[GRASS-SVN] r43347 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Mon Aug 30 00:46:16 EDT 2010
Author: neteler
Date: 2010-08-30 04:46:16 +0000 (Mon, 30 Aug 2010)
New Revision: 43347
grass/branches/develbranch_6/locale/po/grasslibs_vi.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grasstcl_vi.po
grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
Bui Huu Manh: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasslibs_vi.po
--- grass/branches/develbranch_6/locale/po/grasslibs_vi.po 2010-08-30 04:45:43 UTC (rev 43346)
+++ grass/branches/develbranch_6/locale/po/grasslibs_vi.po 2010-08-30 04:46:16 UTC (rev 43347)
@@ -3,19 +3,19 @@
# Copyright (C) 2004, GRASS Development Team
# Bui Huu Manh <bhmanh73 at yahoo.com>, 2006.
-# Markus Neteler <neteler at itc.it>, 2004, 2009.
+# Markus Neteler <neteler at itc.it>, 2004, 2009, 2010.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_vi\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-08-29 12:20+0200\n"
-"PO-Revision-Date: 2009-09-11 09:54+0700\n"
+"PO-Revision-Date: 2010-08-27 11:18+0700\n"
"Last-Translator: \n"
-"Language-Team: American English <kde-i18n-doc at lists.kde.org>\n"
+"Language-Team: American English <kde-i18n-doc at kde.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"X-Generator: Lokalize 0.2\n"
+"X-Generator: Lokalize 1.0\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../lib/raster/rem_io.c:40
@@ -528,14 +528,14 @@
"phép chiếu không hợp lệ\n"
#: ../lib/gis/mapset_msc.c:60
-#, fuzzy, c-format
+#, c-format
msgid "Unable to make mapset element %s (%s): %s"
-msgstr "Không thể tạo thành phần %s (%s) cho bộ bản đồ"
+msgstr "Không thể tạo thành phần cho bộ bản đồ %s (%s): %s"
#: ../lib/gis/mapset_msc.c:64
-#, fuzzy, c-format
+#, c-format
msgid "Unable to access mapset element %s (%s): %s"
+msgstr "Không thể truy cập thành phần của bộ bản đồ %s (%s): %s"
#: ../lib/gis/null_val.c:68
msgid "EmbedGivenNulls: wrong data type!"
@@ -1163,12 +1163,12 @@
#: ../lib/gis/spawn.c:385
#, c-format
msgid "CreateProcess() failed: error = %d"
-msgstr ""
+msgstr "CreateProcess() thất bại: lỗi = %d"
#: ../lib/gis/spawn.c:411
-#, fuzzy, c-format
+#, c-format
msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: không thể sao lặp lại mô tả %d tới %d"
+msgstr "G_spawn: không thể chuyển hướng trình mô tả %d"
#: ../lib/gis/spawn.c:419 ../lib/gis/spawn.c:604
#, c-format
@@ -1789,7 +1789,7 @@
#: ../lib/gis/myname.c:50
msgid "This location has no description."
-msgstr ""
+msgstr "Location này không có mô tả."
#: ../lib/gis/debug.c:74
#, c-format
@@ -2067,9 +2067,9 @@
msgstr "quy tắc tồi (%s): [%d]"
#: ../lib/gis/color_rules.c:265
-#, fuzzy, c-format
+#, c-format
msgid "Unable to load color rules <%s>"
-msgstr "Không thể đóng vec-tơ <%s>"
+msgstr "Không thể nạp các quy tắc màu <%s>"
#: ../lib/gis/done_msg.c:38
#, c-format
@@ -2118,6 +2118,8 @@
"Incompatible library version for module. You need to rebuild GRASS or "
"untangle multiple installations."
msgstr ""
+"Phiên bản thư viện cho mô-đun không tương thích. Bạn cần phải xây dựng lại "
+"GRASS hoặc gỡ rối việc cài đặt nhiều lần."
#: ../lib/gis/gisinit.c:63
#, c-format
@@ -2280,16 +2282,15 @@
#: ../lib/vector/diglib/file.c:157
msgid "Writing to file loaded to memory not supported"
-msgstr ""
+msgstr "Việc ghi vào tập tin nạp trong bộ nhớ không được hỗ trợ"
#: ../lib/vector/diglib/file.c:200
-#, fuzzy
msgid "Unable to load file to memory, file not open"
-msgstr "Không thể mở tập tin tạm"
+msgstr "Không thể nạp tập tin vào bộ nhớ, tập tin không được mở"
#: ../lib/vector/diglib/file.c:215
msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
+msgstr "Chế độ bộ nhớ cho véc-tơ không được hỗ trợ, dùng chế độ 'TỰ ĐỘNG'"
#: ../lib/vector/diglib/spindex.c:248
#, c-format
@@ -3121,9 +3122,9 @@
"'write' (ghi)"
#: ../lib/vector/Vlib/write.c:239
-#, fuzzy, c-format
+#, c-format
msgid "Unable to feature %d from vector map <%s>"
-msgstr "Không thể với đối tượng %d từ bản đồ vec-tơ <%s>"
+msgstr "Không thể đọc đối tượng %d từ bản đồ vec-tơ <%s>"
#: ../lib/vector/Vlib/write.c:265
#, c-format
@@ -4148,7 +4149,6 @@
msgstr "Lỗi yêu cầu miền cho chú giải"
#: ../lib/ogsf/gsd_legend.c:384
-#, fuzzy
msgid "Unable to show discrete FP range (use list"
msgstr "Không thể hiển thị miền FP rời rạc (dùng danh sách"
@@ -4380,12 +4380,11 @@
#: ../lib/db/dbmi_base/login.c:98
msgid "Login file corrupted"
-msgstr ""
+msgstr "Tập tin đăng nhập bị hỏng"
#: ../lib/db/dbmi_base/default_name.c:127
-#, fuzzy
msgid "Programmer error"
-msgstr "Có thể là lỗi chương trình."
+msgstr "Lỗi của lập trình viên"
#: ../lib/db/dbmi_client/table.c:46
#, c-format
@@ -4437,11 +4436,11 @@
#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:217
#: ../lib/db/dbmi_client/select.c:283
msgid "Missing column name"
-msgstr ""
+msgstr "Thiếu tên cột"
#: ../lib/db/dbmi_client/select.c:212 ../lib/db/dbmi_client/select.c:278
msgid "Missing key column name"
-msgstr ""
+msgstr "Thiếu tên cột khoá"
#: ../lib/db/dbmi_client/select.c:305
#, c-format
@@ -4945,19 +4944,19 @@
msgstr "Đang bắt đầu bộ giải khai triển Cholesky"
#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr "Không thể mở tập tin [%s] của nhóm [%s trong %s]"
+msgstr "Không thể mở tập tin điểm khống chế của nhóm [%s trong %s]"
#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
+#, c-format
msgid "Bad format in control point file for group [%s in %s]"
+msgstr "Định dạng tập tin điểm khống chế của nhóm [%s trong %s] không tốt"
#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr "Không thể tạo tập [%s] cho nhóm [%s ở %s]"
+msgstr "Không thể tạo tập tin điểm khống chế cho nhóm [%s trong %s]"
#: ../lib/imagery/fopen.c:23
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2010-08-30 04:45:43 UTC (rev 43346)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2010-08-30 04:46:16 UTC (rev 43347)
@@ -3,19 +3,19 @@
# Markus Neteler <neteler at itc.it>, 2004.
-# Bui Huu Manh <bhmanh73 at yahoo.com>, 2006, 2009.
+# Bui Huu Manh <bhmanh73 at yahoo.com>, 2006, 2009, 2010.
msgid ""
msgstr ""
"Project-Id-Version: grassmods_vi\n"
-"PO-Revision-Date: 2009-09-11 15:39+0700\n"
+"PO-Revision-Date: 2010-08-27 14:37+0700\n"
#: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:300
@@ -2896,6 +2896,8 @@
#: ../raster/r.sun2/main.c:504 ../vector/v.buffer2/main.c:214
msgid "This does nothing. It is retained for backwards compatibility"
msgstr ""
+"Lệnh này không làm gì hết. Nó được giữ lại chỉ nhằm mục đích tương thích "
+"ngược"
#: ../raster/r.sun2/main.c:505 ../vector/v.buffer2/main.c:212
#: ../vector/v.buffer2/main.c:224 ../vector/v.build.polylines/main.c:128
@@ -3129,9 +3131,8 @@
msgstr ""
#: ../raster/r.in.gdal/main.c:194
-#, fuzzy
msgid "Available GDAL Drivers:"
-msgstr "Các trình điều khiển OGR dùng được:"
+msgstr "Các trình điều khiển GDAL dùng được:"
#: ../raster/r.in.gdal/main.c:215 ../raster/r.proj/main.c:246
#: ../raster/r.out.gdal/main.c:230 ../raster/r.proj.seg/main.c:279
@@ -4423,9 +4424,9 @@
msgstr "Không thể đọc miền giá trị cho bản đồ <%s>"
#: ../raster/r.stats/cell_stats.c:51
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read raster <map %d of %d> row %d"
-msgstr "Không thể đọc bản đồ raster <%s> hàng %d"
+msgstr "Không thể đọc <bản đồ raster %d của %d> hàng %d"
#: ../raster/r.compress/main.c:65
msgid "Compresses and decompresses raster maps."
@@ -4870,24 +4871,20 @@
msgstr "Miền dữ liệu kiểu số nguyên cũ từ %d đến %d"
#: ../raster/r.slope.aspect/main.c:153
-#, fuzzy
msgid "raster, terrain"
-msgstr "raster, nội suy"
+msgstr "raster, địa hình"
#: ../raster/r.slope.aspect/main.c:154
-#, fuzzy
msgid ""
"Generates raster maps of slope, aspect, curvatures and partial derivatives "
"from a elevation raster map."
msgstr ""
"Tạo ra các lớp bản đồ độ dốc, hướng, độ cong và các đạo hàm riêng từ một lớp "
-"bản đồ raster có các giá trị độ cao thực. Hướng được tính ngược chiều kim "
-"đồng hồ từ hướng đông."
+"bản đồ raster độ cao."
#: ../raster/r.slope.aspect/main.c:156
-#, fuzzy
msgid "Aspect is calculated counterclockwise from east."
-msgstr "Góc xoay (độ, ngược chiều kim đồng hồ tính từ hướng Đông"
+msgstr "Hướng được tính ngược chiều kim đồng hồ từ hướng Đông."
#: ../raster/r.slope.aspect/main.c:163
msgid "Name for output slope raster map"
@@ -4903,9 +4900,8 @@
#: ../vector/v.surf.rst/main.c:252 ../vector/v.surf.rst/main.c:258
#: ../vector/v.surf.rst/main.c:266 ../vector/v.surf.rst/main.c:273
#: ../vector/v.surf.rst/main.c:280 ../vector/v.surf.rst/main.c:287
-#, fuzzy
msgid "Outputs"
-msgstr "Bản đồ đầu ra"
+msgstr "Đầu ra"
#: ../raster/r.slope.aspect/main.c:169
msgid "Name for output aspect raster map"
@@ -5641,9 +5637,9 @@
msgstr "Không thể ghi tập tin et"
#: ../raster/simwe/simlib/hydro.c:119
-#, fuzzy, c-format
+#, c-format
msgid "nwalk (%d) > maxw (%d)!"
-msgstr "nwalk > maxw!"
+msgstr "nwalk (%d) > maxw (%d)!"
#: ../raster/simwe/simlib/hydro.c:339
msgid "Unable to write raster maps"
@@ -6232,9 +6228,8 @@
msgstr "Lưu lượng riêng tính bằng [1/m]"
#: ../raster/r.gwflow/main.c:84
-#, fuzzy
msgid "Recharge"
-msgstr "Các hàng bị thay đổi"
+msgstr "Nạp lại"
#: ../raster/r.gwflow/main.c:87
msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
@@ -6725,13 +6720,12 @@
"Giá trị đầu vào: Độ dài lớn nhất của các dòng chảy bề mặt, dùng cho USLE"
#: ../raster/r.watershed/front/main.c:170
-#, fuzzy
msgid "Convergence factor for MFD (1-10)"
-msgstr "Hệ số chuyển đổi cho các giá trị z"
+msgstr "Hệ số chuyển đổi cho MFD (1-10)"
#: ../raster/r.watershed/front/main.c:172
msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
+msgstr "1 = dòng chảy phân tán nhất, 10 = dòng chảy hội tụ nhất. Khuyến cáo: 5"
#: ../raster/r.watershed/front/main.c:179
msgid "Maximum memory to be used with -m flag (in MB)"
@@ -6739,11 +6733,11 @@
#: ../raster/r.watershed/front/main.c:183
msgid "Enable MFD flow (default is SFD (D8))"
-msgstr ""
+msgstr "Kích hoạt dòng chảy MFD (mặc định là SFD (D8))"
#: ../raster/r.watershed/front/main.c:185
msgid "SFD: single flow direction, MFD: multiple flow direction"
-msgstr ""
+msgstr "SFD: dòng chảy một hướng, MFD: dòng chảy nhiều hướng"
#: ../raster/r.watershed/front/main.c:190
msgid "Allow only horizontal and vertical flow of water"
@@ -6758,28 +6752,29 @@
"Only needed if memory requirements exceed available RAM; see manual on how "
"to calculate memory requirements"
msgstr ""
+"Chỉ cần hiết nếu yêu cầu bộ nhớ vượt quá RAM; xem tài liệu hướng dẫn cách "
+"tính nhu cầu bộ nhớ"
#: ../raster/r.watershed/front/main.c:202
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
+msgstr "Dùng tích luỹ dòng chảy dương cho cả các giá trị ước lượng có thể thấp"
#: ../raster/r.watershed/front/main.c:204
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
+msgstr "Xem hướng dẫn để biết mô tả chi tiết đầu ra tích luỹ dòng chảy"
#: ../raster/r.watershed/front/main.c:221
msgid "Sorry, you must choose an output map."
msgstr "Xin lỗi, bạn phải chọn một bản đồ đầu ra nào đó."
#: ../raster/r.watershed/front/main.c:237
-#, fuzzy
msgid ""
"Sorry, if any of the following options are set:\n"
" basin, stream, half.basin, length.slope, or slope.steepness\n"
" you MUST provide a value for the basin threshold parameter."
msgstr ""
"Xin lỗi, nếu bất kỳ tùy chọn nào sau đây được thiết lập:\n"
-" basin, stream, half.basin, slope, hay lS\n"
+" basin, stream, half.basin, length.slope, hay slope.steepnes\n"
" thì bạn PHẢI cung cấp một giá trị cho tham số ngưỡng lưu vực."
#: ../raster/r.watershed/front/main.c:392
@@ -6819,47 +6814,42 @@
msgstr "không thể mở lớp bản đồ hướng mới."
#: ../raster/r.watershed/ram/close_maps.c:201
-#, fuzzy
msgid "unable to open new LS factor map layer."
-msgstr "không thể mở lớp bản đồ L mới"
+msgstr "không thể mở lớp bản đồ hệ số LS mới."
#: ../raster/r.watershed/ram/close_maps.c:219
msgid "unable to open new slope length map layer."
msgstr "không thể mở lớp bản đồ chiều dài dốc mới."
#: ../raster/r.watershed/ram/close_maps.c:241
-#, fuzzy
msgid "unable to open new S factor map layer."
-msgstr "không thể mở lớp bản đồ S mới."
+msgstr "không thể mở lớp bản đồ hệ số S mới."
#: ../raster/r.watershed/ram/sg_factor.c:13
#: ../raster/r.watershed/seg/sg_factor.c:12
-#, fuzzy
msgid "SECTION 4: RUSLE LS and/or S factor determination."
-msgstr "PHẦN 4: Xác định chiều dài dốc."
+msgstr "PHẦN 4: Phép xác định hệ số RUSLE LS và/hoặc S."
#: ../raster/r.watershed/ram/do_cum.c:15 ../raster/r.watershed/seg/do_cum.c:17
-#, fuzzy
msgid "SECTION 3: Accumulating Surface Flow with SFD."
-msgstr "PHẦN 3: Dòng chảy bề mặt tích lũy."
+msgstr "PHẦN 3: Dòng chảy bề mặt tích luỹ với SFD."
#: ../raster/r.watershed/ram/do_cum.c:116
#: ../raster/r.watershed/seg/do_cum.c:121
-#, fuzzy
msgid "SECTION 3: Accumulating Surface Flow with MFD."
+msgstr "PHẦN 3: Dòng chảy bề mặt tích lũy với MFD."
#: ../raster/r.watershed/ram/do_cum.c:310
#: ../raster/r.watershed/seg/do_cum.c:325
#, c-format
msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
-msgstr ""
+msgstr "MFD: tỷ lệ tích luỹ của phân bố dòng chảy không phải là 1,0 mà là %f"
#: ../raster/r.watershed/ram/do_cum.c:366
#: ../raster/r.watershed/seg/do_cum.c:385
#, c-format
msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr ""
+msgstr "MFD: Một đường dẫn * được xử lý khi phân bố dòng chảy: %d của %d ô"
#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
#, c-format
@@ -6945,9 +6935,8 @@
msgstr "PHẦN 1b (của %1d): Đang xác định Dòng chảy ra khỏi Bản đồ."
#: ../raster/r.watershed/seg/close_maps.c:52
-#, fuzzy
msgid "unable to open flow accumulation map layer"
-msgstr "không thể mở lớp bản đồ accum (tích lũy) mới."
+msgstr "không thể mở lớp bản đồ tích lũy dòng chảy"
#: ../raster/r.watershed/seg/init_vars.c:114
#, c-format
@@ -8284,12 +8273,12 @@
#: ../raster/r.resamp.rst/main.c:539
#, c-format
msgid "dnorm in mainc after grid before out1= %f"
-msgstr ""
+msgstr "dnorm trong mainc sau lưới trước khi out1= %f"
#: ../raster/r.resamp.rst/main.c:556
#, c-format
msgid "dnorm in mainc after grid before out2= %f"
-msgstr ""
+msgstr "dnorm trong mainc sau lưới trước khi out2= %f"
#: ../raster/r.resamp.rst/main.c:607 ../vector/v.surf.rst/main.c:638
msgid "Not enough memory for zero_array_cell"
@@ -8520,9 +8509,8 @@
msgstr "Vui lòng chỉ định số thứ tự cột hợp lý."
#: ../raster/r.in.xyz/main.c:302
-#, fuzzy
msgid "Invalid zrange"
-msgstr "Giá trị easting không hợp lệ"
+msgstr "Miền zrange không hợp lệ"
#: ../raster/r.in.xyz/main.c:389
msgid "Unable to calculate percentile without the pth option specified!"
@@ -8555,9 +8543,8 @@
msgstr "miền giá trị z (zrange) sẽ không được xem xét trong quá trình quét"
#: ../raster/r.in.xyz/main.c:521
-#, fuzzy
msgid "Reading data ..."
-msgstr "Đang đọc dữ liệu..."
+msgstr "Đang đọc dữ liệu ..."
#: ../raster/r.in.xyz/main.c:599 ../raster/r.in.xyz/main.c:607
#: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
@@ -9400,9 +9387,8 @@
msgstr "Liệt kê các định dạng đầu ra được hỗ trợ"
#: ../raster/r.out.gdal/main.c:137
-#, fuzzy
msgid "Do not write GDAL standard colortable"
-msgstr "Không xuất ra bảng màu dài"
+msgstr "Không bảng màu chuẩn của GDAL"
#: ../raster/r.out.gdal/main.c:138
msgid "Only applicable to Byte or UInt16 data types."
@@ -9410,11 +9396,11 @@
#: ../raster/r.out.gdal/main.c:142
msgid "Force raster export despite any warnings of data loss"
-msgstr ""
+msgstr "Buộc xuất ra raster bất kể cảnh báo mất dữ liệu"
#: ../raster/r.out.gdal/main.c:143
msgid "Overrides nodata safety check."
-msgstr ""
+msgstr "Ghi đè kiểm tra an toàn phần không-dữ-liệu"
#: ../raster/r.out.gdal/main.c:147
msgid "Name of raster map (or group) to export"
@@ -9484,9 +9470,8 @@
"cho bộ dữ liệu trung gian."
#: ../raster/r.out.gdal/main.c:272
-#, fuzzy
msgid "Unable to get in-memory raster driver"
-msgstr "Không thể lấy trình điều khiển raster bộ nhớ nội tại"
+msgstr "Không thể lấy trình điều khiển raster trong-bộ-nhớ"
#: ../raster/r.out.gdal/main.c:276
#, c-format
@@ -9494,9 +9479,9 @@
msgstr "Trình điều khiển <%s> không hỗ trợ việc tạo các raster"
#: ../raster/r.out.gdal/main.c:352
-#, fuzzy, c-format
+#, c-format
msgid "Could not read data range of raster <%s>"
-msgstr "Không thể đọc miền của bản đồ raster <%s>"
+msgstr "Không thể đọc miền dữ liệu của bản đồ raster <%s>"
#: ../raster/r.out.gdal/main.c:409
#, c-format
@@ -9505,7 +9490,7 @@
#: ../raster/r.out.gdal/main.c:424
msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
+msgstr "Việc xuất raster có thể dẫn đến mất dữ liệu hoàn toàn, đang huỷ lệnh."
#: ../raster/r.out.gdal/main.c:435
#, c-format
@@ -9513,6 +9498,8 @@
"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
"avoided by using %s."
msgstr ""
+"Mất độ chính xác: Bản đồ raster <%s> kiểu %s cần được xuất thành %s. Có thể "
+"tránh điều này bằng cách dùng %s."
#: ../raster/r.out.gdal/main.c:446
#, c-format
@@ -9520,6 +9507,9 @@
"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
"datatype Float32. This can be avoided by exporting to Int32 or Float64."
msgstr ""
+"Mất độ chính xác: Miền của <%s> không thể được bảo toàn một cách chính xác "
+"với kiểu dữ liệu GDAL Float32. Có thể tránh điều này bằng cách xuất ra Int32 "
+"hoặc Float64."
#: ../raster/r.out.gdal/main.c:454
#, c-format
@@ -9527,26 +9517,26 @@
"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
"This can be avoided by using Float64"
msgstr ""
+"Mất độ chính xác: Float32 không thể bảo toàn độ chính xác DCELL của bản đồ "
+"raster <%s>. Có thể tránh điều này bằng cách dùng Float64"
#: ../raster/r.out.gdal/main.c:463 ../raster/r.out.gdal/main.c:506
-#, fuzzy
msgid "Forcing raster export."
-msgstr "raster, xuất"
+msgstr "Buộc phải xuất raster."
#: ../raster/r.out.gdal/main.c:465 ../raster/r.out.gdal/main.c:479
#: ../raster/r.out.gdal/main.c:508 ../raster/r.out.gdal/main.c:512
-#, fuzzy
msgid "Raster export aborted."
+msgstr "Việc xuất raster bị huỷ."
#: ../raster/r.out.gdal/main.c:489
msgid "Checking GDAL data type and nodata value"
msgstr ""
#: ../raster/r.out.gdal/main.c:492
-#, fuzzy, c-format
+#, c-format
msgid "Checking options for raster map <%s> (band %d)..."
-msgstr "Đang xuất bản đồ raster <%s> (băng %d)..."
+msgstr "Đang kiểm tra các tuỳ chọn cho bản đồ raster <%s> (băng %d)..."
#: ../raster/r.out.gdal/main.c:533
msgid "Output file name not specified"
@@ -9570,9 +9560,8 @@
msgstr "Không thể thiết lập phép chiếu"
#: ../raster/r.out.gdal/main.c:577
-#, fuzzy
msgid "Exporting to GDAL raster"
-msgstr "Đang xuất ra kiểu dữ liệu GDAL: %s"
+msgstr "Đang xuất raster GDAL"
#: ../raster/r.out.gdal/main.c:580
#, c-format
@@ -9600,7 +9589,7 @@
#: ../raster/r.out.gdal/export_band.c:574
#: ../raster/r.out.gdal/export_band.c:588
msgid "Selected GDAL datatype does not cover data range."
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL được chọn không bao trùm hết miền dữ liệu."
#: ../raster/r.out.gdal/main.c:629 ../raster/r.out.gdal/main.c:641
#: ../raster/r.out.gdal/main.c:654 ../raster/r.out.gdal/main.c:667
@@ -9610,25 +9599,25 @@
#: ../raster/r.out.gdal/export_band.c:550
#, c-format
msgid "GDAL datatype: %s, range: %d - %d"
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL: %s, miền: %d - %d"
#: ../raster/r.out.gdal/main.c:632 ../raster/r.out.gdal/main.c:644
#: ../raster/r.out.gdal/main.c:657 ../raster/r.out.gdal/main.c:670
#: ../raster/r.out.gdal/main.c:682 ../raster/r.out.gdal/main.c:695
-#, fuzzy, c-format
+#, c-format
msgid "Range to be exported: %g - %g"
-msgstr "Tập tin raster cần nhập"
+msgstr "Miền cần xuất: %g - %g"
#: ../raster/r.out.gdal/main.c:679 ../raster/r.out.gdal/export_band.c:562
#, c-format
msgid "GDAL datatype: %s, range: %u - %u"
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL: %s, miền: %u - %u"
#: ../raster/r.out.gdal/main.c:692 ../raster/r.out.gdal/export_band.c:575
#: ../raster/r.out.gdal/export_band.c:589
#, c-format
msgid "GDAL datatype: %s, range: %g - %g"
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL : %s, miền: %g - %g"
#: ../raster/r.out.gdal/main.c:719 ../raster/r.out.gdal/main.c:732
#: ../raster/r.out.gdal/main.c:746 ../raster/r.out.gdal/main.c:759
@@ -9644,12 +9633,12 @@
#: ../raster/r.out.gdal/main.c:777
#, c-format
msgid "GDAL datatype: %s, valid range: %d - %d"
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL: %s, miền hợp lệ: %d - %d"
#: ../raster/r.out.gdal/main.c:735 ../raster/r.out.gdal/main.c:762
#, c-format
msgid "GDAL datatype: %s, valid range: %u - %u"
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL: %s, miền hợp lệ: %u - %u"
#: ../raster/r.out.gdal/main.c:788
#, c-format
@@ -9658,11 +9647,14 @@
"raster: specified nodata value %g gets converted to %g by selected GDAL "
"datatype."
msgstr ""
+"Giá trị không-dữ-liệu trong đặc tả dữ liệu và giá trị không-dữ-liệu thực "
+"trong raster xuất ra không khớp nhau: giá trị không-dữ-liệu đã chỉ định %g "
+"bị kiểu dữ liệu GDAL đã chọn chuyển thành %g."
#: ../raster/r.out.gdal/main.c:791
#, c-format
msgid "GDAL datatype: %s, valid range: %g - %g"
-msgstr ""
+msgstr "Kiểu dữ liệu GDAL: %s, miền hợp lệ: %g - %g"
#: ../raster/r.out.gdal/export_band.c:67 ../raster/r.out.gdal/export_band.c:73
#: ../raster/r.out.gdal/export_band.c:380
@@ -9671,15 +9663,15 @@
msgstr "Không thể cấp phát đệm để đọc bản đồ raster"
#: ../raster/r.out.gdal/export_band.c:195
-#, fuzzy, c-format
+#, c-format
msgid ""
"Input raster map contains cells with NULL-value (no-data). The value %d will "
"be used to represent no-data values in the input map. You can specify a "
"nodata value with the %s option."
msgstr ""
-"Bản đồ raster đầu vào chứa các ô với giá trị RỖNG (không có dữ liệu). Giá "
-"trị %d được dùng để biểu thị các giá trị không có dữ liệu trong bản đồ đầu "
-"vào. Bạn có thể chỉ định giá trị không dữ liệu bằng tham số %s."
+"Bản đồ raster đầu vào chứa các ô với giá trị RỖNG (không-dữ-liệu). Giá trị %"
+"d được dùng để biểu thị các giá trị không-dữ-liệu trong bản đồ đầu vào. Bạn "
+"có thể chỉ định giá trị không-dữ-liệu bằng tuỳ chọn %s."
#: ../raster/r.out.gdal/export_band.c:200
#, fuzzy, c-format
@@ -9698,6 +9690,9 @@
"The default nodata value is present in rasterband <%s> and would lead to "
"data loss. Please specify a custom nodata value with the %s parameter."
msgstr ""
+"Giá trị không-dữ-liệu mặc định có trong băng raster <%s> và sẽ dẫn đến việc "
+"mất dữ liệu. Vui lòng chỉ định một giá trị không-dữ-liệu tuỳ chọn bằng tham "
+"số %s."
#: ../raster/r.out.gdal/export_band.c:217
#, c-format
@@ -9705,6 +9700,9 @@
"The user given nodata value %g is present in rasterband <%s> and would lead "
"to data loss. Please specify a different nodata value with the %s parameter."
msgstr ""
+"Giá trị không-dữ-liệu %g do người dùng cung cấp có trong băng raster <%s> và "
+"sẽ dẫn đến mất dữ liệu. Vui lòng chỉ định một giá trị không-dữ-liệu khác "
+"bằng tham số %s."
#: ../raster/r.out.gdal/export_band.c:261
msgid "Unable to get raster band"
@@ -9723,9 +9721,9 @@
#: ../raster/r.out.gdal/export_band.c:565
#: ../raster/r.out.gdal/export_band.c:578
#: ../raster/r.out.gdal/export_band.c:592
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> range: %g - %g"
-msgstr "Bản đồ raster <%s> được tạo ra."
+msgstr "Bản đồ raster <%s> miền: %g - %g"
#: ../raster/r.null/null.c:58
msgid "raster, null data"
@@ -11568,9 +11566,8 @@
msgstr "Tên của nguồn dữ liệu GDAL phi-tập-tin"
#: ../raster/r.external/main.c:529
-#, fuzzy
msgid "Band to select (default: all)"
-msgstr "Băng cần chọn (mặc định là tất cả các băng)"
+msgstr "Băng cần chọn (mặc định: tất cả)"
#: ../raster/r.external/main.c:550
msgid "Require exact range"
@@ -11589,14 +11586,14 @@
msgstr "Không thể thiết lập cửa sổ"
#: ../raster/r.external/main.c:618
-#, fuzzy, c-format
+#, c-format
msgid "Imagery group <%s> already exists and will be overwritten."
-msgstr "Bản đồ raster <%s> đã có và sẽ bị ghi đè"
+msgstr "Nhóm ảnh <%s> đã có và sẽ bị ghi đè."
#: ../raster/r.external/main.c:658
-#, fuzzy, c-format
+#, c-format
msgid "Imagery group <%s> created"
+msgstr "Nhóm ảnh <%s> được tạo ra"
#: ../raster/r.proj.seg/main.c:204
#, fuzzy
@@ -11735,7 +11732,7 @@
#: ../raster/r.recode/read_rules.c:94
msgid "When finished type \"end\"."
-msgstr ""
+msgstr "Khi kết thúc gõ lệnh \"end\"."
#: ../raster/r.recode/read_rules.c:134
#, c-format
@@ -12546,6 +12543,9 @@
"%.2f]! Needs to be at least identical or the current region resolution lower "
"than the input map resolution"
msgstr ""
+"Độ phân giải vùng hiện tại [%.2fx%.2f] thấp hơn độ phân giải bản đồ đầu vào "
+"[%.2fx%.2f]! Tối thiểu là độ phân giải dùng hiện tại phải giống hoặc thấp "
+"hơn độ phân giải của bản đồ đầu vào"
#: ../raster/r.topidx/file_io.c:90
msgid "Writing topographic index map..."
@@ -13033,7 +13033,6 @@
msgstr "Đang các hộc"
#: ../raster/r.quantile/main.c:133
-#, fuzzy
msgid "Binning data"
msgstr "Đang tạo hộc dữ liệu"
@@ -13058,7 +13057,6 @@
msgstr "Danh sách các phân vị"
#: ../raster/r.quantile/main.c:277
-#, fuzzy
msgid "Number of bins to use"
msgstr "Số lượng hộc cần dùng"
@@ -13090,7 +13088,7 @@
#: ../general/g.version/main.c:56
msgid "Print the GIS library revision number and time"
-msgstr ""
+msgstr "In ra số lần và thời gian kiểm tra thư viện GIS"
#: ../general/manage/cmd/copy.c:39 ../general/manage/cmd/remove.c:99
#: ../general/manage/cmd/list.c:41 ../general/manage/cmd/rename.c:40
@@ -13198,9 +13196,9 @@
msgstr "<%s> đã có trong bộ bản đồ <%s>"
#: ../general/manage/cmd/rename.c:89
-#, fuzzy, c-format
+#, c-format
msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr "%s=%s,%s: các tập tin giống nhau, không cần đổi tên"
+msgstr "%s=%s,%s: các tập tin có vẻ giống nhau, không cần đổi tên"
#: ../general/manage/cmd/rename.c:99
msgid "Renaming reclass maps"
@@ -13223,6 +13221,8 @@
#: ../general/g.access/main.c:59
msgid "UNIX filesystem access controls are not supported by MS-Windows"
msgstr ""
+"Các kiểm soát truy cập hệ thống tập tin UNIX không được hỗ trợ trong M$-"
+"Windows"
#: ../general/g.access/main.c:67
msgid "Access to the PERMANENT mapset must be open, nothing changed"
@@ -13327,19 +13327,16 @@
msgstr "tổng quát, phép chiếu"
#: ../general/g.proj/main.c:56
-#, fuzzy
msgid ""
"Converts co-ordinate system descriptions (i.e. projection information) "
"between various formats (including GRASS format)."
msgstr ""
"Chuyển đổi các mô tả hệ toạ độ (tức là thông tin phép chiếu) giữa các định "
-"dạng khác nhau (kể cả định dạng của GRASS). Cũng có thể dùng để tạo các vị "
-"trí của GRASS."
+"dạng khác nhau (kể cả định dạng của GRASS)."
#: ../general/g.proj/main.c:59
-#, fuzzy
msgid "Can also be used to create GRASS locations."
-msgstr "Không thể tạo vị trí: %s"
+msgstr "Cũng có thể dùng để tạo các Location của GRASS."
#: ../general/g.proj/main.c:65
msgid "Print projection information (in conventional GRASS format)"
@@ -13386,21 +13383,16 @@
#: ../general/g.proj/main.c:137 ../general/g.proj/main.c:143
msgid "Datum"
-msgstr ""
+msgstr "Mốc toạ độ chuẩn"
#: ../general/g.proj/main.c:138
-#, fuzzy
msgid "Index number of datum transform parameters"
-msgstr ""
-"Số chỉ mục của các tham số chuyển đổi mốc tọa độ chuẩn, nhập \"0\" để chỉ "
-"không được chỉ định hoặc nhập \"-1\" để liệt kê và thoát"
+msgstr "Số chỉ mục của các tham số chuyển đổi mốc tọa độ chuẩn"
#: ../general/g.proj/main.c:139
-#, fuzzy
msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
+"nhập \"0\" để chỉ không được chỉ định hoặc nhập \"-1\" để liệt kê và thoát"
#: ../general/g.proj/main.c:145
msgid ""
@@ -13410,9 +13402,8 @@
"Buộc ghi đè thông tin chuyển đổi mốc tọa độ chuẩn trong hệ toạ độ đầu vào"
#: ../general/g.proj/main.c:150 ../general/g.proj/main.c:159
-#, fuzzy
msgid "Create/Edit"
-msgstr "Tạo"
+msgstr "Tạo/Chỉnh sửa"
#: ../general/g.proj/main.c:151
msgid ""
@@ -13597,12 +13588,10 @@
msgstr "Màu nền"
#: ../general/g.message/main.c:33
-#, fuzzy
msgid "general, scripts"
-msgstr "tổng quát, thiết lập"
+msgstr "tổng quát, tập lệnh"
#: ../general/g.message/main.c:35
-#, fuzzy
msgid ""
"Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr "In ra thông báo, cảnh báo hoặc lỗi nghiêm trọng theo kiểu của GRASS."
@@ -13615,44 +13604,37 @@
#: ../general/g.message/main.c:41 ../general/g.message/main.c:46
#: ../general/g.message/main.c:51 ../general/g.message/main.c:56
-#, fuzzy
msgid "Type"
-msgstr "Đến kiểu"
+msgstr "Kiểu"
#: ../general/g.message/main.c:42
-#, fuzzy
msgid "Print message as warning"
-msgstr "In ra thông báo dưới dạng cảnh báo kiểu GRASS"
+msgstr "In ra thông báo dưới dạng cảnh báo"
#: ../general/g.message/main.c:47
-#, fuzzy
msgid "Print message as fatal error"
-msgstr "In ra thông báo dưới dạng lỗi nghiêm trọng kiểu GRASS"
+msgstr "In ra thông báo dưới dạng lỗi nghiêm trọng"
#: ../general/g.message/main.c:52
-#, fuzzy
msgid "Print message as debug message"
-msgstr "In ra thông báo dưới dạng thông báo gỡ lỗi kiểu GRASS"
+msgstr "In ra thông báo dưới dạng thông báo gỡ lỗi"
#: ../general/g.message/main.c:57
-#, fuzzy
msgid "Print message as progress info"
+msgstr "In ra thông báo dưới dạng thông tin tiến trình"
#: ../general/g.message/main.c:61 ../general/g.message/main.c:66
#: ../general/g.message/main.c:80
-#, fuzzy
msgid "Level"
-msgstr "Các cấp"
+msgstr "Cấp"
#: ../general/g.message/main.c:62
msgid "Print message in all but full quiet mode"
msgstr "In ra thông báo toàn bộ nhưng ở chế độ im lặng hoàn toàn"
#: ../general/g.message/main.c:67
-#, fuzzy
msgid "Print message only in verbose mode"
-msgstr "In ra thông báo chỉ khi ở chế độ đầy đủ"
+msgstr "Chỉ in ra thông báo khi ở chế độ đầy đủ"
#: ../general/g.message/main.c:74
msgid "Text of the message to be printed"
@@ -13663,14 +13645,12 @@
msgstr "Cấp để dùng cho các thông báo gỡ lỗi"
#: ../general/g.message/main.c:91
-#, fuzzy
msgid "Select only one message level"
-msgstr "Chỉ chọn một cấp thông báo."
+msgstr "Chỉ chọn một cấp thông báo"
#: ../general/g.message/main.c:104
-#, fuzzy
msgid "Unable to parse input message"
-msgstr "Không thể đóng bản đồ đầu vào"
+msgstr "Không thể phân tách thông báo đầu vào"
#: ../general/g.setproj/main.c:80
msgid "Interactively reset the location's projection settings."
@@ -14075,14 +14055,14 @@
history -S; history -L %s/.history; setenv histfile=%s/.history"
#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
+#, c-format
msgid "Your mapset search list:\n"
-msgstr "In ra đường dẫn tìm kiếm bộ bản đồ hiện tại"
+msgstr "Danh sách tìm kiếm bộ bản đồ của bạn:\n"
#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
+#, c-format
msgid "<%s> not found in mapset list"
-msgstr "Không tìm thấy cột <%s> trong bảng <%s>"
+msgstr "Không tìm thấy <%s> trong danh sách bộ bản đồ"
#: ../general/g.mapsets/main.c:61
msgid ""
@@ -14137,14 +14117,14 @@
msgstr "Không thể mở SEARCH_PATH để ghi"
#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#, c-format
msgid "Available mapsets:"
-msgstr "Liệt kê các bộ bản đồ có thể dùng"
+msgstr "Các bộ bản đồ có thể dùng:"
#: ../general/g.mapsets/dsply_maps.c:33
-#, fuzzy, c-format
+#, c-format
msgid "** no mapsets **\n"
-msgstr "** không tìm thấy tập tin %s**\n"
+msgstr "** không có bộ bản đồ **\n"
#: ../general/g.mremove/main.c:66 ../general/g.mlist/main.c:126
msgid "Use basic regular expressions instead of wildcards"
@@ -14572,9 +14552,8 @@
msgstr "Cập nhật thiết lập GUI mặc định"
#: ../general/g.gui/main.c:63
-#, fuzzy
msgid "Do not launch GUI after updating the default GUI setting"
-msgstr "Cập nhật thiết lập GUI mặc định"
+msgstr "Không khởi động GDĐH sau khi cập nhật thiết lập GDĐH mặc định"
#: ../general/g.gui/main.c:90
#, c-format
@@ -14588,7 +14567,7 @@
#: ../general/g.gui/main.c:107
msgid "The old d.m GUI is not available for WinGRASS"
-msgstr ""
+msgstr "GDĐH kiểu cũ d.m không có trên WinGRASS"
#: ../general/g.findfile/main.c:37
msgid "Searches for GRASS data base files and sets variables for the shell."
@@ -14927,9 +14906,8 @@
msgstr "Màu chữ, hoặc là một màu chuẩn của GRASS, hoặc bộ ba R:G:B"
#: ../display/d.text.new/main.c:175
-#, fuzzy
msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr "Màu chữ, hoặc là một màu chuẩn của GRASS, hoặc bộ ba R:G:B"
+msgstr "Màu nền của chữ, hoặc là một màu chuẩn của GRASS, hoặc bộ ba R:G:B"
#: ../display/d.text.new/main.c:184 ../display/d.text/main.c:94
msgid "The screen line number on which text will begin to be drawn"
@@ -16514,23 +16492,20 @@
msgstr "Trình bày bảng màu liên quan đến một lớp bản đồ raster."
#: ../display/d.colortable/main.c:68
-#, fuzzy
msgid "Name of raster map whose color table is to be displayed"
-msgstr "Tên của bản đồ hướng raster cần trình bày"
+msgstr "Tên của bản đồ raster có bảng màu cần trình bày"
#: ../display/d.colortable/main.c:76
msgid "Color of lines separating the colors of the color table"
-msgstr ""
+msgstr "Màu của các dòng phân biệt với màu của bảng màu"
#: ../display/d.colortable/main.c:82
-#, fuzzy
msgid "Number of lines to appear in the color table"
-msgstr "Số dòng xuất hiện trong chú giải"
+msgstr "Số dòng xuất hiện trong bảng màu"
#: ../display/d.colortable/main.c:88
-#, fuzzy
msgid "Number of columns to appear in the color table"
+msgstr "Số cột xuất hiện trong bảng màu"
#: ../display/d.colortable/main.c:93
msgid "Don't draw a collar showing the NULL color in FP maps"
@@ -16542,6 +16517,8 @@
"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
"ramp"
msgstr ""
+"<%s> là một bản đồ kiểu dấu chấm động. Bỏ qua [các dòng] và vẽ thang màu "
+"liên tục"
#: ../display/d.colortable/main.c:132
#, c-format
@@ -16549,21 +16526,22 @@
"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
"ramp"
msgstr ""
+"<%s> là một bản đồ kiểu dấu chấm động. Bỏ qua các cột và vẽ thang màu liên "
+"tục"
#: ../display/d.colortable/main.c:141
-#, fuzzy, c-format
+#, c-format
msgid "R_color file for [%s] not available"
-msgstr "Tập tin màu cho [%s] không có"
+msgstr "Không có tập tin R_color dùng cho [%s]"
#: ../display/d.colortable/main.c:143
-#, fuzzy, c-format
+#, c-format
msgid "Range file for [%s] not available"
-msgstr "Tập tin phạm trù cho [%s] không có"
+msgstr "Không có tập tin miền cho [%s]"
#: ../display/d.colortable/main.c:156
-#, fuzzy
msgid "Data range is empty"
-msgstr "Miền dữ liệu từ %ld đến %ld\n"
+msgstr "Miền dữ liệu bị rỗng"
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
@@ -18471,7 +18449,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:84
#: ../vector/lidar/v.lidar.correction/main.c:79
msgid "Estimate point density and distance"
-msgstr ""
+msgstr "Ước lượng mật độ và khoảng cách điểm"
#: ../vector/lidar/v.outlier/main.c:80
#: ../vector/lidar/v.surf.bspline/main.c:96
@@ -18481,6 +18459,8 @@
"Estimate point density and distance for the input vector points within the "
"current region extends and quit"
msgstr ""
+"Ước lượng mật độ và khoảng cách điểm dùng cho các điểm vector đầu vào trong "
+"phạm vi vùng hiện tại và thoát"
#: ../vector/lidar/v.outlier/main.c:92
msgid "Name of output outlier vector map"
@@ -18503,9 +18483,8 @@
msgstr "Giá trị bước spline nội suy theo hướng bắc"
#: ../vector/lidar/v.outlier/main.c:122
-#, fuzzy
msgid "Tykhonov regularization weight"
-msgstr "Trọng số của phép chính quy hóa Tychonov"
+msgstr "Trọng số của phép chính quy hóa Tykhonov"
#: ../vector/lidar/v.outlier/main.c:129
msgid "Threshold for the outliers"
@@ -18545,7 +18524,6 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:196
#: ../vector/lidar/v.lidar.edgedetection/main.c:208
#: ../vector/lidar/v.lidar.correction/main.c:172
-#, fuzzy
msgid "Old auxiliar table could not be dropped"
msgstr "Không thể bỏ bảng phụ (auxiliar table)"
@@ -18559,22 +18537,21 @@
#: ../vector/lidar/v.outlier/main.c:186
#: ../vector/lidar/v.lidar.edgedetection/main.c:227
#: ../vector/lidar/v.lidar.correction/main.c:190
-#, fuzzy, c-format
+#, c-format
msgid "Input vector map <%s> is not 3D!"
-msgstr "Bản đồ vec-tơ <%s> không phải kiểu 3D"
+msgstr "Bản đồ vec-tơ đầu vào <%s> không phải kiểu 3D!"
#: ../vector/lidar/v.outlier/main.c:196
#: ../vector/lidar/v.surf.bspline/main.c:241
#: ../vector/lidar/v.lidar.edgedetection/main.c:237
#: ../vector/lidar/v.lidar.correction/main.c:200
-#, fuzzy
msgid "No points in current region!"
-msgstr "Chỉ dùng các điểm trong vùng hiện tại"
+msgstr "Không có điểm nào trong vùng hiện tại!"
#: ../vector/lidar/v.outlier/main.c:243
-#, fuzzy, c-format
+#, c-format
msgid "It was impossible to create <%s> table."
-msgstr "Không thể nào tạo được <%s>."
+msgstr "Không thể tạo bảng <%s>."
#: ../vector/lidar/v.outlier/main.c:276
#: ../vector/lidar/v.surf.bspline/main.c:416
@@ -18582,7 +18559,7 @@
#: ../vector/lidar/v.lidar.correction/main.c:278
#, c-format
msgid "adjusted EW splines %d"
-msgstr ""
+msgstr "các đường spline ĐT %d được điều chỉnh"
#: ../vector/lidar/v.outlier/main.c:277
#: ../vector/lidar/v.surf.bspline/main.c:417
@@ -18590,16 +18567,16 @@
#: ../vector/lidar/v.lidar.correction/main.c:279
#, c-format
msgid "adjusted NS splines %d"
-msgstr ""
+msgstr "các đường spline BN %d được điều chỉnh"
#: ../vector/lidar/v.outlier/main.c:332
#: ../vector/lidar/v.surf.bspline/main.c:485
#: ../vector/lidar/v.lidar.edgedetection/main.c:354
#: ../vector/lidar/v.lidar.growing/main.c:249
#: ../vector/lidar/v.lidar.correction/main.c:334
-#, fuzzy, c-format
+#, c-format
msgid "subregion %d of %d"
-msgstr "Số lần chạy %d trong số %d:"
+msgstr "Vùng con %d của %d"
#: ../vector/lidar/v.outlier/main.c:393
#: ../vector/lidar/v.lidar.edgedetection/main.c:417
@@ -18608,15 +18585,15 @@
msgstr "Phép nội suy song tuyến tính"
#: ../vector/lidar/v.outlier/main.c:405
-#, fuzzy
msgid "Outlier detection"
-msgstr "Màu đường viền"
+msgstr "Phát hiện giá trị ngoại biên"
#: ../vector/lidar/v.outlier/main.c:423
#: ../vector/lidar/v.lidar.edgedetection/main.c:460
#: ../vector/lidar/v.lidar.correction/main.c:429
msgid "No data within this subregion. Consider changing the spline step."
msgstr ""
+"Không có dữ liệu trong vùng con này. Hãy cân nhắc việc thay đổi bước spline."
#: ../vector/lidar/v.outlier/main.c:433
#: ../vector/lidar/v.surf.bspline/main.c:731
@@ -18634,36 +18611,32 @@
msgstr "Nội suy spline bậc ba hoặc song tuyến với phép chính quy hóa Tykhonov."
#: ../vector/lidar/v.surf.bspline/main.c:90
-#, fuzzy
msgid ""
"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
"cross validation method"
msgstr ""
-"Tìm các tham số tốt nhất bằng cách dùng một phương pháp kiểm chứng chéo"
+"Tìm tham số chính quy hoá Tykhonov tốt nhất bằng cách dùng phương pháp kiểm "
+"chứng chéo 'chừa-ra-một\""
#: ../vector/lidar/v.surf.bspline/main.c:104
msgid "Name of input vector map of sparse points"
msgstr "Tên của bản đồ vec-tơ đầu vào chứa các điểm thưa thớt"
#: ../vector/lidar/v.surf.bspline/main.c:119
-#, fuzzy
msgid "Length of each spline step in the east-west direction"
-msgstr "Giá trị bước spline nội suy theo hướng đông"
+msgstr "Chiều dài của mỗi bước spline theo hướng đông-tây"
#: ../vector/lidar/v.surf.bspline/main.c:128
-#, fuzzy
msgid "Length of each spline step in the north-south direction"
-msgstr "Giá trị bước spline nội suy theo hướng bắc"
+msgstr "Chiều dài của mỗi bước spline theo hướng bắc-nam"
#: ../vector/lidar/v.surf.bspline/main.c:135
-#, fuzzy
msgid "Spline interpolation algorithm"
-msgstr "Thuật toán tổng quát hoá"
+msgstr "Thuật toán nội suy spline"
#: ../vector/lidar/v.surf.bspline/main.c:144
-#, fuzzy
msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr "Tham số của phép chính quy hóa Tykhonov (ảnh hưởng đến độ trơn)"
#: ../vector/lidar/v.surf.bspline/main.c:150 ../vector/v.surf.rst/main.c:216
msgid "If set to 0, z coordinates are used. (3D vector only)"
@@ -18679,18 +18652,16 @@
msgstr "Chọn đầu ra kiểu vec-tơ hoặc raster, không được chọn cả hai"
#: ../vector/lidar/v.surf.bspline/main.c:175
-#, fuzzy
msgid "No raster or vector or cross-validation output"
-msgstr "Không có đầu ra raster lẫn vec-tơ"
+msgstr "Không có đầu ra raster lẫn vec-tơ hoặc kiểm chứng chéo"
#: ../vector/lidar/v.surf.bspline/main.c:229
msgid "Need either 3D vector or layer and column with z values"
-msgstr ""
+msgstr "Không có lớp véc-tơ 3D lẫn lớp có cột giá trị z"
#: ../vector/lidar/v.surf.bspline/main.c:231
-#, fuzzy
msgid "Layer but not column with z values given"
-msgstr "Cột trong bảng thuộc tính chứa giá trị cần nội suy"
+msgstr "Có lớp nhưng không có cột chứa giá trị z"
#: ../vector/lidar/v.surf.bspline/main.c:254
msgid "Cross validation didn't finish correctly"
@@ -18699,12 +18670,12 @@
#: ../vector/lidar/v.surf.bspline/main.c:260
#, c-format
msgid "Cross validation finished for sie = %f and sin = %f"
-msgstr ""
+msgstr "Phép kiểm chứng chéo kết thúc với sie = %f và sin = %f"
#: ../vector/lidar/v.surf.bspline/main.c:269
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> of sparse points will be interpolated"
-msgstr "Bản đồ vec-tơ <%s> sẽ được nội suy"
+msgstr "Bản đồ vec-tơ <%s> có các điểm phân tán sẽ được nội suy"
#: ../vector/lidar/v.surf.bspline/main.c:285
#, c-format
@@ -18740,11 +18711,12 @@
msgstr "Nội suy: Đang tạo bảng: Không thể nào tạo được bảng <%s>."
#: ../vector/lidar/v.surf.bspline/main.c:392
-#, fuzzy
msgid ""
"Cannot allocate memory for auxiliar matrix.Consider changing region "
"resolution"
-msgstr "Không thể cấp phát bộ nhớ cho chuỗi "
+msgstr ""
+"Không thể cấp phát bộ nhớ cho ma trận phụ. Hãy cân nhắc việc thay đổi độ "
+"phân giải vùng"
#: ../vector/lidar/v.surf.bspline/main.c:590
#, c-format
@@ -18756,9 +18728,8 @@
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:715
-#, fuzzy
msgid "Writing output..."
-msgstr "Đang ghi ra bản đồ..."
+msgstr "Đang ghi đầu ra..."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:77
#, c-format
@@ -18889,14 +18860,12 @@
msgstr "Không thể nào tạo được bảng nội suy <%s> trong CSDL."
#: ../vector/lidar/v.lidar.edgedetection/main.c:396
-#, fuzzy
msgid "Allocating memory for bilinear interpolation"
-msgstr "Bộ nhớ cấp phát cho phép nội suy song tuyến tính"
+msgstr "Cấp phát bộ nhớ cho phép nội suy song tuyến tính"
#: ../vector/lidar/v.lidar.edgedetection/main.c:429
-#, fuzzy
msgid "Allocating memory for bicubic interpolation"
-msgstr "Bộ nhớ cấp phát cho phép nội suy bậc ba"
+msgstr "Cấp phát bộ nhớ cho phép nội suy bậc ba"
#: ../vector/lidar/v.lidar.edgedetection/main.c:434
msgid "Bicubic interpolation"
@@ -18917,22 +18886,19 @@
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:308
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:326
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:356
-#, fuzzy
msgid "Impossible to read from aux table"
-msgstr "Không thể nào đọc được CSDL"
+msgstr "Không thể nào đọc được bảng phụ (aux table)"
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:237
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:313
-#, fuzzy
msgid "Impossible to update aux table"
-msgstr "Không thể nào cập nhật được CSDL"
+msgstr "Không thể nào cập nhật được bảng phụ (aux table)"
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:250
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:262
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:383
-#, fuzzy
msgid "Impossible to write to aux table"
-msgstr "Không thể nào ghi được CSDL"
+msgstr "Không thể nào ghi được vào bảng phụ (aux table)"
#: ../vector/lidar/lidarlib/TcholBand.c:28
msgid "Decomposition failed"
@@ -18942,9 +18908,9 @@
#: ../vector/lidar/lidarlib/raster.c:108 ../vector/lidar/lidarlib/raster.c:125
#: ../vector/lidar/lidarlib/raster.c:140 ../vector/lidar/lidarlib/raster.c:153
#: ../vector/lidar/lidarlib/raster.c:168 ../vector/lidar/lidarlib/raster.c:181
-#, fuzzy, c-format
+#, c-format
msgid "Unable to access table <%s>"
-msgstr "Không thể tạo bảng <%s>"
+msgstr "Không thể truy cập bảng <%s>"
#: ../vector/lidar/lidarlib/zones.c:413 ../vector/lidar/lidarlib/zones.c:450
#, c-format
@@ -18970,9 +18936,8 @@
"việc xây dựng bên trong"
#: ../vector/lidar/v.lidar.growing/main.c:86
-#, fuzzy
msgid "Input vector (v.lidar.edgedetection output"
-msgstr "Tên bản đồ vec-tơ quan sát đầu vào (đầu ra của v.lidar.growing)"
+msgstr "Vec-tơ đầu vào (đầu ra của v.lidar.edgedetection"
#: ../vector/lidar/v.lidar.growing/main.c:96
msgid "Name of the first pulse vector map"
@@ -18987,9 +18952,9 @@
msgstr "Ngưỡng cho xung kép trong việc làm lớn vùng"
#: ../vector/lidar/v.lidar.growing/main.c:179
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open table <%s>"
-msgstr "Không thể chép bảng <%s>"
+msgstr "Không thể mở bảng <%s>"
#: ../vector/lidar/v.lidar.growing/main.c:204
msgid "Setting regions and boxes"
@@ -19006,9 +18971,8 @@
msgstr "Cột = %d"
#: ../vector/lidar/v.lidar.growing/main.c:291
-#, fuzzy
msgid "read points in input vector"
-msgstr "Đang đọc bản đồ vec-tơđầu vào"
+msgstr "đọc các điểm trong véc-tơ đầu vào"
#: ../vector/lidar/v.lidar.growing/main.c:440
msgid "Region Growing"
@@ -19070,9 +19034,8 @@
msgstr "npoints = %d, nterrain = %d"
#: ../vector/lidar/v.lidar.correction/main.c:372
-#, fuzzy
msgid "Mean calculation"
-msgstr "Phép tính của trị trung bình"
+msgstr "Phép tính trị trung bình"
#: ../vector/lidar/v.lidar.correction/main.c:386
msgid "Only TERRAIN points"
@@ -19219,7 +19182,7 @@
#: ../vector/v.generalize/main.c:453
#, c-format
msgid "%d boundaries were deleted, input areas are not preserved"
-msgstr ""
+msgstr "% ranh giới bị xoá, các vùng đầu vào không được bảo toàn"
#: ../vector/v.generalize/main.c:476
#, c-format
@@ -19229,6 +19192,7 @@
#: ../vector/v.generalize/main.c:483
msgid "New centroids were calculated, attribute attachment may be changed"
msgstr ""
+"Các trọng tâm mới được tính toán, phép gắn thuộc tính có thể bị thay đổi"
#: ../vector/v.generalize/main.c:502
#, c-format
@@ -19239,11 +19203,12 @@
msgid ""
"Areas may have disappeared and/or area attribute attachment may have changed"
msgstr ""
+"Các vùng có thể biến mất và/hoặc phép gắn thuộc tính vùng có thể đã thay đổi"
#: ../vector/v.generalize/main.c:509
#, c-format
msgid "Try v.clean tool=prune thresh=%f"
-msgstr ""
+msgstr "Hãy thử dùng v.clean tool=prune thresh=%f"
#: ../vector/v.generalize/network.c:163
msgid "Calculating centrality measures..."
@@ -19647,7 +19612,7 @@
#: ../vector/v.in.ogr/geom.c:201 ../vector/v.in.ogr/geom.c:214
#: ../vector/v.in.ogr/geom.c:238 ../vector/v.in.ogr/geom.c:280
msgid "Skipping empty geometry feature"
-msgstr ""
+msgstr "Bỏ qua đối tượng hình học rỗng"
#: ../vector/v.in.ogr/geom.c:254
#, c-format
@@ -19817,9 +19782,9 @@
msgstr "Mục văn bản bị bỏ qua: %s"
#: ../vector/v.extract/main.c:297
-#, fuzzy, c-format
+#, c-format
msgid "Unable select records from table <%s>"
-msgstr "Không thể chọn các bản ghi từ bảng LRS: %s"
+msgstr "Không thể chọn các bản ghi từ bảng <%s>"
#: ../vector/v.extract/main.c:298
#, c-format
@@ -20472,9 +20437,8 @@
#: ../vector/v.random/main.c:102 ../vector/v.random/main.c:111
#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:128
-#, fuzzy
msgid "3D output"
-msgstr "Tạo đầu ra 3D"
+msgstr "Đầu ra 3D"
#: ../vector/v.random/main.c:109
msgid "Maximum z height (needs -z flag or column name)"
@@ -20485,11 +20449,12 @@
msgstr "Tên cột và kiểu (là INTEGER, DOUBLE PRECISION) dùng cho các giá trị z"
#: ../vector/v.random/main.c:121
-#, fuzzy
msgid ""
"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
"instead of 3D vector."
-msgstr "Ghi dữ liệu Z vào cột thay vì vào vec-tơ 3D"
+msgstr ""
+"Nếu không cung cấp kiểu thì kiểu DOUBLE PRECISION được dùng. Ghi dữ liệu Z "
+"vào cột thay vì vào véc-tơ 3D."
#: ../vector/v.random/main.c:132
msgid "Use drand48() function instead of rand()"
@@ -20510,9 +20475,9 @@
msgstr "Số lượng điểm phải > 0 (bạn cho %d)"
#: ../vector/v.random/main.c:179
-#, fuzzy, c-format
+#, c-format
msgid "Using 'double precision' for column <%s>"
-msgstr "Không thể dùng cột <%s>"
+msgstr "Dùng 'double precision' cho cột <%s>"
#: ../vector/v.random/main.c:221
msgid "Table should contain only two columns"
@@ -21878,7 +21843,7 @@
#: ../vector/v.out.ogr/main.c:313
msgid ""
"The map contains islands. To preserve them in the output map, use the -c flag"
-msgstr ""
+msgstr "Bản có chứa đảo. Để bảo tồn chúng trong bản đồ đầu ra, dùng cờ -c"
#: ../vector/v.out.ogr/main.c:343
#, c-format
@@ -22173,13 +22138,12 @@
msgstr "Lỗi trong pj_do_transform"
#: ../vector/v.hull/main.c:141
-#, fuzzy
msgid "Simple planar hulls not implemented yet"
-msgstr "Không tìm thấy vùng <%s>"
+msgstr "Chức năng bao phẳng (planar hull) chưa được thực hiện"
#: ../vector/v.hull/main.c:275
msgid "Produces a convex hull for a given vector map."
-msgstr ""
+msgstr "Tạo một bao lồi cho một bản đồ véc-tơ cho trước."
#: ../vector/v.hull/main.c:278
#: ../locale/scriptstrings/v.report_to_translate.c:5
@@ -22192,7 +22156,7 @@
#: ../vector/v.hull/main.c:279
msgid "For vector lines reads their vertices"
-msgstr ""
+msgstr "Đối với đường véc-tơ, đọc đỉnh của chúng"
#: ../vector/v.hull/main.c:286
msgid "Use all vector points (do not limit to current region)"
@@ -22203,19 +22167,18 @@
msgstr "Tạo một bao 2D 'phẳng' ngay cả khi đầu vào là các điểm 3D"
#: ../vector/v.hull/main.c:314
-#, fuzzy, c-format
+#, c-format
msgid "Error loading vector points from <%s>"
-msgstr "Lỗi khi đang nạp bản đồ điểm vec-tơ <%s>"
+msgstr "Lỗi khi đang nạp điểm véc-tơ từ <%s>"
#: ../vector/v.hull/main.c:318
-#, fuzzy
msgid "Convex hull calculation requires at least three points. Exiting."
-msgstr "Việc tính toán bao đòi hỏi ít nhất ba điểm"
+msgstr "Việc tính toán bao lồi cần có ít nhất ba điểm. Thoát lệnh."
#: ../vector/v.hull/main.c:320
-#, fuzzy, c-format
+#, c-format
msgid "%d points read from vector map <%s>"
-msgstr "%d đường được lưu trong bản đồ vec-tơ <%s@%s>"
+msgstr "Đọc %d điểm từ bản đồ vec-tơ <%>"
#: ../vector/v.in.dwg/main.c:66
msgid "Converts DWG/DXF to GRASS vector map"
@@ -22905,9 +22868,8 @@
#: ../vector/v.buffer2/main.c:167 ../vector/v.buffer2/main.c:175
#: ../vector/v.buffer2/main.c:183 ../vector/v.buffer2/main.c:189
#: ../vector/v.buffer2/main.c:197 ../vector/v.buffer2/main.c:206
-#, fuzzy
msgid "Distance"
-msgstr "Tắt"
+msgstr "Khoảng cách"
#: ../vector/v.buffer2/main.c:174
msgid "Buffer distance along minor axis in map units"
@@ -22918,9 +22880,8 @@
msgstr "Góc trục lớn tính theo độ"
#: ../vector/v.buffer2/main.c:188
-#, fuzzy
msgid "Name of column to use for buffer distances"
-msgstr "Cột thuộc tính dùng làm khoảng cách đệm"
+msgstr "Tên cột dùng làm khoảng cách đệm"
#: ../vector/v.buffer2/main.c:196 ../vector/v.buffer/main.c:286
msgid "Scaling factor for attribute column values"
@@ -22939,6 +22900,8 @@
"This is an alias to the distance option. It is retained for backwards "
"compatibility"
msgstr ""
+"Đây là một tên khác (alias) của tuỳ chọn khoảng cách. Nó được giữ lại chỉ "
+"nhằm mục đích tương thích ngược"
#: ../vector/v.buffer2/main.c:223 ../vector/v.buffer/main.c:271
msgid "Buffer distance in map units"
@@ -22972,11 +22935,12 @@
"The buffer option has been replaced by the distance option and will be "
"removed in future."
msgstr ""
+"Tuỳ chọn đệm đã được thay thế bằng tuỳ chọn khoảng cách và sau này sẽ được "
+"loại bỏ."
#: ../vector/v.buffer2/main.c:258
-#, fuzzy
msgid "Use the distance option instead of the buffer option."
-msgstr "Dùng radian thay vì dùng độ để chỉ góc xoay"
+msgstr "Dùng tuỳ chọn khoảng cách thay vì tuỳ chọn đệm."
#: ../vector/v.buffer2/main.c:262
#, c-format
@@ -23465,9 +23429,9 @@
msgstr "Không thể mở tập tin chứa tọa độ <%s>"
#: ../vector/v.transform/main.c:311
-#, fuzzy, c-format
+#, c-format
msgid "Unable to tokenize column string: [%s]"
-msgstr "Không thể chia chuỗi cột: %s"
+msgstr "Không thể thẻ hoá chuỗi cột: [%s]"
#: ../vector/v.transform/main.c:338
#, c-format
@@ -24258,14 +24222,12 @@
msgstr "%d đường được gán nhãn."
#: ../vector/v.delaunay2/main.c:141
-#, fuzzy
msgid "no points to triangulate"
-msgstr "Số điểm cần cấp phát"
+msgstr "không có điểm để chạy phép tính tam giác"
#: ../vector/v.delaunay2/main.c:149
-#, fuzzy
msgid "Delaunay triangulation..."
-msgstr "Các tính toán bề mặt sơ bộ..."
+msgstr "Phép tam giác Delaunay..."
#: ../vector/v.delaunay2/main.c:152
#, fuzzy
@@ -24273,9 +24235,8 @@
msgstr "Đang ghi các đỉnh..."
#: ../vector/v.delaunay2/main.c:162
-#, fuzzy
msgid "Calculate area centroids..."
-msgstr "Không thể tính trọng tâm vùng."
+msgstr "Tính trọng tâm vùng..."
#: ../vector/v.delaunay2/main.c:172 ../vector/v.category/main.c:263
msgid "Unable to calculate area centroid"
@@ -24845,6 +24806,8 @@
"Could not close attribute table. The DBMI driver did not accept all "
"attributes"
msgstr ""
+"Không thể đóng bảng thuộc tính. Trình điều khiển DBMI không chấp nhận tất cả "
+"các thuộc tính"
#: ../vector/v.external/main.c:60
msgid "Creates a new vector as a read-only link to OGR layer."
@@ -25202,19 +25165,16 @@
msgstr "Đệm vùng..."
#: ../vector/v.buffer/main.c:644 ../vector/v.buffer/main.c:734
-#, fuzzy
msgid "Calculating centroids for areas..."
-msgstr "Đang tính các số đo độ trung tâm..."
+msgstr "Đang tính trong tâm cho các vùng..."
#: ../vector/v.buffer/main.c:686
-#, fuzzy
msgid "Generating list of boundaries to be deleted..."
-msgstr "Đang làm sạch ranh giới tại các nốt..."
+msgstr "Đang tạo danh sách các ranh giới cần xoá..."
#: ../vector/v.buffer/main.c:718
-#, fuzzy
msgid "Deleting boundaries..."
-msgstr "Đang ngắt các ranh giới..."
+msgstr "Đang xoá các ranh giới..."
#: ../vector/v.edit/main.c:55
msgid "vector, editing, geometry"
@@ -32633,13 +32593,12 @@
#~ msgid "No lines found, skipping type=line"
#~ msgstr "Không tìm thấy đường, bỏ qua type=line"
-#, fuzzy
#~ msgid ""
#~ "No vector map of sparse points to interpolate was specified. "
#~ "Interpolation will be done with <%s> vector map"
#~ msgstr ""
-#~ "Không có bản đồ vector để nội suy. Phép nội suy sẽ được thực hiện với bản "
-#~ "đồ <%s>"
+#~ "Bản đồ véc-tơ với các điểm phân tán để nội suy không được chỉ định. Phép "
+#~ "nội suy sẽ được thực hiện với bản đồ véc-tơ <%s>"
#~ msgid "Failed in attempt to open %s"
#~ msgstr "Thất bại trong việc mở %s"
@@ -32740,15 +32699,14 @@
#~ msgid "Name for output raster map with lake"
#~ msgstr "Tên của bản đồ raster đầu ra với hồ"
-#, fuzzy
#~ msgid ""
#~ "Input raster map contains cells with NULL-value (no-data). The value %f "
#~ "will be used to represent no-data values in the input map. You can "
#~ "specify a nodata value with the %s option."
#~ msgstr ""
-#~ "Bản đồ raster đầu vào chứa các ô với giá trị RỖNG (không có dữ liệu). Giá "
-#~ "trị %d được dùng để biểu thị các giá trị không có dữ liệu trong bản đồ "
-#~ "đầu vào. Bạn có thể chỉ định giá trị không dữ liệu bằng tham số %s."
+#~ "Bản đồ raster đầu vào chứa các ô với giá trị RỖNG (không-dữ-liệu). Giá "
+#~ "trị %f được dùng để biểu thị các giá trị không có dữ liệu trong bản đồ "
+#~ "đầu vào. Bạn có thể chỉ định giá trị không dữ liệu bằng tuỳ chọn %s."
#~ msgid "Name of the elevation raster map [m]"
#~ msgstr "Tên của bản đồ raster độ cao [m]"
@@ -36513,9 +36471,8 @@
#~ msgid "Illegal configuration file"
#~ msgstr "Tập tin cấu hình không hợp lệ"
-#, fuzzy
#~ msgid "Range to be exported: %f - %f"
-#~ msgstr "Tập tin raster cần nhập"
+#~ msgstr "Miền cần xuất: %f - %f"
#~ msgid "(i) Basin map created by r.water.outlet (MASK)"
#~ msgstr "(i) Bản đồ lưu vực được tạo ra bởi r.water.outlet (MẶT NẠ)"
@@ -36640,9 +36597,8 @@
#~ msgid "vector, query"
#~ msgstr "vector, truy vấn"
-#, fuzzy
#~ msgid "Writing edges..."
-#~ msgstr "Đang ghi các đỉnh..."
+#~ msgstr "Đang ghi các gờ..."
#~ msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
#~ msgstr ""
@@ -37039,3 +36995,35 @@
#~ msgid "Column name (will be updated by qvector values)"
#~ msgstr "Tên cột (sẽ được cập nhật bởi các giá trị qvector (truy vấn vector)"
+#~ msgid "Checking GDAl data type and nodata value"
+#~ msgstr "Kiểm tra kiểu dữ liệu GDAL và giá trị không-dữ-liệu"
+#~ msgid ""
+#~ "Mismatch between metadata nodata value and actual nodata value in "
+#~ "exported raster: specified nodata value %f gets converted to %d by "
+#~ "selected GDAL datatype."
+#~ msgstr ""
+#~ "Giá trị không-dữ-liệu trong đặc tả dữ liệu và giá trị không-dữ-liệu thực "
+#~ "trong raster xuất ra không khớp nhau: giá trị không-dữ-liệu đã chỉ định %"
+#~ "f bị kiểu dữ liệu GDAL đã chọn chuyển thành %d."
+#~ msgid "Default value: GRASS_GUI if defined otherwise tcltk"
+#~ msgstr ""
+#~ "Giá trị mặc định: GRASS_GUI nếu được định nghĩa, nếu không dùng tcltk"
+#~ msgid ""
+#~ "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based "
+#~ "GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;"
+#~ "text;command line interface only"
+#~ msgstr ""
+#~ "tcltk;GDĐH dựa trên cơ sở Tcl/Tk - Trình Quản lý GIS (gis.m);oldtcltk;"
+#~ "GDĐH dựa trên Tcl/Tk kiểu cũ - Bộ Quản lý Trình bày (d.m);wxpython;GDĐH "
+#~ "thế hệ sau này dựa trên wxPython;text;giao diện chỉ có dòng lệnh"
+#~ msgid ""
+#~ "Output long/lat in decimal degrees or other projections with many decimal "
+#~ "places"
+#~ msgstr ""
+#~ "Xuất ra kinh/vĩ dạng độ thập phân hoặc các phép chiếu khác có nhiều chữ "
+#~ "số thập phân"
Modified: grass/branches/develbranch_6/locale/po/grasstcl_vi.po
--- grass/branches/develbranch_6/locale/po/grasstcl_vi.po 2010-08-30 04:45:43 UTC (rev 43346)
+++ grass/branches/develbranch_6/locale/po/grasstcl_vi.po 2010-08-30 04:46:16 UTC (rev 43347)
@@ -3,19 +3,19 @@
# Copyright (C) 2005, GRASS Development Team
# Markus Neteler <neteler at itc.it>, 2006.
msgid ""
msgstr ""
"Project-Id-Version: grasstcl_vi\n"
-"PO-Revision-Date: 2009-09-11 23:33+0700\n"
#: ../vector/v.digit/cats.tcl:20 ../gui/tcltk/gis.m/gmmenu.tcl:178
@@ -707,11 +707,11 @@
#: ../lib/init/gis_set.tcl:549
msgid "Exit"
-msgstr "T&hoát"
+msgstr "Thoát"
#: ../lib/init/gis_set.tcl:583
msgid "Starting GRASS for the first time"
-msgstr ""
+msgstr "Đang khởi động GRASS lần đầu tiên"
#: ../lib/init/gis_set.tcl:584
msgid ""
@@ -719,11 +719,12 @@
"have not already done so. A popular choice is \"grassdata\", located in "
"your home directory."
msgstr ""
+"GRASS cần một thư mục để lưu trữ dữ liệu. Tạo một thư mục ngay nếu bạn chưa "
+"làm. Tên thường được dùng là \"grassdata\", nằm trong thư mục nhà của bạn."
#: ../lib/init/gis_set.tcl:589
-#, fuzzy
msgid "Select GIS data directory"
-msgstr "Thư mục dữ liệu GIS mới"
+msgstr "Chọn thư mục dữ liệu GIS"
#: ../lib/init/gis_set.tcl:594
msgid "WARNING: Invalid Database"
@@ -900,9 +901,8 @@
đối với vùng < 10.000 ô"
#: ../gui/tcltk/gis.m/rastnums.tcl:279
-#, fuzzy
msgid "Constrain map to region geometry?"
-msgstr "Hạn chế bản đồ theo hình học của vùng"
+msgstr "Giới hạn bản đồ theo hình học của vùng?"
#: ../gui/tcltk/gis.m/rastnums.tcl:280
msgid ""
@@ -912,6 +912,10 @@
"\n"
" It's suggested to constrain map to region geometry to display cell values."
msgstr ""
+"Giá trị ô chỉ có thể được trình bày cho \n"
+"những vùng < 10.000 ô. Bản đồ đang khảo sát có thể có nhiều hơn 10.000 ô.\n"
+"\n"
+" Đề nghị bạn giới hạn bản đồ trong hình học vùng để hiển thị các giá trị ô."
#: ../gui/tcltk/gis.m/rastnums.tcl:282 ../gui/tcltk/gis.m/maptool.tcl:327
msgid "Constrain map to region geometry"
@@ -919,7 +923,7 @@
msgid "Leave in explore mode"
-msgstr ""
+msgstr "Để ở chế độ khảo sát"
#: ../gui/tcltk/gis.m/raster.tcl:127
msgid "Raster drape map"
@@ -931,7 +935,7 @@
#: ../gui/tcltk/gis.m/vector.tcl:245 ../gui/tcltk/gis.m/vector.tcl:267
#: ../gui/tcltk/gis.m/vector.tcl:300
msgid "This action requires map name to be set"
-msgstr ""
+msgstr "Lệnh này yêu càu tên bản đồ phải được thiết lập"
#: ../gui/tcltk/gis.m/raster.tcl:177
msgid "Display raster maps"
@@ -1477,7 +1481,6 @@
msgstr "bậc 2"
#: ../gui/tcltk/gis.m/georect.tcl:1020
-#, fuzzy
msgid "polynomial transformation (rasters only). Requires 6+ GCPs."
msgstr "chuyển đổi đa thức (chỉ dùng cho raster). Cần 6+ điểm khống chế."
@@ -1693,7 +1696,7 @@
#: ../gui/tcltk/gis.m/dnviz.tcl:177
msgid "Camera layback "
-msgstr ""
+msgstr "Độ lùi của máy quay "
#: ../gui/tcltk/gis.m/dnviz.tcl:178
msgid "Camera layback distance (in map units)"
@@ -1732,9 +1735,8 @@
msgstr "Vẽ lại đầy đủ (lưu các ảnh)"
#: ../gui/tcltk/gis.m/dnviz.tcl:203
-#, fuzzy
msgid "Render images offscreen"
-msgstr "Kết xuất ảnh không hiển thị trên màn hình"
+msgstr "Kết xuất ảnh ngoài màn hình"
#: ../gui/tcltk/gis.m/dnviz.tcl:215
msgid "Height value is elevation"
@@ -1867,7 +1869,7 @@
#: ../gui/tcltk/gis.m/vector.tcl:251 ../gui/tcltk/gis.m/vector.tcl:273
#: ../gui/tcltk/gis.m/vector.tcl:306
msgid "You must provide valid vector layer number"
-msgstr ""
+msgstr "Bạn phải cung cấp số hiệu lớp véc-tơ hợp lệ"
#: ../gui/tcltk/gis.m/thematic.tcl:218 ../gui/tcltk/gis.m/vector.tcl:317
msgid "Vector point symbol"
@@ -2389,9 +2391,8 @@
msgstr "Miền độ cao 0"
#: ../gui/tcltk/gis.m/profile.tcl:539
-#, fuzzy
msgid "Error reading region values"
-msgstr "Lỗi thiết lập vùng"
+msgstr "Lỗi đọc các giá trị vùng"
#: ../gui/tcltk/gis.m/profile.tcl:563 ../gui/tcltk/gis.m/profile.tcl:648
msgid "r.profile error"
@@ -2744,9 +2745,8 @@
msgstr "Đặt lại tên"
#: ../gui/tcltk/gis.m/gmmenu.tcl:179
-#, fuzzy
msgid "Delete filtered"
-msgstr "Xóa dữ liệu được lọc"
+msgstr "Xóa phần được lọc"
#: ../gui/tcltk/gis.m/gmmenu.tcl:181 ../gui/tcltk/d.m/menu.tcl:159
msgid "Map type conversions"
@@ -2797,7 +2797,6 @@
msgstr "Kết xuất 3D"
#: ../gui/tcltk/gis.m/gmmenu.tcl:200
-#, fuzzy
msgid "NVIZ"
msgstr "NVIZ"
@@ -2861,7 +2860,7 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:219 ../gui/tcltk/d.m/menu.tcl:200
msgid "Change default GUI"
-msgstr ""
+msgstr "Thay đổi GDĐH mặc định"
#: ../gui/tcltk/gis.m/gmmenu.tcl:220 ../gui/tcltk/d.m/menu.tcl:201
msgid "Show current GRASS version"
@@ -2886,7 +2885,7 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:230 ../gui/tcltk/d.m/menu.tcl:221
msgid "&Raster"
-msgstr ""
+msgstr "&Raster"
#: ../gui/tcltk/gis.m/gmmenu.tcl:231 ../gui/tcltk/gis.m/gmmenu.tcl:434
#: ../gui/tcltk/d.m/menu.tcl:222 ../gui/tcltk/d.m/menu.tcl:381
@@ -2946,7 +2945,6 @@
msgstr "Quy chiếu lại"
#: ../gui/tcltk/gis.m/gmmenu.tcl:254
-#, fuzzy
msgid "Tiling"
msgstr "'Lát' ảnh"
@@ -3797,9 +3795,8 @@
msgstr "Gộp nhóm đầu vào dùng cho phân loại không hướng dẫn"
#: ../gui/tcltk/gis.m/gmmenu.tcl:570 ../gui/tcltk/d.m/menu.tcl:501
-#, fuzzy
msgid "Maximum likelihood classification (MLC)"
-msgstr "Phép phân loại Giống nhau tối đa (MLC)"
+msgstr "Phép Phân loại Giống nhau Tối đa (MLC)"
#: ../gui/tcltk/gis.m/gmmenu.tcl:571 ../gui/tcltk/d.m/menu.tcl:502
msgid "Sequential maximum a posteriory classification (SMAP)"
@@ -4321,9 +4318,8 @@
msgstr " Lớp gán nhãn"
#: ../gui/tcltk/gis.m/vector.tcl:494
-#, fuzzy
msgid " Attribute column for labels"
-msgstr "Cột thuộc tính làm nhãn"
+msgstr " Cột thuộc tính làm nhãn"
#: ../gui/tcltk/gis.m/vector.tcl:501
msgid "Query vectors for display: "
@@ -4739,9 +4735,8 @@
msgstr "Đạt mức phóng đại tối đa"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:660
-#, fuzzy
msgid "Error setting region 1"
+msgstr "Lỗi thiết lập vùng 1"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:669
msgid "please wait..."
@@ -4777,14 +4772,14 @@
Bạn có muốn ghi đè?"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:1296
-#, fuzzy, tcl-format
+#, tcl-format
msgid "Display: rows=%d cols=%d N-S res=%s E-W res=%s"
-msgstr "Trình bày: hàng=%d cột=%d độ.p.giải B-N=%g độ.p.giải=%g"
+msgstr "Trình bày: hàng=%d cột=%d độ.p.giải B-N=%s độ.p.giải=%s"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:1299
+#, tcl-format
msgid "Display: rows=%d cols=%d N-S res=%g E-W res=%g"
+msgstr "Trình bày: hàng=%d cột=%d độ.p.giải B-N=%g độ.p.giải Đ-T=%g"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:1374
msgid "Error setting region (Problem with g.region?)"
@@ -4795,9 +4790,8 @@
msgstr "Lỗi đọc độ phân giải hiện tại bằng g.region"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:1477
-#, fuzzy
msgid "Error setting region 2"
+msgstr "Lỗi thiết lập vùng 2"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:1940
msgid "Measurement"
@@ -5113,7 +5107,7 @@
#: ../gui/tcltk/d.m/gridline.tcl:92
msgid " "
-msgstr ""
+msgstr " "
#: ../gui/tcltk/d.m/gridline.tcl:93
msgid "draw grid border"
@@ -6186,7 +6180,6 @@
msgstr "Đầu vào không tương tác cho phân loại có hướng dẫn (SMAP)"
#: ../gui/tcltk/d.m/menu.tcl:509
-#, fuzzy
msgid "Zero edge crossing detection"
msgstr "Phát hiện bắt chéo mép 0"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_vi.po 2010-08-30 04:45:43 UTC (rev 43346)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_vi.po 2010-08-30 04:46:16 UTC (rev 43347)
@@ -2,26 +2,25 @@
# This file is distributed under the same license as the GRASS package.
-# Lê Quốc Thái <lquocthai (A) ioit (D) ac (D) vn>, 2009.
+# Lê Quốc Thái <lquocthai (A) ioit (D) ac (D) vn>, 2009, 2010.
msgid ""
msgstr ""
"Project-Id-Version: grasswxpy_vi\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-08-29 12:20+0200\n"
-"PO-Revision-Date: 2009-09-11 15:29+0700\n"
+"PO-Revision-Date: 2010-08-27 16:40+0700\n"
"Last-Translator: \n"
-"Language-Team: American English <kde-i18n-doc at lists.kde.org>\n"
+"Language-Team: American English <kde-i18n-doc at kde.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Poedit-Bookmarks: 569,706,675,-1,-1,-1,-1,-1,-1,-1\n"
-"X-Generator: Lokalize 0.2\n"
+"X-Generator: Lokalize 1.0\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../gui/wxpython/wxgui.py:99
-#, fuzzy
msgid "GRASS GIS Layer Manager"
-msgstr "Bộ Quản Lý Bảng Thuộc Tính của GRASS GIS"
+msgstr "Bộ Quản lý Lớp của GRASS GIS"
#: ../gui/wxpython/wxgui.py:211
#, fuzzy
@@ -81,9 +80,9 @@
msgstr "Bạn có muốn lưu thiết lập hiện tại vào tệp không gian làm việc?"
#: ../gui/wxpython/wxgui.py:355
-#, fuzzy, python-format
+#, python-format
msgid "Close Map Display %d"
-msgstr "Đóng màn hình"
+msgstr "Đóng trình bày màn hình %d"
#: ../gui/wxpython/wxgui.py:431
#, fuzzy
@@ -169,7 +168,7 @@
#: ../gui/wxpython/wxgui.py:473 ../gui/wxpython/wxgui.py:489
#: ../gui/wxpython/gui_modules/ghelp.py:561
msgid "Info"
-msgstr ""
+msgstr "T.tin"
#: ../gui/wxpython/wxgui.py:484
@@ -216,7 +215,6 @@
msgstr "Xin chờ, đang nạp không gian làm việc..."
#: ../gui/wxpython/wxgui.py:719 ../gui/wxpython/menustrings.py:15
-#, fuzzy
msgid "Load map layers into layer tree"
msgstr "Nạp các lớp bản đồ vào sơ đồ lớp hình cây"
@@ -390,13 +388,12 @@
msgstr "Phóng đến bản đồ đã chọn"
#: ../gui/wxpython/icons/icon.py:168
-#, fuzzy
msgid "Add map elements"
-msgstr "Thêm chú giải"
+msgstr "Thêm thành phần bản đồ"
#: ../gui/wxpython/icons/icon.py:169
msgid "Overlay elements like scale and legend onto map"
-msgstr ""
+msgstr "Chồng các thành phần như tỷ lệ và chú giải lên bản đồ"
#: ../gui/wxpython/icons/icon.py:171
msgid "Add scalebar and north arrow"
@@ -407,9 +404,8 @@
#: ../gui/wxpython/icons/icon.py:175
-#, fuzzy
msgid "Save display to graphic file"
-msgstr "Lưu trình bày ra tập tin PNG"
+msgstr "Lưu trình bày ra tập tin đồ hoạ"
#: ../gui/wxpython/icons/icon.py:177
#: ../gui/wxpython/gui_modules/histogram.py:434
@@ -492,7 +488,6 @@
msgstr "Thêm lớp bản đồ đổ bóng"
#: ../gui/wxpython/icons/icon.py:212
-#, fuzzy
msgid "Add raster flow arrows"
msgstr "Thêm mũi tên dòng chảy raster"
@@ -1065,9 +1060,8 @@
#: ../gui/wxpython/menustrings.py:18 ../gui/wxpython/menustrings.py:19
#: ../gui/wxpython/gui_modules/gdialogs.py:1098
-#, fuzzy
msgid "Import raster data"
-msgstr "Nhập bản đồ raster"
+msgstr "Nhập dữ liệu raster"
#: ../gui/wxpython/menustrings.py:20
msgid "Import GDAL supported raster file into a binary raster map layer."
@@ -1076,22 +1070,18 @@
"phân."
#: ../gui/wxpython/menustrings.py:21
-#, fuzzy
msgid "Bulk import of raster data"
+msgstr "Nhập một lúc nhiều dữ liệu raster"
#: ../gui/wxpython/menustrings.py:22
-#, fuzzy
msgid "Converts multiple GDAL supported layers to GRASS raster maps."
msgstr ""
-"Chuyển đổi lớp GDAL được chọn thành các bản đồ raster của GRASS bằng cách "
-"dùng r.in.gdal"
+"Chuyển đổi nhiều lớp được GDAL hỗ trợ thành các bản đồ raster của GRASS."
#: ../gui/wxpython/menustrings.py:23
#: ../gui/wxpython/gui_modules/gdialogs.py:1096
-#, fuzzy
msgid "Link raster data"
-msgstr "Đang nạp bản đồ raster"
+msgstr "Liên kết dữ liệu raster"
#: ../gui/wxpython/menustrings.py:24
msgid "Link GDAL supported raster file to a binary raster map layer."
@@ -1099,16 +1089,15 @@
"Nối tập tin raster được GDAL hỗ trợ với một lớp bản đồ raster nhị phân."
#: ../gui/wxpython/menustrings.py:25
-#, fuzzy
msgid "Bulk link of raster data"
-msgstr "Đặc tả dữ liệu raster cơ bản"
+msgstr "Liên kết một lúc nhiều dữ liệu raster"
#: ../gui/wxpython/menustrings.py:26
-#, fuzzy
msgid ""
"Link multiple GDAL supported raster maps as pseudo GRASS raster map layers."
msgstr ""
-"Nối tập tin raster được GDAL hỗ trợ với một lớp bản đồ raster nhị phân."
+"Liên kết nhiều raster được GDAL hỗ trợ vào thành các lớp bản đồ raster giả "
+"GRASS."
#: ../gui/wxpython/menustrings.py:27
msgid "Aggregate ASCII xyz import"
@@ -1217,21 +1206,18 @@
#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:50
#: ../gui/wxpython/gui_modules/gdialogs.py:1092
-#, fuzzy
msgid "Import vector data"
-msgstr "Nhập bản đồ véc tơ"
+msgstr "Nhập dữ liệu véc-tơ"
#: ../gui/wxpython/menustrings.py:51
msgid "Convert OGR vector layers to GRASS vector map."
msgstr "Chuyển đổi các lớp vec-tơ OGR thành bản đồ vec-tơ GRASS."
#: ../gui/wxpython/menustrings.py:52
-#, fuzzy
msgid "Bulk import of vector data"
+msgstr "Nhập một lúc nhiều dữ liệu véc-tơ"
#: ../gui/wxpython/menustrings.py:53
-#, fuzzy
msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
msgstr ""
"Chuyển đổi các lớp OGR được chọn thành các bản đồ vec-tơ của GRASS bằng cách "
@@ -1239,23 +1225,21 @@
#: ../gui/wxpython/menustrings.py:54
#: ../gui/wxpython/gui_modules/gdialogs.py:1090
-#, fuzzy
msgid "Link vector data"
-msgstr "Mô tả cơ bản dữ liệu vec-tơ"
+msgstr "Liên kết dữ liệu vec-tơ"
#: ../gui/wxpython/menustrings.py:55
msgstr "Tạo một bản đồ vec-tơ mới ở dạng chỉ đọc liên kết vào lớp OGR."
#: ../gui/wxpython/menustrings.py:56
-#, fuzzy
msgid "Bulk link of vector data"
+msgstr "Liên kết một lúc nhiều dữ liệu vec-tơ"
#: ../gui/wxpython/menustrings.py:57
-#, fuzzy
msgid "Creates multiple new pseduo-vector maps as a read-only links using OGR."
-msgstr "Tạo một bản đồ vec-tơ mới ở dạng chỉ đọc liên kết vào lớp OGR."
+msgstr ""
+"Tạo nhiều bản đồ vec-tơ giả mới ở dạng liên kết chỉ đọc bằng cách dùng OGR."
#: ../gui/wxpython/menustrings.py:58
msgid "ASCII points/GRASS ASCII vector import"
@@ -1294,13 +1278,11 @@
#: ../gui/wxpython/menustrings.py:66
msgid "Bulk import of DXF"
-msgstr ""
+msgstr "Nhập một lúc nhiều DXF"
#: ../gui/wxpython/menustrings.py:67
-#, fuzzy
msgid "Converts multiple DXF layers to GRASS vector maps."
-msgstr ""
-"Chuyển đổi các lớp DXF được chọn thành bản đồ vec-tơ GRASS (dùng v.in.dxf)."
+msgstr "Chuyển đổi nhiều lớp DXF thành bản đồ vec-tơ GRASS."
#: ../gui/wxpython/menustrings.py:68
msgid "ESRI e00 import"
@@ -1366,9 +1348,8 @@
msgstr "Nhập các bản đồ vec-tơ MapGen và Matlab"
#: ../gui/wxpython/menustrings.py:80
-#, fuzzy
msgid "Import 3D raster data"
+msgstr "Nhập dữ liệu raster 3D"
#: ../gui/wxpython/menustrings.py:81
msgid "ASCII 3D import"
@@ -1409,14 +1390,12 @@
msgstr "Xuất bản đồ raster"
#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:120
-#, fuzzy
msgid "Common export formats"
-msgstr "Chuyển đổi tọa độ"
+msgstr "Các định dạng xuất phổ biến"
#: ../gui/wxpython/menustrings.py:90
-#, fuzzy
msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr "Xuất bản đồ raster của GRASS thhành các định dạng được GDAL hỗ trợ."
+msgstr "Xuất cá bản đồ raster của GRASS thành các định dạng được GDAL hỗ trợ."
#: ../gui/wxpython/menustrings.py:91
msgid "ASCII grid export"
@@ -1582,11 +1561,10 @@
msgstr "Xuất nhiều loại định dạng GPS bằng cách dùng GPSBabel"
#: ../gui/wxpython/menustrings.py:127
-#, fuzzy
msgid ""
"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
msgstr ""
-"Xuất một bản đồ véc tơ ra GPS hoặc định dạng tệp tin được GPSBabel hỗ trợ."
+"Xuất một bản đồ véc-tơ ra GPS hoặc định dạng tập tin được GPSBabel hỗ trợ."
#: ../gui/wxpython/menustrings.py:129
msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
@@ -1605,9 +1583,8 @@
msgstr "Chuyển một bản đồ vec-tơ nhị phân GRASS thành đầu ra VTK ASCII."
#: ../gui/wxpython/menustrings.py:134
-#, fuzzy
msgid "Export 3D raster maps"
-msgstr "Xuất bản đồ raster"
+msgstr "Xuất bản đồ raster 3D"
#: ../gui/wxpython/menustrings.py:135
msgid "ASCII 3D export"
@@ -1638,9 +1615,8 @@
msgstr "Xuất nhiều loại định dạng bằng cách dùng OGR"
#: ../gui/wxpython/menustrings.py:143
-#, fuzzy
msgid "Exports attribute tables into various formats."
-msgstr "Xuất các bảng thuộc tính ở nhiều định dạng."
+msgstr "Xuất các bảng thuộc tính ra nhiều định dạng khác nhau."
#: ../gui/wxpython/menustrings.py:144
msgid "Manage maps and volumes"
@@ -1737,10 +1713,10 @@
msgstr "Vector thành raster"
#: ../gui/wxpython/menustrings.py:165
-#, fuzzy
msgid "Converts a binary GRASS vector map into a GRASS raster map ."
msgstr ""
-"Chuyển đổi một lớp bản đồ vec-tơ GRASS thành một lớp bản đồ raster của GRASS."
+"Chuyển đổi một bản đồ vec-tơ GRASS nhị phân thành một bản đồ raster của "
+"GRASS."
#: ../gui/wxpython/menustrings.py:166
msgid "Vector to volume"
@@ -1800,9 +1776,8 @@
msgstr "NVIZ (cần có Tcl/Tk)"
#: ../gui/wxpython/menustrings.py:181
-#, fuzzy
msgid "nviz - Visualization and animation tool for GRASS data."
-msgstr "nviz - Công cụ xem và tạo ảnh động cho dữ liệu GRASS"
+msgstr "nviz - Công cụ xem và tạo ảnh động cho dữ liệu GRASS."
#: ../gui/wxpython/menustrings.py:182
#, fuzzy
@@ -1822,6 +1797,8 @@
"A simple utility for converting bearing and distance measurements to "
"coordinates and vice versa."
msgstr ""
+"Một tiện ích đơn giản dùng để chuyển đổi các số đo hướng và khoảng cách "
+"thành toạ độ và ngược lại."
#: ../gui/wxpython/menustrings.py:186
msgid "Postscript plot"
@@ -1938,13 +1915,13 @@
msgstr "Thay đổi các thiết lập"
#: ../gui/wxpython/menustrings.py:215
-#, fuzzy
-msgstr "Thiết lập làm &mặc định"
#: ../gui/wxpython/menustrings.py:216
msgid "Changes the default GRASS graphical user interface (GUI) setting."
msgstr ""
+"Thay đổi thiết lập mặc định của giao diện người dùng đồ hoạ (GUI) của GRASS."
#: ../gui/wxpython/menustrings.py:217
msgid "Version"
@@ -1974,14 +1951,12 @@
msgstr "Quản lý các phép chiếu"
#: ../gui/wxpython/menustrings.py:223
-#, fuzzy
msgid ""
msgstr ""
"Chuyển đổi các mô tả hệ tọa độ (tức là thông tin phép chiếu) giữa các định "
-"dạng khác nhau (kể cả định dạng của GRASS). Cũng có thể dùng để tạo vị trí "
-"GRASS."
#: ../gui/wxpython/menustrings.py:224
#, fuzzy
@@ -1990,7 +1965,7 @@
#: ../gui/wxpython/menustrings.py:225
-msgstr ""
+msgstr "Tái lập lại (có tương tác) các thiết lập phép chiếu của location."
#: ../gui/wxpython/menustrings.py:226
msgid "Convert coordinates"
@@ -2038,6 +2013,9 @@
"Interactive tool used to draw and save vector features on a graphics monitor "
"using a pointing device (mouse) and save to a raster map."
msgstr ""
+"Công cụ chạy ở chế độ tương tác dùng để vẽ và lưu các đối tượng véc-tơ trên "
+"một màn hình đồ hoạ bằng cách dùng thiết bị trỏ (chuột) và lưu vào một bản "
+"đồ raster."
#: ../gui/wxpython/menustrings.py:236
msgid "Compress/decompress"
@@ -2061,7 +2039,7 @@
#: ../gui/wxpython/menustrings.py:241
msgid "Manages NULL-values of given raster map."
-msgstr ""
+msgstr "Quản lý các giá trị RỖNG của một bản đồ raster."
#: ../gui/wxpython/menustrings.py:242
msgid "Quantization"
@@ -2084,19 +2062,20 @@
msgstr "Thu mẫu lại bằng cách dùng thống kê tổng hợp"
#: ../gui/wxpython/menustrings.py:247
-#, fuzzy
msgid "Resamples raster map layers to a coarser grid using aggregation."
msgstr ""
-"Thu mẫu lại các lớp bản đồ raster bằng cách dùng phép gộp (aggregation)."
+"Thu mẫu lại các lớp bản đồ raster thành một lưới thưa hơn bằng cách dùng "
+"phép gộp."
#: ../gui/wxpython/menustrings.py:248
msgid "Resample using multiple methods"
msgstr "Lấy mẫu lại bằng cách dùng các phương pháp khác"
#: ../gui/wxpython/menustrings.py:249
-#, fuzzy
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr "Lấy mẫu lại các lớp bản đồ raster bằng cách dùng phép nội suy"
+msgstr ""
+"Lấy mẫu lại các lớp bản đồ raster thành một lưới mịn hơn bằng cách dùng phép "
+"nội suy."
#: ../gui/wxpython/menustrings.py:250
msgid "Resample using nearest neighbor"
@@ -2195,11 +2174,11 @@
msgstr "Tạo RGB"
#: ../gui/wxpython/menustrings.py:272
-#, fuzzy
msgid ""
"Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
-"Tổ hợp các lớp bản đồ đỏ, lục và xxanh thành một lớp bản đồ tổ hợp duy nhất."
+"Kết hợp các lớp bản đồ đỏ, lục và xanh thành một lớp bản đồ raster tổ hợp "
+"duy nhất."
#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:677
msgid "RGB to HIS"
@@ -2215,14 +2194,12 @@
"định."
#: ../gui/wxpython/menustrings.py:275
-#, fuzzy
msgid "Query raster maps"
-msgstr "Chồng các bản đồ raster"
+msgstr "Truy vấn các bản đồ raster"
#: ../gui/wxpython/menustrings.py:276
-#, fuzzy
msgid "Query values by coordinates"
-msgstr "Truy vấn theo tọa độ"
+msgstr "Truy vấn giá trị theo tọa độ"
#: ../gui/wxpython/menustrings.py:277
msgid "Queries raster map layers on their category values and category labels."
@@ -2231,14 +2208,12 @@
"chúng."
#: ../gui/wxpython/menustrings.py:278
-#, fuzzy
msgid "Query colors by value"
-msgstr "Đặt bảng màu"
+msgstr "Truy vấn màu theo giá trị"
#: ../gui/wxpython/menustrings.py:279
-#, fuzzy
msgid "Queries colors for a raster map layer."
-msgstr "Báo cáo thống kê dùng cho các lớp bản đồ raster"
+msgstr "Truy cấn màu của một lớp bản đồ raster."
#: ../gui/wxpython/menustrings.py:280
msgid "Buffer rasters"
@@ -2278,9 +2253,8 @@
msgstr "Trình tính toán cho bản đồ raster 3 chiều"
#: ../gui/wxpython/menustrings.py:287
-#, fuzzy
msgid "Map calculator for raster map algebra."
-msgstr "Trình tính toán bản đồ dùng cho đại số bản đồ raster"
+msgstr "Trình tính toán bản đồ dùng cho đại số bản đồ raster."
#: ../gui/wxpython/menustrings.py:288
msgid "Neighborhood analysis"
@@ -2370,9 +2344,8 @@
msgstr "Bức xạ mặt trời"
#: ../gui/wxpython/menustrings.py:304
-#, fuzzy
msgid "Solar irradiance and irradiation model."
-msgstr "Bức xạ mặt trời"
+msgstr "Bức xạ mặt trời và mô hình bức xạ."
#: ../gui/wxpython/menustrings.py:305
msgid "Shadows map"
@@ -2411,22 +2384,20 @@
msgstr "Bề mặt chi phí"
#: ../gui/wxpython/menustrings.py:311
-#, fuzzy
msgid ""
"Creates a raster map showing the cumulative cost of moving between different "
"geographic locations on an input raster map whose cell category values "
"represent cost."
msgstr ""
-"Xuất ra một lớp bản đồ raster biểu thị chi phí tích lũy của sự di chuyển "
-"giữa các vị trí địa lý khác nhau trên một lớp bản đồ raster đầu vào có các "
-"giá trị phạm trù ô biểu thị chi phí."
+"Tạo một bản đồ raster biểu thị chi phí tích lũy của sự di chuyển giữa các vị "
+"trí địa lý khác nhau trên một lớp bản đồ raster đầu vào có các giá trị phạm "
+"trù ô biểu thị chi phí."
#: ../gui/wxpython/menustrings.py:312
msgid "Least cost route or flow"
msgstr "Lộ trình hoặc dòng chảy chi phí nhỏ nhất"
#: ../gui/wxpython/menustrings.py:313
-#, fuzzy
msgid "Traces a flow through an elevation model on a raster map."
msgstr ""
"Truy ra dòng chảy thông qua một mô hình độ cao trên một lớp bản đồ raster."
@@ -2459,9 +2430,8 @@
msgstr "Các tham số địa hình"
#: ../gui/wxpython/menustrings.py:319
-#, fuzzy
msgid "Extracts terrain parameters from a DEM."
-msgstr "Nhập các tham số cho "
+msgstr "Trích xuất các tham số địa hình từ một DEM."
#: ../gui/wxpython/menustrings.py:320
msgid "Textural features"
@@ -2506,14 +2476,12 @@
msgstr "Kết thành khối"
#: ../gui/wxpython/menustrings.py:330
-#, fuzzy
msgid ""
"Recategorizes data in a raster map by grouping cells that form physically "
"discrete areas into unique categories."
msgstr ""
-"Phân loại lại phạm trù của dữ liệu trong một lớp bản đồ raster bằng cách "
-"gộp nhóm các ô nào gộp thành những vùng tách biệt để tạo ra các giá trị phạm "
-"trù riêng."
+"Phân loại lại phạm trù của bản đồ raster bằng cách gộp nhóm các ô nào tạo "
+"thành những vùng tách biệt rõ rệt để tạo ra các giá trị phạm trù riêng."
#: ../gui/wxpython/menustrings.py:331
msgid "Grow"
@@ -2552,9 +2520,8 @@
msgstr "Làm đầy hồ"
#: ../gui/wxpython/menustrings.py:339
-#, fuzzy
msgid "Fills lake from seed at given level."
-msgstr "Làm đầy hồ từ \"hạt gieo\" ở mức đã cho"
+msgstr "Làm đầy hồ từ \"hạt gieo\" ở mức đã cho."
#: ../gui/wxpython/menustrings.py:340
msgid "Depressionless map and flowlines"
@@ -2655,15 +2622,16 @@
msgstr "Lưu vực phụ của đường chia nước"
#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:739
-#, fuzzy
msgid "Groundwater modeling"
-msgstr "Điểm khống chế"
+msgstr "Mô hình hoá nước ngầm"
#: ../gui/wxpython/menustrings.py:361
msgid ""
"Numerical calculation program for transient, confined and unconfined "
"groundwater flow in two dimensions."
msgstr ""
+"Chương trình tính toán số dùng cho dòng chảy ngầm giới hạn, không giới hạn "
+"và tạm thời theo kích thước hai chiều."
#: ../gui/wxpython/menustrings.py:362
msgid "Landscape structure modeling"
@@ -2678,6 +2646,8 @@
"Interactive tool used to setup the sampling and analysis framework that will "
"be used by the other r.le programs."
msgstr ""
+"Công cụ tương tác được dùng để thiết lập hệ thống thu mẫu và phân tách để "
+"dùng trong các chương trình r.le khác."
#: ../gui/wxpython/menustrings.py:365
msgid "Analyze landscape"
@@ -2879,6 +2849,10 @@
"a raster map of the cumulative time of spread, given raster maps containing "
"the rates of spread (ROS), the ROS directions and the spread origins."
msgstr ""
+"Giả lập phép phát tán không đẳng hướng hình elip trên một cửa sổ đồ hoạ và "
+"tạo một bản đồ raster về thời gian tích luỹ của sự phát tán, với các bản đồ "
+"raster cho trước chứa tốc độ phát tán (ROS), các hướng ROS và các nguồn phát "
+"tán."
#: ../gui/wxpython/menustrings.py:407
msgid "Change category values and labels"
@@ -2897,13 +2871,12 @@
msgstr "Phân loại lại theo cỡ"
#: ../gui/wxpython/menustrings.py:411
-#, fuzzy
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)."
msgstr ""
"Phân loại lại một bản đồ raster lớn hơn hoặc nhỏ hơn kích thước diện tích do "
-"người dùng chỉ định (tính theo hec-ta)"
+"người dùng chỉ định (tính theo hec-ta)."
#: ../gui/wxpython/menustrings.py:412
msgid "Reclassify interactively"
@@ -2926,9 +2899,8 @@
msgstr "Mã hoá lại tương tác"
#: ../gui/wxpython/menustrings.py:417
-#, fuzzy
msgid "Recodes categorical raster maps."
-msgstr "Bản đồ raster đã được mã hóa lại:"
+msgstr "Mã hoá lại bản đồ raster kiểu phạm trù."
#: ../gui/wxpython/menustrings.py:418
msgid "Recode using rules file"
@@ -2986,13 +2958,12 @@
msgstr "Ô ngẫu nhiên và điểm vec-tơ"
#: ../gui/wxpython/menustrings.py:430
-#, fuzzy
msgid ""
"Creates a raster map layer and vector point map containing randomly located "
"points."
msgstr ""
-"Tạo một lớp bản đồ raster và bản đồ điểm vec-tơ chứa các địa điểm được định "
-"vị một cách ngẫu nhiên."
+"Tạo một lớp bản đồ raster và bản đồ điểm vec-tơ chứa các điểm được định vị "
+"một cách ngẫu nhiên."
#: ../gui/wxpython/menustrings.py:431
msgid "Generate surfaces"
@@ -3069,7 +3040,6 @@
msgstr "Tạo đường bình độ"
#: ../gui/wxpython/menustrings.py:445
-#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
msgstr ""
"Tạo một lớp bản đồ vec-tơ có các đường bình độ được chỉ định từ một lớp bản "
@@ -3102,18 +3072,18 @@
msgstr "IDW từ các điểm raster"
#: ../gui/wxpython/menustrings.py:452
-#, fuzzy
msgid "Surface interpolation utility for raster map."
-msgstr "Tiện ích nội suy bề mặt dùng cho các lớp bản đồ raster"
+msgstr "Tiện ích nội suy bề mặt dùng cho bản đồ raster."
#: ../gui/wxpython/menustrings.py:453
msgid "IDW from raster points (alternate method for sparse points)"
msgstr ""
+"Tính IDW (trọng số nghịch đảo theo khoảng cách) từ các điểm raster (phương "
+"pháp thay thế dùng cho các điểm phân tán)"
#: ../gui/wxpython/menustrings.py:454
-#, fuzzy
msgid "Surface generation program."
-msgstr "Chương trình tạo bề mặt từ các đường bình độ được raster hoá"
+msgstr "Chương trình tạo bề mặt."
#: ../gui/wxpython/menustrings.py:455
msgid "IDW from vector points"
@@ -3205,9 +3175,8 @@
msgstr "Các điểm phân vị dùng cho những bộ dữ liệu lớn"
#: ../gui/wxpython/menustrings.py:473
-#, fuzzy
msgid "Compute quantiles using two passes."
-msgstr "Tính các điểm phân vị bằng cách chạy qua hai lần."
+msgstr "Tính các điểm phân vị bằng cách chạy hai lượt."
#: ../gui/wxpython/menustrings.py:474
msgid "Range of category values"
@@ -3336,14 +3305,12 @@
msgstr "Tạo mới bản đồ véc tơ rỗng"
#: ../gui/wxpython/menustrings.py:500
-#, fuzzy
msgid "Digitize vector map using Tcl/Tk digitizer"
-msgstr "Số hóa raster (cần có XTerm)"
+msgstr "Số hóa bản đồ véc-tơ bằng trình số hoá Tcl/Tk"
#: ../gui/wxpython/menustrings.py:501
-#, fuzzy
msgid "Interactive editing and digitization of vector maps."
-msgstr "Chỉnh sửa tương tác các giá trị ô trong một bản đồ raster."
+msgstr "Chỉnh sửa tương tác và số hoá các bản đồ véc-tơ."
#: ../gui/wxpython/menustrings.py:502
msgid "Edit vector map (non-interactively)"
@@ -3378,16 +3345,14 @@
msgstr "Làm trơn hoặc đơn giản hoá"
#: ../gui/wxpython/menustrings.py:509
-#, fuzzy
msgid "Vector based generalization."
-msgstr "Các kết nối CSDL véc tơ"
+msgstr "Phép tổng quát hoá dựa trên véc-tơ."
#: ../gui/wxpython/menustrings.py:510
msgid "Convert object types"
msgstr "Chuyển đổi kiểu đối tượng"
#: ../gui/wxpython/menustrings.py:511
-#, fuzzy
msgid "Change the type of geometry elements."
msgstr "Thay đổi kiểu của các yếu tố hình học."
@@ -3408,13 +3373,12 @@
msgstr "Xây dựng đường từ đường thẳng hoặc ranh giới."
#: ../gui/wxpython/menustrings.py:516
-#, fuzzy
msgid "Split lines"
-msgstr "Tách đường"
+msgstr "Ngắt đường"
#: ../gui/wxpython/menustrings.py:517
msgid "Split lines to shorter segments."
-msgstr ""
+msgstr "Ngắt đường thành các đoạn ngắn hơn."
#: ../gui/wxpython/menustrings.py:518
msgid "Split polylines"
@@ -3429,9 +3393,8 @@
msgstr "Các đường song song"
#: ../gui/wxpython/menustrings.py:521
-#, fuzzy
msgid "Creates parallel line to input vector lines."
-msgstr "Tạo đường thẳng song song với các đường thẳng đầu vào"
+msgstr "Tạo đường thẳng song song với các đường của bản đồ véc-tơ đầu vào."
#: ../gui/wxpython/menustrings.py:522
msgid "Dissolve boundaries"
@@ -3467,14 +3430,12 @@
msgstr "Tạo nhãn"
#: ../gui/wxpython/menustrings.py:529
-#, fuzzy
msgid "Create optimally placed labels for vector map(s)"
-msgstr "Tạo bảng màu mới cho bản đồ véc tơ"
+msgstr "Tạo các nhãn cho bản đồ véc tơ được đặt vị trí tối ưu "
#: ../gui/wxpython/menustrings.py:530
-#, fuzzy
msgid "Create optimally placed labels"
-msgstr "Tạo nhãn"
+msgstr "Tạo các nhãn được đặt sao cho tối ưu"
#: ../gui/wxpython/menustrings.py:531
msgid "Creates paint labels for a vector map from attached attributes."
@@ -3501,9 +3462,8 @@
msgstr "Cho phép chuyển đổi phép chiếu các bản đồ raster."
#: ../gui/wxpython/menustrings.py:537
-#, fuzzy
msgid "Updates vector map metadata."
+msgstr "Cập nhật đặc tả dữ liệu bản đồ vec-tơ."
#: ../gui/wxpython/menustrings.py:540
msgid ""
@@ -3541,12 +3501,11 @@
msgstr "Truy vấn theo bản đồ véc tơ khác"
#: ../gui/wxpython/menustrings.py:548
-#, fuzzy
msgid ""
"Selects features from vector map (A) by features from other vector map (B)."
msgstr ""
-"Chọn các đối tượng từ đầu vào a (ainput) theo các đối tượng từ đầu vào b "
-"(binput)"
+"Chọn các đối tượng từ bản đồ véc-tơ (A) theo các đối tượng từ bản đồ véc-tơ "
+"(B)."
#: ../gui/wxpython/menustrings.py:549
msgid "Buffer vectors"
@@ -3660,9 +3619,8 @@
msgstr "Bảo trì mạng"
#: ../gui/wxpython/menustrings.py:571
-#, fuzzy
msgid "Performs network maintenance."
-msgstr "Bảo trì mạng."
+msgstr "Tiến hành bảo trì mạng lưới."
#: ../gui/wxpython/menustrings.py:572
msgid "Allocate subnets"
@@ -3671,6 +3629,8 @@
#: ../gui/wxpython/menustrings.py:573
msgid "Allocate subnets for nearest centres (direction from centre)."
msgstr ""
+"Cấp phát các mạng lưới con cho các trung tâm gần nhất (hướng tính từ trung "
+"tâm)."
#: ../gui/wxpython/menustrings.py:574
msgid "Split net"
@@ -3678,7 +3638,7 @@
#: ../gui/wxpython/menustrings.py:575
msgid "Splits net by cost isolines."
-msgstr ""
+msgstr "Ngắt mạng mưới bằng các đường cùng giá trị chi phí."
#: ../gui/wxpython/menustrings.py:576
msgid "Shortest path"
@@ -3777,7 +3737,7 @@
#: ../gui/wxpython/menustrings.py:597
msgid "Create Steiner tree for the network and given terminals"
-msgstr ""
+msgstr "Tạo cây Steiner cho mạng lưới và các đầu cuối cho trước"
#: ../gui/wxpython/menustrings.py:598
msgid "Minimum spanning tree"
@@ -3794,6 +3754,8 @@
#: ../gui/wxpython/menustrings.py:601
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
msgstr ""
+"Tạo một chu trình kết nối các nốt cho trước (bài toán di chuyển của người "
+"bán hàng)."
#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:603
msgid "Overlay vector maps"
@@ -3995,19 +3957,17 @@
#: ../gui/wxpython/menustrings.py:649
-#, fuzzy
msgid "Outputs basic information about a user-specified vector map."
msgstr ""
"Xuất ra thông tin cơ bản về một lớp bản đồ vec-tơ do người dùng chỉ định."
#: ../gui/wxpython/menustrings.py:650
-#, fuzzy
msgid "Classify attribute data"
-msgstr "Hiện dữ liệu thuộc tính"
+msgstr "Phân loại dữ liệu thuộc tính"
#: ../gui/wxpython/menustrings.py:651
msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
+msgstr "Phân loại dữ liệu thuộc tính, ví dụ để tạo bản đồ chủ đề"
#: ../gui/wxpython/menustrings.py:652
msgid "Report topology by category"
@@ -4022,14 +3982,12 @@
msgstr "Cập nhật hoặc báo cáo tôpô"
#: ../gui/wxpython/menustrings.py:655
-#, fuzzy
msgid "Populates database values from vector features."
-msgstr "Xuất ra các giá trị của CSDL từ các đối tượng vec-tơ"
+msgstr "Tạo các giá trị CSDL từ các đối tượng vec-tơ."
#: ../gui/wxpython/menustrings.py:656
-#, fuzzy
msgid "Univariate attribute statistics for points"
-msgstr "Thống kê thuộc tính một biến"
+msgstr "Thống kê thuộc tính một biến dùng cho điểm"
#: ../gui/wxpython/menustrings.py:657
msgid ""
@@ -4040,16 +3998,16 @@
"được tính toán cho các điểm nếu được chỉ định."
#: ../gui/wxpython/menustrings.py:658
-#, fuzzy
msgid "Univariate statistics for attribute columns"
+msgstr "Thống kê thuộc tính một biến dùng cho cột thuộc tính"
#: ../gui/wxpython/menustrings.py:659
-#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
-msgstr "Tính toán thống kê một biến từ các ô không rỗng của một bản đồ raster."
+msgstr ""
+"Tính toán thống kê một biến cho một cột của bảng đã chọn trong một bản đồ "
+"véc-tơ GRASS."
#: ../gui/wxpython/menustrings.py:660
msgid "Quadrat indices"
@@ -4109,9 +4067,8 @@
msgstr "Cân bằng màu cho RGB"
#: ../gui/wxpython/menustrings.py:674
-#, fuzzy
msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr "Tự động cân bằng màu cho các ảnh LANDSAT"
+msgstr "Thực hiện cân bằng màu tự động cho các ảnh LANDSAT."
#: ../gui/wxpython/menustrings.py:675
msgid "HIS to RGB"
@@ -4122,25 +4079,28 @@
"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
"RGB (Red-Green-Blue) color space."
msgstr ""
+"Chuyển đổi các bản đồ raster từ không gian màu HIS (Màu-Cường độ-Độ bão hoà) "
+"thành không gian màu RGB (Đỏ-Lục-Lam)."
#: ../gui/wxpython/menustrings.py:678
msgid ""
"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
"Intensity-Saturation) color space."
msgstr ""
+"Chuyển đổi các bản đồ raster từ không gian màu RGB (Đỏ-Lục-Lam) thành không "
+"gian màu HIS (Màu sắc-Cường độ-Bão hoà)."
#: ../gui/wxpython/menustrings.py:679
msgid "Rectify image or raster"
msgstr "Nắn chỉnh ảnh hoặc raster"
#: ../gui/wxpython/menustrings.py:680
-#, fuzzy
msgid ""
"Rectifies an image by computing a coordinate transformation for each pixel "
"in the image based on the control points."
msgstr ""
"Nắn chỉnh mộtt ảnh bằng cách tính toán phép chuyển đổi tọa độ cho mỗi điểm "
-"ảnh dựa trên các điểm khống chế"
+"ảnh dựa trên các điểm khống chế."
#: ../gui/wxpython/menustrings.py:681
msgid "Ortho photo rectification (requires Xterm)"
@@ -4148,7 +4108,7 @@
#: ../gui/wxpython/menustrings.py:682
msgid "Menu driver for the photo imagery programs."
-msgstr ""
+msgstr "Trình điều khiển trình đơn dùng cho các chương trình ảnh chụp."
#: ../gui/wxpython/menustrings.py:683
msgid "Brovey sharpening"
@@ -4173,6 +4133,8 @@
"Generates spectral signatures for land cover types in an image using a "
"clustering algorithm."
msgstr ""
+"Tạo các chữ ký phổ cho các kiểu lớp phủ mặt đất trong một ảnh dùng thuật "
+"toán gộp nhóm (clustering)."
#: ../gui/wxpython/menustrings.py:688
@@ -4180,7 +4142,7 @@
#: ../gui/wxpython/menustrings.py:689
msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
+msgstr "Phân loại các hệ số phản xạ phổ của ô trong dữ liệu ảnh."
#: ../gui/wxpython/menustrings.py:690
msgid "Sequential maximum a posteriori classification (SMAP)"
@@ -4203,24 +4165,24 @@
"Generates spectral signatures for an image by allowing the user to outline "
"regions of interest."
msgstr ""
+"Tạo các chữ ký phổ cho một ảnh bằng cách cho phép người dùng vạch ra các "
+"vùng quan tâm (ROI)."
#: ../gui/wxpython/menustrings.py:694
msgid "Input for supervised MLC"
msgstr "Đầu vào dùng cho MLC có hướng dẫn"
#: ../gui/wxpython/menustrings.py:695
-#, fuzzy
msgid "Generates statistics for i.maxlik from raster map."
-msgstr "Tạo thống kê cho i.maxlik từ lớp bản đồ raster."
+msgstr "Tạo thống kê cho i.maxlik từ bản đồ raster."
#: ../gui/wxpython/menustrings.py:696
msgid "Input for supervised SMAP"
msgstr "Đầu vào dùng cho SMAP có hướng dẫn"
#: ../gui/wxpython/menustrings.py:697
-#, fuzzy
msgid "Generates statistics for i.smap from raster map."
-msgstr "Tạo thống kê cho i.smap từ lớp bản đồ raster."
+msgstr "Tạo thống kê cho i.smap từ bản đồ raster."
#: ../gui/wxpython/menustrings.py:698
msgid "Filter image"
@@ -4256,12 +4218,11 @@
msgstr "Đáp ứng phổ"
#: ../gui/wxpython/menustrings.py:706
-#, fuzzy
msgid ""
"Displays spectral response at user specified locations in group or images."
msgstr ""
-"hiển thị đáp ứng phổ tại các vị trí mà người dùng đã chỉ định trong nhóm "
-"hoặc các ảnh "
+"Hiển thị đáp ứng phổ tại các vị trí mà người dùng đã chỉ định trong các ảnh "
+"hoặc trong nhóm."
#: ../gui/wxpython/menustrings.py:707
msgid "Tasseled cap vegetation index"
@@ -4380,14 +4341,12 @@
msgstr "Thiết lập mặt nạ raster 3D hiện đang dùng."
#: ../gui/wxpython/menustrings.py:735
-#, fuzzy
msgid "Volume calculator"
-msgstr "Trình toán toán bản đồ"
+msgstr "Trình toán toán thể tích"
#: ../gui/wxpython/menustrings.py:736
-#, fuzzy
msgid "Map calculator for 3D raster map algebra."
+msgstr "Trình tính toán bản đồ dùng cho đại số bản đồ raster 3D."
#: ../gui/wxpython/menustrings.py:737
msgid "Cross section"
@@ -4405,6 +4364,8 @@
"Numerical calculation program for transient, confined groundwater flow in "
"three dimensions"
msgstr ""
+"và tạm thời ở chế độ ba chiều"
#: ../gui/wxpython/menustrings.py:741
msgid "Interpolate volume from points"
@@ -4432,26 +4393,23 @@
"Xuất ra thông tin cơ bản về lớp bản đồ raster 3 chiều do người dùng chỉ định"
#: ../gui/wxpython/menustrings.py:746
-#, fuzzy
msgid "Voxel statistics"
-msgstr "Thống kê tổng quát"
+msgstr "Thống kê voxel"
#: ../gui/wxpython/menustrings.py:747
-#, fuzzy
msgid "Generates volume statistics for raster3d maps."
-msgstr "Tạo các thống kê diện tích cho các lớp bản đồ raster."
+msgstr "Tạo thống kê thể tích cho các bản đồ raster3d."
#: ../gui/wxpython/menustrings.py:748
-#, fuzzy
msgid "Univariate statistics for volumes"
-msgstr "Thống kế raster một biến"
+msgstr "Thống kế raster một biến dùng cho thể tích"
#: ../gui/wxpython/menustrings.py:749
-#, fuzzy
msgid ""
"Calculates univariate statistics from the non-null 3d cells of a raster3d "
"map."
+msgstr ""
+"Tính toán thống kê một biến từ các ô không rỗng của một bản đồ raster3d."
#: ../gui/wxpython/menustrings.py:750
#, fuzzy
@@ -4517,9 +4475,8 @@
msgstr "Thiết lập người dùng/mật mã dùng cho trình điều khiển/CSDL."
#: ../gui/wxpython/menustrings.py:765
-#, fuzzy
msgid "Drop table"
-msgstr "Chép bảng"
+msgstr "Bỏ bảng"
#: ../gui/wxpython/menustrings.py:766
msgid "Drops an attribute table."
@@ -4530,9 +4487,8 @@
msgstr "Chép bảng"
#: ../gui/wxpython/menustrings.py:768
-#, fuzzy
msgid "Copy a table."
-msgstr "Chép bảng"
+msgstr "Chép một bảng."
#: ../gui/wxpython/menustrings.py:769
msgid "Test"
@@ -4582,12 +4538,11 @@
msgstr "Bảng mới"
#: ../gui/wxpython/menustrings.py:780
-#, fuzzy
msgid ""
"Creates and connects a new attribute table to a given layer of an existing "
"vector map."
msgstr ""
-"Tạo và thêm một bảng thuộc tính mới vào một lớp đã cho của bản đồ véc tơ "
+"Tạo và kết nối một bảng thuộc tính mới vào một lớp đã cho của bản đồ véc-tơ "
"hiện có."
#: ../gui/wxpython/menustrings.py:781
@@ -4595,23 +4550,16 @@
msgstr "Loại bỏ bảng"
#: ../gui/wxpython/menustrings.py:782
-#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
-"Đổi tên một cột trong bảng thuộc tính có kết nối với một bản đồ véc tơ đã "
-"cho."
+msgstr "Loại bỏ bảng thuộc tính hiện có của một bản đồ véc-tơ."
#: ../gui/wxpython/menustrings.py:783
-#, fuzzy
msgid "Join table"
-msgstr "Chép bảng"
+msgstr "Nối bảng"
#: ../gui/wxpython/menustrings.py:784
-#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Cho phép cập nhật một cột trong bảng thuộc tính có kết nối tới một bản đồ "
-"véc tơ."
+msgstr "Cho phép nối một bảng vào một bảng của một bản đồ véc-tơ."
#: ../gui/wxpython/menustrings.py:785
msgid "Add columns"
@@ -4626,17 +4574,14 @@
"cho."
#: ../gui/wxpython/menustrings.py:787
-#, fuzzy
msgid "Drop column"
-msgstr "Bỏ tất cả cột"
+msgstr "Bỏ cột"
#: ../gui/wxpython/menustrings.py:788
-#, fuzzy
msgid ""
"Drops a column from the attribute table connected to a given vector map."
msgstr ""
-"cho."
+"Bỏ một cột khỏi bảng thuộc tính có kết nối với một bản đồ véc-tơ đã cho."
#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/gui_modules/dbm.py:932
msgid "Rename column"
@@ -4661,9 +4606,8 @@
"véc tơ."
#: ../gui/wxpython/menustrings.py:793
-#, fuzzy
msgid "Reconnect vectors to database"
-msgstr "Kết nối lại véc tơ vào CSDL"
+msgstr "Kết nối lại véc-tơ vào CSDL"
#: ../gui/wxpython/menustrings.py:794
msgid "Reconnects vectors to a new database."
@@ -4908,13 +4852,12 @@
msgstr "Xin chờ, đang cập nhật dữ liệu..."
#: ../gui/wxpython/gui_modules/histogram.py:265
-#, fuzzy
msgid "GRASS GIS Histogram of image or raster map"
-msgstr "Tạo biểu đồ tần số của ảnh hoặc tập tin raster"
+msgstr "Tạo biểu đồ tần số GRASS GIS của ảnh hoặc bản đồ raster"
#: ../gui/wxpython/gui_modules/histogram.py:351
msgid "Select font for histogram text"
-msgstr ""
+msgstr "Chọn phông chữ cho biểu đồ tần số"
#: ../gui/wxpython/gui_modules/histogram.py:397
#: ../gui/wxpython/gui_modules/mapdisp.py:1109
@@ -4943,121 +4886,109 @@
msgstr "Trình tính toán Bản đồ %s của GRASS"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:66
-#, fuzzy
msgid "mapcalc statement"
-msgstr "Câu lệnh SQL"
+msgstr "Câu lệnh mapcalc"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:114
#: ../gui/wxpython/gui_modules/nviz_tools.py:891
-#, fuzzy
msgid "3D raster map"
msgstr "Bản đồ raster 3D"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:117
-#, fuzzy
msgid "raster map"
-msgstr "Bản đồ raster"
+msgstr "bản đồ raster"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:121
msgid "Operators"
-msgstr ""
+msgstr "Các toán tử"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:123
-#, fuzzy
msgid "Operands"
-msgstr "Mở"
+msgstr "Các toán hạng"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:125
-#, fuzzy
msgid "Expression"
-msgstr "Độ phát ra"
+msgstr "Biểu thức"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:138
msgid "exponent"
-msgstr ""
+msgstr "luỹ thừa"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:140
msgid "divide"
-msgstr ""
+msgstr "chia"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#, fuzzy
msgid "add"
-msgstr "Thêm"
+msgstr "cộng"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:144
-#, fuzzy
msgid "subtract"
-msgstr "bề mặt"
+msgstr "trừ"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:146
msgid "modulus"
-msgstr ""
+msgstr "trị tuyệt đối"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:148
-#, fuzzy
msgid "multiply"
-msgstr "[nhiều]"
+msgstr "nhân"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:153
msgid "left shift"
-msgstr ""
+msgstr "shift trái"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:155
msgid "right shift"
-msgstr ""
+msgstr "shift phải"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:157
msgid "right shift (unsigned)"
-msgstr ""
+msgstr "shift phải (không dấu)"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:159
-#, fuzzy
msgid "greater than"
-msgstr "ngắn hơn"
+msgstr "lớn hơn"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:161
-#, fuzzy
msgid "greater than or equal to"
-msgstr "Tạo hoặc dựng lại tôpô"
+msgstr "lớn hơn hoặc bằng"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:163
-#, fuzzy
msgid "less than"
-msgstr "dài hơn"
+msgstr "nhỏ hơn"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:165
msgid "less than or equal to"
-msgstr ""
+msgstr "nhỏ hơn hoặc bằng"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:167
msgid "equal to"
-msgstr ""
+msgstr "bằng"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:169
msgid "not equal to"
-msgstr ""
+msgstr "không bằng"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:172
-#, fuzzy
msgid "one's complement"
-msgstr "Hiển thị phạm vi tính toán"
+msgstr "phần bù của một"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:174
msgid "NOT"
-msgstr ""
+msgstr "KHÔNG"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:176
msgid "bitwise AND"
-msgstr ""
+msgstr "đảo bit VÀ"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:178
msgid "bitwise OR"
-msgstr ""
+msgstr "đảo bit HOẶC"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:180
msgid "logical AND"
-msgstr ""
+msgstr "luân lý VÀ"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:182
msgid "logical AND (ignores NULLs)"
@@ -5065,40 +4996,37 @@
#: ../gui/wxpython/gui_modules/mcalc_builder.py:184
msgid "logical OR"
-msgstr ""
+msgstr "luân lý HOẶC"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:186
msgid "logical OR (ignores NULLs)"
msgstr ""
#: ../gui/wxpython/gui_modules/mcalc_builder.py:188
-#, fuzzy
msgid "conditional"
-msgstr "Vị trí"
+msgstr "điều kiện"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:200
+#, python-format
msgid "Name for new %s to create"
-msgstr "Tên cho bản đồ véc tơ mới"
+msgstr "Tên cho %s mới cần tạo"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:203
+#, python-format
msgid "Insert existing %s"
-msgstr "ghi đè tập tin hiện có"
+msgstr "Chèn %s hiện có"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:207
msgid "Insert mapcalc function"
-msgstr ""
+msgstr "Chèn hàm số mapcalc"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:397
-#, fuzzy
msgid "You must enter the name of a new map to create"
-msgstr "Bạn phải nhập phần tên mở rộng hợp lệ cho bản đồ để tiếp tục"
+msgstr "Bạn phải nhập tên của bản đồ mới cần tạo"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:402
-#, fuzzy
msgid "You must enter a mapcalc statement to create a new map"
+msgstr "Bạn phải nhập câu lệnh mapcalc để tạo bản đồ mới"
#: ../gui/wxpython/gui_modules/menudata.py:79
#, fuzzy
@@ -5198,7 +5126,7 @@
#: ../gui/wxpython/gui_modules/mapdisp_window.py:896
msgid "MASK"
-msgstr ""
+msgstr "MẶT NẠ"
#: ../gui/wxpython/gui_modules/mapdisp_window.py:1515
msgid "Update categories"
@@ -5228,9 +5156,8 @@
msgstr "Cần ít nhất %d GCP. Đã hủy thao tác."
#: ../gui/wxpython/gui_modules/mapdisp_window.py:2818
-#, fuzzy
msgid "Save display extents to region file"
-msgstr "Lưu hình học hiển thị vào vùng đã đặt tên"
+msgstr "Lưu phạm vi trình bày vào tập tin vùng"
#: ../gui/wxpython/gui_modules/mapdisp_window.py:2828
#, python-format
@@ -5312,6 +5239,10 @@
"\n"
"Details: %s"
msgstr ""
+"Không thể khởi động trình số hoá véc-tơ wxGUI.\n"
+"Thay vào đó, bạn có muốn khởi động trình số hoá TCL/TK (v.digit) không?\n"
+"\n"
+"Chi tiết: %s"
#: ../gui/wxpython/gui_modules/mapdisp.py:331
#: ../gui/wxpython/gui_modules/mapdisp.py:341
@@ -5324,9 +5255,8 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:334
#: ../gui/wxpython/gui_modules/layertree.py:540
-#, fuzzy
msgid "Vector digitizer failed"
-msgstr "Lỗi trình số hóa vec-tơ"
+msgstr "Trình số hóa vec-tơ thất bại"
#: ../gui/wxpython/gui_modules/mapdisp.py:354
msgid "Vector digitizer toolbar"
@@ -5337,7 +5267,7 @@
msgstr "Thanh công cụ nắn chỉnh địa lý"
#: ../gui/wxpython/gui_modules/mapdisp.py:385
+#, python-format
msgid ""
"Unable to switch to 3D display mode.\n"
"The Nviz python extension was not found or loaded properly.\n"
@@ -5345,8 +5275,9 @@
"\n"
"Details: %s"
msgstr ""
-"Không thể khởi động Nviz. Không thấy phần mở rộng Python cho Nviz, hoặc nó "
-"chưa được nạp đúng. Quay lại chế độ hiển thị 2 chiều.\n"
+"Không thể chuyển qua chế độ trình bày 3D.\n"
+"Không có phần mở rộng python Nviz python hoặc nó không được nạp đúng.\n"
+"Chuyển trở lại chế độ trình bày 2D.\n"
"\n"
"Chi tiết: %s"
@@ -5370,14 +5301,12 @@
msgstr "Không có lớp bản đồ nào được chọn. Thao tác bị hủy."
#: ../gui/wxpython/gui_modules/mapdisp.py:1267
-#, fuzzy
msgid "No raster or vector map layer selected for querying."
-msgstr "Không có bản đồ véc tơ nào được chọn để truy vấn."
+msgstr "Không có bản đồ raster hoặc véc-tơ nào được chọn để truy vấn."
#: ../gui/wxpython/gui_modules/mapdisp.py:1268
-#, fuzzy
msgid "No map layer selected"
-msgstr "Không có lớp bản đồ nào được chọn để truy vấn."
+msgstr "Không có lớp bản đồ nào được chọn"
#: ../gui/wxpython/gui_modules/mapdisp.py:1363
msgid "No vector map selected for querying."
@@ -5385,13 +5314,13 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:1364
#: ../gui/wxpython/gui_modules/mapdisp.py:1372
-#, fuzzy
msgid "Vector querying"
-msgstr "Thiết lập véc tơ"
+msgstr "Truy vấn véc-tơ"
#: ../gui/wxpython/gui_modules/mapdisp.py:1371
msgid "Only vector map from the current mapset can be modified."
msgstr ""
+"Chỉ có bản đồ véc-tơ trong bộ bản đồ hiện tại mới có thể được chỉnh sửa."
#: ../gui/wxpython/gui_modules/mapdisp.py:1443
#, fuzzy
@@ -5465,9 +5394,8 @@
msgstr "Thiết lập vùng tính toán theo phần trình bày"
#: ../gui/wxpython/gui_modules/mapdisp.py:1931
-#, fuzzy
msgid "Save display geometry to named region"
+msgstr "Lưu hình học trình bày vào vùng có đặt tên"
#: ../gui/wxpython/gui_modules/mapdisp.py:2025
msgid "GRASS GIS Map Display: "
@@ -5534,18 +5462,16 @@
msgstr ""
#: ../gui/wxpython/gui_modules/ghelp.py:562
-#, fuzzy
msgid "Copyright"
-msgstr "Sao chép"
+msgstr "Bản quyền"
#: ../gui/wxpython/gui_modules/ghelp.py:563
-#, fuzzy
msgid "License"
-msgstr "Đường"
+msgstr "Giấy phép"
#: ../gui/wxpython/gui_modules/ghelp.py:564
msgid "Authors"
-msgstr ""
+msgstr "Tác giả"
#: ../gui/wxpython/gui_modules/ghelp.py:565
#, fuzzy
@@ -5696,31 +5622,34 @@
msgstr "Chọn phương thức để tạo vị trí mới"
#: ../gui/wxpython/gui_modules/location_wizard.py:247
-#, fuzzy
msgid "Select coordinate system parameters from a list"
-msgstr "Chọn hệ tọa độ"
+msgstr "Chọn các tham số hệ tọa độ từ danh sách"
#: ../gui/wxpython/gui_modules/location_wizard.py:250
-#, fuzzy
msgid "Select EPSG code of spatial reference system"
-msgstr "Chọn mã EPSG của hệ tọa độ"
+msgstr "Chọn mã EPSG của hệ tham chiếu không gian"
#: ../gui/wxpython/gui_modules/location_wizard.py:252
msgid "Read projection and datum terms from a georeferenced data file"
msgstr ""
+"Đọc các thông số của phép chiếu và mốc toạ độ chuẩn từ một tập tin dữ liệu "
+"có tham chiếu"
#: ../gui/wxpython/gui_modules/location_wizard.py:255
msgid "Read projection and datum terms from a WKT or PRJ file"
msgstr ""
+"Đọc các thông số của phép chiếu và mốc toạ độ chuẩn từ một tập tin WKT hoặc "
+"PRJ"
#: ../gui/wxpython/gui_modules/location_wizard.py:258
msgid "Specify projection and datum terms using custom PROJ.4 parameters"
msgstr ""
+"Chỉ định các thông số phép chiếu và mốc toạ độ chuẩn bằng cách dùng các tham "
+"số tuỳ chỉnh PROJ.4"
#: ../gui/wxpython/gui_modules/location_wizard.py:261
-#, fuzzy
msgid "Create an arbitrary non-earth coordinate system (XY)"
-msgstr "Tạo hệ tọa độ giả định tùy ý (XY)"
+msgstr "Tạo hệ tọa độ phi-quả-đất tùy ý (XY)"
#: ../gui/wxpython/gui_modules/location_wizard.py:351
msgid "Choose projection"
@@ -5758,34 +5687,30 @@
msgstr "Không thể đọc danh sách: %s"
#: ../gui/wxpython/gui_modules/location_wizard.py:664
-#, fuzzy
msgid "Choose projection parameters"
-msgstr "Chọn phép chiếu"
+msgstr "Chọn các tham số phép chiếu"
#: ../gui/wxpython/gui_modules/location_wizard.py:677
-#, fuzzy
msgid "Select datum or ellipsoid (next page)"
-msgstr "Chọn mốc tọa độ chuẩn với ellipsoid liên quan"
+msgstr "Chọn mốc tọa độ chuẩn hoặc ellipsoid (trang tiếp)"
#: ../gui/wxpython/gui_modules/location_wizard.py:683
-#, fuzzy
msgid "Datum with associated ellipsoid"
+msgstr "Mốc tọa độ chuẩn với ellipsoid liên quan"
#: ../gui/wxpython/gui_modules/location_wizard.py:686
-#, fuzzy
msgid "Ellipsoid only"
-msgstr "Ellipsoid"
+msgstr "Chỉ ellipsoid"
#: ../gui/wxpython/gui_modules/location_wizard.py:743
#, python-format
msgid "You must enter a value for %s"
-msgstr ""
+msgstr "Bạn phải nhập một giá trị cho %s"
#: ../gui/wxpython/gui_modules/location_wizard.py:755
+#, python-format
msgid " Enter parameters for %s projection "
+msgstr " Nhập các tham số cho phép chiếu %s "
#: ../gui/wxpython/gui_modules/location_wizard.py:796
#, fuzzy
@@ -5917,12 +5842,15 @@
msgstr "Đã tạo vị trí <%s>"
#: ../gui/wxpython/gui_modules/location_wizard.py:1848
+#, python-format
msgid ""
"Unable to create new location. Location <%(loc)s> not created.\n"
"\n"
"Details: %(err)s"
-msgstr "Không thể tạo vị trí mới. Vị trí <%s> không được tạo."
+msgstr ""
+"Không thể tạo location mới. Location <%(loc)s> không được tạo ra.\n"
+"\n"
+"Chi tiết: %(err)s"
#: ../gui/wxpython/gui_modules/location_wizard.py:1853
#: ../gui/wxpython/gui_modules/location_wizard.py:1860
@@ -5943,11 +5871,13 @@
"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
"need to change the default GIS data directory in the GRASS startup screen."
msgstr ""
+"Location <%(loc)s> sẽ được tạo ra trong thư mục dữ liệu GIS <%(dir)s>. Bạn "
+"cần phải thay đổi thư mục dữ liệu GIS mặc định trong màn hình khởi động "
+"GRASS."
#: ../gui/wxpython/gui_modules/location_wizard.py:1992
-#, fuzzy
msgid "New GIS data directory"
-msgstr "Thư mục dữ liệu GIS"
+msgstr "Thư mục dữ liệu GIS mới"
#: ../gui/wxpython/gui_modules/location_wizard.py:2153
msgid "EPSG code missing."
@@ -5955,9 +5885,8 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:2177
#: ../gui/wxpython/gui_modules/location_wizard.py:2201
-#, fuzzy
msgid "File not found."
-msgstr "không tìm thấy tập tin"
+msgstr "Không tìm thấy tập tin."
#: ../gui/wxpython/gui_modules/location_wizard.py:2220
msgid "Set default region extent and resolution"
@@ -6059,9 +5988,8 @@
msgstr "Chọn phép chuyển đổi mốc tọa độ chuẩn"
#: ../gui/wxpython/gui_modules/location_wizard.py:2730
-#, fuzzy
msgid "Select from list of datum transformations"
-msgstr "Danh sách các phép chuyển đổi mốc tọa độ chuẩn"
+msgstr "Chọn từ danh sách các phép chuyển đổi mốc tọa độ chuẩn"
#: ../gui/wxpython/gui_modules/vclean.py:36
msgid "set up vector cleaning tools"
@@ -6484,7 +6412,6 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:453
#: ../gui/wxpython/gui_modules/nviz_tools.py:939
-#, fuzzy
msgid "gouraud"
msgstr "gouraud"
@@ -6530,9 +6457,8 @@
msgstr "mịn:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:553
-#, fuzzy
msgid "Mask zeros:"
-msgstr "Che mặt nạ cho các giá trị 0:"
+msgstr "Che mặt nạ các giá trị 0:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:557
msgid "by elevation"
@@ -6622,7 +6548,6 @@
msgstr "các mặt đồng giá trị"
#: ../gui/wxpython/gui_modules/nviz_tools.py:925
-#, fuzzy
msgid "slides"
msgstr "mặt nghiêng"
@@ -6944,9 +6869,8 @@
msgstr "Bỏ cột đã chọn"
#: ../gui/wxpython/gui_modules/gselect.py:901
-#, fuzzy
msgid "Source name"
-msgstr "Tên cột"
+msgstr "Tên nguồn"
#: ../gui/wxpython/gui_modules/gselect.py:911
#: ../gui/wxpython/gui_modules/menuform.py:1452
@@ -6954,9 +6878,8 @@
msgstr "Tập tin"
#: ../gui/wxpython/gui_modules/gselect.py:915
-#, fuzzy
msgid "Directory"
-msgstr "Hướng"
+msgstr "Thư mục"
#: ../gui/wxpython/gui_modules/gselect.py:919
#: ../gui/wxpython/gui_modules/dbm.py:2283
@@ -6967,17 +6890,16 @@
#: ../gui/wxpython/gui_modules/gselect.py:923
msgid "Protocol"
-msgstr ""
+msgstr "Giao thức"
#: ../gui/wxpython/gui_modules/gselect.py:927
msgid "Source type"
-msgstr ""
+msgstr "Kiểu nguồn"
#: ../gui/wxpython/gui_modules/gselect.py:941
#: ../gui/wxpython/gui_modules/gselect.py:1077
-#, fuzzy
msgid "Choose input file"
-msgstr "Chọn thư mục đầu vào"
+msgstr "Chọn tập tin đầu vào"
#: ../gui/wxpython/gui_modules/gselect.py:950
msgid "Choose input directory"
@@ -6985,33 +6907,28 @@
#: ../gui/wxpython/gui_modules/gselect.py:959
#: ../gui/wxpython/gui_modules/gselect.py:1202
-#, fuzzy
msgid "Choose file"
-msgstr "Chọn tệp DXF:"
+msgstr "Chọn tập tin"
#: ../gui/wxpython/gui_modules/gselect.py:990
-#, fuzzy
msgid "File:"
-msgstr "Tập tin"
+msgstr "Tập tin:"
#: ../gui/wxpython/gui_modules/gselect.py:993
-#, fuzzy
msgid "Directory:"
-msgstr "Hướng"
+msgstr "Thư mục:"
#: ../gui/wxpython/gui_modules/gselect.py:996
-#, fuzzy
msgid "Database:"
-msgstr "CSDL"
+msgstr "CSDL:"
#: ../gui/wxpython/gui_modules/gselect.py:999
-#, fuzzy
msgid "Protocol:"
-msgstr "Mã phép chiếu:"
+msgstr "Giao thức:"
#: ../gui/wxpython/gui_modules/gselect.py:1020
msgid "Format:"
-msgstr ""
+msgstr "Định dạng:"
#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
@@ -7896,7 +7813,6 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:3588
#: ../gui/wxpython/gui_modules/layertree.py:715
#: ../gui/wxpython/gui_modules/georect.py:316
-#, fuzzy
msgid "raster"
msgstr "raster"
@@ -8035,69 +7951,57 @@
msgstr "hàng %d:"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:78
+#, python-format
msgid "GRASS SQL Builder (%(type)s): vector map <%(map)s>"
-msgstr "Trình xây dựng SQL của GRASS: %s"
+msgstr "Trình xây dựng SQL của GRASS (%(type)s): bản đồ véc-tơ <%(map)s>"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:85
-#, fuzzy
msgid "SQL statement not verified"
+msgstr "Câu lệnh SQL không được kiểm chứng"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:91
-#, fuzzy
msgid "Set SQL statement to default"
-msgstr "Đặt về mặc định"
+msgstr "Đặt câu lệnh SQL về mặc định"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:93
-#, fuzzy
msgid "Verify"
-msgstr "Nắn chỉnh địa lý"
+msgstr "Kiểm chứng"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:94
-#, fuzzy
msgid "Verify SQL statement"
+msgstr "Kiển chứng câu lệnh SQL"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:99
-#, fuzzy
msgid "Apply SQL statement and close the dialog"
-msgstr "Áp dụng thay đổi và đóng hộp thoại"
+msgstr "Áp dụng câu lệnh SQL và đóng hộp thoại"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:101
-#, fuzzy
msgid "Close the dialog"
msgstr "Đóng hộp thoại"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:103
-#, fuzzy
msgid "Get all values"
-msgstr "Giá trị ô"
+msgstr "Lấy tất cả các giá trị"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:106
-#, fuzzy
msgid "Get sample"
-msgstr "Thiết lập giá trị"
+msgstr "Lấy mẫu"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:149
-#, fuzzy
msgid "Add on double-click"
-msgstr "Bấm đúp nút trái chuột"
+msgstr "Bấm đúp chuột để thêm vào"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:150
-#, fuzzy
msgid "columns"
-msgstr "Thêm cột"
+msgstr "cột"
-#, fuzzy
msgid "values"
-msgstr "(giá trị)"
+msgstr "giá trị"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:154
-#, fuzzy
msgid "Close dialog on apply"
-msgstr "Đóng hộp thoại khi gửi đi"
+msgstr "Đóng hộp thoại khi áp dụng"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:185
#: ../gui/wxpython/gui_modules/dbm.py:845
@@ -8105,19 +8009,16 @@
msgstr "Kết nối CSDL"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:240
-#, fuzzy
msgid "Columns"
-msgstr "Thể tích"
+msgstr "cột"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:242
-#, fuzzy
msgid "Values"
-msgstr "Thể tích"
+msgstr "giá trị"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:425
-#, fuzzy
msgid "SQL statement is not valid"
+msgstr "Câu lệnh SQL không hợp lệ"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:427
#, python-format
@@ -8126,11 +8027,13 @@
"\n"
"%s"
msgstr ""
+"Câu lệnh SQL không hợp lệ.\n"
+"\n"
+"%s"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:430
-#, fuzzy
msgid "SQL statement is valid"
+msgstr "Câu lệnh SQL hợp lệ"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:453
#: ../gui/wxpython/gui_modules/dbm.py:736
@@ -8222,13 +8125,13 @@
#: ../gui/wxpython/gui_modules/toolbars.py:188
msgid "3D view mode not available"
-msgstr ""
+msgstr "Không có chế độ xem 3D"
#: ../gui/wxpython/gui_modules/toolbars.py:189
#: ../gui/wxpython/gui_modules/toolbars.py:205
#, python-format
msgid "Reason: %s"
-msgstr ""
+msgstr "Lý do: %s"
#: ../gui/wxpython/gui_modules/toolbars.py:190
msgid ""
@@ -8243,9 +8146,8 @@
msgstr "Số hóa"
#: ../gui/wxpython/gui_modules/toolbars.py:204
-#, fuzzy
msgid "Vector digitizer not available"
-msgstr "Thanh công cụ của trình số hoá bản đồ"
+msgstr "Không có trình số hoá véc-tơ"
#: ../gui/wxpython/gui_modules/toolbars.py:206
msgid ""
@@ -8299,7 +8201,6 @@
msgstr "Truy vấn các đối tượng"
#: ../gui/wxpython/gui_modules/toolbars.py:921
-#, fuzzy
msgid "Z bulk-labeling of 3D lines"
msgstr "Gán nhãn hàng loạt giá trị Z cho các đường 3D"
@@ -8308,9 +8209,8 @@
#: ../gui/wxpython/gui_modules/toolbars.py:1040
-#, fuzzy
msgid "Vector map is not 3D. Operation canceled."
-msgstr "Không có lớp bản đồ nào được chọn. Thao tác bị hủy."
+msgstr "Bản đồ véc-tơ không phải loại 3D. Thao tác bị hủy."
#: ../gui/wxpython/gui_modules/toolbars.py:1106
#: ../gui/wxpython/gui_modules/toolbars.py:1203
@@ -8354,9 +8254,8 @@
msgstr "Bản đồ véc tơ mới"
#: ../gui/wxpython/gui_modules/toolbars.py:1666
-#, fuzzy
msgid "Add various raster-based map layers"
-msgstr "Thêm lớp bản đồ raster"
+msgstr "Thêm các lớp bản đồ gốc raster khác nhau"
#: ../gui/wxpython/gui_modules/toolbars.py:1672
#, fuzzy
@@ -8403,6 +8302,8 @@
"Unable to get current geographic extent. Force quiting wxGUI. Please run "
"manually g.region to fix the problem."
msgstr ""
+"Không thể lấy phạm vi địa lý hiện tại. Buộc phải thoát wxGUI. Vui lòng chạy "
+"thủ công lệnh g.region để khắc phục lỗi này."
#: ../gui/wxpython/gui_modules/render.py:923
msgid "ERROR: Rendering failed"
@@ -8434,6 +8335,8 @@
"Attribute table <%s> not found. For creating the table switch to 'Manage "
"layers' tab."
msgstr ""
+"Không tìm thấy bảng thuộc tính <%s>. Để tạo bảo, chuyển qua thẻ 'Quản lý "
+"lớp'."
#: ../gui/wxpython/gui_modules/dbm.py:165
#, python-format
@@ -8459,20 +8362,19 @@
msgstr "Số bản ghi đã nạp: %d"
#: ../gui/wxpython/gui_modules/dbm.py:292
-#, fuzzy
msgid "Unknown value"
-msgstr "Không biết"
+msgstr "Giá trị không biết"
#: ../gui/wxpython/gui_modules/dbm.py:307
+#, python-format
msgid ""
"Error loading attribute data. Record number: %(rec)d. Unable to convert "
"value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
"Details: %(detail)s"
msgstr ""
-"Lỗi khi đang nạp dữ liệu thuộc tính. Số bản ghi: %(rec)d. Không thể cộng gộp "
-"giá trị '%(val)s' trong cột khóa (%(key)s) thành số nguyên.\n"
+"Lỗi khi đang nạp dữ liệu thuộc tính. Số hiệu bản ghi: %(rec)d. Không thể "
+"chuyểnđổi giá trị '%(val)s' trong cột khóa (%(key)s) thành số nguyên.\n"
"\n"
"Chi tiết: %(detail)s"
@@ -8560,13 +8462,12 @@
msgstr "Quản lý lớp"
#: ../gui/wxpython/gui_modules/dbm.py:663
-#, fuzzy
msgid "Close Attribute Table Manager"
-msgstr "Bộ Quản Lý Bảng Thuộc Tính"
+msgstr "Đóng Trình Quản lý Bảng Thuộc tính"
#: ../gui/wxpython/gui_modules/dbm.py:665
msgid "Reload attribute data (selected layer only)"
-msgstr ""
+msgstr "Nạp lại dữ liệu thuộc tính (chỉ của lớp được chọn)"
#: ../gui/wxpython/gui_modules/dbm.py:694
msgid "Attribute data - right-click to edit/manage records"
@@ -8704,9 +8605,9 @@
#: ../gui/wxpython/gui_modules/dbm.py:1397
#: ../gui/wxpython/gui_modules/dbm.py:1504
+#, python-format
msgid "Value '%(value)s' needs to be entered as %(type)s."
-msgstr "Cộng dồn giá trị '%(value)s' vào %(type)s bị thất bại."
+msgstr "Giá trị '%(value)s' cần phải được nhập vào dưới dạng %(type)s."
#: ../gui/wxpython/gui_modules/dbm.py:1408
msgid "Unable to insert new record."
@@ -8750,29 +8651,29 @@
#: ../gui/wxpython/gui_modules/dbm.py:1675
+#, python-format
msgid ""
"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
"drop the column?"
msgstr ""
-"Các bản ghi dữ liệu đã được chọn (%d) sẽ bị xóa bỏ hoàn toàn khỏi bảng. Bạn "
-"có muốn xóa chúng không?"
+"Cột được chọn '%s' sẽ bị xóa bỏ HOÀN TOÀN khỏi bảng. Bạn có muốn xóa nó "
+"không?"
#: ../gui/wxpython/gui_modules/dbm.py:1678
#: ../gui/wxpython/gui_modules/dbm.py:1715
-#, fuzzy
msgid "Drop column(s)"
+msgstr "Bỏ (các) cột"
#: ../gui/wxpython/gui_modules/dbm.py:1712
+#, python-format
msgid ""
"Selected columns\n"
"%s\n"
"will PERMANENTLY removed from table. Do you want to drop the columns?"
msgstr ""
+"Các cột được chọn\n"
+"%s\n"
+"sẽ bị loại bỏ HOÀN TOÀN khỏi bảng. Bạn có muốn bỏ các cột không?"
#: ../gui/wxpython/gui_modules/dbm.py:1750
msgid "Unable to add column to the table. No column name defined."
@@ -8830,13 +8731,12 @@
msgstr "Khóa"
#: ../gui/wxpython/gui_modules/dbm.py:2359
-#, fuzzy
msgid ""
"Unknown default DB connection. Please define DB connection using db.connect "
"module."
msgstr ""
-"Không thể xác định thiết lập kết nối CSDL mặc định. Xin hãy định nghĩa kết "
-"nối CSDL bằng cách dùng mô-đun db.connect."
+"Kết nối CSDL mặc định không rõ. Xin hãy định nghĩa kết nối CSDL bằng cách "
+"dùng mô-đun db.connect."
#: ../gui/wxpython/gui_modules/dbm.py:2380
msgid "Add layer"
@@ -9076,22 +8976,19 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:1104
msgid "Override projection (use location's projection)"
-msgstr ""
+msgstr "Ghi đè phép chiếu (dùng phép chiếu của location)"
#: ../gui/wxpython/gui_modules/gdialogs.py:1108
-#, fuzzy
msgid "Add linked layers into layer tree"
-msgstr "Thêm các lớp đã nhập vào sơ đồ lớp hình cây"
+msgstr "Thêm các lớp được liên kết vào sơ đồ lớp hình cây"
#: ../gui/wxpython/gui_modules/gdialogs.py:1115
-#, fuzzy
msgid "&Link"
-msgstr "Đường"
+msgstr "&Liên kết"
#: ../gui/wxpython/gui_modules/gdialogs.py:1116
-#, fuzzy
msgid "Link selected layers"
-msgstr "Nhập các lớp đã chọn"
+msgstr "Liên kết các lớp đã chọn"
#: ../gui/wxpython/gui_modules/gdialogs.py:1179
msgid "Import DXF layers"
@@ -9106,9 +9003,8 @@
msgstr "Tên lớp"
#: ../gui/wxpython/gui_modules/gdialogs.py:1269
-#, fuzzy
msgid "Name for GRASS map"
+msgstr "Tên cho bản đồ GRASS"
#: ../gui/wxpython/gui_modules/gdialogs.py:1351
msgid "Set Map Layer Opacity"
@@ -9273,9 +9169,8 @@
msgstr "Áp dụng các thay đổi cho phiên làm việc hiện tại"
#: ../gui/wxpython/gui_modules/profile.py:1035
-#, fuzzy
msgid "Apply changes for the current session and close dialog"
-msgstr "Áp dụng các thay đổi cho phiên làm việc hiện tại"
+msgstr "Áp dụng các thay đổi cho phiên làm việc hiện tại và đóng hộp thoại"
#: ../gui/wxpython/gui_modules/profile.py:1038
#: ../gui/wxpython/gui_modules/profile.py:1390
@@ -9391,14 +9286,12 @@
msgstr "Các thuộc tính Nviz"
#: ../gui/wxpython/gui_modules/layertree.py:287
-#, fuzzy
msgid "Zoom to selected map(s)"
-msgstr "Phóng đến bản đồ đã chọn"
+msgstr "Phóng đến (các) bản đồ đã chọn"
#: ../gui/wxpython/gui_modules/layertree.py:289
-#, fuzzy
msgid "Set computational region from selected map(s)"
-msgstr "Thiết lập vùng tính toán từ bản đồ được chọn"
+msgstr "Thiết lập vùng tính toán từ (các) bản đồ đã chọn"
#: ../gui/wxpython/gui_modules/layertree.py:305
msgid "Show attribute data"
@@ -9417,15 +9310,14 @@
msgstr "Dùng như bản đồ véc tơ nền"
#: ../gui/wxpython/gui_modules/layertree.py:364
-#, fuzzy
msgid "Zoom to selected map(s) (ignore NULLs)"
-msgstr "Phóng đến bản đồ đã chọn (bỏ qua các giá trị RỖNG)"
+msgstr "Phóng đến (các) bản đồ đã chọn (bỏ qua các giá trị RỖNG)"
#: ../gui/wxpython/gui_modules/layertree.py:366
-#, fuzzy
msgid "Set computational region from selected map(s) (ignore NULLs)"
msgstr ""
-"Thiết lập vùng tính toán theo bản đồ được chọn (bỏ qua các giá trị RỖNG)"
+"Thiết lập vùng tính toán theo (các) bản đồ được chọn (bỏ qua các giá trị "
+"RỖNG)"
#: ../gui/wxpython/gui_modules/layertree.py:369
msgid "Set color table"
@@ -9496,7 +9388,6 @@
msgstr "số lượng ô raster"
#: ../gui/wxpython/gui_modules/layertree.py:733
-#, fuzzy
msgid "raster flow arrows"
msgstr "mũi tên dòng chảy raster"
@@ -9558,9 +9449,8 @@
msgstr "<bắt buộc>"
#: ../gui/wxpython/gui_modules/menuform.py:677
-#, fuzzy
msgid "Enter parameters for '"
+msgstr "Nhập các tham số cho '"
#: ../gui/wxpython/gui_modules/menuform.py:688
#, fuzzy
@@ -9828,9 +9718,8 @@
msgstr "Co tất cả trừ PERMANENT"
#: ../gui/wxpython/gui_modules/preferences.py:602
-#, fuzzy
msgid "Collapse all except current"
-msgstr "Ẩn tất cả trừ PERMANENT và bộ bản đồ hiện tại"
+msgstr "Thu nhỏ tất cả trừ phần hiện tại"
#: ../gui/wxpython/gui_modules/preferences.py:603
msgid "Collapse all"
@@ -9873,9 +9762,8 @@
msgstr "hình sao"
#: ../gui/wxpython/gui_modules/preferences.py:639
-#, fuzzy
msgid "gyro"
-msgstr "con quay gyro"
+msgstr "gyro"
#: ../gui/wxpython/gui_modules/preferences.py:640
msgid "histogram"
@@ -9977,7 +9865,6 @@
msgstr "Thiết lập cho Bộ Quản Lý Lớp"
#: ../gui/wxpython/gui_modules/preferences.py:1145
-#, fuzzy
msgid "Ask when removing map layer from layer tree"
msgstr "Hỏi khi gỡ lớp bản đồ khỏi sơ đồ lớp hình cây"
@@ -10049,22 +9936,20 @@
msgstr "Làm nổi bật"
#: ../gui/wxpython/gui_modules/preferences.py:1511
-#, fuzzy
msgid "Line width (in pixels):"
-msgstr "Độ dày đường (theo pixels)"
+msgstr "Độ dày đường (theo điểm ảnh):"
#: ../gui/wxpython/gui_modules/preferences.py:1534
msgid "Data browser"
msgstr "Trình duyệt dữ liệu"
#: ../gui/wxpython/gui_modules/preferences.py:1539
-#, fuzzy
msgid "Left mouse double click:"
+msgstr "Bấm đúp nút trái chuột:"
#: ../gui/wxpython/gui_modules/preferences.py:1551
msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
-msgstr ""
+msgstr "Mã hoá (ví dụ như utf-8, ascii, iso8859-1, koi8-r):"
#: ../gui/wxpython/gui_modules/preferences.py:1562
msgid "Ask when deleting data record(s) from table"
@@ -10075,9 +9960,8 @@
msgstr "Tạo bảng"
#: ../gui/wxpython/gui_modules/preferences.py:1590
-#, fuzzy
msgid "Key column:"
-msgstr "Cột khóa"
+msgstr "Cột khóa:"
#: ../gui/wxpython/gui_modules/preferences.py:1623
#, fuzzy
@@ -10219,9 +10103,8 @@
msgstr "Đã hủy việc cài đặt cho nắn chỉnh địa lý"
#: ../gui/wxpython/gui_modules/georect.py:194
-#, fuzzy
msgid "GRASS GIS Map Display: 1"
-msgstr "Màn Hình Bản Đồ GRASS GIS:"
+msgstr "Trình bày Bản đồ GRASS GIS: 1"
#: ../gui/wxpython/gui_modules/georect.py:301
msgid "Select map type and location/mapset"
@@ -10264,9 +10147,8 @@
msgstr "Tạo/biên tập nhóm..."
#: ../gui/wxpython/gui_modules/georect.py:448
-#, fuzzy
msgid "Add vector map to group..."
-msgstr "Thêm lớp bản đồ véc tơ"
+msgstr "Thêm bản đồ véc-tơ vào nhóm..."
#: ../gui/wxpython/gui_modules/georect.py:460
msgid "Extension for output maps:"
@@ -10293,9 +10175,8 @@
msgstr "Bạn phải chọn một ảnh/bản đồ hợp lệ để tiếp tục"
#: ../gui/wxpython/gui_modules/georect.py:666
-#, fuzzy
msgid "Define/manage ground control points"
-msgstr "Tạo và &quản lý các điểm khống chế"
+msgstr "Tạo/quản lý các điểm khống chế"
#: ../gui/wxpython/gui_modules/georect.py:764
msgid "Select rectification method for rasters"
@@ -10366,30 +10247,28 @@
10 điểm trở lên cho bậc 3."
#: ../gui/wxpython/gui_modules/georect.py:1120
-#, fuzzy, python-format
+#, python-format
msgid "Transforming <%s>..."
-msgstr "Chuyển đổi ảnh"
+msgstr "Đang chuyển đổi <%s>..."
#: ../gui/wxpython/gui_modules/georect.py:1139
#: ../gui/wxpython/gui_modules/georect.py:1205
+#, python-format
msgid "Georectification of vector map <%s> failed"
-msgstr "Nắn chỉnh địa lý các bản đồ raster và véc tơ"
+msgstr "Nắn chỉnh địa lý bản đồ véc-tơ <%s> thất bại"
#: ../gui/wxpython/gui_modules/georect.py:1180
+#, python-format
msgid ""
"Vector map <%s> already exists. Change extension name and georectify again."
-msgstr ""
-"Bản đồ véc tơ <%s> đã có trong tập bản đồ hiện tại. Bạn có muốn ghi đè lên "
-"không?"
+msgstr "Bản đồ véc-tơ <%s> đã có. Đổi tên phần mở rộng và nắn chỉnh lại."
#: ../gui/wxpython/gui_modules/georect.py:1211
msgid "Georectifier settings"
msgstr "Các thiết lập cho trình nắn chỉnh địa lý"
#: ../gui/wxpython/gui_modules/georect.py:1305
+#, python-format
msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
msgstr "Sai số RMS cho các điểm được chọn tới: %(fwd)s lui: %(bkw)s"
@@ -10427,14 +10306,12 @@
msgstr "Giá trị tọa độ không hợp lệ. Thao tác bị hủy."
#: ../gui/wxpython/gui_modules/georect.py:1466
-#, fuzzy
msgid "Create vector map group"
-msgstr "Tạo bản đồ véc tơ mới"
+msgstr "Tạo nhóm bản đồ véc-tơ"
#: ../gui/wxpython/gui_modules/georect.py:1539
-#, fuzzy
msgid "Select vector map(s) to add to group:"
-msgstr "Chọn bản đồ véc tơ:"
+msgstr "Chọn (các) bản đồ véc-tơ để thêm vào nhóm:"
#: ../gui/wxpython/gui_modules/georect.py:1597
msgid "Ground Control Point"
@@ -10573,6 +10450,7 @@
#: ../gui/wxpython/gis_set.py:209 ../gui/wxpython/gis_set.py:573
msgid "Unable to set GRASS database. Check your locale settings."
msgstr ""
+"Không thể thiết lập CSDL GRASS. Kiểm tra các thiết lập bản địa của bạn."
#: ../gui/wxpython/gis_set.py:227
#, python-format
@@ -10590,15 +10468,19 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
+"Bộ bản đồ <PERMANENT> cần có đối với một location GRASS hợp lệ.\n"
+"\n"
+"Không thể đổi tên bộ bản đồ này."
#: ../gui/wxpython/gis_set.py:446 ../gui/wxpython/gis_set.py:481
+#, python-format
msgid ""
"Current name: %s\n"
"\n"
"Enter new name:"
msgstr ""
"Tên hiện tại: %s\n"
+"\n"
"Nhập tên mới:"
#: ../gui/wxpython/gis_set.py:447
@@ -10606,40 +10488,52 @@
msgstr "Đổi tên tập bản đồ đã chọn"
#: ../gui/wxpython/gis_set.py:458
+#, python-format
msgid ""
"Unable to rename mapset.\n"
"\n"
"Mapset <%s> already exists in location."
-msgstr "Không thể tạo bảng mới. Bảng <%s> đã có trong CSDL."
+msgstr ""
+"Không thể đổi tên bộ bản đồ.\n"
+"\n"
+"Bộ bản đồ <%s> đã có trong location."
#: ../gui/wxpython/gis_set.py:470
+#, python-format
msgid ""
"\n"
"%s"
-msgstr "Không thể đổi tên tập bản đồ"
+msgstr ""
+"\n"
+"%s"
#: ../gui/wxpython/gis_set.py:482
msgid "Rename selected location"
msgstr "Đổi tên vị trí đã chọn"
#: ../gui/wxpython/gis_set.py:493
+#, python-format
msgid ""
"Unable to rename location.\n"
"\n"
"Location <%s> already exists in GRASS database."
+msgstr ""
+"Không thể đổi tên location.\n"
+"\n"
+"Location <%s> đã có trong CSDL GRASS."
#: ../gui/wxpython/gis_set.py:506
+#, python-format
msgid ""
"\n"
"%s"
-msgstr "Không thể đổi tên vị trí"
+msgstr ""
+"\n"
+"%s"
#: ../gui/wxpython/gis_set.py:518
msgid ""
@@ -10647,6 +10541,9 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
+"\n"
#: ../gui/wxpython/gis_set.py:523
#, python-format
@@ -10711,7 +10608,7 @@
#: ../gui/wxpython/gis_set.py:838
msgid "Starting GRASS for the first time"
-msgstr ""
+msgstr "Khởi động GRASS lần đầu tiên"
#: ../gui/wxpython/gis_set.py:839
msgid ""
@@ -10719,6 +10616,9 @@
"have not already done so. A popular choice is \"grassdata\", located in your "
"home directory."
msgstr ""
+"GRASS cần một thư mục để lưu trữ dữ liệu của nó. Tạo một thư mục ngay nếu "
+"bạn chưa làm. Tên thư mục thường được dùng là \"grassdata\", nằm trong thư "
+"mục nhà của bạn."
#, fuzzy
msgid ""
@@ -10730,9 +10630,8 @@
"Thất bại khi đọc tập tin không gian làm việc <%s>. Tập tin không hợp lệ, "
"không thể phân giải tài liệu XML."
-#, fuzzy
msgid "GRASS GIS Map Calculator (3D raster)"
-msgstr "Trình tính toán Bản đồ %s của GRASS"
+msgstr "Trình tính toán Bản đồ của GRASS GIS (raster 3D)"
msgid "Import raster map"
msgstr "Nhập bản đồ raster"
@@ -10900,9 +10799,8 @@
#~ msgid "Display shortest route (requires XTerm)"
#~ msgstr "Hiển thị lộ trình ngắn nhất (cần có XTerm)"
-#, fuzzy
#~ msgid "Find shortest path for selected starting and ending node"
-#~ msgstr "Tìm đường ngắn nhất trên mạng lưới vec-tơ."
+#~ msgstr "Tìm đường ngắn nhất giữa nốt bắt đầu và kết thúc đã chọn"
#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
#~ msgstr ""
@@ -11279,13 +11177,11 @@
#~ msgid "GRASS GIS Raster Map Calculator (3D raster)"
#~ msgstr "Trình tính toán Bản đồ %s của GRASS"
-#, fuzzy
#~ msgid "Add various vector-based map layer"
-#~ msgstr "Thêm lớp bản đồ véc tơ"
+#~ msgstr "Thêm các lớp bản đồ gốc véc-tơ khác nhau"
-#, fuzzy
#~ msgid "COPYING file missing"
-#~ msgstr "Thiếu mã EPSG."
+#~ msgstr "Thiếu tập tin COPYING"
#~ msgid "Force re-rendering of all layers"
#~ msgstr "Buộc vẽ lại tất cả các lớp"
@@ -11329,25 +11225,23 @@
#~ msgid "Show Nviz settings dialog"
#~ msgstr "Hiện hộp thoại thiết lập Nviz"
-#, fuzzy
#~ msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
#~ msgstr ""
-#~ "Nối tập tin raster được GDAL hỗ trợ với một lớp bản đồ raster nhị phân."
+#~ "Liên kết dữ liệu raster được GDAL hỗ vào thành một lóp bản đồ raster giả "
+#~ "GRASS."
#~ msgid "Downloads and imports data from WMS servers."
#~ msgstr "Tải xuống và nhập dữ liệu từ các máy chủ WMS."
-#, fuzzy
#~ msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-#~ msgstr "Tạo một bản đồ vec-tơ mới ở dạng chỉ đọc liên kết vào lớp OGR."
+#~ msgstr ""
+#~ "Tạo một bản đồ giả vec-tơ mới ở dạng liên kết một vào lớp được OGR hỗ trợ."
-#, fuzzy
#~ msgid "Matlab-ASCII or Mapgen import"
-#~ msgstr "Nhập dữ liệu Matlab và MapGen"
+#~ msgstr "Nhập dữ liệu Matlab-ASCII và Mapgen"
-#, fuzzy
#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-#~ msgstr "Nhập các bản đồ vec-tơ MapGen và Matlab"
+#~ msgstr "Nhập các bản đồ vec-tơ Mapgen và Matlab-ASCII vào GRASS."
#~ msgid "Export GRASS raster as non-georeferenced PNG image format."
#~ msgstr ""
@@ -11362,7 +11256,6 @@
#~ msgid "Config"
#~ msgstr "Cấu hình"
-#, fuzzy
#~ msgid "Raster"
#~ msgstr "Raster"
@@ -11453,17 +11346,14 @@
#~ msgid "Nviz toolbar"
#~ msgstr "Thanh công cụ Nviz"
-#, fuzzy
#~ msgid "Unable to read EPGS file: '%s'"
-#~ msgstr "Không thể đọc các mã EPSG: %s"
+#~ msgstr "Không thể đọc tập tin EPSG: '%s'"
-#, fuzzy
#~ msgid "Resolution cannot be 0"
-#~ msgstr "Độ phân giải"
+#~ msgstr "Độ phân giải không thể là 0"
-#, fuzzy
#~ msgid "3D View Tools"
-#~ msgstr "Các công cụ Nviz"
+#~ msgstr "Các công cụ xem 3D"
#~ msgid "coarse:"
#~ msgstr "thô:"
@@ -11501,15 +11391,14 @@
#~ msgid "Error in command execution %s"
#~ msgstr "Lỗi khi thi hành lệnh %s"
-#, fuzzy
#~ msgid ""
#~ "Unable to initialize display driver of vector digitizer. See 'Command "
#~ "output' for details.\n"
#~ "\n"
#~ "Details:"
#~ msgstr ""
-#~ "Không thể khởi tạo trình điều khiển màn hình, xem tập tin README để có "
-#~ "thêm thông tin.\n"
+#~ "Không thể khởi tạo trình điều khiển trình bày cho chương trình số hoá véc-"
+#~ "tơ. Xem 'Đầu ra của lệnh' để biết thêm chi tiết.\n"
\n"
#~ "Chi tiết:"
@@ -11519,9 +11408,8 @@
#~ msgid "Unable to open file"
#~ msgstr "Không thể mở tập tin"
-#, fuzzy
#~ msgid "DXF file:"
-#~ msgstr "Chọn tệp DXF:"
+#~ msgstr "Tập tin DXF:"
#~ msgid "Parameter not found: %s"
#~ msgstr "Không thấy tham số: %s"
@@ -11553,14 +11441,12 @@
#~ msgid "User GUI settings"
#~ msgstr "Thiết lập giao diện đồ họa của người dùng"
-#, fuzzy
#~ msgid ""
#~ "Check a mapset to make it accessible, uncheck it to hide it.%sNote: The "
#~ "current mapset is always accessible."
#~ msgstr ""
-#~ "Đánh dấu vào bộ bản đồ để truy cập được vào nó, tắt đánh dấu để ẩn nó đi. "
-#~ "%sGhi chú: bộ bản đồ PERMANENT và bộ bản đồ hiện tại luôn luôn truy cập "
-#~ "được."
+#~ "Đánh dấu vào bộ bản đồ để làm cho nó truy cập được, tắt đánh dấu để ẩn nó "
+#~ "đi. %sGhi_chú: Bộ bản đồ hiện tại luôn luôn truy cập được."
#~ msgid "Start GRASS"
#~ msgstr "Khởi động GRASS"
@@ -11587,3 +11473,64 @@
#~ "Bạn có muốn đóng màn hình %d?\n"
#~ "\n"
#~ "%s"
+#~ msgid "Official GRASS site: http://grass.osgeo.org"
+#~ msgstr "Địa chỉ chính thức của GRASS: http://grass.osgeo.org"
+#~ msgid "GIS Library"
+#~ msgstr "Thư viện GIS"
+#~ msgid "GPL.TXT file missing"
+#~ msgstr "Thiếu tập tin GPL.TXT"
+#~ msgid "AUTHORS file missing"
+#~ msgstr "Thiếu tập tin AUTHORS"
+#~ msgid "Extents set incorrectly"
+#~ msgstr "Phạm được thiết lập không đúng"
+#~ msgid ""
+#~ "Command '%s' not yet implemented in the GUI. Try adding it as a command "
+#~ "layer instead."
+#~ msgstr ""
+#~ "Lệnh '%s' chưa được thực thi trong GDĐH. Hãy thử thêm nó vào dưới dạng "
+#~ "một lớp lệnh."
+#~ msgid "Quit wxGUI. GRASS is not running."
+#~ msgstr "Thoát wxGUI. GRASS hiện không chạy."
+#~ msgid "GRASS GIS Map Calculator"
+#~ msgstr "Trình tính toán Bản đồ của GRASS GIS"
+#~ msgid "Projection for current location"
+#~ msgstr "Phép chiếu cho vị trí hiện tại"
+#~ msgid "Raster calculator"
+#~ msgstr "Trình tính toán raster"
+#~ msgid "logical AND (ignores NULLs"
+#~ msgstr "luân lý VÀ (bỏ qua các giá trị RỖNG"
+#~ msgid "logical OR (ignores NULLs"
+#~ msgstr "luân lý HOẶC (bỏ qua các giá trị RỖNG"
+#~ msgid ""
+#~ "Note that the 3D view mode is currently not working under MS Windows "
+#~ "(hopefully this will be fixed soon). Please keep an eye out for updated "
+#~ "versions of GRASS."
+#~ msgstr ""
+#~ "Lưu ý rằng chế độ xem 3D hiện tại không làm việc trong M$ Windows (hy "
+#~ "vọng điều này sẽ được sớm khắc phục). Vui lòng để ý đến các phiên bản cập "
+#~ "nhật của GRASS."
+#~ msgid ""
+#~ "Note that the vector digitizer is currently not working under MS Windows "
+#~ msgstr ""
+#~ "Lưu ý rằng trình số số véc-tơ hiện tại không làm việc trong M$ Windows "
+#~ "(hy vọng điều này sẽ sớm được khắc phục). Vui lòng để ý xem các phiên bản "
+#~ "cập nhật của GRASS."
+#~ msgid "Create/edit projection information for current location"
+#~ msgstr "Tạo/Chỉnh sửa thông tin phép chiếu cho vị trí hiện tại"
