[GRASS-SVN] r40259 - grass/branches/develbranch_6/vector/v.digit
Tue Jan 5 11:30:17 EST 2010
Author: glynn
Date: 2010-01-05 11:30:15 -0500 (Tue, 05 Jan 2010)
New Revision: 40259
Added:
   grass/branches/develbranch_6/vector/v.digit/generate.c
   grass/branches/develbranch_6/vector/v.digit/Makefile
Revert 38954, sync generate.c
Modified: grass/branches/develbranch_6/vector/v.digit/Makefile
--- grass/branches/develbranch_6/vector/v.digit/Makefile	2010-01-05 15:42:23 UTC (rev 40258)
+++ grass/branches/develbranch_6/vector/v.digit/Makefile	2010-01-05 16:30:15 UTC (rev 40259)
@@ -2,8 +2,8 @@
 PGM = v.digit
-LIBES = $(FORMLIB) $(DISPLAYLIB) $(RASTERLIB) $(VECTLIB) $(GISLIB) $(TCLTKLIBPATH) $(TCLTKLIBS)
-DEPENDENCIES= $(FORMDEP) $(DISPLAYDEP) $(RASTERDEP) $(VECTDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(RASTERLIB) $(VECTLIB) $(GISLIB) $(TCLTKLIBPATH) $(TCLTKLIBS)
+DEPENDENCIES= $(DISPLAYDEP) $(RASTERDEP) $(VECTDEP) $(GISDEP)
 EXTRA_CFLAGS = $(XCFLAGS) $(TCLINCDIR) $(TKINCDIR) $(VECT_CFLAGS)
 XTRA_LDFLAGS=$(DFLAGS)
Copied: grass/branches/develbranch_6/vector/v.digit/generate.c (from rev 40258, grass/branches/develbranch_6/lib/form/generate.c)
--- grass/branches/develbranch_6/vector/v.digit/generate.c	                        (rev 0)
+++ grass/branches/develbranch_6/vector/v.digit/generate.c	2010-01-05 16:30:15 UTC (rev 40259)
@@ -0,0 +1,277 @@
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/form.h>
+/* Escape string for use in TCL */
+char *escape_tcl_string(char *input)
+    char *escaped;
+    escaped = G_str_replace(input, "\\", "\\\\");
+    escaped = G_str_replace(escaped, "[", "\\[");
+    escaped = G_str_replace(escaped, "]", "\\]");
+    escaped = G_str_replace(escaped, "$", "\\$");
+    return escaped;
+/* Generate form in HTML/TXT format.
+ *  Pointer to resulting string is stored to 'form'. This string must be freed by application.
+ *  returns: -1 error
+ *            0 success
+int
+F_generate(char *drvname, char *dbname, char *tblname, char *key, int keyval,
+	   char *frmname, char *frmmapset,
+	   int edit_mode, int format, char **form)
+    int col, ncols, ctype, sqltype, more;
+    char buf[5000], buf1[100];
+    const char *colname;
+    dbString sql, html, str;
+    dbDriver *driver;
+    dbHandle handle;
+    dbCursor cursor;
+    dbTable *table;
+    dbColumn *column;
+    dbValue *value;
+    int i = 0;
+    /* see /usr/lib/tcl8.4/encoding/ */
+    static char *encoding_list[] = {
+	"utf-8",
+	"ascii",
+	"iso8859-1",
+	"iso8859-2",
+	"iso8859-15",
+	"iso2022-jp",
+	"koi8-r",
+	"euc-jp",
+	NULL
+    char *enc_env;
+    G__read_env();
+    enc_env = G__getenv("GRASS_DB_ENCODING");
+    /* TODO: support 'format' (txt, html), currently html only */
+    G_debug(2,
+	    "F_generate(): drvname = '%s', dbname = '%s'\n      tblname = '%s', key = '%s', keyval = %d\n"
+	    "    form = '%s', form_mapset = '%s'\n      edit_mode = %d",
+	    drvname, dbname, tblname, key, keyval, frmname, frmmapset,
+	    edit_mode);
+    db_init_string(&sql);
+    db_init_string(&html);	/* here is the result stored */
+    db_init_string(&str);
+    G_debug(2, "Open driver");
+    driver = db_start_driver(drvname);
+    if (driver == NULL) {
+	G_warning("Cannot open driver");
+	sprintf(buf, "Cannot open driver '%s'<BR>",
+		escape_tcl_string(drvname));
+	*form = G_store(buf);
+	return -1;
+    G_debug(2, "Driver opened");
+    db_init_handle(&handle);
+    db_set_handle(&handle, dbname, NULL);
+    G_debug(2, "Open database");
+    if (db_open_database(driver, &handle) != DB_OK) {
+	G_warning("Cannot open database");
+	db_shutdown_driver(driver);
+	sprintf(buf, "Cannot open database '%s' by driver '%s'<BR>",
+		escape_tcl_string(dbname), escape_tcl_string(drvname));
+	return -1;
+    G_debug(2, "Database opened");
+    /* TODO: test if table exist first, but this should be tested by application befor
+     *        F_generate() is called, because it may be correct (connection defined in DB
+     *        but table does not exist) */
+    sprintf(buf, "select * from %s where %s = %d", tblname, key, keyval);
+    G_debug(2, "%s", buf);
+    db_set_string(&sql, buf);
+    if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK) {
+	G_warning("Cannot open select cursor");
+	db_close_database(driver);
+	sprintf(buf,
+		"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>",
+		escape_tcl_string(db_get_string(&sql)),
+	return -1;
+    G_debug(2, "Select Cursor opened");
+    table = db_get_cursor_table(&cursor);
+    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+	G_warning("Cannot fetch next record");
+	db_close_cursor(&cursor);
+	*form = G_store("Cannot fetch next record");
+	return -1;
+    if (!more) {
+	G_warning("No database record");
+	if (format == F_HTML) {
+	    *form = G_store("No record selected.<BR>");
+	else {
+	    *form = G_store("No record selected.");
+    else {
+	ncols = db_get_table_number_of_columns(table);
+	/* Start form */
+	    if (edit_mode == F_EDIT) {
+		db_append_string(&html, "<FORM>");
+		sprintf(buf, "<INPUT type=hidden name=%s value=\"%s\">",
+			escape_tcl_string(F_DRIVER_FNAME),
+		db_append_string(&html, buf);
+		/* Note: because html_library.tcl failes to parse
+		 *  <INPUT name=abc value='dbname=xxx'> and returnes
+		 *  name="xxx" value="dbname=xxx" order of value and name parameters is changed */
+		sprintf(buf, "<INPUT type=hidden value=\"%s\" name=%s>",
+			escape_tcl_string(F_DATABASE_FNAME));
+			escape_tcl_string(F_TABLE_FNAME),
+			escape_tcl_string(tblname));
+			escape_tcl_string(F_KEY_FNAME),
+			escape_tcl_string(key));
+	    for (col = 0; col < ncols; col++) {
+		column = db_get_table_column(table, col);
+		sqltype = db_get_column_sqltype(column);
+		ctype = db_sqltype_to_Ctype(sqltype);
+		value = db_get_column_value(column);
+		db_convert_value_to_string(value, sqltype, &str);
+		colname = db_get_column_name(column);
+		G_debug(2, "%s: %s", colname, db_get_string(&str));
+		if (edit_mode == F_VIEW) {
+		    sprintf(buf, "<B>%s : </B> %s <BR>",
+			    escape_tcl_string(G_strdup(colname)),
+			    escape_tcl_string(db_get_string(&str)));
+		else {
+		    sprintf(buf, "<B>%s : </B>",
+			    escape_tcl_string(G_strdup(colname)));
+		    if (G_strcasecmp(colname, key) == 0) {
+			sprintf(buf,
+				"%s<BR> <INPUT type=hidden name=%s value=\"%s\">",
+				escape_tcl_string(db_get_string(&str)),
+		    else {
+			switch (ctype) {
+			case DB_C_TYPE_INT:
+			    sprintf(buf1, "20");
+			    break;
+			case DB_C_TYPE_DOUBLE:
+			    sprintf(buf1, "30");
+			    break;
+			case DB_C_TYPE_STRING:
+			    sprintf(buf1, "%d", db_get_column_length(column));
+			    break;
+			case DB_C_TYPE_DATETIME:
+			    break;
+			sprintf(buf,
+				"<INPUT type=text size=%s name=%s value=\"%s\"><BR>",
+				escape_tcl_string(buf1),
+		sprintf(buf,
+			"<HR>   Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>",
+			F_ENCODING);
+		i = 0;
+		while (encoding_list[i] != NULL) {
+		    if (G_strcasecmp(encoding_list[i], enc_env) == 0)
+			sprintf(buf, "<OPTION VALUE=\"%s\" SELECTED>%s",
+				encoding_list[i], encoding_list[i]);
+		    else
+			sprintf(buf, "<OPTION VALUE=\"%s\">%s",
+		    ++i;
+		sprintf(buf, "</SELECT>");
+	    /* Close form */
+		db_append_string(&html, "</FORM>");
+	else {			/* F_TXT */
+		sprintf(buf, "%s : %s\n", colname, db_get_string(&str));
+    G_debug(2, "FORM STRING:\n%s\n", db_get_string(&html));
+    *form = G_store(db_get_string(&html));
+    db_free_string(&sql);
+    db_free_string(&html);
+    db_free_string(&str);
+    return 0;
