[GRASS-SVN] r40593 - grass/branches/develbranch_6
svn_grass at osgeo.org
Thu Jan 21 01:29:34 EST 2010
Author: hamish
Date: 2010-01-21 01:29:33 -0500 (Thu, 21 Jan 2010)
New Revision: 40593
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
quote variables which might contain pathnames with spaces
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2010-01-21 06:08:32 UTC (rev 40592)
+++ grass/branches/develbranch_6/configure 2010-01-21 06:29:33 UTC (rev 40593)
@@ -1271,8 +1271,8 @@
# Set GISBASE and GRASS_BIN
-GISBASE=${WINDSTDIR}/dist.${ARCH}
-GRASS_BIN=${DSTDIR}/bin.${ARCH}
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
+GRASS_BIN="${DSTDIR}/bin.${ARCH}"
@@ -1280,10 +1280,10 @@
# Set GRASS_VERSION_*
GRASS_VERSION_FILE=include/VERSION
-GRASS_VERSION_MAJOR=`sed -n 1p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_MINOR=`sed -n 2p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_RELEASE=`sed -n 3p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_DATE=`sed -n 4p ${GRASS_VERSION_FILE}`
+GRASS_VERSION_MAJOR=`sed -n 1p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_MINOR=`sed -n 2p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_RELEASE=`sed -n 3p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_DATE=`sed -n 4p "${GRASS_VERSION_FILE}"`
GRASS_VERSION_NUMBER=`echo ${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}`
NAME_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/\..*//'`
@@ -6065,8 +6065,8 @@
else :
fi
-DBMIEXTRALIB=$LIBS
-LIBS=$ac_save_libs
+DBMIEXTRALIB="$LIBS"
+LIBS="$ac_save_libs"
# Note: -lxdr -liberty -lws2_32 is for MinGW
@@ -8170,6 +8170,7 @@
GGEOS_CFLAGS=
USE_GEOS=
+# FIXME: "quote" $with_geos ?
if test "`basename xx/$with_geos`" = "geos-config" ; then
GEOS_CONFIG="$with_geos"
fi
@@ -8181,7 +8182,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8185: checking for $ac_word" >&5
+echo "configure:8186: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -8229,15 +8230,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8233: checking for $ac_hdr" >&5
+echo "configure:8234: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 8236 "configure"
+#line 8237 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8272,13 +8273,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8276: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8277: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lgeos_c $LIBS"
-#line 8282 "configure"
+#line 8283 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -8289,7 +8290,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -8332,7 +8333,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8336: checking whether to use TIFF" >&5
+echo "configure:8337: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8352,7 +8353,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8356: checking for location of TIFF includes" >&5
+echo "configure:8357: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8378,15 +8379,15 @@
do
-echo "configure:8382: checking for $ac_hdr" >&5
+echo "configure:8383: checking for $ac_hdr" >&5
-#line 8385 "configure"
+#line 8386 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8390: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8420,7 +8421,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8424: checking for location of TIFF library" >&5
+echo "configure:8425: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8451,13 +8452,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8455: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8456: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8461 "configure"
+#line 8462 "configure"
@@ -8468,7 +8469,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8487,13 +8488,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:8491: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8492: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8497 "configure"
+#line 8498 "configure"
@@ -8504,7 +8505,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8523,13 +8524,13 @@
-echo "configure:8527: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8528: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8533 "configure"
+#line 8534 "configure"
@@ -8540,7 +8541,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8559,13 +8560,13 @@
-echo "configure:8563: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8564: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8569 "configure"
+#line 8570 "configure"
@@ -8576,7 +8577,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8595,13 +8596,13 @@
-echo "configure:8599: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8600: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8605 "configure"
+#line 8606 "configure"
@@ -8612,7 +8613,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8631,13 +8632,13 @@
-echo "configure:8635: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8636: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8641 "configure"
+#line 8642 "configure"
@@ -8648,7 +8649,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8667,13 +8668,13 @@
-echo "configure:8671: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8672: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8677 "configure"
+#line 8678 "configure"
@@ -8684,7 +8685,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8703,13 +8704,13 @@
-echo "configure:8707: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8708: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8713 "configure"
+#line 8714 "configure"
@@ -8720,7 +8721,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8818,7 +8819,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8822: checking whether to use PNG" >&5
+echo "configure:8823: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8837,7 +8838,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8841: checking for location of PNG includes" >&5
+echo "configure:8842: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8863,15 +8864,15 @@
do
-echo "configure:8867: checking for $ac_hdr" >&5
+echo "configure:8868: checking for $ac_hdr" >&5
-#line 8870 "configure"
+#line 8871 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8875: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8905,7 +8906,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8909: checking for location of PNG library" >&5
+echo "configure:8910: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8930,13 +8931,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8934: checking for png_read_image in -lpng" >&5
+echo "configure:8935: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8940 "configure"
+#line 8941 "configure"
@@ -8947,7 +8948,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8989,7 +8990,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8993: checking whether to use PostgreSQL" >&5
+echo "configure:8994: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9016,7 +9017,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9020: checking for location of PostgreSQL includes" >&5
+echo "configure:9021: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9042,15 +9043,15 @@
do
-echo "configure:9046: checking for $ac_hdr" >&5
+echo "configure:9047: checking for $ac_hdr" >&5
-#line 9049 "configure"
+#line 9050 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9054: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9055: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9088,7 +9089,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9092: checking for location of PostgreSQL library" >&5
+echo "configure:9093: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9117,13 +9118,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9121: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9122: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9127 "configure"
+#line 9128 "configure"
@@ -9134,7 +9135,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9153,13 +9154,13 @@
-echo "configure:9157: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9158: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9163 "configure"
+#line 9164 "configure"
@@ -9170,7 +9171,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9189,13 +9190,13 @@
-echo "configure:9193: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9194: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9199 "configure"
+#line 9200 "configure"
@@ -9206,7 +9207,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9225,13 +9226,13 @@
-echo "configure:9229: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9230: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9235 "configure"
+#line 9236 "configure"
@@ -9242,7 +9243,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9299,13 +9300,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9303: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9304: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9309 "configure"
+#line 9310 "configure"
@@ -9316,7 +9317,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9338,13 +9339,13 @@
-echo "configure:9342: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9343: checking for PQcmdTuples in -lpq" >&5
-#line 9348 "configure"
+#line 9349 "configure"
@@ -9355,7 +9356,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9382,7 +9383,7 @@
fi
-LDFLAGS=${ac_save_ldflags}
+LDFLAGS="${ac_save_ldflags}"
fi # $USE_POSTGRES
@@ -9398,7 +9399,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9402: checking whether to use MySQL" >&5
+echo "configure:9403: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9418,7 +9419,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9422: checking for location of MySQL includes" >&5
+echo "configure:9423: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9444,15 +9445,15 @@
do
-echo "configure:9448: checking for $ac_hdr" >&5
+echo "configure:9449: checking for $ac_hdr" >&5
-#line 9451 "configure"
+#line 9452 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9489,7 +9490,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9493: checking for location of MySQL library" >&5
+echo "configure:9494: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9520,13 +9521,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9524: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9525: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9530 "configure"
+#line 9531 "configure"
@@ -9537,7 +9538,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9556,13 +9557,13 @@
-echo "configure:9560: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9561: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9566 "configure"
+#line 9567 "configure"
@@ -9573,7 +9574,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9592,13 +9593,13 @@
-echo "configure:9596: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9597: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9602 "configure"
+#line 9603 "configure"
@@ -9609,7 +9610,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9628,13 +9629,13 @@
-echo "configure:9632: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9633: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9638 "configure"
+#line 9639 "configure"
@@ -9645,7 +9646,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9664,13 +9665,13 @@
-echo "configure:9668: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9669: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9674 "configure"
+#line 9675 "configure"
@@ -9681,7 +9682,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9700,13 +9701,13 @@
-echo "configure:9704: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9705: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9710 "configure"
+#line 9711 "configure"
@@ -9717,7 +9718,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9736,13 +9737,13 @@
-echo "configure:9740: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9741: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9746 "configure"
+#line 9747 "configure"
@@ -9753,7 +9754,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9772,13 +9773,13 @@
-echo "configure:9776: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9777: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9782 "configure"
+#line 9783 "configure"
@@ -9789,7 +9790,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9879,7 +9880,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9883: checking for $ac_word" >&5
+echo "configure:9884: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9920,10 +9921,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9924: checking for mysql_server_init" >&5
+echo "configure:9925: checking for mysql_server_init" >&5
-#line 9927 "configure"
+#line 9928 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9946,7 +9947,7 @@
; return 0; }
EOF
-if { (eval echo configure:9950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9984,7 +9985,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9988: checking whether to use SQLite" >&5
+echo "configure:9989: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10004,7 +10005,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10008: checking for location of SQLite includes" >&5
+echo "configure:10009: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10030,15 +10031,15 @@
do
-echo "configure:10034: checking for $ac_hdr" >&5
+echo "configure:10035: checking for $ac_hdr" >&5
-#line 10037 "configure"
+#line 10038 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10043: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10081,7 +10082,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10085: checking for location of SQLite library" >&5
+echo "configure:10086: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10108,13 +10109,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10112: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10113: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10118 "configure"
+#line 10119 "configure"
@@ -10125,7 +10126,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10144,13 +10145,13 @@
-echo "configure:10148: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10149: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10154 "configure"
+#line 10155 "configure"
@@ -10161,7 +10162,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10214,7 +10215,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10218: checking whether to use FFMPEG" >&5
+echo "configure:10219: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10234,7 +10235,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10238: checking for location of FFMPEG includes" >&5
+echo "configure:10239: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10260,15 +10261,15 @@
do
-echo "configure:10264: checking for $ac_hdr" >&5
+echo "configure:10265: checking for $ac_hdr" >&5
-#line 10267 "configure"
+#line 10268 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10304,15 +10305,15 @@
do
-echo "configure:10308: checking for $ac_hdr" >&5
+echo "configure:10309: checking for $ac_hdr" >&5
-#line 10311 "configure"
+#line 10312 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10348,15 +10349,15 @@
do
-echo "configure:10352: checking for $ac_hdr" >&5
+echo "configure:10353: checking for $ac_hdr" >&5
-#line 10355 "configure"
+#line 10356 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10360: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10361: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10399,7 +10400,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10403: checking for location of FFMPEG library" >&5
+echo "configure:10404: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10426,13 +10427,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10430: checking for av_free in -lavutil" >&5
+echo "configure:10431: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10436 "configure"
+#line 10437 "configure"
@@ -10443,7 +10444,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10462,13 +10463,13 @@
-echo "configure:10466: checking for av_free in -lavutil" >&5
+echo "configure:10467: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10472 "configure"
+#line 10473 "configure"
@@ -10479,7 +10480,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10524,13 +10525,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10528: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10529: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10534 "configure"
+#line 10535 "configure"
@@ -10541,7 +10542,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10560,13 +10561,13 @@
-echo "configure:10564: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10565: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10570 "configure"
+#line 10571 "configure"
@@ -10577,7 +10578,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10622,13 +10623,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10626: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10627: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10632 "configure"
+#line 10633 "configure"
@@ -10639,7 +10640,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10658,13 +10659,13 @@
-echo "configure:10662: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10663: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10668 "configure"
+#line 10669 "configure"
@@ -10675,7 +10676,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10734,7 +10735,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10738: checking whether to use OpenGL" >&5
+echo "configure:10739: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10768,7 +10769,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10772: checking for location of OpenGL includes" >&5
+echo "configure:10773: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10794,15 +10795,15 @@
do
-echo "configure:10798: checking for $ac_hdr" >&5
+echo "configure:10799: checking for $ac_hdr" >&5
-#line 10801 "configure"
+#line 10802 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10807: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10836,7 +10837,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10840: checking for location of OpenGL library" >&5
+echo "configure:10841: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10865,13 +10866,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10869: checking for glBegin in -lGL" >&5
+echo "configure:10870: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10875 "configure"
+#line 10876 "configure"
@@ -10882,7 +10883,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10901,13 +10902,13 @@
-echo "configure:10905: checking for glBegin in -lGL" >&5
+echo "configure:10906: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10911 "configure"
+#line 10912 "configure"
@@ -10918,7 +10919,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10937,13 +10938,13 @@
-echo "configure:10941: checking for glBegin in -lGL" >&5
+echo "configure:10942: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10947 "configure"
+#line 10948 "configure"
@@ -10954,7 +10955,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10973,13 +10974,13 @@
-echo "configure:10977: checking for glBegin in -lGL" >&5
+echo "configure:10978: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10983 "configure"
+#line 10984 "configure"
@@ -10990,7 +10991,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11052,13 +11053,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11056: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11057: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11062 "configure"
+#line 11063 "configure"
@@ -11069,7 +11070,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11088,13 +11089,13 @@
-echo "configure:11092: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11093: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11098 "configure"
+#line 11099 "configure"
@@ -11105,7 +11106,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11149,10 +11150,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11153: checking for glXCreatePbuffer" >&5
+echo "configure:11154: checking for glXCreatePbuffer" >&5
-#line 11156 "configure"
+#line 11157 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11175,7 +11176,7 @@
; return 0; }
EOF
-if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11197,10 +11198,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11201: checking for glXCreateGLXPixmap" >&5
+echo "configure:11202: checking for glXCreateGLXPixmap" >&5
-#line 11204 "configure"
+#line 11205 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11223,7 +11224,7 @@
; return 0; }
EOF
-if { (eval echo configure:11227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11244,7 +11245,7 @@
fi
cat >> confdefs.h <<\EOF
#define OPENGL_X11 1
@@ -11262,7 +11263,7 @@
-echo "configure:11266: checking for location of OpenGL includes" >&5
+echo "configure:11267: checking for location of OpenGL includes" >&5
@@ -11288,15 +11289,15 @@
do
-echo "configure:11292: checking for $ac_hdr" >&5
+echo "configure:11293: checking for $ac_hdr" >&5
-#line 11295 "configure"
+#line 11296 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11331,10 +11332,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11335: checking for glBegin" >&5
+echo "configure:11336: checking for glBegin" >&5
-#line 11338 "configure"
+#line 11339 "configure"
which can conflict with char glBegin(); below. */
@@ -11357,7 +11358,7 @@
; return 0; }
EOF
-if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11372,10 +11373,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11376: checking for gluBeginCurve" >&5
+echo "configure:11377: checking for gluBeginCurve" >&5
-#line 11379 "configure"
+#line 11380 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11398,7 +11399,7 @@
; return 0; }
EOF
-if { (eval echo configure:11402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11427,7 +11428,7 @@
{ echo "configure: error: *** Unable to locate OpenGL library." 1>&2; exit 1; }
fi
#define OPENGL_AQUA 1
@@ -11442,7 +11443,7 @@
-echo "configure:11446: checking for location of OpenGL includes" >&5
+echo "configure:11447: checking for location of OpenGL includes" >&5
@@ -11468,15 +11469,15 @@
do
-echo "configure:11472: checking for $ac_hdr" >&5
+echo "configure:11473: checking for $ac_hdr" >&5
-#line 11475 "configure"
+#line 11476 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11510,7 +11511,7 @@
-echo "configure:11514: checking for location of OpenGL library" >&5
+echo "configure:11515: checking for location of OpenGL library" >&5
@@ -11535,18 +11536,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11539: checking for OpenGL library" >&5
+echo "configure:11540: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11543 "configure"
+#line 11544 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11570,18 +11571,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11574: checking for GLU library" >&5
+echo "configure:11575: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11578 "configure"
+#line 11579 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11601,7 +11602,7 @@
LIBS=${ac_save_libs}
-CFLAGS=${ac_save_cflags}
+CFLAGS="${ac_save_cflags}"
OPENGLLIB="$OPENGL_LIB_PATH $OPENGLLIB"
OPENGLULIB="$OPENGL_LIB_PATH $OPENGLULIB"
@@ -11630,7 +11631,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11634: checking whether to use Tcl/Tk" >&5
+echo "configure:11635: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11650,7 +11651,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11654: checking for location of Tcl/Tk includes" >&5
+echo "configure:11655: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11676,15 +11677,15 @@
do
-echo "configure:11680: checking for $ac_hdr" >&5
+echo "configure:11681: checking for $ac_hdr" >&5
-#line 11683 "configure"
+#line 11684 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11721,15 +11722,15 @@
do
-echo "configure:11725: checking for $ac_hdr" >&5
+echo "configure:11726: checking for $ac_hdr" >&5
-#line 11728 "configure"
+#line 11729 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11762,7 +11763,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11766: checking Tcl version" >&5
+echo "configure:11767: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11770,7 +11771,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11774 "configure"
+#line 11775 "configure"
#include <stdio.h>
@@ -11782,7 +11783,7 @@
EOF
-if { (eval echo configure:11786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11800,7 +11801,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11804: checking Tk version" >&5
+echo "configure:11805: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11808,7 +11809,7 @@
else
-#line 11812 "configure"
+#line 11813 "configure"
#include <stdio.h>
@@ -11820,7 +11821,7 @@
EOF
-if { (eval echo configure:11824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11837,7 +11838,7 @@
if test "$tcl_ver" = "$tk_ver" ; then
- tcltk_ver=$tcl_ver
+ tcltk_ver="$tcl_ver"
else
{ echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
fi
@@ -11845,13 +11846,13 @@
TCL_VERSION="$tcl_ver"
# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
+tcltk_ver2=`echo "$tcltk_ver" | sed 's/\.//g'`
# With Tcl/Tk library directory
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11855: checking for location of Tcl/Tk library" >&5
+echo "configure:11856: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11891,13 +11892,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11895: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11896: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11901 "configure"
+#line 11902 "configure"
@@ -11908,7 +11909,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11927,13 +11928,13 @@
-echo "configure:11931: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11932: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11937 "configure"
+#line 11938 "configure"
@@ -11944,7 +11945,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11971,13 +11972,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11975: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11976: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11981 "configure"
+#line 11982 "configure"
@@ -11988,7 +11989,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12007,13 +12008,13 @@
-echo "configure:12011: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12012: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12017 "configure"
+#line 12018 "configure"
@@ -12024,7 +12025,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12051,13 +12052,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12055: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12056: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12061 "configure"
+#line 12062 "configure"
@@ -12068,7 +12069,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12087,13 +12088,13 @@
-echo "configure:12091: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12092: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12097 "configure"
+#line 12098 "configure"
@@ -12104,7 +12105,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12182,13 +12183,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12186: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12187: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12192 "configure"
+#line 12193 "configure"
@@ -12199,7 +12200,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12218,13 +12219,13 @@
-echo "configure:12222: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12223: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12228 "configure"
+#line 12229 "configure"
@@ -12235,7 +12236,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12262,13 +12263,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12266: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12267: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12272 "configure"
+#line 12273 "configure"
@@ -12279,7 +12280,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12298,13 +12299,13 @@
-echo "configure:12302: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12303: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12308 "configure"
+#line 12309 "configure"
@@ -12315,7 +12316,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12342,13 +12343,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12346: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12347: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12352 "configure"
+#line 12353 "configure"
@@ -12359,7 +12360,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12378,13 +12379,13 @@
-echo "configure:12382: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12383: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12388 "configure"
+#line 12389 "configure"
@@ -12395,7 +12396,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12485,13 +12486,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12489: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12490: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12495 "configure"
+#line 12496 "configure"
@@ -12502,7 +12503,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12551,7 +12552,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12555: checking whether to use ODBC" >&5
+echo "configure:12556: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12570,7 +12571,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12574: checking for location of ODBC includes" >&5
+echo "configure:12575: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12596,15 +12597,15 @@
do
-echo "configure:12600: checking for $ac_hdr" >&5
+echo "configure:12601: checking for $ac_hdr" >&5
-#line 12603 "configure"
+#line 12604 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12638,7 +12639,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12642: checking for location of ODBC library" >&5
+echo "configure:12643: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12663,13 +12664,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12667: checking for SQLConnect in -lodbc" >&5
+echo "configure:12668: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12673 "configure"
+#line 12674 "configure"
@@ -12680,7 +12681,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12705,13 +12706,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12709: checking for SQLConnect in -liodbc" >&5
+echo "configure:12710: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12715 "configure"
+#line 12716 "configure"
@@ -12722,7 +12723,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12747,11 +12748,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12751: checking for ODBC library" >&5
+echo "configure:12752: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12755 "configure"
+#line 12756 "configure"
#include <windows.h>
#include <sql.h>
@@ -12759,7 +12760,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12779,7 +12780,7 @@
fi
@@ -12808,7 +12809,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12812: checking whether to use FFTW" >&5
+echo "configure:12813: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12827,7 +12828,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12831: checking for location of FFTW includes" >&5
+echo "configure:12832: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12853,15 +12854,15 @@
do
-echo "configure:12857: checking for $ac_hdr" >&5
+echo "configure:12858: checking for $ac_hdr" >&5
-#line 12860 "configure"
+#line 12861 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12889,15 +12890,15 @@
do
-echo "configure:12893: checking for $ac_hdr" >&5
+echo "configure:12894: checking for $ac_hdr" >&5
-#line 12896 "configure"
+#line 12897 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12925,15 +12926,15 @@
do
-echo "configure:12929: checking for $ac_hdr" >&5
+echo "configure:12930: checking for $ac_hdr" >&5
-#line 12932 "configure"
+#line 12933 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12979,7 +12980,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12983: checking for location of FFTW library" >&5
+echo "configure:12984: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13004,13 +13005,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13008: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13009: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13014 "configure"
+#line 13015 "configure"
@@ -13021,7 +13022,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13046,13 +13047,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13050: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13051: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13056 "configure"
+#line 13057 "configure"
@@ -13063,7 +13064,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13088,13 +13089,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13092: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13093: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13098 "configure"
+#line 13099 "configure"
@@ -13105,7 +13106,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13162,7 +13163,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13166: checking whether to use BLAS" >&5
+echo "configure:13167: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13183,7 +13184,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13187: checking for location of BLAS includes" >&5
+echo "configure:13188: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13203,7 +13204,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13207: checking for location of BLAS library" >&5
+echo "configure:13208: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13229,15 +13230,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13233: checking for $ac_hdr" >&5
+echo "configure:13234: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13236 "configure"
+#line 13237 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13262,7 +13263,7 @@
fi
done
-CPPFLAGS=$save_CPPFLAGS
+CPPFLAGS="$save_CPPFLAGS"
@@ -13272,13 +13273,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13276: checking for dnrm2_ in -lblas" >&5
+echo "configure:13277: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB $LIBS"
-#line 13282 "configure"
+#line 13283 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13289,7 +13290,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13308,13 +13309,13 @@
-echo "configure:13312: checking for dnrm2_ in -lblas" >&5
+echo "configure:13313: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13318 "configure"
+#line 13319 "configure"
@@ -13325,7 +13326,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13369,13 +13370,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13373: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13374: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13379 "configure"
+#line 13380 "configure"
@@ -13386,7 +13387,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13401,13 +13402,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13405: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13406: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13411 "configure"
+#line 13412 "configure"
@@ -13418,7 +13419,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13433,13 +13434,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13437: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13438: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13443 "configure"
+#line 13444 "configure"
@@ -13450,7 +13451,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13496,16 +13497,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13500: checking for sgemm in $vlib_flags" >&5
+echo "configure:13501: checking for sgemm in $vlib_flags" >&5
-#line 13502 "configure"
+#line 13503 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13523,13 +13524,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13527: checking for sgemm_ in -lblas" >&5
+echo "configure:13528: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13533 "configure"
+#line 13534 "configure"
@@ -13540,7 +13541,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13555,13 +13556,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13559: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13560: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13565 "configure"
+#line 13566 "configure"
@@ -13572,7 +13573,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13587,13 +13588,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13591: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13592: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13597 "configure"
+#line 13598 "configure"
@@ -13604,7 +13605,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13638,13 +13639,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13642: checking for acosp in -lsunmath" >&5
+echo "configure:13643: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13648 "configure"
+#line 13649 "configure"
@@ -13655,7 +13656,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13670,13 +13671,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13674: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13675: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13680 "configure"
+#line 13681 "configure"
@@ -13687,7 +13688,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13717,13 +13718,13 @@
# Generic BLAS library
-echo "configure:13721: checking for sgemm_ in -lblas" >&5
+echo "configure:13722: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13727 "configure"
+#line 13728 "configure"
@@ -13734,7 +13735,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13773,7 +13774,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13777: checking whether to use LAPACK" >&5
+echo "configure:13778: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13798,7 +13799,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13802: checking for location of LAPACK includes" >&5
+echo "configure:13803: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13818,7 +13819,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13822: checking for location of LAPACK library" >&5
+echo "configure:13823: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13844,15 +13845,15 @@
do
-echo "configure:13848: checking for $ac_hdr" >&5
+echo "configure:13849: checking for $ac_hdr" >&5
-#line 13851 "configure"
+#line 13852 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13857: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13877,17 +13878,17 @@
fi
done
# LAPACK linked to by default?
if test lapack_ok=no; then
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13888: checking for dsegv_" >&5
+echo "configure:13889: checking for dsegv_" >&5
-#line 13891 "configure"
+#line 13892 "configure"
which can conflict with char dsegv_(); below. */
@@ -13910,7 +13911,7 @@
; return 0; }
EOF
-if { (eval echo configure:13914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13937,13 +13938,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13941: checking for desgv_ in -llapack" >&5
+echo "configure:13942: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13947 "configure"
+#line 13948 "configure"
@@ -13954,7 +13955,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13986,13 +13987,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13990: checking for dgesv_ in -llapack" >&5
+echo "configure:13991: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13996 "configure"
+#line 13997 "configure"
@@ -14003,7 +14004,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14022,13 +14023,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:14026: checking for dgesv_ in -llapack" >&5
+echo "configure:14027: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14032 "configure"
+#line 14033 "configure"
@@ -14039,7 +14040,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14095,7 +14096,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14099: checking whether to use Motif" >&5
+echo "configure:14100: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14114,7 +14115,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14118: checking for location of Motif includes" >&5
+echo "configure:14119: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14140,15 +14141,15 @@
do
-echo "configure:14144: checking for $ac_hdr" >&5
+echo "configure:14145: checking for $ac_hdr" >&5
-#line 14147 "configure"
+#line 14148 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14153: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14182,7 +14183,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14186: checking for location of Motif library" >&5
+echo "configure:14187: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14207,13 +14208,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14211: checking for XmStringCreate in -lXm" >&5
+echo "configure:14212: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14217 "configure"
+#line 14218 "configure"
@@ -14224,7 +14225,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14265,7 +14266,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14269: checking whether to use Cairo" >&5
+echo "configure:14270: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14286,12 +14287,12 @@
fi
# With Cairo includes directory
+#FIXME: somehow quote dirs with spaces in $cairo ?
CAIROINC=`pkg-config --cflags $cairo`
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14295: checking for location of cairo includes" >&5
+echo "configure:14296: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14317,15 +14318,15 @@
do
-echo "configure:14321: checking for $ac_hdr" >&5
+echo "configure:14322: checking for $ac_hdr" >&5
-#line 14324 "configure"
+#line 14325 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14361,7 +14362,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14365: checking for location of cairo library" >&5
+echo "configure:14366: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14381,7 +14382,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14385: checking for cairo linking flags" >&5
+echo "configure:14386: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14397,10 +14398,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14401: checking for cairo_create" >&5
+echo "configure:14402: checking for cairo_create" >&5
-#line 14404 "configure"
+#line 14405 "configure"
which can conflict with char cairo_create(); below. */
@@ -14423,7 +14424,7 @@
; return 0; }
EOF
-if { (eval echo configure:14427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14457,10 +14458,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14461: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14462: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14464 "configure"
+#line 14465 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14483,7 +14484,7 @@
; return 0; }
EOF
-if { (eval echo configure:14487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14525,7 +14526,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14529: checking whether to use GLw" >&5
+echo "configure:14530: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14544,7 +14545,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14548: checking for location of GLw includes" >&5
+echo "configure:14549: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14570,15 +14571,15 @@
do
-echo "configure:14574: checking for $ac_hdr" >&5
+echo "configure:14575: checking for $ac_hdr" >&5
-#line 14577 "configure"
+#line 14578 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14606,15 +14607,15 @@
do
-echo "configure:14610: checking for $ac_hdr" >&5
+echo "configure:14611: checking for $ac_hdr" >&5
-#line 14613 "configure"
+#line 14614 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14654,7 +14655,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14658: checking for location of GLw library" >&5
+echo "configure:14659: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14679,13 +14680,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14683: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14684: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14689 "configure"
+#line 14690 "configure"
@@ -14696,7 +14697,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14721,13 +14722,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14725: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14726: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14731 "configure"
+#line 14732 "configure"
@@ -14738,7 +14739,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14763,13 +14764,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14767: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14768: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14773 "configure"
+#line 14774 "configure"
@@ -14780,7 +14781,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14805,13 +14806,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14809: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14810: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14815 "configure"
+#line 14816 "configure"
@@ -14822,7 +14823,7 @@
; return 0; }
EOF
-if { (eval echo configure:14826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14847,13 +14848,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14851: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14852: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14857 "configure"
+#line 14858 "configure"
@@ -14864,7 +14865,7 @@
; return 0; }
EOF
-if { (eval echo configure:14868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14889,13 +14890,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14893: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14894: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14899 "configure"
+#line 14900 "configure"
@@ -14906,7 +14907,7 @@
; return 0; }
EOF
-if { (eval echo configure:14910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14933,13 +14934,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14937: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14938: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14943 "configure"
+#line 14944 "configure"
@@ -14950,7 +14951,7 @@
; return 0; }
EOF
-if { (eval echo configure:14954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14969,13 +14970,13 @@
-echo "configure:14973: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14974: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14979 "configure"
+#line 14980 "configure"
@@ -14986,7 +14987,7 @@
; return 0; }
EOF
-if { (eval echo configure:14990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15013,13 +15014,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15017: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15018: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15023 "configure"
+#line 15024 "configure"
@@ -15030,7 +15031,7 @@
; return 0; }
EOF
-if { (eval echo configure:15034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15049,13 +15050,13 @@
-echo "configure:15053: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15054: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15059 "configure"
+#line 15060 "configure"
@@ -15066,7 +15067,7 @@
; return 0; }
EOF
-if { (eval echo configure:15070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15179,7 +15180,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15183: checking whether to use FreeType" >&5
+echo "configure:15184: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15198,7 +15199,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15202: checking for location of FreeType includes" >&5
+echo "configure:15203: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15224,15 +15225,15 @@
do
-echo "configure:15228: checking for $ac_hdr" >&5
+echo "configure:15229: checking for $ac_hdr" >&5
-#line 15231 "configure"
+#line 15232 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15266,7 +15267,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15270: checking for location of FreeType library" >&5
+echo "configure:15271: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15291,13 +15292,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15295: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15296: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15301 "configure"
+#line 15302 "configure"
@@ -15308,7 +15309,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15349,7 +15350,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15353: checking whether to use NLS" >&5
+echo "configure:15354: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15369,10 +15370,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15373: checking for gettext" >&5
+echo "configure:15374: checking for gettext" >&5
-#line 15376 "configure"
+#line 15377 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15395,7 +15396,7 @@
; return 0; }
EOF
-if { (eval echo configure:15399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15413,13 +15414,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15417: checking for gettext in -lintl" >&5
+echo "configure:15418: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15423 "configure"
+#line 15424 "configure"
@@ -15430,7 +15431,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15465,7 +15466,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15469: checking whether to use C++" >&5
+echo "configure:15470: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15481,7 +15482,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15485: checking for $ac_word" >&5
+echo "configure:15486: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15510,7 +15511,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15514: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15515: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15521,12 +15522,12 @@
cat > conftest.$ac_ext << EOF
-#line 15525 "configure"
+#line 15526 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15552,19 +15553,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15556: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15557: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15561: checking whether we are using GNU C++" >&5
+echo "configure:15562: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15568: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15582,7 +15583,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15586: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15587: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15623,7 +15624,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15627: checking whether to use openDWG" >&5
+echo "configure:15628: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15643,7 +15644,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15647: checking for location of openDGW includes" >&5
+echo "configure:15648: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15669,15 +15670,15 @@
do
-echo "configure:15673: checking for $ac_hdr" >&5
+echo "configure:15674: checking for $ac_hdr" >&5
-#line 15676 "configure"
+#line 15677 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15711,7 +15712,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15715: checking for location of openDWG library" >&5
+echo "configure:15716: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15735,9 +15736,9 @@
#LOC_CHECK_LIBS(ad?.a,adSeekLayer,openDWG,$OPENDWGLIBPATH,OPENDWGLIB,,)
#for now hack (but working):
-TRUEOPENDWGLIBPATH=`echo $OPENDWGLIBPATH | cut -b3-`
-adlib=`ls -1 $TRUEOPENDWGLIBPATH/ad?.a | tail -1`
-OPENDWGLIB=$adlib
+TRUEOPENDWGLIBPATH=`echo "$OPENDWGLIBPATH" | cut -b3-`
+adlib=`ls -1 "$TRUEOPENDWGLIBPATH"/ad?.a | tail -1`
+OPENDWGLIB="$adlib"
fi # $USE_OPENDWG
@@ -15758,7 +15759,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15762: checking for special C compiler options needed for large files" >&5
+echo "configure:15763: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15766,7 +15767,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15770 "configure"
+#line 15771 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15782,7 +15783,7 @@
; return 0; }
EOF
-if { (eval echo configure:15786: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15787: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15791,7 +15792,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15795 "configure"
+#line 15796 "configure"
@@ -15807,7 +15808,7 @@
; return 0; }
EOF
-if { (eval echo configure:15811: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15812: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15827,11 +15828,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15831: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15832: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15835 "configure"
+#line 15836 "configure"
@@ -15847,14 +15848,14 @@
; return 0; }
EOF
-if { (eval echo configure:15851: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15852: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15858 "configure"
+#line 15859 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15872,7 +15873,7 @@
; return 0; }
EOF
-if { (eval echo configure:15876: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15891,11 +15892,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15895: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15896: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15899 "configure"
+#line 15900 "configure"
@@ -15911,14 +15912,14 @@
; return 0; }
EOF
-if { (eval echo configure:15915: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15916: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15922 "configure"
+#line 15923 "configure"
#define _LARGE_FILES 1
@@ -15936,7 +15937,7 @@
; return 0; }
EOF
-if { (eval echo configure:15940: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15941: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15955,25 +15956,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15959: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15960: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15963 "configure"
+#line 15964 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15971: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15977 "configure"
+#line 15978 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15982,7 +15983,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16003,10 +16004,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16007: checking if system supports Large Files at all" >&5
+echo "configure:16008: checking if system supports Large Files at all" >&5
-#line 16010 "configure"
+#line 16011 "configure"
#include <stdio.h>
@@ -16038,7 +16039,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16043: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16067,7 +16068,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16071: checking whether to use Python" >&5
+echo "configure:16072: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16088,7 +16089,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16092: checking for $ac_word" >&5
+echo "configure:16093: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16130,15 +16131,15 @@
do
-echo "configure:16134: checking for $ac_hdr" >&5
+echo "configure:16135: checking for $ac_hdr" >&5
-#line 16137 "configure"
+#line 16138 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16143: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16186,7 +16187,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:16190: checking for $ac_word" >&5
+echo "configure:16191: checking for $ac_word" >&5
case "$SWIG" in
@@ -16248,7 +16249,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16252: checking whether to use wxWidgets" >&5
+echo "configure:16253: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16269,7 +16270,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16273: checking for $ac_word" >&5
+echo "configure:16274: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16317,7 +16318,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16321: checking wxWidgets version" >&5
+echo "configure:16322: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16340,15 +16341,15 @@
do
-echo "configure:16344: checking for $ac_hdr" >&5
+echo "configure:16345: checking for $ac_hdr" >&5
-#line 16347 "configure"
+#line 16348 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16422,7 +16423,7 @@
STRIPFLAG=
-GRASS_HOME=${DSTDIR}
+GRASS_HOME="${DSTDIR}"
trap '' 1 2 15
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2010-01-21 06:08:32 UTC (rev 40592)
+++ grass/branches/develbranch_6/configure.in 2010-01-21 06:29:33 UTC (rev 40593)
@@ -105,8 +105,8 @@
# Set GISBASE and GRASS_BIN
-GISBASE=${WINDSTDIR}/dist.${ARCH}
-GRASS_BIN=${DSTDIR}/bin.${ARCH}
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
+GRASS_BIN="${DSTDIR}/bin.${ARCH}"
AC_SUBST(GISBASE)
AC_SUBST(GRASS_BIN)
@@ -114,10 +114,10 @@
# Set GRASS_VERSION_*
GRASS_VERSION_FILE=include/VERSION
-GRASS_VERSION_MAJOR=`sed -n 1p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_MINOR=`sed -n 2p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_RELEASE=`sed -n 3p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_DATE=`sed -n 4p ${GRASS_VERSION_FILE}`
+GRASS_VERSION_MAJOR=`sed -n 1p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_MINOR=`sed -n 2p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_RELEASE=`sed -n 3p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_DATE=`sed -n 4p "${GRASS_VERSION_FILE}"`
GRASS_VERSION_NUMBER=`echo ${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}`
NAME_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/\..*//'`
changequote(,)
@@ -546,8 +546,8 @@
ac_save_libs="$LIBS"
LIBS=""
AC_SEARCH_LIBS(cuserid,[compat])
-DBMIEXTRALIB=$LIBS
-LIBS=$ac_save_libs
+DBMIEXTRALIB="$LIBS"
+LIBS="$ac_save_libs"
AC_SUBST(DBMIEXTRALIB)
# Note: -lxdr -liberty -lws2_32 is for MinGW
@@ -852,6 +852,7 @@
GGEOS_CFLAGS=
USE_GEOS=
+# FIXME: "quote" $with_geos ?
if test "`basename xx/$with_geos`" = "geos-config" ; then
GEOS_CONFIG="$with_geos"
fi
@@ -976,7 +977,7 @@
AC_CHECK_LIB(pq,PQcmdTuples, [AC_DEFINE(HAVE_PQCMDTUPLES)], [
], -lcrypt)
-LDFLAGS=${ac_save_ldflags}
+LDFLAGS="${ac_save_ldflags}"
fi # $USE_POSTGRES
@@ -1183,7 +1184,7 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
AC_CHECK_FUNC(glXCreatePbuffer, [AC_DEFINE(HAVE_PBUFFERS)])
AC_CHECK_FUNC(glXCreateGLXPixmap, [AC_DEFINE(HAVE_PIXMAPS)])
AC_DEFINE(OPENGL_X11)
@@ -1211,7 +1212,7 @@
OPENGL_AQUA=1
],[AC_MSG_ERROR([*** Unable to locate GLU library.])])
],[AC_MSG_ERROR([*** Unable to locate OpenGL library.])])
AC_DEFINE(OPENGL_AQUA)
@@ -1233,7 +1234,7 @@
CFLAGS="$CFLAGS $OPENGLINC"
LOC_CHECK_LINK(opengl32,[#include <GL/gl.h>],[glEnd();],OpenGL,$OPENGL_LIB_PATH,OPENGLLIB)
LOC_CHECK_LINK(glu32,[#include <GL/glu.h>],[gluNewQuadric();],GLU,$OPENGL_LIB_PATH,OPENGLULIB,$OPENGLLIB)
-CFLAGS=${ac_save_cflags}
+CFLAGS="${ac_save_cflags}"
OPENGLLIB="$OPENGL_LIB_PATH $OPENGLLIB"
OPENGLULIB="$OPENGL_LIB_PATH $OPENGLULIB"
@@ -1279,7 +1280,7 @@
LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
if test "$tcl_ver" = "$tk_ver" ; then
- tcltk_ver=$tcl_ver
+ tcltk_ver="$tcl_ver"
else
AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
fi
@@ -1287,7 +1288,7 @@
TCL_VERSION="$tcl_ver"
# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
+tcltk_ver2=`echo "$tcltk_ver" | sed 's/\.//g'`
# With Tcl/Tk library directory
@@ -1388,7 +1389,7 @@
CFLAGS="$CFLAGS $ODBCINC"
LOC_CHECK_LINK(odbc32,[#include <windows.h>
#include <sql.h>],[SQLAllocEnv((SQLHENV *)0);],ODBC,$ODBCLIB,ODBCLIB)
@@ -1455,7 +1456,7 @@
save_CPPFLAGS="$CPPFLAGS"
CPPFLAGS="$BLASINC $CPPFLAGS"
AC_CHECK_HEADERS(cblas.h)
LOC_CHECK_LIBS(blas,dnrm2_,BLAS,$BLASLIB,BLASLIB,$MATHLIB,,,-lg2c)
@@ -1554,7 +1555,7 @@
CPPFLAGS="$LAPACKINC $CPPFLAGS"
AC_CHECK_HEADERS(clapack.h)
@@ -1632,7 +1633,7 @@
fi
LOC_CHECK_INC_PATH(cairo,cairo,CAIROINC)
@@ -1795,9 +1796,9 @@
-OPENDWGLIB=$adlib
fi # $USE_OPENDWG
@@ -2000,7 +2001,7 @@
STRIPFLAG=
AC_SUBST(STRIPFLAG)
AC_SUBST(GRASS_HOME)
AC_OUTPUT(include/Make/Grass.make include/Make/Platform.make include/version.h include/winname.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc)
