[GRASS-SVN] r40541 - grass/trunk/raster/r.neighbors
svn_grass at osgeo.org
Mon Jan 18 21:39:26 EST 2010
Author: glynn
Date: 2010-01-18 21:39:24 -0500 (Mon, 18 Jan 2010)
New Revision: 40541
grass/trunk/raster/r.neighbors/main.c
Optimise 40534
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2010-01-18 23:39:37 UTC (rev 40540)
+++ grass/trunk/raster/r.neighbors/main.c 2010-01-19 02:39:24 UTC (rev 40541)
@@ -28,7 +28,6 @@
#include "ncb.h"
#include "local_proto.h"
typedef int (*ifunc) (void);
struct menu
@@ -75,8 +74,8 @@
int selection_fd;
int out_fd;
DCELL *result;
- void *selection_ptr, *selection, *input, *input_ptr;
- RASTER_MAP_TYPE map_type, selection_type;
+ char *selection;
+ RASTER_MAP_TYPE map_type;
int row, col;
int readrow;
int nrows, ncols;
@@ -122,13 +121,14 @@
"map layer.");
parm.input = G_define_standard_option(G_OPT_R_INPUT);
parm.selection = G_define_standard_option(G_OPT_R_INPUT);
parm.selection->key = "selection";
parm.selection->required = NO;
- parm.selection->description = "Name of an input raster map to select the cells which should be processed";
+ parm.selection->description = _("Name of an input raster map to select the cells which should be processed");
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.method = G_define_option();
parm.method->key = "method";
parm.method->type = TYPE_STRING;
@@ -288,12 +288,10 @@
readcell(in_fd, readrow++, nrows, ncols);
/* open the selection raster map */
- if(parm.selection->answer) {
- G_message("Opening selection map %s\n", parm.selection->answer);
+ if (parm.selection->answer) {
+ G_message(_("Opening selection map <%s>"), parm.selection->answer);
selection_fd = Rast_open_old(parm.selection->answer, "");
- selection_type = Rast_get_map_type(selection_fd);
- selection = Rast_allocate_buf(selection_type);
- input = Rast_allocate_buf(map_type);
+ selection = Rast_allocate_null_buf();
} else {
selection_fd = -1;
selection = NULL;
@@ -314,43 +312,36 @@
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- /* if selection map is enabled read each row of the
- selection and intput map
- if(selection != NULL) {
- Rast_get_row(selection_fd, selection, row, selection_type);
- Rast_get_row(in_fd, input, row, map_type);
- selection_ptr = selection;
- input_ptr = input;
+ if (selection)
+ Rast_get_null_value_row(selection_fd, selection, row);
for (col = 0; col < ncols; col++) {
DCELL *rp = &result[col];
- if((selection != NULL && Rast_is_null_value(selection_ptr, selection_type) == 1)) {
- *rp = Rast_get_d_value((const void *)input_ptr, map_type);
- }else {
+ if (selection && selection[col]) {
+ *rp = ncb.buf[ncb.dist][col];
+ continue;
+ if (newvalue_w)
+ n = gather_w(values_w, col);
+ else
+ n = gather(values, col);
+ if (n < 0)
+ Rast_set_d_null_value(rp, 1);
+ else {
if (newvalue_w)
- n = gather_w(values_w, col);
+ newvalue_w(rp, values_w, n, closure);
else
- n = gather(values, col);
+ newvalue(rp, values, n, closure);
- if (n < 0)
- Rast_set_d_null_value(rp, 1);
- else {
- if (newvalue_w)
- newvalue_w(rp, values_w, n, closure);
- else
- newvalue(rp, values, n, closure);
- if (half && !Rast_is_d_null_value(rp))
- *rp += 0.5;
- selection_ptr = G_incr_void_ptr(selection_ptr, Rast_cell_size(selection_type));
- input_ptr = G_incr_void_ptr(input_ptr, Rast_cell_size(map_type));
+ if (half && !Rast_is_d_null_value(rp))
+ *rp += 0.5;
Rast_put_d_row(out_fd, result);
@@ -358,10 +349,9 @@
Rast_close(out_fd);
Rast_close(in_fd);
+ if (selection)
Rast_close(selection_fd);
/* put out category info */
null_cats();
if ((cat_names = menu[method].cat_names))
