgid "Allocating memory for bilinear interpolation"
-msgstr "ãããã®ã«ãã´ãªã¼å¤ã«ã¤ãã¦çµ±è¨è§£æãè¡ãã¾ã"
+msgstr "åç·å½¢è£éã®ããã®ã¡ã¢ãªã¼å²ãå½ã¦"
#: ../vector/v.lidar.edgedetection/main.c:426
-#, fuzzy
msgid "Allocating memory for bicubic interpolation"
-msgstr "è£éã«ç¨ããè¿åç¹"
+msgstr "ãã¤ãã¥ã¼ããã¯è£éã®ããã®ã¡ã¢ãªã¼å²ãå½ã¦"
#: ../vector/v.lidar.edgedetection/main.c:431
msgid "Bicubic interpolation"
@@ -20887,22 +20884,19 @@
#: ../vector/v.lidar.edgedetection/edgedetection.c:304
#: ../vector/v.lidar.edgedetection/edgedetection.c:322
#: ../vector/v.lidar.edgedetection/edgedetection.c:352
-#, fuzzy
msgid "Impossible to read from aux table"
-msgstr "ãã¼ã¿ãã¼ã¹èªã¿è¾¼ã¿ä¸å¯è½ "
+msgstr "å¤é¨ãã¼ãã«ããã®èªã¿è¾¼ã¿ä¸å¯è½ "
#: ../vector/v.lidar.edgedetection/edgedetection.c:233
#: ../vector/v.lidar.edgedetection/edgedetection.c:309
-#, fuzzy
msgid "Impossible to update aux table"
-msgstr "ãã¼ã¿ãã¼ã¹ã¢ãããã¼ãä¸å¯è½ "
+msgstr "å¤é¨ãã¼ãã«ã®ã¢ãããã¼ãä¸å¯è½ "
#: ../vector/v.lidar.edgedetection/edgedetection.c:246
#: ../vector/v.lidar.edgedetection/edgedetection.c:258
#: ../vector/v.lidar.edgedetection/edgedetection.c:379
-#, fuzzy
msgid "Impossible to write to aux table"
-msgstr "ãã¼ã¿ãã¼ã¹ã«ããã¦æ¸ãè¾¼ã¿ä¸å¯è½"
+msgstr "å¤é¨ãã¼ãã«ã¸ã®æ¸ãè¾¼ã¿ä¸å¯è½"
#: ../vector/v.net.timetable/main.c:218
#, fuzzy, c-format
@@ -21417,9 +21411,8 @@
msgstr "å
é¨å»ºç©æ¸¬å®ã®è¼ªé測å®ã¨é åæé·ã¢ã«ã´ãªãºã "
#: ../vector/v.lidar.growing/main.c:84
-#, fuzzy
msgid "Input vector (v.lidar.edgedetection output"
-msgstr "å
¥å観測ãã¯ãã«ãããå (v.lidar.growing output) "
+msgstr "ãã¯ãã«å
¥å (v.lidar.edgedetectionåºå"
#: ../vector/v.lidar.growing/main.c:94
msgid "Name of the first pulse vector map"
@@ -21434,9 +21427,9 @@
msgstr "çºå±ä¸ã®é åã«ãããããã«ãã«ã¹ã®é¾å¤"
#: ../vector/v.lidar.growing/main.c:177
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open table <%s>"
-msgstr "表 <%s> ãã³ãã¼ã§ãã¾ãã"
+msgstr "ãã¼ãã« <%s> ããªã¼ãã³ã§ãã¾ãã"
#: ../vector/v.lidar.growing/main.c:202
msgid "Setting regions and boxes"
@@ -21453,14 +21446,12 @@
msgstr "å = %d"
#: ../vector/v.lidar.growing/main.c:289
-#, fuzzy
msgid "read points in input vector"
-msgstr "æå®ããããã¯ãã«ããããèªã¿è¾¼ã¿ä¸"
+msgstr "å
¥åãã¯ãã«ã®ãã¤ã³ããèªã¿è¾¼ã¿"
#: ../vector/v.lidar.growing/main.c:438
-#, fuzzy
msgid "Region Growing"
-msgstr "ã¬ã³ããªã³ã°"
+msgstr "é åæé·"
#: ../vector/v.lidar.growing/ConvexHull.c:269
msgid "...now exiting to system..."
@@ -24681,7 +24672,6 @@
msgstr "nãã¤ã³ã = %d, nå°å½¢ = %d "
#: ../vector/v.lidar.correction/main.c:369
-#, fuzzy
msgid "Mean calculation"
msgstr "å¹³åå¤ã®è¨ç®"
@@ -24772,7 +24762,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "åºåã(ç°¡æè¡¨ç¤ºã®ã¨ãã®ã¿æå¹)"
+msgstr "ã·ã§ã«ã¹ã¯ãªããã¹ã¿ã¤ã«ã®çµ±è¨ãåºåãã¾ã"
#: ../vector/v.db.connect/main.c:84
msgid "Print all map connection parameters and exit"
@@ -26839,7 +26829,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:18
#, fuzzy
msgid "Projections"
-msgstr "ç·ã«æ²¿ã£ã¦ç¹ãè£é"
+msgstr "æå½±ä¸..."
#: ../locale/scriptstrings/m.proj_to_translate.c:13
msgid "Output projection parameters (PROJ.4 style)"
@@ -27082,7 +27072,7 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:6
#, fuzzy
msgid "Name of extension to install/remove"
-msgstr "使ãããã±ã¼ã·ã§ã³"
+msgstr "使ããæ°ãããã±ã¼ã·ã§ã³å"
#: ../locale/scriptstrings/g.extension_to_translate.c:8
msgid "SVN Addons repository URL"
@@ -30784,4596 +30774,4634 @@
msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr "ä»ã®ãã¤ã³ãã示ããã¨ãã§ãã¾ããã %d ãã¤ã³ãã®ã¿å¯è½ã§ãã"
-#~ msgid "Not enough room in history file"
-#~ msgstr "å±¥æ´ãã¡ã¤ã«ã䏿¯ã§ã "
+#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "ã©ã¹ã¿ã¼ãããã表示ãã¾ã"
-#~ msgid "New MAPSET name"
-#~ msgstr "æ°ãããããã»ããå"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "ãããã»ãããµã¼ããªã¹ãt:\n"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "<%s> ã¯ãããã»ãããªã¹ãã«è¦ã¤ããã¾ããã§ãã"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "** no mapsets **\n"
-#~ msgstr "** ãããã»ãããªã **\n"
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "���"
-#~ msgid "Name of workspace file"
-#~ msgstr "使¥ãã¡ã¤ã«å"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+msgstr "���"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "ã©ã¹ã¿ã¼ãããã表示ãã¾ã"
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "è¨æ¸¬åä½"
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "表示ããå¤ã®ãªã¹ã (FP ããã)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+msgstr "çµæãã·ã§ã«ã¹ã¯ãªããå½¢å¼ã§åºå"
-#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr ""
-#~ "catlist ãç¡è¦ãã¦ãã¾ã: ãããã¯æµ®åå°æ°ç¹ã§ã ('val=' ã使ç¨ãã¦ãã ã"
-#~ "ã) "
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "ã©ã¹ã¿ã¼ãããã«é¢ããä¸é£ã®ã¬ãã¼ãã使ãã¾ã "
-#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr ""
-#~ "vallistãç¡è¦ãã¦ãã¾ã: ãããã¯æ´æ°ã§ã ('cat='ã使ç¨ãã¦ãã ãã) "
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "<%s>ãã¼ã¿ãã¼ã¹ã«ä½æããã¾ãã. "
-#~ msgid "Area size [%.1e], area not imported"
-#~ msgstr "é åãµã¤ãº [%.1e], é åã¯ã¤ã³ãã¼ãããã¦ãã¾ãã"
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "Island size [%.1e], island not imported"
-#~ msgstr "å³¶ã®ãµã¤ãº [%.1e], å³¶ã¯ã¤ã³ãã¼ãããã¦ãã¾ãã"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "ç¾å¨ã®è¨å®ã表示"
-#~ msgid ""
-#~ "No vector map of sparse points to interpolate was specified. "
-#~ "Interpolation will be done with <%s> vector map"
-#~ msgstr ""
-#~ "è£éã«å¯¾ããå°éãã¤ã³ãã®ãã¯ãã«ãããã¯æå®ããã¾ããã§ãã. è£éã¯ãã¯"
-#~ "ãã«ãããã¨è¡ãªããã¾ã <%s> "
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "åºåãããã¡ã¤ã«"
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "%s ãéãã¾ããã§ãã"
+#, fuzzy
+msgid "report"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "çã®æ¨é«å¤ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ãããæé¢ãæ¹ä½ãæ²é¢ãåå°é¢æ°ã®ã©ã¹ã¿ã¼"
-#~ "ãããã使ãã¾ã.ãæ¹ä½ã¯æ±ããåæè¨åãã«è¨ç®ãã¾ã"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "NULLå¤ã«ä»£å
¥ããå¤"
-#~ msgid "Raster elevation file name"
-#~ msgstr "ã©ã¹ã¿ã¼æ¨é«ãã¡ã¤ã«å"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "Output slope filename"
-#~ msgstr "徿ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "Error reading <%s>"
-#~ msgid "Output aspect filename"
-#~ msgstr "æ¹ä½ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "æé¢æ²çãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "æ£æ¥æ²çãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "���"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "䏿¬¡ã®åå°é¢æ° dx (E-W 徿) ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "Unable to open base map <%s>"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "䏿¬¡ã®åå°é¢æ° dy (N-S 徿) ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "äºæ¬¡ã®åå°é¢æ° dxx ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "Unable to open output map <%s>"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "äºæ¬¡ã®åå°é¢æ° dyy ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "Unable to read header for <%s>"
¥ããå¤"
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "äºæ¬¡ã®åå°é¢æ° dxy ãåºåãããã¡ã¤ã«å"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
-#~ msgid ""
-#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
-#~ "quiet' instead."
-#~ msgstr ""
-#~ "-q' ãã©ãã°ã¯å°æ¥å»æ¢ããã¾ãã'--quiet' ãã©ãã°ã使ç¨ãã¦ãã ããã"
+#, fuzzy
+msgid "Unable to read row %d"
-#~ msgid "wrong type: %s"
-#~ msgstr "ééã£ãã¿ã¤ãï¼ %s"
+#, fuzzy
+msgid "unable to open accumulation map layer"
-#~ msgid "Creating support files..."
-#~ msgstr "ãµãã¼ããã¡ã¤ã«ã使ä¸..."
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "ãããã»ãã [%s] ï¼[%s] å
ï¼ã®æ¨é«ã®ãããã¯ã"
+#, fuzzy
+msgid "Error reading row <%d>"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "æ¹ä½ [%s] å®äº"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "徿 [%s] å®äº"
+#, fuzzy
+msgid "Error reading row %d"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "ãããã¡ã¤ã«æ²ç· [%s] å®äº"
+#, fuzzy
+msgid "Unable to tokenize column string: %s"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "æ£æ¥æ²ç· [%s] å®äº"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
¥ããå¤"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "E-W 徿 [%s] å®äº"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "N-S 徿 [%s] å®äº"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
¥ããå¤"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] å®äº"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] å®äº"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
¥ããå¤"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] å®äº"
+#, fuzzy
+msgid "Unable to open training map <%s>"
-#~ msgid "Sources and sinks in [m^3/s]"
-#~ msgstr "æµå
¥ç©ã¨å®¹ç© [m^3/s] "
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
-#~ msgid "Specific yield in 1/m"
-#~ msgstr "ç¹å®ã®åç 1/m "
-#~ msgid "Input elevation map"
-#~ msgstr "å
¥åæ¨é«ããã"
-#~ msgid "Output shaded relief map name"
-#~ msgstr "åºåããé°å½±ã¬ãªã¼ããããå"
-#~ msgid "Layer number of data column"
-#~ msgstr "ãã¼ã¿åã®ã¬ã¤ã¤ã¼æ°"
#, fuzzy
-#~ msgid ""
-#~ "Calculates univariate statistics from a raster map based on vector "
-#~ "polygons and uploads statistics to new attribute columns."
-#~ msgstr "ã©ã¹ã¿ã¼ãããã«ããã¦çµ±è¨è§£æãè¡ãã¾ã"
+msgid "Cannot open cell file [%s]"
#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot read file header of [%s])"
#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Could not open <%s>"
-#~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "å°å·ãå«ããã¯ãã«å
¥åãããå"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "åæ°´åã示ãã©ã¹ã¿ã¼ãããã使ãã¾ã "
-#~ msgid "Coded stream network file name"
-#~ msgstr "æ²³å·ãã¡ã¤ã«"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "åæ°´ç¨ãã¡ã¤ã« "
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "åºåããåæ°´çãã¡ã¤ã« "
-#~ msgid "Name of the elevation raster map [m]"
-#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ãããå [m]"
-#~ msgid "Output water depth raster map [m]"
-#~ msgstr "æ°´æ·±ã©ã¹ã¿ã¼ããããåºåãã [m] "
-#~ msgid "Output elevation raster map"
-#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ããããåºå"
-#~ msgid "Input elevation raster map"
-#~ msgstr "å
¥åæ¨é«ã©ã¹ã¿ã¼ããã"
-#~ msgid "Input aspect raster map"
-#~ msgstr "å
¥åæ¹ä½ã©ã¹ã¿ã¼ããã"
-#~ msgid "Input barrier raster map"
-#~ msgstr "å
¥åããªã¢ã¼ã©ã¹ã¿ã¼ããã"
-#~ msgid "Output flowline vector map"
-#~ msgstr "åºåããã¼ã©ã¤ã³ãã¯ãã«ããã"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ãããå"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "åºåããå½±ã®ã©ã¹ã¿ã¼ãããå"
-#~ msgid "By_position"
-#~ msgstr "ä½ç½®ã使ã "
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: å¹´(1950..2050) "
-#~ msgid "By_time"
-#~ msgstr "By_time "
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: æ(0..12) "
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: æ¥(0..31) "
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: æ(0..24) "
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "æ±è¥¿åº§æ¨(POIãæ¢å®å¤ã¯ãããä¸å¿)"
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "åå座æ¨(POIãæ¢å®å¤ã¯ãããä¸å¿)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "ã¼ãã¯å®éã®æ¨é«"
-#~ msgid "Verbose output (also print out sun position etc.)"
-#~ msgstr "詳細ãåºåãã (太é½ã®ä½ç½®çãåºåãã) "
-#~ msgid "(i) Elevation map"
-#~ msgstr "(i) æ¨é«ããã"
-#~ msgid "(o) Depressionless elevation map"
-#~ msgstr "(o) å¹ã¿ã®ãªãæ¨é«ããã "
-#~ msgid "(o/i) Basin elevation map (MASK applied)"
-#~ msgstr "(o/i) çå°æ¨é«ããã (MASK ãé©ç¨) "
-#~ msgid "(o) Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(o) å°å½¢å¦çã¤ã³ããã¯ã¹ ln(a/tanB) ããã (MASK é©ç¨) "
-#~ msgid "(o) Output file"
-#~ msgstr "(o) åºåãã¡ã¤ã«"
-#~ msgid "(i) OPTIONAL Observed flow file"
-#~ msgstr "(i) ä»»æï¼ 宿¸¬æµéãã¡ã¤ã« "
-#~ msgid "(i) OPTIONAL Output for given time step"
-#~ msgstr "(i) ä»»æï¼ æå®ãããæéã¹ãããã®åºå"
-#~ msgid "(i) OPTIONAL Output for given topographic index class"
-#~ msgstr "(i) ä»»æï¼ æå®ãããå°å½¢å¦çã¤ã³ããã¯ã¹ã¯ã©ã¹ã®åºå"
#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot write to output raster file"
-#~ msgid "Name of existing raster map containing elevation surface"
-#~ msgstr "æ¨é«æ²é¢ãå«ãã©ã¹ã¿ã¼ãããå"
-#~ msgid "Output elevation raster map after filling"
-#~ msgstr "å
å¡«å¾ã«ã©ã¹ã¿ã¼ããããåºå"
-#~ msgid "Output direction raster map"
-#~ msgstr "æ¹åã©ã¹ã¿ã¼ããããåºå"
-#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr "æ¹ä½æ¹åãã©ã¼ããã (agnps, answers, ã¾ã㯠grass) ãåºå"
-#~ msgid "Reading map..."
-#~ msgstr "ããããèªã¿è¾¼ã¿ä¸..."
-#~ msgid "Failed to guess site file format\n"
-#~ msgstr "ãµã¤ããã¡ã¤ã«ã®ãã©ã¼ãããã䏿ã§ã\n"
-#~ msgid "Watershed basin analysis program."
-#~ msgstr "åæ°´åã®è§£æãè¡ãã¾ã "
-#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "å
¥å:æ¨é«ã示ããã¡ã¤ã« "
-#~ msgid "Input map: locations of real depressions"
-#~ msgstr "å
¥å:å°ç¤æ²ä¸éã示ããã¡ã¤ã« "
-#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "å
¥å:éçºå°åã®å²åã示ããã¡ã¤ã« "
-#~ msgid "Output map: drainage direction"
-#~ msgstr "åºå:æåºæ¹åã示ããã¡ã¤ã« "
-#~ msgid "Output map: stream segments"
-#~ msgstr "åºå:æ²³å·ã示ããã¡ã¤ã« "
-#~ msgid "Watershed basin creation program."
-#~ msgstr "æµå使ããã°ã©ã ."
-#~ msgid "Name of raster map to contain results"
-#~ msgstr "çµæãåºåããã©ã¹ã¿ã¼ãããå "
-#~ msgid "The map N grid coordinates"
-#~ msgstr "ãããNã°ãªãã座æ¨"
-#~ msgid "X-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "éæ°´ä¿æ°ãã³ã½ã«ã®Xæå [m/s] "
-#~ msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
-#~ msgstr "éæ°´ä¿æ°ãã³ã½ã«ã®Yæå [m/s] "
-#~ msgid "Decomposition failed"
-#~ msgstr "åè§£ã«å¤±æãã¾ãã"
-#~ msgid "<%s> created in database."
-#~ msgstr "<%s>ãã¼ã¿ãã¼ã¹ã«ä½æããã¾ãã. "
-#~ msgid "<%s> has not been created in database."
-#~ msgstr "<%s> ã¯ãã¼ã¿ãã¼ã¹ã«ä½æããã¾ããã§ã"
#, fuzzy
-#~ msgid "Unable to access table <%s>"
-#~ msgstr "表 <%s> ã使ã§ãã¾ãã"
+msgid "Unable to read header of raster map <%s> "
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "���"
+msgid "Unable to read raster map <%s> row %d >"
¥ããå¤"
#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#~ msgstr "���"
+msgid "qcname"
+msgstr "ãã©ã³ã"
#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "è¨æ¸¬åä½"
+msgid "Name of QC"
+msgstr "å
¥åãããã¡ã¤ã«"
-#~ msgid "Experimental NVIZ CLI prototype."
-#~ msgstr "å®é¨æ®µéã® NVIZ CLI 試ä½å"
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "çµæãã·ã§ã«ã¹ã¯ãªããå½¢å¼ã§åºå"
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "è¡æ°"
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "ã©ã¹ã¿ã¼ãããã«é¢ããä¸é£ã®ã¬ãã¼ãã使ãã¾ã "
+msgid "Cannot read file header of [%s]"
#, fuzzy
-#~ msgid "<%s> table created in database."
+msgid "It was impossible to open table"
#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Spline type of interpolation"
+msgstr "ã¢ã¤ã³ã³ã®ç¨®é¡"
#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "ç¾å¨ã®è¨å®ã表示"
+msgid "Output drain raster map"
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "åºåãããã¡ã¤ã«"
+msgid "raster, rainfall, erosion, USLE"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "report"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Reading %s"
+msgstr "���%s ..."
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "NULLå¤ã«ä»£å
¥ããå¤"
+msgid "Can't find %d,%d:%f"
#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "raster, random, cell"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Error reading <%s>"
+msgid "raster, soil, erosion, USLE"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
+msgid "raster, random, surface"
+msgstr "è²ã«ç¨ããã©ã¹ã¿ã¼ããã"
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in a local text file. Alternatively, "
+"a local time can be specified to compute solar incidence angle and/or "
+"irradiance raster maps. The shadowing effect of the topography is optionally "
+"incorporated."
+msgstr "緯度 (dd:mm:ss{N|S})."
#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "���"
+msgid "Script kill option"
+msgstr "ã¹ã¯ãªããã®çµäº"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
+msgid "Start in Demo mode"
+msgstr "ãã¢ã¢ã¼ã"
#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
+msgid "Output more comments (default=quiet)"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "Unable to open output map <%s>"
+msgid "Cannot open database %s by driver %s"
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
¥ããå¤"
+msgid "Cannot select attributes: %s"
+msgstr "çµ±ä¸ãã屿§ã®å¤"
#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
+msgid ""
+"Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr "ç·ã®è²"
#, fuzzy
-#~ msgid "Unable to read row %d"
+msgid "Output inverse raster map after IFFT"
#, fuzzy
-#~ msgid "unable to open new LS factor map layer."
+msgid "Unable to find the real-image map <%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "unable to open new S factor map layer."
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr "���"
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Power 2 values : [%d] rows [%d] columns."
+msgstr "���"
#, fuzzy
-#~ msgid "Error reading row <%d>"
+msgid "Reading the raster maps..."
+msgstr "ã«ãã¼ããã"
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Rotating data arrays..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Error reading row %d"
+msgid "Inverse FFT completed..."
+msgstr "åæç"
#, fuzzy
-#~ msgid "Unable to tokenize column string: %s"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to open output file."
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
¥ããå¤"
+msgid "Transform successful."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Intensity map name"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
¥ããå¤"
+msgid "Saturation map name"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
+msgid "Output map representing the red"
+msgstr "åºå:æåºæ¹åã示ããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
¥ããå¤"
+msgid "Output map representing the green"
#, fuzzy
-#~ msgid "Unable to open training map <%s>"
+msgid "Output map representing the blue"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
+msgid "Cannot read row from raster map"
+msgstr "対象ããã1"
#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
+msgid "Cannot write row to raster map"
#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
+msgid "Red input raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Could not open <%s>"
+msgid "Green input raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot write to output raster file"
+msgid "Blue input raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
+msgid "Output intensity raster map"
+msgstr "æµç·ã®å¯åº¦ã示ããã¡ã¤ã«(åºå)"
#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
¥ããå¤"
+msgid "Output saturation raster map"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "ãã©ã³ã"
+msgid "Class transition statistics."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "get_img: out of memory."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "è¡æ°"
+msgid "Subgroup [%s] in group [%s] contains no files."
+msgstr "ãµãç»åã°ã«ã¼ã"
#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
+msgid "Writing [%s] ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "It was impossible to open table"
+msgid "Name of imagery signaturefile"
+msgstr "ã·ã°ããã£ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "ã¢ã¤ã³ã³ã®ç¨®é¡"
+msgid "Group [%s] not found."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Output drain raster map"
+msgid "Subgroup [%s] not found."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Signature file [%s] is missing or not readable."
+msgstr "������."
#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "���%s ..."
+msgid "Calculating eigenvalues and eigenvectors..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
+msgid "Transposing eigen matrix..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "raster, random, cell"
-#~ msgstr "対象ããã"
+msgid "Cannot write color table of raster map <%s>"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Calculating class covariance matrix..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "raster, random, surface"
-#~ msgstr "è²ã«ç¨ããã©ã¹ã¿ã¼ããã"
+msgid "Imagery group"
+msgstr "ç»åã°ã«ã¼ã"
#, fuzzy
-#~ msgid ""
-#~ "Computes direct (beam), diffuse and reflected solar irradiation raster "
-#~ "maps for given day, latitude, surface and atmospheric conditions. Solar "
-#~ "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-#~ "irradiance, daylight length) are saved in a local text file. "
-#~ "Alternatively, a local time can be specified to compute solar incidence "
-#~ "angle and/or irradiance raster maps. The shadowing effect of the "
-#~ "topography is optionally incorporated."
-#~ msgstr "緯度 (dd:mm:ss{N|S})."
+msgid "Subgroup containing image files"
#, fuzzy
-#~ msgid "Script kill option"
-#~ msgstr "ã¹ã¯ãªããã®çµäº"
+msgid "Resultant signature file"
#, fuzzy
-#~ msgid "Start in Demo mode"
-#~ msgstr "ãã¢ã¢ã¼ã"
+msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "ã¿ã¤ãã«"
+msgid "Input raster map being fft"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot open database %s by driver %s"
+msgid "Initializing data...\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "çµ±ä¸ãã屿§ã®å¤"
+msgid "Reading the raster map..."
+msgstr "ã«ãã¼ããã"
#, fuzzy
-#~ msgid ""
-#~ "Background color, either a standard GRASS color, R:G:B triplet, or \"none"
-#~ msgstr "ç·ã®è²"
+msgid "FFT completed..."
+msgstr "åæç"
#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to open file in the cell_misc directory."
+msgstr "���"
#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr "���"
+msgid ""
+"\n"
+" group <%s> not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "subgroup <%s> not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "���"
+msgid "Subgroup [%s] doesn't have any files"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Reading the raster maps..."
-#~ msgstr "ã«ãã¼ããã"
+msgid "Unable to proceed"
#, fuzzy
-#~ msgid "Rotating data arrays..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Can't open seed signature file <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "åæç"
+msgid "Can't read signature file <%s>"
#, fuzzy
-#~ msgid "Unable to open output file."
+msgid "Group of imagery files to be clustered"
#, fuzzy
-#~ msgid "Transform successful."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Subgroup name in the above group"
#, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "対象ããã"
+msgid "File containing initial signatures"
+msgstr "ã¤ãã·ã£ã«ã·ã°ããã£ãå«ããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Saturation map name"
-#~ msgstr "対象ããã"
+msgid "Output file to contain final report"
+msgstr "æçµã¬ãã¼ããåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "åºå:æåºæ¹åã示ããã¡ã¤ã«"
+msgid ""
+"\n"
+"<%s> -- illegal value of min_size"
+msgstr "���� ����"
#, fuzzy
-#~ msgid "Output map representing the green"
+msgid "Can't creat reportfile: "
#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "���"
+msgid "Reading image ... "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "対象ããã1"
+msgid "Unable to read head of %s"
¥ããå¤"
#, fuzzy
-#~ msgid "Cannot write row to raster map"
+msgid "group=[%s] - not found."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Red input raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "subgroup=[%s] (of group [%s]) - not found."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Green input raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Can't read signature file [%s]."
#, fuzzy
-#~ msgid "Blue input raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to create reject layer [%s]."
¥ããå¤"
#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "æµç·ã®å¯åº¦ã示ããã¡ã¤ã«(åºå)"
+msgid "Imagery group to be classified"
#, fuzzy
-#~ msgid "Output saturation raster map"
+msgid "Subgroup containing image files to be classified"
#, fuzzy
-#~ msgid "Class transition statistics."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Signatures to use for classification"
#, fuzzy
-#~ msgid "get_img: out of memory."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Raster map to hold classification results"
+msgstr "åé¡çµæãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "ãµãç»åã°ã«ã¼ã"
+msgid "ERROR: Problem opening output file."
#, fuzzy
-#~ msgid "Writing [%s] ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Name of fractal surface raster layer"
#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "ã·ã°ããã£ãã¡ã¤ã«"
+msgid "Name of the sampling locations vector points map"
+msgstr "���"
#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Density of output walkers"
#, fuzzy
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "File [%s] not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "������."
+msgid "Unable to open file [%s]"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Reading sites map (%s) ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Transposing eigen matrix..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Name of the output walkers vector points map"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
+msgid "You are not outputting any raster or vector points maps"
+msgstr "���"
#, fuzzy
-#~ msgid "Calculating class covariance matrix..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s=%s - illegal value"
#, fuzzy
-#~ msgid "Imagery group"
-#~ msgstr "ç»åã°ã«ã¼ã"
+msgid "Unable to read current region parameters"
#, fuzzy
-#~ msgid "Subgroup containing image files"
+msgid "Cannot open cover raster map <%s>"
+msgstr ""
+"#-#-#-#-# grassmods_ja.po (grassmods_ja) #-#-#-#-#\n"
+"åºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Resultant signature file"
+msgid "Cannot open database <%s> by driver <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
+msgid "No map specified"
+msgstr "徿æ¹ä½ã示ããã¡ã¤ã«(å
¥å)"
#, fuzzy
-#~ msgid "Input raster map being fft"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s - unable to remove color table"
#, fuzzy
-#~ msgid "Initializing data...\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s - color table not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Reading the raster map..."
+msgid "%s - unknown color request"
+msgstr "ãã¡ã¤ã«ã®ç¨®é¡"
#, fuzzy
-#~ msgid "FFT completed..."
-#~ msgstr "åæç"
+msgid "Unable to properly read input raster map"
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to properly write output raster map"
#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "���"
+msgid "Could not read range file"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Reading data: "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Name of raster map layer to be used for <%s>"
+msgstr "<%s>ã«å¯¾å¿ãããã©ã¹ã¿ã¼ããã"
#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%d points converted to centroids"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "Unable to proceed"
+msgid "%d centroids converted to points"
+msgstr "åºåãã¡ã¤ã«ã®ä¸æ¸ã"
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "���"
+msgid "%d lines converted to boundaries"
+msgstr "対象ãã¡ã¤ã«<%s>"
#, fuzzy
-#~ msgid "Can't read signature file <%s>"
+msgid "%d boundaries converted to lines"
#, fuzzy
-#~ msgid "Group of imagery files to be clustered"
+msgid "CrossCorrelation: %d points read in region.\n"
#, fuzzy
-#~ msgid "Subgroup name in the above group"
+msgid "CrossCorrelation: Cannot read field info"
#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "ã¤ãã·ã£ã«ã·ã°ããã£ãå«ããã¡ã¤ã«"
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "æçµã¬ãã¼ããåºåãããã¡ã¤ã«"
+msgid "CrossCorrelation: Column type not supported"
+msgstr "ãã¼ã«ã©ã "
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr "���� ����"
+msgid "CrossCorrelation: Cannot select data from table"
#, fuzzy
-#~ msgid "Can't creat reportfile: "
+msgid "CrossCorrelation: %d records selected from table"
#, fuzzy
-#~ msgid "Reading image ... "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "CrossCorrelation: No record for point (cat = %d)"
+msgstr "å¤0ãæ½åºå¯¾è±¡ã«ãã"
#, fuzzy
-#~ msgid "Unable to read head of %s"
¥ããå¤"
+msgid "CrossCorrelation: Mean = %.5lf\n"
#, fuzzy
-#~ msgid "group=[%s] - not found."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "CrossCorrelation: lambda_i = %.3f\n"
#, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "From type"
#, fuzzy
-#~ msgid "Can't read signature file [%s]."
+msgid "From layer"
+msgstr "ç·ã®è²"
#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
¥ããå¤"
+msgid "The column must be type integer or string"
¥å)"
#, fuzzy
-#~ msgid "Imagery group to be classified"
+msgid "Select type"
#, fuzzy
-#~ msgid "Subgroup containing image files to be classified"
+msgid "Cannot select records from database"
#, fuzzy
-#~ msgid "Signatures to use for classification"
+msgid "Cannot fetch data"
#, fuzzy
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "åé¡çµæãåºåãããã¡ã¤ã«"
+msgid "Feature id(s)"
#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
+msgid "Input vector was not found."
+msgstr "���."
#, fuzzy
-#~ msgid "Name of fractal surface raster layer"
+msgid "Cannot open dig_cats file."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of the sampling locations vector points map"
-#~ msgstr "���"
+msgid "Cannot open database %s"
#, fuzzy
-#~ msgid "Density of output walkers"
+msgid "Cannot insert into table: %s"
#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Removed vertices: %5d"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Removed vertices"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Node layer (points)"
+msgstr "è²ç¸ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#~ msgstr "���"
+msgid "Reading data from the map..."
+msgstr "ã«ãã¼ããã"
#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "���"
+msgid "Query layer (used by 'query' option)"
+msgstr "ã©ãã«ã®å±æ§"
#, fuzzy
-#~ msgid "%s=%s - illegal value"
+msgid "%d categories read from map"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "Unable to read current region parameters"
+msgid "Processing ainput lines ..."
+msgstr "ç·ã«æ²¿ã£ã¦ç¹ãè£é"
#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr ""
-#~ "#-#-#-#-# grassmods_ja.po (grassmods_ja) #-#-#-#-#\n"
-#~ "åºåãããã¡ã¤ã«"
+msgid "Processing ainput areas ..."
#, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
+msgid "Writing attributes ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "徿æ¹ä½ã示ããã¡ã¤ã«(å
¥å)"
+msgid "Current region does not include the entire input vector map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "%s - unable to remove color table"
+msgid ""
+"Elevation raster map <%s> does not cover the entire area of the input vector "
+"map <%s>. "
+msgstr "���"
#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Displays thematic vectormap"
#, fuzzy
-#~ msgid "%s - unknown color request"
-#~ msgstr "ãã¡ã¤ã«ã®ç¨®é¡"
+msgid "Vector map to display thematically"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Unable to properly read input raster map"
+msgid "Vector map type"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to properly write output raster map"
+msgid "Attribute column to use for thematic display (must be numeric)"
#, fuzzy
-#~ msgid "Could not read range file"
+msgid "Layer to use for thematic display"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "Reading data: "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "対象ãããã»ãã(ããã©ã«ãï¼ç¾å¨ã®ãããã»ãã)"
#, fuzzy
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "<%s>ã«å¯¾å¿ãããã©ã¹ã¿ã¼ããã"
+msgid "Output separator (default: newline)"
+msgstr "åºåã(ããã©ã«ã:ã¿ã)"
#, fuzzy
-#~ msgid "%d points converted to centroids"
+msgid "Raster to remove"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "åºåãã¡ã¤ã«ã®ä¸æ¸ã"
+msgid "3d raster to remove"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "対象ãã¡ã¤ã«<%s>"
+msgid "Vector to remove"
#, fuzzy
-#~ msgid "%d boundaries converted to lines"
+msgid "Region to remove"
#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
+msgid "Label to remove"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
+msgid "3dview to remove"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
+msgid "Group to remove"
#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "ãã¼ã«ã©ã "
+msgid "raster input maps"
+msgstr "ç®çãã¡ã¤ã«ãå«ããããã»ãã"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
+msgid "Output field seperator"
+msgstr "åºåã"
#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
+msgid "Saving new map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "å¤0ãæ½åºå¯¾è±¡ã«ãã"
+msgid "Terrain raster map (DEM)"
#, fuzzy
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
+msgid "Output raster map with lake"
#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
+msgid "Cannot write lake raster map <%s>!"
#, fuzzy
-#~ msgid "From type"
+msgid "Terrain raster map <%s> not found!"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "From layer"
-#~ msgstr "ç·ã®è²"
+msgid "Cannot open terrain raster map <%s@%s>!"
#, fuzzy
-#~ msgid "The column must be type integer or string"
¥å)"
+msgid "Seed map <%s> not found!"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Select type"
+msgid "Cannot open seed map <%s@%s>!"
#, fuzzy
-#~ msgid "Cannot select records from database"
+msgid "Failure to allocate memory for row pointers"
+msgstr "ãããã®ã«ãã´ãªã¼å¤ã«ã¤ãã¦çµ±è¨è§£æãè¡ãã¾ã"
#, fuzzy
-#~ msgid "Cannot fetch data"
+msgid "Loading maps: "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Feature id(s)"
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Input vector was not found."
-#~ msgstr "���."
+msgid "Error reading seed raster map. Probably broken file."
#, fuzzy
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot write lake raster map <%s@%s>!"
#, fuzzy
-#~ msgid "Cannot open database %s"
+msgid "Error writing color file for <%s@%s>!"
#, fuzzy
-#~ msgid "Cannot insert into table: %s"
+msgid "Name of the vector points map with x,y locations"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Removed vertices: %5d"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Number of time iterations (sec.)"
+msgstr "è£éã«ç¨ããè¿åç¹"
#, fuzzy
-#~ msgid "Removed vertices"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Multiscale simulation"
+msgstr "ãã±ã¼ã·ã§ã³"
#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "è²ç¸ãã¡ã¤ã«"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Reading data from the map..."
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "ã©ãã«ã®å±æ§"
+msgid "Calculates <simple> index on a raster map"
+msgstr "ãµã¤ããããã«ã©ã¹ã¿ã¼å½¢å¼ã®ãã¹ã¯ãããæ°ãããããã使ãã¾ã"
#, fuzzy
-#~ msgid "%d categories read from map"
+msgid "Raster input maps(s)"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "ç·ã«æ²¿ã£ã¦ç¹ãè£é"
+msgid "Output file name"
#, fuzzy
-#~ msgid "Processing ainput areas ..."
+msgid "%s: can't read fp range for [%s]"
#, fuzzy
-#~ msgid "Writing attributes ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "���"
+msgid "Error reading '%s' map"
#, fuzzy
-#~ msgid ""
-#~ "Elevation raster map <%s> does not cover the entire area of the input "
-#~ "vector map <%s>. "
-#~ msgstr "���"
+msgid "Run verbosly"
+msgstr "説æã¤ã表示"
#, fuzzy
-#~ msgid "Displays thematic vectormap"
+msgid "Threshold distance"
+msgstr "é¾å¤"
#, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "対象ããã"
+msgid "Cannot execute: %s"
#, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot link table: %s"
#, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
+msgid "DXF input file"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Layer to use for thematic display"
+msgid "Cannot open dxf file <%s>"
#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "対象ãããã»ãã(ããã©ã«ãï¼ç¾å¨ã®ãããã»ãã)"
+msgid "Cannot open new vector map <%s>"
#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "åºåã(ããã©ã«ã:ã¿ã)"
+msgid "Conversion of <%s> to vector map:"
+msgstr "���."
#, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Create 3D file"
#, fuzzy
-#~ msgid "3d raster to remove"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Do not print polyline info"
#, fuzzy
-#~ msgid "Vector to remove"
+msgid "imagery group"
#, fuzzy
-#~ msgid "Region to remove"
+msgid "imagery subgroup"
#, fuzzy
-#~ msgid "Label to remove"
+msgid "output raster map"
#, fuzzy
-#~ msgid "3dview to remove"
+msgid "Name of input raster map(s)"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Group to remove"
+msgid "Illegal file name for real part: %s"
+msgstr "èé¨ãå«ãå
¥åãã¡ã¤ã«"
#, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "ç®çãã¡ã¤ã«ãå«ããããã»ãã"
+msgid "Illegal file name for imaginary part: %s"
+msgstr "èé¨ãå«ãå
¥åãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "åºåã"
+msgid "** Can't read signature file <%s> **"
#, fuzzy
-#~ msgid "Saving new map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
+msgid "Raster file(s) for Elevation"
#, fuzzy
-#~ msgid "Output raster map with lake"
+msgid "Raster file(s) for Color"
#, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Raster map to zoom into"
+msgstr "ãºã¼ã ããã©ã¹ã¿ã¼ããã"
#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "対象ããã"
+msgid "Save the current region to region definition file"
+msgstr " region (å°åå®ç¾©ãã¡ã¤ã«)\n"
#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Erasing monitors ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "対象ããã"
+msgid "Could not open input file <%s>."
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Removing files from group"
#, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "ãããã®ã«ãã´ãªã¼å¤ã«ã¤ãã¦çµ±è¨è§£æãè¡ãã¾ã"
+msgid "Adding files to group [%s]"
#, fuzzy
-#~ msgid "Loading maps: "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Adding files to subgroup [%s]"
#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Writing subgroup REF"
#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Unable to open file: <%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Raster map not found."
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
+msgid "%s: can't read range for [%s]"
#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Raster file [%s] not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "è£éã«ç¨ããè¿åç¹"
+msgid "It was not possible writing in <%s>."
#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "ãã±ã¼ã·ã§ã³"
+msgid "Cannot create table: '%s'"
#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "���"
#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to delete layer/category [%d/%d] line %d"
#, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "ãµã¤ããããã«ã©ã¹ã¿ã¼å½¢å¼ã®ãã¹ã¯ãããæ°ãããããã使ãã¾ã"
+msgid "Unable to write line %d"
#, fuzzy
-#~ msgid "Raster input maps(s)"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unknown query tool '%s'"
#, fuzzy
-#~ msgid "Output file name"
+msgid "No layer database connection"
#, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
+msgid "%d categories loaded from the database"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "対象ããã"
+msgid "Cannot create layer"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Run verbosly"
-#~ msgstr "説æã¤ã表示"
+msgid ""
+"Load values from vector to database. For uploaded/printed category values '-"
+"1' is used for 'no category' and 'null'/'-' if category cannot be found or "
+"multiple categories were found."
+msgstr "���."
#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "é¾å¤"
+msgid "Column(s)"
+msgstr "æ´æ°ããã«ã©ã 1"
#, fuzzy
-#~ msgid "Cannot execute: %s"
+msgid "Cannot read map header for <%s>"
#, fuzzy
-#~ msgid "Cannot link table: %s"
+msgid "Cannot read category file for <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "DXF input file"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Print;Shell Script"
+msgstr "ç·ã»ã«æ°ã®åºå"
#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Creating support files for [%s]."
#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "%s: <%s> raster map not found"
+msgstr ""
+"対象ããã\n"
+"å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "���."
+msgid "%s: <%s> raster map exists already"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Create 3D file"
+msgid "Cannot read category file of raster map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Do not print polyline info"
+msgid "%s - map not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "imagery group"
+msgid "%s not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "imagery subgroup"
+msgid "Vector map %s - not found"
+msgstr "���"
#, fuzzy
-#~ msgid "output raster map"
+msgid "Raster map containing elevation data"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Raster map name for storing results"
#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "èé¨ãå«ãå
¥åãã¡ã¤ã«"
+msgid "Height of the viewing location"
+msgstr "è¦ç¹ã®é«ã"
#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
¥åãã¡ã¤ã«"
+msgid "%s: <%s> cellfile not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
+msgid "Cell file [%s] not found\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
+msgid "rgb cell map [%s] not found\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
+msgid "vector cell map [%s] not found\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "%s - %s not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Raster map to zoom into"
-#~ msgstr "ãºã¼ã ããã©ã¹ã¿ã¼ããã"
+msgid "raster map <%s> not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr " region (å°åå®ç¾©ãã¡ã¤ã«)\n"
+msgid "can't open vector map <%s> in <%s>"
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Creating support files"
#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "���"
+msgid "%s file [%s] not found!"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Removing files from group"
+msgid "%s: %s - map not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Adding files to group [%s]"
+msgid "%s: unable to open %s"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Adding files to subgroup [%s]"
+msgid "%s - not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Writing subgroup REF"
+msgid "Cannot read %s"
#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "[%s] map not found."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "対象ããã"
+msgid "[%s] map not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: can't read range for [%s]"
+msgid "elevation file [%s] not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "min computed aspect %.4f max computed aspect %.4f"
+msgstr "����� �����"
#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "min computed slope %.4f max computed slope %.4f"
+msgstr "��� ���"
#, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot describe table <%s>"
#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "���"
+msgid "Cannot insert values: %s"
#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "%s given an illegal number of points [%d]"
+msgstr "åæã®ã¯ã©ã¹ã¿ã¼æ°"
#, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to open database %s by driver %s"
#, fuzzy
-#~ msgid "Unknown query tool '%s'"
+msgid "Could not find input %s"
#, fuzzy
-#~ msgid "No layer database connection"
+msgid "Could not find input map <%s>"
#, fuzzy
-#~ msgid "%d categories loaded from the database"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot create layer"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "対象ããã"
+msgid "Can't write region <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr "���."
+msgid "No graphics device selected."
+msgstr "ã°ã©ãã£ãã¯ããã¤ã¹ã鏿ããã¦ããªã"
#, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "æ´æ°ããã«ã©ã 1"
+msgid "Unable to read raster row."
#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
+msgid "Training map [%s] not found."
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "���"
+msgid "%s map not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "ç·ã»ã«æ°ã®åºå"
+msgid "input raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Creating support files for [%s]."
+msgid "Illegal file name: %s"
#, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr ""
-#~ "対象ããã\n"
-#~ "å
¥åãããã¡ã¤ã«"
+msgid "Cannot get layer info for vector map"
+msgstr "���"
#, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "対象ããã"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr ""
+"åºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#~ msgstr "���"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "ã«ãã´ãªã¼å¤ã®ä»£ããã«ã«ãã´ãªã¼ã©ãã«ã使ç¨"
#, fuzzy
-#~ msgid "%s - map not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: %s - raster map not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: %s - illegal name"
#, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "���"
+msgid "%s: ERROR reading category file for %s"
#, fuzzy
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: %s - not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Raster map name for storing results"
+msgid "%s: %s - illegal units"
#, fuzzy
-#~ msgid "Height of the viewing location"
-#~ msgstr "è¦ç¹ã®é«ã"
+msgid "%s: %s - can't open"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Reading input map (%s) ... "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s - ERROR reading %s"
#, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: %s - can't create raster map"
#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Writing output map (%s) ... "
#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s - ERROR re-reading %s"
#, fuzzy
-#~ msgid "raster map <%s> not found"
-#~ msgstr "対象ããã"
+msgid "Reading raster map... "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "can't open vector map <%s> in <%s>"
+msgid "Writing raster map... "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Creating support files"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "ã«ãã´ãªã¼ã©ãã«ã®ãªã¹ã(ä¾ 1,3-8,13)"
#, fuzzy
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Output separator character (default: tab)"
#, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot read category file of raster map <%s> in <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "%s: unable to open %s"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot find file %s"
#, fuzzy
-#~ msgid "%s - not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot get header for %s"
#, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot create raster map %s"
#, fuzzy
-#~ msgid "[%s] map not found."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot create vector map %s"
+msgstr "���"
#, fuzzy
-#~ msgid "[%s] map not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot create raster map '%s'"
#, fuzzy
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Number of raster rows to hold in memory"
+msgstr "ã¡ã¢ãªã«æ®ãè¡"
#, fuzzy
-#~ msgid "min computed aspect %.4f max computed aspect %.4f"
-#~ msgstr "����� �����"
+msgid "Print raster map title only"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "min computed slope %.4f max computed slope %.4f"
-#~ msgstr "��� ���"
+msgid "unknown type: %d"
#, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot open raster map [%s]"
+msgstr ""
+"åºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot get raster band."
#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "åæã®ã¯ã©ã¹ã¿ã¼æ°"
+msgid "Cannot read GRASS raster."
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Cannot get [%s] driver"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Could not find input %s"
+msgid "Couldn't set geo transform."
#, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Couldn't set projection."
#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "���"
+msgid "Cannot export [%s] raster map."
#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "���"
+msgid "Cannot create [%s] raster map using [%s] driver."
#, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "���"
+msgid "Cannot read header of raster map <%s>"
#, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "ã°ã©ãã£ãã¯ããã¤ã¹ã鏿ããã¦ããªã"
+msgid "Cannot open TIFF file <%s>"
#, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Reading raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Training map [%s] not found."
-#~ msgstr "対象ããã"
+msgid "Cannot open output map."
#, fuzzy
-#~ msgid "%s map not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Illegal file name. Please try another."
#, fuzzy
-#~ msgid "input raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: can't open %s"
#, fuzzy
-#~ msgid "Illegal file name: %s"
+msgid "memory allocation failure"
#, fuzzy
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "���"
+msgid "Output terrain only vector map name"
+msgstr "å¾æã®æ¹ä½ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ "åºåãããã¡ã¤ã«"
+msgid "Cannot open vector map <%s> at the topological level"
+msgstr "���"
#, fuzzy
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "ã«ãã´ãªã¼å¤ã®ä»£ããã«ã«ãã´ãªã¼ã©ãã«ã使ç¨"
+msgid "Rebuilding topology ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "対象ããã"
+msgid "Removing duplicates ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: %s - illegal name"
+msgid "Attaching islands ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "Attaching centroids ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: %s - not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "ãã¯ã»ã«ã®æå°å¤"
#, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "Cannot get layer info"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: %s - can't open"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "cell file [%s] not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Reading input map (%s) ... "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "can't open raster map [%s]"
#, fuzzy
-#~ msgid "%s - ERROR reading %s"
+msgid "Cannot rewrite line %d"
+msgstr "���"
#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "Cannot copy line %d, editing terminated"
+msgstr "���"
#, fuzzy
-#~ msgid "Writing output map (%s) ... "
+msgid "No layer database connection."
#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "Cannot snap lines %d,%d"
#, fuzzy
-#~ msgid "Reading raster map... "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%d lines modified"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Could not open ASCII file <%s>"
#, fuzzy
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "ã«ãã´ãªã¼ã©ãã«ã®ãªã¹ã(ä¾ 1,3-8,13)"
+msgid "Print vector map region only"
+msgstr "���"
#, fuzzy
-#~ msgid "Output separator character (default: tab)"
+msgid "Cannot open vector map <%s> at topo level [%d]"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#~ msgstr "���"
+msgid "Cannot get layer info for vector map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Cannot select attribute."
#, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Number of ROWS and COLUMNS in grid"
+msgstr "æ ¼åæ°"
#, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Creating vector grid..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "���"
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Could not find input map <%s>."
#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "ã¡ã¢ãªã«æ®ãè¡"
+msgid "[%d] features written"
+msgstr "���"
#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Parameter <%s> not set"
+msgstr "���."
#, fuzzy
-#~ msgid "unknown type: %d"
+msgid "Output map where segments will be written"
+msgstr "���."
#, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
-#~ "åºåãããã¡ã¤ã«"
+msgid "Cannot get layer information for vector map"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "<%s> cellfile not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "���"
+msgid "Not able to open vector map <%s>"
#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "No table."
+msgstr "ãã¼ãã«"
#, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Can't read raster"
+msgstr "���"
#, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "driver name"
+msgstr "ãã©ã¤ã"
#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "database name"
+msgstr "ãã¼ã¿ãã¼ã¹"
#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Driver name"
+msgstr "ãã©ã¤ã"
#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "database location"
#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "output field separator"
+msgstr "åºåã"
#, fuzzy
-#~ msgid "Reading raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "output vertical record separator"
+msgstr "ä¸ä¸æ¹åã®åºåã"
#, fuzzy
-#~ msgid "Cannot open output map."
+msgid "null value indicator"
+msgstr "NULLå¤ã®èå¥å"
#, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "do not include column names in output"
+msgstr "ã«ã¼ãã«æ²¿ã£ã¦ã»ã«å¤ãã³ãã¼"
#, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "vertical output (instead of horizontal)"
+msgstr "8bitã§åºå"
#, fuzzy
-#~ msgid "memory allocation failure"
+msgid "Cannot find mapset for %s"
#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "å¾æã®æ¹ä½ãåºåãããã¡ã¤ã«"
+msgid "Label file [%s] not available"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#~ msgstr "���"
+msgid "Can't open label file [%s]"
#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "unable to open [%s] in [%s]"
#, fuzzy
-#~ msgid "Removing duplicates ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "warning: unable to open [%s] in [%s]"
#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to open raster map [%s] in [%s]"
#, fuzzy
-#~ msgid "Attaching centroids ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to find input cell map '%s'"
#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "ãã¯ã»ã«ã®æå°å¤"
+msgid "Unable to create raster map [%s]"
¥ããå¤"
#, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to create output <%s>"
¥ããå¤"
#, fuzzy
-#~ msgid "cell file [%s] not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Input file [%s] not found."
+msgstr "���."
#, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "Unable to open output file <%s>."
#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "���"
+msgid "Multiplier for ascii data"
+msgstr "é«ãã®å¼·èª¿"
#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgstr "���"
+msgid "Could not open temporary file: [%s]"
#, fuzzy
-#~ msgid "No layer database connection."
+msgid "Could not open input file [%s]"
#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "unable to create raster"
#, fuzzy
-#~ msgid "%d lines modified"
+msgid "Unable to create output raster map <%s>"
¥ããå¤"
#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "%s: Unable to find raster map <%s>"
#, fuzzy
-#~ msgid "Print vector map region only"
-#~ msgstr "���"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#~ msgstr "���"
+msgid "%s: Unable to open output raster map <%s>"
#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "���"
+msgid "Vector <%s> could not be opened"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot select attribute."
+msgid "Table name"
+msgstr "ãã¼ãã«"
#, fuzzy
-#~ msgid "Number of ROWS and COLUMNS in grid"
-#~ msgstr "æ ¼åæ°"
+msgid "x column name"
+msgstr "ãã¼ã«ã©ã "
#, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "z column name"
+msgstr "ãã¼ã«ã©ã "
#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "���"
+msgid "Cannot drop table: %s"
#, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Cannot open labels <%s>"
#, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "���"
+msgid "SVG file <%s> cannot be opened"
+msgstr "���"
#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "���."
+msgid "Querying input '%s' ... "
+msgstr "���%s ..."
#, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "���."
+msgid "Copying %s input lines ... "
+msgstr "���."
#, fuzzy
-#~ msgid "Cannot get layer information for vector map"
-#~ msgstr "���"
+msgid "Cannot create table <%s>"
#, fuzzy
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "cannot insert row: %s"
#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Cannot find line of cat %d"
+msgstr "���"
#, fuzzy
-#~ msgid "No table."
-#~ msgstr "ãã¼ãã«"
+msgid "Unalbe to open vector map <%s>"
#, fuzzy
-#~ msgid "Can't read raster"
-#~ msgstr "���"
+msgid "Transforms a vector map via a set of tie points."
+msgstr "ãã¯ãã«ãããã®åº§æ¨å¤æãè¡ãã¾ã"
#, fuzzy
-#~ msgid "driver name"
-#~ msgstr "ãã©ã¤ã"
+msgid "Raster map <%s>] not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "database name"
-#~ msgstr "ãã¼ã¿ãã¼ã¹"
+msgid "Cannot start driver <%s>."
#, fuzzy
-#~ msgid "Driver name"
-#~ msgstr "ãã©ã¤ã"
+msgid "Not able to find cellfile [%s]"
#, fuzzy
-#~ msgid "database location"
+msgid "color file for [%s] not available"
#, fuzzy
-#~ msgid "output field separator"
-#~ msgstr "åºåã"
+msgid "Raster file [%s] not available"
+msgstr "��."
#, fuzzy
-#~ msgid "output vertical record separator"
-#~ msgstr "ä¸ä¸æ¹åã®åºåã"
+msgid "Raster map [%s] not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "null value indicator"
-#~ msgstr "NULLå¤ã®èå¥å"
+msgid "Unable to open raster map [%s]"
#, fuzzy
-#~ msgid "do not include column names in output"
-#~ msgstr "ã«ã¼ãã«æ²¿ã£ã¦ã»ã«å¤ãã³ãã¼"
+msgid "Vector file [%s] not available"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "8bitã§åºå"
+msgid "Cannot open driver %s"
#, fuzzy
-#~ msgid "Cannot find mapset for %s"
+msgid "<%s> illegal name"
#, fuzzy
-#~ msgid "Label file [%s] not available"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "%s: %s - illegal name for output raster map."
#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgstr "ã©ã¹ã¿ã¼ãããããã¤ããªã¼ãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "Couldn't find raster map %s"
#, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "%s: <%s> not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "%s: <%s> illegal name"
#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
¥ããå¤"
+msgid "%s: Cannot open <%s>"
#, fuzzy
-#~ msgid "Unable to create output <%s>"
¥ããå¤"
+msgid "Cannot find %s"
#, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "���."
+msgid "could not read range file"
#, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to create raster map [%s]."
¥ããå¤"
#, fuzzy
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "é«ãã®å¼·èª¿"
+msgid "Filtering [%s] in [%s]"
#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Open raster map %s in %s = %d"
#, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Swap temp files"
#, fuzzy
-#~ msgid "unable to create raster"
+msgid "Writing [%s]"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
¥ããå¤"
+msgid "%s: illegal map name"
+msgstr "åºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: <%s> illegal file name"
#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "���"
#, fuzzy
-#~ msgid "%s: Unable to open output raster map <%s>"
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr "ã©ã¹ã¿ã¼ããããPPMãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#~ msgstr "���"
+msgid "Mapset of input map"
#, fuzzy
-#~ msgid "Table name"
-#~ msgstr "ãã¼ãã«"
+msgid "Checking location %s, mapset %s:"
#, fuzzy
-#~ msgid "x column name"
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "z column name"
+msgid "Error writing output map"
+msgstr "è§£å度"
#, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "<%s> is illegal file name"
#, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "[%s] is an illegal file name"
#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "���"
+msgid "no rules specified"
¥å)"
#, fuzzy
-#~ msgid "Querying input '%s' ... "
+msgid "Can't open temp file [%s]"
#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "���."
+msgid "Names of existing raster maps"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "%s - illegal name "
#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "���"
+msgid "Couldn't find raster map [%s]"
#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "%s in %s -can't open raster map"
#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "ãã¯ãã«ãããã®åº§æ¨å¤æãè¡ãã¾ã"
+msgid "%s - can't create raster map"
#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "対象ããã"
+msgid "Cell file [%s] not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot start driver <%s>."
+msgid "Requested 3d raster map not found <%s>"
+msgstr "���."
#, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Could not open elevation map"
#, fuzzy
-#~ msgid "color file for [%s] not available"
+msgid "Could not open output map"
#, fuzzy
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "��."
+msgid "unable to close output map"
#, fuzzy
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "対象ããã"
+msgid "Cannot create output map [%s]"
+msgstr "NULLå¤ã«ä»£å
¥ããå¤"
#, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Cannot open vector points map <%s>"
+msgstr "���."
#, fuzzy
-#~ msgid "Vector file [%s] not available"
-#~ msgstr "対象ããã"
+msgid "Cannot create vector map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Could not find input map <%s> in current mapset."
#, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "Vector file [%s] not available in search list"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot open database <%s>"
#, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "Cannot open table <%s>"
#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "ã©ã¹ã¿ã¼ãããããã¤ããªã¼ãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
+msgid "Cannot open driver <%s>"
#, fuzzy
-#~ msgid "Couldn't find raster map %s"
+msgid "The vector '%s' already exists."
+msgstr "���."
#, fuzzy
-#~ msgid "%s: <%s> not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Could not find input map '%s'."
#, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "Could not find network input map '%s'."
#, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "error opening raster map [%s]."
#, fuzzy
-#~ msgid "Cannot find %s"
+msgid "Cannot describe table %s"
#, fuzzy
-#~ msgid "could not read range file"
+msgid "Patching file <%s@%s>"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to create raster map [%s]."
¥ããå¤"
+msgid "[%d] files patched"
+msgstr "���"
#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Could not open vector map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Name of output raster map"
#, fuzzy
-#~ msgid "Swap temp files"
+msgid "Illegal output name: '%s'"
#, fuzzy
-#~ msgid "Writing [%s]"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: cellfile [%s] not found."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "Unable to open cellfile [%s]."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "Error reading wildcard."
#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "���"
+msgid ""
+"Sets the grid color, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr "ç·ã®è²"
#, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr "ã©ã¹ã¿ã¼ããããPPMãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr "ç·ã®è²"
#, fuzzy
-#~ msgid "Mapset of input map"
+msgid "Unable to open the temporary file."
#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
+msgid "Unable to open raster map [%s]."
#, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "対象ããã"
+msgid "Unable to find raster [%s]."
#, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "è§£å度"
+msgid "name for new raster map"
#, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "Output GRASS image file"
#, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "Resulting output map"
+msgstr "è§£å度"
#, fuzzy
-#~ msgid "no rules specified"
¥å)"
+msgid "name for new vector map (omit for display to stdout)"
#, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Input vector map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Names of existing raster maps"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: ERROR can't open tempfile"
#, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "vector map <%s> not found"
+msgstr "���"
#, fuzzy
-#~ msgid "%s - illegal name "
+msgid "unable to find raster map [%s]"
#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "<%s> raster map not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
+msgid "<%s> unable to open raster map"
#, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "Cannot find vector map [%s]"
+msgstr "���"
#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s - can't open raster map"
#, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "���."
+msgid "Can't get row %d from raster map %s"
+msgstr "対象ããã1"
#, fuzzy
-#~ msgid "Could not open elevation map"
+msgid "%s - raster map not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Could not open output map"
+msgid "string representing no data cell value"
+msgstr "ãã¼ã¿ã®ãªãã»ã«ã«ä»£å
¥ããè¨å·"
#, fuzzy
-#~ msgid "unable to close output map"
+msgid "File name of classification result"
#, fuzzy
-#~ msgid "Cannot create output map [%s]"
¥ããå¤"
+msgid "File name of reference classes"
#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "���."
+msgid "wide report, 132 columns (default: 80)"
+msgstr "ã¬ãã¼ãå¹
ã®æ¡å¤§"
#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#~ msgstr "���"
+msgid "quiet"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "<%s> - illegal output file name"
#, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr "対象ããã"
+msgid "%s: <%s> reference map not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Base raster map"
+msgstr "ãã¼ã¹ããã"
#, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "%s: raster map not found"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Problem opening input file [%s]"
#, fuzzy
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "���."
+msgid "Problem opening output file [%s]"
#, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "can't write category file for <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "%s: can't open tempfile"
#, fuzzy
-#~ msgid "error opening raster map [%s]."
+msgid "Unable to read row %d in raster map [%s]"
#, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Output verbosely"
+msgstr "説æã¤ã表示"
#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Can't open raster map %s"
#, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "���"
+msgid "It could not be find input map <%s>"
#, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "���"
+msgid "It could not be found input map <%s>"
#, fuzzy
-#~ msgid "Name of output raster map"
+msgid "Cannot find input map <%s>"
#, fuzzy
-#~ msgid "Illegal output name: '%s'"
+msgid "Input vector map <%s> not found."
+msgstr "���."
#, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Category ranges: e.g. 1,3-8,13"
#, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Writing attributes ...\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Error reading wildcard."
+msgid "Could not open ascii file <%s>"
#, fuzzy
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr "ç·ã®è²"
+msgid "Could not open temp file <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "ç·ã®è²"
+msgid "Vector map <%s> not fould"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to open the temporary file."
+msgid "SVG output file"
#, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Could not find vector '%s'"
+msgstr "���"
#, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Could not find vector map %s"
+msgstr "���"
#, fuzzy
-#~ msgid "name for new raster map"
+msgid "Unable to get row %d from <%s>"
+msgstr "対象ããã1"
#, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "No input coordinates provided"
+msgstr "X座æ¨å¤"
#, fuzzy
-#~ msgid "Resulting output map"
-#~ msgstr "è§£å度"
+msgid "Unable to allocate memory."
#, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "åºåãããã¡ã¤ã«"
+msgid "Raster output file"
#, fuzzy
-#~ msgid "Input vector map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Writing raster map ... "
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
+msgid "Keep existing color table"
+msgstr "ã«ã©ã¼ãã¼ãã«ã䏿¸ãããªã"
#, fuzzy
-#~ msgid "vector map <%s> not found"
-#~ msgstr "���"
+msgid "Verbose mode."
+msgstr "説æä»ã表示"
#, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid " %d rows, %d cols."
+msgstr "���"
#, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "対象ããã"
+msgid "%s in %s - can't read header file"
#, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "%s - unable to create raster map"
¥ããå¤"
#, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#~ msgstr "���"
+msgid "%s - unable to create category file"
#, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "verbose mode"
+msgstr "説æä»ã表示"
#, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "対象ããã1"
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "���"
#, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgstr "対象ããã"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr "���"
#, fuzzy
-#~ msgid "string representing no data cell value"
-#~ msgstr "ãã¼ã¿ã®ãªãã»ã«ã«ä»£å
¥ããè¨å·"
+msgid "Path to an output file"
#, fuzzy
-#~ msgid "File name of classification result"
+msgid "Name of existing raster map to be displayed"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "File name of reference classes"
+msgid ""
+"ASCII file to be converted to binary vector map, if not given (or \"-\") "
+"reads from standard input"
+msgstr "���"
#, fuzzy
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "ã¬ãã¼ãå¹
ã®æ¡å¤§"
+msgid "could not find input map <%s>"
#, fuzzy
-#~ msgid "quiet"
-#~ msgstr "説æãªã"
+msgid "unable to open raster map [%s]"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "cannot get layer info for vector map"
+msgstr "���"
#, fuzzy
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "cannot open database %s by driver %s"
#, fuzzy
-#~ msgid "Base raster map"
-#~ msgstr "ãã¼ã¹ããã"
+msgid "cannot create table: %s"
#, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgstr "対象ããã"
+msgid "cannot create index"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "cannot grant privileges on table %s"
#, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Cannot find vector map"
+msgstr "���"
#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#~ msgstr "���"
+msgid "Cannot find raster map"
#, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "Cannot open raster map"
#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Can't open temp file %s"
#, fuzzy
-#~ msgid "Output verbosely"
+msgid "Unknown keyword [%s] in vector head."
+msgstr "���."
#, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Error while reading cell map."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "Error while writing new cell map."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "Error in opening output file <%s>"
#, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Unable to find input cell map <%s>"
#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "���."
+msgid "Error in opening input file <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Unable to read map raster row %d"
#, fuzzy
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Unable to write color table to raster [%s]"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Cannot find map %s"
#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgstr "���"
+msgid "Cannot open map %s"
#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#~ msgstr "���"
+msgid "Name of predefined rules file"
#, fuzzy
-#~ msgid "SVG output file"
+msgid "no such value"
+msgstr "é¾å¤"
#, fuzzy
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "���"
+msgid "Unable to find base map <%s>"
#, fuzzy
-#~ msgid "Could not find vector map %s"
-#~ msgstr "���"
+msgid "Unable to find cover map <%s>"
#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgstr "対象ããã1"
+msgid "%s: reading category file for %s"
#, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "X座æ¨å¤"
+msgid "%s: unable to open raster map [%s]"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to allocate memory."
+msgid "%s: unable to create raster map [%s]"
¥ããå¤"
#, fuzzy
-#~ msgid "Raster output file"
+msgid "Unable to open database %s with driver %s"
#, fuzzy
-#~ msgid "Writing raster map ... "
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: Unable to read raster map [%s]"
¥ããå¤"
#, fuzzy
-#~ msgid "Keep existing color table"
-#~ msgstr "ã«ã©ã¼ãã¼ãã«ã䏿¸ãããªã"
+msgid "%s: unable to open raster map <%s>"
#, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "説æä»ã表示"
+msgid "%s: Failed to read raster row %d"
#, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "���"
+msgid "Unable to read cats table for %s"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "Could not open raster <%s>"
#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#~ msgstr "NULLå¤ã«ä»£å
¥ããå¤"
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "ä¸,ä¸,å·¦,å³ã®å¤(ãã¼ã»ã³ãã¼ã¸)"
#, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "verbose mode"
+msgid "%s: o_open_file: could not open raster map %s in %s"
#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "���"
+msgid "No record for category for [%d]"
+msgstr "���"
#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr "���"
+msgid "Error reading ASCII file <%s>"
#, fuzzy
-#~ msgid "Path to an output file"
+msgid "No lines found"
#, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "List of point coordinates. Required for add and move actions."
+msgstr "ã¿ã¤ã"
#, fuzzy
-#~ msgid ""
-#~ "ASCII file to be converted to binary vector map, if not given (or \"-\") "
-#~ "reads from standard input"
-#~ msgstr "���"
+msgid "Could not find input vector '%s'"
+msgstr "���"
#, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "Failed opening output vector map '%s'"
#, fuzzy
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Do not create attribute table."
+msgstr "çµ±ä¸ãã屿§ã®å¤"
#, fuzzy
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr "���"
+msgid "Error reading ascii file: [%s]"
#, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid ""
+"List vector maps in input location and exit (a dummy value must be given for "
+"input)"
+msgstr "ç®çãã±ã¼ã·ã§ã³å
ã®ãã¯ãã«ãããä¸è¦§è¡¨ç¤º"
#, fuzzy
-#~ msgid "cannot create table: %s"
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region"
+msgstr ""
+"ãã¦ã¹ã§æå®ããä½ç½®ã§ã®ãã¯ãã«ãããã®ã«ãã´ãªã¼æ
å ±ã表示ãã¾ã(ããã¯ã©"
+"ã?ãªã«?)"
#, fuzzy
-#~ msgid "cannot create index"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "| Prune | "
+msgstr "端ç¹ãã¹ããã"
#, fuzzy
-#~ msgid "cannot grant privileges on table %s"
+msgid "%s: <%s> vector map not found"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot find vector map"
-#~ msgstr "���"
+msgid "Vector <%s> could not be open"
+msgstr "���"
#, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Raster <%s> could not be open."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Interpolation: Setting regions and boxes"
+msgstr "è£éæ¹æ³"
#, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Interpolation: nsply = %d"
+msgstr "è£éæ¹æ³"
#, fuzzy
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "���."
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
#, fuzzy
-#~ msgid "Error while reading cell map."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
#, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: Dropping <s>"
#, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Interpolation was a success!"
+msgstr "è£éæ¹æ³"
#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "ç¾å¨ã®è¨å®ã表示"
#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "���"
+msgid "CrossCorrelation: It shouldn't take too long."
#, fuzzy
-#~ msgid "Unable to read map raster row %d"
+msgid "%s -- illegal output file name"
#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Sorry, with method '%s' you have to define an output map."
#, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Maximum number of iteration"
+msgstr "æå¤§å復忰"
#, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Existing raster map name"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of predefined rules file"
+msgid "%s - can't read raster cellhd"
#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "é¾å¤"
+msgid "error reading cell data"
#, fuzzy
-#~ msgid "Unable to find base map <%s>"
+msgid "No line found."
#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Do not build topology."
#, fuzzy
-#~ msgid "%s: reading category file for %s"
+msgid "Could not open ascii file [%s]"
#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s: Cannot open dxf file"
#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
¥ããå¤"
+msgid "Conversion of [%s] to vector map ..."
+msgstr "���."
#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Print the current region (shell script style)"
+msgstr "ç¾å¨ã®è¨å®ã表示(ã·ã§ã«ã¹ã¯ãªãã)"
#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
¥ããå¤"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"ããã§ã® %s ã¯æ¬¡ã®ãã¡ã®ããããã§ã:\n"
#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "ERROR: <%s> not found\n"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "ERROR: <%s> illegal name\n"
#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Cannot open toolbox: %s"
#, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "Cannot open toolbox."
#, fuzzy
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "ä¸,ä¸,å·¦,å³ã®å¤(ãã¼ã»ã³ãã¼ã¸)"
+msgid "Vector map(s) -- source for composite"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "New vector composite"
#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "Append files to existing file"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "���"
+msgid "No database updates."
#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
+msgid "Adding new features to vector file ..."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "No lines found"
+msgid "Vector map '%s' not found"
+msgstr "���"
#, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "ã¿ã¤ã"
+msgid "Input elevation file"
+msgstr "æ¨é«ã示ããã¡ã¤ã«(å
¥å)"
#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "���"
+msgid "Input aspect file"
¥å)"
#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Input barrier file"
+msgstr "ããªã¢ã示ããã¡ã¤ã«(å
¥å)"
#, fuzzy
-#~ msgid "Do not create attribute table."
-#~ msgstr "çµ±ä¸ãã屿§ã®å¤"
+msgid "Quiet operation"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Display Reference Information"
+msgstr "ãããã¼ã®è¡¨ç¤º"
#, fuzzy
-#~ msgid ""
-#~ "List vector maps in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr "ç®çãã±ã¼ã·ã§ã³å
+msgid ""
+"Aspect file's resolution differs from current region "
+"resolution"
+msgstr "å¤ã®èªã¿ã¨ãéé(ããã©ã«ã:ç¾å¨ã®è§£å度)"
#, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively query a vector map layer at user-"
-#~ "selected locations within the current geographic region"
-#~ msgstr ""
-#~ "ãã¦ã¹ã§æå®ããä½ç½®ã§ã®ãã¯ãã«ãããã®ã«ãã´ãªã¼æ
å ±ã表示ãã¾ã(ããã¯"
-#~ "ã©ã?ãªã«?)"
+msgid "output layer name"
#, fuzzy
-#~ msgid "| Prune | "
-#~ msgstr "端ç¹ãã¹ããã"
+msgid "Imagery files subgroup"
+msgstr "ãµãç»åã°ã«ã¼ã"
#, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "���"
+msgid "Warning: illegal output file name <%s>."
#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "���"
+msgid "Category <%d>: Line color and background color are the same!"
+msgstr "���!"
#, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Line color and background color are the same!"
+msgstr "���!"
#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "è£éæ¹æ³"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "ã¿ã¤ã ã¹ã¿ã³ã"
#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Open vector 3d raster map %s"
#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgid "Open 3d raster map %s"
#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgid "Vector import complete"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "Unable to create raster map for [%s]"
#, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "error opening 3d raster map"
#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "ç¾å¨ã®è¨å®ã表示"
+msgid "Read fp map as integer (use map's quant rules"
+msgstr "宿°ãæ´æ°ã«å¤æãã¦ä½¿ç¨"
#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "Name for the resulting raster map"
#, fuzzy
-#~ msgid "%s -- illegal output file name"
+msgid "Open Raster file %s in Mapset %s"
+msgstr "���"
#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Open 3d raster map %s\n"
#, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "æå¤§å復忰"
+msgid "Open elev raster map %s\n"
#, fuzzy
-#~ msgid "Existing raster map name"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Could not open map %s\n"
#, fuzzy
-#~ msgid "%s - can't read raster cellhd"
+msgid "Bin raster map to be imported"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "error reading cell data"
+msgid "Output partial derivatives instead"
+msgstr "徿å¤ã徿æ¹ä½ãæ²çã®ä»£ããã«åå°é¢æ°ãåºå"
#, fuzzy
-#~ msgid "No line found."
+msgid "Maximum distance"
+msgstr "æå¤§å¤"
#, fuzzy
-#~ msgid "Do not build topology."
+msgid "Makes 3D trees from input point vector map"
+msgstr "���"
#, fuzzy
-#~ msgid "Could not open ascii file [%s]"
+msgid "Diameter of the tree crown in map units"
+msgstr "è¦ç¹åº§æ¨"
#, fuzzy
-#~ msgid "%s: Cannot open dxf file"
+msgid "Height of tree trunk in meters"
+msgstr "å°è¡¨ããã®é«ã(åä½:ã¡ã¼ãã«)"
#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "���."
+msgid "Name of the column with tree crown width"
+msgstr "æçµã¬ãã¼ããåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr "ç¾å¨ã®è¨å®ã表示(ã·ã§ã«ã¹ã¯ãªãã)"
+msgid "Cannot select attributes for point #%d"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ããã§ã® %s ã¯æ¬¡ã®ãã¡ã®ããããã§ã:\n"
+msgid "Map coordinates"
+msgstr "Z座æ¨å¤"
#, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "%s Quit\n"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid "ERROR: <%s> illegal name\n"
+msgid "Quiet mode"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid "Cannot open toolbox: %s"
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "%s[%d]: No raster map specified."
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Query column name"
+msgstr "ãã¼ã«ã©ã "
#, fuzzy
-#~ msgid "New vector composite"
+msgid "name for new binary vector map (omit for display to stdout)"
#, fuzzy
-#~ msgid "Append files to existing file"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Name for G3d raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "No database updates."
+msgid "No output maps"
#, fuzzy
-#~ msgid "Adding new features to vector file ..."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Connect to the database through DBMI."
+msgstr "ãã¼ã¿ãã¼ã¹ã«æ¥ç¶ãã¾ã"
#, fuzzy
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "���"
+msgid "The resolution of raster and raster3d maps should be equal!"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Input elevation file"
-#~ msgstr "æ¨é«ã示ããã¡ã¤ã«(å
¥å)"
+msgid "top raster map not found\n"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Input aspect file"
¥å)"
+msgid "Compute upslope flowlines"
+msgstr "æµè·¯ãé¡ã£ã¦è¨ç®"
#, fuzzy
-#~ msgid "Input barrier file"
-#~ msgstr "ããªã¢ã示ããã¡ã¤ã«(å
¥å)"
+msgid "The map E and N grid coordinates of a starting point"
+msgstr "å§ç¹ã®åº§æ¨å¤"
#, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "説æãªã"
+msgid "Invoke fast, but memory intensive operation"
+msgstr "é«éè¨ç®(大ããªã¡ã¢ãªãå¿
è¦)"
#, fuzzy
-#~ msgid "Display Reference Information"
-#~ msgstr "ãããã¼ã®è¡¨ç¤º"
+msgid "You first need to run v.build on vector map <%s>"
+msgstr "���"
#, fuzzy
-#~ msgid ""
-#~ "Aspect file's resolution differs from current "
-#~ "region resolution"
-#~ msgstr "å¤ã®èªã¿ã¨ãéé(ããã©ã«ã:ç¾å¨ã®è§£å度)"
+msgid "unknown interpolation method"
+msgstr "è£éæ¹æ³"
#, fuzzy
-#~ msgid "output layer name"
+msgid "Name of existing raster map."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Imagery files subgroup"
-#~ msgstr "ãµãç»åã°ã«ã¼ã"
+msgid "Name of new raster map."
#, fuzzy
-#~ msgid "Warning: illegal output file name <%s>."
+msgid "Name of output map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr "���!"
+msgid "Name of existing input raster map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "���!"
+msgid "cover raster map"
+msgstr "ã«ãã¼ããã"
#, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "ã¿ã¤ã ã¹ã¿ã³ã"
+msgid "resultant raster map"
#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Input layer name"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Open 3d raster map %s"
+msgid "Aspect"
+msgstr "徿æ¹ä½ã¾ãã¯dyå¤ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Vector import complete"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Profile curvature"
+msgstr "æé¢æ²çã¾ãã¯dxxå¤ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
+msgid "Tangential curvature"
+msgstr "æ£æ¥æ²çã¾ãã¯dyyå¤ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "error opening 3d raster map"
+msgid "Mean curvature"
+msgstr "平忲çã¾ãã¯dxyå¤ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "宿°ãæ´æ°ã«å¤æãã¦ä½¿ç¨"
+msgid "Name for ascii output file"
#, fuzzy
-#~ msgid "Name for the resulting raster map"
+msgid "Enter name for the resulting signature file"
#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "���"
+msgid "page length (default: %d lines)"
+msgstr "1ãã¼ã¸ã®è¡æ°"
#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+msgid "page width (default: %d characters)"
+msgstr "1è¡ã®æåæ°"
#, fuzzy
-#~ msgid "Open elev raster map %s\n"
+msgid "suppress page headers"
+msgstr "ãããã¼ã®åé¤"
#, fuzzy
-#~ msgid "Could not open map %s\n"
+msgid "use formfeeds between pages"
+msgstr "ãã©ã¼ã ãã£ã¼ãã®ä½¿ç¨"
#, fuzzy
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Write an Arc-Info line/polygon coverage in e00 format."
+msgstr "ãã¯ãã«ããããARC/INFO E00ãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "徿å¤ã徿æ¹ä½ãæ²çã®ä»£ããã«åå°é¢æ°ãåºå"
+msgid "Mapset holding vector map to be exported (Default = current)"
+msgstr "å
¥åãããã¡ã¤ã«ãå«ããããã»ãã(ããã©ã«ã=ç¾å¨ã®ãããã»ãã)"
#, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "æå¤§å¤"
+msgid "Name of .e00 output file (Default: stdout)"
#, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "���"
+msgid "Process spaghetti-digitized binary vector map."
+msgstr "ã¹ãã²ããã£ãã¼ã¿(ãã¤ããªã¼å½¢å¼)ã®ç·¨éãè¡ãã¾ã"
#, fuzzy
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "è¦ç¹åº§æ¨"
+msgid "Only run identical line tests"
+msgstr "æå®ããã©ã¤ã³ã®ã¿ã§å®è¡"
#, fuzzy
-#~ msgid "Height of tree trunk in meters"
-#~ msgstr "å°è¡¨ããã®é«ã(åä½:ã¡ã¼ãã«)"
+msgid "Snap nodes"
+msgstr "端ç¹ãã¹ããã"
#, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "æçµã¬ãã¼ããåºåãããã¡ã¤ã«"
+msgid ""
+"Set line types to: \n"
+" source same as in binary vector map\n"
+" line lines\n"
+" area area edges\n"
+" point points (sites)\n"
+msgstr ""
+"ç·ã®ç¨®é¡: \n"
+" source å
ã®ãã¯ãã«ãããã¨åã\n"
+" line ç·\n"
+" area ã¨ãªã¢ã¨ãã¸\n"
+" point ç¹(ãµã¤ããã¼ã¿)\n"
#, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
+msgid "Output file is ASCII map"
+msgstr "ASCIIå½¢å¼ã®ãã¯ãã«ããããåºå"
#, fuzzy
-#~ msgid "Map coordinates"
-#~ msgstr "Z座æ¨å¤"
+msgid "Copy attributes and category files"
+msgstr "屿§ããã³ã«ãã´ãªã¼ãã¡ã¤ã«ãã³ãã¼"
#, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "説æãªã"
+msgid ""
+"Converts point data in a binary GRASS vector map layer into a GRASS "
+"site_lists file."
+msgstr "ãã¯ãã«ããããããã¼ã¿ãæ½åºãã¦ãµã¤ããããã«å¤æãã¾ã"
#, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "説æãªã"
+msgid "sites file to be made from vector map"
#, fuzzy
-#~ msgid "Raster map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Use Category NUMERIC data instead of attribute"
+msgstr "屿§ã®ä»£ããã«æ°å¤ãã¼ã¿ã使ç¨"
#, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "対象ããã"
+msgid "Use Category TEXT data instead of attribute"
+msgstr "屿§ã®ä»£ããã«ããã¹ããã¼ã¿ã使ç¨"
#, fuzzy
-#~ msgid "Query column name"
-#~ msgstr "ãã¼ã«ã©ã "
+msgid "Test routine for developing MIF import."
+msgstr " ESRI ã·ã§ã¼ããã¡ã¤ã«ããã¯ãã«ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+msgid "Debugging level : 0 (silent) - 3 (verbose)"
+msgstr "ãããã°ã¬ãã«"
#, fuzzy
-#~ msgid "Name for G3d raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Name of file where to log operations"
+msgstr "ãã°ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "No output maps"
+msgid "Snap distance in ground units (Default = 10^-10)"
+msgstr "端ç¹ã®ã¹ãããè·é¢"
#, fuzzy
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "ãã¼ã¿ãã¼ã¹ã«æ¥ç¶ãã¾ã"
+msgid "Set initial scale [1:2400]"
+msgstr "ã¹ã±ã¼ã«"
#, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Name of attribute to use as category"
+msgstr "屿§çªå·ã®ãã£ã¼ã«ãå"
#, fuzzy
-#~ msgid "top raster map not found\n"
-#~ msgstr "対象ããã"
+msgid "Allow overwrite of existing vector map with the same name"
+msgstr "䏿¸ã"
#, fuzzy
-#~ msgid "Compute upslope flowlines"
-#~ msgstr "æµè·¯ãé¡ã£ã¦è¨ç®"
+msgid "Force writing polygon coverage as a line coverage"
+msgstr "å¼·å¶ã¤ã³ãã¼ã"
#, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "å§ç¹ã®åº§æ¨å¤"
+msgid "Create unique value for parts of compound object"
+msgstr "IDçªå·ã屿§ã¨ãã¦ä½¿ç¨"
#, fuzzy
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "é«éè¨ç®(大ããªã¡ã¢ãªãå¿
è¦)"
+msgid "List fields of DBF file"
+msgstr "ãã¼ã¿ãã¼ã¹ã®ãã£ã¼ã«ãä¸è¦§ã表示ãã¦çµäº"
#, fuzzy
-#~ msgid "You first need to run v.build on vector map <%s>"
-#~ msgstr "���"
+msgid "new categories table title"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "unknown interpolation method"
+msgid "Build topology info (default) OR Edit categories"
+msgstr "ãããã¸ã¼ã®æ§ç¯ãã«ãã´ãªã¼ã®ç·¨é"
#, fuzzy
-#~ msgid "Name of existing raster map."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Prompt user for threshold (Valid only with Build option)"
+msgstr "é¾å¤ã®ã¦ã¼ã¶å®ç¾©"
#, fuzzy
-#~ msgid "Name of new raster map."
+msgid "read data into memory"
+msgstr "ã¿ã¤ãã«"
#, fuzzy
-#~ msgid "Name of output map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Set map region from data (Valid only with Build option)"
+msgstr "ãã¼ã¿ããå°åãè¨å®"
#, fuzzy
-#~ msgid "Name of existing input raster map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Snap Threshold value (Valid only with Build option and -s)"
+msgstr "ã¹ãããã®é¾å¤"
#, fuzzy
-#~ msgid "cover raster map"
-#~ msgstr "ã«ãã¼ããã"
+msgid "Suppress drawing of text outlines"
+msgstr "ããã¹ãã®ã¢ã¦ãã©ã¤ã³ãé表示"
#, fuzzy
-#~ msgid "resultant raster map"
+msgid "DXF layers with line data"
+msgstr "ã©ã¤ã³ãã¼ã¿ãå«ããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Input layer name"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "DXF layers with label data"
+msgstr "ã©ãã«ãã¼ã¿ãå«ããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Aspect"
-#~ msgstr "徿æ¹ä½ã¾ãã¯dyå¤ãåºåãããã¡ã¤ã«"
+msgid "Prefix for dig or dig_ascii and dig_att output files"
#, fuzzy
-#~ msgid "Profile curvature"
-#~ msgstr "æé¢æ²çã¾ãã¯dxxå¤ãåºåãããã¡ã¤ã«"
+msgid ""
+"\n"
+"\n"
+"Where lines and labels are one or more of:\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"ããã§ã®linesï¼labelsã®å
¥åå½¢å¼ã¯ä»¥ä¸ã®éãã§ã:\n"
+"\n"
#, fuzzy
-#~ msgid "Tangential curvature"
-#~ msgstr "æ£æ¥æ²çã¾ãã¯dyyå¤ãåºåãããã¡ã¤ã«"
+msgid ""
+" and/or \n"
+"\n"
+msgstr ""
+" ã¾ã㯠\n"
+"\n"
#, fuzzy
-#~ msgid "Mean curvature"
-#~ msgstr "平忲çã¾ãã¯dxyå¤ãåºåãããã¡ã¤ã«"
+msgid "angle of rotation"
+msgstr "å転è§åº¦"
#, fuzzy
-#~ msgid "Name for ascii output file"
+msgid "provide attributes of type: const,rows,cols"
+msgstr "屿§ã¿ã¤ã"
#, fuzzy
-#~ msgid "Enter name for the resulting signature file"
+msgid "binary vector map to be converted to ascii"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "page length (default: %d lines)"
-#~ msgstr "1ãã¼ã¸ã®è¡æ°"
+msgid "Converts ASCII vector map layers into binary vector map layers."
+msgstr " ASCIIå½¢å¼ã®ãã¡ã¤ã«ããã¯ãã«ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "page width (default: %d characters)"
-#~ msgstr "1è¡ã®æåæ°"
+msgid "what load"
+msgstr "æ´æ°ãã対象"
#, fuzzy
-#~ msgid "suppress page headers"
-#~ msgstr "ãããã¼ã®åé¤"
+msgid "Prints information about a binary GRASS vector map layer."
+msgstr "ãã¯ãã«ãããã«ã¤ãã¦ã®æ
å ±ã表示ãã¾ã"
#, fuzzy
-#~ msgid "use formfeeds between pages"
-#~ msgstr "ãã©ã¼ã ãã£ã¼ãã®ä½¿ç¨"
+msgid "Cleans out dead lines in GRASS vector maps."
+msgstr "ãã¯ãã«ãããã®ãã¼ã¿ä¸ã§åé¤ãã¼ã¯ã®ä»ããç·ãå
¨ã¦åãé¤ãã¾ã"
#, fuzzy
-#~ msgid "Write an Arc-Info line/polygon coverage in e00 format."
-#~ msgstr "ãã¯ãã«ããããARC/INFO E00ãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
+msgid "Key (id) column name"
+msgstr "ãã¼ã«ã©ã "
#, fuzzy
-#~ msgid "Mapset holding vector map to be exported (Default = current)"
-#~ msgstr "å
+msgid "Select area, line, or site "
+msgstr "ã¿ã¤ã"
#, fuzzy
-#~ msgid "Name of .e00 output file (Default: stdout)"
+msgid "input vector map for ARC/INFO conversion"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Process spaghetti-digitized binary vector map."
-#~ msgstr "ã¹ãã²ããã£ãã¼ã¿(ãã¤ããªã¼å½¢å¼)ã®ç·¨éãè¡ãã¾ã"
+msgid "coverage type"
+msgstr "æ½åºããã¿ã¤ã"
#, fuzzy
-#~ msgid "Only run identical line tests"
-#~ msgstr "æå®ããã©ã¤ã³ã®ã¿ã§å®è¡"
+msgid "prefix for ARC/INFO output filenames"
#, fuzzy
-#~ msgid "Snap nodes"
+msgid "The postscript versions of these papers are available via Internet at"
+msgstr "ãããã®æç®ã¯ãã¹ãã¹ã¯ãªããå½¢å¼ã§ä¸ã®URLããå
¥æã§ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Set line types to: \n"
-#~ " source same as in binary vector map\n"
-#~ " line lines\n"
-#~ " area area edges\n"
-#~ " point points (sites)\n"
-#~ msgstr ""
-#~ "ç·ã®ç¨®é¡: \n"
-#~ " source å
ã®ãã¯ãã«ãããã¨åã\n"
-#~ " line ç·\n"
-#~ " area ã¨ãªã¢ã¨ãã¸\n"
-#~ " point ç¹(ãµã¤ããã¼ã¿)\n"
+msgid "Please cite these references in publications where the results of this"
+msgstr "ãã®ããã°ã©ã ã®çµæãè«æçã«å
¬è¡¨ããå ´åï¼ "
#, fuzzy
-#~ msgid "Output file is ASCII map"
-#~ msgstr "ASCIIå½¢å¼ã®ãã¯ãã«ããããåºå"
+msgid "Use category data instead of attribute"
+msgstr "屿§ã®ä»£ããã«ã«ãã´ãªã¼ãã¼ã¿ãæ¨é«å¤ã¨ãã¦åºå"
#, fuzzy
-#~ msgid "Copy attributes and category files"
-#~ msgstr "屿§ããã³ã«ãã´ãªã¼ãã¡ã¤ã«ãã³ãã¼"
+msgid "Do zero attributes/cats represent elevation?"
+msgstr "å
¥åãã¡ã¤ã«ã®å¤ï¼ãæ¨é«ã«ç½®ãæãã"
#, fuzzy
-#~ msgid ""
-#~ "Converts point data in a binary GRASS vector map layer into a GRASS "
-#~ "site_lists file."
-#~ msgstr "ãã¯ãã«ããããããã¼ã¿ãæ½åºãã¦ãµã¤ããããã«å¤æãã¾ã"
+msgid "path to GRASS database of input location"
+msgstr "ç®çãã±ã¼ã·ã§ã³ãå«ããã¼ã¿ãã¼ã¹"
#, fuzzy
-#~ msgid "sites file to be made from vector map"
+msgid "Automatically run \"v.support\" on newly created vector map."
+msgstr "'v.support'ã³ãã³ããèªåçã«å®è¡"
#, fuzzy
-#~ msgid "Use Category NUMERIC data instead of attribute"
-#~ msgstr "屿§ã®ä»£ããã«æ°å¤ãã¼ã¿ã使ç¨"
+msgid "Type of object to extract (area, line or both)"
+msgstr "æ½åºããç·ã®ã¿ã¤ã"
#, fuzzy
-#~ msgid "Use Category TEXT data instead of attribute"
-#~ msgstr "屿§ã®ä»£ããã«ããã¹ããã¼ã¿ã使ç¨"
+msgid "Limit line output to area-edge arcs"
+msgstr "ã¨ãªã¢ã¨ãã¸ã®ã¿æ½åº"
#, fuzzy
-#~ msgid "Test routine for developing MIF import."
-#~ msgstr " ESRI ã·ã§ã¼ããã¡ã¤ã«ããã¯ãã«ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
+msgid "Limit line output to line arcs"
+msgstr "ç·ã®ã¿æ½åº"
#, fuzzy
-#~ msgid "Debugging level : 0 (silent) - 3 (verbose)"
-#~ msgstr "ãããã°ã¬ãã«"
+msgid "Polygon Cookie Cutter (Boolean AND Overlay)."
+msgstr ""
+"2ã¤ã®æ¢åãããã¯ãã«ãããã®äº¤å·®é¢ä¿ã«ãã¨ã¥ããæ¼ç®(ãã¼ã«ä»£æ°ã®ANDãªã¼ãã¼"
+"ã¬ã¤)ãè¡ããæ°ãããããã使ãã¾ã"
#, fuzzy
-#~ msgid "Name of file where to log operations"
-#~ msgstr "ãã°ãã¡ã¤ã«"
+msgid "ARC/INFO ungenerate lines file"
+msgstr "å
¥åããã©ã¤ã³ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Snap distance in ground units (Default = 10^-10)"
-#~ msgstr "端ç¹ã®ã¹ãããè·é¢"
+msgid "ARC/INFO ungenerate label-points file"
+msgstr "å
¥åããã©ãã«(ãã¤ã³ã)ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Set initial scale [1:2400]"
-#~ msgstr "ã¹ã±ã¼ã«"
+msgid "ARC/INFO label-text file"
+msgstr "å
¥åããã©ãã«(ããã¹ã)ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of attribute to use as category"
-#~ msgstr "屿§çªå·ã®ãã£ã¼ã«ãå"
+msgid "resultant Vector output file"
#, fuzzy
-#~ msgid "Allow overwrite of existing vector map with the same name"
-#~ msgstr "䏿¸ã"
+msgid "ID Number column in label-text file"
+msgstr "ããã¹ãã®åæ°(IDçªå·)"
#, fuzzy
-#~ msgid "Force writing polygon coverage as a line coverage"
-#~ msgstr "å¼·å¶ã¤ã³ãã¼ã"
+msgid "GRASS category column in label-text file"
+msgstr "ããã¹ãã®åæ°(ã«ãã´ãªã¼å¤)"
#, fuzzy
-#~ msgid "Create unique value for parts of compound object"
-#~ msgstr "IDçªå·ã屿§ã¨ãã¦ä½¿ç¨"
+msgid "GRASS attribute column in label-text file"
+msgstr "ããã¹ãã®åæ°(屿§)"
#, fuzzy
-#~ msgid "List fields of DBF file"
-#~ msgstr "ãã¼ã¿ãã¼ã¹ã®ãã£ã¼ã«ãä¸è¦§ã表示ãã¦çµäº"
+msgid "new pruned vector map"
#, fuzzy
-#~ msgid "new categories table title"
-#~ msgstr "ã¿ã¤ãã«"
+msgid "reports attribute, label, and other information about a sites file"
+msgstr "ãµã¤ããããã®åºç¤æ
å ±ãåºåãã¾ã"
#, fuzzy
-#~ msgid "Build topology info (default) OR Edit categories"
-#~ msgstr "ãããã¸ã¼ã®æ§ç¯ãã«ãã´ãªã¼ã®ç·¨é"
+msgid "Name of sites file."
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Prompt user for threshold (Valid only with Build option)"
-#~ msgstr "é¾å¤ã®ã¦ã¼ã¶å®ç¾©"
+msgid "Load quietly"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid "read data into memory"
+msgid "Only count sites in current window for min/max."
+msgstr "æå¤§å¤ã¨æå°å¤ã®ã¿åºå"
#, fuzzy
-#~ msgid "Set map region from data (Valid only with Build option)"
-#~ msgstr "ãã¼ã¿ããå°åãè¨å®"
+msgid "Show quartiles for decimal attributes"
+msgstr "屿§çªå·ã®åºå"
#, fuzzy
-#~ msgid "Snap Threshold value (Valid only with Build option and -s)"
-#~ msgstr "ã¹ãããã®é¾å¤"
+msgid "Name of input sites map"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Suppress drawing of text outlines"
-#~ msgstr "ããã¹ãã®ã¢ã¦ãã©ã¤ã³ãé表示"
+msgid "which decimal attribute (if multiple)"
+msgstr "屿§çªå·"
#, fuzzy
-#~ msgid "DXF layers with line data"
-#~ msgstr "ã©ã¤ã³ãã¼ã¿ãå«ããã¡ã¤ã«"
+msgid "Use raster's region vs. current region"
+msgstr "ã©ã¹ã¿ã¼ãããã®é åã®ä½¿ç¨"
#, fuzzy
-#~ msgid "DXF layers with label data"
-#~ msgstr "ã©ãã«ãã¼ã¿ãå«ããã¡ã¤ã«"
+msgid "Name of sites file to filter"
+msgstr "å
¥åãããã¡ã¤ã«(ãµã¤ã)"
#, fuzzy
-#~ msgid "Prefix for dig or dig_ascii and dig_att output files"
+msgid ""
+"Converts a GRASS site list file into an ASCII listing of site locations and "
+"their descriptions."
+msgstr "ãµã¤ãããããASCIIå½¢å¼ã®ãµã¤ããªã¹ãã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Where lines and labels are one or more of:\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ããã§ã®linesï¼labelsã®å
-#~ "\n"
+msgid "Include site attributes in the output"
+msgstr "ã«ãã´ãªã¼ã©ãã«ãåºå"
#, fuzzy
-#~ msgid ""
-#~ " and/or \n"
-#~ "\n"
-#~ msgstr ""
-#~ " ã¾ã㯠\n"
-#~ "\n"
+msgid "Include site attribute identifiers in the output"
+msgstr "屿§èå¥åãåºå"
#, fuzzy
-#~ msgid "angle of rotation"
-#~ msgstr "å転è§åº¦"
+msgid "Name of input site list"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "provide attributes of type: const,rows,cols"
-#~ msgstr "屿§ã¿ã¤ã"
+msgid "Number of cells to surround site cell"
+msgstr "èæ
®ããå¨è¾ºã®ã»ã«æ°"
#, fuzzy
-#~ msgid "binary vector map to be converted to ascii"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Attribute field type to use for operation"
+msgstr "屿§ã¿ã¤ã"
#, fuzzy
-#~ msgid "Converts ASCII vector map layers into binary vector map layers."
-#~ msgstr " ASCIIå½¢å¼ã®ãã¡ã¤ã«ããã¯ãã«ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
+msgid "Attribute field number to use for operation"
+msgstr "屿§çªå·"
#, fuzzy
-#~ msgid "what load"
-#~ msgstr "æ´æ°ãã対象"
+msgid "Create a single-valued (0/1) raster map"
+msgstr "0ã¨1ã®ã¿ã§æ§æãããã©ã¹ã¿ã¼ããããåºå"
#, fuzzy
-#~ msgid "Prints information about a binary GRASS vector map layer."
-#~ msgstr "ãã¯ãã«ãããã«ã¤ãã¦ã®æ
å ±ã表示ãã¾ã"
+msgid "Attribute to average values over"
+msgstr "屿§ã¿ã¤ã"
#, fuzzy
-#~ msgid "Cleans out dead lines in GRASS vector maps."
-#~ msgstr "ãã¯ãã«ãããã®ãã¼ã¿ä¸ã§åé¤ãã¼ã¯ã®ä»ããç·ãå
¨ã¦åãé¤ãã¾ã"
+msgid "Index of attribute type (ignored for cat)"
+msgstr "屿§çªå·"
#, fuzzy
-#~ msgid "Key (id) column name"
+msgid "Suppress windows with zero averages"
+msgstr "ãã¼ã¿ã®ãªãã»ã«ã¯åºåããªã"
#, fuzzy
-#~ msgid "Select area, line, or site "
-#~ msgstr "ã¿ã¤ã"
+msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
+msgstr "'g.gnuplot'ã³ãã³ãå½¢å¼ã§åºå"
#, fuzzy
-#~ msgid "input vector map for ARC/INFO conversion"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Convert an ASCII listing of site locations into a GRASS site list file."
#, fuzzy
-#~ msgid "coverage type"
-#~ msgstr "æ½åºããã¿ã¤ã"
+msgid "sites file to be created"
#, fuzzy
-#~ msgid "prefix for ARC/INFO output filenames"
+msgid "number of dimensions (default=2)"
+msgstr "é
åã®æ°(ããã©ã«ã2)"
#, fuzzy
-#~ msgid ""
-#~ "The postscript versions of these papers are available via Internet at"
-#~ msgstr "ãããã®æç®ã¯ãã¹ãã¹ã¯ãªããå½¢å¼ã§ä¸ã®URLããå
¥æã§ãã¾ã"
+msgid "input field separator"
+msgstr "åºåã"
#, fuzzy
-#~ msgid ""
-#~ "Please cite these references in publications where the results of this"
-#~ msgstr "ãã®ããã°ã©ã ã®çµæãè«æçã«å
¬è¡¨ããå ´åï¼ "
+msgid "datetime or datetime1/datetime2"
#, fuzzy
-#~ msgid "Use category data instead of attribute"
-#~ msgstr "屿§ã®ä»£ããã«ã«ãã´ãªã¼ãã¼ã¿ãæ¨é«å¤ã¨ãã¦åºå"
+msgid ""
+"Allows the user to re-project a sites file from one location to the current "
+"location (no datum transformation yet)."
+msgstr "ãµã¤ããããã®æå½±å¤æãè¡ãã¾ã"
#, fuzzy
-#~ msgid "Do zero attributes/cats represent elevation?"
-#~ msgstr "å
+msgid "input sites list"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "path to GRASS database of input location"
-#~ msgstr "ç®çãã±ã¼ã·ã§ã³ãå«ããã¼ã¿ãã¼ã¹"
+msgid "location of input sites list"
+msgstr "åæå½±ãè¡ããã±ã¼ã·ã§ã³"
#, fuzzy
-#~ msgid "Automatically run \"v.support\" on newly created vector map."
-#~ msgstr "'v.support'ã³ãã³ããèªåçã«å®è¡"
+msgid "mapset of input sites list"
+msgstr "ç®çãã¡ã¤ã«ãå«ããããã»ãã"
#, fuzzy
-#~ msgid "Type of object to extract (area, line or both)"
-#~ msgstr "æ½åºããç·ã®ã¿ã¤ã"
+msgid "output sites list"
#, fuzzy
-#~ msgid "Limit line output to area-edge arcs"
-#~ msgstr "ã¨ãªã¢ã¨ãã¸ã®ã¿æ½åº"
+msgid "List sites files in input location and exit"
ã®ãµã¤ããããä¸è¦§è¡¨ç¤º"
#, fuzzy
-#~ msgid "Limit line output to line arcs"
-#~ msgstr "ç·ã®ã¿æ½åº"
+msgid "Don't prompt for Map header information"
+msgstr "ãããã¼ãåé¤"
#, fuzzy
-#~ msgid "Polygon Cookie Cutter (Boolean AND Overlay)."
-#~ msgstr ""
-#~ "2ã¤ã®æ¢åãããã¯ãã«ãããã®äº¤å·®é¢ä¿ã«ãã¨ã¥ããæ¼ç®(ãã¼ã«ä»£æ°ã®ANDãªã¼"
-#~ "ãã¼ã¬ã¤)ãè¡ããæ°ãããããã使ãã¾ã"
+msgid ""
+"Field type (\"string\", \"dim\", or \"decimal\") and index to use for "
+"category value (uses \"cat\" by default)"
+msgstr "屿§ã¿ã¤ãã¾ãã¯å±æ§çªå·"
#, fuzzy
-#~ msgid "ARC/INFO ungenerate lines file"
-#~ msgstr "å
¥åããã©ã¤ã³ãã¡ã¤ã«"
+msgid ""
+"Allows the user to interactively adjust the settings (zoom and pan) of the "
+"current geographic region using a pointing device such as a mouse."
+msgstr "対象å°åã®ãºã¼ã /ãã³ããã¦ã¹ã«ããè¡ãã¾ã"
#, fuzzy
-#~ msgid "ARC/INFO ungenerate label-points file"
-#~ msgstr "å
+msgid ""
+"Displays points, as icons, at user-defined locations in the active display "
+"frame on the graphics monitor."
+msgstr "ã¢ã¤ã³ã³ã§ãã¤ã³ããã¼ã«ã¼ã表示ãã¾ã"
#, fuzzy
-#~ msgid "ARC/INFO label-text file"
-#~ msgstr "å
+msgid "Name of existing sites file"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "resultant Vector output file"
+msgid "Identify just one site"
+msgstr "1度ã®ã¿å®è¡"
#, fuzzy
-#~ msgid "ID Number column in label-text file"
-#~ msgstr "ããã¹ãã®åæ°(IDçªå·)"
+msgid "For parsing by programs: Terse output"
+msgstr "ç°¡æè¡¨ç¤º"
#, fuzzy
-#~ msgid "GRASS category column in label-text file"
-#~ msgstr "ããã¹ãã®åæ°(ã«ãã´ãªã¼å¤)"
+msgid "Allows the user to interactively query site list descriptions. "
+msgstr ""
+"ãã¦ã¹ã§æå®ããä½ç½®ã§ã®ãµã¤ããããã®ã«ãã´ãªã¼æ
å ±ã表示ãã¾ã(ããã¯ã©ã?"
+"ãªã«?)"
#, fuzzy
-#~ msgid "GRASS attribute column in label-text file"
-#~ msgstr "ããã¹ãã®åæ°(屿§)"
+msgid "Color to erase with"
+msgstr "å¡ãã¤ã¶ãè²"
#, fuzzy
-#~ msgid "new pruned vector map"
+msgid "Name of a spheroid (for lat/lon coordinate conversion)"
+msgstr "夿å
ã®æ¥åä½"
#, fuzzy
-#~ msgid "reports attribute, label, and other information about a sites file"
-#~ msgstr "ãµã¤ããããã®åºç¤æ
å ±ãåºåãã¾ã"
+msgid "Displays three-dimensional images based on raster map layers"
+msgstr "ã©ã¹ã¿ã¼ããããï¼æ¬¡å
ã§è¡¨ç¤ºãã¾ã"
#, fuzzy
-#~ msgid "Name of sites file."
-#~ msgstr "対象ããã"
+msgid "The raster map used to generate the color"
+msgstr "è²ã®ã©ã¹ã¿ã¼ããã"
#, fuzzy
-#~ msgid "Load quietly"
-#~ msgstr "説æãªã"
+msgid "The raster map used to generate the 3-d texture"
+msgstr "æ¨é«ã®ã©ã¹ã¿ã¼ããã"
#, fuzzy
-#~ msgid "Only count sites in current window for min/max."
-#~ msgstr "æå¤§å¤ã¨æå°å¤ã®ã¿åºå"
+msgid "coordinates of center of view"
+msgstr "è¦éã®ä¸å¿åº§æ¨"
#, fuzzy
-#~ msgid "Show quartiles for decimal attributes"
-#~ msgstr "屿§çªå·ã®åºå"
+msgid "Frequency of vector lines in output"
+msgstr "æ ¼åéé"
#, fuzzy
-#~ msgid "Name of input sites map"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Field of view"
+msgstr "è¦éã®è§åº¦"
#, fuzzy
-#~ msgid "which decimal attribute (if multiple)"
-#~ msgstr "屿§çªå·"
+msgid "Color of bounding box"
+msgstr "æ ã®è²"
#, fuzzy
-#~ msgid "Use raster's region vs. current region"
-#~ msgstr "ã©ã¹ã¿ã¼ãããã®é åã®ä½¿ç¨"
+msgid "Show null elevations"
+msgstr "NULLå¤ã表示"
#, fuzzy
-#~ msgid "Name of sites file to filter"
-#~ msgstr "å
¥åãããã¡ã¤ã«(ãµã¤ã)"
+msgid "Draw labelled vector lines to the current display device"
+msgstr "ãã¯ãã«ã©ã¤ã³ã表示ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS site list file into an ASCII listing of site locations "
-#~ "and their descriptions."
-#~ msgstr "ãµã¤ãããããASCIIå½¢å¼ã®ãµã¤ããªã¹ãã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
+msgid "Name of existing vector map to draw"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid "Include site attributes in the output"
-#~ msgstr "ã«ãã´ãªã¼ã©ãã«ãåºå"
+msgid ""
+"Draw all lines using either a GRASS standard color or R:G:B triplet "
+msgstr "ç·ã®è²"
#, fuzzy
-#~ msgid "Include site attribute identifiers in the output"
-#~ msgstr "屿§èå¥åãåºå"
+msgid ""
+"Only draw areas with a matching category number (for constant color option "
+"only)"
+msgstr "表示ããã«ãã´ãªã¼çªå·"
#, fuzzy
-#~ msgid "Name of input site list"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
+msgstr "å¡ä¾ç¨ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Number of cells to surround site cell"
-#~ msgstr "èæ
®ããå¨è¾ºã®ã»ã«æ°"
+msgid "Use random colors"
+msgstr "ã©ã³ãã ãªè²ã使ç¨"
#, fuzzy
-#~ msgid "Attribute field type to use for operation"
+msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "å¢çç·ã®è²"
#, fuzzy
-#~ msgid "Attribute field number to use for operation"
-#~ msgstr "屿§çªå·"
+msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "å¢çç·ã®è²"
#, fuzzy
-#~ msgid "Create a single-valued (0/1) raster map"
-#~ msgstr "0ã¨1ã®ã¿ã§æ§æãããã©ã¹ã¿ã¼ããããåºå"
+msgid "Limit to matching category number(s) (constant color option only)"
+msgstr "表示ããã«ãã´ãªã¼çªå·(è²ãæå®ããã¦ããã¨ãã®ã¿æå¹)"
#, fuzzy
-#~ msgid "Attribute to average values over"
+msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
#, fuzzy
-#~ msgid "Index of attribute type (ignored for cat)"
-#~ msgstr "屿§çªå·"
+msgid "Sets the current color to that stated"
+msgstr "è²"
#, fuzzy
-#~ msgid "Suppress windows with zero averages"
-#~ msgstr "ãã¼ã¿ã®ãªãã»ã«ã¯åºåããªã"
+msgid "Size, in pixels, in which the icon is to be drawn"
+msgstr "ã¢ã¤ã³ã³ã®ãµã¤ãº(ãã¯ã»ã«)"
#, fuzzy
-#~ msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
-#~ msgstr "'g.gnuplot'ã³ãã³ãå½¢å¼ã§åºå"
+msgid ""
+"Interactively label sites using a string or double attribute value or the "
+"category value on the current graphics monitor."
+msgstr "ãµã¤ãã©ãã«ã表示ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Convert an ASCII listing of site locations into a GRASS site list file."
+msgid "Name of sites file"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "sites file to be created"
+msgid "Index of attribute. Ignored when attr=cat or attr=coords."
+msgstr "屿§çªå·"
#, fuzzy
-#~ msgid "number of dimensions (default=2)"
-#~ msgstr "é
åã®æ°(ããã©ã«ã2)"
+msgid "Relative horizontal position 'left|center|right'"
+msgstr "ä½ç½®(æ°´å¹³æ¹å)"
#, fuzzy
-#~ msgid "input field separator"
-#~ msgstr "åºåã"
+msgid "Relative vertical position 'top|center|bottom'"
+msgstr "ä½ç½®(éç´æ¹å)"
#, fuzzy
-#~ msgid "datetime or datetime1/datetime2"
+msgid "Size of text (pixels)"
+msgstr "ããã¹ãã®ãµã¤ãº"
#, fuzzy
-#~ msgid ""
-#~ "Allows the user to re-project a sites file from one location to the "
-#~ "current location (no datum transformation yet)."
-#~ msgstr "ãµã¤ããããã®æå½±å¤æãè¡ãã¾ã"
+msgid "Sets the font"
+msgstr "ãã©ã³ã"
#, fuzzy
-#~ msgid "input sites list"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Sets the current grid color"
+msgstr "ç·ã®è²"
#, fuzzy
-#~ msgid "location of input sites list"
-#~ msgstr "åæå½±ãè¡ããã±ã¼ã·ã§ã³"
+msgid ""
+"displays vector maps, optionally only selected categories in current monitor "
+"window."
+msgstr "ãã¯ãã«ãããã表示ãã¾ã"
#, fuzzy
-#~ msgid "mapset of input sites list"
-#~ msgstr "ç®çãã¡ã¤ã«ãå«ããããã»ãã"
+msgid "Vector category number(s) to be displayed"
#, fuzzy
-#~ msgid "output sites list"
+msgid "Fill areas of selected polygons"
+msgstr "鏿ããã«ãã´ãªã¼çªå·ã®é åãå¡ãã¤ã¶ã"
#, fuzzy
-#~ msgid "List sites files in input location and exit"
+msgid "Input is a UNIX file name"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Don't prompt for Map header information"
-#~ msgstr "ãããã¼ãåé¤"
+msgid ""
+"Allows the user to establish whether a map will be displayed using its own "
+"color table or the fixed color table of the graphics monitor."
+msgstr "ã¢ãã¿ã¼ã«ç¨ããã«ã©ã¼ãã¼ãã«ãè¨å®ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Field type (\"string\", \"dim\", or \"decimal\") and index to use for "
-#~ "category value (uses \"cat\" by default)"
-#~ msgstr "屿§ã¿ã¤ãã¾ãã¯å±æ§çªå·"
+msgid "Creates and modifies icons for use with ps.map."
+msgstr "ãã¹ãã¹ã¯ãªãããããã«ä½¿ç¨ããã¢ã¤ã³ã³ã®ä½æ/ç·¨éãè¡ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively adjust the settings (zoom and pan) of "
-#~ "the current geographic region using a pointing device such as a mouse."
-#~ msgstr "対象å°åã®ãºã¼ã /ãã³ããã¦ã¹ã«ããè¡ãã¾ã"
+msgid "icon filename"
#, fuzzy
-#~ msgid ""
-#~ "Displays points, as icons, at user-defined locations in the active "
-#~ "display frame on the graphics monitor."
-#~ msgstr "ã¢ã¤ã³ã³ã§ãã¤ã³ããã¼ã«ã¼ã表示ãã¾ã"
+msgid ""
+"file containing mapping instructions (or use input=- to enter from keyboard)"
+msgstr "è¨å®ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Name of existing sites file"
-#~ msgstr "対象ããã"
+msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
+msgstr "ã¹ã±ã¼ã« (ä¾: 1:25000)"
#, fuzzy
-#~ msgid "Identify just one site"
-#~ msgstr "1度ã®ã¿å®è¡"
+msgid "number of copies to print"
+msgstr "鍿°"
#, fuzzy
-#~ msgid "For parsing by programs: Terse output"
-#~ msgstr "ç°¡æè¡¨ç¤º"
+msgid "Selects a PostScript device for GRASS hardcopy output."
+msgstr "ãã¼ãã³ãã¼ãåºåããããã¤ã¹ã鏿ãã¾ã"
#, fuzzy
-#~ msgid "Allows the user to interactively query site list descriptions. "
-#~ msgstr ""
-#~ "ãã¦ã¹ã§æå®ããä½ç½®ã§ã®ãµã¤ããããã®ã«ãã´ãªã¼æ
å ±ã表示ãã¾ã(ããã¯ã©"
-#~ "ã?ãªã«?)"
+msgid "name of PostScript painter to select"
+msgstr "使ç¨ããããã¤ã¹"
#, fuzzy
-#~ msgid "Color to erase with"
-#~ msgstr "å¡ãã¤ã¶ãè²"
+msgid "list all available PostScript painters"
+msgstr "ãã¹ãã¹ã¯ãªãããã¤ã³ã¿ã®ä¸è¦§è¡¨ç¤º"
#, fuzzy
-#~ msgid "Name of a spheroid (for lat/lon coordinate conversion)"
-#~ msgstr "夿å
ã®æ¥åä½"
+msgid "print name of currently selected PostScript painter"
+msgstr "ç¾å¨é¸æããã¦ãããã¤ã³ã¿åã表示"
#, fuzzy
-#~ msgid "Displays three-dimensional images based on raster map layers"
-#~ msgstr "ã©ã¹ã¿ã¼ããããï¼æ¬¡å
ã§è¡¨ç¤ºãã¾ã"
+msgid "quietly select PostScript painter"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid "The raster map used to generate the color"
-#~ msgstr "è²ã®ã©ã¹ã¿ã¼ããã"
+msgid "Creates raster maps from ERDAS files."
+msgstr "ERDAS/LANãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "The raster map used to generate the 3-d texture"
-#~ msgstr "æ¨é«ã®ã©ã¹ã¿ã¼ããã"
+msgid "List the ERDAS header only"
+msgstr "ãããã¼ã®ã¿ä¸è¦§è¡¨ç¤º"
#, fuzzy
-#~ msgid "coordinates of center of view"
-#~ msgstr "è¦éã®ä¸å¿åº§æ¨"
+msgid "Disable autoswap detection"
+msgstr "èªåã§ãããå転ããªã"
#, fuzzy
-#~ msgid "Frequency of vector lines in output"
-#~ msgstr "æ ¼åéé"
+msgid "Force Swapping (overrides default auto)"
+msgstr "å¼·å¶ãããå転"
#, fuzzy
-#~ msgid "Field of view"
-#~ msgstr "è¦éã®è§åº¦"
+msgid "output prefix of the GRASS raster maps to be created."
#, fuzzy
-#~ msgid "Color of bounding box"
-#~ msgstr "æ ã®è²"
+msgid "Erdas trailer input file name"
+msgstr "ERDASãã¬ã¤ã©ã¼ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Show null elevations"
-#~ msgstr "NULLå¤ã表示"
+msgid "Starting row."
+msgstr "éå§è¡"
#, fuzzy
-#~ msgid "Draw labelled vector lines to the current display device"
-#~ msgstr "ãã¯ãã«ã©ã¤ã³ã表示ãã¾ã"
+msgid "Starting column."
+msgstr "éå§å"
#, fuzzy
-#~ msgid "Name of existing vector map to draw"
-#~ msgstr "対象ããã"
+msgid "Number of columns to extract."
+msgstr "æ½åºããåæ°"
#, fuzzy
-#~ msgid ""
-#~ "Draw all lines using either a GRASS standard color or R:G:B triplet "
-#~ msgstr "ç·ã®è²"
+msgid "Creates ERDAS files from raster maps."
+msgstr "GRASSã®ç»åãã¡ã¤ã«ãERDAS/LANãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Only draw areas with a matching category number (for constant color "
-#~ "option only)"
-#~ msgstr "表示ããã«ãã´ãªã¼çªå·"
+msgid "Output 16-bit image (default 8)"
+msgstr "16bitã¤ã¡ã¼ã¸ã§åºå"
#, fuzzy
-#~ msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
-#~ msgstr "å¡ä¾ç¨ãã¡ã¤ã«"
+msgid "Force byte swapping"
#, fuzzy
-#~ msgid "Use random colors"
-#~ msgstr "ã©ã³ãã ãªè²ã使ç¨"
+msgid "Erdas output file name"
#, fuzzy
-#~ msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "å¢çç·ã®è²"
+msgid "Allows category values from several raster map layers to be combined."
+msgstr "ã©ã¹ã¿ã¼ãããã®ã«ãã´ãªã¼å¤ãè«çæä½ãã¾ã"
#, fuzzy
-#~ msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgid "Use symbols (instead of graphics)"
+msgstr "ã·ã³ãã«ã使ç¨"
#, fuzzy
-#~ msgid "Limit to matching category number(s) (constant color option only)"
-#~ msgstr "表示ããã«ãã´ãªã¼çªå·(è²ãæå®ããã¦ããã¨ãã®ã¿æå¹)"
+msgid "Import non-georeferenced PNG format image."
+msgstr "PNGãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
+msgid "Verbose mode on."
+msgstr "説æä»ã表示"
#, fuzzy
-#~ msgid "Sets the current color to that stated"
-#~ msgstr "è²"
+msgid "Enable extend memory option: Operation is slow"
+msgstr "ä»®æ³ã¡ã¢ãªã使ç¨"
#, fuzzy
-#~ msgid "Size, in pixels, in which the icon is to be drawn"
-#~ msgstr "ã¢ã¤ã³ã³ã®ãµã¤ãº(ãã¯ã»ã«)"
+msgid "Name of an output binary map (use out=- for stdout)"
#, fuzzy
-#~ msgid ""
-#~ "Interactively label sites using a string or double attribute value or the "
-#~ "category value on the current graphics monitor."
-#~ msgstr "ãµã¤ãã©ãã«ã表示ãã¾ã"
+msgid ""
+"Converts point data in a GRASS raster map layer into a GRASS site_lists file."
+msgstr "ã©ã¹ã¿ã¼ããããããã¼ã¿ãæ½åºãã¦ãµã¤ããããã«å¤æãã¾ã"
#, fuzzy
-#~ msgid "Name of sites file"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "Output as decimal attribute rather than cat"
+msgstr "屿§çªå·ã¨ãã¦åºå"
#, fuzzy
-#~ msgid "Index of attribute. Ignored when attr=cat or attr=coords."
-#~ msgstr "屿§çªå·"
+msgid "Output as third dimension rather than cat"
+msgstr "æ¨é«å¤ã¨ãã¦åºå"
#, fuzzy
-#~ msgid "Relative horizontal position 'left|center|right'"
-#~ msgstr "ä½ç½®(æ°´å¹³æ¹å)"
+msgid ""
+"Creates a new binary GRASS vector (v.digit) file by extracting linear "
+"features from a thinned raster map."
+msgstr "ç´°ç·åããã©ã¹ã¿ã¼ããããããã¯ãã«ãããã使ãã¾ã"
#, fuzzy
-#~ msgid "Relative vertical position 'top|center|bottom'"
-#~ msgstr "ä½ç½®(éç´æ¹å)"
+msgid "Line type of the extracted vectors"
+msgstr "åºåã¿ã¤ã"
#, fuzzy
-#~ msgid "Size of text (pixels)"
-#~ msgstr "ããã¹ãã®ãµã¤ãº"
+msgid ""
+"Creates a raster map layer and site list file containing randomly located "
+"sites."
+msgstr "ä»»ææ½åºãè¡ãã¾ã"
#, fuzzy
-#~ msgid "Sets the font"
-#~ msgstr "ãã©ã³ã"
+msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
+msgstr "TIFFãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "Sets the current grid color"
-#~ msgstr "ç·ã®è²"
+msgid "Name on TIFF file to input."
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid ""
-#~ "displays vector maps, optionally only selected categories in current "
-#~ "monitor window."
-#~ msgstr "ãã¯ãã«ãããã表示ãã¾ã"
+msgid "Bayesian expert system development program."
+msgstr "ãã¤ãºã®çµ±è¨ã«åºã¥ããæ¨è«è¦åãé©ç¨ãæ°ããã©ã¹ã¿ã¼ãããã使ãã¾ã"
#, fuzzy
-#~ msgid "Vector category number(s) to be displayed"
+msgid "Run verbosely with debugging output"
+msgstr "説æä»ã表示"
#, fuzzy
-#~ msgid "Fill areas of selected polygons"
-#~ msgstr "鏿ããã«ãã´ãªã¼çªå·ã®é åãå¡ãã¤ã¶ã"
+msgid "The site list"
+msgstr "åºå:ã¯ã©ã³ãã®éå¿ã示ããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Input is a UNIX file name"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "raster map(s) to report on"
+msgstr "対象ããã"
#, fuzzy
-#~ msgid ""
-#~ "Allows the user to establish whether a map will be displayed using its "
-#~ "own color table or the fixed color table of the graphics monitor."
-#~ msgstr "ã¢ãã¿ã¼ã«ç¨ããã«ã©ã¼ãã¼ãã«ãè¨å®ãã¾ã"
+msgid ""
+"mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p"
+"(ercent_cover)"
+msgstr "åä½"
#, fuzzy
-#~ msgid "Creates and modifies icons for use with ps.map."
-#~ msgstr "ãã¹ãã¹ã¯ãªãããããã«ä½¿ç¨ããã¢ã¤ã³ã³ã®ä½æ/ç·¨éãè¡ãã¾ã"
+msgid "name of an output file to hold the report"
+msgstr "åºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "icon filename"
+msgid "number of fp subranges to collect stats from"
+msgstr "èª¤å·®ã®æ¡æ°"
#, fuzzy
-#~ msgid ""
-#~ "file containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr "è¨å®ãã¡ã¤ã«"
+msgid "filter out all no data cells"
+msgstr "NULLå¤ã対象ã«å«ã¾ãªã"
#, fuzzy
-#~ msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
-#~ msgstr "ã¹ã±ã¼ã« (ä¾: 1:25000)"
+msgid "filter out cells where all maps have no data"
+msgstr "ãã¹ã¦ã®ãããã§NULLå¤ã¨ãªã£ã¦ããã»ã«ãé¤ã"
#, fuzzy
-#~ msgid "number of copies to print"
-#~ msgstr "鍿°"
+msgid "report for cats fp ranges (fp maps only)"
+msgstr "宿°ã§ã¬ãã¼ããåºå"
#, fuzzy
-#~ msgid "Selects a PostScript device for GRASS hardcopy output."
-#~ msgstr "ãã¼ãã³ãã¼ãåºåããããã¤ã¹ã鏿ãã¾ã"
+msgid ""
+"Generates an output raster map layer with contiguous areas grown by one cell "
+"(pixel)."
+msgstr "ã¨ãªã¢ãæ¡å¤§ããã©ã¹ã¿ã¼ãããã使ãã¾ã"
#, fuzzy
-#~ msgid "name of PostScript painter to select"
-#~ msgstr "使ç¨ããããã¤ã¹"
+msgid ""
+"re-project a raster map from one location to the current location (no datum "
+"transformation yet)"
+msgstr "ã©ã¹ã¿ã¼ãããã®æå½±å¤æãè¡ãã¾ã"
#, fuzzy
-#~ msgid "list all available PostScript painters"
-#~ msgstr "ãã¹ãã¹ã¯ãªãããã¤ã³ã¿ã®ä¸è¦§è¡¨ç¤º"
+msgid "mapset of input map"
#, fuzzy
-#~ msgid "print name of currently selected PostScript painter"
-#~ msgstr "ç¾å¨é¸æããã¦ãããã¤ã³ã¿åã表示"
+msgid "resolution of output map"
+msgstr "è§£å度"
#, fuzzy
-#~ msgid "quietly select PostScript painter"
-#~ msgstr "説æãªã"
+msgid "Don't attempt to crop output map"
+msgstr "æå½±å¾ã®ä¸è¦é¨åãåé¤ããªã"
#, fuzzy
-#~ msgid "Creates raster maps from ERDAS files."
-#~ msgstr "ERDAS/LANãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
+msgid "Print grid coordinates (east and north) (requires -1 flag)"
+msgstr "æ ¼åç¹ã®åº§æ¨ãåºå"
#, fuzzy
-#~ msgid "List the ERDAS header only"
-#~ msgstr "ãããã¼ã®ã¿ä¸è¦§è¡¨ç¤º"
+msgid "output is the interpolation error"
+msgstr "誤差ãåºå"
#, fuzzy
-#~ msgid "Disable autoswap detection"
-#~ msgstr "èªåã§ãããå転ããªã"
+msgid "read fp map as integer"
#, fuzzy
-#~ msgid "Force Swapping (overrides default auto)"
-#~ msgstr "å¼·å¶ãããå転"
+msgid "format for reporting the slope"
+msgstr "徿ã®åä½"
#, fuzzy
-#~ msgid "output prefix of the GRASS raster maps to be created."
+msgid "type of output aspect and slope maps"
+msgstr "åºåããå¤ã®å"
#, fuzzy
-#~ msgid "Erdas trailer input file name"
-#~ msgstr "ERDASãã¬ã¤ã©ã¼ãã¡ã¤ã«"
+msgid "Output E-W slope filename"
+msgstr "æ±è¥¿æ¹åã®å¾æãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Starting row."
-#~ msgstr "éå§è¡"
+msgid "Output N-S slope filename"
+msgstr "ååæ¹åã®å¾æãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Starting column."
-#~ msgstr "éå§å"
+msgid "Output partial derivative dxx filename"
+msgstr "dxxå¤ã®åå°é¢æ°ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Number of columns to extract."
-#~ msgstr "æ½åºããåæ°"
+msgid "Output partial derivative dyy filename"
+msgstr "dyyå¤ã®åå°é¢æ°ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Creates ERDAS files from raster maps."
-#~ msgstr "GRASSã®ç»åãã¡ã¤ã«ãERDAS/LANãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã"
+msgid "Output partial derivative dxy filename"
+msgstr "dxyå¤ã®åå°é¢æ°ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Output 16-bit image (default 8)"
-#~ msgstr "16bitã¤ã¡ã¼ã¸ã§åºå"
+msgid "Name of file for output (use out=- for stdout)"
#, fuzzy
-#~ msgid "Force byte swapping"
+msgid "print range only."
#, fuzzy
-#~ msgid "Erdas output file name"
+msgid ""
+"Converts raster data referenced using latitude and longitude coordinates to "
+"a UTM-referenced map layer in GRASS raster format."
+msgstr "緯度/çµåº¦åº§æ¨ãã¡ã¤ã«ãã UTM座æ¨ãã¡ã¤ã«ã使ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Allows category values from several raster map layers to be combined."
-#~ msgstr "ã©ã¹ã¿ã¼ãããã®ã«ãã´ãªã¼å¤ãè«çæä½ãã¾ã"
+msgid "input file"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Use symbols (instead of graphics)"
-#~ msgstr "ã·ã³ãã«ã使ç¨"
+msgid ""
+"one corner latitude and longitude of the input\n"
+"format: {nw|ne|sw|se},%s,%s"
+msgstr "é åã®ç«¯ã®åº§æ¨å¤ãå
¥åå½¢å¼: {nw|ne|sw|se},%s,%s"
#, fuzzy
-#~ msgid "Import non-georeferenced PNG format image."
-#~ msgstr "PNGãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
+msgid "resolution of the input (in arc seconds)"
+msgstr "è§£å度(ç§è§)"
#, fuzzy
-#~ msgid "Verbose mode on."
+msgid "Starting points site file"
+msgstr "å§ç¹ã示ããµã¤ãããã"
#, fuzzy
-#~ msgid "Enable extend memory option: Operation is slow"
-#~ msgstr "ä»®æ³ã¡ã¢ãªã使ç¨"
+msgid "Stop points site file"
+msgstr "çµç¹ã示ããµã¤ãããã"
#, fuzzy
-#~ msgid "Name of an output binary map (use out=- for stdout)"
+msgid ""
+"Extracts area edges from a raster map layer and converts data to GRASS "
+"vector format."
+msgstr "ã©ã¹ã¿ã¼ãããããã¨ãªã¢ã¨ãã¸ãæ½åºãã¦ãã¯ãã«ãããã使ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Converts point data in a GRASS raster map layer into a GRASS site_lists "
-#~ "file."
-#~ msgstr "ã©ã¹ã¿ã¼ããããããã¼ã¿ãæ½åºãã¦ãµã¤ããããã«å¤æãã¾ã"
+msgid "Output only area borders as vector lines"
+msgstr "ãã¯ãã«ã©ã¤ã³ãåºå"
#, fuzzy
-#~ msgid "Output as decimal attribute rather than cat"
-#~ msgstr "屿§çªå·ã¨ãã¦åºå"
+msgid "Number of values printed before wrapping a line"
+msgstr "èªã¿è¾¼ãæ¡æ°"
#, fuzzy
-#~ msgid "Output as third dimension rather than cat"
-#~ msgstr "æ¨é«å¤ã¨ãã¦åºå"
+msgid ""
+"\n"
+"Where color type is one of:\n"
+msgstr ""
+"\n"
+"ããã§ã®ã«ã©ã¼ãã¼ãã«(colorãã©ã¡ã¼ã¿)ã¯æ¬¡ã®ãã¡ã®ããããã§ã:\n"
#, fuzzy
-#~ msgid ""
-#~ "Creates a new binary GRASS vector (v.digit) file by extracting linear "
-#~ "features from a thinned raster map."
-#~ msgstr "ç´°ç·åããã©ã¹ã¿ã¼ããããããã¯ãã«ãããã使ãã¾ã"
+msgid " aspect (aspect oriented grey colors)\n"
+msgstr " aspect (ã°ã¬ã¼ã«ã©ã¼)\n"
#, fuzzy
-#~ msgid "Line type of the extracted vectors"
-#~ msgstr "åºåã¿ã¤ã"
+msgid " grey (linear grey scale)\n"
+msgstr " grey (ã°ã¬ã¼ã¹ã±ã¼ã«)\n"
#, fuzzy
-#~ msgid ""
-#~ "Creates a raster map layer and site list file containing randomly located "
-#~ "sites."
-#~ msgstr "ä»»ææ½åºãè¡ãã¾ã"
+msgid " grey.eq (histogram equalized grey scale)\n"
+msgstr " grey.eq (ãã¹ãã°ã©ã ãå¹³æ»åããã°ã¬ã¼ã¹ã±ã¼ã«)\n"
#, fuzzy
-#~ msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
-#~ msgstr "TIFFãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
+msgid " grey.log (histogram logarithmic transformed grey scale)\n"
+msgstr " grey.log (ãã¹ãã°ã©ã ã対æ°åããã°ã¬ã¼ã¹ã±ã¼ã«)\n"
#, fuzzy
-#~ msgid "Name on TIFF file to input."
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid " byg (blue through yellow to green colors)\n"
+msgstr " byg (éâé»âç·)\n"
#, fuzzy
-#~ msgid "Bayesian expert system development program."
-#~ msgstr ""
-#~ "ãã¤ãºã®çµ±è¨ã«åºã¥ããæ¨è«è¦åãé©ç¨ãæ°ããã©ã¹ã¿ã¼ãããã使ãã¾ã"
+msgid " byr (blue through yellow to red colors)\n"
+msgstr " byr (éâé»â赤)\n"
#, fuzzy
-#~ msgid "Run verbosely with debugging output"
+msgid " gyr (green through yellow to red colors)\n"
+msgstr " gyr (ç·âé»â赤)\n"
#, fuzzy
-#~ msgid "The site list"
-#~ msgstr "åºå:ã¯ã©ã³ãã®éå¿ã示ããã¡ã¤ã«"
+msgid " rainbow (rainbow color table)\n"
+msgstr " rainbow (ã¬ã¤ã³ãã¼)\n"
#, fuzzy
-#~ msgid "raster map(s) to report on"
-#~ msgstr "対象ããã"
+msgid " ramp (color ramp)\n"
+msgstr " ramp (ã©ã³ã)\n"
#, fuzzy
-#~ msgid ""
-#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p"
-#~ "(ercent_cover)"
-#~ msgstr "åä½"
+msgid " ryg (red through yellow to green colors)\n"
+msgstr " ryg (赤âé»âç·)\n"
#, fuzzy
-#~ msgid "name of an output file to hold the report"
+msgid " random (random color table)\n"
+msgstr " random (ã©ã³ãã )\n"
#, fuzzy
-#~ msgid "number of fp subranges to collect stats from"
-#~ msgstr "èª¤å·®ã®æ¡æ°"
+msgid " wave (color wave)\n"
+msgstr " wave (ã«ã©ã¼ã¦ã§ã¼ã)\n"
#, fuzzy
-#~ msgid "filter out all no data cells"
-#~ msgstr "NULLå¤ã対象ã«å«ã¾ãªã"
+msgid " rules (create new color table by rules)\n"
+msgstr " rules (ã«ã¼ã«ã®æ°è¦ä½æ)\n"
#, fuzzy
-#~ msgid "filter out cells where all maps have no data"
-#~ msgstr "ãã¹ã¦ã®ãããã§NULLå¤ã¨ãªã£ã¦ããã»ã«ãé¤ã"
+msgid "method of object-based statistic"
+msgstr "çµ±è¨è§£ææ¹æ³"
#, fuzzy
-#~ msgid "report for cats fp ranges (fp maps only)"
-#~ msgstr "宿°ã§ã¬ãã¼ããåºå"
+msgid "resultant raster map (not used with 'distribution')"
#, fuzzy
-#~ msgid ""
-#~ "Generates an output raster map layer with contiguous areas grown by one "
-#~ "cell (pixel)."
-#~ msgstr "ã¨ãªã¢ãæ¡å¤§ããã©ã¹ã¿ã¼ãããã使ãã¾ã"
+msgid "Northern limit of geographic region"
+msgstr "é åã®å端"
#, fuzzy
-#~ msgid ""
-#~ "re-project a raster map from one location to the current location (no "
-#~ "datum transformation yet)"
-#~ msgstr "ã©ã¹ã¿ã¼ãããã®æå½±å¤æãè¡ãã¾ã"
+msgid "Eastern limit of geographic region"
+msgstr "é åã®æ±ç«¯"
#, fuzzy
-#~ msgid "mapset of input map"
+msgid "Western limit of geographic region"
+msgstr "é åã®è¥¿ç«¯"
#, fuzzy
-#~ msgid "resolution of output map"
-#~ msgstr "è§£å度"
+msgid "Override projection (use locations projection)"
+msgstr "ç¾å¨ã®ãã±ã¼ã·ã§ã³ã®æå½±æ³ã使ç¨"
#, fuzzy
-#~ msgid "Don't attempt to crop output map"
-#~ msgstr "æå½±å¾ã®ä¸è¦é¨åãåé¤ããªã"
+msgid "Extend location extents based on new dataset."
+msgstr "ãã¼ã¿ã»ããããã¨ã«ãã±ã¼ã·ã§ã³ãæ¡å¼µ"
#, fuzzy
-#~ msgid "Print grid coordinates (east and north) (requires -1 flag)"
-#~ msgstr "æ ¼åç¹ã®åº§æ¨ãåºå"
+msgid "Maximum magnitude of random grid point offset"
+msgstr "ã©ã³ãã ã«ã¨ããªãã»ããã®æå¤§å¤"
#, fuzzy
-#~ msgid "output is the interpolation error"
-#~ msgstr "誤差ãåºå"
+msgid ""
+"Outputs a raster map layer whose category values represent the application "
+"of user-specified criteria (rules statements) to other raster map layers' "
+"category values."
+msgstr "æå®ããæ¨è«è¦åãé©ç¨ãæ°ããã©ã¹ã¿ã¼ãããã使ãã¾ã"
#, fuzzy
-#~ msgid "read fp map as integer"
+msgid "Converts a PPM image file to GRASS raster map(s)."
+msgstr "PPMãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
#, fuzzy
-#~ msgid "format for reporting the slope"
-#~ msgstr "徿ã®åä½"
+msgid "Create separate red/green/blue maps."
+msgstr "赤/ç·/éã«å¯¾å¿ããã©ã¹ã¿ã¼ããããåºå"
#, fuzzy
-#~ msgid "type of output aspect and slope maps"
-#~ msgstr "åºåããå¤ã®å"
+msgid "Create composite color map."
+msgstr "åæããè²ã®ã©ã¹ã¿ã¼ããããåºå"
#, fuzzy
-#~ msgid "Output E-W slope filename"
-#~ msgstr "æ±è¥¿æ¹åã®å¾æãåºåãããã¡ã¤ã«"
+msgid ""
+"Converts Universal Transverse Mercator (UTM) coordinates to geographic "
+"(latitude/longitude) coordinates."
+msgstr "UTM座æ¨å¤ãã緯度/çµåº¦åº§æ¨å¤ã«å¤æãã¾ã"
#, fuzzy
-#~ msgid "Output N-S slope filename"
-#~ msgstr "ååæ¹åã®å¾æãåºåãããã¡ã¤ã«"
+msgid "reference spheroid (ellipsoid)"
+msgstr "æ¥åä½"
#, fuzzy
-#~ msgid "Output partial derivative dxx filename"
-#~ msgstr "dxxå¤ã®åå°é¢æ°ãåºåãããã¡ã¤ã«"
+msgid "Specified zone is in the southern hemisphere"
+msgstr "é åãååçã§æå®"
#, fuzzy
-#~ msgid "Output partial derivative dyy filename"
-#~ msgstr "dyyå¤ã®åå°é¢æ°ãåºåãããã¡ã¤ã«"
+msgid "Input is reversed: north,east"
+msgstr "å
¥åãã座æ¨å¤ãå転(north,east)"
#, fuzzy
-#~ msgid "Output partial derivative dxy filename"
-#~ msgstr "dxyå¤ã®åå°é¢æ°ãåºåãããã¡ã¤ã«"
+msgid "Do not flag invalid east,north input lines as errors"
+msgstr "é åå¤ã®åº§æ¨ãå
¥åããã¦ãç¶è¡"
#, fuzzy
-#~ msgid "Name of file for output (use out=- for stdout)"
-#~ msgstr "åºåãããã¡ã¤ã«"
+msgid "Flag other input lines as errors"
+msgstr "ä»ã®å½¢å¼ã§å
¥åããã£ãå ´åã¯ä¸æ¢"
#, fuzzy
-#~ msgid "print range only."
+msgid "Output in decimal degrees"
+msgstr "10鲿°ã§åºå"
#, fuzzy
-#~ msgid ""
-#~ "Converts raster data referenced using latitude and longitude coordinates "
-#~ "to a UTM-referenced map layer in GRASS raster format."
-#~ msgstr "緯度/çµåº¦åº§æ¨ãã¡ã¤ã«ãã UTM座æ¨ãã¡ã¤ã«ã使ãã¾ã"
+msgid ""
+"Converts geographic coordinates to Universal Transverse Mercator (UTM) "
+"coordinates."
+msgstr "緯度/çµåº¦åº§æ¨å¤ããUTM座æ¨å¤ã«å¤æãã¾ã"
#, fuzzy
-#~ msgid "input file"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+msgid "utm zone (results will be forced into this zone)"
+msgstr "UTMã¾ã¼ã³"
#, fuzzy
-#~ msgid ""
-#~ "one corner latitude and longitude of the input\n"
-#~ "format: {nw|ne|sw|se},%s,%s"
-#~ msgstr "é åã®ç«¯ã®åº§æ¨å¤ãå
+msgid "Input is reversed: lat,lon"
+msgstr "å
¥åãã座æ¨å¤ãå転(çµåº¦,緯度)"
#, fuzzy
-#~ msgid "resolution of the input (in arc seconds)"
-#~ msgstr "è§£å度(ç§è§)"
+msgid "Do not flag invalid lon,lat input lines as errors"
¥åããã¦ãç¶è¡"
#, fuzzy
-#~ msgid "Starting points site file"
-#~ msgstr "å§ç¹ã示ããµã¤ãããã"
+msgid "Suppress printing the utm zone"
+msgstr "UTMã¾ã¼ã³ãåºåããªã"
#, fuzzy
-#~ msgid "Stop points site file"
-#~ msgstr "çµç¹ã示ããµã¤ãããã"
+msgid ""
+"Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
+msgstr "æ½åºããæ¨é«ãã¼ã¿ã90度å転ãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "Extracts area edges from a raster map layer and converts data to GRASS "
-#~ "vector format."
-#~ msgstr "ã©ã¹ã¿ã¼ãããããã¨ãªã¢ã¨ãã¸ãæ½åºãã¦ãã¯ãã«ãããã使ãã¾ã"
+msgid "Output file"
#, fuzzy
-#~ msgid "Output only area borders as vector lines"
-#~ msgstr "ãã¯ãã«ã©ã¤ã³ãåºå"
+msgid "Number of bytes per cell (i.e. per data value)"
+msgstr "1ã»ã«ã®ãã¤ãæ°"
#, fuzzy
-#~ msgid "Number of values printed before wrapping a line"
-#~ msgstr "èªã¿è¾¼ãæ¡æ°"
+msgid ""
+"Provides a terse description of level 1 and 2 digital terrain elevation data "
+"(DTED) files produced and distributed by the Defense Mapping Agency (DMA) on "
+"1/2-inch magnetic tapes."
+msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDTEDãç°¡æè¡¨ç¤ºãã¾ã"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where color type is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ããã§ã®ã«ã©ã¼ãã¼ãã«(colorãã©ã¡ã¼ã¿)ã¯æ¬¡ã®ãã¡ã®ããããã§ã:\n"
+msgid "Name of tape drive device"
+msgstr "å
¥åããããã¤ã¹"
#, fuzzy
-#~ msgid " aspect (aspect oriented grey colors)\n"
-#~ msgstr " aspect (ã°ã¬ã¼ã«ã©ã¼)\n"
+msgid ""
+"Datum shift program. Return geographic coordinates based on a different "
+"datum that the one used to obtain the original coordinates. "
+msgstr "æ¥åä½éã®ãã¼ã¿ã·ãããè¡ãã¾ã"
#, fuzzy
-#~ msgid " grey (linear grey scale)\n"
-#~ msgstr " grey (ã°ã¬ã¼ã¹ã±ã¼ã«)\n"
+msgid "use block shift transformation (default)"
+msgstr "ãããã¯å¤æã«ããã·ãã(ããã©ã«ã)"
#, fuzzy
-#~ msgid " grey.eq (histogram equalized grey scale)\n"
-#~ msgstr " grey.eq (ãã¹ãã°ã©ã ãå¹³æ»åããã°ã¬ã¼ã¹ã±ã¼ã«)\n"
+msgid "use bursa wolf 3d similarity transformation (not implemented)"
+msgstr "BURSA夿ã«ããã·ãã(æªå®è£
#, fuzzy
-#~ msgid " grey.log (histogram logarithmic transformed grey scale)\n"
-#~ msgstr " grey.log (ãã¹ãã°ã©ã ã対æ°åããã°ã¬ã¼ã¹ã±ã¼ã«)\n"
+msgid "height above ellipsoid"
+msgstr "é·åããã®é«ã"
#, fuzzy
-#~ msgid " byg (blue through yellow to green colors)\n"
-#~ msgstr " byg (éâé»âç·)\n"
+msgid "input spheroid"
+msgstr "å
ã®æ¥åä½"
#, fuzzy
-#~ msgid " byr (blue through yellow to red colors)\n"
-#~ msgstr " byr (éâé»â赤)\n"
+msgid "output spheroid"
+msgstr "ã·ããå
ã®æ¥åä½"
#, fuzzy
-#~ msgid " gyr (green through yellow to red colors)\n"
-#~ msgstr " gyr (ç·âé»â赤)\n"
+msgid "input datum"
+msgstr "å
ã®ãã¼ã¿"
#, fuzzy
-#~ msgid " rainbow (rainbow color table)\n"
-#~ msgstr " rainbow (ã¬ã¤ã³ãã¼)\n"
+msgid "output datum"
+msgstr "ã·ããå
ã®ãã¼ã¿"
#, fuzzy
-#~ msgid " ramp (color ramp)\n"
-#~ msgstr " ramp (ã©ã³ã)\n"
+msgid "x shift"
+msgstr "Xæ¹åã®ã·ãã"
#, fuzzy
-#~ msgid " ryg (red through yellow to green colors)\n"
-#~ msgstr " ryg (赤âé»âç·)\n"
+msgid "y shift"
+msgstr "Yæ¹åã®ã·ãã"
#, fuzzy
-#~ msgid " random (random color table)\n"
-#~ msgstr " random (ã©ã³ãã )\n"
+msgid "z shift"
+msgstr "Zæ¹åã®ã·ãã"
#, fuzzy
-#~ msgid " wave (color wave)\n"
-#~ msgstr " wave (ã«ã©ã¼ã¦ã§ã¼ã)\n"
+msgid "Rx rotational parameter"
+msgstr "ã¹ã ã¼ã¸ã³ã°ãã©ã¡ã¼ã¿"
#, fuzzy
-#~ msgid " rules (create new color table by rules)\n"
-#~ msgstr " rules (ã«ã¼ã«ã®æ°è¦ä½æ)\n"
+msgid "Ry rotational parameter"
#, fuzzy
-#~ msgid "method of object-based statistic"
-#~ msgstr "çµ±è¨è§£ææ¹æ³"
+msgid "Rz rotational parameter"
#, fuzzy
-#~ msgid "resultant raster map (not used with 'distribution')"
+msgid "spheroid geographic coordinates to base on. "
+msgstr "å°å¿åº§æ¨å¤ãã緯度/çµåº¦å¤ã«å¤æãã¾ã"
#, fuzzy
-#~ msgid "Northern limit of geographic region"
-#~ msgstr "é åã®å端"
+msgid ""
+"Converts UTM coordinates falling within the current geographic region to "
+"geographic (latitude/longitude) coordinates. "
+msgstr "ç¾å¨ã®é åãUTM座æ¨ãã緯度/çµåº¦åº§æ¨ã«å¤æãã¾ã"
#, fuzzy
-#~ msgid "Eastern limit of geographic region"
-#~ msgstr "é åã®æ±ç«¯"
+msgid ""
+"Flips elevation data extracted from systems that retrieve data by rows from "
+"south to north."
+msgstr "æ½åºããæ¨é«ãã¼ã¿ã180度å転ãã¾ã180度å転ãã¾ã"
#, fuzzy
-#~ msgid "Western limit of geographic region"
-#~ msgstr "é åã®è¥¿ç«¯"
+msgid "Number of bytes per cell (ie, per data value)"
#, fuzzy
-#~ msgid "Override projection (use locations projection)"
-#~ msgstr "ç¾å¨ã®ãã±ã¼ã·ã§ã³ã®æå½±æ³ã使ç¨"
+msgid ""
+"Finds geographic region information for U.S. Census Bureau TIGER input data."
+msgstr "TMS(TIGER MAPPING SERVISE)ã«å
¥åããå°åæ
å ±ãã¼ã¿ãæ¤ç´¢ãã¾ã"
#, fuzzy
-#~ msgid "Extend location extents based on new dataset."
-#~ msgstr "ãã¼ã¿ã»ããããã¨ã«ãã±ã¼ã·ã§ã³ãæ¡å¼µ"
+msgid "Filename for raw tiger data (type 1)"
+msgstr "å
¥åãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Maximum magnitude of random grid point offset"
-#~ msgstr "ã©ã³ãã ã«ã¨ããªãã»ããã®æå¤§å¤"
+msgid "UTM zone for this county"
+msgstr "UTMã¾ã¼ã³"
#, fuzzy
-#~ msgid ""
-#~ "Outputs a raster map layer whose category values represent the "
-#~ "application of user-specified criteria (rules statements) to other raster "
-#~ "map layers' category values."
-#~ msgstr "æå®ããæ¨è«è¦åãé©ç¨ãæ°ããã©ã¹ã¿ã¼ãããã使ãã¾ã"
+msgid ""
+"Provides a terse description of USGS Digital Elevation Model (DEM) data "
+"files stored on 1/2-inch magnetic tape."
+msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDEMãç°¡æè¡¨ç¤ºãã¾ã"
#, fuzzy
-#~ msgid "Converts a PPM image file to GRASS raster map(s)."
-#~ msgstr "PPMãã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã"
+msgid "Tape input device"
+msgstr "å
¥åããããã¤ã¹"
#, fuzzy
-#~ msgid "Create separate red/green/blue maps."
-#~ msgstr "赤/ç·/éã«å¯¾å¿ããã©ã¹ã¿ã¼ããããåºå"
+msgid "Blocksize of tape data"
+msgstr "ãã¼ã¿ã®ãããã¯ãµã¤ãº"
#, fuzzy
-#~ msgid "Create composite color map."
-#~ msgstr "åæããè²ã®ã©ã¹ã¿ã¼ããããåºå"
+msgid "First file to examine"
+msgstr "éå§ãã¡ã¤ã«"
#, fuzzy
-#~ msgid ""
-#~ "Converts Universal Transverse Mercator (UTM) coordinates to geographic "
-#~ "(latitude/longitude) coordinates."
-#~ msgstr "UTM座æ¨å¤ãã緯度/çµåº¦åº§æ¨å¤ã«å¤æãã¾ã"
+msgid "Last file to examine"
+msgstr "çµäºãã¡ã¤ã«"
#, fuzzy
-#~ msgid "reference spheroid (ellipsoid)"
-#~ msgstr "æ¥åä½"
+msgid ""
+"Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and "
+"supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
+msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDTEDãæ½åºãã¾ã"
#, fuzzy
-#~ msgid "Specified zone is in the southern hemisphere"
-#~ msgstr "é åãååçã§æå®"
+msgid "Name of header output file"
+msgstr "ãããã¼ãåºåãããã¡ã¤ã«"
#, fuzzy
-#~ msgid "Input is reversed: north,east"
-#~ msgstr "å
+msgid "North latitude of region to extract (format: %s)"
+msgstr "å端(å
¥åå½¢å¼: %s)"
#, fuzzy
-#~ msgid "Do not flag invalid east,north input lines as errors"
-#~ msgstr "é åå¤ã®åº§æ¨ãå
¥åããã¦ãç¶è¡"
+msgid "South latitude of region to extract (format: %s)"
+msgstr "å端(å
¥åå½¢å¼: %s)"
#, fuzzy
-#~ msgid "Flag other input lines as errors"
-#~ msgstr "ä»ã®å½¢å¼ã§å
¥åããã£ãå ´åã¯ä¸æ¢"
+msgid "East longitude of region to extract (format: %s)"
+msgstr "æ±ç«¯(å
¥åå½¢å¼: %s)"
#, fuzzy
-#~ msgid "Output in decimal degrees"
-#~ msgstr "10鲿°ã§åºå"
+msgid "West longitude of region to extract (format: %s)"
+msgstr "西端(å
¥åå½¢å¼: %s)"
#, fuzzy
-#~ msgid ""
-#~ "Converts geographic coordinates to Universal Transverse Mercator (UTM) "
-#~ "coordinates."
-#~ msgstr "緯度/çµåº¦åº§æ¨å¤ããUTM座æ¨å¤ã«å¤æãã¾ã"
+msgid "Read the entire tape in all cases"
+msgstr "ãã¹ã¦ã®ãã¼ããèªã¿è¾¼ã"
#, fuzzy
-#~ msgid "utm zone (results will be forced into this zone)"
-#~ msgstr "UTMã¾ã¼ã³"
+msgid ""
+"Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
+msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDEMãã¼ã¿ãæ½åºãã¾ã"
#, fuzzy
-#~ msgid "Input is reversed: lat,lon"
-#~ msgstr "å
+msgid "Input device or file"
+msgstr "å
¥åããããã¤ã¹ã¾ãã¯ãã¡ã¤ã«"
#, fuzzy
-#~ msgid "Do not flag invalid lon,lat input lines as errors"
¥åããã¦ãç¶è¡"
+msgid "Output raster map (examine only if none specified)"
+msgstr "åºåãããã¡ã¤ã«(æªå
¥åã®å ´åã¯ãã§ãã¯ã®ã¿)"
#, fuzzy
-#~ msgid "Suppress printing the utm zone"
-#~ msgstr "UTMã¾ã¼ã³ãåºåããªã"
+msgid "First file to look at"
#, fuzzy
-#~ msgid ""
-#~ "Rotates elevation data extracted by either m.dted.extract or m."
-#~ "dmaUSGSread."
-#~ msgstr "æ½åºããæ¨é«ãã¼ã¿ã90度å転ãã¾ã"
+msgid "Last file to look at"
#, fuzzy
-#~ msgid "Output file"
+msgid "Selects a device (printer) for GRASS hardcopy output."
#, fuzzy
-#~ msgid "Number of bytes per cell (i.e. per data value)"
-#~ msgstr "1ã»ã«ã®ãã¤ãæ°"
+msgid "list all available painters"
+msgstr "ãã¤ã³ã¿ã®ä¸è¦§è¡¨ç¤º"
#, fuzzy
-#~ msgid ""
-#~ "Provides a terse description of level 1 and 2 digital terrain elevation "
-#~ "data (DTED) files produced and distributed by the Defense Mapping Agency "
-#~ "(DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDTEDãç°¡æè¡¨ç¤ºãã¾ã"
+msgid "print name of currently selected painter"
#, fuzzy
-#~ msgid "Name of tape drive device"
-#~ msgstr "å
¥åããããã¤ã¹"
+msgid "quietly select painter"
+msgstr "説æãªã"
#, fuzzy
-#~ msgid ""
-#~ "Datum shift program. Return geographic coordinates based on a different "
-#~ "datum that the one used to obtain the original coordinates. "
-#~ msgstr "æ¥åä½éã®ãã¼ã¿ã·ãããè¡ãã¾ã"
+msgid "Color map output utility."
+msgstr "ãã¼ãã³ãã¼åºåã®è¨å®ãè¡ãã¾ã"
#, fuzzy
-#~ msgid "use block shift transformation (default)"
-#~ msgstr "ãããã¯å¤æã«ããã·ãã(ããã©ã«ã)"
+msgid "Align region to resolution [default = align to bounds]"
+msgstr "å¢çãåè§£è½ã«åããã"
#, fuzzy
-#~ msgid "use bursa wolf 3d similarity transformation (not implemented)"
-#~ msgstr "BURSA夿ã«ããã·ãã(æªå®è£
+msgid "Set region to match this sites map"
+msgstr "è¨å®ã«ç¨ãããµã¤ãããã"
#, fuzzy
-#~ msgid "height above ellipsoid"
-#~ msgstr "é·åããã®é«ã"
+msgid "Value for the eastern edge "
+msgstr "å端"
#, fuzzy
-#~ msgid "input spheroid"
-#~ msgstr "å
ã®æ¥åä½"
+msgid "Value for the western edge "
+msgstr "西端"
#, fuzzy
-#~ msgid "output spheroid"
-#~ msgstr "ã·ããå
ã®æ¥åä½"
+msgid "Grid resolution (both north-south and east-west)"
+msgstr "æ ¼åã®åè§£è½"
#, fuzzy
-#~ msgid "input datum"
-#~ msgstr "å
ã®ãã¼ã¿"
+msgid "Overwrite <new> file(s)"
+msgstr "䏿¸ã"
#, fuzzy
-#~ msgid "output datum"
-#~ msgstr "ã·ããå
ã®ãã¼ã¿"
+msgid " vect (binary vector maps)\n"
+msgstr " vect (ãã¯ãã«ããã)\n"
#, fuzzy
-#~ msgid "x shift"
-#~ msgstr "Xæ¹åã®ã·ãã"
+msgid " icon (paint icon files)\n"
+msgstr " icon (ãã¤ã³ãã¢ã¤ã³ã³ãã¡ã¤ã«)\n"
#, fuzzy
-#~ msgid "y shift"
-#~ msgstr "Yæ¹åã®ã·ãã"
+msgid " labels (paint label files)\n"
+msgstr " labels (ãã¤ã³ãã©ãã«ãã¡ã¤ã«)\n"
#, fuzzy
-#~ msgid "z shift"
-#~ msgstr "Zæ¹åã®ã·ãã"
+msgid " sites (site list files)\n"
+msgstr " sites (ãµã¤ãããã)\n"
#, fuzzy
-#~ msgid "Rx rotational parameter"
-#~ msgstr "ã¹ã ã¼ã¸ã³ã°ãã©ã¡ã¼ã¿"
+msgid " group (imagery group files)\n"
+msgstr " group (ç»åã°ã«ã¼ã)\n"
#, fuzzy
-#~ msgid "Ry rotational parameter"
+msgid " 3dview (3D view parameters)\n"
+msgstr " 3dview (3次å
表示ãã©ã¡ã¼ã¿ãã¡ã¤ã«)\n"
#, fuzzy
-#~ msgid "Rz rotational parameter"
+msgid "Data type"
+msgstr "ãã¡ã¤ã«ã®ç¨®é¡"
#, fuzzy
-#~ msgid "spheroid geographic coordinates to base on. "
-#~ msgstr "å°å¿åº§æ¨å¤ãã緯度/çµåº¦å¤ã«å¤æãã¾ã"
+msgid "-1' for threshold based on the current resolution settings"
+msgstr "ç¾å¨ã®è¨å®ã表示"
#, fuzzy
-#~ msgid ""
-#~ "Converts UTM coordinates falling within the current geographic region to "
-#~ "geographic (latitude/longitude) coordinates. "
-#~ msgstr "ç¾å¨ã®é åãUTM座æ¨ãã緯度/çµåº¦åº§æ¨ã«å¤æãã¾ã"
+msgid "layer' must be > 0"
+msgstr "å
¥åãããã¡ã¤ã«"
-#, fuzzy
+msgid "Default value: GRASS_GUI if defined otherwise tcltk"
+msgstr "æ¢å®å¤: å®ç¾©ããã¦ããã°GRASS_GUI ããã§ãªããã°tcltk "
+msgid ""
+"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
+"Display Manager (d.m);wxpython;wxPython based next generation GUI;text;"
+"command line interface only"
+msgstr ""
+"tcltk;GUI ã«åºã¥ã Tcl/Tk - GIS管çè
(gis.m);oldtcltk;GUI ã«åºã¥ã Old Tcl/"
+"Tk - 表示管çè
(d.m);wxpython;次ä¸ä»£ GUIã«åºã¥ãwxPython;ããã¹ã;ã³ãã³ãã©"
+"ã¤ã³ã¤ã³ã¿ã¼ãã§ã¼ã¹ã®ã¿"
+msgid "Writes Z data to column instead of 3D vector"
+msgstr " 3D ãã¯ãã« ã®ä»£ããã«Z ãã¼ã¿ãã³ã©ã ã«æ¸ãè¾¼ã¿ã¾ã"
+msgid "Do not export long colortable"
+msgstr "大ãããµã¤ãºã®ã«ã©ã¼ãã¼ãã«ãã¨ã¯ã¹ãã¼ãããªã"
+msgid "unable to open new L map layer."
+msgstr "æ°è¦ã® Lãããã¬ã¤ã¤ã¼ãéãã¾ãã"
+msgid "unable to open new S map layer."
+msgstr "æ°è¦ã® S ãããã¬ã¤ã¤ã¼ãéãã¾ãã"
+msgid ""
+"Sorry, if any of the following options are set:\n"
+" basin, stream, half.basin, slope, or lS\n"
+" you MUST provide a value for the basin threshold parameter."
+msgstr ""
+"次ã®ãªãã·ã§ã³ã®ãããããã»ããããã¦ãã¾ã:\n"
+" basin, stream, half.basin, slope, lS\n"
+" çå°å¢çãã©ã¡ã¼ã¿ã®å¤ãå¿
ããã¦ãããå¿
è¦ãããã¾ã "
+msgid "SECTION 4: Length Slope determination."
+msgstr "ã»ã¯ã·ã§ã³ 4: é·ãã»å¾æã®æ±ºå®"
+msgid "SECTION 3: Accumulating Surface Flow."
+msgstr "ã»ã¯ã·ã§ã³ 3: 表層æµã®ç´¯è¨"
+msgid "Convex hull calculation requires at least three points"
+msgstr "å¸å
æ¼ç®ã«ã¯3ç¹ä»¥ä¸ãå¿
è¦"
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d was "
+"used to represent no-data values in the input map. You can specify nodata "
+"value by %s parameter."
+msgstr ""
+"å
¥åããã©ã¹ã¿ã¼ãããã¯NULLå¤ï¼ãã¼ã¿ç¡ãï¼ã»ã«ãå«ãã§ãã¾ãï¼ãã®æå®ãã"
+"ããããã§å¤ %d ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤ãæå®"
+"ã§ãã¾ã"
+#~ msgid "Not enough room in history file"
+#~ msgstr "å±¥æ´ãã¡ã¤ã«ã䏿¯ã§ã "
+#~ msgid "New MAPSET name"
+#~ msgstr "æ°ãããããã»ããå"
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "ãããã»ãããµã¼ããªã¹ãt:\n"
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "<%s> ã¯ãããã»ãããªã¹ãã«è¦ã¤ããã¾ããã§ãã"
+#~ msgid "** no mapsets **\n"
+#~ msgstr "** ãããã»ãããªã **\n"
+#~ msgid "Name of workspace file"
+#~ msgstr "使¥ãã¡ã¤ã«å"
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "表示ããå¤ã®ãªã¹ã (FP ããã)"
+#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#~ msgstr ""
+#~ "catlist ãç¡è¦ãã¦ãã¾ã: ãããã¯æµ®åå°æ°ç¹ã§ã ('val=' ã使ç¨ãã¦ãã ã"
+#~ "ã) "
+#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
+#~ msgstr ""
+#~ "vallistãç¡è¦ãã¦ãã¾ã: ãããã¯æ´æ°ã§ã ('cat='ã使ç¨ãã¦ãã ãã) "
+#~ msgid "Area size [%.1e], area not imported"
+#~ msgstr "é åãµã¤ãº [%.1e], é åã¯ã¤ã³ãã¼ãããã¦ãã¾ãã"
+#~ msgid "Island size [%.1e], island not imported"
+#~ msgstr "å³¶ã®ãµã¤ãº [%.1e], å³¶ã¯ã¤ã³ãã¼ãããã¦ãã¾ãã"
#~ msgid ""
-#~ "Flips elevation data extracted from systems that retrieve data by rows "
-#~ "from south to north."
-#~ msgstr "æ½åºããæ¨é«ãã¼ã¿ã180度å転ãã¾ã180度å転ãã¾ã"
+#~ "No vector map of sparse points to interpolate was specified. "
+#~ "Interpolation will be done with <%s> vector map"
+#~ msgstr ""
+#~ "è£éã«å¯¾ããå°éãã¤ã³ãã®ãã¯ãã«ãããã¯æå®ããã¾ããã§ãã. è£éã¯ãã¯"
+#~ "ãã«ãããã¨è¡ãªããã¾ã <%s> "
-#, fuzzy
-#~ msgid "Number of bytes per cell (ie, per data value)"
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "%s ãéãã¾ããã§ãã"
-#, fuzzy
#~ msgid ""
-#~ "Finds geographic region information for U.S. Census Bureau TIGER input "
-#~ "data."
-#~ msgstr "TMS(TIGER MAPPING SERVISE)ã«å
¥åããå°åæ
å ±ãã¼ã¿ãæ¤ç´¢ãã¾ã"
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "çã®æ¨é«å¤ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ãããæé¢ãæ¹ä½ãæ²é¢ãåå°é¢æ°ã®ã©ã¹ã¿ã¼"
+#~ "ãããã使ãã¾ã.ãæ¹ä½ã¯æ±ããåæè¨åãã«è¨ç®ãã¾ã"
-#, fuzzy
-#~ msgid "Filename for raw tiger data (type 1)"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+#~ msgid "Raster elevation file name"
+#~ msgstr "ã©ã¹ã¿ã¼æ¨é«ãã¡ã¤ã«å"
-#, fuzzy
-#~ msgid "UTM zone for this county"
+#~ msgid "Output slope filename"
+#~ msgstr "徿ãåºåãããã¡ã¤ã«å"
-#, fuzzy
-#~ msgid ""
-#~ "Provides a terse description of USGS Digital Elevation Model (DEM) data "
-#~ "files stored on 1/2-inch magnetic tape."
-#~ msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDEMãç°¡æè¡¨ç¤ºãã¾ã"
+#~ msgid "Output aspect filename"
+#~ msgstr "æ¹ä½ãåºåãããã¡ã¤ã«å"
-#, fuzzy
-#~ msgid "Tape input device"
-#~ msgstr "å
¥åããããã¤ã¹"
+#~ msgid "Output profile curvature filename"
+#~ msgstr "æé¢æ²çãåºåãããã¡ã¤ã«å"
-#, fuzzy
-#~ msgid "Blocksize of tape data"
-#~ msgstr "ãã¼ã¿ã®ãããã¯ãµã¤ãº"
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "æ£æ¥æ²çãåºåãããã¡ã¤ã«å"
-#, fuzzy
-#~ msgid "First file to examine"
-#~ msgstr "éå§ãã¡ã¤ã«"
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr "䏿¬¡ã®åå°é¢æ° dx (E-W 徿) ãåºåãããã¡ã¤ã«å"
-#, fuzzy
-#~ msgid "Last file to examine"
-#~ msgstr "çµäºãã¡ã¤ã«"
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr "䏿¬¡ã®åå°é¢æ° dy (N-S 徿) ãåºåãããã¡ã¤ã«å"
-#, fuzzy
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr "äºæ¬¡ã®åå°é¢æ° dxx ãåºåãããã¡ã¤ã«å"
+#~ msgid "Output second order partial derivative dyy filename"
+#~ msgstr "äºæ¬¡ã®åå°é¢æ° dyy ãåºåãããã¡ã¤ã«å"
+#~ msgid "Output second order partial derivative dxy filename"
+#~ msgstr "äºæ¬¡ã®åå°é¢æ° dxy ãåºåãããã¡ã¤ã«å"
#~ msgid ""
-#~ "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced "
-#~ "and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic "
-#~ "tapes."
-#~ msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDTEDãæ½åºãã¾ã"
+#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
+#~ "quiet' instead."
+#~ msgstr ""
+#~ "-q' ãã©ãã°ã¯å°æ¥å»æ¢ããã¾ãã'--quiet' ãã©ãã°ã使ç¨ãã¦ãã ããã"
-#, fuzzy
-#~ msgid "Name of header output file"
-#~ msgstr "ãããã¼ãåºåãããã¡ã¤ã«"
+#~ msgid "wrong type: %s"
+#~ msgstr "ééã£ãã¿ã¤ãï¼ %s"
-#, fuzzy
-#~ msgid "North latitude of region to extract (format: %s)"
-#~ msgstr "å端(å
¥åå½¢å¼: %s)"
+#~ msgid "Creating support files..."
+#~ msgstr "ãµãã¼ããã¡ã¤ã«ã使ä¸..."
-#, fuzzy
-#~ msgid "South latitude of region to extract (format: %s)"
-#~ msgstr "å端(å
¥åå½¢å¼: %s)"
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "ãããã»ãã [%s] ï¼[%s] å
ï¼ã®æ¨é«ã®ãããã¯ã"
-#, fuzzy
-#~ msgid "East longitude of region to extract (format: %s)"
-#~ msgstr "æ±ç«¯(å
¥åå½¢å¼: %s)"
+#~ msgid "ASPECT [%s] COMPLETE"
+#~ msgstr "æ¹ä½ [%s] å®äº"
-#, fuzzy
-#~ msgid "West longitude of region to extract (format: %s)"
-#~ msgstr "西端(å
¥åå½¢å¼: %s)"
+#~ msgid "SLOPE [%s] COMPLETE"
+#~ msgstr "徿 [%s] å®äº"
-#, fuzzy
-#~ msgid "Read the entire tape in all cases"
-#~ msgstr "ãã¹ã¦ã®ãã¼ããèªã¿è¾¼ã"
+#~ msgid "PROFILE CURVE [%s] COMPLETE"
+#~ msgstr "ãããã¡ã¤ã«æ²ç· [%s] å®äº"
+#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
+#~ msgstr "æ£æ¥æ²ç· [%s] å®äº"
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "E-W 徿 [%s] å®äº"
+#~ msgid "N-S SLOPE [%s] COMPLETE"
+#~ msgstr "N-S 徿 [%s] å®äº"
+#~ msgid "DXX [%s] COMPLETE"
+#~ msgstr "DXX [%s] å®äº"
+#~ msgid "DYY [%s] COMPLETE"
+#~ msgstr "DYY [%s] å®äº"
+#~ msgid "DXY [%s] COMPLETE"
+#~ msgstr "DXY [%s] å®äº"
+#~ msgid "Sources and sinks in [m^3/s]"
+#~ msgstr "æµå
¥ç©ã¨å®¹ç© [m^3/s] "
+#~ msgid "Specific yield in 1/m"
+#~ msgstr "ç¹å®ã®åç 1/m "
+#~ msgid "Input elevation map"
+#~ msgstr "å
¥åæ¨é«ããã"
+#~ msgid "Output shaded relief map name"
+#~ msgstr "åºåããé°å½±ã¬ãªã¼ããããå"
+#~ msgid "Layer number of data column"
+#~ msgstr "ãã¼ã¿åã®ã¬ã¤ã¤ã¼æ°"
#, fuzzy
#~ msgid ""
-#~ "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic "
-#~ "tape."
-#~ msgstr "1/2ã¤ã³ãç£æ°ãã¼ãã®ãã¼ã¿ããDEMãã¼ã¿ãæ½åºãã¾ã"
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "ãã¯ãã«ããªã´ã³ã¨ã¢ãããã¼ããããçµ±è¨ããã¼ã¹ã«ããGRASSã©ã¹ã¿ã¼ããã"
+#~ "ããæ°ãã屿§åã¸ä¸å¤éã®çµ±è¨ãè¨ç®ãã"
-#, fuzzy
-#~ msgid "Input device or file"
-#~ msgstr "å
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "å°å·ãå«ããã¯ãã«å
¥åãããå"
-#, fuzzy
-#~ msgid "Output raster map (examine only if none specified)"
-#~ msgstr "åºåãããã¡ã¤ã«(æªå
+#~ msgid "Generates a raster map layer showing watershed subbasins."
+#~ msgstr "åæ°´åã示ãã©ã¹ã¿ã¼ãããã使ãã¾ã "
-#, fuzzy
-#~ msgid "First file to look at"
+#~ msgid "Coded stream network file name"
+#~ msgstr "æ²³å·ãã¡ã¤ã«"
-#, fuzzy
-#~ msgid "Last file to look at"
+#~ msgid "Thinned ridge network file name"
+#~ msgstr "åæ°´ç¨ãã¡ã¤ã« "
-#, fuzzy
-#~ msgid "Selects a device (printer) for GRASS hardcopy output."
+#~ msgid "Name for the resultant watershed partition file"
+#~ msgstr "åºåããåæ°´çãã¡ã¤ã« "
-#, fuzzy
-#~ msgid "list all available painters"
-#~ msgstr "ãã¤ã³ã¿ã®ä¸è¦§è¡¨ç¤º"
+#~ msgid "Name of the elevation raster map [m]"
+#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ãããå [m]"
-#, fuzzy
-#~ msgid "print name of currently selected painter"
+#~ msgid "Output water depth raster map [m]"
+#~ msgstr "æ°´æ·±ã©ã¹ã¿ã¼ããããåºåãã [m] "
-#, fuzzy
-#~ msgid "quietly select painter"
-#~ msgstr "説æãªã"
+#~ msgid "Output elevation raster map"
+#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ããããåºå"
-#, fuzzy
-#~ msgid "Color map output utility."
-#~ msgstr "ãã¼ãã³ãã¼åºåã®è¨å®ãè¡ãã¾ã"
+#~ msgid "Input elevation raster map"
+#~ msgstr "å
¥åæ¨é«ã©ã¹ã¿ã¼ããã"
-#, fuzzy
-#~ msgid "Align region to resolution [default = align to bounds]"
-#~ msgstr "å¢çãåè§£è½ã«åããã"
+#~ msgid "Input aspect raster map"
+#~ msgstr "å
¥åæ¹ä½ã©ã¹ã¿ã¼ããã"
-#, fuzzy
-#~ msgid "Set region to match this sites map"
-#~ msgstr "è¨å®ã«ç¨ãããµã¤ãããã"
+#~ msgid "Input barrier raster map"
+#~ msgstr "å
¥åããªã¢ã¼ã©ã¹ã¿ã¼ããã"
-#, fuzzy
-#~ msgid "Value for the eastern edge "
-#~ msgstr "å端"
+#~ msgid "Output flowline vector map"
+#~ msgstr "åºåããã¼ã©ã¤ã³ãã¯ãã«ããã"
-#, fuzzy
-#~ msgid "Value for the western edge "
-#~ msgstr "西端"
+#~ msgid "Name of elevation raster map"
+#~ msgstr "æ¨é«ã©ã¹ã¿ã¼ãããå"
-#, fuzzy
-#~ msgid "Grid resolution (both north-south and east-west)"
-#~ msgstr "æ ¼åã®åè§£è½"
+#~ msgid "Output raster map having shadows"
+#~ msgstr "åºåããå½±ã®ã©ã¹ã¿ã¼ãããå"
-#, fuzzy
-#~ msgid "Overwrite <new> file(s)"
-#~ msgstr "䏿¸ã"
+#~ msgid "By_position"
+#~ msgstr "ä½ç½®ã使ã "
-#, fuzzy
-#~ msgid " vect (binary vector maps)\n"
-#~ msgstr " vect (ãã¯ãã«ããã)\n"
+#~ msgid "B: year (1950..2050)"
+#~ msgstr "B: å¹´(1950..2050) "
-#, fuzzy
-#~ msgid " icon (paint icon files)\n"
-#~ msgstr " icon (ãã¤ã³ãã¢ã¤ã³ã³ãã¡ã¤ã«)\n"
+#~ msgid "By_time"
+#~ msgstr "By_time "
-#, fuzzy
-#~ msgid " labels (paint label files)\n"
-#~ msgstr " labels (ãã¤ã³ãã©ãã«ãã¡ã¤ã«)\n"
+#~ msgid "B: month (0..12)"
+#~ msgstr "B: æ(0..12) "
-#, fuzzy
-#~ msgid " sites (site list files)\n"
-#~ msgstr " sites (ãµã¤ãããã)\n"
+#~ msgid "B: day (0..31)"
+#~ msgstr "B: æ¥(0..31) "
-#, fuzzy
-#~ msgid " group (imagery group files)\n"
-#~ msgstr " group (ç»åã°ã«ã¼ã)\n"
+#~ msgid "B: hour (0..24)"
+#~ msgstr "B: æ(0..24) "
-#, fuzzy
-#~ msgid " 3dview (3D view parameters)\n"
-#~ msgstr " 3dview (3次å
+#~ msgid "East coordinate (point of interest, default: map center)"
+#~ msgstr "æ±è¥¿åº§æ¨(POIãæ¢å®å¤ã¯ãããä¸å¿)"
-#, fuzzy
-#~ msgid "Data type"
-#~ msgstr "ãã¡ã¤ã«ã®ç¨®é¡"
+#~ msgid "North coordinate (point of interest, default: map center)"
+#~ msgstr "åå座æ¨(POIãæ¢å®å¤ã¯ãããä¸å¿)"
+#~ msgid "Zero is a real elevation"
+#~ msgstr "ã¼ãã¯å®éã®æ¨é«"
+#~ msgid "Verbose output (also print out sun position etc.)"
+#~ msgstr "詳細ãåºåãã (太é½ã®ä½ç½®çãåºåãã) "
+#~ msgid "(i) Elevation map"
+#~ msgstr "(i) æ¨é«ããã"
+#~ msgid "(o) Depressionless elevation map"
+#~ msgstr "(o) å¹ã¿ã®ãªãæ¨é«ããã "
+#~ msgid "(o/i) Basin elevation map (MASK applied)"
+#~ msgstr "(o/i) çå°æ¨é«ããã (MASK ãé©ç¨) "
+#~ msgid "(o) Topographic index ln(a/tanB) map (MASK applied)"
+#~ msgstr "(o) å°å½¢å¦çã¤ã³ããã¯ã¹ ln(a/tanB) ããã (MASK é©ç¨) "
+#~ msgid "(o) Output file"
+#~ msgstr "(o) åºåãã¡ã¤ã«"
+#~ msgid "(i) OPTIONAL Observed flow file"
+#~ msgstr "(i) ä»»æï¼ 宿¸¬æµéãã¡ã¤ã« "
+#~ msgid "(i) OPTIONAL Output for given time step"
+#~ msgstr "(i) ä»»æï¼ æå®ãããæéã¹ãããã®åºå"
+#~ msgid "(i) OPTIONAL Output for given topographic index class"
+#~ msgstr "(i) ä»»æï¼ æå®ãããå°å½¢å¦çã¤ã³ããã¯ã¹ã¯ã©ã¹ã®åºå"
+#~ msgid "Name of existing raster map containing elevation surface"
+#~ msgstr "æ¨é«æ²é¢ãå«ãã©ã¹ã¿ã¼ãããå"
+#~ msgid "Output elevation raster map after filling"
+#~ msgstr "å
å¡«å¾ã«ã©ã¹ã¿ã¼ããããåºå"
+#~ msgid "Output direction raster map"
+#~ msgstr "æ¹åã©ã¹ã¿ã¼ããããåºå"
+#~ msgid "Output aspect direction format (agnps, answers, or grass)"
+#~ msgstr "æ¹ä½æ¹åãã©ã¼ããã (agnps, answers, ã¾ã㯠grass) ãåºå"
+#~ msgid "Reading map..."
+#~ msgstr "ããããèªã¿è¾¼ã¿ä¸..."
+#~ msgid "Failed to guess site file format\n"
+#~ msgstr "ãµã¤ããã¡ã¤ã«ã®ãã©ã¼ãããã䏿ã§ã\n"
+#~ msgid "Watershed basin analysis program."
+#~ msgstr "åæ°´åã®è§£æãè¡ãã¾ã "
+#~ msgid "Input map: elevation on which entire analysis is based"
+#~ msgstr "å
¥å:æ¨é«ã示ããã¡ã¤ã« "
+#~ msgid "Input map: locations of real depressions"
+#~ msgstr "å
¥å:å°ç¤æ²ä¸éã示ããã¡ã¤ã« "
+#~ msgid "Input map or value: percent of disturbed land, for USLE"
+#~ msgstr "å
¥å:éçºå°åã®å²åã示ããã¡ã¤ã« "
+#~ msgid "Output map: drainage direction"
+#~ msgstr "åºå:æåºæ¹åã示ããã¡ã¤ã« "
+#~ msgid "Output map: stream segments"
+#~ msgstr "åºå:æ²³å·ã示ããã¡ã¤ã« "
+#~ msgid "Watershed basin creation program."
+#~ msgstr "æµå使ããã°ã©ã ."
+#~ msgid "Name of raster map to contain results"
+#~ msgstr "çµæãåºåããã©ã¹ã¿ã¼ãããå "
+#~ msgid "The map N grid coordinates"
+#~ msgstr "ãããNã°ãªãã座æ¨"
+#~ msgid "X-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "éæ°´ä¿æ°ãã³ã½ã«ã®Xæå [m/s] "
+#~ msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "éæ°´ä¿æ°ãã³ã½ã«ã®Yæå [m/s] "
+#~ msgid "Decomposition failed"
+#~ msgstr "åè§£ã«å¤±æãã¾ãã"
+#~ msgid "<%s> created in database."
+#~ msgstr "<%s>ãã¼ã¿ãã¼ã¹ã«ä½æããã¾ãã. "
+#~ msgid "<%s> has not been created in database."
+#~ msgstr "<%s> ã¯ãã¼ã¿ãã¼ã¹ã«ä½æããã¾ããã§ã"
+#~ msgid "Unable to access table <%s>"
+#~ msgstr "ãã¼ãã« <%s> ã使ã§ãã¾ãã"
+#~ msgid "Experimental NVIZ CLI prototype."
+#~ msgstr "å®é¨æ®µéã® NVIZ CLI 試ä½å"
#, fuzzy
-#~ msgid "-1' for threshold based on the current resolution settings"
-#~ msgstr "ç¾å¨ã®è¨å®ã表示"
+#~ msgid "unable to open new LS factor map layer."
+#~ msgstr "æ°è¦ã® Lãããã¬ã¤ã¤ã¼ãéãã¾ãã"
#, fuzzy
-#~ msgid "layer' must be > 0"
-#~ msgstr "å
¥åãããã¡ã¤ã«"
+#~ msgid "unable to open new S factor map layer."
+#~ msgstr "æ°è¦ã® S ãããã¬ã¤ã¤ã¼ãéãã¾ãã"
#~ msgid "%s' must be greater than zero; using %s=255"
#~ msgstr "%s ã¯ã¼ã以ä¸ãæ¡ä»¶; %s=255 ã使ç¨ä¸ "
@@ -36496,18 +36524,6 @@
#~ msgid "Don't use shell syntax"
#~ msgstr "ã·ã§ã«ã·ã³ã¿ãã¯ã¹ã使ç¨ããªãã§ãã ãã "
-#~ msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-#~ msgstr "æ¢å®å¤: å®ç¾©ããã¦ããã°GRASS_GUI ããã§ãªããã°tcltk "
-#~ msgid ""
-#~ "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based "
-#~ "GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;"
-#~ "text;command line interface only"
-#~ msgstr ""
-#~ "tcltk;GUI ã«åºã¥ã Tcl/Tk - GIS管çè
(gis.m);oldtcltk;GUI ã«åºã¥ã Old "
-#~ "Tcl/Tk - 表示管çè
(d.m);wxpython;次ä¸ä»£ GUIã«åºã¥ãwxPython;ããã¹ã;ã³"
-#~ "ãã³ãã©ã¤ã³ã¤ã³ã¿ã¼ãã§ã¼ã¹ã®ã¿"
#~ msgid "The old d.m GUI is not available for WinGRASS"
#~ msgstr "æ§ d.m GUI 㯠WinGRASS ã«å©ç¨ä¸å¯ "
@@ -36869,9 +36885,6 @@
#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
#~ msgstr "zå¤ã®ååã¨å (ä¾. æ´æ°å, å精度å) "
-#~ msgid "Writes Z data to column instead of 3D vector"
-#~ msgstr " 3D ãã¯ãã« ã®ä»£ããã«Z ãã¼ã¿ãã³ã©ã ã«æ¸ãè¾¼ã¿ã¾ã"
#~ msgid "v.random can't create 3D vector and attribute table at same time"
#~ msgstr "v.random ã¯3Dãã¯ãã«ã¨å±æ§ã-ãã«ãåæã«ä½æã§ãã¾ãã"
@@ -37391,9 +37404,6 @@
#~ msgid "Name of terrain raster map (DEM)"
#~ msgstr "å°å½¢ã®ã©ã¹ã¿ã¼ãããå (DEM) "
-#~ msgid "Do not export long colortable"
-#~ msgstr "大ãããµã¤ãºã®ã«ã©ã¼ãã¼ãã«ãã¨ã¯ã¹ãã¼ãããªã"
#~ msgid "Interpolating raster map <%s> (%d rows)... "
#~ msgstr "ã©ã¹ã¿ã¼ããã <%s> (%d è¡) ãè£éä¸"
@@ -37415,12 +37425,6 @@
#~ msgid "No data"
#~ msgstr "ãã¼ã¿ãããã¾ãã"
-#~ msgid "unable to open new L map layer."
-#~ msgstr "æ°è¦ã® Lãããã¬ã¤ã¤ã¼ãéãã¾ãã"
-#~ msgid "unable to open new S map layer."
-#~ msgstr "æ°è¦ã® S ãããã¬ã¤ã¤ã¼ãéãã¾ãã"
#~ msgid "Input value: maximum length of surface flow, for USLE"
#~ msgstr "æ²é¢æµã®æå¤§é·(åä½:ã¡ã¼ãã«) "
@@ -37708,24 +37712,9 @@
#~ msgid "%s: ERROR running %s command"
#~ msgstr "%s: ã¨ã©ã¼ï¼ %s ã³ãã³ãã®å®è¡ä¸"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ " basin, stream, half.basin, slope, or lS\n"
-#~ " you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "次ã®ãªãã·ã§ã³ã®ãããããã»ããããã¦ãã¾ã:\n"
-#~ " basin, stream, half.basin, slope, lS\n"
-#~ " çå°å¢çãã©ã¡ã¼ã¿ã®å¤ãå¿
ããã¦ãããå¿
è¦ãããã¾ã "
#~ msgid "Close failed."
#~ msgstr "éããã¾ãã"
-#~ msgid "SECTION 4: Length Slope determination."
-#~ msgstr "ã»ã¯ã·ã§ã³ 4: é·ãã»å¾æã®æ±ºå®"
-#~ msgid "SECTION 3: Accumulating Surface Flow."
-#~ msgstr "ã»ã¯ã·ã§ã³ 3: 表層æµã®ç´¯è¨"
#~ msgid "Cannot read ew_res value"
#~ msgstr "æ±è¥¿æ¹åè§£å度ã®å¤ãèªã¿åãã¾ãã"
@@ -38664,9 +38653,6 @@
#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
#~ msgstr "GRASSã®ãã¯ãã«ãã¤ã³ããããã使ç¨ãã¦å¸å
ãã¯ãã«ãããã使"
-#~ msgid "Convex hull calculation requires at least three points"
-#~ msgstr "å¸å
æ¼ç®ã«ã¯3ç¹ä»¥ä¸ãå¿
è¦"
#~ msgid "overlap;features partially or completely overlap"
#~ msgstr "éè¤ï¼ å°ç©ãé¨åçã¾ãã¯å®å
¨ã«éãªã£ã¦ãã¾ã"
@@ -39451,15 +39437,6 @@
#~ msgid "Overlapping area: %e (%d areas)"
#~ msgstr "éè¤ããã¨ãªã¢: %e (%d ã¨ãªã¢)"
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %d "
-#~ "was used to represent no-data values in the input map. You can specify "
-#~ "nodata value by %s parameter."
-#~ msgstr ""
-#~ "å
¥åããã©ã¹ã¿ã¼ãããã¯NULLå¤ï¼ãã¼ã¿ç¡ãï¼ã»ã«ãå«ãã§ãã¾ãï¼ãã®æå®ã"
-#~ "ãããããã§å¤ %d ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤"
-#~ "ãæå®ã§ãã¾ã"
#~ msgid "Rowio_setup failed"
#~ msgstr "Rowio_setup ã«å¤±æãã¾ãã"
@@ -39552,3 +39529,457 @@
#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
#~ msgstr "åå¨ãã SPOT VGT NDVI HDF ãã¡ã¤ã« (0001_NDV.HDF) "
+#~ msgid "The initial piezometric head in [m]"
+#~ msgstr "åæãã¨ã¾ã¡ã¼ã¿ã¼æ°´é [m] "
+#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgstr ""
+#~ "åã»ã«ã®ã¹ãã¼ã¿ã¹ = 0 - ã¤ã³ã¢ã¯ãã£ã, 1 - ã¢ã¯ãã£ã, 2 - ãã£ãªã¯ã¬ "
+#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "éæ°´ä¿æ°ãã³ã½ã« Z-軸æå [m/s] "
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "ã©ã¹ã¿ã¼ãããã¸ã®åæå
¥m^3/s"
+#~ msgid ""
+#~ "The piezometric head result of the numerical calculation will be written "
+#~ "to this map"
+#~ msgstr "ãã¨ã¾æ°´é ã®æ°å¤è¨ç®çµæããã®ãããã«æ¸ãè¾¼ã¾ãã¾ã"
+#~ msgid "Name of base raster map"
+#~ msgstr "åºæ¬ã©ã¹ã¿ã¼ãããå"
+#~ msgid "Converting %s..."
+#~ msgstr "%s ã夿ä¸... "
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "æ¹ä»ãã§åºåããã©ã¹ã¿ã¼ãããå "
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "è£éã«ç¨ããè¿åç¹ "
+#~ msgid ""
+#~ "Sediment transport and erosion/deposition simulation using path sampling "
+#~ "method (SIMWE)"
+#~ msgstr ""
+#~ "çµè·¯ãµã³ããªã³ã°ã¡ã½ãã (SIMWE) ãç¨ããåç æµéãä¾µé£/å ç©ã®ã·ãã¥ã¬ã¼"
+#~ "ã·ã§ã³"
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "æ°´æ·±ã©ã¹ã¿ã¼ãããå [m]"
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "x-å°é¢æ°ã©ã¹ã¿ã¼ãããå [m/m]"
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#~ msgstr "y-å°é¢æ°ã©ã¹ã¿ã¼ãããå [m/m]"
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "åé¢å®¹ç©ä¿æ°ã©ã¹ã¿ã¼ãããå [s/m]"
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "ç§»å容ç©ä¿æ°ã©ã¹ã¿ã¼ãããå [s]"
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "é大ããæå¿åã©ã¹ã¿ã¼ãããå [Pa]"
+#~ msgid "Name of the Mannings n raster map"
+#~ msgstr "ããã³ã°ï½å¤ã©ã¹ã¿ã¼ãããå"
+#~ msgid "Name of the Mannings n value"
+#~ msgstr "ããã³ã°ï½å¤å"
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "åºåããç§»å容ç©ã©ã¹ã¿ããã [kg/ms] "
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr "ééå¶éä¾µé£-å ç©ã©ã¹ã¿ã¼ããããåºå [kg/m2s]"
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "å ç©ç©æ¿åº¦ã©ã¹ã¿ã¼ããããåºå [particle/m3]"
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "å ç©ç©ãã©ãã¯ã¹ã©ã¹ã¿ã¼ããããåºå [kg/ms]"
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#~ msgstr "ä¾µé£-å ç©ã©ã¹ã¿ã¼ããããåºå [kg/m2s]"
+#~ msgid ""
+#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+#~ msgstr ""
+#~ "çµè·¯ãµã³ããªã³ã°ã¡ã½ãã(SIMWE)ãç¨ããå°è¡¨æµã®æ°´æå¦ã·ãã¥ã¬ã¼ã·ã§ã³"
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr "éé¨éå°(鍿°´æµ¸å
¥)ã©ã¹ã¿ã¼ããã [mm/hr]"
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "æµåºæ°´ä¾µå
¥çã©ã¹ã¿ã¼ããã [mm/hr]"
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr "æµéã³ã³ããã¼ã«ã©ã¹ã¿ã¼ãããå (浸éç 0-1)"
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "ææ°´ã©ã¹ã¿ã¼ããããåºåãã [m3/s]"
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "ã·ãã¥ã¬ã¼ã·ã§ã³ã¨ã©ã¼ã©ã¹ã¿ããããåºåãã [m] "
+#~ msgid ""
+#~ "Threshold water depth [m] (diffusion increases after this water depth is "
+#~ "reached)"
+#~ msgstr "é¾å¤æ°´æ·± [m] (ãã®æ°´æ·±ã«éããã¨æ¡æ£ãå¢ãã¾ã) "
+#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
+#~ msgstr "å¢çæ¡ä»¶ã®ã¹ãã¼ã¿ã¹, 0-䏿´»æ§ã 1-æ´»æ§ã2-ãã£ãªã¯ã¬"
+#~ msgid "Water sources and sinks in [m^3/s]"
+#~ msgstr "æ°´æºã¨æ²é[m^3/s] "
+#~ msgid "Specific yield in [1/m]"
+#~ msgstr "ç¹å®ã¤ã¼ã«ã[1/m] "
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "ããããåãã£ã¼ã¸ãã ä¾ï¼ã»ã«ããã 6*10^-9 [m^3/s*m^2]"
+#~ msgid "The map storing the numerical result [m]"
+#~ msgstr "æ°å¤çµæ[m]ãä¿åããããã "
+#~ msgid "The height of the river bed in [m]"
+#~ msgstr "æ²³åºã®é«ã[m] "
+#~ msgid "Water level (head) of the river with leakage connection in [m]"
+#~ msgstr "æ¼åºã¨æ¥ç¶ãããæ²³å·ã®æ°´ä½ (æ°´é )[m] "
+#~ msgid "The leakage coefficient of the river bed in [1/s]."
+#~ msgstr "æ²³åºã®æ¼åºéä¿æ° [1/s]. "
+#~ msgid "The height of the drainage bed in [m]"
+#~ msgstr "ææ°´åºã®é«ã [m] "
+#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
+#~ msgstr "ææ°´åºã®æ¼åºéä¿æ° [1/s] "
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "å
¥å:1ã»ã«ã®æµéã示ããã¡ã¤ã« "
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "å
¥å:æ²é¢æµã§ãããã¯åããå°å½¢ã示ããã¡ã¤ã« "
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "åºåï¼æµãåºãã»ã«æ°ã示ããã¡ã¤ã« "
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "åºå:åæ°´åã®ã©ãã«ãã¡ã¤ã« "
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "åºå:åçå°ã®ã©ãã«ãã¡ã¤ã« "
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr "åºå:徿é·ã¨å¾æå¾é
(LSãã¡ã¯ã¿ã¼)ã示ããã¡ã¤ã« "
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "åºå:RUSLEç¨ã®å¾æå¾é
(Sãã¡ã¯ã¿ã¼)ã示ããã¡ã¤ã« "
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "å¤å´ã®åæ°´åã®æå°ã»ã«æ° "
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "次ã®ãªãã·ã§ã³ã®ãããããã»ããããã¦ãã¾ã:\n"
+#~ " basin, stream, half.basin, slope, lS\n"
+#~ " çå°å¢çãã©ã¡ã¼ã¿ã®å¤ãå¿
ããã¦ãããå¿
è¦ãããã¾ã "
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "æ°è¦ã®ç´¯ç©ãããã¬ã¤ã¤ã¼ãéãã¾ãã"
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "æå®ãããæ¨é«ã¬ã¤ã¤ã¼ããã£ã«ã¿ãªã³ã°ãï¼å¹ã¿ã®ãªãæ¨é«ãããã¨æµãæ¹å"
+#~ "ãããã使"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "課é¡ã¨ãªã¢ã®ã©ã¹ã¿ã¼ããããåºå"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "ã©ã¹ã¿ã¼å½¢å¼ã®çé«ç·ããæ²é¢ã使"
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "çé«ç·ãå«ãæ¢åã®ã©ã¹ã¿ã¼ãããå"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼ã®ã«ã©ã¼ãã¼ãã«ã使/ç·¨éãã¾ã"
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "ã«ã©ã¼ãã¼ãã«ããã³ãã¼ãããã©ã¹ã¿ã¼ãããå"
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "ã«ã¼ã«ãã¡ã¤ã«ã¸ã®ãã¹ (æ¨æºå
¥åããèªã¿è¾¼ãã¨ã㯠\"-\" )"
+#, fuzzy
+#~ msgid ""
+#~ "Input raster map contains cells with NULL-value (no-data). The value %f "
+#~ "will be used to represent no-data values in the input map. You can "
+#~ "specify a nodata value with the %s option."
+#~ msgstr ""
+#~ "å
+#~ "ãããããã§å¤ %d ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤"
+#~ "ãæå®ã§ãã¾ã"
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "æå®ã¬ã¤ã¤ã¼ã§ï¼ãã£ã¼ãã£ã¼ã¸ã®è·é¢ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使"
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) r.water.outlet (MASK) ã§ä½æãããçå°ããã"
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) å¹ã¿ã®ãªãæ¨é«ãããã®æ¹åããã"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) å°å½¢å¦çã¤ã³ããã¯ã¹ã¯ã©ã¹æ°"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(o/i) å°å½¢å¦çã¤ã³ããã¯ã¹çµ±è¨ãã¡ã¤ã« "
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) TOPMODEL ãã©ã¡ã¼ã¿ã¼ãã¡ã¤ã«"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "(i) éé¨ã¨è¸çºæ£ä½ãã¼ã¿ ãã¡ã¤ã« "
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "太é½ä½ç½®ã¨ DEM ããã¨ã«é°å½±é åãè¨ç®ï¼r.sunmask èªèº«ããï¼A: æ£ç¢ºãªå¤ªé½ä½"
+#~ "ç½®ã®æå®ï¼ã¾ã㯠B: 太é½ä½ç½®ãè¨ç®ããããã®æ¥ä»/æå»ãæå®"
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: æ°´å¹³ããã®å¤ªé½ã®é«åº¦ãåä½ã¯åº¦"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: åããã®å¤ªé½ã®æ¹ä½è§ãåä½ã¯åº¦ "
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: å(0..60) "
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: ç§(0..60) "
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr "B: ã¿ã¤ã ã¾ã¼ã³(æ±ãæ£, GMTãªãã»ããã ãµãã¼ã¿ã¤ã 調æ´ãã) "
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "åå¨ããã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ååé¡ã«åºã¥ãã«ãã´ãªã¼å¤ã®æ°ã"
+#~ "ããããã¬ã¤ã¤ã¼ä½æãã¾ã"
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "ååé¡ãããã©ã¹ã¿ã¼ããã"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "ã©ã¹ã¿ã¼ãããããã¯ãã«ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã. "
+#~ msgid ""
+#~ "Do not build vector topology (use with care for massive point export)"
+#~ msgstr "ãã¯ãã«ãããã¸ã¼ã使ããªã(大éãã¤ã³ãåºåã«ä½¿ç¨) "
+#~ msgid "The map E grid coordinates"
+#~ msgstr "ãããEã°ãªãã座æ¨"
+#~ msgid "Stream width (in meters). Default is raster cell width"
+#~ msgstr "æ°´æµå¹
(ã¡ã¼ãã«). ããã©ã«ãã¯ã©ã¹ã¿ã¼ã»ã«å¹
ã§ã "
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr ""
+#~ "徿ã«ã¼ãã®å»ºç¯ï¼ããã¼ã©ã¤ã³ï¼ãããã¼ãã¹ã®é·ããããã¦ã©ã¹ã¿ã¼ãã¸ã¿ã«"
+#~ "æ¨é«ã¢ãã«ï¼DEMï¼ããã®ããã¼ã©ã¤ã³å¯åº¦ï¼ä¸ãåã¨ãªã¢ï¼ "
+#~ msgid "Output flowpath length raster map"
+#~ msgstr "åºåããã¼ãã¹é·ãã©ã¹ã¿ã¼ããã"
+#~ msgid "Output flowline density raster map"
+#~ msgstr "åºåæµç·ã®å¯åº¦ã示ãã©ã¹ã¿ã¼ãã¡ã¤ã«"
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "2-D ã®ä»£ããã«3-Dã®é·ã"
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "æ¨é«ãããããããã°ã©ãã£ãã¯ã¤ã³ããã¯ã¹ [ln(a/tan(beta))] ããã ã使"
+#~ "ãã¾ã. "
+#~ msgid "Output topographic index map"
+#~ msgstr "åºåããã°ã©ãã£ã¼ã®ã¤ã³ããã¯ã¹ããã"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "ä¸è¬çãª, è¨å®"
+#~ msgid "New LOCATION name (not location path)"
+#~ msgstr "æ°ãããã±ã¼ã·ã§ã³å (ãã±ã¼ã·ã§ã³ãã¹ã§ã¯ããã¾ãã) "
+#~ msgid "New GISDBASE (full path to the directory where the new location is)"
+#~ msgstr ""
+#~ "æ°ããGISDBASE (æ°ãããã±ã¼ã·ã§ã³ã®ãããã£ã¬ã¯ããªã¼ã¸ã®ãã«ãã¹) "
+#, fuzzy
+#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
+#~ msgstr "æ¢å®å¤: å®ç¾©ããã¦ããã°GRASS_GUI ããã§ãªããã°tcltk "
+#, fuzzy
+#~ msgid ""
+#~ "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
+#~ "(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
+#~ "command line interface only"
+#~ msgstr ""
+#~ "tcltk;GUI ã«åºã¥ã Tcl/Tk - GIS管çè
+#~ "Tcl/Tk - 表示管çè
+#~ "ãã³ãã©ã¤ã³ã¤ã³ã¿ã¼ãã§ã¼ã¹ã®ã¿"
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "X's 製å³ã®ã«ã©ã¼(Nullå¤) "
+#~ msgid "Either text or -c should be given"
+#~ msgstr "ããã¹ãã¾ãã¯-cã®ã©ã¡ãããæå®ãã¦ãã ãã"
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr "表示ããã«ãã´ãªã¼ãªã¹ã"
+#~ msgid "Invert catlist"
+#~ msgstr "catlistãå転ãã¾ã"
+#~ msgid "vector, interpolation"
+#~ msgstr "ãã¯ãã«ãè£é"
+#~ msgid "Need either 3D vector or layer and column with z values"
+#~ msgstr "ï¼Dãã¯ãã«ã¾ãã¯ã¬ã¤ã¤ã¼ã¨åã®Z-å¤ã®ãã¥ãããå¿
è¦ã§ã"
+#~ msgid "Layer but not column with z values given"
+#~ msgstr "Zå¤ã®æ
å ±ãå®ç¾©ããã¦ããªãã¬ã¤ã¤ã¼"
+#, fuzzy
+#~ msgid ""
+#~ "If type is not given then DOUBLE PRECISION is used. Writes Z data to "
+#~ "column instead of 3D vector."
+#~ msgstr " 3D ãã¯ãã« ã®ä»£ããã«Z ãã¼ã¿ãã³ã©ã ã«æ¸ãè¾¼ã¿ã¾ã"
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "å <%s> ã使ç¨ã§ãã¾ãã"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "å¸å
æ¼ç®ã«ã¯3ç¹ä»¥ä¸ãå¿
è¦"
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "ã©ã¤ã³ãå«ãã ï¼åºåãããã¯ãã«ãããå"
+#~ msgid "Area without centroid (may be OK for island)"
+#~ msgstr "ã»ã³ããã¤ãã®ãªãã¨ãªã¢ (å³¶ã¯åé¡ããã¾ãã) "
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr "å
¨ã¦ã®ãããæ¥ç¶ãã©ã¡ã¼ã¿ã¼ãã·ã§ã«ã¹ã¯ãªããå½¢å¼ã«åºåãã¦çµäº"
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "ãã¯ãã«ããã <%s> é£çµããã¦ãã¾ãï¼ "
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "åºåãã¡ã¤ã«åï¼æ¡å¼µã追å ããªãããã«ï¼"
+#~ msgid "Width and height of output image"
+#~ msgstr "åºåç»åã®å¹
ã¨é«ã"
+#~ msgid "Surface"
+#~ msgstr "æ²é¢"
+#~ msgid "Volume"
+#~ msgstr "ããªã¥ã¼ã "
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr "ç¾å¨ã®ãããã»ããã®ä¸è¬çãªDBæ¥ç¶åºå/è¨å®ãã¦çµäº"
+#~ msgid "Name of file with sql statement"
+#~ msgstr "sqlæã®ãã¡ã¤ã«å"
+#~ msgid "Slower but accurate (applies to FP maps only)"
+#~ msgstr "é
ãã§ããæ£ç¢ºã§ã (FPãããã®ã¿é©ç¨) "
+#~ msgid "Compression for PNG files"
+#~ msgstr "PNGãã¡ã¤ã«ã®å§ç¸®"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "使ç¨å¯è½ãªã«ã¼ã«ã®ä¸è¦§è¡¨ç¤º"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "GRASSã®HTMLmanãã¼ã¸ã表示"
+#~ msgid ""
+#~ "Set color rules for features in a vector using a numeric attribute column."
+#~ msgstr "æ°å¤å±æ§ã®åã§ã®ãã¯ãã«ã®ç¹å¾´ã®è²ã«ã¼ã«"
+#~ msgid "Name of color column to populate"
+#~ msgstr "追å ããã«ã©ã¼åå"
+#, fuzzy
+#~ msgid ""
+#~ "A single vector map can be connected to multiple database tables. This "
+#~ "number determines which table to use"
+#~ msgstr ""
+#~ "åç¬ã®ãã¯ãã«ãããã¯å¤æ°ã®ãã¼ã¿ãã¼ã¹ãã¼ãã«ã«æ¥ç¶ããã¦ããªããã°ãªã"
+#~ "ã¾ããããã®æ°å¤ã¯ã©ã®ãã¼ãã«ã使ç¨ãã¦ãããæ±ºå®ãã¾ã"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Mapgenãããã¯Matlabãã¯ãã«ããããGRASSã«ã¤ã³ãã¼ã"
+#~ msgid "Set color rules based on stddev from a map's mean value."
+#~ msgstr "ãããã®å¹³åå¤ãå
ã«ããæ¨æºåå·®ããã¼ã¹ã«ã¦è²ã«ã¼ã«ãã»ãã"
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "屿§ãã¼ãã«ãç·¨éããããã®ãã¯ãã«ããã"
+#~ msgid "Layer where to add column"
+#~ msgstr "åã追å ããã¬ã¤ã¤ã¼"
+#~ msgid "No target elevation model selected for group <%s>"
+#~ msgstr "ã°ã«ã¼ãã鏿ããããã«æå®ãããæ¨é«ã¢ãã«ãåå¨ãã¾ãã [%s]"
+#~ msgid "No camera reference file selected for group <%s>"
+#~ msgstr "ã°ã«ã¼ãã®é¸æãããã«ã¡ã©åç
§ãã¡ã¤ã«ãããã¾ãã [%s]"
+#~ msgid "Bad format in camera file for group <%s>"
+#~ msgstr "ã°ã«ã¼ã[%s]ã®ã«ã¡ã©ãã¡ã¤ã«ã«ãã䏿£ãªãã©ã¼ããã"
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#~ msgstr "ã°ã«ã¼ã [%s]ã®åæé¢¨é¨ã¹ãã¼ã·ã§ã³ãã¡ã¤ã«ã®ä¸æ£ãªãã©ã¼ããã"
+#~ msgid ""
+#~ "Input raster map contains cells with NULL-value (no-data). The value %g "
+#~ "was used to represent no-data values in the input map. You can specify "
+#~ "nodata value by %s parameter."
+#~ msgstr ""
+#~ "å
+#~ "ãããããã§å¤ %g ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤"
+#~ "ãæå®ã§ãã¾ã"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_ko.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5258,9 +5258,9 @@
msgstr ""
#: ../raster/r.transect/main.c:84
-#, fuzzy, c-format
+#, c-format
msgid "End coordinate: %.15g, %.15g"
-msgstr "ì¶ë ¥í ëì¤í°ë§µ"
+msgstr ""
#: ../raster/r.transect/main.c:105
msgid ""
@@ -8087,9 +8087,8 @@
msgstr ""
#: ../raster/r.in.xyz/main.c:307
-#, fuzzy
msgid "Invalid zrange"
+msgstr ""
#: ../raster/r.in.xyz/main.c:394
msgid "Unable to calculate percentile without the pth option specified!"
@@ -8146,9 +8145,9 @@
msgstr ""
#: ../raster/r.in.xyz/main.c:1059
-#, c-format
+#, fuzzy, c-format
msgid "%lu points found in region."
-msgstr ""
+msgstr "ì¶ë ¥í ëì¤í°ë§µ"
#: ../raster/r.in.xyz/main.c:1086
msgid "Scanning data ..."
@@ -10032,9 +10031,8 @@
#: ../raster/r.reclass/main.c:65
-#, fuzzy
msgid "File containing reclass rules"
+msgstr ""
#: ../raster/r.reclass/main.c:66
#, fuzzy
@@ -13291,8 +13289,9 @@
msgstr ""
#: ../general/g.mlist/main.c:134
+#, fuzzy
msgid "Print data types"
-msgstr ""
#: ../general/g.mlist/main.c:138
#, fuzzy
@@ -14101,9 +14100,9 @@
#: ../display/d.geodesic/main.c:88 ../display/d.geodesic/main.c:91
#: ../display/d.rhumbline/main.c:82 ../display/d.rhumbline/main.c:85
#: ../display/d.rhumbline/main.c:88 ../display/d.rhumbline/main.c:91
-#, c-format
+#, fuzzy, c-format
msgid "%s - illegal longitude"
-msgstr ""
#: ../display/d.path/main.c:49 ../vector/v.net.alloc/main.c:61
#: ../vector/v.net/main.c:46 ../vector/v.net.iso/main.c:73
@@ -14827,8 +14826,9 @@
msgstr ""
#: ../display/d.thematic.area/plot1.c:119 ../display/d.vect/plot1.c:127
+#, fuzzy
msgid "Color definition column not specified"
-msgstr ""
#: ../display/d.thematic.area/plot1.c:129 ../display/d.vect/area.c:79
#: ../display/d.vect/plot1.c:137
@@ -19714,19 +19714,19 @@
msgstr ""
#: ../vector/v.out.ogr/main.c:837
-#, c-format
+#, fuzzy, c-format
msgid "%d features without category were written"
-msgstr ""
#: ../vector/v.out.ogr/main.c:839
-#, c-format
+#, fuzzy, c-format
msgid "%d features without attributes were written"
-msgstr ""
#: ../vector/v.out.ogr/main.c:841
-#, c-format
+#, fuzzy, c-format
msgid "%d features found without category were skipped"
-msgstr ""
#: ../vector/v.out.ogr/main.c:852
#, fuzzy, c-format
@@ -20015,9 +20015,8 @@
msgstr ""
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
+msgstr ""
#: ../vector/v.hull/main.c:64
msgid "Use all vector points (do not limit to current region)"
@@ -21041,11 +21040,11 @@
msgstr ""
#: ../vector/v.what/what.c:394
-#, c-format
+#, fuzzy, c-format
msgid ""
"Area: %d\n"
"Number of isles: %d\n"
-msgstr ""
#: ../vector/v.what/what.c:404
#, c-format
@@ -23955,9 +23954,8 @@
msgstr ""
#: ../vector/v.lidar.correction/main.c:369
-#, fuzzy
msgid "Mean calculation"
+msgstr ""
#: ../vector/v.lidar.correction/main.c:383
msgid "Only TERRAIN points"
@@ -24440,9 +24438,9 @@
msgstr ""
#: ../vector/v.to.3d/trans3.c:102
-#, c-format
+#, fuzzy, c-format
msgid "Feature id %d has no category - skipping"
-msgstr ""
#: ../vector/v.to.3d/trans3.c:105
#, c-format
@@ -24450,8 +24448,9 @@
msgstr ""
#: ../vector/v.to.3d/trans2.c:103
+#, fuzzy
msgid "Skipping feature without category"
-msgstr ""
#: ../vector/v.to.3d/trans2.c:118
#, fuzzy, c-format
@@ -25908,9 +25907,8 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#, fuzzy
msgid "Write output to PNG image"
+msgstr ""
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
msgid "Coordinates"
@@ -25974,8 +25972,9 @@
msgstr ""
#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
+#, fuzzy
msgid "Input type point, line or area"
-msgstr ""
#: ../locale/scriptstrings/v.in.e00_to_translate.c:7
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:6
@@ -25984,14 +25983,16 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:6
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+#, fuzzy
msgid "Name for output vector map"
-msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:1
+#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
-msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -26044,12 +26045,14 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:20
#: ../locale/scriptstrings/m.proj_to_translate.c:22
#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
msgid "Files & format"
-msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:8
msgid "Field separator (format: input[,output])"
@@ -26202,8 +26205,9 @@
msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#, fuzzy
msgid "Source projection"
-msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
@@ -26215,8 +26219,9 @@
msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
-msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:12
msgid "Maximum number of rows for a tile in the source projection"
@@ -26352,8 +26357,9 @@
msgstr ""
#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#, fuzzy
msgid "raster input map"
-msgstr ""
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
msgid "Mosaics several images and extends colormap"
@@ -26391,8 +26397,9 @@
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:6
+#, fuzzy
msgid "Percentage weight of first map for color blending"
-msgstr ""
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
@@ -26437,8 +26444,9 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+#, fuzzy
msgid "Column to be queried"
-msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
msgid "Maximum query distance in map units"
@@ -26454,8 +26462,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
@@ -26477,8 +26486,9 @@
#: ../locale/scriptstrings/v.out.gps_to_translate.c:8
#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+#, fuzzy
msgid "Name of input vector map"
-msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:8
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
@@ -26499,13 +26509,15 @@
msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:11
+#, fuzzy
msgid "Value to calculate"
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+#, fuzzy
msgid ""
"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
#, fuzzy
@@ -26517,8 +26529,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#, fuzzy
msgid "Column to update"
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
msgid ""
@@ -26526,8 +26539,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:9
+#, fuzzy
msgid "Column to query"
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:10
msgid ""
@@ -26606,9 +26620,10 @@
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
+#, fuzzy
msgid ""
"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
#: ../locale/scriptstrings/r.mask_to_translate.c:1
msgid "Creates a mask for limiting raster operation."
@@ -26636,8 +26651,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
#, fuzzy
@@ -26645,8 +26661,9 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#, fuzzy
msgid "Name of new database"
-msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
msgid "Old schema"
@@ -26688,9 +26705,10 @@
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
#, fuzzy
@@ -26698,8 +26716,9 @@
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to rename column"
-msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:7
msgid "Old and new name of the column (old,new)"
@@ -26753,8 +26772,9 @@
msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+#, fuzzy
msgid "Table format"
-msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
@@ -26767,9 +26787,8 @@
msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#, fuzzy
msgid "vector, import"
+msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
msgid "Create a 3D line from 3 column data"
@@ -26782,8 +26801,9 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#, fuzzy
msgid "Field separator"
-msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
msgid ""
@@ -26795,12 +26815,14 @@
msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:5
+#, fuzzy
msgid "Export as waypoints"
-msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:6
+#, fuzzy
msgid "Export as routes"
-msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:7
msgid "Export as tracks"
@@ -26895,8 +26917,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
+#, fuzzy
msgid "Icon size for point data"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
msgid "Minimum icon size/line width for graduated points/lines)"
@@ -27009,10 +27032,11 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+#, fuzzy
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -27067,8 +27091,9 @@
msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+#, fuzzy
msgid "Input map is in Matlab format"
-msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
msgid "Create a 3D vector points map from 3 column Matlab data"
@@ -27080,8 +27105,9 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
+#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
#, fuzzy
@@ -27125,8 +27151,9 @@
msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
+#, fuzzy
msgid "Reset to standard color range"
-msgstr ""
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
@@ -27147,10 +27174,11 @@
msgstr ""
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
-msgstr ""
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
#, fuzzy
@@ -27184,8 +27212,9 @@
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:6
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:7
+#, fuzzy
msgid "Name of the column"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
msgid "Downloads and imports data from WMS servers."
@@ -27234,8 +27263,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
+#, fuzzy
msgid "Import"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Don't reproject the data, just patch it"
@@ -27254,12 +27284,14 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#, fuzzy
msgid "Layers to request from map server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
msgid "Styles to request from map server"
@@ -27278,12 +27310,14 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+#, fuzzy
msgid "Maximum columns to request at a time"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#, fuzzy
msgid "Maximum rows to request at a time"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Additional options for r.tileset"
@@ -27359,24 +27393,28 @@
msgstr ""
#: ../locale/scriptstrings/v.dissolve_to_translate.c:9
+#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#, fuzzy
msgid "Adds missing centroids to closed boundaries."
-msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#, fuzzy
msgid "Action to be taken"
-msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
msgid "Category number starting value"
msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
@@ -27388,16 +27426,19 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:7
+#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:8
+#, fuzzy
msgid "Layer from which to drop linked attribute table"
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
#, fuzzy
@@ -27409,16 +27450,18 @@
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#, fuzzy
msgid "Layer where to join"
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:8
msgid "column"
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:9
+#, fuzzy
msgid "Join column in map table"
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:10
msgid "Other table name"
@@ -27429,13 +27472,15 @@
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+#, fuzzy
msgid "Join column in other table"
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
#, fuzzy
@@ -27443,8 +27488,9 @@
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to drop column"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
@@ -27463,38 +27509,46 @@
msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+#, fuzzy
msgid "raster input map (LANDSAT channel 1)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#, fuzzy
msgid "raster input map (LANDSAT channel 2)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+#, fuzzy
msgid "raster input map (LANDSAT channel 3)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+#, fuzzy
msgid "raster input map (LANDSAT channel 4)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
+#, fuzzy
msgid "raster input map (LANDSAT channel 5)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
+#, fuzzy
msgid "raster input map (LANDSAT channel 7)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
+#, fuzzy
msgid "raster output TC maps prefix"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
+#, fuzzy
msgid ""
"Creates and connects a new attribute table to a given layer of an existing "
"vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
#, fuzzy
@@ -27502,12 +27556,14 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+#, fuzzy
msgid "Layer where to add new attribute table"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
msgid ""
@@ -27598,8 +27654,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+#, fuzzy
msgid "Imports attribute tables in various formats."
-msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
msgid "Table file to be imported or DB connection string"
@@ -27610,8 +27667,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
msgid "Interactively edit cell values in a raster map."
@@ -27635,12 +27693,14 @@
msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+#, fuzzy
msgid "Maximum number of rows to load"
-msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns to load"
-msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
@@ -27656,18 +27716,20 @@
msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:6
+#, fuzzy
msgid "Name of optional EPS output file"
-msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:7
msgid "Plot using Xgraph"
msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
-msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
msgid "Extended statistics (quartiles and 90th percentile)"
@@ -27797,9 +27859,9 @@
#: ../imagery/i.smap/segment.c:91
-#, fuzzy, c-format
+#, c-format
msgid "Processing rows %d-%d (of %d)..."
+msgstr ""
#: ../imagery/i.smap/model.c:43
#, c-format
@@ -27979,9 +28041,9 @@
#: ../imagery/i.pca/main.c:395
-#, fuzzy, c-format
+#, c-format
msgid "Rescaling <%s> to range %d,%d..."
+msgstr ""
#: ../imagery/i.pca/support.c:44
msgid "Eigen values, (vectors), and [percent importance]:"
@@ -28359,9 +28421,8 @@
#: ../imagery/i.rectify/cp.c:32
-#, fuzzy
msgid "Invalid order"
+msgstr ""
#: ../imagery/i.rectify/target.c:14
#, c-format
@@ -29966,47 +30027,225 @@
msgstr ""
#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "ì¶ë ¥í ëì¤í°ë§µ"
+msgid "Raster file to be converted."
#, fuzzy
-#~ msgid "Name of workspace file"
+msgid "terrain analysis"
#, fuzzy
-#~ msgid "Creating support files..."
+msgid "Unable to open vector map <%s> on level 2"
#, fuzzy
-#~ msgid "Raster file to be converted."
+msgid "Open vector map without topology (level 1)"
#, fuzzy
-#~ msgid "Output water depth raster map [m]"
+msgid "<%s> table created in database."
#, fuzzy
-#~ msgid "terrain analysis"
+msgid "Unable to get cell header for <%s>"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+#, fuzzy
+msgid "Error reading <%s>"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+#, fuzzy
+msgid "Unable to read row %d"
+#, fuzzy
+msgid "Unable to read region <%s>"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+#, fuzzy
+msgid "Error reading row <%d>"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+#, fuzzy
+msgid "Could not open <%s>"
+#, fuzzy
+msgid "Cannot write to output raster file"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "Name of QC"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+#, fuzzy
+msgid "Group [%s] not found."
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+#, fuzzy
+msgid "%d lines converted to boundaries"
+#, fuzzy
+msgid "Cannot select records from database"
+#, fuzzy
#, fuzzy
-#~ msgid "Failed to guess site file format\n"
#, fuzzy
-#~ msgid "Unable to access table <%s>"
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
#, fuzzy
-#~ msgid "<%s> table created in database."
#, fuzzy
@@ -30026,10 +30265,6 @@
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#, fuzzy
#~ msgid "Unable to write quant file"
@@ -30046,10 +30281,6 @@
#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#, fuzzy
#~ msgid "Cannot create category file of <%s>"
@@ -30070,10 +30301,6 @@
#, fuzzy
-#~ msgid "Error reading <%s>"
-#, fuzzy
#~ msgid "Horizon file no. %d <%s> not found"
@@ -30102,34 +30329,10 @@
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#, fuzzy
#~ msgid "Unable to get header for %s"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
@@ -30162,14 +30365,6 @@
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
@@ -30190,10 +30385,6 @@
#, fuzzy
-#~ msgid "Unable to read row %d"
-#, fuzzy
#~ msgid "Unable to read raster map row %d "
@@ -30202,10 +30393,6 @@
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#, fuzzy
#~ msgid "Unable to update boundaries"
@@ -30222,14 +30409,6 @@
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#, fuzzy
#~ msgid "Unable to open drainage pointer map"
@@ -30242,10 +30421,6 @@
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#, fuzzy
#~ msgid "Unable to read %s"
@@ -30274,14 +30449,6 @@
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
@@ -30338,62 +30505,10 @@
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#, fuzzy
#~ msgid "Unable to read cell header for first band file"
#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#, fuzzy
-#~ msgid "Could not open <%s>"
-#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
#~ msgid "Unable to compile regular expression %s"
@@ -30442,14 +30557,6 @@
#, fuzzy
-#~ msgid "Name of QC"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
@@ -30542,10 +30649,6 @@
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
@@ -30562,10 +30665,6 @@
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
@@ -30618,20 +30717,6 @@
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#, fuzzy
#~ msgid "Rotating data arrays..."
@@ -30680,10 +30765,6 @@
#, fuzzy
-#~ msgid "Group [%s] not found."
-#, fuzzy
#~ msgid "Subgroup [%s] not found."
@@ -30729,14 +30810,6 @@
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#, fuzzy
#~ msgid "subgroup <%s> not found"
@@ -30745,10 +30818,6 @@
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#, fuzzy
#~ msgid "Output file to contain final report"
@@ -30865,10 +30934,6 @@
#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#, fuzzy
#~ msgid "%d boundaries converted to lines"
@@ -30889,10 +30954,6 @@
#, fuzzy
-#~ msgid "Cannot select records from database"
-#, fuzzy
#~ msgid "Cannot fetch data"
@@ -31191,3 +31252,763 @@
#, fuzzy
#~ msgid "Error reading raster map"
+#, fuzzy
+#~ msgstr "ì¶ë ¥í ëì¤í°ë§µ"
+#, fuzzy
+#~ msgid "raster3d, statistics"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to read category labels of raster map <%s>"
+#, fuzzy
+#~ msgid "raster, map algebra"
+#, fuzzy
+#~ msgid "Unable to find starting vector <%s> "
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#, fuzzy
+#~ msgid "Illegal number of rows <%s>"
+#, fuzzy
+#~ msgid "raster, metadata"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, interpolation"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#, fuzzy
+#, fuzzy
+#~ msgid "No data"
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
+#, fuzzy
+#~ msgid "raster, series"
+#, fuzzy
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#, fuzzy
+#~ msgid "raster, resample"
+#, fuzzy
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#, fuzzy
+#~ msgid "raster, null data"
+#, fuzzy
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#, fuzzy
+#~ msgid "raster, composite"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#, fuzzy
+#~ msgid "general, projection"
+#, fuzzy
+#, fuzzy
+#~ msgid "general, settings"
+#, fuzzy
+#~ msgid "%s: couldn't be removed"
+#, fuzzy
+#~ msgid "No raster or vector map displayed"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#, fuzzy
+#~ msgid "%d new points written to output"
+#, fuzzy
+#~ msgid "Vector map <%s> not found in the current mapset"
+#, fuzzy
+#~ msgid "vector, extract"
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#, fuzzy
+#~ msgid "vector, import, sites"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#, fuzzy
+#, fuzzy
+#~ msgid "No attribute table found"
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#, fuzzy
+#~ msgid "vector, projection"
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#, fuzzy
+#~ msgid "vector, buffer"
+#, fuzzy
+#~ msgid "vector, querying"
+#, fuzzy
+#~ msgid "vector, transformation"
+#, fuzzy
+#~ msgid "Copying vector objects from vector map <%s>..."
+#, fuzzy
+#, fuzzy
+#~ msgid "Name for output vector map where segments will be written"
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#, fuzzy
+#~ msgid "%d points written to output vector map"
+#, fuzzy
+#~ msgid "Copying vector lines..."
+#, fuzzy
+#~ msgid "%d lines / boundaries removed"
+#, fuzzy
+#~ msgid "Error reading ASCII file: '%s'"
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#, fuzzy
+#~ msgid "Name of creator: %s"
+#, fuzzy
+#~ msgid "vector, category"
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, transformation, 3D"
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "How to split display"
+#, fuzzy
+#~ msgid "Select multiple points"
+#, fuzzy
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#, fuzzy
+#~ msgid "raster, elevation"
+#, fuzzy
+#~ msgid "miscellaneous, projection"
+#, fuzzy
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#, fuzzy
+#~ msgid "display, export"
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#, fuzzy
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#, fuzzy
+#~ msgid "raster, tiling"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, imagery, mosaicking"
+#, fuzzy
+#~ msgid "raster, statistics, aggregation"
+#, fuzzy
+#~ msgid "vector, report, statistics"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#, fuzzy
+#~ msgid "display, export, GPS"
+#, fuzzy
+#~ msgid "general, manual, help"
+#, fuzzy
+#~ msgid "sites, vector, import"
+#, fuzzy
+#~ msgid "raster, mask"
+#, fuzzy
+#~ msgid "Raster map to use as MASK"
+#, fuzzy
+#~ msgid "Overwrite existing MASK"
+#, fuzzy
+#~ msgid "raster, imagery, import"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Show vector maps rather than raster maps"
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#, fuzzy
+#~ msgid "Number of subframes"
+#, fuzzy
+#~ msgid "vector, import, gazetteer"
+#, fuzzy
+#~ msgid "vector, raster, statistics"
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#, fuzzy
+#~ msgid "Name of GIS manager settings file (.grc)"
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#, fuzzy
+#~ msgid "Percentile to calculate (requires -e flag)"
+#, fuzzy
+#~ msgid "Do not overwrite existing map"
+#, fuzzy
+#~ msgid "raster, imagery, colors"
+#, fuzzy
+#~ msgid "Import waypoints"
+#, fuzzy
+#~ msgid "Import routes"
+#, fuzzy
+#~ msgid "Import track"
+#, fuzzy
+#~ msgid "raster, elevation, interpolation"
+#, fuzzy
+#~ msgid "vector, centroid, area"
+#, fuzzy
+#, fuzzy
+#~ msgid "Name of PNG file"
+#, fuzzy
+#~ msgid "raster, imagery, statistics"
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#, fuzzy
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Target monitor"
+#, fuzzy
+#~ msgid "Source monitor"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#, fuzzy
+#~ msgid "Writing data..."
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#, fuzzy
+#~ msgid "Computing equations ..."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#, fuzzy
+#~ msgid "Unable to write temp file: %s"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#, fuzzy
+#~ msgid "Group [%s] contains no files"
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#, fuzzy
+#~ msgid "imagery, classification, MLC"
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#, fuzzy
+#~ msgid "Output separator (default: newline)"
+#, fuzzy
+#~ msgid "Icon to remove"
+#, fuzzy
+#~ msgid "3dview to remove"
+#, fuzzy
+#~ msgid "Name of fractal surface raster layer"
+#, fuzzy
+#~ msgid "Name of the sampling locations vector points map"
+#, fuzzy
+#~ msgid "Name of the output walkers vector points map"
+#, fuzzy
+#~ msgid "%d centroids converted to points"
+#, fuzzy
+#~ msgid "vector, attribute table"
+#, fuzzy
+#~ msgid "Cannot open database %s"
+#, fuzzy
+#~ msgid "Type of elements"
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the real-image map."
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#, fuzzy
+#~ msgid "Reading the raster maps..."
+#, fuzzy
+#~ msgid "Unable to open output file."
+#, fuzzy
+#~ msgid "Hue map name"
+#, fuzzy
+#~ msgid "Cannot read row from raster map"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ " group <%s> not found"
+#, fuzzy
+#~ msgid "** Can't open seed singature file <%s> **"
+#, fuzzy
+#~ msgid "** Can't read signature file <%s> **"
+#, fuzzy
+#~ msgid "File containing initial signatures"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#, fuzzy
+#~ msgid "Reading raster map"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#, fuzzy
+#~ msgid "Cannot open labels <%s>"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_lv.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -12872,9 +12872,8 @@
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
-#, fuzzy
msgid "Level"
-msgstr "Ūdens līmenis"
+msgstr ""
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
@@ -16461,9 +16460,9 @@
msgstr ""
#: ../display/d.vect/plot1.c:616
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr ""
+msgstr "Nav ieejas karte(s) norÄdÄ«ta."
#: ../display/d.vect/plot1.c:621
#, fuzzy, c-format
@@ -20672,9 +20671,8 @@
msgstr "Kļūda iekš pj_do_proj"
-#, fuzzy
-msgstr "Vektorkartes nosaukums"
+msgstr ""
#, fuzzy
@@ -24447,9 +24445,8 @@
msgstr "DrukÄt"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "Fonta nosaukums"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -24883,7 +24880,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "Lauku atdalÄ«tÄjs"
+msgstr "DrukÄt statistiku komandrindas skripta stilÄ"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -26865,9 +26862,8 @@
msgstr "Rastra ievades kartes"
-#, fuzzy
-msgstr "Rakstu jaunu failu... \n"
+msgstr ""
#, fuzzy
@@ -26949,10 +26945,11 @@
+#, fuzzy
msgid ""
"point."
-msgstr ""
+msgstr "Izejas rastra kartes nosaukums"
@@ -27013,8 +27010,9 @@
msgstr "OGR formÄts."
+#, fuzzy
-msgstr ""
+msgstr "EksistÄjoÅ¡as rastra kartes nosaukums"
#, fuzzy
@@ -27222,8 +27220,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
+#, fuzzy
msgid "LANDSAT sensor"
-msgstr ""
+msgstr "Spraigums"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
@@ -27237,8 +27236,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
+#, fuzzy
msgid "SPOT sensor"
-msgstr ""
+msgstr "Spraigums"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
#, fuzzy
@@ -27457,8 +27457,9 @@
msgstr "Ä¢enerÄ rastra karÅ¡u platÄ«bu statistiku."
#: ../locale/scriptstrings/v.report_to_translate.c:5
+#, fuzzy
msgid "Reverse sort the result"
-msgstr ""
+msgstr "RezultÄjoÅ¡Äs rastra kartes nosaukums"
#: ../locale/scriptstrings/v.report_to_translate.c:6
#, fuzzy
@@ -27492,8 +27493,9 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "Nevar noteikt laukuma centroīdu"
#, fuzzy
@@ -27605,9 +27607,10 @@
msgstr "AttÄlojamÄ rastra karte"
+#, fuzzy
msgid ""
-msgstr ""
+msgstr "KonvertÄ OGR vektorus uz GRASS vektoriem. Pieejamie draiveri:\n"
@@ -27636,8 +27639,9 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "AtlasÄ«t datus no datubÄzes."
#, fuzzy
@@ -27650,12 +27654,14 @@
msgstr "Datu bÄzes faila nosaukums"
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr "DatubÄzes nosaukums"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
msgid "New schema"
-msgstr ""
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
@@ -27855,8 +27861,9 @@
+#, fuzzy
msgid "display, vector, thematic, legend"
-msgstr ""
+msgstr "DrukÄ ... "
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
@@ -27902,11 +27909,12 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
#, fuzzy
msgid "Vector point icon for point data"
-msgstr "Rastra karte, kuras histogramma tiks parÄdÄ«ta"
+msgstr "IeejoÅ¡Ä karte satur lÄ«nijas"
+#, fuzzy
-msgstr ""
@@ -28024,10 +28032,11 @@
msgstr ""
+#, fuzzy
msgid ""
"points map."
-msgstr ""
+msgstr "Vektorkartes nosaukums"
@@ -28144,8 +28153,9 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "SaglabÄt esoÅ¡o krÄsu tabulu"
@@ -28257,8 +28267,9 @@
+#, fuzzy
msgid "Import"
-msgstr ""
+msgstr "Rakstu jaunu failu... \n"
@@ -28277,36 +28288,43 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "Nevar atlasīt datus no tabulas"
+#, fuzzy
-msgstr ""
+msgstr "nevar nolasÄ«t lÄ«niju ieejas paaugstinÄjumu kartÄ "
+#, fuzzy
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
+#, fuzzy
msgid "Source projection to request from server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#, fuzzy
msgid "Image format requested from the server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
msgid "Addition query options for server"
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "MaksimÄlÄ distance starp punktiem"
+#, fuzzy
-msgstr ""
@@ -28404,8 +28422,9 @@
msgstr "neiespÄjami atjaunot robežas"
+#, fuzzy
-msgstr ""
+msgstr "%s fails(i) kuri tiks attÄlinÄti"
@@ -28491,8 +28510,9 @@
+#, fuzzy
-msgstr ""
+msgstr "Nevajag taisīt atribūtu tabulu"
@@ -28558,8 +28578,9 @@
+#, fuzzy
-msgstr ""
#, fuzzy
@@ -28668,8 +28689,9 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "IzmantojamÄs rastra kartes nosaukums priekÅ¡ <%s>"
#, fuzzy
@@ -28682,8 +28704,9 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+#, fuzzy
msgid "Width of display canvas"
-msgstr ""
+msgstr "ParÄdÄ«t nulles šūnu unformÄciju"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
#, fuzzy
@@ -28754,8 +28777,9 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
#, fuzzy
@@ -28994,7 +29018,7 @@
#: ../imagery/i.pca/main.c:72
#, fuzzy
msgid "Name of two or more input raster maps"
-msgstr "Izejas rastra kartes nosaukums"
+msgstr "Ieejas rastra faila nosaukums"
#: ../imagery/i.pca/main.c:75
#, fuzzy
@@ -31093,6 +31117,257 @@
msgstr ""
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "IzvÄlies fontu kurÅ¡ tiks parÄdÄ«ts lietotÄja grafiskajÄ vidÄ."
+#, fuzzy
+msgstr "ImportÄjamais rastra fails"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "ASCII fails ar ievades datiem"
+#, fuzzy
+#, fuzzy
+msgstr "nevar atvÄrt vektorfailu <%s> iekÅ¡ <%s>"
+#, fuzzy
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr ""
+"jÅ«dzes (mi), metri (me), kilometri (k), akri (a), hektÄri (h), šūnas (c), "
+"procenti (p)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "SummÄ visas rastra šūnu vÄrtÄ«bas."
+#, fuzzy
+msgstr "Izveidit dotÄs datubÄzes tabulu sarakstu."
+#, fuzzy
+msgid "report"
+msgstr "vektora karte <%s> nav atrasta"
+#, fuzzy
+msgstr "Nav iespÄju atvÄrt šūnu failu priekÅ¡[%s]"
+#, fuzzy
+msgstr "NevarÄja atrast rastra failu %s"
+#, fuzzy
+#, fuzzy
+msgstr "neiespÄjami atvÄrt <%s>"
+#, fuzzy
+msgstr "nevar nolasīt reģionu <%s> pie <%s>"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgstr "Kļūda nolasot datu rindu"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "Nevar izveidot index"
+#, fuzzy
+#, fuzzy
+msgstr "Nevar izveidot jaunu rindu: %s"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid "Pass %d:"
+msgstr "GÄjiens: %d\n"
+#, fuzzy
+msgstr "Rastra kartes nosaukums"
+#, fuzzy
+msgstr "Lasam dig_att failu...\n"
+#, fuzzy
+#, fuzzy
+msgstr "Nevar ierakstīt ezera rastra karti <%s>!"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgstr "NevaratvÄrt datubÄzi %s"
+#, fuzzy
+msgstr "Nevar nolasÄ«t faila informÄciju"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid "qcname"
+msgstr "Fonta nosaukums"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Datu bÄzes faila nosaukums"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Līniju skaits"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid ""
+msgstr "Nevar atvÄrt failu ar koordinÄtÄm : %s\n"
+#, fuzzy
+#, fuzzy
+msgstr "reģions <%s> nav atrasts"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgstr "nevar atvÄrt 3d skata failu <%s> no <%s>"
+#, fuzzy
+msgid "Can't read signature file <%s>"
+#, fuzzy
+msgid "Select type"
+msgstr "No tipa"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Reljefa rastra karte (DEM)"
+#, fuzzy
+msgid "Erasing monitors ..."
+#, fuzzy
+msgid "Output terrain only vector map name"
+msgid "Raster file [%s] not available"
+msgstr "Rastra fails [%s] nav pieejams"
+#, fuzzy
#~ msgid "Your mapset search list:\n"
#~ msgstr "drukÄ tekoÅ¡Äs karÅ¡u biblotÄkas/mapset meklÄÅ¡anas ceļu"
@@ -31105,10 +31380,6 @@
#~ msgstr "Datu bÄzes faila nosaukums"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "IzvÄlies fontu kurÅ¡ tiks parÄdÄ«ts lietotÄja grafiskajÄ vidÄ."
-#, fuzzy
#~ msgid "Failed in attempt to open %s"
#~ msgstr "Neveiksme atverot ieejas dig ieejas failu"
@@ -31137,14 +31408,6 @@
#~ msgstr "Nevajag taisīt atribūtu tabulu"
#, fuzzy
-#~ msgstr "ImportÄjamais rastra fails"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "ASCII fails ar ievades datiem"
-#, fuzzy
#~ msgid "Name of the elevation raster map [m]"
#~ msgstr "Ieejas rastra faila nosaukums"
@@ -31199,10 +31462,6 @@
#~ msgstr "PacÄluma slÄ«pums"
#, fuzzy
-#~ msgstr "IzmantojamÄs rastra kartes nosaukums priekÅ¡ <%s>"
-#, fuzzy
#~ msgid "Reading map..."
#~ msgstr "Lasam dig failu... \n"
@@ -31236,20 +31495,6 @@
#~ msgstr "neiespÄjami atvÄrt <%s>"
#, fuzzy
-#~ msgstr "nevar atvÄrt vektorfailu <%s> iekÅ¡ <%s>"
-#, fuzzy
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr ""
-#~ "jÅ«dzes (mi), metri (me), kilometri (k), akri (a), hektÄri (h), šūnas (c), "
-#~ "procenti (p)"
-#, fuzzy
#~ msgid "Import GDAL supported raster file into a binary raster map layer."
#~ msgstr "ImportÄ GDAL atbalstÄ«tu rastra failu kÄ jaunu rastra karti."
@@ -31261,10 +31506,6 @@
#~ "EksportÄ GRASS rastra failu uz 8/24bitu TIFF attÄla failu ar pikseļa "
#~ "izšķirtspÄju kÄda ir nodefinÄta tekoÅ¡ajam reÄ£ionam"
-#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "DrukÄt statistiku komandrindas skripta stilÄ"
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -31273,14 +31514,6 @@
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "SummÄ visas rastra šūnu vÄrtÄ«bas."
-#, fuzzy
-#~ msgstr "Izveidit dotÄs datubÄzes tabulu sarakstu."
-#, fuzzy
#~ msgid "Unable to close output map"
@@ -31320,20 +31553,12 @@
#~ msgstr "Rastra kartes nosaukums"
#, fuzzy
-#~ msgid "report"
-#~ msgstr "vektora karte <%s> nav atrasta"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr ""
#~ "procenti (p)"
#, fuzzy
-#~ msgstr "Nav iespÄju atvÄrt šūnu failu priekÅ¡[%s]"
-#, fuzzy
@@ -31385,10 +31610,6 @@
#~ msgstr "Nevar ierakstīt ezera rastra karti <%s>!"
#, fuzzy
-#~ msgstr "NevarÄja atrast rastra failu %s"
-#, fuzzy
#~ msgid "Reading row %d"
@@ -31460,10 +31681,6 @@
#~ msgstr "Nevar izveidot tabulu: %s"
#, fuzzy
-#, fuzzy
#~ msgid "Error in pipe creation"
#~ msgstr "Kļūda iekš pj_do_proj"
@@ -31508,14 +31725,6 @@
#~ msgstr "Nevar atvÄrt dig_cats failu"
#, fuzzy
-#~ msgstr "neiespÄjami atvÄrt <%s>"
-#, fuzzy
-#~ msgstr "nevar nolasīt reģionu <%s> pie <%s>"
-#, fuzzy
@@ -31524,18 +31733,6 @@
#~ msgstr "Nevar izveidot index"
#, fuzzy
-#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -31580,18 +31777,6 @@
#~ msgstr "RezultÄjoÅ¡Äs rastra kartes nosaukums"
#, fuzzy
-#, fuzzy
-#~ msgstr "Kļūda nolasot datu rindu"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "Nevar izveidot index"
-#, fuzzy
@@ -31612,10 +31797,6 @@
#~ msgstr "DrukÄ ... "
#, fuzzy
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr "Rakstu jaunu failu... \n"
@@ -31627,10 +31808,6 @@
#~ msgid "Failed writing raster map row %d"
#~ msgstr "Lasam dig_att failu...\n"
-#, fuzzy
-#~ msgstr "Nevar izveidot jaunu rindu: %s"
#~ msgid "Invalid region: %s"
#~ msgstr "Nederīgs reģions: %s"
@@ -31654,14 +31831,6 @@
#, fuzzy
-#, fuzzy
-#~ msgstr "Rakstu jaunu failu... \n"
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
#~ msgstr "NevaratvÄrt datubÄzi %s"
@@ -31682,14 +31851,6 @@
#, fuzzy
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "IeejoÅ¡Ä karte satur lÄ«nijas"
-#, fuzzy
@@ -31726,14 +31887,6 @@
#~ msgstr "EksistÄjoÅ¡as rastra kartes nosaukums"
#, fuzzy
-#, fuzzy
-#, fuzzy
@@ -31750,10 +31903,6 @@
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "GÄjiens: %d\n"
-#, fuzzy
#~ msgid "Unable to open table <%s_edge_Interpolation>"
#~ msgstr "Rastra izejas fails"
@@ -31870,22 +32019,10 @@
#, fuzzy
-#~ msgstr "Rastra kartes nosaukums"
-#, fuzzy
-#~ msgstr "Lasam dig_att failu...\n"
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "NeizdevÄs piešķirt atmiÅu rindu norÄdÄm"
#, fuzzy
-#, fuzzy
#~ msgid "Did not find input cell map MASK."
#~ msgstr "Nevar atrast ieejas karti <%s>\n"
@@ -31898,48 +32035,12 @@
#~ msgstr "neiespÄjami atjaunot robežas"
#, fuzzy
-#~ msgstr "Nevar ierakstīt ezera rastra karti <%s>!"
-#, fuzzy
-#, fuzzy
#~ msgid "Error while reading input raster map."
-#, fuzzy
-#, fuzzy
-#, fuzzy
-#~ msgstr "NevaratvÄrt datubÄzi %s"
-#, fuzzy
-#~ msgstr "Nevar nolasÄ«t faila informÄciju"
#~ msgstr "NeiespÄjami atvÄrt <%s>"
-#, fuzzy
-#~ msgstr "Izejas rastra kartes nosaukums"
-#, fuzzy
-#, fuzzy
#~ msgid "Error reading row of data"
@@ -32058,22 +32159,6 @@
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "Fonta nosaukums"
-#, fuzzy
-#~ msgstr "Datu bÄzes faila nosaukums"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Līniju skaits"
-#, fuzzy
-#, fuzzy
@@ -32271,10 +32356,6 @@
#, fuzzy
-#, fuzzy
@@ -32319,10 +32400,6 @@
#, fuzzy
-#, fuzzy
#~ msgstr "Rastra karte ar virsmu"
@@ -32410,20 +32487,6 @@
#, fuzzy
-#, fuzzy
-#~ msgid ""
-#~ msgstr "Nevar atvÄrt failu ar koordinÄtÄm : %s\n"
-#, fuzzy
-#, fuzzy
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "%d rastrs %s, %d vektors %s\n"
@@ -32511,10 +32574,6 @@
#~ msgstr "DarbinÄt mierÄ«gi"
#, fuzzy
-#~ msgstr "reģions <%s> nav atrasts"
-#, fuzzy
@@ -32576,14 +32635,6 @@
#~ msgstr "Pabeigts: "
#, fuzzy
-#, fuzzy
-#, fuzzy
#~ msgid ""
#~ "\n"
@@ -32602,14 +32653,6 @@
#, fuzzy
-#~ msgstr "nevar atvÄrt 3d skata failu <%s> no <%s>"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#, fuzzy
#~ msgid "Group of imagery files to be clustered"
@@ -32871,10 +32914,6 @@
#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "No tipa"
-#, fuzzy
#~ msgstr "Nevar atlasīt datus no tabulas"
@@ -33193,10 +33232,6 @@
#~ msgid "Unable to find clump map"
-#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Reljefa rastra karte (DEM)"
#~ msgid "Output raster map with lake"
#~ msgstr "Izvades rastra karte ar ezeru"
@@ -33683,10 +33718,6 @@
#~ msgstr "izejas lÄ«meÅa nosaukums"
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#, fuzzy
#~ msgid "Could not open input file <%s>."
@@ -34082,10 +34113,6 @@
#~ msgstr "Nevar izveidot datubÄzu sarakstu"
#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#, fuzzy
#~ msgid "Cannot open vector map <%s> at the topological level"
@@ -34387,9 +34414,6 @@
#~ msgid "Not able to find cellfile [%s]"
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Rastra fails [%s] nav pieejams"
#, fuzzy
#~ msgid "Raster map [%s] not found"
#~ msgstr "rastra karte <%s> nav atrasta"
@@ -35512,3 +35536,1205 @@
#~ "Displays the rhumbline joining two user-specified points, in the active "
#~ "frame on the user's graphics monitor."
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Lasam dig_att failu...\n"
+#, fuzzy
+#~ msgstr "IzmantojamÄs rastra kartes nosaukums priekÅ¡ <%s>"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "EksistÄjoÅ¡as rastra kartes nosaukums"
+#, fuzzy
+#~ msgstr "nevar nolasīt reģionu <%s> pie <%s>"
+#, fuzzy
+#~ msgid "raster, import"
+#~ msgstr "vektora karte <%s> nav atrasta"
+#, fuzzy
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "Rakstu jaunu failu... \n"
+#, fuzzy
+#~ msgstr "NevarÄja atrast rastra failu %s"
+#, fuzzy
+#~ msgid "Parsing bytes per cell"
+#~ msgstr "Nederīgs soļu skaits: %s"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "Reljefa rastra karte (DEM)"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Izejas rastra kartes nosaukums"
+#, fuzzy
+#~ msgstr "maksimÄlais ierÄciju skaits"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, terrain"
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "DB tabula"
+#, fuzzy
+#~ msgstr "Nevar atrast vektoru karti [%s]"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "Ieejas rastra faila nosaukums"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Jaunas rastra kartes nosaukums"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "NogÄžu vÄrsuma izvades rastra kartes nosaukums"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "cnevar atvÄrt nepiecieÅ¡amo daļu faila priekÅ¡ %s"
+#, fuzzy
+#~ msgstr "AttÄlojamÄ rastra karte"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Ieejas karte: vidÄjÄ virszemes plÅ«ssma uz šūnu"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr ""
+#~ "Ieejas karte: reljefs, kas bloÄ·Ä virszemes Å«dens plÅ«smu, priekÅ¡ USLE"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Izvades karte: šūnu skaits, kas drenÄjas caur katru šūnu"
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr "Ievades vÄrtÄ«ba: maksimÄlais virszemes plÅ«smas garums, priekÅ¡ USLE"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "neiespÄjami atvÄrt <%s>"
+#, fuzzy
+#~ msgstr "Kļūda rakstot krÄsu failu priekÅ¡ <%s@%s>!"
+#, fuzzy
+#, fuzzy
+#~ msgid "Cannot read ew_res value"
+#~ msgstr "Nevar aprakstīt tabulu "
+#, fuzzy
+#~ msgid "Cannot read ns_res value"
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Izveido/modificÄ rastra kartei piesaistÄ«to krÄsu tabulu."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Rastra kartes nosaukums, no kuras nokopÄt krÄsu tabulu"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "ASCII fails ar ievades datiem"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "Nevar izveidot slÄni"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "%d punkti ierakstÄ«ti izejas kartÄ\n"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "Nederīgs izvades faila nosaukums"
+#, fuzzy
+#~ msgstr "ImportÄjamais rastra fails"
+#, fuzzy
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr ""
+#~ "Ä¢enerÄ rastra karti, kur vienlaidus apgabali ir palielinÄti par vienu "
+#~ "šūnu."
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: minūtes(0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: sekundes (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: laika zona (austrumu pozitīvs, nobīde no GMT, arī uzmanto lai "
+#~ "pielÄgotos dienasgaismas taupīšanai)"
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "nederīgs reģions: %s"
+#, fuzzy
+#~ msgstr "Nevar ierakstīt ezera rastra karti <%s>!"
+#, fuzzy
+#, fuzzy
+#~ msgstr "nevar nolasīt ievadu <%s> pie <%s>"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "IeejoÅ¡Ä karte satur lÄ«nijas"
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "ImportÄ GDAL atbalstÄ«tu rastra failu kÄ jaunu rastra karti."
+#, fuzzy
+#~ msgid "Output topographic index map"
+#~ msgstr "NogĞu slīpuma izvades rastra kartes nosaukums"
+#, fuzzy
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "Kolonas tips nav atbalstīts"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#, fuzzy
+#~ msgid "File containing weights"
+#~ msgstr "Neveiksme atverot ieejas dig_att failu"
+#, fuzzy
+#~ msgid "general, scripts"
+#, fuzzy
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "OGR formÄts."
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#~ msgstr "%s: NevarÄja nolasÄ«t krÄsu tabulu priekÅ¡ <%s@%s>"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "Fonta nosaukums"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitors: waitpid: sagaidÄmais %d iegÅ«tais %d\n"
+#, fuzzy
+#~ msgid "Unable to create face"
+#~ msgstr "neiespÄjami atjaunot robežas"
+#, fuzzy
+#~ msgid "Unable to set size"
+#, fuzzy
+#~ msgstr "RezultÄjoÅ¡Äs rastra kartes nosaukums"
+#, fuzzy
+#~ msgstr "krÄsu fails priekÅ¡ [%s] nav pieejams"
+#, fuzzy
+#~ msgstr "Rastra fails [%s] nav pieejams"
+#~ msgid "Name of graphics monitor to stop"
+#~ msgstr "ApstÄdinÄmÄ/izslÄdzamÄ grafiskÄ monitora mosaukums"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr "IzvÄlies fontu kurÅ¡ tiks parÄdÄ«ts lietotÄja grafiskajÄ vidÄ."
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#, fuzzy
+#~ msgstr "Nav iespÄju atvÄrt šūnu failu priekÅ¡[%s]"
+#, fuzzy
+#~ msgid "Vector map attribute column to use for comparison"
+#, fuzzy
+#, fuzzy
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "EksportÄt GRASS rastru uz binÄro masÄ«vu."
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "Nevajag taisīt atribūtu tabulu"
+#, fuzzy
+#~ msgid "Query layer number (read from)"
+#, fuzzy
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr "Vektorkartes nosaukums"
+#, fuzzy
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "KonvertÄ OGR vektorus uz GRASS vektoriem. Pieejamie draiveri:\n"
+#, fuzzy
+#~ msgid "Total area: %e (%d areas)"
+#, fuzzy
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "%-5d mirušo/neizmantoto punktu kategorijas izlaistas\n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Layer number (from)"
+#, fuzzy
+#~ msgid "Layer number (to)"
+#, fuzzy
+#~ msgstr "Izejas vektora punktu kartes nosaukums"
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "NeiespÄjami atvÄrt šūnu failu[%s]"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#, fuzzy
+#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#~ msgstr "DrukÄt tekoÅ¡o reÄ£ionu pÄc platuma/garuma"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgid "vector, geometry"
+#~ msgstr "vektors, ģeometrija"
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "DrukÄ ... "
+#, fuzzy
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#, fuzzy
+#~ msgstr "2 lÄ«meÅiem jÄbÅ«t norÄdÄ«tiem"
+#, fuzzy
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "KonvertÄt uz vienu no OGR atbalstÄ«tajiem vektoru formÄtiem."
+#~ msgid "Key column '%s' not found"
+#~ msgstr "AtslÄgas kolonna '%s' nav atrasta"
+#, fuzzy
+#~ msgid "Exporting %i points/lines..."
+#, fuzzy
+#~ msgid "%d features written"
+#, fuzzy
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr ""
+#~ "Izveido GRASS vektoru karti ar kontÅ«rlÄ«nijÄm norÄdÄ«tajai rastra kartei."
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, metadata"
+#, fuzzy
+#~ msgid "Buffer distance in map units"
+#~ msgstr "Bufera izmÄrs kartes vienÄ«bÄs"
+#, fuzzy
+#, fuzzy
+#~ msgid "Queries a vector map layer at given locations."
+#, fuzzy
+#~ msgid "If not given reads from standard input"
+#~ msgstr "%-5d punkti nolasÄ«ti un ierakstÄ«ti izejÄ\n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Name of input vector map containing lines"
+#, fuzzy
+#~ msgstr "Izejas karte kurÄ tiks ierakstÄ«ti punkti"
+#, fuzzy
+#~ msgid "Tests for normality for points."
+#~ msgstr "rotÄt/grozÄ«t izdruku"
+#, fuzzy
+#~ msgstr "Nevar noteikt laukuma centroīdu"
+#, fuzzy
+#, fuzzy
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr "Izveidot punktus visÄ garumÄ ilÄ«niju garumÄ"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "%s fails(i) kuri tiks dzÄsti"
+#, fuzzy
+#~ msgid "Duplicate area centroids"
+#, fuzzy
+#~ msgid "No data points found"
+#~ msgstr "Nekas nav atrasts.\n"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Izvada pamata informÄciju par lietotÄja norÄdÄ«to vektoru failu."
+#, fuzzy
+#, fuzzy
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr "izdrukÄt tekoÅ¡Ä pieslÄguma parametrus un iziet"
+#, fuzzy
+#~ msgid "Vector map <%s> is connected by:"
+#, fuzzy
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#, fuzzy
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "NesiespÄjami noskaidrot rastra šūnas tipu."
+#, fuzzy
+#, fuzzy
+#~ msgid "Verbose module output"
+#~ msgstr "IzvÄrstÄ režīmÄ"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "kolona 2"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "OGR draiveris: kolona '%s', OGR tips %d nav atbalstīts"
+#, fuzzy
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#, fuzzy
+#~ msgid "Database schema"
+#~ msgstr "DatubÄzes nosaukums"
+#~ msgid "database, SQL"
+#~ msgstr "datu bÄze, SQL"
+#, fuzzy
+#~ msgid "Name of file with sql statement"
+#~ msgstr "faila nosaukums ar sql formulÄjumiem"
+#, fuzzy
+#~ msgid "The password was stored in file"
+#~ msgstr "Parole tika noglabÄta failÄ."
+#, fuzzy
+#~ msgstr "NeiespÄjami atvÄrt [%s]"
+#, fuzzy
+#~ msgstr "No tipa"
+#, fuzzy
+#~ msgid ""
+#~ "format"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Ieejas fails"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#~ msgstr "Datu bÄzes faila nosaukums"
+#, fuzzy
+#~ msgid "PostScript"
+#~ msgstr "PostScript izvades fails"
+#, fuzzy
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#~ msgstr "PostScript izejas fails"
+#, fuzzy
+#~ msgstr "Nevar nokopÄt tabulu"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Rastra kartes nosaukums"
+#, fuzzy
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "izveidot sarakstu ar visÄm pieejamajÄm karÅ¡u biblotÄkÄm/mapsets"
+#, fuzzy
+#~ msgid "display, diagram"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Ä¢enerÄ rastra karÅ¡u platÄ«bu statistiku."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "PÄrkodÄt rastra kartes."
+#, fuzzy
+#, fuzzy
+#~ msgstr "NevaratvÄrt datubÄzi %s"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#, fuzzy
+#~ msgid "display, slideshow"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Display monitor to start"
+#~ msgstr "StartÄjamÄ/palaižamÄ grafiskÄ monitora nosaukums"
+#, fuzzy
+#, fuzzy
+#~ msgid "Device or file used to import data"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr ""
+#~ "OGR slÄÅa nosaukums. Ja nav norÄdÄ«ts, tad tiek importÄti visi slÄÅi. "
+#~ "PiemÄri:\n"
+#~ "\t\tESRI Shapefile: faila nosaukums\n"
+#~ "\t\tMapInfo fails: faila nosaukums"
+#, fuzzy
+#, fuzzy
+#~ msgid "Configuration editor for r.li.'index'"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Rastra karte, kuras histogramma tiks parÄdÄ«ta"
+#, fuzzy
+#~ msgid "Layer where to add column"
+#, fuzzy
+#~ msgid "stay with source monitor"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "KalkulÄjam Änas no DEM..."
+#, fuzzy
+#~ msgid ""
+#~ msgstr "Nevar atvÄrt failu ar koordinÄtÄm : %s\n"
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgstr "reģions <%s> nav atrasts"
+#, fuzzy
+#, fuzzy
+#~ msgid "No initial camera exposure station for group [%s]"
+#, fuzzy
+#~ msgid "Bad format in initial camera exposure station for group [%s]"
+#, fuzzy
+#~ msgid "No photo points for group [%s]"
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#, fuzzy
+#~ msgstr "Tabulu kopÄÅ¡ana"
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Target information for group [%s] missing\n"
+#~ msgstr "rastra karte <%s> nav atrasta"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Layer to use for thematic display"
+#, fuzzy
+#~ msgid "Mapset(s) to list (default: current mapset search path)"
+#~ msgstr "drukÄ tekoÅ¡Äs karÅ¡u biblotÄkas/mapset meklÄÅ¡anas ceļu"
+#, fuzzy
+#~ msgstr "%s fails(i) kuri tiks attÄlinÄti"
+#, fuzzy
+#~ msgid "Output field seperator"
+#~ msgstr "Izvades lauku atdalÄ«tÄjs"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+#~ "(ercent_cover)"
+#~ msgstr ""
+#~ "jÅ«dzes (mi), metri (me), kilometri (k), akri (a), hektÄri (h), šūnas (c), "
+#~ "procenti (p)"
+#, fuzzy
+#~ msgid "Run verbosly"
+#~ msgstr "Izveidot visu ekrÄnu sarakstu"
+#, fuzzy
+#~ msgid "ID values"
+#~ msgid "To layer"
+#~ msgstr "Uz slÄni"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "Line: %d \n"
+#~ "Type: %s \n"
+#~ "Left: %d \n"
+#~ "Right: %d \n"
+#~ msgstr "Līnija: %d Tips: %s Kreisais: %d Labais: %d "
+#, fuzzy
+#~ msgid ""
+#~ "Node[%d]: %d \n"
+#~ "Number of lines: %d \n"
+#~ "Coordinates: %.6f, %.6f, %.6f\n"
+#~ msgstr " Posms[%d]: %d Līniju skaits: %d\n"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %5d \n"
+#~ "Angle: %.8f\n"
+#~ msgstr " LÄ«nija: %5d LeÅÄ·is: %.8f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Area: %d \n"
+#~ "Number of isles: %d\n"
+#~ msgstr "Laukums: %d Salu skaits: %d\n"
+#, fuzzy
+#~ msgstr "Elementa nosaukums"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Insufficent memory for allocation of data structure"
+#~ msgstr "atubÄzes atraÅ¡nÄs"
+#, fuzzy
+#~ msgid "Writing data to file..."
+#, fuzzy
+#~ msgstr "%s - nederīgs nosaukums"
+#, fuzzy
+#, fuzzy
+#~ msgid "Output hue raster map"
+#, fuzzy
+#~ msgstr "nevar atvÄrt 3d skata failu <%s> no <%s>"
+#, fuzzy
+#~ msgid "Error writing result map file!"
+#~ msgstr "Kļūda meiģinot nolasīt dbmscap failu\n"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#~ msgid "Output file name"
+#~ msgstr "Izvades faila nosaukums"
+#, fuzzy
+#~ msgid "Name of the resultant map"
+#, fuzzy
+#~ msgstr "Nevar atlasīt datus no tabulas"
+#, fuzzy
+#~ msgstr "Nevar izveidot tabulu: %s"
+#, fuzzy
+#~ msgid "Done"
+#~ msgstr "Padarīts\n"
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr "Nevar atvÄrt OGR datu avotu '%s'"
+#, fuzzy
+#~ msgid "Unable to read category file for raster map <%s>"
+#, fuzzy
+#~ msgid "Creating support files"
+#, fuzzy
+#~ msgid "Reading %s ... "
+#~ msgstr "Lasam dig failu... \n"
+#~ msgid "%s in %s: %s"
+#~ msgstr "%s iekš %s: %s"
+#, fuzzy
+#~ msgid "cannot read head of %s"
+#~ msgstr "Nevar nolasÄ«t faila informÄciju"
+#, fuzzy
+#, fuzzy
+#~ msgid "Reading raster map <%s> ..."
+#~ msgid "No record for cat = %d"
+#~ msgstr "Nav ieraksta priekš līnijas cat= %d"
+#, fuzzy
+#~ msgid "Vector map <%s> not found in current mapset"
+#, fuzzy
+#~ msgid "Database connection not defined for layer <%d>"
+#~ msgstr "DatubÄzes konekcija nav definÄta"
+#, fuzzy
+#, fuzzy
+#~ msgid "Database record for cat %d not found"
+#, fuzzy
+#~ msgid "Cannot open file [%s]"
+#, fuzzy
+#~ msgid "%s - illegal name"
+#, fuzzy
+#~ msgid "Closing raster map"
+#~ msgid "Name of the new raster map"
+#, fuzzy
+#~ msgid "Could not find input vector map %s"
+#~ msgstr "Nevar atrast ieejas karti <%s>\n"
+#, fuzzy
+#~ msgid "Can't create output map"
+#, fuzzy
+#~ msgid "name for new raster map"
+#, fuzzy
+#~ msgid "name for new vector map"
+#, fuzzy
+#~ msgid "No input coordinates provided"
+#~ msgid "Raster output file"
+#~ msgstr "Rastra izejas fails"
+#, fuzzy
+#~ msgid "Name of the output walkers site file"
+#, fuzzy
+#~ msgid "Path to the input file"
+#~ msgid "Database name:"
+#~ msgstr "DatubÄzes nosaukums:"
+#, fuzzy
+#~ msgid "column type not supported"
+#, fuzzy
+#~ msgid "Unable to find base map <%s>"
+#, fuzzy
+#~ msgid "category [%d]"
+#~ msgstr ""
+#~ "Līmenis: %d\n"
+#~ "kategorija: %d\n"
+#, fuzzy
+#~ msgid "Interpolation()"
+#~ msgstr "nevar nolasÄ«t lÄ«niju ieejas paaugstinÄjumu kartÄ "
+#, fuzzy
+#~ msgid "Writing "
+#, fuzzy
+#~ msgid "Calculation time"
+#, fuzzy
+#~ msgid "input layer name"
+#~ msgstr "Ieejas draivera nosaukums"
+#, fuzzy
+#~ msgid "Name of the column with tree crown width"
+#, fuzzy
+#~ msgid "Name of spheroid to use"
+#~ msgstr "Līniju skaits"
+#, fuzzy
+#~ msgid "Overwrite <to> file(s)"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "izejas lÄ«meÅa nosaukums"
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_mr.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -2485,9 +2485,8 @@
msgstr ""
#: ../raster/r.in.gdal/main.c:206
-#, fuzzy
msgid "Available GDAL Drivers:"
-msgstr "डाà¤à¤¾à¤¬à¥à¤¸à¤à¥ नाव:"
+msgstr ""
#: ../raster/r.in.gdal/main.c:227 ../raster/r.proj/main.c:282
#: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
@@ -4298,9 +4297,8 @@
#: ../vector/v.surf.rst/main.c:217 ../vector/v.surf.rst/main.c:223
#: ../vector/v.surf.rst/main.c:229 ../vector/v.surf.rst/main.c:236
#: ../vector/v.surf.rst/main.c:243 ../vector/v.surf.rst/main.c:250
-#, fuzzy
msgid "Outputs"
-msgstr "पà¥à¤°à¥à¤£ तपशिल"
+msgstr ""
#: ../raster/r.slope.aspect/main.c:169 ../vector/v.surf.rst/main.c:204
#, fuzzy
@@ -5283,9 +5281,9 @@
msgstr ""
#: ../raster/r.transect/main.c:84
-#, fuzzy, c-format
+#, c-format
msgid "End coordinate: %.15g, %.15g"
-msgstr "तà¤à¥à¤¤à¥à¤¯à¤¾à¤à¥ नाव"
+msgstr ""
#: ../raster/r.transect/main.c:105
msgid ""
@@ -10722,8 +10720,9 @@
msgstr ""
#: ../raster/r.external/main.c:313
+#, fuzzy
msgid "Complex types not supported"
-msgstr ""
+msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
#: ../raster/r.external/main.c:328
#, fuzzy, c-format
@@ -10786,8 +10785,9 @@
msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
#: ../raster/r.external/main.c:529
+#, fuzzy
msgid "Raster file to be linked"
-msgstr ""
+msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
#: ../raster/r.external/main.c:535
#, fuzzy
@@ -14188,9 +14188,9 @@
#: ../display/d.geodesic/main.c:88 ../display/d.geodesic/main.c:91
#: ../display/d.rhumbline/main.c:82 ../display/d.rhumbline/main.c:85
#: ../display/d.rhumbline/main.c:88 ../display/d.rhumbline/main.c:91
-#, c-format
+#, fuzzy, c-format
msgid "%s - illegal longitude"
-msgstr ""
+msgstr "तà¤à¥à¤¤à¥à¤¯à¤¾à¤à¥ नाव"
#: ../display/d.path/main.c:49 ../vector/v.net.alloc/main.c:61
#: ../vector/v.net/main.c:46 ../vector/v.net.iso/main.c:73
@@ -16077,9 +16077,9 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
#, fuzzy, c-format
@@ -17665,7 +17665,7 @@
#: ../vector/v.in.db/main.c:176
#, fuzzy
msgid "Writing features..."
-msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
#: ../vector/v.in.db/main.c:183
msgid "Key column must be integer"
@@ -18521,7 +18521,7 @@
#: ../vector/v.outlier/main.c:240
#, fuzzy, c-format
msgid "It was impossible to create <%s> table."
#: ../vector/v.outlier/main.c:390 ../vector/v.lidar.edgedetection/main.c:414
#: ../vector/v.lidar.correction/main.c:400
@@ -18960,7 +18960,7 @@
#: ../vector/v.delaunay/in_out.c:93
#, fuzzy
msgid "Writing edges..."
#: ../vector/v.delaunay/in_out.c:215
#, fuzzy
@@ -20160,9 +20160,8 @@
msgstr ""
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
+msgstr ""
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -21191,11 +21190,11 @@
msgstr ""
#: ../vector/v.what/what.c:394
-#, c-format
+#, fuzzy, c-format
msgid ""
"Area: %d\n"
-msgstr ""
#: ../vector/v.what/what.c:404
#, c-format
@@ -23808,9 +23807,8 @@
-#, fuzzy
msgid "line"
+msgstr ""
#, fuzzy
@@ -26126,9 +26124,8 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#, fuzzy
msgid "Write output to PNG image"
+msgstr ""
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
msgid "Coordinates"
@@ -26192,8 +26189,9 @@
msgstr ""
#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
+#, fuzzy
msgid "Input type point, line or area"
-msgstr ""
#: ../locale/scriptstrings/v.in.e00_to_translate.c:7
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:6
@@ -26207,10 +26205,11 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:1
+#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
-msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -26268,8 +26267,9 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:8
msgid "Field separator (format: input[,output])"
@@ -26424,8 +26424,9 @@
msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#, fuzzy
msgid "Source projection"
-msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
@@ -26437,8 +26438,9 @@
msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
-msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:12
msgid "Maximum number of rows for a tile in the source projection"
@@ -26615,8 +26617,9 @@
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:6
+#, fuzzy
msgid "Percentage weight of first map for color blending"
-msgstr ""
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
@@ -26642,16 +26645,18 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#, fuzzy
msgid "Layer in the vector to be modified"
-msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
msgid "Column to be updated with the query result"
msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+#, fuzzy
msgid "Vector map to be queried"
-msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
#, fuzzy
@@ -26659,8 +26664,9 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+#, fuzzy
msgid "Column to be queried"
-msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
msgid "Maximum query distance in map units"
@@ -26676,8 +26682,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
@@ -26723,13 +26730,15 @@
msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:11
+#, fuzzy
msgid "Value to calculate"
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+#, fuzzy
msgid ""
"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
#, fuzzy
@@ -26830,9 +26839,10 @@
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
+#, fuzzy
msgid ""
"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
#: ../locale/scriptstrings/r.mask_to_translate.c:1
msgid "Creates a mask for limiting raster operation."
@@ -26860,8 +26870,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
#, fuzzy
@@ -26869,16 +26880,19 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#, fuzzy
msgid "Name of new database"
-msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr "डाà¤à¤¾à¤¬à¥à¤¸à¤à¥ नाव:"
+#, fuzzy
msgid "New schema"
-msgstr ""
msgid ""
@@ -26912,9 +26926,10 @@
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
#, fuzzy
@@ -26994,9 +27009,8 @@
msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#, fuzzy
msgid "vector, import"
+msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
msgid "Create a 3D line from 3 column data"
@@ -27009,8 +27023,9 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#, fuzzy
msgid "Field separator"
-msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
msgid ""
@@ -27022,12 +27037,14 @@
msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:5
+#, fuzzy
msgid "Export as waypoints"
-msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:6
+#, fuzzy
msgid "Export as routes"
-msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:7
msgid "Export as tracks"
@@ -27122,8 +27139,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
+#, fuzzy
msgid "Icon size for point data"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
msgid "Minimum icon size/line width for graduated points/lines)"
@@ -27236,10 +27254,11 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+#, fuzzy
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -27272,8 +27291,9 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:12
+#, fuzzy
msgid "Column prefix for new attribute columns"
-msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
@@ -27354,8 +27374,9 @@
msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
+#, fuzzy
msgid "Reset to standard color range"
-msgstr ""
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
@@ -27376,10 +27397,11 @@
msgstr ""
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
-msgstr ""
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
#, fuzzy
@@ -27413,8 +27435,9 @@
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:6
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:7
+#, fuzzy
msgid "Name of the column"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
msgid "Downloads and imports data from WMS servers."
@@ -27463,8 +27486,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
+#, fuzzy
msgid "Import"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Don't reproject the data, just patch it"
@@ -27483,12 +27507,14 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#, fuzzy
msgid "Layers to request from map server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
msgid "Styles to request from map server"
@@ -27507,12 +27533,14 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+#, fuzzy
msgid "Maximum columns to request at a time"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#, fuzzy
msgid "Maximum rows to request at a time"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Additional options for r.tileset"
@@ -27556,8 +27584,9 @@
msgstr ""
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#, fuzzy
msgid "Raster map in which to fill nulls"
-msgstr ""
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
msgid ""
@@ -27592,8 +27621,9 @@
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#, fuzzy
msgid "Adds missing centroids to closed boundaries."
-msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
msgid "Action to be taken"
@@ -27604,8 +27634,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
@@ -27617,8 +27648,9 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:7
+#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:8
#, fuzzy
@@ -27626,8 +27658,9 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
#, fuzzy
@@ -27662,21 +27695,25 @@
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+#, fuzzy
msgid "Join column in other table"
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
+#, fuzzy
msgid ""
"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
+#, fuzzy
msgid "Vector map for which to drop attribute column"
-msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to drop column"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
@@ -27695,28 +27732,34 @@
msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+#, fuzzy
msgid "raster input map (LANDSAT channel 1)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#, fuzzy
msgid "raster input map (LANDSAT channel 2)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+#, fuzzy
msgid "raster input map (LANDSAT channel 3)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+#, fuzzy
msgid "raster input map (LANDSAT channel 4)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
+#, fuzzy
msgid "raster input map (LANDSAT channel 5)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
+#, fuzzy
msgid "raster input map (LANDSAT channel 7)"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
#, fuzzy
@@ -27724,10 +27767,11 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
+#, fuzzy
msgid ""
"Creates and connects a new attribute table to a given layer of an existing "
"vector map."
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
#, fuzzy
@@ -27735,8 +27779,9 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
#, fuzzy
@@ -27832,8 +27877,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+#, fuzzy
msgid "Imports attribute tables in various formats."
-msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
msgid "Table file to be imported or DB connection string"
@@ -27844,8 +27890,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
msgid "Interactively edit cell values in a raster map."
@@ -27869,12 +27916,14 @@
msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+#, fuzzy
msgid "Maximum number of rows to load"
-msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:11
+#, fuzzy
msgid "Maximum number of columns to load"
-msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
@@ -27920,8 +27969,9 @@
+#, fuzzy
-msgstr ""
msgid "Database/directory for table"
@@ -28035,9 +28085,9 @@
#: ../imagery/i.smap/segment.c:91
-#, fuzzy, c-format
+#, c-format
msgid "Processing rows %d-%d (of %d)..."
+msgstr ""
#: ../imagery/i.smap/model.c:43
#, c-format
@@ -28219,9 +28269,9 @@
#: ../imagery/i.pca/main.c:395
-#, fuzzy, c-format
+#, c-format
msgid "Rescaling <%s> to range %d,%d..."
+msgstr ""
#: ../imagery/i.pca/support.c:44
msgid "Eigen values, (vectors), and [percent importance]:"
@@ -30221,6 +30271,228 @@
msgstr ""
#, fuzzy
+msgid "Raster file to be converted."
+#, fuzzy
+msgid "terrain analysis"
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "दिलà¥à¤²à¥à¤¯à¤¾ डà¥à¤°à¤¾à¤à¤µà¤° व सà¥à¤¥à¤¾à¤¨à¤¾à¤à¥à¤¯à¤¾ सà¤à¤¬à¤à¤§à¥à¤¤ डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¾"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+#, fuzzy
+msgid "Error reading <%s>"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+#, fuzzy
+msgid "Unable to read row %d"
+#, fuzzy
+msgid "Unable to read region <%s>"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+#, fuzzy
+msgid "Error reading row <%d>"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+#, fuzzy
+msgid "Could not open <%s>"
+#, fuzzy
+msgid "Cannot write to output raster file"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+#, fuzzy
+msgid "Name of QC"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+#, fuzzy
+msgid "raster, random, cell"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+#, fuzzy
+msgid "Subgroup [%s] in group [%s] contains no files."
+#, fuzzy
+msgid "Group [%s] not found."
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+#, fuzzy
+#, fuzzy
+msgid "%d lines converted to boundaries"
+#, fuzzy
+msgid "CrossCorrelation: Column type not supported"
+#, fuzzy
+msgid "From layer"
+#, fuzzy
+msgid "Cannot select records from database"
+#, fuzzy
+#, fuzzy
#~ msgid "<%s> not found in mapset list"
#~ msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
@@ -30245,10 +30517,6 @@
#~ msgstr "तà¤à¥à¤¤à¥à¤¯à¤¾à¤à¥ नाव"
#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
-#, fuzzy
#~ msgid "Output water depth raster map [m]"
@@ -30261,10 +30529,6 @@
#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
-#, fuzzy
#~ msgid "Failed to guess site file format\n"
@@ -30273,18 +30537,6 @@
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "दिलà¥à¤²à¥à¤¯à¤¾ डà¥à¤°à¤¾à¤à¤µà¤° व सà¥à¤¥à¤¾à¤¨à¤¾à¤à¥à¤¯à¤¾ सà¤à¤¬à¤à¤§à¥à¤¤ डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¾"
-#, fuzzy
@@ -30325,10 +30577,6 @@
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#, fuzzy
#~ msgid "Unable to write quant file"
@@ -30373,10 +30621,6 @@
#, fuzzy
-#~ msgid "Error reading <%s>"
-#, fuzzy
#~ msgid "Horizon file no. %d <%s> not found"
@@ -30429,10 +30673,6 @@
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#, fuzzy
#~ msgid "Cannot close %s file (PIPE)"
@@ -30465,30 +30705,10 @@
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#, fuzzy
#~ msgid "Unable to get header for %s"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
@@ -30521,14 +30741,6 @@
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
@@ -30549,10 +30761,6 @@
#, fuzzy
-#~ msgid "Unable to read row %d"
-#, fuzzy
#~ msgid "Unable to read raster map row %d "
@@ -30561,10 +30769,6 @@
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#, fuzzy
#~ msgid "Unable to update boundaries"
@@ -30581,14 +30785,6 @@
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#, fuzzy
@@ -30609,10 +30805,6 @@
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#, fuzzy
#~ msgid "Unable to read %s"
@@ -30645,14 +30837,6 @@
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
@@ -30721,66 +30905,14 @@
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#, fuzzy
#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#, fuzzy
#~ msgid "Unable to read cell header for first band file"
#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#, fuzzy
-#~ msgid "Could not open <%s>"
-#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
#~ msgid "Error reading intensity data"
@@ -30857,18 +30989,6 @@
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "तà¤à¥à¤¤à¥à¤¯à¤¾à¤à¥ नाव"
-#, fuzzy
-#~ msgid "Name of QC"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
@@ -30991,10 +31111,6 @@
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#, fuzzy
#~ msgid "Can't find %d,%d:%f"
@@ -31003,18 +31119,10 @@
#, fuzzy
-#~ msgid "raster, random, cell"
-#, fuzzy
#~ msgid "Unable to open MASK"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
@@ -31071,20 +31179,6 @@
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#, fuzzy
#~ msgid "Rotating data arrays..."
@@ -31129,10 +31223,6 @@
#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#, fuzzy
#~ msgid "Writing [%s] ..."
@@ -31141,10 +31231,6 @@
#, fuzzy
-#~ msgid "Group [%s] not found."
-#, fuzzy
#~ msgid "Subgroup [%s] not found."
@@ -31190,14 +31276,6 @@
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#, fuzzy
#~ msgid "subgroup <%s> not found"
@@ -31206,14 +31284,6 @@
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#, fuzzy
-#, fuzzy
@@ -31358,10 +31428,6 @@
#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#, fuzzy
#~ msgid "%d boundaries converted to lines"
@@ -31378,10 +31444,6 @@
#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#, fuzzy
#~ msgid "CrossCorrelation: Cannot select data from table"
@@ -31398,14 +31460,6 @@
#, fuzzy
-#~ msgid "From layer"
-#, fuzzy
-#~ msgid "Cannot select records from database"
-#, fuzzy
#~ msgid "Cannot fetch data"
@@ -31634,10 +31688,6 @@
#, fuzzy
-#, fuzzy
@@ -32266,3 +32316,899 @@
#, fuzzy
#~ msgid "Error reading raster map"
+#, fuzzy
+#~ msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
+#, fuzzy
+#~ msgid "raster3d, statistics"
+#~ msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to read category labels of raster map <%s>"
+#, fuzzy
+#~ msgid "raster, map algebra"
+#, fuzzy
+#~ msgid "Unable to find starting vector <%s> "
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, interpolation"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#, fuzzy
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "तà¤à¥à¤¤à¥à¤¯à¤¾à¤à¥ नाव"
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#, fuzzy
+#~ msgid "Name of the elevation raster map [m]"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, series"
+#, fuzzy
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#, fuzzy
+#~ msgid "raster, null data"
+#, fuzzy
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#, fuzzy
+#~ msgid "File containing recode rules"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#, fuzzy
+#~ msgid "raster, composite"
+#, fuzzy
+#~ msgid "Input barrier raster map"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#, fuzzy
+#, fuzzy
+#~ msgid "general, projection"
+#, fuzzy
+#, fuzzy
+#~ msgid "general, settings"
+#, fuzzy
+#, fuzzy
+#~ msgid "couldn't be removed"
+#, fuzzy
+#~ msgid "name"
+#, fuzzy
+#~ msgid "No raster or vector map displayed"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#, fuzzy
+#~ msgid "%d new points written to output"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Vector map <%s> not found in the current mapset"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, extract"
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
+#, fuzzy
+#~ msgid "vector, import, sites"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#, fuzzy
+#, fuzzy
+#~ msgid "No attribute table found"
+#, fuzzy
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#, fuzzy
+#~ msgid "vector, projection"
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, buffer"
+#, fuzzy
+#~ msgid "vector, querying"
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, transformation"
+#, fuzzy
+#~ msgid "Copying vector objects from vector map <%s>..."
+#, fuzzy
+#, fuzzy
+#~ msgid "Name for output vector map where segments will be written"
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#, fuzzy
+#~ msgid "%d points written to output vector map"
+#, fuzzy
+#~ msgid "Copying vector lines..."
+#, fuzzy
+#~ msgid "%d lines / boundaries removed"
+#, fuzzy
+#~ msgid "Error reading ASCII file: '%s'"
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#, fuzzy
+#~ msgid "Name of creator: %s"
+#, fuzzy
+#~ msgid "vector, category"
+#, fuzzy
+#~ msgid "vector, transformation, 3D"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#, fuzzy
+#~ msgstr "डाà¤à¤¾à¤¬à¥à¤¸à¤à¥ नाव:"
+#, fuzzy
+#~ msgstr "डाà¤à¤¾à¤¬à¥à¤¸à¤à¥ नाव"
+#, fuzzy
+#, fuzzy
+#~ msgid "Enter command to execute in 1st frame"
+#, fuzzy
+#~ msgid "Enter command to execute in 2nd frame"
+#, fuzzy
+#~ msgid "How to split display"
+#, fuzzy
+#~ msgid "Select multiple points"
+#, fuzzy
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#, fuzzy
+#~ msgid "raster, elevation"
+#, fuzzy
+#~ msgid "miscellaneous, projection"
+#, fuzzy
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#, fuzzy
+#~ msgid "display, export"
+#, fuzzy
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#, fuzzy
+#~ msgid "raster, tiling"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, imagery, mosaicking"
+#, fuzzy
+#~ msgid "raster, statistics, aggregation"
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, report, statistics"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#, fuzzy
+#~ msgid "display, export, GPS"
+#, fuzzy
+#~ msgid "general, manual, help"
+#, fuzzy
+#~ msgid "sites, vector, import"
+#, fuzzy
+#~ msgid "raster, mask"
+#, fuzzy
+#~ msgid "Raster map to use as MASK"
+#, fuzzy
+#~ msgid "Overwrite existing MASK"
+#, fuzzy
+#~ msgid "raster, imagery, import"
+#, fuzzy
+#~ msgid "Layer number of data column"
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#, fuzzy
+#~ msgid "Number of subframes"
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#, fuzzy
+#~ msgid "Name of GIS manager settings file (.grc)"
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#, fuzzy
+#~ msgid "Percentile to calculate (requires -e flag)"
+#, fuzzy
+#~ msgid "Do not overwrite existing map"
+#, fuzzy
+#~ msgid "raster, imagery, colors"
+#, fuzzy
+#~ msgid "Import waypoints"
+#, fuzzy
+#~ msgid "Import routes"
+#, fuzzy
+#~ msgid "Import track"
+#, fuzzy
+#~ msgid "raster, elevation, interpolation"
+#, fuzzy
+#~ msgid "raster, imagery"
+#, fuzzy
+#~ msgid "Name of PNG file"
+#, fuzzy
+#~ msgid "raster, imagery, statistics"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#, fuzzy
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Target monitor"
+#, fuzzy
+#~ msgid "Source monitor"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#, fuzzy
+#~ msgid "Writing data..."
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#, fuzzy
+#~ msgid "Computing equations ..."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#, fuzzy
+#~ msgid "Unable to write temp file: %s"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#, fuzzy
+#~ msgid "Group [%s] contains no files"
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#, fuzzy
+#~ msgid "imagery, classification, MLC"
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#, fuzzy
+#~ msgid "Vector map to display thematically"
+#, fuzzy
+#, fuzzy
+#~ msgid "Output separator (default: newline)"
+#, fuzzy
+#~ msgid "3d raster to remove"
+#, fuzzy
+#~ msgid "Vector to remove"
+#, fuzzy
+#~ msgid "Label to remove"
+#, fuzzy
+#~ msgid "3dview to remove"
+#, fuzzy
+#~ msgid "Name of fractal surface raster layer"
+#, fuzzy
+#~ msgid "Name of the output walkers vector points map"
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, attribute table"
+#, fuzzy
+#~ msgid "Type of elements"
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the real-image map."
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#, fuzzy
+#~ msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ सà¥à¤¥à¤¾à¤¨"
+#, fuzzy
+#~ msgid "Reading the raster maps..."
+#, fuzzy
+#~ msgid "Unable to open output file."
+#, fuzzy
+#~ msgid "Hue map name"
+#, fuzzy
+#~ msgid "Cannot read row from raster map"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ " group <%s> not found"
+#, fuzzy
+#~ msgid "** Can't open seed singature file <%s> **"
+#, fuzzy
+#~ msgid "** Can't read signature file <%s> **"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#, fuzzy
+#~ msgid "Cannot read category file for <%s>"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Reading raster map"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#~ msgid "driver name"
+#~ msgstr "डà¥à¤°à¤¾à¤à¤µà¤°à¤à¥ नाव"
+#, fuzzy
+#, fuzzy
+#~ msgid "Could not close the 3d raster map"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "%s: can't open tempfile"
+#, fuzzy
+#~ msgid "cannot create index"
+#, fuzzy
+#~ msgid "Unable to find input cell map <%s>"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_pl.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -8612,7 +8612,7 @@
#: ../raster/r.colors/main.c:191
#, fuzzy
msgid "Path to rules file"
-msgstr "nazwa wynikowego pliku wektorowego"
+msgstr "Scieżka do pliku z fontami"
#: ../raster/r.colors/main.c:192
#, fuzzy
@@ -20400,6 +20400,7 @@
#: ../vector/v.out.ogr/args.c:14
#: ../locale/scriptstrings/v.out.gps_to_translate.c:9
+#, fuzzy
msgid "Feature type(s)"
msgstr "Typ obiektu"
@@ -26820,12 +26821,12 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:6
#, fuzzy
msgid "Raster input maps"
-msgstr "WejÅciowa mapa rastrowa"
+msgstr "Nie można zamknÄ
Ä mapy wejÅciowej "
#, fuzzy
-msgstr "Nadpisz plik mapy wyjÅciowej"
+msgstr "Wynikowy zakres danych"
msgid "Coordinates"
@@ -26849,7 +26850,7 @@
#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Oblicza regresjÄ linearnÄ
dla dwóch map rastrowych: y = a + b*x"
+msgstr ""
#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
msgid "Slower but more accurate (applies to FP maps only)"
@@ -26879,8 +26880,9 @@
"rastra które zawierajÄ
wartoÅci kategorii inne niż NULL"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+#, fuzzy
msgid "Import E00 file into a vector map."
-msgstr "Import pliku E00 do mapy wektorowej."
+msgstr "Importuje starsze wersje wektorowych map GRASS-a."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
msgid "Verbose mode"
@@ -26888,11 +26890,12 @@
#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
msgid "E00 file"
-msgstr "plik E00"
+msgstr ""
+#, fuzzy
-msgstr "Wprowadź typ punkt, linia lub obszar"
+msgstr "Wybierz typ: liniowy lub powierzchniowy"
@@ -26901,8 +26904,9 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:6
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+#, fuzzy
msgid "Name for output vector map"
-msgstr "Nazwa wyjÅciowej mapy wketorowej"
+msgstr "Nazwa dla wynikowej mapy rastrowej "
#, fuzzy
@@ -26922,7 +26926,7 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:4
#, fuzzy
msgid "Name of raster plane to be created"
-msgstr "Nazwa pÅaszczyzny rastrowej która ma byÄ utworzona."
+msgstr "Nazwa wyÅwietanej rastrowej mapy ekspozycji"
#: ../locale/scriptstrings/r.plane_to_translate.c:5
msgid "Dip of plane. Value must be between -90 and 90 degrees"
@@ -26945,12 +26949,12 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:9
#, fuzzy
msgid "Elevation coordinate of a point on the plane"
-msgstr "WspóÅrzÄdna wysokoÅci punktu pÅaszczyzny."
+msgstr "WspóÅrzÄdne E i N punktu koÅcowego 'grida' mapy (E,N)"
#: ../locale/scriptstrings/r.plane_to_translate.c:10
#, fuzzy
msgid "Type of the raster map to be created"
-msgstr "Typ mapy rastrowej która ma byÄ utworzona."
+msgstr "Nazwa mapy rastrowej do przeskalowania"
#: ../locale/scriptstrings/m.proj_to_translate.c:1
#, fuzzy
@@ -26970,11 +26974,11 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:24
#, fuzzy
msgid "Files & format"
-msgstr "Format tabeli"
+msgstr "Format"
-msgstr "WyjÅciowy plik wspóÅrzÄdnych (pomiÅ wysyÅanie do stdout)"
+msgstr ""
#, fuzzy
@@ -26986,8 +26990,9 @@
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#, fuzzy
msgid "Input projection parameters (PROJ.4 style)"
-msgstr "WejÅciowe parametry projekcji (w stylu PROJ.4)"
+msgstr "WyjÅciowe parametry projekcji (w stylu PROJ.4)"
#: ../locale/scriptstrings/m.proj_to_translate.c:12
#: ../locale/scriptstrings/m.proj_to_translate.c:14
@@ -26998,6 +27003,7 @@
msgstr "Przetwarzanie ..."
#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#, fuzzy
msgid "Output projection parameters (PROJ.4 style)"
@@ -27101,20 +27107,17 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-"Testuj driver bazy danych, baza danych musi istnieÄ i byÄ ustawiona przy "
-"pomocy db.connect."
#: ../locale/scriptstrings/db.test_to_translate.c:4
+#, fuzzy
msgid "Test name"
-msgstr "Nazwa testu"
+msgstr "nazwa czcionki"
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
msgstr ""
-"Tworzy kafelki projekcji źródÅowej do zastosowania w docelowym regionie i "
-"projekcji."
#: ../locale/scriptstrings/r.tileset_to_translate.c:3
#, fuzzy
@@ -27122,13 +27125,13 @@
msgstr "raster, kafelkowanie"
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+#, fuzzy
msgid "Produces shell script output"
-msgstr "Tworzy produkt wyjÅciowy skryptu powÅoki"
+msgstr "WyÅwietl ustawienia bieżÄ
cego regionu (styl skryptu powÅoki)"
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-#, fuzzy
msgid "Produces web map server query string output"
+msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
#, fuzzy
@@ -27138,8 +27141,9 @@
"RozdzielczoÅÄ mapy wejÅciowej różni siÄ od rozdzielczoÅci bieżacego regionu!"
+#, fuzzy
-msgstr "Å»ródÅowa projekcja"
+msgstr "raster, projekcja"
@@ -27155,16 +27159,17 @@
#, fuzzy
-msgstr "Maksymalna liczba rzÄdów na czÄÅÄ w źródÅowej projekcji"
+msgstr "Liczba kolumn w nowym regionie"
+#, fuzzy
+msgstr "Liczba rzÄdów do zachowania w pamiÄci"
#: ../locale/scriptstrings/r.tileset_to_translate.c:13
+#, fuzzy
msgid "Number of cells tiles should overlap in each direction"
-msgstr ""
-"Liczba komórek którymi czÄÅÄ pokrywa siÄ z innymi we wszystkich kierunkach"
+msgstr "Liczba poziomów które majÄ
byÄ użyte dla każdego komponentu"
#: ../locale/scriptstrings/r.tileset_to_translate.c:15
#, fuzzy
@@ -27205,7 +27210,7 @@
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
#, fuzzy
msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "wejÅciowa mapa rastrowa (green: tm2 | qbird_green | spot1)"
+msgstr "Nazwa wejÅciowej mapy rastrowej (green)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
#, fuzzy
@@ -27220,12 +27225,12 @@
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:14
#, fuzzy
msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
+msgstr "wejsciowy plik rastrowy (obraz fft, czÄÅÄ rzeczywista)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:15
#, fuzzy
msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "prefiks wyjÅciowej mapy rastrowej TC"
#: ../locale/scriptstrings/g.extension_to_translate.c:1
msgid "Tool to maintain the extensions in local GRASS installation."
@@ -27250,7 +27255,7 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:6
#, fuzzy
msgid "Name of extension to install/remove"
-msgstr "Nazwa istniejÄ
cego pliku wektorowego"
+msgstr "Nazwa nowej lokacji, która ma byÄ utworzona"
#: ../locale/scriptstrings/g.extension_to_translate.c:8
msgid "SVN Addons repository URL"
@@ -27300,8 +27305,9 @@
msgstr "wyÅwietl indeks"
#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#, fuzzy
msgid "raster input map"
-msgstr "wejÅciowa mapa rastrowa"
+msgstr "raster, import"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
msgid "Mosaics several images and extends colormap"
@@ -27324,22 +27330,22 @@
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#, fuzzy
msgid "Name of first raster map for blending"
-msgstr "Nazwa pierwszej mapy rastrowej do wymieszania"
+msgstr "Nazwa pierwszej mapy rastrowej"
#: ../locale/scriptstrings/r.blend_to_translate.c:4
#, fuzzy
msgid "Name of second raster map for blending"
+msgstr "Nazwa nastÄpnej mapy rastrowej"
#: ../locale/scriptstrings/r.blend_to_translate.c:5
msgid "Base name for red, green and blue output maps containing the blend"
msgstr ""
-#, fuzzy
+msgstr ""
msgid ""
@@ -27362,20 +27368,21 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
#, fuzzy
msgid "Vector map to modify"
-msgstr "Wskazuje mapÄ wektorowÄ
do modyfikacji"
+msgstr "Mapa wektorowa do naÅożenia"
#, fuzzy
do modyfikacji"
+msgstr "Należy okreÅliÄ 2 warstwy"
msgstr ""
+#, fuzzy
-msgstr "Mapa wektorowa do odpytania"
#, fuzzy
@@ -27383,8 +27390,9 @@
msgstr "WejÅciowa mapa wektorowa"
+#, fuzzy
-msgstr "Kolumna do odpytania"
+msgstr "Kolumna musi to byÄ numeryczna"
#, fuzzy
@@ -27401,8 +27409,9 @@
msgstr ""
+#, fuzzy
-msgstr "WyjÅciowa mapa rastrowa (default: input tile)"
+msgstr "Nazwa dla wynikowej mapy rastrowej (override)"
@@ -27416,11 +27425,11 @@
#: ../locale/scriptstrings/v.report_to_translate.c:5
#, fuzzy
msgid "Reverse sort the result"
-msgstr "Sortuj wynik"
+msgstr "OdwrÃ³Ä selekcjÄ"
#: ../locale/scriptstrings/v.report_to_translate.c:6
msgid "Sort the result"
+msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:7
#: ../locale/scriptstrings/v.out.gps_to_translate.c:8
@@ -27448,28 +27457,28 @@
msgstr ""
+#, fuzzy
-msgstr "WartoÅÄ do obliczenia"
+msgstr "Nie można obliczyÄ centroid powierzchni"
msgid ""
msgstr ""
-"Umożliwia aktualizacjÄ kolumny w tabeli atrybutów poÅÄ
czonej z zadanÄ
mapÄ
-"wektorowÄ
#, fuzzy
msgid "Vector map to edit the attribute table for"
-msgstr "nazwa mapy wektorowej z której ma byÄ edytowana tabela atrybutów"
+msgstr "wektor, raster, tabela atrybutów"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid "Layer to which the table to be changed is connected"
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#, fuzzy
msgid "Column to update"
-msgstr "Kolumna do aktualizacji"
+msgstr "Typ kolumny nieobsÅugiwany"
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
msgid ""
@@ -27477,8 +27486,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:9
+#, fuzzy
msgid "Column to query"
-msgstr "Kolumna do zapytaÅ"
#: ../locale/scriptstrings/v.db.update_to_translate.c:10
msgid ""
@@ -27487,13 +27497,14 @@
msgstr ""
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
+#, fuzzy
msgid "Displays a raster map and its legend on a graphics window"
-msgstr "WyÅwietla mapÄ rastrowÄ
i jej legendÄ w oknie graficznym"
+msgstr "WyÅwietla podziaÅkÄ liniowÄ
na monitorze."
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
#, fuzzy
msgid "Omit entries with missing label"
-msgstr "pomiÅ pozycje bez etykiet"
+msgstr "PomiÅ kategorie bez etykiet"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
#, fuzzy
@@ -27501,6 +27512,7 @@
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+#, fuzzy
msgid "Number of lines to appear in the legend"
msgstr "Liczba linii legendy"
@@ -27556,13 +27568,13 @@
#: ../locale/scriptstrings/g.manual_to_translate.c:7
#, fuzzy
msgid "Manual entry to be displayed"
-msgstr "manualne wejÅcie które ma byÄ wyswietlone"
+msgstr "Mapa rastrowa która ma byÄ wyÅwietlona"
#, fuzzy
msgid ""
-msgstr "Konwertuje mapÄ rastrowÄ
do warstwy wektorowej."
+msgstr "Konwertuje plik site_lists GRASS do mapy wektorowej."
#, fuzzy
@@ -27592,25 +27604,28 @@
msgstr ""
+#, fuzzy
-msgstr "PodÅÄ
cza wektory do nowej bazy danych."
+msgstr "UsuÅ bazÄ danych."
#, fuzzy
msgid "Name of old database"
-msgstr "Nazwa nowej bazy danych"
+msgstr "Nazwa pliku bazy danych"
+#, fuzzy
msgid "Old schema"
msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
msgid "New schema"
-msgstr "Nowy schemat"
+msgstr "Struktura bazy danych"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
@@ -27646,20 +27661,18 @@
msgstr "Nadpisz istniejÄ
cy plik"
+#, fuzzy
msgid ""
-msgstr ""
-"Zmienia nazwÄ kolumny w tabeli atrybutów poÅÄ
czonej z zadanÄ
mapÄ
wektorowÄ
+msgstr "Nie można skopiowaÄ elementów z mapy wektorowej [%s]"
-#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr "nazwa mapy wektorowej z której ma byÄ usuniÄta tabela atrybutów"
+msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:6
-#, fuzzy
msgid "Layer where to rename column"
-msgstr "Warstwa do której ma byÄ dodana kolumna"
+msgstr ""
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:7
msgid "Old and new name of the column (old,new)"
@@ -27674,7 +27687,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:6
#, fuzzy
msgid "Name of column containing numeric data"
-msgstr "Nazwa mapy rastrowej bÄdÄ
cej gridem z informacjÄ
o kosztach "
+msgstr "Nazwa kolumny zawierajÄ
cej wspóÅrzÄdnÄ
x"
#: ../locale/scriptstrings/v.colors_to_translate.c:7
#, fuzzy
@@ -27697,27 +27710,27 @@
msgstr "Plik zawierajÄ
cy wyrażenia SQL"
#: ../locale/scriptstrings/v.colors_to_translate.c:16
-#, fuzzy
msgid "Save placeholder raster map for use with d.legend"
-msgstr "Nazwa wyÅwietanej rastrowej mapy ekspozycji"
+msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
#, fuzzy
msgid "Exports attribute tables into various formats."
-msgstr ""
-"Eksportuje dane rastrowe GRASS do różnych formatów (wymaga biblioteki GDAL)"
+msgstr "Eksportuje rastrowe mapy GRASS-a do formatów GDAL."
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+#, fuzzy
msgid "GRASS table name"
-msgstr "Nazwa tabeli GRASS"
+msgstr "Nazwa tabeli wejÅciowej"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
msgid "Table file to be exported or DB connection string"
msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+#, fuzzy
msgid "Table format"
+msgstr "Format"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
@@ -27744,27 +27757,28 @@
+#, fuzzy
-msgstr "Separator pól"
+msgstr "WyjÅciowy separator pól"
msgid ""
"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
msgstr ""
-"Eksportuje mapÄ wektorowÄ
do odbiornika GPS lub pliku obsÅugiwanego przez "
-"bibliotekÄ GPSBabel."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
msgid "GPS"
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "Eksportuje linie jako poligony"
+#, fuzzy
-msgstr ""
@@ -27791,7 +27805,7 @@
#: ../locale/scriptstrings/v.out.gps_to_translate.c:14
#: ../locale/scriptstrings/v.out.gps_to_translate.c:17
msgid "Subset"
-msgstr "Podzbiór"
+msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:15
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
@@ -27806,12 +27820,12 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
#, fuzzy
msgid "Displays thematic vector map"
-msgstr "WyÅwietla tematyczne mapy wektorowe"
+msgstr "NakÅada na siebie dwie mapy rastrowe."
#, fuzzy
msgid "display, vector, thematic, legend"
-msgstr "wyÅwietl, ustaw"
+msgstr "wyÅwietl, wektor"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
@@ -27836,15 +27850,16 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
#, fuzzy
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr "Warstwa jak ma byÄ użyta dla wyÅwietlania tematycznego"
+msgstr "Nazwa kolumny atrubutów do stworzenia etykiet"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
+#, fuzzy
msgid "Type of thematic display"
-msgstr "Rodzaj wyÅwietlania tematycznego"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
msgid "Thematic divisions of data for display"
-msgstr "Tematyczny podziaÅ danych do wyÅwietlenia"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
msgid "Break points for custom breaks option"
@@ -27855,13 +27870,14 @@
msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
+#, fuzzy
msgid "Vector point icon for point data"
-msgstr "Wektorowe ikony punktowe dla danych punktowych"
+msgstr "Mapa(y) wektorowa(e) zawierajÄ
ca(e) punkt(y) startowy(e)"
#, fuzzy
+msgstr "Dane o zaokrÄ
glonych wartoÅciach zmiennoprzecinkowych"
@@ -27872,18 +27888,17 @@
msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
+#, fuzzy
msgid "Number of classes for interval theme (integer)"
-msgstr "Liczba klas dla przedziaÅów tematu (caÅkowite)"
+msgstr "Liczba kopii do wydrukowania"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-#, fuzzy
msgid "Color scheme for graduated color mapping"
-msgstr "Kolor dla danych osi Y"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
-#, fuzzy
msgid "Select 'single_color' for graduated point/line display"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
#, fuzzy
@@ -27895,9 +27910,8 @@
msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-#, fuzzy
msgid "Color for graduated lines or point/area outlines"
+msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
@@ -27964,23 +27978,24 @@
msgstr ""
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+#, fuzzy
msgid "Drops an attribute table."
-msgstr "Usuwa tabelÄ atrybutów."
#: ../locale/scriptstrings/db.droptable_to_translate.c:5
+#, fuzzy
msgid "Table to drop"
-msgstr "Tabela do usuniÄcia"
+msgstr "Nie można usunÄ
Ä tabeli: [%s]"
#: ../locale/scriptstrings/r.grow_to_translate.c:3
msgid "radius is in map units rather than cells"
msgstr ""
-#, fuzzy
msgid ""
"points map."
-msgstr "Import pliku E00 do mapy wektorowej"
+msgstr ""
@@ -28013,14 +28028,13 @@
msgstr "Nazwa mapy rastrowej dla której majÄ
byÄ obliczone statystyki"
-#, fuzzy
-msgstr "prefiks kolumny dla nowych kolumn tabeli atrybutów"
+msgstr ""
#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
msgid "Uncompressed geonames file from (with .txt extension)"
@@ -28039,7 +28053,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
#, fuzzy
msgid "Input map is in Matlab format"
-msgstr "nazwa wejsciowego pliku w formacie Mapgen/Matlab"
+msgstr "Mapa wejÅciowa nie zawiera danych"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
msgid "Create a 3D vector points map from 3 column Matlab data"
@@ -28048,17 +28062,18 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
#, fuzzy
msgid "Name of input file in Mapgen/Matlab format"
+msgstr "nazwa wejÅciowego pliku wektorowego"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr "nazwa nowego pliku wektorowego (pomiÅ dla wyÅwietlania do stdout)"
+msgstr "Nazwa wyjÅciowej wektorowej mapy punktów"
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
#, fuzzy
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Nie można odnaleÅÄ wektorowej mapy wejÅciowej %s"
+msgstr ""
+"Nie można modyfikowaÄ map wektorowych znajdujÄ
cych siÄ w innym mapsecie."
#: ../locale/scriptstrings/v.build.all_to_translate.c:2
#, fuzzy
@@ -28099,8 +28114,9 @@
msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "UsuÅ istniejÄ
cÄ
paletÄ kolorów"
@@ -28109,12 +28125,12 @@
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
#, fuzzy
msgid "Name of shaded relief or aspect map"
-msgstr "Nazwa wynikowej mapy rastrowej"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
#, fuzzy
msgid "Name of raster to drape over relief map"
-msgstr "Nazwa rastrowej mapy kÄ
tów"
+msgstr "Nazwa pierwszej mapy rastrowej do wymieszania"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
#, fuzzy
@@ -28126,8 +28142,6 @@
"map."
msgstr ""
-"Dodaje jednÄ
lub wiÄcej kolumn do tabeli atrybutów poÅÄ
czonej z zadanÄ
mapÄ
-"wektorowÄ
#, fuzzy
@@ -28155,21 +28169,22 @@
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
#, fuzzy
msgid "Drops a column from selected attribute table"
-msgstr "Nie twórz tabeli atrybutowych"
+msgstr "Nie twórz tabeli atrubutów."
#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:5
#, fuzzy
msgid "Table from which to drop attribute column"
+msgstr "Nie można skopiowaÄ atrybutów"
+#, fuzzy
-msgstr "Nazwa kolumny"
+msgstr "Liczba kolumn"
-msgstr "ÅciÄ
ga i importuje dane z serwerów WMS."
+msgstr ""
msgid "wms"
@@ -28189,8 +28204,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
+#, fuzzy
msgid "Request"
-msgstr "Å»Ä
danie"
+msgstr "Wymagane"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
msgid "Skip to downloading (to resume downloads faster)"
@@ -28200,7 +28216,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
msgid "Download"
-msgstr "ÅciÄ
gnij"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
msgid "Don't request transparent data"
@@ -28215,7 +28231,7 @@
msgid "Import"
-msgstr "Import"
+msgstr ""
@@ -28236,7 +28252,7 @@
#, fuzzy
-msgstr "Nie można zaznaczyÄ danych z tabeli"
+msgstr "Nie można wybraÄ danych z tabeli"
@@ -28247,9 +28263,8 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-#, fuzzy
msgid "Source projection to request from server"
-msgstr "Metoda reprojekcji"
+msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
msgid "Image format requested from the server"
@@ -28281,8 +28296,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
+#, fuzzy
msgid "Reprojection method to use"
+msgstr "Metoda interpolacji która ma byÄ użyta"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
msgid "Filename to save capabilities XML file to"
@@ -28314,6 +28330,7 @@
msgstr ""
+#, fuzzy
msgstr "Mapa rastrowa w której majÄ
byÄ wypeÅnione zera"
@@ -28323,8 +28340,9 @@
msgstr ""
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#, fuzzy
msgid "Spline tension parameter"
-msgstr "Parametr napiecia krzywej spline"
+msgstr "Parametr napiÄcia"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
#, fuzzy
@@ -28349,11 +28367,11 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:9
#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr "Nazwa wyÅwietlanej kolumny"
+msgstr "Nazwa istniejÄ
cej warstwy mapy rastrowej"
-msgstr "Dodaje brakujÄ
ce centroidy do zamkniÄtych granic."
+msgstr ""
#, fuzzy
@@ -28368,7 +28386,7 @@
#, fuzzy
-msgstr "usuÅ istniejÄ
cÄ
tabelÄ atrybutów mapy wektorowej"
@@ -28377,27 +28395,27 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
#, fuzzy
msgid "Vector map from which to remove attribute table"
+msgstr "Nazwa mapy rastrowej z której kopiujemy paletÄ kolorów"
#, fuzzy
-msgstr "nazwa istniejÄ
cej tabeli atrybutów (domyÅlnie: nazwa mapy wektorowej)"
#, fuzzy
msgid "Layer from which to drop linked attribute table"
#, fuzzy
cÄ
#, fuzzy
msgid "Vector map to which to join other table"
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
msgid "layer,column"
@@ -28406,7 +28424,7 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
#, fuzzy
msgid "Layer where to join"
+msgstr "Liczba warstw (na)"
#: ../locale/scriptstrings/v.db.join_to_translate.c:8
#, fuzzy
@@ -28416,11 +28434,12 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:9
#, fuzzy
msgid "Join column in map table"
-msgstr "Nieznany typ kolumny"
+msgstr "Nieznana kolumna <%s> w tabeli <%s>"
#: ../locale/scriptstrings/v.db.join_to_translate.c:10
+#, fuzzy
msgid "Other table name"
-msgstr "Inna nazwa tabeli"
+msgstr "Wprowadź docelowÄ
nazwÄ tabeli"
#: ../locale/scriptstrings/v.db.join_to_translate.c:11
#, fuzzy
@@ -28430,28 +28449,25 @@
#, fuzzy
+msgstr "Liczba linii legendy"
-#, fuzzy
msgid ""
msgstr ""
-"dodaje jednÄ
czonej z danÄ
mapÄ
#, fuzzy
-#, fuzzy
+msgstr ""
-msgstr "Transformacja Cap (Kauth Thomas) dla danych LANDSAT-TM"
+msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
msgid "use transformation rules for LANDSAT-4"
@@ -28467,62 +28483,59 @@
-msgstr "wejÅciowa mapa rastrowa (LANDSAT channel 1)"
+msgstr ""
-msgstr "wejÅciowa mapa rastrowa (LANDSAT channel 2)"
+msgstr ""
-msgstr "wejÅciowa mapa rastrowa (LANDSAT channel 3)"
+msgstr ""
-msgstr "wejÅciowa mapa rastrowa (LANDSAT channel 4)"
+msgstr ""
-msgstr "wejÅciowa mapa rastrowa (LANDSAT channel 5)"
+msgstr ""
-msgstr "wejÅciowa mapa rastrowa (LANDSAT channel 7)"
+msgstr ""
+#, fuzzy
msgid "raster output TC maps prefix"
+msgstr "Nadpisz plik mapy wyjÅciowej"
-#, fuzzy
msgid ""
"vector map."
msgstr ""
-"Tworzy i dodaje nowÄ
tabelÄ atrybutów do zadanej warstwy istniejÄ
cej mapy "
-"wektorowej."
#, fuzzy
msgid "Vector map for which to add new attribute table"
+msgstr "mapa wektorowa do edycji tabeli atrybutów"
+#, fuzzy
-msgstr "Nazwa nowej tabeli atrybutów (domyslnie: nazwa mapy wektorowej)"
+#, fuzzy
msgid "Layer where to add new attribute table"
-msgstr "Warstwa do której ma byÄ dodana nowa tabela atrybutów"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
-#, fuzzy
msgid ""
"Name and type of the new column(s) (types depend on database backend, but "
"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
msgstr ""
-"Nazwa i typ nowej kolumny (typy w zależnoÅci od database backend, ale "
-"wszystkie wspierajÄ
VARCHAR(), INT, DOUBLE i DATE)"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
msgid "Import GetFeature from WFS."
@@ -28533,8 +28546,9 @@
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#, fuzzy
msgid "Vector output map"
-msgstr "Wektorowa mapa wyjÅciowa"
+msgstr "Brak mapy wyjÅciowej"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
msgid "Creates shaded relief map from an elevation map (DEM)."
@@ -28551,21 +28565,24 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
+#, fuzzy
msgid "Altitude of the sun in degrees above the horizon"
-msgstr "WysokoÅÄ sÅoÅca nad horyzontem w stopniach"
+msgstr "A: wysokoÅÄ sÅoÅca nad horyzontem, w stopniach"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
+#, fuzzy
msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "Azymut sÅoÅca mierzony w stopniach od póÅnocy ku wschodowi"
+msgstr "A: azytmut sÅoÅca od kierunku póÅnocy, w stopniach"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
+#, fuzzy
msgid "Factor for exaggerating relief"
-msgstr "WspóÅczynnik przewyższenia rzeźby"
+msgstr "Format raportu dla spadków"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
+#, fuzzy
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"WspóÅczynnik skalowy do konwersji jednostek poziomych na jednostki wysokoÅci"
+msgstr "Mnożnik do konwersji jednostek wysokoÅci na metry"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
@@ -28608,7 +28625,7 @@
-msgstr "Importuje tabele atrybutów w różnych formatach."
+msgstr ""
@@ -28629,12 +28646,11 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
#, fuzzy
msgid "Name of aspect raster map"
-msgstr "Nazwa mapy rastrowej"
+msgstr "Nazwa bazoewj mapy rastrowej"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-#, fuzzy
msgid "Width of display canvas"
-msgstr "Tekst który ma byÄ wyÅwietlony"
+msgstr ""
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
#, fuzzy
@@ -28649,28 +28665,30 @@
#, fuzzy
-msgstr "Maksymalna liczba powtórzeÅ"
+msgstr " Maksymalna liczba kolumn: %d"
#, fuzzy
msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:4
+#, fuzzy
msgid "Name of raster angle map"
tów"
+msgstr "Nazwa mapy rastrowej"
#: ../locale/scriptstrings/d.polar_to_translate.c:5
msgid "Pixel value to be interpreted as undefined (different from NULL)"
msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:6
+#, fuzzy
msgid "Name of optional EPS output file"
-msgstr "Nazwa opcjonalnego pliku wyjÅciowego EPS"
+msgstr "Nazwa dla pliku wyjÅciowego SVG"
#: ../locale/scriptstrings/d.polar_to_translate.c:7
msgid "Plot using Xgraph"
@@ -28693,8 +28711,9 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#, fuzzy
msgid "Name of data table"
-msgstr "Nazwa tabeli danych"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
#, fuzzy
@@ -28706,8 +28725,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#, fuzzy
msgid "Database driver"
-msgstr "Sterownik bazy danych"
+msgstr "WyÅwietl listÄ wszystkich sterowników bazy danych"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
#, fuzzy
@@ -31100,3042 +31120,2966 @@
msgstr "Nie można zaznaczyÄ innego punktu. Dozwolone jest tylko %d punktów."
#, fuzzy
-#~ msgid "Not enough room in history file"
-#~ msgstr "Zbyt maÅo przestrzeni w pliku historii."
+msgid "Displays raster map layer in the active map display window."
+msgstr ""
+"WyÅwietla i nakÅada warstwy rastrowe w aktywnej ramce wyÅwietlania na "
+"monitorze wyÅwietlania"
-#~ msgid "New MAPSET name"
-#~ msgstr "Nowa nazwa MAPSETu"
#, fuzzy
-#~ msgid "Your mapset search list:\n"
-#~ msgstr "wypisz parametry bieżÄ
cego poÅÄ
czenia i wyjdź"
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr ""
+"Nazwa i typ nowej kolumny (typy w zależnoÅci od database backend, ale "
+"wszystkie wspierajÄ
-#, fuzzy
-#~ msgid "<%s> not found in mapset list"
-#~ msgstr "Kolumna <%s> nie zostaÅa znaleziona w tabeli <%s>"
+msgstr "Plik rastrowy który ma byÄ przetworzony"
#, fuzzy
-#~ msgid "Name of workspace file"
-#~ msgstr "Nazwa pliku etykiety"
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "Plik ascii zawierajÄ
cy sygnatury widmowe"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr ""
-#~ "WyÅwietla i nakÅada warstwy rastrowe w aktywnej ramce wyÅwietlania na "
-#~ "monitorze wyÅwietlania"
+msgstr "raster, analizy powierzchni terenu"
-#~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr "Lista wartoÅci które majÄ
byÄ wyÅwietlone (mapy FP)"
-#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr ""
-#~ "Ignorowanie listy kategorii: mapa zawiera dane zmiennoprzecinkowe (proszÄ "
-#~ "użyÄ 'val=')"
-#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr ""
-#~ "Ignorowanie listy kategorii; mapa zawiera dane caÅkowite (proszÄ użyÄ "
-#~ "'cat=')"
#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "Nie można otworzyÄ wektorowego pliku wyjÅciowego '%s'"
+msgstr "Nie można otworzyÄ mapy wektorowej [%s]"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Tworzy rastrowe warstwy spadków, ekspozycji, krzywizn i czÄÅciowych "
-#~ "pochodnych z rastrowej mapy rzeczywistych wysokoÅci. Ekspozycja jest "
-#~ "obliczana w kierunku przeciwnym do ruchu wskazówek zegara od wschodu."
-#~ msgid "Raster elevation file name"
-#~ msgstr "Nazwa pliku rastrowego mapy wysokoÅci"
-#~ msgid "Output slope filename"
-#~ msgstr "Nazwa wyjÅciowego pliku spadków"
-#~ msgid "Output aspect filename"
-#~ msgstr "Nazwa wyjÅciowego pliku ekspozycji"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nazwa wyjÅciowego pliku krzywizny profilu"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nazwa wyjÅciowego pliku krzywizny tangensa"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr ""
-#~ "Nazwa wyjÅciowego pliku pochodnej czÄ
stkowej pierwszego rzÄdu dx (spadki "
-#~ "E-W)"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr ""
stkowej pierwszego rzÄdu dy(spadki N-"
-#~ "S)"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Nazwa pliku pochodnej czÄ
stkowej drugiego rzÄdu dxx"
-#~ msgid "Output second order partial derivative dyy filename"
stkowej drugiego rzÄdu dyy"
-#~ msgid "Output second order partial derivative dxy filename"
stkowej drugiego rzÄdu dxy"
-#~ msgid "wrong type: %s"
-#~ msgstr "zÅy typ: %s"
-#~ msgid "Creating support files..."
-#~ msgstr "Tworzenie plików wsparcia..."
#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "Nie można otworzyÄ mapy rastrowej [%s] w [%s]"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "EKSPOZYCJA [%s] UKOÅCZONA"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "SPADEK [%s] UKOÅCZONY"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "KRZYWIZNA PROFILU [%s] UKOÅCZONA"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "KRZYWIZNA TANGENSA [%s] UKOÅCZONA"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "SPADKI E-W [%s] UKOÅCZONE"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "SPADKI N-S [%s] UKOÅCZONE"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] UKOÅCZONA"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] UKOÅCZONA"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] UKOÅCZONA"
#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr ""
-#~ "Nazwa i typ nowej kolumny (typy w zależnoÅci od database backend, ale "
-#~ "wszystkie wspierajÄ
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "mile,metry,kilometry,akry,hektary,liczba komórek, procent pokrycia"
-#~ msgid "Output shaded relief map name"
-#~ msgstr "Nazwa wyjÅciowej mapy cieniowanej rzeźby terenu"
#, fuzzy
-#~ msgid "Layer number of data column"
-#~ msgstr "Warstwa do której ma byÄ dodana kolumna"
+msgid "Print bounds and exit (shell style)"
-#~ msgstr "Plik rastrowy który ma byÄ przetworzony"
#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "Plik ascii zawierajÄ
+msgid "Band to select"
+msgstr "Żaden monitor nie zostaŠwybrany"
#, fuzzy
-#~ msgstr "raster, analizy powierzchni terenu"
+msgid "Estimate spline step value"
+msgstr "Informacje statystyczne dla rastrowych warstw mapy."
#, fuzzy
-#~ msgstr "Nie można otworzyÄ mapy wektorowej [%s]"
+msgid "It was impossible to create <Auxiliar_outlier_table>."
+msgstr "Nie można utworzyÄ <Auxiliar_outlier_table>."
#, fuzzy
+msgstr "<%s> utworzono w bazie danych."
#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "mile,metry,kilometry,akry,hektary,liczba komórek, procent pokrycia"
+msgid "M.Q. solution"
+msgstr "RozdzielczoÅÄ"
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "WyÅwietl ustawienia bieżÄ
+msgid "report"
+msgstr "Import"
-#, fuzzy
-#~ msgid "Band to select"
-#~ msgstr "Żaden monitor nie zostaŠwybrany"
+msgstr "Nie można pobraÄ komórki nagÅówka dla %s"
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Informacje statystyczne dla rastrowych warstw mapy."
+msgid "Unable to open cellfile for <%s>"
+msgstr "Nie można otworzyÄ pliku rastra dla [%s]"
#, fuzzy
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "Nie można utworzyÄ <Auxiliar_outlier_table>."
+msgstr "BÅÄ
d podczas odczytywania [%s]."
#, fuzzy
-#~ msgstr "<%s> utworzono w bazie danych."
+msgstr "BÅÄ
d podczas odczytywania mapy rastrowej <%s>"
#, fuzzy
-#~ msgid "M.Q. solution"
-#~ msgstr "RozdzielczoÅÄ"
+msgstr "Nie można otworzyÄ mapy rastrowej <%s> w <%s>"
-#~ msgid "Import SRTM HGT files into GRASS"
-#~ msgstr "Importuje pliki SRTM HGT do GRASS-a"
#, fuzzy
-#~ msgid "report"
-#~ msgstr "Import"
+msgstr "nie można odczytaÄ regionu <%s> w <%s>"
#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
+msgstr "Nie można otworzyÄ mapy rastrowej <%s>"
-#~ msgstr "Nie można pobraÄ komórki nagÅówka dla %s"
#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "Nie można otworzyÄ pliku rastra dla [%s]"
+msgstr "Nie można otworzyÄ mapy wektorowej <%s>"
-#, fuzzy
-#~ msgstr "BÅÄ
+msgstr "Nie można otworzyÄmapy wyjÅciowej <%s>"
#, fuzzy
-#~ msgstr "BÅÄ
+msgstr "Nie można pobraÄ nagÅówka dla %s"
-#, fuzzy
-#~ msgstr "Nie można otworzyÄ mapy rastrowej <%s> w <%s>"
+msgstr "BÅÄ
d podczas odczytu rzÄdu %d danych"
#, fuzzy
-#~ msgstr "nie można odczytaÄ regionu <%s> w <%s>"
+msgid "Cannot set region to output region"
+msgstr "Nie można ustawiÄ regionu z powrotem do regionu poczÄ
tkowego !!!"
#, fuzzy
-#~ msgstr "Nie można otworzyÄ mapy rastrowej <%s>"
+msgid "Cannot set region to back to the initial region"
tkowego !!!"
-#, fuzzy
-#~ msgstr "Nie można otworzyÄ mapy wektorowej <%s>"
+msgstr "Nie możn odczytaÄ wiersza %d"
-#~ msgstr "Nie można otworzyÄmapy wyjÅciowej <%s>"
#, fuzzy
-#~ msgstr "Nie można pobraÄ nagÅówka dla %s"
+msgstr "Nie można wstawiÄ wiersza: %s"
-#~ msgstr "BÅÄ
#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "Nie można ustawiÄ regionu z powrotem do regionu poczÄ
tkowego !!!"
+msgstr "nie można otworzyÄ warstwy mapy wysokoÅci"
#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
tkowego !!!"
+msgstr "Zapiywanie %s ..."
-#~ msgstr "Nie możn odczytaÄ wiersza %d"
+msgstr "BÅÄ
d podczas odczytu rzÄdu <%d>"
#, fuzzy
-#~ msgstr "Nie można wstawiÄ wiersza: %s"
+msgid "Name of input raster map containing starting points"
+msgstr "Mapa rastrowa zawierajÄ
ca wartoÅci użyte dla dÅugoÅci strzaÅek"
-#, fuzzy
-#~ msgstr "nie można otworzyÄ warstwy mapy wysokoÅci"
+msgstr "Nie mozna otworzyÄmapy wejÅciowej <%s>"
-#, fuzzy
-#~ msgstr "Zapiywanie %s ..."
+msgstr "BÅÄ
-#~ msgstr "BÅÄ
#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Mapa rastrowa zawierajÄ
+msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "Nie mozna otworzyÄmapy wejÅciowej <%s>"
-#~ msgstr "BÅÄ
#, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
+msgid "Pass %d:"
+msgstr "2-przebiegowy"
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "2-przebiegowy"
+msgid "Unable to open table <%s_edge_Interpolation>"
+msgstr "Nie można skopiowaÄ tabeli <%s>"
#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Nie można skopiowaÄ tabeli <%s>"
+msgid "Name of output vector area map"
+msgstr "Nazwa wejÅciowego pliku wektorowego"
#, fuzzy
-#~ msgid "Name of output vector area map"
-#~ msgstr "Nazwa wejÅciowego pliku wektorowego"
+msgid "Cannot open vector map <%s>"
+msgstr "Nie mogÄ znaleÅºÄ mapsetu dla %s"
#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "Nie mogÄ znaleÅºÄ mapsetu dla %s"
+msgstr "Nie można odczytaÄ rzÄdu rastra %d"
#, fuzzy
-#~ msgstr "Nie można odczytaÄ rzÄdu rastra %d"
+msgstr "Nie można zapisaÄ wiersza %d mapy rastrowej"
#, fuzzy
-#~ msgstr "Nie można zapisaÄ wiersza %d mapy rastrowej"
+msgstr "Z mapy rastrowej <%s> nie można przeczytaÄ wiersza %d"
#, fuzzy
-#~ msgstr "Z mapy rastrowej <%s> nie można przeczytaÄ wiersza %d"
+msgstr "Nie można przeczytaÄ nagÅówka mapy rastrowej <%s>"
#, fuzzy
-#~ msgstr "Nie można przeczytaÄ nagÅówka mapy rastrowej <%s>"
+msgstr "Nie można zapisaÄ mapy rastrowej"
#, fuzzy
-#~ msgstr "Nie można zapisaÄ mapy rastrowej"
#, fuzzy
#, fuzzy
+msgstr "Nie można otworzyÄ pliku rastra [%s]"
-#, fuzzy
-#~ msgstr "Nie można otworzyÄ pliku rastra [%s]"
+msgstr "Nie można odczytaÄ nagÅówka pliku [%s])"
-#~ msgstr "Nie można odczytaÄ nagÅówka pliku [%s])"
+msgstr "Nie można otworzyÄ <%s>"
-#~ msgstr "Nie można otworzyÄ <%s>"
+msgstr "Nie można zapisaÄ do wyjÅciowej mapy rastrowej"
-#~ msgstr "Nie można zapisaÄ do wyjÅciowej mapy rastrowej"
#, fuzzy
#, fuzzy
-#~ msgid "Configuration editor for r.li.'index'"
-#~ msgstr "Plik wyjÅciowy kluczowej klatki"
+msgid "qcname"
+msgstr "nazwa"
-#~ msgid "vector, import, gazetteer"
-#~ msgstr "wektor, import, indeks nazw geograficznych"
+msgid "Name of QC"
+msgstr "Nazwa QC"
-#~ msgid "vector, centroid, area"
-#~ msgstr "wektor, centroid, obszar"
-#~ msgid "raster, elevation, interpolation"
-#~ msgstr "raster, elewacja, interpolacja"
#, fuzzy
-#~ msgid "miscellaneous, projection"
-#~ msgstr "Mapa ma inne odwzorowanie"
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Liczba klatek"
-#~ msgid "vector, report, statistics"
-#~ msgstr "wektor, raport, statystyki"
+msgstr "Nie można odczytaÄ nagÅówka pliku [%s]"
#, fuzzy
-#~ msgid "vector, color table"
-#~ msgstr "raster do usuniÄcia"
+msgid "Spline type of interpolation"
+msgstr "Wynik jest bÅÄdem interpolacji"
-#~ msgid "raster, statistics, aggregation"
-#~ msgstr "raster, statystyki, agregacja"
+msgid "Use db.select for SELECT SQL statements"
+msgstr "Użyj db.select w wyrażeniu SELECT SQL"
-#~ msgid "vector, export, GPS"
-#~ msgstr "vector, export, GPS"
+msgid "Output drain raster map"
+msgstr "WyjÅciowa mapa rastrowa drenażu"
#, fuzzy
-#~ msgid "raster, imagery, mosaicking"
-#~ msgstr "raster, zobrazowanie, import"
+msgstr "raster, gleba, erozja, USLE"
-#~ msgid "vector, import, GPS"
-#~ msgstr "wektor, import, GPS"
+msgid "Reading %s"
+msgstr "Odczytywanie %s"
#, fuzzy
-#~ msgid "Import waypoints"
-#~ msgstr "Import "
+msgid "can't open raster map [%s] needed for input coordinates"
+msgstr "Nie można otworzyÄ mapy rastrowej [%s] w [%s]"
-#, fuzzy
-#~ msgid "Import routes"
-#~ msgstr "Import"
+msgid "Can't find %d,%d:%f"
+msgstr "Nie mozna odnaleÅºÄ %d,%d:%f"
#, fuzzy
-#~ msgid "Import track"
-#~ msgstr "Import"
+msgid "Nothing to show"
+msgstr "Nic nie znaleziono.\n"
#, fuzzy
-#~ msgid "Device or file used to import data"
-#~ msgstr "urzÄ
dzenie lub plik uzyty do importu danych"
+msgstr "raster, ponowne próbkowanie"
-#, fuzzy
-#~ msgid "imagery, fusion, Brovey"
-#~ msgstr "grupa obrazów"
+msgid "Unable to open MASK"
+msgstr "nie można otworzyÄ maski"
-#~ msgid "vector, raster, statistics"
-#~ msgstr "wektor, raster, statystyki"
+msgid "unable to open MASK"
-#~ msgid "raster, imagery, import"
#, fuzzy
-#~ msgid "raster, imagery, colors"
+msgid "raster, random, surface"
+msgstr "Plik rastra dla powierzchni"
-#~ msgid "raster, imagery"
-#~ msgstr "raster, zobrazowanie"
-#~ msgid "raster, mask"
-#~ msgstr "raster, maska"
-#~ msgid "vector, area, dissolve"
-#~ msgstr "wektor, obszar, rozÅÄ
czanie"
#, fuzzy
-#~ msgid "sites, vector, import"
-#~ msgstr "sites, wektor, import"
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in a local text file. Alternatively, "
+"a local time can be specified to compute solar incidence angle and/or "
+"irradiance raster maps. The shadowing effect of the topography is optionally "
+"incorporated."
+msgstr ""
+"Oblicza mapy rastrowe bezpoÅredniego, rozproszonego i odbitego "
+"napromienienia sÅonecznego dla danego dnia, szerokoÅci geogr., powierzchni i "
+"warunków atmosferycznych.Parametry sÅoneczne (np. czas wschodu i zachodu, "
+"deklinacja, napromieniowanie pozaziemskie, dÅugoÅÄ dnia) sÄ
zapisane w pliku "
+"historii mapy. Alternatywnie do obliczenia kÄ
ta padania promieni sÅonecznych "
+"i/lub napromieniowania może byÄ użyty czas lokalny. Opcjonalnie wÅÄ
czony "
+"jest efekt cieniowania topografii."
#, fuzzy
-#~ msgid "raster, imagery, statistics"
-#~ msgstr "raster, statystyki"
+msgid "incidout requres time parameter to be set"
+msgstr "'incidout' wymaga ustawienia parametru czasu"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "nazwa"
+msgid "Mode 2: integrated daily irradiation"
+msgstr "Tryb 2: zintegrowane dzienne napromienienie dla danego dnia roku"
-#~ msgstr "Nazwa QC"
#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Liczba klatek"
+msgid "Output more comments (default=quiet)"
+msgstr "WyjÅciowa mapa rastrowa (domyÅlnie: input tile)"
-#~ msgstr "Nie można odczytaÄ nagÅówka pliku [%s]"
+msgid "Cannot open database %s by driver %s"
+msgstr "Nie można otworzyÄ bazy danych %s przez sterownik %s"
#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "Wynik jest bÅÄdem interpolacji"
+msgid "Cannot select attributes: %s"
+msgstr "Nir można wybraÄ atrybutów dla pola #%d"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "Użyj db.select w wyrażeniu SELECT SQL"
+msgid ""
+"Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr "Kolor tÅa, standardowe kolory GRASS, triplet R:G:B lub \"none\""
-#~ msgid "Output drain raster map"
-#~ msgstr "WyjÅciowa mapa rastrowa drenażu"
#, fuzzy
-#~ msgstr "raster, gleba, erozja, USLE"
+msgid "Output inverse raster map after IFFT"
+msgstr "wyjÅciowy plik rastra odwróconego po ifft"
-#~ msgid "Reading %s"
-#~ msgstr "Odczytywanie %s"
#, fuzzy
-#~ msgid "can't open raster map [%s] needed for input coordinates"
+msgstr "%s: %s - Nie można odnaleÅºÄ rzeczywistego obrazu."
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "Nie mozna odnaleÅºÄ %d,%d:%f"
#, fuzzy
-#~ msgid "Nothing to show"
-#~ msgstr "Nic nie znaleziono.\n"
+msgid ""
+msgstr ""
+"Nie można otworzyÄ rzeczywistego obrazu w katalogu 'cell_misc'.\n"
+"WejÅciowa mapa prawdopodobnie nie zostaÅa stworzona przez i.fft"
#, fuzzy
-#~ msgstr "raster, ponowne próbkowanie"
+msgstr "%s: %s - Nie można znaleÅºÄ urojonego obrazu."
-#~ msgid "Unable to open MASK"
-#~ msgstr "nie można otworzyÄ maski"
-#~ msgid "unable to open MASK"
#, fuzzy
-#~ msgid "raster, random, surface"
-#~ msgstr "Plik rastra dla powierzchni"
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"Nie można otworzyÄ urojonego obrazu w katalogu 'cell_misc.\n"
+"Mapa wejÅciowa prawdopodobnie nie zostaÅa utworzona przy pomocy i.fft"
-#, fuzzy
-#~ msgid ""
-#~ "Computes direct (beam), diffuse and reflected solar irradiation raster "
-#~ "maps for given day, latitude, surface and atmospheric conditions. Solar "
-#~ "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-#~ "irradiance, daylight length) are saved in a local text file. "
-#~ "Alternatively, a local time can be specified to compute solar incidence "
-#~ "angle and/or irradiance raster maps. The shadowing effect of the "
-#~ "topography is optionally incorporated."
-#~ msgstr ""
-#~ "Oblicza mapy rastrowe bezpoÅredniego, rozproszonego i odbitego "
-#~ "napromienienia sÅonecznego dla danego dnia, szerokoÅci geogr., "
-#~ "powierzchni i warunków atmosferycznych.Parametry sÅoneczne (np. czas "
-#~ "wschodu i zachodu, deklinacja, napromieniowanie pozaziemskie, dÅugoÅÄ "
-#~ "dnia) sÄ
zapisane w pliku historii mapy. Alternatywnie do obliczenia kÄ
ta "
-#~ "padania promieni sÅonecznych i/lub napromieniowania może byÄ użyty czas "
-#~ "lokalny. Opcjonalnie wÅÄ
czony jest efekt cieniowania topografii."
+msgid "Power 2 values : [%d] rows [%d] columns."
+msgstr "PotÄga 2 wartoÅci : [%d] rzÄdy [%d] kolumny."
-#, fuzzy
-#~ msgid "incidout requres time parameter to be set"
-#~ msgstr "'incidout' wymaga ustawienia parametru czasu"
+msgid "Reading the raster maps..."
+msgstr "Odczytywanie map rastrowych..."
-#, fuzzy
-#~ msgid "Mode 2: integrated daily irradiation"
-#~ msgstr "Tryb 2: zintegrowane dzienne napromienienie dla danego dnia roku"
+msgid "Rotating data arrays..."
+msgstr "Obracanie porzÄ
dku danych..."
-#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "WyjÅciowa mapa rastrowa (domyÅlnie: input tile)"
+msgid "Inverse FFT completed..."
+msgstr "Transformacja Inverse FFT zakoÅczona..."
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Nie można otworzyÄ bazy danych %s przez sterownik %s"
+msgid "Unable to open output file."
+msgstr "Nie można otworzyÄ pliku wyjÅciowego."
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "Nir można wybraÄ atrybutów dla pola #%d"
+msgid "Transform successful."
+msgstr "Transformacja zakoÅczona z sukcesem."
-#~ msgid ""
-#~ "Background color, either a standard GRASS color, R:G:B triplet, or \"none"
-#~ msgstr "Kolor tÅa, standardowe kolory GRASS, triplet R:G:B lub \"none\""
+msgid ""
+"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
+"transformation function."
+msgstr ""
+"Funkcja transformacji kolorów mapy hue-intensity-saturation(his) do red."
+"green-blue(rgb) "
#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "wyjÅciowy plik rastra odwróconego po ifft"
+msgid "Intensity map name"
#, fuzzy
-#~ msgstr "%s: %s - Nie można odnaleÅºÄ rzeczywistego obrazu."
+msgid "Saturation map name"
#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "Nie można otworzyÄ rzeczywistego obrazu w katalogu 'cell_misc'.\n"
-#~ "WejÅciowa mapa prawdopodobnie nie zostaÅa stworzona przez i.fft"
+msgid "Output map representing the red"
+msgstr "Mapa wyjÅciowa posiada komórki rastra o wartoÅciach caÅkowitych"
#, fuzzy
-#~ msgstr "%s: %s - Nie można znaleÅºÄ urojonego obrazu."
+msgid "Output map representing the green"
#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "Nie można otworzyÄ urojonego obrazu w katalogu 'cell_misc.\n"
-#~ "Mapa wejÅciowa prawdopodobnie nie zostaÅa utworzona przy pomocy i.fft"
+msgid "Output map representing the blue"
+msgstr "ciÄ
g znaków reprezentujÄ
cy wartoÅci rastra 'no data'"
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "PotÄga 2 wartoÅci : [%d] rzÄdy [%d] kolumny."
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Odczytywanie map rastrowych..."
-#~ msgid "Rotating data arrays..."
-#~ msgstr "Obracanie porzÄ
dku danych..."
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "Transformacja Inverse FFT zakoÅczona..."
-#~ msgid "Unable to open output file."
-#~ msgstr "Nie można otworzyÄ pliku wyjÅciowego."
-#~ msgid "Transform successful."
-#~ msgstr "Transformacja zakoÅczona z sukcesem."
-#~ msgid ""
-#~ "Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
-#~ "transformation function."
-#~ msgstr ""
-#~ "Funkcja transformacji kolorów mapy hue-intensity-saturation(his) do red."
-#~ "green-blue(rgb) "
#, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "Nazwa mapy rastrowej"
+msgid "Cannot read row from raster map"
+msgstr "Nie można pobraÄ rzÄdu %d z mapy rastrowej %s"
#, fuzzy
-#~ msgid "Saturation map name"
+msgid "Cannot write row to raster map"
+msgstr "Nie można otworzyÄ mapy rastrowej [%s]."
-#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "Mapa wyjÅciowa posiada komórki rastra o wartoÅciach caÅkowitych"
+msgid ""
+"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
+"transformation function"
+msgstr ""
+"Funkcja transformacji kolorów mapy red.green-blue(rgb) do hue-intensity-"
+"saturation(his) "
#, fuzzy
-#~ msgid "Output map representing the green"
+msgid "Green input raster map"
+msgstr "WejÅciowa mapa rastrowa"
#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "ciÄ
+msgid "Blue input raster map"
#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Nie można pobraÄ rzÄdu %d z mapy rastrowej %s"
+msgid "Output intensity raster map"
#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#~ msgstr "Nie można otworzyÄ mapy rastrowej [%s]."
+msgid "Output saturation raster map"
-#~ msgid ""
-#~ "Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
-#~ "transformation function"
-#~ msgstr ""
-#~ "Funkcja transformacji kolorów mapy red.green-blue(rgb) do hue-intensity-"
-#~ "saturation(his) "
+msgid ""
+"\n"
+"Resolution = %d; period = %d"
+msgstr ""
+"\n"
+"RozdzielczoÅÄ = %d; okres = %d"
-#, fuzzy
-#~ msgid "Green input raster map"
-#~ msgstr "WejÅciowa mapa rastrowa"
+msgid "Class transition statistics."
+msgstr "Statystyki przejÅcia (przeniesienia) klas."
-#, fuzzy
-#~ msgid "Blue input raster map"
+msgid "Transition probabilities: %f %f %f; %f"
+msgstr "PrawdopodobieÅstwo przejÅcia: %f %f %f; %f"
-#, fuzzy
-#~ msgid "Output intensity raster map"
+msgid "get_img: out of memory."
+msgstr "get_img: zbyt maÅo pamiÄci."
#, fuzzy
-#~ msgid "Output saturation raster map"
+msgid "Subgroup [%s] in group [%s] contains no files."
+msgstr "Podgrupa [%s] w grupie [%s] nie zawiera żadnych plików."
-#~ msgid ""
-#~ "\n"
-#~ "Resolution = %d; period = %d"
-#~ msgstr ""
-#~ "\n"
-#~ "RozdzielczoÅÄ = %d; okres = %d"
+msgid "Writing [%s] ..."
+msgstr "Zapiywanie [%s] ..."
-#~ msgid "Class transition statistics."
-#~ msgstr "Statystyki przejÅcia (przeniesienia) klas."
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "PrawdopodobieÅstwo przejÅcia: %f %f %f; %f"
-#~ msgid "get_img: out of memory."
-#~ msgstr "get_img: zbyt maÅo pamiÄci."
#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "Podgrupa [%s] w grupie [%s] nie zawiera żadnych plików."
+msgid "Name of imagery signaturefile"
+msgstr "plik sygnatur obrazu"
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Zapiywanie [%s] ..."
+msgid "Group [%s] not found."
+msgstr "Grupy [%s] nie znaleziono."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "plik sygnatur obrazu"
+msgid "Subgroup [%s] not found."
+msgstr "Podgrupy [%s] nie znaleziono."
-#~ msgid "Group [%s] not found."
-#~ msgstr "Grupy [%s] nie znaleziono."
+msgid "Signature file [%s] is missing or not readable."
+msgstr "Plik sygnatur [%s] nie istnieje lub jest nieczytelny."
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Podgrupy [%s] nie znaleziono."
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "Plik sygnatur [%s] nie istnieje lub jest nieczytelny."
#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "Obliczanie Åredniej klasy ..."
+msgid "Calculating eigenvalues and eigenvectors..."
+msgstr "Obliczanie Åredniej klasy ..."
#, fuzzy
-#~ msgid "Ordering eigenvalues in descending order..."
+msgid "Ordering eigenvalues in descending order..."
#, fuzzy
-#~ msgid "Transposing eigen matrix..."
dku danych..."
+msgid "Transposing eigen matrix..."
dku danych..."
#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
+msgid "Cannot write color table of raster map <%s>"
-#~ msgid "Calculating class mean ..."
+msgid "Calculating class mean ..."
-#~ msgid "Calculating class covariance matrix..."
-#~ msgstr "Obliczanie sieci kowariancji klas"
+msgid "Calculating class covariance matrix..."
+msgstr "Obliczanie sieci kowariancji klas"
#, fuzzy
-#~ msgid "Imagery group"
+msgid "Imagery group"
+msgstr "grupa obrazów"
#, fuzzy
-#~ msgid "Subgroup containing image files"
-#~ msgstr "podgrupa zawierajÄ
ca pliki obrazów"
+msgid "Subgroup containing image files"
+msgstr "podgrupa zawierajÄ
ca pliki obrazów"
#, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "wynikowy plik sygnatury"
+msgid "Resultant signature file"
+msgstr "wynikowy plik sygnatury"
-#~ msgid "%d classes."
-#~ msgstr "%d klasy."
+msgid "%d classes."
+msgstr "%d klasy."
-#~ msgid ""
-#~ "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-#~ msgstr ""
-#~ "Nie można utworzyÄ pliku sygnatury [%s] dla podgrupy [%s] w grupie [%s]."
+msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
+msgstr ""
+"Nie można utworzyÄ pliku sygnatury [%s] dla podgrupy [%s] w grupie [%s]."
#, fuzzy
-#~ msgid "Input raster map being fft"
-#~ msgstr "wprowadź nazwÄ pliku rastrowego poddawanego fft"
+msgid "Input raster map being fft"
+msgstr "wprowadź nazwÄ pliku rastrowego poddawanego fft"
#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "PrzedziaŠmniejszy lub równy zero niedozwolony."
+msgid "Range less than or equal to zero not allowed."
+msgstr "PrzedziaŠmniejszy lub równy zero niedozwolony."
-#~ msgid "Initializing data...\n"
-#~ msgstr "Inicjalizacja danych...\n"
+msgid "Initializing data...\n"
+msgstr "Inicjalizacja danych...\n"
-#~ msgid "Reading the raster map..."
-#~ msgstr "Odczytywanie mapy rastrowej..."
+msgid "Reading the raster map..."
+msgstr "Odczytywanie mapy rastrowej..."
-#~ msgid "FFT completed..."
-#~ msgstr "FFT zakoÅczona..."
+msgid "FFT completed..."
+msgstr "FFT zakoÅczona..."
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "Zapisywanie podgÅÄ
du przetransformowanych danych do pliku..."
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "Zapisywanie podgÅÄ
#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "Nie można otworzyÄ pliku w katalogu cell_misc."
+msgid "Unable to open file in the cell_misc directory."
+msgstr "Nie można otworzyÄ pliku w katalogu cell_misc."
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ "grupy <%s> nie znaleziono"
+msgid ""
+"\n"
+" group <%s> not found"
+msgstr ""
+"\n"
+"grupy <%s> nie znaleziono"
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "podgrupy <%s> nie znaleziono"
+msgid "subgroup <%s> not found"
+msgstr "podgrupy <%s> nie znaleziono"
#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "Podgrupa [%s] nie zawiera żadnych plików."
+msgid "Subgroup [%s] doesn't have any files"
+msgstr "Podgrupa [%s] nie zawiera żadnych plików."
#, fuzzy
-#~ msgid "The subgroup must have at least 2 files to run %s"
-#~ msgstr ""
-#~ "Podgrupa musi zawieraÄ przynajmniej 2 pliki aby można byÅo uruchomiÄ %s."
+msgid "The subgroup must have at least 2 files to run %s"
+msgstr ""
+"Podgrupa musi zawieraÄ przynajmniej 2 pliki aby można byÅo uruchomiÄ %s."
-#~ msgid "Unable to proceed"
-#~ msgstr "Nie można kontynuowaÄ"
+msgid "Unable to proceed"
+msgstr "Nie można kontynuowaÄ"
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "** Nie można otworzyÄ pliku sygnatury 'seed' <%s> **"
+msgid "Can't open seed signature file <%s>"
+msgstr "** Nie można otworzyÄ pliku sygnatury 'seed' <%s> **"
#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "Nie mogÄ odczytaÄ pliku sygnatury [%s]."
+msgid "Can't read signature file <%s>"
+msgstr "Nie mogÄ odczytaÄ pliku sygnatury [%s]."
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "Grupa plików obrazów do utworzenia klastrów"
+msgid "Group of imagery files to be clustered"
+msgstr "Grupa plików obrazów do utworzenia klastrów"
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "Nazwa podgrupy w powyższej grupie"
+msgid "Subgroup name in the above group"
+msgstr "Nazwa podgrupy w powyższej grupie"
#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "Plik zawiera poczÄ
tkowe sygnatury"
+msgid "File containing initial signatures"
+msgstr "Plik zawiera poczÄ
tkowe sygnatury"
#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "Nazwa wyjÅciowego pliku zawierajÄ
cego raport koÅcowy"
+msgid "Output file to contain final report"
+msgstr "Nazwa wyjÅciowego pliku zawierajÄ
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- niewÅaÅciwa wartoÅÄ min_size"
+msgid ""
+"\n"
+"<%s> -- illegal value of min_size"
+msgstr ""
+"\n"
+"<%s> -- niewÅaÅciwa wartoÅÄ min_size"
-#~ msgid "Can't creat reportfile: "
-#~ msgstr "Nie można utworyÄ pliku raportu: "
+msgid "Can't creat reportfile: "
+msgstr "Nie można utworyÄ pliku raportu: "
-#~ msgid "Reading image ... "
-#~ msgstr "Odczytywanie obrazu ..."
+msgid "Reading image ... "
+msgstr "Odczytywanie obrazu ..."
#, fuzzy
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr ""
-#~ "Nazwa obrazu który ma byÄ rektyfikowany który bÄdzie poczÄ
tkowo "
-#~ "wyÅwietlony na monitorze."
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr ""
+"Nazwa obrazu który ma byÄ rektyfikowany który bÄdzie poczÄ
tkowo wyÅwietlony "
+"na monitorze."
#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr ""
-#~ "Nazwa mapy z docelowego mapsetu która bÄdzie poczÄ
tkowo wyÅwietlona na "
-#~ "monitorze."
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr ""
+"Nazwa mapy z docelowego mapsetu która bÄdzie poczÄ
+"monitorze."
-#~ msgid "Unable to read head of %s"
-#~ msgstr "Nie mozna odczytaÄ nagÅówka pliku %s"
+msgid "Unable to read head of %s"
+msgstr "Nie mozna odczytaÄ nagÅówka pliku %s"
-#~ msgid "group=[%s] - not found."
-#~ msgstr "grupy=[%s] - nie znaleziono."
+msgid "group=[%s] - not found."
+msgstr "grupy=[%s] - nie znaleziono."
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "podgrupy=[%s] (grupy [%s]) - nie znaleziono."
+msgid "subgroup=[%s] (of group [%s]) - not found."
+msgstr "podgrupy=[%s] (grupy [%s]) - nie znaleziono."
-#~ msgid "Can't read signature file [%s]."
+msgid "Can't read signature file [%s]."
-#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "[%s] posiada wiÄcej niż 255 sygnatur."
+msgid "[%s] has more than 255 signatures."
+msgstr "[%s] posiada wiÄcej niż 255 sygnatur."
-#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "Nie można utworzyÄ warstwy wartoÅci odrzuconych [%s]."
+msgid "Unable to create reject layer [%s]."
+msgstr "Nie można utworzyÄ warstwy wartoÅci odrzuconych [%s]."
-#~ msgid "Imagery group to be classified"
-#~ msgstr "Grupa obrazów do klasyfikacji"
+msgid "Imagery group to be classified"
+msgstr "Grupa obrazów do klasyfikacji"
-#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "Podgrupa zawierajÄ
ca pliki obrazów do klasyfikacji"
+msgid "Subgroup containing image files to be classified"
+msgstr "Podgrupa zawierajÄ
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Sygnatury które majÄ
byÄ użyte do klasyfikacji"
+msgid "Signatures to use for classification"
+msgstr "Sygnatury które majÄ
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "Mapa rastrowa do przechowywania wyników klasyfikacji"
+msgid "Raster map to hold classification results"
+msgstr "Mapa rastrowa do przechowywania wyników klasyfikacji"
#, fuzzy
-#~ msgid "raster, imagery, fusion"
+msgid "raster, imagery, fusion"
+msgstr "raster, zobrazowanie, import"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "sensor: LANDSAT"
+msgid "sensor: LANDSAT"
+msgstr "sensor: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "sensor: QuickBird"
+msgid "sensor: QuickBird"
+msgstr "sensor: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "sensor: SPOT"
+msgid "sensor: SPOT"
+msgstr "sensor: SPOT"
-#, fuzzy
-#~ msgid "GIS manager for GRASS"
-#~ msgstr "wyÅwitl strony podrÄcznika GRASS w HTML"
+msgid "ERROR: Problem opening output file."
+msgstr "BÅÄ
d: Nie można otworzyÄ pliku wyjÅciowego <%s>."
-#, fuzzy
-#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Nazwa istniejÄ
cego pliku MAT-File(v4)"
+msgid "Name of fractal surface raster layer"
+msgstr "Nazwa warstwy rastrowej powierzchni fraktalnej"
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "BÅÄ
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "Nazwa warstwy rastrowej powierzchni fraktalnej"
#, fuzzy
-#~ msgid "Name of the sampling locations vector points map"
-#~ msgstr "nazwa wejÅciowego pliku wektorowego"
+msgid "Name of the sampling locations vector points map"
#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nazwa pliku wyjÅciowego"
+msgid "Density of output walkers"
+msgstr "Nazwa pliku wyjÅciowego"
#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "%s plik [%s] nie zostaÅ znaleziony!"
+msgid "File [%s] not found"
+msgstr "%s plik [%s] nie zostaÅ znaleziony!"
-#~ msgid "Unable to open file [%s]"
-#~ msgstr "Nie można otworzyÄ pliku [%s]"
+msgid "Unable to open file [%s]"
+msgstr "Nie można otworzyÄ pliku [%s]"
#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
+msgid "Reading sites map (%s) ..."
#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
+msgid "Name of the output walkers vector points map"
#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
+msgid "You are not outputting any raster or vector points maps"
#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "%s: %s - niewÅaÅciwa nazwa"
+msgid "%s=%s - illegal value"
+msgstr "%s: %s - niewÅaÅciwa nazwa"
#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "Nie można wczytaÄ bieżÄ
cych parametrów regionu"
+msgid "Unable to read current region parameters"
+msgstr "Nie można wczytaÄ bieżÄ
-#~ msgid "Cannot open cover raster map <%s>"
+msgid "Cannot open cover raster map <%s>"
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Bazy danych <%s> nie można otworzyÄ sterownikiem <%s>"
+msgid "Cannot open database <%s> by driver <%s>"
+msgstr "Bazy danych <%s> nie można otworzyÄ sterownikiem <%s>"
-#~ msgid "No map specified"
-#~ msgstr "Nie okreÅlono żadnej mapy"
+msgid "No map specified"
+msgstr "Nie okreÅlono żadnej mapy"
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "%s - nie można usunÄ
Ä palety kolorów"
+msgid "%s - unable to remove color table"
+msgstr "%s - nie można usunÄ
Ä palety kolorów"
#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "mapa %s nie zostaÅa znaleziona"
+msgid "%s - color table not found"
+msgstr "mapa %s nie zostaÅa znaleziona"
#, fuzzy
-#~ msgid "Can't make random color table for floating point map"
-#~ msgstr ""
-#~ "Nie można utworzyÄ palety logarytmicznej kolorów dla mapy z danymi "
-#~ "zmiennoprzecinkowymi"
+msgid "Can't make random color table for floating point map"
+msgstr ""
+"Nie można utworzyÄ palety logarytmicznej kolorów dla mapy z danymi "
+"zmiennoprzecinkowymi"
#, fuzzy
-#~ msgid "Can't make grey.eq color table for floating point map"
-#~ msgstr ""
+msgid "Can't make grey.eq color table for floating point map"
+msgstr ""
-#~ msgid "Can't make logarithmic color table for floating point map"
-#~ msgstr ""
+msgid "Can't make logarithmic color table for floating point map"
+msgstr ""
#, fuzzy
-#~ msgid "%s - unknown color request"
-#~ msgstr "%s - kolor nieznany\n"
+msgid "%s - unknown color request"
+msgstr "%s - kolor nieznany\n"
#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "nie można zamknÄ
Ä mapy wejÅciowej"
+msgid "Unable to properly read input raster map"
+msgstr "nie można zamknÄ
Ä mapy wejÅciowej"
#, fuzzy
-#~ msgid "Unable to properly write output raster map"
Ä mapy wejÅciowej"
+msgid "Unable to properly write output raster map"
Ä mapy wejÅciowej"
#, fuzzy
-#~ msgid "Could not read range file"
-#~ msgstr "nie można odczytaÄ pliku zakresu rozpiÄtoÅci danych"
+msgid "Could not read range file"
+msgstr "nie można odczytaÄ pliku zakresu rozpiÄtoÅci danych"
#, fuzzy
-#~ msgid "Reading data: "
-#~ msgstr "Wczytywanie danych..."
+msgid "Reading data: "
+msgstr "Wczytywanie danych..."
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "Nazwa warstwy mapy rastrowej która ma byÄ użyta dla <%s>"
+msgid "Name of raster map layer to be used for <%s>"
+msgstr "Nazwa warstwy mapy rastrowej która ma byÄ użyta dla <%s>"
#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "Mapa wektorowa punktów koÅcowych"
+msgid "%d points converted to centroids"
+msgstr "Mapa wektorowa punktów koÅcowych"
#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "Nadpisz plik mapy wyjÅciowej"
+msgid "%d centroids converted to points"
#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%s plik(i) do usuniÄcia"
+msgid "%d lines converted to boundaries"
+msgstr "%s plik(i) do usuniÄcia"
#, fuzzy
-#~ msgid "%d boundaries converted to lines"
+msgid "%d boundaries converted to lines"
#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
cego regionu"
+msgid "CrossCorrelation: %d points read in region.\n"
+msgstr "WyÅwietl ustawienia bieżÄ
cego regionu"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "Nie można odczytaÄ pola info"
+msgid "CrossCorrelation: Cannot read field info"
+msgstr "Nie można odczytaÄ pola info"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Ten typ kolumny nie jest obÅugiwany"
+msgid "CrossCorrelation: Column type not supported"
+msgstr "Ten typ kolumny nie jest obÅugiwany"
#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Nie można zaznaczyÄ danych z tabeli"
+msgid "CrossCorrelation: Cannot select data from table"
+msgstr "Nie można zaznaczyÄ danych z tabeli"
#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
+msgid "CrossCorrelation: %d records selected from table"
#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Brak rekordu dla cat = %d"
+msgid "CrossCorrelation: No record for point (cat = %d)"
+msgstr "Brak rekordu dla cat = %d"
#, fuzzy
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
+msgid "CrossCorrelation: Mean = %.5lf\n"
#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
+msgid "CrossCorrelation: lambda_i = %.3f\n"
#, fuzzy
-#~ msgid "From type"
-#~ msgstr "Do typu"
+msgid "From type"
+msgstr "Do typu"
-#~ msgid "From layer"
-#~ msgstr "Z warstwy"
+msgid "From layer"
+msgstr "Z warstwy"
#, fuzzy
-#~ msgid "The column must be type integer or string"
-#~ msgstr "Nazwa kolumny (musi to byÄ typ numeryczny)"
+msgid "The column must be type integer or string"
+msgstr "Nazwa kolumny (musi to byÄ typ numeryczny)"
#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "typ pliku"
+msgid "Select type"
+msgstr "typ pliku"
#, fuzzy
-#~ msgid "Cannot select records from database"
+msgid "Cannot select records from database"
#, fuzzy
-#~ msgid "Cannot fetch data"
+msgid "Cannot fetch data"
#, fuzzy
-#~ msgid "Calculating costs from centres..."
-#~ msgstr "Obliczanie Åredniej klas ..."
+msgid "Calculating costs from centres..."
+msgstr "Obliczanie Åredniej klas ..."
#, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgstr "Typ obiektu"
+msgid "Feature id(s)"
+msgstr "Typ obiektu"
#, fuzzy
-#~ msgid "Input vector was not found."
-#~ msgstr "Nie znaleziono mapy wektorowej <%s>"
+msgid "Input vector was not found."
+msgstr "Nie znaleziono mapy wektorowej <%s>"
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "Nie można otworzyÄ pliku dig_cats."
+msgid "Cannot open dig_cats file."
+msgstr "Nie można otworzyÄ pliku dig_cats."
-#~ msgid "Cannot open database %s"
-#~ msgstr "Nie można otworzyÄ bazy danych %s"
+msgid "Cannot open database %s"
+msgstr "Nie można otworzyÄ bazy danych %s"
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "Nie można wstawiÄ do tabeli: %s"
+msgid "Cannot insert into table: %s"
+msgstr "Nie można wstawiÄ do tabeli: %s"
-#~ msgid "Removed vertices: %5d"
-#~ msgstr "UsuniÄtych wierzchoÅków: %5d"
+msgid "Removed vertices: %5d"
+msgstr "UsuniÄtych wierzchoÅków: %5d"
#, fuzzy
-#~ msgid "Removed vertices"
+msgid "Removed vertices"
#, fuzzy
-#~ msgid "Arc layer (network)"
-#~ msgstr "Warstwa zapytania"
+msgid "Arc layer (network)"
+msgstr "Warstwa zapytania"
#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "Brak punktów poczÄ
tkowych"
+msgid "Node layer (points)"
+msgstr "Brak punktów poczÄ
tkowych"
#, fuzzy
-#~ msgid "Reading data from the map..."
+msgid "Reading data from the map..."
#, fuzzy
-#~ msgid "%d categories read from map"
-#~ msgstr "Wczytano %d kategorii z mapy"
+msgid "%d categories read from map"
+msgstr "Wczytano %d kategorii z mapy"
#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "Uaktualniono %d bÅÄdów"
+msgid "%d update/insert errors"
+msgstr "Uaktualniono %d bÅÄdów"
#, fuzzy
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "Przetwarzanie linii..."
+msgid "Processing ainput lines ..."
+msgstr "Przetwarzanie linii..."
#, fuzzy
-#~ msgid "Processing ainput areas ..."
dku danych..."
+msgid "Processing ainput areas ..."
dku danych..."
-#~ msgid "Writing attributes ..."
-#~ msgstr "Zapisywanie atrybutów ..."
+msgid "Writing attributes ..."
+msgstr "Zapisywanie atrybutów ..."
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "BieżÄ
cy region nie zawiera caÅej wejÅciowej mapy wektorowej <%s>"
+msgid "Current region does not include the entire input vector map <%s>"
+msgstr "BieżÄ
#, fuzzy
-#~ msgid ""
-#~ "Elevation raster map <%s> does not cover the entire area of the input "
-#~ "vector map <%s>. "
-#~ msgstr "BieżÄ
+msgid ""
+"Elevation raster map <%s> does not cover the entire area of the input vector "
+"map <%s>. "
+msgstr "BieżÄ
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Opcjonalnie warunek where (bez sÅowa kluczowego WHERE), np.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Opcjonalnie warunek where (bez sÅowa kluczowego WHERE), np.:\n"
#, fuzzy
-#~ msgid "Display manager for GRASS"
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "nazwa dla nowego obrazu mapy (lives in ~/.gpsdrive)"
#, fuzzy
-#~ msgid "Name of .dmrc settings file"
+msgid "Displays thematic vectormap"
+msgstr "WyÅwietla tematyczne mapy wektorowe"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "SzerokoÅÄ nowego monitora wyÅwietlania w pikselach"
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "WysokoÅÄ nowego monitora wyÅwietlania w pikselach"
#, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "przenieÅ wyÅwietlane obecnie mapy do innego monitora"
+msgid "display, legend"
+msgstr "OdwrÃ³Ä legendÄ"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "wyczyÅÄ docelowy monitor przed przeniesieniem"
+msgid "Vector map to display thematically"
+msgstr "Mapa wektorowa do wyÅwietlenia tematycznie"
-#~ msgid "stay with source monitor"
-#~ msgstr "pozostaw pierwotny monitor"
+msgid "Vector map type"
+msgstr "Typ mapy wektorowej"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "zamknij pierwotny monitor po przeniesieniu"
-#~ msgid "Target monitor"
-#~ msgstr "Docelowy monitor"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr ""
-#~ "Eksportuj zawartoÅÄ monitora do zrzutu obrazu kompatybilnego z GpsDrive"
#, fuzzy
-#~ msgid "display, export, GPS"
-#~ msgstr "wyÅwietl, ustaw"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr "Warstwa jak ma byÄ użyta dla wyÅwietlania tematycznego"
-#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "nazwa dla nowego obrazu mapy (lives in ~/.gpsdrive)"
+msgid "Layer to use for thematic display"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Utwórz obraz JPEG zamiast PNG"
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr ""
-#~ "Zapisuje zawartoÅÄ aktywnego monitora do pliku PNG w katalogu domowym"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr ""
-#~ "RozdzielczoÅÄ pliku wyjÅciowego (pojedyÅcza=1, podwójna=2, poczwórna=4)"
#, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr ""
-#~ "Zapisuje zawartoÅÄ aktywnego monitora do pliku graficznego w katalogu "
-#~ "domowym"
+msgid "Output separator (default: newline)"
+msgstr "wyjÅciowy znak separacji (domyÅlnie: newline)"
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "(10=najmniejsza/worst, 100=najwiÄksza/best)"
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Rozmiar papieru dla wyjÅcia PostScript"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Ustaw kolor tÅa jako czarne (domyÅlnie biaÅe)"
#, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "Przeźroczyste tÅo"
+msgid "Raster to remove"
+msgstr "raster do usuniÄcia"
-#, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "odÅwierz aktualnie wyswietlane mapy w monitorze GRASS'a"
+msgid "3d raster to remove"
+msgstr "raster 3D do usuniÄcia"
#, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "Zapisz wszystkie ramki"
+msgid "Vector to remove"
+msgstr "ikona do usuniÄcia"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "ZmieÅ rozmiar aktywnego monitora wyÅwietlania"
-#~ msgid "New width for window"
-#~ msgstr "Nowa szerokoÅÄ dla okna"
-#~ msgid "New height for window"
-#~ msgstr "Nowa wysokoÅÄ dla okna"
#, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Pokaz slajdów map rastrowych/wektorowych GRASS'a"
+msgid "Region to remove"
+msgstr "region do usuniÄcia"
#, fuzzy
-#~ msgid "display, slideshow"
+msgid "Label to remove"
+msgstr "etykieta do usuniÄcia"
-#, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Ustaw region aby dopasowaÄ do mapy rastrowej"
+msgid "3dview to remove"
+msgstr "widok 3D do usuniÄcia"
#, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Liczba kopii do wydrukowania"
+msgid "Group to remove"
+msgstr "grupa do usuniÄcia"
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "wprowadź mapÄ rastrowÄ
do wyÅwietlenia w pierwszej ramce"
+msgid "raster input maps"
+msgstr "wejÅciowe mapy rastrowe"
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Wprowadź komendÄ do wykonania w pierwszej ramce"
+msgid "Keep band numbers instead of using band color names."
+msgstr "Zachowaj numery pasm zamiast używaÄ nazw kolorów pasm"
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Wprowadź mapÄ rastrowÄ
do wyÅwietlenia w drugiej ramce"
+msgid "Output field seperator"
+msgstr "WyjÅciowy separator pól"
-#, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
+msgid "Saving new map"
+msgstr "Zapisywanie nowej mapy"
-#~ msgid "How to split display"
-#~ msgstr "Jak podzieliÄ monitor wyÅwietlania"
#, fuzzy
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "WyÅwietla tematyczne mapy wektorowe"
+msgid "Terrain raster map (DEM)"
+msgstr "Mapa rastrowa terenu (DEM)"
#, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "OdwrÃ³Ä legendÄ"
+msgid "Output raster map with lake"
+msgstr "WyjÅciowa mapa rastrowa"
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Mapa wektorowa do wyÅwietlenia tematycznie"
-#~ msgid "Vector map type"
-#~ msgstr "Typ mapy wektorowej"
#, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "Warstwa jak ma byÄ użyta dla wyÅwietlania tematycznego"
+msgid "Cannot write lake raster map <%s>!"
-#~ msgid "Layer to use for thematic display"
#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "wyjÅciowy znak separacji (domyÅlnie: newline)"
+msgid "Terrain raster map <%s> not found!"
+msgstr "nie znaleziono mapy rastrowej <%s>"
#, fuzzy
-#~ msgid "Raster to remove"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "Nie można otworzyÄ mapy rastrowej [%s]"
-#~ msgid "3d raster to remove"
-#~ msgstr "raster 3D do usuniÄcia"
#, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "ikona do usuniÄcia"
+msgid "Seed map <%s> not found!"
#, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "region do usuniÄcia"
+msgid "Cannot open seed map <%s@%s>!"
#, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "etykieta do usuniÄcia"
+msgid "Failure to allocate memory for row pointers"
+msgstr "Nie można ulakowaÄ pamiÄci dla ciÄ
gu"
-#~ msgid "3dview to remove"
-#~ msgstr "widok 3D do usuniÄcia"
#, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "grupa do usuniÄcia"
+msgid "Loading maps: "
+msgstr "Odczytywania mapy"
-#~ msgid "raster input maps"
-#~ msgstr "wejÅciowe mapy rastrowe"
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Zachowaj numery pasm zamiast używaÄ nazw kolorów pasm"
#, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Eksportuje wektorowe pliki GRASSa do formatu DXF."
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "BÅÄ
d podczas odczytywania wejÅciowej mapy rastrowej."
-#~ msgid "Output field seperator"
-#~ msgstr "WyjÅciowy separator pól"
#, fuzzy
-#~ msgid "C (grid3D file)"
-#~ msgstr "Utwórz plik 3D"
+msgid "Error reading seed raster map. Probably broken file."
+msgstr "BÅÄ
d podczas odczytywania pliku rastrowego [%s]."
#, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Nazwa dla pliku wyjÅciowego"
+msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgid "Saving new map"
-#~ msgstr "Zapisywanie nowej mapy"
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Mapa rastrowa terenu (DEM)"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "BÅÄ
d podczas zapisu pliku colr dla <%s>."
-#, fuzzy
-#~ msgid "Output raster map with lake"
-#~ msgstr "WyjÅciowa mapa rastrowa"
+msgid "Raster input maps(s)"
+msgstr "WejÅciowa(e) mapa(y) rastrowa(e)"
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Output file name"
-#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "nie znaleziono mapy rastrowej <%s>"
+msgid "%s: can't read fp range for [%s]"
+msgstr "%s: nie można odczytaÄ zakresu fp dla [%s]"
#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Nie można otworzyÄ mapy rastrowej [%s]"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "Mapa rastrowa [%s] już istnieje w grupie."
-#, fuzzy
-#~ msgid "Seed map <%s> not found!"
+msgid "Cannot execute: %s"
+msgstr "Nie można wykonaÄ: %s"
#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot link table: %s"
#, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Nie można ulakowaÄ pamiÄci dla ciÄ
gu"
+msgid "Cannot open dxf file <%s>"
#, fuzzy
-#~ msgid "Loading maps: "
-#~ msgstr "Odczytywania mapy"
+msgid "Cannot open new vector map <%s>"
#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "BÅÄ
+msgid "Conversion of <%s> to vector map:"
+msgstr "Ustaw region aby dopasowaÄ do mapy wektorowej"
#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr "BÅÄ
+msgid "Hilight color for text"
+msgstr "Kolor podÅwietlenia tekstu"
#, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Line: %d\n"
+msgstr "WysokoÅÄ linii: %f\n"
#, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "BÅÄ
+msgid "Insufficent memory for allocation of data structure"
+msgstr "NiewystarczajÄ
ca iloÅÄ pamiÄci dla ulokowania struktury danych."
-#~ msgid "Raster input maps(s)"
-#~ msgstr "WejÅciowa(e) mapa(y) rastrowa(e)"
-#~ msgid "Output file name"
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: nie można odczytaÄ zakresu fp dla [%s]"
#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "Mapa rastrowa [%s] już istnieje w grupie."
+msgid "imagery group"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Nie można wykonaÄ: %s"
+msgid "imagery subgroup"
+msgstr "podgrupa obrazów"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
+msgid "output raster map"
+msgstr "wyjÅciowa mapa rastrowa"
#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Name of input raster map(s)"
+msgstr "Nazwa wejÅciowej mapy rastrowej"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "Output file extension (inputfile(s) + extension)"
+msgstr "Rozszerzenie pliku wyjÅciowego (plik wejÅciowy + rozszerzenie)"
#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "Ustaw region aby dopasowaÄ do mapy wektorowej"
+msgid "Illegal file name for real part: %s"
+msgstr "%s: %s - niewÅÅciwa nazwa pliku dla czÄÅci rzeczywistej\n"
#, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Kolor podÅwietlenia tekstu"
+msgid "Illegal file name for imaginary part: %s"
+msgstr "%s: %s - niewÅaÅciwa nazwa dla czÄÅci obrazu\n"
-#, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "WysokoÅÄ linii: %f\n"
+msgid "** Can't read signature file <%s> **"
+msgstr "** Nie można odczytaÄ pliku sygnatury <%s> **"
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "NiewystarczajÄ
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr ""
+"\n"
+"<%s> -- niewÅaÅciwa nazwa wynikowego pliku nazw sygnatur"
#, fuzzy
-#~ msgid "imagery group"
+msgid "Raster file(s) for Elevation"
+msgstr "Plik(i) rastra do wyÅwietlenia%d"
-#~ msgid "imagery subgroup"
-#~ msgstr "podgrupa obrazów"
-#~ msgid "output raster map"
-#~ msgstr "wyjÅciowa mapa rastrowa"
#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nazwa wejÅciowej mapy rastrowej"
+msgid "Raster file(s) for Color"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr "Rozszerzenie pliku wyjÅciowego (plik wejÅciowy + rozszerzenie)"
#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "%s: %s - niewÅÅciwa nazwa pliku dla czÄÅci rzeczywistej\n"
+msgid "No LatLong information for XY-Projection"
+msgstr "Opcje Geo-Grid sÄ
niedostÄpne dla projekcji XY"
#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "%s: %s - niewÅaÅciwa nazwa dla czÄÅci obrazu\n"
+msgid "Erasing monitors ..."
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "** Nie można odczytaÄ pliku sygnatury <%s> **"
+msgid "Could not open input file <%s>."
+msgstr "Nie można otworzyÄ pliku wejÅciowego <%s>."
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- niewÅaÅciwa nazwa wynikowego pliku nazw sygnatur"
+msgid "Raster map to zoom into"
+msgstr "PowiÄksz do mapy rastrowej"
-#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Plik(i) rastra do wyÅwietlenia%d"
+msgid "Save the current region to region definition file"
+msgstr "Zapisz bieżÄ
cy region w pliku definicji regionu"
#, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist:"
+msgstr ""
+"\a\n"
+"** NastÄpujÄ
cy plik rastrowy w podgrupie [%s] nie istnieje:"
-#, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "Opcje Geo-Grid sÄ
+msgid " %s"
+msgstr " %s"
-#, fuzzy
-#~ msgid "Erasing monitors ..."
+msgid "Removing files from group"
+msgstr "Usuwanie plików z grupy"
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "Nie można otworzyÄ pliku wejÅciowego <%s>."
-#~ msgid "Raster map to zoom into"
-#~ msgstr "PowiÄksz do mapy rastrowej"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "Zapisz bieżÄ
#, fuzzy
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "\a\n"
-#~ "** NastÄpujÄ
+msgid "Adding files to group [%s]"
+msgstr "Dodawanie plików do podgrupy [%s]"
-#~ msgid " %s"
-#~ msgstr " %s"
+msgid "Adding files to subgroup [%s]"
-#~ msgid "Removing files from group"
-#~ msgstr "Usuwanie plików z grupy"
+msgid "Writing group REF"
+msgstr "Zapisywanie ukÅadu odniesienia grupy"
-#, fuzzy
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "Dodawanie plików do podgrupy [%s]"
+msgid "Writing subgroup REF"
+msgstr "Zapisywanie ukÅadu odniesienia podgrupy"
-#~ msgid "Adding files to subgroup [%s]"
+msgid "Found file <%s@%s> in group."
+msgstr "Znaleziono plik <%s@%s>. w grupie."
-#~ msgid "Writing group REF"
-#~ msgstr "Zapisywanie ukÅadu odniesienia grupy"
-#~ msgid "Writing subgroup REF"
-#~ msgstr "Zapisywanie ukÅadu odniesienia podgrupy"
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "Znaleziono plik <%s@%s>. w grupie."
#, fuzzy
-#~ msgid "Found file <%s@%s> in subgroup."
+msgid "Found file <%s@%s> in subgroup."
#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgstr "Nie mozna otworzyÄ pliku wejÅciowego <%s@%s>."
+msgid "Unable to open file: <%s>"
+msgstr "Nie mozna otworzyÄ pliku wejÅciowego <%s@%s>."
-#~ msgid "%s: percent complete: "
-#~ msgstr "%s: procent wykonania: "
+msgid "%s: percent complete: "
+msgstr "%s: procent wykonania: "
-#~ msgid "Raster map not found."
-#~ msgstr "Nie znaleziono mapy rastrowej."
+msgid "Raster map not found."
+msgstr "Nie znaleziono mapy rastrowej."
-#~ msgid "%s: can't read range for [%s]"
-#~ msgstr "%s: nie można odczytaÄ zakresu dla [%s]"
+msgid "%s: can't read range for [%s]"
+msgstr "%s: nie można odczytaÄ zakresu dla [%s]"
#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "Plik rastrowy <%s> nie zostaÅ znaleziony"
+msgid "Raster file [%s] not found"
+msgstr "Plik rastrowy <%s> nie zostaÅ znaleziony"
#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nazwa wyjÅciowego pliku wektorowego"
+msgid "Name of the vector points map with x,y locations"
+msgstr "Nazwa wyjÅciowego pliku wektorowego"
#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Liczba punktów interpolacji"
+msgid "Number of time iterations (sec.)"
+msgstr "Liczba punktów interpolacji"
#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "lokalizacja bazy danych"
+msgid "Multiscale simulation"
+msgstr "lokalizacja bazy danych"
#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nazwa wejÅciowej rastrowej mapy wysokoÅci [metry]"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "Nazwa wejÅciowej rastrowej mapy wysokoÅci [metry]"
#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nazwa wejÅciowego pliku rastrowego"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "Nazwa wejÅciowego pliku rastrowego"
#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "nie można utworzyÄ %s"
+msgid "It was not possible writing in <%s>."
+msgstr "nie można utworzyÄ %s"
-#~ msgid "\rRemoved vertices: %5d"
-#~ msgstr "\rUsuniÄtych wierzchoÅków: %5d"
+msgid "\rRemoved vertices: %5d"
+msgstr "\rUsuniÄtych wierzchoÅków: %5d"
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "Nie można stworzyÄ tabeli: '%s'"
+msgid "Cannot create table: '%s'"
+msgstr "Nie można stworzyÄ tabeli: '%s'"
#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "Dla punktu #%d nie można wybraÄ atrybutów"
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "Dla punktu #%d nie można wybraÄ atrybutów"
#, fuzzy
-#~ msgid "Unable to write line %d"
-#~ msgstr "Nie można zapisaÄ do pliku"
+msgid "Unable to write line %d"
+msgstr "Nie można zapisaÄ do pliku"
#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Nieznany kolor: [%s]"
+msgid "Unknown query tool '%s'"
+msgstr "Nieznany kolor: [%s]"
#, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "Brak warstwy poÅÄ
czenia do bazy danych."
+msgid "No layer database connection"
+msgstr "Brak warstwy poÅÄ
#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "PomiÅ kategorie bez etykiet"
+msgid "%d categories loaded from the database"
+msgstr "PomiÅ kategorie bez etykiet"
-#~ msgid "Cannot create layer"
-#~ msgstr "Nie można utworzyÄ warstwy"
+msgid "Cannot create layer"
+msgstr "Nie można utworzyÄ warstwy"
#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Plik wektorowy [%s] nie jest dostÄpny"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Plik wektorowy [%s] nie jest dostÄpny"
#, fuzzy
-#~ msgid "Column type [%d] not supported"
+msgid "Column type [%d] not supported"
#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "Nie mozna odczytaÄ nagÅówka pliku [%s]"
+msgid "Cannot read map header for <%s>"
+msgstr "Nie mozna odczytaÄ nagÅówka pliku [%s]"
#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "EdytowaÄ plik kategorii dla [%s]? "
+msgid "Cannot read category file for <%s>"
+msgstr "EdytowaÄ plik kategorii dla [%s]? "
-#~ msgid "Print;Shell Script"
-#~ msgstr "WyÅwietl;Skrypt PowÅoki"
+msgid "Print;Shell Script"
+msgstr "WyÅwietl;Skrypt PowÅoki"
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "Torzenie plików wsparcia dla [%s]."
+msgid "Creating support files for [%s]."
+msgstr "Torzenie plików wsparcia dla [%s]."
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "Plik kategorii dla [%s] nie jest dostÄpny"
+msgid "Category file for [%s] not available"
+msgstr "Plik kategorii dla [%s] nie jest dostÄpny"
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr "%s: <%s> mapy rastrowej nie znaleziono"
+msgid "%s: <%s> raster map not found"
+msgstr "%s: <%s> mapy rastrowej nie znaleziono"
#, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "%s: <%s> plik rastrowy już istnieje"
+msgid "%s: <%s> raster map exists already"
+msgstr "%s: <%s> plik rastrowy już istnieje"
#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
-#~ msgid "%s - map not found"
+msgid "%s - map not found"
-#~ msgid "%s not found"
-#~ msgstr "nie znaleziono [%s]"
+msgid "%s not found"
+msgstr "nie znaleziono [%s]"
-#~ msgid "Could not access %s layer"
-#~ msgstr "Brak dostÄpu do %s warstwy"
+msgid "Could not access %s layer"
+msgstr "Brak dostÄpu do %s warstwy"
-#~ msgid "Vector map %s - not found"
-#~ msgstr "Mapa werktorowa %s - nie zostaÅa odnaleziona"
+msgid "Vector map %s - not found"
+msgstr "Mapa werktorowa %s - nie zostaÅa odnaleziona"
-#~ msgid "Raster map containing elevation data"
ca dane wysokoÅciowe powierzchni terenu."
+msgid "Raster map containing elevation data"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Nazwa mapy rastrowej dla przechowywania wyników"
+msgid "Raster map name for storing results"
+msgstr "Nazwa mapy rastrowej dla przechowywania wyników"
-#~ msgid "Height of the viewing location"
-#~ msgstr "WysokoÅÄ lokalizacji punktu widoku"
+msgid "Height of the viewing location"
+msgstr "WysokoÅÄ lokalizacji punktu widoku"
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "%s: <%s> pliku rastrowego nie znaleziono"
+msgid "%s: <%s> cellfile not found"
+msgstr "%s: <%s> pliku rastrowego nie znaleziono"
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "mapy rastrowej rgb [%s] nie znaleziono\n"
+msgid "rgb cell map [%s] not found\n"
+msgstr "mapy rastrowej rgb [%s] nie znaleziono\n"
#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgstr "%s - nie znaleziono"
+msgid "%s - %s not found"
+msgstr "%s - nie znaleziono"
-#~ msgid "raster map <%s> not found"
+msgid "raster map <%s> not found"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "nie można odczytaÄ nagÅówka dla <%s> w <%s>"
+msgid "can't read header for <%s> in <%s>"
+msgstr "nie można odczytaÄ nagÅówka dla <%s> w <%s>"
#, fuzzy
-#~ msgid "region <%s> not found"
-#~ msgstr "nie znaleziono regionu <%s>"
+msgid "region <%s> not found"
+msgstr "nie znaleziono regionu <%s>"
-#~ msgid "can't read region <%s> in <%s>"
+msgid "can't read region <%s> in <%s>"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "nie można otworzyÄ pliku <%s> widoku 3d w <%s>"
+msgid "can't open 3dview file <%s> in <%s>"
+msgstr "nie można otworzyÄ pliku <%s> widoku 3d w <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgstr "nie można odczytaÄ pliku <%s> widoku 3d w <%s>"
+msgid "can't read 3dview file <%s> in <%s>"
+msgstr "nie można odczytaÄ pliku <%s> widoku 3d w <%s>"
#, fuzzy
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "Nie można otworzyÄ mapy wektorowej [%s]"
+msgid "can't open vector map <%s> in <%s>"
+msgstr "Nie można otworzyÄ mapy wektorowej [%s]"
-#~ msgid "invalid region: %s"
-#~ msgstr "nieprawidÅowy region: %s"
+msgid "invalid region: %s"
+msgstr "nieprawidÅowy region: %s"
#, fuzzy
-#~ msgid "Creating support files"
-#~ msgstr "tworzenie plików wsparcia (support files) dla %s"
+msgid "Creating support files"
+msgstr "tworzenie plików wsparcia (support files) dla %s"
-#~ msgid "can't open %s"
-#~ msgstr "nie można otworzyÄ %s"
+msgid "can't open %s"
+msgstr "nie można otworzyÄ %s"
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
#, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "%s: %s - nie znaleziono"
+msgid "%s: %s - map not found"
+msgstr "%s: %s - nie znaleziono"
#, fuzzy
-#~ msgid "%s: unable to open %s"
-#~ msgstr "nie można otworzyÄ <%s>"
+msgid "%s: unable to open %s"
+msgstr "nie można otworzyÄ <%s>"
-#~ msgid "%s - not found"
+msgid "%s - not found"
-#~ msgid "Cannot read %s"
-#~ msgstr "Nie można odczytaÄ <%s>"
+msgid "Cannot read %s"
+msgstr "Nie można odczytaÄ <%s>"
-#~ msgid "[%s] map not found."
-#~ msgstr "[%s] mapy nie znaleziono."
+msgid "[%s] map not found."
+msgstr "[%s] mapy nie znaleziono."
-#~ msgid "[%s] map not found"
-#~ msgstr "[%s] mapy nie znaleziono"
+msgid "[%s] map not found"
+msgstr "[%s] mapy nie znaleziono"
#, fuzzy
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "pliku rastra [%s] nie znaleziono"
+msgid "elevation file [%s] not found"
+msgstr "pliku rastra [%s] nie znaleziono"
-#~ msgid "min computed aspect %.4f max computed aspect %.4f"
-#~ msgstr ""
-#~ "minimalna obliczona ekspozycja %.4f maksymalna obliczona ekspozycja %.4f"
+msgid "min computed aspect %.4f max computed aspect %.4f"
+msgstr ""
+"minimalna obliczona ekspozycja %.4f maksymalna obliczona ekspozycja %.4f"
-#~ msgid "min computed slope %.4f max computed slope %.4f"
-#~ msgstr "minimalny obliczony spadek %.4f maksymalny obliczony spadek %.4f"
+msgid "min computed slope %.4f max computed slope %.4f"
+msgstr "minimalny obliczony spadek %.4f maksymalny obliczony spadek %.4f"
#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Nie można opisaÄ tabeli %s"
+msgid "Cannot describe table <%s>"
+msgstr "Nie można opisaÄ tabeli %s"
#, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot insert values: %s"
#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- niewÅaÅciwa liczba poczÄ
tkowych klas"
+msgid "%s given an illegal number of points [%d]"
+msgstr ""
+"\n"
+"<%s> -- niewÅaÅciwa liczba poczÄ
tkowych klas"
#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Unable to open database %s by driver %s"
#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Nie zdefiniowano ustawieÅ poÅÄ
czenia bazy danych. Ustaw za pomocÄ
db."
-#~ "connect"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr ""
+"Nie zdefiniowano ustawieÅ poÅÄ
db.connect"
-#~ msgid "Could not find input %s"
-#~ msgstr "Nie można odnaleÅ¼Ä pliku wejÅciowego %s"
+msgid "Could not find input %s"
+msgstr "Nie można odnaleÅ¼Ä pliku wejÅciowego %s"
-#~ msgid "Could not open input"
-#~ msgstr "Nie można otworzyÄ pliku wejÅciowego"
+msgid "Could not open input"
+msgstr "Nie można otworzyÄ pliku wejÅciowego"
-#~ msgid "Could not open output"
-#~ msgstr "Nie można otworzyÄ pliku wyjÅciowego"
+msgid "Could not open output"
+msgstr "Nie można otworzyÄ pliku wyjÅciowego"
#, fuzzy
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "Nie można odnaleÅ¼Ä pliku wejÅciowego"
+msgid "Could not find input map <%s>"
+msgstr "Nie można odnaleÅ¼Ä pliku wejÅciowego"
-#~ msgid "Unkown item type in pad: %s"
-#~ msgstr "Nieznany typ obiektu w Åcieżce: %s"
+msgid "Unkown item type in pad: %s"
+msgstr "Nieznany typ obiektu w Åcieżce: %s"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "PoÅÄ
czenie z bazÄ
danych nie zostaÅo zdefiniowane\n"
+msgid "Database connection not defined\n"
+msgstr "PoÅÄ
czenie z bazÄ
#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "nie można odczytaÄ nagÅówka dla mapy rastrowej 3D <%s> w <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "nie można odczytaÄ nagÅówka dla mapy rastrowej 3D <%s> w <%s>"
#, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "nie można zapisaÄ regionu <%s>"
+msgid "Can't write region <%s>"
+msgstr "nie można zapisaÄ regionu <%s>"
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** niepoprawne dane wejÅciowe **"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** niepoprawne dane wejÅciowe **"
-#~ msgid "No graphics device selected."
-#~ msgstr "Nie zaznaczono żadnego użÄ
dzenia graficznego."
+msgid "No graphics device selected."
+msgstr "Nie zaznaczono żadnego użÄ
-#~ msgid "Unable to read raster row."
-#~ msgstr "Nie można odczytaÄ rzÄdu rastra."
+msgid "Unable to read raster row."
+msgstr "Nie można odczytaÄ rzÄdu rastra."
-#~ msgid "Training map [%s] not found."
-#~ msgstr "Mapy treningowej [%s] nie znaleziono."
+msgid "Training map [%s] not found."
+msgstr "Mapy treningowej [%s] nie znaleziono."
-#~ msgid "%s map not found"
-#~ msgstr "[%s] nie znaleziono mapy"
+msgid "%s map not found"
+msgstr "[%s] nie znaleziono mapy"
#, fuzzy
-#~ msgid "input raster map"
+msgid "input raster map"
#, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "Uwaga: niedozwolona nazwa pliku wyjÅciowego <%s>."
+msgid "Illegal file name: %s"
+msgstr "Uwaga: niedozwolona nazwa pliku wyjÅciowego <%s>."
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Nie można pobraÄ informacji o warstwie dla mapy wektorowej"
+msgid "Cannot get layer info for vector map"
+msgstr "Nie można pobraÄ informacji o warstwie dla mapy wektorowej"
#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr "Nie można otworzyÄ mapy rastrowej <%s> w <%s>"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr "Nie można otworzyÄ mapy rastrowej <%s> w <%s>"
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "wartoÅci uzyskane z etykiet kategorii mapy wierzchniej"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "wartoÅci uzyskane z etykiet kategorii mapy wierzchniej"
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "%s: %s - mapy rastrowej nie znaleziono"
+msgid "%s: %s - raster map not found"
+msgstr "%s: %s - mapy rastrowej nie znaleziono"
-#~ msgid "%s: %s - illegal name"
+msgid "%s: %s - illegal name"
-#~ msgid "%s: ERROR reading category file for %s"
-#~ msgstr "%s: BÅÄD podczas odczytu pliku kategorii dla %s"
+msgid "%s: ERROR reading category file for %s"
+msgstr "%s: BÅÄD podczas odczytu pliku kategorii dla %s"
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
-#~ msgid "%s: %s - illegal units"
-#~ msgstr "%s: %s - niewÅaÅciwe jednostki"
+msgid "%s: %s - illegal units"
+msgstr "%s: %s - niewÅaÅciwe jednostki"
#, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
#, fuzzy
-#~ msgid "Reading input map (%s) ... "
+msgid "Reading input map (%s) ... "
#, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "%s: BÅÄD podczas uruchamiania komendy %s"
+msgid "%s - ERROR reading %s"
+msgstr "%s: BÅÄD podczas uruchamiania komendy %s"
#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "%s - nie można otworzyÄ mapy rastrowej"
+msgid "%s: %s - can't create raster map"
+msgstr "%s - nie można otworzyÄ mapy rastrowej"
#, fuzzy
-#~ msgid "Writing output map (%s) ... "
-#~ msgstr "yjÅciowa mapa rastrowa"
+msgid "Writing output map (%s) ... "
+msgstr "yjÅciowa mapa rastrowa"
#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
#, fuzzy
-#~ msgid "%s - ERROR writing %s"
+msgid "%s - ERROR writing %s"
#, fuzzy
-#~ msgid "Reading raster map... "
+msgid "Reading raster map... "
#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr ""
-#~ "\n"
-#~ "Zapisywanie pliku rastrowego"
+msgid "Writing raster map... "
+msgstr ""
+"\n"
+"Zapisywanie pliku rastrowego"
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Lista kategorii: np. 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Lista kategorii: np. 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
-#~ msgstr "WyjÅciowy znak separacji (domyÅlnie: tab)"
+msgid "Output separator character (default: tab)"
+msgstr "WyjÅciowy znak separacji (domyÅlnie: tab)"
#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
#, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
-#~ msgid "Cannot create raster map %s"
-#~ msgstr "Nie można utworzyÄ mapy rastrowej %s"
+msgid "Cannot create raster map %s"
+msgstr "Nie można utworzyÄ mapy rastrowej %s"
#, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "Nie mogÄ znaleÅºÄ mapsetu dla %s"
+msgid "Cannot create vector map %s"
+msgstr "Nie mogÄ znaleÅºÄ mapsetu dla %s"
#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Liczba rzÄdów do zachowania w pamiÄci"
+msgid "Number of raster rows to hold in memory"
+msgstr "Liczba rzÄdów do zachowania w pamiÄci"
#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "WyÅwietl tylko typ mapy rastrowej"
+msgid "Print raster map title only"
+msgstr "WyÅwietl tylko typ mapy rastrowej"
#, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Typ nieznany: %c"
+msgid "unknown type: %d"
+msgstr "Typ nieznany: %c"
-#~ msgid "Cannot open raster map [%s]"
+msgid "Cannot open raster map [%s]"
#, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "Nie można otworzyÄ mapy rastrowej"
+msgid "Cannot get raster band."
+msgstr "Nie można otworzyÄ mapy rastrowej"
#, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
gu"
+msgid "Cannot allocate buffer for reading null values."
gu"
#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "Nie można wczytaÄ rastra"
+msgid "Cannot read GRASS raster."
+msgstr "Nie można wczytaÄ rastra"
#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "Nie można otworzyÄ sterownika %s"
+msgid "Cannot get [%s] driver"
+msgstr "Nie można otworzyÄ sterownika %s"
#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#~ msgstr "Nie mogÄ otworzyÄ Pliku %s"
+msgid "Cannot open TIFF file <%s>"
+msgstr "Nie mogÄ otworzyÄ Pliku %s"
#, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
-#~ msgid "Cannot open output map."
-#~ msgstr "Nie można otworzyÄ mapy wyjÅciowej."
+msgid "Cannot open output map."
+msgstr "Nie można otworzyÄ mapy wyjÅciowej."
#, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
#, fuzzy
-#~ msgid "memory allocation failure"
ca iloÅÄ pamiÄci dla ulokowania struktury danych"
+msgid "memory allocation failure"
#, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "Nie można znaleÅºÄ danych mapy."
+msgid "Can't find data map."
+msgstr "Nie można znaleÅºÄ danych mapy."
#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "Nazwa wyjÅciowego pliku ekspozycji"
+msgid "Output terrain only vector map name"
+msgstr "Nazwa wyjÅciowego pliku ekspozycji"
#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#~ msgstr "Wczytywanie plika wektorowego..."
+msgid "Rebuilding topology ..."
+msgstr "Wczytywanie plika wektorowego..."
#, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Zapiywanie %s ..."
+msgid "Attaching islands ..."
+msgstr "Zapiywanie %s ..."
#, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Minimalna liczba map wejÅciowych to dwa."
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Minimalna liczba map wejÅciowych to dwa."
-#~ msgid "Attribute column(s)"
-#~ msgstr "Kolumna(y) atrybutów"
+msgid "Attribute column(s)"
+msgstr "Kolumna(y) atrybutów"
-#~ msgid "Cannot get layer info"
-#~ msgstr "Nie można pobraÄ informacji o warstwie"
+msgid "Cannot get layer info"
+msgstr "Nie można pobraÄ informacji o warstwie"
-#~ msgid "cell file [%s] not found"
+msgid "cell file [%s] not found"
#, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Nie można zapisaÄ <%s>"
+msgid "Cannot rewrite line %d"
+msgstr "Nie można zapisaÄ <%s>"
#, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "IstniejÄ
cy"
+msgid "Editing tool"
+msgstr "IstniejÄ
cy"
#, fuzzy
-#~ msgid "Close boundaries"
+msgid "Close boundaries"
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#~ msgstr "Nie można przeskanowaÄ czasu: "
+msgid "Cannot snap lines %d,%d"
+msgstr "Nie można przeskanowaÄ czasu: "
#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
+msgid "Cannot get layer info for vector map <%s>"
#, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr ""
-#~ "\n"
-#~ "Tworzenie nowego pliku wektorowego...\n"
+msgid "Creating vector grid..."
+msgstr ""
+"\n"
+"Tworzenie nowego pliku wektorowego...\n"
#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "nie znaleziono mapy wektorowej <%s>"
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "nie znaleziono mapy wektorowej <%s>"
#, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "Wymagany parameter <%s> nie jest ustawiony"
+msgid "Parameter <%s> not set"
+msgstr "Wymagany parameter <%s> nie jest ustawiony"
#, fuzzy
-#~ msgid "Cannot get layer information for vector map"
+msgid "Cannot get layer information for vector map"
#, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "Nie można otworzyÄ mapy wektorowej <%s>"
+msgid "Not able to open vector map <%s>"
+msgstr "Nie można otworzyÄ mapy wektorowej <%s>"
-#~ msgid "No table."
-#~ msgstr "Brak tabeli."
+msgid "No table."
+msgstr "Brak tabeli."
-#~ msgid "Can't read raster"
+msgid "Can't read raster"
-#~ msgid "driver name:"
-#~ msgstr "nazwa sterownika:"
+msgid "driver name:"
+msgstr "nazwa sterownika:"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Nie można uruchomiÄ sterownika '%s'."
+msgid "Cannot start driver '%s'."
+msgstr "Nie można uruchomiÄ sterownika '%s'."
-#~ msgid "Cannot describe table"
-#~ msgstr "Nie można opisaÄ tabeli"
+msgid "Cannot describe table"
+msgstr "Nie można opisaÄ tabeli"
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Nie można uruchomiÄ sterownika <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "Nie można uruchomiÄ sterownika <%s>."
-#~ msgid "Driver name"
-#~ msgstr "Nazwa sterownika"
+msgid "Driver name"
+msgstr "Nazwa sterownika"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nazwa tabeli, wybierz wszystko z tej tabeli"
+msgid "Table name, select all from this table"
+msgstr "Nazwa tabeli, wybierz wszystko z tej tabeli"
-#~ msgid "output field separator"
-#~ msgstr "wyjÅciowy separator pola"
+msgid "output field separator"
+msgstr "wyjÅciowy separator pola"
-#~ msgid "output vertical record separator"
-#~ msgstr "wyjÅciowy separator pionowy"
+msgid "output vertical record separator"
+msgstr "wyjÅciowy separator pionowy"
-#~ msgid "null value indicator"
-#~ msgstr "wskaźnik wartosci zerowej"
+msgid "null value indicator"
+msgstr "wskaźnik wartosci zerowej"
-#~ msgid "do not include column names in output"
-#~ msgstr "nie wÅÄ
czaj nazw kolumn"
+msgid "do not include column names in output"
+msgstr "nie wÅÄ
czaj nazw kolumn"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "wynik pionowy (zamiast poziomego)"
+msgid "vertical output (instead of horizontal)"
+msgstr "wynik pionowy (zamiast poziomego)"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nazwa czcionki (nie ubsÅugiwana interaktywnie, zobacz także -l flag)lub "
-#~ "Åcieżka do czcionki TrueType (zawierajÄ
ca nazwÄ pliku)"
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr ""
+"Nazwa czcionki (nie ubsÅugiwana interaktywnie, zobacz także -l flag)lub "
+"Åcieżka do czcionki TrueType (zawierajÄ
ca nazwÄ pliku)"
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Ustawienia koloru siatki, standardowe kolory GRASS lub triplet R:G:B"
-#~ "(oddzielone dwukropkiem)"
+msgid ""
+"Sets the grid color, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Ustawienia koloru siatki, standardowe kolory GRASS lub triplet R:G:B"
+"(oddzielone dwukropkiem)"
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr ""
-#~ "Ustawienia koloru obramowania, standardowe kolory GRASSlub triplet R:G:B "
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+"Ustawienia koloru obramowania, standardowe kolory GRASSlub triplet R:G:B "
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr "Obramowanie jeszcze nie zaimplementowane dla lokacji LatLong"
+msgid "Border not yet implemented for LatLong locations: border not drawn."
+msgstr "Obramowanie jeszcze nie zaimplementowane dla lokacji LatLong"
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "Mapa rastrowa [%s] nie jest dostÄpna"
+msgid "Raster map [%s] not available"
+msgstr "Mapa rastrowa [%s] nie jest dostÄpna"
-#~ msgid "color file for [%s] not available"
-#~ msgstr "Plik koloru dla [%s] nie jest dostÄpny"
+msgid "color file for [%s] not available"
+msgstr "Plik koloru dla [%s] nie jest dostÄpny"
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "WpóÅrzÄdne ekranowe dla umieszczenia legendy (jako procent)"
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "WpóÅrzÄdne ekranowe dla umieszczenia legendy (jako procent)"
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Plik rastra [%s] nie jest dostÄpny"
+msgid "Raster file [%s] not available"
+msgstr "Plik rastra [%s] nie jest dostÄpny"
-#~ msgid "Not able to open file for [%s]"
-#~ msgstr "Nie można otworzyÄ pliku dla %s"
+msgid "Not able to open file for [%s]"
+msgstr "Nie można otworzyÄ pliku dla %s"
-#~ msgid "Label file [%s] not available"
-#~ msgstr "Plik etykiety %s nie jest dostÄpny"
+msgid "Label file [%s] not available"
+msgstr "Plik etykiety %s nie jest dostÄpny"
-#~ msgid "Can't open label file [%s]"
-#~ msgstr "Nie mogÄ otworzyÄ pliku etykiety [%s]"
+msgid "Can't open label file [%s]"
+msgstr "Nie mogÄ otworzyÄ pliku etykiety [%s]"
-#~ msgid "L: from M: to R: quit\n"
-#~ msgstr "L: od M: do R: wyjÅcie\n"
+msgid "L: from M: to R: quit\n"
+msgstr "L: od M: do R: wyjÅcie\n"
-#~ msgid "unable to open [%s] in [%s]"
-#~ msgstr "nie można otworzyÄ [%s] w [%s]"
+msgid "unable to open [%s] in [%s]"
+msgstr "nie można otworzyÄ [%s] w [%s]"
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgstr "ostrzeżenie: nie można otworzyÄ [%s] w [%s]"
+msgid "warning: unable to open [%s] in [%s]"
+msgstr "ostrzeżenie: nie można otworzyÄ [%s] w [%s]"
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "Nie można otworzyÄ pliku rastra dla [%s]"
+msgid "Not able to open cellfile for [%s]"
+msgstr "Nie można otworzyÄ pliku rastra dla [%s]"
-#~ msgid "Unable to open the temporary file."
-#~ msgstr "Nie można otworzyÄ pliku tymczasowego"
+msgid "Unable to open the temporary file."
+msgstr "Nie można otworzyÄ pliku tymczasowego"
-#~ msgid "Category <%d>: Area fill color and background color are the same!"
-#~ msgstr ""
-#~ "Kategoria <%d>: Kolor wypeÅnienia obszaru i kolor tÅa jest taki sam!"
+msgid "Category <%d>: Area fill color and background color are the same!"
+msgstr "Kategoria <%d>: Kolor wypeÅnienia obszaru i kolor tÅa jest taki sam!"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "Rozmiar obszaru jest mniejszy niż minimalny rozmiar obszaru,nic nie "
-#~ "zostaÅo wyÅwietlone.\n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr ""
+"Rozmiar obszaru jest mniejszy niż minimalny rozmiar obszaru,nic nie zostaÅo "
+"wyÅwietlone.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "Rozmiar obszaru jest wiÄkszy niż maksymalny rozmiar obszaru,nic nie "
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr ""
+"Rozmiar obszaru jest wiÄkszy niż maksymalny rozmiar obszaru,nic nie zostaÅo "
+"wyÅwietlone.\n"
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "Kolor linii i kolor tÅa sÄ
takie same!"
+msgid "Line color and background color are the same!"
+msgstr "Kolor linii i kolor tÅa sÄ
takie same!"
-#~ msgid "Area fill color and background color are the same!"
-#~ msgstr "Kolor wypeÅnienia obszaru i kolor tÅa sÄ
takie same!"
+msgid "Area fill color and background color are the same!"
+msgstr "Kolor wypeÅnienia obszaru i kolor tÅa sÄ
takie same!"
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
-#~ msgid "Done\n"
-#~ msgstr "Proces zakoÅczony\n"
+msgid "Done\n"
+msgstr "Proces zakoÅczony\n"
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr "Kategorie <%d>: Kolor linii i kolor tÅa sÄ
takie same!"
+msgid "Category <%d>: Line color and background color are the same!"
+msgstr "Kategorie <%d>: Kolor linii i kolor tÅa sÄ
takie same!"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "BÅÄD: <%s> niewÅaÅciwa nazwa\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "BÅÄD: <%s> niewÅaÅciwa nazwa\n"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Gdzie %s jest jednym z:\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"Gdzie %s jest jednym z:\n"
-#~ msgid "%s: - no such database %s\n"
-#~ msgstr "%s: - brak takiej bazy danych %s\n"
+msgid "%s: - no such database %s\n"
+msgstr "%s: - brak takiej bazy danych %s\n"
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "BÅÄD: <%s> nie znaleziono\n"
+msgid "ERROR: <%s> not found\n"
+msgstr "BÅÄD: <%s> nie znaleziono\n"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Zbyt maÅa iloÅÄ pamiÄci!\n"
+msgid "Out of Memory!\n"
+msgstr "Zbyt maÅa iloÅÄ pamiÄci!\n"
-#~ msgid "Imagery files subgroup"
-#~ msgstr "Podgrupa obrazów"
+msgid "Imagery files subgroup"
+msgstr "Podgrupa obrazów"
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "Uwaga: niedozwolona nazwa grupy <%s>."
+msgid "Warning: illegal group name <%s>."
+msgstr "Uwaga: niedozwolona nazwa grupy <%s>."
-#~ msgid "Warning: illegal output file name <%s>."
+msgid "Warning: illegal output file name <%s>."
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr "Nazwa wyjÅciowej mapy rastrowej nie może byÄ dÅuższa niż 12 znaków."
+msgid "The output cell map name can not be longer than 12 characters."
+msgstr "Nazwa wyjÅciowej mapy rastrowej nie może byÄ dÅuższa niż 12 znaków."
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#~ msgstr "Nie można wyÅwietliÄ stron podrÄcznika map rastrowych <%s>.\n"
+msgid "Unable to open cell man <%s> for input.\n"
+msgstr "Nie można wyÅwietliÄ stron podrÄcznika map rastrowych <%s>.\n"
-#~ msgid "Unable to open cell map <%s> for output.\n"
-#~ msgstr "Nie można otworzyÄ mapy rastrowej <%s> dla wyjÅciowego pliku.\n"
+msgid "Unable to open cell map <%s> for output.\n"
+msgstr "Nie można otworzyÄ mapy rastrowej <%s> dla wyjÅciowego pliku.\n"
-#~ msgid "Hit RETURN -->"
-#~ msgstr "NaciÅnij ENTER -->"
+msgid "Hit RETURN -->"
+msgstr "NaciÅnij ENTER -->"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following cell files in subgroup [%s] do not exist."
-#~ msgstr ""
-#~ "\a\n"
-#~ "** NastÄpujÄ
ce pliki w podgrupie [%s] nie istniejÄ
+msgid ""
+"\a\n"
+"** The following cell files in subgroup [%s] do not exist."
+msgstr ""
+"\a\n"
+"** NastÄpujÄ
-#~ msgid "Subgroup [%s] doesn't have any files."
-#~ msgstr "Podgrupa [%s] nie zawiera żadnych plików."
+msgid "Subgroup [%s] doesn't have any files."
+msgstr "Podgrupa [%s] nie zawiera żadnych plików."
-#~ msgid "Subgroup [%s] only has 1 file."
-#~ msgstr "Podgrupa [%s] zawiera tylko 1 plik."
+msgid "Subgroup [%s] only has 1 file."
+msgstr "Podgrupa [%s] zawiera tylko 1 plik."
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr ""
-#~ "Podgrupa musi zawieraÄ przynajmniej 2 pliki aby można byÅo uruchomiÄ %s."
+msgid "The subgroup must have at least 2 files to run %s."
+msgstr ""
+"Podgrupa musi zawieraÄ przynajmniej 2 pliki aby można byÅo uruchomiÄ %s."
-#~ msgid ""
-#~ "\n"
-#~ "If you continue the mask will be removed."
-#~ msgstr ""
-#~ "\n"
-#~ "W przypadku kontynuacji maska zostanie usuniÄta."
+msgid ""
+"\n"
+"If you continue the mask will be removed."
+msgstr ""
+"\n"
+"W przypadku kontynuacji maska zostanie usuniÄta."
-#~ msgid "Did not find input cell map."
-#~ msgstr "Nie znaleziono wejÅciowej mapy rastrowej."
+msgid "Did not find input cell map."
+msgstr "Nie znaleziono wejÅciowej mapy rastrowej."
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "%s: %s - Nie można otworzyÄ wejÅciowej mapy rastrowej\n"
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "%s: %s - Nie można otworzyÄ wejÅciowej mapy rastrowej\n"
-#~ msgid "Unable to open raster map [%s]."
-#~ msgstr "Nie można otworzyÄ mapy rastrowej [%s]."
+msgid "Unable to open raster map [%s]."
+msgstr "Nie można otworzyÄ mapy rastrowej [%s]."
-#~ msgid "#%s"
-#~ msgstr "#%s"
+msgid "#%s"
+msgstr "#%s"
-#~ msgid "%s: %s - illegal name for output raster file."
-#~ msgstr "%s: %s - niedozwolona nazwa dla wyjÅciowego pliku rastrowego."
+msgid "%s: %s - illegal name for output raster file."
+msgstr "%s: %s - niedozwolona nazwa dla wyjÅciowego pliku rastrowego."
-#~ msgid "Unable to allocate memory."
-#~ msgstr "Nie można ulokowaÄ pamiÄci."
+msgid "Unable to allocate memory."
+msgstr "Nie można ulokowaÄ pamiÄci."
-#~ msgid "Unable to create raster map [%s]."
-#~ msgstr "Nie można utworzyÄ mapy rastrowej [%s]."
+msgid "Unable to create raster map [%s]."
+msgstr "Nie można utworzyÄ mapy rastrowej [%s]."
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "%s: BÅÄD nie można otworzyÄ pliku tymczasowego"
+msgid "%s: ERROR can't open tempfile"
+msgstr "%s: BÅÄD nie można otworzyÄ pliku tymczasowego"
-#~ msgid "%s: <%s> raster file not found"
-#~ msgstr "%s: <%s> nie znaleziono pliku rastrowego"
+msgid "%s: <%s> raster file not found"
+msgstr "%s: <%s> nie znaleziono pliku rastrowego"
-#~ msgid "Couldn't find raster file %s"
-#~ msgstr "Nie można znaleÅºÄ pliku rastrowego %s"
+msgid "Couldn't find raster file %s"
+msgstr "Nie można znaleÅºÄ pliku rastrowego %s"
-#~ msgid "done."
-#~ msgstr "Zrobione."
+msgid "done."
+msgstr "Zrobione."
-#~ msgid "unable to find raster file [%s]"
-#~ msgstr "Nie można odnaleÅºÄ rastra [%s]"
+msgid "unable to find raster file [%s]"
+msgstr "Nie można odnaleÅºÄ rastra [%s]"
-#~ msgid "%s: %s in %s - can't read category file"
-#~ msgstr "%s: %s %s - nie można odczytaÄ pliku kategrii"
+msgid "%s: %s in %s - can't read category file"
+msgstr "%s: %s %s - nie można odczytaÄ pliku kategrii"
-#~ msgid "%s: <%s> illegal name"
-#~ msgstr "%s: <%s> niedozwolona nazwa"
+msgid "%s: <%s> illegal name"
+msgstr "%s: <%s> niedozwolona nazwa"
-#~ msgid "%s: Cannot open <%s>"
-#~ msgstr "%s: Nie można otworzyÄ <%s>"
+msgid "%s: Cannot open <%s>"
+msgstr "%s: Nie można otworzyÄ <%s>"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nazwa pliku predefiniowanej formuly"
+msgid "Name of predefined rules file"
+msgstr "Nazwa pliku predefiniowanej formuly"
-#~ msgid "List rules"
-#~ msgstr "Lista formuÅ"
+msgid "List rules"
+msgstr "Lista formuÅ"
-#~ msgid "** warning: R:G:B value(s) out of range [0..255]: %d:%d:%d **\n"
-#~ msgstr "** uwaga: wartoÅci R:G:B poza przedziaÅem [0..255]: %d:%d:%d **\n"
+msgid "** warning: R:G:B value(s) out of range [0..255]: %d:%d:%d **\n"
+msgstr "** uwaga: wartoÅci R:G:B poza przedziaÅem [0..255]: %d:%d:%d **\n"
-#~ msgid "** warning: R G B value(s) out of range [0..255]: %d %d %d **\n"
-#~ msgstr "** uwaga: wartoÅci R G B poza przedziaÅem [0.255]: %d %d %d **\n"
+msgid "** warning: R G B value(s) out of range [0..255]: %d %d %d **\n"
+msgstr "** uwaga: wartoÅci R G B poza przedziaÅem [0.255]: %d %d %d **\n"
-#~ msgid "** warning: no such value **\n"
-#~ msgstr "** uwaga: nie takie wartosci **\n"
+msgid "** warning: no such value **\n"
+msgstr "** uwaga: nie takie wartosci **\n"
-#~ msgid "%s:line %d:%s\n"
-#~ msgstr "%s:linia %d:%s\n"
+msgid "%s:line %d:%s\n"
+msgstr "%s:linia %d:%s\n"
-#~ msgid "** bad color specification **\n"
-#~ msgstr "** zÅa specyfikacja koloru **\n"
+msgid "** bad color specification **\n"
+msgstr "** zÅa specyfikacja koloru **\n"
-#~ msgid "%s - unknown color\n"
+msgid "%s - unknown color\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "Dopuszczalnymi kolorami sÄ
:\n"
+msgid "Valid colors are:\n"
+msgstr "Dopuszczalnymi kolorami sÄ
:\n"
-#~ msgid "<%s> raster file not found"
+msgid "<%s> raster file not found"
-#~ msgid "<%s> unable to open raster file"
-#~ msgstr "Nie można wczytaÄ rastra <%s>"
+msgid "<%s> unable to open raster file"
+msgstr "Nie można wczytaÄ rastra <%s>"
-#~ msgid "Finished"
-#~ msgstr "ZakoÅczono"
+msgid "Finished"
+msgstr "ZakoÅczono"
-#~ msgid "%s - can't open raster file"
-#~ msgstr "%s - nie można otworzyÄ pliku rastrowego"
+msgid "%s - can't open raster file"
+msgstr "%s - nie można otworzyÄ pliku rastrowego"
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d rzÄdy, %d kolumny"
+msgid " %d rows, %d cols."
+msgstr "%d rzÄdy, %d kolumny"
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "Otwórz plik rastrow %s w mapsecie %s"
+msgid "Open Raster file %s in Mapset %s"
+msgstr "Otwórz plik rastrow %s w mapsecie %s"
#, fuzzy
-#~ msgid "output 3dcell map"
+msgid "output 3dcell map"
#, fuzzy
-#~ msgid "input cell file not found\n"
+msgid "input cell file not found\n"
#, fuzzy
-#~ msgid "elev cell file not found\n"
+msgid "elev cell file not found\n"
-#~ msgid "error opening g3d file"
-#~ msgstr "BÅÄ
d podczas otwierania pliku g3d"
+msgid "error opening g3d file"
+msgstr "BÅÄ
#, fuzzy
-#~ msgid "Input aspect file"
-#~ msgstr "Plik wejÅciowy aspektu"
+msgid "Input aspect file"
+msgstr "Plik wejÅciowy aspektu"
-#~ msgid "Input barrier file"
+msgid "Input barrier file"
-#~ msgid "Display Reference Information"
-#~ msgstr "WyÅwietl informacje o odniesieniu."
+msgid "Display Reference Information"
+msgstr "WyÅwietl informacje o odniesieniu."
-#~ msgid "Unable to open output file <%s>."
-#~ msgstr "Nie można otworzyÄ pliku wyjÅciowego <%s>."
+msgid "Unable to open output file <%s>."
+msgstr "Nie można otworzyÄ pliku wyjÅciowego <%s>."
-#~ msgid "%s: <%s> cell file not found"
-#~ msgstr "%s: <%s> pliku rastra nie znaleziono"
+msgid "%s: <%s> cell file not found"
+msgstr "%s: <%s> pliku rastra nie znaleziono"
-#~ msgid "Not able to find cellfile [%s]"
-#~ msgstr "Nie można odnaleÅºÄ pliku rastroweg [%s]"
+msgid "Not able to find cellfile [%s]"
+msgstr "Nie można odnaleÅºÄ pliku rastroweg [%s]"
-#~ msgid "** errors detected in header section **\n"
-#~ msgstr "** wykryto bÅÄdy w nagÅówku **\n"
+msgid "** errors detected in header section **\n"
+msgstr "** wykryto bÅÄdy w nagÅówku **\n"
#, fuzzy
-#~ msgid "%s -- illegal output file name"
-#~ msgstr ""
-#~ "\n"
+msgid "%s -- illegal output file name"
+msgstr ""
+"\n"
-#~ msgid "Raster output file"
-#~ msgstr "WyjÅciowy plik rastrowy"
+msgid "Raster output file"
+msgstr "WyjÅciowy plik rastrowy"
#, fuzzy
-#~ msgid "Print the input data extent in shell script style"
-#~ msgstr "WyÅwietl ustawienia bieżÄ
cego regionu (styl skryptu powÅoki)"
+msgid "Print the input data extent in shell script style"
+msgstr "WyÅwietl ustawienia bieżÄ
-#~ msgid "could not read range file"
-#~ msgstr "nie można odczytaÄ pliku zakresu rozpiÄtoÅci danych"
+msgid "could not read range file"
+msgstr "nie można odczytaÄ pliku zakresu rozpiÄtoÅci danych"
#, fuzzy
-#~ msgid "File name of classification result"
-#~ msgstr "Mapa rastrowa do przechowywania wyników klasyfikacji"
+msgid "File name of classification result"
+msgstr "Mapa rastrowa do przechowywania wyników klasyfikacji"
-#~ msgid "quiet"
-#~ msgstr "nie pokazuj komunikatów"
+msgid "quiet"
+msgstr "nie pokazuj komunikatów"
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "%s: <%s> mapy odniesienia nie znaleziono"
+msgid "%s: <%s> reference map not found"
+msgstr "%s: <%s> mapy odniesienia nie znaleziono"
-#~ msgid "Base raster map"
-#~ msgstr "Bazowa mapa rastrowa"
+msgid "Base raster map"
+msgstr "Bazowa mapa rastrowa"
-#~ msgid "Name of the input raster file"
+msgid "Name of the input raster file"
-#~ msgid "Output raster file title"
-#~ msgstr "TytuÅ wyjÅciowego pliku rastrowego"
+msgid "Output raster file title"
+msgstr "TytuÅ wyjÅciowego pliku rastrowego"
-#~ msgid "Name of existing raster file"
-#~ msgstr "Nazwa istniejÄ
cego pliku rastrowego"
+msgid "Name of existing raster file"
+msgstr "Nazwa istniejÄ
-#~ msgid ""
-#~ "Converts a GRASS raster file to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Konwertuje pliki rastrowe GRASS do pliku obrazu PPM o rozdzielczoÅci "
-#~ "piksela aktualnie zdefiniowanego regionu"
+msgid ""
+"Converts a GRASS raster file to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr ""
+"Konwertuje pliki rastrowe GRASS do pliku obrazu PPM o rozdzielczoÅci piksela "
+"aktualnie zdefiniowanego regionu"
-#~ msgid "Verbose mode."
-#~ msgstr "Pokazuj komunikaty."
+msgid "Verbose mode."
+msgstr "Pokazuj komunikaty."
-#~ msgid "%s - can't read raster cellhd"
-#~ msgstr "%s - nie można odczytaÄ pliku nagÅówkowego rastra 'cellhd'"
+msgid "%s - can't read raster cellhd"
+msgstr "%s - nie można odczytaÄ pliku nagÅówkowego rastra 'cellhd'"
-#~ msgid "error reading cell data"
-#~ msgstr "bÅÄ
d podczas odczytu danych rastrowych"
+msgid "error reading cell data"
+msgstr "bÅÄ
#, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "Problem opening input file [%s]"
#, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr ""
-#~ "Flaga -i może byÄ użyta z parametrem trasy zarówno ÅÄ
cznie jak i "
-#~ "rozdzielnie"
+msgid "Either -i flag and/or profile parameter must be used."
+msgstr ""
+"Flaga -i może byÄ użyta z parametrem trasy zarówno ÅÄ
cznie jak i rozdzielnie"
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "NIEDOZWOLONA rozdzielczoÅÄ!"
+msgid "ILLEGAL Resolution!"
+msgstr "NIEDOZWOLONA rozdzielczoÅÄ!"
-#~ msgid "Cannot find map %s"
-#~ msgstr "Nie mozna odnaleÅºÄ mapy %s"
+msgid "Cannot find map %s"
+msgstr "Nie mozna odnaleÅºÄ mapy %s"
-#~ msgid "Cannot open map %s"
-#~ msgstr "Nie można otworzyÄ mapy %s"
+msgid "Cannot open map %s"
+msgstr "Nie można otworzyÄ mapy %s"
-#~ msgid "Mapset of input map"
-#~ msgstr "Mapset mapy wejÅciowej"
+msgid "Mapset of input map"
+msgstr "Mapset mapy wejÅciowej"
#, fuzzy
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr ""
-#~ "Czytaj mapÄ fp jako mapÄ o danych caÅkowitych (użyj regóŠiloÅciowych "
-#~ "mapy)"
+msgid "Read fp map as integer (use map's quant rules"
+msgstr ""
+"Czytaj mapÄ fp jako mapÄ o danych caÅkowitych (użyj regóŠiloÅciowych mapy)"
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "Wynikowe pochodne czÄÅciowe"
+msgid "Output partial derivatives instead"
+msgstr "Wynikowe pochodne czÄÅciowe"
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "Nie można otworzyÄ pliku tymczasowego [%s]"
+msgid "Can't open temp file [%s]"
+msgstr "Nie można otworzyÄ pliku tymczasowego [%s]"
-#~ msgid "CREATING SUPPORT FILES"
-#~ msgstr "TWORZENIE PLIKÃW WSPARCIA"
+msgid "CREATING SUPPORT FILES"
+msgstr "TWORZENIE PLIKÃW WSPARCIA"
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "PRODUKTY WYSOKOÅCIOWE dla mapsetu [%s] w [%s]"
+msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
+msgstr "PRODUKTY WYSOKOÅCIOWE dla mapsetu [%s] w [%s]"
#, fuzzy
-#~ msgid "elevin cell file <%s> not found"
-#~ msgstr "nie znaleziono pliku <%s> widoku 3d "
+msgid "elevin cell file <%s> not found"
+msgstr "nie znaleziono pliku <%s> widoku 3d "
#, fuzzy
-#~ msgid "aspin cell file <%s> not found"
-#~ msgstr "nie znaleziono pliku rastra aspin <%s> "
+msgid "aspin cell file <%s> not found"
+msgstr "nie znaleziono pliku rastra aspin <%s> "
#, fuzzy
-#~ msgid "slopein cell file <%s> not found"
+msgid "slopein cell file <%s> not found"
#, fuzzy
-#~ msgid "linkein cell file <%s> not found"
+msgid "linkein cell file <%s> not found"
#, fuzzy
-#~ msgid "albedo cell file <%s> not found"
+msgid "albedo cell file <%s> not found"
#, fuzzy
-#~ msgid "latin cell file <%s> not found"
+msgid "latin cell file <%s> not found"
#, fuzzy
-#~ msgid "coefbh cell file <%s> not found"
+msgid "coefbh cell file <%s> not found"
#, fuzzy
-#~ msgid "coefdh cell file <%s> not found"
+msgid "coefdh cell file <%s> not found"
-#~ msgid "Finished.\n"
-#~ msgstr "ZakoÅczono.\n"
+msgid "Finished.\n"
+msgstr "ZakoÅczono.\n"
-#~ msgid "Unable to find [%s]."
-#~ msgstr "Nie można odnaleÅºÄ [%s]."
+msgid "Unable to find [%s]."
+msgstr "Nie można odnaleÅºÄ [%s]."
-#~ msgid "%s in %s -can't open raster file"
-#~ msgstr "%s w %s - nie można otworzyÄ pliku rastrowego"
+msgid "%s in %s -can't open raster file"
+msgstr "%s w %s - nie można otworzyÄ pliku rastrowego"
#, fuzzy
-#~ msgid "%s - can't create cell file"
+msgid "%s - can't create cell file"
-#~ msgid "%s: can't create %s"
-#~ msgstr "%s: nie można utworzyÄ %s"
+msgid "%s: can't create %s"
+msgstr "%s: nie można utworzyÄ %s"
-#~ msgid "Area 0, %d \t%d \t%d \t%d \t%d"
-#~ msgstr "Powierzchnia 0, %d \t%d \t%d \t%d \t%d"
+msgid "Area 0, %d \t%d \t%d \t%d \t%d"
+msgstr "Powierzchnia 0, %d \t%d \t%d \t%d \t%d"
-#~ msgid "Could not open raster '%s'"
-#~ msgstr "Nie można otworzyÄ rastra %s"
+msgid "Could not open raster '%s'"
+msgstr "Nie można otworzyÄ rastra %s"
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgstr "Nie można odczytaÄ wiersza %d w mapie rastrowej [%s]"
+msgid "Unable to read row %d in raster map [%s]"
+msgstr "Nie można odczytaÄ wiersza %d w mapie rastrowej [%s]"
#, fuzzy
-#~ msgid "Can't read current window parameters"
-#~ msgstr "wypisz parametry bieżÄ
cego poÅÄ
czenia i wyjdź"
+msgid "Can't read current window parameters"
+msgstr "wypisz parametry bieżÄ
cego poÅÄ
czenia i wyjdź"
-#~ msgid "[%s] file name not legal"
-#~ msgstr "[%s] nazwa pliku jest niedozwolona"
+msgid "[%s] file name not legal"
+msgstr "[%s] nazwa pliku jest niedozwolona"
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "[%s] nazwa pliku jest niedozwolona\n"
+msgid "[%s] file name not legal\n"
+msgstr "[%s] nazwa pliku jest niedozwolona\n"
#, fuzzy
-#~ msgid "Name of the infiltration excess raster file"
+msgid "Name of the infiltration excess raster file"
-#~ msgid "Open 3D raster file %s"
-#~ msgstr "Nie Otwórz plik rastrowy 3D %s"
+msgid "Open 3D raster file %s"
+msgstr "Nie Otwórz plik rastrowy 3D %s"
-#~ msgid "Requested g3d file not found <%s>"
-#~ msgstr "Wymagany plik g3d nie zostaÅ znaleziony <%s>"
+msgid "Requested g3d file not found <%s>"
+msgstr "Wymagany plik g3d nie zostaÅ znaleziony <%s>"
-#~ msgid "Error opening g3d file <%s>"
-#~ msgstr "BÅÄ
d podczas otwierania pliku g3d <%s>."
+msgid "Error opening g3d file <%s>"
+msgstr "BÅÄ
#, fuzzy
-#~ msgid "Could not open elevation map\n"
+msgid "Could not open elevation map\n"
-#~ msgid "Error opening g3d file"
-#~ msgstr "BÅÄ
+msgid "Error opening g3d file"
+msgstr "BÅÄ
#, fuzzy
-#~ msgid "Open vector g3d raster file %s"
+msgid "Open vector g3d raster file %s"
-#~ msgid "Open g3d raster file %s"
-#~ msgstr "Otwórz plik rastra g3d %s"
+msgid "Open g3d raster file %s"
+msgstr "Otwórz plik rastra g3d %s"
-#~ msgid "Could not close the g3d map"
-#~ msgstr "Nie można zamknÄ
Ä mapy g3d"
+msgid "Could not close the g3d map"
+msgstr "Nie można zamknÄ
Ä mapy g3d"
-#~ msgid "cannot create output map [%s]"
-#~ msgstr "nie można utowrzyÄ wyjÅciowej mapy [%s]"
+msgid "cannot create output map [%s]"
+msgstr "nie można utowrzyÄ wyjÅciowej mapy [%s]"
#, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
#, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#~ msgstr "Nie można odnaleÅ¼Ä mapy wejÅciowego <%s>"
+msgid "Cannot find input map <%s>"
+msgstr "Nie można odnaleÅ¼Ä mapy wejÅciowego <%s>"
-#~ msgid "No db connection for driver <%s> defined. Run db.connect"
-#~ msgstr ""
-#~ "Nie zdefiniowano poÅÄ
czenia z bazÄ
danych dla sterownika <%s>. Uruchom db."
-#~ "conect"
+msgid "No db connection for driver <%s> defined. Run db.connect"
+msgstr ""
+"Nie zdefiniowano poÅÄ
czenia z bazÄ
+"conect"
-#~ msgid "+---------------------------------+---------------+"
-#~ msgstr "+---------------------------------+---------------+"
+msgid "+---------------------------------+---------------+"
+msgstr "+---------------------------------+---------------+"
-#~ msgid " %13e |"
-#~ msgstr " %13e |"
+msgid " %13e |"
+msgstr " %13e |"
-#~ msgid "--------------------------------------------------"
-#~ msgstr "--------------------------------------------------"
+msgid "--------------------------------------------------"
+msgstr "--------------------------------------------------"
-#~ msgid "Table name"
-#~ msgstr "Nazwa tabeli"
+msgid "Table name"
+msgstr "Nazwa tabeli"
#, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "Nie można otworzyÄ bazy danych %s"
+msgid "Cannot open database <%s>"
+msgstr "Nie można otworzyÄ bazy danych %s"
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "Nie można otworzyÄ paska narzÄdziowego: %s"
+msgid "Cannot open toolbox: %s"
+msgstr "Nie można otworzyÄ paska narzÄdziowego: %s"
-#~ msgid "Cannot open toolbox."
-#~ msgstr "Nie można otworzyÄ paska narzÄdziowego."
+msgid "Cannot open toolbox."
+msgstr "Nie można otworzyÄ paska narzÄdziowego."
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "BÅÄD: Dla linii wymagane sÄ
przynajmniej 2 punkty"
+msgid "ERROR: A line needs at least 2 points"
+msgstr "BÅÄD: Dla linii wymagane sÄ
-#~ msgid "ERROR: An area needs at least 3 points"
-#~ msgstr "BÅÄD: Dla powierzchni wymagane sÄ
przynajmniej 3 punkty"
+msgid "ERROR: An area needs at least 3 points"
+msgstr "BÅÄD: Dla powierzchni wymagane sÄ
#, fuzzy
-#~ msgid "No database updates."
-#~ msgstr "Brak uakualnieÅ bazy danych."
+msgid "No database updates."
+msgstr "Brak uakualnieÅ bazy danych."
#, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "Zapisywanie atrybutów ...\n"
+msgid "Writing attributes ...\n"
+msgstr "Zapisywanie atrybutów ...\n"
-#~ msgid "Could not open ascii file [%s]"
-#~ msgstr "Nie można otworzyÄ pliku ASCII [%s]"
+msgid "Could not open ascii file [%s]"
+msgstr "Nie można otworzyÄ pliku ASCII [%s]"
-#~ msgid "Can't open temp file %s"
-#~ msgstr "Nie można otworzyÄ pliku tymczasowego %s"
+msgid "Can't open temp file %s"
+msgstr "Nie można otworzyÄ pliku tymczasowego %s"
-#~ msgid "x column name"
-#~ msgstr "Nazwa kolumny x"
+msgid "x column name"
+msgstr "Nazwa kolumny x"
-#~ msgid "z column name"
-#~ msgstr "Nazwa kolumny z"
+msgid "z column name"
+msgstr "Nazwa kolumny z"
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "%s: Nie można otworzyÄ pliku dxf"
+msgid "%s: Cannot open dxf file"
+msgstr "%s: Nie można otworzyÄ pliku dxf"
-#~ msgid "%s: Cannot open new vector file"
-#~ msgstr "%s: Nie można otworzyÄ nowego pliku wektorowego"
+msgid "%s: Cannot open new vector file"
+msgstr "%s: Nie można otworzyÄ nowego pliku wektorowego"
#, fuzzy
-#~ msgid "Could not find input vector '%s'"
+msgid "Could not find input vector '%s'"
#, fuzzy
-#~ msgid "New vector composite"
-#~ msgstr "nazwa wejÅciowego pliku wektorowego"
+msgid "New vector composite"
+msgstr "nazwa wejÅciowego pliku wektorowego"
#, fuzzy
-#~ msgid "Append files to existing file"
-#~ msgstr "Nazwy istniejÄ
cych plików rastrowych"
+msgid "Append files to existing file"
+msgstr "Nazwy istniejÄ
#, fuzzy
-#~ msgid " Patching file %s"
-#~ msgstr "Odczytywanie obrazu ..."
+msgid " Patching file %s"
+msgstr "Odczytywanie obrazu ..."
#, fuzzy
-#~ msgid ""
-#~ "List vector files in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr "WyÅwietl listÄ plików rastrowych w wejÅciowej lokacji i wyjdź"
+msgid ""
+"List vector files in input location and exit (a dummy value must be given "
+"for input)"
+msgstr "WyÅwietl listÄ plików rastrowych w wejÅciowej lokacji i wyjdź"
#, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
#, fuzzy
-#~ msgid "unable to open cell file [%s]"
+msgid "unable to open cell file [%s]"
#, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "cannot get layer info for vector map"
#, fuzzy
-#~ msgid "cannot open database %s by driver %s"
-#~ msgstr "Nie można otworzyÄ bazy danych %s przez sterownik %s"
+msgid "cannot open database %s by driver %s"
+msgstr "Nie można otworzyÄ bazy danych %s przez sterownik %s"
-#~ msgid "cannot create table: %s"
-#~ msgstr "Nie można stworzyÄ tabeli: %s"
+msgid "cannot create table: %s"
+msgstr "Nie można stworzyÄ tabeli: %s"
#, fuzzy
-#~ msgid "cannot create index"
-#~ msgstr "Brak bieżÄ
cego okna"
+msgid "cannot create index"
+msgstr "Brak bieżÄ
cego okna"
-#~ msgid "no record for cat = %d"
-#~ msgstr "Brak rekordu dla cat = %d"
+msgid "no record for cat = %d"
+msgstr "Brak rekordu dla cat = %d"
-#~ msgid "cannot insert row: %s"
-#~ msgstr "Nie można wstawiÄ wiersza: %s"
+msgid "cannot insert row: %s"
+msgstr "Nie można wstawiÄ wiersza: %s"
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "Nie można odnaleÅºÄ pliku wektorowego '%s'"
+msgid "Could not find vector '%s'"
+msgstr "Nie można odnaleÅºÄ pliku wektorowego '%s'"
-#~ msgid "Could not find vector file %s"
-#~ msgstr "Nie można odnaleÅÄ pliku wektorowego %s"
+msgid "Could not find vector file %s"
+msgstr "Nie można odnaleÅÄ pliku wektorowego %s"
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "%s: nie odnaleziono wektorowej mapy <%s>"
+msgid "%s: <%s> vector map not found"
+msgstr "%s: nie odnaleziono wektorowej mapy <%s>"
-#~ msgid "Do not create attribute table."
-#~ msgstr "Nie twórz tabeli atrubutów."
+msgid "Do not create attribute table."
+msgstr "Nie twórz tabeli atrubutów."
-#~ msgid "Could not close new g3d map"
Ä nowej mapy g3d"
+msgid "Could not close new g3d map"
Ä nowej mapy g3d"
#, fuzzy
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s' has finished the transformation of the vectors.\n"
+msgid "'%s' has finished the transformation of the vectors.\n"
+msgstr "'%s' has finished the transformation of the vectors.\n"
-#~ msgid ""
-#~ " CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr ""
-#~ " SPRAWDŹ REZYDUÅA MAPY\n"
-#~ "\n"
+msgid ""
+" CHECK MAP RESIDUALS\n"
+"\n"
+msgstr ""
+" SPRAWDŹ REZYDUÅA MAPY\n"
+"\n"
-#~ msgid " Current Map New Map\n"
-#~ msgstr " BieżÄ
ca mapa Nowa Mapa\n"
+msgid " Current Map New Map\n"
+msgstr " BieżÄ
-#~ msgid ""
-#~ " POINT X coord Y coord | X coord Y coord | "
-#~ "residuals\n"
-#~ msgstr ""
-#~ " PUNKT wspol X wspol Y | wspol X wspol Y | "
-#~ "residua\n"
+msgid ""
+" POINT X coord Y coord | X coord Y coord | "
+"residuals\n"
+msgstr ""
+" PUNKT wspol X wspol Y | wspol X wspol Y | "
+"residua\n"
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "Nnie znaleziono mapy wektorowej '%s'"
+msgid "Vector map '%s' not found"
+msgstr "Nnie znaleziono mapy wektorowej '%s'"
-#~ msgid "Cannot find vector map"
-#~ msgstr "Nie można odnaleÅºÄ mapy wektorowej"
+msgid "Cannot find vector map"
+msgstr "Nie można odnaleÅºÄ mapy wektorowej"
-#~ msgid "Cannot find raster map"
-#~ msgstr "Nie można odnaleÅºÄ mapy rastrowej"
+msgid "Cannot find raster map"
+msgstr "Nie można odnaleÅºÄ mapy rastrowej"
-#~ msgid "Name of existing 3dcell map"
cej mapy 3dcell"
+msgid "Name of existing 3dcell map"
cej mapy 3dcell"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Rysuj siatkÄ geograficznÄ
+msgid "Draw geographic grid"
+msgstr "Rysuj siatkÄ geograficznÄ
-#~ msgid "Output GRASS image file"
-#~ msgstr "WyjÅciowy plik obrazu GRASS'a"
+msgid "Output GRASS image file"
+msgstr "WyjÅciowy plik obrazu GRASS'a"
#, fuzzy
-#~ msgid "Resulting output grid3D volume"
-#~ msgstr "Wynikowa mapa wyjÅciowa"
+msgid "Resulting output grid3D volume"
+msgstr "Wynikowa mapa wyjÅciowa"
-#~ msgid "verbose mode"
-#~ msgstr "pokazuj komunikaty"
+msgid "verbose mode"
+msgstr "pokazuj komunikaty"
-#~ msgid "name for new binary vector file (omit for display to stdout)"
-#~ msgstr ""
-#~ "nazwa nowego vektorowego pliku binarnego (pomiÅ wyÅwietlanie w stdout)"
+msgid "name for new binary vector file (omit for display to stdout)"
+msgstr "nazwa nowego vektorowego pliku binarnego (pomiÅ wyÅwietlanie w stdout)"
-#~ msgid "name for new binary vector file"
-#~ msgstr "nazwa nowego binarnego pliku wektorowego"
+msgid "name for new binary vector file"
+msgstr "nazwa nowego binarnego pliku wektorowego"
-#~ msgid "Query layer"
-#~ msgstr "Warstwa zapytania"
+msgid "Query layer"
+msgstr "Warstwa zapytania"
-#~ msgid "Query column name"
-#~ msgstr "Nazwa kolumny zapytania"
+msgid "Query column name"
+msgstr "Nazwa kolumny zapytania"
-#~ msgid ""
-#~ "GRASS module to create a fractal surface of a given fractal dimension. "
-#~ "Uses spectral synthesis method. Can create intermediate layers showing "
-#~ "the build up of different spectral coefficients (see Saupe, pp.106-107 "
-#~ "for an example of this). Use this module to generate naturally looking "
-#~ "synthetical elevation models (DEM)."
-#~ msgstr ""
-#~ "ModuÅ GRASS'a do tworzenia powierzchni fraktalnych o wymiarze danego "
-#~ "fraktala. Używa metody syntezy fraktalnej. Potrafi tworzyÄ warstwy "
-#~ "poÅrednie ukazujÄ
ce budowÄ różnych wspóÅczynników fraktalnych (zobacz "
-#~ "Saupe, str. 106-107 dla tego przykÅadu). Użyj tego moduÅu aby tworzyÄ "
-#~ "naturalnie wyglÄ
dajÄ
ce sztuczne modele terenu (DEM)."
+msgid ""
+"GRASS module to create a fractal surface of a given fractal dimension. Uses "
+"spectral synthesis method. Can create intermediate layers showing the build "
+"up of different spectral coefficients (see Saupe, pp.106-107 for an example "
+"of this). Use this module to generate naturally looking synthetical "
+"elevation models (DEM)."
+msgstr ""
+"ModuÅ GRASS'a do tworzenia powierzchni fraktalnych o wymiarze danego "
+"fraktala. Używa metody syntezy fraktalnej. Potrafi tworzyÄ warstwy poÅrednie "
+"ukazujÄ
ce budowÄ różnych wspóÅczynników fraktalnych (zobacz Saupe, str. 106-"
+"107 dla tego przykÅadu). Użyj tego moduÅu aby tworzyÄ naturalnie wyglÄ
dajÄ
ce "
+"sztuczne modele terenu (DEM)."
-#~ msgid "Display active frame dimensions"
-#~ msgstr "WyÅwietl wymiary aktywnej ramki"
+msgid "Display active frame dimensions"
+msgstr "WyÅwietl wymiary aktywnej ramki"
-#~ msgid "%s Pan\n"
-#~ msgstr "%s PrzesuÅ\n"
+msgid "%s Pan\n"
+msgstr "%s PrzesuÅ\n"
-#~ msgid "%s Quit menu\n"
-#~ msgstr "%s menu WyjÅcie\n"
+msgid "%s Quit menu\n"
+msgstr "%s menu WyjÅcie\n"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s Wyjdź\n"
+msgid "%s Quit\n"
+msgstr "%s Wyjdź\n"
#, fuzzy
-#~ msgid "Right: "
-#~ msgstr "Prawy: wyjdź\n"
+msgid "Right: "
+msgstr "Prawy: wyjdź\n"
-#~ msgid "%s[%d]: No raster file specified."
-#~ msgstr "%s[%d]: Nie okreÅlono pliku rastrowego."
+msgid "%s[%d]: No raster file specified."
+msgstr "%s[%d]: Nie okreÅlono pliku rastrowego."
#, fuzzy
-#~ msgid "Makes 3D trees from input point vector file"
+msgid "Makes 3D trees from input point vector file"
#, fuzzy
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "WspóÅrzÄdne sÄ
dane w jednostkach mapy"
+msgid "Diameter of the tree crown in map units"
+msgstr "WspóÅrzÄdne sÄ
#, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "Nazwa mapy rastrowej bÄdÄ
cej gridem z informacjÄ
o kosztach "
+msgid "Name of the column with tree crown width"
+msgstr "Nazwa mapy rastrowej bÄdÄ
o kosztach "
-#~ msgid "%s\n"
-#~ msgstr " %s\n"
+msgid "%s\n"
+msgstr " %s\n"
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "PoÅÄ
cz z bazÄ
danych poprzez DBMI."
+msgid "Connect to the database through DBMI."
+msgstr "PoÅÄ
cz z bazÄ
-#~ msgid "Done.\n"
-#~ msgstr "Proces zakoÅczony.\n"
+msgid "Done.\n"
+msgstr "Proces zakoÅczony.\n"
-#~ msgid "Zooming finished.\n"
-#~ msgstr "PowiÄkszenie zakoÅczone.\n"
+msgid "Zooming finished.\n"
+msgstr "PowiÄkszenie zakoÅczone.\n"
-#~ msgid "Read fp map as integer - use map's quant rules"
-#~ msgstr ""
-#~ "Czytaj mapÄ fp jako mapÄ o danych caÅkowitych - użyj regóŠiloÅciowych "
-#~ "mapy"
+msgid "Read fp map as integer - use map's quant rules"
+msgstr ""
+"Czytaj mapÄ fp jako mapÄ o danych caÅkowitych - użyj regóŠiloÅciowych mapy"
-#~ msgid "cover raster map"
-#~ msgstr "wierzchnia mapa rastrowa"
+msgid "cover raster map"
+msgstr "wierzchnia mapa rastrowa"
-#~ msgid "resultant raster map"
-#~ msgstr "wynikowa mapa rastrowa"
+msgid "resultant raster map"
+msgstr "wynikowa mapa rastrowa"
-#~ msgid "Name of existing raster file."
cego pliku rastrowego."
+msgid "Name of existing raster file."
-#~ msgid "Input layer name"
-#~ msgstr "Nazwa warstwy wejsciowej"
+msgid "Input layer name"
+msgstr "Nazwa warstwy wejsciowej"
-#~ msgid "Name of existing input raster file"
cego wejÅciowego pliu rastrowego"
+msgid "Name of existing input raster file"
#, fuzzy
-#~ msgid "display, export"
-#~ msgstr "wyÅwietl, ustaw"
+msgid "Data type"
+msgstr "typ danych"
#, fuzzy
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Nazwa wyjÅciowego pliku (nie dodawaj rozszerzenia)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Nazwa mapsetu (domyÅlnie: bieżÄ
cy)"
#, fuzzy
-#~ msgid "Data type"
-#~ msgstr "typ danych"
+msgid "Icon to remove"
+msgstr "ikona do usuniÄcia"
#, fuzzy
-#~ msgid "Display monitor to start"
-#~ msgstr "Nazwa monitora graficznego który ma byÄ uruchomiony"
+msgid ""
+"mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+"(ercent_cover)"
+msgstr "mile,metry,kilometry,akry,hektary,liczba komórek, procent pokrycia"
#, fuzzy
-#~ msgid "Name of PNG file"
-#~ msgstr "Nazwa pliku etykiety"
+msgid "Run verbosly"
+msgstr "Uruchom z opisem"
#, fuzzy
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "Nazwa mapy wyjÅciowej"
+msgid ""
+"Line: %d \n"
+"Type: %s \n"
+"Left: %d \n"
+"Right: %d \n"
+msgstr "Linia: %d Typ: %s Lewa: %d Prawa: %d "
#, fuzzy
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Rozmiar papieru dla wyjÅcia PostScript"
+msgid ""
+"Node[%d]: %d \n"
+"Number of lines: %d \n"
+"Coordinates: %.6f, %.6f, %.6f\n"
+msgstr " WÄzeÅ [%d]: %d Liczba linii: %d WspóÅrzÄdne: %.6f, %.6f, %.6f\n"
#, fuzzy
-#~ msgid "Split the display into subframes."
-#~ msgstr "wprowadź mapÄ rastrowÄ
do wyÅwietlenia w pierwszej ramce"
+msgid ""
+"Line: %5d \n"
+"Angle: %.8f\n"
+msgstr " Linia: %5d KÄ
t: %.8f\n"
#, fuzzy
-#~ msgid "Number of subframes"
-#~ msgstr "Liczba klatek"
+msgid ""
+"Area: %d \n"
+"Number of isles: %d\n"
+msgstr "Poligon: %d Liczba wysp: %d\n"
#, fuzzy
-#~ msgid "Select multiple points"
-#~ msgstr "typ pliku"
+msgid "Error writing result map file!"
+msgstr "BÅÄ
d zapisu pliku mapy wynikowej!"
#, fuzzy
-#~ msgid "Do not overwrite existing map"
cej mapy rastrowej"
+msgid "DXF input file"
+msgstr "Plik wejÅciowy DXF"
#, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "nie można zamknÄ
Ä mapy wejÅciowej"
+msgid "Create 3D file"
+msgstr "Nazwa mapy wektorowej"
#, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "Utwórz plik 3D"
+msgid "Unable to connect line id %d to line %d"
+msgstr "Nie mozna otworzyÄ pliku wejÅciowego <%s@%s>."
#, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "Unable to read category file for raster map <%s>"
+msgstr "Nie można utworzyÄ mapy rastrowej <%s>"
#, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "Reading %s ... "
+msgstr "Odczytywanie %s ..."
#, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "An output cell map name is required."
+msgstr "Co najmiej dwie mapy rastrowe sÄ
wymagane"
#, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "unable to open cellfile for [%s]"
#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Nazwa mapsetu (domyÅlnie: bieżÄ
cy)"
+msgid "%s - illegal name"
+msgstr "%s: %s - niewÅaÅciwa nazwa"
#, fuzzy
-#~ msgid "Icon to remove"
-#~ msgstr "ikona do usuniÄcia"
+msgid "Cover raster map"
#, fuzzy
-#~ msgid ""
-#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
-#~ "(ercent_cover)"
-#~ msgstr "mile,metry,kilometry,akry,hektary,liczba komórek, procent pokrycia"
+msgid "%s: %s - Unable to find the real-image map."
+msgstr "%s: %s - Nie można odnaleÅºÄ rzeczywistego obrazu."
#, fuzzy
-#~ msgid "Run verbosly"
-#~ msgstr "Uruchom z opisem"
+msgid "%s: %s - Unable to find the imaginary-image."
+msgstr "%s: %s - Nie można znaleÅºÄ urojonego obrazu."
#, fuzzy
-#~ msgid ""
-#~ "Line: %d \n"
-#~ "Type: %s \n"
-#~ "Left: %d \n"
-#~ "Right: %d \n"
-#~ msgstr "Linia: %d Typ: %s Lewa: %d Prawa: %d "
+msgid "Name of the resultant map"
+msgstr "Nazwa mapy wynikowej"
#, fuzzy
-#~ msgid ""
-#~ "Node[%d]: %d \n"
-#~ "Number of lines: %d \n"
-#~ "Coordinates: %.6f, %.6f, %.6f\n"
-#~ msgstr " WÄzeÅ [%d]: %d Liczba linii: %d WspóÅrzÄdne: %.6f, %.6f, %.6f\n"
+msgid "cannot read head of %s"
+msgstr "Nie można odczytaÄ nagÅówka [%s]"
#, fuzzy
-#~ msgid ""
-#~ "Line: %5d \n"
-#~ "Angle: %.8f\n"
-#~ msgstr " Linia: %5d KÄ
t: %.8f\n"
+msgid "Name of the ouput raster map"
+msgstr "TytuÅ wyjÅciowego rastra"
#, fuzzy
+msgid "Name of the output walkers site file"
+msgstr "Nazwa wejÅciowego pliku rastrowego"
+#, fuzzy
+msgid "can't open cell file [%s]"
+msgstr "Nie można otworzyÄ pliku rastra [%s]"
+msgid "Can't create output map"
+msgstr "Nie można utworzyÄ mapy wyjÅciowej:"
+msgid "Name of the resulting map"
+#, fuzzy
+msgid "Name of the output USLE K factor layer"
+msgstr "Nazwa wyjÅciowej mapy rastrowej"
+#, fuzzy
+#~ msgid "Not enough room in history file"
+#~ msgstr "Zbyt maÅo przestrzeni w pliku historii."
+#~ msgid "New MAPSET name"
+#~ msgstr "Nowa nazwa MAPSETu"
+#, fuzzy
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "wypisz parametry bieżÄ
cego poÅÄ
czenia i wyjdź"
+#, fuzzy
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "Kolumna <%s> nie zostaÅa znaleziona w tabeli <%s>"
+#, fuzzy
+#~ msgid "Name of workspace file"
+#~ msgstr "Nazwa pliku etykiety"
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "Lista wartoÅci które majÄ
byÄ wyÅwietlone (mapy FP)"
+#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#~ msgstr ""
+#~ "Ignorowanie listy kategorii: mapa zawiera dane zmiennoprzecinkowe (proszÄ "
+#~ "użyÄ 'val=')"
+#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
+#~ msgstr ""
+#~ "Ignorowanie listy kategorii; mapa zawiera dane caÅkowite (proszÄ użyÄ "
+#~ "'cat=')"
+#, fuzzy
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "Nie można otworzyÄ wektorowego pliku wyjÅciowego '%s'"
#~ msgid ""
-#~ "Area: %d \n"
-#~ "Number of isles: %d\n"
-#~ msgstr "Poligon: %d Liczba wysp: %d\n"
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "Tworzy rastrowe warstwy spadków, ekspozycji, krzywizn i czÄÅciowych "
+#~ "pochodnych z rastrowej mapy rzeczywistych wysokoÅci. Ekspozycja jest "
+#~ "obliczana w kierunku przeciwnym do ruchu wskazówek zegara od wschodu."
+#~ msgid "Raster elevation file name"
+#~ msgstr "Nazwa pliku rastrowego mapy wysokoÅci"
+#~ msgid "Output slope filename"
+#~ msgstr "Nazwa wyjÅciowego pliku spadków"
+#~ msgid "Output aspect filename"
+#~ msgstr "Nazwa wyjÅciowego pliku ekspozycji"
+#~ msgid "Output profile curvature filename"
+#~ msgstr "Nazwa wyjÅciowego pliku krzywizny profilu"
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "Nazwa wyjÅciowego pliku krzywizny tangensa"
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr ""
+#~ "Nazwa wyjÅciowego pliku pochodnej czÄ
stkowej pierwszego rzÄdu dx (spadki "
+#~ "E-W)"
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr ""
stkowej pierwszego rzÄdu dy(spadki N-"
+#~ "S)"
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr "Nazwa pliku pochodnej czÄ
stkowej drugiego rzÄdu dxx"
+#~ msgid "Output second order partial derivative dyy filename"
stkowej drugiego rzÄdu dyy"
+#~ msgid "Output second order partial derivative dxy filename"
stkowej drugiego rzÄdu dxy"
+#~ msgid "wrong type: %s"
+#~ msgstr "zÅy typ: %s"
+#~ msgid "Creating support files..."
+#~ msgstr "Tworzenie plików wsparcia..."
#, fuzzy
-#~ msgid "Error writing result map file!"
-#~ msgstr "BÅÄ
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "Nie można otworzyÄ mapy rastrowej [%s] w [%s]"
+#~ msgid "ASPECT [%s] COMPLETE"
+#~ msgstr "EKSPOZYCJA [%s] UKOÅCZONA"
+#~ msgid "SLOPE [%s] COMPLETE"
+#~ msgstr "SPADEK [%s] UKOÅCZONY"
+#~ msgid "PROFILE CURVE [%s] COMPLETE"
+#~ msgstr "KRZYWIZNA PROFILU [%s] UKOÅCZONA"
+#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
+#~ msgstr "KRZYWIZNA TANGENSA [%s] UKOÅCZONA"
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "SPADKI E-W [%s] UKOÅCZONE"
+#~ msgid "N-S SLOPE [%s] COMPLETE"
+#~ msgstr "SPADKI N-S [%s] UKOÅCZONE"
+#~ msgid "DXX [%s] COMPLETE"
+#~ msgstr "DXX [%s] UKOÅCZONA"
+#~ msgid "DYY [%s] COMPLETE"
+#~ msgstr "DYY [%s] UKOÅCZONA"
+#~ msgid "DXY [%s] COMPLETE"
+#~ msgstr "DXY [%s] UKOÅCZONA"
#, fuzzy
-#~ msgid "DXF input file"
-#~ msgstr "Plik wejÅciowy DXF"
+#~ msgid "Output shaded relief map name"
+#~ msgstr "Wprowadź docelowÄ
nazwÄ sterownika"
#, fuzzy
-#~ msgid "Create 3D file"
-#~ msgstr "Nazwa mapy wektorowej"
+#~ msgid "Layer number of data column"
+#~ msgstr "Liczba warstw (z)"
#, fuzzy
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "Nie mozna otworzyÄ pliku wejÅciowego <%s@%s>."
+#~ msgid "Configuration editor for r.li.'index'"
+#~ msgstr "Plik konfiguracyjny"
#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-#~ msgstr "Nie można utworzyÄ mapy rastrowej <%s>"
+#~ msgid "vector, import, gazetteer"
+#~ msgstr "nazwa wejÅciowego pliku wektorowego"
#, fuzzy
-#~ msgid "Reading %s ... "
-#~ msgstr "Odczytywanie %s ..."
+#~ msgid "vector, centroid, area"
+#~ msgstr "wektor, metadane"
#, fuzzy
-#~ msgid "An output cell map name is required."
-#~ msgstr "Co najmiej dwie mapy rastrowe sÄ
wymagane"
+#~ msgid "raster, elevation, interpolation"
+#~ msgstr "raster, interpolacja"
#, fuzzy
-#~ msgid "unable to open cellfile for [%s]"
+#~ msgid "miscellaneous, projection"
+#~ msgstr "różne"
#, fuzzy
-#~ msgid "%s - illegal name"
-#~ msgstr "%s: %s - niewÅaÅciwa nazwa"
+#~ msgid "vector, report, statistics"
#, fuzzy
-#~ msgid "Cover raster map"
+#~ msgid "vector, color table"
+#~ msgstr "raster do usuniÄcia"
#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-#~ msgstr "nazwa dla nowego obrazu mapy (lives in ~/.gpsdrive)"
+#~ msgid "raster, statistics, aggregation"
+#~ msgstr "raster, statystyki"
#, fuzzy
-#~ msgid "Name of raster map to print in legend"
+#~ msgid "vector, export, GPS"
+#~ msgstr "wctor, eksport"
+#, fuzzy
+#~ msgid "raster, imagery, mosaicking"
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#~ msgstr "wektor, import"
+#, fuzzy
+#~ msgid "Import waypoints"
+#~ msgstr "Zapiywanie %s ..."
+#, fuzzy
+#~ msgid "Import routes"
+#, fuzzy
+#~ msgid "Device or file used to import data"
+#~ msgstr "Plik rastrowy który ma byÄ importowany"
+#, fuzzy
+#~ msgid "imagery, fusion, Brovey"
+#~ msgstr "grupa obrazów, rektyfikuj"
+#, fuzzy
+#~ msgid "vector, raster, statistics"
+#, fuzzy
+#~ msgid "raster, imagery, import"
+#~ msgstr "raster, import"
+#, fuzzy
+#~ msgid "raster, imagery, colors"
+#, fuzzy
+#~ msgid "raster, imagery"
+#~ msgstr "Nazwa mapy rastrowej"
+#, fuzzy
+#~ msgid "raster, mask"
+#~ msgstr "raster, metadane"
+#, fuzzy
+#~ msgid "vector, area, dissolve"
+#, fuzzy
+#~ msgid "sites, vector, import"
+#, fuzzy
+#~ msgid "raster, imagery, statistics"
+#, fuzzy
+#~ msgid "Name of GIS manager settings file (.grc)"
+#~ msgstr "Nazwa istniejÄ
cego pliku MAT-File(v4)"
+#, fuzzy
+#~ msgid "Display manager for GRASS"
+#~ msgstr "WyÅwietl liczbÄ kolorów"
+#, fuzzy
+#~ msgid "Name of .dmrc settings file"
+#, fuzzy
+#~ msgid "Moves displayed maps to another monitor"
+#~ msgstr ""
+#~ "Tworzy i wyÅwietla menu wewnÄ
trz aktywnej ramki w monitorze graficznym."
+#, fuzzy
+#~ msgid "Target monitor"
+#, fuzzy
+#~ msgid "display, export, GPS"
+#~ msgstr "wyÅwietl, wektor"
+#, fuzzy
+#~ msgid "Saves the contents of the active display monitor to a graphics file."
+#~ msgstr "Wymaż zawartoÅÄ aktywnej ramki podanym kolorem"
+#, fuzzy
+#~ msgid "Paper size for PostScript output"
+#~ msgstr "WyjÅciowy plik PostScript"
+#, fuzzy
+#~ msgid "Set transparent background"
+#~ msgstr "Ustawia kolor tÅa menu"
+#, fuzzy
+#~ msgid "Redraws the current display frame in the GRASS monitor"
+#~ msgstr "Podaj nazwy map wyÅwietlonych w monitorze GRASSa"
+#, fuzzy
+#~ msgid "Redraw all frames"
+#~ msgstr "Zapisz wszystkie ramki"
+#, fuzzy
+#~ msgid "Resizes active display monitor"
+#~ msgstr "WyÅwietl informacje na temat aktywnego monitora wyÅwietlania"
+#, fuzzy
+#~ msgid "Slide show of GRASS raster/vector maps."
+#~ msgstr "Importuje starsze wersje wektorowych map GRASS-a."
+#, fuzzy
+#~ msgid "display, slideshow"
+#~ msgstr "wyÅwietl, ustaw"
+#, fuzzy
+#~ msgid "Show vector maps rather than raster maps"
+#~ msgstr "Ustaw region aby dopasowaÄ do mapy rastrowej"
+#, fuzzy
+#~ msgid "Number of seconds to pause between slides"
+#~ msgstr "Liczba punktów do utworzenia"
+#, fuzzy
+#~ msgid "Enter raster map to display in 1st frame"
#~ msgstr "Nazwa wyÅwietanej rastrowej mapy ekspozycji"
#, fuzzy
-#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "wejÅciowa mapa rastrowa (green: tm2 | qbird_green | spot1)"
+#~ msgid "Enter raster map to display in 2nd frame"
+#~ msgstr "Nazwa wyÅwietanej rastrowej mapy ekspozycji"
#, fuzzy
-#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#~ msgid "How to split display"
+#~ msgstr "Tekst który ma byÄ wyÅwietlony"
#, fuzzy
-#~ msgid "Overwrite existing MASK"
cej mapy rastrowej"
+#~ msgid "Exports GRASS raster into GDAL supported formats."
+#~ msgstr "Eksportuje rastrowe mapy GRASS-a do formatów GDAL."
#, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "Problem z odczytem wyników r.stats"
+#~ msgid "C (grid3D file)"
+#~ msgstr "Wprowadź nazwÄ grid3"
#, fuzzy
-#~ msgid "%s: %s - Unable to find the real-image map."
-#~ msgstr "%s: %s - Nie można odnaleÅºÄ rzeczywistego obrazu."
+#~ msgid "Name for output grid3D volume"
+#~ msgstr "Nazwa dla pliku wyjÅciowego"
#, fuzzy
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#~ msgstr "%s: %s - Nie można znaleÅºÄ urojonego obrazu."
+#~ msgid "display, export"
#, fuzzy
-#~ msgid "Name of the resultant map"
-#~ msgstr "Nazwa mapy wynikowej"
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "Nazwa wyjÅciowego pliku (nie dodawaj rozszerzenia)"
#, fuzzy
-#~ msgid "cannot read head of %s"
-#~ msgstr "Nie można odczytaÄ nagÅówka [%s]"
+#~ msgid "Display monitor to start"
+#~ msgstr "Nazwa monitora graficznego który ma byÄ uruchomiony"
#, fuzzy
-#~ msgid "Name of the ouput raster map"
-#~ msgstr "TytuÅ wyjÅciowego rastra"
+#~ msgid "Name of PNG file"
#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#~ msgstr "Nazwa wejÅciowego pliku rastrowego"
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#~ msgstr "Nazwa mapy wyjÅciowej"
#, fuzzy
-#~ msgid "can't open cell file [%s]"
-#~ msgstr "Nie można otworzyÄ pliku rastra [%s]"
+#~ msgid "Number of subframes"
+#~ msgstr "Liczba klatek"
-#~ msgid "Can't create output map"
-#~ msgstr "Nie można utworzyÄ mapy wyjÅciowej:"
+#, fuzzy
+#~ msgid "Do not overwrite existing map"
cej mapy rastrowej"
-#~ msgid "Name of the resulting map"
+#, fuzzy
+#~ msgid "Percentile to calculate (requires -e flag)"
+#~ msgstr "nie można zamknÄ
Ä mapy wejÅciowej"
#, fuzzy
-#~ msgid "Name of the output USLE K factor layer"
-#~ msgstr "Nazwa wyjÅciowej mapy rastrowej"
+#~ msgid "A (grid3D file)"
+#, fuzzy
+#~ msgid "B (grid3D file)"
+#, fuzzy
+#~ msgid "D (grid3D file)"
+#, fuzzy
+#~ msgid "E (grid3D file)"
+#, fuzzy
+#~ msgid "F (grid3D file)"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "Nazwa wejÅciowej mapy rastrowej (red)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+#~ msgid "Region sensitive output"
+#~ msgstr "Problem z odczytem wyników r.stats"
#~ msgid "Input elevation map"
#~ msgstr "WejÅciowa mapa wysokoÅci"
@@ -37155,3 +37099,120 @@
#, fuzzy
#~ msgid "permission denied\n"
#~ msgstr "odmowa dostÄpu"
+#~ msgid "New LOCATION name (not location path)"
+#~ msgstr "Nowa nazwa LOKACJI (nie Åcieżka dostÄpu)"
+#~ msgid "New GISDBASE (full path to the directory where the new location is)"
+#~ msgstr "Nowe GISDBASE (peÅna Åcieżka dostÄpu do nowej lokacji)"
+#~ msgid "Name of graphics monitor to stop"
+#~ msgstr "Nazwa monitora graficznego który ma byÄ zatrzymany"
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr ""
+#~ "Lista kategorii które majÄ
byÄ wyÅwietlone (mapy z danymi caÅkowitymi)"
+#~ msgid "Invert catlist"
+#~ msgstr "OdwrÃ³Ä listÄ kategorii"
+#~ msgid "Area without centroid (may be OK for island)"
+#~ msgstr "Obszar bez centroidu (może byÄ OK dla wysp)"
+#, fuzzy
+#~ msgid "Print all map connection parameters and exit in shell script style"
cego poÅÄ
czenia i wyjdź"
+#, fuzzy
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "nie znaleziono mapy wektorowej <%s>"
+#, fuzzy
+#~ msgid "Width and height of output image"
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr ""
+#~ "WyÅwietla/ustawia ogólne poÅÄ
czenie DB dla bieżÄ
cego mapsetu, nastÄpnie "
+#~ "koÅczy."
+#~ msgid "Name of file with sql statement"
+#~ msgstr "Nazwa pliku z wyrażeniem sql"
+#, fuzzy
+#~ msgid "raster, elevation"
+#, fuzzy
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#~ msgstr "WejÅciowy plik wspóÅrzÄdnych (pomiÅ odczyt z stdin"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Zobrazowanie"
+#, fuzzy
+#~ msgid "PostScript"
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "Kopiowanie tablicy nie powiodÅo siÄ"
+#, fuzzy
+#~ msgid "raster, tiling"
+#~ msgstr "wektor, interpolacja"
+#, fuzzy
+#~ msgid "general, extensions"
+#~ msgstr "ogólne, ustawienia"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "WyÅwietl dostÄpne warstwy i wyjdź"
+#, fuzzy
+#~ msgid "display, diagram"
+#~ msgstr "wyÅwietl, raster"
+#, fuzzy
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Informacje statystyczne dla rastrowych warstw mapy."
+#, fuzzy
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "Mapa rastrowa do próbkowania"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "Nazwa wyÅwietlanej kolumny"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr "oblicza statystyki z mapy rastrowej GRASS"
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#~ msgstr "Nazwa mapy wektorowej"
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "Nazwa rastra(ów) do wÅÄ
czenia do grupy"
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr "Numer warstwy. Jesli -l, wszystkie warstwy sÄ
wyÅwietlane."
+#, fuzzy
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Import binarnego pliku rastrowego do warstwy mapy rastrowej GRASS."
+#, fuzzy
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Mapa rastrowa w której majÄ
byÄ wypeÅnione zera"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_pt.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -13483,9 +13483,8 @@
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
-#, fuzzy
msgid "Level"
-msgstr "Valor do raster"
+msgstr ""
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
@@ -13511,7 +13510,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+msgstr "Não consegui fechar mapa de entrada"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -18919,7 +18918,7 @@
#: ../vector/v.in.db/main.c:176
#, fuzzy
msgid "Writing features..."
-msgstr "Escrevendo arquivo de assinatura %s ..."
+msgstr "Escrevendo [%s]..."
#: ../vector/v.in.db/main.c:183
msgid "Key column must be integer"
@@ -19468,7 +19467,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "Saída de mapa"
+msgstr "Criar saída 3D"
#: ../vector/v.random/main.c:111
#, fuzzy
@@ -21591,11 +21590,8 @@
msgstr "Erro em pj_do_proj"
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
msgstr ""
-"Criar rótulos de pintura para arquivo vetorial do GRASS e atributos "
-"relacionados."
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -24727,7 +24723,7 @@
#: ../vector/v.buffer/main.c:200 ../vector/v.buffer/main.c:209
#, fuzzy
msgid "Distance"
-msgstr "Zonas de distância"
+msgstr "Tabela faltando"
#: ../vector/v.buffer/main.c:177
#, fuzzy
@@ -25505,9 +25501,8 @@
msgstr "Nome da Fonte"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "nome=%s\n"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -25961,7 +25956,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "Separador de Campos"
+msgstr "Mostra as estatísticas em estilo shell script"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -29166,8 +29161,9 @@
msgstr "Raiz de para em atual não"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
+#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
+msgstr "Raiz de para em atual não"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
#, fuzzy
@@ -29281,8 +29277,11 @@
msgstr "Entrada mapear é em"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
msgstr ""
+"Cria novo vetor (pontos) a partir de tabela do banco de dados contento "
+"coordenadas."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
#, fuzzy
@@ -29627,8 +29626,9 @@
msgstr "ícone para remover"
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
+#, fuzzy
msgid "Category number starting value"
-msgstr ""
+msgstr "Nome da coluna categoria"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
@@ -29715,20 +29715,24 @@
msgstr "Camada para"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+#, fuzzy
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
+msgstr "Altura fixa para objetos vetoriais 3D"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#, fuzzy
msgid "use transformation rules for LANDSAT-4"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#, fuzzy
msgid "use transformation rules for LANDSAT-5"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+#, fuzzy
msgid "use transformation rules for LANDSAT-7"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
#, fuzzy
@@ -29905,8 +29909,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "Nome do mapa raster a ser usado para <%s>"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#, fuzzy
@@ -30251,7 +30256,11 @@
#: ../imagery/i.pca/main.c:72
#, fuzzy
msgid "Name of two or more input raster maps"
-msgstr "Nome do Raster de entrada"
+msgstr ""
+"#-#-#-#-# grassmods_pt_br.po (grassmods_pt_br) #-#-#-#-#\n"
+"Nome do raster de entrada\n"
+"Nome do mapa raster de entrada"
#: ../imagery/i.pca/main.c:75
#, fuzzy
@@ -32466,6 +32475,303 @@
"Não posso marcar outro ponto. Somente %d pontos permitidos. Desculpe."
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr ""
+"Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "Arquivo raster para importar"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "Arquivo ASCII contendo assinaturas espectrais"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "Estatísticas de transição de classe."
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "Relatório de estatísticas para mapas raster."
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "<%s> criados na base de dados."
+#, fuzzy
+msgid "report"
+msgstr "Importar"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Não consegui escrever cabeçalho para [%s]."
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "Erro lendo coringa."
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+msgstr "Erro lendo arquivo raster [%s]."
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Não consegui abrir mapa raster [%s] em [%s]"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "Não consegui ler região <%s> em <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+msgstr "Não consegui abrir mapa raster [%s]."
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "Não consegui abrir arquivo de saída <%s>."
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "Não consegui obter linha %d (erro = %d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "para para!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Não consegui ler linha %i\n"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Não consegui iniciar o driver '%s'."
+#, fuzzy
+msgid "unable to open accumulation map layer"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "Erro escrevendo linha nula [%d]."
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "Nome do mapa raster existente contendo isolinhas"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "Máscara: %s\n"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+msgstr "Não consegui criar arquivo raster [%s]."
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "Lendo arquivo dig_att...\n"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Não consegui escrever em <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "Não consegui abrir o arquivo [%s]"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "Nome do Raster de saída"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "nome=%s\n"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Nome do arquivo de rótulos"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Número de quadros"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "Inportação de vetor incompleta"
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD"
+msgstr "Por cento:"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "%s: %s - Não encontrei o mapa imagem real."
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"Impossível abrir imagem real do diretório cell_misc.\n"
+"Mapa de entrada provavelmente não foi criado por i.fft"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "%s: %s - Não encontrei o mapa imaginário"
+#, fuzzy
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"Impossível abrir mapa imaginário no diretório cell_misc.\n"
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "Grupo <%s> não encontrado."
+#, fuzzy
+msgid "Range less than or equal to zero not allowed."
+msgstr "Limite menor ou igual a zero não permitido."
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "Escrevendo versões visíveis do dado transformado para arquivos ..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+msgstr "Impossível abrir arquivo do diretório cell_misc."
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+msgstr "** Não consigo semear arquivo de assinatura <%s> **"
+#, fuzzy
+msgid "Can't read signature file <%s>"
+msgstr "Não consegui ler o arquivo de assinatura [%s]."
+#, fuzzy
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr "Nome de mapear destino ativo."
+#, fuzzy
+msgid ""
+"Name of old database. The database must be in form printed by v.db.connect -"
+"g, i.e. with substituted variables"
+msgstr "Nome de banco de dados banco de dados em substituído"
+#, fuzzy
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "mapear imagem em"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Escrevendo arquivo raster %i\n"
+#, fuzzy
+msgid "Use output= option to change vector map name"
+msgstr "Usar opção output= para alterar o nome do mapa vetor"
+#, fuzzy
+msgid "Erasing monitors ..."
+msgid "Category file for [%s] not available"
+msgstr "Arquivo de categorias para [%s] não disponível"
+msgid "color file for [%s] not available"
+msgstr "Arquivo de cores para [%s] não disponível"
+#, fuzzy
#~ msgstr "Memória insuficiente para az"
@@ -32482,11 +32788,6 @@
#~ msgstr "Nome do arquivo de rótulos"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr ""
-#~ "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
-#, fuzzy
#~ msgstr "Lista de valores de célula para mascarar"
@@ -32586,13 +32887,6 @@
#~ msgstr "DXY [%s] COMPLETA"
#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
-#, fuzzy
#~ msgstr "Nome do Arquivo raster de elevação"
@@ -32604,14 +32898,6 @@
#~ msgstr "Camada para"
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "Arquivo raster para importar"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "Arquivo ASCII contendo assinaturas espectrais"
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Gera uma camada raster mostrando as sub-bacias de drenagem."
@@ -32718,10 +33004,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr " saída para uma classe topográfica índice"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "Estatísticas de transição de classe."
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "Nome do mapa raster contendo a superfície"
@@ -32781,18 +33063,6 @@
#~ msgid "Unable to access table <%s>"
#~ msgstr "Não consegui abrir arquivo de saída <%s>."
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Converte mapas raster 3D (G3D) para o formato VTK-ASCII"
@@ -32809,10 +33079,6 @@
#~ "região atualmente definida."
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "Mostra as estatísticas em estilo shell script"
-#, fuzzy
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -32825,10 +33091,6 @@
#~ msgstr "Nenhum monitor selecionado"
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Relatório de estatísticas para mapas raster."
-#, fuzzy
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "Impossível criar <Tabela_auxiliar_dos_desvios>"
@@ -32840,10 +33102,6 @@
#~ "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "<%s> criados na base de dados."
-#, fuzzy
#~ msgid "M.Q. solution"
#~ msgstr "Resolução"
@@ -32913,18 +33171,10 @@
#~ msgstr "Não consegui ler arquivo raster agora."
#, fuzzy
-#~ msgid "report"
-#~ msgstr "Importar"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Não consegui escrever cabeçalho para [%s]."
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "Não consegui escrever o arquivo temporário."
@@ -32977,10 +33227,6 @@
#~ msgstr "Não consegui escrever em <%s>"
#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "Erro lendo coringa."
-#, fuzzy
#~ msgid "Reading row %d"
#~ msgstr "\rLendo arquivo [%s] ..."
@@ -33080,10 +33326,6 @@
#~ msgstr "Não encontrei %s"
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#~ msgstr "Erro lendo arquivo raster [%s]."
-#, fuzzy
#~ msgid "Error in pipe creation"
#~ msgstr "Erro em pj_do_proj"
@@ -33124,14 +33366,6 @@
#~ msgstr "Não encontrei mapa raster"
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Não consegui abrir mapa raster [%s] em [%s]"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "Não consegui ler região <%s> em <%s>"
-#, fuzzy
#~ msgid "Unable to get header for %s"
@@ -33140,18 +33374,6 @@
#~ msgstr "Mostra a região atual"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#~ msgstr "Não consegui abrir mapa raster [%s]."
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "Não consegui abrir arquivo de saída <%s>."
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
#~ msgstr "Editar arquivo de categorias para [%s]?"
@@ -33196,22 +33418,6 @@
#~ msgstr "Erro na leitura do mapa raster de entrada."
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "Não consegui obter linha %d (erro = %d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "para para!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
#~ msgstr "Não consegui criar arquivo raster [%s]."
@@ -33242,10 +33448,6 @@
#~ msgstr "Erro escrevendo linha nula [%d]."
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Não consegui ler linha %i\n"
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr "Coluna %d definida como inteiro só possui valores double"
@@ -33261,10 +33463,6 @@
#~ msgstr "Lendo arquivo dig_att...\n"
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Não consegui iniciar o driver '%s'."
-#, fuzzy
#~ msgid "Invalid region: %s"
#~ msgstr "região inválida: %s"
@@ -33325,14 +33523,6 @@
#~ msgstr "Não consegui abrir os arquivos das bandas."
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "Escrevendo [%s]..."
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
@@ -33353,14 +33543,6 @@
#~ msgstr "Não consegui abrir o mapa de células MASK."
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "Erro escrevendo linha nula [%d]."
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Nome do mapa raster existente contendo isolinhas"
-#, fuzzy
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "Número de vezes para repetir o filtro"
@@ -33479,14 +33661,6 @@
#~ msgstr "Escrevendo arquivo raster %i\n"
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
@@ -33509,10 +33683,6 @@
#~ msgstr "Tabela <%s> não existe no banco de dados <%s>"
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Máscara: %s\n"
-#, fuzzy
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "Criando tabela auxiliar para arquivar zonas adjacentes"
@@ -33689,21 +33859,9 @@
#~ msgstr "Região atual não pode ser ajustada."
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Não consegui criar arquivo raster [%s]."
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Lendo arquivo dig_att...\n"
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "Não consegui alocar memória para 'string'"
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
#~ msgid "Unable to open the cell map MASK."
@@ -33724,14 +33882,6 @@
#~ msgid "Unable to open band files."
-#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Não consegui escrever em <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
#~ msgid "Error while reading input raster map."
@@ -33741,22 +33891,6 @@
#~ msgid "Error writing cell map during transform."
#~ msgstr "Erro na escrita do mapa de células durante a transformação."
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "Não consegui abrir o arquivo [%s]"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
#~ msgid "Could not open <%s>"
#~ msgstr "Não consegui abrir <%s>"
@@ -33764,18 +33898,6 @@
#~ msgstr "Não consegui ler de <%s>"
#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "Nome do Raster de saída"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
#~ msgid "Error reading row of data"
@@ -34037,22 +34159,6 @@
#~ msgstr "Nome do grupo de imagens"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "nome=%s\n"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "Nome do arquivo de rótulos"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Número de quadros"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "Nome do arquivo para o resultado da classificação"
@@ -34404,10 +34510,6 @@
#~ msgstr "Alterado para"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "Inportação de vetor incompleta"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
@@ -34464,10 +34566,6 @@
#~ msgstr "Não consegui ler MASK"
#, fuzzy
-#~ msgid "SECTION 3: Accumulating Surface Flow with MFD"
-#~ msgstr "Por cento:"
-#, fuzzy
#~ msgid "unable to open MASK"
@@ -34475,10 +34573,6 @@
#~ msgstr "Mapa de saída: útil para exibição visual dos resultados"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "Arquivo raster para superfície"
@@ -34608,30 +34702,6 @@
#~ msgid "Output inverse raster map after IFFT"
#~ msgstr "Título do raster de saída após ifft"
-#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "%s: %s - Não encontrei o mapa imagem real."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Impossível abrir imagem real do diretório cell_misc.\n"
-#~ "Mapa de entrada provavelmente não foi criado por i.fft"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "%s: %s - Não encontrei o mapa imaginário"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "Impossível abrir mapa imaginário no diretório cell_misc.\n"
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "Valores ao quadrado : [%d} linhas [%d] colunas."
@@ -34734,10 +34804,6 @@
#~ msgid "Run quietly"
#~ msgstr "Executa silenciosamente"
-#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "Grupo <%s> não encontrado."
#~ msgid "Subgroup [%s] not found."
#~ msgstr "Subrupo <%s> não encontrado."
@@ -34792,10 +34858,6 @@
#~ msgid "Range of values in output display files"
#~ msgstr "Limite dos valores nos arquivos de saída"
-#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "Limite menor ou igual a zero não permitido."
#~ msgid "Initializing data...\n"
#~ msgstr "Inicializando dados ...\n"
@@ -34806,14 +34868,6 @@
#~ msgstr "FFT concluída..."
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "Escrevendo versões visíveis do dado transformado para arquivos ..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "Impossível abrir arquivo do diretório cell_misc."
-#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
@@ -34835,14 +34889,6 @@
#~ msgid "Unable to proceed"
#~ msgstr "Impossível prosseguir"
-#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "** Não consigo semear arquivo de assinatura <%s> **"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "Não consegui ler o arquivo de assinatura [%s]."
#~ msgid "Group of imagery files to be clustered"
#~ msgstr "Grupo de arquivos de imagens a ser agrupados"
@@ -34876,16 +34922,6 @@
#~ msgstr "Marque os pontos de controle no solo para retificar a imagem."
#, fuzzy
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
-#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr "Nome de mapear destino ativo."
-#, fuzzy
#~ msgid "Unable to read head of %s"
@@ -34958,12 +34994,6 @@
#~ msgstr "para"
#, fuzzy
-#~ msgid ""
-#~ "Name of old database. The database must be in form printed by v.db."
-#~ "connect -g, i.e. with substituted variables"
-#~ msgstr "Nome de banco de dados banco de dados em substituído"
-#, fuzzy
#~ msgstr "Nome de um arquivo MAT (v4) existente"
@@ -35420,10 +35450,6 @@
#~ msgstr "Exibir"
#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "mapear imagem em"
-#, fuzzy
#~ msgid "Make JPEG instead of PNG image"
#~ msgstr "JPEG de imagem"
@@ -35791,10 +35817,6 @@
#~ msgstr "Lendo mapa"
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Escrevendo arquivo raster %i\n"
-#, fuzzy
#~ msgid "Output raster map with lake"
#~ msgstr "Mapa raster de saída"
@@ -36210,10 +36232,6 @@
#, fuzzy
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr "Usar opção output= para alterar o nome do mapa vetor"
-#, fuzzy
#~ msgid "Cannot open new vector map <%s>"
#~ msgstr "%s: Novo arquivo vetorial não pode ser aberto"
@@ -36784,10 +36802,6 @@
#~ msgstr "Opção Geo-Grid não disponível para projeção XY"
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#, fuzzy
#~ msgid "Could not open input file <%s>."
#~ msgstr "Não consegui abrir arquivo vetorial <%s>"
@@ -36953,9 +36967,6 @@
#~ msgid "Creating support files for [%s]."
#~ msgstr "Criando arquivos de suporte para [%s]."
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "Arquivo de categorias para [%s] não disponível"
#~ msgid "%s: <%s> raster map not found"
#~ msgstr "%s: <%s> mapa raster não encontrado"
@@ -37668,9 +37679,6 @@
#~ msgid "Raster map [%s] not available"
#~ msgstr "Arquivo raster [%s] não disponível"
-#~ msgid "color file for [%s] not available"
-#~ msgstr "Arquivo de cores para [%s] não disponível"
#~ msgid "Raster file [%s] not available"
@@ -39290,3 +39298,1672 @@
#~ "Displays the rhumbline joining two user-specified points, in the active "
#~ "frame on the user's graphics monitor."
#~ msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Converte uma camada raster 3D para um arquivo de texto ASCII"
+#, fuzzy
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr "Converte um arquivo raster ASCII 3D para um mapa raster 3D binário."
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Lendo arquivo dig_att...\n"
+#~ msgid ""
+#~ "Cannot create mask file: G3D_MASK already exists!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+#~ msgstr ""
+#~ "Não consegui criar arqivo máscara: G3D_MASK já existe!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' para remover a máscara existente."
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "Exporta um raster 3D do GRASS para um arquivo Vis5D"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "Exporta mapa raster do GRASS para arquivo GRIDATB.FOR (TOPMODEL)"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "Nome do mapa raster"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr ""
+#~ "Converte uma camada raster num campo de altura (height field) para o "
+#~ "POVRAY."
+#, fuzzy
+#~ msgid "raster, map algebra"
+#~ msgstr "Inportação de vetor incompleta"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "Converte uma camada raster para um arquivo de texto ASCII"
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "Escrevendo [%s]..."
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "Não encontrei mapset para %s"
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "Importar como dado 'floating point' (padrão: inteiro)"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr "Importar como dado 'double precision' (padrão: inteiro)"
+#, fuzzy
+#~ msgid "Parsing bytes per cell"
+#~ msgstr " Número de bytes por célula"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#~ msgid "Update the statistics (histogram, range) for [%s]? "
+#~ msgstr "Atualizar estatísticas (histograma, intervalo) para [%s]?"
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "Escrevendo arquivo raster %i\n"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Nome do Raster de saída"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#~ msgstr "Interpolando mapa raster <%s> ... %d linhas ..."
+#, fuzzy
+#~ msgid "raster, statistics"
+#~ msgstr "Estatísticas de transição de classe."
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Converte mapas raster para o formato VTK-ASCII"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "Número de pontos de interpolação"
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "Sem tabela"
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#~ msgstr "Não encontrei linha com cat %s"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr ""
+#~ "#-#-#-#-# grassmods_pt_br.po (grassmods_pt_br) #-#-#-#-#\n"
+#~ "Nome do raster de entrada\n"
+#~ "Nome do mapa raster de entrada"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Nome do raster de entrada"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr ""
+#~ "Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Nome do arquivo raster com o albedo do solo [-]"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "Nome do novo arquivo raster"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Gera arquivo com a direção da encosta"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Gera uma mapa de direções"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Gera mapa raster de drenagem"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "Gera arquivo raster com a curvatura média"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Gera arquivo com a declividade"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução "
+#~ "da região atualmente definida."
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "Não consegui abrir arquivo de células [%s]"
+#, fuzzy
+#~ msgid "raster, buffer"
+#~ msgstr "Mapa raster de entrada"
+#, fuzzy
+#~ msgid "raster, series"
+#~ msgstr "Mapa raster a ser amostrado"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Mapa de Entrada: quantidade de fluxo superficial por célula"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "Mapa de entrada: terreno bloqueando fluxo superficial, para USLE"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Mapa de saída: número de células que drenam através de cada célula"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "Mapa de saída: rótulo único para cada bacia de drenagem"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "Mapa de saída: um valor único é dado para cada meia-bacia"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr ""
+#~ "Saída de mapa: fator de comprimento do declive e declividade (LS) para "
+#~ "USLE"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "Saída de mapa: fator de comprimento de declividade (S) para USLE"
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "Mapa de entrada: tamanho mínimo de bacias de drenagem exteriores"
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr ""
+#~ "Valor de entrada: comprimento máximo para fluxo superficial, para USLE"
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "de\n"
+#~ " fluxo\n"
+#~ " limiar limiar."
+#, fuzzy
+#~ msgid ""
+#~ "USAGE for basin delineation:\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "\n"
+#~ "USAGE for ARMSED FILE creation:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "\n"
+#~ "USAGE for slope length determination:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
+#~ msgstr ""
+#~ "mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo "
+#~ "mapear mapear limiar mapear mapear mapear mapear exibir mapear mapear "
+#~ "fluxo mapear mapear comprimento mapear limiar mapear mapear mapear exibir "
+#~ "mapear comprimento Bloqueio mapear mapear LS comprimento mapear mapear "
+#~ "mapear"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "Não consegui abrir o mapa de células MASK."
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "Erro na escrita do arquivo 'colr' para <%s>."
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programa para conversão de uma série de arquivos para MPEG."
+#, fuzzy
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Filtra e gera um mapa de elevação sem depressões e uma direção de fluxo a "
+#~ "partir de um mapa de elevação fornecido"
+#~ msgid "Output direction raster map"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "Gera um mapa das áreas problemáticas"
+#, fuzzy
+#~ msgid "raster, resample"
+#, fuzzy
+#~ msgid "Cannot read ew_res value"
+#~ msgstr "Não consegui criar árvore"
+#, fuzzy
+#~ msgid "Cannot read ns_res value"
+#, fuzzy
+#~ msgid "[%s]: Map is the wrong resolution"
+#~ msgstr "Mapa é"
+#~ msgid "Cannot get row %d (error = %d)"
+#~ msgstr "Não consegui obter linha %d (erro = %d)"
+#, fuzzy
+#~ msgid "Cannot set region to back to the initial region !!!"
+#~ msgstr "para para!"
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
+#~ "will be rounded to integer!"
+#~ msgstr "mapear em é mapear Decimal para!"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr ""
+#~ "Programa para geração de superfícies a partir de isolinhas rasterizadas."
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "Nome do mapa raster existente contendo isolinhas"
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Cria/Modifica a tabela de cores associada com uma camada raster."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Mapa raster do qual copiarei a tabela de cores"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "Arquivo raster de entrada (imagem FFT, parte real)"
+#, fuzzy
+#~ msgid ""
+#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
+#~ "be specified!"
+#~ msgstr "Um de!"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "Não consegui criar camada"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "Não consegui criar o mapa de saída"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "Não consegui criar a tabela %s"
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#~ msgstr "Arquivo raster para importar"
+#, fuzzy
+#~ msgid "raster, null data"
+#~ msgstr "vetor, metadados"
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "Gera um mapa raster com áreas contíguas acrescidas de uma célula"
+#, fuzzy
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Mapa de bacias criado por r.water.outlet"
+#, fuzzy
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) Mapa de direção com mapa de elevação sem depressões"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) Número de classes de índice topográfico"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(o/i) Arquivo índice das estatísticas topográficas"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) Arquivo de parâmetros TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "(i) Arquivo de dados de precipitação e evapotranspiração"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "Calcula áreas de sombra a partir da posição do sol e de um modelo de "
+#~ "elevação digital. Deve ser especificada A: posição exata do sol ou B: "
+#~ "data e hora para cálculo da posição por r.sunmask."
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: altitude do Sol sobre o horizonte, graus"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: azimute do Sol a partir do norte, graus"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: minuto (0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: segundos (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: fuso horário (leste positivo, diferença de GMT, também usar para "
+#~ "compensar horário de verão)"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Cria um novo mapa cujas categorias são baseadas na reclassificação do "
+#~ "usuário sobre as categorias de um mapa raster existente."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "Mapa raster a ser reclassificado"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "Converte um mapa raster em uma camada de mapa vetorial."
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "Coordenadas Este do mapa"
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "Não consegui escrever em <%s>"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#~ msgstr "fp: intervalo de dados é %.25f a %.25f\n"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#~ msgstr "O intervalo de dados é de %ld a %ld\n"
+#, fuzzy
+#~ msgid "'%s' is not a valid rule"
+#~ msgstr "é não mapear"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#, fuzzy
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr "de"
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#, fuzzy
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "de"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "Converte um arquivo raster ASCII para um mapa raster binário."
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "Mostra os rótulos de categoria na célula da malha"
+#, fuzzy
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#~ msgstr "Não consegui abrir mapa raster [%s]."
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "Tipo da coluna não suportado"
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Converte um raster ASCII (GRID) do ESRI ARC/INFO em uma camada raster "
+#~ "binária."
+#, fuzzy
+#~ msgid "File containing weights"
+#~ msgstr "Arquivo contendo declarações SQL"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "general, settings"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "Formato OGR."
+#, fuzzy
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#~ msgstr "Não consegui ler arquivo de cores."
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "Cor para desenhas X's (valores nulos)"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "nome=%s\n"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitor: esperava waitpid %d mas obtive %d\n"
+#, fuzzy
+#~ msgid "display, networking"
+#~ msgstr "Exibir"
+#~ msgid ""
+#~ "Identifies the geographic coordinates associated with point locations in "
+#~ "the active frame on the graphics monitor."
+#~ msgstr ""
+#~ "Identifica as coordenadas geográficas associadas com locações no quadro "
+#~ "ativo do monitor gráfico"
+#~ msgid "Command mode (Compatibility with d.text)"
+#~ msgstr "Modo de comando (compatibilidade com d.text)"
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Pelo menos o texto ou '-c' devem ser fornecidos."
+#~ msgid "Unable to create face"
+#~ msgstr "Não consegui criar face"
+#~ msgid "Unable to set size"
+#~ msgstr "Não consegui definir tamanho"
+#~ msgid "Text conversion error"
+#~ msgstr "Erro na conversão de texto"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#~ msgstr "Erro na leitura do mapa raster de entrada."
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "Arquivo de cores para [%s] não disponível"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr "Arquivo de categorias para [%s] não disponível"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr ""
+#~ "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+#~ msgstr "Lista de categorias para exibir (mapas INT)"
+#, fuzzy
+#~ msgstr "Inverter catlist"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#~ msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "Não consegui ler símbolos, não consegui exibir pontos"
+#~ msgid "Vector map attribute column to use for comparison"
+#~ msgstr "Nome da coluna de atributos do vetor para usar como comparação"
+#~ msgid "Vector map to store differences"
+#~ msgstr "Mapa vetorial para armazenas diferenças"
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "Fator de escala opcional para valores lidos do mapa raster. Valores "
+#~ "amostrados serão multiplicados por esse fator."
+#, fuzzy
+#~ msgid "%d new points written to output"
+#~ msgstr "%d pontos escrito no mapa de saída\n"
+#, fuzzy
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "Exporta um raster do GRASS para um arquivo binário"
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "Camada número"
+#, fuzzy
+#~ msgid "Query layer number (read from)"
+#, fuzzy
+#~ msgid "vector, interpolation"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgstr ""
+#~ "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
+#, fuzzy
+#~ msgid "Vector based generalization."
+#, fuzzy
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr ""
+#~ "Criar rótulos de pintura para arquivo vetorial do GRASS e atributos "
+#~ "relacionados."
+#, fuzzy
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
+#, fuzzy
+#~ msgid "Total area: %e (%d areas)"
+#, fuzzy
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "Centróide da área sem categoria"
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada "
+#~ "raster 3D do GRASS."
+#, fuzzy
+#~ msgid "vector, extract"
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr "Perturbações aleatórias nos pontos do GRASS"
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "Parâmetro(s) da distribuição. Se a distribuição é uniforme, apenas o "
+#~ "máximo é necessário. Para uma distribuição normal, a média e o desvio "
+#~ "padrão são necessários."
+#, fuzzy
+#~ msgid "Layer number (from)"
+#, fuzzy
+#~ msgid "Layer number (to)"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr "Gera mapa de pontos 2D/3D do GRASS aleatóriamente."
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "Não consegui usar a coluna '%s'"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "Converter um mapa vetorial binárido GRASS em saída ASCII VTK"
+#, fuzzy
+#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#~ msgstr "%d pontos fora da região atual."
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS num mapa vetorial GRASS ASCII"
+#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
+#~ msgstr ""
+#~ "Caminho para o arquivo ASCCI resultante ou nome do vetor ASCII se '-o' "
+#~ "foi definido"
+#, fuzzy
+#~ msgid "Parameter '%s' ignored in standard mode"
+#~ msgstr "parâmetro para"
+#, fuzzy
+#~ msgid "vector, geometry"
+#~ msgstr "Arquivo vetorial para criar"
+#, fuzzy
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr "Usar opção output= para alterar o nome do mapa vetor"
+#, fuzzy
+#~ msgid "Output quadrant centres, number of points is written as category"
+#~ msgstr ""
+#~ "Resultados dos centros dos quadrados, o número de pontos é escrito como "
+#~ "categoria"
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "Contando locais no quadrado..."
+#, fuzzy
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "Duas camadas devem ser especificadas"
+#, fuzzy
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "Converter para um dos formatos vetoriais suportados pelo OGR."
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "Exportar apenas feições com categorias. De outro modo, todas as feições "
+#~ "serão exportadas."
+#~ msgid "Key column '%s' not found"
+#~ msgstr "Coluna chave '%s' não encontrada"
+#, fuzzy
+#~ msgid "Exporting %i points/lines..."
+#, fuzzy
+#~ msgid "%d features written"
+#~ msgstr "%d pontos escritos no vetor"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "Esta opção requer ao menos duas colunas"
+#, fuzzy
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS pela combinação de outros "
+#~ "camadas de mapa vetorial."
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#~ msgid "vector, metadata"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Cria um buffer ao redor de feições de um determinado tipo (áreas devem "
+#~ "conter centróide)"
+#~ msgid "Buffer distance in map units"
+#~ msgstr "Distância do buffer (em unidades do mapa)"
+#, fuzzy
+#~ msgid "Use the distance option instead of the buffer option."
+#~ msgstr "Usar rotação em radianos ao invés de graus"
+#, fuzzy
+#~ msgid "vector, querying"
+#, fuzzy
+#~ msgid "Queries a vector map layer at given locations."
+#~ msgstr "Pesquisa um mapa vetorial em pontos determinados"
+#, fuzzy
+#~ msgid "If not given reads from standard input"
+#~ msgstr ""
+#~ "Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+#~ "entrada padrão"
+#, fuzzy
+#~ msgid "vector, transformation"
+#, fuzzy
+#~ msgid "Copying vector objects from vector map <%s>..."
+#, fuzzy
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Mapa de entrada contendo linhas"
+#, fuzzy
+#~ msgid "Name for output vector map where segments will be written"
+#~ msgstr "Mapa de saída no qual os pontos serão gravados"
+#, fuzzy
+#~ msgid "Tests for normality for points."
+#~ msgstr "pontos."
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Calcula estatísticas univariadas para atributo. Variância e desvio padrão "
+#~ "é calculado apenas para pontos se especificado."
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#~ msgstr "Não consegui calcular centróide da área."
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS numa camada raster do GRASS."
+#, fuzzy
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr "Cria pontos ao longo das linhas de entrada"
+#, fuzzy
+#~ msgid "%d points written to output vector map"
+#~ msgstr "[%d] pontos escritos no vetor"
+#, fuzzy
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr ""
+#~ msgid ""
+#~ "Number of column used as y coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Número da coluna usada como coordenada y (primeira coluna é 1) para o "
+#~ "modo de pontos"
+#, fuzzy
+#~ msgid ""
+#~ "Number of column used as z coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ "Number of column used as category (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Número da coluna usada como coordenada x (primeira coluna é 1) para o "
+#, fuzzy
+#~ msgid ""
+#~ "If 0, unique category is assigned to each row and written to new column "
+#~ "'cat'"
+#~ msgstr ""
+#~ "Número da coluna usada como categoria (primeira coluna é 1) para o modo "
+#~ "de pontos. Se 0, uma categoria única é designada para cada linha e "
+#~ "escrita na nova coluna cat"
+#, fuzzy
+#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
+#~ msgstr "Cria um novo mapa vazio e sai. Nada é lido da entrada"
+#, fuzzy
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr ""
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "Tolerância em unidades de mapa, um valor para cada ferramenta (padrão: 0.0"
+#~ "[,0.0,...])"
+#, fuzzy
+#~ msgid "Copying vector lines..."
+#~ msgstr "Verificando pontos vetoriais ..."
+#, fuzzy
+#~ msgid "%d lines / boundaries removed"
+#, fuzzy
+#~ msgid "Duplicate area centroids: %5d"
+#~ msgstr "Não consegui calcular área do centróide."
+#, fuzzy
+#~ msgid "Attribute table column with values to interpolate"
+#~ msgstr ""
+#, fuzzy
+#~ msgid "No data points found"
+#~ msgstr "%s: nenhum ponto de dados encontrado"
+#~ msgid "Attribute column to use for buffer distances"
+#~ msgstr "Nome da coluna de atributo a usar como distância dos buffers"
+#, fuzzy
+#~ msgid "Lines buffers... "
+#~ msgstr "Encontrando classes de treinamento..."
+#, fuzzy
+#~ msgid "Error reading ASCII file: '%s'"
+#~ msgstr "Erro na leitura do arquivo de categorias para <%s>."
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#~ msgstr ""
+#~ "Imprime informações básicas sobre uma camada de mapa vetorial "
+#~ "especificada pelo usuário."
+#, fuzzy
+#~ msgid "Map format: %s"
+#~ msgstr " %s"
+#, fuzzy
+#~ msgid "Name of creator: %s"
+#, fuzzy
+#~ msgid " Comments:"
+#~ msgstr " média "
+#, fuzzy
+#~ msgid "Extrudes flat vector object to 3D with defined height."
+#~ msgstr "Extruda vetores 2D para 3D com alturas definidas"
+#, fuzzy
+#~ msgid "Output surface raster map (elevation)"
+#~ msgstr "Gerar arquivo raster da superfície (elevação)"
+#, fuzzy
+#~ msgid "Output cross-validation errors vector point file"
+#~ msgstr "Nome do mapa de pontos de validação cruzada para saída"
+#, fuzzy
+#~ msgid "Output vector map showing quadtree segmentation"
+#~ msgstr "Saída de arquivo vetorial mostrando segmentação"
+#, fuzzy
+#~ msgid "Output vector map showing overlapping windows"
+#~ msgstr "Saída de vetor mostrando segmentos sobrepostos"
+#, fuzzy
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "Nome da coluna de atributos com valores para interpolar (se >0 camada)"
+#~ msgid "Cannot write raster maps -- try to increase resolution"
+#~ msgstr ""
+#~ "Não consegui escrever arquivo de células -- tente aumentar a resolução"
+#, fuzzy
+#~ msgstr "Mostra os parâmetros de conexão atuais e finaliza"
+#, fuzzy
+#~ msgstr "mapa vetorial <%s> não encontrado"
+#, fuzzy
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#, fuzzy
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "Não consegui determinar o tipo de célula raster."
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#~ msgid "Verbose module output"
+#~ msgstr "Modo verboso"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "Nome de um arquivo para gravar a saída do relatório"
+#, fuzzy
+#~ msgstr "Largura do destaque colorido"
+#, fuzzy
+#~ msgid "Surface"
+#~ msgstr "Variância da soma"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "coluna(s)"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "Driver OGR : coluna '%s', tipo OGR %d não é suportado"
+#, fuzzy
+#~ msgstr "Mostra/seleciona conexão ao BD para o mapset atual"
+#, fuzzy
+#~ msgid "Database schema"
+#~ msgstr "Nome do banco de dados"
+#, fuzzy
+#~ msgid "database, SQL"
+#~ msgstr "banco de dados"
+#, fuzzy
+#~ msgstr "nome do arquivo com a declaração SQL"
+#, fuzzy
+#~ msgid "The password was stored in file"
+#~ msgstr "A senha foi arquivada"
+#, fuzzy
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr "todos em atual para atual"
+#, fuzzy
+#~ msgstr "Problema na leitura da saída r.stats"
+#, fuzzy
+#~ msgstr "Traçar elevação"
+#, fuzzy
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr "para."
+#, fuzzy
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Grupo de arquivos de imagem"
+#, fuzzy
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#~ msgstr "Compactação nenhum"
+#, fuzzy
+#~ msgstr "Arquivo de saída PostScript"
+#, fuzzy
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#, fuzzy
+#~ msgstr "Não consegui copiar a tabela"
+#, fuzzy
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "mapear"
+#, fuzzy
+#~ msgstr "mapear"
+#, fuzzy
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgstr "Lista camadas disponíveis e finaliza"
+#, fuzzy
+#~ msgstr "Exibir"
+#, fuzzy
+#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+#~ msgstr "acima para mapear"
+#, fuzzy
+#~ msgid "2nd map for mosaic."
+#~ msgstr "mapear."
+#, fuzzy
+#~ msgstr "Relatório de estatísticas para mapas raster."
+#, fuzzy
+#~ msgid ""
+#~ "Value to update the column with (varchar values have to be in single "
+#~ "quotes, e.g. 'grass')"
+#~ msgstr "para para para em"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#~ msgstr "Nome do mapa de orientação para exibição"
+#, fuzzy
+#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+#~ msgstr "mapear imagem em"
+#, fuzzy
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "exibir de"
+#, fuzzy
+#~ msgid "general, manual, help"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgstr "Mapas raster para ler"
+#, fuzzy
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "para"
+#, fuzzy
+#~ msgid "Overwrite existing MASK"
+#~ msgstr "Substituir"
+#, fuzzy
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr "Nome de banco de dados banco de dados em substituído"
+#, fuzzy
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr "em de"
+#, fuzzy
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
+#~ msgstr "faixa para Cilindro faixa"
+#, fuzzy
+#~ msgstr "Digite o nome da coluna para exibição"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "Calcula estatísticas univariada das células não nulas de um mapa raster."
+#, fuzzy
+#, fuzzy
+#~ msgstr "Nome do mapa raster que conterá os resultados"
+#, fuzzy
+#~ msgid "GIS manager for GRASS"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importar."
+#, fuzzy
+#~ msgstr ""
+#, fuzzy
+#~ msgid "Show help"
+#~ msgstr "Mostrar"
+#, fuzzy
+#~ msgid "Display monitor to start"
+#~ msgstr "Exibir para"
+#, fuzzy
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "para para"
+#, fuzzy
+#~ msgstr "Número da camada. Se -1, todas as camadas serão exibidas"
+#, fuzzy
+#~ msgid "Name of PNG file"
+#~ msgstr "Nome do arquivo de rótulos"
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#, fuzzy
+#~ msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
+#, fuzzy
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr "mapear status mapear mapear"
+#, fuzzy
+#~ msgstr "Não criar tabela de atributo."
+#, fuzzy
+#~ msgid "Layer where to add column"
+#~ msgstr "Camada para"
+#, fuzzy
+#~ msgid "Source monitor"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#~ msgstr "Calculando matriz de covariância de classes..."
+#, fuzzy
+#~ msgid "imagery, rectify"
+#~ msgstr "Nome do grupo de imagens"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#~ msgstr ""
+#~ "Impossível abrir imagem real do diretório cell_misc.\n"
+#~ "Mapa de entrada provavelmente não foi criado por i.fft"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#~ msgstr ""
+#~ "Impossível abrir mapa imaginário no diretório cell_misc.\n"
+#, fuzzy
+#~ msgid "imagery, orthorectify"
+#, fuzzy
+#~ msgid ""
+#~ "Name of image to be rectified which will be initially drawn on screen"
+#~ msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
+#, fuzzy
+#~ msgid ""
+#~ "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgstr "Nome de mapear destino ativo."
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#~ msgstr "Grupo <%s> não encontrado."
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#, fuzzy
+#~ msgid "No initial camera exposure station for group [%s]"
+#~ msgstr "Adicionando arquivos ao grupo [%s]"
+#, fuzzy
+#~ msgid "Bad format in initial camera exposure station for group [%s]"
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "Não consegui obter informações da camada para o mapa vetorial"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+#~ msgid "Interactively select or modify the target elevation model."
+#~ msgstr "Selecionar trajeto interativamente"
+#, fuzzy
+#~ msgid "Target information for group [%s] missing\n"
+#~ msgstr "Informação de limites para [%s] indisponível"
+#, fuzzy
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#, fuzzy
+#~ msgid "Range less than or equal to zero not allowed"
+#~ msgstr "Limite menor ou igual a zero não permitido."
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
+#~ msgstr "Escrevendo versões visíveis do dado transformado para arquivos ..."
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#~ msgstr "Impossível abrir arquivo do diretório cell_misc."
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#~ msgstr "Nome do mapa vetorial (2d) de entrada"
+#, fuzzy
+#~ msgid "Eigen values:"
+#~ msgstr "Valor dos padrões de bits"
+#, fuzzy
+#~ msgid "display, legend"
+#~ msgstr "Espelhar legenda"
+#, fuzzy
+#~ msgid "Use regular expression instead of wildcard"
+#~ msgstr "de"
+#, fuzzy
+#~ msgid "Icon to remove"
+#~ msgstr "ícone para remover"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+#~ "(ercent_cover)"
+#~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
+#, fuzzy
+#~ msgid "Writing %s"
+#, fuzzy
+#~ msgid "ID values"
+#, fuzzy
+#~ msgid "To layer"
+#~ msgstr "Consultar"
+#, fuzzy
+#~ msgid "vector, attribute table"
+#~ msgstr "Mostra atributos do vetor"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %d \n"
+#~ "Type: %s \n"
+#~ "Left: %d \n"
+#~ "Right: %d \n"
+#~ msgstr "Linha: %d Tipo: %s Esquerda: %d Direita: %d "
+#, fuzzy
+#~ msgid ""
+#~ "Node[%d]: %d \n"
+#~ "Number of lines: %d \n"
+#~ "Coordinates: %.6f, %.6f, %.6f\n"
+#~ msgstr " Nó[%d]: %d Número de linhas: %d Coordenadas %.6f, %.6f %.6f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %5d \n"
+#~ "Angle: %.8f\n"
+#~ msgstr " Linha: %5d Ângulo: %.8f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Area: %d \n"
+#~ "Number of isles: %d\n"
+#~ msgstr "Área: %d Número de ilhas: %d\n"
+#, fuzzy
+#~ msgid "Type of elements"
+#~ msgstr "Nome do mapset de destino"
+#~ msgid "%s: %s - Unable to find the real-image map."
+#~ msgstr "%s: %s - Não encontrei o mapa imagem real."
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#~ msgstr "%s: %s - Não encontrei o mapa imaginário"
+#, fuzzy
+#~ msgid "Writing data to file..."
+#~ msgstr "Escrevendo dados transformados para o arquivo ..."
+#, fuzzy
+#~ msgid "Hue map name"
+#~ msgstr "%s=%s - nome ilegal"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#~ msgid "Output hue raster map"
+#~ msgstr "Mapa raster de saída"
+#, fuzzy
+#~ msgid "1 class."
+#~ msgstr "%d classes."
+#~ msgid "** Can't open seed singature file <%s> **"
+#~ msgstr "** Não consigo semear arquivo de assinatura <%s> **"
+#, fuzzy
+#~ msgid "Error writing result map file!"
+#~ msgstr "Erro tentando ler o arquivo dbmscap\n"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#~ msgid "Skipping [%s]..."
+#~ msgstr "Passando [%s]..."
+#, fuzzy
+#~ msgid "Name of the resultant map"
+#~ msgstr "Nome do mapa resultante"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#~ msgstr "Não consegui selecionar dados da tabela"
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#~ msgstr "Não consegui executar: %s"
+#, fuzzy
+#~ msgid "Done"
+#~ msgstr "Concluído."
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr "Não consegui abrir fonte de dados OGR '%s'"
+#~ msgid "Column(s)"
+#, fuzzy
+#~ msgid "Unable to read category file for raster map <%s>"
+#~ msgstr "Editar arquivo de categorias para [%s]?"
+#, fuzzy
+#~ msgid "Reading %s ... "
+#~ msgstr "Lendo imagem ... "
+#~ msgid "%s in %s: %s"
+#~ msgstr "%s:em %s: %s"
+#, fuzzy
+#~ msgid "cannot read head of %s"
+#~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+#, fuzzy
+#~ msgid "Cannot open file for <%s>"
+#~ msgstr "Não consegui abrir o arquivo [%s]"
+#~ msgid "Name of the random surface to be produced"
+#~ msgstr "Nome da superfície aleatória a produzir"
+#~ msgid "No record for cat = %d"
+#~ msgstr "Sem registros para cat = %d"
+#, fuzzy
+#~ msgid "Vector map <%s> not found in current mapset"
+#~ msgid "Database connection not defined for layer <%d>"
+#~ msgstr "Conexão com banco de dados não definida para camada <%d>"
+#, fuzzy
+#~ msgid "Editing tool"
+#~ msgid "Cannot open file [%s]"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#~ msgid "Database record for cat %d not found"
+#~ msgstr "Sem registro no banco para categoria %d"
+#~ msgid "Read coordinates from standard input"
+#~ msgstr "Obtém coordenadas a partir da entrada padrão"
+#, fuzzy
+#~ msgid "%s - illegal name"
+#, fuzzy
+#~ msgid "Error reading map %s"
+#~ msgstr "Erro lendo arquivo raster [%s]."
+#, fuzzy
+#~ msgid "Closing raster map"
+#~ msgstr "Mapa raster de cobertura"
+#~ msgid "Name of the new raster map"
+#, fuzzy
+#~ msgid "Could not close the 3d raster map"
+#~ msgstr "Não consegui fechar o novo mapa g3d"
+#~ msgid "Could not find input vector map %s"
+#~ msgstr "Não consegui encontrar o mapa vetorial de entrada %s"
+#~ msgid "Can't create output map"
+#, fuzzy
+#~ msgid "name for new vector map"
+#~ msgstr "Nome do novo arquivo raster."
+#, fuzzy
+#~ msgid "Cover raster map"
+#~ msgstr "Mapa de cobertura"
+#~ msgid "Topographic index ln(a/tanB) map"
+#~ msgstr "Mapa de índice topográfico [ln(a/tanB)]"
+#~ msgid "No input coordinates provided"
+#~ msgstr "Coordenadas de entrada não foram informadas"
+#~ msgid "Database name:"
+#~ msgstr "Banco de dados:"
+#, fuzzy
+#~ msgid "Path to the input file"
+#~ msgid ""
+#~ "Number of column used as z coordinate (first column is 1) for points "
+#~ "mode. If 0, z coordinate is not used."
+#~ msgstr ""
+#~ "Número da coluna usada como coordenada z (primeira coluna é 1) para o "
+#~ "modo de pontos. Se 0, coordenada z não é usada."
+#, fuzzy
+#~ msgid "Name of the output walkers site file"
+#~ msgstr "Nome do raster de saída"
+#~ msgid "column type not supported"
+#~ msgstr "tipo de coluna não suportado"
+#, fuzzy
+#~ msgid "%s - too many patch files. only %d allowed"
+#~ msgstr "correção"
+#, fuzzy
+#~ msgid "category [%d]"
+#~ msgstr ""
+#~ "Camada: %d\n"
+#~ "categoria: %d\n"
+#, fuzzy
+#~ msgid "Interpolation()"
+#~ msgstr "Método de intepolação a usar"
+#, fuzzy
+#~ msgid "Calculation time"
+#~ msgstr "Calculando médias das classes ..."
+#, fuzzy
+#~ msgid "History line too long: truncating to %d characters"
+#~ msgstr "Histórico para"
+#~ msgid "Name of output 3d raster map"
+#~ msgstr "Nome do arquivo G3D de saída"
+#, fuzzy
+#~ msgid "input layer name"
+#~ msgstr "Nome da tabela de entrada"
+#, fuzzy
+#~ msgid "Column name (will be updated by qvector values)"
+#~ msgstr "Coluna"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "[%s] é um nome ilegal"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -13482,9 +13482,8 @@
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
-#, fuzzy
msgid "Level"
-msgstr "Valor do raster"
+msgstr ""
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
@@ -13510,7 +13509,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+msgstr "Não consegui fechar mapa de entrada"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -18922,7 +18921,7 @@
#: ../vector/v.in.db/main.c:176
#, fuzzy
msgid "Writing features..."
-msgstr "Escrevendo arquivo de assinatura %s ..."
+msgstr "Escrevendo [%s]..."
#: ../vector/v.in.db/main.c:183
msgid "Key column must be integer"
@@ -19473,7 +19472,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "Saída de mapa"
+msgstr "Criar saída 3D"
#: ../vector/v.random/main.c:111
#, fuzzy
@@ -21600,11 +21599,8 @@
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
msgstr ""
-"Criar rótulos de pintura para arquivo vetorial do GRASS e atributos "
-"relacionados."
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -24747,7 +24743,7 @@
#: ../vector/v.buffer/main.c:200 ../vector/v.buffer/main.c:209
#, fuzzy
msgid "Distance"
-msgstr "Zonas de distância"
+msgstr "Tabela faltando"
#: ../vector/v.buffer/main.c:177
#, fuzzy
@@ -25525,9 +25521,8 @@
msgstr "Nome da Fonte"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "nome=%s\n"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -25986,7 +25981,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "Separador de Campos"
+msgstr "Mostra as estatísticas em estilo shell script"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -29196,8 +29191,9 @@
msgstr "Raiz de para em atual não"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
+#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
+msgstr "Raiz de para em atual não"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
#, fuzzy
@@ -29660,8 +29656,9 @@
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
+#, fuzzy
msgid "Category number starting value"
-msgstr ""
+msgstr "Nome da coluna categoria"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
@@ -29748,20 +29745,24 @@
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+#, fuzzy
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
+msgstr "Altura fixa para objetos vetoriais 3D"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#, fuzzy
msgid "use transformation rules for LANDSAT-4"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#, fuzzy
msgid "use transformation rules for LANDSAT-5"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+#, fuzzy
msgid "use transformation rules for LANDSAT-7"
-msgstr ""
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
#, fuzzy
@@ -29938,8 +29939,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "Nome do mapa raster a ser usado para <%s>"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#, fuzzy
@@ -30284,7 +30286,11 @@
#: ../imagery/i.pca/main.c:72
#, fuzzy
msgid "Name of two or more input raster maps"
-msgstr "Nome do Raster de entrada"
+msgstr ""
+"#-#-#-#-# grassmods_pt_br.po (grassmods_pt_br) #-#-#-#-#\n"
+"Nome do raster de entrada\n"
+"Nome do mapa raster de entrada"
#: ../imagery/i.pca/main.c:75
#, fuzzy
@@ -32499,6 +32505,303 @@
"Não posso marcar outro ponto. Somente %d pontos permitidos. Desculpe."
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr ""
+"Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "Arquivo raster para importar"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "Arquivo ASCII contendo assinaturas espectrais"
+#, fuzzy
+msgid "terrain analysis"
+msgstr "Estatísticas de transição de classe."
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "Relatório de estatísticas para mapas raster."
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "<%s> criados na base de dados."
+#, fuzzy
+msgid "report"
+msgstr "Importar"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Não consegui escrever cabeçalho para [%s]."
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr "Erro lendo coringa."
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+msgstr "Erro lendo arquivo raster [%s]."
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Não consegui abrir mapa raster [%s] em [%s]"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "Não consegui ler região <%s> em <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+msgstr "Não consegui abrir mapa raster [%s]."
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "Não consegui abrir arquivo de saída <%s>."
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "Não consegui obter linha %d (erro = %d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "para para!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Não consegui ler linha %i\n"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Não consegui inserir nova linha: %s"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "Erro escrevendo linha nula [%d]."
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "Nome do mapa raster existente contendo isolinhas"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "Máscara: %s\n"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+msgstr "Não consegui criar arquivo raster [%s]."
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "Lendo arquivo dig_att...\n"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Não consegui escrever em <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr "Não consegui abrir o arquivo [%s]"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "Nome do Raster de saída"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "nome=%s\n"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Nome do arquivo de rótulos"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "Número de quadros"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "Inportação de vetor incompleta"
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD"
+msgstr "Por cento:"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "%s: %s - Não encontrei o mapa imagem real."
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"Impossível abrir imagem real do diretório cell_misc.\n"
+"Mapa de entrada provavelmente não foi criado por i.fft"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "%s: %s - Não encontrei o mapa imaginário"
+#, fuzzy
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"Impossível abrir mapa imaginário no diretório cell_misc.\n"
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "Grupo <%s> não encontrado."
+#, fuzzy
+msgid "Range less than or equal to zero not allowed."
+msgstr "Limite menor ou igual a zero não permitido."
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "Escrevendo versões visíveis do dado transformado para arquivos ..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+msgstr "Impossível abrir arquivo do diretório cell_misc."
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+msgstr "** Não consigo semear arquivo de assinatura <%s> **"
+#, fuzzy
+msgid "Can't read signature file <%s>"
+msgstr "Não consegui ler o arquivo de assinatura [%s]."
+#, fuzzy
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr "Nome de mapear destino ativo."
+#, fuzzy
+msgid ""
+"Name of old database. The database must be in form printed by v.db.connect -"
+"g, i.e. with substituted variables"
+msgstr "Nome de banco de dados banco de dados em substituído"
+#, fuzzy
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "mapear imagem em"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Escrevendo arquivo raster %i\n"
+#, fuzzy
+msgid "Use output= option to change vector map name"
+msgstr "Usar opção output= para alterar o nome do mapa vetor"
+#, fuzzy
+msgid "Erasing monitors ..."
+msgid "Category file for [%s] not available"
+msgstr "Arquivo de categorias para [%s] não disponível"
+msgid "color file for [%s] not available"
+msgstr "Arquivo de cores para [%s] não disponível"
+#, fuzzy
#~ msgid "Not enough room in history file"
#~ msgstr "Memória insuficiente para az"
@@ -32515,11 +32818,6 @@
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr ""
-#~ "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
-#, fuzzy
#~ msgid "List of values to be displayed (FP maps)"
#~ msgstr "Lista de valores de célula para mascarar"
@@ -32619,13 +32917,6 @@
#~ msgstr "DXY [%s] COMPLETA"
#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
-#, fuzzy
#~ msgid "Input elevation map"
#~ msgstr "Nome do Arquivo raster de elevação"
@@ -32637,14 +32928,6 @@
#~ msgid "Layer number of data column"
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "Arquivo raster para importar"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "Arquivo ASCII contendo assinaturas espectrais"
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Gera uma camada raster mostrando as sub-bacias de drenagem."
@@ -32751,10 +33034,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr " saída para uma classe topográfica índice"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "Estatísticas de transição de classe."
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "Nome do mapa raster contendo a superfície"
@@ -32814,18 +33093,6 @@
#~ msgid "Unable to access table <%s>"
#~ msgstr "Não consegui abrir arquivo de saída <%s>."
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Converte mapas raster 3D (G3D) para o formato VTK-ASCII"
@@ -32842,10 +33109,6 @@
#~ "região atualmente definida."
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "Mostra as estatísticas em estilo shell script"
-#, fuzzy
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -32858,10 +33121,6 @@
#~ msgstr "Nenhum monitor selecionado"
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Relatório de estatísticas para mapas raster."
-#, fuzzy
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "Impossível criar <Tabela_auxiliar_dos_desvios>"
@@ -32873,10 +33132,6 @@
#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "<%s> criados na base de dados."
-#, fuzzy
#~ msgid "M.Q. solution"
#~ msgstr "Resolução"
@@ -32946,18 +33201,10 @@
#~ msgstr "Não consegui ler arquivo raster agora."
#, fuzzy
-#~ msgid "report"
-#~ msgstr "Importar"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Não consegui escrever cabeçalho para [%s]."
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "Não consegui escrever o arquivo temporário."
@@ -33010,10 +33257,6 @@
#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "Erro lendo coringa."
-#, fuzzy
#~ msgid "Reading row %d"
#~ msgstr "\rLendo arquivo [%s] ..."
@@ -33113,10 +33356,6 @@
#~ msgstr "Não encontrei %s"
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#~ msgstr "Erro lendo arquivo raster [%s]."
-#, fuzzy
#~ msgid "Error in pipe creation"
#~ msgstr "Erro em pj_do_proj"
@@ -33157,14 +33396,6 @@
#~ msgstr "Não encontrei mapa raster"
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Não consegui abrir mapa raster [%s] em [%s]"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "Não consegui ler região <%s> em <%s>"
-#, fuzzy
#~ msgid "Unable to get header for %s"
@@ -33173,18 +33404,6 @@
#~ msgstr "Mostra a região atual"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#~ msgstr "Não consegui abrir mapa raster [%s]."
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "Não consegui abrir arquivo de saída <%s>."
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
@@ -33229,22 +33448,6 @@
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "Não consegui obter linha %d (erro = %d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "para para!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
#~ msgstr "Não consegui criar arquivo raster [%s]."
@@ -33275,10 +33478,6 @@
#~ msgstr "Erro escrevendo linha nula [%d]."
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Não consegui ler linha %i\n"
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr "Coluna %d definida como inteiro só possui valores double"
@@ -33294,10 +33493,6 @@
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Não consegui inserir nova linha: %s"
-#, fuzzy
#~ msgid "Invalid region: %s"
#~ msgstr "região inválida: %s"
@@ -33358,14 +33553,6 @@
#~ msgstr "Não consegui abrir os arquivos das bandas."
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "Escrevendo [%s]..."
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
@@ -33386,14 +33573,6 @@
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "Erro escrevendo linha nula [%d]."
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Nome do mapa raster existente contendo isolinhas"
-#, fuzzy
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "Número de vezes para repetir o filtro"
@@ -33512,14 +33691,6 @@
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
@@ -33542,10 +33713,6 @@
#~ msgstr "Tabela <%s> não existe no banco de dados <%s>"
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Máscara: %s\n"
-#, fuzzy
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "Criando tabela auxiliar para arquivar zonas adjacentes"
@@ -33724,21 +33891,9 @@
#~ msgstr "Região atual não pode ser ajustada."
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Não consegui criar arquivo raster [%s]."
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Lendo arquivo dig_att...\n"
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "Não consegui alocar memória para 'string'"
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
#~ msgid "Unable to open the cell map MASK."
@@ -33759,14 +33914,6 @@
#~ msgid "Unable to open band files."
-#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Não consegui escrever em <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
#~ msgid "Error while reading input raster map."
@@ -33776,22 +33923,6 @@
#~ msgid "Error writing cell map during transform."
#~ msgstr "Erro na escrita do mapa de células durante a transformação."
-#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr "Não consegui abrir o arquivo [%s]"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
#~ msgid "Could not open <%s>"
#~ msgstr "Não consegui abrir <%s>"
@@ -33799,18 +33930,6 @@
#~ msgstr "Não consegui ler de <%s>"
#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "Nome do Raster de saída"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
#~ msgid "Error reading row of data"
@@ -34072,22 +34191,6 @@
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "nome=%s\n"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "Nome do arquivo de rótulos"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "Número de quadros"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "Nome do arquivo para o resultado da classificação"
@@ -34439,10 +34542,6 @@
#~ msgstr "Alterado para"
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "Inportação de vetor incompleta"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
@@ -34499,10 +34598,6 @@
#~ msgstr "Não consegui ler MASK"
#, fuzzy
-#~ msgid "SECTION 3: Accumulating Surface Flow with MFD"
-#~ msgstr "Por cento:"
-#, fuzzy
#~ msgid "unable to open MASK"
@@ -34510,10 +34605,6 @@
#~ msgstr "Mapa de saída: útil para exibição visual dos resultados"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "Arquivo raster para superfície"
@@ -34643,30 +34734,6 @@
#~ msgid "Output inverse raster map after IFFT"
#~ msgstr "Título do raster de saída após ifft"
-#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "%s: %s - Não encontrei o mapa imagem real."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Impossível abrir imagem real do diretório cell_misc.\n"
-#~ "Mapa de entrada provavelmente não foi criado por i.fft"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "%s: %s - Não encontrei o mapa imaginário"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "Impossível abrir mapa imaginário no diretório cell_misc.\n"
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "Valores ao quadrado : [%d} linhas [%d] colunas."
@@ -34769,10 +34836,6 @@
#~ msgid "Run quietly"
#~ msgstr "Executa silenciosamente"
-#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "Grupo <%s> não encontrado."
#~ msgid "Subgroup [%s] not found."
#~ msgstr "Subrupo <%s> não encontrado."
@@ -34827,10 +34890,6 @@
#~ msgid "Range of values in output display files"
#~ msgstr "Limite dos valores nos arquivos de saída"
-#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "Limite menor ou igual a zero não permitido."
#~ msgid "Initializing data...\n"
#~ msgstr "Inicializando dados ...\n"
@@ -34841,14 +34900,6 @@
#~ msgstr "FFT concluída..."
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "Escrevendo versões visíveis do dado transformado para arquivos ..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "Impossível abrir arquivo do diretório cell_misc."
-#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
@@ -34870,14 +34921,6 @@
#~ msgid "Unable to proceed"
#~ msgstr "Impossível prosseguir"
-#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "** Não consigo semear arquivo de assinatura <%s> **"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "Não consegui ler o arquivo de assinatura [%s]."
#~ msgid "Group of imagery files to be clustered"
#~ msgstr "Grupo de arquivos de imagens a ser agrupados"
@@ -34911,16 +34954,6 @@
#~ msgstr "Marque os pontos de controle no solo para retificar a imagem."
#, fuzzy
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
-#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr "Nome de mapear destino ativo."
-#, fuzzy
#~ msgid "Unable to read head of %s"
@@ -34993,12 +35026,6 @@
#~ msgstr "para"
#, fuzzy
-#~ msgid ""
-#~ "Name of old database. The database must be in form printed by v.db."
-#~ "connect -g, i.e. with substituted variables"
-#~ msgstr "Nome de banco de dados banco de dados em substituído"
-#, fuzzy
#~ msgid "Name of GIS manager settings file (.grc)"
#~ msgstr "Nome de um arquivo MAT (v4) existente"
@@ -35455,10 +35482,6 @@
#~ msgstr "Exibir"
#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "mapear imagem em"
-#, fuzzy
#~ msgid "Make JPEG instead of PNG image"
#~ msgstr "JPEG de imagem"
@@ -35826,10 +35849,6 @@
#~ msgstr "Lendo mapa"
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Escrevendo arquivo raster %i\n"
-#, fuzzy
#~ msgid "Output raster map with lake"
@@ -36245,10 +36264,6 @@
#, fuzzy
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr "Usar opção output= para alterar o nome do mapa vetor"
-#, fuzzy
#~ msgid "Cannot open new vector map <%s>"
#~ msgstr "%s: Novo arquivo vetorial não pode ser aberto"
@@ -36819,10 +36834,6 @@
#~ msgstr "Opção Geo-Grid não disponível para projeção XY"
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#, fuzzy
#~ msgid "Could not open input file <%s>."
#~ msgstr "Não consegui abrir arquivo vetorial <%s>"
@@ -36989,9 +37000,6 @@
#~ msgid "Creating support files for [%s]."
#~ msgstr "Criando arquivos de suporte para [%s]."
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "Arquivo de categorias para [%s] não disponível"
#~ msgid "%s: <%s> raster map not found"
#~ msgstr "%s: <%s> mapa raster não encontrado"
@@ -37749,9 +37757,6 @@
#~ msgid "Raster map [%s] not available"
#~ msgstr "Arquivo raster [%s] não disponível"
-#~ msgid "color file for [%s] not available"
-#~ msgstr "Arquivo de cores para [%s] não disponível"
#~ msgid "Raster file [%s] not available"
@@ -39362,3 +39367,1680 @@
#~ "Displays the rhumbline joining two user-specified points, in the active "
#~ "frame on the user's graphics monitor."
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Converte uma camada raster 3D para um arquivo de texto ASCII"
+#, fuzzy
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr "Converte um arquivo raster ASCII 3D para um mapa raster 3D binário."
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Lendo arquivo dig_att...\n"
+#~ msgid ""
+#~ "Cannot create mask file: G3D_MASK already exists!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+#~ msgstr ""
+#~ "Não consegui criar arqivo máscara: G3D_MASK já existe!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' para remover a máscara existente."
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "Exporta um raster 3D do GRASS para um arquivo Vis5D"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "Exporta mapa raster do GRASS para arquivo GRIDATB.FOR (TOPMODEL)"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "Nome do mapa raster"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr ""
+#~ "Converte uma camada raster num campo de altura (height field) para o "
+#~ "POVRAY."
+#, fuzzy
+#~ msgid "raster, map algebra"
+#~ msgstr "Inportação de vetor incompleta"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "Converte uma camada raster para um arquivo de texto ASCII"
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "Escrevendo [%s]..."
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "Não encontrei mapset para %s"
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "Importar como dado 'floating point' (padrão: inteiro)"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr "Importar como dado 'double precision' (padrão: inteiro)"
+#, fuzzy
+#~ msgid "Parsing bytes per cell"
+#~ msgstr " Número de bytes por célula"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#~ msgid "Update the statistics (histogram, range) for [%s]? "
+#~ msgstr "Atualizar estatísticas (histograma, intervalo) para [%s]?"
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "Escrevendo arquivo raster %i\n"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Nome do Raster de saída"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#~ msgstr "Interpolando mapa raster <%s> ... %d linhas ..."
+#, fuzzy
+#~ msgid "raster, statistics"
+#~ msgstr "Estatísticas de transição de classe."
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Converte mapas raster para o formato VTK-ASCII"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "Número de pontos de interpolação"
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "Sem tabela"
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr ""
+#~ "#-#-#-#-# grassmods_pt_br.po (grassmods_pt_br) #-#-#-#-#\n"
+#~ "Nome do raster de entrada\n"
+#~ "Nome do mapa raster de entrada"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Nome do raster de entrada"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr ""
+#~ "Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Nome do arquivo raster com o albedo do solo [-]"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "Nome do novo arquivo raster"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Gera arquivo com a direção da encosta"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Gera uma mapa de direções"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Gera mapa raster de drenagem"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "Gera arquivo raster com a curvatura média"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Gera arquivo com a declividade"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução "
+#~ "da região atualmente definida."
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "Não consegui abrir arquivo de células [%s]"
+#, fuzzy
+#~ msgid "raster, buffer"
+#~ msgstr "Mapa raster de entrada"
+#, fuzzy
+#~ msgid "raster, series"
+#~ msgstr "Mapa raster a ser amostrado"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Mapa de Entrada: quantidade de fluxo superficial por célula"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "Mapa de entrada: terreno bloqueando fluxo superficial, para USLE"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Mapa de saída: número de células que drenam através de cada célula"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "Mapa de saída: rótulo único para cada bacia de drenagem"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "Mapa de saída: um valor único é dado para cada meia-bacia"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr ""
+#~ "Saída de mapa: fator de comprimento do declive e declividade (LS) para "
+#~ "USLE"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "Saída de mapa: fator de comprimento de declividade (S) para USLE"
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "Mapa de entrada: tamanho mínimo de bacias de drenagem exteriores"
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr ""
+#~ "Valor de entrada: comprimento máximo para fluxo superficial, para USLE"
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "de\n"
+#~ " fluxo\n"
+#~ " limiar limiar."
+#, fuzzy
+#~ msgid ""
+#~ "USAGE for basin delineation:\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "\n"
+#~ "USAGE for ARMSED FILE creation:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "\n"
+#~ "USAGE for slope length determination:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
+#~ msgstr ""
+#~ "mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo "
+#~ "mapear mapear limiar mapear mapear mapear mapear exibir mapear mapear "
+#~ "fluxo mapear mapear comprimento mapear limiar mapear mapear mapear exibir "
+#~ "mapear comprimento Bloqueio mapear mapear LS comprimento mapear mapear "
+#~ "mapear"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "Não consegui abrir o mapa de células MASK."
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "Erro na escrita do arquivo 'colr' para <%s>."
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programa para conversão de uma série de arquivos para MPEG."
+#, fuzzy
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Filtra e gera um mapa de elevação sem depressões e uma direção de fluxo a "
+#~ "partir de um mapa de elevação fornecido"
+#~ msgid "Output direction raster map"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "Gera um mapa das áreas problemáticas"
+#, fuzzy
+#~ msgid "raster, resample"
+#, fuzzy
+#~ msgid "Cannot read ew_res value"
+#~ msgstr "Não consegui criar árvore"
+#, fuzzy
+#~ msgid "Cannot read ns_res value"
+#, fuzzy
+#~ msgid "[%s]: Map is the wrong resolution"
+#~ msgstr "Mapa é"
+#~ msgid "Cannot get row %d (error = %d)"
+#~ msgstr "Não consegui obter linha %d (erro = %d)"
+#, fuzzy
+#~ msgid "Cannot set region to back to the initial region !!!"
+#~ msgstr "para para!"
+#, fuzzy
+#~ msgid ""
+#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
+#~ "will be rounded to integer!"
+#~ msgstr "mapear em é mapear Decimal para!"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr ""
+#~ "Programa para geração de superfícies a partir de isolinhas rasterizadas."
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "Nome do mapa raster existente contendo isolinhas"
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Cria/Modifica a tabela de cores associada com uma camada raster."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Mapa raster do qual copiarei a tabela de cores"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "Arquivo raster de entrada (imagem FFT, parte real)"
+#, fuzzy
+#~ msgid ""
+#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
+#~ "be specified!"
+#~ msgstr "Um de!"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "Não consegui criar camada"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "Não consegui criar o mapa de saída"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "Não consegui criar a tabela %s"
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#~ msgstr "Arquivo raster para importar"
+#, fuzzy
+#~ msgid "raster, null data"
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "Gera um mapa raster com áreas contíguas acrescidas de uma célula"
+#, fuzzy
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Mapa de bacias criado por r.water.outlet"
+#, fuzzy
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) Mapa de direção com mapa de elevação sem depressões"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) Número de classes de índice topográfico"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(o/i) Arquivo índice das estatísticas topográficas"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) Arquivo de parâmetros TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "(i) Arquivo de dados de precipitação e evapotranspiração"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "Calcula áreas de sombra a partir da posição do sol e de um modelo de "
+#~ "elevação digital. Deve ser especificada A: posição exata do sol ou B: "
+#~ "data e hora para cálculo da posição por r.sunmask."
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: altitude do Sol sobre o horizonte, graus"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: azimute do Sol a partir do norte, graus"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: minuto (0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: segundos (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: fuso horário (leste positivo, diferença de GMT, também usar para "
+#~ "compensar horário de verão)"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Cria um novo mapa cujas categorias são baseadas na reclassificação do "
+#~ "usuário sobre as categorias de um mapa raster existente."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "Mapa raster a ser reclassificado"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "Converte um mapa raster em uma camada de mapa vetorial."
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "Coordenadas Este do mapa"
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "Não consegui escrever em <%s>"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#~ msgstr "fp: intervalo de dados é %.25f a %.25f\n"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#~ msgstr "O intervalo de dados é de %ld a %ld\n"
+#, fuzzy
+#~ msgid "'%s' is not a valid rule"
+#~ msgstr "é não mapear"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#, fuzzy
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr "de"
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#, fuzzy
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "de"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "Converte um arquivo raster ASCII para um mapa raster binário."
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "Mostra os rótulos de categoria na célula da malha"
+#, fuzzy
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#~ msgstr "Não consegui abrir mapa raster [%s]."
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "Tipo da coluna não suportado"
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Converte um raster ASCII (GRID) do ESRI ARC/INFO em uma camada raster "
+#~ "binária."
+#, fuzzy
+#~ msgid "File containing weights"
+#~ msgstr "Arquivo contendo declarações SQL"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "general, settings"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "Formato OGR."
+#, fuzzy
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#~ msgstr "Não consegui ler arquivo de cores."
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "Cor para desenhas X's (valores nulos)"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "nome=%s\n"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitor: esperava waitpid %d mas obtive %d\n"
+#, fuzzy
+#~ msgid "display, networking"
+#~ msgstr "Exibir"
+#~ msgid ""
+#~ "Identifies the geographic coordinates associated with point locations in "
+#~ "the active frame on the graphics monitor."
+#~ msgstr ""
+#~ "Identifica as coordenadas geográficas associadas com locações no quadro "
+#~ "ativo do monitor gráfico"
+#~ msgid "Command mode (Compatibility with d.text)"
+#~ msgstr "Modo de comando (compatibilidade com d.text)"
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Pelo menos o texto ou '-c' devem ser fornecidos."
+#~ msgid "Unable to create face"
+#~ msgstr "Não consegui criar face"
+#~ msgid "Unable to set size"
+#~ msgstr "Não consegui definir tamanho"
+#~ msgid "Text conversion error"
+#~ msgstr "Erro na conversão de texto"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#~ msgstr "Erro na leitura do mapa raster de entrada."
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "Arquivo de cores para [%s] não disponível"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr "Arquivo de categorias para [%s] não disponível"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr ""
+#~ "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr "Lista de categorias para exibir (mapas INT)"
+#, fuzzy
+#~ msgid "Invert catlist"
+#~ msgstr "Inverter catlist"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#~ msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
+#, fuzzy
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "Não consegui ler símbolos, não consegui exibir pontos"
+#~ msgid "Vector map attribute column to use for comparison"
+#~ msgstr "Nome da coluna de atributos do vetor para usar como comparação"
+#~ msgid "Vector map to store differences"
+#~ msgstr "Mapa vetorial para armazenas diferenças"
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "Fator de escala opcional para valores lidos do mapa raster. Valores "
+#~ "amostrados serão multiplicados por esse fator."
+#, fuzzy
+#~ msgid "%d new points written to output"
+#~ msgstr "%d pontos escrito no mapa de saída\n"
+#, fuzzy
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "Exporta um raster do GRASS para um arquivo binário"
+#, fuzzy
+#~ msgid "Layer number (write to)"
+#~ msgstr "Camada número"
+#, fuzzy
+#~ msgid "Query layer number (read from)"
+#, fuzzy
+#~ msgid "vector, interpolation"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgstr ""
+#~ "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
+#, fuzzy
+#~ msgid "Vector based generalization."
+#, fuzzy
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr ""
+#~ "Criar rótulos de pintura para arquivo vetorial do GRASS e atributos "
+#~ "relacionados."
+#, fuzzy
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
+#, fuzzy
+#~ msgid "Total area: %e (%d areas)"
+#, fuzzy
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "%d pontos sem categoria"
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada "
+#~ "raster 3D do GRASS."
+#, fuzzy
+#~ msgid "vector, extract"
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr "Perturbações aleatórias nos pontos do GRASS"
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "Parâmetro(s) da distribuição. Se a distribuição é uniforme, apenas o "
+#~ "máximo é necessário. Para uma distribuição normal, a média e o desvio "
+#~ "padrão são necessários."
+#, fuzzy
+#~ msgid "Layer number (from)"
+#, fuzzy
+#~ msgid "Layer number (to)"
+#, fuzzy
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr "Gera mapa de pontos 2D/3D do GRASS aleatóriamente."
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "Não consegui usar a coluna '%s'"
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "Converter um mapa vetorial binárido GRASS em saída ASCII VTK"
+#, fuzzy
+#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#~ msgstr "%d pontos fora da região atual."
+#, fuzzy
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS num mapa vetorial GRASS ASCII"
+#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
+#~ msgstr ""
+#~ "Caminho para o arquivo ASCCI resultante ou nome do vetor ASCII se '-o' "
+#~ "foi definido"
+#, fuzzy
+#~ msgid "Parameter '%s' ignored in standard mode"
+#~ msgstr "parâmetro para"
+#, fuzzy
+#~ msgid "vector, geometry"
+#~ msgstr "Arquivo vetorial para criar"
+#, fuzzy
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr "Usar opção output= para alterar o nome do mapa vetor"
+#, fuzzy
+#~ msgid "Output quadrant centres, number of points is written as category"
+#~ msgstr ""
+#~ "Resultados dos centros dos quadrados, o número de pontos é escrito como "
+#~ "categoria"
+#, fuzzy
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "Contando locais no quadrado..."
+#, fuzzy
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS numa camada raster do GRASS."
+#, fuzzy
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "Duas camadas devem ser especificadas"
+#, fuzzy
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "Converter para um dos formatos vetoriais suportados pelo OGR."
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "Exportar apenas feições com categorias. De outro modo, todas as feições "
+#~ "serão exportadas."
+#~ msgid "Key column '%s' not found"
+#~ msgstr "Coluna chave '%s' não encontrada"
+#, fuzzy
+#~ msgid "Exporting %i points/lines..."
+#, fuzzy
+#~ msgid "%d features written"
+#~ msgstr "%d pontos escritos no vetor"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "Esta opção requer ao menos duas colunas"
+#, fuzzy
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS pela combinação de outros "
+#~ "camadas de mapa vetorial."
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#, fuzzy
+#~ msgid "vector, metadata"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Cria um buffer ao redor de feições de um determinado tipo (áreas devem "
+#~ "conter centróide)"
+#~ msgid "Buffer distance in map units"
+#~ msgstr "Distância do buffer (em unidades do mapa)"
+#, fuzzy
+#~ msgid "Use the distance option instead of the buffer option."
+#~ msgstr "Usar rotação em radianos ao invés de graus"
+#, fuzzy
+#~ msgid "vector, querying"
+#, fuzzy
+#~ msgid "Queries a vector map layer at given locations."
+#~ msgstr "Pesquisa um mapa vetorial em pontos determinados"
+#, fuzzy
+#~ msgid "If not given reads from standard input"
+#~ msgstr ""
+#~ "Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+#~ "entrada padrão"
+#, fuzzy
+#~ msgid "vector, transformation"
+#, fuzzy
+#~ msgid "Copying vector objects from vector map <%s>..."
+#, fuzzy
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Mapa de entrada contendo linhas"
+#, fuzzy
+#~ msgid "Name for output vector map where segments will be written"
+#~ msgstr "Mapa de saída no qual os pontos serão gravados"
+#, fuzzy
+#~ msgid "Tests for normality for points."
+#~ msgstr "pontos."
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Calcula estatísticas univariadas para atributo. Variância e desvio padrão "
+#~ "é calculado apenas para pontos se especificado."
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#~ msgstr "Não consegui calcular centróide da área."
+#, fuzzy
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#~ msgstr ""
+#, fuzzy
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr "Cria pontos ao longo das linhas de entrada"
+#, fuzzy
+#~ msgid "%d points written to output vector map"
+#, fuzzy
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr ""
+#~ msgid ""
+#~ "Number of column used as y coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Número da coluna usada como coordenada y (primeira coluna é 1) para o "
+#~ "modo de pontos"
+#, fuzzy
+#~ msgid ""
+#~ "Number of column used as z coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ "Number of column used as category (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Número da coluna usada como coordenada x (primeira coluna é 1) para o "
+#, fuzzy
+#~ msgid ""
+#~ "If 0, unique category is assigned to each row and written to new column "
+#~ "'cat'"
+#~ msgstr ""
+#~ "Número da coluna usada como categoria (primeira coluna é 1) para o modo "
+#~ "de pontos. Se 0, uma categoria única é designada para cada linha e "
+#~ "escrita na nova coluna cat"
+#, fuzzy
+#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
+#~ msgstr "Cria um novo mapa vazio e sai. Nada é lido da entrada"
+#, fuzzy
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr ""
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "Tolerância em unidades de mapa, um valor para cada ferramenta (padrão: 0.0"
+#~ "[,0.0,...])"
+#, fuzzy
+#~ msgid "Copying vector lines..."
+#~ msgstr "Verificando pontos vetoriais ..."
+#, fuzzy
+#~ msgid "%d lines / boundaries removed"
+#, fuzzy
+#~ msgid "Duplicate area centroids: %5d"
+#~ msgstr "Não consegui calcular área do centróide."
+#, fuzzy
+#~ msgid "Attribute table column with values to interpolate"
+#~ msgstr ""
+#, fuzzy
+#~ msgid "No data points found"
+#~ msgstr "%s: nenhum ponto de dados encontrado"
+#~ msgid "Attribute column to use for buffer distances"
+#~ msgstr "Nome da coluna de atributo a usar como distância dos buffers"
+#, fuzzy
+#~ msgid "Lines buffers... "
+#~ msgstr "Encontrando classes de treinamento..."
+#, fuzzy
+#~ msgid "Error reading ASCII file: '%s'"
+#~ msgstr "Erro na leitura do arquivo de categorias para <%s>."
+#, fuzzy
+#~ msgid "Outputs basic information about a user-specified vector map."
+#~ msgstr ""
+#~ "Imprime informações básicas sobre uma camada de mapa vetorial "
+#~ "especificada pelo usuário."
+#, fuzzy
+#~ msgid "Map format: %s"
+#~ msgstr " %s"
+#, fuzzy
+#~ msgid "Name of creator: %s"
+#, fuzzy
+#~ msgid " Comments:"
+#~ msgstr " média "
+#, fuzzy
+#~ msgid "Extrudes flat vector object to 3D with defined height."
+#~ msgstr "Extruda vetores 2D para 3D com alturas definidas"
+#, fuzzy
+#~ msgid "Output surface raster map (elevation)"
+#~ msgstr "Gerar arquivo raster da superfície (elevação)"
+#, fuzzy
+#~ msgid "Output cross-validation errors vector point file"
+#~ msgstr "Nome do mapa de pontos de validação cruzada para saída"
+#, fuzzy
+#~ msgid "Output vector map showing quadtree segmentation"
+#~ msgstr "Saída de arquivo vetorial mostrando segmentação"
+#, fuzzy
+#~ msgid "Output vector map showing overlapping windows"
+#~ msgstr "Saída de vetor mostrando segmentos sobrepostos"
+#, fuzzy
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "Nome da coluna de atributos com valores para interpolar (se >0 camada)"
+#~ msgid "Cannot write raster maps -- try to increase resolution"
+#~ msgstr ""
+#~ "Não consegui escrever arquivo de células -- tente aumentar a resolução"
+#, fuzzy
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr "Mostra os parâmetros de conexão atuais e finaliza"
+#, fuzzy
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "mapa vetorial <%s> não encontrado"
+#, fuzzy
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#, fuzzy
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "Não consegui determinar o tipo de célula raster."
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#~ msgid "Verbose module output"
+#~ msgstr "Modo verboso"
+#, fuzzy
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "Nome de um arquivo para gravar a saída do relatório"
+#, fuzzy
+#~ msgid "Width and height of output image"
+#~ msgstr "Largura do destaque colorido"
+#, fuzzy
+#~ msgid "Surface"
+#~ msgstr "Variância da soma"
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "coluna(s)"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "Driver OGR : coluna '%s', tipo OGR %d não é suportado"
+#, fuzzy
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr "Mostra/seleciona conexão ao BD para o mapset atual"
+#, fuzzy
+#~ msgid "Database schema"
+#~ msgstr "Nome do banco de dados"
+#, fuzzy
+#~ msgid "database, SQL"
+#~ msgstr "base de dados SQL"
+#, fuzzy
+#~ msgid "Name of file with sql statement"
+#~ msgstr "nome do arquivo com a declaração SQL"
+#, fuzzy
+#~ msgid "The password was stored in file"
+#~ msgstr "A senha foi arquivada"
+#, fuzzy
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr "todos em atual para atual"
+#, fuzzy
+#~ msgid "Region sensitive output"
+#~ msgstr "Problema na leitura da saída r.stats"
+#, fuzzy
+#~ msgid "raster, elevation"
+#~ msgstr "Traçar elevação"
+#, fuzzy
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr "para."
+#, fuzzy
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Grupo de arquivos de imagem"
+#, fuzzy
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#, fuzzy
+#~ msgid "Compression for PNG files"
+#~ msgstr "Compactação nenhum"
+#, fuzzy
+#~ msgid "PostScript"
+#~ msgstr "Arquivo de saída PostScript"
+#, fuzzy
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "Não consegui copiar a tabela"
+#, fuzzy
+#~ msgid "raster, tiling"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "mapear"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#~ msgstr "mapear"
+#, fuzzy
+#~ msgid "general, extensions"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "Lista camadas disponíveis e finaliza"
+#, fuzzy
+#~ msgid "display, diagram"
+#~ msgstr "Exibir"
+#, fuzzy
+#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+#~ msgstr "acima para mapear"
+#, fuzzy
+#~ msgid "2nd map for mosaic."
+#~ msgstr "mapear."
+#, fuzzy
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Relatório de estatísticas para mapas raster."
+#, fuzzy
+#~ msgid ""
+#~ "Value to update the column with (varchar values have to be in single "
+#~ "quotes, e.g. 'grass')"
+#~ msgstr "para para para em"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#~ msgstr "Nome do mapa de orientação para exibição"
+#, fuzzy
+#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+#~ msgstr "mapear imagem em"
+#, fuzzy
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "exibir de"
+#, fuzzy
+#~ msgid "general, manual, help"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "Mapas raster para ler"
+#, fuzzy
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "para"
+#, fuzzy
+#~ msgid "Overwrite existing MASK"
+#~ msgstr "Substituir"
+#, fuzzy
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr "Nome de banco de dados banco de dados em substituído"
+#, fuzzy
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr "em de"
+#, fuzzy
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
+#~ msgstr "faixa para Cilindro faixa"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "Digite o nome da coluna para exibição"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcula estatísticas univariada das células não nulas de um mapa raster."
+#, fuzzy
+#~ msgid "Name of vector polygon map"
+#, fuzzy
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "Nome do mapa raster que conterá os resultados"
+#, fuzzy
+#~ msgid "GIS manager for GRASS"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importar."
+#, fuzzy
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr ""
+#, fuzzy
+#~ msgid "Show help"
+#~ msgstr "Mostrar"
+#, fuzzy
+#~ msgid "Display monitor to start"
+#~ msgstr "Exibir para"
+#, fuzzy
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "para para"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr "Número da camada. Se -1, todas as camadas serão exibidas"
+#, fuzzy
+#~ msgid "Name of PNG file"
+#~ msgstr "Nome do arquivo de rótulos"
+#, fuzzy
+#~ msgid "raster, landscape structure analysis"
+#, fuzzy
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
+#, fuzzy
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr "mapear status mapear mapear"
+#, fuzzy
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Não criar tabela de atributo."
+#, fuzzy
+#~ msgid "Layer where to add column"
+#~ msgstr "Camada para"
+#, fuzzy
+#~ msgid "Source monitor"
+#~ msgstr "Fonte"
+#, fuzzy
+#~ msgid "Computing row %d of covariance matrix..."
+#~ msgstr "Calculando matriz de covariância de classes..."
+#, fuzzy
+#~ msgid "imagery, rectify"
+#~ msgstr "Nome do grupo de imagens"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#~ msgstr ""
+#~ "Impossível abrir imagem real do diretório cell_misc.\n"
+#~ "Mapa de entrada provavelmente não foi criado por i.fft"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#~ msgstr ""
+#~ "Impossível abrir mapa imaginário no diretório cell_misc.\n"
+#, fuzzy
+#~ msgid "imagery, orthorectify"
+#, fuzzy
+#~ msgid ""
+#~ "Name of image to be rectified which will be initially drawn on screen"
+#~ msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
+#, fuzzy
+#~ msgid ""
+#~ "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgstr "Nome de mapear destino ativo."
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#~ msgstr "Grupo <%s> não encontrado."
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#, fuzzy
+#~ msgid "No initial camera exposure station for group [%s]"
+#~ msgstr "Adicionando arquivos ao grupo [%s]"
+#, fuzzy
+#~ msgid "Bad format in initial camera exposure station for group [%s]"
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "Não consegui obter informações da camada para o mapa vetorial"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+#~ msgid "Interactively select or modify the target elevation model."
+#~ msgstr "Selecionar trajeto interativamente"
+#, fuzzy
+#~ msgid "Target information for group [%s] missing\n"
+#~ msgstr "Informação de limites para [%s] indisponível"
+#, fuzzy
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#, fuzzy
+#~ msgid "Range less than or equal to zero not allowed"
+#~ msgstr "Limite menor ou igual a zero não permitido."
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
+#~ msgstr "Escrevendo versões visíveis do dado transformado para arquivos ..."
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#~ msgstr "Impossível abrir arquivo do diretório cell_misc."
+#, fuzzy
+#~ msgid "raster, terrain analysis"
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#~ msgstr "Nome do mapa vetorial (2d) de entrada"
+#, fuzzy
+#~ msgid "Eigen values:"
+#~ msgstr "Valor dos padrões de bits"
+#, fuzzy
+#~ msgid "display, legend"
+#~ msgstr "Espelhar legenda"
+#, fuzzy
+#~ msgid "Use regular expression instead of wildcard"
+#~ msgstr "de"
+#, fuzzy
+#~ msgid "Icon to remove"
+#~ msgstr "ícone para remover"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+#~ "(ercent_cover)"
+#~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
+#, fuzzy
+#~ msgid "Writing %s"
+#, fuzzy
+#~ msgid "ID values"
+#, fuzzy
+#~ msgid "To layer"
+#~ msgstr "Consultar"
+#, fuzzy
+#~ msgid "vector, attribute table"
+#~ msgstr "Mostra atributos do vetor"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %d \n"
+#~ "Type: %s \n"
+#~ "Left: %d \n"
+#~ "Right: %d \n"
+#~ msgstr "Linha: %d Tipo: %s Esquerda: %d Direita: %d "
+#, fuzzy
+#~ msgid ""
+#~ "Node[%d]: %d \n"
+#~ "Number of lines: %d \n"
+#~ "Coordinates: %.6f, %.6f, %.6f\n"
+#~ msgstr " Nó[%d]: %d Número de linhas: %d Coordenadas %.6f, %.6f %.6f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %5d \n"
+#~ "Angle: %.8f\n"
+#~ msgstr " Linha: %5d Ângulo: %.8f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Area: %d \n"
+#~ "Number of isles: %d\n"
+#~ msgstr "Área: %d Número de ilhas: %d\n"
+#, fuzzy
+#~ msgid "Type of elements"
+#~ msgstr "Nome do mapset de destino"
+#~ msgid "%s: %s - Unable to find the real-image map."
+#~ msgstr "%s: %s - Não encontrei o mapa imagem real."
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#~ msgstr "%s: %s - Não encontrei o mapa imaginário"
+#, fuzzy
+#~ msgid "Writing data to file..."
+#~ msgstr "Escrevendo dados transformados para o arquivo ..."
+#, fuzzy
+#~ msgid "Hue map name"
+#~ msgstr "%s=%s - nome ilegal"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#~ msgid "Output hue raster map"
+#~ msgstr "Mapa raster de saída"
+#, fuzzy
+#~ msgid "1 class."
+#~ msgstr "%d classes."
+#~ msgid "** Can't open seed singature file <%s> **"
+#~ msgstr "** Não consigo semear arquivo de assinatura <%s> **"
+#, fuzzy
+#~ msgid "Error writing result map file!"
+#~ msgstr "Erro tentando ler o arquivo dbmscap\n"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#~ msgid "Skipping [%s]..."
+#~ msgstr "Passando [%s]..."
+#, fuzzy
+#~ msgid "Name of the resultant map"
+#~ msgstr "Nome do mapa resultante"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#~ msgstr "Não consegui selecionar dados da tabela"
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#~ msgstr "Não consegui executar: %s"
+#, fuzzy
+#~ msgid "Done"
+#~ msgstr "Concluído."
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr "Não consegui abrir fonte de dados OGR '%s'"
+#, fuzzy
+#~ msgid "Column(s)"
+#, fuzzy
+#~ msgid "Unable to read category file for raster map <%s>"
+#~ msgstr "Editar arquivo de categorias para [%s]?"
+#, fuzzy
+#~ msgid "Reading %s ... "
+#~ msgstr "Lendo imagem ... "
+#~ msgid "%s in %s: %s"
+#~ msgstr "%s:em %s: %s"
+#, fuzzy
+#~ msgid "cannot read head of %s"
+#~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+#, fuzzy
+#~ msgid "Reading raster map <%s> ..."
+#~ msgid "No record for cat = %d"
+#~ msgstr "Sem registros para cat = %d"
+#, fuzzy
+#~ msgid "Vector map <%s> not found in current mapset"
+#~ msgid "Database connection not defined for layer <%d>"
+#~ msgstr "Conexão com banco de dados não definida para camada <%d>"
+#, fuzzy
+#~ msgid "Editing tool"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#~ msgid "Database record for cat %d not found"
+#~ msgstr "Sem registro no banco para categoria %d"
+#, fuzzy
+#~ msgid "Cannot open file for <%s>"
+#~ msgstr "Não consegui abrir o arquivo [%s]"
+#~ msgid "Name of the random surface to be produced"
+#~ msgstr "Nome da superfície aleatória a produzir"
+#~ msgid "Cannot open file [%s]"
+#, fuzzy
+#~ msgid "Read coordinates from standard input"
+#~ msgstr "Obtém coordenadas a partir da \"entrada padrão\" (stdin)"
+#, fuzzy
+#~ msgid "%s - illegal name"
+#, fuzzy
+#~ msgid "Error reading map %s"
+#~ msgstr "Erro lendo arquivo raster [%s]."
+#, fuzzy
+#~ msgid "Closing raster map"
+#~ msgstr "Mapa raster de cobertura"
+#~ msgid "Name of the new raster map"
+#, fuzzy
+#~ msgid "Could not close the 3d raster map"
+#~ msgstr "Não consegui fechar o novo mapa g3d"
+#~ msgid "Could not find input vector map %s"
+#~ msgstr "Não consegui encontrar o mapa vetorial de entrada %s"
+#~ msgid "Can't create output map"
+#, fuzzy
+#~ msgid "name for new vector map"
+#~ msgstr "Nome do novo arquivo raster."
+#, fuzzy
+#~ msgid "Cover raster map"
+#~ msgstr "Mapa de cobertura"
+#~ msgid "Topographic index ln(a/tanB) map"
+#~ msgstr "Mapa de índice topográfico [ln(a/tanB)]"
+#~ msgid "No input coordinates provided"
+#~ msgstr "Coordenadas de entrada não foram informadas"
+#~ msgid "Database name:"
+#~ msgstr "Banco de dados:"
+#, fuzzy
+#~ msgid "Path to the input file"
+#~ msgid ""
+#~ "Number of column used as z coordinate (first column is 1) for points "
+#~ "mode. If 0, z coordinate is not used."
+#~ msgstr ""
+#~ "Número da coluna usada como coordenada z (primeira coluna é 1) para o "
+#~ "modo de pontos. Se 0, coordenada z não é usada."
+#, fuzzy
+#~ msgid "Name of the output walkers site file"
+#~ msgstr "Nome do raster de saída"
+#~ msgid "column type not supported"
+#~ msgstr "tipo de coluna não suportado"
+#, fuzzy
+#~ msgid "%s - too many patch files. only %d allowed"
+#~ msgstr "correção"
+#, fuzzy
+#~ msgid "category [%d]"
+#~ msgstr ""
+#~ "Camada: %d\n"
+#~ "categoria: %d\n"
+#, fuzzy
+#~ msgid "Interpolation()"
+#~ msgstr "Método de intepolação a usar"
+#, fuzzy
+#~ msgid "Calculation time"
+#~ msgstr "Calculando médias das classes ..."
+#, fuzzy
+#~ msgid "History line too long: truncating to %d characters"
+#~ msgstr "Histórico para"
+#~ msgid "Name of output 3d raster map"
+#~ msgstr "Nome do arquivo G3D de saída"
+#, fuzzy
+#~ msgid "input layer name"
+#~ msgstr "Nome da tabela de entrada"
+#, fuzzy
+#~ msgid "Column name (will be updated by qvector values)"
+#~ msgstr "Coluna"
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr "[%s] é um nome ilegal"
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_ru.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -5059,7 +5059,7 @@
#: ../raster/r.topmodel/main.c:137
#, fuzzy
msgid "Output"
-msgstr "ÐÑÑ
од:"
+msgstr " "
#: ../raster/simwe/r.sim.sediment/main.c:183
#, fuzzy
@@ -13244,7 +13244,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "Ðевозможно оÑкÑÑÑÑ Ð¸ÑÑ
однÑй Ñайл <%s>"
+msgstr "Ðевозможно закÑÑÑÑ Ð¸ÑÑ
однÑй Ñлой"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -19028,7 +19028,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr " "
+msgstr "СоздаÑÑ Ð²ÑÑ
одной 3D Ñлой"
#: ../vector/v.random/main.c:111
msgid "Maximum z height (needs -z flag or column name)"
@@ -21070,9 +21070,8 @@
msgstr "ÐÑибка в pj_do_transform"
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "СоздаÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ GRASS."
+msgstr ""
#: ../vector/v.hull/main.c:64
msgid "Use all vector points (do not limit to current region)"
@@ -21100,7 +21099,7 @@
#: ../vector/v.hull/hull.c:106
#, fuzzy
msgid "Simple planar hulls not implemented yet"
-msgstr "ÐейÑÑвие '%s' еÑе не Ñеализовано"
+msgstr " "
#: ../vector/v.in.dwg/main.c:84
msgid "Converts DWG/DXF to GRASS vector map"
@@ -25309,7 +25308,6 @@
#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.centrality/main.c:148
-#, fuzzy
msgid "Columns"
msgstr "СÑолбÑÑ"
@@ -25374,7 +25372,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "РазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹ (ÑоÑеÑнÑй Ñежим)"
+msgstr "ÐÑвеÑÑи ÑÑаÑиÑÑÐ¸ÐºÑ Ð² ÑÑиле shell"
#: ../vector/v.db.connect/main.c:84
msgid "Print all map connection parameters and exit"
@@ -28457,7 +28455,6 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
-#, fuzzy
msgid "Misc"
msgstr "Разное"
@@ -28478,8 +28475,11 @@
"ÑÐ°Ð¹Ð»Ñ Ð¸Ð½ÑÑÑÑкÑии psmap не бÑдÑÑ ÑозданÑ) "
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
+#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
msgstr ""
+"ÐоÑÐµÐ½Ñ Ð¸Ð¼ÐµÐ½Ð¸ Ñайлов инÑÑÑÑкÑии psmap в ÑекÑÑей папке (еÑли не ÑÑÑановлено, "
+"ÑÐ°Ð¹Ð»Ñ Ð¸Ð½ÑÑÑÑкÑии psmap не бÑдÑÑ ÑозданÑ) "
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Name of group file where thematic map commands will be saved"
@@ -31566,6 +31566,446 @@
msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr "ÐелÑÐ·Ñ Ð¾ÑмеÑиÑÑ ÐµÑе Ð¾Ð´Ð½Ñ ÑоÑкÑ. РазÑеÑено ÑолÑко %d ÑоÑек."
+#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr ""
+"ÐоказаÑÑ Ð¸ наложиÑÑ ÑаÑÑÑовÑе Ñлои в акÑивном ÑÑейме гÑаÑиÑеÑкого мониÑоÑа."
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr ""
+"ÐÐ¼Ñ Ð¸ Ñип нового Ð¿Ð¾Ð»Ñ (полей) (ÑÐ¸Ð¿Ñ Ð·Ð°Ð²Ð¸ÑÑÑ Ð¾Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, но вÑе "
+"поддеÑживаÑÑ VARCHAR(), INT, DOUBLE and DATE)"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "ÐмпоÑÑиÑÑемÑй ÑаÑÑÑовÑй Ñайл"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr ""
+"Файл ÑодеÑжаÑий пÑавила подпиÑей каÑегоÑий (или \"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¸Ð· stdin)"
+#, fuzzy
+msgid "GDAL datatype: %s, range: %f - %f"
+msgstr "РаÑÑÑовÑй Ñлой <%s> Ñоздан."
+#, fuzzy
+msgid "terrain analysis"
+msgstr "ÑаÑÑÑ, анализ ÑелÑеÑа"
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> на ÑÑовне Ñопологии %d"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr ""
+"mi (мили), f (ÑÑÑÑ), me (меÑÑÑ), k (киломеÑÑÑ), a (акÑÑ), h (гекÑаÑÑ), p "
+"(пÑоÑенÑÑ)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+msgstr "ÐÑвеÑÑи ÑезÑлÑÑаÑÑ Ð² ÑÑиле shell ÑкÑипÑа"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "ÐаÑÑÑабиÑоваÑÑ Ð¿Ð¾Ð»ÑÑеннÑе знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑа"
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "<%s> Ñоздано в базе даннÑÑ
+#, fuzzy
+msgid ""
+"Calculate the groundwater distance velocity vector field \n"
+"and write the x, y, and z components to maps named name_[xyz].\n"
+"Name is basename for the new raster3d maps"
+msgstr ""
+"ÐÑÑиÑлиÑÑ ÑаÑÑÑоÑние, ÑкоÑоÑÑÑ Ð²ÐµÐºÑоÑного Ð¿Ð¾Ð»Ñ Ð³ÑÑнÑовÑÑ
вод и запиÑаÑÑ x, "
+"y, z ÑоÑÑавлÑÑÑие в Ñлои Ñ Ð¸Ð¼ÐµÐ½Ð°Ð¼Ð¸ name_[xyz]. Name - пÑеÑÐ¸ÐºÑ Ð´Ð»Ñ Ð½Ð¾Ð²ÑÑ
+"ÑаÑÑÑовÑÑ
3D Ñлоев"
+#, fuzzy
+msgid "report"
+msgstr "РаÑÑиÑеннÑй оÑÑеÑ"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Ðевозможна запиÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²ÐºÐ° Ð´Ð»Ñ %s"
+#, fuzzy
+msgid "Error reading <%s>"
+msgstr " "
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#, fuzzy
+msgid "r.li.worker (pid %i) exited with abnormal status: %i"
+msgstr "r.li.worker (pid %i) завеÑÑилÑÑ Ð½ÐµÑдаÑно %i"
+#, fuzzy
+msgid "r.li.worker (pid %i) terminated successfully"
+msgstr "r.li.worker (pid %i) пÑеÑван"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s> в <%s>"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñегион <%s> в <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ ÑезÑлÑÑиÑÑÑÑий Ñайл <%s>"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+msgstr "Ðевозможно ÑÑение ÑÑÑоки %d (оÑибка = %d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "Ðевозможно ÑÑÑановиÑÑ Ñегион Ð´Ð»Ñ Ð²Ð¾Ð·Ð²ÑаÑа к наÑалÑÐ½Ð¾Ð¼Ñ ÑегионÑ!!!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑÐ¾ÐºÑ %i\n"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Ðевозможно задаÑÑ Ñегион <%s>"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой аккÑмÑлÑÑии"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+msgstr "ÐолÑÑение полигонов..."
+#, fuzzy
+msgid "Error reading row <%d>"
+msgstr "ÐÑибка запиÑи нÑлевой ÑÑÑоки [%d]."
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr ""
+"ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑодеÑжаÑего знаÑÐµÐ½Ð¸Ñ ÑаÑÑ
одов на пÑеодоление"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð¸ÑÑ
однÑй Ñайл <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Pass %d:"
+msgstr "ÐÑоÑ
од %d..."
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑÐ¾ÐºÑ %d ÑаÑÑÑового ÑлоÑ"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "ÐÑибка запиÑи ÑÑÑоки %d ÑаÑÑÑового ÑлоÑ"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>, ÑÑÑока %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "Ðевозможно запиÑаÑÑ ÑаÑÑÑовÑе Ñлои"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> в <%s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+msgstr " "
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr " "
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "ÐÐ¼Ñ Ð´Ð»Ñ Ð²ÑÑ
одного ÑаÑÑÑового Ñайла"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "имÑ"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Ðазвание Ñайла PNG"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr "ЧиÑло гÑÐ°Ð½Ð¸Ñ Ð²Ð½Ðµ диапазона"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+msgstr " "
+msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
+msgstr "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS в ÑаÑÑÑовÑй Ñлой GRASS."
+msgid "%d points written to vector map"
+msgstr "%d ÑоÑек запиÑано в векÑоÑнÑй Ñлой"
+msgid "Traces a flow through an elevation model on a raster map layer."
+msgstr "ÐÑоведение поÑока ÑеÑез Ð¼Ð¾Ð´ÐµÐ»Ñ Ð²ÑÑÐ¾Ñ Ð½Ð° ÑаÑÑÑовом Ñлое каÑÑÑ."
+msgid "The E and N coordinates of starting point(s)"
+msgstr "ÐооÑдинаÑÑ E и N наÑалÑной ÑоÑки (ÑоÑек)"
+msgid "Vector map(s) containing starting point(s)"
+msgstr "ÐекÑоÑнÑй Ñлой (Ñлои) ÑодеÑжаÑий наÑалÑнÑÑ ÑоÑÐºÑ (ÑоÑки)"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "ÑаÑÑÑ, импоÑÑ, конвеÑÑаÑиÑ"
+msgid ""
+"Outputs a raster map layer showing the cumulative cost of moving between "
+"different geographic locations on an input raster map layer whose cell "
+"category values represent cost."
+msgstr ""
+"ÐÑвеÑÑи ÑаÑÑÑовÑй Ñлой показÑваÑÑий кÑмÑлÑÑивнÑÑ ÑÑоимоÑÑÑ Ð¿ÐµÑемеÑÐµÐ½Ð¸Ñ Ð¼ÐµÐ¶Ð´Ñ "
+"ÑазнÑми меÑÑоположениÑми иÑÑ
одного ÑаÑÑÑового Ñлой, ÑÑи ÑÑейки имеÑÑ "
+"знаÑение ÑÑоимоÑÑи."
+msgid "Bad Start Cell"
+msgstr "ÐевеÑÐ½Ð°Ñ Ð½Ð°ÑалÑÐ½Ð°Ñ ÑÑейка"
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD"
+msgstr "СÐÐЦÐЯ 3: ÐккÑмÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока."
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "%s: %s - Ðевозможно найÑи Ñлой веÑеÑÑвенного изобÑажениÑ."
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"Ðевозможно оÑкÑÑÑÑ Ð²ÐµÑеÑÑвенного изобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð² каÑалоге cell_misc.\n"
+"ÐÑÑ
однÑй Ñлой не бÑÐ´ÐµÑ Ñоздан i.fft"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "%s: %s - Ðевозможно найÑи Ñлой мнимого изобÑажениÑ."
+#, fuzzy
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"Ðевозможно оÑкÑÑÑÑ Ð¼Ð½Ð¸Ð¼Ð¾Ðµ изобÑажение в каÑалоге cell_misc.\n"
+"ÐÑÑ
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "ÐÑÑппа [%s] не найдена."
+#, fuzzy
+msgid "Range less than or equal to zero not allowed."
+msgstr "Ðиапазон менÑÑе или ÑавнÑй нÑÐ»Ñ Ð½ÐµÐ´Ð¾Ð¿ÑÑÑим."
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "ÐапиÑÑ Ð¿ÑоÑмаÑÑиваемÑÑ
веÑÑий ÑÑанÑÑоÑмиÑованнÑÑ
даннÑÑ
в ÑайлÑ..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл в каÑалоге cell_misc."
+#, fuzzy
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr "ÐÐ¼Ñ ÑÑанÑÑоÑмиÑÑемого изобÑажениÑ, показÑваемого на ÑкÑане."
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr "ÐÐ¼Ñ ÑÐ»Ð¾Ñ Ð¸Ð· Ñелевого набоÑа, показÑваемого на ÑкÑане."
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) (types depend on database backend, but "
+"all support VARCHAR(), INT, DOUBLE and DATE)"
+msgstr ""
, но вÑе "
+#, fuzzy
+msgid "Use output= option to change vector map name"
+msgstr "ÐÑполÑзоваÑÑ Ð¾Ð¿ÑÐ¸Ñ '%s' Ð´Ð»Ñ ÑÐ¼ÐµÐ½Ñ Ð¸Ð¼ÐµÐ½Ð¸ векÑоÑного ÑлоÑ"
+#, fuzzy
+msgid "Cannot read category file of raster map <%s>"
+msgstr " "
+#, fuzzy
+msgid "Displays thematic vectormap"
+msgstr "ÐÑобÑазиÑÑ ÑемаÑиÑеÑкий векÑоÑнÑй Ñлой"
+#, fuzzy
+msgid ""
+"Name of old database. The database must be in form printed by v.db.connect -"
+"g, i.e. with substituted variables"
+msgstr ""
+"ÐÐ¼Ñ ÑÑаÑой Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. Ðаза даннÑÑ
должна бÑÑÑ Ñказана в ÑоÑме задаваемой v."
+"db.connect -g, Ñо еÑÑÑ Ñ Ð¿Ð¾Ð´Ð¼ÐµÐ½ÐµÐ½Ð½Ñми пеÑеменнÑми."
+#, fuzzy
+msgid "Category file for [%s] not available"
+msgstr " "
+#, fuzzy
+msgid "color file for [%s] not available"
+msgstr " "
+#, fuzzy
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "Ð¸Ð¼Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ обÑаза ÑÐ»Ð¾Ñ (наÑ
одиÑÑÑ Ð² ~/.gpsdrive)"
+msgid "Bad format in initial exposusre station file for group [%s]"
+msgstr ""
+"ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла наÑалÑной ÑкÑпозиÑии ÑÑанÑии Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
+msgid "Default value: GRASS_GUI if defined otherwise tcltk"
+msgstr "ÐнаÑение по ÑмолÑаниÑ: GRASS_GUI еÑли ÑÑÑановлен, инаÑе - tcltk"
+#, fuzzy
+msgid ""
+"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
+"Display Manager (d.m);wxpython;wxPython based next generation GUI;text;"
+"command line interface only"
+msgstr ""
+"tcltk;GUI оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ GIS (gis.m);oldtcltk;СÑаÑÑй GUI "
+"оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð´Ð¸Ñплеев (d.m);wxpython;GUI нового Ð¿Ð¾ÐºÐ¾Ð»ÐµÐ½Ð¸Ñ "
+"оÑнованнÑй на wxPython "
+#, fuzzy
+msgid "raster input map (green: tm2 | qbird_green | spot1)"
+msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (green: tm2 | qbird_green | spot1)"
+#, fuzzy
+msgid "raster input map (NIR: tm4 | qbird_nir | spot2)"
+msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (NIR: tm4 | qbird_nir | spot2)"
+#, fuzzy
+msgid "raster input map (MIR; tm5 | qbird_red | spot3)"
+msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+msgid "raster input map (etmpan | qbird_pan | spotpan)"
+msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (etmpan | qbird_pan | spotpan)"
+#, fuzzy
+msgid "raster output map prefix (e.g. 'brov')"
+msgstr "пÑеÑÐ¸ÐºÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (напÑÐ¸Ð¼ÐµÑ 'brov')"
+#, fuzzy
+msgid "Auto-balancing of colors for LANDSAT images"
+msgstr "ÐвÑомаÑиÑеÑÐºÐ°Ñ Ð±Ð°Ð»Ð°Ð½ÑиÑовка ÑвеÑов Ð´Ð»Ñ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ LANDSAT"
+#, fuzzy
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+"ÐоказаÑÑ ÑпекÑÑалÑное оÑÑажение Ð´Ð»Ñ Ð³ÑÑпп или изобÑажений, опÑеделеннÑÑ
+"полÑзоваÑелем"
+#, fuzzy
+msgid "group input"
+msgstr "иÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð³ÑÑппа"
+#, fuzzy
+msgid "write output to PNG image"
+msgstr "запиÑаÑÑ ÑезÑлÑÑÐ°Ñ Ð² изобÑажение PNG"
+#, fuzzy
+msgid "label with coordinates instead of numbering"
+msgstr "подпиÑаÑÑ ÐºÐ¾Ð¾ÑдинаÑами вмеÑÑо ÑиÑел"
+#, fuzzy
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)"
+msgstr ""
+"ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой болÑÑе или менÑÑе Ñем плоÑÐ°Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð°Ñ "
+"полÑзоваÑелем (в гекÑаÑаÑ
+#, fuzzy
+msgid "lesser val option that sets the <= area size limit [hectares]"
+msgstr ""
+"менÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ <= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
+"[гекÑаÑÑ]"
+#, fuzzy
+msgid "greater val option that sets the >= area size limit [hectares]"
+msgstr ""
+"болÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ >= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
+"[гекÑаÑÑ]"
+#, fuzzy
+msgid "Layer number. If -1, all layers are extracted"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ. ÐÑли -1, полÑÑаÑÑÑÑ Ð²Ñе Ñлои"
#~ msgid "Not enough room in history file"
#~ msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¼ÐµÑÑа в Ñайле иÑÑоÑии"
@@ -31587,12 +32027,6 @@
#~ msgid "Name of workspace file"
#~ msgstr "ÐÐ¼Ñ Ñайла пÑоекÑа"
-#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr ""
-#~ "ÐоказаÑÑ Ð¸ наложиÑÑ ÑаÑÑÑовÑе Ñлои в акÑивном ÑÑейме гÑаÑиÑеÑкого "
-#~ "мониÑоÑа."
#~ msgid "List of values to be displayed (FP maps)"
#~ msgstr "СпиÑок знаÑений Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (Ñлои FP)"
@@ -31704,15 +32138,6 @@
#~ msgid "DXY [%s] COMPLETE"
#~ msgstr "ÐавеÑÑено: DXY [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr ""
-#~ "ÐÐ¼Ñ Ð¸ Ñип нового Ð¿Ð¾Ð»Ñ (полей) (ÑÐ¸Ð¿Ñ Ð·Ð°Ð²Ð¸ÑÑÑ Ð¾Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, но вÑе "
-#~ "поддеÑживаÑÑ VARCHAR(), INT, DOUBLE and DATE)"
#~ msgid "Sources and sinks in [m^3/s]"
#~ msgstr "ÐÑиÑок и ÑÑок в [м^3/Ñек]"
@@ -31729,15 +32154,6 @@
#~ msgid "Layer number of data column"
#~ msgstr "Слой к коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð¸ÑÑ ÑÑолбеÑ"
-#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "ÐмпоÑÑиÑÑемÑй ÑаÑÑÑовÑй Ñайл"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr ""
-#~ "Файл ÑодеÑжаÑий пÑавила подпиÑей каÑегоÑий (или \"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¸Ð· stdin)"
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Ð¡Ð¾Ð·Ð´Ð°ÐµÑ ÑаÑÑÑовÑй Ñлой каÑÑÑ, показÑваÑÑий ÑÑббаÑÐµÐ¹Ð½Ñ Ð²Ð¾Ð´Ð¾Ñаздела."
@@ -31760,10 +32176,6 @@
#~ "иÑполÑзовалоÑÑ Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений no-data иÑÑ
одного ÑлоÑ. ÐÑ Ð¼Ð¾Ð¶ÐµÑе "
#~ "задаÑÑ Ð·Ð½Ð°Ñение no-data ÑеÑез паÑамеÑÑ %s."
-#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#~ msgstr "РаÑÑÑовÑй Ñлой <%s> Ñоздан."
#~ msgid "Name of the elevation raster map [m]"
#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð²ÑÑÐ¾Ñ [m]"
@@ -31845,10 +32257,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr "(i) Ðо вÑбоÑÑ Ð²ÑÑ
од Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ клаÑÑа ÑопогÑаÑиÑеÑкого индекÑа"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "ÑаÑÑÑ, анализ ÑелÑеÑа"
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ, ÑодеÑжаÑего повеÑÑ
ноÑÑÑ Ð²ÑÑоÑ"
@@ -31912,20 +32320,6 @@
#~ msgid "Unable to access table <%s>"
#~ msgstr "Ðевозможно ÑоздаÑÑ ÑаблиÑÑ: <%s>"
-#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> на ÑÑовне Ñопологии %d"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr ""
-#~ "mi (мили), f (ÑÑÑÑ), me (меÑÑÑ), k (киломеÑÑÑ), a (акÑÑ), h (гекÑаÑÑ), p "
-#~ "(пÑоÑенÑÑ)"
#~ msgid "Experimental NVIZ CLI prototype."
#~ msgstr "ÐкÑпеÑименÑалÑнÑй пÑоÑоÑип NVIZ CLI"
@@ -31942,10 +32336,6 @@
#~ "ÐонвеÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой GRASS в PPM изобÑажение Ñ ÑазÑеÑением "
#~ "ÑекÑÑего Ñегиона."
-#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "ÐÑвеÑÑи ÑезÑлÑÑаÑÑ Ð² ÑÑиле shell ÑкÑипÑа"
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -31956,10 +32346,6 @@
#~ msgid "Band to select"
#~ msgstr "ÐÑÐ±Ð¾Ñ ÐºÐ°Ð½Ð°Ð»Ð°"
-#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "ÐаÑÑÑабиÑоваÑÑ Ð¿Ð¾Ð»ÑÑеннÑе знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑа"
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "Ðевозможно ÑоздаÑÑ <Auxiliar_outlier_table>."
@@ -31973,10 +32359,6 @@
#~ msgstr ""
#~ "Ðоле аÑÑибÑÑивной ÑаблиÑÑ Ñ Ð¸Ð½ÑеÑполиÑÑемÑми знаÑениÑми (еÑли layer>0)"
-#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "<%s> Ñоздано в базе даннÑÑ
#~ msgid "M.Q. solution"
#~ msgstr "ÑеÑение M.Q."
@@ -32022,17 +32404,7 @@
#~ msgid "Unable to close elevation map"
#~ msgstr "Ðевозможно закÑÑÑÑ Ñлой вÑÑоÑ"
-#, fuzzy
#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new raster3d maps"
-#~ msgstr ""
-#~ "ÐÑÑиÑлиÑÑ ÑаÑÑÑоÑние, ÑкоÑоÑÑÑ Ð²ÐµÐºÑоÑного Ð¿Ð¾Ð»Ñ Ð³ÑÑнÑовÑÑ
вод и запиÑаÑÑ "
-#~ "x, y, z ÑоÑÑавлÑÑÑие в Ñлои Ñ Ð¸Ð¼ÐµÐ½Ð°Ð¼Ð¸ name_[xyz]. Name - пÑеÑÐ¸ÐºÑ Ð´Ð»Ñ "
-#~ "новÑÑ
ÑаÑÑÑовÑÑ
3D Ñлоев"
-#~ msgid ""
#~ "Use a sparse linear equation system, only available with iterative solvers"
#~ msgstr ""
#~ "ÐÑполÑзование ÑаÑÑеÑнной ÑиÑÑÐµÐ¼Ñ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ
ÑÑавнений, доÑÑÑпно ÑолÑко пÑи "
@@ -32059,19 +32431,11 @@
#~ msgid "Unable to write raster row"
#~ msgstr "Ðевозможно запиÑаÑÑ ÑаÑÑÑовÑй ÑÑд"
-#, fuzzy
-#~ msgid "report"
-#~ msgstr "РаÑÑиÑеннÑй оÑÑеÑ"
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr ""
#~ "(пÑоÑенÑÑ)"
-#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Ðевозможна запиÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²ÐºÐ° Ð´Ð»Ñ %s"
#~ msgid "Unable to write quant file"
#~ msgstr "ÐÑибка запиÑи в Ñайл кванÑованиÑ"
@@ -32112,10 +32476,6 @@
#~ msgid "Unable to read header of raster map <%s>"
#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
-#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr " "
#~ msgid "Reading row %d"
#~ msgstr "ЧÑение ÑÑда %d"
@@ -32224,24 +32584,12 @@
#~ msgid "Cannot read row"
#~ msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑокÑ"
-#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#~ msgid "Error in pipe creation"
#~ msgstr "ÐÑибка пÑи Ñоздании канала"
#~ msgid "Error opening channel %i"
#~ msgstr "ÐÑибка пÑи оÑкÑÑÑии канала %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) завеÑÑилÑÑ Ð½ÐµÑдаÑно %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) пÑеÑван"
#~ msgid "Cannot close %s file (PIPE)"
#~ msgstr "Ðевозможно закÑÑÑÑ Ñайл %s (PIPE)"
@@ -32338,32 +32686,12 @@
#~ " \t\t\t\tpid = %i \n"
-#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s> в <%s>"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñегион <%s> в <%s>"
#~ msgid "Unable to get header for %s"
#~ msgid "Cannot reset current region"
#~ msgstr "Ðевозможно ÑбÑоÑиÑÑ ÑекÑÑий Ñегион"
-#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÑезÑлÑÑиÑÑÑÑий Ñайл <%s>"
#~ msgid "Cannot create category file for <%s>"
#~ msgstr "Ðевозможно ÑоздаÑÑ Ñайл каÑегоÑий Ð´Ð»Ñ <%s>"
@@ -32398,22 +32726,6 @@
#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑÐ»Ð¾Ñ 'saturation'"
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#~ msgstr "Ðевозможно ÑÑение ÑÑÑоки %d (оÑибка = %d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "Ðевозможно ÑÑÑановиÑÑ Ñегион Ð´Ð»Ñ Ð²Ð¾Ð·Ð²ÑаÑа к наÑалÑÐ½Ð¾Ð¼Ñ ÑегионÑ!!!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>, ÑÑÑока %d"
@@ -32438,10 +32750,6 @@
#~ msgid "Error writing null row [%d]."
#~ msgstr "ÐÑибка запиÑи нÑлевой ÑÑÑоки [%d]."
-#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑÐ¾ÐºÑ %i\n"
#~ msgid "Swapping header data"
#~ msgstr "Ðамена даннÑÑ
заголовка"
@@ -32457,10 +32765,6 @@
#~ msgid "Failed writing raster map row %d"
#~ msgstr "ÐÑибка запиÑи ÑÑÑоки %d ÑаÑÑÑового ÑлоÑ"
-#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Ðевозможно задаÑÑ Ñегион <%s>"
#~ msgid "Invalid region: %s"
#~ msgstr "ÐепÑавилÑнÑй Ñегион: %s"
@@ -32511,14 +32815,6 @@
#~ msgid "unable to open accum file in valid_basins()"
#~ msgstr "невозможно оÑкÑÑÑÑ Ñайл аккÑмÑлÑÑии в valid_basins()"
-#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#~ msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой аккÑмÑлÑÑии"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "ÐолÑÑение полигонов..."
#~ msgid "Can't create raster map <%s>"
#~ msgstr "Ðевозможно ÑоздаÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
@@ -32534,15 +32830,6 @@
#~ msgid "Unable to close new basin map layer"
#~ msgstr "Ðевозможно закÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой баÑÑейнов"
-#, fuzzy
-#~ msgid "Error reading row <%d>"
-#~ msgstr "ÐÑибка запиÑи нÑлевой ÑÑÑоки [%d]."
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr ""
-#~ "ÐÐ¼Ñ Ð¸ÑÑ
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "ÐÐ¾Ð¼ÐµÑ Ñоздаваемого ÑегменÑа (библиоÑека ÑегменÑов)"
@@ -32656,14 +32943,6 @@
#~ "иÑеÑаÑионном алгоÑиÑме"
-#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð¸ÑÑ
однÑй Ñайл <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
#~ msgid "Error reading input"
#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
@@ -32682,10 +32961,6 @@
#~ msgid "<Auxiliar_edge_table> created in database."
#~ msgstr "<Auxiliar_edge_table> Ñоздана в базе даннÑÑ
-#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "ÐÑоÑ
од %d..."
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "Создание дополниÑелÑной ÑаблиÑÑ Ð´Ð»Ñ Ð½Ð°Ñ
Ð¾Ð¶Ð´ÐµÐ½Ð¸Ñ Ð·Ð¾Ð½ пеÑеÑеÑений"
@@ -32883,21 +33158,9 @@
#~ msgid "Current region cannot be set."
#~ msgstr "Ðевозможно ÑÑÑановиÑÑ ÑекÑÑий Ñегион."
-#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#~ msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑÐ¾ÐºÑ %d ÑаÑÑÑового ÑлоÑ"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "ÐÑибка запиÑи ÑÑÑоки %d ÑаÑÑÑового ÑлоÑ"
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ Ð¸ÑÑ
одного бÑÑеÑа ÑÑÑоки"
-#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>, ÑÑÑока %d"
#~ msgid "Unable to open the cell map MASK."
#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ñлой MASK."
@@ -32916,14 +33179,6 @@
#~ msgid "Unable to open band files."
#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÑÐ°Ð¹Ð»Ñ ÐºÐ°Ð½Ð°Ð»Ð¾Ð²."
-#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "Ðевозможно запиÑаÑÑ ÑаÑÑÑовÑе Ñлои"
#~ msgid "Error while reading input raster map."
одного ÑаÑÑÑового ÑлоÑ."
@@ -32934,40 +33189,12 @@
#~ msgstr "ÐÑибка запиÑи ÑÐ»Ð¾Ñ ÑÑеек в пÑоÑеÑÑе ÑÑанÑÑоÑмаÑии."
#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> в <%s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#~ msgstr " "
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr " "
-#, fuzzy
#~ msgid "Could not open <%s>"
#~ msgstr " "
#~ msgid "Could not read from <%s>"
#~ msgstr "Ðевозможно пÑоÑеÑÑÑ Ð¸Ð· <%s>"
-#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#~ msgstr "ÐÐ¼Ñ Ð´Ð»Ñ Ð²ÑÑ
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
#~ msgid "Error reading row of data"
#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑÑÑоки даннÑÑ
@@ -33208,22 +33435,6 @@
#~ msgid "imagery, FFT"
#~ msgstr "изобÑажениÑ, FFT"
-#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "имÑ"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "Ðазвание Ñайла PNG"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr "ЧиÑло гÑÐ°Ð½Ð¸Ñ Ð²Ð½Ðµ диапазона"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#~ msgstr " "
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "изобÑажениÑ, клаÑÑиÑикаÑÐ¸Ñ Ñ Ð¾Ð±ÑÑением, SMAP"
@@ -33315,11 +33526,6 @@
#~ msgid "vector, raster, conversion"
#~ msgstr "векÑоÑ, ÑаÑÑÑ, конвеÑÑаÑиÑ"
-#~ msgid ""
-#~ "Converts a binary GRASS vector map layer into a GRASS raster map layer."
-#~ msgstr ""
-#~ "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS в ÑаÑÑÑовÑй Ñлой GRASS."
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
#~ msgstr "mi(мили),f(ÑÑÑÑ),me(меÑÑÑ),k(киломеÑÑÑ),a(акÑÑ),h(гекÑаÑÑ)"
@@ -33439,9 +33645,6 @@
#~ msgid "Unknown keyword <%s> in vector head"
#~ msgstr "ÐеизвеÑÑное клÑÑевое Ñлово <%s> в заголовке векÑоÑа"
-#~ msgid "%d points written to vector map"
-#~ msgstr "%d ÑоÑек запиÑано в векÑоÑнÑй Ñлой"
#~ msgid "vector, raster, attribute table"
#~ msgstr "векÑоÑ, ÑаÑÑÑ, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
@@ -33624,18 +33827,9 @@
#~ msgid "Selects data from table."
#~ msgstr "ÐÑбÑаÑÑ Ð´Ð°Ð½Ð½Ñе из ÑаблиÑÑ."
-#~ msgid "Traces a flow through an elevation model on a raster map layer."
-#~ msgstr "ÐÑоведение поÑока ÑеÑез Ð¼Ð¾Ð´ÐµÐ»Ñ Ð²ÑÑÐ¾Ñ Ð½Ð° ÑаÑÑÑовом Ñлое каÑÑÑ."
#~ msgid "Output drain raster map"
#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой водоÑÑока"
-#~ msgid "The E and N coordinates of starting point(s)"
-#~ msgstr "ÐооÑдинаÑÑ E и N наÑалÑной ÑоÑки (ÑоÑек)"
-#~ msgid "Vector map(s) containing starting point(s)"
-#~ msgstr "ÐекÑоÑнÑй Ñлой (Ñлои) ÑодеÑжаÑий наÑалÑнÑÑ ÑоÑÐºÑ (ÑоÑки)"
#~ msgid ""
#~ "Unused; retained for compatibility purposes, will be removed in future"
#~ msgstr ""
@@ -33714,10 +33908,6 @@
#~ msgid "raster, export, VRML"
#~ msgstr "ÑаÑÑÑ, ÑкÑпоÑÑ, VRML"
-#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "ÑаÑÑÑ, импоÑÑ, конвеÑÑаÑиÑ"
#~ msgid "raster, flow, hydrology"
#~ msgstr "ÑаÑÑÑ, поÑок, гидÑологиÑ"
@@ -33730,15 +33920,6 @@
#~ msgid "raster, cost surface, cumulative costs"
#~ msgstr "ÑаÑÑÑ, повеÑÑ
ноÑÑÑ ÑÑоимоÑÑи, кÑмÑлÑÑÐ¸Ð²Ð½Ð°Ñ ÑÑоимоÑÑÑ"
-#~ msgid ""
-#~ "Outputs a raster map layer showing the cumulative cost of moving between "
-#~ "different geographic locations on an input raster map layer whose cell "
-#~ "category values represent cost."
-#~ msgstr ""
-#~ "ÐÑвеÑÑи ÑаÑÑÑовÑй Ñлой показÑваÑÑий кÑмÑлÑÑивнÑÑ ÑÑоимоÑÑÑ Ð¿ÐµÑемеÑÐµÐ½Ð¸Ñ "
-#~ "Ð¼ÐµÐ¶Ð´Ñ ÑазнÑми меÑÑоположениÑми иÑÑ
одного ÑаÑÑÑового Ñлой, ÑÑи ÑÑейки "
-#~ "имеÑÑ Ð·Ð½Ð°Ñение ÑÑоимоÑÑи."
#~ msgid "Source map is: Integer cell type"
#~ msgstr "ÐÑÑ
однÑй Ñлой ÑелоÑиÑленного Ñипа"
@@ -33770,9 +33951,6 @@
#~ msgid "Nothing to show"
#~ msgstr "ÐеÑего показаÑÑ"
-#~ msgid "Bad Start Cell"
-#~ msgstr "ÐевеÑÐ½Ð°Ñ Ð½Ð°ÑалÑÐ½Ð°Ñ ÑÑейка"
#~ msgid "%s %f-%f lower cost higher or equal"
#~ msgstr "%s %f-%f нижнÑÑ Ñен болÑÑе или Ñавна"
@@ -33821,10 +33999,6 @@
#~ msgid "unable to open new S map layer."
#~ msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй S-Ñлой."
-#, fuzzy
-#~ msgid "SECTION 3: Accumulating Surface Flow with MFD"
-#~ msgstr "СÐÐЦÐЯ 3: ÐккÑмÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока."
#~ msgid "unable to open MASK"
#~ msgstr "невозможно оÑкÑÑÑÑ MASK"
@@ -33845,10 +34019,6 @@
#~ " паÑамеÑÑ Ð¿Ð¾Ñога баÑÑейна обÑзаÑелÑно должен бÑÑÑ Ð·Ð°Ð´Ð°Ð½."
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "РаÑÑÑовÑй Ñайл повеÑÑ
ноÑÑи"
@@ -33962,79 +34132,9 @@
#~ "Ð¿Ð¾ÐºÐ¾Ð»ÐµÐ½Ð¸Ñ Ð¾ÑнованнÑй на wxPython "
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "%s: %s - Ðевозможно найÑи Ñлой веÑеÑÑвенного изобÑажениÑ."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÑеÑÑвенного изобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð² каÑалоге cell_misc.\n"
-#~ "ÐÑÑ
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "%s: %s - Ðевозможно найÑи Ñлой мнимого изобÑажениÑ."
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "Ðевозможно оÑкÑÑÑÑ Ð¼Ð½Ð¸Ð¼Ð¾Ðµ изобÑажение в каÑалоге cell_misc.\n"
-#~ "ÐÑÑ
-#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "ÐÑÑппа [%s] не найдена."
-#, fuzzy
#~ msgid "Cannot allocate memory for raster row"
#~ msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ ÑÑÑоки"
-#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "Ðиапазон менÑÑе или ÑавнÑй нÑÐ»Ñ Ð½ÐµÐ´Ð¾Ð¿ÑÑÑим."
-#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#~ msgstr "ÐапиÑÑ Ð¿ÑоÑмаÑÑиваемÑÑ
даннÑÑ
в ÑайлÑ..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл в каÑалоге cell_misc."
-#, fuzzy
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr "ÐÐ¼Ñ ÑÑанÑÑоÑмиÑÑемого изобÑажениÑ, показÑваемого на ÑкÑане."
-#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr "ÐÐ¼Ñ ÑÐ»Ð¾Ñ Ð¸Ð· Ñелевого набоÑа, показÑваемого на ÑкÑане."
-#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) (types depend on database backend, but "
-#~ "all support VARCHAR(), INT, DOUBLE and DATE)"
-#~ msgstr ""
, но вÑе "
-#, fuzzy
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr "ÐÑполÑзоваÑÑ Ð¾Ð¿ÑÐ¸Ñ '%s' Ð´Ð»Ñ ÑÐ¼ÐµÐ½Ñ Ð¸Ð¼ÐµÐ½Ð¸ векÑоÑного ÑлоÑ"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#~ msgstr " "
-#, fuzzy
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "ÐÑобÑазиÑÑ ÑемаÑиÑеÑкий векÑоÑнÑй Ñлой"
#~ msgid "Cannot open database %s by driver %s"
#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÐÐ %s Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð´ÑайвеÑа %s"
@@ -34370,14 +34470,6 @@
#~ msgid "run non-interactively"
#~ msgstr "запÑÑÑиÑÑ Ð±ÐµÐ· инÑеÑакÑивноÑÑи"
-#, fuzzy
-#~ msgid ""
-#~ "Name of old database. The database must be in form printed by v.db."
-#~ "connect -g, i.e. with substituted variables"
-#~ msgstr ""
-#~ "ÐÐ¼Ñ ÑÑаÑой Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. Ðаза даннÑÑ
должна бÑÑÑ Ñказана в ÑоÑме "
-#~ "задаваемой v.db.connect -g, Ñо еÑÑÑ Ñ Ð¿Ð¾Ð´Ð¼ÐµÐ½ÐµÐ½Ð½Ñми пеÑеменнÑми."
#~ msgid "Run non-interactively"
#~ msgstr "ÐÑполниÑÑ Ð±ÐµÐ· инÑеÑакÑивноÑÑи"
@@ -35447,10 +35539,6 @@
#~ msgstr " ."
#, fuzzy
-#~ msgid "Category file for [%s] not available"
-#~ msgstr " "
-#, fuzzy
#~ msgid "%s: <%s> raster map not found"
#~ msgstr " "
@@ -36058,10 +36146,6 @@
#~ msgstr " "
#, fuzzy
-#~ msgid "color file for [%s] not available"
-#~ msgstr " "
-#, fuzzy
#~ msgid "Raster file [%s] not available"
#~ msgstr " "
@@ -37070,10 +37154,6 @@
#~ msgid "display, export, GPS"
#~ msgstr "диÑплей, ÑкÑпоÑÑ, GPS"
-#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "Ð¸Ð¼Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ обÑаза ÑÐ»Ð¾Ñ (наÑ
#~ msgid "Make JPEG instead of PNG image"
#~ msgstr "СоздаÑÑ JPEG на оÑнове PNG"
@@ -38359,10 +38439,6 @@
#~ msgstr "Ðевозможно ÑгенеÑиÑоваÑÑ ÑÑавнение ÑÑанÑÑоÑмаÑии."
-#~ msgid "Bad format in initial exposusre station file for group [%s]"
-#~ msgstr ""
-#~ "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла наÑалÑной ÑкÑпозиÑии ÑÑанÑии Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
#, fuzzy
#~ msgstr "Режим ÑаÑÑиÑенной инÑоÑмаÑии"
@@ -38402,19 +38478,6 @@
#~ msgid "Don't use shell syntax"
#~ msgstr "Ðе иÑполÑзÑйÑе ÑинÑакÑÐ¸Ñ Ð¾Ð±Ð¾Ð»Ð¾Ñки"
-#~ msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-#~ msgstr "ÐнаÑение по ÑмолÑаниÑ: GRASS_GUI еÑли ÑÑÑановлен, инаÑе - tcltk"
-#, fuzzy
-#~ msgid ""
-#~ "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based "
-#~ "GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;"
-#~ "text;command line interface only"
-#~ msgstr ""
-#~ "tcltk;GUI оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ GIS (gis.m);oldtcltk;СÑаÑÑй "
-#~ "GUI оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð´Ð¸Ñплеев (d.m);wxpython;GUI нового "
-#~ "Ð¿Ð¾ÐºÐ¾Ð»ÐµÐ½Ð¸Ñ Ð¾ÑнованнÑй на wxPython "
#~ msgid "Field value. If set to 0, z coordinates are used. (3D vector only)"
#~ msgstr ""
#~ "ÐнаÑение полÑ. ÐÑли ÑÑÑановлено в 0, иÑполÑзÑÑÑÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ z (ÑолÑко 3D "
@@ -38426,26 +38489,6 @@
-#, fuzzy
-#~ msgid "raster input map (green: tm2 | qbird_green | spot1)"
-#~ msgstr "иÑÑ
-#, fuzzy
-#~ msgid "raster input map (NIR: tm4 | qbird_nir | spot2)"
-#~ msgstr "иÑÑ
-#, fuzzy
-#~ msgid "raster input map (MIR; tm5 | qbird_red | spot3)"
-#~ msgstr "иÑÑ
-#, fuzzy
-#~ msgid "raster input map (etmpan | qbird_pan | spotpan)"
-#~ msgstr "иÑÑ
-#, fuzzy
-#~ msgid "raster output map prefix (e.g. 'brov')"
-#~ msgstr "пÑеÑÐ¸ÐºÑ Ð²ÑÑ
#~ msgstr ""
#~ "ÐозаиÑиÑоваÑÑ Ð´Ð¾ 4 изобÑажений и ÑаÑÑиÑиÑÑ ÑвеÑовÑÑ ÑаблиÑÑ; ÑоздаÑÑ Ñлой "
@@ -38454,30 +38497,7 @@
#~ msgstr "ÐÑоÑой Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
-#, fuzzy
-#~ msgid "Auto-balancing of colors for LANDSAT images"
-#~ msgstr "ÐвÑомаÑиÑеÑÐºÐ°Ñ Ð±Ð°Ð»Ð°Ð½ÑиÑовка ÑвеÑов Ð´Ð»Ñ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ LANDSAT"
-#, fuzzy
#~ msgid ""
-#~ "displays spectral response at user specified locations in group or images"
-#~ msgstr ""
-#~ "ÐоказаÑÑ ÑпекÑÑалÑное оÑÑажение Ð´Ð»Ñ Ð³ÑÑпп или изобÑажений, опÑеделеннÑÑ
-#~ "полÑзоваÑелем"
-#, fuzzy
-#~ msgid "group input"
-#~ msgstr "иÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð³ÑÑппа"
-#, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "запиÑаÑÑ ÑезÑлÑÑÐ°Ñ Ð² изобÑажение PNG"
-#, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "подпиÑаÑÑ ÐºÐ¾Ð¾ÑдинаÑами вмеÑÑо ÑиÑел"
-#~ msgid ""
#~ msgstr ""
@@ -38497,37 +38517,13 @@
#~ msgstr "ÐÑвод завиÑÑÑий Ð¾Ñ Ñегиона"
-#, fuzzy
#~ msgid ""
-#~ "Reclasses a raster map greater or less than user specified area size (in "
-#~ "hectares)"
-#~ msgstr ""
-#~ "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой болÑÑе или менÑÑе Ñем плоÑÐ°Ð´Ñ "
-#~ "Ð·Ð°Ð´Ð°Ð½Ð½Ð°Ñ Ð¿Ð¾Ð»ÑзоваÑелем (в гекÑаÑаÑ
-#, fuzzy
-#~ msgid "lesser val option that sets the <= area size limit [hectares]"
-#~ msgstr ""
-#~ "менÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ <= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
-#~ "[гекÑаÑÑ]"
-#, fuzzy
-#~ msgid "greater val option that sets the >= area size limit [hectares]"
-#~ msgstr ""
-#~ "болÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ >= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
-#~ "[гекÑаÑÑ]"
-#~ msgid ""
#~ msgstr ""
#~ "ÐнаÑение иÑполÑзÑемое Ð´Ð»Ñ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½Ð¸Ñ ÑÑолбÑа (знаÑÐµÐ½Ð¸Ñ varchar Ð´Ð¾Ð»Ð¶Ð½Ñ "
#~ "бÑÑÑ Ð² одиноÑнÑÑ
кавÑÑкаÑ
, напÑÐ¸Ð¼ÐµÑ 'grass')"
-#, fuzzy
-#~ msgid "Layer number. If -1, all layers are extracted"
-#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ. ÐÑли -1, полÑÑаÑÑÑÑ Ð²Ñе Ñлои"
@@ -38569,3 +38565,1289 @@
#, fuzzy
#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемого Ð´Ð»Ñ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ñлой 3-Ñ
меÑной ÑаÑÑÑовой каÑÑÑ Ð² ÑекÑÑовÑй ASCII Ñайл"
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "ÐÑеобÑазоваÑÑ 3D ASCII ÑекÑÑовÑй Ñайл ÑаÑÑÑа во внÑÑÑÑ (бинаÑного) 3D "
+#~ "ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ°ÑÑÑ"
+#, fuzzy
+#~ msgid "The initial piezometric head in [m]"
+#~ msgstr "ÐÑÑ
одное положение пÑезомеÑÑиÑеÑкой головки в [м]"
+#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgstr ""
+#~ "СÑаÑÑÑ Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð¹ ÑÑейки, = 0 - неакÑивна, 1 - акÑивна, 2 - ÑÑд ÐиÑиÑ
ле"
+#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "Z-Ð´Ð¾Ð»Ñ ÑензоÑа гидÑавлиÑеÑкой пÑоводимоÑÑи в [м/Ñ]"
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "ÐеÑезагÑÑзка ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² м^3/Ñек"
+#~ msgid ""
+#~ "The piezometric head result of the numerical calculation will be written "
+#~ "to this map"
+#~ msgstr ""
+#~ "ЧиÑловое пÑедÑÑавление ÑезÑлÑÑаÑа пÑезомеÑÑиÑеÑкой головки бÑÐ´ÐµÑ Ð·Ð°Ð¿Ð¸Ñано "
+#~ "в ÑÑÐ¾Ñ Ñлой"
+#~ msgid ""
+#~ "Calculate the groundwater distance velocity vector field and write the x, "
+#~ "y, and z components to maps named name_[xyz]. Name is basename for the "
+#~ "new raster3d maps"
+#~ msgstr ""
+#~ "ÐÑÑиÑлиÑÑ ÑаÑÑÑоÑние, ÑкоÑоÑÑÑ Ð²ÐµÐºÑоÑного Ð¿Ð¾Ð»Ñ Ð³ÑÑнÑовÑÑ
вод и запиÑаÑÑ "
+#~ "x, y, z ÑоÑÑавлÑÑÑие в Ñлои Ñ Ð¸Ð¼ÐµÐ½Ð°Ð¼Ð¸ name_[xyz]. Name - пÑеÑÐ¸ÐºÑ Ð´Ð»Ñ "
+#~ "новÑÑ
ÑаÑÑÑовÑÑ
3D Ñлоев"
+#~ msgid "The direct cholesky solver do not work with sparse matrices"
+#~ msgstr ""
+#~ "ÐÑÑмой ÑеÑаÑÐµÐ»Ñ Ð¥Ð¾Ð»ÐµÑки (Сholesky) не ÑабоÑÐ°ÐµÑ Ñ ÑазÑеженнÑми маÑÑиÑами"
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "ÐкÑпоÑÑ 3D ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS в 3 Vis5D Ñайл."
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS в Ñайл каÑÑÑ GRIDATB.FOR (TOPMODEL)"
+#~ msgid "Name of base raster map"
+#~ msgstr "ÐÐ¼Ñ Ð±Ð°Ð·Ð¾Ð²Ð¾Ð³Ð¾ ÑаÑÑÑового ÑлоÑ"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr "ÐонвеÑÑиÑÑÐµÑ ÑаÑÑÑовÑй Ñлой в Ñайл вÑÑÐ¾Ñ Ð´Ð»Ñ POVRAY."
+#~ msgid "raster, map algebra"
+#~ msgstr "ÑаÑÑÑ, ÑаÑÑÑÐ¾Ð²Ð°Ñ Ð°Ð»Ð³ÐµÐ±Ñа"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "ÐонвеÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой в ÑекÑÑовÑй Ñайл ASCII."
+#~ msgid "Converting %s..."
+#~ msgstr "ÐÑеобÑазование %s..."
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "Ðевозможно найÑи конеÑнÑй векÑÐ¾Ñ <%s>"
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr ""
+#~ "ÐмпоÑÑиÑоваÑÑ ÐºÐ°Ðº даннÑе Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой (по ÑмолÑаниÑ: ÑелоÑиÑленное)"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr ""
+#~ "ÐмпоÑÑ ÐºÐ°Ðº даннÑе Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой (double) (по ÑмолÑаниÑ: "
+#~ "ÑелоÑиÑленное)"
+#~ msgid "Bad number of bytes per cell"
+#~ msgstr "ÐепÑавилÑно колиÑеÑÑво байÑов на ÑÑейкÑ"
+#~ msgid "Bytes do not match File size"
+#~ msgstr "ÐайÑÑ Ð½Ðµ ÑооÑвеÑÑÑвÑÑÑ ÑазмеÑÑ Ñайла"
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ Ñ Ð¾Ð·ÐµÑом"
+#~ msgid "raster, interpolation"
+#~ msgstr "ÑаÑÑÑ, инÑеÑполÑÑиÑ"
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "ÐонвеÑÑаÑÐ¸Ñ ÑаÑÑÑовÑÑ
Ñлоев в ÑоÑÐ¼Ð°Ñ VTK-Ascii"
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgid ""
+#~ "Sediment transport and erosion/deposition simulation using path sampling "
+#~ "method (SIMWE)"
+#~ msgstr ""
+#~ "СимÑлÑÑÐ¸Ñ Ð¿ÐµÑеноÑа и ÑÑозии/оÑÐ»Ð¾Ð¶ÐµÐ½Ð¸Ñ Ð½Ð°Ð½Ð¾Ñов иÑполÑзÑÑ Ð¼ÐµÑод линейной "
+#~ "вÑбоÑки (SIMWE)"
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð³Ð»ÑÐ±Ð¸Ð½Ñ Ð²Ð¾Ð´Ñ [m]"
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¿ÑоизводнÑÑ
x [m/m]"
+#~ msgid "Name of the y-derivatives raster map [m/m]"
y [m/m]"
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа емкоÑÑи оÑÐ´ÐµÐ»ÐµÐ½Ð¸Ñ [s/m]"
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа ÑÑанÑпоÑÑной емкоÑÑи [s]"
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ñдвигового ÑÑÑеÑÑа [Pa]"
+#~ msgid "Name of the Mannings n raster map"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Mannings n"
+#~ msgid "Name of the Mannings n value"
+#~ msgstr "ÐÐ¼Ñ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Mannings n"
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑÑанÑпоÑÑной емкоÑÑи [кг/мÑ]"
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой огÑаниÑений ÑÑозии-оÑÐ»Ð¾Ð¶ÐµÐ½Ð¸Ñ [кг/м2Ñ]"
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой конÑенÑÑаÑии оÑложений [ÑаÑÑиÑ/м3]"
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой поÑока оÑложений [кг/мÑ]"
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑÑозии-оÑÐ»Ð¾Ð¶ÐµÐ½Ð¸Ñ [кг/м2Ñ]"
+#~ msgid ""
+#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+#~ msgstr ""
+#~ "ÐидÑологиÑеÑÐºÐ°Ñ ÑимÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока Ñ Ð¸ÑполÑзованием меÑода "
+#~ "вÑбоÑа ÑÑаекÑоÑий (SIMWE)"
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑÑÐ¾Ð²Ð½Ñ Ð¸Ð·Ð±ÑÑоÑнÑÑ
оÑадков (rain-infilt) [мм/ÑаÑ]"
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑкоÑоÑÑи инÑилÑÑÑаÑии ÑÑока [мм/Ñ]"
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾Ð½ÑÑÐ¾Ð»Ñ ÑÑока (ÑÑÐµÐ¿ÐµÐ½Ñ Ð¿ÑониÑаемоÑÑи 0-1)"
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑазгÑÑзки поÑока [м3/Ñ]"
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой оÑибки ÑимÑлÑÑии [м]"
+#~ msgid ""
+#~ "Threshold water depth [m] (diffusion increases after this water depth is "
+#~ "reached)"
+#~ msgstr ""
+#~ "ÐоÑÐ¾Ð³Ð¾Ð²Ð°Ñ Ð³Ð»Ñбина Ð²Ð¾Ð´Ñ [м] (диÑÑÑÐ·Ð¸Ñ ÑвелиÑиваеÑÑÑ Ð¿Ð¾Ñле доÑÑÐ¸Ð¶ÐµÐ½Ð¸Ñ ÑÑого "
+#~ "знаÑÐµÐ½Ð¸Ñ Ð³Ð»ÑбинÑ)"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ 3 ÑаÑÑÑовÑÑ
ÑÐ»Ð¾Ñ GRASS (R,G,B) в Ñайл PPM Ñ ÑазÑеÑением "
+#~ "ТÐÐУЩÐÐÐ Ð ÐÐÐÐÐÐ."
+#~ msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
+#~ msgstr ""
+#~ "СÑаÑÑÑ Ð³ÑаниÑного ÑÑловиÑ, 0-неакÑивнÑй, 1-акÑивнÑй, 2-ÑÑловие ÐиÑиÑ
ле"
+#~ msgid "Water sources and sinks in [m^3/s]"
+#~ msgstr "ÐоднÑе иÑÑоÑники и ÑÐ°ÐºÐ¾Ð²Ð¸Ð½Ñ Ð² [м^3/Ñ]"
+#~ msgid "Specific yield in [1/m]"
+#~ msgstr "УделÑÐ½Ð°Ñ Ð²Ð¾Ð´Ð¾Ð¾ÑдаÑа в [1/м]"
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "Слой облаÑÑи пиÑаниÑ, напÑимеÑ: *10^-9 в ÑÑейке в [м^3/Ñ*м^2]."
+#~ msgid "The map storing the numerical result [m]"
+#~ msgstr "Слой Ð´Ð»Ñ Ñ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ ÑиÑлового ÑезÑлÑÑаÑа [м]"
+#~ msgid ""
+#~ "Calculate the groundwater filter velocity vector field [m/s]\n"
+#~ "and write the x, and y components to maps named name_[xy]"
+#~ msgstr ""
+#~ "РаÑÑÑиÑаÑÑ Ð¿Ð¾Ð»Ðµ векÑоÑа ÑкоÑоÑÑи гÑÑнÑовÑÑ
вод в (м/Ñ)\n"
+#~ "и запиÑаÑÑ X и Y компоненÑÑ Ð² Ñлой Ñ Ð½Ð°Ð·Ð²Ð°Ð½Ð¸ÐµÐ¼ имÑ_(xy)."
+#~ msgid "The height of the river bed in [m]"
+#~ msgstr "ÐÑÑоÑа ÑÑÑла Ñеки в [м]"
+#~ msgid "Water level (head) of the river with leakage connection in [m]"
+#~ msgstr "УÑÐ¾Ð²ÐµÐ½Ñ Ð²Ð¾Ð´Ñ (веÑÑ
ний) в Ñеке Ñ ÑÑеÑом ÑеÑнÑÑ
пÑоÑок в (м)."
+#~ msgid "The leakage coefficient of the river bed in [1/s]."
+#~ msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÑоÑÐµÐºÐ°Ð½Ð¸Ñ Ð»Ð¾Ð¶Ð° Ñеки в [1/Ñек]."
+#~ msgid "The height of the drainage bed in [m]"
+#~ msgstr "ÐÑÑоÑа ложа дÑенажа в [м]"
+#~ msgid "The leakage coefficient of the drainage bed in [1/s]"
+#~ msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÑоÑÐµÐºÐ°Ð½Ð¸Ñ Ð»Ð¾Ð¶Ð° дÑенажа в [1/Ñек]."
+#~ msgid "raster, buffer"
+#~ msgstr "ÑаÑÑеÑ, бÑÑеÑ"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "ÐÑÑ
однÑй Ñлой: колиÑеÑÑво повеÑÑ
ноÑÑного ÑÑока на ÑÑейкÑ"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr ""
+#~ "ÐÑÑ
однÑй Ñлой: ÑоÑÐ¼Ñ ÑелÑеÑа блокиÑÑÑÑие повеÑÑ
ноÑÑнÑй ÑÑок, Ð´Ð»Ñ USLE"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "ÐÑÑ
одной Ñлой: колиÑеÑÑво ÑÑеек дÑениÑÑемÑÑ
ÑеÑез каждÑÑ ÑÑейкÑ"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "ÐÑÑ
одной Ñлой: ÑникалÑнÑе подпиÑи Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ водоÑбоÑного баÑÑейна"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "ÐÑÑ
одной Ñлой: ÐºÐ°Ð¶Ð´Ð¾Ð¼Ñ Ð¿Ð¾Ð»ÑбаÑÑÐµÐ¹Ð½Ñ Ð½Ð°Ð·Ð½Ð°Ñено ÑникалÑное знаÑение"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr "ÐÑÑ
одной Ñлой: длина Ñклона и кÑÑÑизна (LS) Ð´Ð»Ñ USLE"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "ÐÑÑ
одной Ñлой: кÑÑÑизна Ñклона (S) Ð´Ð»Ñ USLE"
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr ""
+#~ "ÐÑÑ
одное знаÑение: минималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð²Ð½ÐµÑнего водоÑбоÑного баÑÑейна"
+#, fuzzy
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "ÐÑли одна из ÑледÑÑÑиÑ
опÑий ÑÑÑановлена:\n"
+#~ " basin, stream, half.basin, slope, or lS\n"
+#~ " паÑамеÑÑ Ð¿Ð¾Ñога баÑÑейна обÑзаÑелÑно должен бÑÑÑ Ð·Ð°Ð´Ð°Ð½."
+#~ msgid ""
+#~ "USAGE for basin delineation:\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "\n"
+#~ "USAGE for ARMSED FILE creation:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "\n"
+#~ "USAGE for slope length determination:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
+#~ msgstr ""
+#~ "ÐÑполÑзование вÑÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ð±Ð°ÑÑейнов:\n"
+#~ "\n"
+#~ "ÐÑполÑзование ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ñайла ARMSED:\n"
+#~ "\n"
+#~ "ÐÑполÑзование Ð´Ð»Ñ Ð¾Ð¿ÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ð´Ð»Ð¸Ð½Ñ Ñклона:\n"
+#~ "map]"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#~ msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой аккÑмÑлÑÑии"
+#~ msgid "Error writing color file for <%s>"
+#~ msgstr "ÐÑибка запиÑи ÑвеÑового Ñайла Ð´Ð»Ñ <%s>"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "ÐÑогÑамма конвеÑÑаÑии ÑеÑии ÑаÑÑÑов в MPEG."
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "ФилÑÑÑÑÐµÑ Ð¸ ÑÐ¾Ð·Ð´Ð°ÐµÑ Ñлой вÑÑÐ¾Ñ Ð±ÐµÐ· депÑеÑÑий, а Ñак же Ñлой напÑавлений "
+#~ "ÑÑока на оÑнове заданного Ñлой вÑÑоÑ."
+#~ msgid "Output direction raster map"
+#~ msgstr "ÐÑвеÑÑи ÑаÑÑÑовÑй Ñлой напÑавлений"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "ÐÑвеÑÑи ÑаÑÑÑовÑй Ñлой пÑоблемнÑÑ
ÑеÑÑиÑоÑий"
+#~ msgid "raster, resample"
+#~ msgstr "ÑаÑÑÑ, ÑеÑÑмплинг"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "ÐÑогÑамма генеÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи из ÑаÑÑеÑизованнÑÑ
изолиний."
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ, ÑодеÑжаÑего изолинии"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "СоздаÑÑ/измениÑÑ ÑвеÑовÑÑ ÑаблиÑÑ ÑвÑзаннÑÑ Ñ ÑаÑÑÑовÑм Ñлоем."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "ÐÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸Ð· коÑоÑого бÑÐ´ÐµÑ ÑкопиÑована ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "ÐÑÑÑ Ðº ÑÐ°Ð¹Ð»Ñ Ð¿Ñавил (\"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¿Ñавил из stdin)"
+#~ msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
+#~ msgstr ""
+#~ "CHILD[pid = %i]: невозможно оÑкÑÑÑÑ Ð¼Ð°ÑÐºÑ %s ... пÑодолжаем без неÑ!!!"
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "Ðевозможно ÑоздаÑÑ ÐºÐ°Ñалог %s/.r.li/"
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "Ðевозможно ÑоздаÑÑ ÐºÐ°Ñалог %s/.r.li/output/"
+#~ msgid "r.li.worker (pid %i) exited with abnormal status %i"
+#~ msgstr "r.li.worker (pid %i) завеÑÑилÑÑ Ð½ÐµÑдаÑно %i"
+#~ msgid "r.li.worker (pid %i) terminated"
+#~ msgstr "r.li.worker (pid %i) пÑеÑван"
+#~ msgid "Cannot make stat of %s configuration file"
+#~ msgstr "Ðевозможно ÑобÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÐºÐ¾Ð½ÑигÑÑаÑионного Ñайла %s"
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#~ msgstr " "
+#~ msgid "raster, null data"
+#~ msgstr "ÑаÑÑÑ, null даннÑе"
+#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+#~ msgstr ""
+#~ "ÐкÑпоÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой в Virtual Reality Modeling Language (VRML)"
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ñ ÑаÑÑÑоÑниÑми до обÑекÑов в иÑÑ
одном Ñлое"
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Слой баÑÑейнов Ñоздан r.water.outlet (MASK)"
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) Слой напÑавлений Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ð²ÑÑÐ¾Ñ Ð±ÐµÐ· депÑеÑÑий"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) ÐолиÑеÑÑво клаÑÑов ÑопогÑаÑиÑеÑкого индекÑа"
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr "(o/i) Файл ÑÑаÑиÑÑики ÑопогÑаÑиÑеÑкого индекÑа"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) Ñайл паÑамеÑÑов TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "(i) Файл даннÑÑ
об оÑадкаÑ
и поÑенÑиалÑном ÑÑммаÑном иÑпаÑении"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "РаÑÑÑиÑаÑÑ Ð·Ð°ÑененнÑе ÑеÑÑиÑоÑии иÑполÑзÑÑ ÑаÑположение ÑолнÑа и ЦÐÐ . "
+#~ "ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ Ð»Ð¸Ð±Ð¾ Ð: ÑоÑное положение ÑолнÑа, либо Ð: даÑа/вÑÐµÐ¼Ñ "
+#~ "Ð´Ð»Ñ ÐºÐ¾ÑоÑÑÑ
надо ÑаÑÑÑиÑаÑÑ Ð¿Ð¾Ð»Ð¾Ð¶ÐµÐ½Ð¸Ðµ ÑолнÑа Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ r.sunmask."
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: вÑÑоÑа ÑолнÑа над гоÑизонÑом в гÑадÑÑаÑ
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: азимÑÑ ÑолнÑа оÑноÑиÑелÑно ÑевеÑа в гÑадÑÑаÑ
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: минÑÑÑ (0..60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: ÑекÑÐ½Ð´Ñ (0..60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: ÑаÑовой поÑÑ (воÑÑоÑнÑе положиÑелÑнÑе кооÑдинаÑÑ, ÑмеÑение "
+#~ "оÑноÑиÑелÑно GMT, Ñакже иÑполÑзÑеÑÑÑ Ð´Ð»Ñ Ð¿Ð¾Ð¿Ñавки пÑи пеÑеÑ
оде на леÑнее "
+#~ "вÑемÑ)"
+#, fuzzy
+#~ msgid "Seed [%d] larger than maximum [%d]"
+#~ msgstr "ÐаÑÑавка [%d] болÑÑе Ñем макÑимÑм [%d]"
+#, fuzzy
+#~ msgid "Seed [%d] smaller than minimum [%d]"
+#~ msgstr "ÐаÑÑавка [%d] менÑÑе Ñем минимÑм [%d]"
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Ð¡Ð¾Ð·Ð´Ð°ÐµÑ Ð½Ð¾Ð²Ñй Ñлой каÑÑÑ, каÑегоÑии коÑоÑого оÑÐ½Ð¾Ð²Ð°Ð½Ñ Ð½Ð° "
+#~ "пеÑеклаÑÑиÑикаÑии каÑегоÑий ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ°ÑÑÑ."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "ÐеÑеклаÑÑиÑиÑиÑÑемÑй ÑаÑÑÑовÑй Ñлой"
+#~ msgid "Converts a raster map into a vector map layer."
+#~ msgstr "ÐонвеÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой в векÑоÑнÑй Ñлой."
+#~ msgid ""
+#~ "Do not build vector topology (use with care for massive point export)"
+#~ msgstr ""
+#~ "Ðе ÑоздаваÑÑ Ð²ÐµÐºÑоÑнÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ (иÑполÑзоваÑÑ Ð¾ÑÑоÑожно пÑи ÑкÑпоÑÑе "
+#~ "болÑÑого ÑиÑла ÑоÑек)"
+#~ msgid "The map E grid coordinates"
+#~ msgstr "E кооÑдинаÑа ÑлоÑ"
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "РаÑÑÐµÑ ÑÐ»Ð¾Ñ %01d из %01d (Ñгол %lf, ÑаÑÑÑовÑй Ñлой <%s>)"
+#~ msgid "Unable to read range of raster map <%s>"
+#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного векÑоÑного ÑлоÑ, ÑодеÑжаÑего поÑок (поÑоки)"
+#~ msgid "Stream width (in meters). Default is raster cell width"
+#~ msgstr ""
+#~ "ШиÑина поÑока (в меÑÑаÑ
). Ðо ÑмолÑÐ°Ð½Ð¸Ñ Ð¸ÑполÑзÑеÑÑÑ ÑиÑина ÑаÑÑÑовой "
+#~ "ÑÑейки"
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr ""
+#~ "РаÑÑÐµÑ ÐºÑÑÑÐ¸Ð·Ð½Ñ Ñклонов (линий ÑÑока), Ð´Ð»Ð¸Ð½Ñ ÑÑока и плоÑноÑÑи поÑоков из "
+#~ "ÑаÑÑÑовой ÑиÑÑовой модели ÑелÑеÑа (ЦÐÐ )"
+#~ msgid "Output flowpath length raster map"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой пÑоÑÑжÑнноÑÑи пÑÑи поÑоков"
+#~ msgid "Output flowline density raster map"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой плоÑноÑÑи линий поÑоков"
+#~ msgid "3-D lengths instead of 2-D"
+#~ msgstr "Ðлина в 3-D вмеÑÑо 2-D"
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "ÐонвеÑÑиÑование ÑаÑÑÑового Ñайла ASCII в бинаÑнÑй ÑаÑÑÑовÑй Ñлой."
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "ÐоказаÑÑ Ð¿Ð¾Ð´Ð¿Ð¸ÑÑ ÐºÐ°ÑегоÑии Ð´Ð»Ñ ÑÑейки(ÑÑеек) "
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Ð¡Ð¾Ð·Ð´Ð°ÐµÑ Ñлой ÑопогÑаÑиÑеÑкого индекÑа [ln(a/tan(beta))] из ÑÐ»Ð¾Ñ Ð²ÑÑоÑ"
+#~ msgid "Output topographic index map"
+#~ msgstr "ÐÑÑ
одной Ñлой ÑопогÑаÑиÑеÑкого индекÑа"
+#~ msgid "raster, geomorphology"
+#~ msgstr "ÑаÑÑÑ, геомоÑÑологиÑ"
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñайл ascii ESRI ARC/INFO (GRID) в (бинаÑнÑй) "
+#~ "ÑаÑÑÑовÑй Ñлой."
+#~ msgid "File containing weights"
+#~ msgstr "Файл, ÑодеÑжаÑий веÑа"
+#~ msgid "general, map management"
+#~ msgstr "обÑее, ÑпÑавление каÑÑой"
+#, fuzzy
+#~ msgid "general, scripts"
+#~ msgstr "обÑее, наÑÑÑойки"
+#~ msgid "New LOCATION name (not location path)"
+#~ msgstr "Ðовое Ð¸Ð¼Ñ ÐÐÐÐСТР(не пÑÑÑ Ðº облаÑÑи)"
+#~ msgid "New GISDBASE (full path to the directory where the new location is)"
+#~ msgstr "ÐÐ¾Ð²Ð°Ñ GISDBASE (полнÑй пÑÑÑ Ðº каÑÐ°Ð»Ð¾Ð³Ñ Ñ Ð½Ð¾Ð²Ð¾Ð¹ облаÑÑÑÑ)"
+#~ msgid "format"
+#~ msgstr "ÑоÑмаÑ"
+#, fuzzy
+#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
+#~ msgstr "ÐнаÑение по ÑмолÑаниÑ: GRASS_GUI еÑли ÑÑÑановлен, инаÑе - tcltk"
+#, fuzzy
+#~ msgid ""
+#~ "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
+#~ "(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
+#~ "command line interface only"
+#~ msgstr ""
+#~ "tcltk;GUI оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ GIS (gis.m);oldtcltk;СÑаÑÑй "
+#~ "GUI оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð´Ð¸Ñплеев (d.m);wxpython;GUI нового "
+#~ "Ð¿Ð¾ÐºÐ¾Ð»ÐµÐ½Ð¸Ñ Ð¾ÑнованнÑй на wxPython "
+#~ msgid "Color for drawing X's (Null values)"
+#~ msgstr "Ð¦Ð²ÐµÑ Ð·Ð½Ð°Ñений X (нÑлевÑе знаÑениÑ)"
+#~ msgid "display, cartography"
+#~ msgstr "визÑализаÑиÑ, каÑÑогÑаÑиÑ"
+#~ msgid "name"
+#~ msgstr "имÑ"
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitor: waitpid: ожидалоÑÑ %d полÑÑено %d"
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Ðолжен бÑÑÑ Ñказан либо ÑекÑÑ, либо -c"
+#~ msgid "Unable to set size"
+#~ msgstr "Ðевозможно ÑÑÑановиÑÑ ÑазмеÑ"
+#~ msgid "Text conversion error"
+#~ msgstr "ÐÑибка конвеÑÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ ÑекÑÑа"
+#~ msgid "Error reading hue data"
+#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑÐ»Ð¾Ñ Ñона"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#~ msgstr " "
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr ""
+#~ "ÐоказаÑÑ Ð¸ наложиÑÑ ÑаÑÑÑовÑе Ñлои в акÑивном ÑÑейме гÑаÑиÑеÑкого "
+#~ "мониÑоÑа."
+#~ msgid "List of categories to be displayed (INT maps)"
+#~ msgstr "СпиÑок каÑегоÑий Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (Ñлои INT)"
+#~ msgid "Invert catlist"
+#~ msgstr "ÐнвеÑÑиÑоваÑÑ catlist"
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#~ msgstr "ÐоказаÑÑ Ð²ÐµÐºÑоÑнÑе даннÑе в акÑивном ÑÑейме мониÑоÑа гÑаÑики."
+#~ msgid "Unable to read symbol, unable todisplay points"
+#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñимвол, невозможно показаÑÑ ÑоÑки"
+#~ msgid "Vector map attribute column to use for comparison"
+#~ msgstr "Ðоле аÑÑибÑÑов векÑоÑного ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемое Ð´Ð»Ñ ÑÑавнениÑ"
+#~ msgid "Vector map to store differences"
+#~ msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ Ñ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð¾ÑлиÑий"
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "ÐпÑÐ¸Ñ ÑакÑоÑа маÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð·Ð½Ð°Ñений, полÑÑаемÑÑ
Ñ ÑаÑÑÑового ÑлоÑ. "
+#~ "ÐолÑÑеннÑе знаÑÐµÐ½Ð¸Ñ Ð±ÑдÑÑ ÑÐ¼Ð½Ð¾Ð¶ÐµÐ½Ñ Ð½Ð° ÑÑÐ¾Ñ ÑакÑоÑ"
+#~ msgid "vector, networking"
+#~ msgstr "векÑоÑ, Ñоздание ÑеÑи."
+#~ msgid "Required for operation 'connect'"
+#~ msgstr "ÐеобÑ
одимо Ð´Ð»Ñ Ð¾Ð¿ÐµÑаÑии 'connect'"
+#~ msgid ""
+#~ "nodes;new point is placed on each node (line end) if doesn't exist;"
+#~ "connect;connect still unconnected points to vector network by inserting "
+#~ "new line(s);report;print to standard output {line_category "
+#~ "start_point_category end_point_category};nreport;print to standard output "
+#~ "{point_category line_category[,line_category...]}"
+#~ msgstr ""
+#~ "nodes;Ð½Ð¾Ð²Ð°Ñ ÑоÑка ÑазмеÑаеÑÑÑ Ð½Ð° каждом Ñзле (оконÑании линии), еÑли не "
+#~ "ÑÑÑеÑÑвÑеÑ;connect;ÑоединÑÐµÑ Ð½ÐµÑоединеннÑе ÑоÑки в векÑоÑнÑÑ ÑеÑÑ, "
+#~ "вÑÑавлÑÑ Ð½Ð¾Ð²ÑÑ Ð»Ð¸Ð½Ð¸Ñ (линии);report;вÑÐ²Ð¾Ð´Ð¸Ñ Ð½Ð° ÑÑандаÑÑное ÑÑÑÑойÑÑво "
+#~ "вÑвода {line_category start_point_category end_point_category};nreport;"
+#~ "вÑÐ²Ð¾Ð´Ð¸Ñ Ð½Ð° ÑÑандаÑÑное ÑÑÑÑойÑÑво вÑвода {point_category line_category[,"
+#~ "line_category...]}"
+#~ msgid "%d new points written to output"
+#~ msgstr "в вÑÑ
одной Ñайл запиÑано %d ÑоÑек"
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "ÐкÑпоÑÑ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ GRASS в SVG."
+#~ msgid "Layer number (write to)"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи)"
+#~ msgid "Query layer number (read from)"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð²ÑбоÑки (Ð´Ð»Ñ ÑÑениÑ)"
+#~ msgid "vector, interpolation"
+#~ msgstr "векÑоÑ, инÑеÑполÑÑиÑ"
+#, fuzzy
+#~ msgid "Layer but not column with z values given"
+#~ msgstr "Ðоле аÑÑибÑÑивной ÑаблиÑÑ Ñо знаÑениÑми Ð´Ð»Ñ Ð¸Ð½ÑеÑполÑÑии"
+#~ msgid "Vector based generalization."
+#~ msgstr "ÐекÑоÑÐ½Ð°Ñ Ð³ÐµÐ½ÐµÑализаÑиÑ."
+#~ msgid "Number of vertices was reduced from %d to %d [%d%%]"
+#~ msgstr "ÐолиÑеÑÑво Ñзлов бÑло ÑменÑÑено Ñ %d до %d [%d%%]"
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr "СоздаÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ GRASS."
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "ÐонвеÑÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑе Ñлои OGR в векÑоÑнÑе Ñлои GRASS."
+#~ msgid "Total area: %e (%d areas)"
+#~ msgstr "ÐбÑÐ°Ñ Ð¿Ð»Ð¾ÑадÑ: %e (%d полигонов)"
+#~ msgid "Overlapping area: %e (%d areas)"
+#~ msgstr "ÐлоÑÐ°Ð´Ñ Ð¿ÐµÑекÑÑÑиÑ: %e (%d полигонов)"
+#~ msgid "Area without category: %e (%d areas)"
+#~ msgstr "ÐÐ¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð±ÐµÐ· каÑегоÑий: %e (%d полигонов)"
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS (ÑолÑко ÑоÑки) в ÑаÑÑÑовÑй "
+#~ "3D Ñлой GRASS."
+#~ msgid "vector, extract"
+#~ msgstr "векÑоÑ, ÑкÑпоÑÑ"
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr "СлÑÑайное ÑмеÑение меÑÑоположений векÑоÑнÑÑ
ÑоÑек GRASS"
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "ÐаÑамеÑÑÑ ÑаÑпÑеделениÑ. ÐÑли ÑаÑпÑеделение одноÑодно, нÑжен ÑолÑко один "
+#~ "паÑамеÑÑ, макÑимÑм. ÐÐ»Ñ Ð½Ð¾ÑмалÑного ÑаÑпÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ - два паÑамеÑÑа: "
+#~ "ÑÑеднее и ÑÑандаÑÑное оÑклонение."
+#~ msgid "Layer number (from)"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (из)"
+#~ msgid "Layer number (to)"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (в)"
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr "Создание Ñлоев Ñо ÑлÑÑайнÑми 2D/3D ÑоÑеÑками."
+#, fuzzy
+#~ msgid ""
+#~ "If type is not given then DOUBLE PRECISION is used. Writes Z data to "
+#~ "column instead of 3D vector."
+#~ msgstr "ÐапиÑÑ Ð´Ð°Ð½Ð½ÑÑ
Z в ÑÑÐ¾Ð»Ð±ÐµÑ Ð²Ð¼ÐµÑÑо 3D векÑоÑа"
+#~ msgid "v.random can't create 3D vector and attribute table at same time"
+#~ msgstr ""
+#~ "v.random не Ð¼Ð¾Ð¶ÐµÑ Ð¾Ð´Ð½Ð¾Ð²Ñеменно ÑоздаÑÑ 3D векÑÐ¾Ñ Ð¸ ÑаблиÑÑ Ð°ÑÑибÑÑов"
+#, fuzzy
+#~ msgid "Using 'double precision' for column <%s>"
+#~ msgstr "Ðевозможно иÑполÑзоваÑÑ ÑÑÐ¾Ð»Ð±ÐµÑ <%s>"
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS в VTK ASCII."
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS в векÑоÑнÑй ASCII Ñлой GRASS."
+#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
+#~ msgstr ""
+#~ "ÐÑÑÑ Ðº вÑÑ
Ð¾Ð´Ð½Ð¾Ð¼Ñ ÑÐ°Ð¹Ð»Ñ ASCII или название векÑоÑа ASCII, еÑли "
+#~ "иÑполÑзÑеÑÑÑ '-o' "
+#~ msgid "Parameter '%s' ignored in standard mode"
+#~ msgstr "ÐаÑамеÑÑ '%s' в ÑÑандаÑÑном Ñежиме игноÑиÑÑеÑÑÑ"
+#~ msgid "vector, paint labels"
+#~ msgstr "векÑоÑ, ÑоздаÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи"
+#~ msgid "vector, geometry"
+#~ msgstr "векÑоÑ, геомеÑÑиÑ"
+#~ msgid "Output quadrant centres, number of points is written as category"
+#~ msgstr ""
+#~ "ÐÑвеÑÑи ÑенÑÑÑ ÐºÐ²Ð°Ð´ÑанÑов, колиÑеÑÑво ÑоÑек запиÑÑваеÑÑÑ ÐºÐ°Ðº каÑегоÑиÑ"
+#~ msgid "Counting sites in quadrats..."
+#~ msgstr "ÐодÑÑÐµÑ ÑайÑов в квадÑаÑаÑ
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой GRASS из заданного полÑзоваÑелем гÑида."
+#~ msgid "Either 'rules' or 'col' must be specified"
+#~ msgstr "ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ Ð²ÑбÑÐ°Ð½Ñ Ð»Ð¸Ð±Ð¾ 'rules' либо 'col'"
+#~ msgid "vector, kernel density"
+#~ msgstr "векÑоÑ, плоÑноÑÑÑ ÑдÑа"
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "ÐонвеÑÑиÑоваÑÑ Ð² один из поддеÑживаемÑÑ
ÑоÑмаÑов OGR."
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "ÐкÑпоÑÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ ÑолÑко Ñ ÐºÐ°ÑегоÑиÑми (подпиÑаннÑми). ÐнаÑе "
+#~ "ÑкÑпоÑÑиÑÑÑÑÑÑ Ð²Ñе обÑекÑÑ"
+#~ msgid ""
+#~ "Vector map <%s> is 3D. Use format specific layer creation options "
+#~ "(parameter 'lco') to export in 3D rather than 2D (default)"
+#~ msgstr ""
+#~ "ÐекÑоÑнÑй Ñлой <%s> 3D. ÐÑполÑзÑйÑе опÑии ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ ÑпеÑиалÑно Ð´Ð»Ñ ÑоÑмаÑа "
+#~ "(паÑамеÑÑ 'lco') Ð´Ð»Ñ ÑкÑпоÑÑа в 3D а не 2D (по ÑмолÑаниÑ)"
+#~ msgid "Key column '%s' not found"
+#~ msgstr "ÐлÑÑевое поле '%s' не найдено"
+#~ msgid "Exporting %i points/lines..."
+#~ msgstr "ÐкÑпоÑÑ %i ÑоÑек/линий..."
+#~ msgid "%d features written"
+#~ msgstr "Ðадано %d обÑекÑов"
+#, fuzzy
+#~ msgid "Convex hull calculation requires at least three points. Exiting."
+#~ msgstr "ÐÐ»Ñ Ð²ÑÑиÑление конвекÑного полигона ÑÑебÑÐµÑ ÐºÐ°Ðº минимÑм ÑÑеÑ
ÑоÑек"
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr ""
+#~ "СоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй Ñлой пÑÑем комбиниÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´ÑÑгиÑ
векÑоÑнÑÑ
Ñлоев."
+#~ msgid "overlap;features partially or completely overlap"
+#~ msgstr "пеÑекÑÑвание;обÑекÑÑ ÑаÑÑиÑно или полноÑÑÑÑ Ð¿ÐµÑекÑÑваÑÑÑÑ"
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "СоздаÑÑ Ð±ÑÑÐµÑ Ð²Ð¾ÐºÑÑг обÑекÑов данного Ñипа (плоÑаднÑе обÑекÑÑ Ð´Ð¾Ð»Ð¶Ð½Ñ "
+#~ "ÑодеÑжаÑÑ ÑенÑÑоидÑ)."
+#~ msgid "Buffer distance in map units"
+#~ msgstr "РаÑÑÑоÑние бÑÑеÑизаÑии в единиÑаÑ
каÑÑÑ"
+#~ msgid "vector, querying"
+#~ msgstr "векÑоÑ, запÑоÑ"
+#~ msgid "Queries a vector map layer at given locations."
+#~ msgstr "СоздаÑÑ Ð·Ð°Ð¿ÑÐ¾Ñ Ðº векÑоÑÐ½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ Ð² заданнÑÑ
меÑÑоположениÑÑ
+#~ msgid "If not given reads from standard input"
+#~ msgstr "ÐÑли не задано, Ñо ÑÑение пÑоизводиÑÑÑ Ñо ÑÑандаÑÑного вÑ
ода"
+#~ msgid "vector, transformation"
+#~ msgstr "векÑоÑ, ÑÑанÑÑоÑмаÑиÑ"
+#~ msgid "Copying vector objects from vector map <%s>..."
+#~ msgstr "ÐопиÑование векÑоÑнÑÑ
обÑекÑов из векÑоÑного ÑÐ»Ð¾Ñ <%s>..."
+#~ msgid "Name of input vector map containing lines"
+#~ msgstr "Ðазвание иÑÑ
одного векÑоÑного ÑлоÑ, ÑодеÑжаÑего линии"
+#~ msgid "Name for output vector map where segments will be written"
+#~ msgstr "Ðазвание вÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи ÑегменÑов"
+#~ msgid "Tests for normality for points."
+#~ msgstr "ТеÑÑÑ Ð½Ð¾ÑмалÑноÑÑи Ð´Ð»Ñ ÑоÑек."
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ Ð°ÑÑибÑÑов. ÐаÑиаÑÐ¸Ñ Ð¸ ÑÑандаÑÑное "
+#~ "оÑклонение ÑаÑÑÑиÑÑваеÑÑÑ ÑолÑко Ð´Ð»Ñ ÑоÑек."
+#, fuzzy
+#~ msgid "Calculate area centroids..."
+#~ msgstr "Ðевозможно ÑаÑÑÑиÑаÑÑ ÑенÑÑоид полигона"
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS в ÑаÑÑÑовÑй Ñлой GRASS."
+#~ msgid "Area without centroid (may be OK for island)"
+#~ msgstr "Ðолигон без ÑенÑÑоида (возможно Ð´Ð»Ñ Ð¾ÑÑÑова)"
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr "СоздаÑÑ ÑоÑки Ð²Ð´Ð¾Ð»Ñ Ð¸ÑÑ
однÑÑ
линий в новом векÑоÑе Ñ Ð´Ð²ÑÐ¼Ñ ÑлоÑми."
+#~ msgid "%d points written to output vector map"
+#~ msgstr "%d ÑоÑек запиÑано в вÑÑ
одной векÑоÑнÑй Ñлой"
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой из ÑоÑеÑного или векÑоÑного Ñайла ASCII."
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй векÑÐ¾Ñ ÐºÐ°Ðº ÑÑÑÐ»ÐºÑ (ÑолÑко Ð´Ð»Ñ ÑÑениÑ) на Ñлой OGR."
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "ÐоÑог в единиÑаÑ
ÑлоÑ, одно знаÑение Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ инÑÑÑÑменÑа (по "
+#~ "ÑмолÑаниÑ: 0.0[,0.0,...])"
+#~ msgid "Copying vector lines..."
+#~ msgstr "ÐопиÑование линий векÑоÑа..."
+#~ msgid "%d lines / boundaries removed"
+#~ msgstr "Ñдалено %d линий/гÑаниÑ"
+#~ msgid "Duplicate area centroids: %5d"
+#~ msgstr "ÐÑблиÑÑÑÑиеÑÑ ÑенÑÑÐ¾Ð¸Ð´Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð¾Ð²: %5d"
+#~ msgid "Attribute table column with values to interpolate"
+#~ msgid "No data points found"
+#~ msgstr "Ðе найдено ни одной ÑоÑки Ñ Ð´Ð°Ð½Ð½Ñми"
+#~ msgid "Lines buffers... "
+#~ msgstr "ÐÑÑеÑизаÑÐ¸Ñ Ð»Ð¸Ð½Ð¸Ð¹..."
+#~ msgid "Difference in x,y direction for moving feature or vertex"
+#~ msgstr "РазниÑа в напÑавлении x,y Ð´Ð»Ñ Ð¿ÐµÑемеÑÐµÐ½Ð¸Ñ Ð¾Ð±ÑекÑа или веÑÑинÑ"
+#~ msgid "Error reading ASCII file: '%s'"
+#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ñайла ASCII: '%s'"
+#~ msgid "Outputs basic information about a user-specified vector map."
+#~ msgstr ""
+#~ "ÐÑвеÑÑи оÑновнÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ векÑоÑном Ñлое, вÑбÑанном полÑзоваÑелем."
+#~ msgid "Displaying column types/names for database connection of layer %d:"
+#~ msgstr "ÐÑобÑазиÑÑ ÑипÑ/имена полей Ð´Ð»Ñ ÑвÑзи ÐÐ Ñо Ñлоем %d:"
+#~ msgid "Map scale: 1:%d"
+#~ msgstr "ÐаÑÑÑаб каÑÑÑ: 1:%d"
+#~ msgid "Map format: %s"
+#~ msgstr "ФоÑÐ¼Ð°Ñ ÐºÐ°ÑÑÑ: %s"
+#~ msgid "Name of creator: %s"
+#~ msgstr "ÐвÑоÑ: %s"
+#~ msgid "Organization: %s"
+#~ msgstr "ÐÑганизаÑиÑ: %s"
+#~ msgid "Source date: %s"
+#~ msgstr "ÐаÑалÑÐ½Ð°Ñ Ð´Ð°Ñа: %s"
+#~ msgid " Digitization threshold: %s"
+#~ msgstr " ÐоÑог диÑкÑеÑизаÑии: %s"
+#~ msgid " Comments:"
+#~ msgstr " ÐомменÑаÑии:"
+#~ msgid "Extrudes flat vector object to 3D with defined height."
+#~ msgstr "ÐÑдавиÑÑ Ð² 3D плоÑкий векÑоÑнÑй обÑÐµÐºÑ Ð½Ð° заданнÑÑ Ð²ÑÑоÑÑ."
+#~ msgid "vector, category"
+#~ msgstr "векÑоÑнÑй Ñлой, каÑегоÑиÑ"
+#~ msgid "Attach, delete or report vector categories to map geometry."
+#~ msgstr ""
+#~ "ÐÑикÑепиÑÑ, ÑдалиÑÑ Ð¸Ð»Ð¸ вÑвеÑÑи векÑоÑнÑе каÑегоÑии Ð´Ð»Ñ Ð³ÐµÐ¾Ð¼ÐµÑÑии ÑлоÑ."
+#~ msgid "Output surface raster map (elevation)"
+#~ msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ (вÑÑоÑа)"
+#~ msgid "Output cross-validation errors vector point file"
+#~ msgstr "ÐÑÑ
одной ÑоÑеÑнÑй векÑоÑнÑй Ñайл оÑибок кÑоÑÑ-валидаÑии"
+#~ msgid "Output vector map showing quadtree segmentation"
+#~ msgstr ""
+#~ "ÐÑÑ
одной векÑоÑнÑй Ñлой показÑваÑÑий ÑегменÑаÑÐ¸Ñ ÐºÐ²Ð°Ð´ÑаÑиÑного деÑева"
+#~ msgid "Output vector map showing overlapping windows"
+#~ msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой показÑваÑÑий пеÑекÑÑваÑÑиеÑÑ Ð¾ÐºÐ½Ð°"
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ ÑÑолбÑа аÑÑибÑÑа Ñо знаÑениÑми Ð´Ð»Ñ Ð°Ð¿Ð¿ÑокÑимаÑии (еÑли Ñлой > 0)"
+#~ msgid ""
+#~ "Processing all selected output files\n"
+#~ "will require %d bytes of disk space for temp files"
+#~ msgstr ""
+#~ "ÐбÑабоÑка вÑеÑ
вÑбÑаннÑÑ
вÑÑ
однÑÑ
Ñайлов\n"
+#~ "поÑÑебÑÐµÑ %d Ð±Ð°Ð¹Ñ Ð´Ð¸Ñкового пÑоÑÑÑанÑÑва Ð´Ð»Ñ Ð²ÑеменнÑÑ
Ñайлов"
+#~ msgid "Cannot write raster maps -- try to increase resolution"
+#~ msgstr ""
+#~ "Ðевозможно ÑоздаÑÑ ÑаÑÑÑовÑй Ñайл -- попÑобÑйÑе ÑвелиÑиÑÑ ÑазÑеÑение"
+#~ msgid "Print all map connection parameters and exit in shell script style"
+#~ msgstr ""
+#~ "ÐÑвеÑÑи вÑе паÑамеÑÑÑ ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ ÑÐ»Ð¾Ñ Ð¸ вÑйÑи в ÑÑиле ÑкÑипÑа оболоÑки"
+#~ msgid "Vector map <%s> is connected by:"
+#~ msgstr "ÐекÑоÑнÑй Ñлой <%s> пÑиÑоединен к:"
+#~ msgid ""
+#~ "No features drapped. Check Your computational region and input raster map."
+#~ msgstr ""
+#~ "ÐбÑекÑÑ Ð½Ðµ дÑаппиÑованÑ. ÐÑовеÑÑÑе ÑаÑÑеÑнÑй Ñегион и вÑ
одной ÑаÑÑÑовÑй "
+#~ "Ñлой."
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#~ msgstr "ÐкÑпоÑÑ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ GRASS в ÑоÑÐ¼Ð°Ñ DXF."
+#~ msgid "Unable to determine raster cell type"
+#~ msgstr "Ðевозможно опÑеделиÑÑ Ñип ÑÑеек ÑаÑÑÑа"
+#~ msgid "Name for output file (do not add extension)"
+#~ msgstr "Ðазвание Ð´Ð»Ñ Ñайла вÑвода (ÐÐ ÑказÑваÑÑ ÑаÑÑиÑение)"
+#~ msgid "Width and height of output image"
+#~ msgstr "ШиÑина и вÑÑоÑа вÑÑ
одного изобÑажениÑ"
+#~ msgid "Surface"
+#~ msgstr "ÐовеÑÑ
ноÑÑÑ"
+#~ msgid "Volume"
+#~ msgstr "ÐбÑем"
+#~ msgid "OGR driver: column '%s', OGR type %d is not supported"
+#~ msgstr "OGR дÑайвеÑ: ÑÑÐ¾Ð»Ð±ÐµÑ '%s', OGR Ñип %d не поддеÑживаеÑÑÑ"
+#~ msgid "Prints/sets general DB connection for current mapset and exits."
+#~ msgstr ""
+#~ "ÐоказаÑÑ/ÑÑÑановиÑÑ Ñоединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
Ð´Ð»Ñ ÑекÑÑего набоÑа и вÑйÑи."
+#~ msgid "Database schema"
+#~ msgstr "СÑ
ема Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
+#~ msgid "database, SQL"
+#~ msgstr "база даннÑÑ
, SQL"
+#~ msgid "Name of file with sql statement"
+#~ msgstr "Ðазвание Ñайла, ÑодеÑжаÑего SQL-опеÑаÑоÑ"
+#~ msgid "The password was stored in file"
+#~ msgstr "ÐаÑÐ¾Ð»Ñ ÑоÑ
Ñанен в Ñайле"
+#~ msgid "imagery, raster, multispectral"
+#~ msgstr "изобÑажениÑ, ÑаÑÑÑ, мÑлÑÑиÑпекÑÑалÑнÑе"
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ð²Ñе ÑÑаÑÑе Ñлои GRASS < Ver5.7 в ÑекÑÑем набоÑе в ÑекÑÑий "
+#~ "ÑоÑмаÑ"
+#~ msgid "Slower but accurate (applies to FP maps only)"
+#~ msgstr "Ðедленнее, но ÑоÑнее (пÑименимо ÑолÑко Ð´Ð»Ñ FP Ñлоев)"
+#~ msgid "raster, elevation"
+#~ msgstr "ÑаÑÑÑ, вÑÑоÑа"
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸Ð· одной пÑоекÑии в дÑÑгÑÑ (иÑполÑзÑÐµÑ cs2cs)."
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#~ msgstr "ÐÑÑ
однÑй Ñайл кооÑÐ´Ð¸Ð½Ð°Ñ (не ÑказÑвайÑе Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¸Ð· stdin)"
+#~ msgid "Images"
+#~ msgstr "ÐзобÑажениÑ"
+#~ msgid "Compression for PNG files"
+#~ msgstr "СжаÑие Ð´Ð»Ñ PNG Ñайла"
+#~ msgid "PostScript"
+#~ msgstr "PostScript"
+#, fuzzy
+#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
+#~ msgstr "ÐлÑÑ(и) меÑаданнÑÑ
и вклÑÑаемÑе знаÑениÑ"
+#, fuzzy
+#~ msgid ""
+#~ "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+#~ msgstr "ФоÑÐ¼Ð°Ñ \"NAME=VALUE\", ÑазделиÑÐµÐ»Ñ - запÑÑаÑ."
+#, fuzzy
+#~ msgid "Do not crop away margins"
+#~ msgstr "Ðе копиÑоваÑÑ ÑаблиÑÑ"
+#~ msgid "raster, tiling"
+#~ msgstr "ÑаÑÑÑ, плиÑки"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (NIR: tm4 | qbird_nir | spot2)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+#~ msgid "general, extensions"
+#, fuzzy
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "ÐÑвеÑÑи ÑпиÑок доÑÑÑпнÑÑ
пÑавил и вÑйÑи"
+#~ msgid "display, diagram"
+#~ msgstr "показ, диагÑамма"
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "ÐÑÑÐµÑ Ð³ÐµÐ¾Ð¼ÐµÑÑиÑеÑкой ÑÑаÑиÑÑики Ð´Ð»Ñ Ð²ÐµÐºÑоÑов."
+#, fuzzy
+#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+#~ msgstr "Ð¸Ð¼Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ обÑаза ÑÐ»Ð¾Ñ (наÑ
одиÑÑÑ Ð² ~/.gpsdrive)"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "ÐоказаÑÑ HTML ÑÑÑаниÑÑ ÑÑководÑÑва GRASS"
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr "СоздаÑÑ MASK Ð´Ð»Ñ Ð¾Ð³ÑаниÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
опеÑаÑий"
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "РаÑÑÑовÑй Ñлой, иÑполÑзÑемÑй в каÑеÑÑве MASK"
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "ÐнаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий Ð´Ð»Ñ MASK (ÑоÑмаÑ: 1 2 3 до 7 *)"
+#~ msgid "Create inverse MASK from specified 'maskcats' list"
+#~ msgstr "СоздаÑÑ Ð¸Ð½Ð²ÐµÑÑиÑованнÑÑ MASK из заданного ÑпиÑка 'maskcats'"
+#~ msgid "Remove existing MASK (overrides other options)"
+#~ msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ MASK (заменÑÐµÑ Ð´ÑÑгие опÑии)"
+#, fuzzy
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ ÑÑаÑой Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. Ðаза даннÑÑ
+#~ "задаваемой v.db.connect -g, Ñо еÑÑÑ Ñ Ð¿Ð¾Ð´Ð¼ÐµÐ½ÐµÐ½Ð½Ñми пеÑеменнÑми."
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "ÐÐ¼Ñ Ð¿Ð¾ÐºÐ°Ð·Ñваемого полÑ"
+#, fuzzy
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "ÐÑÑиÑление одномеÑной ÑÑаÑиÑÑики по ÑаÑÑÑÐ¾Ð²Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ GRASS, иÑполÑзÑÑ "
+#~ "векÑоÑнÑе полигонÑ. ÐагÑÑзка ÑÑаÑиÑÑики в новÑй ÑÑÐ¾Ð»Ð±ÐµÑ Ð°ÑÑибÑÑов."
+#~ msgid "Name of vector polygon map"
+#~ msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного полигоналÑного ÑлоÑ"
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð²ÑÑиÑÐ»ÐµÐ½Ð¸Ñ ÑÑаÑиÑÑики"
+#, fuzzy
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "ÐмпоÑÑ Ð² GRASS векÑоÑнÑÑ
Ñлоев ÑоÑмаÑа Mapgen или Matlab."
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr "РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS"
+#~ msgid "C"
+#~ msgstr "C"
+#~ msgid "D"
+#~ msgstr "D"
+#~ msgid "Show help"
+#~ msgstr "ÐоказаÑÑ Ð¿Ð¾Ð¼Ð¾ÑÑ"
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "ÐаÑалог Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð·Ð°Ð³ÑÑженнÑÑ
даннÑÑ
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ. ÐÑли -1, полÑÑаÑÑÑÑ Ð²Ñе Ñлои"
+#, fuzzy
+#~ msgid "Import GetFeature from WFS"
+#~ msgstr "импоÑÑиÑоваÑÑ GetFeature из WFS"
+#~ msgid "raster, landscape structure analysis"
+#~ msgstr "ÑаÑÑÑ, ÑÑÑÑкÑÑÑнÑй анализ ландÑаÑÑа"
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "ÐмпоÑÑ Ñайла SPOT VGT NDVI в ÑаÑÑÑовÑй Ñлой"
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr ""
+#~ "Ñакже импоÑÑиÑоваÑÑ Ñлой каÑеÑÑва (Ñлой ÑÑаÑÑÑа SM) и Ñлой "
+#~ "оÑÑилÑÑÑованного NDVI"
+#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+#~ msgstr "ÑÑÑеÑÑвÑÑÑий Ñайл SPOT VGT NDVI HDF (0001_NDV.HDF)"
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ ÐºÐ¾ÑоÑого ÑедакÑиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
+#~ msgid "Layer where to add column"
+#~ msgstr "Слой к коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð¸ÑÑ ÑÑолбеÑ"
+#~ msgid "Computing row %d of covariance matrix..."
+#~ msgstr "ÐÑÑиÑлÑеÑÑÑ ÑÑÑока %d маÑÑиÑÑ ÐºÐ¾Ð²Ð°ÑиаÑии..."
+#~ msgid "imagery, rectify"
+#~ msgstr "изобÑажениÑ, ÑÑанÑÑоÑмиÑоваÑÑ"
+#, fuzzy
+#~ msgid "No target elevation model selected for group <%s>"
+#~ msgstr "Ðе вÑбÑан Ñайл камеÑÑ Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s]"
+#, fuzzy
+#~ msgid "No camera reference file selected for group <%s>"
+#, fuzzy
+#~ msgid "Bad format in camera file for group <%s>"
+#~ msgstr "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла камеÑÑ Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s]"
+#, fuzzy
+#~ msgid "Bad format in initial exposusre station file for group <%s>"
+#~ msgstr ""
+#~ "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла наÑалÑной ÑкÑпозиÑии ÑÑанÑии Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
+#~ msgid "raster, terrain analysis"
+#~ msgstr "ÑаÑÑÑ, анализ ÑелÑеÑа"
+#~ msgid "SECTION 3: Accumulating Surface Flow."
+#~ msgstr "СÐÐЦÐЯ 3: ÐккÑмÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока."
+#~ msgid "Name of input vector points map"
одного ÑоÑеÑного векÑоÑного ÑлоÑ"
+#~ msgid "Eigen values:"
+#~ msgstr "Eigen знаÑениÑ:"
+#~ msgid "<%s> vector map will be interpolated"
+#~ msgstr "<%s> векÑоÑнÑй Ñлой бÑÐ´ÐµÑ Ð¸Ð½ÑеÑполиÑован."
+#, fuzzy
+#~ msgid "Writing data to file..."
+#~ msgstr "ÐапиÑÑ ÑÑанÑÑоÑмиÑованнÑÑ
даннÑÑ
в Ñайл..."
+#~ msgid "Writing %s"
+#~ msgstr "ÐапиÑÑ %s"
+#~ msgid "ID values"
+#~ msgstr "ÐнаÑÐµÐ½Ð¸Ñ ID"
+#~ msgid "To layer"
+#~ msgstr "ÐонеÑнÑй Ñлой"
+#~ msgid "vector, attribute table"
+#~ msgstr "векÑоÑ, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
+#~ msgid "Type of elements"
+#~ msgstr "Тип ÑлеменÑов"
+#~ msgid "Output hue raster map"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ñона"
+#, fuzzy
+#~ msgid "1 class."
+#~ msgstr "%d клаÑÑов."
+#, fuzzy
+#~ msgid "Skipping [%s]..."
+#~ msgstr " ."
+#, fuzzy
+#~ msgid "Unable to delete line %d"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Cannot open OGR data source '%s'"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "%s in %s: %s"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Reading raster map <%s> ..."
+#~ msgstr " ."
+#, fuzzy
+#~ msgid "Vector map <%s> not found in current mapset"
+#~ msgstr "векÑÐ¾Ñ "
+#, fuzzy
+#~ msgid "Database record for cat %d not found"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Cannot open file for <%s>"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Read coordinates from standard input"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Could not find input vector map %s"
+#, fuzzy
+#~ msgid "name for new vector map"
+#~ msgstr "векÑоÑ"
+#, fuzzy
+#~ msgid "%s - too many patch files. only %d allowed"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "<%s> is an ilegal name"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Direction raster found <%s>"
+#~ msgstr "ÐапиÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#, fuzzy
+#~ msgid "Input value: maximum length of surface flow in map units, for USLE"
+#~ msgstr ""
+#~ "ÐÑÑ
одное знаÑение: макÑималÑÐ½Ð°Ñ Ð´Ð»Ð¸Ð½Ð° повеÑÑ
ноÑÑного ÑÑока, Ð´Ð»Ñ USLE"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d"
+#~ "(egrees)"
+#~ msgstr ""
+#~ "mi (мили), f (ÑÑÑÑ), me (меÑÑÑ), k (киломеÑÑÑ), a (акÑÑ), h (гекÑаÑÑ), p "
+#~ "(пÑоÑенÑÑ)"
+#, fuzzy
+#~ msgid "vector, spatial query"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_sl.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -13201,9 +13201,8 @@
#: ../general/g.message/main.c:62 ../general/g.message/main.c:67
#: ../general/g.message/main.c:81
-#, fuzzy
msgid "Level"
-msgstr "Ime rastrskega sloja"
+msgstr ""
#: ../general/g.message/main.c:63
msgid "Print message in all but full quiet mode"
@@ -13229,7 +13228,7 @@
#: ../general/g.message/main.c:105
#, fuzzy
msgid "Unable to parse input message"
-msgstr "ne morem odpreti <%s>"
+msgstr "\"Mapset\" vhodnega rastrskega sloja"
#: ../general/g.pnmcat/main.c:49
msgid "Unsupported PPM file (format = P6 required)"
@@ -16817,9 +16816,9 @@
msgstr ""
#: ../display/d.vect/plot1.c:616
-#, c-format
+#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr ""
+msgstr "Doloèena ni bila nobena vhodna datoteka."
#: ../display/d.vect/plot1.c:621
#, fuzzy, c-format
@@ -19001,7 +19000,7 @@
#: ../vector/v.random/main.c:134
#, fuzzy
msgid "3D output"
-msgstr "Izhodni sloj"
+msgstr "Prepi¹i izhod"
#: ../vector/v.random/main.c:111
msgid "Maximum z height (needs -z flag or column name)"
@@ -21034,9 +21033,8 @@
msgstr ""
#: ../vector/v.hull/main.c:53
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "Ime vhodnega rastrskega sloja"
+msgstr ""
#: ../vector/v.hull/main.c:64
#, fuzzy
@@ -24825,9 +24823,8 @@
msgstr "ime tabele"
#: ../vector/v.category/main.c:471
-#, fuzzy
msgid "line"
-msgstr "ime tabele"
+msgstr ""
#: ../vector/v.category/main.c:475
#, fuzzy
@@ -25276,7 +25273,7 @@
#: ../vector/v.db.connect/main.c:79
#, fuzzy
msgid "Field separator for shell script style output"
-msgstr "izpi¹i znak razmejitve med polji"
+msgstr "Izpi¹e vrednosti v stilu lupinskega skripta"
#: ../vector/v.db.connect/main.c:84
#, fuzzy
@@ -27369,10 +27366,14 @@
msgstr "Ime izhodnega vektorskega sloja"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
+#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
msgstr ""
+"Izdela rastrski sloj in vektorski toèkovni sloj vsebujoè nakljuèno "
+"locirane \n"
+"toèke."
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -27597,9 +27598,10 @@
msgstr "Izhodni rastrski sloj"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+#, fuzzy
msgid ""
"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
+msgstr "Resolucija vzdol¾ linije (privzeta = trenutna resolucija regije)"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
#, fuzzy
@@ -27651,8 +27653,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
+#, fuzzy
msgid "LANDSAT sensor"
-msgstr ""
+msgstr "Napetost"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
@@ -27666,8 +27669,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
+#, fuzzy
msgid "SPOT sensor"
-msgstr ""
+msgstr "Napetost"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
#, fuzzy
@@ -27922,8 +27926,9 @@
msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:11
+#, fuzzy
msgid "Value to calculate"
-msgstr ""
+msgstr "Ne morem izraèunati centroida obmoèja."
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
#, fuzzy
@@ -28067,8 +28072,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr ""
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
#, fuzzy
@@ -28081,12 +28087,14 @@
msgstr "Ime novega rastrskega sloja."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+#, fuzzy
msgid "Old schema"
-msgstr ""
+msgstr "ime baze podatkov"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+#, fuzzy
msgid "New schema"
-msgstr ""
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
@@ -28286,8 +28294,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
+#, fuzzy
msgid "display, vector, thematic, legend"
-msgstr ""
+msgstr "Ri¹em ..."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
@@ -28384,8 +28393,9 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
+#, fuzzy
msgid "Must be expressed as R:G:B triplet"
-msgstr ""
+msgstr "Uporabljam koordinate sredi¹èa sloja\n"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
#, fuzzy
@@ -28454,10 +28464,11 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+#, fuzzy
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
-msgstr ""
+msgstr "Ime vhodnega rastrskega sloja"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -28577,8 +28588,9 @@
msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
+#, fuzzy
msgid "Reset to standard color range"
-msgstr ""
+msgstr "Ohrani obstojeèo barvno paleto"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
@@ -28595,8 +28607,9 @@
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+#, fuzzy
msgid "Percent to brighten"
-msgstr ""
+msgstr "Izpi¹i le razpon vrednosti"
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
#, fuzzy
@@ -28689,8 +28702,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
+#, fuzzy
msgid "Import"
-msgstr ""
+msgstr "Zapisujem novo datoteko...\n"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Don't reproject the data, just patch it"
@@ -28709,16 +28723,19 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr ""
+msgstr "Ne morem izbrati (select) podatkov iz tabele"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#, fuzzy
msgid "Layers to request from map server"
-msgstr ""
+msgstr "Interpolacijska metoda, ki jo ¾elite uporabiti"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#, fuzzy
msgid "Styles to request from map server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
#, fuzzy
@@ -28726,28 +28743,32 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#, fuzzy
msgid "Image format requested from the server"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
msgid "Addition query options for server"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+#, fuzzy
msgid "Maximum columns to request at a time"
-msgstr ""
+msgstr "Najveèja mo¾na razdalja od toèk (v metrih)."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#, fuzzy
msgid "Maximum rows to request at a time"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Additional options for r.tileset"
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
+#, fuzzy
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
msgid "Folder to save downloaded data to (default $GISDBASE/wms_download)"
@@ -28830,8 +28851,9 @@
msgstr "ne morem posodobiti meja"
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#, fuzzy
msgid "Action to be taken"
-msgstr ""
+msgstr "ne morem odpreti <%s>"
#: ../locale/scriptstrings/v.centroids_to_translate.c:9
msgid "Category number starting value"
@@ -28917,8 +28939,9 @@
msgstr "Ne ustvari tabele z atributi."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:6
+#, fuzzy
msgid "Layer where to drop column"
-msgstr ""
+msgstr "Ne ustvari tabele z atributi."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
@@ -28984,8 +29007,9 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
+msgstr "Nisem mogel odpreti vhodne datoteke dig_att."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
#, fuzzy
@@ -29102,8 +29126,9 @@
msgstr ""
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "Ime rastrskega sloja, ki bo uporabljen za <%s>"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#, fuzzy
@@ -29116,8 +29141,9 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+#, fuzzy
msgid "Width of display canvas"
-msgstr ""
+msgstr "Izpi¹i informacije o vhodnem rastrskem sloju in konèaj"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
#, fuzzy
@@ -29191,8 +29217,9 @@
msgstr "Ime datoteke s filtrom"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
#, fuzzy
@@ -31536,6 +31563,257 @@
msgstr ""
#, fuzzy
+msgid "Displays raster map layer in the active map display window."
+msgstr "Izbere pisavo v kateri bo tekst zapisan na grafiènem monitorju"
+#, fuzzy
+msgid "Raster file to be converted."
+msgstr "Rastrski sloj, ki ga nameravate uvoziti"
+#, fuzzy
+msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr "Ne najdem vhodne datoteke %s\n"
+#, fuzzy
+msgid "terrain analysis"
+#, fuzzy
+msgid "Unable to open vector map <%s> on level 2"
+msgstr "ne morem odpreti vektorske datoteke <%s> v <%s>"
+#, fuzzy
+msgid "Open vector map without topology (level 1)"
+#, fuzzy
+msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+msgstr ""
+"mi(lj), me(trov), k(ilometrov), a(krov), h(ektarov), c(elic), p(rocentov)"
+#, fuzzy
+msgid "Print bounds and exit (shell style)"
+#, fuzzy
+msgid "Estimate spline step value"
+msgstr "Izpi¹e osnovne statistike za rastrske sloje"
+#, fuzzy
+msgid "<%s> table created in database."
+msgstr "Izpi¹i vse tabele za dano bazo podatkov."
+#, fuzzy
+msgid "report"
+msgstr "©iroki izpis"
+#, fuzzy
+msgid "Unable to get cell header for <%s>"
+msgstr "Ne morem odpreti cellfile za [%s]"
+#, fuzzy
+msgid "Error reading <%s>"
+#, fuzzy
+msgid "%s: Error reading from raster map <%s>"
+#, fuzzy
+msgid "unable to open map <%s> in <%s>"
+msgstr "Ime izhodnega rastrskega sloja"
+#, fuzzy
+msgid "unable to read map <%s> in <%s>"
+msgstr "ne morem prebrati regije <%s> v <%s>"
+#, fuzzy
+msgid "Unable to open base map <%s>"
+#, fuzzy
+msgid "Unable to open cover map <%s>"
+#, fuzzy
+msgid "Unable to open output map <%s>"
+#, fuzzy
+msgid "Unable to read header for <%s>"
+#, fuzzy
+msgid "Error reading row %d (error = %d)"
+#, fuzzy
+msgid "Cannot set region to output region"
+msgstr "Ne morem ustvariti indeksa"
+#, fuzzy
+msgid "Unable to read row %d"
+msgstr "Vrednost, ki bo prirejena NULL vrednosti"
+#, fuzzy
+msgid "Unable to read region <%s>"
+msgstr "Ne morem vstaviti nove vrstice: %s"
+#, fuzzy
+msgid "unable to open accumulation map layer"
+#, fuzzy
+msgid "SECTION 4: Extracting Streams."
+#, fuzzy
+msgid "Error reading row <%d>"
+#, fuzzy
+msgid "Name of input raster map containing starting points"
+msgstr "Ime obstojeèega rastrskega sloja s plastnicami"
+#, fuzzy
+msgid "Unable to open input map <%s>"
+#, fuzzy
+msgid "Error reading row %d"
+#, fuzzy
+msgid "Unable to read raster map row %ld"
+#, fuzzy
+msgid "Failed writing raster map row %ld"
+msgstr "Berem dig_att datoteko...\n"
+#, fuzzy
+msgid "Unable to read from <%s> row %d"
+#, fuzzy
+msgid "Unable to read file header of raster map <%s>"
+msgstr "Ne morem odpreti baze podatkov %s"
+#, fuzzy
+msgid "Unable to write to raster map<%s>"
+msgstr "Ime rastrskega sloja"
+#, fuzzy
+msgid "Unable to open training map <%s>"
+#, fuzzy
+msgid "Unable to open training map <%s in %s>"
+#, fuzzy
+msgid "Cannot open cell file [%s]"
+#, fuzzy
+msgid "Cannot read file header of [%s])"
+msgstr "Ne morem prebrati informacije polja"
+#, fuzzy
+msgid "Cannot write to output raster file"
+#, fuzzy
+msgid "Unable to read header of raster map <%s> "
+#, fuzzy
+msgid "Unable to read raster map <%s> row %d >"
+#, fuzzy
+msgid "qcname"
+msgstr "ime tabele"
+#, fuzzy
+msgid "Name of QC"
+msgstr "Ime datoteke s filtrom"
+#, fuzzy
+msgid "250m band number is out of allowed range [1,2]"
+msgstr " ©tevilo vrstic\n"
+#, fuzzy
+msgid "Cannot read file header of [%s]"
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "Ime izhodne datoteke"
+#, fuzzy
+msgid "raster, soil, erosion, USLE"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+#, fuzzy
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr "Ne morem odpreti datoteke s koordinatami : %s\n"
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+#, fuzzy
+msgid "Group [%s] not found."
+msgstr "ne najdem regije <%s>"
+#, fuzzy
+msgid "Writing viewable versions of transformed data to files..."
+#, fuzzy
+msgid "Unable to open file in the cell_misc directory."
+#, fuzzy
+msgid "Can't open seed signature file <%s>"
+msgstr "ne morem odpreti 3Dview datoteke <%s> v <%s>"
+#, fuzzy
+msgid "Can't read signature file <%s>"
+#, fuzzy
+msgid "From layer"
+msgstr " nv barva\n"
+#, fuzzy
+msgid "Select type"
+msgstr "Tip objektov"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "izhodni rastrski sloj"
+#, fuzzy
+msgid "Erasing monitors ..."
+#, fuzzy
+msgid "Output terrain only vector map name"
+msgstr "Ime izhodnega rastrskega sloja ekspozicij"
+#, fuzzy
+msgid "Raster file [%s] not available"
+msgstr "Rastrska(e) datoteka(e) za ogled %d"
+#, fuzzy
#~ msgid "Not enough room in history file"
#~ msgstr "Ime vhodnega rastrskega sloja"
@@ -31552,10 +31830,6 @@
#~ msgstr "Ime datoteke s filtrom"
#, fuzzy
-#~ msgid "Displays raster map layer in the active map display window."
-#~ msgstr "Izbere pisavo v kateri bo tekst zapisan na grafiènem monitorju"
-#, fuzzy
#~ msgid "Failed in attempt to open %s"
#~ msgstr "Ime izhodnega vektorskega sloja"
@@ -31614,14 +31888,6 @@
#~ msgstr "Ne ustvari tabele z atributi."
#, fuzzy
-#~ msgid "Raster file to be converted."
-#~ msgstr "Rastrski sloj, ki ga nameravate uvoziti"
-#, fuzzy
-#~ msgid "File containing reclass rules; \"-\" to read from stdin"
-#~ msgstr "Ne najdem vhodne datoteke %s\n"
-#, fuzzy
#~ msgid "Generates a raster map layer showing watershed subbasins."
#~ msgstr "Izdela rastrski sloj, ki prikazuje razvodnice in podpovodja"
@@ -31735,10 +32001,6 @@
#~ msgid "(i) OPTIONAL Output for given topographic index class"
#~ msgstr " Izhod za doloèeni razred topografskega indeksa"
-#, fuzzy
-#~ msgid "terrain analysis"
-#~ msgstr "Ime rastrskega sloja, ki bo uporabljen za <%s>"
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr ""
#~ "Ime obstojeèega rastrskega sloja, ki vsebuje podatke o vi¹ini povr¹ja"
@@ -31791,19 +32053,6 @@
#~ msgstr "ne morem odpreti <%s>"
#, fuzzy
-#~ msgid "Unable to open vector map <%s> on level 2"
-#~ msgstr "ne morem odpreti vektorske datoteke <%s> v <%s>"
-#, fuzzy
-#~ msgid "Open vector map without topology (level 1)"
-#, fuzzy
-#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-#~ msgstr ""
-#~ "mi(lj), me(trov), k(ilometrov), a(krov), h(ektarov), c(elic), p(rocentov)"
-#, fuzzy
#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
#~ msgstr "Preoblikuje rastrski sloj v vektorskega."
@@ -31823,10 +32072,6 @@
#~ "DEFINIRANE REGIJE"
#, fuzzy
-#~ msgid "Print bounds and exit (shell style)"
-#~ msgstr "Izpi¹e vrednosti v stilu lupinskega skripta"
-#, fuzzy
#~ msgid ""
#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
#~ "resolution of the currently defined region."
@@ -31836,14 +32081,6 @@
#, fuzzy
-#~ msgid "Estimate spline step value"
-#~ msgstr "Izpi¹e osnovne statistike za rastrske sloje"
-#, fuzzy
-#~ msgid "<%s> table created in database."
-#~ msgstr "Izpi¹i vse tabele za dano bazo podatkov."
-#, fuzzy
#~ msgid "Unable to close output map"
#~ msgstr "Ime izhodnega sloja"
@@ -31896,19 +32133,11 @@
#~ msgstr "Ime rastrskega sloja"
#, fuzzy
-#~ msgid "report"
-#~ msgstr "©iroki izpis"
-#, fuzzy
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr ""
#, fuzzy
-#~ msgid "Unable to get cell header for <%s>"
-#~ msgstr "Ne morem odpreti cellfile za [%s]"
-#, fuzzy
#~ msgid "Unable to write quant file"
#~ msgstr "Vrednost, ki bo prirejena NULL vrednosti"
@@ -31961,10 +32190,6 @@
#~ msgstr "Ne morem odpreti baze podatkov %s"
#, fuzzy
-#~ msgid "Error reading <%s>"
-#~ msgstr "Ime vhodnega rastrskega sloja"
-#, fuzzy
#~ msgid "Reading row %d"
#~ msgstr "Berem dig datoteko...\n"
@@ -32057,10 +32282,6 @@
#~ msgstr "Ne morem ustvariti tabele: %s"
#, fuzzy
-#~ msgid "%s: Error reading from raster map <%s>"
-#, fuzzy
#~ msgid "Error in pipe creation"
#~ msgstr "Nisem uspel odpreti vhodne datoteke."
@@ -32105,14 +32326,6 @@
#~ msgstr "Ne morem odpreti dig_cats datoteke."
#, fuzzy
-#~ msgid "unable to open map <%s> in <%s>"
-#~ msgstr "Ime izhodnega rastrskega sloja"
-#, fuzzy
-#~ msgid "unable to read map <%s> in <%s>"
-#~ msgstr "ne morem prebrati regije <%s> v <%s>"
-#, fuzzy
#~ msgid "Unable to get header for %s"
@@ -32121,18 +32334,6 @@
#~ msgstr "Ne morem ustvariti indeksa"
#, fuzzy
-#~ msgid "Unable to open base map <%s>"
-#, fuzzy
-#~ msgid "Unable to open cover map <%s>"
-#, fuzzy
-#~ msgid "Unable to open output map <%s>"
-#~ msgstr "ne morem odpreti <%s>"
-#, fuzzy
#~ msgid "Cannot create category file for <%s>"
@@ -32177,18 +32378,6 @@
#, fuzzy
-#~ msgid "Unable to read header for <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d (error = %d)"
-#, fuzzy
-#~ msgid "Cannot set region to output region"
-#~ msgstr "Ne morem ustvariti indeksa"
-#, fuzzy
#~ msgid "Unable to read raster <map %d of %d> row %d"
@@ -32209,10 +32398,6 @@
#~ msgstr "Ri¹em ..."
#, fuzzy
-#~ msgid "Unable to read row %d"
-#~ msgstr "Vrednost, ki bo prirejena NULL vrednosti"
-#, fuzzy
#~ msgid "Exporting raster as double values (bytes=%d)"
#~ msgstr "Zapisujem novo datoteko...\n"
@@ -32229,10 +32414,6 @@
#~ msgstr "Berem dig_att datoteko...\n"
#, fuzzy
-#~ msgid "Unable to read region <%s>"
-#~ msgstr "Ne morem vstaviti nove vrstice: %s"
-#, fuzzy
#~ msgid "Invalid region: %s"
#~ msgstr "neveljavna regija: %s"
@@ -32293,14 +32474,6 @@
#, fuzzy
-#~ msgid "unable to open accumulation map layer"
-#, fuzzy
-#~ msgid "SECTION 4: Extracting Streams."
-#~ msgstr "Zapisujem novo datoteko...\n"
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
@@ -32321,14 +32494,6 @@
#, fuzzy
-#~ msgid "Error reading row <%d>"
-#, fuzzy
-#~ msgid "Name of input raster map containing starting points"
-#~ msgstr "Ime obstojeèega rastrskega sloja s plastnicami"
-#, fuzzy
#~ msgid "Number of the segment to create (segment library)"
#~ msgstr "©tevilo ponovitev filtracije"
@@ -32377,14 +32542,6 @@
#~ msgstr "izhodni rastrski sloj"
#, fuzzy
-#~ msgid "Unable to open input map <%s>"
-#, fuzzy
-#~ msgid "Error reading row %d"
-#, fuzzy
#~ msgid "Error reading input"
@@ -32533,22 +32690,10 @@
#~ msgstr "Ne morem prebrati informacije polja"
#, fuzzy
-#~ msgid "Unable to read raster map row %ld"
-#, fuzzy
-#~ msgid "Failed writing raster map row %ld"
-#~ msgstr "Berem dig_att datoteko...\n"
-#, fuzzy
#~ msgid "Unable to allocate the input row buffer"
#~ msgstr "Ne morem izraèunati centroida obmoèja."
#, fuzzy
-#~ msgid "Unable to read from <%s> row %d"
-#, fuzzy
#~ msgid "Did not find input cell map MASK."
#~ msgstr "Ne morem najti vhodne datoteke <%s>\n"
@@ -32561,34 +32706,10 @@
#~ msgstr "ne morem posodobiti meja"
#, fuzzy
-#~ msgid "Unable to read file header of raster map <%s>"
-#~ msgstr "Ne morem odpreti baze podatkov %s"
-#, fuzzy
-#~ msgid "Unable to write to raster map<%s>"
-#~ msgstr "Ime rastrskega sloja"
-#, fuzzy
#~ msgid "Error while reading input raster map."
#, fuzzy
-#~ msgid "Unable to open training map <%s>"
-#, fuzzy
-#~ msgid "Unable to open training map <%s in %s>"
-#, fuzzy
-#~ msgid "Cannot open cell file [%s]"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s])"
-#~ msgstr "Ne morem prebrati informacije polja"
-#, fuzzy
#~ msgid "Could not open <%s>"
@@ -32597,18 +32718,6 @@
#, fuzzy
-#~ msgid "Cannot write to output raster file"
-#, fuzzy
-#~ msgid "Unable to read header of raster map <%s> "
-#, fuzzy
-#~ msgid "Unable to read raster map <%s> row %d >"
-#, fuzzy
#~ msgid "Error reading row of data"
@@ -32762,22 +32871,6 @@
#~ msgstr "©tevilo toèk najbli¾jih toèk, ki bodo upo¹tevane"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "ime tabele"
-#, fuzzy
-#~ msgid "Name of QC"
-#~ msgstr "Ime datoteke s filtrom"
-#, fuzzy
-#~ msgid "250m band number is out of allowed range [1,2]"
-#~ msgstr " ©tevilo vrstic\n"
-#, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#, fuzzy
#~ msgid "imagery, classification, supervised, SMAP"
#~ msgstr "Ime datoteke z rezultatom klasifikacije"
@@ -33034,10 +33127,6 @@
#, fuzzy
-#~ msgid "raster, rainfall, erosion, USLE"
-#~ msgstr "Ime izhodne datoteke"
-#, fuzzy
#~ msgid "raster, flow, hydrology"
@@ -33085,10 +33174,6 @@
#~ msgstr "Izhodni sloj: uporaben za vizualni pregled rezultatov"
#, fuzzy
-#~ msgid "raster, soil, erosion, USLE"
-#, fuzzy
#~ msgid "raster, random, surface"
#~ msgstr "Rastrski sloj za povr¹ino"
@@ -33202,20 +33287,6 @@
#~ msgstr "Naslov izhodnega rastrskega sloja"
#, fuzzy
-#~ msgid "Unable to find the real-image map <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open real-image in the cell_misc directory.\n"
-#~ "Input map probably wasn't created by i.fft"
-#~ msgstr "Ne morem odpreti datoteke s koordinatami : %s\n"
-#, fuzzy
-#~ msgid "Unable to find the imaginary-image <%s>"
-#, fuzzy
#~ msgid "Power 2 values : [%d] rows [%d] columns."
#~ msgstr "%d raster%s, %d vektor%s\n"
@@ -33307,10 +33378,6 @@
#~ msgstr "Po¾eni tiho"
#, fuzzy
-#~ msgid "Group [%s] not found."
-#~ msgstr "ne najdem regije <%s>"
-#, fuzzy
#~ msgid "Subgroup [%s] not found."
@@ -33380,14 +33447,6 @@
#~ msgstr "Nepoznan tip"
#, fuzzy
-#~ msgid "Writing viewable versions of transformed data to files..."
-#, fuzzy
-#~ msgid "Unable to open file in the cell_misc directory."
-#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
@@ -33406,14 +33465,6 @@
#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "ne morem odpreti 3Dview datoteke <%s> v <%s>"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#, fuzzy
#~ msgid "Group of imagery files to be clustered"
@@ -33699,18 +33750,10 @@
#, fuzzy
-#~ msgid "From layer"
-#~ msgstr " nv barva\n"
-#, fuzzy
#~ msgid "The column must be type integer or string"
#~ msgstr "Ne najdem vhodnega vektorja <%s>"
#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "Tip objektov"
-#, fuzzy
#~ msgid "Cannot select records from database"
#~ msgstr "Ne morem izbrati (select) podatkov iz tabele"
@@ -34036,10 +34079,6 @@
#~ msgstr "Rastrski sloj nadmorskih vi¹in"
#, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "izhodni rastrski sloj"
-#, fuzzy
#~ msgid "Output raster map with lake"
@@ -34581,10 +34620,6 @@
#, fuzzy
-#~ msgid "Erasing monitors ..."
-#, fuzzy
#~ msgid "Could not open input file <%s>."
@@ -35023,10 +35058,6 @@
#~ msgstr "Ne morem izpisati baz podatkov."
#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "Ime izhodnega rastrskega sloja ekspozicij"
-#, fuzzy
#~ msgid "Cannot open vector map <%s> at the topological level"
@@ -35342,10 +35373,6 @@
#, fuzzy
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Rastrska(e) datoteka(e) za ogled %d"
-#, fuzzy
#~ msgid "Raster map [%s] not found"
#~ msgstr "Ne najdem vhodnega rastrskega sloja <%s>."
@@ -36600,3 +36627,1382 @@
#~ "Displays the rhumbline joining two user-specified points, in the active "
#~ "frame on the user's graphics monitor."
+#, fuzzy
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Preobrazi rastrski sloj v ASCII tekstovno datoteko."
+#, fuzzy
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr "Spremeni ascii rastrsko tekstovno datoteko v binarni rastrski sloj."
+#, fuzzy
+#~ msgid "Recharge raster map in m^3/s"
+#~ msgstr "Berem dig_att datoteko...\n"
+#, fuzzy
+#~ msgid "raster3d, statistics"
+#~ msgstr "Ime rastrskega sloja, ki bo uporabljen za <%s>"
+#, fuzzy
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "Izvozi GRASS rastrski sloj v binarni MAT-File"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "Izvozi GRASS-ov rastrski sloj v GRIDATB.FOR datoteko (TOPMODEL)"
+#, fuzzy
+#~ msgid "Name of base raster map"
+#~ msgstr "Ime rastrskega sloja"
+#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
+#~ msgstr "Preobrazi rastrski sloj v datoteko polja vi¹in za POVRAY"
+#, fuzzy
+#~ msgid "raster, map algebra"
+#~ msgstr "Ime izhodne datoteke"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#, fuzzy
+#~ msgid "Converting %s..."
+#~ msgstr "Zapisujem novo datoteko...\n"
+#, fuzzy
+#~ msgid "Unable to find stop vector <%s>"
+#~ msgstr "Ne najdem vhodne datoteke %s\n"
+#~ msgid "Import as Floating Point Data (default: Integer)"
+#~ msgstr "Uvozi kot \"Floating Point\" (privzeto: Integer)"
+#~ msgid "Import as Double Precision Data (default: Integer)"
+#~ msgstr "Uvozi kot \"Double precision\" (privzeto: Integer)"
+#, fuzzy
+#~ msgid "Parsing bytes per cell"
+#~ msgstr "©tevilo bajtov na celico (1, 2, 4)"
+#, fuzzy
+#~ msgid "Bad number of bytes per cell"
+#, fuzzy
+#~ msgid "Name of terrain raster map (DEM)"
+#~ msgstr "izhodni rastrski sloj"
+#, fuzzy
+#~ msgid "Name for output raster map with lake"
+#~ msgstr "Ime izhodnega rastrskega sloja"
+#, fuzzy
+#~ msgid "Interpolating raster map <%s> (%d rows)... "
+#, fuzzy
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Preoblikuje rastrski sloj v vektorskega."
+#, fuzzy
+#~ msgid "raster, terrain"
+#~ msgstr "©tevilo toèk najbli¾jih toèk, ki bodo upo¹tevane"
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "Ime datoteke s filtrom"
+#, fuzzy
+#~ msgid "Unable to find row %d, col %d: %f"
+#~ msgstr "Ne morem najti vhodne datoteke <%s>\n"
+#, fuzzy
+#~ msgid "Name of the water depth raster map [m]"
+#~ msgstr "Ime rastrskega sloja ekspozicij"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Ime vhodnega rastrskega sloja"
+#, fuzzy
+#~ msgid "Name of the y-derivatives raster map [m/m]"
+#, fuzzy
+#~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr ""
+#~ "Rastrski sloj koeficienta prave nebesne radiacije (direktne in sipajoèe) "
+#, fuzzy
+#~ msgid "Name of the transport capacity coefficient raster map [s]"
+#, fuzzy
+#~ msgid "Name of the critical shear stress raster map [Pa]"
+#~ msgstr "Ime novega rastrskega sloja"
+#, fuzzy
+#~ msgid "Name of the Mannings n raster map"
+#, fuzzy
+#~ msgid "Name of the Mannings n value"
+#, fuzzy
+#~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Ime izhodnega rastrskega sloja ekspozicij"
+#, fuzzy
+#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Output sediment concentration raster map [particle/m3]"
+#~ msgstr "Ime izhodnega rastrskega sloja smeri toka"
+#, fuzzy
+#~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Ime \"drain\" izhodnega rastrskega sloja"
+#, fuzzy
+#~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#, fuzzy
+#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#, fuzzy
+#~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#, fuzzy
+#~ msgid "Output water discharge raster map [m3/s]"
+#~ msgstr "Ime izhodnega gonilnika"
+#, fuzzy
+#~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Ime izhodnega rastrskega sloja naklonov"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Preobrazi 3 GRASS rastrske sloje (R,G,B) v PPM slikovno datoteko v "
+#~ "resolucijo \n"
+#~ "TRENUTNO DEFINIRANE REGIJE."
+#, fuzzy
+#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+#~ msgstr "ne morem odpreti razpona za datoteko %s"
+#, fuzzy
+#~ msgid "raster, buffer"
+#~ msgstr "Vhodni rastrski sloj"
+#, fuzzy
+#~ msgid "raster, series"
+#~ msgstr "Rastrski sloj, ki ga ¾elite rekodirati"
+#~ msgid "Input map: amount of overland flow per cell"
+#~ msgstr "Vhodni sloj: kolièina povr¹inskega toka na celico"
+#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
+#~ msgstr "Vhodni sloj: ovire povr¹inskemu toku (za USLE)"
+#~ msgid "Output map: number of cells that drain through each cell"
+#~ msgstr "Izhodni sloj: ¹tevilo celic, ki se odvodnjavajo skozi vsako celico"
+#~ msgid "Output map: unique label for each watershed basin"
+#~ msgstr "Izhodni sloj: edinstvena vrednost za vsako poreèje"
+#~ msgid "Output map: each half-basin is given a unique value"
+#~ msgstr "Izhodni sloj: vsaka polovica poreèja pridobi edinstveno vrednost"
+#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
+#~ msgstr "Izhodni sloj: dol¾ina poboèja (L faktor za USLE)"
+#~ msgid "Output map: slope steepness (S) factor for USLE"
+#~ msgstr "Izhodni sloj: naklon poboèja (S faktor za USLE)"
+#~ msgid "Input value: minimum size of exterior watershed basin"
+#~ msgstr "Vhodni sloj: najmanj¹a velikost zunanjega poreèja"
+#~ msgid "Input value: maximum length of surface flow, for USLE"
+#~ msgstr "Vhodni sloj: najveèja dol¾ina povr¹inskega toka (za USLE)"
+#, fuzzy
+#~ msgid "unable to open flow accumulation map layer"
+#, fuzzy
+#~ msgid "Error writing color file for <%s>"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Serija rastrskih slojev v MPEG program."
+#, fuzzy
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Filtrira in izdela povr¹inski sloj brez depresij in sloj smeri toka iz \n"
+#~ "podanega sloja vi¹in."
+#, fuzzy
+#~ msgid "Output direction raster map"
+#~ msgid "Output raster map of problem areas"
+#~ msgstr "Ime izhodnega rastrskega sloja problematiènih obmoèij"
+#, fuzzy
+#~ msgid "raster, resample"
+#, fuzzy
+#~ msgid "Cannot read ew_res value"
+#~ msgstr "Ne morem opisati tabele"
+#, fuzzy
+#~ msgid "Cannot read ns_res value"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "Izdelava DMNV iz rasteriziranih plastnic"
+#~ msgid "Name of existing raster map containing contours"
+#~ msgstr "Ime obstojeèega rastrskega sloja s plastnicami"
+#, fuzzy
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Ustvari/Spremeni barvno paleto rastrskega sloja."
+#~ msgid "Raster map name from which to copy color table"
+#~ msgstr "Ime rastrskega sloja iz katerega kopirati barvno paleto"
+#, fuzzy
+#~ msgid "Path to rules file (\"-\" to read rules from stdin)"
+#~ msgstr "Binarna rastrska datoteka, ki jo nameravate uvoziti"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/ directory"
+#~ msgstr "Ne morem ustvariti indeksa"
+#, fuzzy
+#~ msgid "Cannot create %s/.r.li/output/ directory"
+#~ msgstr "Ime izhodnega sloja"
+#, fuzzy
+#~ msgid "Cannot make stat of %s configuration file"
+#, fuzzy
+#~ msgid "Range to be exported: %f - %f"
+#~ msgstr "Rastrski sloj, ki ga nameravate uvoziti"
+#, fuzzy
+#~ msgid "raster, null data"
+#, fuzzy
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr ""
+#~ "Izdela rastrski sloj z s stiènimi (contiguous) obmoèji poveèanimi za eno "
+#~ "celico"
+#, fuzzy
+#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
+#~ msgstr "(i) Karta poreèij izdelana z r.water.outlet"
+#, fuzzy
+#~ msgid "(o) Direction map for depressionless elevation map"
+#~ msgstr "(o) Sloj smeri vodnega odtoka iz brez-depresijskega sloja"
+#~ msgid "(i) Number of topographic index classes"
+#~ msgstr "(i) ©tevilo razredov topografskega indeksa"
+#, fuzzy
+#~ msgid "(o/i) Topographic index statistics file"
+#~ msgstr ""
+#~ "(i/o) Ime datoteke s statistiènimi znaèilnostmi topografskega indeksa"
+#~ msgid "(i) TOPMODEL Parameters file"
+#~ msgstr "(i) Datoteka s parametri za TOPMODEL"
+#~ msgid "(i) Rainfall and potential evapotranspiration data file"
+#~ msgstr "(i) Datoteka s padavinami in potencialno evapotranspiracijo"
+#~ msgid "A: altitude of the sun above horizon, degrees"
+#~ msgstr "A: vi¹ina sonca nad horizontom v stopinjah"
+#~ msgid "A: azimuth of the sun from the north, degrees"
+#~ msgstr "A: azimut sonca v stopinjah"
+#~ msgid "B: minutes (0..60)"
+#~ msgstr "B: minuta (med 0 in 60)"
+#~ msgid "B: seconds (0..60)"
+#~ msgstr "B: sekunda (med 0 in 60)"
+#~ msgid ""
+#~ "B: timezone (east positive, offset from GMT, also use to adjust daylight "
+#~ "savings)"
+#~ msgstr ""
+#~ "B: èasovni pas (nara¹èa proti vzhodu od GMT, uporabite za odpravo "
+#~ "poletnega\n"
+#~ "èasa)"
+#, fuzzy
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Izdela nov rastrski sloj katerega kategorije so rezultat reklasifikacije "
+#~ "kategorij obstojeèega rastrskega sloja."
+#~ msgid "Raster map to be reclassified"
+#~ msgstr "Rastrski sloj, ki ga ¾elite reklasificirati"
+#~ msgid "Converts a raster map into a vector map layer."
+#, fuzzy
+#~ msgid "The map E grid coordinates"
+#~ msgstr "X koordinata oziroma geografska dol¾ina"
+#, fuzzy
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "Ne morem odpreti baze podatkov %s"
+#, fuzzy
+#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
+#~ msgstr "fp: Razpon podatkov je %.25f do %.25f\n"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Integer data range of raster map <%s> is empty"
+#, fuzzy
+#~ msgid "Integer data range of raster mao <%s> is %d to %d"
+#~ msgstr "Razpon podatkov je %ld do %ld\n"
+#, fuzzy
+#~ msgid "Name of vector input map containing stream(s)"
+#~ msgstr "Vhodni sloj vsebuje linije."
+#, fuzzy
+#~ msgid "Output flowpath length raster map"
+#, fuzzy
+#~ msgid "Output flowline density raster map"
+#, fuzzy
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgid "Show the category label in the grid cell(s)"
+#~ msgstr "Poka¾e etiketo v mre¾i celic"
+#, fuzzy
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Izdela rastrski sloj s topografskim indeksom, ln(a/tan(beta)), iz "
+#~ "rastrskega\n"
+#~ "sloja nadmorskih vi¹in."
+#, fuzzy
+#~ msgid "Unable to open vector map <%s> in <%s>"
+#, fuzzy
+#~ msgid "Lat/Long location is not supported"
+#~ msgstr "Tip zapisa kolone ni podprt"
+#, fuzzy
+#~ msgid "raster, geomorphology"
+#, fuzzy
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Spremeni ESRI-jev ARC/INFO ascii rastrsko datoteko (GRID) v binarni "
+#~ "rastrski\n"
+#~ "sloj."
+#, fuzzy
+#~ msgid "File containing weights"
+#~ msgstr "Nisem mogel odpreti vhodne datoteke dig_att."
+#, fuzzy
+#~ msgid "general, scripts"
+#, fuzzy
+#~ msgid "general, settings"
+#, fuzzy
+#~ msgid "Erasing monitors..."
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "Izhodni sloj"
+#, fuzzy
+#~ msgid "%s: Couldn't read color table for <%s@%s>"
+#, fuzzy
+#~ msgid "name"
+#~ msgstr "ime tabele"
+#, fuzzy
+#~ msgid "Monitor: waitpid: expected %d but got %d"
+#~ msgstr "Monitor: waitpid: prièakovan %d, dobil pa %d\n"
+#, fuzzy
+#~ msgid "Either text or -c should be given"
+#~ msgstr "Uporabi¹ lahko ali 'from_table' ali 'select'"
+#, fuzzy
+#~ msgid "Unable to create face"
+#~ msgstr "ne morem posodobiti meja"
+#, fuzzy
+#~ msgid "Unable to set size"
+#~ msgstr "ne morem odpreti <%s>"
+#, fuzzy
+#~ msgid "Error reading hue data"
+#, fuzzy
+#~ msgid "R_color file for [%s] not available"
+#~ msgstr "Rastrska(e) datoteka(e) za ogled %d"
+#, fuzzy
+#~ msgid "Range file for [%s] not available"
+#, fuzzy
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr "Izbere pisavo v kateri bo tekst zapisan na grafiènem monitorju"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "%d toèk je bilo zapisanih na izhodno datoteko\n"
+#, fuzzy
+#~ msgstr "Izvozi GRASS-ov rastrski sloj v binarni \"array\""
+#, fuzzy
+#~ msgstr "Ne ustvari tabele z atributi."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ime rastrskega sloja, ki vsebuje podatke o stro¹ku premikanja"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Uvozi binarno rastrsko datoteko v GRASS-ov rastrski sloj."
+#, fuzzy
+#, fuzzy
+#~ msgstr "%-5d mrtvih kategorij toèk preskoèenih\n"
+#, fuzzy
+#~ msgid ""
+#, fuzzy
+#, fuzzy
+#~ msgid "vector, import, database, points"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ime izhodnega vektorskega toèkovnega sloja"
+#, fuzzy
+#~ msgstr "Ne morem odpreti cellfile za [%s]"
+#, fuzzy
+#, fuzzy
+#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+#~ msgstr "Uporabi trenutno regijo"
+#, fuzzy
+#, fuzzy
+#~ msgstr "ne najdem 3Dview datoteke <%s>"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ri¹em ..."
+#, fuzzy
+#, fuzzy
+#~ msgstr "navedena morata biti 2 sloja"
+#, fuzzy
+#~ msgstr "ne najdem regije <%s>"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Patching vector map <%s@%s>..."
+#, fuzzy
+#~ msgid "vector, metadata"
+#, fuzzy
+#~ msgstr "Najveèja razdalja med toèkami in enotami karte."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ascii rastrski sloj, ki ga nameravate uvoziti"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ime izhodnega vektorskega sloja"
+#, fuzzy
+#~ msgstr "Ne morem izraèunati centroida obmoèja."
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ustvari toèke vzdol¾ vhodnih linij."
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Nièesar nisem na¹el.\n"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Izpi¹e osnovne informacije o doloèenem rastrskem sloju."
+#, fuzzy
+#, fuzzy
+#~ msgstr "Izdelaj z-sloj (nadmorsko vi¹ino)"
+#, fuzzy
+#~ msgstr "Izpi¹i trenutne parametre povezave in konèaj"
+#, fuzzy
+#~ msgstr "Ne najdem vhodnega vektorja <%s>"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ime obstojeèega rastrskega sloja."
+#, fuzzy
+#~ msgid "raster, vector, visualization"
+#, fuzzy
+#~ msgstr "Ime izhodne datoteke, ki bo vsebovala poroèilo"
+#, fuzzy
+#, fuzzy
+#~ msgid "Volume"
+#~ msgstr "OGR gonilnik: kolona '%s', OGR tip %d ni podprt"
+#, fuzzy
+#, fuzzy
+#~ msgstr "ime baze podatkov"
+#, fuzzy
+#, fuzzy
+#~ msgstr "datoteka z SQL stavkom"
+#, fuzzy
+#~ msgstr "Geslo je bilo shranjeno v datoteko"
+#, fuzzy
+#~ msgid "How to split display"
+#, fuzzy
+#~ msgid "Select multiple points"
+#~ msgstr "Tip objektov"
+#, fuzzy
+#~ msgid ""
+#~ "format"
+#, fuzzy
+#~ msgid "Region sensitive output"
+#~ msgstr "Rastrski sloj nadmorskih vi¹in"
+#, fuzzy
+#~ msgstr "Niè je nadmorska vi¹ina"
+#, fuzzy
+#~ msgid "miscellaneous, projection"
+#, fuzzy
+#, fuzzy
+#~ msgid "display, export"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Vhodni sloj"
+#, fuzzy
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Izhodni rastrski sloj"
+#, fuzzy
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#, fuzzy
+#~ msgstr "Ne morem kopirati tabele"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "Izpi¹i podprte formate in konèaj"
+#, fuzzy
+#, fuzzy
+#~ msgid "raster, imagery, mosaicking"
+#, fuzzy
+#~ msgid "raster, statistics, aggregation"
+#, fuzzy
+#~ msgstr "Izpi¹e osnovne statistike za rastrske sloje"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#, fuzzy
+#~ msgid "display, export, GPS"
+#, fuzzy
+#~ msgstr " ©tevilo kolon\n"
+#, fuzzy
+#~ msgid "general, manual, help"
+#, fuzzy
+#~ msgstr "Vhodni rastrski sloj(i)"
+#, fuzzy
+#~ msgid "Overwrite existing MASK"
+#, fuzzy
+#, fuzzy
+#~ msgid "display, slideshow"
+#, fuzzy
+#~ msgid "vector, import, GPS"
+#, fuzzy
+#~ msgid ""
+#~ msgstr ""
+#~ "Izraèuna univariatne statistiène parametre za ne NULL celice rastrskega "
+#~ "sloja."
+#, fuzzy
+#, fuzzy
+#~ msgstr "Ime rastrskega sloja, ki bo vseboval rezultate"
+#, fuzzy
+#~ msgid "Display manager for GRASS"
+#, fuzzy
+#~ msgid "GIS manager for GRASS"
+#, fuzzy
+#~ msgstr ""
+#~ "sloja."
+#, fuzzy
+#~ msgid "Percentile to calculate (requires -e flag)"
+#~ msgstr "\"Mapset\" vhodnega rastrskega sloja"
+#, fuzzy
+#~ msgid "Do not overwrite existing map"
+#, fuzzy
+#~ msgid "Display monitor to start"
+#, fuzzy
+#~ msgid "Import track"
+#, fuzzy
+#~ msgid "Name of PNG file"
+#, fuzzy
+#~ msgid "Configuration editor for r.li.'index'"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "stay with source monitor"
+#, fuzzy
+#~ msgid "Target monitor"
+#, fuzzy
+#~ msgid "Source monitor"
+#, fuzzy
+#~ msgstr "Izraèunavam sence iz DMR..."
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#~ msgstr "Ne morem odpreti datoteke s koordinatami : %s\n"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#, fuzzy
+#~ msgid "No camera reference file selected for group [%s]"
+#, fuzzy
+#~ msgid "No initial camera exposure station for group [%s]"
+#~ msgstr "ne morem prebrati regije <%s> v <%s>"
+#, fuzzy
+#~ msgid "Bad format in initial camera exposure station for group [%s]"
+#, fuzzy
+#~ msgid "No photo points for group [%s]"
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#, fuzzy
+#~ msgid "Computing equations ..."
+#~ msgstr "Kopiranje tabele ni bilo uspe¹no"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "Izpi¹i korelacijsko matriko"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+#~ msgid "Interactively select or modify the target elevation model."
+#~ msgstr "Interaktivno izberi konèni toèki"
+#, fuzzy
+#~ msgid "Target information for group [%s] missing\n"
+#, fuzzy
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
+#, fuzzy
+#~ msgid "Enter a camera reference file to be used with this imagery group"
+#, fuzzy
+#~ msgid "Writing viewable versions of transformed data..."
+#, fuzzy
+#~ msgid "Unable to open file in the 'cell_misc' directory"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgid "Layer to use for thematic display"
+#, fuzzy
+#~ msgid "Mapset(s) to list (default: current mapset search path)"
+#, fuzzy
+#~ msgid "Icon to remove"
+#, fuzzy
+#~ msgid "Name of the output walkers vector points map"
+#, fuzzy
+#~ msgid ""
+#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
+#~ "(ercent_cover)"
+#~ msgstr ""
+#~ "mi(lj), me(trov), k(ilometrov), a(krov), h(ektarov), c(elic), p(rocentov)"
+#, fuzzy
+#, fuzzy
+#~ msgid "Run verbosly"
+#~ msgstr "Po¾eni ukaz z dolgoveznim izpisom"
+#, fuzzy
+#, fuzzy
+#~ msgstr "Vpi¹i ime sloja"
+#, fuzzy
+#~ msgstr "Izpi¹i etikete kategorij"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %d \n"
+#~ "Type: %s \n"
+#~ "Left: %d \n"
+#~ "Right: %d \n"
+#~ msgstr "Linija %d Tip: %s Levo: %d Desno: %d "
+#, fuzzy
+#~ msgid ""
+#~ "Node[%d]: %d \n"
+#~ "Number of lines: %d \n"
+#~ "Coordinates: %.6f, %.6f, %.6f\n"
+#~ msgstr " Vozel[%d]: %d ©tevilo linij: %d\n"
+#, fuzzy
+#~ msgid ""
+#~ "Line: %5d \n"
+#~ "Angle: %.8f\n"
+#~ msgstr "Linija: %5d Kot: %.8f\n"
+#, fuzzy
+#~ msgid ""
+#~ "Area: %d \n"
+#~ "Number of isles: %d\n"
+#~ msgstr "Obmoèje: %d ©tevilo otokov: %d\n"
+#, fuzzy
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the real-image map."
+#, fuzzy
+#~ msgid "%s: %s - Unable to find the imaginary-image."
+#, fuzzy
+#~ msgid "Insufficent memory for allocation of data structure"
+#~ msgstr "lokacija baze podatkov"
+#, fuzzy
+#, fuzzy
+#~ msgid "Hue map name"
+#, fuzzy
+#~ msgid "Red input raster map"
+#, fuzzy
+#, fuzzy
+#~ msgid "** Can't open seed singature file <%s> **"
+#~ msgstr "ne morem odpreti 3Dview datoteke <%s> v <%s>"
+#, fuzzy
+#~ msgid "Error writing result map file!"
+#~ msgstr "Napaka pri branju dbmscap datoteke\n"
+#, fuzzy
+#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+#, fuzzy
+#~ msgid "Error reading '%s' map"
+#, fuzzy
+#~ msgid "Multiplier"
+#~ msgstr "Faktor mno¾enja za ascii podatke"
+#, fuzzy
+#~ msgid "Name of the resultant map"
+#, fuzzy
+#~ msgid "Unable to connect line id %d to line %d"
+#~ msgstr "Ne morem izbrati (select) podatkov iz tabele"
+#, fuzzy
+#, fuzzy
+#~ msgid "Done"
+#~ msgstr "Narejeno\n"
+#, fuzzy
+#, fuzzy
+#~ msgid "Unable to read category file for raster map <%s>"
+#, fuzzy
+#~ msgid "Reading %s ... "
+#~ msgstr "Berem dig datoteko...\n"
+#, fuzzy
+#~ msgstr "%s:linija %d:%s\n"
+#, fuzzy
+#~ msgid "cannot read head of %s"
+#~ msgstr "Ne morem prebrati informacije polja"
+#, fuzzy
+#~ msgid "Cannot allocate buffer for reading null values."
+#, fuzzy
+#, fuzzy
+#~ msgid "No record for cat = %d"
+#~ msgstr "Za vrstico (cat = %d) ni zapisa (record)<"
+#, fuzzy
+#, fuzzy
+#~ msgid "Database connection not defined for layer <%d>"
+#~ msgstr "Povezava z bazo podatkov ni definirana\n"
+#, fuzzy
+#~ msgid "Editing tool"
+#, fuzzy
+#~ msgid "Input map containing lines"
+#, fuzzy
+#~ msgid "Name of the random surface to be produced"
+#~ msgstr "Ime rastrskega sloja nakljuène povr¹ine, ki bo ustvarjen"
+#, fuzzy
+#~ msgid "Cannot open file [%s]"
+#, fuzzy
+#~ msgstr "EASTING in NORTHING koordinate zaèetne toèke"
+#, fuzzy
+#~ msgid "Closing raster map"
+#~ msgstr "Pokrovni rastrski sloj"
+#~ msgid "Name of the new raster map"
+#, fuzzy
+#~ msgid "Could not close the 3d raster map"
+#, fuzzy
+#, fuzzy
+#~ msgid "Can't create output map"
+#, fuzzy
+#~ msgstr "Ime novega rastrskega sloja."
+#, fuzzy
+#~ msgid "Cover raster map"
+#~ msgstr "pokrovni rastrski sloj"
+#~ msgid "Topographic index ln(a/tanB) map"
+#~ msgstr "Rastrski sloj s topografskim indeksom"
+#, fuzzy
+#~ msgid "No input coordinates provided"
+#~ msgstr "Y koordinata oziroma geografska ¹irina"
+#, fuzzy
+#~ msgid "Name of the output walkers site file"
+#, fuzzy
+#~ msgid "Path to the input file"
+#~ msgid "Database name:"
+#, fuzzy
+#~ msgid "column type not supported"
+#, fuzzy
+#~ msgid "Unable to find base map <%s>"
+#, fuzzy
+#~ msgid "category [%d]"
+#~ msgstr ""
+#~ "polje: %d\n"
+#~ "kategorija: %d\n"
+#, fuzzy
+#~ msgid "Interpolation()"
+#~ msgstr "Interpolacijska metoda, ki jo ¾elite uporabiti"
+#, fuzzy
+#~ msgid "Calculation time"
+#, fuzzy
+#~ msgid "Name of output 3d raster map"
+#, fuzzy
+#~ msgid "output layer name"
+#, fuzzy
+#~ msgid "Name of the column with tree species"
+#~ msgstr "Ime rastrskega sloja s podatki o glajenju"
+#, fuzzy
+#~ msgid "Name of input map"
+#~ msgid "Name of the resulting map"
+#~ msgstr "Ime novega sloja"
+#, fuzzy
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2010-08-29 10:52:30 UTC (rev 43336)
+++ grass/trunk/locale/po/grassmods_th.po 2010-08-29 10:56:46 UTC (rev 43337)
@@ -3011,8 +3011,9 @@
msgstr "à¸à¸²à¸£à¸ªà¸£à¹à¸²à¸ Algorithm"
#: ../raster/r.resamp.bspline/main.c:116 ../vector/v.surf.bspline/main.c:148
+#, fuzzy
msgid "Tykhonov regularization parameter (affects smoothing)"
-msgstr ""
+msgstr "Tychonov regularization weight"
#: ../raster/r.resamp.bspline/main.c:122
#, fuzzy
@@ -4618,7 +4619,7 @@
#: ../raster/r.cost/main.c:183
#, fuzzy
msgid "Name of starting raster points map"
-msgstr "à¸à¸·à¹à¸à¸à¸à¸à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¸ าà¸"
+msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸µà¹à¸¡à¸µà¸à¸¢à¸¹à¹"
#: ../raster/r.cost/main.c:192
#, fuzzy
@@ -9211,7 +9212,7 @@
#: ../raster/r.out.gdal/main.c:510 ../raster/r.out.gdal/main.c:514
#, fuzzy
msgid "Raster export aborted."
-msgstr "à¹à¸à¸¥à¹à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸²"
+msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, สà¹à¸à¸à¸à¸"
#: ../raster/r.out.gdal/main.c:491
msgid "Checking GDAL data type and nodata value"
@@ -13001,7 +13002,7 @@
#, fuzzy
-msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¹à¸à¸¥à¹ à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² <%s>"
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¸à¸µà¹à¸à¸³à¹à¸à¹à¸²"
@@ -18167,7 +18168,7 @@
#: ../vector/v.in.db/main.c:176
#, fuzzy
msgid "Writing features..."
-msgstr "à¸à¸³à¸¥à¸±à¸à¹à¸à¸µà¸¢à¸à¹à¸à¸¥à¹ signature [%s] ..."
+msgstr "à¸à¸·à¹à¸à¸à¸µà¹ Extracting ..."
#: ../vector/v.in.db/main.c:183
msgid "Key column must be integer"
@@ -18726,7 +18727,7 @@
#, fuzzy
msgid "3D output"
-msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹:"
+msgstr "สรà¹à¸²à¸à¸à¸¥à¸¥à¸±à¸à¸à¹ 3มิà¸à¸´"
#, fuzzy
@@ -18989,8 +18990,9 @@
msgstr "à¸à¹à¸²à¸à¸±à¹à¸ à¸à¸à¸ Interpolation spline à¹à¸ north direction"
#: ../vector/v.outlier/main.c:119
+#, fuzzy
msgid "Tykhonov regularization weight"
-msgstr ""
#: ../vector/v.outlier/main.c:126
msgid "Threshold for the outliers"
@@ -20723,9 +20725,8 @@
msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¹à¸ pj_do_transform"
-#, fuzzy
-msgstr "สรà¹à¸²à¸ topology สำหรัภà¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ GRASS."
+msgstr ""
msgid "Use all vector points (do not limit to current region)"
@@ -23733,7 +23734,7 @@
#: ../vector/v.buffer/main.c:200 ../vector/v.buffer/main.c:209
#, fuzzy
msgid "Distance"
-msgstr " zone ระยะà¸à¸²à¸"
+msgstr "à¸à¸²à¸£à¸²à¸à¸«à¸²à¸¢à¹à¸"
#: ../vector/v.buffer/main.c:177
#, fuzzy
@@ -24882,9 +24883,8 @@
#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.centrality/main.c:148
-#, fuzzy
msgid "Columns"
-msgstr "Column(s)"
+msgstr "Columns"
#: ../vector/v.net.centrality/main.c:135
#, fuzzy
@@ -24945,7 +24945,7 @@
#, fuzzy
-msgstr "à¸à¸±à¸§à¸à¸±à¹à¸ Field (à¹à¸«à¸¡à¸ à¸à¸¸à¸)"
+msgstr "à¹à¸ªà¸à¸ stats à¹à¸à¸£à¸¹à¸à¹à¸à¸ shell script"
msgid "Print all map connection parameters and exit"
@@ -27897,7 +27897,6 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
-#, fuzzy
msgid "Files"
msgstr "à¹à¸à¸¥à¹"
@@ -28008,7 +28007,6 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
-#, fuzzy
msgid "Misc"
msgstr "à¸à¸·à¹à¸à¹"
@@ -28028,8 +28026,11 @@
"à¸à¸°à¹à¸¡à¹à¸¡à¸µà¸à¸²à¸£à¸ªà¸£à¹à¸²à¸à¹à¸à¸¥à¹ psmap instruction)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
+#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
msgstr ""
+"Root สำหรัà¸à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸¥à¹ psmap instruction à¸à¸°à¸à¹à¸à¸à¸à¸¢à¸¹à¹à¹à¸ directory (à¸à¹à¸²à¹à¸¡à¹à¹à¸à¹à¸à¸³à¸«à¸à¸, "
+"à¸à¸°à¹à¸¡à¹à¸¡à¸µà¸à¸²à¸£à¸ªà¸£à¹à¸²à¸à¹à¸à¸¥à¹ psmap instruction)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Name of group file where thematic map commands will be saved"
@@ -28689,8 +28690,9 @@
msgstr "à¸à¸·à¹à¸à¸à¸²à¸£à¸²à¸à¸à¸à¸ SQL DB"
+#, fuzzy
-msgstr ""
+msgstr "à¸à¸·à¹à¸à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¸ าà¸à¸à¸µà¹à¸à¸°à¹à¸à¹ <%s>"
msgid "Interactively edit cell values in a raster map."
@@ -31149,6 +31151,328 @@
msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ mark à¸à¸¸à¸à¸à¸·à¹à¸ ยà¸à¸¡à¸£à¸±à¸à¹à¸à¸µà¸¢à¸ %d à¸à¸¸à¸ à¹à¸ªà¸µà¸¢à¹à¸"
+#, fuzzy
+msgstr "à¹à¸ªà¸à¸à¹à¸¥à¸°à¸à¹à¸à¸à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¸ าà¸à¹à¸à¸à¸£à¸à¸à¸à¸µà¹à¸à¸³à¸¥à¸±à¸à¸à¸³à¸à¸²à¸à¸à¸à¸à¸à¸à¸ าà¸à¹à¸ªà¸à¸à¸à¸¥"
+#, fuzzy
+msgid ""
+"Name and type of the new column(s) ('name type [,name type, ...]' - types "
+"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
+"and DATE)"
+msgstr ""
+"à¸à¸·à¹à¸à¹à¸¥à¸°à¸à¸à¸´à¸à¸à¸à¸ column à¹à¸«à¸¡à¹ (à¸à¸à¸´à¸à¸à¸¶à¹à¸à¸à¸¢à¸¹à¹à¸à¸±à¸ à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥, à¹à¸à¹à¸à¹à¸à¸à¸£à¸à¸à¸£à¸±à¸ VARCHAR(), INT, DOUBLE "
+"à¹à¸¥à¸° DATE)"
+#, fuzzy
+msgstr "à¹à¸à¸¥à¹à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸²"
+#, fuzzy
+msgstr "à¹à¸à¸¥à¹à¸¡à¸µà¸à¸à¸à¸à¸à¹à¸à¸à¸à¹à¸à¸à¸§à¸²à¸¡à¸«à¸¡à¸§à¸à¸«à¸¡à¸¹à¹ (หรืภ\"-\" à¸à¹à¸²à¸à¸à¸²à¸ stdin)"
+#, fuzzy
+msgstr "à¸à¸²à¸£à¸§à¸´à¹à¸à¸£à¸²à¸° à¹à¸à¸£à¸à¸ªà¸£à¹à¸²à¸ ภาà¸, landscape"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¸à¸µà¹ topology ระà¸à¸±à¸ %d"
+#, fuzzy
+#, fuzzy
+msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
+#, fuzzy
+msgstr "à¸à¸¸à¸à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¹à¸à¸ shell script"
+#, fuzzy
+msgstr "สà¸à¸´à¸à¸´ à¸à¸µà¹à¸à¸°à¹à¸à¹à¸à¸±à¸à¸à¹à¸² à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+msgstr "<%s> สรà¹à¸²à¸à¹à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥."
+#, fuzzy
+msgid ""
+"Calculate the groundwater distance velocity vector field \n"
+"and write the x, y, and z components to maps named name_[xyz].\n"
+"Name is basename for the new raster3d maps"
+msgstr ""
+"à¸à¸³à¸à¸§à¸ groundwater distance velocity vector field à¹à¸¥à¸°à¹à¸à¸µà¸¢à¸ x, y, à¹à¸¥à¸° z "
+"à¹à¸à¸à¸µà¹à¹à¸à¸à¸à¸µà¹ à¸à¸·à¹à¸ name_[xyz]. à¸à¸·à¹à¸à¸à¸¶à¹à¸à¸à¸¢à¸¹à¹à¸à¸±à¸ à¸à¸·à¹à¸à¸à¸²à¸ สำหรัภà¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´"
+#, fuzzy
+msgid "report"
+msgstr "รายà¸à¸²à¸ à¹à¸à¸ à¸à¸§à¹à¸²à¸"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ สà¹à¸§à¸à¸«à¸±à¸§ สำหรัภ%s"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ <%s> à¹à¸à¹"
+#, fuzzy
+msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¸à¹à¸²à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ[%s]."
+#, fuzzy
+#, fuzzy
+msgid "r.li.worker (pid %i) exited with abnormal status: %i"
+msgstr "r.li.worker (pid %i) à¸à¸à¸ à¸à¹à¸§à¸¢ สà¸à¸²à¸à¸°à¸à¸µà¹à¹à¸¡à¹à¸à¸à¸à¸´ %i"
+#, fuzzy
+msgid "r.li.worker (pid %i) terminated successfully"
+msgstr "r.li.worker (pid %i) à¸à¸¹à¸à¸¢à¸à¹à¸¥à¸´à¸"
+#, fuzzy
+msgstr " à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> à¹à¸ <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¸à¸à¸à¹à¸à¸ <%s> à¹à¸ <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ à¸à¸¥à¸¥à¸±à¸à¸à¹ <%s>"
+#, fuzzy
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ row %d (à¸à¸´à¸à¸à¸¥à¸²à¸ = %d)"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¸³à¸«à¸à¸à¸à¸à¸à¹à¸à¸ à¸à¸¥à¸±à¸à¹à¸à¹à¸à¹à¸ à¸à¸²à¸¡à¹à¸à¸´à¸¡!!!"
+#, fuzzy
+msgid "Cannot set region to back to the initial region"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ row %i\n"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸³à¸«à¸à¸ à¸à¸à¸à¹à¸à¸ <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¸à¸§à¸²à¸¡à¸ªà¸¹à¸"
+#, fuzzy
+#, fuzzy
+msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¹à¸à¸µà¸¢à¸ Null row [%d]."
+#, fuzzy
+msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² à¹à¸¥à¸°à¸¡à¸µ friction costs"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¹à¸à¸¥à¹ à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² <%s>"
+#, fuzzy
+#, fuzzy
+msgid "Pass %d:"
+msgstr "à¸à¹à¸²à¸: %d\n"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภrow %d"
+#, fuzzy
+msgstr "à¸à¸²à¸£à¹à¸à¸µà¸¢à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภrow ลà¹à¸¡à¹à¸«à¸¥à¸§"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> à¹à¸à¸§ %d"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸²à¸à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¹à¸ <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸¥à¹ rule <%s>"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ สà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹ <%s>"
+#, fuzzy
+msgid "Could not open <%s>"
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸à¸à¸µà¹ %s"
+#, fuzzy
+msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸¥à¸¥à¸±à¸à¸à¹"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+msgid "qcname"
+msgstr "à¸à¸·à¹à¸"
+#, fuzzy
+msgid "Name of QC"
+msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸¥à¹ PNG"
+#, fuzzy
+msgstr "à¸à¸³à¸à¸§à¸ edge à¹à¸¡à¹à¸à¸¢à¸¹à¹à¹à¸à¸à¹à¸§à¸"
+#, fuzzy
+#, fuzzy
+msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, à¸à¸£à¸´à¸¡à¸²à¸à¸£, à¸à¸²à¸£à¹à¸à¸¥à¸"
+msgid "Bad Start Cell"
+msgstr "Cell à¹à¸£à¸´à¹à¸¡à¸à¹à¸ à¹à¸¡à¹à¸à¸µ"
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD"
+msgstr "SECTION 3: Accumulating Surface Flow."
+#, fuzzy
+#, fuzzy
+msgstr "%s: %s - à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸² à¹à¸à¸à¸à¸µà¹ real-image"
+#, fuzzy
+msgid ""
+msgstr ""
+"à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ real-image à¹à¸ cell_misc directory.\n"
+"à¹à¸à¸à¸à¸µà¹à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² à¸à¸²à¸à¸à¸µà¸à¸²à¸à¸à¸°à¹à¸¡à¹à¹à¸à¹à¸ªà¸£à¹à¸²à¸à¸à¹à¸§à¸¢ i.fft"
+#, fuzzy
+msgstr "%s: %s - à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸² à¹à¸à¸à¸à¸µà¹ imaginary-image"
+#, fuzzy
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ imaginary-image à¹à¸ cell_misc directory.\n"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸à¸ à¸à¸¥à¸¸à¹à¸¡ [%s]"
+#, fuzzy
+msgid "Range less than or equal to zero not allowed."
+msgstr "à¸à¹à¸§à¸ à¸à¹à¸à¸¢à¸à¸§à¹à¸²à¸«à¸£à¸·à¸à¹à¸à¹à¸²à¸à¸±à¸ 0 à¹à¸¡à¹à¸¢à¸à¸¡à¸£à¸±à¸"
+#, fuzzy
+msgstr "à¸à¸³à¸¥à¸±à¸à¹à¸à¸µà¸¢à¸ viewable versions à¸à¸à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸µà¹à¹à¸à¸¥à¸à¹à¸à¸à¸µà¹à¹à¸à¸¥à¹..."
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹à¹à¸ cell_misc directory"
+#, fuzzy
+msgstr "** à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸¥à¹ seed singature <%s> **"
+#, fuzzy
+msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¹à¸à¸¥à¹ signature [%s]"
+#, fuzzy
+msgid "Name of image to be rectified which will be initially drawn on screen."
+msgstr "à¸à¸·à¹à¸à¸à¸à¸à¸ าà¸à¸à¸µà¹à¸à¸° rectified à¹à¸¥à¸°à¹à¸ªà¸à¸à¸à¸à¸«à¸à¹à¸²à¸à¸"
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen."
+msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¸à¸²à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¹à¸²à¸«à¸¡à¸²à¸¢ à¸à¸µà¹à¸à¸°à¹à¸ªà¸à¸à¸à¸à¸«à¸à¹à¸²à¸à¸"
+#, fuzzy
+msgid ""
+"Name of old database. The database must be in form printed by v.db.connect -"
+"g, i.e. with substituted variables"
+msgstr ""
+"à¸à¸·à¹à¸à¸à¸à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸¡ à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸°à¸à¹à¸à¸à¸à¸¢à¸¹à¹à¹à¸à¹à¸à¸ printed à¹à¸à¸¢ v.db.connect -g, à¸à¹à¸§à¸¢ "
+"substituted variables"
+#, fuzzy
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "à¸à¸·à¹à¸à¸à¸à¸à¸ าà¸à¹à¸à¸à¸à¸µà¹à¹à¸«à¸¡à¹(à¸à¸¢à¸¹à¹à¹à¸ ~/.gpsdrive)"
+#, fuzzy
+msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภTerrain (DEM)"
+#, fuzzy
+msgid "Use output= option to change vector map name"
+msgstr "à¹à¸à¹à¹à¸à¸·à¹à¸à¸à¹à¸ output= à¹à¸à¸·à¹à¸à¹à¸à¸¥à¸µà¹à¸¢à¸à¸à¸·à¹à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸"
+#, fuzzy
+msgstr "à¸à¸³à¸¥à¸±à¸à¸¥à¸à¸«à¸à¹à¸²à¸à¸ ..."
#~ msgstr "à¸à¸µà¹à¹à¸¡à¹à¸à¸ สำหรัà¸à¹à¸à¸¥à¹à¸à¸£à¸°à¸§à¸±à¸à¸´"
@@ -31167,10 +31491,6 @@
#~ msgid "Name of workspace file"
#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸¥à¹à¸ªà¸µ"
-#, fuzzy
-#~ msgstr "à¹à¸ªà¸à¸à¹à¸¥à¸°à¸à¹à¸à¸à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¸ าà¸à¹à¸à¸à¸£à¸à¸à¸à¸µà¹à¸à¸³à¸¥à¸±à¸à¸à¸³à¸à¸²à¸à¸à¸à¸à¸à¸à¸ าà¸à¹à¸ªà¸à¸à¸à¸¥"
#~ msgid "List of values to be displayed (FP maps)"
#~ msgstr "à¹à¸ªà¸à¸à¸£à¸²à¸¢à¸à¸²à¸£à¸à¹à¸² (FP maps)"
@@ -31276,15 +31596,6 @@
#~ msgid "DXY [%s] COMPLETE"
#~ msgstr "DXY [%s] à¹à¸ªà¸£à¹à¸"
-#, fuzzy
-#~ msgid ""
-#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
-#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-#~ "PRECISION and DATE)"
-#~ msgstr ""
-#~ "à¸à¸·à¹à¸à¹à¸¥à¸°à¸à¸à¸´à¸à¸à¸à¸ column à¹à¸«à¸¡à¹ (à¸à¸à¸´à¸à¸à¸¶à¹à¸à¸à¸¢à¸¹à¹à¸à¸±à¸ à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥, à¹à¸à¹à¸à¹à¸à¸à¸£à¸à¸à¸£à¸±à¸ VARCHAR(), INT, "
-#~ "DOUBLE à¹à¸¥à¸° DATE)"
#~ msgid "Sources and sinks in [m^3/s]"
#~ msgstr "Sources à¹à¸¥à¸° sinks à¹à¸ [à¹à¸¡à¸à¸£^3/วิà¸à¸²à¸à¸µ]"
@@ -31301,14 +31612,6 @@
#~ msgid "Layer number of data column"
#~ msgstr "à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸µà¹à¸à¸°à¹à¸à¸´à¹à¸¡ column"
-#, fuzzy
-#~ msgstr "à¹à¸à¸¥à¹à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸²"
-#, fuzzy
-#~ msgstr "à¹à¸à¸¥à¹à¸¡à¸µà¸à¸à¸à¸à¸à¹à¸à¸à¸à¹à¸à¸à¸§à¸²à¸¡à¸«à¸¡à¸§à¸à¸«à¸¡à¸¹à¹ (หรืภ\"-\" à¸à¹à¸²à¸à¸à¸²à¸ stdin)"
#~ msgstr "สรà¹à¸²à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¹à¸ªà¸à¸ watershed subbasins."
@@ -31404,10 +31707,6 @@
#~ msgstr "(i) OPTIONAL Output สำหรัà¸à¹à¸«à¹ topographic index class"
-#, fuzzy
-#~ msgstr "à¸à¸²à¸£à¸§à¸´à¹à¸à¸£à¸²à¸° à¹à¸à¸£à¸à¸ªà¸£à¹à¸²à¸ ภาà¸, landscape"
#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸µà¹à¸¡à¸µ elevation surface"
@@ -31470,18 +31769,6 @@
#~ msgid "Unable to access table <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¸à¸²à¸£à¸²à¸ <%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¸à¸µà¹ topology ระà¸à¸±à¸ %d"
-#, fuzzy
-#, fuzzy
-#~ msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr "à¹à¸à¸¥à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´ (G3D) à¹à¸à¹à¸à¹à¸ à¹à¸à¸ VTK-Ascii"
@@ -31495,10 +31782,6 @@
#~ "à¹à¸à¸¥à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภGRASS à¹à¸à¹à¸à¹à¸ à¹à¸à¸¥à¹à¸ าภPPM à¸à¸µà¹à¸à¸§à¸²à¸¡à¸¥à¸°à¹à¸à¸µà¸¢à¸à¹à¸à¹à¸ pixel à¸à¸à¸ "
#~ "à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¸à¸³à¸«à¸à¸"
-#, fuzzy
-#~ msgstr "à¸à¸¸à¸à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¹à¸à¸ shell script"
#~ msgid ""
@@ -31510,10 +31793,6 @@
#~ msgid "Band to select"
#~ msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸à¸à¸¹à¸à¹à¸¥à¸·à¸à¸"
-#, fuzzy
-#~ msgstr "สà¸à¸´à¸à¸´ à¸à¸µà¹à¸à¸°à¹à¸à¹à¸à¸±à¸à¸à¹à¸² à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "มัà¸à¹à¸à¹à¸à¹à¸à¹à¸¡à¹à¹à¸à¹à¸à¸µà¹à¸à¸°à¸ªà¸£à¹à¸²à¸ <Auxiliar_outlier_table>."
@@ -31523,10 +31802,6 @@
#~ msgid "Attribute table column with values to interpolate (if layer>0)"
#~ msgstr "Column à¸à¸à¸à¸à¸²à¸£à¸²à¸à¸£à¸²à¸¢à¸¥à¸°à¹à¸à¸µà¸¢à¸ à¸à¸µà¹à¸¡à¸µà¸à¹à¸² à¹à¸à¹à¸à¸±à¸ interpolate (à¸à¹à¸²à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥ >0)"
-#, fuzzy
-#~ msgstr "<%s> สรà¹à¸²à¸à¹à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥."
#~ msgid "M.Q. solution"
#~ msgstr "M.Q. solution"
@@ -31572,16 +31847,7 @@
#~ msgid "Unable to close elevation map"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¸à¸§à¸²à¸¡à¸ªà¸¹à¸"
-#, fuzzy
#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field \n"
-#~ "and write the x, y, and z components to maps named name_[xyz].\n"
-#~ "Name is basename for the new raster3d maps"
-#~ msgstr ""
-#~ "à¸à¸³à¸à¸§à¸ groundwater distance velocity vector field à¹à¸¥à¸°à¹à¸à¸µà¸¢à¸ x, y, à¹à¸¥à¸° z "
-#~ "à¹à¸à¸à¸µà¹à¹à¸à¸à¸à¸µà¹ à¸à¸·à¹à¸ name_[xyz]. à¸à¸·à¹à¸à¸à¸¶à¹à¸à¸à¸¢à¸¹à¹à¸à¸±à¸ à¸à¸·à¹à¸à¸à¸²à¸ สำหรัภà¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´"
-#~ msgid ""
#~ "Use a sparse linear equation system, only available with iterative solvers"
#~ msgstr "à¹à¸à¹à¸£à¸°à¸à¸ sparse linear equation , à¹à¸à¸à¸²à¸°à¸à¸±à¸ iterative solvers"
@@ -31606,18 +31872,10 @@
#~ msgid "Unable to write raster row"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸ row à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
-#, fuzzy
-#~ msgid "report"
-#~ msgstr "รายà¸à¸²à¸ à¹à¸à¸ à¸à¸§à¹à¸²à¸"
#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ สà¹à¸§à¸à¸«à¸±à¸§ สำหรัภ%s"
-#, fuzzy
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸à¹à¸à¸à¸µà¹à¹à¸à¸¥à¹"
@@ -31634,10 +31892,6 @@
#~ msgid "Cannot open raster map <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ <%s> à¹à¸à¹"
#~ msgid "Cannot create category file of <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ สรà¹à¸²à¸à¹à¸à¸¥à¹ หมวà¸à¸«à¸¡à¸¹à¹ à¸à¸à¸ <%s>"
@@ -31659,10 +31913,6 @@
#~ msgid "Unable to read header of raster map <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
-#, fuzzy
-#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¸à¹à¸²à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ[%s]."
#~ msgstr "à¸à¸³à¸¥à¸±à¸à¸à¹à¸²à¸ row %d"
@@ -31773,24 +32023,12 @@
#~ msgid "Cannot read row"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ row"
-#, fuzzy
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸ à¹à¸à¸à¸²à¸£à¸ªà¸£à¹à¸²à¸ pipe"
#~ msgid "Error opening channel %i"
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¹à¸à¸´à¸ channel %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) exited with abnormal status: %i"
-#~ msgstr "r.li.worker (pid %i) à¸à¸à¸ à¸à¹à¸§à¸¢ สà¸à¸²à¸à¸°à¸à¸µà¹à¹à¸¡à¹à¸à¸à¸à¸´ %i"
-#, fuzzy
-#~ msgid "r.li.worker (pid %i) terminated successfully"
-#~ msgstr "r.li.worker (pid %i) à¸à¸¹à¸à¸¢à¸à¹à¸¥à¸´à¸"
#~ msgid "Cannot close %s file (PIPE)"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¸´à¸ %s à¹à¸à¸¥à¹ (PIPE)"
@@ -31887,32 +32125,12 @@
#~ " \t\t\t\tpid = %i \n"
-#, fuzzy
-#~ msgstr " à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> à¹à¸ <%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¸à¸à¸à¹à¸à¸ <%s> à¹à¸ <%s>"
#~ msgid "Cannot reset current region"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¸³à¸«à¸à¸ à¸à¸à¸à¹à¸à¸"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ à¸à¸¥à¸¥à¸±à¸à¸à¹ <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸à¹à¸à¸¥à¹ หมวà¸à¸«à¸¡à¸¹à¹ สำหรัภ<%s>"
@@ -31947,22 +32165,6 @@
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¸à¸à¸°à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹ 'saturation'"
#, fuzzy
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ row %d (à¸à¸´à¸à¸à¸¥à¸²à¸ = %d)"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¸³à¸«à¸à¸à¸à¸à¸à¹à¸à¸ à¸à¸¥à¸±à¸à¹à¸à¹à¸à¹à¸ à¸à¸²à¸¡à¹à¸à¸´à¸¡!!!"
-#, fuzzy
-#~ msgid "Cannot set region to back to the initial region"
-#, fuzzy
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> à¹à¸à¸§ %d"
@@ -31991,10 +32193,6 @@
#~ msgid "Error writing null row [%d]."
#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¹à¸à¸µà¸¢à¸ Null row [%d]."
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ row %i\n"
#~ msgid "Swapping header data"
#~ msgstr "à¸à¸²à¸£à¹à¸¥à¸à¹à¸à¸¥à¸µà¹à¸¢à¸ à¸à¹à¸à¸¡à¸¹à¸¥ header"
@@ -32012,10 +32210,6 @@
#~ msgid "Failed writing raster map row %d"
#~ msgstr "à¸à¸²à¸£à¹à¸à¸µà¸¢à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภrow ลà¹à¸¡à¹à¸«à¸¥à¸§"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸³à¸«à¸à¸ à¸à¸à¸à¹à¸à¸ <%s>"
#~ msgstr "à¸à¸à¸à¹à¸à¸à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸: %s"
@@ -32067,14 +32261,6 @@
#~ msgid "unable to open accum file in valid_basins()"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¹à¸à¸¥à¹ accum à¹à¸ valid_basins()"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¸à¸§à¸²à¸¡à¸ªà¸¹à¸"
-#, fuzzy
-#~ msgstr "à¸à¸·à¹à¸à¸à¸µà¹ Extracting ..."
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
@@ -32090,14 +32276,6 @@
#~ msgid "Unable to close new basin map layer"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸´à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹ basin à¹à¸«à¸¡à¹"
-#, fuzzy
-#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¹à¸à¸µà¸¢à¸ Null row [%d]."
-#, fuzzy
-#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² à¹à¸¥à¸°à¸¡à¸µ friction costs"
#~ msgstr "à¸à¸³à¸à¸§à¸à¸à¸à¸à¸à¸´à¹à¸à¸ªà¹à¸§à¸à¸à¸µà¹à¸à¸°à¸ªà¸£à¹à¸²à¸ (segment library)"
@@ -32210,14 +32388,6 @@
#~ msgid "Use a sparse matrix, only available with iterative solvers"
#~ msgstr "à¹à¸à¹ sparse matrix, à¸à¸µà¹à¹à¸à¹à¹à¸à¹à¸à¸±à¸ iterative solvers"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ à¹à¸à¸¥à¹ à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² <%s>"
-#, fuzzy
#~ msgstr "à¸à¸´à¸à¸à¸¥à¸²à¸ à¸à¸à¸°à¸à¹à¸²à¸à¹à¸à¸·à¹à¸à¸à¸³à¹à¸à¹à¸²"
@@ -32237,10 +32407,6 @@
#~ msgstr "<Auxiliar_edge_table> สรà¹à¸²à¸ à¹à¸ à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥"
#, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "à¸à¹à¸²à¸: %d\n"
-#, fuzzy
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "à¸à¸³à¸¥à¸±à¸à¸ªà¸£à¹à¸²à¸ à¸à¸²à¸£à¸²à¸ auxiliar สำหรัภarchiving overlaping zones"
@@ -32430,21 +32596,9 @@
#~ msgid "Current region cannot be set."
#~ msgstr "à¸à¸à¸à¹à¸à¸à¸à¸±à¸à¸à¸¸à¸à¸±à¸ à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸³à¸«à¸à¸à¹à¸à¹"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภrow %d"
-#, fuzzy
-#~ msgstr "à¸à¸²à¸£à¹à¸à¸µà¸¢à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภrow ลà¹à¸¡à¹à¸«à¸¥à¸§"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ ระà¸à¸¸ row buffer à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸²"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s> à¹à¸à¸§ %d"
#~ msgid "Unable to open the cell map MASK."
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ cell map MASK"
@@ -32463,14 +32617,6 @@
#~ msgid "Unable to open band files."
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ band à¹à¸à¹"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¸ªà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¸à¸à¸°à¸à¹à¸²à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸..."
@@ -32480,41 +32626,9 @@
#~ msgid "Error writing cell map during transform."
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¸à¸à¸° à¹à¸à¸µà¸¢à¸ cell map ระหวà¹à¸²à¸à¸à¸²à¸£à¹à¸à¸¥à¸"
-#, fuzzy
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸²à¸à¹à¸à¸´à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¹à¸ <%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸¥à¹ rule <%s>"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¸à¹à¸²à¸ สà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸à¹à¸à¸¥à¹ <%s>"
-#, fuzzy
-#~ msgid "Could not open <%s>"
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸à¸à¸µà¹ %s"
#~ msgid "Could not read from <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ à¸à¸²à¸ <%s>"
-#, fuzzy
-#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸¥à¸¥à¸±à¸à¸à¹"
-#, fuzzy
-#, fuzzy
#~ msgstr "à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸à¸à¸à¸°à¸à¹à¸²à¸à¹à¸à¸§à¸à¹à¸à¸¡à¸¹à¸¥"
@@ -32746,22 +32860,6 @@
#~ msgstr "ภาà¸"
#, fuzzy
-#~ msgid "qcname"
-#~ msgstr "à¸à¸·à¹à¸"
-#, fuzzy
-#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸¥à¹ PNG"
-#, fuzzy
-#~ msgstr "à¸à¸³à¸à¸§à¸ edge à¹à¸¡à¹à¸à¸¢à¸¹à¹à¹à¸à¸à¹à¸§à¸"
-#, fuzzy
-#, fuzzy
#~ msgstr "à¸à¸²à¸£à¸à¸³à¹à¸à¸ à¸à¸¸à¸"
@@ -33136,10 +33234,6 @@
#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, สà¹à¸à¸à¸à¸, VRML"
#, fuzzy
-#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, à¸à¸£à¸´à¸¡à¸²à¸à¸£, à¸à¸²à¸£à¹à¸à¸¥à¸"
-#, fuzzy
#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, geomorphology"
@@ -33180,9 +33274,6 @@
#~ msgid "Nothing to show"
#~ msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸°à¹à¸£ à¹à¸ªà¸à¸"
-#~ msgid "Bad Start Cell"
-#~ msgstr "Cell à¹à¸£à¸´à¹à¸¡à¸à¹à¸ à¹à¸¡à¹à¸à¸µ"
#~ msgid "%s %f-%f lower cost higher or equal"
#~ msgstr "%s %f-%f à¸à¹à¸²à¸à¹à¸³à¸à¸§à¹à¸² มีà¸à¹à¸² สูà¸à¹à¸à¸´à¸à¹à¸ หรืภà¹à¸à¹à¸²à¸à¸±à¸"
@@ -33221,10 +33312,6 @@
#~ msgid "Unable to open MASK"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ MASK"
-#, fuzzy
-#~ msgid "SECTION 3: Accumulating Surface Flow with MFD"
-#~ msgstr "SECTION 3: Accumulating Surface Flow."
#~ msgid "unable to open MASK"
@@ -33232,10 +33319,6 @@
#~ msgstr "à¹à¸à¸à¸à¸µà¸à¸¥à¸¥à¸±à¸à¸à¹: มีà¸à¸£à¸°à¹à¸¢à¸à¸à¹à¸¡à¸²à¸à¸ªà¸³à¸«à¸£à¸±à¸ visual display à¸à¸à¸à¸à¸¥à¸¥à¸±à¸à¸à¹"
#, fuzzy
-#, fuzzy
#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸ªà¸³à¸«à¸£à¸±à¸ Surface"
@@ -33384,30 +33467,6 @@
#~ msgid "Output inverse raster map after IFFT"
#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ สà¹à¸§à¸à¸à¸¥à¸±à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภหลัà¸à¸à¸²à¸ IFFT"
-#, fuzzy
-#~ msgstr "%s: %s - à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸² à¹à¸à¸à¸à¸µà¹ real-image"
-#, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ real-image à¹à¸ cell_misc directory.\n"
-#~ "à¹à¸à¸à¸à¸µà¹à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² à¸à¸²à¸à¸à¸µà¸à¸²à¸à¸à¸°à¹à¸¡à¹à¹à¸à¹à¸ªà¸£à¹à¸²à¸à¸à¹à¸§à¸¢ i.fft"
-#, fuzzy
-#~ msgstr "%s: %s - à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸² à¹à¸à¸à¸à¸µà¹ imaginary-image"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open imaginary-image in the cell_misc directory.\n"
-#~ msgstr ""
-#~ "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ imaginary-image à¹à¸ cell_misc directory.\n"
#~ msgstr "à¸à¹à¸²à¸à¸³à¸¥à¸±à¸ 2 : [%d] rows [%d] columns"
@@ -33505,10 +33564,6 @@
#~ msgid "Run quietly"
#~ msgstr "à¸à¸³à¸à¸²à¸à¹à¸à¸à¹à¸à¸µà¸¢à¸"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸à¸ à¸à¸¥à¸¸à¹à¸¡ [%s]"
#~ msgstr "à¹à¸¡à¹à¸à¸ à¸à¸¥à¸¸à¹à¸¡à¸¢à¹à¸à¸¢ [%s]"
@@ -33556,10 +33611,6 @@
#~ msgid "Range of values in output display files"
#~ msgstr "à¸à¹à¸§à¸à¸à¸à¸à¸à¹à¸² à¸à¸¥à¸¥à¸±à¸à¸à¹à¹à¸à¸¥à¹à¹à¸ªà¸à¸à¸à¸¥"
-#, fuzzy
-#~ msgid "Range less than or equal to zero not allowed."
-#~ msgstr "à¸à¹à¸§à¸ à¸à¹à¸à¸¢à¸à¸§à¹à¸²à¸«à¸£à¸·à¸à¹à¸à¹à¸²à¸à¸±à¸ 0 à¹à¸¡à¹à¸¢à¸à¸¡à¸£à¸±à¸"
#~ msgid "Initializing data...\n"
#~ msgstr "à¹à¸£à¸´à¹à¸¡à¸à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥...\n"
@@ -33570,14 +33621,6 @@
#~ msgstr "FFT สำà¹à¸£à¹à¸à¹à¸¥à¹à¸§..."
#, fuzzy
-#~ msgstr "à¸à¸³à¸¥à¸±à¸à¹à¸à¸µà¸¢à¸ viewable versions à¸à¸à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸µà¹à¹à¸à¸¥à¸à¹à¸à¸à¸µà¹à¹à¸à¸¥à¹..."
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹à¹à¸ cell_misc directory"
-#, fuzzy
#~ msgid ""
#~ "\n"
@@ -33597,14 +33640,6 @@
#~ msgid "Unable to proceed"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸³à¸à¸²à¸à¹à¸à¹"
-#, fuzzy
-#~ msgstr "** à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸ à¹à¸à¸´à¸ à¹à¸à¸¥à¹ seed singature <%s> **"
-#, fuzzy
-#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸à¹à¸à¸¥à¹ signature [%s]"
#~ msgstr "à¸à¸¥à¸¸à¹à¸¡à¹à¸à¸¥à¹à¸ าà¸à¸à¸µà¹à¸à¸°à¸£à¸§à¸¡à¹à¸à¹à¸à¸à¸¥à¸¸à¹à¸¡"
@@ -33636,16 +33671,6 @@
#~ msgid "Creates control points on an image to be ortho-rectified."
#~ msgstr "สรà¹à¸²à¸à¸à¸¸à¸à¸à¸§à¸à¸à¸¸à¸¡ à¸à¸à¸ าà¸à¸à¸µà¹à¸à¸°à¸à¸³ ortho-rectified"
-#, fuzzy
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen."
-#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¸ าà¸à¸à¸µà¹à¸à¸° rectified à¹à¸¥à¸°à¹à¸ªà¸à¸à¸à¸à¸«à¸à¹à¸²à¸à¸"
-#, fuzzy
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen."
-#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¸à¸²à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¹à¸²à¸«à¸¡à¸²à¸¢ à¸à¸µà¹à¸à¸°à¹à¸ªà¸à¸à¸à¸à¸«à¸à¹à¸²à¸à¸"
#~ msgid "Unable to read head of %s"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¹à¸²à¸ สà¹à¸§à¸à¸«à¸±à¸§à¸à¸à¸ %s"
@@ -33722,14 +33747,6 @@
#~ msgid "run non-interactively"
#~ msgstr "à¸à¸³à¸à¸²à¸à¹à¸à¸à¹à¸¡à¹à¹à¸à¹à¸à¸²à¸£à¹à¸à¹à¸à¸à¸"
-#, fuzzy
-#~ msgid ""
-#~ "Name of old database. The database must be in form printed by v.db."
-#~ "connect -g, i.e. with substituted variables"
-#~ msgstr ""
-#~ "à¸à¸·à¹à¸à¸à¸à¸à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸¡ à¸à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸°à¸à¹à¸à¸à¸à¸¢à¸¹à¹à¹à¸à¹à¸à¸ printed à¹à¸à¸¢ v.db.connect -g, à¸à¹à¸§à¸¢ "
-#~ "substituted variables"
#~ msgid "Run non-interactively"
#~ msgstr "à¸à¸³à¸à¸²à¸à¹à¸à¸ à¹à¸¡à¹à¸¡à¸µà¸à¸²à¸£ à¸à¸à¸à¹à¸à¹"
@@ -34146,10 +34163,6 @@
#~ msgstr "à¹à¸ªà¸à¸, สà¹à¸à¸à¸à¸, à¸à¸µà¸à¸µà¹à¸à¸ª"
-#, fuzzy
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¸ าà¸à¹à¸à¸à¸à¸µà¹à¹à¸«à¸¡à¹(à¸à¸¢à¸¹à¹à¹à¸ ~/.gpsdrive)"
#~ msgid "Make JPEG instead of PNG image"
#~ msgstr "สรà¹à¸²à¸ JPEG à¹à¸à¸à¸à¸µà¹à¸à¸°à¹à¸à¹à¸ PNG"
@@ -34543,10 +34556,6 @@
#~ msgid "Cell area: %f"
#~ msgstr "Cell area: %f"
-#, fuzzy
-#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภTerrain (DEM)"
#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸¥à¸¥à¸±à¸à¸à¹ à¸à¸µà¹à¸¡à¸µ lake"
@@ -34939,10 +34948,6 @@
#~ msgid "Cannot open dxf file <%s>"
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ dxf à¹à¸à¸¥à¹ <%s>"
-#, fuzzy
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr "à¹à¸à¹à¹à¸à¸·à¹à¸à¸à¹à¸ output= à¹à¸à¸·à¹à¸à¹à¸à¸¥à¸µà¹à¸¢à¸à¸à¸·à¹à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸"
#~ msgid "Conversion of <%s> to vector map:"
#~ msgstr "à¸à¸²à¸£à¹à¸à¸¥à¸à¸à¸à¸ <%s> à¹à¸à¹à¸à¹à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸:"
@@ -35523,10 +35528,6 @@
#~ msgid "No LatLong information for XY-Projection"
#~ msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¹à¸à¸¡à¸¹à¸¥ à¹à¸¥à¸/ลà¸à¸ สำหรัภXY-Projection"
-#, fuzzy
-#~ msgstr "à¸à¸³à¸¥à¸±à¸à¸¥à¸à¸«à¸à¹à¸²à¸à¸ ..."
#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸à¹à¸à¸¥à¹ <%s>"
@@ -35847,3 +35848,1553 @@
#~ msgstr "à¹à¸ªà¸à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸´à¸à¹à¸ªà¹à¸à¸à¸à¸ GRASS à¹à¸à¸à¸£à¸à¸à¸à¸µà¹à¸à¸³à¸¥à¸±à¸à¸à¸³à¸à¸²à¸à¸à¸à¸à¸à¹à¸ªà¸à¸à¸à¸¥"
+#~ msgstr "à¹à¸à¸¥à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´ à¹à¸à¹à¸à¹à¸ à¹à¸à¸¥à¹ ASCII"
+#~ msgid ""
+#~ msgstr ""
+#~ "à¹à¸à¸¥à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´à¹à¸à¸ ASCII à¹à¸à¹à¸à¹à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´ à¹à¸à¸ binary"
+#~ msgid "The initial piezometric head in [m]"
+#~ msgstr "The initial piezometric head หà¸à¹à¸§à¸¢ [m]"
+#~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgstr "สà¸à¸²à¸à¸° à¸à¸à¸à¹à¸à¹à¸¥à¸° cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#~ msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+#~ msgstr "z-part à¸à¸à¸ hydraulic conductivity tensor à¹à¸ [à¹à¸¡à¸à¸£/วิà¸à¸²à¸à¸µ]"
+#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภRecharge à¹à¸ หà¸à¹à¸§à¸¢ à¹à¸¡à¸à¸£^3/วิà¸à¸²à¸à¸µ"
+#~ msgid ""
+#~ "The piezometric head result of the numerical calculation will be written "
+#~ "to this map"
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ piezometric head à¸à¸à¸ à¸à¸²à¸£à¸à¸³à¸à¸§à¸à¸à¸±à¸§à¹à¸¥à¸ à¸à¸°à¹à¸à¸µà¸¢à¸à¸¥à¸à¹à¸à¹à¸à¸à¸à¸µà¹"
+#~ msgid ""
+#~ "Calculate the groundwater distance velocity vector field and write the x, "
+#~ "y, and z components to maps named name_[xyz]. Name is basename for the "
+#~ "new raster3d maps"
+#~ msgstr ""
+#~ "à¸à¸³à¸à¸§à¸ groundwater distance velocity vector field à¹à¸¥à¸°à¹à¸à¸µà¸¢à¸ x, y, à¹à¸¥à¸° z "
+#~ "à¹à¸à¸à¸µà¹à¹à¸à¸à¸à¸µà¹ à¸à¸·à¹à¸ name_[xyz]. à¸à¸·à¹à¸à¸à¸¶à¹à¸à¸à¸¢à¸¹à¹à¸à¸±à¸ à¸à¸·à¹à¸à¸à¸²à¸ สำหรัภà¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´"
+#~ msgid "The direct cholesky solver do not work with sparse matrices"
+#~ msgstr "Direct cholesky solver à¹à¸à¹à¸à¸²à¸à¹à¸¡à¹à¹à¸à¹à¸à¸±à¸ sparse matrices"
+#~ msgid ""
+#~ "Cannot create mask file: G3D_MASK already exists!\n"
+#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+#~ msgstr ""
+#~ "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸ªà¸£à¹à¸²à¸ mask à¹à¸à¸¥à¹: G3D_MASK มีà¸à¸¢à¸¹à¹à¹à¸¥à¹à¸§!\n"
+#~ " à¹à¸à¹ 'g.remove rast3d=G3D_MASK' à¹à¸à¸·à¹à¸à¸à¸µà¹à¸à¸°à¹à¸à¸² mask à¸à¸à¸."
+#~ msgstr "สà¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ3 มิà¸à¸´ GRASS à¹à¸à¹à¸à¹à¸ à¹à¸à¸¥à¹ à¹à¸à¸à¸à¸µà¹ 3 มิà¸à¸´ Vis5D"
+#~ msgstr "สà¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภGRASSà¹à¸à¹à¸à¹à¸ à¹à¸à¸¥à¹à¹à¸à¸à¸à¸µà¹ GRIDATB.FOR (TOPMODEL)"
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸²à¸"
+#~ msgid "raster, export"
+#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, สà¹à¸à¸à¸à¸"
+#~ msgstr "à¹à¸à¸¥à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¹à¸à¹à¸à¹à¸ à¹à¸à¸¥à¹ height-field สำหรัภPOVRAY."
+#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, à¹à¸à¸à¸à¸µà¹ algebra"
+#~ msgstr "à¹à¸à¸¥à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¹à¸à¹à¸à¹à¸ ASCII text à¹à¸à¸¥à¹"
+#~ msgstr "à¸à¸³à¸¥à¸±à¸à¹à¸à¸¥à¸ %s..."
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸² stop vector <%s>"
+#~ msgstr "à¸à¸³à¹à¸à¹à¸² à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸ Floating Point (à¸à¹à¸²à¸à¸±à¹à¸à¸à¹à¸: Integer)"
+#~ msgstr "à¸à¸³à¹à¸à¹à¸² à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸ Double Precision (à¸à¹à¸²à¸à¸±à¹à¸à¸à¹à¸: Integer)"
+#, fuzzy
+#~ msgstr " à¸à¸³à¸à¸§à¸à¸à¸à¸ bytes à¸à¹à¸ cell"
+#, fuzzy
+#~ msgid "Bytes do not match File size"
+#~ msgstr "Bytesà¹à¸¡à¹à¸ªà¸à¸à¸à¸¥à¹à¸à¸à¸à¸±à¸à¸à¸à¸²à¸à¸à¸à¸ à¹à¸à¸¥à¹"
+#~ msgid "Update the statistics (histogram, range) for [%s]? "
+#~ msgstr "à¸à¸£à¸±à¸à¸à¸£à¸¸à¸ statistics (histogram, range) สำหรัภ[%s]? "
+#, fuzzy
+#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภTerrain (DEM)"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸à¸à¸¥à¸¥à¸±à¸à¸à¹"
+#, fuzzy
+#~ msgid "raster, interpolation"
+#~ msgstr "vector, interpolation"
+#, fuzzy
+#~ msgstr "Interpolating à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภ<%s>... %d rows... "
+#~ msgid "raster, statistics"
+#~ msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸, สà¸à¸´à¸à¸´"
+#~ msgstr "à¹à¸à¸¥à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¹à¸à¹à¸à¹à¸ à¹à¸à¸ VTK-Ascii"
+#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
+#~ msgstr "à¸à¸²à¸£à¸à¸³à¸«à¸à¸ quant rule สำหัà¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² à¹à¸à¸à¸µà¹ (%f %f) -> (%d,%d)"
+#, fuzzy
+#, fuzzy
+#~ msgid "No data"
+#~ msgstr "à¹à¸¡à¹à¸¡à¸µ à¸à¸²à¸£à¸²à¸"
+#, fuzzy
+#~ msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸«à¸²à¹à¸ªà¹à¸ à¸à¸à¸ cat %d"
+#, fuzzy
+#~ msgid "Bad start cell"
+#~ msgstr "Cell à¹à¸£à¸´à¹à¸¡à¸à¹à¸ à¹à¸¡à¹à¸à¸µ"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ water height à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ x-derivatives à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ y-derivatives à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ detachment capacity coefficient à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ transport capacity coefficient à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ critical shear stress à¹à¸à¸´à¸à¸ าà¸"
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ Mannings n à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¸à¸à¸µà¹ transport capacity à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¸à¸à¸µà¹ transp.limited erosion-deposition à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¸à¸à¸µà¹ sediment concentration à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¸à¸à¸µà¹ sediment flux à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹ à¹à¸à¸à¸à¸µà¹ erosion-deposition à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgid ""
+#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+#~ msgstr ""
+#~ "à¹à¸à¸à¸à¸³à¸¥à¸à¸ Overland flow hydrologic à¸à¸¶à¹à¸à¸à¸¢à¸¹à¹à¸à¸±à¸ duality particle-field concept "
+#~ "(SIMWE)"
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ rainfall excess rate (rain-infilt) à¹à¸à¸´à¸à¸ าà¸, [ม.ม./à¸à¸±à¹à¸§à¹à¸¡à¸]"
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ runoff infiltration rate à¹à¸à¸´à¸à¸ าà¸, [ม.ม./à¸à¸±à¹à¸§à¹à¸¡à¸]"
+#~ msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹ flow controls à¹à¸à¸´à¸à¸ าภ(permeability ratio 0-1)"
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹à¹à¸à¸à¸à¸µà¹ water discharge à¹à¸à¸´à¸à¸ าà¸"
+#, fuzzy
+#~ msgstr "à¸à¸¥à¸¥à¸±à¸à¸à¹à¹à¸à¸à¸à¸µà¹ simulation error à¹à¸à¸´à¸à¸ าà¸"
