[GRASS-SVN] r41181 - grass/trunk/scripts/d.vect.thematic
svn_grass at osgeo.org
Wed Feb 24 09:24:47 EST 2010
Author: glynn
Date: 2010-02-24 09:24:45 -0500 (Wed, 24 Feb 2010)
New Revision: 41181
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
Fix various bugs:
add missing "icon" parameter
type conversions
grass. prefix
various typos
missing newlines
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2010-02-24 13:17:29 UTC (rev 41180)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2010-02-24 14:24:45 UTC (rev 41181)
@@ -276,6 +276,7 @@
themetype = options['themetype']
type = options['type']
where = options['where']
+ icon = options['icon']
flag_f = flags['f']
flag_g = flags['g']
@@ -284,6 +285,11 @@
flag_s = flags['s']
flag_u = flags['u']
+ layer = int(layer)
+ nint = int(nint)
+ size = float(size)
+ maxsize = float(maxsize)
# check column type
inf = grass.vector_columns(map, layer)
if column not in inf:
@@ -319,7 +325,7 @@
os.environ['GRASS_PNG_READ'] = 'TRUE'
os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
- db = vector_db(map)[1]
+ db = grass.vector_db(map)[1]
if not db or not db['table']:
grass.fatal(_("No table connected or layer <%s> does not exist.") % layer)
table = db['table']
@@ -395,7 +401,7 @@
else:
grass.fatal(_("Unknown themecalc type <%s>") % themecalc)
- pointstep = float(maxsize - ptsize) / (numint - 1)
+ pointstep = (maxsize - ptsize) / (numint - 1)
# Prepare legend cuts for too large numint
if numint > max_leg_items:
@@ -419,11 +425,11 @@
f_gisleg = file(tmp_gisleg, 'w')
out(f_gisleg, locals(), """\
-title - - - {Thematic map legend for column $colum of map $map}
+title - - - {Thematic map legend for column $column of map $map}
f_psleg = file(tmp_psleg, 'w')
- out(f.psleg, locals(), """\
+ out(f_psleg, locals(), """\
text 1% 95% Thematic map legend for column $column of map $map
ref bottom left
end
@@ -460,8 +466,8 @@
else:
grass.fatal(_("This should not happen: parser error. Unknown color scheme %s") % colorscheme)
- color = startc.split(":")
- endcolor = endc.split(":")
+ color = __builtins__.map(int, startc.split(":"))
+ endcolor = __builtins__.map(int, endc.split(":"))
#The number of color steps is one less then the number of classes
nclrstep = numint - 1
@@ -480,7 +486,7 @@
subtitle - - - {Mapped by $numint intervals of $step}
text 4% 87% Mapped by $numint intervals of $step
ref bottom left
end
@@ -583,7 +589,7 @@
else:
mincomparison = ">"
- themecolor = ":".join(color)
+ themecolor = ":".join(__builtins__.map(str,color))
if flag_f:
linecolor = "none"
else:
@@ -678,7 +684,7 @@
f_gisleg.write("text - - - {...}\n")
- sys.stdout.write(subs(locals(), "$themecolor\t\t$openbracket$rangemin - $rangemax$closebracket $extranote"))
+ sys.stdout.write(subs(locals(), "$themecolor\t\t$openbracket$rangemin - $rangemax$closebracket $extranote\n"))
if not where:
sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax")
else:
@@ -692,7 +698,7 @@
# Create group for GIS Manager
if flag_g:
# change rgb colors to hex
- xthemecolor = "#%02X%02X%02X" % tuple(themecolor.split(":"))
+ xthemecolor = "#%02X%02X%02X" % tuple(__builtins__.map(int, themecolor.split(":")))
#xlinecolor=`echo $linecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
if "$linecolor" == "black":
@@ -886,8 +892,8 @@
- sys.stdout.write("Size/width\tValue")
- sys.stdout.write("==========\t=====")
+ sys.stdout.write("Size/width\tValue\n")
+ sys.stdout.write("==========\t=====\n")
themecolor = pointcolor
@@ -994,7 +1000,7 @@
end
- sys.stdout.write(subs(locals(), "$ptsize\t\t$openbracket$rangemin - $rangemax$closebracket $extranote"))
+ sys.stdout.write(subs(locals(), "$ptsize\t\t$openbracket$rangemin - $rangemax$closebracket $extranote\n"))
if not where:
@@ -1009,7 +1015,7 @@
if flag_g:
+ xthemecolor = "#%02X%02X%02X" % tuple(__builtins__.map(int,themecolor.split(":")))
xlinecolor = "#000000"
# create group entry
