[GRASS-SVN] r40309 -
grass/branches/releasebranch_6_4/scripts/v.db.addtable
svn_grass at osgeo.org
Fri Jan 8 00:22:32 EST 2010
Author: hamish
Date: 2010-01-08 00:22:32 -0500 (Fri, 08 Jan 2010)
New Revision: 40309
grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
don't use v.db.connect as it expands in db name (#809, merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
--- grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2010-01-08 05:19:53 UTC (rev 40308)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2010-01-08 05:22:32 UTC (rev 40309)
@@ -125,13 +125,16 @@
driver=`db.connect -p | grep '^driver' | cut -d':' -f2`
else
# there is a definition for layer 1, so we check for the user defined layer
- database=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$QUERYLAYER" | awk -F ";" '{print $4}'`
+ # v.db.connect expands $VARIABLES, we want to keep them relative so use the raw file
+ eval `g.findfile elem="vector/$GIS_OPT_MAP" file=dbln`
+ database=`grep -w "^$QUERYLAYER" "$file" | cut -f4- -d' ' | sed -e 's/ [^ ]*$//'`
if [ -z "$database" ] ; then
#nothing on user defined layer, so we use the default mapset settings in this case:
database=`db.connect -p | grep '^database' | cut -d':' -f2-`
else
- driver=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$QUERYLAYER" | awk -F ";" '{print $5}'`
+ driver=`grep -w "^$QUERYLAYER" "$file" | sed -e 's/^.* \(.*\)$/\1/'`
fi
fi
@@ -182,7 +185,8 @@
# finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
# (creates new row for each vector line):
-v.to.db "$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" option=cat col=cat qlayer="$GIS_OPT_LAYER"
+v.to.db "$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" option=cat \
+ col=cat qlayer="$GIS_OPT_LAYER"
if [ -z "$GRASS_VERBOSE" ] || [ "$GRASS_VERBOSE" -gt 0 ] ; then
g.message "Current attribute table links:"
