[GRASS-SVN] r44736 - grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
Sun Dec 26 13:53:25 EST 2010
Author: martinl
Date: 2010-12-26 10:53:25 -0800 (Sun, 26 Dec 2010)
New Revision: 44736
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
wxGUI/GSelect: filtering items in progress, see #1251 (r44725 cont'ed)
patch by Anna Kratochvilova
(merge r44734 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2010-12-26 18:52:33 UTC (rev 44735)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2010-12-26 18:53:25 UTC (rev 44736)
@@ -76,10 +76,10 @@
             self.tcp.SetData(type = type, mapsets = mapsets,
                              multiple = multiple,
                              updateOnPopup = updateOnPopup, onPopup = onPopup)
-        self.GetChildren()[0].Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+        self.GetChildren()[0].Bind(wx.EVT_KEY_UP, self.OnKeyUp)
-    def OnKeyDown(self, event):
-        """!Shows popupwindow if down arrow key is pressed"""
+    def OnKeyUp(self, event):
+        """!Shows popupwindow if down arrow key is released"""
         if event.GetKeyCode() == wx.WXK_DOWN:
             self.ShowPopup()
         else:
@@ -184,10 +184,6 @@
     def SetFilter(self, filter):
         """!Set filter for GIS elements, see e.g. VectorSelect"""
         self.filterElements = filter
-    def _startsWith(self, text):
-        """!Filter items - currently unused"""
-        return True if text.startswith(self.GetCombo().GetValue()) else False
     def OnPopup(self, force = False):
         """!Limited only for first selected"""
@@ -206,10 +202,6 @@
         if inputText:
             root = self.seltree.GetRootItem()
             match = self.FindItem(root, inputText, startLetters = True)
-            if wx.TreeItemId.IsOk(self.seltree.GetPrevSibling(match)):
-                match = self.seltree.GetPrevSibling(match)
-            else:
-                match = self.seltree.GetItemParent(match)
             self.seltree.EnsureVisible(match)
             self.seltree.SelectItem(match)
@@ -459,8 +451,13 @@
                 mapsetItem = self.seltree.GetItemParent(item)
                 fullName = self.seltree.GetItemText(item) + '@' \
                             + self.seltree.GetItemText(mapsetItem).split(' ', 1)[1]
-                self.value = [fullName, ]
-                self.Dismiss()
+                if self.multiple is True:
+                    # text item should be unique
+                    self.value.append(fullName)
+                else:
+                    self.value = [fullName, ]
+            self.Dismiss()
     def OnMotion(self, evt):
         """!Have the selection follow the mouse, like in a real combobox
