[GRASS-SVN] r44543 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat Dec 4 19:25:02 EST 2010
Author: neteler
Date: 2010-12-04 16:25:02 -0800 (Sat, 04 Dec 2010)
New Revision: 44543
grass/trunk/locale/po/grasslibs_it.po
grass/trunk/locale/po/grasswxpy_it.po
Luca Delucchi: cont'ed
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po 2010-12-05 00:24:49 UTC (rev 44542)
+++ grass/trunk/locale/po/grasslibs_it.po 2010-12-05 00:25:02 UTC (rev 44543)
@@ -13,12 +13,13 @@
"Project-Id-Version: grasslibs_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-08-29 12:41+0200\n"
-"PO-Revision-Date: 2007-11-21 12:41+0100\n"
-"Last-Translator: Andrea Giacomelli <pibinko at gmail.com>\n"
+"PO-Revision-Date: 2010-12-05 00:35+0100\n"
+"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
+"Language: it\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
"X-Generator: KBabel 1.11.4\n"
@@ -38,7 +39,6 @@
msgstr ""
#: ../lib/raster/sample.c:70
-#, fuzzy
msgid "Unknown interpolation type"
msgstr "Tipo di interpolazione sconosciuta"
@@ -135,9 +135,9 @@
msgstr ""
#: ../lib/raster/put_row.c:179
-#, fuzzy, c-format
+#, c-format
msgid "xdr_double failed for index %d of row %d"
-msgstr "cell_values_double: xdr_double fallimento lettura dell'indice %d."
+msgstr "xdr_double fallito per l'indice %d della riga %d"
#: ../lib/raster/put_row.c:397 ../lib/raster/put_row.c:403
#, fuzzy, c-format
@@ -243,10 +243,10 @@
msgstr "supporto colore per [%s] nel mapset [%s] %s"
#: ../lib/raster/get_row.c:37 ../lib/raster/get_row.c:882
-#, fuzzy, c-format
+#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
msgstr ""
-"[%s in %s] - la lettura richiesta per la riga %d è al di fuori dalla regione"
+" Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
#: ../lib/raster/get_row.c:96 ../lib/raster/get_row.c:101
#: ../lib/raster/get_row.c:134 ../lib/raster/get_row.c:140
@@ -266,14 +266,14 @@
msgstr "cell_values_float: xdr_float lettura non riuscita per l'indice %d"
#: ../lib/raster/get_row.c:352
-#, fuzzy, c-format
+#, c-format
msgid "cell_values_double: xdr_double failed for index %d"
-msgstr "cell_values_double: xdr_double lettura non riuscita per l'indice %d."
+msgstr "cell_values_double: xdr_double fallita per l'indice %d"
#: ../lib/raster/get_row.c:866 ../lib/raster/get_row.c:869
-#, fuzzy, c-format
+#, c-format
msgid "Error reading null row %d"
-msgstr "errore nella lettura della riga vuota %d"
+msgstr "Errore nella lettura della riga vuota %d"
#: ../lib/raster/alloc_cell.c:151
#, c-format
@@ -378,14 +378,13 @@
msgstr ""
#: ../lib/raster/gdal.c:76
-#, fuzzy, c-format
+#, c-format
msgid "Unable to locate symbol <%s>"
-msgstr "Impossibile aprire il file %s in %s"
+msgstr "Impossibile trovare il simbolo <%s>"
#: ../lib/raster/gdal.c:119
-#, fuzzy
msgid "Unable to load GDAL library"
-msgstr "Impossibile calcolare il centroide dell'area %d"
+msgstr "Impossibile caricare le librerie GDAL"
#: ../lib/raster/gdal.c:335
#, fuzzy
@@ -474,9 +473,8 @@
#: ../lib/raster/closecell.c:477
-#, fuzzy
msgid "unable to write f_format file for CELL maps"
-msgstr "Impossibile creare il file di intestazione per [%s]"
+msgstr "Impossibile scrivere file f_format per mappe CELL"
#: ../lib/raster/opencell.c:170 ../lib/raster/opencell.c:742
#: ../lib/raster/opencell.c:779 ../lib/raster/opencell.c:831
@@ -501,18 +499,18 @@
#: ../lib/ogsf/Gs3.c:356 ../lib/ogsf/Gs3.c:470 ../lib/ogsf/Gs3.c:565
#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:758
#: ../lib/ogsf/Gs3.c:828
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found"
-msgstr "Non riesco a trovare il vettore '%s' di input"
+msgstr "Raster <%s> non trovato"
#: ../lib/raster/opencell.c:185
-#, fuzzy, c-format
+#, c-format
msgid ""
"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%"
"s> which does not exist"
msgstr ""
-"impossibile aprire [%s] in [%s] poiché è una riclassificazione di [%s] in [%"
-"s] che non esiste"
+"impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@%"
+"s> che non esiste"
#: ../lib/raster/opencell.c:190
#, fuzzy, c-format
@@ -525,10 +523,9 @@
msgstr "per mappe raster presenti %d\n"
#: ../lib/raster/opencell.c:209
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-"[%s] nel mapset [%s] - formato campo nell'intestazione del file non valido"
+msgstr "Raster <%s@%s>: formato campo nell'intestazione del file non valido"
#: ../lib/raster/opencell.c:214
#, fuzzy, c-format
@@ -577,15 +574,14 @@
#: ../lib/raster/opencell.c:575
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr ""
-"Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
+msgstr "Il raster <%s> non si trova nel mapset in uso (%s)"
#: ../lib/raster/opencell.c:582
-#, fuzzy, c-format
+#, c-format
msgid "<%s> is an illegal file name"
-msgstr "opencell: %s - nome file non valido"
+msgstr "<%s> è un nome file non valido"
#: ../lib/raster/opencell.c:596
#, fuzzy
@@ -602,19 +598,19 @@
msgstr ""
#: ../lib/raster/opencell.c:776
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found in mapset <%s>"
+msgstr "Raster <%s> non trovato nel mapset <%s>"
#: ../lib/raster/opencell.c:837
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find '%s'"
-msgstr "impossibile trovare [%s]"
+msgstr "Impossibile trovare '%s'"
#: ../lib/raster/opencell.c:848
-#, fuzzy, c-format
+#, c-format
msgid "Invalid type: field '%s' in file '%s'"
-msgstr "tipo non valido: campo %s nel file %s"
+msgstr "Tipo non valido: campo '%s' nel file '%s'"
#: ../lib/raster/opencell.c:853
#, fuzzy, c-format
@@ -622,9 +618,9 @@
#: ../lib/raster/opencell.c:858
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> is not xdr: byte_order: %s"
+msgstr "Raster <%s> non è xdr: byte_order: %s"
#: ../lib/raster/opencell.c:927
msgid ""
@@ -710,9 +706,8 @@
msgstr "R/G/B non in raggio 0-255"
#: ../lib/raster/color_rules.c:116
-#, fuzzy
msgid "invalid color name"
-msgstr "Coordinate non valide"
+msgstr "Nome del colore non valido"
#: ../lib/raster/color_rules.c:118
msgid "percentage not in range 0-100"
@@ -732,9 +727,9 @@
msgstr ""
#: ../lib/raster/color_rules.c:268
-#, fuzzy, c-format
+#, c-format
msgid "Unable to load color rules <%s>"
-msgstr "impossibile cambiare la directory %s"
+msgstr "Impossibile caricare le regole dei colori <%s>"
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
@@ -746,19 +741,17 @@
"s] che non esiste"
#: ../lib/raster/get_cellhd.c:70
-#, fuzzy
msgid "which is missing."
-msgstr "che non è presente"
+msgstr "che non è presente."
#: ../lib/raster/get_cellhd.c:71
-#, fuzzy
msgid "whose header file can't be opened."
-msgstr "il cui header file non può essere aperto"
+msgstr "il cui header file non può essere aperto."
#: ../lib/raster/get_cellhd.c:76
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open header file for raster map <%s@%s>"
-msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
+msgstr "Non riesco ad aprire il file di intestazione per il raster <%s@%s>"
#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
#, fuzzy, c-format
@@ -827,9 +820,9 @@
#: ../lib/vector/Vlib/legal_vname.c:115 ../lib/vector/Vlib/legal_vname.c:118
#: ../lib/vector/Vlib/map.c:403 ../lib/vector/Vlib/open.c:197
#: ../lib/ogsf/Gv3.c:58 ../lib/ogsf/Gp3.c:58
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> not found"
+msgstr "Vettoriale <%s> non trovato"
#: ../lib/manage/do_rename.c:45
#, fuzzy, c-format
@@ -1037,9 +1030,9 @@
msgstr ""
#: ../lib/proj/get_proj.c:148
-#, fuzzy, c-format
+#, c-format
msgid "Invalid zone %s specified"
-msgstr "Nessun ellissoide valido %s nel file"
+msgstr "Zona %s specificata invalida"
#: ../lib/proj/get_proj.c:228
msgid "Unable to initialise PROJ.4 with the following parameter list:"
@@ -1048,16 +1041,16 @@
#: ../lib/proj/get_proj.c:236
#, c-format
msgid "The error message: %s"
-msgstr ""
+msgstr "Il messaggio d'errore: %s"
#: ../lib/proj/get_proj.c:294
msgid "Option input overflowed option table"
msgstr ""
#: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
+#, c-format
msgid "Unable to initialize pj cause: %s"
+msgstr "Impossibile inizializzare pj a causa: %s"
#: ../lib/proj/get_proj.c:401
msgid "Input Projection Parameters"
@@ -1076,14 +1069,14 @@
msgstr ""
#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open datum table file <%s>"
-msgstr "impossibile aprire il file tabella datum: %s"
+msgstr "impossibile aprire il file tabella datum <%s>"
#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
-#, fuzzy, c-format
+#, c-format
msgid "Error in datum table file <%s>, line %d"
-msgstr "errore nel file tabella datum, linea %d"
+msgstr "Errore nel file tabella datum <%s>, linea %d"
#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
#, c-format
@@ -1091,27 +1084,26 @@
msgstr ""
#: ../lib/proj/ellipse.c:76
-#, fuzzy, c-format
+#, c-format
msgid "Invalid ellipsoid <%s> in file"
+msgstr "Ellissoide <%s> invalido nel file"
#: ../lib/proj/ellipse.c:100
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
msgstr ""
#: ../lib/proj/ellipse.c:104
-#, fuzzy
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr "Descrittori (a, rf, es o b) dell'ellissoide invalidi nel file"
#: ../lib/proj/ellipse.c:117
msgid "No ellipsoid info given in file"
msgstr "Nessuna informazione sull'ellissoide nel file dato"
#: ../lib/proj/ellipse.c:217 ../lib/gis/get_ellipse.c:263
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open ellipsoid table file <%s>"
-msgstr "impossibile aprire il file con la tabella dell'ellissoide: %s"
+msgstr "impossibile aprire il file con la tabella dell'ellissoide <%s>"
#: ../lib/proj/ellipse.c:270 ../lib/gis/get_ellipse.c:322
#, c-format
@@ -1126,7 +1118,7 @@
#: ../lib/proj/convert.c:111
msgid "Unable parse GRASS PROJ_INFO file"
-msgstr ""
+msgstr "Impossibile analizzare il file di GRASS PROJ_INFO"
#: ../lib/proj/convert.c:116
msgid "Unable get PROJ.4-style parameter string"
@@ -1150,7 +1142,7 @@
#: ../lib/proj/convert.c:433
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
+msgstr "Datum <%s> non riconosciuto da GRASS e nessun parametro trovato"
#: ../lib/proj/convert.c:449
#, c-format
@@ -1158,6 +1150,8 @@
"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
"want to look into this."
msgstr ""
+"Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro "
+"è stato trovato. Dovresto controllare all'interno di questo."
#: ../lib/proj/convert.c:453
#, c-format
@@ -1172,9 +1166,9 @@
msgstr ""
#: ../lib/gis/find_file.c:88
-#, fuzzy, c-format
+#, c-format
msgid "Using <%s@%s>"
+msgstr "Usando <%s@%s>"
#: ../lib/gis/view.c:176
#, c-format
@@ -1207,14 +1201,14 @@
"GRASS in uso"
#: ../lib/gis/mapset_msc.c:61
-#, fuzzy, c-format
+#, c-format
msgid "Unable to make mapset element %s (%s): %s"
-msgstr "Non posso creare l'elemento mapset %s (%s)"
+msgstr ""
#: ../lib/gis/mapset_msc.c:65
-#, fuzzy, c-format
+#, c-format
msgid "Unable to access mapset element %s (%s): %s"
+msgstr "Non è possibile accedere all'elemento mapset %s (%s): %s"
#: ../lib/gis/adj_cellhd.c:44 ../lib/gis/adj_cellhd.c:192
msgid "Illegal n-s resolution value"
@@ -1301,7 +1295,6 @@
msgstr "valore di profondità non valido"
#: ../lib/gis/adj_cellhd.c:299
-#, fuzzy
msgid "Top must be larger than Bottom"
msgstr "Il Nord deve essere più grande del Sud"
@@ -1323,7 +1316,7 @@
#: ../lib/gis/parser.c:388
#, c-format
msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr ""
+msgstr "BUG nella descrizione, opzione '%s' in <%s> non esiste"
#: ../lib/gis/parser.c:490
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
@@ -1339,9 +1332,8 @@
msgstr "Mi spiace <%s> non è una opzione valida\n"
#: ../lib/gis/parser.c:778
-#, fuzzy
msgid "Unable to determine program name"
-msgstr "Impossibile determinare la cartella di home degli utenti"
+msgstr "Impossibile determinare il nome del programma"
#: ../lib/gis/parser.c:792 ../lib/gis/parser.c:807
#, c-format
@@ -1359,13 +1351,13 @@
msgstr "Spiacente <%s> non è un parametro valido\n"
#: ../lib/gis/parser.c:987
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"ERROR: illegal range syntax for parameter <%s>\n"
msgstr ""
"\n"
-"Errore: intervallo di sintassi non valido per il parametro <%s>\n"
+"ERRORE: intervallo di sintassi non valido per il parametro <%s>\n"
#: ../lib/gis/parser.c:988
#, c-format
@@ -1373,13 +1365,13 @@
msgstr " Presentato come: %s\n"
#: ../lib/gis/parser.c:992
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"ERROR: value <%s> out of range for parameter <%s>\n"
msgstr ""
"\n"
-"Errore: il valore <%s> è fuori dall'intervallo atteso dal parametro<%s>\n"
+"ERRORE: il valore <%s> è fuori dall'intervallo atteso dal parametro<%s>\n"
#: ../lib/gis/parser.c:994
#, c-format
@@ -1387,13 +1379,13 @@
msgstr " Intervallo valido: %s\n"
#: ../lib/gis/parser.c:997
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"ERROR: Missing value for parameter <%s>\n"
msgstr ""
"\n"
-"Errore: Valore assente per il parametro <%s>\n"
+"ERRORE: Valore assente per il parametro <%s>\n"
#: ../lib/gis/parser.c:1001
#, fuzzy, c-format
@@ -1421,13 +1413,13 @@
" (%s).\n"
#: ../lib/gis/parser.c:1232
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"ERROR: option <%s> must be provided in multiples of %d\n"
msgstr ""
"\n"
-"Errore: l'opzione <%s> deve essere fornita come multipli di %d\n"
+"ERRORE: l'opzione <%s> deve essere fornita come multipli di %d\n"
#: ../lib/gis/parser.c:1234
#, c-format
@@ -1435,9 +1427,9 @@
msgstr " Hai fornito %d oggetti:\n"
#: ../lib/gis/parser.c:1292
-#, fuzzy, c-format
+#, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr "Errore: l'opzione <%s>: <%s> esiste.\n"
+msgstr "ERRORE: l'opzione <%s>: <%s> esiste.\n"
#: ../lib/gis/worker.c:72
msgid "Task already has a worker"
@@ -1469,9 +1461,9 @@
msgstr ""
#: ../lib/gis/spawn.c:416
-#, fuzzy, c-format
+#, c-format
msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: impossibile duplicare la descrizione %d in %d"
+msgstr "G_spawn: impossibile duplicare la descrizione %d"
#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:609
#, c-format
@@ -1479,9 +1471,8 @@
msgstr "G_spawn: impossibile aprire il file %s"
#: ../lib/gis/spawn.c:493 ../lib/gis/spawn.c:679
-#, fuzzy
msgid "Unable to execute command"
-msgstr "impossibile eseguire il comando"
+msgstr "Impossibile eseguire il comando"
#: ../lib/gis/spawn.c:518 ../lib/gis/spawn.c:526
#, c-format
@@ -1514,14 +1505,13 @@
#: ../lib/gis/spawn.c:656
-#, fuzzy
msgid "Unable to create a new process"
-msgstr "impossibile creare un nuovo processo"
+msgstr "Impossibile creare un nuovo processo"
#: ../lib/gis/spawn.c:671
-#, fuzzy, c-format
+#, c-format
msgid "Unable to change directory to %s"
+msgstr "Impossibile cambiare la directory %s"
#: ../lib/gis/proj2.c:57
msgid "State Plane"
@@ -1571,11 +1561,8 @@
#: ../lib/gis/parser_standard_options.c:106
-#, fuzzy
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"La clausola WHERE del comando SQL manca della parola chiave 'where'. "
-"(esempio: income < 1000 and inhab >=10000)"
+msgstr "La clausola WHERE del comando SQL manca della parola chiave 'where'"
#: ../lib/gis/parser_standard_options.c:107
msgid "Example: income < 1000 and inhab >= 10000"
@@ -1604,24 +1591,20 @@
msgstr ""
#: ../lib/gis/parser_standard_options.c:152
-#, fuzzy
msgid "Name of attribute column"
-msgstr "Nome della mappa vettoriale in input"
+msgstr "Nome della colonna dell'attributo"
#: ../lib/gis/parser_standard_options.c:161
-#, fuzzy
msgid "Name of attribute column(s)"
+msgstr "Nome della colonna(e) dell'attributo"
#: ../lib/gis/parser_standard_options.c:172
-#, fuzzy
msgid "Name of input imagery group"
-msgstr "Nome della mappa raster in input"
+msgstr "Nome del gruppo di immagini di input"
#: ../lib/gis/parser_standard_options.c:180
-#, fuzzy
msgid "Name of input imagery subgroup"
+msgstr "Nome del sottogruppo di immagini di input"
#: ../lib/gis/parser_standard_options.c:190
msgid "Name of input raster map"
@@ -1632,9 +1615,8 @@
msgstr "Nome delle mappe raster in input"
#: ../lib/gis/parser_standard_options.c:207
-#, fuzzy
msgid "Name for output raster map"
-msgstr "Nome della mappa raster in output"
+msgstr "Nome del raster di output"
#: ../lib/gis/parser_standard_options.c:215
#, fuzzy
@@ -1647,14 +1629,12 @@
#: ../lib/gis/parser_standard_options.c:232
-#, fuzzy
msgid "Name of base raster map"
-msgstr "Nome della mappa raster base in input"
+msgstr "Nome del raster base"
#: ../lib/gis/parser_standard_options.c:240
-#, fuzzy
msgid "Name of cover raster map"
-msgstr "Nome del raster in output"
+msgstr "Nome del raster cover"
#: ../lib/gis/parser_standard_options.c:248
#, fuzzy
@@ -1695,24 +1675,21 @@
#: ../lib/gis/parser_standard_options.c:321
#: ../lib/gis/parser_standard_options.c:348
-#, fuzzy
msgid "Name of input vector map(s)"
+msgstr "Nome del vettoriale di input"
#: ../lib/gis/parser_standard_options.c:322
msgid "Data source(s) for OGR access"
msgstr ""
#: ../lib/gis/parser_standard_options.c:330
-#, fuzzy
msgid "Name for output vector map"
-msgstr "Nome della mappa vettoriale in output"
+msgstr "Nome del vettoriale in output"
#: ../lib/gis/parser_standard_options.c:357
#: ../lib/gis/parser_standard_options.c:366
-#, fuzzy
msgid "Feature type"
-msgstr "Tipo di "
+msgstr "Tipologia delle feature "
#: ../lib/gis/parser_standard_options.c:373
#, fuzzy
@@ -1752,9 +1729,8 @@
msgstr "Id dell'elemento"
#: ../lib/gis/parser_standard_options.c:417
-#, fuzzy
msgid "Feature ids"
-msgstr "Tipo di "
+msgstr "Id delle feature"
#: ../lib/gis/parser_standard_options.c:428
#, fuzzy
@@ -1768,7 +1744,7 @@
#: ../lib/gis/parser_standard_options.c:444
msgid "Field separator"
-msgstr ""
+msgstr "Separatore dei campi"
#: ../lib/gis/parser_standard_options.c:445
msgid "Special characters: newline, space, comma, tab"
@@ -1795,7 +1771,7 @@
msgstr ""
#: ../lib/gis/list.c:85
-#, fuzzy, c-format
+#, c-format
msgid "no %s files available in current mapset\n"
msgstr "Nessun file %s disponibile nel mapset in uso\n"
@@ -1810,9 +1786,8 @@
msgstr "%s file disponibili nel mapset <%s>:\n"
#: ../lib/gis/list.c:206
-#, fuzzy
msgid "G_list: Unknown element type"
-msgstr "Tipo di interpolazione sconosciuta"
+msgstr "G_list: Tipologia dell'elemento sconosciuta"
#: ../lib/gis/parser_html.c:40
msgid "NAME"
@@ -1827,11 +1802,8 @@
msgstr "SINOPSI"
#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:147
-#, fuzzy
msgid "Flags"
-msgstr ""
-"\n"
-"Flags:\n"
+msgstr "Flag"
#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:157
msgid "Parameters"
@@ -1856,23 +1828,23 @@
msgstr "Nome del file non valido. Il carattere <%c> non è permesso.\n"
#: ../lib/gis/legal_name.c:74 ../lib/gis/legal_name.c:78
-#, fuzzy, c-format
+#, c-format
msgid "Output raster map name <%s> is not valid map name"
-msgstr "Il nome '%s' in output non è un nome di raster valido."
+msgstr "Il nome '%s' del raster di output non è un nome valido"
#: ../lib/gis/legal_name.c:115 ../lib/gis/legal_name.c:119
-#, fuzzy, c-format
+#, c-format
msgid "Output raster map <%s> is used as input"
-msgstr "La mappa '%s' in output è utilizzata come input"
+msgstr "Il raster '%s' in output è utilizzata come input"
#: ../lib/gis/env.c:260
msgid "GISRC - variable not set"
msgstr "GISRC - variabile non impostata"
#: ../lib/gis/env.c:292
-#, fuzzy, c-format
+#, c-format
msgid "G_getenv(): Variable %s not set"
-msgstr "GISRC - variabile non impostata"
+msgstr "G_getenv(): variabile %s non impostata"
#: ../lib/gis/env.c:318
#, c-format
@@ -1992,13 +1964,13 @@
msgstr ""
#: ../lib/gis/location.c:60
-#, fuzzy, c-format
+#, c-format
msgid "LOCATION << %s >> not available"
msgstr "LOCATION << %s >> non disponibile"
#: ../lib/gis/myname.c:46
msgid "This location has no description."
-msgstr ""
+msgstr "Questa location non ha descrizione"
#: ../lib/gis/debug.c:81
#, c-format
@@ -2133,24 +2105,24 @@
msgstr ""
#: ../lib/gis/get_ellipse.c:343 ../lib/gis/get_ellipse.c:366
-#, fuzzy, c-format
+#, c-format
msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "non valido: campo %s nel file %s in %s"
+msgstr "Non valido: campo '%s' nel file %s in <%s>"
#: ../lib/gis/get_ellipse.c:355
-#, fuzzy, c-format
+#, c-format
msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "ellissoide %s non valido nel file %s in %s"
+msgstr "Ellissoide '%s' non valido nel file '%s' in <%s>"
#: ../lib/gis/get_ellipse.c:369
-#, fuzzy, c-format
+#, c-format
msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "non valido es. campo %s nel file %s in %s"
+msgstr "Non valido. es. campo '%s' nel file %s in <%s>"
#: ../lib/gis/get_ellipse.c:382
-#, fuzzy, c-format
+#, c-format
msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "Nessun informazione sull'ellissoide disponibile nel file %s in %s"
+msgstr "Nessun informazione sull'ellissoide disponibile nel file %s in <%s>"
#: ../lib/gis/proj3.c:92 ../lib/vector/Vlib/header.c:596
msgid "Unknown projection"
@@ -2262,7 +2234,6 @@
msgstr "campo formato duplicato"
#: ../lib/gis/rd_cellhd.c:325
-#, fuzzy
msgid "duplicate compressed field"
msgstr "campo compressed duplicato"
@@ -2307,9 +2278,9 @@
msgstr "campo rows3 mancante"
#: ../lib/gis/ls.c:99
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open directory %s"
#: ../lib/gis/done_msg.c:38
#, c-format
@@ -2333,11 +2304,10 @@
msgstr "MAPSET %s non trovato"
#: ../lib/gis/gisinit.c:108
-#, fuzzy
msgid "System not initialized. Programmer forgot to call G_gisinit()."
msgstr ""
-"ERRORE: Sistema non inizializzato. Il programmatore si è scordato di usare "
-"la funzione G_gisinit()\n"
+"Sistema non inizializzato. Il programmatore si è scordato di usare la "
+"funzione G_gisinit()."
#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
#: ../lib/vector/Vlib/ascii.c:200 ../lib/vector/Vlib/line.c:50
@@ -2431,69 +2401,60 @@
msgstr ""
#: ../lib/vector/diglib/plus.c:277
-#, fuzzy
msgid "Unable read topology for nodes"
-msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
+msgstr "Impossibile leggere la topologia per i nodi"
#: ../lib/vector/diglib/plus.c:282
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read topology for node %d"
+msgstr "Impossibile leggere la topologia per il nodo %d"
#: ../lib/vector/diglib/plus.c:287
-#, fuzzy
msgid "Unable read topology for lines"
-msgstr "Non riesco a riscrivere la linea"
+msgstr "Impossibile leggere la topologia per le linee"
#: ../lib/vector/diglib/plus.c:292
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read topology for line %d"
-msgstr "Non riesco ad aprire il file temp"
+msgstr "Impossibile leggere la topologia per la linea %d"
#: ../lib/vector/diglib/plus.c:297
-#, fuzzy
msgid "Unable to read topo for areas"
+msgstr "Impossibile leggere la topologia per le aree"
#: ../lib/vector/diglib/plus.c:302
-#, fuzzy, c-format
+#, c-format
msgid "Unable read topology for area %d"
+msgstr "Impossibile leggere la topologia per l'area %d"
#: ../lib/vector/diglib/plus.c:307
-#, fuzzy
msgid "Unable to read topology for isles"
+msgstr "Impossibile leggere la topologia per le isole"
#: ../lib/vector/diglib/plus.c:312
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read topology for isle %d"
+msgstr "Impossibile leggere la topologia per l'isola %d"
#: ../lib/vector/diglib/plus.c:334 ../lib/vector/diglib/plus.c:360
-#, fuzzy
msgid "Unable to write head to plus file"
+msgstr ""
#: ../lib/vector/diglib/plus.c:339
-#, fuzzy
msgid "Unable to write nodes to plus file"
+msgstr ""
#: ../lib/vector/diglib/plus.c:344
-#, fuzzy
msgid "Unable to write lines to plus file"
+msgstr ""
#: ../lib/vector/diglib/plus.c:349
-#, fuzzy
msgid "Unable to write areas to plus file"
+msgstr ""
#: ../lib/vector/diglib/plus.c:354
-#, fuzzy
msgid "Unable to write isles to plus file"
+msgstr ""
#: ../lib/vector/diglib/plus_area.c:208 ../lib/vector/diglib/plus_area.c:677
#: ../lib/vector/diglib/plus_area.c:685
@@ -2525,23 +2486,22 @@
msgstr ""
#: ../lib/vector/diglib/plus_area.c:419
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
+msgstr ""
#: ../lib/vector/diglib/plus_area.c:775
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
+msgstr ""
#: ../lib/vector/diglib/file.c:161
msgid "Writing to file loaded to memory not supported"
msgstr ""
#: ../lib/vector/diglib/file.c:205
-#, fuzzy
msgid "Unable to load file to memory, file not open"
+msgstr "Impossibile caricare file in memoria, file non aperto"
#: ../lib/vector/diglib/file.c:220
msgid "Vector memory mode not supported, using 'AUTO'"
@@ -2579,83 +2539,76 @@
#: ../lib/vector/diglib/spindex.c:285
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete node %d from spatial index"
+msgstr "Impossibile eliminare il nodo %d dall'indice spaziale"
#: ../lib/vector/diglib/spindex.c:325
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete line %d from spatial index"
+msgstr "Impossibile eliminare la linea %d dall'indice spaziale"
#: ../lib/vector/diglib/spindex.c:351
-#, fuzzy
msgid "Attempt to delete sidx for dead area"
+msgstr ""
#: ../lib/vector/diglib/spindex.c:364
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete area %d from spatial index"
+msgstr "Impossibile eliminare l'area %d dall'indice spaziale"
#: ../lib/vector/diglib/spindex.c:399
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete isle %d from spatial index"
+msgstr "Impossibile eliminare l'isola %d dall'indice spaziale"
#: ../lib/vector/Vlib/write_nat.c:54 ../lib/vector/Vlib/write_nat.c:88
#, c-format
msgid "%s: Area %d does not exist"
-msgstr ""
+msgstr "%s: Area %d non esiste"
#: ../lib/vector/Vlib/write_nat.c:670 ../lib/vector/Vlib/write_ogr.c:298
-#, fuzzy
msgid "Attempt to delete dead feature"
+msgstr ""
#: ../lib/vector/Vlib/write_nat.c:910
-#, fuzzy
msgid "Attempt to restore alive feature"
+msgstr ""
#: ../lib/vector/Vlib/legal_vname.c:45
-#, fuzzy, c-format
+#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
msgstr ""
-"Nome non valido per una mappa vettoriale <%s>. Non deve contenere '.' oppure "
-"'NULL'.\n"
+"Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:52
-#, fuzzy, c-format
+#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
msgstr ""
-"Nome non valido per una mappa vettoriale <%s>. Deve cominciare con una "
-"lettera.\n"
+"Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
#: ../lib/vector/Vlib/legal_vname.c:60
-#, fuzzy, c-format
+#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-"Il nome <%s> non è valido per una mappa vettoriale. Il carattere <%c> non è "
-"concesso.\n"
+msgstr "Nome non valido per il vettoriale <%s>. Carattere '%c' non permesso."
#: ../lib/vector/Vlib/legal_vname.c:67
-#, fuzzy, c-format
+#, c-format
msgid ""
"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
msgstr ""
-"concesso.\n"
+"Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono "
+"essere usate come nome della mappa."
#: ../lib/vector/Vlib/legal_vname.c:98 ../lib/vector/Vlib/legal_vname.c:102
-#, fuzzy, c-format
+#, c-format
msgid "Output vector map name <%s> is not valid map name"
+msgstr "Il nome '%s' del vettoriale di output non è un nome valido"
#: ../lib/vector/Vlib/legal_vname.c:139 ../lib/vector/Vlib/legal_vname.c:143
-#, fuzzy, c-format
+#, c-format
msgid "Output vector map <%s> is used as input"
+msgstr "Vettoriale <%s> di output è utilizzata come input"
#: ../lib/vector/Vlib/read_ogr.c:117 ../lib/vector/Vlib/read_ogr.c:307
#: ../lib/vector/Vlib/read_ogr.c:365 ../lib/vector/Vlib/build_ogr.c:309
@@ -2665,7 +2618,7 @@
#: ../lib/vector/Vlib/read_ogr.c:174
msgid "OGR feature without ID"
-msgstr ""
+msgstr "Feature OGR senza ID"
#: ../lib/vector/Vlib/read_ogr.c:416 ../lib/vector/Vlib/read_ogr.c:424
#, c-format
@@ -2674,9 +2627,8 @@
#: ../lib/vector/Vlib/read_ogr.c:464 ../lib/vector/Vlib/geos.c:66
#: ../lib/vector/Vlib/geos.c:256 ../lib/vector/Vlib/read_nat.c:134
-#, fuzzy
msgid "Attempt to read dead line"
+msgstr ""
#: ../lib/vector/Vlib/cats.c:44
msgid "Vect_new_cats_struct(): Out of memory"
@@ -2715,7 +2667,7 @@
#: ../lib/vector/Vlib/intersect.c:127
msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
+msgstr "3D non supportato da Vect_segment_intersection()"
#: ../lib/vector/Vlib/intersect.c:322
msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
@@ -2752,7 +2704,7 @@
#: ../lib/vector/Vlib/array.c:154 ../lib/vector/Vlib/array.c:177
#: ../lib/vector/Vlib/array.c:306 ../lib/vector/Vlib/array.c:339
msgid "Not enough space in vector array"
-msgstr ""
+msgstr "Non abbastanza spazo nell'array del vettore"
#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:312
#: ../lib/vector/Vlib/map.c:439 ../lib/vector/Vlib/map.c:551
@@ -2762,7 +2714,7 @@
#: ../lib/rst/interp_float/vinput2d.c:79
#, c-format
msgid "Database connection not defined for layer %d"
-msgstr ""
+msgstr "La connessione del database non è definita per il layer %d"
#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:341
#: ../lib/vector/Vlib/map.c:480 ../lib/vector/Vlib/map.c:702
@@ -2772,19 +2724,18 @@
#: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/copy_tab.c:105
#: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
#: ../lib/db/dbmi_client/delete_tab.c:49 ../lib/sites/sites.c:320
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Non posso scrivere i collegamenti del database"
+msgstr "Impossibile aprire il database <%s> dal driver <%s>"
#: ../lib/vector/Vlib/array.c:294
-#, fuzzy, c-format
+#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "Impossibile creare il file di intestazione per [%s in %s]"
+msgstr "Impossibile selezionare record dalla tabella <%s> (chiave %s, dove %s)"
#: ../lib/vector/Vlib/geos.c:53 ../lib/vector/Vlib/read.c:105
-#, fuzzy
msgid "vector map is not opened"
+msgstr "Il vettoriale non è aperto"
#: ../lib/vector/Vlib/geos.c:56
#, c-format
@@ -2794,9 +2745,8 @@
msgstr ""
#: ../lib/vector/Vlib/geos.c:61
-#, fuzzy
msgid "only native format supported"
-msgstr "Vect_write_line() non supportato per questo formato/livello"
+msgstr "solo il formato nativo è supportato"
#: ../lib/vector/Vlib/geos.c:91
#, c-format
@@ -2809,19 +2759,19 @@
msgstr ""
#: ../lib/vector/Vlib/geos.c:203
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read line offset %ld"
+msgstr ""
#: ../lib/vector/Vlib/geos.c:410
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to read points of nonexistent area id %d"
+msgstr ""
#: ../lib/vector/Vlib/geos.c:470
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read feature id %d"
+msgstr "Impossibile leggere la feature con id %d"
#: ../lib/vector/Vlib/snap.c:150
msgid "Snap vertices (pass 1: select points)..."
@@ -2865,117 +2815,112 @@
#: ../lib/vector/Vlib/graph.c:107 ../lib/vector/Vlib/net.c:429
#: ../lib/vector/neta/flow.c:309
msgid "GngFlatten error"
-msgstr ""
+msgstr "Errore GngFlatten"
#: ../lib/vector/Vlib/graph.c:140
-#, fuzzy
msgid "Unable to add network arc"
+msgstr ""
#: ../lib/vector/Vlib/graph.c:228 ../lib/vector/Vlib/net.c:511
#, c-format
msgid "dglShortestPath error: %s"
-msgstr ""
+msgstr "Errore dglShortestPath: %s"
#: ../lib/vector/Vlib/build.c:129
-#, fuzzy, c-format
+#, c-format
msgid "Building topology for vector map <%s>..."
-msgstr "Ricrea la topologia per il vettore '%s@%s'"
+msgstr "Si sta ricreando la topologia per il vettore <%s>..."
#: ../lib/vector/Vlib/build.c:147
-#, fuzzy
msgid "Topology was built"
-msgstr "La topologia è stata creata.\n"
+msgstr "La topologia è stata creata"
#: ../lib/vector/Vlib/build.c:159
-#, fuzzy, c-format
+#, c-format
msgid "Number of nodes: %d"
-msgstr "Numero di nodi : %d\n"
+msgstr "Numero di nodi: %d"
#: ../lib/vector/Vlib/build.c:160
-#, fuzzy, c-format
+#, c-format
msgid "Number of primitives: %d"
-msgstr "Numero di primitive: %d\n"
+msgstr "Numero di primitive:%d"
#: ../lib/vector/Vlib/build.c:161
-#, fuzzy, c-format
+#, c-format
msgid "Number of points: %d"
-msgstr "Numero di punti : %d\n"
+msgstr "Numero di punti:%d"
#: ../lib/vector/Vlib/build.c:162
-#, fuzzy, c-format
+#, c-format
msgid "Number of lines: %d"
-msgstr "Numero di linee : %d\n"
+msgstr "Numero di linee:%d"
#: ../lib/vector/Vlib/build.c:163
-#, fuzzy, c-format
+#, c-format
msgid "Number of boundaries: %d"
-msgstr "Numero di confini : %d\n"
+msgstr "Numero di confini:%d"
#: ../lib/vector/Vlib/build.c:164
-#, fuzzy, c-format
+#, c-format
msgid "Number of centroids: %d"
-msgstr "Numero di centroidi: %d\n"
+msgstr "Numero di centroidi:%d"
#: ../lib/vector/Vlib/build.c:167
-#, fuzzy, c-format
+#, c-format
msgid "Number of faces: %d"
-msgstr "Numero di facce : %d\n"
+msgstr "Numero di facce:%d"
#: ../lib/vector/Vlib/build.c:170
-#, fuzzy, c-format
+#, c-format
msgid "Number of kernels: %d"
-msgstr "Numero di kernel : %d\n"
+msgstr "Numero di kernel:%d"
#: ../lib/vector/Vlib/build.c:211
-#, fuzzy, c-format
+#, c-format
msgid "Number of areas: %d"
-msgstr "Numero di aree : %d\n"
+msgstr "Numero di aree:%d"
#: ../lib/vector/Vlib/build.c:212
-#, fuzzy, c-format
+#, c-format
msgid "Number of isles: %d"
-msgstr "Numero di isole : %d\n"
+msgstr "Numero di isole:%d"
#: ../lib/vector/Vlib/build.c:215
-#, fuzzy, c-format
+#, c-format
msgid "Number of incorrect boundaries: %d"
-msgstr "Numero di confini non corretti : %d\n"
+msgstr "Numero di confini non corretti:%d"
#: ../lib/vector/Vlib/build.c:219
-#, fuzzy, c-format
+#, c-format
msgid "Number of centroids outside area: %d"
-msgstr "Numero di centroidi al di fuori dell'area : %d\n"
+msgstr "Numero di centroidi al di fuori dell'area:%d"
#: ../lib/vector/Vlib/build.c:223
-#, fuzzy, c-format
+#, c-format
msgid "Number of duplicate centroids: %d"
-msgstr "Numero di centroidi duplicati : %d\n"
+msgstr "Numero di centroidi duplicati:%d"
#: ../lib/vector/Vlib/build.c:226
-#, fuzzy, c-format
+#, c-format
msgid "Number of areas without centroid: %d"
-msgstr "Numero di aree senza centroide : %d\n"
+msgstr "Numero di aree senza centroide:%d"
#: ../lib/vector/Vlib/build.c:230
-#, fuzzy
msgid "Number of areas: -"
-msgstr "Numero di aree : -\n"
+msgstr "Numero di aree: -"
#: ../lib/vector/Vlib/build.c:231
-#, fuzzy
msgid "Number of isles: -"
-msgstr "Numero di isole : -\n"
+msgstr "Numero di isole:-"
#: ../lib/vector/Vlib/build.c:261
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open topo file for write <%s>"
-msgstr "Non riesco ad aprire il file di topologia in scrittura: %s\n"
+msgstr "Impossibile aprire il file di topologia in scrittura <%s>"
#: ../lib/vector/Vlib/build.c:269
-#, fuzzy
msgid "Error writing out topo file"
-msgstr "Errore nella scrittura del file di topologia.\n"
+msgstr "Errore nella scrittura del file di topologia"
#: ../lib/vector/Vlib/build.c:401
#, fuzzy
@@ -3002,19 +2947,17 @@
msgstr ""
#: ../lib/vector/Vlib/build.c:543
-#, fuzzy, c-format
+#, c-format
msgid "Unable open spatial index file for write <%s>"
-msgstr "Non riesco ad aprire il file di indice spaziale in scrittura: %s\n"
+msgstr "Impossibile aprire il file di indice spaziale per scrivere <%s>"
#: ../lib/vector/Vlib/build.c:552
-#, fuzzy
msgid "Error writing out spatial index file"
-msgstr "Errore nella scrittura del file dell'indice spaziale.\n"
+msgstr "Errore nella scrittura del file dell'indice spaziale"
#: ../lib/vector/Vlib/field.c:89
-#, fuzzy
msgid "Layer number must be 1 or greater"
-msgstr "Il numero di campi deve essere 1 o maggiore."
+msgstr "Il numero del layer deve essere 1 o maggiore."
#: ../lib/vector/Vlib/field.c:94
#, fuzzy
@@ -3034,25 +2977,24 @@
#: ../lib/vector/Vlib/field.c:152
-#, fuzzy
msgid "Unable to write database links"
+msgstr "Impossibile scrivere i collegamenti del database"
#: ../lib/vector/Vlib/field.c:228
-#, fuzzy, c-format
+#, c-format
msgid "Layer number %d or name <%s> already exists"
-msgstr "Numero di campo <%d> o nome <%s> già in uso"
+msgstr "Numero del layer %d o nome <%s> esistono già"
#: ../lib/vector/Vlib/field.c:308
-#, fuzzy, c-format
+#, c-format
msgid ""
"Default driver / database set to:\n"
"driver: %s\n"
"database: %s"
msgstr ""
-"Driver / database predefinito:\n"
-"driver: dbf\n"
-"database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
+"Driver / database predefinito impostato a:\n"
+"driver: %s\n"
+"database: %s"
#: ../lib/vector/Vlib/field.c:315
msgid "Default driver is not set"
@@ -3083,9 +3025,8 @@
#: ../lib/vector/Vlib/field.c:601
-#, fuzzy
msgid "Unable to open OGR DBMI driver"
-msgstr "Non riesco ad aprire il driver OGR DBMI"
+msgstr "Impossibile aprire il driver OGR DBMI"
#: ../lib/vector/Vlib/field.c:640
msgid ""
@@ -3104,51 +3045,49 @@
msgstr "Errore nella regola alla riga %d in %s"
#: ../lib/vector/Vlib/field.c:809
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open vector database definition file '%s'"
+msgstr ""
#: ../lib/vector/Vlib/field.c:895
-#, fuzzy
msgid "Bug: attempt to update map which is not in current mapset"
msgstr ""
#: ../lib/vector/Vlib/area.c:52
-#, fuzzy
msgid "Attempt to read points of nonexistent area"
+msgstr ""
#: ../lib/vector/Vlib/area.c:125
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read line %d"
+msgstr "Impossibile leggere la linea %d"
#: ../lib/vector/Vlib/area.c:164 ../lib/vector/Vlib/area.c:193
#: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to read topo for dead area (%d)"
+msgstr ""
#: ../lib/vector/Vlib/area.c:227 ../lib/vector/Vlib/area.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to read topo for dead isle (%d)"
+msgstr ""
#: ../lib/vector/Vlib/header.c:91 ../lib/vector/Vlib/header.c:139
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open header file of vector <%s>"
+msgstr "Impossibile aprire il file di intestazione per il vettoriale <%s>"
#: ../lib/vector/Vlib/header.c:147
#, c-format
msgid "Corrupted row in head: %s"
-msgstr ""
+msgstr "Riga corrotta nel head: %s"
#: ../lib/vector/Vlib/header.c:183
-#, fuzzy, c-format
+#, c-format
msgid "Unknown keyword %s in vector head"
+msgstr ""
#: ../lib/vector/Vlib/read.c:108
#, c-format
@@ -3158,14 +3097,12 @@
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:100
-#, fuzzy
msgid "Unable to add area (map closed, topo saved)"
-msgstr "Non posso aggiungere un'area (mappa chiusa, topologia salvata)"
+msgstr "Impossibile aggiungere un'area (mappa chiusa, topologia salvata)"
#: ../lib/vector/Vlib/build_nat.c:109
-#, fuzzy
msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Non riesco ad aggiungere un'isola (mappa chiusa, topologia salvata)"
+msgstr "Impossibile aggiungere un'isola (mappa chiusa, topologia salvata)"
#: ../lib/vector/Vlib/build_nat.c:119
msgid "Area of size = 0.0 ignored"
@@ -3176,24 +3113,22 @@
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:525
-#, fuzzy
msgid "Registering primitives..."
-msgstr "Linee registrate: "
+msgstr "Registrando primitive..."
#: ../lib/vector/Vlib/build_nat.c:534
-#, fuzzy
msgid "Unable to read vector map"
+msgstr "Impossibile leggere il vettoriale"
#: ../lib/vector/Vlib/build_nat.c:578
-#, fuzzy, c-format
+#, c-format
msgid "%d primitives registered"
-msgstr "\r%d primitive registrate \n"
+msgstr "%d primitive registrate"
#: ../lib/vector/Vlib/build_nat.c:579
-#, fuzzy, c-format
+#, c-format
msgid "%d vertices registered"
+msgstr "%d vertici registrati"
#: ../lib/vector/Vlib/build_nat.c:590
#, fuzzy
@@ -3228,7 +3163,7 @@
#: ../lib/vector/Vlib/merge_lines.c:193
#, c-format
msgid "%d new boundaries"
-msgstr ""
+msgstr "%d aree nuove"
#: ../lib/vector/Vlib/buffer2.c:360
#, fuzzy
@@ -3250,7 +3185,7 @@
#: ../lib/vector/Vlib/buffer2.c:886 ../lib/vector/Vlib/buffer2.c:919
msgid "Vect_get_point_in_poly() failed"
-msgstr ""
+msgstr "Vect_get_point_in_poly() fallito"
#: ../lib/vector/Vlib/map.c:73
#, fuzzy
@@ -3556,9 +3491,9 @@
#: ../lib/vector/Vlib/select.c:107
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete item %d from spatial index"
+msgstr "Impossibile eliminare l'elemento %d dall'indice spaziale"
#: ../lib/vector/Vlib/open.c:106
#, fuzzy, c-format
@@ -3819,7 +3754,7 @@
#: ../lib/vector/Vlib/cindex.c:283
msgid "Layer index out of range"
-msgstr ""
+msgstr "Indice del layer fuori dal range"
#: ../lib/vector/Vlib/cindex.c:460
#, fuzzy, c-format
@@ -3905,7 +3840,7 @@
#: ../lib/vector/Vlib/line.c:180 ../lib/vector/Vlib/line.c:213
#: ../lib/vector/Vlib/line.c:246
msgid "Index out of range in"
-msgstr ""
+msgstr "Indice fuori dal range in "
#: ../lib/vector/Vlib/line.c:546
msgid "Segment outside line, no segment created"
@@ -4674,7 +4609,7 @@
#: ../lib/rst/interp_float/vinput2d.c:121
#, fuzzy
msgid "Reading features from vector map ..."
+msgstr "Lettura linee dalla mappa vettorialie..."
#: ../lib/rst/interp_float/vinput2d.c:153
#: ../lib/rst/interp_float/vinput2d.c:270
@@ -4690,7 +4625,7 @@
#: ../lib/rst/interp_float/vinput2d.c:233
#, fuzzy
msgid "Reading nodes from vector map ..."
+msgstr "Lettura nodi dalla mappa vettoriale..."
#: ../lib/rst/interp_float/vinput2d.c:314
msgid "Strip exists with insufficient data"
@@ -4702,9 +4637,9 @@
msgstr ""
#: ../lib/rst/interp_float/vinput2d.c:331
-#, c-format
+#, fuzzy, c-format
msgid "Ignoring %d points (too dense)"
-msgstr ""
+msgstr "Ignorati %d punti -- densità eccessiva"
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
@@ -5631,7 +5566,7 @@
#: ../lib/gmath/la.c:598
msgid "Matrix is singular"
-msgstr ""
+msgstr "Matrice è singolare"
#: ../lib/gmath/la.c:603
msgid "Problem in LA procedure."
@@ -5652,11 +5587,11 @@
#: ../lib/gmath/la.c:755 ../lib/gmath/la.c:796 ../lib/gmath/la.c:1109
#: ../lib/gmath/la.c:1161 ../lib/gmath/la.c:1236
msgid "Matrix is not initialised"
-msgstr ""
+msgstr "La matrice non è inizializzata"
#: ../lib/gmath/la.c:760 ../lib/gmath/la.c:801
msgid "Could not allocate space for vector structure"
-msgstr ""
+msgstr "Non è possibile alloccare spazio per la struttura del vettoriale"
#: ../lib/gmath/la.c:791
msgid "Specified matrix row index is outside range"
@@ -5664,11 +5599,11 @@
#: ../lib/gmath/la.c:831
msgid "Specified row index is outside range"
-msgstr ""
+msgstr "L'indice della riga specificata è fuori dal range"
#: ../lib/gmath/la.c:836
msgid "Specified column index is outside range"
-msgstr ""
+msgstr "L'indice della colonna specificata è fuori dal range"
#: ../lib/gmath/la.c:856
#, fuzzy
@@ -5681,15 +5616,15 @@
#: ../lib/gmath/la.c:986
msgid "Vectors are not of the same type"
-msgstr ""
+msgstr "Vettoriali non sono dello stesso tipo"
#: ../lib/gmath/la.c:991
msgid "Output vector is of incorrect type"
-msgstr ""
+msgstr "Il vettoriale di output ha una tipologia non corretta"
#: ../lib/gmath/la.c:996
msgid "Matrices not allowed"
-msgstr ""
+msgstr "Matrici non permesse"
#: ../lib/gmath/la.c:1002
msgid "Vectors have differing dimensions"
@@ -5697,15 +5632,15 @@
#: ../lib/gmath/la.c:1008
msgid "Output vector has incorrect dimension"
-msgstr ""
+msgstr "Il vettoriale di output ha dimensione non corretta"
#: ../lib/gmath/la.c:1054
msgid "Vector dimensions out of range"
-msgstr ""
+msgstr "Dimensione del vettoriale fuori dal range"
#: ../lib/gmath/la.c:1059
msgid "Row/column out of range"
-msgstr ""
+msgstr "Riga/colonna fuori dal range"
#: ../lib/gmath/la.c:1274
msgid "Vector structure is not initialised"
@@ -5791,11 +5726,12 @@
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
+"Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
#: ../lib/imagery/list_gp.c:34
#, c-format
msgid "group <%s> is empty\n"
-msgstr ""
+msgstr "group <%s> è vuoto\n"
#: ../lib/imagery/list_gp.c:44
#, c-format
@@ -5810,7 +5746,7 @@
#: ../lib/imagery/list_subgp.c:36
#, c-format
msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr ""
+msgstr "subgrou <%s> del group <%s> è vuoto\n"
#: ../lib/imagery/list_subgp.c:48
#, c-format
@@ -6180,6 +6116,15 @@
msgid "unable to find [%s] in [%s]"
msgstr "impossibile trovare [%s] in [%s]"
+msgid "Reading lines from vector map ... "
+msgid "Reading nodes from vector map ... "
+msgid "ignoring %d points -- too dense"
#~ msgid "Unknown Location"
#~ msgstr "Posizione sconosciuta"
@@ -6216,34 +6161,24 @@
#~ msgid "Unable to write raster row %i"
#~ msgstr "impossibile creare un nuovo processo"
-#, fuzzy
#~ msgid "Unable to open raster map <%s@%s>"
-#~ msgstr "impossibile cambiare la directory %s"
+#~ msgstr "Impossibile aprire il raster <%s@%s>"
-#, fuzzy
#~ msgid "Unable to find <%s@%s>"
-#~ msgstr "impossibile trovare [%s]"
+#~ msgstr "Impossibile trovare <%s@%s>"
-#, fuzzy
#~ msgid "Unable to open '%s'"
-#~ msgstr "Impossibile aprire %s"
+#~ msgstr "Impossibile aprire '%s'"
-#, fuzzy
-#~ msgid "unable to write quant file!"
-#~ msgstr "impossibile creare un nuovo processo"
#~ msgid "Error writing floating point format file for map %s"
#~ msgstr "Errore scrivendo file di formato virgola mobile per mappa %s"
-#, fuzzy
#~ msgid "Unable to read header file for raster map <%s@%s>."
-#~ msgstr "Impossibile creare il file di intestazione per [%s in %s]"
+#~ msgstr "Impossibile leggere il file di intestazione per il raster <%s@%s>"
-#, fuzzy
#~ msgid " It is a reclass of raster map <%s@%s> "
-#~ msgstr "È una riclassificazione di [%s in %s]"
+#~ msgstr "È una riclassificazione del raster <%s@%s>"
-#, fuzzy
#~ msgid "Unable to realloc buffer"
#~ msgstr "Non riesco a riallocare il buffer"
@@ -6257,9 +6192,8 @@
#~ msgid "Too many arguments"
#~ msgstr "troppi argomenti"
-#, fuzzy
#~ msgid "Unable to open file %s in <%s>"
-#~ msgstr "Impossibile aprire il file %s in %s"
+#~ msgstr "Impossibile aprire il file %s in <%s>"
#~ msgid "ERROR in reading <%s> file for location <%s>"
#~ msgstr "ERRORE nella lettura del file <%s> per la locazione <%s>"
@@ -6337,31 +6271,28 @@
#~ msgstr ""
#~ "Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
-#, fuzzy
#~ msgid "Can't read %s for [%s in %s]"
-#~ msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
+#~ msgstr "Non riesco a leggere %s per [%s in %s]"
-#, fuzzy
#~ msgid "Can't create %s metadata file for [%s in %s]"
-#~ msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
+#~ msgstr "Non riesco a creare il %s file metadata per [%s in %s]"
#, fuzzy
#~ msgid "Matrix is not symmetric!"
#~ msgstr "Il valore predefinito del driver non è impostato"
-#, fuzzy
#~ msgid ""
#~ "Unable to write embedded null values for raster map open for random access"
#~ msgstr ""
-#~ "Non riesco a scrivere valori nulli nella mappa aperta con accesso casuale"
+#~ "Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
-#, fuzzy
#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr "È un reclass di [%s in %s] il cui file header non è valido\n"
+#~ msgstr ""
+#~ "È una riclassificazione del raster <%s@%s> il cui file header non è "
+#~ "valido."
-#, fuzzy
#~ msgid " Invalid format."
-#~ msgstr "Formato non valido\n"
+#~ msgstr "Formato non valido."
#~ msgid "Null values have not been initialized. "
#~ msgstr "I valore null non vanno inizializzati."
@@ -6378,10 +6309,6 @@
#~ msgid "Run quietly"
#~ msgstr "Avvia in modo tranquillo"
-#, fuzzy
-#~ msgid "Unable to spawn the 'wish' program"
#~ msgid "Monitor: get_command: Premature EOF"
#~ msgstr "Monitor: get_command: EOF prematuro"
@@ -6403,47 +6330,32 @@
#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
#~ msgstr "ERRORE: nessuna risposta dai monitor grafici <%s>.\n"
-#, fuzzy
#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "Non è stato selezionato nessun monitor grafico per l'output.\n"
+#~ msgstr "Non è stato selezionato nessun monitor grafico per l'output."
-#, fuzzy
#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr "Per piacere avvia \"d.mon\" per selezionare un monitor grafico.\n"
+#~ msgstr "Eseguire \"d.mon\" per selezionare un monitor grafico."
-#, fuzzy
#~ msgid "Failed to get socket name for monitor <%s>."
-#~ msgstr "Fallimento nel dare un nome alla socket per il monitor <%s>.\n"
+#~ msgstr "Fallimento nel dare un nome alla socket per il monitor <%s>."
-#, fuzzy
#~ msgid "No socket to connect to for monitor <%s>."
-#~ msgstr "Nessuna socket per connettersi al monitor <%s>.\n"
+#~ msgstr "Nessuna socket per connettersi al monitor <%s>."
-#, fuzzy
#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr ""
-#~ "Socket già in uso o non in grado di accettare connessioni.\n"
-#~ "Usa d.mon per selezionare un monitor\n"
+#~ msgstr "Socket già in uso o non in grado di accettare connessioni."
-#, fuzzy
#~ msgid "Use d.mon to select a monitor"
+#~ msgstr "Eseguire d.mon per selezionare un monitor grafico"
-#, fuzzy
#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Tentativo di connessione a qualcosa che non è una socket.\n"
-#~ "Probabilmente un errore nel programma\n"
+#~ msgstr "Tentativo di connessione a qualcosa che non è una socket."
-#, fuzzy
#~ msgid "Probably an error with the server."
-#~ msgstr ""
-#~ "Tempo di connessione scaduto. Probabilmente ci sono errore con il "
-#~ "server.\n"
+#~ msgstr "Probabilmente ci sono errore con il server."
-#, fuzzy
#~ msgid "Connection failed."
-#~ msgstr "Connessione fallita.\n"
+#~ msgstr "Connessione fallita."
#~ msgid "Hit RETURN to cancel request\n"
#~ msgstr "Premi INVIO per annullare la richiesta\n"
@@ -6680,16 +6592,11 @@
#~ msgid "ask: can't happen"
#~ msgstr "ask.c: non deve succedere"
-#, fuzzy
-#~ msgid "<%s>: bad mapset"
-#~ msgstr "<%s> nel mapset <%s>"
#~ msgid "Unable to allocate memory\n"
#~ msgstr "Impossibile allocare memoria\n"
-#, fuzzy
#~ msgid "Unable to open file %s"
+#~ msgstr "Impossibile aprire il file %s"
#~ msgid " The raster map %s@%s is empty"
#~ msgstr " La mappa raster %s@%s è vuota"
@@ -6697,7 +6604,6 @@
#~ msgid "Cannot write quant rules: map %s is integer"
#~ msgstr "Non riesco a scrivere le regole quant: la mappa %s è un integer"
-#, fuzzy
#~ msgid ""
#~ "G_set_window(): projection/zone differs from that of currently open "
#~ "raster maps"
@@ -6708,9 +6614,8 @@
#~ msgid "map [%s] - unable to write row %d"
#~ msgstr "mappa [%s] - impossibile scrivere nella riga %d"
-#, fuzzy
#~ msgid "unable to find a temporary null file %s"
-#~ msgstr "impossibile aprire il file tabella datum: %s"
+#~ msgstr "impossibile trovare un file %s temporaneo nullo"
#~ msgid "error writing null row %d"
#~ msgstr "errore nella scrittura della riga vuota %d"
@@ -6750,14 +6655,11 @@
#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
#~ msgstr "timestamp non valido nel file per %s mappa %s nel mapset %s"
-#, fuzzy
#~ msgid "Error reading compressed map <%s@%s>, row %d"
-#~ msgstr ""
-#~ "errore nella lettura della mappa compressa [%s] nel mapset [%s], riga %d"
+#~ msgstr "Errore nella lettura della mappa compressa <%s@%s>, riga %d"
-#, fuzzy
#~ msgid "Error reading map <%s@%s>, row %d"
-#~ msgstr "errore nella lettura della mappa [%s] nel mapset [%s], riga %d"
+#~ msgstr "Errore nella lettura della mappa <%s@%s>, riga %d"
#~ msgid "unable to determine user's home directory"
#~ msgstr "Impossibile determinare la cartella di home degli utenti"
@@ -6792,42 +6694,33 @@
#~ msgid "Unable to create dependency file in [%s in %s]"
#~ msgstr "Impossibile creare il file delle dipendenze in [%s in %s]"
-#, fuzzy
#~ msgid ""
#~ "Raster map <%s@%s> is in different projection than current region. Found "
#~ "raster map <%s@%s>, should be <%s>."
#~ msgstr ""
-#~ "[%s] nel mapset [%s] - proiezione differenza rispetto alla regione "
-#~ "attualmente in uso:\n"
-#~ " la mappa trovata [%s] in: <%s>, deve essere <%s> "
+#~ "Raster <%s@%s> ha una proiezione differente rispetto alla regione "
+#~ "attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
-#, fuzzy
#~ msgid ""
#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-#~ msgstr "[%s] nel mapset [%s] - zona [%d] diversa dalla regione in uso [%d]"
+#~ msgstr "Il raster <%s@%s> è in zona (%d) diversa dalla regione in uso (%d)"
-#, fuzzy
#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
-#~ msgstr "[%s] in [%s] - byte per cella (%d) troppo grande"
+#~ msgstr "Il raster <%s@%s>: byte per cella (%d) troppo grande"
-#, fuzzy
#~ msgid "Unable to find '%s' in '%s'"
+#~ msgstr "Impossibile trovare '%s' in '%s'"
#~ msgid "can't write history information for [%s]"
#~ msgstr "non riesco a scrivere le informazioni dello storico per [%s]"
-#, fuzzy
#~ msgid "Unknown command: %d last: %d"
-#~ msgstr ""
-#~ "\n"
-#~ "Comando sconosciuto: %d ultimo: %d\n"
+#~ msgstr "Comando sconosciuto: %d ultimo: %d"
-#, fuzzy
#~ msgid "Unable to add database link, map is not opened in WRITE mode"
#~ msgstr ""
-#~ "Non riesco ad aprire un collegamento database, la mappa non è stata "
-#~ "aperta in modalità di SCRITTURA."
+#~ "Impossibile aprire il collegamento al database, la mappa non è stata "
+#~ "aperta in modalità di SCRITTURA"
#~ msgid "Error in rule on row %d in %s"
#~ msgstr "Errore nella regola alla riga %d in %s"
@@ -6887,22 +6780,11 @@
#~ "Impossibile trovare la colonna z <%s> (si prega di verificarne il nome "
#~ "con v.info)"
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "Lettura linee dalla mappa vettorialie..."
-#~ msgid "Reading nodes from vector map ... "
-#~ msgstr "Lettura nodi dalla mappa vettoriale..."
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "Ignorati %d punti -- densità eccessiva"
-#, fuzzy
#~ msgid "Unable to open temporary file"
+#~ msgstr "Impossibile aprire il file temporaneo"
-#, fuzzy
#~ msgid "Problem reading raster map"
-#~ msgstr "problemi leggendo il file di cellule raster"
+#~ msgstr "Problemi leggendo la mappa raster"
#~ msgid ""
#~ "\n"
@@ -6914,13 +6796,11 @@
#~ msgid "Please advise GRASS developers of this error.\n"
#~ msgstr "Per piacere avvisa gli sviluppatori GRASS per questo errore\n"
-#, fuzzy
#~ msgid "Name of elevation raster map"
-#~ msgstr "Nome della mappa raster in input"
+#~ msgstr "Nome del raster dell'elevazione"
-#, fuzzy
#~ msgid "Name of elevation raster map(s)"
-#~ msgstr "Nome delle mappe raster in input"
#~ msgid "to accept the default"
#~ msgstr "per accettare i valori predefiniti"
@@ -6931,6 +6811,26 @@
#~ msgid "No help available for command [%s]\n"
#~ msgstr "Nessun aiuto disponibile per il comando [%s]\n"
-#, fuzzy
#~ msgid "Unable to add database link"
-#~ msgstr "Non riesco ad aggiungere un collegamento database"
+#~ msgstr "Impossibile aggiungere un collegamento database"
+#~ msgid "%s: map [%s] not open for write - request ignored"
+#~ msgstr "%s: mappa [%s] non è stata aperta per scrivere - richiesta ignorata"
+#~ msgid "%s: map [%s] not open for random write - request ignored"
+#~ msgid "%s: map [%s] not open for sequential write - request ignored"
+#~ msgid "Path to input file"
+#~ msgstr "Percorso al file di input"
+#~ msgid "Path for output file"
+#~ msgstr "Percorso al file di output"
+#~ msgid "not implemented"
+#~ msgstr "non implementato"
+#~ msgid "OGR format cannot be updated"
+#~ msgstr "Il formato OGR non può essere aggiornato"
Modified: grass/trunk/locale/po/grasswxpy_it.po
--- grass/trunk/locale/po/grasswxpy_it.po 2010-12-05 00:24:49 UTC (rev 44542)
+++ grass/trunk/locale/po/grasswxpy_it.po 2010-12-05 00:25:02 UTC (rev 44543)
@@ -9,8 +9,8 @@
"Project-Id-Version: grasswxpy_it\n"
-"PO-Revision-Date: 2010-08-22 03:01+0100\n"
-"Last-Translator: Andrea Giacomelli <pibinko gmail.com>\n"
+"PO-Revision-Date: 2010-12-04 19:21+0100\n"
@@ -24,7 +24,6 @@
msgstr "GRASS GIS Layer Manager"
#: ../gui/wxpython/wxgui.py:214
-#, fuzzy
msgid "Map layers"
msgstr "Layer"
@@ -33,29 +32,25 @@
msgstr "Console dei programmi"
#: ../gui/wxpython/wxgui.py:222
-#, fuzzy
msgid "Search module"
-msgstr "Cerca:"
+msgstr "Cerca modulo"
#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/gui_modules/toolbars.py:184
msgid "3D view"
msgstr "Vista 3D"
#: ../gui/wxpython/wxgui.py:280
-#, fuzzy
msgid "Choose model to run"
-msgstr "Chiudi dialogo dopo l'invio"
+msgstr "Scegli il modello da eseguire"
#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/gmodeler.py:791
#: ../gui/wxpython/gui_modules/gmodeler.py:834
-#, fuzzy
msgid "GRASS Model File (*.gxm)|*.gxm"
-msgstr "FIle ambiente di lavoro di GRASS (*.gxw)|*.gxw"
+msgstr "FIle del modello di GRASS (*.gxm)|*.gxm"
#: ../gui/wxpython/wxgui.py:291 ../gui/wxpython/gui_modules/gmodeler.py:1233
-#, fuzzy
msgid "Validating model..."
-msgstr "Range valido"
+msgstr "Si sta validando il modello..."
#: ../gui/wxpython/wxgui.py:295 ../gui/wxpython/gui_modules/gmodeler.py:907
#, python-format
@@ -64,14 +59,17 @@
"\n"
"%s"
msgstr ""
+"Il modello non è valido. Vuoi eseguire il modello in tutti i casi?\n"
+"\n"
+"%s"
#: ../gui/wxpython/wxgui.py:297 ../gui/wxpython/gui_modules/gmodeler.py:909
msgid "Run model?"
-msgstr ""
+msgstr "Eseguire modello?"
#: ../gui/wxpython/wxgui.py:304 ../gui/wxpython/gui_modules/gmodeler.py:972
msgid "Running model..."
-msgstr ""
+msgstr "Si sta eseguendo il modello..."
#: ../gui/wxpython/wxgui.py:354 ../gui/wxpython/wxgui.py:1459
msgid "Do you want to save changes in the workspace?"
@@ -91,9 +89,8 @@
msgstr "Scegli file degli script"
#: ../gui/wxpython/wxgui.py:441
-#, fuzzy
msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
-msgstr "Bash script (*.sh)|*.sh|Python script (*.py)|*.py"
+msgstr "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
#: ../gui/wxpython/wxgui.py:452
#, python-format
@@ -212,13 +209,13 @@
#: ../gui/wxpython/wxgui.py:623
-#, fuzzy, python-format
+#, python-format
msgid ""
"Reading workspace file <%s> failed.\n"
"Invalid file, unable to parse XML document."
msgstr ""
-"Lettura file dell'ambiente di lavoro <%s> fallita. File invalido, "
-"impossibile parsare il documento XML."
+"Lettura file dell'ambiente di lavoro <%s> fallita.\n"
+"File invalido, impossibile parsare il documento XML."
#: ../gui/wxpython/wxgui.py:627 ../gui/wxpython/wxgui.py:736
#: ../gui/wxpython/wxgui.py:772
@@ -254,17 +251,16 @@
msgstr "Salva ambiente di lavoro"
#: ../gui/wxpython/wxgui.py:849
-#, fuzzy
msgid "Writing current settings to workspace file failed."
msgstr ""
"Scrittura delle impostazioni correnti nel file dell'ambiente di lavoro "
-"fallita (%s)"
+"fallita."
#: ../gui/wxpython/wxgui.py:860 ../gui/wxpython/gui_modules/gmodeler.py:1553
#: ../gui/wxpython/gui_modules/profile.py:597
+#, python-format
msgid "Unable to open file <%s> for writing."
-msgstr "Impossibile aprile il file <%s> per leggerlo"
+msgstr "Impossibile aprile il file <%s> per scriverlo."
#: ../gui/wxpython/wxgui.py:1027
msgid "Nothing to import. No WMS layer selected."
@@ -326,18 +322,16 @@
msgstr "Visualizza mappa"
#: ../gui/wxpython/icons/icon.py:140
-#, fuzzy
msgid "Re-render modified map layers"
-msgstr "Rimuovi layer"
+msgstr "Ridisegna i layer modificati"
#: ../gui/wxpython/icons/icon.py:142
msgid "Re-render map"
msgstr "Aggiorna mappa"
#: ../gui/wxpython/icons/icon.py:143
-#, fuzzy
msgid "Force re-rendering all map layers"
-msgstr "Forza l'aggiornamento di tutti i layers"
+msgstr "Forza il ridisegnamento di tutti i layers"
#: ../gui/wxpython/icons/icon.py:145
msgid "Erase display"
@@ -392,7 +386,6 @@
msgstr "Gestione dello zoom del display"
#: ../gui/wxpython/icons/icon.py:166
-#, fuzzy
msgid "Zoom to selected map layer(s)"
msgstr "Zoom alla mappa selezionata"
@@ -456,16 +449,14 @@
msgstr "Aggiungi livello comando"
#: ../gui/wxpython/icons/icon.py:196
-#, fuzzy
msgid "Add group"
-msgstr "Aggiungi un gruppo di layer"
+msgstr "Aggiungi un gruppo"
#: ../gui/wxpython/icons/icon.py:198
msgid "Add grid or vector labels overlay"
msgstr "Aggiungi un grid o etichette vettoriali"
#: ../gui/wxpython/icons/icon.py:200
-#, fuzzy
msgid "Delete selected map layer"
msgstr "Elimina il layer selezionato"
@@ -478,12 +469,10 @@
msgstr "Mostra la tabella degli attributi"
#: ../gui/wxpython/icons/icon.py:206
-#, fuzzy
msgid "Add RGB map layer"
msgstr "Aggiungi RGB layer"
#: ../gui/wxpython/icons/icon.py:208
-#, fuzzy
msgid "Add HIS map layer"
msgstr "Aggiungi HIS layer"
@@ -530,18 +519,16 @@
msgstr "Aggiungi livello testo"
#: ../gui/wxpython/icons/icon.py:230
-#, fuzzy
msgid "Add 3D raster map layer"
-msgstr "Aggiunge un layer raster"
+msgstr "Aggiunge un layer raster 3D"
#: ../gui/wxpython/icons/icon.py:231
msgid "Note that 3D raster data are rendered only in 3D view mode"
-msgstr ""
+msgstr "Notare che i raster 3D sono visualizzati solo nel visualizzatore 3D"
#: ../gui/wxpython/icons/icon.py:233
-#, fuzzy
msgid "Show GUI settings"
-msgstr "Mostra impostazioni"
+msgstr "Mostra impostazioni della GUI"
#: ../gui/wxpython/icons/icon.py:236
msgid "Digitize new point"
@@ -655,9 +642,8 @@
msgstr "Misura distanza"
#: ../gui/wxpython/icons/icon.py:295
-#, fuzzy
msgid "Draw transect in map display window to profile"
-msgstr "Traccia un transetto nella mappa a schermo per eseguire la sezione"
+msgstr "Traccia un transetto nella mappa a schermo per eseguire il profilo"
#: ../gui/wxpython/icons/icon.py:297
msgid "Profile surface map"
@@ -672,9 +658,8 @@
msgstr "Opzioni del profilo"
#: ../gui/wxpython/icons/icon.py:303
-#, fuzzy
msgid "Save profile data to csv file"
-msgstr "Salva il display in un file"
+msgstr "Salva il profilo in un file csv"
#: ../gui/wxpython/icons/icon.py:305
msgid "Create histogram of image or raster file"
@@ -734,9 +719,8 @@
msgstr "Cancella GCP selezionati"
#: ../gui/wxpython/icons/icon.py:331
-#, fuzzy
msgid "Reload GCPs from POINTS file"
-msgstr "Ricarica GCP dal file POINTS selezionato"
+msgstr "Ricarica GCP dal file POINTS"
#: ../gui/wxpython/icons/icon.py:333
msgid "Quit georectification module"
@@ -748,9 +732,8 @@
#: ../gui/wxpython/icons/icon.py:338 ../gui/wxpython/icons/icon.py:363
#: ../gui/wxpython/icons/icon.py:400
-#, fuzzy
msgid "Show help"
-msgstr "Mostra linee"
+msgstr "Mostra help"
#: ../gui/wxpython/icons/icon.py:339
msgid "Display GCP Manager manual page"
@@ -761,27 +744,24 @@
msgstr ""
#: ../gui/wxpython/icons/icon.py:343
-#, fuzzy
msgid "Change view settings"
-msgstr "Cambia impostazione"
+msgstr "Cambia impostazione della vista"
#: ../gui/wxpython/icons/icon.py:345
msgid "Switch to surface (raster) control page"
msgstr ""
#: ../gui/wxpython/icons/icon.py:346
-#, fuzzy
msgid "Change surface (loaded raster maps) settings"
-msgstr "Ricampiona raster usando regole"
+msgstr ""
#: ../gui/wxpython/icons/icon.py:348
msgid "Switch to vector (2D/3D) control page"
msgstr ""
#: ../gui/wxpython/icons/icon.py:349
-#, fuzzy
msgid "Change 2D/3D vector settings"
+msgstr "Cambia impostazioni dei vettoriali 2D/3D"
#: ../gui/wxpython/icons/icon.py:351
msgid "Switch to volume (3D raster) control page"
@@ -796,9 +776,8 @@
msgstr ""
#: ../gui/wxpython/icons/icon.py:355
-#, fuzzy
msgid "Change lighting settings"
+msgstr ""
#: ../gui/wxpython/icons/icon.py:357
msgid "Switch to fringe control page"
@@ -809,14 +788,13 @@
msgstr ""
#: ../gui/wxpython/icons/icon.py:360
-#, fuzzy
msgid "3D view mode tools"
msgstr "Strumenti visualizzazione 3D"
#: ../gui/wxpython/icons/icon.py:361
-#, fuzzy
msgid "Show/hide 3D view mode settings dialog"
-msgstr "Mostra impostazioni NVIZ"
+msgstr ""
+"Mostra/nascondi la finestra delle impostazioni della visualizzazione 3D"
#: ../gui/wxpython/icons/icon.py:364
msgid "Display 3D view mode manual page"
@@ -824,7 +802,7 @@
#: ../gui/wxpython/icons/icon.py:366
msgid "Quit 3D view mode"
-msgstr ""
+msgstr "Esci dal visualizzatore 3D"
#: ../gui/wxpython/icons/icon.py:367
msgid "Switch back to 2D view mode"
@@ -835,36 +813,32 @@
msgstr ""
#: ../gui/wxpython/icons/icon.py:372
-#, fuzzy
msgid "Create new model (Ctrl+N)"
-msgstr "Crea nuovo ambiente di lavoro (Ctrl+N)"
+msgstr "Crea nuovo modello (Ctrl+N)"
#: ../gui/wxpython/icons/icon.py:374
-#, fuzzy
msgid "Load model from file (Ctrl+O)"
-msgstr "Carica l'area di lavoro dal file"
+msgstr "Carica il modello dal file (Ctrl+O)"
#: ../gui/wxpython/icons/icon.py:376
-#, fuzzy
msgid "Save current model to file (Ctrl+S)"
-msgstr "Salva corrente ambiente di lavoro in un file (Ctrl+S)"
+msgstr "Salva il corrente modello in un file (Ctrl+S)"
#: ../gui/wxpython/icons/icon.py:378 ../gui/wxpython/menustrings.py:852
-#, fuzzy
msgid "Export model to image"
-msgstr "Esporta mappa vettoriale"
+msgstr "Esporta modello ad un'immagine"
#: ../gui/wxpython/icons/icon.py:380 ../gui/wxpython/menustrings.py:854
msgid "Export model to Python script"
-msgstr ""
+msgstr "Esporta modello in un script Python"
#: ../gui/wxpython/icons/icon.py:382 ../gui/wxpython/menustrings.py:862
msgid "Add action (GRASS module) to model"
-msgstr ""
+msgstr "Aggiungi azione (modulo GRASS) al modello"
#: ../gui/wxpython/icons/icon.py:384 ../gui/wxpython/menustrings.py:864
msgid "Add data item to model"
-msgstr ""
+msgstr "Aggiungi dati al modello"
#: ../gui/wxpython/icons/icon.py:386 ../gui/wxpython/menustrings.py:866
msgid "Define relation between data and action items"
@@ -873,26 +847,23 @@
#: ../gui/wxpython/icons/icon.py:388 ../gui/wxpython/menustrings.py:178
#: ../gui/wxpython/menustrings.py:877
msgid "Run model"
-msgstr ""
+msgstr "Esegui modello"
#: ../gui/wxpython/icons/icon.py:390 ../gui/wxpython/menustrings.py:879
msgid "Validate model"
-msgstr ""
+msgstr "Valida modello"
#: ../gui/wxpython/icons/icon.py:392
-#, fuzzy
msgid "Show modeler settings"
+msgstr ""
#: ../gui/wxpython/icons/icon.py:394
-#, fuzzy
msgid "Show model properties"
-msgstr "Proprietà del layer"
+msgstr "Mostra le proprietà del modello"
#: ../gui/wxpython/icons/icon.py:396
-#, fuzzy
msgid "Manage model variables"
-msgstr "Gestione delle tabelle"
+msgstr "Gestione delle variabili del modello"
#: ../gui/wxpython/icons/icon.py:398
msgid "Redraw model canvas"
@@ -983,9 +954,8 @@
msgstr "Tecniche di Kriging"
#: ../gui/wxpython/scripts/vkrige.py:358
-#, fuzzy
msgid "Block size:"
-msgstr "Dimensione dell'icona:"
+msgstr "Dimensione del blocco:"
#: ../gui/wxpython/scripts/vkrige.py:391
msgid "Auto-fit variogram"
@@ -1153,9 +1123,8 @@
#: ../gui/wxpython/menustrings.py:23
#: ../gui/wxpython/gui_modules/gdialogs.py:1097
-#, fuzzy
msgid "Link raster data"
-msgstr "Sto caricando raster"
+msgstr "Collegamento a dati raster"
#: ../gui/wxpython/menustrings.py:24
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
@@ -1287,9 +1256,8 @@
#: ../gui/wxpython/menustrings.py:54
#: ../gui/wxpython/gui_modules/gdialogs.py:1091
-#, fuzzy
msgid "Link vector data"
-msgstr "Collega mappa vettoriale"
+msgstr "Collega dati vettoriali"
#: ../gui/wxpython/menustrings.py:55
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
@@ -1607,9 +1575,8 @@
msgstr "Converte un vettore in un VTK ASCII"
#: ../gui/wxpython/menustrings.py:132
-#, fuzzy
msgid "Export 3D raster maps"
-msgstr "Esporta mappa raster"
+msgstr "Esporta mappa raster 3D"
#: ../gui/wxpython/menustrings.py:133
msgid "ASCII 3D export"
@@ -1728,6 +1695,7 @@
#: ../gui/wxpython/menustrings.py:161
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr ""
+"Crea una mappa 3D basandosi sui valori dell'elevazione di un raster 2D."
#: ../gui/wxpython/menustrings.py:162
msgid "Vector to raster"
@@ -1771,14 +1739,12 @@
#: ../gui/wxpython/menustrings.py:172
#: ../gui/wxpython/gui_modules/gcpmanager.py:730
-#, fuzzy
msgid "Manage Ground Control Points"
-msgstr "Punti di controllo sul terreno"
+msgstr "Gestione Punti di Controllo sul Terreno"
#: ../gui/wxpython/menustrings.py:173
-#, fuzzy
msgid "Manage Ground Control Points for Georectification"
+msgstr "Gestione dei Punti di controllo sul terreno per la georettifica"
#: ../gui/wxpython/menustrings.py:175
msgid "Georectify raster and vector maps"
@@ -1805,13 +1771,12 @@
msgstr "nviz - Strumento per la visualizzazione e l'animazione per dati GRASS"
#: ../gui/wxpython/menustrings.py:182
-#, fuzzy
msgid "NVIZ (non-interactive)"
-msgstr "Modifica vettore"
+msgstr "NVIZ (non interattivo)"
#: ../gui/wxpython/menustrings.py:183
msgid "Allows rendering GIS data is a 3D space."
-msgstr ""
+msgstr "Permette la visualizzazione di dati GIS in 3D."
#: ../gui/wxpython/menustrings.py:184
msgid "Bearing/distance to coordinates"
@@ -1856,9 +1821,8 @@
msgstr "Esci dalla sessione di GRASS includendo wxGUI"
#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:857
-#, fuzzy
msgid "&Settings"
-msgstr "Impostazioni"
+msgstr "&Impostazioni"
#: ../gui/wxpython/menustrings.py:195
msgid "Region"
@@ -1938,18 +1902,16 @@
msgstr "Visualizza informazioni sulla versione e sul copyright"
#: ../gui/wxpython/menustrings.py:217
-#, fuzzy
msgid "Map projections"
-msgstr "Gestione proiezioni"
+msgstr "Proiezioni della mappa"
#: ../gui/wxpython/menustrings.py:218
-#, fuzzy
msgid "Display map projection"
-msgstr "Visualizza region"
+msgstr "Visualizza proiezione"
#: ../gui/wxpython/menustrings.py:219
msgid "Print projection information (in conventional GRASS format)."
-msgstr ""
+msgstr "Stampa informazioni sulla proiezione (nel formato di GRASS)."
#: ../gui/wxpython/menustrings.py:220
msgid "Manage projections"
@@ -1980,7 +1942,6 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:226
-#, fuzzy
msgid "Manage add-ons extensions"
msgstr "Gestisci estensioni"
@@ -2046,7 +2007,7 @@
#: ../gui/wxpython/menustrings.py:242
msgid "Resample using aggregate statistics"
-msgstr ""
+msgstr "Risemplifica usando statistiche aggregate"
#: ../gui/wxpython/menustrings.py:243
msgid "Resamples raster map layers to a coarser grid using aggregation."
@@ -2240,9 +2201,8 @@
msgstr "Crea una mask per limitare le operazioni sui raster"
#: ../gui/wxpython/menustrings.py:286
-#, fuzzy
msgid "Raster map calculator"
-msgstr "Map calculator per raster 3D"
+msgstr "Map calculator per raster"
#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:760
#, fuzzy
@@ -2338,13 +2298,12 @@
#: ../gui/wxpython/menustrings.py:307
msgid "Shadows map"
-msgstr ""
+msgstr "Mappa delle ombre"
#: ../gui/wxpython/menustrings.py:308
-#, fuzzy
msgid ""
"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr "Calcola l'indice di diversità di posizione dominante su un raster"
+msgstr ""
#: ../gui/wxpython/menustrings.py:309
msgid "Terrain analysis"
@@ -2396,14 +2355,12 @@
msgstr "Pendio e aspetto"
#: ../gui/wxpython/menustrings.py:319
-#, fuzzy
msgid ""
"Generates raster maps of slope, aspect, curvatures and partial derivatives "
"from a elevation raster map."
msgstr ""
"Genera raster della pendenza, esposizione, curvature e le derivate parziali "
-"da un raster con valori dell'elevazione. Esposizione è calcolata in senso "
-"antiorario partendo dall'est."
+"da un raster con valori dell'elevazione. "
#: ../gui/wxpython/menustrings.py:320
msgid "Terrain parameters"
@@ -2580,13 +2537,12 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:361
-#, fuzzy
msgid "Generates watershed subbasins raster map."
-msgstr "Genera statistiche per layer raster"
+msgstr "Genera sottobacini idrografici di un raster."
#: ../gui/wxpython/menustrings.py:362
msgid "Watershed analysis"
-msgstr ""
+msgstr "Analisi dei bacini idrografici"
#: ../gui/wxpython/menustrings.py:363
msgid "Calculates hydrological parameters and RUSLE factors."
@@ -2594,7 +2550,7 @@
#: ../gui/wxpython/menustrings.py:364
msgid "Watershed basin creation"
-msgstr ""
+msgstr "Creazione dei bacini idrografici"
#: ../gui/wxpython/menustrings.py:365
msgid "Creates watershed basins."
@@ -2665,7 +2621,7 @@
#: ../gui/wxpython/menustrings.py:380
msgid "Configuration editor for r.li.'index'"
-msgstr ""
+msgstr "Editor per la configurazione di r.li"
#: ../gui/wxpython/menustrings.py:381
msgid "Edge density"
@@ -2809,7 +2765,7 @@
#: ../gui/wxpython/menustrings.py:414
msgid "Change category values and labels"
-msgstr ""
+msgstr "Cambia i valori e le etichette delle categorie"
#: ../gui/wxpython/menustrings.py:415
msgid "Interactively edit category values"
@@ -3538,9 +3494,8 @@
msgstr "Trova il percorso più breve in una rete vettoriale."
#: ../gui/wxpython/menustrings.py:581
-#, fuzzy
msgid "Shortest path for sets of features"
-msgstr "Trova il percorso più breve in una rete vettoriale."
+msgstr ""
#: ../gui/wxpython/menustrings.py:582
msgid ""
@@ -3549,19 +3504,16 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:583
-#, fuzzy
msgid "Shortest path using timetables"
-msgstr "Percorso più breve"
+msgstr ""
#: ../gui/wxpython/menustrings.py:584
-#, fuzzy
msgid "Finds shortest path using timetables."
+msgstr ""
#: ../gui/wxpython/menustrings.py:585
-#, fuzzy
msgid "Shortest path for all pairs"
+msgstr ""
#: ../gui/wxpython/menustrings.py:586
msgid "Computes the shortest path between all pairs of nodes in the network."
@@ -3592,27 +3544,24 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:593
-#, fuzzy
msgid "Vertex connectivity"
-msgstr "Connessione al database vettoriale"
+msgstr ""
#: ../gui/wxpython/menustrings.py:594
msgid "Computes vertex connectivity between two sets of nodes in the network."
msgstr ""
#: ../gui/wxpython/menustrings.py:595
-#, fuzzy
msgid "Components"
-msgstr "esponente"
+msgstr "Componenti"
#: ../gui/wxpython/menustrings.py:596
msgid "Computes strongly and weakly connected components in the network."
msgstr ""
#: ../gui/wxpython/menustrings.py:597
-#, fuzzy
msgid "Centrality"
-msgstr "Test di normalità"
+msgstr "Centralità"
#: ../gui/wxpython/menustrings.py:598
msgid ""
@@ -3709,9 +3658,8 @@
msgstr "Poligoni convessi"
#: ../gui/wxpython/menustrings.py:621
-#, fuzzy
msgid "Produces a convex hull for a given vector map."
-msgstr "Crea poligoni convessi da un vettore puntuale"
+msgstr "Crea poligoni convessi da un dato vettoriale."
#: ../gui/wxpython/menustrings.py:622
msgid "Delaunay triangles"
@@ -4312,9 +4260,8 @@
msgstr "Imposta la mask corrente per lavorare con raster 3D"
#: ../gui/wxpython/menustrings.py:759
-#, fuzzy
msgid "Volume calculator"
-msgstr "Calcolatore Mappa"
+msgstr "Calcolatore dei volumi"
#: ../gui/wxpython/menustrings.py:761
msgid "Cross section"
@@ -4468,9 +4415,8 @@
msgstr "Elimina una tabella da un database"
#: ../gui/wxpython/menustrings.py:795
-#, fuzzy
msgid "Drop table"
-msgstr "Copia tabella"
+msgstr "Elimina tabella"
#: ../gui/wxpython/menustrings.py:796
msgid "Removes a table from database."
@@ -4485,9 +4431,8 @@
msgstr "Copia una tabella"
#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:819
-#, fuzzy
msgid "Drop column"
-msgstr "Cancella tutte le colonne"
+msgstr "Cancella colonna"
#: ../gui/wxpython/menustrings.py:800
#, fuzzy
@@ -4554,23 +4499,16 @@
msgstr "Rimuovi tabella"
#: ../gui/wxpython/menustrings.py:814
-#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
-"Rinomina una colonna nella tabella degli attributi connessa a una mappa "
-"vettoriale"
+msgstr "Rimuovi gli attributi esistenti di vettoriale."
#: ../gui/wxpython/menustrings.py:815
-#, fuzzy
msgid "Join table"
+msgstr "Unisci tabella"
#: ../gui/wxpython/menustrings.py:816
-#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Permette di aggiornare una colonna nella tabella degli attributi connessa a "
-"una mappa vettoriale"
+msgstr "Permette di unire una tabella a una tabella di un vettoriale."
#: ../gui/wxpython/menustrings.py:817
msgid "Add columns"
@@ -4585,12 +4523,11 @@
"mappa vettoriale"
#: ../gui/wxpython/menustrings.py:820
-#, fuzzy
msgid ""
"Drops a column from the attribute table connected to a given vector map."
msgstr ""
-"vettoriale"
+"Cancella una colonna dalla tabella degli attributi connessa a un dato "
+"vettoriale."
#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/gui_modules/dbm.py:932
msgid "Rename column"
@@ -4625,9 +4562,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:827
-#, fuzzy
msgid "Reconnect vectors to database"
-msgstr "Riconnetti mappa vettoriale al database"
+msgstr "Riconnetti vettoriali al database"
#: ../gui/wxpython/menustrings.py:828
msgid "Reconnects vectors to a new database."
@@ -4666,40 +4602,33 @@
msgstr "Informazioni su GRASS GIS"
#: ../gui/wxpython/menustrings.py:842
-#, fuzzy
msgid "Create new model"
-msgstr "Crea un nuovo mapset"
+msgstr "Crea un nuovo modello"
#: ../gui/wxpython/menustrings.py:844
-#, fuzzy
msgid "Load model from file"
+msgstr "Carica modello dal file"
#: ../gui/wxpython/menustrings.py:846
#: ../gui/wxpython/gui_modules/gmodeler.py:816
-#, fuzzy
msgid "Save model"
-msgstr "Tipologia di categoria"
+msgstr "Salva modello"
#: ../gui/wxpython/menustrings.py:848
-#, fuzzy
msgid "Save model to file"
-msgstr "Salva l'area di lavoro in un file"
+msgstr "Salva modello in un file"
#: ../gui/wxpython/menustrings.py:850
-#, fuzzy
msgid "Close model file"
-msgstr "Chiudi file dell'ambiente di lavoro"
+msgstr "Chiudi file del modello"
#: ../gui/wxpython/menustrings.py:851
-#, fuzzy
msgid "Export to image"
+msgstr "Esporta a immagine"
#: ../gui/wxpython/menustrings.py:853
-#, fuzzy
msgid "Export to Python"
+msgstr "Esporta a Python"
#: ../gui/wxpython/menustrings.py:855
msgid "Quit modeler"
@@ -4711,101 +4640,89 @@
#: ../gui/wxpython/menustrings.py:859
#: ../gui/wxpython/gui_modules/gmodeler.py:3025
-#, fuzzy
msgid "Modeler settings"
-msgstr "Impostazioni generali"
+msgstr ""
#: ../gui/wxpython/menustrings.py:860
-#, fuzzy
msgid "&Model"
-msgstr "Modalità"
+msgstr "&Modallo"
#: ../gui/wxpython/menustrings.py:861
-#, fuzzy
msgid "Add action"
-msgstr "Aggiungi colonne"
+msgstr "Aggiungi azione"
#: ../gui/wxpython/menustrings.py:863
msgid "Add data"
-msgstr ""
+msgstr "Aggiungi dati"
#: ../gui/wxpython/menustrings.py:865
-#, fuzzy
msgid "Define relation"
-msgstr "Definisci una nuova location"
+msgstr "Definisci relazione"
#: ../gui/wxpython/menustrings.py:867
-#, fuzzy
msgid "Add loop"
+msgstr "Aggiungi ciclo"
#: ../gui/wxpython/menustrings.py:868
msgid "Adds loop (for) to model"
-msgstr ""
+msgstr "Aggiungi ciclo (for) al modello"
#: ../gui/wxpython/menustrings.py:869
-#, fuzzy
msgid "Add condition"
-msgstr "opzionale"
+msgstr "Aggiungi condizione"
#: ../gui/wxpython/menustrings.py:870
msgid "Adds condition (if/else) to model"
-msgstr ""
+msgstr "Aggiungi condizione (if/else) al modello"
#: ../gui/wxpython/menustrings.py:871
-#, fuzzy
msgid "Remove item"
-msgstr "Rimuovi tabella"
+msgstr ""
#: ../gui/wxpython/menustrings.py:872
-#, fuzzy
msgid "Remove action/data from model"
-msgstr "Elimina una tabella da un database"
+msgstr "Elimina azione/dati dal modello"
#: ../gui/wxpython/menustrings.py:873
#: ../gui/wxpython/gui_modules/gmodeler.py:3310
-#, fuzzy
msgid "Model properties"
+msgstr "Proprietà del modello"
#: ../gui/wxpython/menustrings.py:874
msgid "Model properties (name, purpose, etc.)"
-msgstr ""
+msgstr "Proprietà del modello (nome, scopo, ecc.)"
#: ../gui/wxpython/menustrings.py:875
-#, fuzzy
msgid "Delete intermediate data"
-msgstr "Elimina filtro"
+msgstr "Elimina dati intermediari"
#: ../gui/wxpython/menustrings.py:876
msgid "Delete intermediate data defined in the model"
-msgstr ""
+msgstr "Elimina i dati intermedi definiti nel modello"
#: ../gui/wxpython/menustrings.py:878
msgid "Run entire model"
-msgstr ""
+msgstr "Esegui il modello per intero"
#: ../gui/wxpython/menustrings.py:880
msgid "Validate entire model"
-msgstr ""
+msgstr "Valida il modello per intero"
#: ../gui/wxpython/menustrings.py:882
msgid "Help"
msgstr "Aiuto"
#: ../gui/wxpython/menustrings.py:883
-#, fuzzy
msgid "Display the HTML man pages of Graphical modeler"
-msgstr "Visualizza la pagina di supporto HTML di GRASS "
+msgstr ""
#: ../gui/wxpython/menustrings.py:884
msgid "About Graphical Modeler"
msgstr ""
#: ../gui/wxpython/menustrings.py:885
-#, fuzzy
msgid "Display information about Graphical Modeler"
-msgstr "Stampa informazioni basi di un raster."
+msgstr ""
#: ../gui/wxpython/gui_modules/colorrules.py:94
msgid "Create new color table for raster map"
@@ -4865,14 +4782,12 @@
#: ../gui/wxpython/gui_modules/histogram.py:175
#: ../gui/wxpython/gui_modules/mapdisp_window.py:669
-#, fuzzy
msgid "Please wait, exporting image..."
-msgstr "Per favore aspettare, aggiornamento dei dati..."
+msgstr "Per favore aspettare, esportando immagine..."
#: ../gui/wxpython/gui_modules/histogram.py:265
-#, fuzzy
msgid "GRASS GIS Histogram of image or raster map"
-msgstr "Crea istogramma di immagini o file raster"
+msgstr ""
#: ../gui/wxpython/gui_modules/histogram.py:351
msgid "Select font for histogram text"
@@ -4900,55 +4815,46 @@
msgstr "Anteprima di stampa"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:54
-#, fuzzy
msgid "GRASS GIS Raster Map Calculator"
-msgstr "GRASS %s Map Calculator"
+msgstr "GRASS GIS Raster Map Calculator"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:57
-#, fuzzy
msgid "GRASS GIS 3D Raster Map Calculator"
+msgstr "GRASS GIS RASTER 3D Map Calculator"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:67
-#, fuzzy
msgid "mapcalc statement"
-msgstr "comando SQL"
+msgstr ""
#: ../gui/wxpython/gui_modules/mcalc_builder.py:115
#: ../gui/wxpython/gui_modules/nviz_tools.py:890
-#, fuzzy
msgid "3D raster map"
msgstr "Raster 3D"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:118
-#, fuzzy
msgid "raster map"
-msgstr "Mappa Raster"
+msgstr "mappa raster"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:122
-#, fuzzy
msgid "Operators"
-msgstr "Traduttori"
+msgstr "Operatori"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:124
-#, fuzzy
msgid "Operands"
-msgstr "Apri"
+msgstr "Operandi"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:126
-#, fuzzy
msgid "Expression"
-msgstr "Emissione"
+msgstr "Espressione"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#, fuzzy
msgid "Command dialog"
-msgstr "Impostazioni finestre di dialogo"
+msgstr "Finestra del comando"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:138
+#, python-format
msgid "Open %s dialog"
-msgstr "Chiudi dialogo"
+msgstr "Apri finestra %s"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:142
msgid "exponent"
@@ -5047,34 +4953,30 @@
msgstr "opzionale"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:204
+#, python-format
msgid "Name for new %s to create"
-msgstr "Nome per il nuovo %s:"
+msgstr "Nome per il nuovo %s da creare"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:207
+#, python-format
msgid "Insert existing %s"
-msgstr "Inserisci %s esistente"
+msgstr "Inserisciu %s esistente"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:211
-#, fuzzy
msgid "Insert mapcalc function"
-msgstr "Inverti selezione"
+msgstr "Inserisci funzione mapcalc"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:412
-#, fuzzy
msgid "You must enter the name of a new map to create"
-msgstr "Per poter continuare devi inserire il nome dell'estensione della mappa"
+msgstr "Bisogna inserire il nome della nuova mappa da creare"
#: ../gui/wxpython/gui_modules/mcalc_builder.py:417
-#, fuzzy
msgid "You must enter a mapcalc statement to create a new map"
+msgstr ""
#: ../gui/wxpython/gui_modules/menudata.py:80
-#, fuzzy
msgid "Unknow tag"
-msgstr "Sconosciuto"
+msgstr ""
#: ../gui/wxpython/gui_modules/dbm_dialogs.py:71
msgid "Database connection is not defined in DB file."
@@ -5252,33 +5154,28 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:605
-#, fuzzy
msgid "Select maps to display for ground control point (GCP) creation"
msgstr ""
-"Seleziona immagine/mappa da visualizzare per creare i punti di controllo sul "
-"terreno (GCP)"
+"Seleziona mappa da visualizzare per creare i punti di controllo sul terreno "
+"(GCP)"
#: ../gui/wxpython/gui_modules/gcpmanager.py:613
#: ../gui/wxpython/gui_modules/gcpmanager.py:2542
-#, fuzzy
msgid "Select source map to display:"
-msgstr "Seleziona mapset di partenza"
+msgstr "Seleziona mappa sorgente da visualizzare:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:624
#: ../gui/wxpython/gui_modules/gcpmanager.py:2547
-#, fuzzy
msgid "Select target map to display:"
-msgstr "Seleziona raster per creare il profilo"
+msgstr "Seleziona mappa target da visualizzare:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:680
-#, fuzzy
msgid "You must select a source map in order to continue"
-msgstr "Devi selezionare un'immagine/mappa valide per continuare"
+msgstr "Devi selezionare una mappa sorgente per continuare"
#: ../gui/wxpython/gui_modules/gcpmanager.py:702
-#, fuzzy
msgid "Select maps to display"
-msgstr "Seleziona il font di default"
+msgstr "Seleziona mappe da visualizzare"
#: ../gui/wxpython/gui_modules/gcpmanager.py:703
#, python-format
@@ -5286,6 +5183,8 @@
"No maps in selected group <%s>. \n"
"Please edit group or select another group."
msgstr ""
+"Nessuna mappa nel gruppo <%s> selezionato. \n"
+"Editare il gruppo o selezionarne un altro."
#: ../gui/wxpython/gui_modules/gcpmanager.py:956
#: ../gui/wxpython/gui_modules/georect.py:846
@@ -5305,17 +5204,16 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:1116
#: ../gui/wxpython/gui_modules/toolbars.py:411
msgid "source"
-msgstr ""
+msgstr "sorgente"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1118
msgid "target"
-msgstr ""
+msgstr "destinazione"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1120
-#, fuzzy
msgid "Set GCP coordinates"
-msgstr "Converte coordinate"
+msgstr "Imposta coordinate GCP"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1121
#, python-format
@@ -5332,9 +5230,9 @@
msgstr "Scrittura del file POINTS fallita"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1191
+#, python-format
msgid "POINTS file saved for group <%s>"
-msgstr "File POINTS salvato"
+msgstr "File POINTS salvato per il group <%s>"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1207
msgid "source mapwin not defined"
@@ -5393,24 +5291,24 @@
"Vettore <%s> esiste già. Cambia nome dell'estensione e georettifica di nuovo."
#: ../gui/wxpython/gui_modules/gcpmanager.py:1461
-#, fuzzy
msgid "GCP Manager settings"
-msgstr "Impostazione del Layer Manager"
+msgstr "Impostazione del Gestore GCP"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1507
msgid "Quit GCP Manager"
-msgstr ""
+msgstr "Esci dal manager GCP"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1508
-#, fuzzy
msgid "Save ground control points?"
-msgstr "Imposta punti di controllo sul terreno (GCPs)"
+msgstr "Salva punti di controllo sul terreno?"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1585
msgid ""
"Could not calculate RMS Error. \n"
"Possible error with g.transform."
msgstr ""
+"Non è possibile calcolare l'errore RMS. \n"
+"Possibile un errore con g.transform."
#: ../gui/wxpython/gui_modules/gcpmanager.py:1717
msgid "Adjust GCP Displays "
@@ -5421,6 +5319,8 @@
"Could not calculate new extends. \n"
msgstr ""
+"Non è possibile calcolare la nuova estensione. \n"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1849
msgid "Adjust source display to target display"
@@ -5432,21 +5332,18 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:1914
#: ../gui/wxpython/gui_modules/gcpmanager.py:1931
-#, fuzzy
msgid "use"
-msgstr "deseleziona"
+msgstr "usare"
#: ../gui/wxpython/gui_modules/gcpmanager.py:1915
#: ../gui/wxpython/gui_modules/gcpmanager.py:1932
-#, fuzzy
msgid "source E"
-msgstr "Nome della colonna"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:1916
#: ../gui/wxpython/gui_modules/gcpmanager.py:1933
-#, fuzzy
msgid "source N"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:1917
#: ../gui/wxpython/gui_modules/gcpmanager.py:1934
@@ -5493,23 +5390,20 @@
msgstr "Seleziona vettore/i da aggiungere al gruppo:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2236
-#, fuzzy
msgid "Ground Control Point No."
-msgstr "Punto di controllo sul terreno"
+msgstr "Punto di controllo sul terreno."
#: ../gui/wxpython/gui_modules/gcpmanager.py:2255
-#, fuzzy
msgid "source E:"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:2256
msgid "target E:"
msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:2257
-#, fuzzy
msgid "source N:"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:2258
msgid "target N:"
@@ -5577,34 +5471,28 @@
msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:2453
-#, fuzzy
msgid "Color for selected GCP:"
-msgstr "Cancella GCP selezionati"
+msgstr "Colore per GCP selezionati:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2470
-#, fuzzy
msgid "Color for unused GCPs:"
-msgstr "Regole dei colori"
+msgstr "Colore per GCP non selezionati:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2486
-#, fuzzy
msgid "Show unused GCPs"
+msgstr "Mostra GCPs non usati"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2495
-#, fuzzy
msgid "Symbol size:"
-msgstr "Impostazioni dei simboli"
+msgstr "Dimensione dei simboli:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2510
-#, fuzzy
msgid "Line width:"
-msgstr "Grandezza linea"
+msgstr "Grandezza linea:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2567
-#, fuzzy
msgid "Rectification"
-msgstr "Barra degli strumenti del georettificatore"
+msgstr "Rettificazione"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2573
#: ../gui/wxpython/gui_modules/georect.py:764
@@ -5633,9 +5521,8 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:2620
#: ../gui/wxpython/gui_modules/gcpmanager.py:2625
-#, fuzzy
msgid "Update settings"
-msgstr "Impostazioni raster"
+msgstr "Aggiorna impostazioni"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2621
msgid "RMS threshold factor must be > 0"
@@ -5648,9 +5535,9 @@
msgstr ""
#: ../gui/wxpython/gui_modules/gcpmanager.py:2743
+#, python-format
msgid "GCP Manager settings saved to file '%s'."
-msgstr "Impostazione del profilo salvate nel file '%s'."
+msgstr "Impostazione del Gestore GCP salvate nel file '%s'."
#: ../gui/wxpython/gui_modules/mapdisp_window.py:123
#: ../gui/wxpython/gui_modules/mapdisp.py:740
@@ -5686,9 +5573,8 @@
msgstr "Nessuna mappa vettoriale selezionate per l'editing"
#: ../gui/wxpython/gui_modules/mapdisp_window.py:1625
-#, fuzzy
msgid "Vector digitizer"
-msgstr "Errore nel digitalizzatore di vettori"
+msgstr "Digitalizzatore vettoriale"
#: ../gui/wxpython/gui_modules/mapdisp_window.py:2316
msgid "Z bulk-labeling dialog"
@@ -5787,7 +5673,6 @@
"può essere definita nella GUI preferenze (tab 'Display')"
#: ../gui/wxpython/gui_modules/mapdisp.py:317
-#, fuzzy
msgid "Map toolbar"
msgstr "Barra degli strumenti della mappa"
@@ -5800,6 +5685,10 @@
"\n"
"Details: %s"
msgstr ""
+"Impossibile avviare il vettoriali digitalizzatore wxGUI.\n"
+"Vuoi invece avviare il digitalizzatore TCL/TK (v.digit)?\n"
+"\n"
+"Dettagli: %s"
#: ../gui/wxpython/gui_modules/mapdisp.py:333
#: ../gui/wxpython/gui_modules/mapdisp.py:343
@@ -5815,9 +5704,8 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:336
#: ../gui/wxpython/gui_modules/layertree.py:530
-#, fuzzy
msgid "Vector digitizer failed"
-msgstr "Digitalizzatore di vettori"
+msgstr "Digitalizzatore vettoriale fallito"
#: ../gui/wxpython/gui_modules/mapdisp.py:356
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:438
@@ -5847,7 +5735,7 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:404
msgid "Starting 3D view mode..."
-msgstr ""
+msgstr "Avviando la visualizzazione 3D..."
#: ../gui/wxpython/gui_modules/mapdisp.py:405
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:524
@@ -5855,15 +5743,13 @@
msgstr "Per favore aspettare, caricamento dei dati..."
#: ../gui/wxpython/gui_modules/mapdisp.py:435
-#, fuzzy
msgid "3D view toolbar"
-msgstr "Strumenti visualizzazione 3D"
+msgstr "Barra degli strumenti di visualizzazione 3D"
#: ../gui/wxpython/gui_modules/mapdisp.py:1096
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:1355
-#, fuzzy
msgid "Nothing to render (empty map). Operation canceled."
-msgstr "Nessun layer selezionato. Operazione cancellata"
+msgstr "Niente da visualizzare (mappa vuota). Operazione cancellata"
#: ../gui/wxpython/gui_modules/mapdisp.py:1269
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:1506
@@ -5893,14 +5779,12 @@
msgstr "Solo i vettori del mapset corrente possono essere modificati."
#: ../gui/wxpython/gui_modules/mapdisp.py:1445
-#, fuzzy
msgid "Query surface (raster map)"
-msgstr "Interroga mappe raster"
+msgstr "Interroga superficie (mappe raster)"
#: ../gui/wxpython/gui_modules/mapdisp.py:1452
-#, fuzzy
msgid "Query vector map"
-msgstr "Overlay vettori"
+msgstr "Interroga vettoriale"
#: ../gui/wxpython/gui_modules/mapdisp.py:1460
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:1681
@@ -6003,9 +5887,8 @@
msgstr "parole chiave"
#: ../gui/wxpython/gui_modules/ghelp.py:74
-#, fuzzy
msgid "Find module(s)"
-msgstr "Trova modulo:"
+msgstr "Trova modulo(i)"
#: ../gui/wxpython/gui_modules/ghelp.py:146
#: ../gui/wxpython/gui_modules/ghelp.py:179
@@ -6027,25 +5910,22 @@
#: ../gui/wxpython/gui_modules/ghelp.py:338
#: ../gui/wxpython/gui_modules/goutput.py:588
+#, python-format
msgid "%d modules match"
-msgstr "%d oggetti che combaciano"
+msgstr "%d moduli che combaciano"
#: ../gui/wxpython/gui_modules/ghelp.py:353
#: ../gui/wxpython/gui_modules/ghelp.py:968
-#, fuzzy
msgid "Menu tree"
-msgstr "Mostra menu tree"
+msgstr "Menu tree"
#: ../gui/wxpython/gui_modules/ghelp.py:508
-#, fuzzy
msgid "Official GRASS site:"
-msgstr "Sito ufficiale di GRASS: http://grass.osgeo.org"
+msgstr "Sito ufficiale di GRASS"
#: ../gui/wxpython/gui_modules/ghelp.py:524
-#, fuzzy
msgid "GIS Library Revision:"
-msgstr "Librerie GIS"
+msgstr "Revisione librerie GIS:"
#: ../gui/wxpython/gui_modules/ghelp.py:562
msgid "Copyright"
@@ -6109,12 +5989,11 @@
#: ../gui/wxpython/gui_modules/ghelp.py:770
msgid "Repository"
-msgstr ""
+msgstr "Repository"
#: ../gui/wxpython/gui_modules/ghelp.py:772
-#, fuzzy
msgid "List of extensions"
-msgstr "Seleziona l'estensione del file:"
+msgstr "Lista delle estensioni"
#: ../gui/wxpython/gui_modules/ghelp.py:777
msgid "Fetch full info including description and keywords (takes time)"
@@ -6130,15 +6009,16 @@
#: ../gui/wxpython/gui_modules/ghelp.py:792
msgid "&Install"
-msgstr ""
+msgstr "&Installa"
#: ../gui/wxpython/gui_modules/ghelp.py:793
msgid "Install selected add-ons GRASS module"
-msgstr ""
+msgstr "Installa il modulo GRASS add-ons selezionato"
#: ../gui/wxpython/gui_modules/ghelp.py:857
msgid "Fetch list of available extensions by clicking on 'Fetch' button"
msgstr ""
+"Controlla la lista delle estensioni disponibili cliccando sul bottone 'Fetch'"
#: ../gui/wxpython/gui_modules/ghelp.py:865
#, python-format
@@ -6147,16 +6027,15 @@
#: ../gui/wxpython/gui_modules/ghelp.py:877
msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr ""
+msgstr "Controllando la lista dei moduli dal SVN GRASS-Addons (attendere)..."
#: ../gui/wxpython/gui_modules/ghelp.py:1119
msgid "&Next"
-msgstr ""
+msgstr "&Prosegui"
#: ../gui/wxpython/gui_modules/ghelp.py:1122
-#, fuzzy
msgid "&Previous"
-msgstr "Anteprima"
+msgstr "&Precedente"
#: ../gui/wxpython/gui_modules/location_wizard.py:132
msgid "Define GRASS Database and Location Name"
@@ -6509,60 +6388,52 @@
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:75
-#, fuzzy
msgid "break lines/boundaries"
-msgstr "Unisci le linee/aree selezionate"
+msgstr "rompe linee/aree"
#: ../gui/wxpython/gui_modules/vclean.py:76
-#, fuzzy
msgid "remove duplicates"
-msgstr "Controlla duplicati"
+msgstr "rimuove duplicati"
#: ../gui/wxpython/gui_modules/vclean.py:77
-#, fuzzy
msgid "remove dangles"
-msgstr "Seleziona dangle"
+msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:78
msgid "change boundary dangles to lines"
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:79
-#, fuzzy
msgid "remove bridges"
+msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:80
msgid "change bridges to lines"
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:81
-#, fuzzy
msgid "snap lines/boundaries"
-msgstr "Inverti le linee/confini selezionati"
+msgstr "unisce linee/aree"
#: ../gui/wxpython/gui_modules/vclean.py:82
msgid "remove duplicate area centroids"
-msgstr ""
+msgstr "Rimuove i centroidi duplicati"
#: ../gui/wxpython/gui_modules/vclean.py:83
msgid "break polygons"
-msgstr ""
+msgstr "Separa poligoni"
#: ../gui/wxpython/gui_modules/vclean.py:84
-#, fuzzy
msgid "prune lines/boundaries"
+msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:85
-#, fuzzy
msgid "remove small areas"
+msgstr "rimuove aree piccole"
#: ../gui/wxpython/gui_modules/vclean.py:86
-#, fuzzy
msgid "remove lines/boundaries of zero length"
-msgstr "Spezza le linee/aree selezionate all'intersezione"
+msgstr "rimuove linee/aree con lunghezza zero"
#: ../gui/wxpython/gui_modules/vclean.py:87
msgid "remove small angles at nodes"
@@ -6570,28 +6441,24 @@
#: ../gui/wxpython/gui_modules/vclean.py:120
#: ../gui/wxpython/gui_modules/vclean.py:121
-#, fuzzy
msgid "Set up vector cleaning tools"
-msgstr "Selezione elemento vettoriale"
+msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:123
msgid "Choose cleaning tools and set thresholds"
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:127
-#, fuzzy
msgid "Select input vector map:"
-msgstr "Seleziona vettore:"
+msgstr "Seleziona vettoriale di input:"
#: ../gui/wxpython/gui_modules/vclean.py:133
-#, fuzzy
msgid " Feature type: "
-msgstr "Feature id:"
+msgstr "Tipologia delle feature:"
#: ../gui/wxpython/gui_modules/vclean.py:137
-#, fuzzy
msgid "Select output vector map:"
+msgstr "Seleziona vettoriale di output:"
#: ../gui/wxpython/gui_modules/vclean.py:167
#: ../gui/wxpython/gui_modules/menuform.py:759
@@ -6599,24 +6466,20 @@
msgstr "Copia la seguente stringa di comando negli appunti (Ctrl+C)"
#: ../gui/wxpython/gui_modules/vclean.py:203
-#, fuzzy
msgid "point"
-msgstr "Punto"
+msgstr "punto"
#: ../gui/wxpython/gui_modules/vclean.py:204
-#, fuzzy
msgid "line"
-msgstr "linea lossodromica"
+msgstr "linea"
#: ../gui/wxpython/gui_modules/vclean.py:205
-#, fuzzy
msgid "boundary"
-msgstr "Edita linea/confine"
+msgstr "area"
#: ../gui/wxpython/gui_modules/vclean.py:206
-#, fuzzy
msgid "centroid"
-msgstr "Aggiungi centroidi"
+msgstr "centroide"
#: ../gui/wxpython/gui_modules/vclean.py:207
#: ../gui/wxpython/gui_modules/vdigit.py:1539
@@ -6624,7 +6487,6 @@
msgstr "area"
#: ../gui/wxpython/gui_modules/vclean.py:208
-#, fuzzy
msgid "face"
msgstr "superficie"
@@ -6638,18 +6500,17 @@
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:385
+#, python-format
msgid "%s. cleaning tool moved up"
-msgstr "Strumenti per aggiustare la topologia di un vettore."
+msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:387
msgid "1. cleaning tool can not be moved up "
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:389
-#, fuzzy
msgid "Please select a cleaning tool to move up"
+msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:412
#, python-format
@@ -6679,9 +6540,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/vclean.py:510
-#, fuzzy
msgid "Vector cleaning command copied to clipboard"
-msgstr "Copia la seguente stringa di comando negli appunti"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:68
#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
@@ -6691,14 +6551,12 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:72
#: ../gui/wxpython/gui_modules/gmodeler.py:3176
-#, fuzzy
msgid "Data"
-msgstr "Database"
+msgstr "Dati"
#: ../gui/wxpython/gui_modules/nviz_tools.py:76
-#, fuzzy
msgid "Appearance"
-msgstr "Aspetto dell'Immagine"
+msgstr "Aspetto"
#: ../gui/wxpython/gui_modules/nviz_tools.py:110
msgid "Control View"
@@ -6818,12 +6676,10 @@
msgstr "Vettore"
#: ../gui/wxpython/gui_modules/nviz_tools.py:280
-#, fuzzy
msgid "Volume"
msgstr "Volumi"
#: ../gui/wxpython/gui_modules/nviz_tools.py:296
-#, fuzzy
msgid "Lighting"
msgstr "Evidenziazione"
@@ -6948,14 +6804,12 @@
msgstr "superficie"
#: ../gui/wxpython/gui_modules/nviz_tools.py:503
-#, fuzzy
msgid "wire color"
-msgstr "Colore della linea"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:517
-#, fuzzy
msgid "Fine:"
-msgstr "Linea:"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:552
msgid "Mask zeros:"
@@ -6967,16 +6821,15 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:561
msgid "by color"
-msgstr ""
+msgstr "attreverso il colore"
#: ../gui/wxpython/gui_modules/nviz_tools.py:576
msgid "Position"
msgstr "Posizione"
#: ../gui/wxpython/gui_modules/nviz_tools.py:627
-#, fuzzy
msgid "Vector map"
-msgstr "Nuova mappa vettoriale"
+msgstr "Mappa vettoriale"
#: ../gui/wxpython/gui_modules/nviz_tools.py:651
msgid "Show vector lines"
@@ -7007,7 +6860,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:706
msgid "on surface"
-msgstr ""
+msgstr "sulla superficie"
#: ../gui/wxpython/gui_modules/nviz_tools.py:716
#: ../gui/wxpython/gui_modules/nviz_tools.py:834
@@ -7060,27 +6913,24 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1128
-#, fuzzy
msgid "Show light model"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
msgid "Follow source viewpoint"
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1139
-#, fuzzy
msgid "Light source position"
-msgstr "Seleziona location di partenza"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1183
msgid "Light color and intensity"
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1196
-#, fuzzy
msgid "Brightness:"
-msgstr "Ricchezza"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1206
msgid "Ambient:"
@@ -7092,19 +6942,19 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:1269
msgid "N && W"
-msgstr ""
+msgstr "N && O"
#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
msgid "N && E"
-msgstr ""
+msgstr "N && E"
#: ../gui/wxpython/gui_modules/nviz_tools.py:1271
msgid "S && W"
-msgstr ""
+msgstr "S && O"
#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
msgid "S && E"
-msgstr ""
+msgstr "S && E"
#: ../gui/wxpython/gui_modules/nviz_tools.py:1292
msgid "Elevation of fringe from bottom:"
@@ -7116,14 +6966,12 @@
msgstr "Livello"
#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
-#, fuzzy
msgid "Vector map is 3D"
-msgstr "Mappa vettoriale <%s> è 3D"
+msgstr "Mappa vettoriale è 3D"
#: ../gui/wxpython/gui_modules/nviz_tools.py:2640
-#, fuzzy
msgid "Vector map is 2D"
-msgstr "Mappa vettoriale <%s> è 2D"
+msgstr "Mappa vettoriale è 2D"
#: ../gui/wxpython/gui_modules/nviz_tools.py:2642
#, python-format
@@ -7183,14 +7031,14 @@
msgstr "Layer"
#: ../gui/wxpython/gui_modules/prompt.py:392
+#, python-format
msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
-msgstr "Attenzione: opzione <%s> non trovata in '%s'"
+msgstr "Attenzione: flag <%(flag)s> non trovato in '%(module)s'"
#: ../gui/wxpython/gui_modules/prompt.py:395
+#, python-format
msgid "Warning: option <%(param)s> not found in '%(module)s'"
+msgstr "Attenzione: opzione <%(param)s> non trovata in '%(module)s'"
#: ../gui/wxpython/gui_modules/prompt.py:632
msgid "Type GRASS command and run by pressing ENTER"
@@ -7262,14 +7110,12 @@
msgstr "sovrascrivi il file esistente"
#: ../gui/wxpython/gui_modules/gselect.py:286
-#, fuzzy
msgid "Not selectable element"
-msgstr "Cancella la colonna selezionata"
+msgstr "Elemento non selezionabile"
#: ../gui/wxpython/gui_modules/gselect.py:942
-#, fuzzy
msgid "Source name"
+msgstr "Nome sorgete"
#: ../gui/wxpython/gui_modules/gselect.py:952
#: ../gui/wxpython/gui_modules/menuform.py:1545
@@ -7297,9 +7143,8 @@
#: ../gui/wxpython/gui_modules/gselect.py:982
#: ../gui/wxpython/gui_modules/gselect.py:1118
-#, fuzzy
msgid "Choose input file"
-msgstr "Scegli file degli script"
+msgstr "Scegli file di input"
#: ../gui/wxpython/gui_modules/gselect.py:991
msgid "Choose input directory"
@@ -7323,19 +7168,16 @@
msgstr "Database:"
#: ../gui/wxpython/gui_modules/gselect.py:1040
-#, fuzzy
msgid "Protocol:"
-msgstr "Codice della proiezione:"
+msgstr "Protocollo:"
#: ../gui/wxpython/gui_modules/gselect.py:1061
-#, fuzzy
msgid "Format:"
-msgstr "Formato"
+msgstr "Formato:"
#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
-#, fuzzy
msgid "3D view settings"
-msgstr "Impostazioni server"
+msgstr "Impostazioni visualizzazione 3D"
#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
@@ -7388,9 +7230,9 @@
msgstr "Impostazione di NVIZ salvate nel file <%s>"
#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
+#, python-format
msgid "3D view settings saved to file <%s>."
-msgstr "Impostazione di NVIZ salvate nel file <%s>"
+msgstr "Impostazioni visualizzazione 3D salvate nel file <%s>."
#: ../gui/wxpython/gui_modules/gcmd.py:75
msgid "Reason"
@@ -7415,7 +7257,6 @@
msgstr "Impossibile eseguire il comando '%s'"
#: ../gui/wxpython/gui_modules/vdigit.py:114
-#, fuzzy
msgid ""
"Unable to initialize display driver of vector digitizer. See 'Command "
"output' for details.\n"
@@ -7848,27 +7689,23 @@
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:175
msgid "Go to GCP No."
-msgstr ""
+msgstr "Vai al GCP No."
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:176
-#, fuzzy
msgid "RMS error"
msgstr "Errore RMS"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:316
-#, fuzzy
msgid "GCP List"
-msgstr "Lista"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:321
-#, fuzzy
msgid "Source Display"
-msgstr "Visualizza"
+msgstr "Visualizza sorgente"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:325
-#, fuzzy
msgid "Target Display"
+msgstr "Visualizza targer"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:405
msgid "Map Toolbar"
@@ -7890,14 +7727,12 @@
"Dettagli: %s"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:456
-#, fuzzy
msgid "GCP Display toolbar"
-msgstr "Visualizza mappa"
+msgstr "Barra degli strumenti Visualizzatore GCP"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:469
-#, fuzzy
msgid "GCP Manager toolbar"
-msgstr "Gestisci colori"
+msgstr "Barra degli strumente Gestore GCP"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:493
#, python-format
@@ -7919,13 +7754,12 @@
msgstr "Barra degli strumenti Nviz"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:943
-#, fuzzy
msgid "Valid Range:"
+msgstr "Range valido:"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:945
msgid "Invalid GCP Number"
-msgstr ""
+msgstr "Numero di GCP invalido"
#: ../gui/wxpython/gui_modules/gcpmapdisp.py:1280
#, python-format
@@ -7940,44 +7774,37 @@
"('Attributi')."
#: ../gui/wxpython/gui_modules/gmodeler.py:89
-#, fuzzy
msgid "model"
-msgstr "Modello:"
+msgstr "modello"
#: ../gui/wxpython/gui_modules/gmodeler.py:90
msgid "Script generated by wxGUI Graphical Modeler."
msgstr ""
#: ../gui/wxpython/gui_modules/gmodeler.py:408
-#, fuzzy
msgid "Raster maps"
+msgstr "Mappe Raster"
#: ../gui/wxpython/gui_modules/gmodeler.py:411
-#, fuzzy
msgid "3D raster maps"
-msgstr "Raster 3D"
+msgstr "Mappe raster 3D"
#: ../gui/wxpython/gui_modules/gmodeler.py:414
-#, fuzzy
msgid "Vector maps"
-msgstr "Punti vettoriale"
+msgstr "Mappe Vettoriali"
#: ../gui/wxpython/gui_modules/gmodeler.py:440
#: ../gui/wxpython/gui_modules/gmodeler.py:563
-#, fuzzy
msgid "Variables"
-msgstr "Lista tabelle"
+msgstr "Variabile"
#: ../gui/wxpython/gui_modules/gmodeler.py:506
-#, fuzzy
msgid "GRASS GIS Graphical Modeler"
-msgstr "Aiuto GRASS GIS"
+msgstr ""
#: ../gui/wxpython/gui_modules/gmodeler.py:561
-#, fuzzy
msgid "Model"
-msgstr "Modalità"
+msgstr "Modello"
#: ../gui/wxpython/gui_modules/gmodeler.py:562
msgid "Items"
@@ -7985,17 +7812,15 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:631
msgid "Redrawing model..."
-msgstr ""
+msgstr "Si sta ridisegnando il modello...."
#: ../gui/wxpython/gui_modules/gmodeler.py:658
-#, fuzzy
msgid "Do you want to save changes in the model?"
-msgstr "Vuoi salvare i cambiamenti nell'ambiente di lavoro?"
+msgstr "Vuoi salvare i cambiamenti nel modello?"
#: ../gui/wxpython/gui_modules/gmodeler.py:660
-#, fuzzy
msgid "Do you want to store current model settings to model file?"
-msgstr "Vuoi salvare le impostazioni correnti in un file d'ambiente di lavoro?"
+msgstr "Vuoi salvare le impostazioni del modello correnti in un file?"
#: ../gui/wxpython/gui_modules/gmodeler.py:666
msgid "Quit Graphical Modeler"
@@ -8007,40 +7832,36 @@
msgstr "Niente da eliminare"
#: ../gui/wxpython/gui_modules/gmodeler.py:731
+#, python-format
msgid "Do you want to permanently delete data?%s"
-msgstr "Vuoi salvare i cambiamenti nella mappa vettoriale <%s>?"
+msgstr "Vuoi eliminare permanentemente i dati?%s"
#: ../gui/wxpython/gui_modules/gmodeler.py:732
-#, fuzzy
msgid "Delete intermediate data?"
+msgstr "Elimina dati intermediari?"
#: ../gui/wxpython/gui_modules/gmodeler.py:746
+#, python-format
msgid "%d maps deleted from current mapset"
-msgstr "Rimuove i file degli elementi nel corrente mapset nel database"
+msgstr "%d mappe eliminate dal mapset attuale"
#: ../gui/wxpython/gui_modules/gmodeler.py:761
#: ../gui/wxpython/gui_modules/gmodeler.py:873
-#, fuzzy
msgid ""
"Current model is not empty. Do you want to store current settings to model "
"file?"
msgstr ""
-"L'ambiente di lavoro corrente non è vuoto. Vuoi salvare le impostazioni "
-"correnti in un file d'ambiente di lavoro?"
+"Il modello corrente non è vuoto. Vuoi salvare le impostazioni correnti in un "
+"file?"
#: ../gui/wxpython/gui_modules/gmodeler.py:764
#: ../gui/wxpython/gui_modules/gmodeler.py:876
-#, fuzzy
msgid "Create new model?"
+msgstr "Crea un nuovo modelo?"
#: ../gui/wxpython/gui_modules/gmodeler.py:789
-#, fuzzy
msgid "Choose model file"
-msgstr "Scegli file:"
+msgstr "Scegli file del modello"
#: ../gui/wxpython/gui_modules/gmodeler.py:807
#, python-format
@@ -8049,77 +7870,69 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:813
#: ../gui/wxpython/gui_modules/gmodeler.py:850
+#, python-format
msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Il file dell'ambiente di lavoro <%s> esiste già. Vuoi sovrascrivvere questo "
-"file?"
+msgstr "Il file del modello <%s> esiste già. Vuoi sovrascrivvere questo file?"
#: ../gui/wxpython/gui_modules/gmodeler.py:823
#: ../gui/wxpython/gui_modules/gmodeler.py:863
+#, python-format
msgid "File <%s> saved"
-msgstr "File POINTS <%s> salvato"
+msgstr "File <%s> salvato"
#: ../gui/wxpython/gui_modules/gmodeler.py:832
-#, fuzzy
msgid "Choose file to save current model"
-msgstr "Scegli il file dove salvare il corrente ambiente di lavoro"
+msgstr "Scegli il file dove salvare il modello attuale"
#: ../gui/wxpython/gui_modules/gmodeler.py:852
msgid "File already exists"
-msgstr ""
+msgstr "Il file esiste già"
#: ../gui/wxpython/gui_modules/gmodeler.py:900
msgid "Model is empty. Nothing to run."
-msgstr ""
+msgstr "Il modello è vuoto. Niente da eseguire."
#: ../gui/wxpython/gui_modules/gmodeler.py:987
msgid "Model is empty. Nothing to validate."
-msgstr ""
+msgstr "Il modello è vuoto. Niente da validare."
#: ../gui/wxpython/gui_modules/gmodeler.py:994
+#, python-format
msgid ""
"Model is not valid.\n"
"\n"
"%s"
msgstr ""
-"Istruzione SQL non è valida.\n"
+"Il modello non è valido.\n"
"\n"
"%s"
#: ../gui/wxpython/gui_modules/gmodeler.py:997
msgid "Model is valid."
-msgstr ""
+msgstr "Il modello è valido"
#: ../gui/wxpython/gui_modules/gmodeler.py:1059
#: ../gui/wxpython/gui_modules/gmodeler.py:1102
#, python-format
msgid "Model exported to <%s>"
-msgstr ""
+msgstr "Il modello esportato a <%s>"
#: ../gui/wxpython/gui_modules/gmodeler.py:1067
-#, fuzzy
msgid "Choose file to save"
-msgstr "Scegli il file GRC da caricare"
+msgstr "Scegli il file da salvare"
#: ../gui/wxpython/gui_modules/gmodeler.py:1069
-#, fuzzy
msgid "Python script (*.py)|*.py"
+msgstr "Python script (*.py)|*.py"
#: ../gui/wxpython/gui_modules/gmodeler.py:1083
+#, python-format
msgid "File <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"file?"
+msgstr "Il file <%s> esiste già. Vuoi sovrascrivvere questo file?"
#: ../gui/wxpython/gui_modules/gmodeler.py:1085
-#, fuzzy
msgid "Save file"
-msgstr "Salva file come..."
+msgstr "Salva file"
#: ../gui/wxpython/gui_modules/gmodeler.py:1350
msgid "wxGUI Graphical Modeler"
@@ -8130,33 +7943,34 @@
"(C) 2010 by the GRASS Development Team\n"
"\n"
msgstr ""
+"(C) 2010 GRASS Development Team\n"
+"\n"
#: ../gui/wxpython/gui_modules/gmodeler.py:1353
msgid ""
"This program is free software under the GNU General Public License(>=v2). "
"Read the file COPYING that comes with GRASS for details."
msgstr ""
+"Questo programma è software libero rilasciato sotto GNU General Public "
+"LIcense(>=v2). Per maggiori dettagli leggi il file COPYING che viene "
+"distribuito con GRASS."
#: ../gui/wxpython/gui_modules/gmodeler.py:1482
+#, python-format
msgid ""
"Reading model file <%s> failed.\n"
msgstr ""
+"Lettura file del modello <%s> fallita.\n"
#: ../gui/wxpython/gui_modules/gmodeler.py:1488
-#, fuzzy
msgid "Please wait, loading model..."
-msgstr "Per favore aspettare, caricamento dei dati..."
+msgstr "Per favore aspettare, caricamento modello..."
#: ../gui/wxpython/gui_modules/gmodeler.py:1543
-#, fuzzy
msgid "Writing current settings to model file failed."
-msgstr ""
-"Scrittura delle impostazioni correnti nel file dell'ambiente di lavoro "
-"fallita (%s)"
+msgstr "Scrittura delle impostazioni correnti nel file del modello fallita."
#: ../gui/wxpython/gui_modules/gmodeler.py:1796
#: ../gui/wxpython/gui_modules/gmodeler.py:1853
@@ -8166,24 +7980,20 @@
msgstr "sconosciuto"
#: ../gui/wxpython/gui_modules/gmodeler.py:2085
-#, fuzzy
msgid "Data properties"
+msgstr "Proprietà dei dati"
#: ../gui/wxpython/gui_modules/gmodeler.py:2092
-#, fuzzy
msgid "Name of raster map:"
-msgstr "Raster ricampionato:"
+msgstr "Nome del raster:"
#: ../gui/wxpython/gui_modules/gmodeler.py:2094
-#, fuzzy
msgid "Name of vector map:"
-msgstr "Nome per il nuovo vettore:"
+msgstr "Nome del vettoriale:"
#: ../gui/wxpython/gui_modules/gmodeler.py:2096
-#, fuzzy
msgid "Name of element:"
-msgstr "Nome del mapset:"
+msgstr "Nome dell'elemento:"
#: ../gui/wxpython/gui_modules/gmodeler.py:2270
#: ../gui/wxpython/gui_modules/layertree.py:264
@@ -8191,24 +8001,20 @@
msgstr "Rimuovi"
#: ../gui/wxpython/gui_modules/gmodeler.py:2274
-#, fuzzy
msgid "Disable"
+msgstr ""
#: ../gui/wxpython/gui_modules/gmodeler.py:2277
-#, fuzzy
msgid "Enable"
-msgstr "Tabella"
+msgstr ""
#: ../gui/wxpython/gui_modules/gmodeler.py:2282
-#, fuzzy
msgid "Add control point"
+msgstr "Aggiungi Punto di controllo sul terreno"
#: ../gui/wxpython/gui_modules/gmodeler.py:2284
-#, fuzzy
msgid "Remove control point"
+msgstr "Rimuovi punti di controllo sul terreno"
#: ../gui/wxpython/gui_modules/gmodeler.py:2291
msgid "Intermediate"
@@ -8220,13 +8026,12 @@
msgstr "Proprietà"
#: ../gui/wxpython/gui_modules/gmodeler.py:2306
-#, fuzzy
msgid "Change ID"
-msgstr "Cambia valori"
+msgstr "Cambia ID"
#: ../gui/wxpython/gui_modules/gmodeler.py:2362
msgid "Add new GRASS module to the model"
-msgstr ""
+msgstr "Aggiungi un nuovo modulo di GRASS al modello."
#: ../gui/wxpython/gui_modules/gmodeler.py:2380
#: ../gui/wxpython/gui_modules/gmodeler.py:3883
@@ -8241,6 +8046,9 @@
"\n"
"Unable to add new action to the model."
msgstr ""
+"Comando non definito.\n"
+"\n"
+"Impossibile aggiungere la nuova azione al modello."
#: ../gui/wxpython/gui_modules/gmodeler.py:2454
#, python-format
@@ -8249,40 +8057,38 @@
"\n"
msgstr ""
+"'%s' non è un modulo di GRASS.\n"
+"\n"
#: ../gui/wxpython/gui_modules/gmodeler.py:3040
-#, fuzzy
msgid "Action"
-msgstr "Direzione"
+msgstr "Azione"
#: ../gui/wxpython/gui_modules/gmodeler.py:3045
msgid "Validity"
-msgstr ""
+msgstr "Validità"
#: ../gui/wxpython/gui_modules/gmodeler.py:3053
-#, fuzzy
msgid "Valid:"
+msgstr "Valido:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3070
-#, fuzzy
msgid "Invalid:"
-msgstr "Valore non valido: %s"
+msgstr "Invalido:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3087
msgid "Running:"
-msgstr ""
+msgstr "Eseguendo:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3104
-#, fuzzy
msgid "Disabled:"
+msgstr "Disabilitato:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3124
#: ../gui/wxpython/gui_modules/gmodeler.py:3243
-#, fuzzy
msgid "Shape size"
-msgstr "Indice shape"
+msgstr "Dimensione dello shape"
#: ../gui/wxpython/gui_modules/gmodeler.py:3181
#: ../gui/wxpython/gui_modules/profile.py:1252
@@ -8290,19 +8096,16 @@
msgstr "Tipe"
#: ../gui/wxpython/gui_modules/gmodeler.py:3189
-#, fuzzy
msgid "Raster:"
-msgstr "Raster"
+msgstr "Raster:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3206
-#, fuzzy
msgid "3D raster:"
-msgstr "raster 3d"
+msgstr "Raster 3D:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3223
-#, fuzzy
msgid "Vector:"
-msgstr "Vettore"
+msgstr "Vettoriale:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3317
#: ../gui/wxpython/gui_modules/layertree.py:351
@@ -8311,39 +8114,32 @@
msgstr "Metadati"
#: ../gui/wxpython/gui_modules/gmodeler.py:3319
-#, fuzzy
msgid "Commands"
-msgstr "Comando"
+msgstr "Comandi"
#: ../gui/wxpython/gui_modules/gmodeler.py:3339
-#, fuzzy
msgid "Apply properties"
+msgstr "Applica proprietà"
#: ../gui/wxpython/gui_modules/gmodeler.py:3353
-#, fuzzy
msgid "Name:"
-msgstr "Nome"
+msgstr "Nome:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3362
-#, fuzzy
msgid "Description:"
-msgstr "Descrizione"
+msgstr "Descrizione:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3371
-#, fuzzy
msgid "Author(s):"
-msgstr "Autori"
+msgstr "Autore(i):"
#: ../gui/wxpython/gui_modules/gmodeler.py:3420
-#, fuzzy
msgid "Model parameters"
-msgstr "Parametri del terreno"
+msgstr "Parametri del modello"
#: ../gui/wxpython/gui_modules/gmodeler.py:3567
-#, fuzzy
msgid "List of variables - right-click to delete"
-msgstr "Lista delle categorie - clicca tasto destro per eliminare"
+msgstr ""
#: ../gui/wxpython/gui_modules/gmodeler.py:3570
#: ../gui/wxpython/gui_modules/gmodeler.py:3617
@@ -8354,19 +8150,16 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:3571
#: ../gui/wxpython/gui_modules/gmodeler.py:3623
-#, fuzzy
msgid "Default value"
-msgstr "Imposta valore"
+msgstr "Valore di default"
#: ../gui/wxpython/gui_modules/gmodeler.py:3575
-#, fuzzy
msgid "Add new variable"
-msgstr "Aggiungi nuovo vertice"
+msgstr "Aggiungi nuova variabile"
#: ../gui/wxpython/gui_modules/gmodeler.py:3579
-#, fuzzy
msgid "integer"
-msgstr "Puntatore"
+msgstr "intero"
#: ../gui/wxpython/gui_modules/gmodeler.py:3580
msgid "float"
@@ -8374,75 +8167,67 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:3581
msgid "string"
-msgstr ""
+msgstr "stringa"
#: ../gui/wxpython/gui_modules/gmodeler.py:3589
msgid "Add new variable to the model"
-msgstr ""
+msgstr "Aggiungi nuova variabile al modello"
#: ../gui/wxpython/gui_modules/gmodeler.py:3737
+#, python-format
msgid "Variable <%s> already exists in the model. Adding variable failed."
msgstr ""
-"Impossibile creare nuova tabella. La tabella <%s> esiste già nel database"
+"La variabile <%s> esiste già nel modello. Aggiunta della variabile fallita."
#: ../gui/wxpython/gui_modules/gmodeler.py:3766
-#, fuzzy
msgid "Do you want to delete all variables from the model?"
-msgstr "Vuoi rimuove i layer selezionati dal layer tree"
+msgstr "Vuoi rimuove tutte le variabili dal modello?"
#: ../gui/wxpython/gui_modules/gmodeler.py:3768
-#, fuzzy
msgid "Delete variables"
-msgstr "Elimina tutto"
+msgstr "Elimina variabili"
#: ../gui/wxpython/gui_modules/gmodeler.py:3852
-#, fuzzy
msgid "Condition: "
-msgstr "opzionale"
+msgstr "Condizione:"
#: ../gui/wxpython/gui_modules/gmodeler.py:3854
msgid "Condition: not defined"
-msgstr ""
+msgstr "Condizione: non definito"
#: ../gui/wxpython/gui_modules/gmodeler.py:3876
-#, fuzzy
msgid "Condition"
-msgstr "opzionale"
+msgstr "Condizione"
#: ../gui/wxpython/gui_modules/gmodeler.py:3882
#: ../gui/wxpython/gui_modules/gmodeler.py:3986
#: ../gui/wxpython/gui_modules/gmodeler.py:4285
msgid "ID"
-msgstr ""
+msgstr "ID"
#: ../gui/wxpython/gui_modules/gmodeler.py:3928
msgid "loop"
-msgstr ""
+msgstr "ciclo"
#: ../gui/wxpython/gui_modules/gmodeler.py:3932
-#, fuzzy
msgid "Loop properties"
+msgstr "Proprietà del ciclo"
#: ../gui/wxpython/gui_modules/gmodeler.py:3938
-#, fuzzy
msgid "List of items in loop"
-msgstr "Lista dei duplicati"
+msgstr ""
#: ../gui/wxpython/gui_modules/gmodeler.py:3983
-#, fuzzy
msgid "List of items - right-click to delete"
+msgstr ""
msgid "In block"
-msgstr ""
+msgstr "nel blocco"
#: ../gui/wxpython/gui_modules/gmodeler.py:3987
-#, fuzzy
msgid "Command / Condition"
-msgstr "Console dei programmi"
+msgstr "Comando / Condizione"
#: ../gui/wxpython/gui_modules/gmodeler.py:4106
#: ../gui/wxpython/gui_modules/dbm.py:1181
@@ -8466,12 +8251,11 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:4259
msgid "if-else"
-msgstr ""
+msgstr "if-else"
#: ../gui/wxpython/gui_modules/gmodeler.py:4271
-#, fuzzy
msgid "If-else properties"
+msgstr "Proprietà if-else"
#: ../gui/wxpython/gui_modules/gmodeler.py:4277
msgid "List of items in 'if' block"
@@ -8597,23 +8381,20 @@
msgstr "Generatore SQL"
#: ../gui/wxpython/gui_modules/goutput.py:206
-#, fuzzy
msgid "Click here to show search module engine"
-msgstr "Clicca qui per mostrare le impostazioni 3D"
+msgstr ""
#: ../gui/wxpython/gui_modules/goutput.py:207
-#, fuzzy
msgid "Click here to hide search module engine"
-msgstr "Clicca qui per nascondere le impostazioni 3D"
+msgstr ""
#: ../gui/wxpython/gui_modules/goutput.py:232
msgid "C&lear output"
msgstr "P&ulisci output"
#: ../gui/wxpython/gui_modules/goutput.py:234
-#, fuzzy
msgid "&Clear command"
-msgstr "&Interrompi programma"
+msgstr "&Interrompi comando"
#: ../gui/wxpython/gui_modules/goutput.py:238
msgid "&Save output"
@@ -8628,12 +8409,12 @@
msgstr "Stoppa l'esecuzione del comando"
#: ../gui/wxpython/gui_modules/goutput.py:479
-#, fuzzy, python-format
+#, python-format
msgid ""
"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
"layer instead."
msgstr ""
-"Comando '%s' non è ancora implementato nella GUI. Piuttosto prova "
+"Comando '%s' non è ancora implementato nella WxGUI. Piuttosto prova "
"utilizzando la barra dei comandi. "
#: ../gui/wxpython/gui_modules/goutput.py:565
@@ -8661,30 +8442,30 @@
#: ../gui/wxpython/gui_modules/wxnviz.py:227
#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#, python-format
msgid "Raster map <%s> not found"
-msgstr "Mappa <%s> non trovata."
+msgstr "Raster <%s> non trovato"
#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#, python-format
msgid "Vector map <%s> not found"
+msgstr "Vettoriale <%s> non trovato."
#: ../gui/wxpython/gui_modules/wxnviz.py:354
#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#, python-format
msgid "3d raster map <%s> not found"
+msgstr "Raster 3D <%s> non trovato"
#: ../gui/wxpython/gui_modules/toolbars.py:188
msgid "3D view mode not available"
-msgstr ""
+msgstr "Visualizzazione 3D non disponibile"
#: ../gui/wxpython/gui_modules/toolbars.py:189
#: ../gui/wxpython/gui_modules/toolbars.py:205
#, python-format
msgid "Reason: %s"
-msgstr ""
+msgstr "Motivazione: %s"
#: ../gui/wxpython/gui_modules/toolbars.py:190
msgid ""
@@ -8699,9 +8480,8 @@
msgstr "Digitalizza"
#: ../gui/wxpython/gui_modules/toolbars.py:204
-#, fuzzy
msgid "Vector digitizer not available"
-msgstr "Barra degli strumenti per il digitalizzatore"
+msgstr "Digitalizzatore vettoriale non disponibile"
#: ../gui/wxpython/gui_modules/toolbars.py:206
msgid ""
@@ -8715,9 +8495,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/toolbars.py:418
-#, fuzzy
msgid " / Zoom to map"
-msgstr "Zoom sulla mappa"
+msgstr "/ Zoom sulla mappa"
#: ../gui/wxpython/gui_modules/toolbars.py:472
msgid "Adjust display zoom"
@@ -8832,14 +8611,14 @@
msgstr "Aggiungi diversi layer vettoriali"
#: ../gui/wxpython/gui_modules/utils.py:498
+#, python-format
msgid "failed to open '%s'"
-msgstr "Impossibile aprire il file"
+msgstr "Impossibile aprire '%s'"
#: ../gui/wxpython/gui_modules/render.py:134
+#, python-format
msgid "<%(name)s>: layer type <%(type)s> is not supported"
-msgstr "<%(name)s>: layer <%(type)s> non è supportato ancora"
+msgstr "<%(name)s>: la tipologia di layer <%(type)s> non è supportata"
#: ../gui/wxpython/gui_modules/render.py:263
#, python-format
@@ -8855,6 +8634,8 @@
#, python-format
msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
msgstr ""
+"Errore: Impossibile aprire '%(file)s'. Motivazione: %(ret)s. Usciti da "
+"wxGUI.\n"
#: ../gui/wxpython/gui_modules/render.py:616
#, python-format
@@ -8991,9 +8772,8 @@
msgstr "Sinuosità della linea"
#: ../gui/wxpython/gui_modules/dbm.py:408
-#, fuzzy
msgid "Line azimuth"
+msgstr ""
#: ../gui/wxpython/gui_modules/dbm.py:560
#: ../gui/wxpython/gui_modules/dbm.py:3078
@@ -9216,19 +8996,18 @@
#: ../gui/wxpython/gui_modules/dbm.py:1675
+#, python-format
msgid ""
"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
"drop the column?"
msgstr ""
-"I record (%d) selezionati saranno permanentemente eliminati della tabella. "
-"Vuoi eliminarli?"
+"La colonna selezionata '%s' sarà permanentemente eliminata della tabella. "
+"Vuoi eliminara la colonna?"
#: ../gui/wxpython/gui_modules/dbm.py:1678
#: ../gui/wxpython/gui_modules/dbm.py:1715
-#, fuzzy
msgid "Drop column(s)"
+msgstr "Cancella colonna(e)"
#: ../gui/wxpython/gui_modules/dbm.py:1712
#, python-format
@@ -9509,9 +9288,8 @@
msgstr "Tipologia del layer:"
#: ../gui/wxpython/gui_modules/gdialogs.py:779
-#, fuzzy
msgid "Select toggle"
+msgstr ""
#: ../gui/wxpython/gui_modules/gdialogs.py:786
msgid "Mapset:"
@@ -9583,14 +9361,12 @@
msgstr "opaco"
#: ../gui/wxpython/gui_modules/gdialogs.py:1498
-#, fuzzy
msgid "Set image size"
-msgstr "Dimensione dell'area"
+msgstr "Imposta dimensione dell'immagine"
#: ../gui/wxpython/gui_modules/gdialogs.py:1507
-#, fuzzy
msgid "Image size"
+msgstr "Dimensione dell'immagine"
#: ../gui/wxpython/gui_modules/gdialogs.py:1554
msgid "Template:"
@@ -9646,11 +9422,13 @@
#: ../gui/wxpython/gui_modules/profile.py:576
msgid "Comma separated value (*.csv)|*.csv"
-msgstr ""
+msgstr "Comma separated value (*.csv)|*.csv"
#: ../gui/wxpython/gui_modules/profile.py:579
msgid "Path and prefix (for raster name) to save profile values..."
msgstr ""
+"Percorso e prefisso (per il nome del raster) dove salvare i valori del "
+"profilo..."
#: ../gui/wxpython/gui_modules/profile.py:674
msgid "This feature is not yet functional"
@@ -9658,7 +9436,7 @@
#: ../gui/wxpython/gui_modules/profile.py:675
msgid "Under Construction"
-msgstr ""
+msgstr "In costruzione"
#: ../gui/wxpython/gui_modules/profile.py:702
msgid "Profile text settings"
@@ -9697,9 +9475,8 @@
msgstr "Dimensione del font del titolo (pts):"
#: ../gui/wxpython/gui_modules/profile.py:932
-#, fuzzy
msgid "X-axis label:"
-msgstr "label dell'asse Y:"
+msgstr "label dell'asse X:"
#: ../gui/wxpython/gui_modules/profile.py:942
msgid "Y-axis label:"
@@ -9728,9 +9505,8 @@
msgstr "Larghezza:"
#: ../gui/wxpython/gui_modules/profile.py:1035
-#, fuzzy
msgid "Apply changes for the current session and close dialog"
-msgstr "Applica i cambiamenti per la sessione corrente"
+msgstr "Applica i cambiamenti per la sessione corrente e chiudi la finestra"
#: ../gui/wxpython/gui_modules/profile.py:1091
#: ../gui/wxpython/gui_modules/profile.py:1441
@@ -9831,9 +9607,8 @@
msgstr "Cambia il livello di opacità"
#: ../gui/wxpython/gui_modules/layertree.py:283
-#, fuzzy
msgid "3D view properties"
-msgstr "Proprietà di NVIZ"
+msgstr "Proprieta della visualizzazione 3D"
#: ../gui/wxpython/gui_modules/layertree.py:287
msgid "Zoom to selected map(s)"
@@ -9980,9 +9755,9 @@
msgstr "Flag non trovata: %s"
#: ../gui/wxpython/gui_modules/menuform.py:463
+#, python-format
msgid "Parameter '%(name)s' (%(desc)s) is missing."
-msgstr "Parametro %(name)s (%(desc)s) manca.\n"
+msgstr "Parametro %(name)s (%(desc)s) è mancante."
#: ../gui/wxpython/gui_modules/menuform.py:489
msgid "<required>"
@@ -10005,9 +9780,8 @@
msgstr "Esegui il commando (Ctrl+R)"
#: ../gui/wxpython/gui_modules/menuform.py:793
-#, fuzzy
msgid "Add created map(s) into layer tree"
-msgstr "Aggiungi la mappa creata nel layer tree"
+msgstr "Aggiungi la mappa(e) creata nel layer tree"
#: ../gui/wxpython/gui_modules/menuform.py:802
#: ../gui/wxpython/gui_modules/preferences.py:1360
@@ -10036,16 +9810,14 @@
#: ../gui/wxpython/gui_modules/menuform.py:1106
#: ../gui/wxpython/gui_modules/menuform.py:1580
-#, fuzzy
msgid "Parameterized in model"
-msgstr "Paramentro non trovato:%s"
+msgstr ""
#: ../gui/wxpython/gui_modules/menuform.py:1177
msgid "[multiple]"
msgstr "[multiplo]"
#: ../gui/wxpython/gui_modules/menuform.py:1225
-#, fuzzy
msgid "valid range"
msgstr "Range valido"
@@ -10072,9 +9844,8 @@
msgstr "Scegli %s"
#: ../gui/wxpython/gui_modules/menuform.py:1571
-#, fuzzy
msgid "or enter values interactively"
-msgstr "Ricodifica interattivamente"
+msgstr "o inserisci interattivamente i valori"
#: ../gui/wxpython/gui_modules/menuform.py:1961
#, python-format
@@ -10107,29 +9878,24 @@
msgstr "Proiezione"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:265
-#, fuzzy
msgid "Easting"
msgstr "Est"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:266
-#, fuzzy
msgid "Northing"
msgstr "Nord"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:267
-#, fuzzy
msgid "Elevation"
-msgstr "dall'elevazione"
+msgstr "Elevazione"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:268
-#, fuzzy
msgid "Surface map elevation"
-msgstr "Comando per la generazione di superfice."
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
-#, fuzzy
msgid "Surface map color"
-msgstr "Gestione colori image"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:278
msgid "XY distance from previous"
@@ -10140,19 +9906,16 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:280
-#, fuzzy
msgid "Distance along surface"
-msgstr "Distanza lungo il transetto"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:285
-#, fuzzy
msgid "Distance along exag. surface"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
-#, fuzzy
msgid "No point on surface"
-msgstr "Superficie Coste"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:297
msgid "Function not implemented yet"
@@ -10207,14 +9970,14 @@
msgstr "Vettoriale <%(name)s> (%(type)s) caricato con successo"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1072
+#, python-format
msgid "Vector point layer not found (id = %d)"
-msgstr "Vettore puntuale non trovato (id=%d)"
+msgstr "Vettoriale puntuale non trovato (id = %d)"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1074
+#, python-format
msgid "Unable to set data layer properties (id = %d)"
-msgstr "Impossibile impostare proprietà del layer (id=%d)"
+msgstr "Impossibile impostare proprietà del layer (id = %d)"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1077
#, python-format
@@ -10334,9 +10097,8 @@
msgstr "Impossibile analizzare il comando %s"
#: ../gui/wxpython/gui_modules/preferences.py:913
-#, fuzzy
msgid "User settings"
-msgstr "Impostazione dell'interfaccia grafica"
+msgstr "Impostazioni dell'utente"
#: ../gui/wxpython/gui_modules/preferences.py:933
msgid "Set to default"
@@ -10360,9 +10122,8 @@
msgstr "La chiave primaria non può essere una stringa vuota"
#: ../gui/wxpython/gui_modules/preferences.py:1058
-#, fuzzy
msgid "GUI settings"
+msgstr "Impostazioni dell'interfaccia grafica"
#: ../gui/wxpython/gui_modules/preferences.py:1082
msgid "General settings"
@@ -10577,9 +10338,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/preferences.py:2061
-#, fuzzy
msgid "Font size:"
-msgstr "Dimensione dell'icona:"
+msgstr "Dimensione del font:"
#: ../gui/wxpython/gui_modules/preferences.py:2160
msgid "Set/unset access to mapsets in current location"
@@ -10752,24 +10512,20 @@
"o la location selezionata"
#: ../gui/wxpython/gis_set.py:128
-#, fuzzy
msgid "Start &GRASS"
-msgstr "Avvia GRASS"
+msgstr "Avvia &GRASS"
#: ../gui/wxpython/gis_set.py:134
-#, fuzzy
msgid "&Browse"
-msgstr "Naviga"
+msgstr "&Naviga"
#: ../gui/wxpython/gis_set.py:136
-#, fuzzy
msgid "&Create mapset"
-msgstr "Crea mapset"
+msgstr "&Crea mapset"
#: ../gui/wxpython/gis_set.py:138
-#, fuzzy
msgid "&Location wizard"
-msgstr "Location wizard"
+msgstr "&Location wizard"
#: ../gui/wxpython/gis_set.py:140
msgid "Rename mapset"
@@ -10822,56 +10578,67 @@
"Questo mapset non può essere rinominato."
#: ../gui/wxpython/gis_set.py:444 ../gui/wxpython/gis_set.py:479
+#, python-format
msgid ""
"Current name: %s\n"
"\n"
"Enter new name:"
msgstr ""
"Nome attuale: %s\n"
-"Inserisci il nuovo nome"
+"\n"
+"Inserisci il nuovo nome:"
#: ../gui/wxpython/gis_set.py:445
msgid "Rename selected mapset"
msgstr "Rinomina il mapset selezionato"
#: ../gui/wxpython/gis_set.py:456
+#, python-format
msgid ""
"Unable to rename mapset.\n"
"\n"
"Mapset <%s> already exists in location."
msgstr ""
+"Impossibile rinominare il mapset.\n"
+"\n"
+"Il mapset <%s> esiste già nella location."
#: ../gui/wxpython/gis_set.py:468
+#, python-format
msgid ""
"\n"
"%s"
-msgstr "Impossibile rinominare il mapset"
+msgstr ""
+"\n"
+"%s"
#: ../gui/wxpython/gis_set.py:480
msgid "Rename selected location"
msgstr "Rinomina la location selezionata"
#: ../gui/wxpython/gis_set.py:491
+#, python-format
msgid ""
"Unable to rename location.\n"
"\n"
"Location <%s> already exists in GRASS database."
msgstr ""
+"Impossibile rinominare la location.\n"
+"\n"
+"La location <%s> esiste già nel database di GRASS"
#: ../gui/wxpython/gis_set.py:504
+#, python-format
msgid ""
"\n"
"%s"
-msgstr "Impossibile rinominare la location"
+msgstr ""
+"\n"
+"%s"
#: ../gui/wxpython/gis_set.py:516
msgid ""
@@ -11145,12 +10912,11 @@
msgid "Reload GCPs from selected POINTS file"
msgstr "Ricarica GCP dal file POINTS selezionato"
-#, fuzzy
msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Importa vettori Mapgen o Matlab in GRASS"
+msgstr "Importa vettoriali Mapgen o Matlab-ASCII in GRASS"
msgid "Converts a raster map into a vector map layer."
-msgstr "Converte un raster in un vettore"
+msgstr "Converte un raster in un vettoriale."
msgid "Icon size:"
@@ -11196,3 +10962,942 @@
msgid "3d view tools"
+#~ msgid "Choose script file to run"
+#~ msgstr "Scegli file script da eseguire"
+#~ msgid "Add thematic layer"
+#~ msgstr "Aggiungi layer tematico"
+#~ msgid "GRASS_PYCMDFILE - File not found. Run p.mon."
+#~ msgstr "GRASS_PYCMDFILE - File non trovato. Eseguire p.mon."
+#~ msgid "Aggregate ASCII xyz import"
+#~ msgstr "Importa ASCII xyz aggregati"
+#~ msgid "Converts ASCII raster file to binary raster map layer."
+#~ msgstr "Converte un file raster ASCII in un raster binario"
+#~ msgid "ASCII polygons and lines import"
+#~ msgstr "Importa poligoni e linee ASCII"
+#~ msgid "Binary file import"
+#~ msgstr "Importa file binario"
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Converte un file raster ESRI ARC/INFO acii (GRID) in un raster (binario)"
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importa file SPOT VGT NDVI in un raster"
+#~ msgid "Import SRTM HGT files into GRASS"
+#~ msgstr "Importa file SRTM HGT in GRASS"
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "Georeferenzia, rettifica e importa immagini Terra-ASTER e relativi DEM "
+#~ "usando gdalwarp."
+#~ msgid "Downloads and imports data from WMS servers"
+#~ msgstr "Scarica e importa dati da server WMS"
+#~ msgid "ASCII points/GRASS ASCII vector import"
+#~ msgstr "Importa vettore ASCII points/GRASS ASCII"
+#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr "Crea un vettore da file ASCI points o ASCII vector"
+#~ msgid "Historical GRASS vector import (all maps)"
+#~ msgstr "Import vecchi GRASS vector (tutte le mappe)"
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "Converte tutti i vecchi vettoriali di GRASS < Versione 5.7 nel corrente "
+#~ "mapset all'attuale formato"
+#~ msgid "WFS"
+#~ msgstr "WFS"
+#~ msgid "Import GetFeature from WFS"
+#~ msgstr "Importa GetFeature da WFS"
+#~ msgid "Garmin GPS import"
+#~ msgstr "Importa GPS Garmin"
+#~ msgid ""
+#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+#~ "vector map."
+#~ msgstr ""
+#~ "Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
+#~ msgid "GPSBabel GPS import"
+#~ msgstr "Importa GPS GPSBabel"
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+#~ "file into a vector map."
+#~ msgstr ""
+#~ "Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati "
+#~ "scaricati da un GPS in un vettore"
+#~ msgid "Matlab array and MapGen import"
+#~ msgstr "Importa array di Matlab e MapGen"
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+#~ msgid ""
+#~ "import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable "
+#~ "and 1 time step)"
+#~ msgstr ""
+#~ "Importa file Vis5D tridimensionale (es file v5d con una variabile e un "
+#~ "time step)"
+#~ msgid "Converts a raster map layer into an ASCII text file."
+#~ msgstr "Converte un raster in un file di testo ASCII"
+#~ msgid "ASCII x,y,z export"
+#~ msgstr "Esporta ASCII x,y,z"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+#~ msgstr "Esporta raster GRASS in un file GRIDATB.FOR (TOPMODEL)"
+#~ msgid "Binary export"
+#~ msgstr "Esporta binario"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programma di conversione per serie di file raster in MPEG"
+#~ msgid "Export GRASS raster as non-georeferenced PNG image."
+#~ msgstr "Esporta raster GRASS in un'immagine PNG non georeferenziata."
+#~ msgid ""
+#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
+#~ "of the currently defined region."
+#~ msgstr ""
+#~ "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel "
+#~ "della region corrente"
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del "
+#~ "pixel della region corrente"
+#~ msgid ""
+#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+#~ "resolution of the currently defined region."
+#~ msgstr ""
+#~ "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione "
+#~ "del pixel definita della region corrente"
+#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+#~ msgstr "Esporta raster in Virtual Reality Modeling Language (VRML)"
+#~ msgid "Converts raster maps into the VTK-Ascii format"
+#~ msgstr "Converte un raster in formato VTK-Ascii"
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "Converte in uno dei formati vettoriali supportati da OGR"
+#~ msgid "ASCII points/GRASS ASCII vector export"
+#~ msgstr "Esporta vettore in ASCII points/GRASS ASCII"
+#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+#~ msgstr "Converte un vettore GRASS binario in un vettore GRASS ASCII"
+#~ msgid "Exports GRASS vector map layers to DXF file format."
+#~ msgstr "Esporta vettore GRASS in un file DXF"
+#~ msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
+#~ msgstr "Converte in formato POV-Ray, GRASS x,y,z -> POV-Ray x,z,y"
+#~ msgid "Exports a GRASS vector map to SVG."
+#~ msgstr "Esporta vettore GRASS in un SVG"
+#~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
+#~ msgstr "Converte un vettore GRASS in un VTK ASCII"
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Converte un raster 3D in un file di testo ASCII"
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr "Esporta raster GRASS 3D in un file Vis5D tridimensionale"
+#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+#~ msgstr "Converte raster 3D (G3D) in formato VTK-Ascii"
+#~ msgid "Multiple export formats using OGR"
+#~ msgstr "Esporta diversi formati usando OGR"
+#~ msgid "Converts (rasterize) a vector map into a raster map."
+#~ msgstr "Converte (rasterizza) un vettoriale in un raster."
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Convert una mappa puntuale di GRASS (solo punti) in un raster 3D di GRASS."
+#~ msgid "Changes current mapset."
+#~ msgstr "Cambia il mapset corrente."
+#~ msgid "Change default GUI"
+#~ msgstr "Cambia la GUI di default"
+#~ msgid "Changes the default GRASS graphical user interface (GUI) setting."
+#~ msgstr ""
+#~ "Cambia le impostazioni dell'interfaccia grafica (GUI) di GRASS di default."
+#~ msgid "Change projection for current location"
+#~ msgstr "Cambia proiezione della location corrente"
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr ""
+#~ "Converte coordinate da una proiezione ad un'altra (interfaccia a cs2cs)."
+#~ msgid "Digitize raster (requires XTerm)"
+#~ msgstr "Digitalizza raster (richiede XTerm)"
+#~ msgid "Modifies a timestamp for a raster map."
+#~ msgstr "Modifica un timestamp di un raster"
+#~ msgid "Reproject raster map"
+#~ msgstr "Riproietta raster"
+#~ msgid "Creates/modifies the color table associated with a raster map layer."
+#~ msgstr "Crea/modifica la tabella dei colori associata a un raster"
+#~ msgid "Interactive management of raster color tables."
+#~ msgstr ""
+#~ "Modifica i valori della tabella dei colori di un raster interattivamente"
+#~ msgid ""
+#~ "Creates a raster map layer showing buffer zones surrounding cells that "
+#~ "contain non-NULL category values."
+#~ msgstr ""
+#~ "Crea un raster mostrando una zona di buffer intorno alle celle che "
+#~ "contengono valori non nulli."
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr "Crea una maschera per limitare le operazioni sui raster"
+#~ msgid "Map calculator for raster map algebra."
+#~ msgstr "Calcolatore di map algebra per i raster."
+#~ msgid "Generates a raster map layer of distance to features in input layer."
+#~ msgstr "Genera un raster della distanza dagli elementi del layer di input"
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Crea mappa di indice topografico [ln(a/tan(beta))] da una mappa "
+#~ "dell'elevatione."
+#~ msgid "Watershed basin analysis program."
+#~ msgstr "Programma per l'analisi dei bacini idrografici."
+#~ msgid "Watershed basin creation program."
+#~ msgstr "Comando per la generazione di bacini idrografici."
+#~ msgid "Reclassify"
+#~ msgstr "Riclassifica"
+#~ msgid "Recode"
+#~ msgstr "Ricodifica"
+#~ msgid "Bilinear from raster points"
+#~ msgstr "Interpolazione bilineare da punti raster"
+#~ msgid "Bilinear interpolation utility for raster map layers."
+#~ msgstr "Interpolazione bilineare da layer raster"
+#~ msgid "Surface generation program from rasterized contours."
+#~ msgstr "Comando per la generazione di superfice da contorni rasterizzati"
+#~ msgid "Digitize vector map using Tcl/Tk digitizer"
+#~ msgstr "DIgitalizza vettoriale usando il digitalizzatore Tcl/Tk"
+#~ msgid "Interactive editing and digitization of vector maps."
+#~ msgstr "Modifica e digitalizzazione interattiva di vettori."
+#~ msgid "Creates topology for GRASS vector map."
+#~ msgstr "Crea topologia per un vettore GRASS"
+#~ msgid "Rebuild topology on all vector maps"
+#~ msgstr "Ricostruisci la topologia di tutti i vettoriali"
+#~ msgid "Rebuilds topology on all vector maps in the current mapset."
+#~ msgstr ""
+#~ "Ricostruisci la topologia di tutti i vettoriali nell'attuale mapset."
+#~ msgid "Vector based generalization."
+#~ msgstr "Generalizzazione vettoriale"
+#~ msgid "Change the type of geometry elements."
+#~ msgstr "Cambia la tipologia della geometria degli elementi."
+#~ msgid "Split lines to shorter segments."
+#~ msgstr "Dividi linee a segmenti più corti."
+#~ msgid "Re-projects a vector map from one location to the current location."
+#~ msgstr "Riproietta un vettoriale da una location alla location corrente."
+#~ msgid "Queries a vector map layer at given locations."
+#~ msgstr "Interroga un vettoriale a una certa posizione."
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Crea un buffer intorno agli elementi di un dato tipo (aree devono "
+#~ "contenere centroide)."
+#~ msgid "Create a new vector map layer by combining other vector map layers."
+#~ msgstr "Crea un nuovo vettoriale contenendo altri vettoriali."
+#~ msgid "Attach, delete or report vector categories to map geometry."
+#~ msgstr ""
+#~ "Attacca, elimina o visualizza le categorie per geometrie della mappa."
+#~ msgid "Creates a GRASS vector map of a user-defined grid."
+#~ msgstr "Crea un vettoriale di una griglia definita dall'utente"
+#~ msgid "Create points along input lines in new vector with 2 layers."
+#~ msgstr ""
+#~ "Crea punti lungo una linea di input in un nuovo vettoriale con 2 layer"
+#~ msgid "Randomly generate a 2D/3D vector points map."
+#~ msgstr "Genera casualmente un mappa puntuale 2D/3D"
+#~ msgid "Random location perturbations of GRASS vector points"
+#~ msgstr "Disturbo casuale del posizionamento di punti vettoriali"
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcola statistiche univariate per un raster basandosi su poligoni "
+#~ "vettoriale e carica le statistiche in una nuova colonna della tabella "
+#~ "degli attributi."
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Riporta le statistiche delle geometrie per i vettoriali"
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Calcola statistiche univariate per gli attributi. Varianza e deviazione "
+#~ "standard è calcolate solo per punti se specificato."
+#~ msgid "Ortho photo rectification (requires Xterm)"
+#~ msgstr "Ortorettificazione (richiede Xterm)"
+#~ msgid "Map calculator for 3D raster map algebra."
+#~ msgstr "Calcolatore di map algebra per i raster 3D."
+#~ msgid "Drops an attribute table."
+#~ msgstr "Elimina una tabella degli attributi"
+#~ msgid "Selects data from table."
+#~ msgstr "Seleziona dati dalla tabella"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "Visualizza la pagina di supporto HTML di GRASS "
+#~ msgid "Enter raster category values or percents"
+#~ msgstr "Inserisci valore o percentuale nella categoria del raster"
+#~ msgid "Save color table to file"
+#~ msgstr "Salva tabella dei colori in un file"
+#~ msgid ""
+#~ "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+#~ msgstr ""
+#~ "Inserisci valore o percentuale nella categoria del raster (%(range)s = %"
+#~ "(min)d-%(max)d)"
+#~ msgid "Nothing to save."
+#~ msgstr "Niente da salvare."
+#~ msgid ""
+#~ "Color table already exists. Check out 'replace existing color table' to "
+#~ "overwrite it."
+#~ msgstr ""
+#~ "Tabella dei colori esiste già. Segna 'sovrascrivi la tabella dei colori "
+#~ "esistente' per sovrascriverla."
+#~ msgid "Save expression to file"
+#~ msgstr "Salva espressione in un file"
+#~ msgid "Load expression from file"
+#~ msgstr "Carica espressione dal file"
+#~ msgid "Add created raster map into layer tree"
+#~ msgstr "Aggiungi la raster creata nel layer tree"
+#~ msgid "Choose a file name to save the expression"
+#~ msgstr "Scegli un nome per salvara l'espressione"
+#~ msgid "Expression file (*)|*"
+#~ msgstr "File espressione (*)|*"
+#~ msgid "Choose a file name to load the expression"
+#~ msgstr "Scegliere il nome di un file per caricare l'espressione"
+#~ msgid ""
+#~ "Set %(coor)s coordinates for GCP No. %(key)s? \n"
+#~ "\n"
+#~ "East: %(coor0)s \n"
+#~ "North: %(coor1)s"
+#~ msgstr ""
+#~ "Impostare le coordinate %(coor)s per GCP No. %(key)s? \n"
+#~ "\n"
+#~ "Est: %(coor0)s \n"
+#~ "Nord:%(coor1)s"
+#~ msgid "Rectifying images, please wait..."
+#~ msgstr "Rettifica immagine, attendere..."
+#~ msgid "Zoom to computational region"
+#~ msgstr "Zoom alla region computazionale (impostata con g.region)"
+#~ msgid "Choose GIS Data Directory"
+#~ msgstr "Selezionare cartella del database GIS"
+#~ msgid ""
+#~ "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
+#~ msgstr ""
+#~ "Il modulo r.mapcalc non può essere usato nel modello. Usare invece r."
+#~ "mapcalculator."
+#~ msgid "<not defined>"
+#~ msgstr "<non definito>"
+#~ msgid ""
+#~ "Please note that the data are left in inconsistent state and may be "
+#~ "corrupted"
+#~ msgstr ""
+#~ "Attenzione notare che i dati sono inconistenti e possono essere corrotti"
+#~ msgid "Show Help"
+#~ msgstr "Mostra Aiuto"
+#~ msgid "Rebuild topology"
+#~ msgstr "Ricrea topologia"
+#~ msgid "Unable to initialize display driver of vector digitizer"
+#~ msgstr "Impossibile avviare il monitor per il digitalizzatore di vettori"
+#~ msgid "thematic map"
+#~ msgstr "mappa tematica"
+#~ msgid "opacity:"
+#~ msgstr "opacità:"
+#~ msgid "Uknown settings file location."
+#~ msgstr "Posizione del file delle impostazioni sconosciuta"
+#~ msgid "Unable to parse settings '%s'"
+#~ msgstr "Impossibile analizzare le impostazioni '%s'"
+#~ msgid "Allow interactive input"
+#~ msgstr "Permetti input interattivo"
+#~ msgid "Overlay raster maps"
+#~ msgstr "Overlay mappe raster"
+#~ msgid "Place where to store settings:"
+#~ msgstr "Inserisci dove mantenere le impostazioni:"
+#~ msgid "Manage access to mapsets"
+#~ msgstr "Gestisci l'accesso ai mapset"
+#~ msgid ""
+#~ "Check a mapset to make it accessible, uncheck it to hide it.\n"
+#~ " Notes:\n"
+#~ " - The current mapset is always accessible.\n"
+#~ " - You may only write to the current mapset.\n"
+#~ " - You may only write to mapsets which you own."
+#~ msgstr ""
+#~ "Marca mapset per renderlo accessibile, demarca per nasconderlo.\n"
+#~ " Note:\n"
+#~ " - L'attuale mapset è sempre accessibile.\n"
+#~ " - Puoi scrivere solo nel mapset corrente.\n"
+#~ " - Puoi scrivere solo nei tuoi mapset."
+#~ msgid "Bash script (*.sh)|*.sh|Python script (*.py)|*.py"
+#~ msgstr "Bash script (*.sh)|*.sh|Python script (*.py)|*.py"
+#~ msgid "Import GDAL supported raster file into a binary raster map layer."
+#~ msgstr "Importa file raster supportato da GDAL in un layer raster binario"
+#, fuzzy
+#~ msgid "Link GDAL supported raster file to a binary raster map layer."
+#~ msgid "Convert OGR vector layers to GRASS vector map."
+#~ msgstr "Converte vettore OGR in vettore GRASS"
+#~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
+#~ msgstr "Converte i layer OGR selezionati in vettori GRASS usando v.in.ogr"
+#~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr "Crea nuovo vettore come link in sola lettura a un layer OGR"
+#~ msgid "Old GRASS vector import"
+#~ msgstr "Import vecchi GRASS vector"
+#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+#~ msgstr "Converte vettore binario GRASS in raster GRASS"
+#, fuzzy
+#~ msgid "Generates stream channels."
+#~ msgstr "Genera celle random"
+#~ msgid "Map layers for each display"
+#~ msgstr "Layers per ogni display"
+#~ msgid "Unable to read workspace file"
+#~ msgstr "Impossibile leggere il file dell'ambiente di lavoro"
+#~ msgid "Unable to open workspace file <%s> for writing."
+#~ msgstr ""
+#~ "Impossibile aprire il file dell'ambiente di lavoro <%s> per scriverci."
+#, fuzzy
+#~ msgid "GRASS GIS Raster Map Calculator (3D raster)"
+#~ msgstr "GRASS %s Map Calculator"
+#~ msgid "Add various vector-based map layer"
+#~ msgstr "Aggiungi diversi layer vettoriali"
+#~ msgid "COPYING file missing"
+#~ msgstr "File COPYING mancante"
+#~ msgid "GPL.TXT file missing"
+#~ msgstr "File GPL.TXT mancante"
+#~ msgid "AUTHORS file missing"
+#~ msgstr "File AUTHORS mancante"
+#~ msgid "Create new workspace file"
+#~ msgstr "Crea nuovo ambiente di lavoro"
+#~ msgid "Load map layers into workspace"
+#~ msgstr "Carica layers nell'ambiente di lavoro"
+#~ msgid "Open existing workspace file"
+#~ msgstr "Apri file workspace"
+#~ msgid "Save current workspace to file"
+#~ msgstr "Salva il corrente ambiente di lavoro in un file"
+#~ msgid "Add vector map layer"
+#~ msgstr "Aggiunge un layer vettoriale"
+#~ msgid "Add 3D raster map"
+#~ msgstr "Aggiungi mappa raster 3D"
+#~ msgid "Redraw GCP markers in map displays"
+#~ msgstr "Aggiorna i punti GCP nel display"
+#~ msgid "Save workspace to open file"
+#~ msgstr "Salva l'area di lavoro in un file"
+#~ msgid "Close loaded workspace"
+#~ msgstr "Chiudi l'area di lavoro caricata"
+#, fuzzy
+#~ msgid "Matlab-ASCII or Mapgen import"
+#~ msgstr "Importa array Matlab o formato MapGen"
+#~ msgid "E&xit"
+#~ msgstr "E&sci"
+#~ msgid "Config"
+#~ msgstr "Configurazione"
+#~ msgid "Display shortest route (requires XTerm)"
+#~ msgstr "Visualizza il percorso più breve (richiede XTerm)"
+#, fuzzy
+#~ msgid "Find shortest path for selected starting and ending node"
+#~ msgstr ""
+#~ "Trova il percorso più breve per i nodi di partenza ed arrivo selezionati"
+#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
+#~ msgstr ""
+#~ "Usa un vettoriale di punti per produrre un vettoriale di poligoni "
+#~ "convessi."
+#~ msgid "Imagery"
+#~ msgstr "Immagini"
+#~ msgid "GRASS GIS GUI help"
+#~ msgstr "Aiuto GRASS GIS GUI "
+#~ msgid "Set ground control points (GCPs)"
+#~ msgstr "Imposta punti di controllo sul terreno (GCPs)"
+#~ msgid "Quit wxGUI. GRASS is not running."
+#~ msgstr "Esci da wxGUI. GRASS non è in esecuzione."
+#~ msgid "wxGUI closed."
+#~ msgstr "chiude wxGUI"
+#~ msgid "Error in command execution %s"
+#~ msgstr "Errore nell'esecuzione del comando %s"
+#~ msgid "Preferences error"
+#~ msgstr "Errore nelle preferenze"
+#~ msgid "Attribute table manager error"
+#~ msgstr "Errore nel manager degli attributi della tabella"
+#~ msgid "Nviz error"
+#~ msgstr "Errore di NVIZ"
+#~ msgid "Map calculator"
+#~ msgstr "Calcolatore Mappa"
+#, fuzzy
+#~ msgid "3D View Tools"
+#~ msgstr "Strumenti visualizzazione 3D"
+#~ msgid "width:"
+#~ msgstr "larghezza:"
+#~ msgid "symbol:"
+#~ msgstr "simbolo:"
+#~ msgid "color:"
+#~ msgstr "colore:"
+#~ msgid "Default"
+#~ msgstr "Default"
+#~ msgid "Restore default settings"
+#~ msgstr "Rimposta le impostazioni di default"
+#, fuzzy
+#~ msgid "Unable to read EPGS file: '%s'"
+#~ msgstr "Impossibile leggere i codici EPSG: %s"
+#~ msgid "Resolution cannot be 0"
+#~ msgstr "La risoluzione non può essere 0"
+#~ msgid "Extents set incorrectly"
+#~ msgstr "Estensione impostata non correttamente"
+#~ msgid "Load"
+#~ msgstr "Carica"
+#~ msgid "DXF file:"
+#~ msgstr "File DXF:"
+#~ msgid "Close this window without executing the command"
+#~ msgstr "Chiudi questa finestra senza eseguire il comando"
+#~ msgid "Show manual page of the command"
+#~ msgstr "Mostra la pagine del manuale del comando"
+#~ msgid "Run the command"
+#~ msgstr "Esegui il commando"
+#~ msgid "Input DXF file"
+#~ msgstr "File DXF di input"
+#~ msgid "Input directory"
+#~ msgstr "Cartella di input"
+#~ msgid "Choose DXF file:"
+#~ msgstr "Scegli file DXF:"
+#~ msgid "Choose directory:"
+#~ msgstr "Scegli cartella:"
+#~ msgid ""
+#~ "File <%(file)s>: Unable to get list of DXF layers.\n"
+#~ "\n"
+#~ "%(details)s"
+#~ msgstr ""
+#~ "File <%(file)s>: Impossibile ottenere la lista dei layer DXF.\n"
+#~ "\n"
+#~ "%(details)s"
+#~ msgid "GRASS %s Map Calculator"
+#~ msgid "Create & manage ground control points"
+#~ msgstr "Crea & gestisci punti di controllo sul terreno"
+#~ msgid ""
+#~ "Unable to determine default DB connection settings. Please define DB "
+#~ "connection using db.connect module."
+#~ msgstr ""
+#~ "Impossibile determinare le impostazioni della connessione del DB. Per "
+#~ "favore definire la connessione al DB usando il modulo db.connect"
+#~ msgid "Height"
+#~ msgstr "Altezza"
+#~ msgid "(step):"
+#~ msgstr "(step):"
+#~ msgid "Import raster map"
+#~ msgstr "Importa mappe raster"
+#~ msgid "Import raster data using GDAL"
+#~ msgstr "Importa mappa raster usando GDAL"
+#~ msgid "Multiple raster data import using GDAL"
+#~ msgstr "Importa più raster usando GDAL"
+#~ msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal"
+#~ msgstr ""
+#~ "Converti i layer GDAL selezionati in una mappa raster GRASS usando r.in."
+#~ "gdal"
+#~ msgid "Link to GDAL"
+#~ msgstr "Collega a GDAL"
+#~ msgid "Import vector map"
+#~ msgstr "Importa mappa vettoriale"
+#~ msgid "Import vector data using OGR"
+#~ msgstr "Importa mappa vettoriale usando OGR"
+#~ msgid "Multiple vector data import using OGR"
+#~ msgstr "Importa diversi dati vettoriali usando OGR"
+#~ msgid "Creates a new vectors as a read-only link to OGR layers"
+#~ msgid "Multiple DXF layers import"
+#~ msgstr "Importa diversi layer DXF"
+#~ msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)"
+#~ msgstr ""
+#~ "Converte i layer DXF selezionati in mappe vettoriali GRASS (usando v.in."
+#~ "dxf)"
+#~ msgid "Import grid 3D volume"
+#~ msgstr "Importa volumi grid3D"
+#~ msgid "Multiple export formats using GDAL"
+#~ msgstr "Esporta diversi formati usando GDAL"
+#~ msgid "Export grid 3D volume"
+#~ msgstr "Esporta volume grid 3D"
+#~ msgid "Map calculator for volumetric map algebra"
+#~ msgstr "Map calculator per map algebra sui volumi"
+#~ msgid ""
+#~ "Creates and adds a new attribute table to a given layer of an existing "
+#~ "vector map."
+#~ msgstr ""
+#~ "Crea e aggiunge una nuova tabella degli attributi per un certo layer di "
+#~ "una mappa vettoriale esistente"
+#~ msgid ""
+#~ "Current name: %s\n"
+#~ "Enter new name:"
+#~ msgstr ""
+#~ "Nome attuale: %s\n"
+#~ "Inserisci il nuovo nome"
+#~ msgid "Unable to rename mapset"
+#~ msgstr "Impossibile rinominare il mapset"
+#~ msgid "Unable to rename location"
+#~ msgstr "Impossibile rinominare la location"
+#~ msgid "Import GDAL layers"
+#~ msgstr "Importa layers GDAL"
+#~ msgid "Link GDAL layers"
+#~ msgstr "Collegati a layers GDAL"
+#~ msgid "Import OGR layers"
+#~ msgstr "Importa layers OGR"
+#~ msgid "Link OGR layers"
+#~ msgstr "Collegati a layers OGR"
+#~ msgid "Command %s could not be run"
+#~ msgstr "Comando %s non ancora implementato"
+#~ msgid "Command '%s' not yet implemented."
+#~ msgid "&Close"
+#~ msgstr "Chiudi"
+#~ msgid "&Stop"
+#~ msgstr "C&opia"
+#~ msgid "C&opy"
+#~ msgstr "C&opia"
+#~ msgid "Native"
+#~ msgstr "Nativo"
+#~ msgid "OGR"
+#~ msgstr "OGR"
+#~ msgid "Choose OGR data source"
+#~ msgstr "Scegli sorgente dei dati OGR"
+#~ msgid "Name of OGR data source:"
+#~ msgstr "Nome della sorgente dei dati OGR:"
+#~ msgid "Error in command execution '%s'"
+#~ msgstr "Errore nell'esecuzione del comando '%s'"
+#~ msgid "label"
+#~ msgstr "etichetta"
+#~ msgid "help"
+#~ msgstr "aiuto"
+#~ msgid "Run"
+#~ msgstr "Esegui"
+#~ msgid "Saved NVIZ Settings"
+#~ msgstr "Salva impostazioni NVIZ"
+#~ msgid "Load and apply settings from user settings file"
+#~ msgstr ""
+#~ "Carica e applica le impostazioni da un file delle impostazione dell'utente"
+#~ msgid "Link to external raster map"
+#~ msgstr "Collega a raster esterno"
+#~ msgid "Link to external vector map"
+#~ msgstr "Collega a un vettore esterno"
+#~ msgid "Export a GRASS raster map as non-georeferenced PNG image format."
+#~ msgid "C&onfig"
+#~ msgstr "C&onfigurazione"
+#~ msgid "Change the type of geometry elements"
+#~ msgstr "Cambia la tipologia della geometrie degli elementi"
+#~ msgid "Show menu tree in new window"
+#~ msgstr "Mostra il menu tree in una nuova finestra"
+#~ msgid ""
+#~ "Reading workspace file <%(file)s> failed.\n"
+#~ "Invalid file, unable to parse XML document.\n"
+#~ "\n"
+#~ "%(err)s"
+#~ msgstr ""
+#~ "Letture del file d'ambiente di lavoro <%(file)s> fallito.\n"
+#~ "File invalido, impossibile fare il parse del documento XML.\n"
+#~ "\n"
+#~ "%(err)s"
+#~ msgid "WARNING: Unable to quit GRASS, uknown GIS_LOCK"
+#~ msgstr "Attenzione: impossibile uscira da GRASS, GIS_LOCK sconosciuto"
+#~ msgid " (those in bold typeface are required)"
+#~ msgstr " (quelli in grassetto sono richiesti)"
+#~ msgid "Cmd >"
+#~ msgstr "Cmd >"
+#~ msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal."
+#~ msgstr ""
+#~ "gdal"
+#~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr."
+#~ msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)."
+#~ msgstr "Converte i layer DXF selezionati in vettori GRASS (usando v.in.dxf)"
+#~ msgid ""
+#~ "Change current location and mapset (note that current workspace will be "
+#~ "closed)."
+#~ msgstr ""
+#~ "Cambia location e mapset correnti (nota che l'ambiente di lavoro corrente "
+#~ "sarà chiuso)"
+#~ msgid "Query by coordinates"
+#~ msgstr "Interroga utilizzando coordinate"
+#~ msgid "Univariate attribute statistics"
+#~ msgstr "Statistiche univariate attributi"
+#~ msgid "Click here to show database connection information"
+#~ msgstr ""
+#~ "Clicca qui per mostrare le informazione della connessione del database"
+#~ msgid "Click here to hide database connection information"
+#~ msgstr ""
+#~ "Clicca qui per nascondere le informazione della connessione del database"
+#~ msgid "Use coordinate system of selected georeferenced file"
+#~ msgstr "Usa il sistema di coordinate del file georeferenziato selezionato"
+#~ msgid "Use coordinate system of selected WKT or PRJ file"
+#~ msgstr "Usa il sistema di coordinate del file WKT o file PRJ"
+#~ msgid "Select ellipsoid"
+#~ msgstr "Seleziona elissoide"
+#~ msgid "Set zone for UTM projection:"
+#~ msgstr "Imposta la zona per la proiezione UTM:"
+#~ msgid "Zone:"
+#~ msgstr "Zona:"
+#~ msgid "Hemisphere for zone:"
+#~ msgstr "Emisfero per la zona:"
+#~ msgid "Datum"
+#~ msgstr "Datum"
+#~ msgid "Transformation parameters:"
+#~ msgstr "Parametri di trasformazione:"
+#~ msgid "Browse EPSG Codes"
+#~ msgstr "Naviga i codici EPSG"
+#~ msgid "Datums:"
+#~ msgstr "Datum:"
+#~ msgid "Vector map <%s> georectified successfully"
+#~ msgstr "Vettoriale <%s> georettificato correttamente"
+#~ msgid "Copying attributes..."
+#~ msgstr "Copia attributi..."
+#~ msgid "Output vector map name"
+#~ msgstr "Nome del vettoriale di output"
+#~ msgid "Reclassify vector objects interactively by entering SQL rules"
+#~ msgstr "Riclassifica vettoriale interattivamente inserendo regole SQL"
+#~ msgid "GRASS GIS Layer Manager (Experimental Prototype)"
+#~ msgstr "GRASS GIS Manager dei layer (Prototipo esperimentale)"
+#~ msgid "Digitize raster map"
+#~ msgstr "Digitalizza raster"
+#~ msgid "Ortho Photo rectification"
+#~ msgstr "Rettificazione ortofoto"
