[GRASS-SVN] r40343 - grass/trunk/lib/db/dbmi_base
Sat Jan 9 04:45:28 EST 2010
Author: hamish
Date: 2010-01-09 04:45:28 -0500 (Sat, 09 Jan 2010)
New Revision: 40343
   grass/trunk/lib/db/dbmi_base/login.c
use "|" as the field sep so spaces in the database path and pswd do not cause trouble
Modified: grass/trunk/lib/db/dbmi_base/login.c
--- grass/trunk/lib/db/dbmi_base/login.c	2010-01-09 09:14:21 UTC (rev 40342)
+++ grass/trunk/lib/db/dbmi_base/login.c	2010-01-09 09:45:28 UTC (rev 40343)
@@ -73,7 +73,7 @@
-   Read file if exists
+   Read the DB login file if it exists
    return: -1 error (cannot read file)
    number of items (0 also if file does not exist)
@@ -88,7 +88,7 @@
     login->n = 0;
     file = login_filename();
-    G_debug(3, "file = <%s>", file);
+    G_debug(3, "DB login file = <%s>", file);
     if (stat(file, &info) != 0) {
 	G_debug(3, "login file does not exist");
@@ -103,10 +103,10 @@
 	G_chop(buf);
 	usr[0] = pwd[0] = '\0';
-	/* FIXME: not safe for spaces in DB path name */
-	ret = sscanf(buf, "%[^ ] %[^ ] %[^ ] %[^ ]", dr, db, usr, pwd);
+	/* is last scan ok? the newline is already stripped by G_getl2() */
+	ret = sscanf(buf, "%[^|]|%[^|]|%[^|]|%[^\n]", dr, db, usr, pwd);
-	G_debug(3, "ret = %d : dr=[%s] db=[%s] us=[%s] pw=[%s]",
+	G_debug(3, "ret = %d : drv=[%s] db=[%s] usr=[%s] pwd=[%s]",
 		ret, dr, db, usr, pwd);
 	if (ret < 2) {
@@ -123,7 +123,7 @@
-   Write file
+   Write the DB login file
    0 OK
@@ -135,7 +135,7 @@
-    G_debug(3, "file = %s", file);
     fd = fopen(file, "w");
     if (fd == NULL)
@@ -146,12 +146,12 @@
     chmod(file, S_IRUSR | S_IWUSR);
     for (i = 0; i < login->n; i++) {
-	fprintf(fd, "%s %s", login->data[i].driver, login->data[i].database);
+	fprintf(fd, "%s|%s", login->data[i].driver, login->data[i].database);
 	if (login->data[i].user) {
-	    fprintf(fd, " %s", login->data[i].user);
+	    fprintf(fd, "|%s", login->data[i].user);
 	    if (login->data[i].password)
-		fprintf(fd, " %s", login->data[i].password);
+		fprintf(fd, "|%s", login->data[i].password);
 	fprintf(fd, "\n");
@@ -178,8 +178,8 @@
     int i, found;
     LOGIN login;
-    G_debug(3, "db_set_login(): %s %s %s %s", driver, database, user,
-	    password);
+    G_debug(3, "db_set_login(): drv=[%s] db=[%s] usr=[%s] pwd=[%s]",
+	    driver, database, user, password);
     init_login(&login);
