[GRASS-SVN] r44564 - grass-addons/postscript/ps.output
svn_grass at osgeo.org
Wed Dec 8 17:53:50 EST 2010
Author: hamish
Date: 2010-12-08 14:53:50 -0800 (Wed, 08 Dec 2010)
New Revision: 44564
grass-addons/postscript/ps.output/local_proto.h
grass-addons/postscript/ps.output/ps3_map.c
grass-addons/postscript/ps.output/set_draw.c
grass-addons/postscript/ps.output/set_ps.c
grass-addons/postscript/ps.output/set_vpoints.c
fix a number of function prototype and usage errors so it compliles with gcc -Werror-implicit-function-declaration
Modified: grass-addons/postscript/ps.output/local_proto.h
--- grass-addons/postscript/ps.output/local_proto.h 2010-12-08 09:04:52 UTC (rev 44563)
+++ grass-addons/postscript/ps.output/local_proto.h 2010-12-08 22:53:50 UTC (rev 44564)
@@ -14,7 +14,7 @@
#define DEF_FONT "Helvetica"
/* cat_val.c */
-#ifdef DBMIN_H
+#ifdef GRASS_DBMI_H
int load_catval_array(VECTOR *, const char *, dbCatValArray *);
void get_number(dbCatValArray *, int, double *);
char *get_string(dbCatValArray *, int, int);
@@ -70,7 +70,7 @@
int error(char *, char *, char *);
/* legends.c */
-#ifdef _LEGENG_H_
+#ifdef _LEGEND_H_
void set_legend_adjust(LEGEND *, double);
#endif
@@ -86,6 +86,16 @@
int load_cell(int, char *);
int load_rgb(char *, char *, char *);
+/* palettes.c */
+#ifdef _PSCOLOR_H_
+int analogous(char *, PSCOLOR *, int, double);
+int complementary(char *, PSCOLOR *, int, double);
+int diverging(char *, PSCOLOR *, PSCOLOR *, int);
+int gradient(char *, PSCOLOR *, PSCOLOR *, int, int);
+int PS_str_to_color(char *, PSCOLOR *);
+#endif
+int pure_color(char *, int);
/* paper.c */
int set_paper(char *);
@@ -119,7 +129,7 @@
#endif
/* r_grid.c */
-#ifdef _GRID_H_
+#ifdef _PSGRID_H_
int read_grid(GRID *, int);
#endif
@@ -135,6 +145,12 @@
/* r_note.c */
int read_note(char *);
+/* r_palette.c */
+#ifdef _PSCOLOR_H_
+int monochrome(char *, PSCOLOR *, int);
+#endif
+int read_palette(void);
/* r_paper.c */
int read_paper(char *);
@@ -144,9 +160,15 @@
/* r_rlegend.c */
int read_rlegend(char *);
+/* r_scalebar.c */
+int read_scalebar(void);
/* r_vareas.c */
int r_vareas(char *);
+/* read_vareas.c */
+int read_vareas(char *);
/* r_vlabels.c */
int read_vlabels(char *);
@@ -156,9 +178,15 @@
/* r_vlines.c */
int r_vlines(char *);
+/* reqad_vlines.c */
+int read_vlines(char *);
/* r_vpoints.c */
int r_vpoints(char *);
+/* read_vpoints.c */
+int read_vpoints(char *);
/* raster.c */
int raster_close(void);
@@ -178,6 +206,7 @@
/* set_draw.c */
int set_draw(char *, char *);
+int set_on_paper(char *, char *, char *, char *);
/* set_geogrid.c */
int set_lines_geogrid(void);
@@ -213,6 +242,9 @@
int note_int_file(char *);
int set_note(int);
+/* set_outline.c */
+int set_outline(void);
/* set_ps.c */
void set_ps_rect(double, double, double, double);
void set_ps_brd(double);
@@ -276,8 +308,10 @@
/* symbol.c */
#if defined GRASS_SYMB_H
int draw_chain(SYMBCHAIN *, double);
+#ifdef _VPOINTS_H_
int symbol_save(int, VPOINTS *, SYMBOL *);
#endif
+#endif
/* val_list.c */
#ifdef GRASS_GIS_H
Modified: grass-addons/postscript/ps.output/ps3_map.c
--- grass-addons/postscript/ps.output/ps3_map.c 2010-12-08 09:04:52 UTC (rev 44563)
+++ grass-addons/postscript/ps.output/ps3_map.c 2010-12-08 22:53:50 UTC (rev 44564)
@@ -50,7 +50,8 @@
" currentdict F0 known {pop pop}\n"
" {findfont dup length dict begin {1 index /FID ne {def} {pop pop} ifelse } forall\n"
" /Encoding ISOLatin1Encoding def\n"
- " /FontName 0 index def\n" " currentdict end definefont pop} ifelse} D\n");
+ " /FontName 0 index def\n"
+ " currentdict end definefont pop} ifelse} D\n");
fprintf(PS.fp, "/FS {/FS0 exch def F0 findfont FS0 scalefont setfont} D\n");
fprintf(PS.fp, "/FE {F0 findfont 3 1 roll 1 index dup /FS0 exch def mul 0 0 4 -1 roll 0 0 6 packedarray makefont setfont} D\n");
fprintf(PS.fp, "/FA {currentfont [1 0 0 1.25 0 0] makefont setfont} D\n");
@@ -197,7 +198,7 @@
/* CLIPED CUSTOM DRAWS */
if (PS.n_draws > 0)
- /* fprintf(PS.fp, "0 0 0 C "); /* default color */
+ /* fprintf(PS.fp, "0 0 0 C "); // default color */
for (i = 0; i < PS.n_draws; i++)
if (PS.draw.flag[i] == 0)
@@ -222,7 +223,7 @@
/* CLIPED CUSTOM DRAWS ONTO ALL MAP ITEMS */
if (PS.n_draws > 0)
if (PS.draw.flag[i] == 3)
Modified: grass-addons/postscript/ps.output/set_draw.c
--- grass-addons/postscript/ps.output/set_draw.c 2010-12-08 09:04:52 UTC (rev 44563)
+++ grass-addons/postscript/ps.output/set_draw.c 2010-12-08 22:53:50 UTC (rev 44564)
@@ -301,7 +301,7 @@
int dg, mn;
double conv, sec;
- if (sscanf(data, "%lf %lf %lf %lf", east, north, &d, &conv) != 4)
+ if (sscanf(data, "%lf %lf %lf %lf", &east, &north, &d, &conv) != 4)
error(key, data, "compass: x, y, radius and magnetic declination");
Modified: grass-addons/postscript/ps.output/set_ps.c
--- grass-addons/postscript/ps.output/set_ps.c 2010-12-08 09:04:52 UTC (rev 44563)
+++ grass-addons/postscript/ps.output/set_ps.c 2010-12-08 22:53:50 UTC (rev 44564)
@@ -12,9 +12,9 @@
#include "vareas.h"
#include "vpoints.h"
#include "ps_info.h"
+#include "local_proto.h"
void set_ps_rect(double x, double y, double w, double h)
fprintf(PS.fp, "%.3f %.3f %.3f %.3f RO\n", x, y, w, h);
@@ -109,7 +109,7 @@
if (llx == 0. && lly == 0. && urx == 0. && ury == 0.)
fclose(fp);
- error("ERROR:", "", "Bounding box in <%s> was not found\n", eps);
+ error(eps, "", "ERROR: Bounding box in <%s> was not found");
llx *= va->sc_pat;
Modified: grass-addons/postscript/ps.output/set_vpoints.c
--- grass-addons/postscript/ps.output/set_vpoints.c 2010-12-08 09:04:52 UTC (rev 44563)
+++ grass-addons/postscript/ps.output/set_vpoints.c 2010-12-08 22:53:50 UTC (rev 44564)
@@ -114,7 +114,7 @@
else
- rotate = get_number(&rotcv, cat);
+ get_number(&rotcv, cat, &rotate);
if (rotate > 0.)
fprintf(PS.fp, "%.3f ROT ", rotate);
@@ -183,7 +183,7 @@
else
- size = get_number(&cv_size, cat);
+ get_number(&cv_size, cat, &size);
size *= vp->scale;
if (size > 0.)
@@ -195,7 +195,7 @@
else
- rotate = get_number(&cv_rot, cat);
+ get_number(&cv_rot, cat, &rotate);
if (rotate > 0.)
