[GRASS-SVN] r40840 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Sat Feb 6 01:14:27 EST 2010
Author: rashadkm
Date: 2010-02-06 01:14:26 -0500 (Sat, 06 Feb 2010)
New Revision: 40840
grass-addons/gui/wxpython/data_catalog/LayerTree.py
grass-addons/gui/wxpython/data_catalog/catalog.py
added send to ossimplanet for r.planet.py
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-02-06 03:12:23 UTC (rev 40839)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-02-06 06:14:26 UTC (rev 40840)
@@ -1,31 +1,11 @@
- at package layertree.py
- at brief Tree widget for listing maps raster, vector and DBF.
-Classes:
- - LayerTree
-(C) 2006-2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Michael Barton (Arizona State University)
- at author Jachym Cepicky (Mendel University of Agriculture)
- at author Martin Landa <landa.martin gmail.com>
- at author Mohammed Rashad K.M <rashadkm at gmail dot com> (modified for DataCatalog)
import os
import sys
import wx
import glob
import render
+from threading import Thread
#To run DataCatalog from any directory set this pathname for access to gui_modules
gbase = os.getenv("GISBASE")
pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
@@ -58,6 +38,7 @@
self.ID_REN= wx.NewId()
self.ID_COPY = wx.NewId()
self.ID_DEL = wx.NewId()
+ self.ID_OSSIM = wx.NewId()
acel = wx.AcceleratorTable([
(wx.ACCEL_CTRL, ord('R'), self.ID_REN ) ,
@@ -145,18 +126,19 @@
def OnTreePopUp(self,event):
- Display a popupMenu for copy,rename & delete operations
- item = event.GetItem()
- if not self.ItemHasChildren(item) and \
- self.GetItemFont(item) != self.itemFont:
+ Display a popupMenu for copy,rename & delete operations
+ item = event.GetItem()
+ if not self.ItemHasChildren(item) and \
+ self.GetItemFont(item) != self.itemFont:
- self.popupmenu = wx.Menu()
- mnuCopy = self.popupmenu.Append(self.ID_COPY,'&Copy\tCtrl+C')
- mnuRename = self.popupmenu.Append(self.ID_REN,'&Rename\tCtrl-R')
- mnuDel = self.popupmenu.Append(self.ID_DEL,'&Delete\tDEL')
- self.PopupMenu(self.popupmenu)
+ self.popupmenu = wx.Menu()
+ mnuCopy = self.popupmenu.Append(self.ID_COPY,'&Copy\tCtrl+C')
+ mnuRename = self.popupmenu.Append(self.ID_REN,'&Rename\tCtrl-R')
+ mnuDel = self.popupmenu.Append(self.ID_DEL,'&Delete\tDEL')
+ mnuOssim = self.popupmenu.Append(self.ID_OSSIM,'&send to OssimPlanet')
+ self.PopupMenu(self.popupmenu)
def OnCopy( self,event ):
@@ -259,9 +241,30 @@
elif ret == wx.ID_CANCEL:
dlg.Destroy()
return
+ def OnOssim( self,event ):
+ Performs grass command for deleting a map
+ item = self.GetSelection()
+ parent =self.GetItemParent(item)
+ if self.GetItemText(parent) == "Raster Map" :
+ cmdflag = 'r.planet.py -a map=' + str(self.GetItemText(item))
+ elif self.tree.GetItemText(parent) == "Vector Map" :
+ cmdflag = 'v.planet.py -a map=' + str(self.GetItemText(item))
+ if cmdflag:
+ #command = ["r.planet.py", cmdflag]
+ #gcmd.CommandThread(command,stdout=None,stderr=None).run()
+ current = OssimPlanet(cmdflag)
+ current.start()
def OnCloseWindow(self,event):
if self.gisrc['LOCATION_NAME'] != self.iLocation or \
@@ -312,6 +315,11 @@
panel.MapWindow2D.flag = True
panel.MapWindow2D.UpdateMap(render=True)
+class OssimPlanet(Thread):
+ def __init__ (self,cmd):
+ Thread.__init__(self)
+ self.cmd = cmd
+ def run(self):
+ os.system(self.cmd)
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py 2010-02-06 03:12:23 UTC (rev 40839)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py 2010-02-06 06:14:26 UTC (rev 40840)
@@ -28,6 +28,7 @@
import getopt
import platform
import shlex
+import gc
try:
import xml.etree.ElementTree as etree
@@ -107,6 +108,7 @@
def __init__(self, parent=None, id=wx.ID_ANY, title=_("Data Catalog"),
workspace=None,size=wx.DefaultSize,pos=wx.DefaultPosition):
+ gc.enable()
self.iconsize = (16, 16)
self.baseTitle = title
@@ -143,17 +145,6 @@
self.g_catalog=None
- self.ID_REN= wx.NewId()
- self.ID_COPY = wx.NewId()
- self.ID_DEL = wx.NewId()
- acel = wx.AcceleratorTable([
- (wx.ACCEL_CTRL, ord('R'), self.ID_REN ) ,
- (wx.ACCEL_CTRL, ord('C'), self.ID_COPY) ,
- (wx.ACCEL_NORMAL, wx.WXK_DELETE, self.ID_DEL) ])
- self.SetAcceleratorTable(acel)
self.menucmd = dict()
@@ -226,9 +217,11 @@
self.Map = self.GetMapDisplay()
def GetMapDisplay(self):
self.winlist = self.GetChildren()
for win in self.winlist:
@@ -1589,6 +1582,7 @@
self.notebook.DeleteAllPages()
self.Destroy()
def MsgNoLayerSelected(self):
"""!Show dialog message 'No layer selected'"""
@@ -1650,22 +1644,23 @@
def doBindings(self):
#Event bindings for combo boxes
- self.Bind(wx.EVT_COMBOBOX,self.OnMapsetChange,self.cmbMapset)
- self.Bind(wx.EVT_COMBOBOX,self.OnLocationChange,self.cmbLocation)
+ self.Bind(wx.EVT_COMBOBOX,self.OnMapsetChange,self.cmbMapset)
+ self.Bind(wx.EVT_COMBOBOX,self.OnLocationChange,self.cmbLocation)
- #Event bindings for tree -(display,popup,label edit.)
- self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.ltree.OnDisplay,self.ltree)
- self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK,self.ltree.OnTreePopUp,self.ltree)
- self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.ltree.OnEndRename,self.ltree)
- self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, self.ltree.OnBeginRename,self.ltree)
+ #Event bindings for tree -(display,popup,label edit.)
+ self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.ltree.OnDisplay,self.ltree)
+ self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK,self.ltree.OnTreePopUp,self.ltree)
+ self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.ltree.OnEndRename,self.ltree)
+ self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, self.ltree.OnBeginRename,self.ltree)
#Event bindings for tree menu
- self.Bind(wx.EVT_MENU,self.ltree.OnCopy,id=self.ltree.ID_COPY)
- self.Bind(wx.EVT_MENU,self.ltree.OnRename,id=self.ltree.ID_REN)
- self.Bind(wx.EVT_MENU,self.ltree.OnDelete,id=self.ltree.ID_DEL)
+ self.Bind(wx.EVT_MENU,self.ltree.OnCopy,id=self.ltree.ID_COPY)
+ self.Bind(wx.EVT_MENU,self.ltree.OnRename,id=self.ltree.ID_REN)
+ self.Bind(wx.EVT_MENU,self.ltree.OnDelete,id=self.ltree.ID_DEL)
+ self.Bind(wx.EVT_MENU,self.ltree.OnOssim,id=self.ltree.ID_OSSIM)
- self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
#Event bindings for v/r.info checkbox
#self.Bind(wx.EVT_CHECKBOX, self.OnToggleInfo,self.chkInfo)
