[GRASS-SVN] r40258 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Tue Jan 5 10:42:23 EST 2010
Author: hamish
Date: 2010-01-05 10:42:23 -0500 (Tue, 05 Jan 2010)
New Revision: 40258
grass/trunk/ps/ps.map/ps.map.html
document header file instruction (merge from devbr6)
Modified: grass/trunk/ps/ps.map/ps.map.html
--- grass/trunk/ps/ps.map/ps.map.html 2010-01-05 15:41:37 UTC (rev 40257)
+++ grass/trunk/ps/ps.map/ps.map.html 2010-01-05 15:42:23 UTC (rev 40258)
@@ -558,7 +558,39 @@
and the location's description.<!-- PERMANENT/MYNAME -->
The text will be centered on the page above the map.
The default text color is black.
+<P>
+If the <EM>file</EM> sub-instruction is given the header will consist
+of the text in the text file specified, with some special formatting keys:
+<ul>
+<li><tt>%%</tt> - a literal %
+<li><tt>%n</tt> - ? newline ?
+<li><tt>%_</tt> - horizontal bar
+<li><tt>%c</tt> - "<raster name> in mapset <mapset name>"
+<li><tt>%d</tt> - today's date
+<li><tt>%l</tt> - location name
+<li><tt>%L</tt> - Location's text description
+<li><tt>%m</tt> - mapset name
+<li><tt>%u</tt> - user name
+<li><tt>%x</tt> - mask info
+<li><tt>%-</tt> - advance to this character column number (see example below)
+</ul>
+Example header file:
+<div class="code"><pre>
+%_
+LOCATION: %-27l DATE: %d
+MAPSET: %-27m USER: %u
+RASTER MAP: %c
+MASK: %x
+%_
+Produced by: US Army CERL, Champaign Illinois
+Software: GRASS
+%_
+</pre></div>
<P>
This example prints (in red) whatever is in the file <EM>soils.hdr</EM> above
