[GRASS-SVN] r44661 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Dec 22 06:32:55 EST 2010
Author: martinl
Date: 2010-12-22 03:32:54 -0800 (Wed, 22 Dec 2010)
New Revision: 44661
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI/dialog: fix dialog size
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-12-22 11:03:58 UTC (rev 44660)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-12-22 11:32:54 UTC (rev 44661)
@@ -867,9 +867,8 @@
sizeFrame = self.GetBestSize()
self.SetMinSize(sizeFrame)
- self.SetSize((sizeFrame[0], sizeFrame[1] +
- self.notebookpanel.constrained_size[1] -
- self.notebookpanel.panelMinHeight))
+ self.SetSize(wx.Size(sizeFrame[0], sizeFrame[1] + 0.33 * max(self.notebookpanel.panelMinHeight,
+ self.notebookpanel.constrained_size[1])))
# thread to update dialog
# create queues
@@ -881,8 +880,8 @@
# keep initial window size limited for small screens
width, height = self.GetSizeTuple()
- self.SetSize(wx.Size(min(width, 640),
- min(height, 480)))
+ self.SetSize(wx.Size(min(width, 650),
+ min(height, 500)))
# fix goutput's pane size
if self.goutput:
@@ -1265,10 +1264,10 @@
p.get('gisprompt',False) == False and \
p.get('type', '') == 'string':
title_txt.SetLabel(" %s: (%s, %s) " % (title, p['name'], p['type']))
- if len(valuelist) > 6:
- hSizer = wx.StaticBoxSizer (box = title_txt, orient = wx.VERTICAL)
+ if valuelist_desc:
+ hSizer = wx.StaticBoxSizer(box = title_txt, orient = wx.VERTICAL)
else:
- hSizer = wx.StaticBoxSizer (box = title_txt, orient = wx.HORIZONTAL)
+ hSizer = wx.StaticBoxSizer(box = title_txt, orient = wx.HORIZONTAL)
isEnabled = {}
# copy default values
if p['value'] == '':
@@ -1294,15 +1293,14 @@
hSizer.Add(item = chkbox, proportion = 0,
flag = wx.ADJUST_MINSIZE | wx.ALL, border = 1)
chkbox.Bind(wx.EVT_CHECKBOX, self.OnCheckBoxMulti)
idx += 1
which_sizer.Add(item = hSizer, proportion = 0,
- flag = wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border = 5)
+ flag = wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border = 5)
elif p.get('gisprompt', False) == False:
if len(valuelist) == 1: # -> textctrl
title_txt.SetLabel("%s (%s %s):" % (title, _('valid range'),
- str(valuelist[0])))
+ str(valuelist[0])))
if p.get('type', '') == 'integer' and \
not p.get('multiple', False):
@@ -1813,13 +1811,13 @@
# determine panel size
- maxsizes = (0,0)
+ maxsizes = (0, 0)
for section in sections:
tab[section].SetSizer(tabsizer[section])
tabsizer[section].Fit(tab[section])
tab[section].Layout()
minsecsizes = tabsizer[section].GetSize()
- maxsizes = map(lambda x: max(maxsizes[x], minsecsizes[x]), (0,1))
+ maxsizes = map(lambda x: max(maxsizes[x], minsecsizes[x]), (0, 1))
# TODO: be less arbitrary with these 600
self.panelMinHeight = 100
