[GRASS-SVN] r40939 - grass/branches/develbranch_6/raster/r.univar2
svn_grass at osgeo.org
Fri Feb 12 07:19:01 EST 2010
Author: hamish
Date: 2010-02-12 07:19:00 -0500 (Fri, 12 Feb 2010)
New Revision: 40939
grass/branches/develbranch_6/raster/r.univar2/globals.h
grass/branches/develbranch_6/raster/r.univar2/r.univar.html
grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c
grass/branches/develbranch_6/raster/r.univar2/r3.univar.html
grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c
grass/branches/develbranch_6/raster/r.univar2/stats.c
support for non-integer percentiles (trac #873)
Modified: grass/branches/develbranch_6/raster/r.univar2/globals.h
--- grass/branches/develbranch_6/raster/r.univar2/globals.h 2010-02-12 07:47:05 UTC (rev 40938)
+++ grass/branches/develbranch_6/raster/r.univar2/globals.h 2010-02-12 12:19:00 UTC (rev 40939)
@@ -30,7 +30,7 @@
double min;
double max;
unsigned int n_perc;
- int *perc;
+ double *perc;
double sum_abs;
int n;
int size;
Modified: grass/branches/develbranch_6/raster/r.univar2/r.univar.html
--- grass/branches/develbranch_6/raster/r.univar2/r.univar.html 2010-02-12 07:47:05 UTC (rev 40938)
+++ grass/branches/develbranch_6/raster/r.univar2/r.univar.html 2010-02-12 12:19:00 UTC (rev 40939)
@@ -19,6 +19,9 @@
extended statistics flag is used with a very large region setting. If the
region is too large the module should exit gracefully with a memory allocation
error. Basic statistics can be calculated using any size input region.
+<p>
+The <em>r.quantile</em> module will be significantly more efficient for
+calculating percentiles with large maps.
<h2>TODO</h2>
@@ -36,6 +39,7 @@
<a href="r.average.html">r.average</a><br>
<a href="r.median.html">r.median</a><br>
<a href="r.mode.html">r.mode</a><br>
+<a href="r.quantile.html">r.quantile</a><br>
<a href="r.sum.html">r.sum</a><br>
<a href="r.series.html">r.series</a><br>
<a href="r.stats.html">r.stats</a><br>
Modified: grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c
--- grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c 2010-02-12 07:47:05 UTC (rev 40938)
+++ grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c 2010-02-12 12:19:00 UTC (rev 40939)
@@ -31,7 +31,7 @@
param.percentile = G_define_option();
param.percentile->key = "percentile";
- param.percentile->type = TYPE_INTEGER;
+ param.percentile->type = TYPE_DOUBLE;
param.percentile->required = NO;
param.percentile->multiple = YES;
param.percentile->options = "0-100";
@@ -166,7 +166,7 @@
i++;
stats = create_univar_stat_struct(map_type, size, i);
for (i = 0; i < stats->n_perc; i++) {
- sscanf(param.percentile->answers[i], "%i", &stats->perc[i]);
+ sscanf(param.percentile->answers[i], "%lf", &stats->perc[i]);
Modified: grass/branches/develbranch_6/raster/r.univar2/r3.univar.html
--- grass/branches/develbranch_6/raster/r.univar2/r3.univar.html 2010-02-12 07:47:05 UTC (rev 40938)
+++ grass/branches/develbranch_6/raster/r.univar2/r3.univar.html 2010-02-12 12:19:00 UTC (rev 40939)
@@ -19,8 +19,12 @@
+<!-- no rast3D support?
+<p>
<h2>TODO</h2>
<i>mode, skewness, kurtosis</i>
@@ -36,6 +40,7 @@
Modified: grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c
--- grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c 2010-02-12 07:47:05 UTC (rev 40938)
+++ grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c 2010-02-12 12:19:00 UTC (rev 40939)
@@ -30,7 +30,7 @@
@@ -118,7 +118,7 @@
i++;
stats = create_univar_stat_struct(map_type, cols * rows * depths, i);
stats->n = 0;
Modified: grass/branches/develbranch_6/raster/r.univar2/stats.c
--- grass/branches/develbranch_6/raster/r.univar2/stats.c 2010-02-12 07:47:05 UTC (rev 40938)
+++ grass/branches/develbranch_6/raster/r.univar2/stats.c 2010-02-12 12:19:00 UTC (rev 40939)
@@ -28,7 +28,7 @@
stats->max = 0.0 / 0.0; /*set to nan as default */
stats->n_perc = n_perc;
if (n_perc > 0)
- stats->perc = (int *)G_malloc(n_perc * sizeof(int));
+ stats->perc = (double *)G_malloc(n_perc * sizeof(double));
else
stats->perc = NULL;
stats->sum_abs = 0.0;
@@ -204,8 +204,10 @@
fprintf(stdout, "median=%g\n", median);
fprintf(stdout, "third_quartile=%g\n", quartile_75);
- fprintf(stdout, "percentile_%d=%g\n", stats->perc[i],
- quartile_perc[i]);
+ char buf[24];
+ sprintf(buf, "%.15g", stats->perc[i]);
+ G_strchg(buf, '.', '_');
+ fprintf(stdout, "percentile_%s=%g\n", buf, quartile_perc[i]);
else {
@@ -219,18 +221,38 @@
- if (stats->perc[i] % 10 == 1 && stats->perc[i] != 11)
- fprintf(stdout, "%dst percentile: %g\n", stats->perc[i],
+ if (stats->perc[i] == (int)stats->perc[i]) {
+ /* percentile is an exact integer */
+ if ((int)stats->perc[i] % 10 == 1 && (int)stats->perc[i] != 11)
+ fprintf(stdout, "%dst percentile: %g\n", (int)stats->perc[i],
+ quartile_perc[i]);
+ else if ((int)stats->perc[i] % 10 == 2 && (int)stats->perc[i] != 12)
+ fprintf(stdout, "%dnd percentile: %g\n", (int)stats->perc[i],
+ else if ((int)stats->perc[i] % 10 == 3 && (int)stats->perc[i] != 13)
+ fprintf(stdout, "%drd percentile: %g\n", (int)stats->perc[i],
+ else
+ fprintf(stdout, "%dth percentile: %g\n", (int)stats->perc[i],
+ else {
+ /* percentile is not an exact integer */
+ char buf[24], suffix[3];
+ if (buf[strlen(buf)-1] == '1')
+ strcpy(suffix, "st");
+ else if (buf[strlen(buf)-1] == '2')
+ strcpy(suffix, "nd");
+ else if (buf[strlen(buf)-1] == '3')
+ strcpy(suffix, "rd");
+ else
+ strcpy(suffix, "th");
+ fprintf(stdout, "%.15g percentile: %g\n", stats->perc[i],
quartile_perc[i]);
- else if (stats->perc[i] % 10 == 2 && stats->perc[i] != 12)
- fprintf(stdout, "%dnd percentile: %g\n", stats->perc[i],
- else if (stats->perc[i] % 10 == 3 && stats->perc[i] != 13)
- fprintf(stdout, "%drd percentile: %g\n", stats->perc[i],
- else
- fprintf(stdout, "%dth percentile: %g\n", stats->perc[i],
G_free((void *)quartile_perc);
