[GRASS-SVN] r40446 -
grass/branches/releasebranch_6_4/lib/db/dbmi_base
svn_grass at osgeo.org
Thu Jan 14 03:24:45 EST 2010
Author: hamish
Date: 2010-01-14 03:24:44 -0500 (Thu, 14 Jan 2010)
New Revision: 40446
grass/branches/releasebranch_6_4/lib/db/dbmi_base/login.c
change to new db login file, this time with '|' as fs so it can survive spaces in the db pathname and passwd (#809, merge from devbr6 r40369)
Modified: grass/branches/releasebranch_6_4/lib/db/dbmi_base/login.c
--- grass/branches/releasebranch_6_4/lib/db/dbmi_base/login.c 2010-01-14 07:08:20 UTC (rev 40445)
+++ grass/branches/releasebranch_6_4/lib/db/dbmi_base/login.c 2010-01-14 08:24:44 UTC (rev 40446)
@@ -6,6 +6,7 @@
#include <unistd.h>
#include <grass/gis.h>
#include <grass/dbmi.h>
+#include <grass/glocale.h>
typedef struct
@@ -27,7 +28,7 @@
if (!file) {
file = (char *)malloc(1000);
- sprintf(file, "%s/.grasslogin6", G_home());
+ sprintf(file, "%s/.grasslogin64", G_home());
return file;
@@ -58,7 +59,7 @@
- Read file if exists
+ Read the DB login file if it exists
return: -1 error (cannot read file)
number of items (0 also if file does not exist)
@@ -73,7 +74,7 @@
login->n = 0;
file = login_filename();
- G_debug(3, "file = %s", file);
+ G_debug(3, "DB login file = <%s>", file);
if (stat(file, &info) != 0) {
G_debug(3, "login file does not exist");
@@ -88,12 +89,13 @@
G_chop(buf);
usr[0] = pwd[0] = '\0';
- ret = sscanf(buf, "%[^ ] %[^ ] %[^ ] %[^ ]", dr, db, usr, pwd);
+ ret = sscanf(buf, "%[^|]|%[^|]|%[^|]|%[^\n]", dr, db, usr, pwd);
- G_debug(3, "ret = %d : %s %s %s %s", ret, dr, db, usr, pwd);
+ G_debug(3, "ret = %d : drv=[%s] db=[%s] usr=[%s] pwd=[%s]",
+ ret, dr, db, usr, pwd);
if (ret < 2) {
- G_warning("Login file corrupted");
+ G_warning(_("Login file corrupted"));
continue;
@@ -106,7 +108,7 @@
- Write file
+ Write the DB login file
0 OK
@@ -118,7 +120,7 @@
fd = fopen(file, "w");
if (fd == NULL)
@@ -129,12 +131,12 @@
chmod(file, S_IRUSR | S_IWUSR);
for (i = 0; i < login->n; i++) {
- fprintf(fd, "%s %s", login->data[i].driver, login->data[i].database);
+ fprintf(fd, "%s|%s", login->data[i].driver, login->data[i].database);
if (login->data[i].user) {
- fprintf(fd, " %s", login->data[i].user);
+ fprintf(fd, "|%s", login->data[i].user);
if (login->data[i].password)
- fprintf(fd, " %s", login->data[i].password);
+ fprintf(fd, "|%s", login->data[i].password);
fprintf(fd, "\n");
@@ -156,8 +158,8 @@
int i, found;
LOGIN login;
- G_debug(3, "db_set_login(): %s %s %s %s", driver, database, user,
- password);
+ G_debug(3, "db_set_login(): drv=[%s] db=[%s] usr=[%s] pwd=[%s]",
+ driver, database, user, password);
init_login(&login);
@@ -205,7 +207,7 @@
int i;
LOGIN login;
- G_debug(3, "db_get_login(): %s %s", driver, database);
+ G_debug(3, "db_get_login(): drv=[%s] db=[%s]", driver, database);
user[0] = '\0';
password[0] = '\0';
