[GRASS-SVN] r40349 - in grass/trunk/scripts: . v.in.lines
svn_grass at osgeo.org
Sat Jan 9 08:23:31 EST 2010
Author: hamish
Date: 2010-01-09 08:23:31 -0500 (Sat, 09 Jan 2010)
New Revision: 40349
Added:
grass/trunk/scripts/v.in.lines/
Removed:
grass/trunk/scripts/v.in.lines/v.in.lines
grass/trunk/scripts/Makefile
grass/trunk/scripts/v.in.lines/v.in.lines.py
module to import vector lines from a stream of x,y data (move from addons)
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2010-01-09 13:17:25 UTC (rev 40348)
+++ grass/trunk/scripts/Makefile 2010-01-09 13:23:31 UTC (rev 40349)
@@ -54,6 +54,7 @@
v.in.e00 \
v.in.geonames \
v.in.gns \
+ v.in.lines \
v.in.mapgen \
v.in.sites.all \
v.in.wfs \
Deleted: grass/trunk/scripts/v.in.lines/v.in.lines
--- grass-addons/vector/v.in.lines/v.in.lines 2010-01-09 13:17:25 UTC (rev 40348)
+++ grass/trunk/scripts/v.in.lines/v.in.lines 2010-01-09 13:23:31 UTC (rev 40349)
@@ -1,133 +0,0 @@
-#!/bin/sh
-# MODULE: v.in.lines
-# AUTHOR(S): Hamish Bowman
-# PURPOSE: Import point data as lines ('v.in.mapgen -f' wrapper script)
-# COPYRIGHT: (c) 2009 The GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Import ASCII x,y[,z] coordinates as a series of lines.
-#% keywords: vector, import
-#%End
-#%flag
-#% key: z
-#% description: Create a 3D line from 3 column data
-#%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old_file,file,input
-#% description: Name of input file (or "-" to read from stdin)
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,vector,vector
-#% description: Name for output vector map
-#% required : yes
-#%end
-#%option
-#% key: fs
-#% type: string
-#% key_desc: character
-#% description: Field separator
-#% answer: |
-#% required: no
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-#### setup temporary file
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
- g.message -e "unable to create temporary files"
- exit 1
-fi
-#### trap ctrl-c so that we can clean up tmp
-trap 'rm -f "$TMP"' 2 3 15
-#### parse field separator
-if [ "$GIS_OPT_FS" = "space" ] || [ "$GIS_OPT_FS" = "tab" ] ; then
- fs=" "
-else
- fs="`echo "$GIS_OPT_FS" | cut -c1`"
-fi
-if [ "$GIS_OPT_INPUT" = "-" ] ; then
- # read from stdin to temp file (code borrowed from m.proj)
- EXITCODE=0
- while [ $EXITCODE -eq 0 ] ; do
- unset REPLY
- read REPLY
- EXITCODE=$?
- if [ -n "$REPLY" ] ; then
- echo "$REPLY" >> "$TMP.raw"
- fi
- done
- if [ "$fs" = " " ] ; then
- \mv -f "$TMP.raw" "$TMP"
- else
- tr "$fs" ' ' < "$TMP.raw" > "$TMP"
- \rm -f "$TMP.raw"
- fi
- # make sure we have at least one line of data
- if [ "`wc -l "$TMP" | cut -f1 -d' '`" -eq 0 ] ; then
- g.message -e "Problem reading data from stdin"
- exit 1
- fi
- INFILE="$TMP"
-else
- INFILE="$GIS_OPT_INPUT"
- else
- tr "$fs" ' ' < "$GIS_OPT_INPUT" > "$TMP"
- INFILE="$TMP"
- fi
-fi
-if [ "$GIS_FLAG_Z" -eq 1 ] ; then
- ZFLAG="-z"
-else
- ZFLAG=""
-fi
-if [ -z "`head -n 1 "$INFILE" | sed -e 's/[^ \t]*$//'`" ] ; then
- g.message -e "Not enough data columns. (incorrect fs setting?)"
- rm -f "$TMP"
- exit 1
-fi
-v.in.mapgen -f $ZFLAG in="$INFILE" out="$GIS_OPT_OUTPUT"
-EXITCODE=$?
-#cleanup
-rm -f "$TMP"
-exit $EXITCODE
Property changes on: grass/trunk/scripts/v.in.lines/v.in.lines.py
___________________________________________________________________
Modified: svn:mime-type
- text/x-sh
+ text/x-python
