[GRASS-SVN] r40345 - grass-addons/vector/v.in.lines
svn_grass at osgeo.org
Sat Jan 9 07:38:42 EST 2010
Author: hamish
Date: 2010-01-09 07:38:41 -0500 (Sat, 09 Jan 2010)
New Revision: 40345
grass-addons/vector/v.in.lines/v.in.lines.py
minor fixes
Modified: grass-addons/vector/v.in.lines/v.in.lines.py
--- grass-addons/vector/v.in.lines/v.in.lines.py 2010-01-09 12:30:44 UTC (rev 40344)
+++ grass-addons/vector/v.in.lines/v.in.lines.py 2010-01-09 12:38:41 UTC (rev 40345)
@@ -129,18 +129,17 @@
##### check that there are at least two columns (three if -z is given)
- inf = file(infile)
+ inf = file(runfile)
line = inf.readline()
numcols = len(line.split(' '))
if (do3D and numcols < 3) or (not do3D and numcols < 2):
- g.message -e "Not enough data columns. (incorrect fs setting?)"
+ grass.fatal(_("Not enough data columns. (incorrect fs setting?)"))
inf.close()
grass.run_command('v.in.mapgen', flags = 'f' + do3D,
input = runfile, output = output)
if __name__ == "__main__":
options, flags = grass.parser()
