[GRASS-SVN] r40839 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Feb 5 22:12:24 EST 2010
Author: glynn
Date: 2010-02-05 22:12:23 -0500 (Fri, 05 Feb 2010)
New Revision: 40839
grass/trunk/lib/gis/asprintf.c
grass/trunk/lib/gis/snprintf.c
Fix G_snprintf() to allow for bug in Windows vsnprintf()
Change G_vasprintf() to use vsnprintf instead of temporary file
Modified: grass/trunk/lib/gis/asprintf.c
--- grass/trunk/lib/gis/asprintf.c 2010-02-06 02:42:44 UTC (rev 40838)
+++ grass/trunk/lib/gis/asprintf.c 2010-02-06 03:12:23 UTC (rev 40839)
@@ -6,39 +6,23 @@
* Eric G. Miller - Thu, 2 May 2002 17:51:54 -0700
- * I've got a sort of cheat for asprintf. We can't use vsnprintf for the
- * same reason we can't use snprintf ;-) Comments welcome.
+ * Rewritten by Glynn Clements, Sat, 6 Feb 2010
+ * Assumes that vsnprintf() is available
- * We cheat by printing to a tempfile via vfprintf() and then reading it
- * back in. Probably not the most efficient way.
- * <b>WARNING:</b> Temporarily, the G_asprintf macro cannot be used. See
- * explanation in gisdefs.h.
* (C) 2001-2008 by the GRASS Development Team
+ * (C) 2010 by Glynn Clements
* This program is free software under the GNU General Public License
* (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Eric Miller - egm2 at jps net
- * \date 2002-2008
#define _GNU_SOURCE /* enable asprintf */
#include <grass/config.h>
#include <stdio.h>
-#include <stdlib.h>
#include <stdarg.h>
-#include <unistd.h>
-#include <assert.h>
+#include <string.h>
#include <grass/gis.h>
-#ifdef __MINGW32__
-#include <windows.h>
-#endif /* __MINGW32__ */
#ifndef G_asprintf
@@ -54,64 +38,29 @@
* \return number of bytes written
-#ifdef HAVE_ASPRINTF
int G_vasprintf(char **out, const char *fmt, va_list ap)
+#ifdef HAVE_ASPRINTF
return vasprintf(out, fmt, ap);
#else
+ size_t size = strlen(fmt) + 50;
+ char *buf = G_malloc(size);
+ int count;
-int G_vasprintf(char **out, const char *fmt, va_list ap)
- int ret_status = EOF;
- char dir_name[2001];
- char file_name[2000];
- FILE *fp = NULL;
- char *work = NULL;
- assert(out != NULL && fmt != NULL);
- /* Warning: tmpfile() does not work well on Windows (MinGW)
- * if user does not have write access on the drive where
- * working dir is? */
-#ifdef __MINGW32__
- /* file_name = G_tempfile(); */
- GetTempPath(2000, dir_name);
- GetTempFileName(dir_name, "asprintf", 0, file_name);
- fp = fopen(file_name, "w+");
-#else
- fp = tmpfile();
- if (fp) {
- int count;
- count = vfprintf(fp, fmt, ap);
- if (count >= 0) {
- work = G_calloc(count + 1, sizeof(char));
- if (work != NULL) {
- rewind(fp);
- ret_status = fread(work, sizeof(char), count, fp);
- if (ret_status != count) {
- ret_status = EOF;
- G_free(work);
- work = NULL;
- fclose(fp);
-#ifdef __MINGW32__
- unlink(file_name);
+ for (;;) {
+ count = vsnprintf(buf, size, fmt, ap);
+ if (count >= 0 && count < size)
+ break;
+ size *= 2;
+ buf = G_realloc(buf, size);
- *out = work;
- return ret_status;
+ buf = G_realloc(buf, count + 1);
+ *out = buf;
+ return count;
#endif /* HAVE_ASPRINTF */
int G_asprintf(char **out, const char *fmt, ...)
Modified: grass/trunk/lib/gis/snprintf.c
--- grass/trunk/lib/gis/snprintf.c 2010-02-06 02:42:44 UTC (rev 40838)
+++ grass/trunk/lib/gis/snprintf.c 2010-02-06 03:12:23 UTC (rev 40839)
@@ -27,8 +27,6 @@
#include <assert.h>
-/* #ifdef HAVE_SNPRINTF */
* \brief snprintf() clone.
@@ -51,7 +49,9 @@
count = vsnprintf(str, size, fmt, ap);
va_end(ap);
+ /* Windows' vsnprintf() doesn't always NUL-terminate the buffer */
+ if (count == size)
+ str[--count] = '\0';
return count;
-/* #endif */
