[GRASS-SVN] r44735 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Dec 26 13:52:34 EST 2010
Author: martinl
Date: 2010-12-26 10:52:33 -0800 (Sun, 26 Dec 2010)
New Revision: 44735
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI/GSelect: filtering items in progress, see #1251 (r44725 cont'ed)
patch by Anna Kratochvilova
(merge r44734 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-12-26 18:50:26 UTC (rev 44734)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-12-26 18:52:33 UTC (rev 44735)
@@ -76,10 +76,10 @@
self.tcp.SetData(type = type, mapsets = mapsets,
multiple = multiple,
updateOnPopup = updateOnPopup, onPopup = onPopup)
- self.GetChildren()[0].Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+ self.GetChildren()[0].Bind(wx.EVT_KEY_UP, self.OnKeyUp)
- def OnKeyDown(self, event):
- """!Shows popupwindow if down arrow key is pressed"""
+ def OnKeyUp(self, event):
+ """!Shows popupwindow if down arrow key is released"""
if event.GetKeyCode() == wx.WXK_DOWN:
self.ShowPopup()
else:
@@ -184,10 +184,6 @@
def SetFilter(self, filter):
"""!Set filter for GIS elements, see e.g. VectorSelect"""
self.filterElements = filter
- def _startsWith(self, text):
- """!Filter items - currently unused"""
- return True if text.startswith(self.GetCombo().GetValue()) else False
def OnPopup(self, force = False):
"""!Limited only for first selected"""
@@ -206,10 +202,6 @@
if inputText:
root = self.seltree.GetRootItem()
match = self.FindItem(root, inputText, startLetters = True)
- if wx.TreeItemId.IsOk(self.seltree.GetPrevSibling(match)):
- match = self.seltree.GetPrevSibling(match)
- else:
- match = self.seltree.GetItemParent(match)
self.seltree.EnsureVisible(match)
self.seltree.SelectItem(match)
@@ -459,8 +451,13 @@
mapsetItem = self.seltree.GetItemParent(item)
fullName = self.seltree.GetItemText(item) + '@' \
+ self.seltree.GetItemText(mapsetItem).split(' ', 1)[1]
- self.value = [fullName, ]
- self.Dismiss()
+ if self.multiple is True:
+ # text item should be unique
+ self.value.append(fullName)
+ else:
+ self.value = [fullName, ]
+ self.Dismiss()
def OnMotion(self, evt):
"""!Have the selection follow the mouse, like in a real combobox
