[GRASS-SVN] r40594 - grass/trunk
Thu Jan 21 01:36:15 EST 2010
Author: hamish
Date: 2010-01-21 01:36:14 -0500 (Thu, 21 Jan 2010)
New Revision: 40594
   grass/trunk/configure
   grass/trunk/configure.in
quote variables which might contain pathnames with spaces (merge from devbr6)
Modified: grass/trunk/configure
--- grass/trunk/configure	2010-01-21 06:29:33 UTC (rev 40593)
+++ grass/trunk/configure	2010-01-21 06:36:14 UTC (rev 40594)
@@ -1262,8 +1262,8 @@
 # Set GISBASE and GRASS_BIN
-GISBASE=${WINDSTDIR}/dist.${ARCH}
-GRASS_BIN=${DSTDIR}/bin.${ARCH}
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
+GRASS_BIN="${DSTDIR}/bin.${ARCH}"
@@ -1271,10 +1271,10 @@
 # Set GRASS_VERSION_*
 GRASS_VERSION_FILE=include/VERSION
-GRASS_VERSION_MAJOR=`sed -n 1p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_MINOR=`sed -n 2p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_RELEASE=`sed -n 3p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_DATE=`sed -n 4p ${GRASS_VERSION_FILE}`
+GRASS_VERSION_MAJOR=`sed -n 1p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_MINOR=`sed -n 2p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_RELEASE=`sed -n 3p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_DATE=`sed -n 4p "${GRASS_VERSION_FILE}"`
 GRASS_VERSION_NUMBER=`echo ${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}`
 NAME_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/\..*//'`
@@ -4430,8 +4430,8 @@
 else :
 fi
-DBMIEXTRALIB=$LIBS
-LIBS=$ac_save_libs
+DBMIEXTRALIB="$LIBS"
+LIBS="$ac_save_libs"
 # Note: -lxdr -liberty -lws2_32 is for MinGW
@@ -6535,6 +6535,7 @@
 GGEOS_CFLAGS=
 USE_GEOS=
+# FIXME: "quote" $with_geos ?
 if test "`basename xx/$with_geos`" = "geos-config" ; then
   GEOS_CONFIG="$with_geos"
 fi
@@ -6546,7 +6547,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6550: checking for $ac_word" >&5
+echo "configure:6551: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6594,15 +6595,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:6598: checking for $ac_hdr" >&5
+echo "configure:6599: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 6601 "configure"
+#line 6602 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:6606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -6637,13 +6638,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6641: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6642: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 6647 "configure"
+#line 6648 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -6654,7 +6655,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -6697,7 +6698,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6701: checking whether to use TIFF" >&5
+echo "configure:6702: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6717,7 +6718,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6721: checking for location of TIFF includes" >&5
+echo "configure:6722: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6743,15 +6744,15 @@
 do
-echo "configure:6747: checking for $ac_hdr" >&5
+echo "configure:6748: checking for $ac_hdr" >&5
-#line 6750 "configure"
+#line 6751 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6755: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6756: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6785,7 +6786,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6789: checking for location of TIFF library" >&5
+echo "configure:6790: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6816,13 +6817,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6820: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6821: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6826 "configure"
+#line 6827 "configure"
@@ -6833,7 +6834,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6852,13 +6853,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:6856: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6857: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6862 "configure"
+#line 6863 "configure"
@@ -6869,7 +6870,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6888,13 +6889,13 @@
-echo "configure:6892: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6893: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6898 "configure"
+#line 6899 "configure"
@@ -6905,7 +6906,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6924,13 +6925,13 @@
-echo "configure:6928: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6929: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6934 "configure"
+#line 6935 "configure"
@@ -6941,7 +6942,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6960,13 +6961,13 @@
-echo "configure:6964: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6965: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 6970 "configure"
+#line 6971 "configure"
@@ -6977,7 +6978,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6996,13 +6997,13 @@
-echo "configure:7000: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7001: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7006 "configure"
+#line 7007 "configure"
@@ -7013,7 +7014,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7032,13 +7033,13 @@
-echo "configure:7036: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7037: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7042 "configure"
+#line 7043 "configure"
@@ -7049,7 +7050,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7068,13 +7069,13 @@
-echo "configure:7072: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7073: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7078 "configure"
+#line 7079 "configure"
@@ -7085,7 +7086,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7183,7 +7184,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7187: checking whether to use PNG" >&5
+echo "configure:7188: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7202,7 +7203,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7206: checking for location of PNG includes" >&5
+echo "configure:7207: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7228,15 +7229,15 @@
 do
-echo "configure:7232: checking for $ac_hdr" >&5
+echo "configure:7233: checking for $ac_hdr" >&5
-#line 7235 "configure"
+#line 7236 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7270,7 +7271,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7274: checking for location of PNG library" >&5
+echo "configure:7275: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7295,13 +7296,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7299: checking for png_read_image in -lpng" >&5
+echo "configure:7300: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7305 "configure"
+#line 7306 "configure"
@@ -7312,7 +7313,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7354,7 +7355,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7358: checking whether to use PostgreSQL" >&5
+echo "configure:7359: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7381,7 +7382,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7385: checking for location of PostgreSQL includes" >&5
+echo "configure:7386: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7407,15 +7408,15 @@
 do
-echo "configure:7411: checking for $ac_hdr" >&5
+echo "configure:7412: checking for $ac_hdr" >&5
-#line 7414 "configure"
+#line 7415 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7453,7 +7454,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7457: checking for location of PostgreSQL library" >&5
+echo "configure:7458: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7482,13 +7483,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7486: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7487: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7492 "configure"
+#line 7493 "configure"
@@ -7499,7 +7500,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7518,13 +7519,13 @@
-echo "configure:7522: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7523: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7528 "configure"
+#line 7529 "configure"
@@ -7535,7 +7536,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7554,13 +7555,13 @@
-echo "configure:7558: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7559: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7564 "configure"
+#line 7565 "configure"
@@ -7571,7 +7572,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7590,13 +7591,13 @@
-echo "configure:7594: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7595: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7600 "configure"
+#line 7601 "configure"
@@ -7607,7 +7608,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7664,13 +7665,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7668: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7669: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7674 "configure"
+#line 7675 "configure"
@@ -7681,7 +7682,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7703,13 +7704,13 @@
-echo "configure:7707: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7708: checking for PQcmdTuples in -lpq" >&5
-#line 7713 "configure"
+#line 7714 "configure"
@@ -7720,7 +7721,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7747,7 +7748,7 @@
 fi
-LDFLAGS=${ac_save_ldflags}
+LDFLAGS="${ac_save_ldflags}"
 fi # $USE_POSTGRES
@@ -7763,7 +7764,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7767: checking whether to use MySQL" >&5
+echo "configure:7768: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7783,7 +7784,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7787: checking for location of MySQL includes" >&5
+echo "configure:7788: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7809,15 +7810,15 @@
 do
-echo "configure:7813: checking for $ac_hdr" >&5
+echo "configure:7814: checking for $ac_hdr" >&5
-#line 7816 "configure"
+#line 7817 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7821: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7854,7 +7855,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7858: checking for location of MySQL library" >&5
+echo "configure:7859: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7885,13 +7886,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7889: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7890: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7895 "configure"
+#line 7896 "configure"
@@ -7902,7 +7903,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7921,13 +7922,13 @@
-echo "configure:7925: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7926: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7931 "configure"
+#line 7932 "configure"
@@ -7938,7 +7939,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7957,13 +7958,13 @@
-echo "configure:7961: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7962: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7967 "configure"
+#line 7968 "configure"
@@ -7974,7 +7975,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7993,13 +7994,13 @@
-echo "configure:7997: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7998: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8003 "configure"
+#line 8004 "configure"
@@ -8010,7 +8011,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8029,13 +8030,13 @@
-echo "configure:8033: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8034: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8039 "configure"
+#line 8040 "configure"
@@ -8046,7 +8047,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8065,13 +8066,13 @@
-echo "configure:8069: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8070: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8075 "configure"
+#line 8076 "configure"
@@ -8082,7 +8083,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8101,13 +8102,13 @@
-echo "configure:8105: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8106: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8111 "configure"
+#line 8112 "configure"
@@ -8118,7 +8119,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8137,13 +8138,13 @@
-echo "configure:8141: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8142: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8147 "configure"
+#line 8148 "configure"
@@ -8154,7 +8155,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8244,7 +8245,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8248: checking for $ac_word" >&5
+echo "configure:8249: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8293,10 +8294,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8297: checking for mysql_server_init" >&5
+echo "configure:8298: checking for mysql_server_init" >&5
-#line 8300 "configure"
+#line 8301 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8322,7 +8323,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8374,7 +8375,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8378: checking whether to use SQLite" >&5
+echo "configure:8379: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8394,7 +8395,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8398: checking for location of SQLite includes" >&5
+echo "configure:8399: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8420,15 +8421,15 @@
 do
-echo "configure:8424: checking for $ac_hdr" >&5
+echo "configure:8425: checking for $ac_hdr" >&5
-#line 8427 "configure"
+#line 8428 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8433: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8471,7 +8472,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8475: checking for location of SQLite library" >&5
+echo "configure:8476: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8498,13 +8499,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8502: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8503: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8508 "configure"
+#line 8509 "configure"
@@ -8515,7 +8516,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8534,13 +8535,13 @@
-echo "configure:8538: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8539: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8544 "configure"
+#line 8545 "configure"
@@ -8551,7 +8552,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8604,7 +8605,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8608: checking whether to use FFMPEG" >&5
+echo "configure:8609: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8624,7 +8625,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8628: checking for location of FFMPEG includes" >&5
+echo "configure:8629: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8650,15 +8651,15 @@
 do
-echo "configure:8654: checking for $ac_hdr" >&5
+echo "configure:8655: checking for $ac_hdr" >&5
-#line 8657 "configure"
+#line 8658 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8663: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8694,15 +8695,15 @@
 do
-echo "configure:8698: checking for $ac_hdr" >&5
+echo "configure:8699: checking for $ac_hdr" >&5
-#line 8701 "configure"
+#line 8702 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8738,15 +8739,15 @@
 do
-echo "configure:8742: checking for $ac_hdr" >&5
+echo "configure:8743: checking for $ac_hdr" >&5
-#line 8745 "configure"
+#line 8746 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8750: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8751: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8789,7 +8790,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8793: checking for location of FFMPEG library" >&5
+echo "configure:8794: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8816,13 +8817,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8820: checking for av_free in -lavutil" >&5
+echo "configure:8821: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 8826 "configure"
+#line 8827 "configure"
@@ -8833,7 +8834,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8852,13 +8853,13 @@
-echo "configure:8856: checking for av_free in -lavutil" >&5
+echo "configure:8857: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 8862 "configure"
+#line 8863 "configure"
@@ -8869,7 +8870,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8914,13 +8915,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:8918: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8919: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8924 "configure"
+#line 8925 "configure"
@@ -8931,7 +8932,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8950,13 +8951,13 @@
-echo "configure:8954: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8955: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8960 "configure"
+#line 8961 "configure"
@@ -8967,7 +8968,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9012,13 +9013,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9016: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9017: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9022 "configure"
+#line 9023 "configure"
@@ -9029,7 +9030,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9048,13 +9049,13 @@
-echo "configure:9052: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9053: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9058 "configure"
+#line 9059 "configure"
@@ -9065,7 +9066,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9124,7 +9125,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9128: checking whether to use OpenGL" >&5
+echo "configure:9129: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9158,7 +9159,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9162: checking for location of OpenGL includes" >&5
+echo "configure:9163: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9184,15 +9185,15 @@
 do
-echo "configure:9188: checking for $ac_hdr" >&5
+echo "configure:9189: checking for $ac_hdr" >&5
-#line 9191 "configure"
+#line 9192 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9226,7 +9227,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9230: checking for location of OpenGL library" >&5
+echo "configure:9231: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9255,13 +9256,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9259: checking for glBegin in -lGL" >&5
+echo "configure:9260: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9265 "configure"
+#line 9266 "configure"
@@ -9272,7 +9273,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9291,13 +9292,13 @@
-echo "configure:9295: checking for glBegin in -lGL" >&5
+echo "configure:9296: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9301 "configure"
+#line 9302 "configure"
@@ -9308,7 +9309,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9327,13 +9328,13 @@
-echo "configure:9331: checking for glBegin in -lGL" >&5
+echo "configure:9332: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9337 "configure"
+#line 9338 "configure"
@@ -9344,7 +9345,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9363,13 +9364,13 @@
-echo "configure:9367: checking for glBegin in -lGL" >&5
+echo "configure:9368: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9373 "configure"
+#line 9374 "configure"
@@ -9380,7 +9381,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9442,13 +9443,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9446: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9447: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9452 "configure"
+#line 9453 "configure"
@@ -9459,7 +9460,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9478,13 +9479,13 @@
-echo "configure:9482: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9483: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9488 "configure"
+#line 9489 "configure"
@@ -9495,7 +9496,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9542,10 +9543,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9546: checking for glXCreatePbuffer" >&5
+echo "configure:9547: checking for glXCreatePbuffer" >&5
-#line 9549 "configure"
+#line 9550 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9568,7 +9569,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9605,10 +9606,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9609: checking for glXCreateGLXPixmap" >&5
+echo "configure:9610: checking for glXCreateGLXPixmap" >&5
-#line 9612 "configure"
+#line 9613 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9631,7 +9632,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9674,7 +9675,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9678: checking for location of OpenGL framework" >&5
+echo "configure:9679: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9698,15 +9699,15 @@
 do
-echo "configure:9702: checking for $ac_hdr" >&5
+echo "configure:9703: checking for $ac_hdr" >&5
-#line 9705 "configure"
+#line 9706 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9711: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9742,10 +9743,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9746: checking for glBegin" >&5
+echo "configure:9747: checking for glBegin" >&5
-#line 9749 "configure"
+#line 9750 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9768,7 +9769,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9805,10 +9806,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9809: checking for gluBeginCurve" >&5
+echo "configure:9810: checking for gluBeginCurve" >&5
-#line 9812 "configure"
+#line 9813 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9831,7 +9832,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9879,7 +9880,7 @@
-echo "configure:9883: checking for location of OpenGL includes" >&5
+echo "configure:9884: checking for location of OpenGL includes" >&5
@@ -9905,15 +9906,15 @@
 do
-echo "configure:9909: checking for $ac_hdr" >&5
+echo "configure:9910: checking for $ac_hdr" >&5
-#line 9912 "configure"
+#line 9913 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9947,7 +9948,7 @@
-echo "configure:9951: checking for location of OpenGL library" >&5
+echo "configure:9952: checking for location of OpenGL library" >&5
@@ -9972,18 +9973,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9976: checking for OpenGL library" >&5
+echo "configure:9977: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9980 "configure"
+#line 9981 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10007,18 +10008,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10011: checking for GLU library" >&5
+echo "configure:10012: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10015 "configure"
+#line 10016 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10038,7 +10039,7 @@
 LIBS=${ac_save_libs}
-CFLAGS=${ac_save_cflags}
+CFLAGS="${ac_save_cflags}"
 OPENGLLIB="$OPENGL_LIB_PATH $OPENGLLIB"
 OPENGLULIB="$OPENGL_LIB_PATH $OPENGLULIB"
@@ -10067,7 +10068,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10071: checking whether to use Tcl/Tk" >&5
+echo "configure:10072: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -10087,7 +10088,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10091: checking for location of Tcl/Tk includes" >&5
+echo "configure:10092: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10113,15 +10114,15 @@
 do
-echo "configure:10117: checking for $ac_hdr" >&5
+echo "configure:10118: checking for $ac_hdr" >&5
-#line 10120 "configure"
+#line 10121 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10158,15 +10159,15 @@
 do
-echo "configure:10162: checking for $ac_hdr" >&5
+echo "configure:10163: checking for $ac_hdr" >&5
-#line 10165 "configure"
+#line 10166 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10170: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10200,7 +10201,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10204: checking Tcl version" >&5
+echo "configure:10205: checking Tcl version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -10208,7 +10209,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 10212 "configure"
+#line 10213 "configure"
 #include <stdio.h>
@@ -10220,7 +10221,7 @@
 EOF
-if { (eval echo configure:10224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -10238,7 +10239,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10242: checking Tk version" >&5
+echo "configure:10243: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10246,7 +10247,7 @@
 else
-#line 10250 "configure"
+#line 10251 "configure"
 #include <stdio.h>
@@ -10258,7 +10259,7 @@
 EOF
-if { (eval echo configure:10262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -10275,19 +10276,19 @@
 if test "$tcl_ver" = "$tk_ver" ; then
-    tcltk_ver=$tcl_ver
+    tcltk_ver="$tcl_ver"
 else
     { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
 fi
 # FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
+tcltk_ver2=`echo "$tcltk_ver" | sed 's/\.//g'`
 # With Tcl/Tk library directory
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10291: checking for location of Tcl/Tk library" >&5
+echo "configure:10292: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10327,13 +10328,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10331: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10332: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 10337 "configure"
+#line 10338 "configure"
@@ -10344,7 +10345,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10363,13 +10364,13 @@
-echo "configure:10367: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10368: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10373 "configure"
+#line 10374 "configure"
@@ -10380,7 +10381,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10407,13 +10408,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10411: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10412: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10417 "configure"
+#line 10418 "configure"
@@ -10424,7 +10425,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10443,13 +10444,13 @@
-echo "configure:10447: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10448: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10453 "configure"
+#line 10454 "configure"
@@ -10460,7 +10461,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10487,13 +10488,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10491: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10492: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10497 "configure"
+#line 10498 "configure"
@@ -10504,7 +10505,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10523,13 +10524,13 @@
-echo "configure:10527: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10528: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10533 "configure"
+#line 10534 "configure"
@@ -10540,7 +10541,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10618,13 +10619,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10622: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10623: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10628 "configure"
+#line 10629 "configure"
@@ -10635,7 +10636,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10654,13 +10655,13 @@
-echo "configure:10658: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10659: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10664 "configure"
+#line 10665 "configure"
@@ -10671,7 +10672,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10698,13 +10699,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10702: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10703: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10708 "configure"
+#line 10709 "configure"
@@ -10715,7 +10716,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10734,13 +10735,13 @@
-echo "configure:10738: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10739: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10744 "configure"
+#line 10745 "configure"
@@ -10751,7 +10752,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10778,13 +10779,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10782: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10783: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10788 "configure"
+#line 10789 "configure"
@@ -10795,7 +10796,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10814,13 +10815,13 @@
-echo "configure:10818: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10819: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10824 "configure"
+#line 10825 "configure"
@@ -10831,7 +10832,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10921,13 +10922,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:10925: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:10926: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 10931 "configure"
+#line 10932 "configure"
@@ -10938,7 +10939,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10988,7 +10989,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10992: checking whether to use ODBC" >&5
+echo "configure:10993: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11007,7 +11008,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11011: checking for location of ODBC includes" >&5
+echo "configure:11012: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11033,15 +11034,15 @@
 do
-echo "configure:11037: checking for $ac_hdr" >&5
+echo "configure:11038: checking for $ac_hdr" >&5
-#line 11040 "configure"
+#line 11041 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11075,7 +11076,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11079: checking for location of ODBC library" >&5
+echo "configure:11080: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11100,13 +11101,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11104: checking for SQLConnect in -lodbc" >&5
+echo "configure:11105: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11110 "configure"
+#line 11111 "configure"
@@ -11117,7 +11118,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11142,13 +11143,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11146: checking for SQLConnect in -liodbc" >&5
+echo "configure:11147: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11152 "configure"
+#line 11153 "configure"
@@ -11159,7 +11160,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11184,11 +11185,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11188: checking for ODBC library" >&5
+echo "configure:11189: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 11192 "configure"
+#line 11193 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -11196,7 +11197,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:11200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11216,7 +11217,7 @@
 fi
@@ -11245,7 +11246,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11249: checking whether to use FFTW" >&5
+echo "configure:11250: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11264,7 +11265,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11268: checking for location of FFTW includes" >&5
+echo "configure:11269: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11290,15 +11291,15 @@
 do
-echo "configure:11294: checking for $ac_hdr" >&5
+echo "configure:11295: checking for $ac_hdr" >&5
-#line 11297 "configure"
+#line 11298 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11326,15 +11327,15 @@
 do
-echo "configure:11330: checking for $ac_hdr" >&5
+echo "configure:11331: checking for $ac_hdr" >&5
-#line 11333 "configure"
+#line 11334 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11338: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11362,15 +11363,15 @@
 do
-echo "configure:11366: checking for $ac_hdr" >&5
+echo "configure:11367: checking for $ac_hdr" >&5
-#line 11369 "configure"
+#line 11370 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11374: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11375: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11416,7 +11417,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11420: checking for location of FFTW library" >&5
+echo "configure:11421: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11441,13 +11442,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11445: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11446: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11451 "configure"
+#line 11452 "configure"
@@ -11458,7 +11459,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:11462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11483,13 +11484,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11487: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11488: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 11493 "configure"
+#line 11494 "configure"
@@ -11500,7 +11501,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11525,13 +11526,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11529: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11530: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11535 "configure"
+#line 11536 "configure"
@@ -11542,7 +11543,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11599,7 +11600,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11603: checking whether to use BLAS" >&5
+echo "configure:11604: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -11620,7 +11621,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11624: checking for location of BLAS includes" >&5
+echo "configure:11625: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11640,7 +11641,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11644: checking for location of BLAS library" >&5
+echo "configure:11645: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11666,15 +11667,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11670: checking for $ac_hdr" >&5
+echo "configure:11671: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 11673 "configure"
+#line 11674 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11679: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11699,7 +11700,7 @@
 fi
 done
-CPPFLAGS=$save_CPPFLAGS
+CPPFLAGS="$save_CPPFLAGS"
@@ -11709,13 +11710,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11713: checking for dnrm2_ in -lblas" >&5
+echo "configure:11714: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 11719 "configure"
+#line 11720 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -11726,7 +11727,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -11745,13 +11746,13 @@
-echo "configure:11749: checking for dnrm2_ in -lblas" >&5
+echo "configure:11750: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11755 "configure"
+#line 11756 "configure"
@@ -11762,7 +11763,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11806,13 +11807,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11810: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11811: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 11816 "configure"
+#line 11817 "configure"
@@ -11823,7 +11824,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:11827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11838,13 +11839,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11842: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11843: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 11848 "configure"
+#line 11849 "configure"
@@ -11855,7 +11856,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11870,13 +11871,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11874: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11875: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11880 "configure"
+#line 11881 "configure"
@@ -11887,7 +11888,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:11891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11933,16 +11934,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11937: checking for sgemm in $vlib_flags" >&5
+echo "configure:11938: checking for sgemm in $vlib_flags" >&5
-#line 11939 "configure"
+#line 11940 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -11960,13 +11961,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11964: checking for sgemm_ in -lblas" >&5
+echo "configure:11965: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 11970 "configure"
+#line 11971 "configure"
@@ -11977,7 +11978,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11992,13 +11993,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11996: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11997: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12002 "configure"
+#line 12003 "configure"
@@ -12009,7 +12010,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12024,13 +12025,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12028: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12029: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12034 "configure"
+#line 12035 "configure"
@@ -12041,7 +12042,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12075,13 +12076,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12079: checking for acosp in -lsunmath" >&5
+echo "configure:12080: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12085 "configure"
+#line 12086 "configure"
@@ -12092,7 +12093,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12107,13 +12108,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12111: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12112: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12117 "configure"
+#line 12118 "configure"
@@ -12124,7 +12125,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12154,13 +12155,13 @@
 # Generic BLAS library
-echo "configure:12158: checking for sgemm_ in -lblas" >&5
+echo "configure:12159: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12164 "configure"
+#line 12165 "configure"
@@ -12171,7 +12172,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12210,7 +12211,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12214: checking whether to use LAPACK" >&5
+echo "configure:12215: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12235,7 +12236,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12239: checking for location of LAPACK includes" >&5
+echo "configure:12240: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12255,7 +12256,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12259: checking for location of LAPACK library" >&5
+echo "configure:12260: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12281,15 +12282,15 @@
 do
-echo "configure:12285: checking for $ac_hdr" >&5
+echo "configure:12286: checking for $ac_hdr" >&5
-#line 12288 "configure"
+#line 12289 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12314,17 +12315,17 @@
 fi
 done
 # LAPACK linked to by default?
 if test lapack_ok=no; then
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12325: checking for dsegv_" >&5
+echo "configure:12326: checking for dsegv_" >&5
-#line 12328 "configure"
+#line 12329 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -12347,7 +12348,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -12374,13 +12375,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12378: checking for desgv_ in -llapack" >&5
+echo "configure:12379: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 12384 "configure"
+#line 12385 "configure"
@@ -12391,7 +12392,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12423,13 +12424,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12427: checking for dgesv_ in -llapack" >&5
+echo "configure:12428: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 12433 "configure"
+#line 12434 "configure"
@@ -12440,7 +12441,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12459,13 +12460,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12463: checking for dgesv_ in -llapack" >&5
+echo "configure:12464: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12469 "configure"
+#line 12470 "configure"
@@ -12476,7 +12477,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12532,7 +12533,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12536: checking whether to use Cairo" >&5
+echo "configure:12537: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -12553,12 +12554,12 @@
 fi
 # With Cairo includes directory
+#FIXME: somehow quote dirs with spaces in $cairo ?
 CAIROINC=`pkg-config --cflags $cairo`
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12562: checking for location of cairo includes" >&5
+echo "configure:12563: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12584,15 +12585,15 @@
 do
-echo "configure:12588: checking for $ac_hdr" >&5
+echo "configure:12589: checking for $ac_hdr" >&5
-#line 12591 "configure"
+#line 12592 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12628,7 +12629,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12632: checking for location of cairo library" >&5
+echo "configure:12633: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12648,7 +12649,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12652: checking for cairo linking flags" >&5
+echo "configure:12653: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12664,10 +12665,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12668: checking for cairo_create" >&5
+echo "configure:12669: checking for cairo_create" >&5
-#line 12671 "configure"
+#line 12672 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -12690,7 +12691,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -12724,10 +12725,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12728: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12729: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12731 "configure"
+#line 12732 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -12750,7 +12751,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -12783,10 +12784,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12787: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12788: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12790 "configure"
+#line 12791 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -12809,7 +12810,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -12851,7 +12852,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12855: checking whether to use FreeType" >&5
+echo "configure:12856: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -12870,7 +12871,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12874: checking for location of FreeType includes" >&5
+echo "configure:12875: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12896,15 +12897,15 @@
 do
-echo "configure:12900: checking for $ac_hdr" >&5
+echo "configure:12901: checking for $ac_hdr" >&5
-#line 12903 "configure"
+#line 12904 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12938,7 +12939,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12942: checking for location of FreeType library" >&5
+echo "configure:12943: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12963,13 +12964,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12967: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12968: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 12973 "configure"
+#line 12974 "configure"
@@ -12980,7 +12981,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13021,7 +13022,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13025: checking whether to use NLS" >&5
+echo "configure:13026: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13041,10 +13042,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13045: checking for gettext" >&5
+echo "configure:13046: checking for gettext" >&5
-#line 13048 "configure"
+#line 13049 "configure"
     which can conflict with char gettext(); below.  */
@@ -13067,7 +13068,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13085,13 +13086,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13089: checking for gettext in -lintl" >&5
+echo "configure:13090: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13095 "configure"
+#line 13096 "configure"
@@ -13102,7 +13103,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13137,7 +13138,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13141: checking whether to use C++" >&5
+echo "configure:13142: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13153,7 +13154,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13157: checking for $ac_word" >&5
+echo "configure:13158: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13182,7 +13183,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13186: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13187: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13193,12 +13194,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13197 "configure"
+#line 13198 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13224,19 +13225,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13228: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13229: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13233: checking whether we are using GNU C++" >&5
+echo "configure:13234: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13254,7 +13255,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13258: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13259: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13295,7 +13296,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13299: checking whether to use openDWG" >&5
+echo "configure:13300: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -13315,7 +13316,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13319: checking for location of openDGW includes" >&5
+echo "configure:13320: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13341,15 +13342,15 @@
 do
-echo "configure:13345: checking for $ac_hdr" >&5
+echo "configure:13346: checking for $ac_hdr" >&5
-#line 13348 "configure"
+#line 13349 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13354: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13383,7 +13384,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13387: checking for location of openDWG library" >&5
+echo "configure:13388: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13407,9 +13408,9 @@
 #LOC_CHECK_LIBS(ad?.a,adSeekLayer,openDWG,$OPENDWGLIBPATH,OPENDWGLIB,,)
 #for now hack (but working):
-TRUEOPENDWGLIBPATH=`echo $OPENDWGLIBPATH | cut -b3-`
-adlib=`ls -1 $TRUEOPENDWGLIBPATH/ad?.a | tail -1`
-OPENDWGLIB=$adlib
+TRUEOPENDWGLIBPATH=`echo "$OPENDWGLIBPATH" | cut -b3-`
+adlib=`ls -1 "$TRUEOPENDWGLIBPATH"/ad?.a | tail -1`
+OPENDWGLIB="$adlib"
 fi # $USE_OPENDWG
@@ -13424,7 +13425,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13428: checking whether to use POSIX threads" >&5
+echo "configure:13429: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -13444,7 +13445,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13448: checking for location of POSIX threads includes" >&5
+echo "configure:13449: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13470,15 +13471,15 @@
 do
-echo "configure:13474: checking for $ac_hdr" >&5
+echo "configure:13475: checking for $ac_hdr" >&5
-#line 13477 "configure"
+#line 13478 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13482: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13483: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13512,7 +13513,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13516: checking for location of POSIX threads library" >&5
+echo "configure:13517: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13537,10 +13538,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13541: checking for pthread_create" >&5
+echo "configure:13542: checking for pthread_create" >&5
-#line 13544 "configure"
+#line 13545 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -13563,7 +13564,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13590,13 +13591,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13594: checking for pthread_create in -lpthread" >&5
+echo "configure:13595: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13600 "configure"
+#line 13601 "configure"
@@ -13607,7 +13608,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13663,7 +13664,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13667: checking for special C compiler options needed for large files" >&5
+echo "configure:13668: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13671,7 +13672,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13675 "configure"
+#line 13676 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13687,7 +13688,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13692: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -13696,7 +13697,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13700 "configure"
+#line 13701 "configure"
@@ -13712,7 +13713,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13716: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13717: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13732,11 +13733,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13736: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13737: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13740 "configure"
+#line 13741 "configure"
@@ -13752,14 +13753,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13756: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13763 "configure"
+#line 13764 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13777,7 +13778,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13781: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13782: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13796,11 +13797,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13800: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13801: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13804 "configure"
+#line 13805 "configure"
@@ -13816,14 +13817,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13820: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13821: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13827 "configure"
+#line 13828 "configure"
 #define _LARGE_FILES 1
@@ -13841,7 +13842,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13845: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13846: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13860,25 +13861,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13864: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13865: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13868 "configure"
+#line 13869 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13875: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13876: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13882 "configure"
+#line 13883 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13887,7 +13888,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13891: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13892: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13908,10 +13909,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13912: checking if system supports Large Files at all" >&5
+echo "configure:13913: checking if system supports Large Files at all" >&5
-#line 13915 "configure"
+#line 13916 "configure"
 #include <stdio.h>
@@ -13943,7 +13944,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13947: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13948: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13972,7 +13973,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:13976: checking whether to use Python" >&5
+echo "configure:13977: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -13993,7 +13994,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:13997: checking for $ac_word" >&5
+echo "configure:13998: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14035,15 +14036,15 @@
 do
-echo "configure:14039: checking for $ac_hdr" >&5
+echo "configure:14040: checking for $ac_hdr" >&5
-#line 14042 "configure"
+#line 14043 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14091,7 +14092,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:14095: checking for $ac_word" >&5
+echo "configure:14096: checking for $ac_word" >&5
 case "$SWIG" in
@@ -14153,7 +14154,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14157: checking whether to use wxWidgets" >&5
+echo "configure:14158: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14174,7 +14175,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14178: checking for $ac_word" >&5
+echo "configure:14179: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14222,7 +14223,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14226: checking wxWidgets version" >&5
+echo "configure:14227: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14245,15 +14246,15 @@
 do
-echo "configure:14249: checking for $ac_hdr" >&5
+echo "configure:14250: checking for $ac_hdr" >&5
-#line 14252 "configure"
+#line 14253 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14257: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14327,7 +14328,7 @@
 STRIPFLAG=
-GRASS_HOME=${DSTDIR}
+GRASS_HOME="${DSTDIR}"
 trap '' 1 2 15
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2010-01-21 06:29:33 UTC (rev 40593)
+++ grass/trunk/configure.in	2010-01-21 06:36:14 UTC (rev 40594)
@@ -105,8 +105,8 @@
 # Set GISBASE and GRASS_BIN
-GISBASE=${WINDSTDIR}/dist.${ARCH}
-GRASS_BIN=${DSTDIR}/bin.${ARCH}
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
+GRASS_BIN="${DSTDIR}/bin.${ARCH}"
 AC_SUBST(GISBASE)
 AC_SUBST(GRASS_BIN)
@@ -114,10 +114,10 @@
 # Set GRASS_VERSION_*
 GRASS_VERSION_FILE=include/VERSION
-GRASS_VERSION_MAJOR=`sed -n 1p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_MINOR=`sed -n 2p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_RELEASE=`sed -n 3p ${GRASS_VERSION_FILE}`
-GRASS_VERSION_DATE=`sed -n 4p ${GRASS_VERSION_FILE}`
+GRASS_VERSION_MAJOR=`sed -n 1p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_MINOR=`sed -n 2p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_RELEASE=`sed -n 3p "${GRASS_VERSION_FILE}"`
+GRASS_VERSION_DATE=`sed -n 4p "${GRASS_VERSION_FILE}"`
 GRASS_VERSION_NUMBER=`echo ${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}`
 NAME_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/\..*//'`
 changequote(,)
@@ -506,8 +506,8 @@
 LIBS=""
 AC_SEARCH_LIBS(cuserid,[compat])
-DBMIEXTRALIB=$LIBS
-LIBS=$ac_save_libs
+DBMIEXTRALIB="$LIBS"
+LIBS="$ac_save_libs"
 AC_SUBST(DBMIEXTRALIB)
 # Note: -lxdr -liberty -lws2_32 is for MinGW
@@ -812,6 +812,7 @@
 GGEOS_CFLAGS=
 USE_GEOS=
+# FIXME: "quote" $with_geos ?
 if test "`basename xx/$with_geos`" = "geos-config" ; then
   GEOS_CONFIG="$with_geos"
 fi
@@ -936,7 +937,7 @@
 AC_CHECK_LIB(pq,PQcmdTuples, [AC_DEFINE(HAVE_PQCMDTUPLES)], [
 ], -lcrypt)
-LDFLAGS=${ac_save_ldflags}
+LDFLAGS="${ac_save_ldflags}"
 fi # $USE_POSTGRES
@@ -1182,7 +1183,7 @@
 CFLAGS="$CFLAGS $OPENGLINC"
 LOC_CHECK_LINK(opengl32,[#include <GL/gl.h>],[glEnd();],OpenGL,$OPENGL_LIB_PATH,OPENGLLIB)
 LOC_CHECK_LINK(glu32,[#include <GL/glu.h>],[gluNewQuadric();],GLU,$OPENGL_LIB_PATH,OPENGLULIB,$OPENGLLIB)
@@ -1229,13 +1230,13 @@
 LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
 else
     AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
 fi
@@ -1337,7 +1338,7 @@
 CFLAGS="$CFLAGS $ODBCINC"
 LOC_CHECK_LINK(odbc32,[#include <windows.h>
 #include <sql.h>],[SQLAllocEnv((SQLHENV *)0);],ODBC,$ODBCLIB,ODBCLIB)
@@ -1404,7 +1405,7 @@
 save_CPPFLAGS="$CPPFLAGS"
 CPPFLAGS="$BLASINC $CPPFLAGS"
 AC_CHECK_HEADERS(cblas.h)
 LOC_CHECK_LIBS(blas,dnrm2_,BLAS,$BLASLIB,BLASLIB,$MATHLIB,,,-lg2c)
@@ -1503,7 +1504,7 @@
 CPPFLAGS="$LAPACKINC $CPPFLAGS"
 AC_CHECK_HEADERS(clapack.h)
@@ -1553,7 +1554,7 @@
 fi
 LOC_CHECK_INC_PATH(cairo,cairo,CAIROINC)
@@ -1674,9 +1675,9 @@
-OPENDWGLIB=$adlib
 fi # $USE_OPENDWG
@@ -1912,7 +1913,7 @@
 STRIPFLAG=
 AC_SUBST(STRIPFLAG)
 AC_SUBST(GRASS_HOME)
 AC_OUTPUT(include/Make/Platform.make include/Make/Doxyfile_arch_html include/Make/Doxyfile_arch_latex include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc)
