[GRASS-SVN] r40350 - in grass/branches/develbranch_6/scripts: .
v.in.lines
svn_grass at osgeo.org
Sat Jan 9 08:24:00 EST 2010
Author: hamish
Date: 2010-01-09 08:23:59 -0500 (Sat, 09 Jan 2010)
New Revision: 40350
Added:
grass/branches/develbranch_6/scripts/v.in.lines/
Removed:
grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines.py
grass/branches/develbranch_6/scripts/Makefile
module to import vector lines from a stream of x,y data (move from addons)
Modified: grass/branches/develbranch_6/scripts/Makefile
--- grass/branches/develbranch_6/scripts/Makefile 2010-01-09 13:23:31 UTC (rev 40349)
+++ grass/branches/develbranch_6/scripts/Makefile 2010-01-09 13:23:59 UTC (rev 40350)
@@ -73,6 +73,7 @@
v.in.geonames \
v.in.gns \
v.in.gpsbabel \
+ v.in.lines \
v.in.mapgen \
v.in.sites.all \
v.in.wfs \
Deleted: grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines.py
--- grass-addons/vector/v.in.lines/v.in.lines.py 2010-01-09 13:17:25 UTC (rev 40348)
+++ grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines.py 2010-01-09 13:23:59 UTC (rev 40350)
@@ -1,150 +0,0 @@
-#!/usr/bin/env python
-# MODULE: v.in.lines
-# AUTHOR(S): Hamish Bowman
-# PURPOSE: Import point data as lines ('v.in.mapgen -f' wrapper script)
-# COPYRIGHT: (c) 2009-2010 The GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Import ASCII x,y[,z] coordinates as a series of lines.
-#% keywords: vector, import
-#%End
-#%flag
-#% key: z
-#% description: Create a 3D line from 3 column data
-#%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old_file,file,input
-#% description: Name of input file (or "-" to read from stdin)
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,vector,vector
-#% description: Name for output vector map
-#% required : yes
-#%end
-#%option
-#% key: fs
-#% type: string
-#% key_desc: character
-#% description: Field separator
-#% answer: |
-#% required: no
-#%end
-import sys
-import os
-import atexit
-import string
-from grass.script import core as grass
-def cleanup():
- grass.try_remove(tmp)
-def main():
- global tmp
- infile_opt = options['input']
- output = options['output']
- fs = options['fs']
- threeD = flags['z']
- prog = 'v.in.lines'
- opts = ""
- if threeD:
- do3D = 'z'
- else:
- do3D = ''
- tmp = grass.tempfile()
- #### parse field separator
- if fs in ('space', 'tab'):
- fs = ' '
- elif fs == 'comma':
- fs = ','
- else:
- if len(fs) > 1:
- grass.warning(_("Invalid field separator, using '%s'") % fs[0])
- try:
- fs = fs[0]
- except IndexError:
- grass.fatal(_("Invalid field separator '%s'") % fs)
- #### set up input file
- if infile_opt == '-':
- infile = None
- inf = sys.stdin
- else:
- infile = infile_opt
- if not os.path.exists(infile):
- grass.fatal(_("Unable to read input file <%s>") % infile)
- grass.debug("input file=[%s]" % infile)
- if not infile:
- # read from stdin and write to tmpfile (v.in.mapgen wants a real file)
- outf = file(tmp, 'w')
- for line in inf:
- if len(line.lstrip()) == 0 or line[0] == '#':
- continue
- outf.write(line.replace(fs, ' '))
- outf.close()
- runfile = tmp
- else:
- # read from a real file
- if fs == ' ':
- runfile = infile
- else:
- inf = file(infile)
- for line in inf:
- continue
- inf.close()
- outf.close()
- runfile = tmp
- ##### check that there are at least two columns (three if -z is given)
- inf = file(runfile)
- for line in inf:
- continue
- numcols = len(line.split())
- break
- if (do3D and numcols < 3) or (not do3D and numcols < 2):
- grass.fatal(_("Not enough data columns. (incorrect fs setting?)"))
- inf.close()
- grass.run_command('v.in.mapgen', flags = 'f' + do3D,
- input = runfile, output = output)
-if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- main()
