[GRASS-SVN] r40910 - grass/trunk/lib/segment
svn_grass at osgeo.org
Wed Feb 10 09:26:41 EST 2010
Author: mmetz
Date: 2010-02-10 09:26:37 -0500 (Wed, 10 Feb 2010)
New Revision: 40910
grass/trunk/lib/segment/format.c
fix nonsense if statements
Modified: grass/trunk/lib/segment/format.c
--- grass/trunk/lib/segment/format.c 2010-02-10 13:59:05 UTC (rev 40909)
+++ grass/trunk/lib/segment/format.c 2010-02-10 14:26:37 UTC (rev 40910)
@@ -119,20 +119,7 @@
return -3;
- /* no LFS, file size within 2GB limit ? */
- if (sizeof(off_t) == 4) {
- double file_size;
- file_size = (double) nrows * ncols * len;
- if (file_size > INT_MAX) {
- G_warning("segment file size would be %.2fGB, but file size limit is 2GB", file_size / (1 << 30));
- G_warning("please recompile with LFS");
- G_fatal_error("can not create temporary segment file");
- if (lseek(fd, 0L, SEEK_SET) == (off_t) - 1) {
+ if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
G_warning("Segment_format: %s", strerror(errno));
return -1;
@@ -170,15 +157,12 @@
static int write_int(int fd, int n)
- int x;
- int bytes_wrote;
- x = n;
- if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
+ if (write(fd, &n, sizeof(int)) != sizeof(int)) {
G_warning("%s", strerror(errno));
+ return 0;
- return bytes_wrote;
+ return 1;
