[GRASS-SVN] r40310 - in grass/branches/develbranch_6/scripts: d.vect.thematic v.db.addcol v.db.addtable v.db.dropcol v.db.droptable v.db.renamecol v.db.update v.dissolve v.rast.stats v.report
Fri Jan 8 00:44:03 EST 2010
Author: hamish
Date: 2010-01-08 00:44:02 -0500 (Fri, 08 Jan 2010)
New Revision: 40310
   grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
   grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
   grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
   grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
   grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable
   grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
   grass/branches/develbranch_6/scripts/v.db.update/v.db.update
   grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve
   grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
   grass/branches/develbranch_6/scripts/v.report/v.report
stricter grep search
Modified: grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
--- grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic	2010-01-08 05:44:02 UTC (rev 40310)
@@ -361,9 +361,9 @@
     export GRASS_PNG_AUTO_WRITE
 fi
-table=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
-database=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $4}'`
-driver=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $5}'`
+table=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+database=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $4}'`
+driver=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $5}'`
 if [ -z "$table" ]
     then
Modified: grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
--- grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol	2010-01-08 05:44:02 UTC (rev 40310)
@@ -84,14 +84,14 @@
    exit 1
 fi
-table=`v.db.connect "$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+table=`v.db.connect "$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
 if [ -z "$table" ] ; then
    g.message -e 'There is no table connected to this map! Run v.db.connect or v.db.addtable first.'
    exit 1
 fi
-database=`v.db.connect "$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $4}'`
-driver=`v.db.connect "$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $5}'`
+database=`v.db.connect "$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $4}'`
+driver=`v.db.connect "$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $5}'`
 colnum=`echo "$GIS_OPT_COLUMNS" | awk -F, '{print NF}'`
Modified: grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
--- grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable	2010-01-08 05:44:02 UTC (rev 40310)
@@ -140,7 +140,7 @@
 #maybe there is already a table linked to the selected layer?
 if [ "$GIS_OPT_LAYER" -eq 1 ] ; then
-  v.db.connect "$GIS_OPT_MAP" -g 2> /dev/null | grep -w "$GIS_OPT_LAYER" > /dev/null
+  v.db.connect "$GIS_OPT_MAP" -g 2> /dev/null | grep -w "^$GIS_OPT_LAYER" > /dev/null
   if [ $? -eq 0 ] ; then
      g.message -e "There is already a table linked to layer <$GIS_OPT_LAYER>"
      exit 1
Modified: grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
--- grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol	2010-01-08 05:44:02 UTC (rev 40310)
@@ -97,15 +97,15 @@
    exit 1
 fi
-table=`v.db.connect map=$GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | cut -f2 -d";"`
+table=`v.db.connect map=$GIS_OPT_MAP -g fs=";" | grep -w "^$GIS_OPT_LAYER" | cut -f2 -d";"`
    g.message -e 'There is no table connected to the input vector map! Cannot delete any column'
    cleanup
    exit 1
 fi
-keycol=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f3 -d';'`
-database=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f4 -d';'`
-driver=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f5 -d';'`
+keycol=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w "^$GIS_OPT_LAYER" | cut -f3 -d';'`
+database=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w "^$GIS_OPT_LAYER" | cut -f4 -d';'`
+driver=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w "^$GIS_OPT_LAYER" | cut -f5 -d';'`
 col="$GIS_OPT_COLUMN"
 if [ "$col" = "$keycol" ] ; then
Modified: grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable
--- grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable	2010-01-08 05:44:02 UTC (rev 40310)
@@ -78,7 +78,7 @@
        g.message -e "An error occured while running v.db.connect"
        exit 1
     fi
-    table=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+    table=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
        g.message -e "No table assigned to layer <$GIS_OPT_LAYER>"
        exit 1
@@ -86,7 +86,7 @@
     # Removing table name connected to selected layer
 else
     # Removing user specified table
-    existingtable=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+    existingtable=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
     table="$GIS_OPT_TABLE"
     if [ "$existingtable" != "$table" ] ; then
        g.message -e "User selected table <$table> but the table <$existingtable> is linked to layer <$GIS_OPT_LAYER>"
@@ -100,8 +100,8 @@
    exit 1
 fi
-database=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $4}'`
-driver=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $5}'`
+database=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $4}'`
+driver=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $5}'`
 g.message "Removing table <$table> linked to layer <$GIS_OPT_LAYER> of vector map <$GIS_OPT_MAP>"
Modified: grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol	2010-01-08 05:44:02 UTC (rev 40310)
@@ -102,16 +102,16 @@
    exit 1
 fi
-table="`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "$GIS_OPT_LAYER" | cut -f2 -d';'`"
+table="`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "^$GIS_OPT_LAYER" | cut -f2 -d';'`"
    g.message -e 'There is no table connected to the input vector map! Cannot rename any column'
    cleanup
    exit 1
 fi
-keycol=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w $GIS_OPT_LAYER | cut -f3 -d';'`
-database="`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w $GIS_OPT_LAYER | cut -f4 -d';'`"
-driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w $GIS_OPT_LAYER | cut -f5 -d';'`
+keycol=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "^$GIS_OPT_LAYER" | cut -f3 -d';'`
+database="`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w ^$GIS_OPT_LAYER | cut -f4 -d';'`"
+driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "^$GIS_OPT_LAYER" | cut -f5 -d';'`
 oldcol="`echo $GIS_OPT_COLUMN | cut -d',' -f1`"
 newcol="`echo $GIS_OPT_COLUMN | cut -d',' -f2`"
Modified: grass/branches/develbranch_6/scripts/v.db.update/v.db.update
--- grass/branches/develbranch_6/scripts/v.db.update/v.db.update	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.db.update/v.db.update	2010-01-08 05:44:02 UTC (rev 40310)
@@ -99,14 +99,14 @@
    exit 1
 fi
-table=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+table=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
    exit 1
 fi
 # checking column types
 coltype=`v.info -c map="$GIS_OPT_MAP" layer=$GIS_OPT_LAYER --quiet | grep -w "$GIS_OPT_COLUMN" | cut -d'|' -f1`
Modified: grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve
--- grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve	2010-01-08 05:44:02 UTC (rev 40310)
@@ -102,7 +102,7 @@
        exit 1
     fi
-   table=`v.db.connect $GIS_OPT_INPUT -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
+   table=`v.db.connect $GIS_OPT_INPUT -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
       g.message -e "Database connection not defined for layer $GIS_OPT_LAYER"
       exit 1
Modified: grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
--- grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats	2010-01-08 05:44:02 UTC (rev 40310)
@@ -197,7 +197,7 @@
 #check if DBF driver used, in this case cut to 10 chars col names:
 DBFDRIVER=0
-v.db.connect -g "$VECTOR" fs=";" | grep -w "$GIS_OPT_LAYER" | \
+v.db.connect -g "$VECTOR" fs=";" | grep -w "^$GIS_OPT_LAYER" | \
    cut -d';' -f5 | grep -i dbf --quiet
    DBFDRIVER=1
@@ -222,7 +222,7 @@
 DB_DATABASE="`v.db.connect -g "$VECTOR" fs=";" | cut -d';' -f4`"
 #Find out which table is linked to the vector map on the given layer
-TABLE=`v.db.connect map="$VECTOR" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+TABLE=`v.db.connect map="$VECTOR" -g fs=";" | grep -w "^$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
 if [ -z "$TABLE" ] ; then
    exit 1
Modified: grass/branches/develbranch_6/scripts/v.report/v.report
--- grass/branches/develbranch_6/scripts/v.report/v.report	2010-01-08 05:22:32 UTC (rev 40309)
+++ grass/branches/develbranch_6/scripts/v.report/v.report	2010-01-08 05:44:02 UTC (rev 40310)
@@ -94,9 +94,9 @@
 TMP3="`g.tempfile pid=$$`"
 TMP4="`g.tempfile pid=$$`"
-MAP=$GIS_OPT_MAP
-OPTION=$GIS_OPT_OPTION
-LAYER=$GIS_OPT_LAYER
+MAP="$GIS_OPT_MAP"
+OPTION="$GIS_OPT_OPTION"
+LAYER="$GIS_OPT_LAYER"
 # does the input vector map exist?
 eval `g.findfile element=vector file=$GIS_OPT_MAP`
@@ -143,7 +143,7 @@
 if [ $TABLEEXISTS -eq 1 ] ; then
    v.db.select -c map="$MAP" layer="$LAYER" | sort -n -t'|' -k 1 | grep -v '^0' > "$TMP1"
    if [ `wc -l "$TMP1" | awk '{print $1}'` -eq 0 ] ; then
-      KEY=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "$LAYER" | cut -f3 -d';'`
+      KEY=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "^$LAYER" | cut -f3 -d';'`
       g.message -e "There is a table connected to input vector map '$MAP', but\
       there are no categories present in the key column '$KEY'. Consider using\
       v.to.db to correct this."
