[GRASS-SVN] r44586 -
grass/branches/develbranch_6/lib/external/bwidget
svn_grass at osgeo.org
Sun Dec 12 11:41:54 EST 2010
Author: marisn
Date: 2010-12-12 08:41:54 -0800 (Sun, 12 Dec 2010)
New Revision: 44586
grass/branches/develbranch_6/lib/external/bwidget/combobox.tcl
Modify BWidget ComboBox to allow choice labels
Modified: grass/branches/develbranch_6/lib/external/bwidget/combobox.tcl
--- grass/branches/develbranch_6/lib/external/bwidget/combobox.tcl 2010-12-11 13:34:08 UTC (rev 44585)
+++ grass/branches/develbranch_6/lib/external/bwidget/combobox.tcl 2010-12-12 16:41:54 UTC (rev 44586)
@@ -15,6 +15,9 @@
# - ComboBox::_select
# - ComboBox::_modify_value
+# -labels is a list of value labels. Such ComboBoxes are not editable
+# -labelsvariable will contain a label for selected value
+# If You use -labels, You also have to specify -labelsvariable!
namespace eval ComboBox {
ArrowButton::use
@@ -34,6 +37,8 @@
Widget::declare ComboBox {
{-height TkResource 0 0 listbox}
{-values String "" 0}
+ {-labels String "" 0}
+ {-labelsvariable String "" 0}
{-modifycmd String "" 0}
{-postcommand String "" 0}
@@ -58,7 +63,17 @@
proc ComboBox::create { path args } {
Widget::init ComboBox $path $args
+ if { [Widget::getoption $path -labels] != "" && [Widget::getoption $path -labelsvariable] != "" } {
+ Widget::setoption $path -editable 0
+ # Set initial label if it's not set
+ if { [GlobalVar::getvar [Widget::getoption $path -labelsvariable]] == "" } {
+ GlobalVar::setvar [Widget::getoption $path -labelsvariable] [lindex [Widget::getoption $path -labels] [lsearch [Widget::getoption $path -values] [GlobalVar::getvar [Widget::getoption $path -textvariable]]]]
+ if { [Widget::getoption $path -labels] == "" || [Widget::getoption $path -labelsvariable] == "" } {
+ Widget::setoption $path -labelsvariable [Widget::getoption $path -textvariable]
frame $path -background [Widget::getoption $path -background] \
-highlightthickness 0 -bd 0 -relief flat -takefocus 0
@@ -67,7 +82,7 @@
set labf [eval LabelFrame::create $path.labf [Widget::subcget $path .labf] \
-focus $path.e]
set entry [eval Entry::create $path.e [Widget::subcget $path .e] \
- -relief flat -borderwidth 0]
+ -relief flat -borderwidth 0 -textvariable [Widget::getoption $path -labelsvariable]]
set width 11
set height [winfo reqheight $entry]
@@ -140,8 +155,12 @@
# Command ComboBox::setvalue
proc ComboBox::setvalue { path index } {
- set values [Widget::getoption $path -values]
- set value [Entry::cget $path.e -text]
+ if { [Widget::getoption $path -labels] == "" } {
+ set values [Widget::getoption $path -values]
+ } else {
+ set values [Widget::getoption $path -labels]
+ set value [Entry::cget $path.e -text]
switch -- $index {
next {
if { [set idx [lsearch $values $value]] != -1 } {
@@ -177,8 +196,13 @@
if { $idx >= 0 && $idx < [llength $values] } {
set newval [lindex $values $idx]
Widget::setoption $path -text $newval
- if { [set varname [Entry::cget $path.e -textvariable]] != "" } {
- GlobalVar::setvar $varname $newval
+ if { [set varname [Widget::getoption $path -textvariable]] != "" } {
+ GlobalVar::setvar $varname $newval
+ } else {
+ GlobalVar::setvar $varname [lindex [Widget::getoption $path -values] $idx]
+ GlobalVar::setvar [Widget::getoption $path.e -textvariable] $newval
} else {
Entry::configure $path.e -text $newval
@@ -192,10 +216,11 @@
# Command ComboBox::getvalue
proc ComboBox::getvalue { path } {
- return [lsearch $values $value]
+ return [lsearch [Widget::getoption $path -values] [Entry::cget $path.e -text]]
+ } else {
+ return [lsearch [Widget::getoption $path -labels] [Entry::cget $path.e -text]]
@@ -216,7 +241,11 @@
wm withdraw $shell
wm transient $shell [winfo toplevel $path]
wm group $shell [winfo toplevel $path]
- set lval [Widget::getoption $path -values]
+ set lval [Widget::getoption $path -values]
+ } else {
+ set lval [Widget::getoption $path -labels]
set h [Widget::getoption $path -height]
set sb 0
if { $h <= 0 } {
@@ -264,7 +293,7 @@
proc ComboBox::_mapliste { path } {
set listb $path.shell.listb
if { [winfo exists $path.shell] } {
- _unmapliste $path
+ _unmapliste $path
return
