[GRASS-SVN] r40909 - grass/trunk/raster/r.out.gdal
svn_grass at osgeo.org
Wed Feb 10 08:59:05 EST 2010
Author: epatton
Date: 2010-02-10 08:59:05 -0500 (Wed, 10 Feb 2010)
New Revision: 40909
grass/trunk/raster/r.out.gdal/r.out.gdal.html
Updated manpage with description of -f flag, merge from devbr6 r40900
Modified: grass/trunk/raster/r.out.gdal/r.out.gdal.html
--- grass/trunk/raster/r.out.gdal/r.out.gdal.html 2010-02-10 13:53:57 UTC (rev 40908)
+++ grass/trunk/raster/r.out.gdal/r.out.gdal.html 2010-02-10 13:59:05 UTC (rev 40909)
@@ -105,6 +105,13 @@
only be supported for certain data types (depends on vendor and version).
<!-- e.g. data destined for ESRI software should use COMPRESS=LZW/PACKBITS/DEFLATE ??? -->
<p>
+If the export settings are set such that data loss would occur in the output
+file (i.e, due to the particular choice of data type and/or file type), the
+normal behaviour of <em>r.out.gdal</em> in this case would be to issue an error
+message describing the problem and exit without exporting. The <b>-f</b> flag
+allows raster export even if some of the data loss tests are not passed, and
+warnings are issued instead of errors.
+<p>
<em>r.out.gdal</em> exports may appear all black or gray on initial
display in other GIS software. This is not a bug of <em>r.out.gdal</em>,
but often caused by the default color table assigned by that software.
