[GRASS-SVN] r44585 - grass-addons/raster/r.stream.extract
Sat Dec 11 08:34:08 EST 2010
Author: mmetz
Date: 2010-12-11 05:34:08 -0800 (Sat, 11 Dec 2010)
New Revision: 44585
   grass-addons/raster/r.stream.extract/close.c
   grass-addons/raster/r.stream.extract/del_streams.c
   grass-addons/raster/r.stream.extract/do_astar.c
   grass-addons/raster/r.stream.extract/load.c
   grass-addons/raster/r.stream.extract/main.c
   grass-addons/raster/r.stream.extract/streams.c
   grass-addons/raster/r.stream.extract/thin.c
update messages
Modified: grass-addons/raster/r.stream.extract/close.c
--- grass-addons/raster/r.stream.extract/close.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/close.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -30,7 +30,7 @@
     double north_offset, west_offset, ns_res, ew_res;
     int next_cat;
-    G_message(_("write vector maps"));
+    G_message(_("Write vector map <%s>..."), stream_vect);
     if (0 > Vect_open_new(&Out, stream_vect, 0)) {
 	G_fatal_error(_("Unable to create vector map <%s>"), stream_vect);
@@ -138,7 +138,7 @@
 		    draindir.pos = INDEX(r_nbr, c_nbr);
 		    if (stream[INDEX(r_nbr, c_nbr)] <= 0)
-			G_fatal_error("stream id not set");
+			G_fatal_error(_("BUG: stream id not set"));
 		    Vect_append_point(Points, west_offset + c_nbr * ew_res,
 				      north_offset - r_nbr * ns_res, 0);
@@ -152,7 +152,7 @@
     G_percent(n_outlets, n_outlets, 1);	/* finish it */
-    G_message(_("write vector attribute table"));
+    G_message(_("Write vector attribute table"));
     /* Prepeare strings for use in db_* calls */
     db_init_string(&dbsql);
@@ -210,15 +210,13 @@
-    G_message(_("close vector"));
     db_commit_transaction(driver);
     db_close_database_shutdown_driver(driver);
     Vect_map_add_dblink(&Out, 1, NULL, Fi->table,
 			cat_col_name, Fi->database, Fi->driver);
+    G_debug(1, "close vector");
     Vect_hist_command(&Out);
     Vect_build(&Out);
@@ -241,7 +239,8 @@
     stream_fd = dir_fd = -1;
     cell_buf1 = cell_buf2 = NULL;
-    G_message(_("write raster maps"));
+    G_message(_("Write raster %s"),
+              (stream_rast != NULL) + (dir_rast != NULL) > 1 ? "maps" : "map");
     /* write requested output rasters */
     if (stream_rast) {
Modified: grass-addons/raster/r.stream.extract/del_streams.c
--- grass-addons/raster/r.stream.extract/del_streams.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/del_streams.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -13,7 +13,7 @@
     int curr_stream, stream_id, other_trib, tmp_trib;
     int slength;
-    G_message(_("delete stream segments shorter than %d cells..."), min_length);
+    G_message(_("Delete stream segments shorter than %d cells..."), min_length);
     /* go through all nodes */
     for (i = 1; i <= n_stream_nodes; i++) {
@@ -71,7 +71,7 @@
-    G_debug(1, "%d stream segments deleted", n_deleted);
+    G_verbose_message(_("%d stream segments deleted"), n_deleted);
     return n_deleted;
Modified: grass-addons/raster/r.stream.extract/do_astar.c
--- grass-addons/raster/r.stream.extract/do_astar.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/do_astar.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -65,11 +65,11 @@
     while (heap_size > 0) {
 	G_percent(count++, n_points, 1);
 	if (count > n_points)
-	    G_fatal_error("broken A* Search, %d surplus points", heap_size);
+	    G_fatal_error(_("BUG in A* Search: %d surplus points"), heap_size);
 	if (heap_size > n_points)
 	    G_fatal_error
-		("broken A* Search, too many points in heap %d, should be %d",
+		(_("BUG in A* Search: too many points in heap %d, should be %d"),
 		 heap_size, n_points);
 	astp = astar_pts[1];
@@ -217,9 +217,6 @@
     heap_size++;
-    if (heap_size > n_points)
-	G_fatal_error(_("heapsize too large"));
     astar_added[heap_size] = nxt_avail_pt;
     astar_pts[heap_size] = INDEX(r, c);
Modified: grass-addons/raster/r.stream.extract/load.c
--- grass-addons/raster/r.stream.extract/load.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/load.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -40,9 +40,9 @@
     DCELL *accp;
     if (acc_fd < 0)
-	G_message(_("load elevation map and get start points"));
+	G_message(_("Load elevation map and get start points..."));
     else
-	G_message(_("load input maps and get start points"));
+	G_message(_("Load input maps and get start points..."));
     n_search_points = n_points = 0;
@@ -52,7 +52,7 @@
     ele_buf = G_allocate_raster_buf(ele_map_type);
     if (ele_buf == NULL) {
-	G_warning(_("could not allocate memory"));
+	G_warning(_("Could not allocate memory"));
 	return -1;
@@ -61,7 +61,7 @@
 	acc_size = G_raster_size(acc_map_type);
 	acc_buf = G_allocate_raster_buf(acc_map_type);
 	if (acc_buf == NULL) {
 	    return -1;
@@ -83,14 +83,14 @@
 	G_percent(r, nrows, 2);
 	if (G_get_raster_row(ele_fd, ele_buf, r, ele_map_type) < 0) {
-	    G_warning(_("could not read raster maps at row <%d>"), r);
+	    G_warning(_("Could not read raster maps at row <%d>"), r);
 	    return -1;
 	ptr = ele_buf;
 	if (acc_fd >= 0) {
 	    if (G_get_raster_row(acc_fd, acc_buf, r, acc_map_type) < 0) {
 		return -1;
 	    acc_ptr = acc_buf;
@@ -180,14 +180,14 @@
     else
 	depr_buf = NULL;
-    G_message(_("set edge points"));
+    G_message(_("Set edge points..."));
     loadp = ele;
     for (r = 0; r < nrows; r++) {
 	if (depr_fd >= 0) {
 	    if (G_get_raster_row(depr_fd, depr_buf, r, CELL_TYPE) < 0) {
-		G_warning(_("could not read raster map at row <%d>"), r);
+		G_warning(_("Could not read raster map at row <%d>"), r);
 		return -1;
@@ -266,7 +266,7 @@
 	G_free(depr_buf);
-    G_debug(1, "%d edge cells", heap_size);
+    G_debug(1, "%d edge (and depression) cells", heap_size);
     G_debug(1, "%d non-NULL cells", n_points);
     return 1;
Modified: grass-addons/raster/r.stream.extract/main.c
--- grass-addons/raster/r.stream.extract/main.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/main.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -225,13 +225,13 @@
     mapset = G_find_cell2(input.ele->answer, "");
     ele_fd = G_open_cell_old(input.ele->answer, mapset);
     if (ele_fd < 0)
-	G_fatal_error(_("could not open input map %s"), input.ele->answer);
+	G_fatal_error(_("Could not open input map %s"), input.ele->answer);
     if (input.acc->answer) {
 	mapset = G_find_cell2(input.acc->answer, "");
 	acc_fd = G_open_cell_old(input.acc->answer, mapset);
 	if (acc_fd < 0)
 			  input.acc->answer);
     else
@@ -241,7 +241,7 @@
 	mapset = G_find_cell2(input.depression->answer, "");
 	depr_fd = G_open_cell_old(input.depression->answer, mapset);
 	if (depr_fd < 0)
 			  input.depression->answer);
     else
@@ -260,7 +260,7 @@
     /* load maps */
     if (load_maps(ele_fd, acc_fd, depr_fd) < 0)
-	G_fatal_error(_("could not load input map(s)"));
+	G_fatal_error(_("Could not load input map(s)"));
     /*    processing    */
@@ -268,35 +268,35 @@
     /* sort elevation and get initial stream direction */
     if (do_astar() < 0)
-	G_fatal_error(_("could not sort elevation map"));
+	G_fatal_error(_("Could not sort elevation map"));
     /* extract streams */
     if (acc_fd < 0) {
 	if (do_accum(d8cut) < 0)
-	    G_fatal_error(_("could not calculate flow accumulation"));
+	    G_fatal_error(_("Could not calculate flow accumulation"));
     stream = (CELL *) G_malloc(nrows * ncols * sizeof(CELL));
     if (extract_streams
 	(threshold, mont_exp, min_stream_length) < 0)
-	G_fatal_error(_("could not extract streams"));
+	G_fatal_error(_("Could not extract streams"));
     G_free(acc);
     /* thin streams */
     if (thin_streams() < 0)
     /* delete short streams */
     if (min_stream_length) {
 	if (del_streams(min_stream_length) < 0)
     /* write output maps */
     if (close_maps(output.stream_rast->answer, output.stream_vect->answer,
 		   output.dir_rast->answer) < 0)
-	G_fatal_error(_("could not write output maps"));
+	G_fatal_error(_("Could not write output maps"));
     G_free(ele);
     G_free(stream);
Modified: grass-addons/raster/r.stream.extract/streams.c
--- grass-addons/raster/r.stream.extract/streams.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/streams.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -108,7 +108,7 @@
 	/* debug */
 	if (n_stream_nodes != *stream_no)
-	    G_warning(_("stream_no %d and n_stream_nodes %d out of sync"),
+	    G_warning(_("BUG: stream_no %d and n_stream_nodes %d out of sync"),
 		      *stream_no, n_stream_nodes);
 	/* add all tributaries */
@@ -167,12 +167,12 @@
 	while ((founddir = rbtree_find(draintree, &draindir)) != NULL) {
 	    if (asp_r[(int)founddir->dir] == 0 &&
 		asp_c[(int)founddir->dir] == 0)
-		G_fatal_error("no valid stream direction");
+		G_fatal_error(_("BUG: no valid stream direction"));
 	    r_nbr = r_nbr + asp_r[(int)founddir->dir];
 	    c_nbr = c_nbr + asp_c[(int)founddir->dir];
 	    else
 		stream[INDEX(r_nbr, c_nbr)] = curr_stream;
@@ -201,7 +201,7 @@
     G_debug(2, "%d tribs", stream_node[curr_stream].n_trib);
     if (stream_node[curr_stream].n_trib == 1)
-	G_warning("stream node %d only 1 trib: %d", curr_stream,
+	G_warning(_("BUG: stream node %d has only 1 tributary: %d"), curr_stream,
 		  stream_node[curr_stream].trib[0]);
     return 1;
@@ -231,7 +231,7 @@
     int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
     unsigned int thisindex, nindex, workedon, killer;
-    G_message(_("calculate flow accumulation..."));
+    G_message(_("Calculate flow accumulation..."));
     count = 0;
@@ -456,7 +456,7 @@
     int stream_no = 0, stream_node_step = 1000;
     double slope, diag;
-    G_message(_("extract streams..."));
+    G_message(_("Extract streams..."));
     /* init BST for drainage direction */
     draintree = rbtree_create(draindir_compare, sizeof(struct ddir));
@@ -728,7 +728,7 @@
 	    /* debug */
 	    if (n_stream_nodes != stream_no)
Modified: grass-addons/raster/r.stream.extract/thin.c
--- grass-addons/raster/r.stream.extract/thin.c	2010-12-11 13:33:43 UTC (rev 44584)
+++ grass-addons/raster/r.stream.extract/thin.c	2010-12-11 13:34:08 UTC (rev 44585)
@@ -20,7 +20,7 @@
     curr_stream = stream[thisindex];
     if (curr_stream != stream_id)
-	G_fatal_error(_("stream node and stream not identical: stream id %d, stream node id %d, stream %d"),
+	G_fatal_error(_("BUG: stream node and stream not identical: stream id %d, stream node id %d, stream %d"),
 		      stream_id, stream_node[stream_id].id, curr_stream);
     draindir.pos = thisindex;
@@ -90,7 +90,7 @@
     int top = 0, stack_step = 1000;
     int n_trib_total;
-    G_message(_("thin stream segments"));
+    G_message(_("Thin stream segments..."));
     nodestack = (struct sstack *)G_malloc(stack_step * sizeof(struct sstack));
