[GRASS-SVN] r44581 - grass-addons/vector/v.vect.stats
svn_grass at osgeo.org
Sat Dec 11 05:34:29 EST 2010
Author: mmetz
Date: 2010-12-11 02:34:29 -0800 (Sat, 11 Dec 2010)
New Revision: 44581
grass-addons/vector/v.vect.stats/main.c
db_add_column() not implemented, fix bug if pcolumn is of type double
Modified: grass-addons/vector/v.vect.stats/main.c
--- grass-addons/vector/v.vect.stats/main.c 2010-12-10 12:30:39 UTC (rev 44580)
+++ grass-addons/vector/v.vect.stats/main.c 2010-12-11 10:34:29 UTC (rev 44581)
@@ -103,7 +103,7 @@
int area, nareas, nacats, nacatsalloc;
int ctype, nrec;
struct field_info *PFi, *AFi;
- dbString stmt, dbstr;
+ dbString stmt;
dbDriver *Pdriver, *Adriver;
char buf[2000];
int update_ok, update_err;
@@ -294,7 +294,6 @@
/* Open database driver */
db_init_string(&stmt);
- db_init_string(&dbstr);
Adriver = NULL;
if (!print_flag->answer) {
@@ -313,6 +312,7 @@
G_fatal_error(_("ccolumn is required to upload point counts"));
/* check if count column exists */
+ G_debug(1, "check if count column exists");
db_get_column(Adriver, AFi->table, count_column_opt->answer, &column);
if (column) {
/* check count column type */
@@ -324,16 +324,15 @@
column = NULL;
else {
- /* create column */
- db_init_column(column);
- db_set_column_name(column, count_column_opt->answer);
- db_set_column_sqltype(column, DB_SQL_TYPE_INTEGER);
- db_set_string(&dbstr, AFi->table);
- if (db_add_column(Adriver, &dbstr, column) != DB_OK)
+ /* create count column */
+ /* db_add_column() exists but is not implemented,
+ * see lib/db/stubs/add_col.c */
+ sprintf(buf, "alter table %s add column %s integer",
+ AFi->table, count_column_opt->answer);
+ db_set_string(&stmt, buf);
+ if (db_execute_immediate(Adriver, &stmt) != DB_OK)
G_fatal_error(_("Unable to add column <%s>"),
- db_free_column(column);
- column = NULL;
if (method_opt->answer) {
@@ -341,6 +340,7 @@
G_fatal_error(_("scolumn is required to upload point stats"));
/* check if stats column exists */
+ G_debug(1, "check if stats column exists");
db_get_column(Adriver, AFi->table, stats_column_opt->answer,
&column);
if (column) {
@@ -354,16 +354,15 @@
column = NULL;
else {
- db_set_column_name(column, stats_column_opt->answer);
- db_set_column_sqltype(column, DB_SQL_TYPE_DOUBLE_PRECISION);
+ /* create stats column */
+ sprintf(buf, "alter table %s add column %s double",
+ AFi->table, stats_column_opt->answer);
- column = NULL;
@@ -385,7 +384,7 @@
G_fatal_error(_("Unable to open database <%s> with driver <%s>"),
PFi->database, PFi->driver);
- /* check if column exists */
+ /* check if point column exists */
db_get_column(Pdriver, PFi->table, point_column_opt->answer, &column);
if (column) {
@@ -545,7 +544,7 @@
case DB_C_TYPE_DOUBLE:
pvalcats[npvalcats].dval = catval->val.d;
- pvalcats++;
+ npvalcats++;
break;
if (npvalcats >= npvalcatsalloc) {
