[GRASS-SVN] r40344 - grass-addons/vector/v.in.lines
Sat Jan 9 07:30:49 EST 2010
Author: hamish
Date: 2010-01-09 07:30:44 -0500 (Sat, 09 Jan 2010)
New Revision: 40344
Added:
   grass-addons/vector/v.in.lines/v.in.lines.py
port shell script to python (work in progress)
Copied: grass-addons/vector/v.in.lines/v.in.lines.py (from rev 40343, grass-addons/vector/v.in.lines/v.in.lines)
--- grass-addons/vector/v.in.lines/v.in.lines.py	                        (rev 0)
+++ grass-addons/vector/v.in.lines/v.in.lines.py	2010-01-09 12:30:44 UTC (rev 40344)
@@ -0,0 +1,149 @@
+#!/usr/bin/env python
+# MODULE:       v.in.lines
+# AUTHOR(S):    Hamish Bowman
+# PURPOSE:      Import point data as lines ('v.in.mapgen -f' wrapper script)
+# COPYRIGHT:    (c) 2009-2010 The GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% description: Import ASCII x,y[,z] coordinates as a series of lines.
+#% keywords: vector, import
+#%End
+#%flag
+#% key: z
+#% description: Create a 3D line from 3 column data
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old_file,file,input
+#% description: Name of input file (or "-" to read from stdin)
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: Name for output vector map
+#% required : yes
+#%end
+#%option
+#% key: fs
+#% type: string
+#% key_desc: character
+#% description: Field separator
+#% answer: |
+#% required: no
+#%end
+import sys
+import os
+import atexit
+import string
+from grass.script import core as grass
+def cleanup():
+    grass.try_remove(tmp)
+def main():
+    global tmp
+    infile_opt = options['input']
+    output = options['output']
+    fsep = options['fs']
+    threeD = flags['z']
+    prog = 'v.in.lines'
+    opts = ""
+    if threeD:
+        do3D = 'z'
+    else:
+        do3D = ''
+    #### parse field separator
+    if fs in ('space', 'tab'):
+        fs = ' '
+    elif fs == 'comma':
+        fs = ','
+    else:
+        if len(fs) > 1:
+            grass.warning(_("Invalid field separator, using '%s'") % fs[0])
+        try:
+            fs = fs[0]
+        except IndexError:
+            grass.fatal(_("Invalid field separator '%s'") % fs)
+    #### set up input file
+    if infile_opt == '-':
+        infile = None
+        inf = sys.stdin
+    else:
+        infile = infile_opt
+        if not os.path.exists(infile):
+            grass.fatal(_("Unable to read input data"))
+        grass.debug("input file=[%s]" % infile)
+    tmp = grass.tempfile()
+    if not infile:
+        # read from stdin and write to tmpfile (v.in.mapgen wants a real file)
+        outf = file(tmp, 'w')
+        for line in inf:
+            if len(line) == 0 or line[0] == '#':
+	        continue
+            outf.write(line.replace(fs, ' '))
+        outf.close()
+        runfile = tmp
+    else:
+        # read from a real file
+        if fs == ' ':
+            runfile = infile
+        else:
+	    inf = file(infile)
+            for line in inf:
+	            continue
+            outf.close()
+            runfile = tmp
+    if infile:
+        inf.close()
+    ##### check that there are at least two columns (three if -z is given)
+    line = inf.readline()
+    numcols = len(line.split(' '))
+    if (do3D and numcols < 3) or (not do3D and numcols < 2):
+        g.message -e "Not enough data columns. (incorrect fs setting?)"
+    inf.close()
+    grass.run_command('v.in.mapgen', flags = 'f' + do3D,
+                      input = runfile, output = output)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
