[GRASS-SVN] r44580 - grass/trunk/imagery/i.aster.toar
svn_grass at osgeo.org
Fri Dec 10 07:30:39 EST 2010
Author: ychemin
Date: 2010-12-10 04:30:39 -0800 (Fri, 10 Dec 2010)
New Revision: 44580
grass/trunk/imagery/i.aster.toar/main.c
bug fixing
Modified: grass/trunk/imagery/i.aster.toar/main.c
--- grass/trunk/imagery/i.aster.toar/main.c 2010-12-10 11:15:57 UTC (rev 44579)
+++ grass/trunk/imagery/i.aster.toar/main.c 2010-12-10 12:30:39 UTC (rev 44580)
@@ -20,7 +20,7 @@
#include <grass/raster.h>
#include <grass/glocale.h>
-#define MAXFILES 14
+#define MAXFILES 15
/* DN to radiance conversion factors */
double gain_aster(int band_number, int gain_code);
@@ -225,24 +225,22 @@
for (; *ptr != NULL; ptr++) {
- if (nfiles > MAXFILES+1)
+ if (nfiles > MAXFILES)
G_fatal_error(_("Too many input maps. Only %d allowed."),
- MAXFILES+1);
+ MAXFILES);
name = *ptr;
/* Allocate input buffer */
- in_data_type[nfiles] = Rast_map_type(name, "");
+ in_data_type[nfiles-1] = Rast_map_type(name, "");
/* For some strange reason infd[0] cannot be used later */
/* So nfiles is initialized with nfiles = 1 */
infd[nfiles] = Rast_open_old(name, "");
Rast_get_cellhd(name, "", &cellhd);
- /* Because of nfiles init with 1 */
- /* To return index init with 0 later in code [nfiles-1] */
- inrast[nfiles-1] = Rast_allocate_buf(in_data_type[nfiles]);
+ inrast[nfiles-1] = Rast_allocate_buf(in_data_type[nfiles-1]);
nfiles++;
nfiles--;
- if (nfiles < MAXFILES+1)
+ if (nfiles < MAXFILES)
G_fatal_error(_("The input band number should be 15"));
@@ -253,21 +251,21 @@
for (i = 0; i < MAXFILES; i++)
outrast[i] = Rast_allocate_buf(out_data_type);
- outfd[0] = Rast_open_new(result0, 1);
- outfd[1] = Rast_open_new(result1, 1);
- outfd[2] = Rast_open_new(result2, 1);
- outfd[3] = Rast_open_new(result3, 1);
- outfd[4] = Rast_open_new(result4, 1);
- outfd[5] = Rast_open_new(result5, 1);
- outfd[6] = Rast_open_new(result6, 1);
- outfd[7] = Rast_open_new(result7, 1);
- outfd[8] = Rast_open_new(result8, 1);
- outfd[9] = Rast_open_new(result9, 1);
- outfd[10] = Rast_open_new(result10, 1);
- outfd[11] = Rast_open_new(result11, 1);
- outfd[12] = Rast_open_new(result12, 1);
- outfd[13] = Rast_open_new(result13, 1);
- outfd[14] = Rast_open_new(result14, 1);
+ outfd[1] = Rast_open_new(result0, 1);
+ outfd[2] = Rast_open_new(result1, 1);
+ outfd[3] = Rast_open_new(result2, 1);
+ outfd[4] = Rast_open_new(result3, 1);
+ outfd[5] = Rast_open_new(result4, 1);
+ outfd[6] = Rast_open_new(result5, 1);
+ outfd[7] = Rast_open_new(result6, 1);
+ outfd[8] = Rast_open_new(result7, 1);
+ outfd[9] = Rast_open_new(result8, 1);
+ outfd[10] = Rast_open_new(result9, 1);
+ outfd[11] = Rast_open_new(result10, 1);
+ outfd[12] = Rast_open_new(result11, 1);
+ outfd[13] = Rast_open_new(result12, 1);
+ outfd[14] = Rast_open_new(result13, 1);
+ outfd[15] = Rast_open_new(result14, 1);
/* Process pixels */
DCELL dout[MAXFILES];
@@ -276,8 +274,8 @@
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
/* read input map */
- for (i = 1; i < MAXFILES; i++)
- Rast_get_row(infd[i], inrast[i-1], row, in_data_type[i]);
+ for (i = 1; i <= MAXFILES; i++)
+ Rast_get_row(infd[i], inrast[i-1], row, in_data_type[i-1]);
/*process the data */
for (col = 0; col < ncols; col++) {
@@ -306,13 +304,13 @@
outrast[i][col] = dout[i];
- for (i = 0; i < MAXFILES; i++)
- Rast_put_row(outfd[i], outrast[i], out_data_type);
+ Rast_put_row(outfd[i], outrast[i-1], out_data_type);
- for (i = 0; i < MAXFILES; i++) {
- G_free(inrast[i]);
+ for (i = 1; i <= MAXFILES; i++) {
+ G_free(inrast[i-1]);
Rast_close(infd[i]);
- G_free(outrast[i]);
+ G_free(outrast[i-1]);
Rast_close(outfd[i]);
exit(EXIT_SUCCESS);
