[GRASS-SVN] r44662 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Dec 22 08:21:54 EST 2010
Author: martinl
Date: 2010-12-22 05:21:54 -0800 (Wed, 22 Dec 2010)
New Revision: 44662
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: fix wrapping module description
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-12-22 11:32:54 UTC (rev 44661)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-12-22 13:21:54 UTC (rev 44662)
@@ -1503,7 +1503,7 @@
return filetype, ltype
class StaticWrapText(wx.StaticText):
- """! A Static Text field that wraps its text to fit its width,
+ """!A Static Text field that wraps its text to fit its width,
enlarging its height if necessary.
def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
@@ -1523,7 +1523,7 @@
def OnResize(self, event):
if not getattr(self, "resizing", False):
self.resizing = True
- newSize = wx.Size(self.parent.GetSize().width,
+ newSize = wx.Size(self.parent.GetSize().width - 50,
self.GetSize().height)
if self.wrappedSize != newSize:
wx.StaticText.SetLabel(self, self.originalLabel)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-12-22 11:32:54 UTC (rev 44661)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-12-22 13:21:54 UTC (rev 44662)
@@ -33,8 +33,8 @@
@todo
- verify option value types
-Copyright (C) 2000-2010 by the GRASS Development Team
-This program is free software under the GPL (>=v2) Read the file
+Copyright(C) 2000-2010 by the GRASS Development Team
+This program is free software under the GPL(>=v2) Read the file
COPYING coming with GRASS for details.
@author Jan-Oliver Wagner <jan at intevation.de>
@@ -741,21 +741,21 @@
bitmap = wx.Bitmap(name = os.path.join(imagepath,
'grass_form.png'),
type = wx.BITMAP_TYPE_PNG))
- topsizer.Add (item = self.logo, proportion = 0, border = 3,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL)
+ topsizer.Add(item = self.logo, proportion = 0, border = 3,
+ flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL)
# add module description
- if self.task.label != '':
+ if self.task.label:
module_desc = self.task.label + ' ' + self.task.description
else:
module_desc = self.task.description
self.description = gdialogs.StaticWrapText(parent = self.panel,
label = module_desc)
- topsizer.Add (item = self.description, proportion = 1, border = 5,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
- guisizer.Add (item = topsizer, proportion = 0, flag = wx.EXPAND)
+ topsizer.Add(item = self.description, proportion = 1, border = 5,
+ flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+ guisizer.Add(item = topsizer, proportion = 0, flag = wx.EXPAND)
self.panel.SetSizerAndFit(guisizer)
self.Layout()
@@ -764,7 +764,7 @@
mainFrame = self)
self.goutput = self.notebookpanel.goutput
self.notebookpanel.OnUpdateValues = self.updateValuesHook
- guisizer.Add (item = self.notebookpanel, proportion = 1, flag = wx.EXPAND)
+ guisizer.Add(item = self.notebookpanel, proportion = 1, flag = wx.EXPAND)
# status bar
status_text = _("Enter parameters for '") + self.task.name + "'"
@@ -803,7 +803,7 @@
self.btn_run.SetToolTipString(_("Run the command (Ctrl+R)"))
self.btn_run.SetDefault()
# copy
- self.btn_clipboard = wx.Button(parent = self.panel, id = wx.ID_COPY)
+ self.btn_clipboard = wx.Button(parent = self.panel, id = wx.ID_COPY, label = _("C&opy"))
self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
btnsizer.Add(item = self.btn_run, proportion = 0,
@@ -855,11 +855,6 @@
self.Bind(wx.EVT_CLOSE, self.OnCancel)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
- # constrained_size = self.notebookpanel.GetSize()
- # 80 takes the tabbar into account
- ### self.notebookpanel.SetSize((constrained_size[0] + 25, constrained_size[1]))
- ### self.notebookpanel.Layout()
# do layout
# called automatically by SetSizer()
self.panel.SetAutoLayout(True)
@@ -1154,7 +1149,7 @@
# if label is given: description -> tooltip
if f.get('label','') != '':
title = text_beautify(f['label'])
- tooltip = text_beautify (f['description'], width = -1)
+ tooltip = text_beautify(f['description'], width = -1)
else:
title = text_beautify(f['description'])
tooltip = None
@@ -1215,7 +1210,7 @@
# otherwise description -> lavel
if p.get('label','') != '':
title = text_beautify(p['label'])
- tooltip = text_beautify (p['description'], width = -1)
+ tooltip = text_beautify(p['description'], width = -1)
else:
title = text_beautify(p['description'])
tooltip = None
@@ -1232,7 +1227,7 @@
p.get('multiple', False) and \
p.get('gisprompt',False) == False and \
p.get('type', '') == 'string':
- title_txt = wx.StaticBox (parent = which_panel, id = wx.ID_ANY)
+ title_txt = wx.StaticBox(parent = which_panel, id = wx.ID_ANY)
else:
title_sizer = wx.BoxSizer(wx.HORIZONTAL)
title_txt = wx.StaticText(parent = which_panel)
