[GRASS-SVN] r41069 - grass/trunk/vector/v.parallel
Wed Feb 17 20:02:34 EST 2010
Author: hamish
Date: 2010-02-17 20:02:33 -0500 (Wed, 17 Feb 2010)
New Revision: 41069
   grass/trunk/vector/v.parallel/Makefile
   grass/trunk/vector/v.parallel/main.c
   grass/trunk/vector/v.parallel/v.parallel.html
merge cleanups from devbr6 r41042)
Property changes on: grass/trunk/vector/v.parallel/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Modified: grass/trunk/vector/v.parallel/main.c
--- grass/trunk/vector/v.parallel/main.c	2010-02-18 00:38:50 UTC (rev 41068)
+++ grass/trunk/vector/v.parallel/main.c	2010-02-18 01:02:33 UTC (rev 41069)
@@ -76,7 +76,7 @@
     angle_opt->required = NO;
     angle_opt->answer = "0";
     angle_opt->multiple = NO;
-    angle_opt->description = _("Angle of major axis in degrees");
+    angle_opt->description = _("Angle of major axis in degrees"); /* CW or CCW? does this even work?? */
     side_opt = G_define_option();
     side_opt->key = "side";
Property changes on: grass/trunk/vector/v.parallel/main.c
   + text/x-csrc
Modified: grass/trunk/vector/v.parallel/v.parallel.html
--- grass/trunk/vector/v.parallel/v.parallel.html	2010-02-18 00:38:50 UTC (rev 41068)
+++ grass/trunk/vector/v.parallel/v.parallel.html	2010-02-18 01:02:33 UTC (rev 41069)
@@ -1,6 +1,6 @@
 <H2>DESCRIPTION</H2>
-<EM>v.parallel</EM> create parallel line to input vector lines which
+<EM>v.parallel</EM> creates parallel lines to the input vector lines which
 can be used as half-buffers.
 <H2>SEE ALSO</H2>
@@ -14,4 +14,5 @@
 Radim Blazek<br>
 Rewritten by Rosen Matev (with support through the Google Summer of Code program 2008)
-<p><i>Last changed: $Date: 2005-11-15 07:46:14 +0100 (Tue, 15 Nov 2005) $</i>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass/trunk/vector/v.parallel/v.parallel.html
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
