[GRASS-SVN] r40838 - in grass/trunk: include lib/gis lib/sites lib/vector/Vlib lib/vector/diglib
Fri Feb 5 21:42:45 EST 2010
Author: glynn
Date: 2010-02-05 21:42:44 -0500 (Fri, 05 Feb 2010)
New Revision: 40838
Removed:
   grass/trunk/lib/gis/index.c
   grass/trunk/include/gisdefs.h
   grass/trunk/lib/gis/parser_help.c
   grass/trunk/lib/gis/token.c
   grass/trunk/lib/sites/sites.c
   grass/trunk/lib/vector/Vlib/ascii.c
   grass/trunk/lib/vector/Vlib/header.c
   grass/trunk/lib/vector/diglib/frmt.c
Eliminate G_index(), G_rindex(); replace with strchr(), strrchr()
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/include/gisdefs.h	2010-02-06 02:42:44 UTC (rev 40838)
@@ -286,10 +286,6 @@
 const char *G_home(void);
 const char *G__home(void);
-/* index.c */
-char *G_index(const char *, int);
-char *G_rindex(const char *, int);
 /* intersect.c */
 int G_intersect_line_segments(double, double, double, double, double, double,
 			      double, double, double *, double *, double *,
Deleted: grass/trunk/lib/gis/index.c
--- grass/trunk/lib/gis/index.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/gis/index.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -1,49 +0,0 @@
-/* TODO: should this go into strings.c ? */
-#include <grass/gis.h>
- * \brief delimiter
- * position of delimiter
- *  \param str
- *  \param delim
- *  \return char *
-char *G_index(const char *str, int delim)
-    while (*str && *str != delim)
-	str++;
-    if (delim == 0)
-	return (char *)str;
-    return *str ? (char *)str : NULL;
- * \brief ???
- *  \param str
- *  \param delim
- *  \return char *
-char *G_rindex(const char *str, int delim)
-    const char *p;
-    p = NULL;
-    while (*str) {
-	if (*str == delim)
-	    p = str;
-	str++;
-    if (delim == 0)
-    return (char *)p;
Modified: grass/trunk/lib/gis/parser_help.c
--- grass/trunk/lib/gis/parser_help.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/gis/parser_help.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -218,7 +218,7 @@
     fprintf(stderr, _("  %*s   options: "), maxlen, " ");
     totlen = maxlen + 13;
     p1 = buff;
-    while ((p2 = G_index(p1, ','))) {
+    while ((p2 = strchr(p1, ','))) {
 	*p2 = '\0';
 	len = strlen(p1) + 1;
 	if ((len + totlen) > 76) {
Modified: grass/trunk/lib/gis/token.c
--- grass/trunk/lib/gis/token.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/gis/token.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -15,6 +15,7 @@
 #include <stdlib.h>
+#include <string.h>
@@ -49,7 +50,7 @@
     char *p;
     i = 0;
-    while (!G_index(delim, *buf) && (*buf == ' ' || *buf == '\t'))	/* needed for G_free () */
+    while (!strchr(delim, *buf) && (*buf == ' ' || *buf == '\t'))	/* needed for G_free () */
 	buf++;
     p = G_store(buf);
@@ -57,14 +58,14 @@
     tokens = (char **)G_malloc(sizeof(char *));
     while (1) {
-	while (!G_index(delim, *p) && (*p == ' ' || *p == '\t'))
+	while (!strchr(delim, *p) && (*p == ' ' || *p == '\t'))
 	    p++;
 	if (*p == 0)
 	    break;
 	tokens[i++] = p;
 	tokens = (char **)G_realloc((char *)tokens, (i + 1) * sizeof(char *));
-	while (*p && (G_index(delim, *p) == NULL))
+	while (*p && (strchr(delim, *p) == NULL))
 	    p++;
 	if (*p == 0)
 	    break;
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/sites/sites.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -632,9 +632,9 @@
     /* move pointer past easting and northing fields */
-    if (NULL == (buf = G_index(buf, PIPE)))
+    if (NULL == (buf = strchr(buf, PIPE)))
 	return -2;
-    if (NULL == (buf = G_index(buf + 1, PIPE)))
+    if (NULL == (buf = strchr(buf + 1, PIPE)))
 	return -2;
     /* check for remaining dimensional fields */
@@ -647,13 +647,13 @@
 	    if (sscanf(buf, "%lf|", &(s->dim[dim++])) < 1)
 		return -2;	/* no more dims, though expected */
-	else if (NULL != (p1 = G_index(buf, PIPE))) {
-	    if (NULL == (p2 = G_index(buf, DQUOTE)))
+	else if (NULL != (p1 = strchr(buf, PIPE))) {
+	    if (NULL == (p2 = strchr(buf, DQUOTE)))
 		err = 1;	/* more dims, though none expected */
 	    else if (strlen(p1) > strlen(p2))
-    } while ((buf = G_index(buf, PIPE)) != NULL);
+    } while ((buf = strchr(buf, PIPE)) != NULL);
     buf = last;
     /* no more dimensions-now we parse attribute fields */
@@ -803,7 +803,7 @@
-    while (G_index(buf, PIPE) != (char *)NULL) {
+    while (strchr(buf, PIPE) != (char *)NULL) {
 	(*dims)++;
 	while (!ispipe(*buf) && !isnull(*buf))
 	    buf++;
@@ -920,7 +920,7 @@
     /* find where this string terminates */
     if (*buf != DQUOTE) {	/* if no DQUOTEs, */
-	stop = G_index(buf, SPACE);	/* then SPACE separates */
+	stop = strchr(buf, SPACE);	/* then SPACE separates */
 	if (stop == (char *)NULL)
 	    return strlen(buf);
 	else
@@ -935,14 +935,14 @@
 		p++;
 	    p = buf;
-	    stop = G_index(p + 1, DQUOTE);
+	    stop = strchr(p + 1, DQUOTE);
 	    while (*(stop - 1) == BSLASH)
-		stop = G_index(++stop, DQUOTE);
+		stop = strchr(++stop, DQUOTE);
     /* remove backslashes between buf and stop */
     p = buf;
-    while ((p = G_index(p, BSLASH)) != (char *)NULL && p <= stop) {
+    while ((p = strchr(p, BSLASH)) != (char *)NULL && p <= stop) {
 	p2 = p + 1;
 	if (*p2 != '\0' && (*p2 == DQUOTE || *p2 == BSLASH)) {
 	    while (*p != '\0') {
@@ -1102,7 +1102,7 @@
 	    /* do not uncomment this code because sites file was created
 	     * as we want. So it's enough to print them out as it is.
-	     if (G_index (s->str_att[i], DQUOTE) != (char *) NULL)
+	     if (strchr (s->str_att[i], DQUOTE) != (char *) NULL)
 	     while (!isnull(s->str_att[i][j]))
@@ -1124,7 +1124,7 @@
 	    strcpy(s->str_att[i], xbuf);
-	    if (G_index(s->str_att[i], SPACE) != (char *)NULL)
+	    if (strchr(s->str_att[i], SPACE) != (char *)NULL)
 		sprintf(xbuf, "%s%s\"%s\"", nfs, ((id == 0) ? "" : "@"),
 			s->str_att[i]);
 	    else
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/vector/Vlib/ascii.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -14,6 +14,7 @@
   \author Updated for GRASS 7 (SF support) by Martin Landa <landa.martin gmail.com>
 #include <stdio.h>
 #include <grass/vector.h>
 #include <grass/dbmi.h>
@@ -217,7 +218,7 @@
 	if (strncmp(buff, "VERTI:", 6) == 0)
 	    return (0);
-	if (!(ptr = G_index(buff, ':')))
+	if (!(ptr = strchr(buff, ':')))
 	    G_fatal_error(_("Unexpected data in vector head:\n[%s]"), buff);
 	ptr++;			/* Search for the start of text */
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/vector/Vlib/header.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -143,7 +143,7 @@
     while (G_getl2(buff, 2000, head_fp)) {
-	if (!(ptr = G_index(buff, ':'))) {
+	if (!(ptr = strchr(buff, ':'))) {
 	    G_warning(_("Corrupted row in head: %s"), buff);
 	    continue;
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c	2010-02-06 02:37:43 UTC (rev 40837)
+++ grass/trunk/lib/vector/diglib/frmt.c	2010-02-06 02:42:44 UTC (rev 40838)
@@ -41,7 +41,7 @@
     if (G_getl2(buff, 2000, dascii)) {
 	G_chop(buff);
 	    G_warning("Vector format not recognized: %s", buff);
 	    return (-1);
@@ -73,7 +73,7 @@
     while (G_getl2(buff, 2000, dascii)) {
 	G_chop(buff);
 	    G_warning("Format definition is not correct: %s", buff);
 	    continue;
