[GRASS-SVN] r44565 - grass-addons/postscript/ps.output
Wed Dec 8 18:19:08 EST 2010
Author: hamish
Date: 2010-12-08 15:19:08 -0800 (Wed, 08 Dec 2010)
New Revision: 44565
   grass-addons/postscript/ps.output/cat_val.c
   grass-addons/postscript/ps.output/colors.c
   grass-addons/postscript/ps.output/eps.c
   grass-addons/postscript/ps.output/fonts.c
   grass-addons/postscript/ps.output/format.c
   grass-addons/postscript/ps.output/frames.c
   grass-addons/postscript/ps.output/input.c
   grass-addons/postscript/ps.output/legends.c
   grass-addons/postscript/ps.output/load_raster.c
   grass-addons/postscript/ps.output/local_proto.h
   grass-addons/postscript/ps.output/main.c
   grass-addons/postscript/ps.output/palettes.c
   grass-addons/postscript/ps.output/palettes.h
   grass-addons/postscript/ps.output/papers.c
   grass-addons/postscript/ps.output/proj_geo.c
   grass-addons/postscript/ps.output/ps3_map.c
   grass-addons/postscript/ps.output/ps_info.h
   grass-addons/postscript/ps.output/r_block.c
   grass-addons/postscript/ps.output/r_draw.c
   grass-addons/postscript/ps.output/r_font.c
   grass-addons/postscript/ps.output/r_frame.c
   grass-addons/postscript/ps.output/r_grid.c
   grass-addons/postscript/ps.output/r_line.c
   grass-addons/postscript/ps.output/r_maparea.c
   grass-addons/postscript/ps.output/r_note.c
   grass-addons/postscript/ps.output/r_palette.c
   grass-addons/postscript/ps.output/r_paper.c
   grass-addons/postscript/ps.output/r_raster.c
   grass-addons/postscript/ps.output/r_rlegend.c
   grass-addons/postscript/ps.output/r_scalebar.c
   grass-addons/postscript/ps.output/r_vareas.c
   grass-addons/postscript/ps.output/r_vlabels.c
   grass-addons/postscript/ps.output/r_vlegend.c
   grass-addons/postscript/ps.output/r_vlines.c
   grass-addons/postscript/ps.output/r_vpoints.c
   grass-addons/postscript/ps.output/raster.c
   grass-addons/postscript/ps.output/scanners.c
   grass-addons/postscript/ps.output/set_draw.c
   grass-addons/postscript/ps.output/set_geogrid.c
   grass-addons/postscript/ps.output/set_grid.c
   grass-addons/postscript/ps.output/set_mask.c
   grass-addons/postscript/ps.output/set_note.c
   grass-addons/postscript/ps.output/set_outline.c
   grass-addons/postscript/ps.output/set_ps.c
   grass-addons/postscript/ps.output/set_raster.c
   grass-addons/postscript/ps.output/set_rlegend.c
   grass-addons/postscript/ps.output/set_scalebar.c
   grass-addons/postscript/ps.output/set_vareas.c
   grass-addons/postscript/ps.output/set_vector.c
   grass-addons/postscript/ps.output/set_vlabels.c
   grass-addons/postscript/ps.output/set_vlegend.c
   grass-addons/postscript/ps.output/set_vlines.c
   grass-addons/postscript/ps.output/set_vpoints.c
   grass-addons/postscript/ps.output/start_map.c
   grass-addons/postscript/ps.output/symbol.c
   grass-addons/postscript/ps.output/val_list.c
   grass-addons/postscript/ps.output/vector.c
   grass-addons/postscript/ps.output/vpoints.h
run tools/grass_indent.sh
Modified: grass-addons/postscript/ps.output/cat_val.c
--- grass-addons/postscript/ps.output/cat_val.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/cat_val.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -16,25 +16,30 @@
 static char catval_str[128];
 /* LOAD CAT_VAL */
-int load_catval_array(VECTOR * vector, const char *colname, dbCatValArray * cvarr)
+int load_catval_array(VECTOR * vector, const char *colname,
+		      dbCatValArray * cvarr)
     int n_records;
     struct field_info *Fi;
     dbDriver *driver;
     db_CatValArray_init(cvarr);
     Fi = Vect_get_field(&(vector->Map), vector->layer);
-    if (Fi == NULL)
+    if (Fi == NULL) {
 	G_fatal_error(_("Unable to get layer info for vector map"));
     driver = db_start_driver_open_database(Fi->driver, Fi->database);
     if (driver == NULL)
-	G_fatal_error(_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      Fi->database, Fi->driver);
-    n_records = db_select_CatValArray(driver, Fi->table, Fi->key, colname, NULL, cvarr);
+    n_records =
+	db_select_CatValArray(driver, Fi->table, Fi->key, colname, NULL,
+			      cvarr);
     if (n_records < 0)
 	G_fatal_error(_("Unable to select data from table"));
@@ -51,33 +56,28 @@
 void get_number(dbCatValArray * cvarr, int cat, double *d)
     int ret, int_val;
     dbCatVal *cv = NULL;
     *d = -1.;
-    if (cvarr->ctype == DB_C_TYPE_INT)
+    if (cvarr->ctype == DB_C_TYPE_INT) {
 	ret = db_CatValArray_get_value_int(cvarr, cat, &int_val);
-	if (ret != DB_OK)
+	if (ret != DB_OK) {
 	    G_warning(_("No record for category [%d]"), cat);
 	else
 	    *d = (double)int_val;
-    else if (cvarr->ctype == DB_C_TYPE_DOUBLE)
+    else if (cvarr->ctype == DB_C_TYPE_DOUBLE) {
 	ret = db_CatValArray_get_value_double(cvarr, cat, d);
-	if (ret != DB_OK)
-    else if (cvarr->ctype == DB_C_TYPE_STRING)
+    else if (cvarr->ctype == DB_C_TYPE_STRING) {
 	ret = db_CatValArray_get_value(cvarr, cat, &cv);
-	if (ret != DB_OK)
 	else
@@ -89,42 +89,37 @@
 char *get_string(dbCatValArray * cvarr, int cat, int dec)
     int ret, int_val;
     double double_val;
     char buf[10], *str = NULL;
-    if (cvarr->ctype == DB_C_TYPE_STRING)
+    if (cvarr->ctype == DB_C_TYPE_STRING) {
-	if (ret != DB_OK)
 	else
 	    str = db_get_string(cv->val.s);
-    else if (cvarr->ctype == DB_C_TYPE_INT)
+    else if (cvarr->ctype == DB_C_TYPE_INT) {
-	if (ret != DB_OK)
-	else
+	else {
 	    sprintf(catval_str, "%d", int_val);
 	    str = catval_str;
 	ret = db_CatValArray_get_value_double(cvarr, cat, &double_val);
-	if (ret != DB_OK)
-	else
+	else {
 	    sprintf(buf, "%%0.%df", dec);
 	    sprintf(catval_str, buf, double_val);
 	    str = catval_str;
Modified: grass-addons/postscript/ps.output/colors.c
--- grass-addons/postscript/ps.output/colors.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/colors.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -26,21 +26,18 @@
     int R, G, B;
-    if (*name == 0 || strcmp(name, "none") == 0)
-        unset_color(color);
-        return 1;
+    if (*name == 0 || strcmp(name, "none") == 0) {
+	unset_color(color);
+	return 1;
     /* standard GRASS colors */
-    if (G_str_to_color(name, &R, &G, &B) == 1)
-        set_color_rgb(color, R, G, B);
-        return 1;
+    if (G_str_to_color(name, &R, &G, &B) == 1) {
+	set_color_rgb(color, R, G, B);
+	return 1;
     /* PS3 palette colors */
-    if (PS_str_to_color(name, color) == 1)
-        return 1;
+    if (PS_str_to_color(name, color) == 1) {
+	return 1;
     unset_color(color);
     return 0;
@@ -91,8 +88,7 @@
 int set_ps_color(PSCOLOR * color)
-    if (!color->none)
+    if (!color->none) {
 	fprintf(PS.fp, "%.3f %.3f %.3f C ", color->r, color->g, color->b);
 	if ((PS.flag & 1) && color->a > 0.)
@@ -103,8 +99,7 @@
 int set_ps_grey(PSCOLOR * color)
-    if (!color->none)
 	fprintf(PS.fp, "%.3f %.3f %.3f CG ", color->r, color->g, color->b);
Modified: grass-addons/postscript/ps.output/eps.c
--- grass-addons/postscript/ps.output/eps.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/eps.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -18,28 +18,28 @@
 int eps_bbox(char *eps, double *llx, double *lly, double *urx, double *ury)
     char buf[201];
     FILE *fp;
     int v1, v2, v3, v4;
     /* test if file is realy eps and find bbox */
-    if ((fp = fopen(eps, "r")) == NULL)
+    if ((fp = fopen(eps, "r")) == NULL) {
 	fprintf(stderr, "can't open eps file <%s>\n", eps);
 	return (0);
     /* test if first row contains '%!PS-Adobe-m.n EPSF-m.n' string */
     fgets(buf, 200, fp);
-    if (sscanf(buf, "%%!PS-Adobe-%d.%d EPSF-%d.%d", &v1, &v2, &v3, &v4) < 4)
+    if (sscanf(buf, "%%!PS-Adobe-%d.%d EPSF-%d.%d", &v1, &v2, &v3, &v4) < 4) {
 	fprintf(stderr, "file <%s> is not in EPS format\n", eps);
 	fclose(fp);
 	return (0);
     /* looking for bbox */
-    while (fgets(buf, 200, fp) != NULL)
-	if (sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf", llx, lly, urx, ury) == 4)
+    while (fgets(buf, 200, fp) != NULL) {
+	if (sscanf
+	    (buf, "%%%%BoundingBox: %lf %lf %lf %lf", llx, lly, urx,
+	     ury) == 4) {
 	    fclose(fp);
 	    return (1);
@@ -53,7 +53,8 @@
  * rotate is in degrees
 int eps_trans(double llx, double lly, double urx, double ury,
-	      double x, double y, double scale, double rotate, double *xt, double *yt)
+	      double x, double y, double scale, double rotate, double *xt,
+	      double *yt)
     double xc, yc, angle;
@@ -71,6 +72,7 @@
 int eps_save(FILE * fp, char *epsf, char *name)
     char buf[1024];
     FILE *epsfp;
     if ((epsfp = fopen(epsf, "r")) == NULL)
@@ -86,7 +88,8 @@
 /* draw EPS file saved by eps_save */
-int eps_draw_saved(FILE * fp, char *name, double x, double y, double scale, double rotate)
+int eps_draw_saved(FILE * fp, char *name, double x, double y, double scale,
+		   double rotate)
     fprintf(PS.fp, "\nBeginEPSF\n");
     fprintf(PS.fp, "%.5f %.5f translate\n", x, y);
@@ -104,9 +107,11 @@
 /* write EPS file into PS file */
-int eps_draw(FILE * fp, char *eps, double x, double y, double scale, double rotate)
+int eps_draw(FILE * fp, char *eps, double x, double y, double scale,
+	     double rotate)
     char buf[1024];
     FILE *epsfp;
     if ((epsfp = fopen(eps, "r")) == NULL)
@@ -133,15 +138,16 @@
 int pat_save(FILE * fp, char *epsf, char *name)
     char buf[1024];
     FILE *epsfp;
 	return (0);
     fprintf(fp, "\n/%s {\n", name);
-    while (fgets(buf, 1024, epsfp) != NULL)
-	if (strncmp(buf, "%!PS-Adobe", 10) == 0 || strncmp(buf, "%%BoundingBox", 13) == 0)
+    while (fgets(buf, 1024, epsfp) != NULL) {
+	if (strncmp(buf, "%!PS-Adobe", 10) == 0 ||
+	    strncmp(buf, "%%BoundingBox", 13) == 0)
 	    continue;
 	fprintf(fp, "%s", buf);
Modified: grass-addons/postscript/ps.output/fonts.c
--- grass-addons/postscript/ps.output/fonts.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/fonts.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -16,13 +16,12 @@
 double set_ps_font_nocolor(PSFONT * font)
-    if (font->extend == 1. || font->extend <= 0.)
+    if (font->extend == 1. || font->extend <= 0.) {
 	fprintf(PS.fp, "(%s) FN %.1f FS\n", font->name, font->size);
-    else
-	fprintf(PS.fp, "(%s) FN %.1f %.2f FE\n", font->name, font->size, font->extend);
+    else {
+	fprintf(PS.fp, "(%s) FN %.1f %.2f FE\n", font->name, font->size,
+		font->extend);
     return font->size;
Modified: grass-addons/postscript/ps.output/format.c
--- grass-addons/postscript/ps.output/format.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/format.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -17,32 +17,30 @@
 void format_northing(double north, char *buf, int map_proj)
     char h;
     int d, m;
     double s;
-    if (map_proj == PROJECTION_LL)
+    if (map_proj == PROJECTION_LL) {
 	G_lon_parts(north, &d, &m, &s, &h);
 	if (s < 0.1)
 	    s = 0.0;
-	if (s > 59.9)
+	if (s > 59.9) {
 	    s = 0.0;
 	    ++m;
 	if (s != 0.0)
 	    sprintf(buf, "%dº%d'%.1f\"%c", d, m, s, h);
-	else
+	else {
 	    if (m != 0)
 		sprintf(buf, "%dº%d'%c", d, m, h);
 	    else
 		sprintf(buf, "%dº%c", d, h);
-    else
+    else {
 	sprintf(buf, "%0.8f", north);
 	G_trim_decimal(buf);
@@ -51,32 +49,30 @@
 void format_easting(double east, char *buf, int map_proj)
     char h;
     int d, m;
     double s;
 	G_lat_parts(east, &d, &m, &s, &h);
 	if (s < 0.1)
 	    s = 0.0;
-	if (s > 59.9)
+	if (s > 59.9) {
 	    s = 0.0;
 	    ++m;
 	if (s != 0.0)
-	else
+	else {
 	    if (m != 0)
 	    else
-    else
+    else {
 	sprintf(buf, "%0.8f", east);
@@ -86,16 +82,16 @@
 void format_iho(double value, char *buf)
     char h;
     int d, m;
     double s;
-    if (PS.map.proj == PROJECTION_LL)
+    if (PS.map.proj == PROJECTION_LL) {
 	G_lon_parts(value, &d, &m, &s, &h);
 	if (s < 0.1)
 	    s = 0.0;
-	if (s > 59.9)
+	if (s > 59.9) {
 	    s = 0.0;
 	    ++m;
@@ -103,16 +99,14 @@
 	if (s != 0.0)
 	    //             sprintf(buf, "%dº|%d'%.8f\"", d, m, s);
 	    sprintf(buf, "%dº|%.1f'", d, (double)m + s / 60.);
-	else
+	else {
 	    if (m != 0)
 		sprintf(buf, "%dº|%d'", d, m);
 	    else
 		sprintf(buf, "%dº|", d);
-    else
+    else {
 	sprintf(buf, "%d|%03d", (int)(value / 1000), (int)value % 1000);
Modified: grass-addons/postscript/ps.output/frames.c
--- grass-addons/postscript/ps.output/frames.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/frames.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -18,8 +18,7 @@
     double x, y;
-    if (box->x <= 0.0)
+    if (box->x <= 0.0) {
 	box->x = PS.map_x - PS.map_w * (box->x / 100.);
@@ -27,12 +26,10 @@
        box->x = 0 + box->x;
-    if (box->y <= 0.0)
+    if (box->y <= 0.0) {
 	box->y = PS.map_y - PS.map_h * (box->y / 100.);
-    else
+    else {
 	box->y = PS.page.height - box->y;
@@ -46,15 +43,13 @@
     fprintf(PS.fp, "/mg %.4f def\n", box->margin);
     /* Height "hg" and content height "chg" */
-    if (height > 0.)
+    if (height > 0.) {
 	fprintf(PS.fp, "/hg %.4f def\n", height);	/* height */
 	fprintf(PS.fp, "/chg hg mg 2 mul sub def\n");	/* content height */
     /* Width "wd" and content width "cwd" */
-    if (width > 0.)
+    if (width > 0.) {
 	fprintf(PS.fp, "/wd %.4f def\n", width);	/* width */
 	fprintf(PS.fp, "/cwd wd mg 2 mul sub def\n");	/* content width */
@@ -79,14 +74,12 @@
 	fprintf(PS.fp, "/yo %.4f def\n", box->y + box->yset);
     /* Make color background, if set */
-    if (!box->fcolor.none)
+    if (!box->fcolor.none) {
 	set_ps_color(&(box->fcolor));
 	fprintf(PS.fp, "xo yo wd hg neg RF\n");
     /* Draw the border, if set */
-    if (box->border > 0.)
+    if (box->border > 0.) {
 	set_ps_color(&(box->color));
 	fprintf(PS.fp, "%.4f LW xo yo wd hg neg RO\n", box->border);
@@ -109,7 +102,7 @@
     /* Height "hg", content height "chg", and interline "dy" */
     fprintf(PS.fp, "/dy %.4f def\n", factor * font->size);	/* standard row sep */
-    fprintf(PS.fp, "/chg dy neg ARh {add dy add} forall def\n"); /* content height */
+    fprintf(PS.fp, "/chg dy neg ARh {add dy add} forall def\n");	/* content height */
     fprintf(PS.fp, "/hg chg mg 2 mul add def\n");	/* height */
     /* Width "wd", content width "cwd", and intercolum "dx" */
@@ -122,28 +115,24 @@
 /* Readjust the size of a box with new margins */
 void set_inner_readjust(double left, double top, double width, double height)
-    if (left > 0.)
+    if (left > 0.) {
 	if (width >= 0.)
 	    width += left;
 	else
 	    width = left;
 	fprintf(PS.fp, "/mgx mg %.4f add def\n", left);
-    if (top > 0.)
+    if (top > 0.) {
 	if (height >= 0.)
 	    height += top;
 	else
 	    height = top;
 	fprintf(PS.fp, "/mgy mg %.4f add def\n", top);
-    if (height > 0.)
 	fprintf(PS.fp, "/hg hg %.4f add def\n", height);
-    if (width > 0.)
+    if (width > 0.) {
 	fprintf(PS.fp, "/wd wd %.4f add def\n", width);
Modified: grass-addons/postscript/ps.output/input.c
--- grass-addons/postscript/ps.output/input.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/input.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -19,28 +19,24 @@
 int input(int level, char *buf)
     int i;
     char command[20], empty[3];
     if (level && isatty(fileno(inputfd)))
 	fprintf(stdout, "enter 'end' when done, 'exit' to quit\n");
-    do
-	if (level && isatty(fileno(inputfd)))
+    do {
+	if (level && isatty(fileno(inputfd))) {
 	    fprintf(stdout, "%s ", level == 1 ? ">" : ">>");
-	if (!G_getl2(buf, 1024, inputfd))
-	    if (inputfd != stdin)
+	if (!G_getl2(buf, 1024, inputfd)) {
+	    if (inputfd != stdin) {
 		fclose(inputfd);
 		inputfd = stdin;
 	    return 0;
-	if (sscanf(buf, "%5s %1s", command, empty) == 1)
+	if (sscanf(buf, "%5s %1s", command, empty) == 1) {
 	    if (strcmp(command, "end") == 0)
 		return 0;
 	    if (strcmp(command, "exit") == 0)
@@ -61,8 +57,7 @@
     while (*key && *key <= ' ')
 	key++;
-    if (*key == 0)
+    if (*key == 0) {
 	*k = *d = key;
 	return 0;
Modified: grass-addons/postscript/ps.output/legends.c
--- grass-addons/postscript/ps.output/legends.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/legends.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -29,31 +29,28 @@
     /* Symbol width "syw" and adding to all width columns */
     fprintf(PS.fp, "/syw %.5f def\n", legend->width);	/* symbol width */
-    fprintf(PS.fp, "0 1 ARw length -- {ARw exch dup ARw exch get syw add put} for\n");
+    fprintf(PS.fp,
+	    "0 1 ARw length -- {ARw exch dup ARw exch get syw add put} for\n");
-    if (height > 0.)
 	fprintf(PS.fp, "/hg %.5f def\n", height);	/* height */
 	fprintf(PS.fp, "/dy ARh length 1 eq {0} {chg ARh {sub} forall ARh length -- div} ifelse def\n");	/* rowsep */
-    else
+    else {
 	fprintf(PS.fp, "/dy %.5f def\n", .5 * legend->font.size);	/* standard row sep */
     /* Width "wd", content width "cwd", and colspan "dx" */
-    if (legend->xspan < 0.)
-    {				/* auto-adjust */
+    if (legend->xspan < 0.) {	/* auto-adjust */
 	fprintf(PS.fp, "/wd %.5f def ", -(PS.map_w * legend->xspan));	/* width */
 	fprintf(PS.fp, "/dx ARw length 1 eq {0} {cwd ARw {sub} forall ARw length -- div} ifelse def\n");	/* colspan */
-    else
+    else {
 	if (legend->xspan == 0.)
 	    legend->xspan = legend->box.margin;
 	fprintf(PS.fp, "/dx %.4f def\n", legend->xspan);	/* colspan */
Modified: grass-addons/postscript/ps.output/load_raster.c
--- grass-addons/postscript/ps.output/load_raster.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/load_raster.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -37,7 +37,9 @@
 int load_group(char *name)
     int i;
     struct Ref ref;
     char fullname[100];
     /* close open rasters */
@@ -46,8 +48,7 @@
     I_init_group_ref(&ref);
     /* get group info */
-    if (I_get_group_ref(PS.rst.title, &ref) == 0)
+    if (I_get_group_ref(PS.rst.title, &ref) == 0) {
 	G_fatal_error(_("Can't get group information"));
@@ -63,10 +64,9 @@
     PS.rst.mapset[2] = G_store(ref.file[ref.blu.n].mapset);
     /* check load colors */
-    for (i = 0; i < 3; i++)
-	if (G_read_colors(PS.rst.name[i], PS.rst.mapset[i], &(PS.rst.colors[i])) == -1)
+    for (i = 0; i < 3; i++) {
+	if (G_read_colors
+	    (PS.rst.name[i], PS.rst.mapset[i], &(PS.rst.colors[i])) == -1) {
 	    sprintf(fullname, "%s in %s", PS.rst.name[i], PS.rst.mapset[i]);
 	    error(fullname, "", "can't load color table");
 	    return 0;
@@ -74,10 +74,9 @@
     /* check open raster maps */
-	if ((PS.rst.fd[i] = G_open_cell_old(PS.rst.name[i], PS.rst.mapset[i])) < 0)
+	if ((PS.rst.fd[i] =
+	     G_open_cell_old(PS.rst.name[i], PS.rst.mapset[i])) < 0) {
 	    error(fullname, "", "can't open raster map");
 	    G_free_colors(&(PS.rst.colors[i]));
@@ -93,11 +92,11 @@
 int load_cell(int slot, char *name)
     char *mapset, *ptr;
     char fullname[100];
     /* close raster cell, if any */
-    if (PS.rst.fd[slot] >= 0)
+    if (PS.rst.fd[slot] >= 0) {
 	G_close_cell(PS.rst.fd[slot]);
 	G_free(PS.rst.name[slot]);
 	G_free(PS.rst.mapset[slot]);
@@ -107,16 +106,13 @@
     /* get mapset */
     ptr = strchr(name, '@');
-    if (ptr)
+    if (ptr) {
 	*ptr = '\0';
 	mapset = ptr + 1;
-    else
+    else {
 	mapset = G_find_file2("cell", name, "");
-	if (!mapset)
+	if (!mapset) {
 	    error(name, "", "not found");
 	    return 0;
@@ -130,16 +126,14 @@
     G_message(_("  Reading raster map <%s> ..."), fullname);
     /* load colors */
-    if (G_read_colors(name, mapset, &PS.rst.colors[slot]) == -1)
+    if (G_read_colors(name, mapset, &PS.rst.colors[slot]) == -1) {
 	return 0;
     G_get_color_range(&(PS.rst.min), &(PS.rst.max), &(PS.rst.colors[slot]));
     /* open raster map */
-    if ((PS.rst.fd[slot] = G_open_cell_old(name, mapset)) < 0)
+    if ((PS.rst.fd[slot] = G_open_cell_old(name, mapset)) < 0) {
 	G_free_colors(&PS.rst.colors[slot]);
 	return 0;
Modified: grass-addons/postscript/ps.output/local_proto.h
--- grass-addons/postscript/ps.output/local_proto.h	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/local_proto.h	2010-12-08 23:19:08 UTC (rev 44565)
@@ -16,57 +16,80 @@
 /* cat_val.c */
 #ifdef GRASS_DBMI_H
 int load_catval_array(VECTOR *, const char *, dbCatValArray *);
 void get_number(dbCatValArray *, int, double *);
 char *get_string(dbCatValArray *, int, int);
 #endif
 /* colors.c */
 #ifdef _PSCOLOR_H_
 int set_color_name(PSCOLOR *, char *);
 void set_color_rgb(PSCOLOR *, int, int, int);
 void set_color_pscolor(PSCOLOR *, PSCOLOR *);
 void unset_color(PSCOLOR *);
 int set_ps_color(PSCOLOR *);
 int set_ps_grey(PSCOLOR *);
 long color_to_long(PSCOLOR *);
 int long_to_color(long, PSCOLOR *);
 #endif
 /* eps.c */
 int eps_bbox(char *, double *, double *, double *, double *);
-int eps_trans(double, double, double, double, double, double, double, double, double *, double *);
+int eps_trans(double, double, double, double, double, double, double, double,
+	      double *, double *);
 #ifdef _STDIO_H
 int eps_save(FILE *, char *, char *);
 int eps_draw_saved(FILE *, char *, double, double, double, double);
 int eps_draw(FILE *, char *, double, double, double, double);
 int pat_save(FILE *, char *, char *);
 #endif
 /* fonts.c */
 #ifdef _PSFONT_H_
 double set_ps_font(PSFONT *);
 double set_ps_font_nocolor(PSFONT *);
 #endif
 /* format.c */
 void format_northing(double, char *, int);
 void format_easting(double, char *, int);
 void format_iho(double, char *);
 /* frames.c */
 #ifdef _PSFRAME_H_
 void set_box_orig(PSFRAME *);
 void set_box_size(PSFRAME *, double, double);
 void set_box_draw(PSFRAME *);
 void set_box_auto(PSFRAME *, PSFONT *, double);
 #endif
 void set_inner_readjust_title(const char *);
 void set_inner_readjust(double, double, double, double);
 /* input.c */
 int input(int, char *);
 int key_data(char *, char **, char **);
 int error(char *, char *, char *);
 /* legends.c */
@@ -77,21 +100,29 @@
 /* lines.c */
 #ifdef _PSLINE_H_
 int set_ps_linewidth(double);
 int set_ps_line(PSLINE *);
 int set_ps_line_no_color(PSLINE *);
 #endif
 /* load_raster.c */
 int load_group(char *);
 int load_cell(int, char *);
 int load_rgb(char *, char *, char *);
 /* palettes.c */
 #ifdef _PSCOLOR_H_
 int analogous(char *, PSCOLOR *, int, double);
 int complementary(char *, PSCOLOR *, int, double);
 int diverging(char *, PSCOLOR *, PSCOLOR *, int);
 int gradient(char *, PSCOLOR *, PSCOLOR *, int, int);
 int PS_str_to_color(char *, PSCOLOR *);
 #endif
 int pure_color(char *, int);
@@ -105,7 +136,9 @@
 /* proj_geo.c */
 #ifdef _GPROJECTS_H
 void init_proj(struct pj_info *, struct pj_info *);
-int find_limits(double *, double *, double *, double *, struct pj_info *, struct pj_info *);
+int find_limits(double *, double *, double *, double *, struct pj_info *,
+		struct pj_info *);
 #endif
 /* r_block.c */
@@ -119,12 +152,14 @@
 #ifdef _PSFONT_H_
 int default_font(PSFONT *);
 int read_font(char *, PSFONT *);
 #endif
 /* r_frame.c */
 #ifdef _PSFRAME_H_
 int default_frame(PSFRAME *, int, int);
 int read_frame(PSFRAME *);
 #endif
@@ -136,6 +171,7 @@
 /* r_line.c */
 #ifdef _PSLINE_H_
 int default_psline(PSLINE *);
 int read_psline(char *, PSLINE *);
 #endif
@@ -192,12 +228,19 @@
 /* scanners.c */
 int scan_easting(char *, double *);
 int scan_northing(char *, double *);
 int scan_resolution(char *, double *);
 int scan_percent(char *, double *, double, double);
 int scan_ref(char *, int *, int *);
 int scan_yesno(char *, char *);
 int scan_dimen(char *, double *);
 int scan_second(char *, double *);
 #ifdef _PSCOLOR_H_
@@ -206,33 +249,43 @@
 /* set_draw.c */
 int set_draw(char *, char *);
 int set_on_paper(char *, char *, char *, char *);
 /* set_geogrid.c */
 int set_lines_geogrid(void);
 int set_numbers_geogrid(void);
 #ifdef _PSLINE_H_
 int set_geogrid_lines(PSLINE *, int);
 #endif
 int set_geogrid_inner_numbers(void);
 int set_geogrid_outer_numbers(void);
 /* set_grid.c */
 int set_lines_grid(void);
 int set_numbers_grid(void);
 #ifdef _PSLINE_H_
 int set_grid_lines(char, PSLINE *, int);
 #endif
 int set_grid_inner_numbers(void);
 int set_grid_outer_numbers(int);
 int set_grid_iho_numbers(double, double);
 int set_grid_can_numbers(double, double);
 void set_grid_minordiv_border(int, double, double);
 void set_grid_minor_border(double, double, double);
 void set_grid_major_border(double, double);
 void set_grid_corners(double, double);
 /* set_mask.c */
@@ -240,6 +293,7 @@
 /* set_note.c */
 int note_int_file(char *);
 int set_note(int);
 /* set_outline.c */
@@ -247,10 +301,15 @@
 /* set_ps.c */
 void set_ps_rect(double, double, double, double);
 void set_ps_brd(double);
 void set_ps_brd2(double, double);
 int set_ps_where(char, double, double);
 int set_xy_where(char *, double, double, char *);
 int set_ps_symbol_eps(int, char *);
 #ifdef _VECTOR_H_
@@ -259,18 +318,25 @@
 /* set_raster.c */
 int set_raster(void);
 int set_raster_cell(void);
 int set_raster_rgb(void);
 int set_raster_maskcell(void);
 int set_raster_maskcolor(void);
 /* set_rlegend.c */
 int set_rlegend_cats(void);
 int set_rlegend_gradient(void);
 static double nice_step(double, int, int *);
 /* set_scalebar.c */
 char *strnumber(double);
 int set_scalebar(void);
 /* set_vector.c */
@@ -279,6 +345,7 @@
 #ifdef GRASS_VECT_H
 /* set_vareas.c */
 int set_vareas(VECTOR *, VAREAS *);
 int set_vareas_line(VECTOR *, VAREAS *);
 /* set_vlabels.c */
@@ -286,19 +353,27 @@
 /* set_vlegend.c */
 int set_vlegend(void);
 int set_vlegend_simple(int, const int *, int);
 int set_vlegend_multi(int, VECTOR *);
 void make_vareas(VECTOR *, int);
 void make_vlines(VECTOR *, int);
 void make_vpoints(VECTOR *, int);
 void set_vlegend_ps(int, int, int);
 /* set_vlines.c */
 int set_vlines(VECTOR *, VLINES *, int);
 int vector_line(struct line_pnts *);
 /* set_vpoints.c */
 int set_vpoints(VECTOR *, VPOINTS *);
 int set_vpoints_line(VECTOR *, VPOINTS *);
 #endif
@@ -308,6 +383,7 @@
 /* symbol.c */
 #if defined GRASS_SYMB_H
 int draw_chain(SYMBCHAIN *, double);
 #ifdef _VPOINTS_H_
 int symbol_save(int, VPOINTS *, SYMBOL *);
 #endif
@@ -316,20 +392,26 @@
 /* val_list.c */
 #ifdef GRASS_GIS_H
 int parse_val_list(char *, DCELL **);
 int sort_list(char *, int, CELL **);
 #endif
 /* vector.c */
 int vector_new(void);
 int default_vector(int);
 #ifdef _VECTOR_H_
 int vector_item_new(VECTOR *, double, long);
 int vector_rule_find(VECTOR *, double);
 int vector_rule_new(VECTOR *, char *, char *, double);
 #endif
 /* vlegend.c */
 int vlegend_block_new(void);
 void vlegend_block_adjust(int, const char *);
 void vlegend_block_reload(int);
Modified: grass-addons/postscript/ps.output/main.c
--- grass-addons/postscript/ps.output/main.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/main.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -31,8 +31,11 @@
 int main(int argc, char *argv[])
     struct Option *input_file;
     struct Option *output_file;
     struct GModule *module;
     struct Flag *draft, *eps, *ghost, *style;
     G_gisinit(argv[0]);
@@ -58,19 +61,23 @@
     draft = G_define_flag();
     draft->key = 'd';
-    draft->description = _("draft: Draw a 1x1 cm grid on paper to help the placement of the elements of the map");
+    draft->description =
+	_("draft: Draw a 1x1 cm grid on paper to help the placement of the elements of the map");
     eps = G_define_flag();
     eps->key = 'e';
-    eps->description = _("eps: Create output as EPS file for embedding into another ps.out map");
+    eps->description =
+	_("eps: Create output as EPS file for embedding into another ps.out map");
     ghost = G_define_flag();
     ghost->key = 'g';
-    ghost->description = _("ghostscript: Use the extended PostScript of Ghostscript (for transparent colors)");
+    ghost->description =
+	_("ghostscript: Use the extended PostScript of Ghostscript (for transparent colors)");
     style = G_define_flag();
     style->key = 's';
-    style->description = _("special: Draw the small digit in the coordinate numbers to lower instead upper position");
+    style->description =
+	_("special: Draw the small digit in the coordinate numbers to lower instead upper position");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -83,13 +90,12 @@
     if (!isatty(0))
 	G_disable_interactive();
-    if (output_file->answer)
+    if (output_file->answer) {
 	if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
-	    G_fatal_error("%s - %s: %s", G_program_name(), output_file->answer, strerror(errno));
+	    G_fatal_error("%s - %s: %s", G_program_name(),
+			  output_file->answer, strerror(errno));
-    else
+    else {
 	G_message(_("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
 		  output_file->key, output_file->description);
 	exit(EXIT_FAILURE);
@@ -137,57 +143,48 @@
     /* process options */
     char buf[1024];
     double number;
-    while (input(1, buf))
+    while (input(1, buf)) {
 	char *key;
 	char *data;
-	if (!key_data(buf, &key, &data))
+	if (!key_data(buf, &key, &data)) {
 	    continue;
 	/* General information */
-	if (KEY("paper"))
+	if (KEY("paper")) {
 	    read_paper(data);
 	    continue;
-	if (KEY("palette"))
+	if (KEY("palette")) {
 	    read_palette();
 	    continue;
-	if (KEY("maparea"))
+	if (KEY("maparea")) {
 	    read_maparea();
 	    continue;
-	if (KEY("scale"))
-	    if (sscanf(data, "1:%d", &(PS.scale)) != 1)
+	if (KEY("scale")) {
+	    if (sscanf(data, "1:%d", &(PS.scale)) != 1) {
 		error(key, data, "illegal scale request");
 	    continue;
 	/* Raster map related information */
-	if (KEY("cell") || KEY("rast") || KEY("raster") || KEY("rgb"))
-	    if (PS.rst.files != 0)
+	if (KEY("cell") || KEY("rast") || KEY("raster") || KEY("rgb")) {
+	    if (PS.rst.files != 0) {
 		error(key, data, "only one raster command");
 		continue;
 	    read_raster(data);
 	    continue;
-	if (KEY("rlegend"))
-	    if (PS.do_rlegend != 0)
+	if (KEY("rlegend")) {
+	    if (PS.do_rlegend != 0) {
 		error(key, data, "only one rlegend command");
 	    read_rlegend(data);
@@ -195,50 +192,40 @@
 	/* Vector map related information */
-	if (KEY("vlines") || KEY("vline"))
+	if (KEY("vlines") || KEY("vline")) {
 	    G_strip(data);
-	    if (*data == 0)
+	    if (*data == 0) {
 		error(key, data, "vlines need vector map");
 	    read_vlines(data);
 	    continue;
-	if (KEY("vareas") || KEY("varea"))
+	if (KEY("vareas") || KEY("varea")) {
 	    G_strip(data);
-	    if (*data == 0)
+	    if (*data == 0) {
 		error(key, data, "vareas need vector map");
 	    read_vareas(data);
 	    continue;
-	if (KEY("vpoints") || KEY("vpoint"))
+	if (KEY("vpoints") || KEY("vpoint")) {
 	    G_strip(data);
-	    if (*data == 0)
+	    if (*data == 0) {
 		error(key, data, "vpoints need vector map");
 	    read_vpoints(data);
 	    continue;
-	if (KEY("vlabels") || KEY("vlabel"))
+	if (KEY("vlabels") || KEY("vlabel")) {
 	    G_strip(data);
-	    if (*data == 0)
+	    if (*data == 0) {
 		error(key, data, "vlabels need vector map");
 	    read_vlabels(data);
 	    continue;
-	if (KEY("vlegend"))
-	    if (PS.do_vlegend != 0)
+	if (KEY("vlegend")) {
+	    if (PS.do_vlegend != 0) {
 		error(key, data, "only one vlegend command");
 	    read_vlegend(data);
@@ -246,29 +233,25 @@
 	/* Grid and scalebar related */
-	if (KEY("grid"))
+	if (KEY("grid")) {
 	    read_grid(&(PS.grid), 1);
 	    continue;
-	if (KEY("geogrid"))
-	    if (G_projection() == PROJECTION_XY)
-		error(key, data, "geogrid is not available for XY projection");
+	if (KEY("geogrid")) {
+	    if (G_projection() == PROJECTION_XY) {
+		error(key, data,
+		      "geogrid is not available for XY projection");
-	    else if (G_projection() == PROJECTION_LL)
+	    else if (G_projection() == PROJECTION_LL) {
 		error(key, data, "grid just uses LL projection");
 	    read_grid(&(PS.geogrid), 0);
 	    continue;
-	if (KEY("scalebar"))
-	    if (G_projection() == PROJECTION_LL)
-		error(key, data, "scalebar is not appropriate for this projection");
+	if (KEY("scalebar")) {
+	    if (G_projection() == PROJECTION_LL) {
+		error(key, data,
+		      "scalebar is not appropriate for this projection");
 	    if (sscanf(data, "%c", &(PS.sbar.type)) != 1)
 		PS.sbar.type = 'I';	/* default new style scalebar */
@@ -277,20 +260,16 @@
 	/* Addons related data */
-	if (KEY("note"))
-	    if (PS.n_notes >= MAX_NOTES)
+	if (KEY("note")) {
+	    if (PS.n_notes >= MAX_NOTES) {
 		G_warning("Only %d notes by map", MAX_NOTES);
 		continue;
 	    read_note(data);
 	    continue;
-	if (KEY("draw"))
-	    if (PS.n_draws >= MAX_DRAWS)
+	if (KEY("draw")) {
+	    if (PS.n_draws >= MAX_DRAWS) {
 		G_warning("Only %d draw commands by map", MAX_DRAWS);
 		continue;
@@ -303,8 +282,7 @@
     /* last minute adjust */
-    if (PS.grid.format >= 2)
-    {				/* IHO */
+    if (PS.grid.format >= 2) {	/* IHO */
 	PS.brd.width = 2. * MM_TO_POINT;	/* 12.7 */
Modified: grass-addons/postscript/ps.output/palettes.c
--- grass-addons/postscript/ps.output/palettes.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/palettes.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -17,6 +17,7 @@
 #include "palettes.h"
 void RGB_HSV(PSCOLOR *, PALETTE *);
 void HSV_RGB(PALETTE *, PSCOLOR *);
@@ -34,33 +35,32 @@
     int i;
-    for (i = 0; i < ncolors; i++)
-        if (strcmp(Palette[i].name, name) == 0)
-            HSV_RGB(&(Palette[i]), color);
-            color->none = 0;
-            return 1;
+    for (i = 0; i < ncolors; i++) {
+	if (strcmp(Palette[i].name, name) == 0) {
+	    HSV_RGB(&(Palette[i]), color);
+	    color->none = 0;
+	    return 1;
     color->none = 1;
     return 0;
-void PL_set_name(int k, char *name, int i)
-    if (Palette[k].h < 0.)    Palette[k].h += 360.;
-    if (Palette[k].h >= 360.) Palette[k].h -= 360.;
+   void PL_set_name(int k, char *name, int i)
+   if (Palette[k].h < 0.)    Palette[k].h += 360.;
+   if (Palette[k].h >= 360.) Palette[k].h -= 360.;
-    sprintf(Palette[k].name, "%s%d", name, i);
+   sprintf(Palette[k].name, "%s%d", name, i);
 /* pure colors: color-wheel */
 int pure_color(char *name, int div)
     int i, k;
     double step;
     /* alloc memory */
@@ -68,13 +68,12 @@
     step = 360. / div;
-    for (i = 0; i < div; i++, k++)
-        Palette[k].h = (double)i *step;
+    for (i = 0; i < div; i++, k++) {
+	Palette[k].h = (double)i *step;
-        Palette[k].s = 1.;
-        Palette[k].v = 1.;
-        sprintf(Palette[k].name, "%s%d", name, i+1);
+	Palette[k].s = 1.;
+	Palette[k].v = 1.;
+	sprintf(Palette[k].name, "%s%d", name, i + 1);
     return 1;
@@ -84,19 +83,19 @@
 int gray(char *name, int div)
     int i, k;
     double step;
     /* alloc memory */
     k = palette_new(div);
     step = (div > 1) ? (1. / (double)(div - 1)) : 0.;
-        Palette[k].h = 0.;
-        Palette[k].s = 0.;
-        Palette[k].v = (double)i * step; /* ((double)i * step) ^ (1.5) */
+	Palette[k].h = 0.;
+	Palette[k].s = 0.;
+	Palette[k].v = (double)i *step;	/* ((double)i * step) ^ (1.5) */
     return 1;
@@ -106,13 +105,14 @@
 int monochrome(char *name, PSCOLOR * rgb, int div)
     int i, k;
     double step;
     PALETTE hsv;
-    if (rgb->r == rgb->g && rgb->g == rgb->b)
-        gray(name, div);
-        return 1;
+    if (rgb->r == rgb->g && rgb->g == rgb->b) {
+	gray(name, div);
+	return 1;
     RGB_HSV(rgb, &hsv);
@@ -121,13 +121,13 @@
-        Palette[k].h = hsv.h;
-        Palette[k].s = (double)i * step;
-        Palette[k].v = 1. + (double)i * step * (hsv.v - 1.); /* if pure v = 1. */
+	Palette[k].h = hsv.h;
+	Palette[k].s = (double)i *step;
+	Palette[k].v = 1. + (double)i *step * (hsv.v - 1.);	/* if pure v = 1. */
     return 1;
@@ -137,7 +137,9 @@
 int complementary(char *name, PSCOLOR * rgb, int div, double sector)
     int i, k;
     double step;
     PALETTE hsv;
     RGB_HSV(rgb, &hsv);
@@ -148,17 +150,19 @@
     hsv.h += 180.;
     if (div > 1)
-        hsv.h -= (sector/2.);
+	hsv.h -= (sector / 2.);
-        Palette[k].h = hsv.h + (double)i * step;
-        Palette[k].s = hsv.s;
-        Palette[k].v = hsv.v;
+	Palette[k].h = hsv.h + (double)i *step;
+	Palette[k].s = hsv.s;
+	Palette[k].v = hsv.v;
+	    Palette[k].h += 360.;
+	    Palette[k].h -= 360.;
     return 1;
@@ -168,7 +172,9 @@
 int analogous(char *name, PSCOLOR * rgb, int div, double sector)
     int i, k;
     double step;
     PALETTE hsv;
     RGB_HSV(rgb, &hsv);
@@ -178,17 +184,19 @@
     step = (div > 1) ? (sector / (double)(div - 1)) : 0.;
     if (div > 1)
-        Palette[k].h = hsv.h + (double)i *step;
     return 1;
@@ -198,34 +206,39 @@
 int gradient(char *name, PSCOLOR * A, PSCOLOR * B, int div, int pure)
     int i, k;
     double h_step, s_step, v_step;
     PALETTE pal_A, pal_B;
     RGB_HSV(A, &pal_A);
     RGB_HSV(B, &pal_B);
     if (pal_A.h == pal_B.h || div < 2)
-        return 0;
+	return 0;
     /* alloc memory */
     if (pal_A.h < pal_B.h)
-        pal_A.h += 360;
+	pal_A.h += 360;
     h_step = (pal_B.h - pal_A.h) / (div - 1.);
     s_step = (pal_B.s - pal_A.s) / (div - 1.);
     v_step = (pal_B.v - pal_A.v) / (div - 1.);
-        Palette[k].h = pal_A.h + (double)i * h_step;
-        Palette[k].s = pure ? 1. : pal_A.s + (double)i * s_step;
-        Palette[k].v = pure ? 1. : pal_A.v + (double)i * v_step;
+	Palette[k].h = pal_A.h + (double)i *h_step;
+	Palette[k].s = pure ? 1. : pal_A.s + (double)i *s_step;
+	Palette[k].v = pure ? 1. : pal_A.v + (double)i *v_step;
     return 1;
@@ -235,35 +248,39 @@
 int diverging(char *name, PSCOLOR * A, PSCOLOR * B, int div)
     int i, k;
     double h_step, v_step, tmp;
     RGB_HSV(A, &pal_A);
     RGB_HSV(B, &pal_B);
-        return 0;
+	return 0;
     /* alloc memory */
-        pal_A.h += 360;
+	pal_A.h += 360;
     div -= 1;
     h_step = (pal_B.h - pal_A.h) / div;
     v_step = (pal_B.v - pal_A.v) / div;
-    for (i = 0; i < (div+1); i++, k++)
-        tmp = (2. * i / div - 1.);
-        Palette[k].s = tmp * tmp;
-        Palette[k].v = pal_A.v + (double)i * v_step;
+    for (i = 0; i < (div + 1); i++, k++) {
+	tmp = (2. * i / div - 1.);
+	Palette[k].s = tmp * tmp;
+	Palette[k].v = pal_A.v + (double)i *v_step;
     return 1;
@@ -276,69 +293,59 @@
 /* r, g, b values are from 0 to 1
    h = [0,360], s = [0,1], v = [0,1]
 void RGB_HSV(PSCOLOR * col, PALETTE * pal)
     double min, max, delta;
     int r_max = 1, b_max = 0;
     min = max = col->r;
-    if(min > col->g)
-        if(col->b < col->g)
-            min = col->b;
-        else
-            min = col->g;
-            if(col->b > col->r)
-                max = col->b;
-                b_max = 1;
-                r_max = 0;
+    if (min > col->g) {
+	if (col->b < col->g) {
+	    min = col->b;
+	else {
+	    min = col->g;
+	    if (col->b > col->r) {
+		max = col->b;
+		b_max = 1;
+		r_max = 0;
-    else
-        if(col->b > col->g)
-            max = col->b;
-            b_max = 1;
-            r_max = 0;
-        else
-            max = col->g;
-            r_max = 0;
-            if(col->b < col->r)
-                min = col->b;
+    else {
+	if (col->b > col->g) {
+	    max = col->b;
+	    b_max = 1;
+	    r_max = 0;
+	else {
+	    max = col->g;
+	    r_max = 0;
+	    if (col->b < col->r)
+		min = col->b;
     pal->v = max;
-    if( max == 0 || (delta = max - min) == 0)
-        pal->s = pal->h = 0;
-        return;
+    if (max == 0 || (delta = max - min) == 0) {
+	pal->s = pal->h = 0;
+	return;
     pal->s = delta / max;
-    if (r_max == 1)
-        pal->h = ( col->g - col->b ) / delta;
+    if (r_max == 1) {
+	pal->h = (col->g - col->b) / delta;
-    else if (b_max == 1)
-        pal->h = 4 + ( col->r - col->g ) / delta;
+    else if (b_max == 1) {
+	pal->h = 4 + (col->r - col->g) / delta;
-    else
-        pal->h = 2 + ( col->b - col->r ) / delta;
+    else {
+	pal->h = 2 + (col->b - col->r) / delta;
     pal->h *= 60.;
     if (pal->h < 0)
-        pal->h += 360.;
+	pal->h += 360.;
     return;
@@ -346,36 +353,59 @@
 void HSV_RGB(PALETTE * pal, PSCOLOR * col)
     /* achromatic, gray */
-    if (pal->s == 0)
-        col->r = col->g = col->b = pal->v;
-        return;
+    if (pal->s == 0) {
+	col->r = col->g = col->b = pal->v;
+	return;
     double f, p, q, t;
     int i;
-//     f = modf(pal->h * 60, &t);
-//     i = ((int) t) % 60;
+    //     f = modf(pal->h * 60, &t);
+    //     i = ((int) t) % 60;
     i = floor(pal->h / 60.);
     f = pal->h / 60. - (double)i;
     p = pal->v * (1. - pal->s);
     q = pal->v * (1. - pal->s * f);
     t = pal->v * (1. - pal->s * (1. - f));
-    switch (i)
-    case 0: col->r = pal->v; col->g = t;      col->b = p;      break;
-    case 1: col->r = q;      col->g = pal->v; col->b = p;      break;
-    case 2: col->r = p;      col->g = pal->v; col->b = t;      break;
-    case 3: col->r = p;      col->g = q;      col->b = pal->v; break;
-    case 4: col->r = t;      col->g = p;      col->b = pal->v; break;
-    case 5: col->r = pal->v; col->g = p;      col->b = q;      break;
+    switch (i) {
+    case 0:
+	col->r = pal->v;
+	col->g = t;
+	col->b = p;
+	break;
+    case 1:
+	col->r = q;
+	col->g = pal->v;
+	col->b = p;
+	break;
+    case 2:
+	col->r = p;
+	col->g = pal->v;
+	col->b = t;
+	break;
+    case 3:
+	col->r = p;
+	col->g = q;
+	col->b = pal->v;
+	break;
+    case 4:
+	col->r = t;
+	col->g = p;
+	col->b = pal->v;
+	break;
+    case 5:
+	col->r = pal->v;
+	col->g = p;
+	col->b = q;
+	break;
     default:
-        col->none = 1;
+	col->none = 1;
Modified: grass-addons/postscript/ps.output/palettes.h
--- grass-addons/postscript/ps.output/palettes.h	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/palettes.h	2010-12-08 23:19:08 UTC (rev 44565)
@@ -20,9 +20,11 @@
 #ifdef MAIN
 PALETTE *Palette;
 int ncolors;
 #else
 extern PALETTE *Palette;
 extern int ncolors;
 #endif
Modified: grass-addons/postscript/ps.output/papers.c
--- grass-addons/postscript/ps.output/papers.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/papers.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -63,10 +63,8 @@
     register int i;
-    for (i = 0; papers[i].name != NULL; i++)
-	if (strcmp(papers[i].name, name) == 0)
+    for (i = 0; papers[i].name != NULL; i++) {
+	if (strcmp(papers[i].name, name) == 0) {
 	    PS.page.width = papers[i].width;
 	    PS.page.height = papers[i].height;
 	    PS.page.left = papers[i].left;
Modified: grass-addons/postscript/ps.output/proj_geo.c
--- grass-addons/postscript/ps.output/proj_geo.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/proj_geo.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -46,9 +46,11 @@
 int find_limits(double *north, double *south,
-		double *east, double *west, struct pj_info *ll_proj, struct pj_info *xy_proj)
+		double *east, double *west, struct pj_info *ll_proj,
+		struct pj_info *xy_proj)
     int x, y;
     double d, z;
     /* West */
Modified: grass-addons/postscript/ps.output/ps3_map.c
--- grass-addons/postscript/ps.output/ps3_map.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/ps3_map.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -23,28 +23,30 @@
 int PS3_map(void)
     int i, j;
     double d;
     /* PostScript header */
     fprintf(PS.fp, "%%!PS-Adobe-3.0 %s\n", PS.level == 0 ? "EPS 1.2" : "");
-    fprintf(PS.fp, "%%%%BoundingBox: 0 0 %d %d\n", (int)(PS.page.width), (int)(PS.page.height));
+    fprintf(PS.fp, "%%%%BoundingBox: 0 0 %d %d\n", (int)(PS.page.width),
+	    (int)(PS.page.height));
     fprintf(PS.fp,
-        "%%%%Title: \n"
-        "%%%%Creator: \n"
-        "%%%%CreationDate: %s\n"
-        "%%%%Programming: E. Jorge Tizado, Spain 2009\n"
-        "%%%%EndComments\n\n", G_date());
+	    "%%%%Title: \n" "%%%%Creator: \n" "%%%%CreationDate: %s\n"
+	    "%%%%Programming: E. Jorge Tizado, Spain 2009\n"
+	    "%%%%EndComments\n\n", G_date());
     /* BEGIN NO EMBEBED EPS file */
-    if (PS.level > 0)
+    if (PS.level > 0) {
 	fprintf(PS.fp, "%%%%BeginProlog\n");
 	fprintf(PS.fp, "/D {bind def} bind def\n");
 	fprintf(PS.fp, "/XD {exch def} D\n");
 	fprintf(PS.fp, "/str 20 string def\n");
 	fprintf(PS.fp, "/i2s {str cvs} D\n");
-	fprintf(PS.fp, "/c2s {/charcode exch def /thechar ( ) dup 0 charcode put def thechar} D\n");
-        fprintf(PS.fp, "/adds { exch dup length 2 index length add string dup dup 4 2 roll copy length " "4 -1 roll putinterval} D\n");
 	fprintf(PS.fp,
+		"/c2s {/charcode exch def /thechar ( ) dup 0 charcode put def thechar} D\n");
+	fprintf(PS.fp,
+		"/adds { exch dup length 2 index length add string dup dup 4 2 roll copy length "
+		"4 -1 roll putinterval} D\n");
+	fprintf(PS.fp,
 		"/FN { % (FontName) FN -\n"
 		"    dup (-ISOLatin1) adds dup /F0 exch cvn def exch cvn\n"
 		"    currentdict F0 known {pop pop}\n"
@@ -52,15 +54,21 @@
 		"        /Encoding ISOLatin1Encoding def\n"
 		"        /FontName 0 index def\n"
 		"        currentdict end definefont pop} ifelse} D\n");
-	fprintf(PS.fp, "/FS {/FS0 exch def F0 findfont FS0 scalefont setfont} D\n");
-    fprintf(PS.fp, "/FE {F0 findfont 3 1 roll 1 index dup /FS0 exch def mul 0 0 4 -1 roll 0 0 6 packedarray makefont setfont} D\n");
-	fprintf(PS.fp, "/FA {currentfont [1 0 0 1.25 0 0] makefont setfont} D\n");
-    fprintf(PS.fp, "/FR {currentfont [1 0 0 .707 0 %d] makefont setfont} D\n", ((PS.flag & 2) ? 0: 2));
+	fprintf(PS.fp,
+		"/FS {/FS0 exch def F0 findfont FS0 scalefont setfont} D\n");
+	fprintf(PS.fp,
+		"/FE {F0 findfont 3 1 roll 1 index dup /FS0 exch def mul 0 0 4 -1 roll 0 0 6 packedarray makefont setfont} D\n");
+	fprintf(PS.fp,
+		"/FA {currentfont [1 0 0 1.25 0 0] makefont setfont} D\n");
+	fprintf(PS.fp,
+		"/FR {currentfont [1 0 0 .707 0 %d] makefont setfont} D\n",
+		((PS.flag & 2) ? 0 : 2));
 	fprintf(PS.fp, "/++ {1 add} D\n");
 	fprintf(PS.fp, "/-- {1 sub} D\n");
 	fprintf(PS.fp, "/mm {360 mul 127 div} D\n");
 	fprintf(PS.fp, "/inch {72 mul} D\n");
-    fprintf(PS.fp, "/B {4 1 roll 2 copy 5 index 5 index 8 1 roll newpath moveto lineto lineto lineto closepath} D\n");
+	fprintf(PS.fp,
+		"/B {4 1 roll 2 copy 5 index 5 index 8 1 roll newpath moveto lineto lineto lineto closepath} D\n");
 	fprintf(PS.fp, "/C {setrgbcolor} D\n");
 	fprintf(PS.fp, "/cLW {currentlinewidth} D\n");
 	fprintf(PS.fp, "/cP {currentpoint} D\n");
@@ -69,7 +77,8 @@
 	fprintf(PS.fp, "/F {gsave fill grestore} D\n");
 	fprintf(PS.fp, "/G {setgray} D\n");
 	fprintf(PS.fp, "/GET {get aload pop} D\n");
-	fprintf(PS.fp, "/CG {0.11 mul exch 0.59 mul add exch 0.30 mul add setgray} D\n");
+	fprintf(PS.fp,
+		"/CG {0.11 mul exch 0.59 mul add exch 0.30 mul add setgray} D\n");
 	fprintf(PS.fp, "/GS {gsave} D\n");
 	fprintf(PS.fp, "/GR {grestore} D\n");
 	fprintf(PS.fp, "/LC {setlinecap} D\n");
@@ -86,90 +95,107 @@
 	fprintf(PS.fp, "/MS {moveto show} D\n");
 	fprintf(PS.fp, "/NM {newpath moveto} D\n");
 	fprintf(PS.fp, "/NP {newpath} D\n");
-    fprintf(PS.fp, "/O {%s} D\n", ((PS.flag & 1) ? ".setopacityalpha" : "pop"));
+	fprintf(PS.fp, "/O {%s} D\n",
+		((PS.flag & 1) ? ".setopacityalpha" : "pop"));
 	fprintf(PS.fp, "/RE {rectstroke} D\n");
-    fprintf(PS.fp, "/Re {currentpoint 4 2 roll rectstroke} D\n");
-    fprintf(PS.fp, "/RES {gsave newpath false charpath flattenpath pathbbox grestore} D\n");
+	fprintf(PS.fp, "/Re {currentpoint 4 2 roll rectstroke} D\n");
+	fprintf(PS.fp,
+		"/RES {gsave newpath false charpath flattenpath pathbbox grestore} D\n");
 	fprintf(PS.fp, "/RF {rectfill} D\n");
-    fprintf(PS.fp, "/Rf {currentpoint 4 2 roll rectfill} D\n");
+	fprintf(PS.fp, "/Rf {currentpoint 4 2 roll rectfill} D\n");
 	fprintf(PS.fp, "/RC {rectclip} D\n");
 	fprintf(PS.fp, "/ROT {rotate} D\n");
 	fprintf(PS.fp, "/S {stroke} D\n");
 	fprintf(PS.fp, "/SC {scale} D\n");
-    fprintf(PS.fp, "/SW {stringwidth pop} D\n");
-    fprintf(PS.fp, "/SWH {gsave newpath 0 0 moveto false charpath flattenpath pathbbox " "4 2 roll pop pop grestore} D\n");
+	fprintf(PS.fp, "/SW {stringwidth pop} D\n");
+	fprintf(PS.fp,
+		"/SWH {gsave newpath 0 0 moveto false charpath flattenpath pathbbox "
+		"4 2 roll pop pop grestore} D\n");
 	fprintf(PS.fp, "/SHL {show} D\n");
 	fprintf(PS.fp, "/SHR {dup SW neg 0 rmoveto show} D\n");
 	fprintf(PS.fp, "/SHC {dup SW -2 div 0 rmoveto show} D\n");
 	fprintf(PS.fp, "/SHLC {dup SWH -2 div 0 exch rmoveto pop show} D\n");
-	fprintf(PS.fp, "/SHRC {dup SWH -2 div exch neg exch rmoveto show} D\n");
-	fprintf(PS.fp, "/SHCC {dup SWH -2 div exch 2 div neg exch rmoveto show} D\n");
-    fprintf(PS.fp, "/SHS {(:) anchorsearch {pop exch 0 rmoveto SHR} {(.) anchorsearch {pop exch 2 div 0 rmoveto SHC} {exch pop SHL} ifelse} ifelse} D\n");
-    fprintf(PS.fp, "/COOR {(º) search {GS SHL SHL FR SHL GR} {dup length /n XD {c2s GS n 4 lt n 5 gt or {FR} if show cP GR M n -- /n XD} forall} ifelse} D\n");
+	fprintf(PS.fp,
+		"/SHRC {dup SWH -2 div exch neg exch rmoveto show} D\n");
+	fprintf(PS.fp,
+		"/SHCC {dup SWH -2 div exch 2 div neg exch rmoveto show} D\n");
+	fprintf(PS.fp,
+		"/SHS {(:) anchorsearch {pop exch 0 rmoveto SHR} {(.) anchorsearch {pop exch 2 div 0 rmoveto SHC} {exch pop SHL} ifelse} ifelse} D\n");
+	fprintf(PS.fp,
+		"/COOR {(º) search {GS SHL SHL FR SHL GR} {dup length /n XD {c2s GS n 4 lt n 5 gt or {FR} if show cP GR M n -- /n XD} forall} ifelse} D\n");
 	fprintf(PS.fp, "/SVC {{c2s GS SHC GR 0 FS0 neg MR} forall} D\n");
-    fprintf(PS.fp, "/SWx {0 exch {SW 2 copy lt {exch} if pop} forall} D\n");
+	fprintf(PS.fp,
+		"/SWx {0 exch {SW 2 copy lt {exch} if pop} forall} D\n");
 	fprintf(PS.fp, "/TR {translate} D\n");
-    fprintf(PS.fp, "/TSEL {(:) anchorsearch {pop SHR} {(.) anchorsearch {pop SHC} {SHL} ifelse} ifelse} D\n");
-    fprintf(PS.fp, "/TXT {(|) search {GS TSEL GR pop 0 FS0 -1.2 mul rmoveto TXT} {TSEL} ifelse} D\n");
-    fprintf(PS.fp, "/TCIR {SWH 2 copy gt {pop} {exch pop} ifelse 2 div 2 add cP 3 -1 roll 0 360 NP arc CP S} D\n");
-    fprintf(PS.fp, "/RO {GS dup cLW exch 0 lt {neg} if add exch cLW add exch cLW -2 div dup 2 index 0 lt {neg} if TR RE GR} D\n");
-	fprintf(PS.fp, "/RESET {/x xo mgx add def /y yo mgy sub def /col 0 def /row 0 def} def\n");
-    fprintf(PS.fp, "/READJUST {SWH mg add dup hg add /hg XD mg add /mgy XD mgx 2 mul add dup wd gt {/wd XD} {pop} ifelse} def\n");
-	fprintf(PS.fp, "/COL {/col XD xo mgx add 0 1 col -- {ARw exch get dx add add} for /x XD} def\n");
-	fprintf(PS.fp, "/ROW {/row XD yo mgy sub 0 1 row -- {ARh exch get dy add sub} for /y XD} def\n");
+	fprintf(PS.fp,
+		"/TSEL {(:) anchorsearch {pop SHR} {(.) anchorsearch {pop SHC} {SHL} ifelse} ifelse} D\n");
+	fprintf(PS.fp,
+		"/TXT {(|) search {GS TSEL GR pop 0 FS0 -1.2 mul rmoveto TXT} {TSEL} ifelse} D\n");
+	fprintf(PS.fp,
+		"/TCIR {SWH 2 copy gt {pop} {exch pop} ifelse 2 div 2 add cP 3 -1 roll 0 360 NP arc CP S} D\n");
+	fprintf(PS.fp,
+		"/RO {GS dup cLW exch 0 lt {neg} if add exch cLW add exch cLW -2 div dup 2 index 0 lt {neg} if TR RE GR} D\n");
+	fprintf(PS.fp,
+		"/RESET {/x xo mgx add def /y yo mgy sub def /col 0 def /row 0 def} def\n");
+	fprintf(PS.fp,
+		"/READJUST {SWH mg add dup hg add /hg XD mg add /mgy XD mgx 2 mul add dup wd gt {/wd XD} {pop} ifelse} def\n");
+	fprintf(PS.fp,
+		"/COL {/col XD xo mgx add 0 1 col -- {ARw exch get dx add add} for /x XD} def\n");
+	fprintf(PS.fp,
+		"/ROW {/row XD yo mgy sub 0 1 row -- {ARh exch get dy add sub} for /y XD} def\n");
 	/* end */
 	fprintf(PS.fp, "%%%%EndProlog\n");
 	/* Page specifications */
-	fprintf(PS.fp, "<< /PageSize [%d %d] >> setpagedevice\n", (int)(PS.page.width), (int)(PS.page.height));
+	fprintf(PS.fp, "<< /PageSize [%d %d] >> setpagedevice\n",
+		(int)(PS.page.width), (int)(PS.page.height));
     /* END NO EPS file */
     /* Prepare the map */
     start_map();
-    if (!PS.page.fcolor.none)
+    if (!PS.page.fcolor.none) {
 	set_ps_color(&(PS.page.fcolor));
-	fprintf(PS.fp, "0 0 %d %d RF\n", (int)(PS.page.width), (int)(PS.page.height));
+	fprintf(PS.fp, "0 0 %d %d RF\n", (int)(PS.page.width),
-    if (PS.draft) /* print a reticule as watermark on page */
-	fprintf(PS.fp, "GS .5 LW 0.9 G /Helvetica findfont 7 scalefont setfont\n");
-    fprintf(PS.fp, "0 0 10 mm %d {0 M GS 0.5 G 1 1 MR dup i2s show ++ GR 0 %d LRS} for pop\n",
+    if (PS.draft) {		/* print a reticule as watermark on page */
+	fprintf(PS.fp,
+		"GS .5 LW 0.9 G /Helvetica findfont 7 scalefont setfont\n");
+	fprintf(PS.fp,
+		"0 0 10 mm %d {0 M GS 0.5 G 1 1 MR dup i2s show ++ GR 0 %d LRS} for pop\n",
-    fprintf(PS.fp, "0 %d -10 mm 0 {0 exch M GS 0.5 G 1 1 MR dup i2s show ++ GR %d 0 LRS} for pop\n",
+	fprintf(PS.fp,
+		"0 %d -10 mm 0 {0 exch M GS 0.5 G 1 1 MR dup i2s show ++ GR %d 0 LRS} for pop\n",
 		(int)(PS.page.height), (int)(PS.page.width));
 	fprintf(PS.fp, "[1 2] 0 LD \n");
-    fprintf(PS.fp, "5 mm 10 mm %d {0 M 0 %d LRS} for\n",
-        (int)(PS.page.width), (int)(PS.page.height));
-    fprintf(PS.fp, "%d 5 mm sub -10 mm 0 {0 exch M %d 0 LRS} for\n",
-        (int)(PS.page.height), (int)(PS.page.width));
+	fprintf(PS.fp, "5 mm 10 mm %d {0 M 0 %d LRS} for\n",
+	fprintf(PS.fp, "%d 5 mm sub -10 mm 0 {0 exch M %d 0 LRS} for\n",
+		(int)(PS.page.height), (int)(PS.page.width));
 	fprintf(PS.fp, "GR\n");
     /* PAPER CUSTOM DRAWS */
-    if (PS.n_draws > 0)
-	for (i = 0; i < PS.n_draws; i++)
+    if (PS.n_draws > 0) {
+	for (i = 0; i < PS.n_draws; i++) {
 	    if (PS.draw.flag[i] == 2)
 		set_draw(PS.draw.key[i], PS.draw.data[i]);
     /* CLIP to MAP AREA */
     fprintf(PS.fp, "gsave 0 0 0 C ");
-    fprintf(PS.fp, "%.4f %.4f %.4f %.4f rectclip\n", PS.map_x, PS.map_y, PS.map_w, PS.map_h);
-    if (!PS.fcolor.none)
+    fprintf(PS.fp, "%.4f %.4f %.4f %.4f rectclip\n", PS.map_x, PS.map_y,
+	    PS.map_w, PS.map_h);
+    if (!PS.fcolor.none) {
 	set_ps_color(&(PS.fcolor));
-	fprintf(PS.fp, "%.4f %.4f %.4f %.4f RF\n", PS.map_x, PS.map_y, PS.map_w, PS.map_h);
+	fprintf(PS.fp, "%.4f %.4f %.4f %.4f RF\n", PS.map_x, PS.map_y,
     /* needed by uncolored patterns */
     fprintf(PS.fp, "[/Pattern /DeviceRGB] setcolorspace\n");
     /* RASTER */
 	set_raster();
 	/* outline, if requested */
-	if (PS.rst.outline.width > 0.)
+	if (PS.rst.outline.width > 0.) {
 	    if (!G_raster_map_is_fp(PS.rst.name[0], PS.rst.mapset[0]))
 		set_outline();
 	    else
@@ -177,109 +203,88 @@
     /* VECTOR (masked) */
-    if (PS.vct_files != 0)
-        set_vector(MASKED, AREAS);
-        set_vector(MASKED, LINES);
-        set_vector(MASKED, POINTS);
-        set_vector(MASKED, LABELS);
+    if (PS.vct_files != 0) {
+	set_vector(MASKED, AREAS);
+	set_vector(MASKED, LINES);
+	set_vector(MASKED, POINTS);
+	set_vector(MASKED, LABELS);
     /* RASTER MASK */
-    if (PS.need_mask && PS.rst.do_mask)
+    if (PS.need_mask && PS.rst.do_mask) {
 	set_mask();
     /* VECTOR-LINES/AREAS under grids (unmasked) */
 	set_vector(UNMASKED, AREAS);
 	set_vector(UNMASKED, LINES);
     /* CLIPED CUSTOM DRAWS */
 	/* fprintf(PS.fp, "0 0 0 C "); // default color */
 	    if (PS.draw.flag[i] == 0)
     /* GRIDS LINES INSIDE OF BORDER  */
-    if (PS.grid.sep > 0)
+    if (PS.grid.sep > 0) {
 	set_lines_grid();
-    if (PS.geogrid.sep > 0)
+    if (PS.geogrid.sep > 0) {
 	set_lines_geogrid();
     /* VECTOR-POINTS/LABELS on grids (unmasked) */
 	set_vector(UNMASKED, POINTS);
 	set_vector(UNMASKED, LABELS);
     /* CLIPED CUSTOM DRAWS ONTO ALL MAP ITEMS */
-        /* fprintf(PS.fp, "0 0 0 C "); // default color */
-            if (PS.draw.flag[i] == 3)
-                set_draw(PS.draw.key[i], PS.draw.data[i]);
+	/* fprintf(PS.fp, "0 0 0 C "); // default color */
+	    if (PS.draw.flag[i] == 3)
+		set_draw(PS.draw.key[i], PS.draw.data[i]);
     /* no more work in the map area */
     fprintf(PS.fp, "grestore\n");
     /* BORDER */
-    if (PS.do_border && PS.brd.width > 0 && !PS.brd.color.none)
+    if (PS.do_border && PS.brd.width > 0 && !PS.brd.color.none) {
 	set_ps_line(&(PS.brd));
 	set_ps_rect(PS.map_x, PS.map_y, PS.map_w, PS.map_h);
     /* GRID NUMBER, OUTSIDE OF BORDER */
 	set_numbers_geogrid();
 	set_numbers_grid();
     /* LEGENDS */
-    if (PS.do_rlegend)
-	if (G_raster_map_is_fp(PS.rl.name, PS.rl.mapset) || PS.rl.do_gradient)
+    if (PS.do_rlegend) {
+	if (G_raster_map_is_fp(PS.rl.name, PS.rl.mapset) || PS.rl.do_gradient) {
 	    set_rlegend_gradient();
-	else
+	else {
 	    set_rlegend_cats();
-    if (PS.do_vlegend)
+    if (PS.do_vlegend) {
 	set_vlegend();
     /* NOTES */
-    for (i = 0; i < PS.n_notes; i++)
+    for (i = 0; i < PS.n_notes; i++) {
 	set_note(i);
     /* SCALEBAR */
-    if (PS.sbar.segments > 0 && PS.sbar.length > 0)
+    if (PS.sbar.segments > 0 && PS.sbar.length > 0) {
 	set_scalebar();
     /* FREE CUSTOM DRAWS */
 	    if (PS.draw.flag[i] == 1)
@@ -287,16 +292,14 @@
     /* END */
     /* BEGIN NO EPS file */
-    if (PS.level > 0)
 	fprintf(PS.fp, "showpage\n");
 	fprintf(PS.fp, "%%%%Trailer\n");
 	fprintf(PS.fp, "%%%%EOF\n");
 	fclose(PS.fp);
     /* FREE ALLOCATED POINTERS */
-    for (i = 0; i < PS.vct_files; i++)
+    for (i = 0; i < PS.vct_files; i++) {
 	G_free(PS.vct[i].data);
 	G_free(PS.vct[i].item);
Modified: grass-addons/postscript/ps.output/ps_info.h
--- grass-addons/postscript/ps.output/ps_info.h	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/ps_info.h	2010-12-08 23:19:08 UTC (rev 44565)
@@ -82,8 +82,10 @@
 #ifdef MAIN
 struct PS3_info PS;
 int sec_draw;			/* used in PS_plot */
 #else
 extern struct PS3_info PS;
 extern int sec_draw;
 #endif
Modified: grass-addons/postscript/ps.output/r_block.c
--- grass-addons/postscript/ps.output/r_block.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_block.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -20,47 +20,40 @@
 int read_block(int i)
     char buf[1024];
     char *key, *data;
     G_debug(1, "Reading legend settings ..");
-    while (input(2, buf))
+    while (input(2, buf)) {
 	    continue;
-	if (KEY("lpos"))
-	    if (sscanf(data, "%d", &(PS.vct[i].lpos)) != 1)
+	if (KEY("lpos")) {
+	    if (sscanf(data, "%d", &(PS.vct[i].lpos)) != 1) {
 		error(key, data, "illegal lpos request (legend)");
 	    continue;
-	if (KEY("cols"))
-	    int n = sscanf(data, "%d %lf", &(PS.vct[i].cols), &(PS.vct[i].xspan));
+	if (KEY("cols")) {
+	    int n =
+		sscanf(data, "%d %lf", &(PS.vct[i].cols), &(PS.vct[i].xspan));
-	    if (n != 1 && n != 2)
+	    if (n != 1 && n != 2) {
 		error(key, data, "illegal cols/span request (legend)");
-	    else
-                if (PS.vct[i].cols <= 0)
+	    else {
+		if (PS.vct[i].cols <= 0)
 		    PS.vct[i].cols = 1;
 		if (n == 1)
 		    PS.vct[i].xspan = -1.;
 	    continue;
-	if (KEY("interline") || KEY("dy"))
-            if (scan_dimen(data, &(PS.vct[i].yspan)) != 1)
-                PS.vct[i].yspan = -1.;
+	if (KEY("interline") || KEY("dy")) {
+	    if (scan_dimen(data, &(PS.vct[i].yspan)) != 1) {
+		PS.vct[i].yspan = -1.;
 		error(key, data, "illegal interline request (legend)");
 	    continue;
Modified: grass-addons/postscript/ps.output/r_draw.c
--- grass-addons/postscript/ps.output/r_draw.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_draw.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -22,25 +22,23 @@
 int read_draw(char *name)
     char buf[1024];
     char *key, *data;
     int type = 0;
     G_debug(1, "Reading draw settings ..");
     if (strcmp(name, "free") == 0)
 	type = 1;
-    else
-    if (strcmp(name, "paper") == 0)
-        type = 2;
-    else
-    if (strcmp(name, "legend") == 0)
-        type = 3;
+    else if (strcmp(name, "paper") == 0)
+	type = 2;
+    else if (strcmp(name, "legend") == 0)
+	type = 3;
 	    continue;
Modified: grass-addons/postscript/ps.output/r_font.c
--- grass-addons/postscript/ps.output/r_font.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_font.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -31,10 +31,8 @@
     dp = data;
     if (*dp >= 'a' && *dp <= 'z')
 	*dp = *dp - 'a' + 'A';
-    while (*dp)
-	if (*dp == ' ')
+    while (*dp) {
+	if (*dp == ' ') {
 	    *dp++ = '-';
@@ -57,6 +55,7 @@
 int read_font(char *arg, PSFONT * font)
     char buf[1024];
     char *key, *data;
     G_debug(1, "Reading font settings ..");
@@ -66,40 +65,31 @@
-    while (input(3, buf))
+    while (input(3, buf)) {
 	    continue;
-	if (KEY("name"))
+	if (KEY("name")) {
 	    get_font(data);
 	    strcpy(font->name, data);
 	    continue;
-	if (KEY("size"))
-	    if (scan_dimen(data, &(font->size)) != 1)
+	if (KEY("size")) {
+	    if (scan_dimen(data, &(font->size)) != 1) {
 		font->size = 10.;
 		error(key, data, "illegal size request (font)");
 	    continue;
-	if (KEY("extend"))
-	    if (scan_dimen(data, &(font->extend)) != 1)
+	if (KEY("extend")) {
+	    if (scan_dimen(data, &(font->extend)) != 1) {
 		font->extend = 1.;
 		error(key, data, "illegal extent request (font)");
 	    continue;
-	if (KEY("color"))
-	    if (!scan_color(data, &(font->color)))
+	if (KEY("color")) {
+	    if (!scan_color(data, &(font->color))) {
 		error(key, data, "illegal color request (font)");
 	    continue;
Modified: grass-addons/postscript/ps.output/r_frame.c
--- grass-addons/postscript/ps.output/r_frame.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_frame.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -36,6 +36,7 @@
 int read_frame(PSFRAME * box)
     char buf[1024];
     char *key, *data;
     G_debug(1, "Reading frame settings ..");
@@ -45,22 +46,17 @@
 	    continue;
-	if (KEY("where"))
+	if (KEY("where")) {
 	    char xx[50], yy[50];
-	    if (sscanf(data, "%s %s", xx, yy) != 2)
+	    if (sscanf(data, "%s %s", xx, yy) != 2) {
 		error(key, data, "illegal box where request");
-	    else
+	    else {
 		if (scan_dimen(xx, &(box->x)) == 2)
 		    box->x *= -1;
 		if (scan_dimen(yy, &(box->y)) == 2)
@@ -68,58 +64,44 @@
 		continue;
-	if (KEY("offset"))
-	    if (sscanf(data, "%lf %lf", &(box->xset), &(box->yset)) != 2)
+	if (KEY("offset")) {
+	    if (sscanf(data, "%lf %lf", &(box->xset), &(box->yset)) != 2) {
 		error(key, data, "illegal box offset request");
 	    continue;
-	if (KEY("ref"))
-	    if (!scan_ref(data, &(box->xref), &(box->yref)))
+	if (KEY("ref")) {
+	    if (!scan_ref(data, &(box->xref), &(box->yref))) {
 		error(key, data, "illegal box ref request");
 	    continue;
-	if (KEY("border"))
-	    if (scan_dimen(data, &(box->border)) != 1)
+	if (KEY("border")) {
+	    if (scan_dimen(data, &(box->border)) != 1) {
 		box->border = -1;
 	    continue;
-	if (KEY("color"))
-	    if (!scan_color(data, &(box->color)))
+	    if (!scan_color(data, &(box->color))) {
 		error(key, data, "illegal box color request");
 	    continue;
-	if (KEY("fcolor"))
-	    if (!scan_color(data, &(box->fcolor)))
+	if (KEY("fcolor")) {
+	    if (!scan_color(data, &(box->fcolor))) {
 		error(key, data, "illegal box fcolor request");
 	    continue;
-	if (KEY("margin"))
-	    if (scan_dimen(data, &(box->margin)) != 1)
+	if (KEY("margin")) {
+	    if (scan_dimen(data, &(box->margin)) != 1) {
 		error(key, data, "illegal box margin request");
 	    continue;
-	if (KEY("rotate"))
-	    if (scan_dimen(data, &(box->rotate)) != 1)
+	if (KEY("rotate")) {
+	    if (scan_dimen(data, &(box->rotate)) != 1) {
 		error(key, data, "illegal box rotate request");
 	    continue;
Modified: grass-addons/postscript/ps.output/r_grid.c
--- grass-addons/postscript/ps.output/r_grid.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_grid.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,6 +21,7 @@
 int read_grid(GRID * grid, int type)
     char buf[1024];
     char *key, *data;
     G_debug(1, "Reading grid settings ..");
@@ -39,115 +40,92 @@
     grid->msubdiv = -1;
 	    continue;
-	if (KEY("major") || KEY("line"))
+	if (KEY("major") || KEY("line")) {
 	    char str[50];
-	    if (sscanf(data, "%s", str) != 1)
+	    if (sscanf(data, "%s", str) != 1) {
 		error(key, data, "illegal major request (grid)");
-	    if (G_projection() == PROJECTION_LL || type == 0)
+	    if (G_projection() == PROJECTION_LL || type == 0) {
 		double seconds;
 		scan_second(str, &seconds);
 		grid->sep = (int)seconds;
-	    else
+	    else {
 		grid->sep = atoi(str);	/* units, usually meters */
-	    if (grid->sep <= 0)
+	    if (grid->sep <= 0) {
 	    read_psline("", &(grid->line));
 	    continue;
-	if (KEY("minor"))
+	if (KEY("minor")) {
 	    char str[50];
 		error(key, data, "illegal minor request (grid)");
 		double seconds;
 		grid->msep = (int)seconds;
-	    else
+	    else {
 		grid->msep = atoi(str);	/* units, usually meters */
 	    read_psline("", &(grid->mline));
 	    continue;
-	if (KEY("subminor"))
+	if (KEY("subminor")) {
 	    G_strip(data);
 	    grid->msubdiv = atoi(data);
 	    continue;
-	if (KEY("format"))
+	if (KEY("format")) {
 	    G_strip(data);
-	    if (strncmp(data, "in", 2) == 0)
+	    if (strncmp(data, "in", 2) == 0) {
 		grid->format = 0;
-	    else if (strncmp(data, "out", 3) == 0)
+	    else if (strncmp(data, "out", 3) == 0) {
 		grid->format = 1;
-	    else if (strncmp(data, "+out", 4) == 0)
+	    else if (strncmp(data, "+out", 4) == 0) {
 		grid->format = 1;
 		grid->lsides = 4;
-	    else if (strcmp(data, "iho") == 0)
+	    else if (strcmp(data, "iho") == 0) {
 		grid->format = 2;
-	    else if (strcmp(data, "can") == 0)
+	    else if (strcmp(data, "can") == 0) {
 		grid->format = 3;
 	    else
 		grid->format = atoi(data);
 	    continue;
-	if (KEY("trim"))
+	if (KEY("trim")) {
 	    G_strip(data);
 	    grid->trim = atoi(data);
 	    continue;
-	if (KEY("font"))
+	if (KEY("font")) {
 	    read_font(data, &(grid->font));
 	    continue;
-	    if (!scan_color(data, &(grid->fcolor)))
+	    if (!scan_color(data, &(grid->fcolor))) {
 		error(key, data, "illegal fcolor request (grid)");
 	    continue;
-	if (KEY("cross"))
+	if (KEY("cross")) {
 	    grid->cross = atof(data);
 	    continue;
@@ -155,8 +133,7 @@
     /* swap major and minor if ... */
-    if (grid->sep < grid->msep)
+    if (grid->sep < grid->msep) {
 	int tmp;
 	tmp = grid->msep;
@@ -165,8 +142,7 @@
     /* draw minor? .... */
-    if (grid->mline.width <= 0. || grid->msep == 0)
+    if (grid->mline.width <= 0. || grid->msep == 0) {
 	grid->msep = 0;		/* dont draw minor grid */
Modified: grass-addons/postscript/ps.output/r_line.c
--- grass-addons/postscript/ps.output/r_line.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_line.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -31,7 +31,9 @@
 int read_psline(char *arg, PSLINE * line)
     char buf[1024];
     char *key, *data;
     char i, dash[31];
     G_debug(1, "Reading line settings ..");
@@ -40,10 +42,8 @@
     default_psline(line);
     /* inline argument: width */
-    if (arg[0] != 0)
-	if (scan_dimen(arg, &(line->width)) != 1)
+    if (arg[0] != 0) {
+	if (scan_dimen(arg, &(line->width)) != 1) {
 	    line->width = 1.;
 	    error("ERROR:", arg, "illegal line width request");
@@ -51,37 +51,30 @@
 	    continue;
-	if (KEY("width"))
-	    if (scan_dimen(data, &(line->width)) != 1)
+	if (KEY("width")) {
+	    if (scan_dimen(data, &(line->width)) != 1) {
 		line->width = -1.;
 		error(key, data, "illegal line width request");
 	    continue;
-	if (KEY("color"))
-	    if (!scan_color(data, &(line->color)))
+	    if (!scan_color(data, &(line->color))) {
 		error(key, data, "illegal line color request");
 	    continue;
-	if (KEY("style"))
+	if (KEY("style")) {
 	    char str[50];
 	    int x, o;
 	    x = sscanf(data, "%s %s", str, &o);
-	    if (x != 1 && x != 2)
+	    if (x != 1 && x != 2) {
 		error(key, data, "illegal line style request");
 		continue;
@@ -89,37 +82,31 @@
 		line->odash = o;
 	    G_strip(str);
-	    if (strncmp(str, "solid", 5) == 0)
+	    if (strncmp(str, "solid", 5) == 0) {
 		line->dash = G_store("");
 		continue;
-	    else if (strncmp(str, "dashed", 5) == 0)
+	    else if (strncmp(str, "dashed", 5) == 0) {
 		line->dash = G_store("3 2");
 		continue;
-	    else if (strncmp(str, "dotted", 3) == 0)
+	    else if (strncmp(str, "dotted", 3) == 0) {
 		line->dash = G_store("1");
 		continue;
-	    else if (strncmp(str, "dashdotted", 5) == 0)
+	    else if (strncmp(str, "dashdotted", 5) == 0) {
 		line->dash = G_store("4 2 1 2");
 		continue;
 	    char *dp;
-	    for (i = 0, dp = str; *dp && i < 20; dp++)
+	    for (i = 0, dp = str; *dp && i < 20; dp++) {
 		if (*dp < '0' || *dp > '9')
 		    break;
 		dash[i++] = *dp;
 		dash[i++] = ' ';
-	    if (i == 0)
+	    if (i == 0) {
 		error(key, str, "illegal line style");
 		continue;
@@ -127,21 +114,17 @@
 	    line->dash = G_store(dash);
 	    continue;
-	if (KEY("cap"))
+	if (KEY("cap")) {
 	    G_strip(data);
-	    if (strncmp(data, "butt", 2) == 0)
+	    if (strncmp(data, "butt", 2) == 0) {
 		line->cap = LINECAP_BUTT;
 		continue;
-	    else if (strncmp(data, "round", 2) == 0)
+	    else if (strncmp(data, "round", 2) == 0) {
 		line->cap = LINECAP_ROUND;
 		continue;
-	    else if (strncmp(data, "extended_butt", 2) == 0)
+	    else if (strncmp(data, "extended_butt", 2) == 0) {
 		line->cap = LINECAP_EXTBUTT;
 		continue;
Modified: grass-addons/postscript/ps.output/r_maparea.c
--- grass-addons/postscript/ps.output/r_maparea.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_maparea.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,7 +21,9 @@
 int read_maparea(void)
     char buf[1024];
     char *key, *data;
     double point;
     G_debug(1, "Reading maparea settings ..");
@@ -30,70 +32,54 @@
     default_psline(&(PS.brd));
 	    continue;
-	    if (scan_dimen(data, &(point)) != 1)
+	    if (scan_dimen(data, &(point)) != 1) {
 		error(key, data, "illegal border width request (maparea)");
 	    PS.brd.width = point;
 	    PS.do_border = 1;
 	    continue;
-	if (KEY("color"))
-	    if (!scan_color(data, &(PS.brd.color)))
+	    if (!scan_color(data, &(PS.brd.color))) {
 		error(key, data, "illegal border color request (maparea)");
 	    continue;
-	    if (!scan_color(data, &(PS.fcolor)))
+	    if (!scan_color(data, &(PS.fcolor))) {
 		error(key, data, "illegal fcolor request (maparea)");
 	    continue;
-	if (KEY("width"))
 		error(key, data, "illegal map width request (maparea)");
 	    PS.map_w = point;
 	    continue;
-	if (KEY("height"))
+	if (KEY("height")) {
 		error(key, data, "illegal map height request (maparea)");
 	    PS.map_h = point;
 	    continue;
-	if (KEY("top"))
+	if (KEY("top")) {
 		error(key, data, "illegal map top request (maparea)");
 	    PS.map_top = point;
 	    continue;
 	    continue;
-	if (KEY("left"))
+	if (KEY("left")) {
 		error(key, data, "illegal map left request (maparea)");
 	    PS.map_x = point;
Modified: grass-addons/postscript/ps.output/r_note.c
--- grass-addons/postscript/ps.output/r_note.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_note.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -22,6 +22,7 @@
 int read_note(char *name)
     char buf[1024];
     char *key, *data;
     G_debug(1, "Reading note settings ..");
@@ -34,56 +35,44 @@
     default_frame(&(PS.note[PS.n_notes].box), LEFT, UPPER);
     /* inline argument */
-    if (*name != 0)
+    if (*name != 0) {
 	strncpy(PS.note[PS.n_notes].text, name, 1024);
 	PS.note[PS.n_notes].text[1023] = 0;
 	    continue;
-	if (KEY("frame"))
+	if (KEY("frame")) {
 	    read_frame(&(PS.note[PS.n_notes].box));
 	    continue;
-	if (KEY("font"))
 	    read_font(data, &(PS.note[PS.n_notes].font));
 	    continue;
-	if (KEY("text"))
-	    if (sscanf(data, "%s", PS.note[PS.n_notes].text) != 1)
+	if (KEY("text")) {
+	    if (sscanf(data, "%s", PS.note[PS.n_notes].text) != 1) {
 		PS.note[PS.n_notes].text[0] = 0;
 		error(key, data, "illegal note sub-request");
-	    else
+	    else {
 		strncpy(PS.note[PS.n_notes].text, data, 1024);
 	    continue;
-	if (KEY("width"))
-	    if (scan_dimen(data, &(PS.note[PS.n_notes].width)) != 1)
+	    if (scan_dimen(data, &(PS.note[PS.n_notes].width)) != 1) {
 		PS.note[PS.n_notes].width = 0.;
 		error(key, data, "illegal width sub-request");
 	    continue;
-	if (KEY("angle"))
-	    if (sscanf(data, "%lf", &(PS.note[PS.n_notes].angle)) != 1)
+	if (KEY("angle")) {
+	    if (sscanf(data, "%lf", &(PS.note[PS.n_notes].angle)) != 1) {
 		PS.note[PS.n_notes].angle = 0.;
 		error(key, data, "illegal angle sub-request");
Modified: grass-addons/postscript/ps.output/r_palette.c
--- grass-addons/postscript/ps.output/r_palette.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_palette.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -26,119 +26,110 @@
 int read_palette(void)
     char buf[1024];
     char *key, *data;
     int i;
     char name[50];
     PSCOLOR color, colorb;
     G_debug(1, "Reading palette settings ..");
 	    continue;
-	if (KEY("wheel", 2))
-	    if (sscanf(data, "%d %s", &i, name) != 2 || i < 2)
-            error(key, data, "illegal wheel sub-request (palette)");
+	if (KEY("wheel", 2)) {
+	    if (sscanf(data, "%d %s", &i, name) != 2 || i < 2) {
+		error(key, data, "illegal wheel sub-request (palette)");
 	    pure_color(name, i);
 	    continue;
-	if (KEY("monochrome", 4))
+	if (KEY("monochrome", 4)) {
 	    char color_name[50];
-	    if (sscanf(data, "%s %d %s", color_name, &i, name) != 3)
-            error(key, data, "illegal monochrome sub-request (palette)");
+	    if (sscanf(data, "%s %d %s", color_name, &i, name) != 3) {
+		error(key, data, "illegal monochrome sub-request (palette)");
-	    if (i < 1 || !scan_color(color_name, &color))
+	    if (i < 1 || !scan_color(color_name, &color)) {
 	    monochrome(name, &color, i);
 	    continue;
-	if (KEY("complementary", 4))
+	if (KEY("complementary", 4)) {
-            error(key, data, "illegal complementary sub-request (palette)");
+		error(key, data,
+		      "illegal complementary sub-request (palette)");
+		error(key, data,
 	    complementary(name, &color, i, 90.);
 	    continue;
-    if (KEY("analogous", 3))
-        char color_name[50];
+	if (KEY("analogous", 3)) {
+	    char color_name[50];
-            error(key, data, "illegal analogous sub-request (palette)");
-        analogous(name, &color, i, 90.);
-        continue;
-    if (KEY("pure_gradient", 4))
-        char A_name[50], B_name[50];
+		error(key, data, "illegal analogous sub-request (palette)");
+	    analogous(name, &color, i, 90.);
+	    continue;
+	if (KEY("pure_gradient", 4)) {
+	    char A_name[50], B_name[50];
-        if (sscanf(data, "%s %s %d %s", A_name, B_name, &i, name) != 4)
-            error(key, data, "illegal pure_gradient sub-request (palette)");
-        if (i < 3 || !scan_color(A_name, &color) || !scan_color(B_name, &colorb))
-        gradient(name, &color, &colorb, i, 1);
-        continue;
-	if (KEY("gradient", 4))
+	    if (sscanf(data, "%s %s %d %s", A_name, B_name, &i, name) != 4) {
+		error(key, data,
+		      "illegal pure_gradient sub-request (palette)");
+	    if (i < 3 || !scan_color(A_name, &color) ||
+		!scan_color(B_name, &colorb)) {
+		error(key, data,
+	    gradient(name, &color, &colorb, i, 1);
+	    continue;
+	if (KEY("gradient", 4)) {
-            error(key, data, "illegal gradient sub-request (palette)");
+		error(key, data, "illegal gradient sub-request (palette)");
 	    gradient(name, &color, &colorb, i, 0);
 	    continue;
-    if (KEY("diverging", 4))
+	if (KEY("diverging", 4)) {
-            error(key, data, "illegal xxx diverging sub-request (palette)");
-            error(key, data, "illegal yyy diverging sub-request (palette)");
-        diverging(name, &color, &colorb, i);
-        continue;
+		error(key, data,
+		      "illegal xxx diverging sub-request (palette)");
+		error(key, data,
+		      "illegal yyy diverging sub-request (palette)");
+	    diverging(name, &color, &colorb, i);
+	    continue;
 	error(key, data, "illegal zzz palette sub-request");
Modified: grass-addons/postscript/ps.output/r_paper.c
--- grass-addons/postscript/ps.output/r_paper.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_paper.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -18,15 +18,17 @@
 int read_paper(char *arg)
     char buf[1024];
     char *key, *data;
     int do_landscape;
     double point;
     G_debug(1, "Reading paper settings ..");
     /* default values */
-    if (arg[0] != 0)
 	set_paper(arg);
     do_landscape = 0;
@@ -34,94 +36,74 @@
     /* init values */
     unset_color(&(PS.page.fcolor));	/* no paper color */
 	    continue;
-	if (KEY("color"))
-	    if (!scan_color(data, &(PS.page.fcolor)))
+	    if (!scan_color(data, &(PS.page.fcolor))) {
 	    continue;
-	if (KEY("width"))
 		error(key, data, "illegal paper width request");
 	    PS.page.width = (int)(point);
 	    continue;
 	    PS.page.height = (int)(point);
 	    continue;
-	if (KEY("left"))
 	    PS.page.left = point;
 	    continue;
-	if (KEY("right"))
+	if (KEY("right")) {
 	    PS.page.right = point;
 	    continue;
-	if (KEY("top"))
+	if (KEY("top")) {
 	    PS.page.top = point;
 	    continue;
-	if (KEY("bottom"))
+	if (KEY("bottom")) {
 	    PS.page.bot = point;
 	    continue;
-	if (KEY("landscape"))
+	if (KEY("landscape")) {
 	    do_landscape = scan_yesno(key, data);
 	    continue;
-	if (KEY("font"))
 	    read_font(data, &(PS.font));
 	    continue;
-	if (KEY("draw"))
 	    read_draw("paper");
 	    continue;
 	error(key, data, "illegal paper sub-request");
-    if (do_landscape != 0)
+    if (do_landscape != 0) {
 	int tmp;
 	tmp = PS.page.width;
@@ -129,7 +111,8 @@
 	PS.page.height = tmp;
-    G_debug(1, "Setting paper: %.1f %.1f : %d %d\n", PS.page.left, PS.page.top, PS.page.width, PS.page.height);
+    G_debug(1, "Setting paper: %.1f %.1f : %d %d\n", PS.page.left,
+	    PS.page.top, PS.page.width, PS.page.height);
     return 0;
Modified: grass-addons/postscript/ps.output/r_raster.c
--- grass-addons/postscript/ps.output/r_raster.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_raster.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -20,8 +20,11 @@
 int read_raster(char *arg)
     char buf[1024];
     char *key, *data;
     char name[3][100];
     int ret;
     G_debug(1, "Reading raster settings ..");
@@ -36,24 +39,19 @@
     ret = sscanf(arg, "%s %s %s", name[0], name[1], name[2]);
-    if (ret != 1 && ret != 3)
+    if (ret != 1 && ret != 3) {
 	error(key, data, "illegal raster request");
-    if (ret == 3)
+    if (ret == 3) {
 	PS.rst.files = load_rgb(name[0], name[1], name[2]);
 	PS.rst.do_rgb = 1;
-    else
-	if (name[0][0] == ':')
+    else {
+	if (name[0][0] == ':') {
 	    PS.rst.files = load_group(name[0] + 1);
 	    PS.rst.do_rgb = 1;
-	else
+	else {
 	    PS.rst.files = load_cell(0, name[0]);
 	    PS.rst.fd[1] = PS.rst.fd[2] = -1;
 	    PS.rst.do_rgb = 0;
@@ -61,34 +59,26 @@
 	    continue;
-	if (KEY("grey") || KEY("gray"))
+	if (KEY("grey") || KEY("gray")) {
 	    PS.rst.do_grey = scan_yesno(key, data);
 	    continue;
-	if (KEY("maskcolor"))
-	    if (!scan_color(data, &(PS.rst.mask_color)))
+	if (KEY("maskcolor")) {
+	    if (!scan_color(data, &(PS.rst.mask_color))) {
 		error(key, data, "illegal raster mask color request");
 	    continue;
-	if (KEY("maskcell"))
-	    if (PS.rst.do_rgb)
+	if (KEY("maskcell")) {
+	    if (PS.rst.do_rgb) {
 		error(key, data, "illegal maskcell with rgb/group raster");
 	    ret = sscanf(data, "%s %s", name[1], name[2]);
-	    if (ret != 1 && ret != 2)
+	    if (ret != 1 && ret != 2) {
 		error(key, data, "illegal maskcell raster request");
 	    PS.rst.do_mask = 1;
@@ -97,58 +87,52 @@
 		load_cell(2, name[2]);	/* slot 2: background */
 	    continue;
-	if (KEY("outline"))
+	if (KEY("outline")) {
 		error(key, data, "illegal outline with rgb raster");
 	    read_psline(data, &(PS.rst.outline));
 	    continue;
-	if (KEY("setcolor"))
+	if (KEY("setcolor")) {
 	    int i, count, R, G, B;
 	    PSCOLOR color;
 	    DCELL *val_list, dmin, dmax;
 	    char colorbuf[100], catsbuf[100];
 	    /* set color inline */
-	    if (PS.rst.fd[0] < 0 || PS.rst.do_rgb)
+	    if (PS.rst.fd[0] < 0 || PS.rst.do_rgb) {
 		error(key, data, "setcolor is not for RGB raster");
-	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2)
-		if (!scan_color(colorbuf, &color))
+	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2) {
+		if (!scan_color(colorbuf, &color)) {
 		    error(key, data, "illegal setcolor request");
 		    continue;
 		R = (int)(255. * color.r);
 		G = (int)(255. * color.g);
 		B = (int)(255. * color.b);
-		if (strncmp(catsbuf, "null", 4) == 0)
+		if (strncmp(catsbuf, "null", 4) == 0) {
 		    G_set_null_value_color(R, G, B, &(PS.rst.colors[0]));
 		    continue;
-		if (strncmp(catsbuf, "default", 7) == 0)
+		if (strncmp(catsbuf, "default", 7) == 0) {
 		    G_set_default_color(R, G, B, &(PS.rst.colors[0]));
 		    continue;
-		if ((count = parse_val_list(catsbuf, &val_list)) < 0)
+		if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
 		    /* G_free(val_list); */
 		    error(key, data, "illegal value list");
 		    continue;
-		for (i = 0; i < count; i += 2)
+		for (i = 0; i < count; i += 2) {
 		    dmin = val_list[i];
 		    dmax = val_list[i + 1];
-		    G_add_d_raster_color_rule(&dmin, R, G, B, &dmax, R, G, B, &(PS.rst.colors[0]));
+		    G_add_d_raster_color_rule(&dmin, R, G, B, &dmax, R, G, B,
+					      &(PS.rst.colors[0]));
 		G_free(val_list);
Modified: grass-addons/postscript/ps.output/r_rlegend.c
--- grass-addons/postscript/ps.output/r_rlegend.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_rlegend.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -20,7 +20,9 @@
 int read_rlegend(char *arg)
     char buf[1024];
     char *key, *data, *mapset;
     double dimen;
     G_debug(1, "Reading rlegend settings ..");
@@ -45,45 +47,37 @@
     strncpy(PS.rl.legend.title, arg, TITLE_LEN);
 	    continue;
-	if (KEY("title"))
+	if (KEY("title")) {
 	    G_strip(data);
 	    read_font(data, &(PS.rl.legend.title_font));
 	    continue;
-	if (KEY("font"))
 	    G_strip(data);
 	    read_font(data, &(PS.rl.legend.font));
 	    continue;
-	if (KEY("frame"))
 	    read_frame(&(PS.rl.legend.box));
 	    continue;
-    if (KEY("swidth"))
-	    if (scan_dimen(data, &(PS.rl.legend.width)) != 1)
+	if (KEY("swidth")) {
+	    if (scan_dimen(data, &(PS.rl.legend.width)) != 1) {
 		PS.rl.legend.width = -1.;
 		error(key, data, "illegal width request (rlegend)");
 	    continue;
-	if (KEY("cols"))
 	    int n;
-	    n = sscanf(data, "%d %lf", &(PS.rl.legend.cols), &(PS.rl.legend.xspan));
-	    if (n == 1 || n == 2)
+	    n = sscanf(data, "%d %lf", &(PS.rl.legend.cols),
+		       &(PS.rl.legend.xspan));
+	    if (n == 1 || n == 2) {
 		if (PS.rl.legend.cols < 0)
 		    PS.rl.legend.cols = 1;
 		if (n == 1)
@@ -93,20 +87,16 @@
 		error(key, data, "illegal cols/span request (rlegend)");
 	    continue;
-	    if (scan_dimen(data, &(PS.rl.height)) != 1)
+	    if (scan_dimen(data, &(PS.rl.height)) != 1) {
 		error(key, data, "illegal height request (rlegend)");
 	    continue;
-	if (KEY("raster"))
+	if (KEY("raster")) {
 	    G_strip(data);
 	    mapset = G_find_file("cell", data, "");
-	    if (PS.rl.mapset == NULL)
+	    if (PS.rl.mapset == NULL) {
 		PS.rl.name[0] = 0;
 		error(key, data, "illegal raster request (rlegend)");
@@ -114,20 +104,16 @@
 	    strcpy(PS.rl.mapset, mapset);
 	    continue;
-	if (KEY("range"))
-	    if (sscanf(data, "%lf %lf", &(PS.rl.min), &(PS.rl.max)) != 2)
+	if (KEY("range")) {
+	    if (sscanf(data, "%lf %lf", &(PS.rl.min), &(PS.rl.max)) != 2) {
 		PS.rl.custom_range = FALSE;
 		error(key, data, "illegal range request (rlegend)");
-	    else
+	    else {
 		double tmpD;
 		PS.rl.custom_range = TRUE;
-		if (PS.rl.min > PS.rl.max)
+		if (PS.rl.min > PS.rl.max) {
 		    tmpD = PS.rl.min;
 		    PS.rl.min = PS.rl.max;
 		    PS.rl.max = tmpD;
@@ -135,36 +121,29 @@
 		continue;
-	if (KEY("nodata"))
+	if (KEY("nodata")) {
 	    PS.rl.do_nodata = scan_yesno(key, data);
 	    continue;
-	if (KEY("gradient"))
+	if (KEY("gradient")) {
 	    PS.rl.do_gradient = scan_yesno(key, data);
 	    continue;
-	if (KEY("tick"))
-	    if (scan_dimen(data, &dimen) != 1)
+	if (KEY("tick")) {
+	    if (scan_dimen(data, &dimen) != 1) {
 		error(key, data, "illegal tickbar request (rlegend)");
 	    PS.rl.tickbar = (int)(dimen);
 	    continue;
-	if (KEY("whiteframe"))
+	if (KEY("whiteframe")) {
 		error(key, data, "illegal whiteframe request (rlegend)");
 	    PS.rl.whiteframe = (int)(dimen);
 	    continue;
-	if (KEY("order"))
+	if (KEY("order")) {
 	    G_strip(data);
 	    strncpy(PS.rl.cat_order, data, MAX_CATS);
 	    //            PS.rl.cat_order[510] = 0;
@@ -174,8 +153,7 @@
     /* end check */
-    if (!PS.rl.name)
+    if (!PS.rl.name) {
 	PS.do_rlegend = 0;
 	error(key, data, "rlegend need 'raster' option sub-request");
Modified: grass-addons/postscript/ps.output/r_scalebar.c
--- grass-addons/postscript/ps.output/r_scalebar.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_scalebar.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -23,6 +23,7 @@
 int read_scalebar(void)
     char buf[1024];
     char *key, *data;
     G_debug(1, "Reading scalebar settings ..");
@@ -41,52 +42,40 @@
     set_color_rgb(&(PS.sbar.fcolor), 255, 255, 255);
 	    continue;
-	if (KEY("frame"))
 	    read_frame(&(PS.sbar.box));
 	    continue;
-	if (KEY("font"))
 	    read_font(data, &(PS.sbar.font));
 	    continue;
-	    if (!scan_color(data, &(PS.sbar.fcolor)))
+	    if (!scan_color(data, &(PS.sbar.fcolor))) {
 		error(key, data, "illegal fcolor request (scalebar)");
 	    continue;
-	    if (scan_dimen(data, &(PS.sbar.height)) != 1)
+	    if (scan_dimen(data, &(PS.sbar.height)) != 1) {
 		error(key, data, "illegal height request (scalebar)");
 	    continue;
-	if (KEY("length"))
-	    if (scan_dimen(data, &(PS.sbar.length)) != 1)
+	if (KEY("length")) {
+	    if (scan_dimen(data, &(PS.sbar.length)) != 1) {
 		error(key, data, "illegal length request (scalebar)");
 	    continue;
-	if (KEY("major") || KEY("segments"))
+	if (KEY("major") || KEY("segments")) {
 	    int i, j;
-	    switch (sscanf(data, "%d %d", &i, &j))
+	    switch (sscanf(data, "%d %d", &i, &j)) {
 	    case 1:
 		PS.sbar.segments = ABS(i);
 		PS.sbar.labels = 1;
@@ -101,12 +90,10 @@
 	    continue;
-	if (KEY("minor"))
 	    int i, j;
 	    case 1:
 		PS.sbar.subsegs = ABS(i);
 		PS.sbar.sublabs = 1;
@@ -121,54 +108,48 @@
 	    continue;
-	if (KEY("units"))
+	if (KEY("units")) {
 	    int ret;
 	    char stra[50], strb[50];
 	    G_strip(data);
 	    ret = sscanf(data, "%s %s", stra, strb);
 		error(key, data, "illegal units request (scalebar)");
-	    if (strcmp(stra, "auto") == 0)
+	    if (strcmp(stra, "auto") == 0) {
 		PS.sbar.units[0] = 0;
 		PS.sbar.ucode = SB_UNITS_AUTO;
 		continue;
-	    else if (G_projection() == PROJECTION_XY)
-		error(key, data, "Earth units not available in simple XY location");
+	    else if (G_projection() == PROJECTION_XY) {
+		error(key, data,
+		      "Earth units not available in simple XY location");
-	    else if (strcmp(stra, "meters") == 0 || strcmp(stra, "m") == 0)
+	    else if (strcmp(stra, "meters") == 0 || strcmp(stra, "m") == 0) {
 		strcpy(PS.sbar.units, "meters");
 		PS.sbar.ucode = SB_UNITS_METERS;
-	    else if (strcmp(stra, "kilometers") == 0 || strcmp(stra, "km") == 0)
+	    else if (strcmp(stra, "kilometers") == 0 ||
+		     strcmp(stra, "km") == 0) {
 		strcpy(PS.sbar.units, "kilometers");
 		PS.sbar.ucode = SB_UNITS_KM;
-	    else if (strcmp(stra, "feet") == 0 || strcmp(stra, "ft") == 0)
+	    else if (strcmp(stra, "feet") == 0 || strcmp(stra, "ft") == 0) {
 		strcpy(PS.sbar.units, "feet");
 		PS.sbar.ucode = SB_UNITS_FEET;
-	    else if (strcmp(stra, "miles") == 0 || strcmp(stra, "mil") == 0)
+	    else if (strcmp(stra, "miles") == 0 || strcmp(stra, "mil") == 0) {
 		strcpy(PS.sbar.units, "miles");
 		PS.sbar.ucode = SB_UNITS_MILES;
-	    else if (strcmp(stra, "nautmiles") == 0 || strcmp(stra, "nm") == 0)
+	    else if (strcmp(stra, "nautmiles") == 0 ||
+		     strcmp(stra, "nm") == 0) {
 		strcpy(PS.sbar.units, "nautical miles");
 		PS.sbar.ucode = SB_UNITS_NMILES;
-	    else
+	    else {
 	    if (ret == 2)
Modified: grass-addons/postscript/ps.output/r_vareas.c
--- grass-addons/postscript/ps.output/r_vareas.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_vareas.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,32 +21,32 @@
 int read_vareas(char *name)
     int i;
     char buf[1024];
-    VAREAS * vector = NULL;
+    VAREAS *vector = NULL;
     G_debug(1, "Reading vareas settings ..");
     i = vector_new();		/* G_realloc */
     default_vector(i);
-    if (strcmp(name, "(none)") != 0)
-        mapset = G_find_vector(name, "");
-	if (mapset == NULL)
+    if (strcmp(name, "(none)") != 0) {
+	mapset = G_find_vector(name, "");
+	if (mapset == NULL) {
 	    error("ERROR:", name, "Can't find vector map");
 	PS.vct[i].name = G_store(name);
 	PS.vct[i].mapset = G_store(mapset);
 	PS.vct[i].data = G_malloc(sizeof(VAREAS));
-        Vect_set_open_level(2);	/* level 2: topology */
+	Vect_set_open_level(2);	/* level 2: topology */
 	Vect_set_fatal_error(GV_FATAL_PRINT);
-	if (2 > Vect_open_old(&(PS.vct[i].Map), name, mapset))
+	if (2 > Vect_open_old(&(PS.vct[i].Map), name, mapset)) {
 	    sprintf(buf, "%s in %s", name, mapset);
 	    error("ERROR:", buf, "can't open vector map");
 	    return 0;
@@ -64,112 +64,97 @@
     vector->sc_pat = 1.;
     vector->island = 1;
     vector->rgbcol = NULL;
-    vector->idcol  = NULL;
+    vector->idcol = NULL;
 	    continue;
-	if (KEY("lwidth"))
+	if (KEY("lwidth")) {
 	    G_strip(data);
-            if (scan_dimen(data, &(vector->width)) != 1)
-                error(key, data, "illegal 'lwidth' width (vareas)");
+	    if (scan_dimen(data, &(vector->width)) != 1)
+		error(key, data, "illegal 'lwidth' width (vareas)");
 	    continue;
-	if (KEY("line"))
+	if (KEY("line")) {
 	    read_psline(data, &(vector->line));
 	    continue;
 	    int ret = sscanf(data, "%s %[^\n]", stra, strb);
-            if (ret == 1 || ret == 2)
-                if (!scan_color(stra, &(vector->fcolor)))
-                    double alpha;
-                    if (ret == 2)
-                        vector->idcol = G_store(strb);
+	    if (ret == 1 || ret == 2) {
+		if (!scan_color(stra, &(vector->fcolor))) {
+		    double alpha;
-                    ret = sscanf(stra, "%[^$]$%lf", strb, &alpha);
-                    vector->rgbcol = G_store(strb);
-                    vector->fcolor.a = (ret == 2) ? alpha : 1.;
-                    G_message(" >>> Request fcolor from column '%s' (vareas)", vector->rgbcol);
-                    vector->type_pat = 2;	/* uncolored pattern */
-            else
-                error(key, data, "illegal data in 'fcolor' (vareas)");
+		    if (ret == 2)
+			vector->idcol = G_store(strb);
+		    ret = sscanf(stra, "%[^$]$%lf", strb, &alpha);
+		    vector->rgbcol = G_store(strb);
+		    vector->fcolor.a = (ret == 2) ? alpha : 1.;
+		    G_message(" >>> Request fcolor from column '%s' (vareas)",
+			      vector->rgbcol);
+		    vector->type_pat = 2;	/* uncolored pattern */
+	    else {
+		error(key, data, "illegal data in 'fcolor' (vareas)");
 	    continue;
-	if (KEY("pat"))
+	if (KEY("pat")) {
 	    G_chop(data);
 	    vector->name_pat = G_store(data);
 	    continue;
-	if (KEY("pscale"))
+	if (KEY("pscale")) {
 	    G_chop(data);
 	    vector->sc_pat = atof(data);
 	    continue;
-	if (KEY("pwidth"))
+	if (KEY("pwidth")) {
 	    if (scan_dimen(data, &(vector->lw_pat)) != 1)
 		error(key, data, "illegal pattern width (vareas)");
 	    continue;
-	if (KEY("island"))
+	if (KEY("island")) {
 	    vector->island = scan_yesno(key, data);
 	    continue;
 	/* common options of all vectors */
-	if (KEY("layer"))
+	if (KEY("layer")) {
 	    G_strip(data);
 	    PS.vct[i].layer = atoi(data);
 	    if (PS.vct[i].layer < 1)
 		PS.vct[i].layer = 1;
 	    continue;
-	if (KEY("cats") || KEY("cat"))
+	if (KEY("cats") || KEY("cat")) {
 	    G_strip(data);
 	    PS.vct[i].cats = G_store(data);
 	    continue;
-	if (KEY("where"))
 	    G_strip(data);
 	    PS.vct[i].where = G_store(data);
 	    continue;
-	if (KEY("masked"))
+	if (KEY("masked")) {
 	    PS.vct[i].masked = scan_yesno(key, data);
 	    if (PS.vct[i].masked)
 		PS.need_mask = 1;
 	    continue;
-	if (KEY("label"))
+	if (KEY("label")) {
 	    G_strip(data);
 	    PS.vct[i].label = G_store(data);
 	    continue;
-	if (KEY("legend") || KEY("lpos"))
+	if (KEY("legend") || KEY("lpos")) {
 	    int k;
 	    if (sscanf(data, "%d", &k) == 1)
@@ -178,37 +163,34 @@
 		read_block(i);
 	    continue;
-	if (KEY("setrule"))
-            double val;
-            char str[128], catsbuf[128], labelbuf[128];
+	if (KEY("setrule")) {
+	    double val;
-            if (sscanf(data, "%s %[^\n]", str, labelbuf) > 0)
-                if (sscanf(str, "%[^:]:%lf", catsbuf, &val) == 1)
-                    val = 0.;
-                vector_rule_new(&(PS.vct[i]), catsbuf, labelbuf, val);
-            else
-                error(key, data, "illegal 'setrule' request (vareas)");
-            continue;
+	    char str[128], catsbuf[128], labelbuf[128];
+	    if (sscanf(data, "%s %[^\n]", str, labelbuf) > 0) {
+		if (sscanf(str, "%[^:]:%lf", catsbuf, &val) == 1)
+		    val = 0.;
+		vector_rule_new(&(PS.vct[i]), catsbuf, labelbuf, val);
+	    else
+		error(key, data, "illegal 'setrule' request (vareas)");
+	    continue;
 	error(key, "", "illegal request (vareas)");
     /* default label */
-    if (PS.vct[i].label == NULL)
+    if (PS.vct[i].label == NULL) {
 	sprintf(buf, "%s (%s)", PS.vct[i].name, PS.vct[i].mapset);
 	PS.vct[i].label = G_store(buf);
-    if (vector->rgbcol == NULL)
-        vector_item_new(&(PS.vct[i]), 0, color_to_long(&(vector->fcolor)));
+    if (vector->rgbcol == NULL) {
+	vector_item_new(&(PS.vct[i]), 0, color_to_long(&(vector->fcolor)));
        int x, y;
        for (x = 0; x < PS.vct[i].n_rule; x++)
@@ -220,7 +202,7 @@
        PS.vct[i].rule[x].value, PS.vct[i].rule[x].label);
     return 1;
Modified: grass-addons/postscript/ps.output/r_vlabels.c
--- grass-addons/postscript/ps.output/r_vlabels.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_vlabels.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,8 +21,11 @@
 int read_vlabels(char *name)
     int i;
     char buf[1024];
     VLABELS *vector;
@@ -31,11 +34,9 @@
@@ -45,8 +46,7 @@
 	    return 0;
@@ -66,84 +66,70 @@
     vector->style = 0;
 	    continue;
-	if (KEY("font"))
 	    read_font(data, &(vector->font));
 	    continue;
-	if (KEY("labelcol"))
+	if (KEY("labelcol")) {
 	    G_strip(data);
 	    vector->labelcol = G_store(data);
-	    G_warning("Request label column from database '%s' (vlabel)", vector->labelcol);
+	    G_warning("Request label column from database '%s' (vlabel)",
+		      vector->labelcol);
 	    continue;
-	if (KEY("decimals"))
+	if (KEY("decimals")) {
 	    vector->decimals = atoi(data);
 	    continue;
-        if (KEY("circled"))
-            scan_dimen(data, &(vector->style));
+	if (KEY("circled")) {
+	    scan_dimen(data, &(vector->style));
 	    continue;
-	if (KEY("layer"))
 	    G_strip(data);
 	    continue;
 	    G_strip(data);
 	    continue;
-	if (KEY("where"))
 	    G_strip(data);
 	    continue;
 		PS.need_mask = 1;
 	    continue;
-	if (KEY("label"))
 	    G_strip(data);
 	    continue;
 	    int k;
-	    if (sscanf(data, "%d", &k) == 1)
+	    if (sscanf(data, "%d", &k) == 1) {
 		PS.vct[i].lpos = k;
-	    else
+	    else {
 		read_block(i);
 	    continue;
 	    char catsbuf[128], labelbuf[128];
 	    sscanf(data, "%s %[^\n]", catsbuf, labelbuf);
@@ -154,13 +140,12 @@
     /* default label */
-    PS.vct[i].lpos = -1; /* Not in legends */
+    PS.vct[i].lpos = -1;	/* Not in legends */
     return 1;
Modified: grass-addons/postscript/ps.output/r_vlegend.c
--- grass-addons/postscript/ps.output/r_vlegend.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_vlegend.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -19,6 +19,7 @@
 int read_vlegend(char *arg)
     char buf[1024];
     char *key, *data;
@@ -36,61 +37,50 @@
     PS.vl.legend.yspan = -1;
     /* process options */
-	if (!key_data(buf, &key, &data))
+	if (!key_data(buf, &key, &data)) {
 	    continue;
-	if (KEY("title") || KEY("title_font"))
+	if (KEY("title") || KEY("title_font")) {
 	    G_strip(data);
 	    read_font(data, &(PS.vl.legend.title_font));
 	    continue;
-	if (KEY("font"))
 	    read_font(data, &(PS.vl.legend.font));
 	    continue;
-	if (KEY("frame"))
 	    read_frame(&(PS.vl.legend.box));
 	    continue;
-        if (KEY("cols"))
-                           &(PS.vl.legend.cols), &(PS.vl.legend.xspan));
+	    int n = sscanf(data, "%d %lf",
+			   &(PS.vl.legend.cols), &(PS.vl.legend.xspan));
-                if (PS.vl.legend.cols <= 0)
-                    PS.vl.legend.cols = 1;
-                if (n == 1)
-                    PS.vl.legend.xspan = -1.;
-            else
-                error(key, data, "illegal cols/xspan request (vlegend)");
-            continue;
-            if (scan_dimen(data, &(PS.vl.legend.width)) != 1)
-                PS.vl.legend.width = -1.;
-                error(key, data, "illegal swidth request (vlegend)");
-            continue;
-            if (scan_dimen(data, &(PS.vl.legend.yspan)) != 1)
-                error(key, data, "illegal interline request (vlegend)");
-            continue;
+		if (PS.vl.legend.cols <= 0)
+		    PS.vl.legend.cols = 1;
+		if (n == 1)
+		    PS.vl.legend.xspan = -1.;
+	    else
+		error(key, data, "illegal cols/xspan request (vlegend)");
+	    continue;
+	    if (scan_dimen(data, &(PS.vl.legend.width)) != 1) {
+		PS.vl.legend.width = -1.;
+		error(key, data, "illegal swidth request (vlegend)");
+	    continue;
+	    if (scan_dimen(data, &(PS.vl.legend.yspan)) != 1) {
+		error(key, data, "illegal interline request (vlegend)");
+	    continue;
 	error(key, data, "illegal vlegend sub-request");
Modified: grass-addons/postscript/ps.output/r_vlines.c
--- grass-addons/postscript/ps.output/r_vlines.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_vlines.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,8 +21,11 @@
 int read_vlines(char *name)
     int i;
     char buf[1024];
     VLINES *vector;
@@ -31,11 +34,9 @@
@@ -45,8 +46,7 @@
 	    return 0;
@@ -68,14 +68,11 @@
 	    continue;
-	if (KEY("type"))
+	if (KEY("type")) {
 	    G_strip(data);
 	    if (data[0] == 'b')
 		vector->type = GV_BOUNDARY;
@@ -83,120 +80,105 @@
 		vector->type = GV_LINE;
 	    continue;
-	if (KEY("line"))
 	    continue;
-        if (KEY("rgbcol"))
-            double alpha;
+	if (KEY("rgbcol")) {
+	    double alpha;
 		error(key, data, "illegal fcolor (vlines)");
-	    if (ret == 2)
+	    if (ret == 2) {
 	    vector->line.color.a = (ret == 2) ? alpha : 1.;
-	    G_warning("Request rgbcol from '%s' database column (vlines)", vector->rgbcol);
+	    G_warning("Request rgbcol from '%s' database column (vlines)",
+		      vector->rgbcol);
 	    continue;
-	if (KEY("hline"))
+	if (KEY("hline")) {
 	    read_psline(data, &(vector->hline));
 	    continue;
-	    if (scan_dimen(data, &(vector->offset)) == 0)
+	    if (scan_dimen(data, &(vector->offset)) == 0) {
 		vector->offset = 0.;
 	    continue;
-	if (KEY("layer"))
 	    G_strip(data);
 	    continue;
 	    G_strip(data);
 	    continue;
-	if (KEY("where"))
 	    G_strip(data);
 	    continue;
 		PS.need_mask = 1;
 	    continue;
-	if (KEY("label"))
 	    G_strip(data);
 	    continue;
 	    int k;
 		PS.vct[i].lpos = k;
-	    else
+	    else {
 		read_block(i);
 	    continue;
-            if (sscanf(data, "%s %[^\n]", catsbuf, labelbuf) != 2)
-                error(key, data, "illegal setrule request (vlines)");;
-            vector_rule_new(&(PS.vct[i]), catsbuf, labelbuf, 0);
+	    if (sscanf(data, "%s %[^\n]", catsbuf, labelbuf) != 2)
+		error(key, data, "illegal setrule request (vlines)");;
+	    vector_rule_new(&(PS.vct[i]), catsbuf, labelbuf, 0);
 	    continue;
 	error(key, "", "illegal request (vlines)");
     /* final adjust of hline width */
-    if (vector->hline.width > 0. && vector->offset == 0.)
+    if (vector->hline.width > 0. && vector->offset == 0.) {
 	vector->hline.width = vector->line.width + 2. * vector->hline.width;
     /* default label */
-       vector_item_new(&(PS.vct[i]), 0, color_to_long(&(vector->line.color)));
+			color_to_long(&(vector->line.color)));
     return 1;
Modified: grass-addons/postscript/ps.output/r_vpoints.c
--- grass-addons/postscript/ps.output/r_vpoints.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/r_vpoints.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,8 +21,11 @@
 int read_vpoints(char *name)
     int i;
     char buf[1024];
     VPOINTS *vector;
@@ -31,11 +34,9 @@
@@ -45,8 +46,7 @@
 	    return 0;
@@ -61,12 +61,12 @@
     vector = (VPOINTS *) PS.vct[i].data;
     vector->type = GV_POINT;
     vector->symbol = G_store("basic/circle");
-    vector->size    = 1.0;
+    vector->size = 1.0;
     vector->sizecol = NULL;
-    vector->rotate    = 0.0;
+    vector->rotate = 0.0;
     vector->rotatecol = NULL;
     vector->scale = 1.0;
-    vector->bias  = 0.0;
+    vector->bias = 0.0;
     unset_color(&(vector->fcolor));
     default_psline(&(vector->line));
     vector->distance = 0.;
@@ -75,17 +75,13 @@
 	    continue;
-	if (KEY("type"))
 	    G_strip(data);
-	    switch (data[0])
+	    switch (data[0]) {
 	    case 'c':
 		vector->type = GV_CENTROID;
 		break;
@@ -101,177 +97,152 @@
 	    continue;
-	if (KEY("symbol"))
+	if (KEY("symbol")) {
 	    vector->symbol = G_store(data);
 	    continue;
-	if (KEY("line"))
 	    continue;
-	    if (!scan_color(data, &(vector->fcolor)))
+	    if (!scan_color(data, &(vector->fcolor))) {
 		error(key, data, "illegal fcolor request (vpoints)");
 	    continue;
-	if (KEY("size"))
-	    switch (sscanf(data, "%s %s", stra, strb))
+	    switch (sscanf(data, "%s %s", stra, strb)) {
 	    case 1:
-            if (atof(stra) != 0.)
-                vector->size = atof(stra);
-            else
-                vector->sizecol = G_store(stra);
-            break;
+		if (atof(stra) != 0.)
+		    vector->size = atof(stra);
+		else
+		    vector->sizecol = G_store(stra);
+		break;
 	    case 2:
-            vector->size = atof(strb);
-            break;
+		vector->size = atof(strb);
+		break;
 	    default:
-            error(key, data, "illegal scale request (vpoints)");
+		error(key, data, "illegal scale request (vpoints)");
 	    if (vector->sizecol != NULL)
-            G_warning("Request size from '%s' column (vpoints)", vector->sizecol);
+		G_warning("Request size from '%s' column (vpoints)",
+			  vector->sizecol);
 	    continue;
-	if (KEY("scale"))
-        char stra[50], strb[50];
+	if (KEY("scale")) {
+	    char stra[50], strb[50];
-        case 1:
-            scan_dimen(stra, &(vector->scale));
-            vector->bias = 0.;
-            break;
-        case 2:
-            scan_dimen(strb, &(vector->bias));
-            break;
-        default:
-            error(key, data, "illegal scale [bias] request (vpoints)");
-            break;
+	    case 1:
+		scan_dimen(stra, &(vector->scale));
+		vector->bias = 0.;
+		break;
+	    case 2:
+		scan_dimen(strb, &(vector->bias));
+		break;
+	    default:
+		error(key, data, "illegal scale [bias] request (vpoints)");
+		break;
 	    continue;
-        if (scan_dimen(data, &(vector->voffset)) != 1)
-            error(key, data, "illegal voffset request (vpoints)");
-        continue;
-	    if (atof(data) != 0.)
+	    if (scan_dimen(data, &(vector->voffset)) != 1) {
+		error(key, data, "illegal voffset request (vpoints)");
+	    continue;
+	    if (atof(data) != 0.) {
 		vector->rotate = atof(data);
-	    else
+	    else {
 		vector->rotatecol = G_store(data);
-		G_warning("Request rotate from '%s' column (vpoints)", vector->rotatecol);
+		G_warning("Request rotate from '%s' column (vpoints)",
+			  vector->rotatecol);
 	    continue;
-	if (KEY("dist"))
-	    if (scan_dimen(data, &(vector->distance)) != 1)
+	if (KEY("dist")) {
+	    if (scan_dimen(data, &(vector->distance)) != 1) {
 		error(key, data, "illegal dist request (vpoints)");
 	    continue;
-	if (KEY("cline"))
+	if (KEY("cline")) {
 	    read_psline(data, &(vector->cline));
 	    continue;
-	if (KEY("layer"))
 	    G_strip(data);
 	    continue;
 	    G_strip(data);
 	    continue;
-	if (KEY("where"))
 	    G_strip(data);
 	    continue;
 		PS.need_mask = 1;
 	    continue;
-	if (KEY("label"))
 	    G_strip(data);
 	    continue;
 	    int k;
 		PS.vct[i].lpos = k;
-	    else
+	    else {
 		read_block(i);
 	    continue;
 	    double val;
-                val = atof(catsbuf) * vector->scale;
+		    val = atof(catsbuf) * vector->scale;
 	    else
-            error(key, data, "illegal setrule request (vpoints)");
+		error(key, data, "illegal setrule request (vpoints)");
 	    continue;
 	error(key, "", "illegal request (vpoints)");
     /* default label */
-    if (vector->sizecol == NULL)
-        vector_item_new(&(PS.vct[i]), 0, (long)(vector->size * 1000.));
+    if (vector->sizecol == NULL) {
+	vector_item_new(&(PS.vct[i]), 0, (long)(vector->size * 1000.));
     return 1;
Modified: grass-addons/postscript/ps.output/raster.c
--- grass-addons/postscript/ps.output/raster.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/raster.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -17,10 +17,8 @@
     int i;
-    for (i = 0; i < 3; i++)
-	if (PS.rst.fd[i] >= 0)
+    for (i = 0; i < 3; i++) {
+	if (PS.rst.fd[i] >= 0) {
 	    G_close_cell(PS.rst.fd[i]);
 	    G_free(PS.rst.name[i]);
 	    G_free(PS.rst.mapset[i]);
Modified: grass-addons/postscript/ps.output/scanners.c
--- grass-addons/postscript/ps.output/scanners.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/scanners.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -79,13 +79,14 @@
 int scan_color(char *data, PSCOLOR * color)
     int ret;
     char name[20];
     double alpha;
     ret = sscanf(data, "%[^$]$%lf", name, &alpha);
-    if (set_color_name(color, name))
+    if (set_color_name(color, name)) {
 	color->a = (ret == 2) ? alpha : 1.;
 	return 1;
@@ -97,20 +98,19 @@
 int scan_dimen(char *data, double *d)
     int ret;
     char unit = ' ';
     ret = sscanf(data, "%lf%c", d, &unit);
     if (ret == 1)
 	unit = ' ';
-    else if (ret != 2)
+    else if (ret != 2) {
 	*d = 0.;
 	return 0;
-    switch (unit)
+    switch (unit) {
 	/* metric to points */
     case 'i':
 	*d *= INCH_TO_POINT;
@@ -133,14 +133,14 @@
 int scan_second(char *data, double *d)
     int ret;
     char unit = ' ';
     if (ret == 1)
 	unit = ' ';
-    else if (ret != 2 || *d < 0.)
+    else if (ret != 2 || *d < 0.) {
 	*d = 0.;
 	return 0;
Modified: grass-addons/postscript/ps.output/set_draw.c
--- grass-addons/postscript/ps.output/set_draw.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_draw.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -27,41 +27,38 @@
 int set_draw(char *key, char *data)
     char h, label[100], buf[256];
     char e1[20], n1[20], e2[20], n2[20];
     int i, x, y, dg, mg;
     double east, north, lw, d, sg;
     PSCOLOR color;
-    if (KEY("direct"))
+    if (KEY("direct")) {
 	fprintf(PS.fp, " %s ", data);
-    else if (KEY("color"))
-        if (!scan_color(data, &color))
-            error(key, data, "color: color");
-        set_ps_color(&color);
+    else if (KEY("color")) {
+	if (!scan_color(data, &color))
+	    error(key, data, "color: color");
+	set_ps_color(&color);
-    else if (KEY("fcolor"))
+    else if (KEY("fcolor")) {
 	scan_color(data, &fcolor);
-    else if (KEY("linewidth"))
-        if (sscanf(data, "%s", label) != 1 ||
-            scan_dimen(label, &lw) != 1)
+    else if (KEY("linewidth")) {
+	if (sscanf(data, "%s", label) != 1 || scan_dimen(label, &lw) != 1)
 	    error(key, data, "linewidth: width");
 	fprintf(PS.fp, "%.1f LW ", lw);
-    else if (KEY("linedash"))
+    else if (KEY("linedash")) {
 	if (sscanf(data, "%[^\n]", label) != 1)
-            fprintf(PS.fp, "[] 0 LD ");
-        else
-            fprintf(PS.fp, "[%s] 0 LD ", label);
+	    fprintf(PS.fp, "[] 0 LD ");
+	else
+	    fprintf(PS.fp, "[%s] 0 LD ", label);
-    else if (KEY("font"))
+    else if (KEY("font")) {
 	i = sscanf(data, "%s %s %lf", label, buf, &d);
 	if ((i != 2 && i != 3) || (scan_dimen(buf, &lw) != 1))
@@ -75,77 +72,62 @@
     /* Drawing text */
     else if (KEY("text") ||
-             KEY("ltext") ||
-             KEY("ctext") ||
-             KEY("rtext") ||
-             KEY("xtext") ||
-             KEY("vtext"))
+	     KEY("ltext") ||
+	     KEY("ctext") || KEY("rtext") || KEY("xtext") || KEY("vtext")) {
 	if (sscanf(data, "%s %s %[^\n]", e1, n1, label) != 3)
 	    error(key, data, "text: east, north and text");
-	if (atoi(e1) < 0)
+	if (atoi(e1) < 0) {
 	    fprintf(PS.fp, "GS %s ROT (%s) ", n1, label);
-	else
+	else {
 	    sprintf(buf, "M (%s) ", label);
 	    set_on_paper("GS", e1, n1, buf);
-        switch (*key)
-        case 'x':
-            strcpy(buf, "SHCC");
-            break;
-        case 'c':
-            strcpy(buf, "SHC");
-            break;
-        case 'r':
-            strcpy(buf, "SHR");
-            break;
-        case 'v':
-            strcpy(buf, "SVC");
-            break;
-        default:
-            strcpy(buf, "TXT");
-            break;
-        fprintf(PS.fp, "%s GR\n", buf);
+	switch (*key) {
+	case 'x':
+	    strcpy(buf, "SHCC");
+	    break;
+	case 'c':
+	    strcpy(buf, "SHC");
+	    break;
+	case 'r':
+	    strcpy(buf, "SHR");
+	    break;
+	case 'v':
+	    strcpy(buf, "SVC");
+	    break;
+	default:
+	    strcpy(buf, "TXT");
+	    break;
+	fprintf(PS.fp, "%s GR\n", buf);
-    else if (KEY("-text"))
+    else if (KEY("-text")) {
 	fprintf(PS.fp, " (%s) SHL ", data);
-    else if (KEY("textc"))
+    else if (KEY("textc")) {
-            error(key, data, "ctext: east, north, and text");
+	    error(key, data, "ctext: east, north, and text");
 	sprintf(buf, "M GS (%s) dup SHCC GR "
-                "SWH 2 copy gt {pop} {exch pop} ifelse 2 div 2 add "
-                "cP 3 -1 roll 0 360 NP arc CP S\n", label);
+		"SWH 2 copy gt {pop} {exch pop} ifelse 2 div 2 add "
+		"cP 3 -1 roll 0 360 NP arc CP S\n", label);
 	set_on_paper("", e1, n1, buf);
-    else if (KEY("labels") ||
-             KEY("label"))
+    else if (KEY("labels") || KEY("label")) {
 	if (sscanf(data, "%s", label) != 1)
 	    error(key, data, "labels: filename");
 	label_in_file(label);
     /* Drawing paths */
-    else if (KEY("moveto"))
+    else if (KEY("moveto")) {
 	if (sscanf(data, "%s %s", e1, n1) != 2)
 	    error(key, data, "moveto: east and north");
 	set_on_paper("", e1, n1, "M ");
-    else if (KEY("lineto") ||
-             KEY("ruteto"))
-	switch (sscanf(data, "%s %s %[^\n]", e1, n1, buf))
+    else if (KEY("lineto") || KEY("ruteto")) {
+	switch (sscanf(data, "%s %s %[^\n]", e1, n1, buf)) {
 	case 2:
 	    set_on_paper("", e1, n1, "L ");
 	    break;
@@ -153,37 +135,31 @@
 	    set_on_paper("cP exch 2 copy", e1, n1, "L GS cP 2 copy 8 2 roll");
 	    fprintf(PS.fp,
 		    " 4 -1 roll add 2 div 3 1 roll add 2 div exch M"
-		    " 4 1 roll sub 3 1 roll exch sub atan ROT 0 2 MR (%s) SHC S GR\n", buf);
+		    " 4 1 roll sub 3 1 roll exch sub atan ROT 0 2 MR (%s) SHC S GR\n",
+		    buf);
 	    break;
 	default:
 	    error(key, data, "lineto: east, north, and [text]");
-    else if (KEY("endline"))
-        fprintf(PS.fp, " S");
+    else if (KEY("endline")) {
+	fprintf(PS.fp, " S");
-    else if (KEY("line"))
+    else if (KEY("line")) {
 	if (sscanf(data, "%s %s %s %s", e1, n1, e2, n2) != 4)
-            error(key, data, "line: east/north east/north");
+	    error(key, data, "line: east/north east/north");
 	set_on_paper("", e1, n1, "M");
 	/* if e2 < 0 polares angulo y longitud */
 	set_on_paper("", e2, n2, "LS\n");
-    else if (KEY("border"))
-            scan_dimen(label, &d) != 1)
-            error(key, data, "border: width");
-        set_ps_brd(d);
+    else if (KEY("border")) {
+	if (sscanf(data, "%s", label) != 1 || scan_dimen(label, &d) != 1)
+	    error(key, data, "border: width");
+	set_ps_brd(d);
-    else if (KEY("rect") ||
-             KEY("rectangle"))
-	switch (sscanf(data, "%s %s %s %s %s", e1, n1, e2, n2, buf))
+    else if (KEY("rect") || KEY("rectangle")) {
+	switch (sscanf(data, "%s %s %s %s %s", e1, n1, e2, n2, buf)) {
 	case 4:
 	    set_on_paper("", e1, n1, "");
 	    set_on_paper("", e2, n2, "B S\n");
@@ -196,20 +172,19 @@
 	    fprintf(PS.fp, "fill GR S\n");
 	    break;
 	default:
-	    error(key, data, "rectangle: east/north and east/north [fill color])");
+	    error(key, data,
+		  "rectangle: east/north and east/north [fill color])");
-    else if (KEY("circ") ||
-             KEY("circle"))
+    else if (KEY("circ") || KEY("circle")) {
 	if (sscanf(data, "%s %s %lf", e1, n1, &d) != 3)
 	    error(key, data, "circle: x, y and radius");
-	sprintf(buf, "%.1f 0 360 arc S\n", d * (MT_TO_POINT / (double)PS.scale));
+	sprintf(buf, "%.1f 0 360 arc S\n",
+		d * (MT_TO_POINT / (double)PS.scale));
-    else if (KEY("arc"))
+    else if (KEY("arc")) {
 	if (sscanf(data, "%s %s %lf %s %s", e1, n1, &d, e2, n2) != 5)
 	    error(key, data, "arc need 5 parameters");
@@ -218,27 +193,22 @@
 	set_on_paper(buf, e2, n2, "arc S\n");
     /* Include files */
-    else if (KEY("psfile") ||
-             KEY("epsfile"))
-	if (sscanf(data, "%lf %s %s %s", &d, e1, n1, label) != 4)
+    else if (KEY("psfile") || KEY("epsfile")) {
+	if (sscanf(data, "%lf %s %s %s", &d, e1, n1, label) != 4) {
 	    error(key, data, "psfile: scale, east, north, and filename");
 	set_on_paper("GS", e1, n1, "TR ");
 	fprintf(PS.fp, "%.2f dup scale ", d);
 	FILE *fp;
-	if ((fp = fopen(label, "r")) != NULL)
+	if ((fp = fopen(label, "r")) != NULL) {
 	    G_message("Reading PostScript file <%s> ...", label);
 	    fprintf(PS.fp, "\n");
 	       while (fgets(buf, 256, fp) != NULL)
 	       fprintf(PS.fp, "%s", buf);
-	    while (fgets(buf, 256, fp) != NULL)
+	    while (fgets(buf, 256, fp) != NULL) {
 		if (strcmp(buf, "showpage\n") == 0)
 		    continue;
@@ -249,33 +219,33 @@
     /* Drawing complements */
-    else if (KEY("maplimit") ||
-             KEY("maplimits"))
+    else if (KEY("maplimit") || KEY("maplimits")) {
 	    d = 0.;
 	else
 	    scan_dimen(label, &d);
-	fprintf(PS.fp, "%.1f %.1f add %.1f %.1f add M ", PS.map_right, d, PS.map_top, d);
+	fprintf(PS.fp, "%.1f %.1f add %.1f %.1f add M ", PS.map_right, d,
+		PS.map_top, d);
 	format_northing(PS.map.north, buf, PS.map.proj);
 	fprintf(PS.fp, "GS (%s) dup SWH ++ neg dup MR pop SHR GR\n", buf);
 	format_easting(PS.map.east, buf, PS.map.proj);
-	fprintf(PS.fp, "GS (%s) dup SWH ++ dup neg 3 1 roll add neg MR 270 ROT SHR GR\n", buf);
+	fprintf(PS.fp,
+		"GS (%s) dup SWH ++ dup neg 3 1 roll add neg MR 270 ROT SHR GR\n",
+		buf);
-	fprintf(PS.fp, "%.1f %.1f sub %.1f %.1f sub M ", PS.map_x, d, PS.map_y, d);
+	fprintf(PS.fp, "%.1f %.1f sub %.1f %.1f sub M ", PS.map_x, d,
+		PS.map_y, d);
 	format_northing(PS.map.south, buf, PS.map.proj);
 	fprintf(PS.fp, "GS (%s) dup SWH ++ 1 MR pop SHL GR\n", buf);
 	format_easting(PS.map.west, buf, PS.map.proj);
 	fprintf(PS.fp, "GS (%s) dup SWH ++ dup MR pop 90 ROT SHL GR\n", buf);
-    else if (KEY("northarrow") ||
-             KEY("north"))
-	switch (sscanf(data, "%s %s %s", e1, n1, buf))
+    else if (KEY("northarrow") || KEY("north")) {
+	switch (sscanf(data, "%s %s %s", e1, n1, buf)) {
 	case 2:
-	    sprintf(buf, "M 5 dup neg dup 3 mul LR dup dup LR dup neg LR CP cP S M 0 2 MR (N) SHC\n");
+	    sprintf(buf,
+		    "M 5 dup neg dup 3 mul LR dup dup LR dup neg LR CP cP S M 0 2 MR (N) SHC\n");
 	    set_on_paper("NP .2 mm LW", e1, n1, buf);
 	    break;
 	case 3:
@@ -291,19 +261,18 @@
 	    error(key, data, "northarrow: x, y and radius");
-    else if (KEY("declination"))
+    else if (KEY("declination")) {
-    else if (KEY("compass") ||
-             KEY("rose"))
+    else if (KEY("compass") || KEY("rose")) {
 	char h;
 	int dg, mn;
 	double conv, sec;
-	if (sscanf(data, "%lf %lf %lf %lf", &east, &north, &d, &conv) != 4)
-	    error(key, data, "compass: x, y, radius and magnetic declination");
+	if (sscanf(data, "%lf %lf %lf %lf", &east, &north, &d, &conv) != 4) {
+	    error(key, data,
+		  "compass: x, y, radius and magnetic declination");
 	d *= (MT_TO_POINT / (double)PS.scale);
 	set_xy_where(".25 LW", east, north, "M ");
@@ -326,8 +295,7 @@
 	fprintf(PS.fp, "2 div 1 MR (%s) SHC GR\n", buf);
     /* Oops ending */
-    else
+    else {
 	error(key, data, "not found\n");
@@ -338,35 +306,36 @@
 void label_in_file(char *name)
     FILE *in = NULL;
     char buf[1024], code[1024], data[1024];
     int x, y;
     double n;
     PSFRAME frame;
     PSFONT font;
     frame.xref = CENTER;
     frame.yref = CENTER;
-    if (*name)
+    if (*name) {
 	in = fopen(name, "r");
-	if (in == NULL)
+	if (in == NULL) {
 	    G_message("Labels file <%s> can't open", name);
 	    return;
-    while (fgets(buf, sizeof(buf), in))
+    while (fgets(buf, sizeof(buf), in)) {
 	*code = 0;
 	*data = 0;
 	if (sscanf(buf, "%[^:]:%[^\n]", code, data) < 1)
 	    continue;
 	G_strip(data);
-	if (CODE("text"))
+	if (CODE("text")) {
 	    G_plot_where_xy(frame.x, frame.y, &x, &y);
 	    frame.x = ((double)x) / 10.;
@@ -375,93 +344,73 @@
 		set_ps_font(&font);
 	    fprintf(PS.fp, "GS\n");
 	    fprintf(PS.fp, "/ARo [(%s)] def\n", data);
-            fprintf(PS.fp, "/ARw [ARo SWx] def ");
-            fprintf(PS.fp, "/ARh [FS0] def\n");
+	    fprintf(PS.fp, "/ARw [ARo SWx] def ");
+	    fprintf(PS.fp, "/ARh [FS0] def\n");
 	    set_box_auto(&frame, &font, 0.25);
-            fprintf(PS.fp, "(%s) READJUST ", data);
+	    fprintf(PS.fp, "(%s) READJUST ", data);
 	    set_box_draw(&frame);
-	    fprintf(PS.fp, "(%s) xo wd 2 div add yo hg 2 div sub M SHCC\n", data);
+	    fprintf(PS.fp, "(%s) xo wd 2 div add yo hg 2 div sub M SHCC\n",
+		    data);
 	/* Option to modify the text */
-	else if (CODE("east"))
+	else if (CODE("east")) {
 	    frame.x = atof(data);
-	else if (CODE("north"))
+	else if (CODE("north")) {
 	    frame.y = atof(data);
-	else if (CODE("xoffset"))
+	else if (CODE("xoffset")) {
 	    frame.xset = atof(data);
-	else if (CODE("yoffset"))
+	else if (CODE("yoffset")) {
 	    frame.yset = atof(data);
-	else if (CODE("ref"))
+	else if (CODE("ref")) {
 	    scan_ref(data, &(frame.xref), &(frame.yref));
-	else if (CODE("font"))
+	else if (CODE("font")) {
 	    get_font(data);
 	    strcpy(font.name, data);
-	else if (CODE("fontsize"))
+	else if (CODE("fontsize")) {
 	    if (scan_dimen(data, &(font.size)) != 1)
 		font.size = 10.;
-	else if (CODE("size"))
+	else if (CODE("size")) {
 	    n = atof(data);
 	    font.size = (n * MT_TO_POINT) / PS.scale;
-	else if (CODE("color"))
-	    if (!scan_color(data, &(font.color)))
+	else if (CODE("color")) {
+	    if (!scan_color(data, &(font.color))) {
 		set_color_rgb(&(font.color), 0, 0, 0);
-	else if (CODE("space"))
+	else if (CODE("space")) {
-	else if (CODE("rotation"))
+	else if (CODE("rotation")) {
 	    frame.rotate = atof(data);
-	else if (CODE("width"))
-	    if (scan_dimen(data, &(frame.border)) != 1)
+	else if (CODE("width")) {
+	    if (scan_dimen(data, &(frame.border)) != 1) {
 		frame.border = -1;
-	else if (CODE("hcolor"))
+	else if (CODE("hcolor")) {
-	else if (CODE("hwidth"))
+	else if (CODE("hwidth")) {
-	else if (CODE("background"))
-	    if (!scan_color(data, &(frame.fcolor)))
+	else if (CODE("background")) {
+	    if (!scan_color(data, &(frame.fcolor))) {
 		unset_color(&(frame.fcolor));
-	else if (CODE("border"))
-	    if (!scan_color(data, &(frame.color)))
+	else if (CODE("border")) {
+	    if (!scan_color(data, &(frame.color))) {
 		unset_color(&(frame.color));
-	else if (CODE("opaque"))
+	else if (CODE("opaque")) {
     fclose(in);
@@ -473,22 +422,22 @@
 int set_on_paper(char *pre, char *c_x, char *c_y, char *post)
     char xunit, yunit;
     int xret, yret, x, y;
     double dx, dy;
     xret = sscanf(c_x, "%lf%c", &dx, &xunit);
     yret = sscanf(c_y, "%lf%c", &dy, &yunit);
     /* east | north */
-    if (xret == 1 && yret == 1)
+    if (xret == 1 && yret == 1) {
 	G_plot_where_xy(dx, dy, &x, &y);
 	dx = ((double)x) / 10.;
 	dy = ((double)y) / 10.;
     /* x | y */
-    else if (xret == 2 && yret == 2)
+    else if (xret == 2 && yret == 2) {
 	xret = scan_dimen(c_x, &dx);
 	yret = scan_dimen(c_y, &dy);
 	/* percent */
@@ -500,8 +449,8 @@
 	    dx = (PS.page.width + dx);
 	if (yret < 0)
 	    dy = (PS.page.height + dy);
-        /* margen inferior */
-        dy = PS.page.height - dy;
+	/* margen inferior */
+	dy = PS.page.height - dy;
     fprintf(PS.fp, "%s %.1f %.1f %s", pre, dx, dy, post);
     return xret;
Modified: grass-addons/postscript/ps.output/set_geogrid.c
--- grass-addons/postscript/ps.output/set_geogrid.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_geogrid.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -34,7 +34,9 @@
 int set_geogrid_lines(PSLINE * line, int grid_sep)
     double sep, n_min, nmin, e_min, emin;
     double e, n, east, west, north, south;
     struct pj_info ll_proj, proj;
     if (PS.geogrid.sep <= 0 || PS.geogrid.line.color.none)
@@ -53,10 +55,8 @@
     e_min = ceil(east / sep) * sep;
     /* latitude lines */
-    for (nmin = n_min; nmin >= south; nmin -= sep)
-	for (emin = e_min; emin >= west; emin -= sep)
+    for (nmin = n_min; nmin >= south; nmin -= sep) {
+	for (emin = e_min; emin >= west; emin -= sep) {
 	    e = emin;
 	    n = nmin;
 	    pj_do_proj(&e, &n, &ll_proj, &proj);	/* LL to PROJ */
@@ -69,10 +69,8 @@
     /* longitude lines */
 	    e = emin;
 	    n = nmin;
@@ -94,10 +92,15 @@
 int set_numbers_geogrid(void)
     char label[50];
     int i, x, y;
     double dx, dy;
     double grid_sep, nmin, emin, dif;
     if (PS.geogrid.sep <= 0)
@@ -115,8 +118,7 @@
     /* vertical-right numbers */
     fprintf(PS.fp, "/GRR [\n");
     nmin = floor(north / grid_sep) * grid_sep;
-    for (; nmin > south; nmin -= grid_sep)
+    for (; nmin > south; nmin -= grid_sep) {
 	e = east;
 	n = nmin;
@@ -137,8 +139,7 @@
     /* horizontal-bottom numbers */
     fprintf(PS.fp, "/GRB [\n");
     emin = floor(east / grid_sep) * grid_sep;
-    for (; emin > west; emin -= grid_sep)
+    for (; emin > west; emin -= grid_sep) {
 	n = south;
 	e = emin;
@@ -157,8 +158,7 @@
     fprintf(PS.fp, "] def\n");
     /* select format */
-    switch (PS.geogrid.format)
+    switch (PS.geogrid.format) {
     case 0:
 	set_geogrid_inner_numbers();
 	break;
@@ -183,7 +183,9 @@
     if (PS.geogrid.fcolor.none)
 	fprintf(PS.fp, "SW .5 add neg .5 MR ");
     else
-	fprintf(PS.fp, "SWH m 2 mul add 1 index m 1 add add neg " "exch dup -2 div 0 exch MR Rf ++ neg m MR ");
+	fprintf(PS.fp,
+		"SWH m 2 mul add 1 index m 1 add add neg "
+		"exch dup -2 div 0 exch MR Rf ++ neg m MR ");
     set_ps_color(&(PS.geogrid.font.color));
     fprintf(PS.fp, "%s} for\n", (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
@@ -193,9 +195,12 @@
 	fprintf(PS.fp, "pop -.5 .5 MR ");
     else
-	fprintf(PS.fp, "SWH m 2 mul add exch m 1 add add 1 index -2 div 0 MR " "1 index exch Rf m sub 1 MR ");
+	fprintf(PS.fp,
+		"SWH m 2 mul add exch m 1 add add 1 index -2 div 0 MR "
+		"1 index exch Rf m sub 1 MR ");
-    fprintf(PS.fp, "GS 90 ROT %s GR} for\n", (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
+    fprintf(PS.fp, "GS 90 ROT %s GR} for\n",
+	    (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
     fprintf(PS.fp, "GR\n");
     return 0;
@@ -210,12 +215,14 @@
     /* vertical numbers */
     fprintf(PS.fp,
 	    "0 1 GRR length -- {GRR exch GET M dup "
-	    "SW 2 div %.2f exch MR GS 270 ROT %s GR} for ", PS.brd.width + 1., (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
+	    "SW 2 div %.2f exch MR GS 270 ROT %s GR} for ", PS.brd.width + 1.,
     /* horizontal numbers */
     fprintf(PS.fp,
 	    "0 1 GRB length -- {GRB exch GET M dup "
-	    "SWH %.2f add neg exch -2 div exch MR %s} for ", PS.brd.width + 1., (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
+	    "SWH %.2f add neg exch -2 div exch MR %s} for ",
+	    PS.brd.width + 1., (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
     return 0;
Modified: grass-addons/postscript/ps.output/set_grid.c
--- grass-addons/postscript/ps.output/set_grid.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_grid.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -24,8 +24,7 @@
     fprintf(PS.fp, "/XY {get aload pop exch pop} D\n");
-    if (PS.grid.msep > 0)
+    if (PS.grid.msep > 0) {
 	set_grid_lines('m', &(PS.grid.mline), PS.grid.msep);
     set_grid_lines('M', &(PS.grid.line), PS.grid.sep);
@@ -34,7 +33,9 @@
 int set_grid_lines(char code, PSLINE * line, int grid_sep)
     char label[50], h;
     int i, x, y, zero, d, m;
     double sep, north, west, dx, dy, s;
     if (grid_sep <= 0)
@@ -42,20 +43,16 @@
     /* detect trailer zeros if format zero and not LL */
     zero = 1;
-    if (PS.map.proj == PROJECTION_LL)
+    if (PS.map.proj == PROJECTION_LL) {
 	sep = (double)grid_sep / 3600.;
 	/* break iho */
-    else
+    else {
 	sep = (double)grid_sep;
-	if (PS.grid.format < 2 && PS.grid.trim > 0)
+	if (PS.grid.format < 2 && PS.grid.trim > 0) {
 	    while (PS.grid.sep % zero == 0)
 		zero *= 10;
-	    if (zero > 1)
+	    if (zero > 1) {
 		zero /= 10;
 		for (i = 0, x = 1; i < PS.grid.trim; i++)
 		    x *= 10;
@@ -68,16 +65,13 @@
     fprintf(PS.fp, "/VGR%c [\n", code);
     north = floor(PS.map.north / sep) * sep;
-    for (; north >= PS.map.south; north -= sep)
+    for (; north >= PS.map.south; north -= sep) {
 	G_plot_where_xy(PS.map.east, north, &x, &y);
-	if (PS.grid.format == 2)
+	if (PS.grid.format == 2) {
 	    format_iho(north, label);
-	else
+	else {
 	    format_easting(north / zero, label, PS.map.proj);
 	fprintf(PS.fp, "[(%s) %.2f]\n", label, dy);
@@ -87,16 +81,13 @@
     fprintf(PS.fp, "/HGR%c [\n", code);
     west = ceil(PS.map.west / sep) * sep;
-    for (; west < PS.map.east; west += sep)
+    for (; west < PS.map.east; west += sep) {
 	G_plot_where_xy(west, PS.map.south, &x, &y);
 	    format_iho(west, label);
-	else
+	else {
 	    format_easting(west / zero, label, PS.map.proj);
 	fprintf(PS.fp, "[(%s) %.2f]\n", label, dx);
@@ -104,30 +95,31 @@
-    if (line->color.none != 1)
+    if (line->color.none != 1) {
 	set_ps_line(line);
-	if (PS.grid.cross <= 0.)
-	{			/* draw lines */
+	if (PS.grid.cross <= 0.) {	/* draw lines */
 	    fprintf(PS.fp,
 		    "VGR%c 0 1 2 index length -- {1 index exch XY "
-		    "%.2f exch dup %.2f exch M LS} for pop\n", code, PS.map_x, PS.map_right);
+		    "%.2f exch dup %.2f exch M LS} for pop\n", code, PS.map_x,
+		    PS.map_right);
 	    fprintf(PS.fp,
 		    "HGR%c 0 1 2 index length -- {1 index exch XY "
-		    "%.2f 1 index %.2f M LS} for pop\n", code, PS.map_y, PS.map_top);
+		    "%.2f 1 index %.2f M LS} for pop\n", code, PS.map_y,
+		    PS.map_top);
-	else
-	{			/* draw crosses */
+	else {			/* draw crosses */
 	    G_plot_where_xy(PS.map.east, PS.map.north, &x, &y);
-	    G_plot_where_xy(PS.map.east - PS.grid.cross, PS.map.north, &x, &y);
+	    G_plot_where_xy(PS.map.east - PS.grid.cross, PS.map.north, &x,
+			    &y);
 	    dy = ((double)x) / 10.;
 	    fprintf(PS.fp,
-		    "2 index M 0 90 270 {GS ROT 0 %.2f LRS GR} for} " "for pop pop} for pop\n", code, code, dx - dy);
+		    "2 index M 0 90 270 {GS ROT 0 %.2f LRS GR} for} "
+		    "for pop pop} for pop\n", code, code, dx - dy);
     /* draw crosses como rotate una longitud desde el punto central */
@@ -143,42 +135,43 @@
     set_ps_color(&(PS.grid.fcolor));
     /* make numbers */
-    switch (PS.grid.format)
+    switch (PS.grid.format) {
     case 0:
 	set_ps_brd2(.2 * MM_TO_POINT, 0.);
 	set_grid_inner_numbers();
 	break;
     case 1:
-	    if (PS.grid.msubdiv >= 0)
+	    if (PS.grid.msubdiv >= 0) {
 		double mrga = 0.4 * PS.brd.width - .2 * MM_TO_POINT;
 		double mrgb = 0.6 * PS.brd.width - .2 * MM_TO_POINT;
-		set_grid_minordiv_border(PS.grid.msubdiv, .2 * MM_TO_POINT, mrga);
+		set_grid_minordiv_border(PS.grid.msubdiv, .2 * MM_TO_POINT,
+					 mrga);
 		set_grid_minor_border(.2 * MM_TO_POINT + mrga, mrgb, mrgb);
 	    else
-		set_grid_minor_border(.2 * MM_TO_POINT, PS.brd.width - .2 * MM_TO_POINT, PS.brd.width);
+		set_grid_minor_border(.2 * MM_TO_POINT,
+				      PS.brd.width - .2 * MM_TO_POINT,
+				      PS.brd.width);
 	set_grid_outer_numbers(2);
 	break;
     case 2:
 	    fprintf(PS.fp, "0.2 mm LW ");
-	    set_grid_minordiv_border(PS.grid.msubdiv, 0.2 * MM_TO_POINT, 0.4 * MM_TO_POINT);
-	    set_grid_minor_border(0.8 * MM_TO_POINT, 1.0 * MM_TO_POINT, 0.2 * MM_TO_POINT);
+	    set_grid_minordiv_border(PS.grid.msubdiv, 0.2 * MM_TO_POINT,
+				     0.4 * MM_TO_POINT);
+	    set_grid_minor_border(0.8 * MM_TO_POINT, 1.0 * MM_TO_POINT,
+				  0.2 * MM_TO_POINT);
 	    fprintf(PS.fp, "0.8 mm LW ");
 	    set_grid_major_border(2.0 * MM_TO_POINT, 9.9 * MM_TO_POINT);
 	    set_grid_iho_numbers(2.0 * MM_TO_POINT, 9.9 * MM_TO_POINT);
-	else
+	else {
 	    set_grid_major_border(0.2 * MM_TO_POINT, 11.7 * MM_TO_POINT);
 	    set_grid_iho_numbers(0.2 * MM_TO_POINT, 11.7 * MM_TO_POINT);
@@ -186,10 +179,12 @@
 	break;
     case 3:
 	fprintf(PS.fp, "0.005 inch LW ");
-	set_grid_minordiv_border(PS.grid.msubdiv, 0.005 * INCH_TO_POINT, 0.035 * INCH_TO_POINT);
-	    set_grid_minor_border(0.045 * INCH_TO_POINT, 0.025 * INCH_TO_POINT, 0.025 * INCH_TO_POINT);
+	set_grid_minordiv_border(PS.grid.msubdiv, 0.005 * INCH_TO_POINT,
+				 0.035 * INCH_TO_POINT);
+	    set_grid_minor_border(0.045 * INCH_TO_POINT,
+				  0.025 * INCH_TO_POINT,
+				  0.025 * INCH_TO_POINT);
 	set_ps_brd(15.605 * MM_TO_POINT);
 	set_ps_brd2(0.025 * INCH_TO_POINT, 17.3322 * MM_TO_POINT);
@@ -209,14 +204,15 @@
     set_ps_font(&(PS.grid.font));
-    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_x);
-    if (PS.grid.fcolor.none)
+    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ",
+	    PS.map_x);
+    if (PS.grid.fcolor.none) {
 	fprintf(PS.fp, ".2 mm .2 mm MR ");
-    else
-	fprintf(PS.fp, "dup SWH m 2 mul add exch m 1 add add exch " "dup 2 div neg 0 exch MR GS ");
+    else {
+	fprintf(PS.fp,
+		"dup SWH m 2 mul add exch m 1 add add exch "
+		"dup 2 div neg 0 exch MR GS ");
 	fprintf(PS.fp, "Rf GR 1 m MR ");
@@ -224,17 +220,18 @@
     fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_top);
 	fprintf(PS.fp, "dup SW .5 add neg -.5 exch MR ");
-    else
-	fprintf(PS.fp, "dup SWH m 2 mul add exch m 1 add add " "1 index 2 div 1 index neg MR exch neg exch GS ");
+    else {
+	fprintf(PS.fp,
+		"dup SWH m 2 mul add exch m 1 add add "
+		"1 index 2 div 1 index neg MR exch neg exch GS ");
 	fprintf(PS.fp, "Rf GR m neg m MR ");
-    fprintf(PS.fp, "GS 90 ROT %s GR} for\n", (PS.grid.trim < 0 ? "COOR" : "SHL"));
+	    (PS.grid.trim < 0 ? "COOR" : "SHL"));
     return 0;
@@ -249,25 +246,29 @@
+	    PS.map_x);
     fprintf(PS.fp, "dup SW -2 div -%.2f exch MR ", PS.brd.width + M);
     fprintf(PS.fp, "dup SW -2 div %.2f MR ", PS.brd.width + M);
     fprintf(PS.fp, "%s} for\n", (PS.grid.trim < 0 ? "COOR" : "SHL"));
-    if (PS.grid.lsides == 4)
+    if (PS.grid.lsides == 4) {
 	/* right vertical numbers */
-	fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_right);
+		PS.map_right);
 	fprintf(PS.fp, "dup SW 2 div %.2f exch MR ", PS.brd.width + M);
-	fprintf(PS.fp, "GS 270 ROT %s GR} for\n", (PS.grid.trim < 0 ? "COOR" : "SHL"));
+	fprintf(PS.fp, "GS 270 ROT %s GR} for\n",
 	/* bottom horizontal numbers */
 	fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_y);
-	fprintf(PS.fp, "dup SWH %.2f add neg exch -2 div exch MR ", PS.brd.width + M);
+	fprintf(PS.fp, "dup SWH %.2f add neg exch -2 div exch MR ",
+		PS.brd.width + M);
@@ -283,22 +284,28 @@
-    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_x - A - B / 2.);
+	    PS.map_x - A - B / 2.);
     fprintf(PS.fp, " (|) search pop exch pop ");
-    fprintf(PS.fp, "GS 0 1.25 MR SHC GR GS FR dup SWH exch pop 1.25 add neg 0 exch MR SHC GR} for\n");
+    fprintf(PS.fp,
+	    "GS 0 1.25 MR SHC GR GS FR dup SWH exch pop 1.25 add neg 0 exch MR SHC GR} for\n");
-    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_right + A + B / 2.);
+	    PS.map_right + A + B / 2.);
+    fprintf(PS.fp,
-    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_top + A + B / 2.);
+    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ",
+	    PS.map_top + A + B / 2.);
     fprintf(PS.fp, "GS -1.25 0 MR SHRC GR GS FR 1.25 0 MR SHLC GR} for\n");
-    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_y - A - B / 2.);
+	    PS.map_y - A - B / 2.);
@@ -314,19 +321,23 @@
     fprintf(PS.fp, "dup SWH 2 div neg exch 2 div neg exch MR COOR} for\n");
@@ -339,54 +350,62 @@
 void set_grid_minordiv_border(int div, double margin, double width)
-    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x, PS.map_top + margin, PS.map_w, width);
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x, PS.map_top + margin,
+	    PS.map_w, width);
-    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x, PS.map_y - margin, PS.map_w, -width);
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x, PS.map_y - margin,
+	    PS.map_w, -width);
-    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x - margin - width, PS.map_y, width, PS.map_h);
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x - margin - width,
+	    PS.map_y, width, PS.map_h);
-    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_right + margin, PS.map_y, width, PS.map_h);
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_right + margin,
-    if (div > 0)
+    if (div > 0) {
 	fprintf(PS.fp,
 		"1 1 VGRm length -- {dup VGRm exch XY exch -- VGRm exch XY "
 		"1 index sub %d div exch %d ++ {"
 		"dup %.2f exch M %.2f 0 LR dup %.2f exch M %.2f 0 LR S "
-		"1 index add} repeat pop pop} for ", div, div, PS.map_x - margin, -width, PS.map_right + margin, width);
+		"1 index add} repeat pop pop} for ", div, div,
+		PS.map_x - margin, -width, PS.map_right + margin, width);
 	fprintf(PS.fp,
 		"1 1 HGRm length -- {dup HGRm exch XY exch -- HGRm exch XY "
 		"dup %.2f M 0 %.2f LR dup %.2f M 0 %.2f LR S "
-		"1 index add} repeat pop pop} for ", div, div, PS.map_y - margin, -width, PS.map_top + margin, width);
+		PS.map_y - margin, -width, PS.map_top + margin, width);
-    if (div > 1)
+    if (div > 1) {
 	fprintf(PS.fp,
 		"VGRm 0 XY VGRm 1 XY 1 index sub neg %d div exch {"
 		"1 index add dup %.2f gt {exit} {"
-		"} ifelse} loop ", div, PS.map_top, PS.map_x - margin, -width, PS.map_right + margin, width);
+		"} ifelse} loop ", div, PS.map_top, PS.map_x - margin, -width,
+		PS.map_right + margin, width);
 	fprintf(PS.fp,
 		"/i VGRm length -- def VGRm i XY VGRm i -- XY 1 index sub neg %d div exch {"
 		"1 index add dup %.2f lt {exit} {"
-		"} ifelse} loop ", div, PS.map_y, PS.map_x - margin, -width, PS.map_right + margin, width);
+		"} ifelse} loop ", div, PS.map_y, PS.map_x - margin, -width,
 	fprintf(PS.fp,
 		"HGRm 0 XY HGRm 1 XY 1 index sub neg %d div exch {"
-		"} ifelse} loop ", div, PS.map_x, PS.map_y - margin, -width, PS.map_top + margin, width);
+		"} ifelse} loop ", div, PS.map_x, PS.map_y - margin, -width,
+		PS.map_top + margin, width);
 	fprintf(PS.fp,
 		"/i HGRm length -- def HGRm i XY HGRm i -- XY 1 index sub neg %d div exch {"
-		"} ifelse} loop\n", div, PS.map_right, PS.map_y - margin, -width, PS.map_top + margin, width);
+		"} ifelse} loop\n", div, PS.map_right, PS.map_y - margin,
+		-width, PS.map_top + margin, width);
@@ -409,17 +428,18 @@
 	    "%.2f M %.2f 0 exch LR %.2f M %.2f 0 exch LRS} for\n",
-    if (midline > 0)
+    if (midline > 0) {
 	fprintf(PS.fp, "GS %.2f LW ", midline);
 	fprintf(PS.fp,
 		"1 2 VGRm length -- {/i XD VGRm i XY VGRm i -- XY 2 copy "
-		"%.2f exch M cP pop exch LS %.2f exch M cP pop exch LS} for\n", PS.map_x - dist, PS.map_right + dist);
+		"%.2f exch M cP pop exch LS %.2f exch M cP pop exch LS} for\n",
+		PS.map_x - dist, PS.map_right + dist);
 	fprintf(PS.fp,
 		"1 2 HGRm length -- {/i XD HGRm i XY HGRm i -- XY 2 copy "
-		"%.2f M cP exch pop LS %.2f M cP exch pop LS} for\n", PS.map_y - dist, PS.map_top + dist);
+		"%.2f M cP exch pop LS %.2f M cP exch pop LS} for\n",
+		PS.map_y - dist, PS.map_top + dist);
 	fprintf(PS.fp,
 		"VGRm length 2 mod 0 ne {VGRm dup length -- XY %.2f 2 copy "
@@ -428,7 +448,8 @@
 	fprintf(PS.fp,
 		"HGRm length 2 mod 0 ne {HGRm dup length -- XY %.2f 2 copy "
-		"%.2f M cP exch pop LS %.2f M cP exch pop LS} if\n", PS.map_right, PS.map_y - dist, PS.map_top + dist);
+		"%.2f M cP exch pop LS %.2f M cP exch pop LS} if\n",
+		PS.map_right, PS.map_y - dist, PS.map_top + dist);
@@ -454,14 +475,18 @@
 void set_grid_corners(double margin, double width)
     fprintf(PS.fp, "%.2f cLW 2 div sub %.2f cLW 2 div sub M "
-	    "%.2f dup 0 LR neg 0 exch LRS ", PS.map_x - margin - width, PS.map_y - margin, width);
+	    "%.2f dup 0 LR neg 0 exch LRS ", PS.map_x - margin - width,
+	    PS.map_y - margin, width);
     fprintf(PS.fp, "%.2f cLW 2 div sub %.2f cLW 2 div add M "
-	    "%.2f dup 0 LR 0 exch LRS ", PS.map_x - margin - width, PS.map_top + margin, width);
+	    "%.2f dup 0 LR 0 exch LRS ", PS.map_x - margin - width,
     fprintf(PS.fp, "%.2f cLW 2 div add %.2f cLW 2 div sub M "
-	    "%.2f neg dup 0 LR 0 exch LRS ", PS.map_right + margin + width, PS.map_y - margin, width);
+	    "%.2f neg dup 0 LR 0 exch LRS ", PS.map_right + margin + width,
     fprintf(PS.fp, "%.2f cLW 2 div add %.2f cLW 2 div add M "
-	    "%.2f dup neg 0 LR 0 exch LRS ", PS.map_right + margin + width, PS.map_top + margin, width);
+	    "%.2f dup neg 0 LR 0 exch LRS ", PS.map_right + margin + width,
Modified: grass-addons/postscript/ps.output/set_mask.c
--- grass-addons/postscript/ps.output/set_mask.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_mask.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -19,50 +19,46 @@
 int set_mask(void)
     int i, byte, row, col, br;
     void *cbuf, *cptr;
     RASTER_MAP_TYPE map_type;
     static int bit[] = { 128, 64, 32, 16, 8, 4, 2, 1 };
-    if (PS.rst.fd[1] < 0)
-    {				/* there is no mask */
+    if (PS.rst.fd[1] < 0) {	/* there is no mask */
 	G_warning(_("Any raster mask to read, don't mask!"));
 	if (PS.need_mask)
 	    PS.need_mask = 0;
 	return 0;
-    fprintf(PS.fp, "currentfile /ASCIIHexDecode filter /ReusableStreamDecode filter\n");
+    fprintf(PS.fp,
+	    "currentfile /ASCIIHexDecode filter /ReusableStreamDecode filter\n");
     /* storing the bytes of the mask */
     map_type = G_get_raster_map_type(PS.rst.fd[1]);
     cbuf = G_allocate_raster_buf(map_type);
-    for (br = 0, row = 0; row < PS.map.rows; row++)
+    for (br = 0, row = 0; row < PS.map.rows; row++) {
 	G_get_raster_row(PS.rst.fd[1], cbuf, row, map_type);
 	cptr = cbuf;
 	i = byte = 0;
-	for (col = 0; col < PS.map.cols; col++)
-	    if (G_is_null_value(cptr, map_type))
+	for (col = 0; col < PS.map.cols; col++) {
+	    if (G_is_null_value(cptr, map_type)) {
 		byte |= bit[i];
 	    ++i;
-	    if (i == 8)
+	    if (i == 8) {
 		fprintf(PS.fp, "%02x", byte);
 		i = byte = 0;
-	    if (br++ == 45)
+	    if (br++ == 45) {
 		br = 0;
 	    cptr = G_incr_void_ptr(cptr, G_raster_size(map_type));
-	if (i)
+	if (i) {
 	    while (i < 8)
 		byte |= bit[i++];
@@ -79,7 +75,8 @@
     fprintf(PS.fp, "   /BitsPerComponent 1\n");
     /* fprintf(PS.fp, "   /Interpolate true\n"); */
     fprintf(PS.fp, "   /Decode [1 0]\n");
-    fprintf(PS.fp, "   /ImageMatrix [%d 0 0 %d 0 %d]\n", PS.map.cols, -PS.map.rows, PS.map.rows);
+    fprintf(PS.fp, "   /ImageMatrix [%d 0 0 %d 0 %d]\n", PS.map.cols,
+	    -PS.map.rows, PS.map.rows);
     fprintf(PS.fp, "   /DataSource maskstream\n");
     fprintf(PS.fp, ">> store\n");
@@ -87,7 +84,8 @@
     fprintf(PS.fp, "maskstream resetfile\n");
     fprintf(PS.fp, "mapstream resetfile\n");
     fprintf(PS.fp, "gsave\n");
-    fprintf(PS.fp, "  /Device%s setcolorspace\n", PS.rst.do_grey ? "Gray" : "RGB");
+    fprintf(PS.fp, "  /Device%s setcolorspace\n",
+	    PS.rst.do_grey ? "Gray" : "RGB");
     fprintf(PS.fp, "  %.2f %.2f translate\n", PS.map_x, PS.map_y);
     fprintf(PS.fp, "  %.1f %.1f scale\n", PS.map_w, PS.map_h);
     fprintf(PS.fp, "  << /ImageType 3\n");
Modified: grass-addons/postscript/ps.output/set_note.c
--- grass-addons/postscript/ps.output/set_note.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_note.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,20 +21,20 @@
 int set_note(int i)
     int rows, type;
     double x, y, dy, fontsize;
     char *chr, *str, txt[1024];
     rows = 0;			/* useful to decide if write it */
     fontsize = set_ps_font(&(PS.note[i].font));
-    if (strncmp(PS.note[i].text, ":file", 5) == 0)
+    if (strncmp(PS.note[i].text, ":file", 5) == 0) {
 	str = PS.note[i].text + 6;
 	rows = note_in_file(str);
 	type = -1;
-    else if (strncmp(PS.note[i].text, ":maplim", 7) == 0)
+    else if (strncmp(PS.note[i].text, ":maplim", 7) == 0) {
 	char label[50];
 	/* get north, south, east and west strings */
@@ -51,29 +51,27 @@
 	rows = 4;
 	type = 0;
-    else if (strncmp(PS.note[i].text, ":dimen", 6) == 0)
+    else if (strncmp(PS.note[i].text, ":dimen", 6) == 0) {
 	fprintf(PS.fp, "/ARo [\n");
 	fprintf(PS.fp, "(Map Area)");
-	fprintf(PS.fp, "(Position: %.1f mm x %.1f mm)\n", POINT_TO_MM * PS.map_x, POINT_TO_MM * PS.map_y);
-	fprintf(PS.fp, "(Dimension: %.1f mm x %.1f mm)\n", POINT_TO_MM * PS.map_w, POINT_TO_MM * PS.map_h);
+	fprintf(PS.fp, "(Position: %.1f mm x %.1f mm)\n",
+		POINT_TO_MM * PS.map_x, POINT_TO_MM * PS.map_y);
+	fprintf(PS.fp, "(Dimension: %.1f mm x %.1f mm)\n",
+		POINT_TO_MM * PS.map_w, POINT_TO_MM * PS.map_h);
 	rows = 3;
 	type = 1;
-    else if (strncmp(PS.note[i].text, ":scale", 6) == 0)
+    else if (strncmp(PS.note[i].text, ":scale", 6) == 0) {
 	str = PS.note[i].text + 7;
 	fprintf(PS.fp, "/ARo [(%s 1 : %d)] def\n", str, PS.scale);
 	rows = 1;
 	type = 2;
-    else
-    {				/* free line of text with "|" to cut lines */
+    else {			/* free line of text with "|" to cut lines */
 	chr = str = PS.note[i].text;
-	while (*chr)
+	while (*chr) {
 	    while (*str && *str != '|')
 		str++;
 	    *str++ = '\0';
@@ -85,24 +83,23 @@
 	type = 4;
-    if (rows > 0)
+    if (rows > 0) {
 	/* Define ARw */
-	if (PS.note[i].width > 0.)
-            x = PS.note[i].box.margin;
-            if (x < 0.)
-                x = 0.4 * PS.note[i].font.size;
+	if (PS.note[i].width > 0.) {
+	    x = PS.note[i].box.margin;
+	    if (x < 0.)
+		x = 0.4 * PS.note[i].font.size;
-            fprintf(PS.fp, "/ARw [%.3f] def\n", PS.note[i].width - 2 * x);
+	    fprintf(PS.fp, "/ARw [%.3f] def\n", PS.note[i].width - 2 * x);
 	else
-            fprintf(PS.fp, "/ARw [ARo SWx] def\n");
-            //fprintf(PS.fp, "/ARw 1 array def ARw 0 ARo SWx put\n");
+	    fprintf(PS.fp, "/ARw [ARo SWx] def\n");
+	//fprintf(PS.fp, "/ARw 1 array def ARw 0 ARo SWx put\n");
 	/* Define ARh: todas de igual altura */
 	fprintf(PS.fp, "/ARh ARo length array def ");
-	fprintf(PS.fp, "0 1 ARo length -- {ARh exch %.2f put} for\n", fontsize);
+	fprintf(PS.fp, "0 1 ARo length -- {ARh exch %.2f put} for\n",
+		fontsize);
 	/* Make de frame */
 	set_box_orig(&(PS.note[i].box));
@@ -113,19 +110,23 @@
 	/* Draw the content */
 	fprintf(PS.fp, "RESET ");
-	fprintf(PS.fp, "0 1 ARo length 1 sub {dup ROW ARo exch get x y ARh row get sub M ");
-	switch (type)
+	fprintf(PS.fp,
+		"0 1 ARo length 1 sub {dup ROW ARo exch get x y ARh row get sub M ");
+	switch (type) {
 	case 0:
-	    fprintf(PS.fp, "GS dup SW ARw 0 get exch sub 0 32 4 -1 roll widthshow GR");
+	    fprintf(PS.fp,
+		    "GS dup SW ARw 0 get exch sub 0 32 4 -1 roll widthshow GR");
 	    break;
 	case 2:
-	    fprintf(PS.fp, "GS dup SWH exch pop 0 MR %.2f ROT show GR", PS.note[i].angle);
+	    fprintf(PS.fp, "GS dup SWH exch pop 0 MR %.2f ROT show GR",
+		    PS.note[i].angle);
 	    break;
 	default:
-	    fprintf(PS.fp, "(.) anchorsearch {GS pop %.3f 2 div 0 MR SHC GR} {SHL} ifelse", PS.note[i].width);
+	    fprintf(PS.fp,
+		    "(.) anchorsearch {GS pop %.3f 2 div 0 MR SHC GR} {SHL} ifelse",
+		    PS.note[i].width);
 	    break;
 	fprintf(PS.fp, "} for\n");
@@ -137,21 +138,20 @@
 int note_in_file(char *name)
     FILE *in = NULL;
     char buf[1024];
     int r = 0;
-    if (*name)
+    if (*name) {
-	if (in == NULL)
+	if (in == NULL) {
 	    G_message(_("Comment file <%s> can't open"), name);
 	    return 0;
-    {				/* TODO don't read end-of-line */
+    while (fgets(buf, sizeof(buf), in)) {	/* TODO don't read end-of-line */
 	fprintf(PS.fp, "(%s)\n", buf);
 	++r;
Modified: grass-addons/postscript/ps.output/set_outline.c
--- grass-addons/postscript/ps.output/set_outline.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_outline.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -18,12 +18,16 @@
 int set_outline(void)
     int row, col;
     double nrow, n_rw, erow, e_rw;
     void *rbuf, *nbuf, *rptr, *nptr, *next;
     /* let user know what's happenning */
-    G_message(_("Reading raster map <%s in %s> ..."), PS.rst.name[0], PS.rst.mapset[0]);
+    G_message(_("Reading raster map <%s in %s> ..."), PS.rst.name[0],
+	      PS.rst.mapset[0]);
     /* set the outline color and width */
     set_ps_line(&(PS.rst.outline));
@@ -34,8 +38,7 @@
     map_type = G_get_raster_map_type(PS.rst.fd[0]);
     rbuf = G_allocate_raster_buf(map_type);
     nbuf = G_allocate_raster_buf(map_type);
-    for (row = 0; row < PS.map.rows - 1; row++)
+    for (row = 0; row < PS.map.rows - 1; row++) {
 	nrow = G_row_to_northing((double)row, &(PS.map));
 	n_rw = G_row_to_northing((double)row + 1, &(PS.map));
 	/* load buffers */
@@ -44,21 +47,18 @@
 	/* set pointers */
 	rptr = rbuf;
 	nptr = nbuf;
-	for (col = 0; col < PS.map.cols - 1; col++)
+	for (col = 0; col < PS.map.cols - 1; col++) {
 	    erow = G_col_to_easting((double)col + 1, &(PS.map));
 	    e_rw = G_col_to_easting((double)col, &(PS.map));
 	    /* check right outline */
 	    next = G_incr_void_ptr(rptr, G_raster_size(map_type));
-	    if (G_raster_cmp(rptr, next, map_type) != 0)
+	    if (G_raster_cmp(rptr, next, map_type) != 0) {
 		set_ps_where('M', erow, nrow);
 		set_ps_where('L', erow, n_rw);
 		fprintf(PS.fp, "S\n");
 	    /* check bottom outline */
-	    if (G_raster_cmp(rptr, nptr, map_type) != 0)
+	    if (G_raster_cmp(rptr, nptr, map_type) != 0) {
 		set_ps_where('M', e_rw, n_rw);
Modified: grass-addons/postscript/ps.output/set_ps.c
--- grass-addons/postscript/ps.output/set_ps.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_ps.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -24,14 +24,16 @@
 void set_ps_brd(double margin)
     fprintf(PS.fp, "%.3f %.3f %.3f %.3f RO\n",
-	    PS.map_x - margin, PS.map_y - margin, PS.map_w + 2. * margin, PS.map_h + 2. * margin);
+	    PS.map_x - margin, PS.map_y - margin, PS.map_w + 2. * margin,
+	    PS.map_h + 2. * margin);
     return;
 void set_ps_brd2(double lwidth, double margin)
     fprintf(PS.fp, "%.3f LW %.3f %.3f %.3f %.3f RO\n",
-	    lwidth, PS.map_x - margin, PS.map_y - margin, PS.map_w + 2. * margin, PS.map_h + 2. * margin);
+	    lwidth, PS.map_x - margin, PS.map_y - margin,
+	    PS.map_w + 2. * margin, PS.map_h + 2. * margin);
     return;
@@ -40,6 +42,7 @@
 int set_ps_where(char action, double east, double north)
     int x, y;
     double dx, dy;
     G_plot_where_xy(east, north, &x, &y);
@@ -57,6 +60,7 @@
 int set_xy_where(char *pre, double east, double north, char *post)
     int x, y;
     double dx, dy;
@@ -71,6 +75,7 @@
 int is_xy_outside(double east, double north)
     int x, y;
     double dx, dy;
@@ -78,7 +83,8 @@
-    if (dx < PS.map_x || dx > PS.map_right || dy < PS.map_y || dy > PS.map_top)
+    if (dx < PS.map_x || dx > PS.map_right || dy < PS.map_y ||
+	dy > PS.map_top)
 	return 1;
     return 0;
@@ -90,24 +96,26 @@
 int set_ps_pattern(int code, char *eps, VAREAS * va)
     FILE *fp;
     char buf[1024];
     int ret = 0;
     double llx, lly, urx, ury;
-    if ((fp = fopen(eps, "r")) == NULL)
+    if ((fp = fopen(eps, "r")) == NULL) {
 	G_message("File <%s> not found!\n", eps);
 	return 0;
     /* find the bounding box in EPS */
     llx = lly = urx = ury = 0.;
-    while (fgets(buf, 128, fp) != NULL && ret != 4)
-	ret = sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf", &llx, &lly, &urx, &ury);
+    while (fgets(buf, 128, fp) != NULL && ret != 4) {
+	ret =
+	    sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf", &llx, &lly, &urx,
+		   &ury);
-    if (llx == 0. && lly == 0. && urx == 0. && ury == 0.)
+    if (llx == 0. && lly == 0. && urx == 0. && ury == 0.) {
 	fclose(fp);
 	error(eps, "", "ERROR: Bounding box in <%s> was not found");
@@ -118,14 +126,15 @@
     ury *= va->sc_pat;
     fprintf(PS.fp, "/PATTERN%d\n", code);
-    fprintf(PS.fp, "<< /PatternType 1\n   /PaintType %d\n   /TilingType 1\n", va->type_pat);
+    fprintf(PS.fp, "<< /PatternType 1\n   /PaintType %d\n   /TilingType 1\n",
+	    va->type_pat);
     fprintf(PS.fp, "   /BBox [%.4f %.3f %.4f %.4f]\n", llx, lly, urx, ury);
-    fprintf(PS.fp, "   /XStep %.4f\n   /YStep %.4f\n", (urx - llx), (ury - lly));
+    fprintf(PS.fp, "   /XStep %.4f\n   /YStep %.4f\n", (urx - llx),
+	    (ury - lly));
     fprintf(PS.fp, "   /PaintProc\n");
     fprintf(PS.fp, "   { begin\n");
     fprintf(PS.fp, "     %.4f dup scale\n", va->sc_pat);
-    if (va->type_pat == 1)
+    if (va->type_pat == 1) {
 	fprintf(PS.fp, "     ");
 	set_ps_color(&(va->fcolor));
@@ -146,18 +155,18 @@
 int set_ps_symbol_eps(int code, char *eps)
     FILE *fp;
     char buf[1024];
 	return 0;
     fprintf(PS.fp, "/SYMBOL%d {\n", code);
-    while (fgets(buf, 1024, fp) != NULL)
-	if (strncmp(buf, "%!PS-Adobe", 10) == 0 || strncmp(buf, "%%BoundingBox", 13) == 0)
+    while (fgets(buf, 1024, fp) != NULL) {
+	if (strncmp(buf, "%!PS-Adobe", 10) == 0 ||
+	    strncmp(buf, "%%BoundingBox", 13) == 0)
 	    continue;
 	fprintf(PS.fp, "     %s", buf);
Modified: grass-addons/postscript/ps.output/set_raster.c
--- grass-addons/postscript/ps.output/set_raster.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_raster.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -28,15 +28,15 @@
     int i;
     /* starting */
-    if (PS.need_mask && PS.rst.do_mask)
+    if (PS.need_mask && PS.rst.do_mask) {
+	fprintf(PS.fp,
-    else
+    else {
 	/* Map Dictionary when no mask needed, no reusable stream */
-	fprintf(PS.fp, "/Device%s setcolorspace\n", PS.rst.do_grey ? "Gray" : "RGB");
+	fprintf(PS.fp, "/Device%s setcolorspace\n",
 	fprintf(PS.fp, "%.2f %.2f translate\n", PS.map_x, PS.map_y);
 	fprintf(PS.fp, "%.1f %.1f scale\n", PS.map_w, PS.map_h);
 	fprintf(PS.fp, "<< /ImageType 1\n");
@@ -44,31 +44,29 @@
 	fprintf(PS.fp, "   /Height %d\n", PS.map.rows);
 	fprintf(PS.fp, "   /BitsPerComponent 8\n");
-	fprintf(PS.fp, "   /Decode [%s]\n", PS.rst.do_grey ? "0 1" : "0 1 0 1 0 1");
+	fprintf(PS.fp, "   /Decode [%s]\n",
+		PS.rst.do_grey ? "0 1" : "0 1 0 1 0 1");
 	fprintf(PS.fp, "   /DataSource currentfile /ASCIIHexDecode filter\n");
 	fprintf(PS.fp, ">> ");
 	fprintf(PS.fp, "image\n");
     /* split loading stream for some better speed */
-    if (PS.rst.do_rgb)
+    if (PS.rst.do_rgb) {
 	set_raster_rgb();
-    else if (PS.rst.do_mask)
+    else if (PS.rst.do_mask) {
 	if (PS.rst.fd[2] < 0)
 	    set_raster_maskcolor();
 	else
 	    set_raster_maskcell();
-    else
+    else {
 	set_raster_cell();
     /* ending */
 	fprintf(PS.fp, "\n> ");
 	fprintf(PS.fp, "/mapstream exch def\n");
 	/* Map Dictionary when mask needed, reusable stream */
@@ -78,19 +76,21 @@
 	fprintf(PS.fp, "   /DataSource mapstream\n");
 	fprintf(PS.fp, "  mapstream resetfile\n");
 	fprintf(PS.fp, "  MapDictionary image\n");
-    else
+    else {
 	fprintf(PS.fp, ">\n");
@@ -102,36 +102,35 @@
 int set_raster_cell(void)
     int row, col, br, R, G, B;
     void *cbuf, *cptr;
     /* storing the bytes of the image */
 	G_get_raster_row(PS.rst.fd[0], cbuf, row, map_type);
 	cptr = cbuf;
 	    /* get the map colors */
-	    G_get_raster_color(cptr, &R, &G, &B, &(PS.rst.colors[0]), map_type);
+	    G_get_raster_color(cptr, &R, &G, &B, &(PS.rst.colors[0]),
+			       map_type);
 	    /* processing data to the postscript file */
-	    if (PS.rst.do_grey)
+	    if (PS.rst.do_grey) {
 		fprintf(PS.fp, "%02X", (int)NTSC(R, G, B));
-	    else
+	    else {
 		fprintf(PS.fp, "%02X%02X%02X", R, G, B);
-	    if (br++ == 15)
+	    if (br++ == 15) {
 		br = 0;
@@ -146,8 +145,11 @@
 int set_raster_rgb(void)
     int i, row, col, br;
     int R[3], G[3], B[3];
     void *cbuf[3], *cptr[3];
     RASTER_MAP_TYPE map_type[3];
@@ -155,35 +157,31 @@
     G_message(_("Reading raster maps in group <%s> ..."), PS.rst.title);
 	map_type[i] = G_get_raster_map_type(PS.rst.fd[i]);
 	cbuf[i] = G_allocate_raster_buf(map_type[i]);
 	    G_get_raster_row(PS.rst.fd[i], cbuf[i], row, map_type[i]);
 	    cptr[i] = cbuf[i];
-	    G_get_raster_color(cptr[0], &(R[0]), &(G[0]), &(B[0]), &(PS.rst.colors[0]), map_type[0]);
-	    G_get_raster_color(cptr[1], &(R[1]), &(G[1]), &(B[1]), &(PS.rst.colors[1]), map_type[1]);
-	    G_get_raster_color(cptr[2], &(R[2]), &(G[2]), &(B[2]), &(PS.rst.colors[2]), map_type[2]);
+	    G_get_raster_color(cptr[0], &(R[0]), &(G[0]), &(B[0]),
+			       &(PS.rst.colors[0]), map_type[0]);
+	    G_get_raster_color(cptr[1], &(R[1]), &(G[1]), &(B[1]),
+			       &(PS.rst.colors[1]), map_type[1]);
+	    G_get_raster_color(cptr[2], &(R[2]), &(G[2]), &(B[2]),
+			       &(PS.rst.colors[2]), map_type[2]);
 		fprintf(PS.fp, "%02X", (int)NTSC(R[0], G[1], B[2]));
-	    else
+	    else {
 		fprintf(PS.fp, "%02X%02X%02X", R[0], G[1], B[2]);
-	    if (br++ == 15)
+	    if (br++ == 15) {
 		br = 0;
@@ -193,8 +191,7 @@
 	    cptr[2] = G_incr_void_ptr(cptr[2], G_raster_size(map_type[2]));
 	G_free(cbuf[i]);
 	G_free_colors(&(PS.rst.colors[i]));
@@ -209,9 +206,13 @@
 int set_raster_maskcell(void)
     int r, g, b, R[3], G[3], B[3];
     double f, red, green, blue;
     red = (1. - PS.rst.mask_color.r);
@@ -222,63 +223,57 @@
     B[1] = (int)(255. * PS.rst.mask_color.b);
-    G_message(_("Reading raster map <%s in %s> ... %d rows"), PS.rst.name[0], PS.rst.mapset[0], PS.map.rows);
-    G_message(_("... mask raster <%s in %s>"), PS.rst.name[1], PS.rst.mapset[1]);
-    G_message(_("... background raster <%s in %s>"), PS.rst.name[2], PS.rst.mapset[2]);
+    G_message(_("Reading raster map <%s in %s> ... %d rows"), PS.rst.name[0],
+	      PS.rst.mapset[0], PS.map.rows);
+    G_message(_("... mask raster <%s in %s>"), PS.rst.name[1],
+	      PS.rst.mapset[1]);
+    G_message(_("... background raster <%s in %s>"), PS.rst.name[2],
+	      PS.rst.mapset[2]);
 	    /* G_get_raster_row(PS.rst.fd[i], cbuf[i], row, map_type[i]); */
 	    G_get_raster_row_nomask(PS.rst.fd[i], cbuf[i], row, map_type[i]);
 	    cptr[i] = cbuf[i];
 	    /* select color by mask */
-	    if (G_is_null_value(cptr[1], map_type[1]))
-		if (PS.rst.mask_color.none)
+	    if (G_is_null_value(cptr[1], map_type[1])) {
+		if (PS.rst.mask_color.none) {
 		    r = R[2];
 		    g = G[2];
 		    b = B[2];
-		else
+		else {
 		    f = (double)GREY(R[2], G[2], B[2]);
 		    r = (int)(f * red + (double)R[1]);
 		    g = (int)(f * green + (double)G[1]);
 		    b = (int)(f * blue + (double)B[1]);
-	    else
+	    else {
 		r = R[0];
 		g = G[0];
 		b = B[0];
 		fprintf(PS.fp, "%02X", (int)NTSC(r, g, b));
-	    else
+	    else {
 		fprintf(PS.fp, "%02X%02X%02X", r, g, b);
-	    if (br++ == 15)
+	    if (br++ == 15) {
 		br = 0;
@@ -300,60 +295,56 @@
 int set_raster_maskcolor(void)
     int color, r, g, b, R, G, B;
     void *cbuf[2], *cptr[2];
     RASTER_MAP_TYPE map_type[2];
 	r = g = b = 255.;
-    else
+    else {
 	r = (int)(255. * PS.rst.mask_color.r);
 	g = (int)(255. * PS.rst.mask_color.g);
 	b = (int)(255. * PS.rst.mask_color.b);
-    G_message(_("... raster to mask <%s in %s>"), PS.rst.name[1], PS.rst.mapset[1]);
+    G_message(_("... raster to mask <%s in %s>"), PS.rst.name[1],
-    for (i = 0; i < 2; i++)
+    for (i = 0; i < 2; i++) {
 	    cptr[i] = cbuf[i];
-	    G_get_raster_color(cptr[0], &R, &G, &B, &(PS.rst.colors[0]), map_type[0]);
+	    G_get_raster_color(cptr[0], &R, &G, &B, &(PS.rst.colors[0]),
+			       map_type[0]);
 		R = r;
 		G = g;
 		B = b;
-	    else
+	    else {
-	    if (br++ == 15)
+	    if (br++ == 15) {
 		br = 0;
Modified: grass-addons/postscript/ps.output/set_rlegend.c
--- grass-addons/postscript/ps.output/set_rlegend.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_rlegend.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -20,29 +20,32 @@
 int set_rlegend_cats(void)
     int i, j, k, n, R, G, B;
     char *label;
     int num_cats, rows, cols;
     double fontsize, fwidth;
     DCELL dmin, dmax, val;
     /* Let user know what's happenning */
-    G_message(_("Raster legend with category <%s in %s>..."), PS.rl.name, PS.rl.mapset);
+    G_message(_("Raster legend with category <%s in %s>..."), PS.rl.name,
+	      PS.rl.mapset);
     /* Load the categories */
-    if (G_read_raster_cats(PS.rl.name, PS.rl.mapset, &(PS.rst.cats)) != 0)
+    if (G_read_raster_cats(PS.rl.name, PS.rl.mapset, &(PS.rst.cats)) != 0) {
 	G_warning(_("Category file for <%s> not available"), PS.rl.name);
 	return 1;
     /* Reload colors if raster in rlegend is not the same as raster command.
        If the same, don't touch to not overwrite setcolor command */
-    if (strcmp(PS.rl.name, PS.rst.name[0]) != 0)
+    if (strcmp(PS.rl.name, PS.rst.name[0]) != 0) {
 	G_warning("Using color table of %s in %s", PS.rl.name, PS.rl.mapset);
-	if (G_read_colors(PS.rl.name, PS.rl.mapset, &PS.rst.colors[0]) == -1)
-	    G_warning("Can't load color table of %s in %s", PS.rl.name, PS.rl.mapset);
+	if (G_read_colors(PS.rl.name, PS.rl.mapset, &PS.rst.colors[0]) == -1) {
+	    G_warning("Can't load color table of %s in %s", PS.rl.name,
+		      PS.rl.mapset);
 	    return 1;
 	PS.rst.do_grey = 0;	/* Null grey because is not the same map as raster */
@@ -51,8 +54,7 @@
     /* Sort categories by user (min value) */
     CELL *ip = (CELL *) G_malloc(sizeof(CELL) * PS.rst.cats.ncats);
-    for (i = 0; i < PS.rst.cats.ncats; i++)
+    for (i = 0; i < PS.rst.cats.ncats; i++) {
 	G_get_ith_d_raster_cat(&(PS.rst.cats), i, &dmin, &dmax);
 	ip[i] = (CELL) dmin;
@@ -61,28 +63,25 @@
     /* How many categories to show */
     G_debug(3, "colortable: %d categories", num_cats);
     num_cats = PS.rst.cats.ncats;
-    if (num_cats <= 0)
+    if (num_cats <= 0) {
 	G_warning(_("Your cats/ file is invalid. A cats/ file with "
 		    "categories and labels is required for 'colortable' when using "
-		    "CELL rasters. No colortable will be assigned to this output " "postscript file."));
+		    "CELL rasters. No colortable will be assigned to this output "
+		    "postscript file."));
 	return 1;
-    else if (num_cats > 100)
+    else if (num_cats > 100) {
 	G_warning(_("Your cats/ file has %d cats (limit to 100)!"), num_cats);
     if (PS.rl.do_nodata)
 	++num_cats;		/* slot for no_data */
     /* define number of rows */
-    if (num_cats < PS.rl.legend.cols)
+    if (num_cats < PS.rl.legend.cols) {
 	PS.rl.legend.cols = num_cats;
 	rows = 1;
-    else
+    else {
 	rows = (int)num_cats / PS.rl.legend.cols;
 	if (num_cats % PS.rl.legend.cols)
 	    ++rows;
@@ -101,45 +100,44 @@
     fprintf(PS.fp, "/ARw %d array def\n", cols);
     i = PS.rl.do_nodata ? 0 : 1;
-    for (n = 0; n < cols; n++)
+    for (n = 0; n < cols; n++) {
 	fprintf(PS.fp, "/AR%d [\n", n);
-	for (j = 0; j < rows && i < num_cats; j++, i++)
+	for (j = 0; j < rows && i < num_cats; j++, i++) {
 	    /* labels */
-	    if (i == 0)
+	    if (i == 0) {
 		fprintf(PS.fp, "(%s) ", "no data");
 		G_get_null_value_color(&R, &G, &B, &(PS.rst.colors[0]));
 		dmin = dmax = 0.;
-	    else
-		label = G_get_ith_d_raster_cat(&(PS.rst.cats), ip[i - 1], &dmin, &dmax);
+	    else {
+		label =
+		    G_get_ith_d_raster_cat(&(PS.rst.cats), ip[i - 1], &dmin,
+					   &dmax);
 		fprintf(PS.fp, "(%s) ", label);
 	    /* colors */
 	    fprintf(PS.fp, "[");
-	    if (dmin == dmax)
+	    if (dmin == dmax) {
 		G_get_d_raster_color(&dmin, &R, &G, &B, &(PS.rst.colors[0]));
-		fprintf(PS.fp, "%.3f %.3f %.3f", R / 255., G / 255., B / 255.);
+		fprintf(PS.fp, "%.3f %.3f %.3f", R / 255., G / 255.,
+			B / 255.);
-	    else
-		for (k = 0; k < 5; k++)
+	    else {
+		for (k = 0; k < 5; k++) {
 		    val = dmin + (double)k *(dmax - dmin) / 5;
-		    G_get_d_raster_color(&val, &R, &G, &B, &(PS.rst.colors[0]));
-		    fprintf(PS.fp, "%.3f %.3f %.3f ", R / 255., G / 255., B / 255.);
+		    G_get_d_raster_color(&val, &R, &G, &B,
+					 &(PS.rst.colors[0]));
+		    fprintf(PS.fp, "%.3f %.3f %.3f ", R / 255., G / 255.,
+			    B / 255.);
 	    fprintf(PS.fp, "]\n");
 	fprintf(PS.fp, "/mx 0 def 0 2 AR%d length -- {", n);
-	fprintf(PS.fp, "AR%d exch get SW /t XD t mx gt {/mx t def} if} for\n", n);
+	fprintf(PS.fp, "AR%d exch get SW /t XD t mx gt {/mx t def} if} for\n",
+		n);
 	fprintf(PS.fp, "ARw %d mx put\n", n);
@@ -159,23 +157,26 @@
     fprintf(PS.fp, "/xw syw %.2f mul def ", 0.8);	/* symbol-width */
     fprintf(PS.fp, "/yh %.2f def ", -fontsize);	/* symbol-height */
     fprintf(PS.fp, "/t yh %d div def\n", 5);	/* gradient symbol-height, if any */
 	fprintf(PS.fp, "%d COL 0 ROW\n", n);
 	fprintf(PS.fp, "0 2 AR%d length -- {/i XD\n", n);
 	fprintf(PS.fp, "x y -- xw yh\nAR%d i ++ get aload length 3 eq ", n);
 	fprintf(PS.fp, "{%s 4 copy RF} ", PS.rst.do_grey ? "CG" : "C");
-	fprintf(PS.fp, "{/z y def %d {C /z t add def x z xw t neg RF} repeat} ", 5);
+	fprintf(PS.fp,
+		"{/z y def %d {C /z t add def x z xw t neg RF} repeat} ", 5);
 	fprintf(PS.fp, "ifelse\n0 0 0 C RE\n");
 	set_ps_color(&(PS.rl.legend.font.color));
-	fprintf(PS.fp, "AR%d i get x syw add y ARh row get sub MS row 1 add ROW} for\n", n);
+	fprintf(PS.fp,
+		"AR%d i get x syw add y ARh row get sub MS row 1 add ROW} for\n",
+		n);
     /* Make the title of legend */
-    if (PS.rl.legend.title[0] != 0)
+    if (PS.rl.legend.title[0] != 0) {
 	set_ps_font(&(PS.rl.legend.title_font));
-	fprintf(PS.fp, "xo mgx add yo mgy mg sub sub M wd mgx 2 mul sub (%s) SHS\n", PS.rl.legend.title);
+	fprintf(PS.fp,
+		"xo mgx add yo mgy mg sub sub M wd mgx 2 mul sub (%s) SHS\n",
+		PS.rl.legend.title);
     return 0;
@@ -185,52 +186,54 @@
 int set_rlegend_gradient(void)
     int i, k, rows, nlines, dec;
     int R, G, B;
     double fontsize, step, fwidth;
     struct Colors colors;
     struct FPRange range;
     char *units[GNAME_MAX];
     char format[50];
-    G_message(_("Raster legend with gradient <%s in %s> ..."), PS.rl.name, PS.rl.mapset);
+    G_message(_("Raster legend with gradient <%s in %s> ..."), PS.rl.name,
+	      PS.rl.mapset);
     /* Get color range */
-    if (G_read_fp_range(PS.rl.name, PS.rl.mapset, &range) == -1)
+    if (G_read_fp_range(PS.rl.name, PS.rl.mapset, &range) == -1) {
 	G_warning(_("Range information not available (run r.support)"));
 	return 1;
     /* range and check */
-    if (PS.rl.custom_range)
+    if (PS.rl.custom_range) {
 	dmin = PS.rl.min;
 	dmax = PS.rl.max;
-    else
+    else {
 	G_get_fp_range_min_max(&range, &dmin, &dmax);
 	PS.rl.min = dmin;
 	PS.rl.max = dmax;
-    if (dmin == dmax)
 	G_warning(_("It is not a range of values (max = min)"));
 	return 1;
     /* color table */
-    if (G_read_colors(PS.rl.name, PS.rl.mapset, &colors) == -1)
+    if (G_read_colors(PS.rl.name, PS.rl.mapset, &colors) == -1) {
 	G_warning(_("Unable to read colors for rlegend"));
     /* units label */
-    if (G_read_raster_units(PS.rl.name, PS.rl.mapset, (char *)units) != 0)
+    if (G_read_raster_units(PS.rl.name, PS.rl.mapset, (char *)units) != 0) {
 	units[0] = 0;
@@ -238,8 +241,7 @@
     fontsize = set_ps_font(&(PS.rl.legend.font));
     /* set standard height */
-    if (PS.rl.height <= 0.)
+    if (PS.rl.height <= 0.) {
 	PS.rl.height = 15. * fontsize;
 	rows = 10;		/* = PS.rl.height / 1.5*fontsize */
@@ -255,15 +257,16 @@
     /* Array of strings and widths */
     sprintf(format, "(%%.%df) %%.8f\n", dec);
     fprintf(PS.fp, "/AR0 [\n");
-    while (val <= dmax)
+    while (val <= dmax) {
 	fprintf(PS.fp, format, val, (dmax - val) / (dmax - dmin));
 	val += step;
     fprintf(PS.fp, "/ARh 1 array def ARh 0 %.2f put\n", fontsize);
     fprintf(PS.fp, "/ARw 1 array def "
-	    "/mx 0 def 0 2 AR0 length 1 sub {" "AR0 exch get SW /t XD t mx gt {/mx t def} if } for " "ARw 0 mx put\n");
+	    "/mx 0 def 0 2 AR0 length 1 sub {"
+	    "AR0 exch get SW /t XD t mx gt {/mx t def} if } for "
+	    "ARw 0 mx put\n");
     PS.rl.legend.xspan = 0.;	/* needed for auto adjust */
@@ -286,15 +289,16 @@
     fprintf(PS.fp, "/y y %.3f sub def\n", fwidth / 2.);
     fprintf(PS.fp, "0 2 AR0 length -- {/i XD\n");
     fprintf(PS.fp, "x y ch AR0 i ++ get mul\n");
-    if (PS.rl.tickbar)
+    if (PS.rl.tickbar) {
 	fprintf(PS.fp, "GS ");
 	fprintf(PS.fp, "3 copy sub ");
 	fprintf(PS.fp, "NM -1 0 MR -%d 0 LR CS GR\n", PS.rl.tickbar);	/* length of tickbar */
     /* Ajusta los extremos que no salgan de la barra */
     fprintf(PS.fp, "%.3f ", 0.6 * fontsize);	/* aprox part upper tickbar */
-    fprintf(PS.fp, "2 copy lt {2 div add}" " {2 div add dup ch gt {pop ch} if} ifelse ");
+    fprintf(PS.fp,
+	    "2 copy lt {2 div add}"
+	    " {2 div add dup ch gt {pop ch} if} ifelse ");
     fprintf(PS.fp, "sub M AR0 i get show} for\n");
     /* Prepare the border and stroke area */
@@ -306,15 +310,18 @@
     /* draw the colorbar and frame */
     fprintf(PS.fp, "dy 1.1 mul LW x y chg sub\n");	/* stack x and y */
     fprintf(PS.fp, "[\n");
-    for (val = dmin; val <= dmax; val += step)
+    for (val = dmin; val <= dmax; val += step) {
 	G_get_d_raster_color(&val, &R, &G, &B, &colors);
 	if (PS.rst.do_grey)
-	    fprintf(PS.fp, "[%.3f]\n", (0.30 * (double)R + 0.59 * (double)G + 0.11 * (double)B) / 255.);
+	    fprintf(PS.fp, "[%.3f]\n",
+		    (0.30 * (double)R + 0.59 * (double)G +
 	else
-	    fprintf(PS.fp, "[%.3f %.3f %.3f]\n", R / 255., G / 255., B / 255.);
+	    fprintf(PS.fp, "[%.3f %.3f %.3f]\n", R / 255., G / 255.,
+		    B / 255.);
-    fprintf(PS.fp, "] {aload pop %c 2 copy M dx 0 LR stroke dy add} forall\n", PS.rst.do_grey ? 'G' : 'C');
+    fprintf(PS.fp, "] {aload pop %c 2 copy M dx 0 LR stroke dy add} forall\n",
+	    PS.rst.do_grey ? 'G' : 'C');
     fprintf(PS.fp, "pop pop\n");
     fprintf(PS.fp, "GS 4 copy RC\n");
     if (PS.rl.whiteframe > 0.)	/* white border: print on colors */
@@ -324,12 +331,12 @@
     fprintf(PS.fp, "%.5f LW RO\n", fwidth);
     /* print units label, if present */
-    if (units[0])
+    if (units[0]) {
 	fprintf(PS.fp, "%.1f FS ", 0.8 * fontsize);
 	fprintf(PS.fp, "RESET (%s) dup SW ", units);
-	fprintf(PS.fp, "x cwd add exch sub y chg %.1f add sub MS\n", fontsize);
+	fprintf(PS.fp, "x cwd add exch sub y chg %.1f add sub MS\n",
+		fontsize);
     G_free_colors(&colors);
@@ -348,28 +355,23 @@
     step = diff / cuts;
-    for (i = 0; i < 4; i++)
+    for (i = 0; i < 4; i++) {
 	dec = 0;
 	/* smalest n for which nice step >= raw step */
-	if (nice_steps[i] <= step)
+	if (nice_steps[i] <= step) {
 	    ex = 1;
 	    while (nice_steps[i] * ex < step)
 		ex *= 10;
-	else
+	else {
 	    ex = 0.1;
-	    while (nice_steps[i] * ex > step)
+	    while (nice_steps[i] * ex > step) {
 		++dec;
 		ex *= 0.1;
 	    ex *= 10;
-	if (i == 0 || (nice_steps[i] * ex - step) < cur_d)
+	if (i == 0 || (nice_steps[i] * ex - step) < cur_d) {
 	    cur_step = i;
 	    cur_d = nice_steps[i] * ex - step;
 	    cur_ex = ex;
Modified: grass-addons/postscript/ps.output/set_scalebar.c
--- grass-addons/postscript/ps.output/set_scalebar.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_scalebar.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -12,6 +12,7 @@
 int set_scalebar(void)
     int i, j;
     double width, segment;
     if (PS.sbar.length <= 0 || PS.sbar.segments <= 0)
@@ -21,8 +22,7 @@
     /* width of scalebar in points */
     width = PS.sbar.length;
-    switch (PS.sbar.ucode)
+    switch (PS.sbar.ucode) {
     case SB_UNITS_KM:
 	width *= KILOMETERS_TO_METERS;
 	break;
@@ -41,8 +41,7 @@
     width *= (1000. * MM_TO_POINT / (double)PS.scale);
-    if (PS.sbar.subsegs > 0 && PS.sbar.type != 'I')
+    if (PS.sbar.subsegs > 0 && PS.sbar.type != 'I') {
 	segment = width / (double)PS.sbar.segments;
 	width += segment;
@@ -57,62 +56,60 @@
     /* labels of the scalebar */
     fprintf(PS.fp, "/AR0 [");
     segment = (PS.sbar.length / PS.sbar.segments);
-    for (i = 0; i <= PS.sbar.segments; i += PS.sbar.labels)
+    for (i = 0; i <= PS.sbar.segments; i += PS.sbar.labels) {
 	fprintf(PS.fp, "(%s)", strnumber(i * segment));
     /* sublabels of the scalebar */
-    if (PS.sbar.type != 'I')
+    if (PS.sbar.type != 'I') {
 	fprintf(PS.fp, "/AR1 [(0)");
 	segment = (PS.sbar.length / PS.sbar.segments) / PS.sbar.subsegs;
-	for (i = PS.sbar.sublabs; i <= PS.sbar.subsegs; i += PS.sbar.sublabs)
+	for (i = PS.sbar.sublabs; i <= PS.sbar.subsegs; i += PS.sbar.sublabs) {
     /* The text in PS.sbar.units used to calculate size of text */
-    if (PS.sbar.type == 'I')
+    if (PS.sbar.type == 'I') {
 	fprintf(PS.fp,
-		"/mgy mg def (%s) SWH 2 add /chg XD " "chg mg 2 mul add /hg XD 2 add wd add /wd XD\n", PS.sbar.units);
+		"/mgy mg def (%s) SWH 2 add /chg XD "
+		"chg mg 2 mul add /hg XD 2 add wd add /wd XD\n",
+		PS.sbar.units);
-    else if (PS.sbar.type == 's' || PS.sbar.type == 'S')
+    else if (PS.sbar.type == 's' || PS.sbar.type == 'S') {
 	fprintf(PS.fp,
 		"AR0 dup length -- get SWH "
 		"mg add /mgy XD 2 div dup mg add /mgr XD wd add (%s) SW 2 add add /wd XD "
 		"/hg mgy 2 add mg add chg add def\n", PS.sbar.units);
-    else
+    else {
 	fprintf(PS.fp,
-		"mg add /mgy XD 2 div dup mg add /mgr XD wd add /wd XD " "/hg mgy 2 mul ++ chg add def\n");
+		"mg add /mgy XD 2 div dup mg add /mgr XD wd add /wd XD "
+		"/hg mgy 2 mul ++ chg add def\n");
     /* prepare the scalebar */
-    if (PS.sbar.subsegs == 0 || PS.sbar.type == 'I')
-	fprintf(PS.fp, "/dx cwd %d div def " "/mgx mg def\n", PS.sbar.segments);
+    if (PS.sbar.subsegs == 0 || PS.sbar.type == 'I') {
+	fprintf(PS.fp, "/dx cwd %d div def " "/mgx mg def\n",
+		PS.sbar.segments);
-    else
+    else {
 	fprintf(PS.fp,
 		"/dx cwd %d div def\n"
-		"AR1 dup length -- get SW 2 div dup " "mg add dx add /mgx XD wd add /wd XD\n", PS.sbar.segments + 1);
+		"AR1 dup length -- get SW 2 div dup "
+		"mg add dx add /mgx XD wd add /wd XD\n",
+		PS.sbar.segments + 1);
     /* do the scalebar */
     set_box_draw(&(PS.sbar.box));
-    switch (PS.sbar.type)
+    switch (PS.sbar.type) {
     case 'I':
 	fprintf(PS.fp, "/RBAR {{x exch dx mul add y dx dy RF} for} D\n");
-        fprintf(PS.fp, "/RTXT {{dup x exch dx mul add -- y M AR0 exch get SHR} for} D\n");
-        fprintf(PS.fp, "/mgy mg def RESET /dy chg neg def\n");
+	fprintf(PS.fp,
+		"/RTXT {{dup x exch dx mul add -- y M AR0 exch get SHR} for} D\n");
+	fprintf(PS.fp, "/mgy mg def RESET /dy chg neg def\n");
 	set_ps_color(&(PS.sbar.font.color));
 	fprintf(PS.fp, "1 LW x y cwd dy RE\n");
 	fprintf(PS.fp, "1 2 %d RBAR\n", PS.sbar.segments - 1);
@@ -128,42 +125,43 @@
     case 'F':
 	fprintf(PS.fp, "/RBAR ");
 	if (PS.sbar.type == 'F')
-	    fprintf(PS.fp, "{ {x exch dx mul add y chg 2 div sub dx 3 index RF} for pop} D\n");
+	    fprintf(PS.fp,
+		    "{ {x exch dx mul add y chg 2 div sub dx 3 index RF} for pop} D\n");
 	else
-	    fprintf(PS.fp, "{ {x exch dx mul add y dx 3 index RF} for pop} D\n");
+	    fprintf(PS.fp,
+		    "{ {x exch dx mul add y dx 3 index RF} for pop} D\n");
 	fprintf(PS.fp,
 		"/RTXT {1 2 index length -- "
-		"{dup x exch dx mul i mul add y 1 add M" " 1 index exch get SHC} for pop} D\n");
+		"{dup x exch dx mul i mul add y 1 add M"
+		" 1 index exch get SHC} for pop} D\n");
 	fprintf(PS.fp, "RESET /dy chg neg def\n");
 	set_ps_color(&(PS.sbar.fcolor));
-	fprintf(PS.fp, "x %s y cwd dy 4 copy RF ", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
+	fprintf(PS.fp, "x %s y cwd dy 4 copy RF ",
+		(PS.sbar.subsegs > 0 ? "dx sub" : ""));
 	fprintf(PS.fp, ".5 LW RE\n");
-	if (PS.sbar.type == 'F')
+	if (PS.sbar.type == 'F') {
 	    fprintf(PS.fp, "dy 2 div neg 0 2 %d RBAR ", PS.sbar.segments - 1);
 	    fprintf(PS.fp, "dy 2 div 1 2 %d RBAR\n", PS.sbar.segments - 1);
-	else
+	else {
 	    fprintf(PS.fp, "dy 0 2 %d RBAR ", PS.sbar.segments - 1);
 	fprintf(PS.fp, "/i %d def AR0 0 RTXT ", PS.sbar.labels);
-	if (PS.sbar.subsegs > 0)
+	if (PS.sbar.subsegs > 0) {
 	    fprintf(PS.fp, "/dx dx %d div neg def ", PS.sbar.subsegs);
 		fprintf(PS.fp, "dy 2 div 0 2 %d RBAR ", PS.sbar.subsegs - 1);
-		fprintf(PS.fp, "dy 2 neg div 1 2 %d RBAR ", PS.sbar.subsegs - 1);
+		fprintf(PS.fp, "dy 2 neg div 1 2 %d RBAR ",
+			PS.sbar.subsegs - 1);
-	    else
+	    else {
 		fprintf(PS.fp, "dy 1 2 %d RBAR ", PS.sbar.subsegs - 1);
 	    fprintf(PS.fp, "/i %d def AR1 1 RTXT\n", PS.sbar.sublabs);
-	fprintf(PS.fp, "xo wd add mgr sub yo hg sub mg add M (%s) SHR\n", PS.sbar.units);
+	fprintf(PS.fp, "xo wd add mgr sub yo hg sub mg add M (%s) SHR\n",
+		PS.sbar.units);
 	break;
     case 's':
     case 'S':
@@ -171,31 +169,33 @@
 	fprintf(PS.fp,
 		"/RBAR { {x exch dx mul add y M dup 0 exch LRS} for pop} D\n"
-		"{dup x exch dx mul i mul add y dy add ++ M" " 1 index exch get SHC} for pop} D\n");
+		"{dup x exch dx mul i mul add y dy add ++ M"
 	fprintf(PS.fp, "RESET /dy chg 2 div def /y y dy sub def .5 LW\n");
-	if (PS.sbar.type == 'S')
+	if (PS.sbar.type == 'S') {
-	    fprintf(PS.fp, "x %s y cwd dy neg 4 copy RF ", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
+	    fprintf(PS.fp, "x %s y cwd dy neg 4 copy RF ",
 	    fprintf(PS.fp, "RE\n", PS.sbar.segments);
-	else
+	else {
-	    fprintf(PS.fp, "GS 2 LC x %s y dy sub M cwd 0 LRS GR\n", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
+	    fprintf(PS.fp, "GS 2 LC x %s y dy sub M cwd 0 LRS GR\n",
 	fprintf(PS.fp, "dy neg 0 1 %d RBAR\n", PS.sbar.segments);
 	fprintf(PS.fp, "dy 0 %d %d RBAR\n", PS.sbar.labels, PS.sbar.segments);
 	    fprintf(PS.fp, "dy neg 1 1 %d RBAR ", PS.sbar.subsegs);
-	    fprintf(PS.fp, "dy 0 %d %d RBAR ", PS.sbar.sublabs, PS.sbar.subsegs);
+	    fprintf(PS.fp, "dy 0 %d %d RBAR ", PS.sbar.sublabs,
+		    PS.sbar.subsegs);
-	fprintf(PS.fp, "xo wd add mg sub y dy add ++ M (%s) SHR\n", PS.sbar.units);
+	fprintf(PS.fp, "xo wd add mg sub y dy add ++ M (%s) SHR\n",
+		PS.sbar.units);
 	break;
Modified: grass-addons/postscript/ps.output/set_vareas.c
--- grass-addons/postscript/ps.output/set_vareas.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_vareas.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -21,8 +21,7 @@
 /* TO DRAW AREAS */
 int vector_area(struct line_pnts *lpoints, double sep)
-    if (lpoints->n_points > 0)
+    if (lpoints->n_points > 0) {
 	struct line_pnts *opoints;
 	opoints = Vect_new_line_struct();
@@ -30,14 +29,12 @@
 	register int i;
 	set_ps_where('M', lpoints->x[0], lpoints->y[0]);
-	for (i = 1; i < lpoints->n_points; i++)
+	for (i = 1; i < lpoints->n_points; i++) {
 	    set_ps_where('L', lpoints->x[i], lpoints->y[i]);
 	Vect_line_parallel(lpoints, sep, 0.01, 0, opoints);
 	Vect_line_reverse(opoints);
-	for (i = 0; i < opoints->n_points; i++)
+	for (i = 0; i < opoints->n_points; i++) {
 	    set_ps_where('L', opoints->x[i], opoints->y[i]);
 	set_ps_where('L', lpoints->x[0], lpoints->y[0]);
@@ -49,9 +46,13 @@
 int set_vareas(VECTOR * vec, VAREAS * va)
     int k, ret, cat;
     int area, nareas, island, nislands, centroid;
     struct line_cats *lcats;
     struct line_pnts *lpoints;
     BOUND_BOX box;
     nareas = Vect_get_num_areas(&(vec->Map));
@@ -59,15 +60,15 @@
     fprintf(PS.fp, "GS 1 setlinejoin\n");
     /* Create vector array, if required */
-    if (vec->cats != NULL)
+    if (vec->cats != NULL) {
 	vec->Varray = Vect_new_varray(nareas);
-	Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats, GV_AREA, 1, vec->Varray);
+	Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats,
+					GV_AREA, 1, vec->Varray);
-    else if (vec->where != NULL)
+    else if (vec->where != NULL) {
-	Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, GV_AREA, 1, vec->Varray);
+	Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, GV_AREA,
+				1, vec->Varray);
     else
 	vec->Varray = NULL;
@@ -79,18 +80,15 @@
     /* load attributes if fcolor is named */
     dbCatValArray rgbcv, idcv;
-    if (va->rgbcol != NULL)
+    if (va->rgbcol != NULL) {
 	load_catval_array(&(vec->Map), va->rgbcol, &rgbcv);
-        if (va->idcol != NULL)
+	if (va->idcol != NULL)
 	    load_catval_array(&(vec->Map), va->idcol, &idcv);
     /* read and plot vectors */
-    for (area = 1; area <= nareas; area++)
-	if (vec->Varray != NULL && vec->Varray->c[area] == 0)
+    for (area = 1; area <= nareas; area++) {
+	if (vec->Varray != NULL && vec->Varray->c[area] == 0) {
 	    continue;
 	/* check if is a island */
@@ -99,7 +97,8 @@
 	    continue;
 	/* check if in window */
 	Vect_get_area_box(&(vec->Map), area, &box);
-	if (box.N < PS.map.south || box.S > PS.map.north || box.E < PS.map.west || box.W > PS.map.east)
+	if (box.N < PS.map.south || box.S > PS.map.north ||
+	    box.E < PS.map.west || box.W > PS.map.east)
 	    continue;
 	/* Oops is a correct area, I can draw it */
 	if (Vect_get_area_points(&(vec->Map), area, lpoints) < 0)
@@ -109,11 +108,9 @@
 	vector_line(lpoints);
 	fprintf(PS.fp, "CP\n");
 	/* islands */
-	if (centroid > 0 && va->island)
+	if (centroid > 0 && va->island) {
 	    nislands = Vect_get_area_num_isles(&(vec->Map), area);
-	    for (island = 0; island < nislands; island++)
+	    for (island = 0; island < nislands; island++) {
 		k = Vect_get_area_isle(&(vec->Map), area, island);
 		if (Vect_get_isle_points(&(vec->Map), k, lpoints) < 0)
 		    return -1;	/* ? break; */
@@ -123,57 +120,48 @@
 	/* set the fill */
-	if (!va->fcolor.none || va->rgbcol != NULL)
+	if (!va->fcolor.none || va->rgbcol != NULL) {
 	    PSCOLOR color;
-	    if (va->rgbcol == NULL)
+	    if (va->rgbcol == NULL) {
 		set_color_pscolor(&color, &(va->fcolor));
-	    else
+	    else {
 		cat = Vect_get_area_cat(&(vec->Map), area, vec->layer);
 		set_color_name(&color, get_string(&rgbcv, cat, 0));
 		color.a = va->fcolor.a;
+		if (va->idcol != NULL) {
 		    double value;
 		    get_number(&idcv, cat, &value);
-                    vector_item_new(vec, value, color_to_long(&color));
-		else
+		    vector_item_new(vec, value, color_to_long(&color));
+		else {
 		    vector_item_new(vec, 0, color_to_long(&color));
 	    /* set the type of fill if color */
-	    if (!color.none)
+	    if (!color.none) {
 		fprintf(PS.fp, "GS %.2f O ", color.a);
-		if (va->name_pat == NULL || va->type_pat == 2)
-		    fprintf(PS.fp, "%.3f %.3f %.3f ", color.r, color.g, color.b);
+		if (va->name_pat == NULL || va->type_pat == 2) {
+		    fprintf(PS.fp, "%.3f %.3f %.3f ", color.r, color.g,
+			    color.b);
-		if (va->name_pat != NULL)
+		if (va->name_pat != NULL) {
 		    fprintf(PS.fp, "PATTERN%d setpattern ", vec->id);
-		else
+		else {
 		    fprintf(PS.fp, "C ");
 		fprintf(PS.fp, "fill GR ");
 	/* set the line style */
-        if (va->line.width > 0. && !va->line.color.none)
-            set_ps_line(&(va->line));
-            fprintf(PS.fp, "S\n");
+	if (va->line.width > 0. && !va->line.color.none) {
+	    set_ps_line(&(va->line));
+	    fprintf(PS.fp, "S\n");
@@ -184,9 +172,13 @@
 int set_vareas_line(VECTOR * vec, VAREAS * va)
     int ret, cat;
     int ln, nlines, pt, npoints;
     double width;
@@ -195,15 +187,18 @@
     fprintf(PS.fp, "GS 1 setlinejoin\n");	/* lines with linejoin = round */
 	vec->Varray = Vect_new_varray(nlines);
-	ret = Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats, GV_LINE, 1, vec->Varray);
+	ret =
+					    vec->cats, GV_LINE, 1,
+					    vec->Varray);
-	ret = Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, GV_LINE, 1, vec->Varray);
+	ret =
+				    GV_LINE, 1, vec->Varray);
     else
 	vec->Varray = NULL;
@@ -214,13 +209,12 @@
     /* process only vectors in current window */
     Vect_set_constraint_region(&(vec->Map),
-                               PS.map.north, PS.map.south,
-                               PS.map.east, PS.map.west,
-                               PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
+			       PS.map.north, PS.map.south,
+			       PS.map.east, PS.map.west,
+			       PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
     /* read and plot lines */
-    for (ln = 1; ln <= nlines; ln++)
+    for (ln = 1; ln <= nlines; ln++) {
 	ret = Vect_read_line(&(vec->Map), lpoints, lcats, ln);
 	if (ret < 0)
 	    continue;
@@ -234,10 +228,9 @@
 	vector_area(lpoints, va->width * POINT_TO_MM / 1000. * PS.scale);
 	/* set the fill */
-	if (!va->fcolor.none)
-            fprintf(PS.fp, "GS %.2f O %.3f %.3f %.3f ",
-                    va->fcolor.a, va->fcolor.r, va->fcolor.g, va->fcolor.b);
+	if (!va->fcolor.none) {
+	    fprintf(PS.fp, "GS %.2f O %.3f %.3f %.3f ",
+		    va->fcolor.a, va->fcolor.r, va->fcolor.g, va->fcolor.b);
 		fprintf(PS.fp, "PATTERN%d setpattern fill ", vec->id);
 	    else
@@ -245,8 +238,7 @@
 	    fprintf(PS.fp, "GR ");
Modified: grass-addons/postscript/ps.output/set_vector.c
--- grass-addons/postscript/ps.output/set_vector.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_vector.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -23,69 +23,57 @@
 int set_vector(int masked, int type)
     int i;
     char buf[1024];
-    for (i = PS.vct_files - 1; i >= 0; i--)
-	if (masked && !PS.vct[i].masked)
+    for (i = PS.vct_files - 1; i >= 0; i--) {
+	if (masked && !PS.vct[i].masked) {
 	    continue;
-        if (!masked && PS.vct[i].masked)
+	if (!masked && PS.vct[i].masked) {
 	    continue;
-        if (PS.vct[i].type != type)
+	if (PS.vct[i].type != type) {
 	    continue;
-        /* select the type of output, NONE: no draw anything */
-	if (PS.vct[i].type == AREAS)
+	/* select the type of output, NONE: no draw anything */
+	if (PS.vct[i].type == AREAS) {
 	    VAREAS *va = (VAREAS *) PS.vct[i].data;
-            set_ps_pattern(PS.vct[i].id, va->name_pat, va);
+		set_ps_pattern(PS.vct[i].id, va->name_pat, va);
-	    if (va->width != 0.)
-            set_vareas_line(&(PS.vct[i]), va);
-	    else
-            set_vareas(&(PS.vct[i]), va);
+	    if (va->width != 0.) {
+		set_vareas_line(&(PS.vct[i]), va);
+	    else {
+		set_vareas(&(PS.vct[i]), va);
-	else if (PS.vct[i].type == LABELS)
+	else if (PS.vct[i].type == LABELS) {
 	    VLABELS *vl = (VLABELS *) PS.vct[i].data;
 	    set_vlabels(&(PS.vct[i]), vl);
-	else if (PS.vct[i].type == LINES)
+	else if (PS.vct[i].type == LINES) {
 	    VLINES *vl = (VLINES *) PS.vct[i].data;
-	    if (vl->hline.width > 0 && !(vl->hline.color.none))
+	    if (vl->hline.width > 0 && !(vl->hline.color.none)) {
 		set_vlines(&(PS.vct[i]), vl, DRAW_HLINE);
 		Vect_rewind(&(PS.vct[i].Map));
 	    set_vlines(&(PS.vct[i]), vl, DRAW_LINE);
-	else if (PS.vct[i].type == POINTS)
+	else if (PS.vct[i].type == POINTS) {
 	    SYMBOL *symb;
 	    VPOINTS *vp = (VPOINTS *) PS.vct[i].data;
 	    symb = S_read(vp->symbol);
-	    if (symb != NULL)
+	    if (symb != NULL) {
 		symbol_save(PS.vct[i].id, vp, symb);
-	    else
+	    else {
 		set_ps_symbol_eps(PS.vct[i].id, vp->symbol);
 	    if (vp->distance > 0.)
Modified: grass-addons/postscript/ps.output/set_vlabels.c
--- grass-addons/postscript/ps.output/set_vlabels.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_vlabels.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -22,22 +22,25 @@
 int set_vlabels(VECTOR * vec, VLABELS * vx)
     int ret, cat;
     int x, y, pt, npoints;
     npoints = Vect_get_num_lines(&(vec->Map));
 	vec->Varray = Vect_new_varray(npoints);
-        Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats, vx->type, 1, vec->Varray);
+					vx->type, 1, vec->Varray);
-        Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, vx->type, 1, vec->Varray);
+	Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, vx->type,
+				1, vec->Varray);
     else
 	vec->Varray = NULL;
@@ -49,9 +52,8 @@
     /* load attributes if any */
     dbCatValArray cv_label;
-    if (vx->labelcol != NULL)
-        load_catval_array(&(vec->Map), vx->labelcol, &cv_label);
+    if (vx->labelcol != NULL) {
+	load_catval_array(&(vec->Map), vx->labelcol, &cv_label);
     else
 	return 0;
@@ -60,12 +62,11 @@
     set_ps_font(&(vx->font));
-    for (pt = 1; pt <= npoints; pt++)
+    for (pt = 1; pt <= npoints; pt++) {
 	ret = Vect_read_line(&(vec->Map), lpoints, lcats, pt);
 	if (ret < 0)
 	    continue;
-        if (!(ret & GV_POINTS) || !(ret & vx->type))
+	if (!(ret & GV_POINTS) || !(ret & vx->type))
 	    continue;
 	if (vec->Varray != NULL && vec->Varray->c[pt] == 0)
 	    continue;
@@ -73,19 +74,19 @@
 	G_plot_where_xy(lpoints->x[0], lpoints->y[0], &x, &y);
 	PS.x = (double)x / 10.;
 	PS.y = (double)y / 10.;
-	if (PS.x < PS.map_x || PS.x > PS.map_right || PS.y < PS.map_y || PS.y > PS.map_top)
+	if (PS.x < PS.map_x || PS.x > PS.map_right || PS.y < PS.map_y ||
+	    PS.y > PS.map_top)
 	    continue;
 	/* Oops the point is correct, I can draw it */
 	Vect_cat_get(lcats, 1, &cat);
-        fprintf(PS.fp, "%.4f %.4f M (%s) ",
-                PS.x, PS.y, get_string(&cv_label, cat, vx->decimals));
+	fprintf(PS.fp, "%.4f %.4f M (%s) ",
+		PS.x, PS.y, get_string(&cv_label, cat, vx->decimals));
 	/* Draw text with a style */
-        if (vx->style != 0)
-            fprintf(PS.fp, "GS %.2f LW [] 0 LD dup TCIR GR\n", vx->style);
+	if (vx->style != 0) {
+	    fprintf(PS.fp, "GS %.2f LW [] 0 LD dup TCIR GR\n", vx->style);
 	fprintf(PS.fp, "SHCC ");
Modified: grass-addons/postscript/ps.output/set_vlegend.c
--- grass-addons/postscript/ps.output/set_vlegend.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_vlegend.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -28,8 +28,7 @@
     G_debug(1, "Placing vlegend ...");
     /* How many vectors to draw? */
-    for (n_vct = 0, i = 0; i < PS.vct_files; i++)
+    for (n_vct = 0, i = 0; i < PS.vct_files; i++) {
 	if (PS.vct[i].lpos >= 0)
 	    ++n_vct;
@@ -39,17 +38,13 @@
     /* Reorder as defined by the user */
     int *ip = (int *)G_malloc(n_vct * sizeof(int));
-    for (i = 0; i < n_vct; i++)
+    for (i = 0; i < n_vct; i++) {
 	ip[i] = -1;
-    for (i = 0; i < PS.vct_files; i++)
-	if (PS.vct[i].lpos > 0)
+    for (i = 0; i < PS.vct_files; i++) {
+	if (PS.vct[i].lpos > 0) {
 	    j = PS.vct[i].lpos - 1;
-	    if (j < n_vct && ip[j] < 0)
+	    if (j < n_vct && ip[j] < 0) {
 		ip[j] = i;
 		PS.vct[i].lpos = -1;
@@ -57,10 +52,8 @@
 		PS.vct[i].lpos = 0;
-	if (PS.vct[i].lpos == 0)
+	if (PS.vct[i].lpos == 0) {
 	    j = 0;
 	    while (j < n_vct && ip[j] >= 0)
 		j++;
@@ -74,7 +67,7 @@
 	PS.vl.legend.box.margin = 0.4 * PS.vl.legend.font.size;
     if (PS.vl.legend.width <= 0)
-        PS.vl.legend.width = 2.4 * PS.vl.legend.font.size;
+	PS.vl.legend.width = 2.4 * PS.vl.legend.font.size;
     if (PS.vl.legend.xspan <= 0)
 	PS.vl.legend.xspan = PS.vl.legend.box.margin;
@@ -99,43 +92,36 @@
     /* Prepare the content of legend by vector */
     int K, n;
 	j = ip[i];
-        qsort(PS.vct[j].item, PS.vct[j].n_item, sizeof(ITEMS), cmpitems);
-        if (PS.vct[j].yspan <= 0)
+	qsort(PS.vct[j].item, PS.vct[j].n_item, sizeof(ITEMS), cmpitems);
+	if (PS.vct[j].yspan <= 0)
 	    PS.vct[j].yspan = PS.vl.legend.yspan;
     set_ps_font(&(PS.vl.legend.font));
-    for (K = 0, i = 0; i < n_vct; i++, K++)
-        j = ip[i];
-        /* if (PS.vct[j].n_item == 1) continue; con K-- */
-        if (PS.vct[j].n_item == 1)
-            n = 0;
-            while ((i+n) < n_vct && PS.vct[ip[i+n]].n_item == 1)
-                ++n;
-            set_vlegend_simple(K, ip + i, n);
-            i += (n-1);
-        else
-            set_vlegend_multi(K, &(PS.vct[j]));
+    for (K = 0, i = 0; i < n_vct; i++, K++) {
+	j = ip[i];
+	/* if (PS.vct[j].n_item == 1) continue; con K-- */
+	if (PS.vct[j].n_item == 1) {
+	    n = 0;
+	    while ((i + n) < n_vct && PS.vct[ip[i + n]].n_item == 1) {
+		++n;
+	    set_vlegend_simple(K, ip + i, n);
+	    i += (n - 1);
+	else {
+	    set_vlegend_multi(K, &(PS.vct[j]));
     n_vct = K;
     G_free(ip);
     /* Prepare the title of the legend */
-    if (!PS.vl.legend.title || PS.vl.legend.title[0] == 0)
+    if (!PS.vl.legend.title || PS.vl.legend.title[0] == 0) {
 	fprintf(PS.fp, "/mgy 0 def\n");
-    else
+    else {
 	set_ps_font(&(PS.vl.legend.title_font));
 	fprintf(PS.fp, "(%s) SWH ", PS.vl.legend.title);
@@ -145,18 +131,20 @@
     /* Prepare and draw the frame of the legend */
-    fprintf(PS.fp, "hg BKh {add dyy add} forall dyy sub BKt {add} forall /hg XD\n");
-    fprintf(PS.fp, "wd BKw {mg 2 mul add 2 copy lt {exch} if pop} forall /wd XD\n");
+    fprintf(PS.fp,
+	    "hg BKh {add dyy add} forall dyy sub BKt {add} forall /hg XD\n");
+    fprintf(PS.fp,
+	    "wd BKw {mg 2 mul add 2 copy lt {exch} if pop} forall /wd XD\n");
     set_box_orig(&(PS.vl.legend.box));
     set_box_draw(&(PS.vl.legend.box));
     /* Draw the title of the legend */
-    if (PS.vl.legend.title && PS.vl.legend.title[0] != 0)
+    if (PS.vl.legend.title && PS.vl.legend.title[0] != 0) {
-	fprintf(PS.fp, "xo mg add yo mgy sub M wd mg 2 mul sub (%s) SHS\n", PS.vl.legend.title);
+	fprintf(PS.fp, "xo mg add yo mgy sub M wd mg 2 mul sub (%s) SHS\n",
+		PS.vl.legend.title);
 	fprintf(PS.fp, "GR\n");
@@ -166,36 +154,39 @@
 	    "dup 0 get /dy XD\n"
 	    "dup 1 get dup length 0 eq {pop} {x y dy add MS} ifelse y roh sub /y XD /yt y def\n"
 	    "dup 2 exch length 2 sub getinterval {"
-            "dup 0 3 2 index length -- {"
-            "3 getinterval aload pop /code XD aload pop\n");
+	    "dup 0 3 2 index length -- {"
+	    "3 getinterval aload pop /code XD aload pop\n");
     fprintf(PS.fp,
 	    "code %d eq {"
 	    "GS 0 ne {LW 0 LD C x syw add 0 roh sub 2 div neg y add dup x exch ML [] 0 LD} if "
-            "x syw 2 div add 0.65 roh mul 2 div y add TR SC ROT LW cvx cvn exec GR} if\n", POINTS);
+	    "x syw 2 div add 0.65 roh mul 2 div y add TR SC ROT LW cvx cvn exec GR} if\n",
+	    POINTS);
+    fprintf(PS.fp, "code %d eq {"
+	    //            "GS {LW 0 LD C roh .35 mul /z XD x y z add M syw .3 mul z neg syw .6 mul z syw .9 mul 0 rcurveto S} repeat GR} if\n", LINES);
+	    "GS {LW 0 LD C x syw add y roh 0.35 mul add dup x exch ML} repeat GR} if\n",
+	    LINES);
     fprintf(PS.fp,
-            "code %d eq {"
-//            "GS {LW 0 LD C roh .35 mul /z XD x y z add M syw .3 mul z neg syw .6 mul z syw .9 mul 0 rcurveto S} repeat GR} if\n", LINES);
-            "GS {LW 0 LD C x syw add y roh 0.35 mul add dup x exch ML} repeat GR} if\n", LINES);
-    fprintf(PS.fp,
-            "code %d eq {"
-            "GS [] 0 LD x y -- x syw .9 mul add y roh add -- B "
-            "GS 0 ne {0 eq {C} {setpattern} ifelse fill} if GR 0 ne {LW 0 LD C S} if GR} if\n", AREAS);
+	    "code %d eq {"
+	    "GS [] 0 LD x y -- x syw .9 mul add y roh add -- B "
+	    "GS 0 ne {0 eq {C} {setpattern} ifelse fill} if GR 0 ne {LW 0 LD C S} if GR} if\n",
+	    AREAS);
     set_ps_color(&(PS.vl.legend.font.color));
     fprintf(PS.fp,
 	    "x syw add y MS\n"
-            "y roh dy add sub /y XD dup} for pop pop\n" "x cow dxx add add /x XD yt /y XD} forall} D\n");
+	    "y roh dy add sub /y XD dup} for pop pop\n"
+	    "x cow dxx add add /x XD yt /y XD} forall} D\n");
     fprintf(PS.fp, "yo mgy mg add sub /yo XD\n");
-        /* caja del elemento *
-        fprintf(PS.fp, "GS .2 LW [1] 0 LD ");
-        fprintf(PS.fp, "xo mg add yo BKw %d get BKh %d get BKt %d get add neg RE GR\n", i, i, i);
+	/* caja del elemento *
+	   fprintf(PS.fp, "GS .2 LW [1] 0 LD ");
+	   fprintf(PS.fp, "xo mg add yo BKw %d get BKh %d get BKt %d get add neg RE GR\n", i, i, i);
 	fprintf(PS.fp, "/x xo mg add def ");
 	fprintf(PS.fp, "/y yo BKt %d get sub def\n", i);
 	fprintf(PS.fp, "BK%d VLEGEND\n", i);
-	fprintf(PS.fp, "yo BKh %i get BKt %d get dyy add add sub /yo XD\n", i, i);
+	fprintf(PS.fp, "yo BKh %i get BKt %d get dyy add add sub /yo XD\n", i,
+		i);
     return 1;
@@ -204,6 +195,7 @@
 void make_vareas(VECTOR * vec, int rows)
     int i, item;
     VAREAS *va = (VAREAS *) vec->data;
     /* Set the title of the vector */
@@ -214,61 +206,48 @@
     /* Iterate by items */
-    for (item = 0, i = 0; i < vec->n_item; i++, item++)
-	if (item == rows)
+    for (item = 0, i = 0; i < vec->n_item; i++, item++) {
+	if (item == rows) {
 	    item = 0;
 	    fprintf(PS.fp, "][\n");
 	/* set the label of the item */
 	    fprintf(PS.fp, "( %s)", vec->label);
-	else
-            int id = vec->item[i].rule;
+	else {
+	    int id = vec->item[i].rule;
-	    if (id == -1)
+	    if (id == -1) {
 		fprintf(PS.fp, "( )");
-	    else
+	    else {
 		fprintf(PS.fp, "( %s)", vec->rule[id].label);
 	    long_to_color(vec->item[i].data, &(va->fcolor));
 	/* set the specific data of the item */
 	fprintf(PS.fp, " [");
-	if (va->line.color.none || va->line.width <= 0)
+	if (va->line.color.none || va->line.width <= 0) {
 	    fprintf(PS.fp, "0 ");
-	else
+	else {
 	    fprintf(PS.fp, "%.3f %.3f %.3f [%s] %.3f 1 ",
-                    va->line.color.r, va->line.color.g, va->line.color.b,
-                    va->line.dash, va->line.width);
+		    va->line.color.r, va->line.color.g, va->line.color.b,
+		    va->line.dash, va->line.width);
-	if (va->fcolor.none && va->name_pat == NULL)
+	if (va->fcolor.none && va->name_pat == NULL) {
 	    fprintf(PS.fp, "0");
-	else
-                        va->fcolor.r, va->fcolor.g, va->fcolor.b);
+	else {
+			va->fcolor.r, va->fcolor.g, va->fcolor.b);
 		fprintf(PS.fp, "PATTERN%d 1 1", vec->id);
-	    else
+	    else {
 		fprintf(PS.fp, "0 1");
@@ -280,6 +259,7 @@
 void make_vlines(VECTOR * vec, int rows)
     int i, item;
     VLINES *vl = (VLINES *) vec->data;
@@ -290,28 +270,22 @@
-	if (item == rows)
 	    item = 0;
-	if (vl->rgbcol == NULL)
+	if (vl->rgbcol == NULL) {
-	else
+	else {
-	    if (id == -1)
+	    if (id == -1) {
-	    else
+	    else {
 	    long_to_color(vec->item[i].data, &(vl->line.color));
@@ -319,15 +293,15 @@
 	fprintf(PS.fp, "%.3f %.3f %.3f [%s] %.4f",
-		vl->line.color.r, vl->line.color.g, vl->line.color.b, vl->line.dash, vl->line.width);
-	if (vl->hline.width <= 0)
+		vl->line.color.r, vl->line.color.g, vl->line.color.b,
+		vl->line.dash, vl->line.width);
+	if (vl->hline.width <= 0) {
 	    fprintf(PS.fp, " 1");
-	else
+	else {
 	    fprintf(PS.fp, " %.3f %.3f %.3f [%s] %.4f",
-		    vl->hline.color.r, vl->hline.color.g, vl->hline.color.b, vl->hline.dash, vl->hline.width);
+		    vl->hline.color.r, vl->hline.color.g, vl->hline.color.b,
+		    vl->hline.dash, vl->hline.width);
 	    fprintf(PS.fp, " 2");
 	fprintf(PS.fp, "] %d\n", vec->type);
@@ -338,6 +312,7 @@
 void make_vpoints(VECTOR * vec, int rows)
     int i, item;
     VPOINTS *vp = (VPOINTS *) vec->data;
@@ -348,31 +323,25 @@
 	/* if vp->size == 0 => no draw? */
-	if (item == rows)
 	    item = 0;
-	if (vp->sizecol == NULL || vec->n_rule == 0)
+	if (vp->sizecol == NULL || vec->n_rule == 0) {
-	else
+	else {
-	    if (id == -1)
+	    if (id == -1) {
 		vp->size = (double)(vec->item[i].data / 1000.);
-                fprintf(PS.fp, "( %.3f)", vp->size);
+		fprintf(PS.fp, "( %.3f)", vp->size);
-	    else
+	    else {
 		vp->size = vec->rule[id].value;
@@ -381,21 +350,20 @@
 	fprintf(PS.fp, "(SYMBOL%d)", vec->id);
-// 	fprintf(PS.fp, " %.4f", vp->line.width / vp->size);	/* div! 0 */
-    if (vp->size == 0.)
-        fprintf(PS.fp, " %.4f", vp->line.width);
-    else
-        fprintf(PS.fp, " %.4f", vp->line.width / vp->size);
+	//      fprintf(PS.fp, " %.4f", vp->line.width / vp->size);     /* div! 0 */
+	if (vp->size == 0.)
+	    fprintf(PS.fp, " %.4f", vp->line.width);
+	else
+	    fprintf(PS.fp, " %.4f", vp->line.width / vp->size);
 	fprintf(PS.fp, " %.3f", vp->rotate);
 	fprintf(PS.fp, " %.3f dup", vp->size);
-	if (vp->distance != 0.)
+	if (vp->distance != 0.) {
-		    vp->cline.color.r, vp->cline.color.g, vp->cline.color.b, vp->cline.dash, vp->cline.width);
+		    vp->cline.color.r, vp->cline.color.g, vp->cline.color.b,
+		    vp->cline.dash, vp->cline.width);
-	else
+	else {
 	    fprintf(PS.fp, " 0");
@@ -404,7 +372,7 @@
 /* Join vector legend with simple line */
-int set_vlegend_simple(int i, const int * ip, int items)
+int set_vlegend_simple(int i, const int *ip, int items)
     int x, rows, cols, item;
@@ -414,50 +382,40 @@
 	++rows;
     fprintf(PS.fp, "/BK%d [\n%.4f ()\n[\n", i, PS.vl.legend.yspan);
-    for (item = 0, x = 0; x < items; x++, item++)
+    for (item = 0, x = 0; x < items; x++, item++) {
 	VECTOR *vec = &(PS.vct[ip[x]]);
-	if (item == rows)
 	    item = 0;
-	switch (vec->type)
+	switch (vec->type) {
 	case AREAS:
-		else
+		else {
+			    va->line.color.b, va->line.dash, va->line.width);
-		else
+		else {
-		    else
+		    else {
@@ -470,17 +428,16 @@
-                        vl->line.dash, vl->line.width);
-		else
+		else {
-                            vl->hline.dash, vl->hline.width);
+			    vl->hline.color.b, vl->hline.dash,
+			    vl->hline.width);
@@ -495,15 +452,14 @@
-                            vp->cline.dash, vp->cline.width);
+			    vp->cline.color.b, vp->cline.dash,
+			    vp->cline.width);
-		else
+		else {
@@ -532,22 +488,21 @@
     /* Make de legend */
     fprintf(PS.fp, "/BK%d [\n%.4f ", i, vec->yspan);
     case AREAS:
-	make_vareas(vec, rows);
+	    make_vareas(vec, rows);
 	break;
     case LINES:
-	make_vlines(vec, rows);
+	    make_vlines(vec, rows);
 	break;
     case POINTS:
-	make_vpoints(vec, rows);
+	    make_vpoints(vec, rows);
 	break;
     fprintf(PS.fp, "] def\n");
@@ -562,14 +517,16 @@
 void set_vlegend_ps(int i, int rows, int cols)
     fprintf(PS.fp, "BK%d aload length 2 sub {"
-            "aload length 3 idiv"
-            "{pop pop SW syw add cow 2 copy lt {pop} {exch /cow XD} ifelse pop}"
-            "repeat} repeat exch /dy XD\n", i);
+	    "aload length 3 idiv"
+	    "{pop pop SW syw add cow 2 copy lt {pop} {exch /cow XD} ifelse pop}"
+	    "repeat} repeat exch /dy XD\n", i);
     fprintf(PS.fp, "BKh %d roh dy add %d mul dy sub put\n", i, rows);
     fprintf(PS.fp, "BKw %d cow dxx add %d mul dxx sub put\n", i, cols);
     fprintf(PS.fp, "dup length 0 eq {BKt %d 0 put} ", i);
     fprintf(PS.fp, "{SWH BKt %d 3 -1 roll dy add put ", i);
-    fprintf(PS.fp, "BKw %d get 2 copy gt {pop BKw %d 3 -1 roll put} {pop pop} ifelse} ifelse\n", i, i);
+    fprintf(PS.fp,
+	    "BKw %d get 2 copy gt {pop BKw %d 3 -1 roll put} {pop pop} ifelse} ifelse\n",
+	    i, i);
Modified: grass-addons/postscript/ps.output/set_vlines.c
--- grass-addons/postscript/ps.output/set_vlines.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_vlines.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -24,13 +24,11 @@
 /* TO DRAW LINES */
 int vector_line(struct line_pnts *lpoints)
 	register int i;
-	for (i = 1; i <= lpoints->n_points - 1; i++)
+	for (i = 1; i <= lpoints->n_points - 1; i++) {
@@ -41,8 +39,11 @@
 int set_vlines(VECTOR * vec, VLINES * vl, int flag)
     int ret, cat;
@@ -51,15 +52,18 @@
     fprintf(PS.fp, "GS 1 setlinejoin NP\n");	/* lines with linejoin = round */
-	ret = Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats, vl->type, 1, vec->Varray);
+	ret =
+					    vec->cats, vl->type, 1,
+					    vec->Varray);
-	ret = Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, vl->type, 1, vec->Varray);
+	ret =
+				    vl->type, 1, vec->Varray);
     else
 	vec->Varray = NULL;
@@ -70,17 +74,15 @@
-    if (flag == DRAW_LINE)
-        if (vl->rgbcol != NULL)
+    if (flag == DRAW_LINE) {
+	if (vl->rgbcol != NULL) {
 	    load_catval_array(&(vec->Map), vl->rgbcol, &rgbcv);
 	    if (vl->idcol != NULL)
 		load_catval_array(&(vec->Map), vl->idcol, &idcv);
@@ -88,8 +90,7 @@
 	if (ret < 0)
 	    continue;
@@ -100,11 +101,10 @@
 	/* Oops the line is correct, I can draw it */
 	/* How I can draw it? */
-	if (flag == DRAW_HLINE)
-	    if (vl->offset != 0.)
+	if (flag == DRAW_HLINE) {
+	    if (vl->offset != 0.) {
 		double dis;
 		struct line_pnts *opoints = Vect_new_line_struct();
 		/* perhaps dont run in Lat/Lon */
@@ -112,21 +112,17 @@
 		Vect_line_parallel(lpoints, dis, 0.1, 0, opoints);
 		vector_line(opoints);
-	    else
+	    else {
 	    set_ps_line(&(vl->hline));
-	else
+	else {
 		set_ps_color(&(vl->line.color));
-	    else
+	    else {
 		PSCOLOR color;
@@ -134,8 +130,7 @@
 		color.a = vl->line.color.a;
 		set_ps_color(&color);
-		if (vl->idcol != NULL)
+		if (vl->idcol != NULL) {
 		    double value;
Modified: grass-addons/postscript/ps.output/set_vpoints.c
--- grass-addons/postscript/ps.output/set_vpoints.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/set_vpoints.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -22,23 +22,27 @@
 int set_vpoints(VECTOR * vec, VPOINTS * vp)
     int ret, cat;
     int pt, npoints;
     double tmp, size, rotate;
-	Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats, vp->type, 1, vec->Varray);
+					vp->type, 1, vec->Varray);
-	Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, vp->type, 1, vec->Varray);
+	Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, vp->type,
+				1, vec->Varray);
     else
 	vec->Varray = NULL;
@@ -50,18 +54,15 @@
     dbCatValArray sizecv, rotcv;
-    if (vp->rotatecol != NULL)
+    if (vp->rotatecol != NULL) {
 	load_catval_array(&(vec->Map), vp->rotatecol, &rotcv);
-    if (vp->sizecol != NULL)
+    if (vp->sizecol != NULL) {
 	load_catval_array(&(vec->Map), vp->sizecol, &sizecv);
 	if (ret < 0)
 	    continue;
@@ -75,32 +76,29 @@
 	    continue;
 	fprintf(PS.fp, "%.4f %.4f TR ", PS.x, PS.y);
 	/* symbol size */
-	if (vp->sizecol == NULL)
+	if (vp->sizecol == NULL) {
 	    size = vp->size;
-	else
+	else {
 	    get_number(&sizecv, cat, &tmp);
-            size = tmp * vp->scale + vp->bias;
-	    if (vec->n_rule == 0)
-            vector_item_new(vec, tmp, (long)(vp->size * 1000.));
+	    size = tmp * vp->scale + vp->bias;
+	    if (vec->n_rule == 0) {
+		vector_item_new(vec, tmp, (long)(vp->size * 1000.));
-	    else
+	    else {
 		int i;
 		i = vector_item_new(vec, tmp, (long)(size * 1000.));
-                if (vec->item[i].rule != -1)
-                    size = vec->rule[vec->item[i].rule].value;
+		if (vec->item[i].rule != -1)
+		    size = vec->rule[vec->item[i].rule].value;
 	if (size <= 0.)
@@ -108,12 +106,10 @@
 	fprintf(PS.fp, "%.3f dup SC ", size);
 	/* symbol rotate */
-	if (vp->rotatecol == NULL)
+	if (vp->rotatecol == NULL) {
 	    rotate = vp->rotate;
-	else
+	else {
 	    get_number(&rotcv, cat, &rotate);
 	if (rotate > 0.)
@@ -131,9 +127,13 @@
 int set_vpoints_line(VECTOR * vec, VPOINTS * vp)
     int ret, cat;
     double size, rotate;
@@ -142,15 +142,18 @@
-	ret = Vect_set_varray_from_cat_string(&(vec->Map), vec->layer, vec->cats, vp->type, 1, vec->Varray);
+	ret =
+					    vec->cats, vp->type, 1,
+					    vec->Varray);
-	ret = Vect_set_varray_from_db(&(vec->Map), vec->layer, vec->where, vp->type, 1, vec->Varray);
+	ret =
     else
 	vec->Varray = NULL;
@@ -161,40 +164,36 @@
-			       PS.map.north, PS.map.south, PS.map.east, PS.map.west, PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
+			       PS.map.north, PS.map.south, PS.map.east,
+			       PS.map.west, PORT_DOUBLE_MAX,
+			       -PORT_DOUBLE_MAX);
     /* prepare the symbol to draw */
     dbCatValArray cv_size, cv_rot;
 	load_catval_array(&(vec->Map), vp->sizecol, &cv_size);
 	load_catval_array(&(vec->Map), vp->rotatecol, &cv_rot);
     fprintf(PS.fp, "/LSYMBOL {GS %.3f TR [] 0 LD ", vp->voffset);
     /* symbol size */
 	size = vp->size;
-    else
+    else {
 	get_number(&cv_size, cat, &size);
 	size *= vp->scale;
     if (size > 0.)
     /* symbol rotate */
-    else
+    else {
 	get_number(&cv_rot, cat, &rotate);
     if (rotate > 0.)
@@ -206,8 +205,7 @@
     fprintf(PS.fp, "GR} def\n");
 	if (ret < 0)
 	    continue;
Modified: grass-addons/postscript/ps.output/start_map.c
--- grass-addons/postscript/ps.output/start_map.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/start_map.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -16,20 +16,20 @@
 #include "conversion.h"
 int move_local(int x, int y);
 int cont_local(int x, int y);
 int start_map(void)
     double width, height;
     double fact, d_ns, ns, d_ew, ew;
     /* default position */
-    if (PS.map_x < 0)
+    if (PS.map_x < 0) {
 	PS.map_x = PS.page.left + PS.brd.width;
-    if (PS.map_top < 0)
+    if (PS.map_top < 0) {
 	PS.map_top = PS.page.top + PS.brd.width;
@@ -38,40 +38,34 @@
     height = PS.page.height - PS.map_top - (PS.page.bot + PS.brd.width);
     /* default size */
-    if (PS.map_w < 0 || PS.map_w > width)
+    if (PS.map_w < 0 || PS.map_w > width) {
 	PS.map_w = width;
-    if (PS.map_h < 0 || PS.map_h > height)
+    if (PS.map_h < 0 || PS.map_h > height) {
 	PS.map_h = height;
     /* distance calculation, throught center of map */
     G_begin_distance_calculations();
-    if (PS.map.proj == PROJECTION_LL)
+    if (PS.map.proj == PROJECTION_LL) {
 	ns = (PS.map.north + PS.map.south) / 2.;
 	d_ew = G_distance(PS.map.east, ns, PS.map.west, ns);
 	ew = (PS.map.east + PS.map.west) / 2.;
 	d_ns = G_distance(ew, PS.map.north, ew, PS.map.south);
-    else
+    else {
 	d_ew = (PS.map.east - PS.map.west);
 	d_ns = (PS.map.north - PS.map.south);
     /* to define the scale */
-    if (PS.scale > 0)
+    if (PS.scale > 0) {
 	fact = MT_TO_POINT / (double)PS.scale;
 	ew = fact * d_ew;
 	ns = fact * d_ns;
-	if (ew <= PS.map_w && ns <= PS.map_h)
+	if (ew <= PS.map_w && ns <= PS.map_h) {
 	    PS.map_w = ew;
 	    PS.map_h = ns;
@@ -79,8 +73,7 @@
 	    PS.scale = 0;	/* forze readjust scale */
     /* auto scale */
-    if (PS.scale <= 0)
+    if (PS.scale <= 0) {
 	ew = d_ew / PS.map_w;
 	ns = d_ns / PS.map_h;
 	fact = (ew > ns) ? ew : ns;
@@ -101,7 +94,8 @@
     PS.map_top = PS.map_y + PS.map_h;
     G_setup_plot(10. * (PS.map_y + PS.map_h), 10. * PS.map_y,
-		 10. * PS.map_x, 10. * (PS.map_x + PS.map_w), move_local, cont_local);
+		 10. * PS.map_x, 10. * (PS.map_x + PS.map_w), move_local,
+		 cont_local);
     return 0;
@@ -112,6 +106,7 @@
     fprintf(PS.fp, "%.1f %.1f M\n", (double)x / 10., (double)y / 10.);
     return 0;
     fprintf(PS.fp, "%.1f %.1f L ", (double)x / 10., (double)y / 10.);
Modified: grass-addons/postscript/ps.output/symbol.c
--- grass-addons/postscript/ps.output/symbol.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/symbol.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -14,22 +14,22 @@
 int draw_chain(SYMBCHAIN * chain, double s)
     int k, l;
     char *mvcmd;
     SYMBEL *elem;
-    for (k = 0; k < chain->count; k++)
+    for (k = 0; k < chain->count; k++) {
 	elem = chain->elem[k];
-	switch (elem->type)
+	switch (elem->type) {
 	case S_LINE:
-	    for (l = 0; l < elem->coor.line.count; l++)
+	    for (l = 0; l < elem->coor.line.count; l++) {
 		if (k == 0 && l == 0)
 		    mvcmd = "M";
 		else
 		    mvcmd = "L";
-		fprintf(PS.fp, "%.4f %.4f %s\n", s * elem->coor.line.x[l], s * elem->coor.line.y[l], mvcmd);
+		fprintf(PS.fp, "%.4f %.4f %s\n", s * elem->coor.line.x[l],
+			s * elem->coor.line.y[l], mvcmd);
 	    break;
 	case S_ARC:
@@ -39,7 +39,8 @@
 		mvcmd = "arc";
 	    fprintf(PS.fp, "%.4f %.4f %.4f %.4f %.4f %s\n",
 		    s * elem->coor.arc.x,
-		    s * elem->coor.arc.y, s * elem->coor.arc.r, elem->coor.arc.a1, elem->coor.arc.a2, mvcmd);
+		    s * elem->coor.arc.y, s * elem->coor.arc.r,
+		    elem->coor.arc.a1, elem->coor.arc.a2, mvcmd);
 	    break;
@@ -51,8 +52,11 @@
 int symbol_save(int code, VPOINTS * vp, SYMBOL * Symb)
     SYMBPART *part;
     SYMBCHAIN *chain;
     int i, j, points;
     double s, xo[4], yo[4];
     points = 4;
@@ -70,57 +74,51 @@
     s *= Symb->scale;
-    for (i = 0; i < Symb->count; i++)
+    for (i = 0; i < Symb->count; i++) {
 	part = Symb->part[i];
-	switch (part->type)
+	switch (part->type) {
 	case S_POLYGON:
 	    fprintf(PS.fp, "NP\n");	/* Start ring */
-	    for (j = 0; j < part->count; j++)
-	    {			/* RINGS */
+	    for (j = 0; j < part->count; j++) {	/* RINGS */
 		chain = part->chain[j];
 		draw_chain(chain, s);
 		fprintf(PS.fp, "CP\n");	/* Close one ring */
 	    /* Fill */
-	    if (part->fcolor.color == S_COL_DEFAULT && !vp->fcolor.none)
+	    if (part->fcolor.color == S_COL_DEFAULT && !vp->fcolor.none) {
 		set_ps_color(&(vp->fcolor));
 		fprintf(PS.fp, "F\n");	/* Fill polygon */
-	    else if (part->fcolor.color == S_COL_DEFINED)
-		fprintf(PS.fp, "%.3f %.3f %.3f C ", part->fcolor.fr, part->fcolor.fg, part->fcolor.fb);
+	    else if (part->fcolor.color == S_COL_DEFINED) {
+		fprintf(PS.fp, "%.3f %.3f %.3f C ", part->fcolor.fr,
+			part->fcolor.fg, part->fcolor.fb);
 	    /* Outline */
-	    if (part->color.color == S_COL_DEFAULT && !vp->line.color.none)
+	    if (part->color.color == S_COL_DEFAULT && !vp->line.color.none) {
 		set_ps_color(&(vp->line.color));
 		fprintf(PS.fp, "S\n");	/* Draw boundary */
-	    else if (part->color.color == S_COL_DEFINED)
-		fprintf(PS.fp, "%.3f %.3f %.3f C ", part->color.fr, part->color.fg, part->color.fb);
+	    else if (part->color.color == S_COL_DEFINED) {
+		fprintf(PS.fp, "%.3f %.3f %.3f C ", part->color.fr,
+			part->color.fg, part->color.fb);
 	    break;
 	case S_STRING:		/* string has 1 chain */
-	    if (part->color.color != S_COL_NONE)
+	    if (part->color.color != S_COL_NONE) {
 		chain = part->chain[0];
 		/* Color */
+		    !vp->line.color.none) {
-		else
+		else {
Modified: grass-addons/postscript/ps.output/val_list.c
--- grass-addons/postscript/ps.output/val_list.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/val_list.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -14,7 +14,9 @@
 int sort_list(char *order, int items, CELL ** item)
     int i, j, k, count, tmp;
     CELL *ip, val;
     DCELL *vlist;
     /* initial order */
@@ -23,16 +25,11 @@
 	ip[i] = i;
     /* if any to order */
-    if (order[0] != 0 && (count = parse_val_list(order, &vlist)) > 0)
-	for (i = 0, j = 0; j < count; j += 2)
-	    for (val = vlist[j]; val <= vlist[j + 1]; val++)
-		for (k = i; k < items; k++)
-		    if ((*item)[k] == val)
+    if (order[0] != 0 && (count = parse_val_list(order, &vlist)) > 0) {
+	for (i = 0, j = 0; j < count; j += 2) {
+	    for (val = vlist[j]; val <= vlist[j + 1]; val++) {
+		for (k = i; k < items; k++) {
+		    if ((*item)[k] == val) {
 			tmp = ip[k];
 			ip[k] = ip[i];
 			ip[i] = tmp;
@@ -76,21 +73,19 @@
 int parse_val_list(char *buf, DCELL ** list)
     int count;
     DCELL a, b;
     DCELL *lp;
     count = 0;
     lp = (DCELL *) G_malloc(sizeof(DCELL));
-    while (*buf)
-	while (*buf == ' ' || *buf == '\t' || *buf == ',' || *buf == '\n')
+    while (*buf) {
+	while (*buf == ' ' || *buf == '\t' || *buf == ',' || *buf == '\n') {
 	    buf++;
-	if (sscanf(buf, "%lf-%lf", &a, &b) == 2)
-	    if (a > b)
+	if (sscanf(buf, "%lf-%lf", &a, &b) == 2) {
+	    if (a > b) {
 		DCELL t;
 		t = a;
@@ -101,14 +96,12 @@
 	    lp[count++] = a;
 	    lp[count++] = b;
-	else if (sscanf(buf, "%lf", &a) == 1)
+	else if (sscanf(buf, "%lf", &a) == 1) {
 	    lp = (DCELL *) G_realloc(lp, (count + 2) * sizeof(DCELL));
 	    lp[count++] = a;
 	    lp[count++] = a;
-	else
+	else {
 	    G_free(lp);
 	    return -1;
Modified: grass-addons/postscript/ps.output/vector.c
--- grass-addons/postscript/ps.output/vector.c	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/vector.c	2010-12-08 23:19:08 UTC (rev 44565)
@@ -47,13 +47,10 @@
     int i, j;
-    for (i = 0; i < vct->n_rule; i++)
-	for (j = 0; j < vct->rule[i].count; j++)
-            if (value >= vct->rule[i].val_list[j] &&
-                value <= vct->rule[i].val_list[j + 1])
+    for (i = 0; i < vct->n_rule; i++) {
+	for (j = 0; j < vct->rule[i].count; j++) {
+	    if (value >= vct->rule[i].val_list[j] &&
+		value <= vct->rule[i].val_list[j + 1]) {
 		return i;
@@ -69,16 +66,13 @@
     rule = vector_rule_find(vct, value);
     /* Check if already exist */
-    for (k = 0; k < vct->n_item; k++)
-        if (vct->item[k].rule == -1)
+    for (k = 0; k < vct->n_item; k++) {
+	if (vct->item[k].rule == -1) {
 	    if (vct->item[k].data == data)
 		return k;
-	else
-            if (vct->item[k].rule == rule)
+	else {
+	    if (vct->item[k].rule == rule)
 		return k;
Modified: grass-addons/postscript/ps.output/vpoints.h
--- grass-addons/postscript/ps.output/vpoints.h	2010-12-08 22:53:50 UTC (rev 44564)
+++ grass-addons/postscript/ps.output/vpoints.h	2010-12-08 23:19:08 UTC (rev 44565)
@@ -24,7 +24,7 @@
     PSLINE line;
     PSCOLOR fcolor;
-    double size, scale, bias;   /* standard size, scale and bias to draw */
+    double size, scale, bias;	/* standard size, scale and bias to draw */
     char *sizecol;		/* size from database or rule */
     double rotate;		/* standard rotate */
