[GRASS-SVN] r41068 - in grass/branches/develbranch_6:
lib/cairodriver lib/pngdriver visualization/ximgview
svn_grass at osgeo.org
Wed Feb 17 19:38:51 EST 2010
Author: hamish
Date: 2010-02-17 19:38:50 -0500 (Wed, 17 Feb 2010)
New Revision: 41068
grass/branches/develbranch_6/lib/cairodriver/cairodriver.h
grass/branches/develbranch_6/lib/cairodriver/write_bmp.c
grass/branches/develbranch_6/lib/pngdriver/pngdriver.h
grass/branches/develbranch_6/lib/pngdriver/write_bmp.c
grass/branches/develbranch_6/visualization/ximgview/main.c
Glynn: Use 64-byte header to ensure frame buffer alignment (merge from trunk r41029, trac #937)
Modified: grass/branches/develbranch_6/lib/cairodriver/cairodriver.h
--- grass/branches/develbranch_6/lib/cairodriver/cairodriver.h 2010-02-18 00:23:37 UTC (rev 41067)
+++ grass/branches/develbranch_6/lib/cairodriver/cairodriver.h 2010-02-18 00:38:50 UTC (rev 41068)
@@ -14,7 +14,7 @@
#define DEFAULT_FILE_NAME "map.png"
-#define HEADER_SIZE 54
+#define HEADER_SIZE 64
/* Scale for converting colors from [0..255] to cairo's [0.0..1.0] */
#define COLORSCALE (1.0/255.0)
Modified: grass/branches/develbranch_6/lib/cairodriver/write_bmp.c
--- grass/branches/develbranch_6/lib/cairodriver/write_bmp.c 2010-02-18 00:23:37 UTC (rev 41067)
+++ grass/branches/develbranch_6/lib/cairodriver/write_bmp.c 2010-02-18 00:38:50 UTC (rev 41068)
@@ -57,6 +57,7 @@
if (!output)
G_fatal_error("cairo: couldn't open output file %s", file_name);
+ memset(header, 0, sizeof(header));
make_bmp_header(header);
fwrite(header, sizeof(header), 1, output);
Modified: grass/branches/develbranch_6/lib/pngdriver/pngdriver.h
--- grass/branches/develbranch_6/lib/pngdriver/pngdriver.h 2010-02-18 00:23:37 UTC (rev 41067)
+++ grass/branches/develbranch_6/lib/pngdriver/pngdriver.h 2010-02-18 00:38:50 UTC (rev 41068)
@@ -8,7 +8,7 @@
#define FILE_NAME "map.png"
extern char *file_name;
extern int currentColor;
Modified: grass/branches/develbranch_6/lib/pngdriver/write_bmp.c
--- grass/branches/develbranch_6/lib/pngdriver/write_bmp.c 2010-02-18 00:23:37 UTC (rev 41067)
+++ grass/branches/develbranch_6/lib/pngdriver/write_bmp.c 2010-02-18 00:38:50 UTC (rev 41068)
@@ -59,6 +59,7 @@
if (!output)
G_fatal_error("PNG: couldn't open output file %s", file_name);
Modified: grass/branches/develbranch_6/visualization/ximgview/main.c
--- grass/branches/develbranch_6/visualization/ximgview/main.c 2010-02-18 00:23:37 UTC (rev 41067)
+++ grass/branches/develbranch_6/visualization/ximgview/main.c 2010-02-18 00:38:50 UTC (rev 41068)
@@ -30,7 +30,7 @@
#include <grass/gis.h>
#include <grass/glocale.h>
Display *dpy;
int scrn;
