[GRASS-SVN] r40600 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Thu Jan 21 10:03:12 EST 2010
Author: neteler
Date: 2010-01-21 10:03:12 -0500 (Thu, 21 Jan 2010)
New Revision: 40600
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
Hirotoshi Toyoda: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2010-01-21 14:45:20 UTC (rev 40599)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2010-01-21 15:03:12 UTC (rev 40600)
@@ -7,13 +7,14 @@
# Markus Neteler <neteler at itc.it>, 2004, 2005.
# Naoki Ueda <nao at locapoint.com>, 2010
# Akira Taniguchi <taniguti at apptec.co.jp>, 2010
+# Hirotoshi Toyoda <toyoda at ex.media.osaka-cu.ac.jp>, 2010
msgid ""
msgstr ""
"Project-Id-Version: grassmods_ja\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-01-14 07:12+0100\n"
-"PO-Revision-Date: 2010-01-21 15:43+0100\n"
+"PO-Revision-Date: 2010-01-21 16:00+0100\n"
"Last-Translator: Markus Neteler <neteler osgeo.org>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -3930,143 +3931,134 @@
#: ../raster/r.in.bin/main.c:293
#: ../raster/r.in.bin/main.c:333
-#, fuzzy
msgid "You have to provide all limits of geographic region (n,s,e,w)"
-msgstr "領域の南端"
+msgstr "領域の指定"
#: ../raster/r.in.bin/main.c:295
#: ../raster/r.in.bin/main.c:335
#: ../display/d.grid/main.c:181
-#, fuzzy, c-format
+#, c-format
msgid "Illegal north coordinate <%s>"
-msgstr "変換の基準となる座標を示すファイル"
+msgstr "無効な座標値(北)"
#: ../raster/r.in.bin/main.c:297
#: ../raster/r.in.bin/main.c:337
-#, fuzzy, c-format
+#, c-format
msgid "Illegal south coordinate <%s>"
+msgstr "無効な座標値(南)"
#: ../raster/r.in.bin/main.c:299
#: ../raster/r.in.bin/main.c:339
#: ../display/d.grid/main.c:175
-#, fuzzy, c-format
+#, c-format
msgid "Illegal east coordinate <%s>"
-msgstr "Z座標値"
+msgstr "無効な座標値(東)"
#: ../raster/r.in.bin/main.c:301
#: ../raster/r.in.bin/main.c:341
-#, fuzzy, c-format
+#, c-format
msgid "Illegal west coordinate <%s>"
-msgstr "Z座標値"
+msgstr "無効な座標値(西)"
#: ../raster/r.in.bin/main.c:303
#: ../raster/r.in.bin/main.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number of rows <%s>"
-msgstr "出力するファイル"
+msgstr "無効な列数"
#: ../raster/r.in.bin/main.c:305
#: ../raster/r.in.bin/main.c:316
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number of columns <%s>"
-msgstr "最大反復回数"
+msgstr "無効な行数"
#: ../raster/r.in.bin/main.c:321
#, c-format
msgid "Using N=%f S=%f E=%f W=%f"
-msgstr ""
+msgstr "利用する値 N=%f S=%f E=%f W=%f "
#: ../raster/r.in.bin/main.c:346
-#, fuzzy, c-format
+#, c-format
msgid "Using rows=%d cols=%d\n"
-msgstr "���"
+msgstr "利用する値 rows=%d cols=%d\n"
#: ../raster/r.in.bin/main.c:451
#: ../raster/r.in.bin/main.c:461
#: ../raster/r.in.bin/main.c:473
msgid "Bytes do not match File size"
-msgstr ""
+msgstr "ファイルサイズの不一致"
#: ../raster/r.in.bin/main.c:452
#: ../raster/r.in.bin/main.c:462
#: ../raster/r.in.bin/main.c:474
#, c-format
msgid "File Size %d ... Total Bytes %d"
-msgstr ""
+msgstr "ファイルサイズ %d ... Total Bytes %d "
#: ../raster/r.in.bin/main.c:454
#: ../raster/r.in.bin/main.c:464
#: ../raster/r.in.bin/main.c:476
#, c-format
msgid "Try bytes=%d or adjusting input parameters"
-msgstr ""
+msgstr "試行するbyte値=%d または、補正値の入力 "
#: ../raster/r.in.bin/main.c:510
#, c-format
msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
-msgstr ""
+msgstr "東西 (ewres: %f) と 南北 (nwres: %f)の 解像度が不適切. 適切な値ですか? "
#: ../raster/r.in.bin/main.c:518
#, c-format
msgid "Conversion failed at row %d"
-msgstr ""
+msgstr "行の変換に失敗 %d "
#: ../raster/r.rescale.eq/main.c:54
-#, fuzzy
msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr "ラスターマップのカテゴリー値の範囲を変更します"
+msgstr "ヒストグラムをラスターマップのレイヤーのカテゴリー値の範囲と一致させる"
#: ../raster/r.rescale.eq/main.c:64
#: ../raster/r.rescale/main.c:61
-#, fuzzy
msgid "The name of the raster map to be rescaled"
-msgstr "入力するファイル"
+msgstr "このラスターマップの縮尺を変更"
#: ../raster/r.rescale.eq/main.c:72
#: ../raster/r.rescale/main.c:69
-#, fuzzy
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr "元のカテゴリー値の範囲"
+msgstr "入力データの縮尺を変更(省略時は入力した地図の縮尺)"
#: ../raster/r.rescale.eq/main.c:79
#: ../raster/r.rescale/main.c:76
-#, fuzzy
msgid "The resulting raster map name"
-msgstr "出力するファイル"
+msgstr "出力するラスターマップのファイル名"
#: ../raster/r.rescale.eq/main.c:86
#: ../raster/r.rescale/main.c:83
-#, fuzzy
msgid "The output data range"
-msgstr "変更後のカテゴリー値の範囲"
+msgstr "出力するデータの範囲"
#: ../raster/r.rescale.eq/main.c:93
#: ../raster/r.rescale/main.c:90
-#, fuzzy
msgid "Title for new raster map"
-msgstr "タイトル"
+msgstr "新しいラスターマップのタイトル"
#: ../raster/r.rescale.eq/main.c:146
#, c-format
msgid "Rescale %s[%d,%d] to %s[%d,%d]"
-msgstr ""
+msgstr "縮尺の変更 %s[%d,%d] to %s[%d,%d] "
#: ../raster/r.rescale.eq/get_stats.c:19
#: ../raster/r.rescale/get_range.c:25
-#, fuzzy, c-format
+#, c-format
msgid "Reading %s ..."
-msgstr "���%s ..."
+msgstr "読み込み中%s ..."
#: ../raster/r.drain/main.c:96
-#, fuzzy
msgid "Traces a flow through an elevation model on a raster map."
-msgstr "最小コストで目的地に到達する経路のラスターマップを作成します"
+msgstr "ラスターマップの落水線図の流れをたどる"
#: ../raster/r.drain/main.c:109
-#, fuzzy
msgid "Map coordinates of starting point(s) (E,N)"
-msgstr "始点の座標値"
+msgstr "始点(東、西)の座標値"
#: ../raster/r.drain/main.c:110
#: ../raster/r.drain/main.c:116
@@ -4074,49 +4066,42 @@
#: ../raster/r.cost/main.c:153
#: ../raster/r.cost/main.c:162
#: ../raster/r.cost/main.c:212
-#, fuzzy
msgid "Start"
msgstr "スタート"
#: ../raster/r.drain/main.c:115
-#, fuzzy
msgid "Name of vector map(s) containing starting point(s)"
-msgstr "入力するファイル"
+msgstr "始点を含むベクトル地図名"
#: ../raster/r.drain/main.c:120
-#, fuzzy
msgid "Copy input cell values on output"
-msgstr "ルートに沿ってセル値をコピー"
+msgstr "入力セル値を出力へコピー"
#: ../raster/r.drain/main.c:124
-#, fuzzy
msgid "Accumulate input values along the path"
-msgstr "ルートに沿って累積したセル値を出力"
+msgstr "ルートに沿って累積したセル値"
#: ../raster/r.drain/main.c:128
-#, fuzzy
msgid "Count cell numbers along the path"
msgstr "ルートに沿ってセル数をカウント"
#: ../raster/r.drain/main.c:149
msgid "Specify just one of the -c, -a and -n flags"
-msgstr ""
+msgstr "単一の -c, -a と -n のフラッグを指定 "
#: ../raster/r.drain/main.c:168
-#, fuzzy
msgid "Metrics allocation"
msgstr "ロケーション"
#: ../raster/r.drain/main.c:179
-#, fuzzy, c-format
+#, c-format
msgid "Starting point %d is outside the current region"
-msgstr "領域を更新しない"
+msgstr "始点が現在の範囲外"
#: ../raster/r.drain/main.c:187
#: ../raster/r.drain/main.c:228
-#, fuzzy
msgid "Too many start points"
-msgstr "90度回転"
+msgstr "多すぎる始点の数"
#: ../raster/r.drain/main.c:202
#: ../raster/r.cost/main.c:301
@@ -4207,22 +4192,20 @@
#: ../raster/r.drain/main.c:208
#: ../raster/r.cost/main.c:496
msgid "Failed to guess site file format"
-msgstr ""
+msgstr "サイトファイル形式の予測に失敗"
#: ../raster/r.drain/main.c:234
#, c-format
msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
+msgstr "この範囲内にベクターマップ <%s> の始点がありません"
#: ../raster/r.drain/main.c:240
-#, fuzzy
msgid "No start/stop point(s) specified"
-msgstr "傾斜方位を示すファイル(入力)"
+msgstr "始点・終点が未指定"
#: ../raster/r.drain/main.c:300
-#, fuzzy
msgid "Calculating flow directions..."
-msgstr "入力するファイル"
+msgstr "流動方向を計算中"
#: ../raster/r.drain/main.c:362
#: ../raster/r.drain/main.c:415
@@ -4238,11 +4221,13 @@
"\n"
"Hit RETURN to continue -->"
msgstr ""
+"\n"
+"リターンを押して続行 --> "
#: ../raster/r.support/front/check.c:29
#, c-format
msgid "Update the statistics (histogram, range) for [%s]? "
-msgstr ""
+msgstr "統計情報(ヒストグラム、範囲) [%s] 更新しますか? "
#: ../raster/r.support/front/check.c:35
#, c-format
@@ -4250,6 +4235,8 @@
"\n"
" Updating statistics for [%s]"
msgstr ""
+"\n"
+"統計情報を更新中 [%s] "
#: ../raster/r.support/front/check.c:77
#, c-format
@@ -4257,65 +4244,59 @@
" Updating the number of categories for [%s]\n"
"\n"
msgstr ""
+" カテゴリー数を更新中 [%s]\n"
+"\n"
#: ../raster/r.support/front/front.c:54
-#, fuzzy
msgid "raster, metadata"
-msgstr "入力するファイル"
+msgstr "ラスター、メタデータ"
#: ../raster/r.support/front/front.c:55
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
+msgstr "ラスターマップをサポートするファイルの作成(更新)を許可"
#: ../raster/r.support/front/front.c:65
-#, fuzzy
msgid "Text to use for map title"
-msgstr "タイトル"
+msgstr "マップタイトルのテキスト"
#: ../raster/r.support/front/front.c:73
msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
+msgstr "マップのメタデータファイルに追加する線のテキスト"
#: ../raster/r.support/front/front.c:79
-#, fuzzy
msgid "Text to use for map data units"
-msgstr "タイトル"
+msgstr "マップデータの単位に使うテキスト"
#: ../raster/r.support/front/front.c:85
-#, fuzzy
msgid "Text to use for map vertical datum"
-msgstr "タイトル"
+msgstr "鉛直データに使うテキスト"
#: ../raster/r.support/front/front.c:92
-#, fuzzy
msgid "Text to use for data source, line 1"
-msgstr "タイトル"
+msgstr "1行目のデータソースに使うテキスト"
#: ../raster/r.support/front/front.c:99
-#, fuzzy
msgid "Text to use for data source, line 2"
-msgstr "タイトル"
+msgstr "2行目のデータソースに使うテキスト"
#: ../raster/r.support/front/front.c:107
msgid "Text to use for data description or keyword(s)"
-msgstr ""
+msgstr "データのコメント(キーワード)に使うテキスト"
#: ../raster/r.support/front/front.c:114
#: ../raster/r.cats/main.c:78
-#, fuzzy
msgid "Raster map from which to copy category table"
-msgstr "カラーテーブルに用いるラスターマップ"
+msgstr "カラーテーブルに用いるラスター地図"
#: ../raster/r.support/front/front.c:125
#: ../raster/r.cats/main.c:136
#, c-format
msgid "Raster map <%s> not found in current mapset"
-msgstr ""
+msgstr "ラスターマップ <%s> が使用中のマップセットにありません"
#: ../raster/r.support/front/front.c:143
-#, fuzzy
msgid "Not enough room in history file"
-msgstr "シグネチャファイル"
+msgstr "履歴ファイルが一杯です"
#: ../raster/r.support/front/front.c:230
#: ../raster/r.statistics/main.c:91
@@ -4330,14 +4311,14 @@
msgstr ""
#: ../raster/r.support/front/front.c:234
-#, fuzzy, c-format
+#, c-format
msgid "cats table for [%s] set to %s"
-msgstr "色に用いるラスターマップ"
+msgstr "色に用いるラスター地図"
#: ../raster/r.support/front/front.c:248
#, c-format
msgid "Edit header for [%s]? "
-msgstr ""
+msgstr "[%s] のヘッダーを編集しますか? "
#: ../raster/r.support/front/front.c:250
#, c-format
@@ -4345,25 +4326,27 @@
"\n"
"NOTE: [%s] is a reclass of [%s in %s]"
msgstr ""
+"\n"
+"注意: [%s] は [%s 中の %s] の再分類"
#: ../raster/r.support/front/front.c:264
msgid "Canceling from edit header."
-msgstr ""
+msgstr "ヘッダーの編集をキャンセル "
#: ../raster/r.support/front/front.c:271
#, c-format
msgid "Edit the category file for [%s]? "
-msgstr ""
+msgstr "[%s]のカテゴリーファイルを編集しますか? "
#: ../raster/r.support/front/front.c:281
#, c-format
msgid "Create/Update the color table for [%s]? "
-msgstr ""
+msgstr "[%s] のカラーテーブルを作成(更新)しますか? "
#: ../raster/r.support/front/front.c:292
#, c-format
msgid "Edit the history file for [%s]? "
-msgstr ""
+msgstr "[%s] の履歴を編集しますか? "
#: ../raster/r.support/front/front.c:302
#, c-format
@@ -4373,29 +4356,35 @@
" no data. If the null file for [%s] doesn't exist, zero cells in\n"
" it are treated by GRASS application programs as no data."
msgstr ""
+"\n"
+"[%s] の null ファイルは空のセルを含んでいると表示されるかもしれません\n"
+"もし [%s] の null ファイルがない場合、GRASSはゼロ値のセルを\n"
+"データが無いと判断します "
#: ../raster/r.support/front/front.c:308
-#, c-format
+#, fuzzy, c-format
msgid ""
"\n"
"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
msgstr ""
+"\n"
+"Do you want to create/re集合 the null ファイル for [%s] so that null セル values are considered valid data? "
#: ../raster/r.support/front/front.c:317
#: ../raster/r.support/front/front.c:354
-#, c-format
+#, fuzzy, c-format
msgid "[%s] is a reclass of another map. Exiting."
-msgstr ""
+msgstr "[%s] is a reクラス of another map. Exiting. "
#: ../raster/r.support/front/front.c:329
#, c-format
msgid "Writing new null file for [%s]... "
-msgstr ""
+msgstr "[%s] のnullファイルを書き込み中 "
#: ../raster/r.support/front/front.c:334
#, c-format
msgid "Error writing null row [%d]."
-msgstr ""
+msgstr "エラーを null 行 [%d] に書き込み中 "
#: ../raster/r.support/front/front.c:346
#, c-format
@@ -4404,82 +4393,88 @@
"Do you want to delete the null file for [%s]\n"
"(all zero cells will then be considered no data)? "
msgstr ""
+"\n"
+"[%s] の null ファイルを消去\n"
+"(ゼロ値のセルはデータ無しとして処理)? "
#: ../raster/r.support/front/front.c:360
#, c-format
msgid "Removing null file for [%s]...\n"
msgstr ""
+"[%s] の null ファイルを削除中.\n"
#: ../raster/r.support/front/front.c:367
#: ../display/d.what.vect/main.c:172
msgid "Done."
-msgstr ""
+msgstr "完了"
#: ../raster/r.support/modhead/ask_format.c:24
#, c-format
msgid "Please enter the following information for [%s]:"
-msgstr ""
+msgstr "[%s] のための情報を順次入力してください"
#: ../raster/r.support/modhead/ask_format.c:29
-#, fuzzy
msgid " Number of rows"
msgstr "行数"
#: ../raster/r.support/modhead/ask_format.c:30
-#, fuzzy
msgid " Number of cols"
msgstr "列数"
#: ../raster/r.support/modhead/ask_format.c:32
-#, fuzzy
msgid " Number of bytes per cell"
msgstr "1セルのバイト数"
#: ../raster/r.support/modhead/ask_format.c:33
-#, fuzzy
msgid " Floating point map"
-msgstr "目的ファイルを含むロケーション"
+msgstr "浮動小数点での地図"
#: ../raster/r.support/modhead/ask_format.c:51
-#, c-format
+#, fuzzy, c-format
msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-msgstr ""
+msgstr "rows * cols * bytes per セル must be same as ファイル size (%lu) "
#: ../raster/r.support/modhead/ask_format.c:55
+#, fuzzy
msgid "If you need help figuring them out, just hit ESC"
-msgstr ""
+msgstr "If you need help figu輪 them out, just hit ESC "
#: ../raster/r.support/modhead/ask_format.c:76
+#, fuzzy
msgid "** Negative values not allowed!"
-msgstr ""
+msgstr "** Negative values not allowed! "
#: ../raster/r.support/modhead/ask_format.c:79
+#, fuzzy
msgid "** Positive values only please!"
-msgstr ""
+msgstr "** Positive values only please! "
#: ../raster/r.support/modhead/modhead.c:70
-#, c-format
+#, fuzzy, c-format
msgid "Edit header for [%s]\n"
msgstr ""
+"編集 header for [%s]\n"
#: ../raster/r.support/modhead/modhead.c:73
-#, c-format
+#, fuzzy, c-format
msgid "[%s] cannot be found!"
-msgstr ""
+msgstr "[%s] cannot be found! "
#: ../raster/r.support/modhead/modhead.c:76
+#, fuzzy
msgid "For what layer shall the header file be edited? "
-msgstr ""
+msgstr "For what レイヤー, 層 shall the ヘッダーファイル be edited? "
#: ../raster/r.support/modhead/modhead.c:86
-#, c-format
+#, fuzzy, c-format
msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-msgstr ""
+msgstr "[%s] is a reクラス of [%s] - cannot 編集 header! Run support on [%s]. "
#: ../raster/r.support/modhead/modhead.c:90
-#, c-format
+#, fuzzy, c-format
msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-msgstr ""
+msgstr "[%s] is a reクラス of [%s in %s] - cannot 編集 header! "
#: ../raster/r.support/modhead/modhead.c:96
#, fuzzy, c-format
@@ -4487,9 +4482,9 @@
msgstr "出力するファイル"
#: ../raster/r.support/modhead/modhead.c:101
-#, c-format
+#, fuzzy, c-format
msgid "Raster file [%s] is empty."
-msgstr ""
+msgstr "ラスタ ファイル [%s] is empty. "
#: ../raster/r.support/modhead/modhead.c:103
#, fuzzy, c-format
@@ -4497,28 +4492,37 @@
msgstr "出力するファイル"
#: ../raster/r.support/modhead/modhead.c:191
-#, c-format
+#, fuzzy, c-format
msgid "cellhd compression: %d\n"
msgstr ""
+"cellhd compression: %d\n"
#: ../raster/r.support/modhead/modhead.c:192
-#, c-format
+#, fuzzy, c-format
msgid "3.0 compression %sindicated\n"
msgstr ""
+"3.0 圧縮 %sindicated\n"
#: ../raster/r.support/modhead/modhead.c:194
-#, c-format
+#, fuzzy, c-format
msgid "Pre 3.0 compression %sindicated\n"
msgstr ""
+"Pre 3.0 圧縮 %sindicated\n"
#: ../raster/r.support/modhead/modhead.c:201
-#, c-format
+#, fuzzy, c-format
msgid "[%s] appears to be compressed. Is it? "
-msgstr ""
+msgstr "[%s] appears to be compressed. Is it? "
#: ../raster/r.support/modhead/modhead.c:207
+#, fuzzy
msgid "Please indicate the type of compression:\n"
msgstr ""
+"Please indicate the 型 of compression:\n"
#: ../raster/r.support/modhead/modhead.c:208
#, fuzzy
@@ -4531,9 +4535,9 @@
msgstr "圧縮形式"
#: ../raster/r.support/modhead/modhead.c:245
-#, c-format
+#, fuzzy, c-format
msgid "The header for [%s] says the file is not compressed. "
-msgstr ""
+msgstr "The header for [%s] says the ファイル is not compressed. "
#: ../raster/r.support/modhead/modhead.c:247
#, fuzzy
@@ -4542,22 +4546,28 @@
#: ../raster/r.support/modhead/modhead.c:248
#: ../raster/r.support/modhead/modhead.c:257
+#, fuzzy
msgid "Most likely the header is wrong, but I want you to decide.\n"
msgstr ""
+"Most likely the header is wrong, but I want you to decide.\n"
#: ../raster/r.support/modhead/modhead.c:254
-#, c-format
+#, fuzzy, c-format
msgid "The header for [%s] says the file is compressed. "
-msgstr ""
+msgstr "The header for [%s] says the ファイル is compressed. "
#: ../raster/r.support/modhead/modhead.c:256
+#, fuzzy
msgid "The file does NOT appear to be compressed.\n"
msgstr ""
+"The ファイル does NOT appear to be compressed.\n"
#: ../raster/r.support/modhead/modhead.c:271
-#, c-format
+#, fuzzy, c-format
msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-msgstr ""
+msgstr "Header indicates %d row%s in the ラスタ map, but the actual ファイル 形式, 書式, 初期化 indicates %d row%s "
#: ../raster/r.support/modhead/modhead.c:303
#, fuzzy, c-format
@@ -4570,14 +4580,18 @@
msgstr "入力するファイル"
#: ../raster/r.support/modhead/hitreturn.c:12
+#, fuzzy
msgid ""
"\n"
"hit RETURN to continue -->"
msgstr ""
+"\n"
+"hit RETURN to continue --> "
#: ../raster/r.support/modcolr/modcolr.c:38
+#, fuzzy
msgid "Which raster map needs a color table"
-msgstr ""
+msgstr "Which ラスタ地図 needs a color 表 "
#: ../raster/r.support/modcolr/modcolr.c:53
#, fuzzy, c-format
@@ -4585,8 +4599,9 @@
#: ../raster/r.support/modhist/modhist.c:38
+#, fuzzy
msgid "Which raster map needs an updated history? "
-msgstr ""
+msgstr "Which ラスタ地図 needs an updated history? "
#: ../raster/r.support/modhist/modhist.c:46
#, fuzzy, c-format
@@ -4599,17 +4614,19 @@
#: ../raster/r.support/modhist/modhist.c:53
-#, c-format
+#, fuzzy, c-format
msgid "History file for [%s] not updated."
-msgstr ""
+msgstr "歴史 ファイル for [%s] not updated. "
#: ../raster/r.support/modcats/modcats.c:46
+#, fuzzy
msgid "Which vector map needs updated categories?"
-msgstr ""
+msgstr "?"
#: ../raster/r.support/modcats/modcats.c:49
+#, fuzzy
msgid "Which raster map needs updated categories?"
-msgstr ""
+msgstr "Which ラスタ地図 needs updated categories? "
#: ../raster/r.support/modcats/modcats.c:53
#: ../raster/r.support/modcats/modcats.c:62
@@ -4634,8 +4651,9 @@
msgstr "入力するファイル"
#: ../raster/r.lake/main.c:149
+#, fuzzy
msgid "Fills lake from seed at given level."
-msgstr ""
+msgstr "Fills lake from 面識別点 at given level. "
#: ../raster/r.lake/main.c:154
#, fuzzy
@@ -4658,9 +4676,8 @@
msgstr "Z座標値"
#: ../raster/r.lake/main.c:185
-#, fuzzy
msgid "Name of raster map with seed (at least 1 cell > 0)"
-msgstr "<%s>に対応させるラスターマップ"
+msgstr "<%s>に対応させるラスター地図"
#: ../raster/r.lake/main.c:193
#, fuzzy
@@ -4668,28 +4685,34 @@
msgstr "サイトマップをラスターマップに変換します"
#: ../raster/r.lake/main.c:198
+#, fuzzy
msgid "Overwrite seed map with result (lake) map"
-msgstr ""
+msgstr "Overwrite 面識別点 地図 with result (lake) 地図 "
#: ../raster/r.lake/main.c:206
+#, fuzzy
msgid "Both seed map and coordinates cannot be specified"
-msgstr ""
+msgstr "Both 面識別点 地図 and coordinates cannot be specified "
#: ../raster/r.lake/main.c:209
+#, fuzzy
msgid "Seed map or seed coordinates must be set!"
-msgstr ""
+msgstr "面識別点 地図 or 面識別点 coordinates must be set! "
#: ../raster/r.lake/main.c:212
+#, fuzzy
msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
+msgstr "面識別点 coordinates and output 地図 lake= must be set! "
#: ../raster/r.lake/main.c:215
+#, fuzzy
msgid "Both lake and overwrite cannot be specified"
-msgstr ""
+msgstr "Both lake and overwrite cannot be specified "
#: ../raster/r.lake/main.c:218
+#, fuzzy
msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
+msgstr "Output lake 地図 or overwrite flag must be set! "
#: ../raster/r.lake/main.c:248
#, fuzzy
@@ -4702,27 +4725,29 @@
msgstr "入力するファイル"
#: ../raster/r.lake/main.c:303
+#, fuzzy
msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
-msgstr ""
+msgstr "Given 水位 at 面識別点 点 is below earth surface. Increase 水位 or move 面識別点 point. "
#: ../raster/r.lake/main.c:386
-#, c-format
+#, fuzzy, c-format
msgid "Lake depth from %f to %f"
-msgstr ""
+msgstr "Lake 深度, 深さ from %f to %f "
#: ../raster/r.lake/main.c:387
-#, c-format
+#, fuzzy, c-format
msgid "Lake area %f square meters"
-msgstr ""
+msgstr "Lake 地域 %f square meters "
#: ../raster/r.lake/main.c:388
-#, c-format
+#, fuzzy, c-format
msgid "Lake volume %f cubic meters"
-msgstr ""
+msgstr "Lake volume %f cubic meters "
#: ../raster/r.lake/main.c:389
+#, fuzzy
msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
+msgstr "Volume is correct only if lake 深度, 深さ (ter雨 ラスタ map) is in meters "
#: ../raster/r.lake/main.c:407
#: ../raster/r.composite/main.c:167
@@ -4738,7 +4763,7 @@
#: ../raster/r.surf.idw/main.c:71
#, fuzzy
msgid "Surface interpolation utility for raster map."
-msgstr "データ点から補間計算により曲面を推定します"
+msgstr "色"
#: ../raster/r.surf.idw/main.c:81
#: ../raster/r.surf.idw2/main.c:72
@@ -4753,9 +4778,9 @@
msgstr "誤差を出力"
#: ../raster/r.surf.idw/main.c:92
-#, c-format
+#, fuzzy, c-format
msgid "Illegal value for '%s' (%s)"
-msgstr ""
+msgstr " "
#: ../raster/r.surf.idw/main.c:233
#, fuzzy, c-format
@@ -4902,7 +4927,7 @@
#: ../raster/r.stats/main.c:208
#, fuzzy, c-format
msgid "Unable to open file <%s> for writing"
-msgstr "入力するファイル"
+msgstr "Unable to open ファイル <%s> for writing "
#: ../raster/r.stats/main.c:214
#, c-format
@@ -4916,19 +4941,19 @@
msgstr "対象マップ"
#: ../raster/r.stats/main.c:284
-#, c-format
+#, fuzzy, c-format
msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
-msgstr ""
+msgstr "ラスタ地図 <%s> is reading as 整数 map! Flag '-%c' and/or '%s' option will be ignored. "
#: ../raster/r.stats/main.c:301
#, fuzzy, c-format
msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
-msgstr "������"
+msgstr "Cats for ラスタ地図 <%s> are either missing or have no explicit labels. Using %s=%d. "
#: ../raster/r.stats/main.c:308
-#, c-format
+#, fuzzy, c-format
msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
-msgstr ""
+msgstr "Flag '-%c' was given, using cats fp ranges of ラスタ地図 <%s>, igno輪 '%s' option "
#: ../raster/r.stats/main.c:342
#, fuzzy, c-format
@@ -4952,61 +4977,62 @@
msgstr "対象マップ"
#: ../raster/r.compress/main.c:77
-#, fuzzy
msgid "Uncompress the map"
-msgstr "解凍"
+msgstr "マップを解凍"
#: ../raster/r.compress/main.c:117
-#, fuzzy, c-format
+#, c-format
msgid "[%s] not found"
-msgstr "入力するファイル"
+msgstr "見つかりません"
#: ../raster/r.compress/main.c:123
-#, c-format
+#, fuzzy, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
+msgstr "[%s] is a reクラス ファイル of 地図 <%s> in map集合 <%s> - can't uncompress "
#: ../raster/r.compress/main.c:125
-#, c-format
+#, fuzzy, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
+msgstr "[%s] is a reクラス ファイル of 地図 <%s> in map集合 <%s> - can't compress "
#: ../raster/r.compress/main.c:168
-#, c-format
+#, fuzzy, c-format
msgid "DONE: uncompressed file is %lu bytes smaller"
-msgstr ""
+msgstr "DONE: uncompressed ファイル is %lu bytes smaller "
#: ../raster/r.compress/main.c:169
-#, c-format
+#, fuzzy, c-format
msgid "DONE: compressed file is %lu bytes smaller"
-msgstr ""
+msgstr "DONE: compressed ファイル is %lu bytes smaller "
#: ../raster/r.compress/main.c:173
-#, c-format
+#, fuzzy, c-format
msgid "DONE: uncompressed file is %lu bytes bigger"
-msgstr ""
+msgstr "DONE: uncompressed ファイル is %lu bytes bigger "
#: ../raster/r.compress/main.c:174
-#, c-format
+#, fuzzy, c-format
msgid "DONE: compressed file is %lu bytes bigger"
-msgstr ""
+msgstr "DONE: compressed ファイル is %lu bytes bigger "
#: ../raster/r.compress/main.c:196
-#, c-format
+#, fuzzy, c-format
msgid "[%s] already uncompressed"
-msgstr ""
+msgstr "[%s] already uncompressed "
#: ../raster/r.compress/main.c:200
-#, c-format
+#, fuzzy, c-format
msgid "[%s] already compressed"
-msgstr ""
+msgstr "[%s] already compressed "
#: ../raster/r.compress/main.c:204
-#, c-format
+#, fuzzy, c-format
msgid ""
"\n"
"%sCOMPRESS [%s]"
msgstr ""
+"\n"
+"%sCOMPRESS [%s] "
#: ../raster/r.circle/dist.c:53
#, fuzzy
@@ -5019,29 +5045,32 @@
msgstr "格子点の座標を出力"
#: ../raster/r.circle/dist.c:69
+#, fuzzy
msgid "Minimum radius for ring/circle map (in meters)"
-msgstr ""
+msgstr "Minimum radius for ring/circle 地図 (in meters) "
#: ../raster/r.circle/dist.c:75
+#, fuzzy
msgid "Maximum radius for ring/circle map (in meters)"
-msgstr ""
+msgstr "Maximum radius for ring/circle 地図 (in meters) "
#: ../raster/r.circle/dist.c:81
msgid "Data value multiplier"
-msgstr ""
+msgstr "データの値が重複"
#: ../raster/r.circle/dist.c:85
-#, fuzzy
msgid "Generate binary raster map"
-msgstr "出力するファイル"
+msgstr "バイナリ形式のラスターマップを作成"
#: ../raster/r.circle/dist.c:108
+#, fuzzy
msgid "Please specify a radius in which min < max"
-msgstr ""
+msgstr "Please specify a radius in which min < max "
#: ../raster/r.circle/dist.c:116
+#, fuzzy
msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
+msgstr "Please specify min and/or max radius when using the バイナリ, 二進法 flag "
#: ../raster/r.sun/main.c:295
#, fuzzy
@@ -5054,12 +5083,14 @@
msgstr "入力するファイル"
#: ../raster/r.sun/main.c:418
+#, fuzzy
msgid "time and insol_time are incompatible options"
-msgstr ""
+msgstr "time and insol_time are incompatible options "
#: ../raster/r.sun/main.c:419
+#, fuzzy
msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-msgstr ""
+msgstr "モード 1: instantaneous solar incidence angle & ir放射, 放射輝度 given a 集合 local time "
#: ../raster/r.sun/main.c:529
#, fuzzy, c-format
@@ -5107,19 +5138,19 @@
#: ../raster/r.sun/main.c:757
#: ../raster/r.sun/main.c:764
#: ../raster/r.horizon/main.c:622
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create raster map %s"
-msgstr "NULL値に代入する値"
+msgstr "ラスターマップを作成できない"
#: ../raster/r.sun/main.c:772
-#, c-format
+#, fuzzy, c-format
msgid "rows changed from %d to %d"
-msgstr ""
+msgstr "rows changed from %d to %d "
#: ../raster/r.sun/main.c:775
-#, c-format
+#, fuzzy, c-format
msgid "cols changed from %d to %d"
-msgstr ""
+msgstr "cols changed from %d to %d "
#: ../raster/r.sun/main.c:1347
#: ../raster/r.horizon/main.c:823
@@ -5147,54 +5178,64 @@
#: ../ps/ps.map/do_geogrid.c:419
#: ../ps/ps.map/do_geogrid.c:427
#: ../ps/ps.map/do_geogrid.c:431
+#, fuzzy
msgid "Error in pj_do_proj"
-msgstr ""
+msgstr "エラー in pj_do_proj "
#: ../raster/r.out.vtk/main.c:79
-#, fuzzy, c-format
+#, c-format
msgid "RGB raster map <%s> not found"
-msgstr "対象マップ"
+msgstr "RGBラスターマップ<%s>がありません"
#: ../raster/r.out.vtk/main.c:86
+#, fuzzy
msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-msgstr ""
+msgstr "Cannot create 三原色 data, please provide three maps [r,g,b] "
#: ../raster/r.out.vtk/main.c:102
#, c-format
msgid "Vector cell map <%s> not found"
-msgstr ""
+msgstr "ベクターセルマップ <%s> がありません "
#: ../raster/r.out.vtk/main.c:109
+#, fuzzy
msgid "Cannot create vector data, please provide three maps [x,y,z]"
-msgstr ""
+msgstr "Cannot create ベクトル data, please provide three maps [x,y,z] "
#: ../raster/r.out.vtk/main.c:149
+#, fuzzy
msgid "Converts raster maps into the VTK-Ascii format"
-msgstr ""
+msgstr "Converts ラスタ maps into the VTK-Ascii 形式, 書式, 初期化 "
#: ../raster/r.out.vtk/main.c:215
#: ../raster/r.out.vtk/main.c:280
#: ../raster/r.out.vtk/main.c:307
#: ../raster/r.out.vtk/main.c:353
-#, fuzzy, c-format
+#, c-format
msgid "Open Raster file %s"
-msgstr "出力するファイル"
+msgstr "ラスターファイル<%s>を開く"
#: ../raster/r.out.vtk/main.c:324
msgid "Writing VTK ImageData\n"
msgstr ""
+"VTK イメージデータを書き込み中\n"
#: ../raster/r.out.vtk/main.c:334
+#, fuzzy
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
+msgstr "Wrong 三原色 maps. Maps should have the same type! 三原色 output not added! "
#: ../raster/r.out.vtk/main.c:371
+#, fuzzy
msgid "Writing VTK Vector Data\n"
msgstr ""
+"Writing VTK ベクトル Data\n"
#: ../raster/r.out.vtk/main.c:381
+#, fuzzy
msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
+msgstr "Wrong ベクトル maps. Maps should have the same type! ベクトル output not added! "
#: ../raster/r.out.vtk/parameters.c:46
#, fuzzy
@@ -5207,56 +5248,69 @@
msgstr "データのないセルに代入する記号"
#: ../raster/r.out.vtk/parameters.c:60
+#, fuzzy
msgid "Elevation (if no elevation map is specified)"
-msgstr ""
+msgstr "標高 (if no 標高 地図 is specified) "
#: ../raster/r.out.vtk/parameters.c:66
+#, fuzzy
msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
+msgstr "Create VTK 点 データ instead of VTK セル データ (if no 標高 地図 is given) "
#: ../raster/r.out.vtk/parameters.c:76
+#, fuzzy
msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
+msgstr "Three (r,g,b) ラスタ maps to create 三原色 values [redmap,greenmap,bluemap] "
#: ../raster/r.out.vtk/parameters.c:86
+#, fuzzy
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
+msgstr "Three (x,y,z) ラスタ maps to create ベクトル values [xmap,ymap,zmap] "
#: ../raster/r.out.vtk/parameters.c:111
+#, fuzzy
msgid "Use structured grid for elevation (not recommended)"
-msgstr ""
+msgstr "Use structured 格子 for 標高 (not recommended) "
#: ../raster/r.out.vtk/parameters.c:117
+#, fuzzy
msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
+msgstr "Use polydata-trianglestrips for 標高 格子 creation "
#: ../raster/r.out.vtk/parameters.c:123
+#, fuzzy
msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
+msgstr "Use polydata-vertices for 標高 格子 creation (to use with vtkDelauny2D) "
#: ../raster/r.out.vtk/parameters.c:129
+#, fuzzy
msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
+msgstr "縮尺 要因 effects the 原点 (if no 標高 地図 is given) "
#: ../raster/r.out.vtk/writeascii.c:74
+#, fuzzy
msgid "write_vtk_normal_header: Writing VTK-Header"
-msgstr ""
+msgstr "write_vtk_normal_header: Writing VTK-Header "
#: ../raster/r.out.vtk/writeascii.c:107
+#, fuzzy
msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
-msgstr ""
+msgstr "write_vtk_structured_elevation_header: Writing VTK-Header "
#: ../raster/r.out.vtk/writeascii.c:123
+#, fuzzy
msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
-msgstr ""
+msgstr "write_vtk_polygonal_elevation_header: Writing VTK-Header "
#: ../raster/r.out.vtk/writeascii.c:138
+#, fuzzy
msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
-msgstr ""
+msgstr "write_vtk_celldata_header: Writing VTK-DataHeader "
#: ../raster/r.out.vtk/writeascii.c:147
+#, fuzzy
msgid "writeVTKPointHeader: Writing VTK-DataHeader"
-msgstr ""
+msgstr "writeVTKPointHeader: Writing VTK-DataHeader "
#: ../raster/r.out.vtk/writeascii.c:168
#, fuzzy
@@ -5272,37 +5326,46 @@
#: ../raster/r.out.vtk/writeascii.c:471
#: ../raster/r.out.vtk/writeascii.c:475
#: ../raster/r.out.vtk/writeascii.c:479
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read row %i\n"
-msgstr "出力するファイル"
+msgstr "行を読めません%i\n"
#: ../raster/r.out.vtk/writeascii.c:227
+#, fuzzy
msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr ""
+msgstr "write_vtk_polygonal_coordinates: Writing VTK Polygonal データ "
#: ../raster/r.out.vtk/writeascii.c:339
+#, fuzzy
msgid "write_vtk_data: Writing VTK-Data"
-msgstr ""
+msgstr "write_vtk_data: Writing VTK-データ "
#: ../raster/r.out.vtk/writeascii.c:392
+#, fuzzy
msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
-msgstr ""
+msgstr "write_vtk_rgb_image_data: Writing VTK-Imageデータ "
#: ../raster/r.out.vtk/writeascii.c:429
+#, fuzzy
msgid "Wrong map values! Values should in between 0 and 255!\n"
msgstr ""
+"Wrong 地図 values! Values should in between 0 and 255!\n"
#: ../raster/r.out.vtk/writeascii.c:459
+#, fuzzy
msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr ""
+msgstr "write_vtk_vector_data: Writing VTK-ベクトルデータ "
#: ../raster/r.quant/main.c:43
+#, fuzzy
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
+msgstr "Produces the quantization ファイル for a floating-点 map. "
#: ../raster/r.quant/main.c:51
+#, fuzzy
msgid "Base map to take quant rules from"
-msgstr ""
+msgstr "基本図, 基図 to take quant rules from "
#: ../raster/r.quant/main.c:59
#, fuzzy
@@ -5310,30 +5373,29 @@
msgstr "対象マップ"
#: ../raster/r.quant/main.c:64
+#, fuzzy
msgid "Floating point range: dmin,dmax"
-msgstr ""
+msgstr "浮点 range: dmin,dmax "
#: ../raster/r.quant/main.c:72
msgid "Integer range: min,max"
-msgstr ""
+msgstr "整数の範囲: min,max "
#: ../raster/r.quant/main.c:79
msgid "Truncate floating point data"
-msgstr ""
+msgstr "浮点小数点データを切り捨てる"
#: ../raster/r.quant/main.c:83
-#, fuzzy
msgid "Round floating point data"
-msgstr "倍精度の浮動小数点データをインポート"
+msgstr "浮動小数点データを丸める"
#: ../raster/r.quant/main.c:111
msgid "Truncating..."
-msgstr ""
+msgstr "切捨て処理中、、、"
#: ../raster/r.quant/main.c:116
-#, fuzzy
msgid "Rounding..."
-msgstr "入力するファイル"
+msgstr "丸め処理中、、、"
#: ../raster/r.quant/main.c:144
#, c-format
@@ -18159,9 +18221,8 @@
msgstr "統一する属性の値"
#: ../vector/v.db.select/main.c:53
-#, fuzzy
msgid "Prints vector map attributes."
-msgstr "���"
+msgstr ""
#: ../vector/v.db.select/main.c:64
#: ../vector/v.db.select/main.c:70
@@ -18557,9 +18618,9 @@
msgstr "入力するファイル"
#: ../vector/v.to.db/update.c:211
-#, fuzzy, c-format
+#, c-format
msgid "Record (cat %d) already exists (not inserted)"
-msgstr "���."
+msgstr ""
#: ../vector/v.to.db/update.c:219
#: ../vector/v.to.3d/trans3.c:128
@@ -18657,9 +18718,8 @@
msgstr "入力するファイル"
#: ../vector/v.to.db/query.c:93
-#, fuzzy
msgid "Querying database... "
-msgstr "���%s ..."
+msgstr ""
#: ../vector/v.to.db/query.c:108
#, c-format
@@ -20375,9 +20435,9 @@
msgstr "キーカラム"
#: ../vector/v.distance/main.c:302
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr "���"
+msgstr ""
#: ../vector/v.distance/main.c:373
#: ../vector/v.distance/main.c:407
@@ -20531,14 +20591,13 @@
msgstr "出力するファイル"
#: ../vector/v.in.sites/main.c:255
-#, fuzzy, c-format
+#, c-format
msgid "%d sites written."
-msgstr "���"
+msgstr ""
#: ../vector/v.random/main.c:85
-#, fuzzy
msgid "Randomly generate a 2D/3D vector points map."
-msgstr "���."
+msgstr ""
#: ../vector/v.random/main.c:93
#, fuzzy
@@ -20705,9 +20764,9 @@
msgstr ""
#: ../vector/v.out.ascii/out.c:111
-#, fuzzy, c-format
+#, c-format
msgid "Parameter '%s' ignored in standard mode"
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ascii/out.c:119
msgid "Format 'point' is not supported for old version"
@@ -20808,9 +20867,8 @@
#: ../vector/v.label.sa/main.c:181
#: ../vector/v.label/main.c:201
-#, fuzzy
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr "���"
+msgstr ""
#: ../vector/v.label.sa/main.c:200
msgid "Border width (only for ps.map output)"
@@ -20840,9 +20898,8 @@
msgstr ""
#: ../vector/v.label.sa/labels.c:103
-#, fuzzy
msgid "Font file can not be loaded"
-msgstr "���"
+msgstr ""
#: ../vector/v.label.sa/labels.c:112
#, fuzzy
@@ -21198,9 +21255,8 @@
msgstr "入力するファイル"
#: ../vector/v.lrs/v.lrs.where/main.c:69
-#, fuzzy
msgid "Input vector map containing points"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.where/main.c:74
#: ../vector/v.lrs/v.lrs.create/main.c:144
@@ -21294,9 +21350,8 @@
msgstr "出力するファイル"
#: ../vector/v.lrs/v.lrs.create/main.c:140
-#, fuzzy
msgid "Input vector map containing reference points"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:155
msgid "Column containing line identifiers for lines"
@@ -21343,9 +21398,8 @@
msgstr "入力するファイル"
#: ../vector/v.lrs/v.lrs.create/main.c:279
-#, fuzzy
msgid "Cannot get layer info for points"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:314
#, fuzzy, c-format
@@ -21457,9 +21511,8 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:111
-#, fuzzy
msgid "Output vector map where stationing will be written"
-msgstr "���."
+msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:146
#, fuzzy
@@ -21487,9 +21540,8 @@
msgstr "ショートヘルプを表示"
#: ../vector/v.lrs/v.lrs.label/main.c:202
-#, fuzzy
msgid "Line width of text"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:203
#: ../vector/v.lrs/v.lrs.label/main.c:211
@@ -21499,9 +21551,8 @@
msgstr "バイナリ-による出力"
#: ../vector/v.lrs/v.lrs.label/main.c:220
-#, fuzzy
msgid "Line width of highlight color"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:246
#, fuzzy
@@ -21509,9 +21560,8 @@
msgstr "出力するファイル"
#: ../vector/v.lrs/v.lrs.label/main.c:247
-#, fuzzy
msgid "Only relevant if background color is selected"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:338
#, fuzzy, c-format
@@ -21533,9 +21583,8 @@
msgstr "線に沿って点を補間"
#: ../vector/v.lrs/v.lrs.segment/main.c:80
-#, fuzzy
msgid "Output vector map where segments will be written"
-msgstr "���."
+msgstr ""
#: ../vector/v.lrs/v.lrs.segment/main.c:112
#: ../vector/v.segment/main.c:71
@@ -21561,9 +21610,9 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:202
#: ../vector/v.lrs/v.lrs.segment/main.c:289
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find line of cat [%d]"
-msgstr "���"
+msgstr ""
#: ../vector/v.lrs/v.lrs.segment/main.c:212
#, c-format
@@ -21710,9 +21759,9 @@
msgstr "入力するファイル"
#: ../vector/v.reclass/main.c:317
-#, fuzzy, c-format
+#, c-format
msgid "Category %d overwritten by '%s'"
-msgstr "���"
+msgstr ""
#: ../vector/v.reclass/main.c:321
#, fuzzy, c-format
@@ -21720,9 +21769,9 @@
#: ../vector/v.reclass/main.c:325
-#, fuzzy, c-format
+#, c-format
msgid "Label '%s' overwritten by '%s'"
-msgstr "���"
+msgstr ""
#: ../vector/v.reclass/main.c:331
#, c-format
@@ -21750,9 +21799,9 @@
msgstr "収束率"
#: ../vector/v.reclass/main.c:428
-#, fuzzy, c-format
+#, c-format
msgid "%d features reclassed."
-msgstr "���"
+msgstr ""
#: ../vector/v.kernel/main.c:72
#, c-format
@@ -21764,24 +21813,20 @@
msgstr ""
#: ../vector/v.kernel/main.c:111
-#, fuzzy
msgid "Generates a raster density map from vector points data using a moving 2D isotropic Gaussian kernel or optionally generates a vector density map on vector network with a 1D kernel."
-msgstr "��� ��� ���"
+msgstr ""
#: ../vector/v.kernel/main.c:115
-#, fuzzy
msgid "Input vector with training points"
-msgstr "���"
+msgstr ""
#: ../vector/v.kernel/main.c:119
-#, fuzzy
msgid "Input network vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.kernel/main.c:127
-#, fuzzy
msgid "Output raster/vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.kernel/main.c:133
#, fuzzy
@@ -21816,9 +21861,9 @@
msgstr ""
#: ../vector/v.kernel/main.c:230
-#, fuzzy, c-format
+#, c-format
msgid "Network input map <%s> not found"
-msgstr "���"
+msgstr ""
#: ../vector/v.kernel/main.c:257
#, fuzzy, c-format
@@ -21856,11 +21901,11 @@
msgstr ""
#: ../vector/v.kernel/main.c:344
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"Writing output vector map using smooth parameter=%f."
-msgstr "���."
+msgstr ""
#: ../vector/v.kernel/main.c:346
#: ../vector/v.kernel/main.c:419
@@ -21888,9 +21933,8 @@
msgstr "NULL値も出力"
#: ../vector/v.out.ogr/main.c:88
-#, fuzzy
msgid "Converts to one of the supported OGR vector formats."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:96
msgid "Feature type. Combination of types is not supported by all formats."
@@ -21986,34 +22030,34 @@
msgstr "入力するファイル"
#: ../vector/v.out.ogr/main.c:399
-#, fuzzy, c-format
+#, c-format
msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:404
-#, fuzzy, c-format
+#, c-format
msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:410
-#, fuzzy, c-format
+#, c-format
msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:416
-#, fuzzy, c-format
+#, c-format
msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:421
-#, fuzzy, c-format
+#, c-format
msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:426
-#, fuzzy, c-format
+#, c-format
msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr "���."
+msgstr ""
#: ../vector/v.out.ogr/main.c:434
#, fuzzy, c-format
@@ -22032,9 +22076,9 @@
#: ../vector/v.out.ogr/main.c:654
#: ../vector/v.out.pov/main.c:207
-#, fuzzy, c-format
+#, c-format
msgid "%d features written"
-msgstr "���"
+msgstr ""
#: ../vector/v.out.ogr/main.c:656
#, fuzzy, c-format
@@ -22042,9 +22086,9 @@
msgstr "出力ファイルの上書き"
#: ../vector/v.out.ogr/main.c:658
-#, fuzzy, c-format
+#, c-format
msgid "%d features without attributes were written"
-msgstr "���"
+msgstr ""
#: ../vector/v.out.ogr/main.c:660
#, fuzzy, c-format
@@ -22124,9 +22168,8 @@
msgstr ""
#: ../vector/v.hull/main.c:293
-#, fuzzy
msgid "Name of input vector points map"
-msgstr "���"
+msgstr ""
#: ../vector/v.hull/main.c:296
#, fuzzy
@@ -22145,14 +22188,14 @@
#: ../vector/v.hull/main.c:322
#: ../vector/v.hull/main.c:347
#: ../vector/v.hull/main.c:352
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open vector map <%s>"
-msgstr "���."
+msgstr ""
#: ../vector/v.hull/main.c:328
-#, fuzzy, c-format
+#, c-format
msgid "Error loading vector points map <%s>"
-msgstr "���."
+msgstr ""
#: ../vector/v.hull/main.c:331
msgid "Convex hull calculation requires at least three points"
@@ -22212,9 +22255,8 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:237
-#, fuzzy
msgid "Name of the vector map with input x,y,z,w"
-msgstr "���"
+msgstr ""
#: ../vector/v.vol.rst/main.c:245
#, fuzzy
@@ -22245,9 +22287,8 @@
#: ../vector/v.vol.rst/main.c:286
#: ../vector/v.surf.rst/main.c:257
-#, fuzzy
msgid "Output deviations vector point file"
-msgstr "���"
+msgstr ""
#: ../vector/v.vol.rst/main.c:287
#: ../vector/v.vol.rst/main.c:295
@@ -22255,9 +22296,8 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:294
-#, fuzzy
msgid "Output cross-validation vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.vol.rst/main.c:302
#: ../vector/v.surf.rst/main.c:284
@@ -22347,9 +22387,8 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:548
-#, fuzzy
msgid "Vector is not 3D"
-msgstr "���"
+msgstr ""
#: ../vector/v.vol.rst/main.c:584
#, c-format
@@ -22459,9 +22498,9 @@
msgstr ""
#: ../vector/v.patch/main.c:374
-#, fuzzy, c-format
+#, c-format
msgid "%d vector maps patched"
-msgstr "���"
+msgstr ""
#: ../vector/v.patch/main.c:397
#, fuzzy, c-format
@@ -22506,9 +22545,9 @@
msgstr "���"
#: ../vector/v.kcv/main.c:174
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get layer info for vector map <%s>"
-msgstr "���"
+msgstr ""
#: ../vector/v.kcv/main.c:198
#, fuzzy, c-format
@@ -22534,9 +22573,8 @@
msgstr ""
#: ../vector/v.support/main.c:68
-#, fuzzy
msgid "Person who created vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.support/main.c:75
#, fuzzy
@@ -22588,9 +22626,8 @@
#: ../vector/v.select/main.c:141
#: ../vector/v.overlay/main.c:59
-#, fuzzy
msgid "Name of input vector map (A)"
-msgstr "���"
+msgstr ""
#: ../vector/v.select/main.c:145
#: ../vector/v.overlay/main.c:63
@@ -22600,15 +22637,13 @@
#: ../vector/v.select/main.c:150
#: ../vector/v.overlay/main.c:69
-#, fuzzy
msgid "Layer number (vector map A)"
-msgstr "���"
+msgstr ""
#: ../vector/v.select/main.c:155
#: ../vector/v.overlay/main.c:73
-#, fuzzy
msgid "Name of input vector map (B)"
-msgstr "���"
+msgstr ""
#: ../vector/v.select/main.c:159
#: ../vector/v.overlay/main.c:77
@@ -22618,14 +22653,12 @@
#: ../vector/v.select/main.c:164
#: ../vector/v.overlay/main.c:83
-#, fuzzy
msgid "Layer number (vector map B)"
-msgstr "���"
+msgstr ""
#: ../vector/v.select/main.c:178
-#, fuzzy
msgid "Operator defines required relation between features"
-msgstr "���"
+msgstr ""
#: ../vector/v.select/main.c:180
msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
@@ -22839,9 +22872,8 @@
msgstr "入力するファイル"
#: ../vector/v.voronoi/vo_main.c:120
-#, fuzzy
msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-msgstr "���."
+msgstr ""
#: ../vector/v.voronoi/vo_main.c:135
msgid "Output tessellation as a graph (lines), not areas"
@@ -22853,9 +22885,8 @@
#: ../vector/v.voronoi/dt_main.c:47
#: ../vector/v.delaunay2/main.c:59
-#, fuzzy
msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-msgstr "���."
+msgstr ""
#: ../vector/v.voronoi/dt_main.c:55
#: ../vector/v.delaunay2/main.c:67
@@ -22948,9 +22979,8 @@
msgstr "指定した位置でのベクトルマップのカテゴリー情報を表示します"
#: ../vector/v.what/main.c:70
-#, fuzzy
msgid "If not given reads from standard input"
-msgstr "���"
+msgstr ""
#: ../vector/v.what/main.c:77
#, fuzzy
@@ -22973,13 +23003,13 @@
msgstr "出力するファイル"
#: ../vector/v.what/what.c:141
-#, fuzzy, c-format
+#, c-format
msgid ""
"Id: %d\n"
"Type: %s\n"
"Left: %d\n"
"Right: %d\n"
-msgstr "��� "
+msgstr ""
#: ../vector/v.what/what.c:161
#, c-format
@@ -22990,11 +23020,11 @@
msgstr ""
#: ../vector/v.what/what.c:169
-#, fuzzy, c-format
+#, c-format
msgid ""
"Id: %5d\n"
"Angle: %.8f\n"
-msgstr "���"
+msgstr ""
#: ../vector/v.what/what.c:176
#, c-format
@@ -23002,23 +23032,23 @@
msgstr ""
#: ../vector/v.what/what.c:177
-#, fuzzy, c-format
+#, c-format
msgid "Id: %d\n"
-msgstr "���"
+msgstr ""
#: ../vector/v.what/what.c:203
-#, fuzzy, c-format
+#, c-format
msgid ""
"Line height min: %f\n"
"Line height max: %f\n"
-msgstr "���"
+msgstr ""
#: ../vector/v.what/what.c:212
-#, fuzzy, c-format
+#, c-format
msgid ""
"Type: Area\n"
"Area height: %f\n"
-msgstr "���"
+msgstr ""
#: ../vector/v.what/what.c:216
#, fuzzy, c-format
@@ -23187,9 +23217,9 @@
msgstr ""
#: ../vector/v.transform/main.c:206
-#, fuzzy, c-format
+#, c-format
msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-msgstr "���."
+msgstr ""
#: ../vector/v.transform/main.c:212
#, c-format
@@ -23201,9 +23231,9 @@
msgstr ""
#: ../vector/v.transform/main.c:231
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open file with coordinates <%s>"
-msgstr "���"
+msgstr ""
#: ../vector/v.transform/main.c:311
#, fuzzy, c-format
@@ -23211,11 +23241,11 @@
msgstr "入力するファイル"
#: ../vector/v.transform/main.c:338
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"New vector map <%s> boundary coordinates:"
-msgstr "���"
+msgstr ""
#: ../vector/v.transform/main.c:340
#, c-format
@@ -23252,9 +23282,8 @@
msgstr ""
#: ../vector/v.transform/creat_trans.c:102
-#, fuzzy
msgid "Please answer yes or no"
-msgstr "���� yes ��no"
+msgstr ""
#: ../vector/v.transform/creat_trans.c:118
#, fuzzy
@@ -23290,9 +23319,8 @@
msgstr "対象マップのタイプ"
#: ../vector/v.overlay/main.c:95
-#, fuzzy
msgid "Operator defines features written to output vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.overlay/main.c:98
msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
@@ -23421,9 +23449,8 @@
msgstr ""
#: ../vector/v.build.polylines/main.c:108
-#, fuzzy
msgid "vector, geometry, topology"
-msgstr "���"
+msgstr ""
#: ../vector/v.build.polylines/main.c:109
#, fuzzy
@@ -23440,14 +23467,14 @@
msgstr ""
#: ../vector/v.build.polylines/main.c:206
-#, fuzzy, c-format
+#, c-format
msgid "%d lines or boundaries found in vector map <%s@%s>"
-msgstr "���"
+msgstr ""
#: ../vector/v.build.polylines/main.c:208
-#, fuzzy, c-format
+#, c-format
msgid "%d polylines stored in vector map <%s@%s>"
-msgstr "���"
+msgstr ""
#: ../vector/v.convert/main.c:36
#, fuzzy
@@ -23455,14 +23482,12 @@
msgstr "入力するファイル"
#: ../vector/v.convert/main.c:37
-#, fuzzy
msgid "Imports older versions of GRASS vector maps."
-msgstr "���"
+msgstr ""
#: ../vector/v.convert/main.c:54
-#, fuzzy
msgid "Endian of input vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.convert/type.c:29
#, c-format
@@ -23633,9 +23658,9 @@
msgstr "タイトル"
#: ../vector/v.convert/read.c:295
-#, fuzzy, c-format
+#, c-format
msgid "[%d] centroids read"
-msgstr "���"
+msgstr ""
#: ../vector/v.convert/read.c:296
#, fuzzy, c-format
@@ -23673,9 +23698,8 @@
msgstr "入力するファイル"
#: ../vector/v.segment/main.c:61
-#, fuzzy
msgid "Name for output vector map where segments will be written"
-msgstr "���."
+msgstr ""
#: ../vector/v.segment/main.c:137
#: ../vector/v.segment/main.c:177
@@ -23685,9 +23709,9 @@
#: ../vector/v.segment/main.c:147
#: ../vector/v.segment/main.c:186
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find line of cat %d"
-msgstr "���"
+msgstr ""
#: ../vector/v.segment/main.c:157
#, c-format
@@ -23815,9 +23839,8 @@
msgstr "キーカラム"
#: ../vector/v.univar/main.c:127
-#, fuzzy
msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
-msgstr "���"
+msgstr ""
#: ../vector/v.univar/main.c:132
msgid "Extended statistics is currently supported only for points/centroids"
@@ -23829,9 +23852,8 @@
msgstr "出力するファイル"
#: ../vector/v.label/main.c:63
-#, fuzzy
msgid "Creates paint labels for a vector map from attached attributes."
-msgstr "���."
+msgstr ""
#: ../vector/v.label/main.c:70
#, fuzzy
@@ -23878,9 +23900,8 @@
msgstr "異方性の角度"
#: ../vector/v.label/main.c:167
-#, fuzzy
msgid "Border width"
-msgstr "���"
+msgstr ""
#: ../vector/v.label/main.c:252
msgid "size and space options vary significantly which may lead to crummy output"
@@ -23979,9 +24000,8 @@
msgstr "ラベルの属性"
#: ../vector/v.to.rast/main.c:110
-#, fuzzy
msgid "Column parameter missing (or use value parameter)"
-msgstr "������"
+msgstr ""
#: ../vector/v.to.rast/main.c:115
msgid "Column parameter cannot be combined with use of category values option"
@@ -24017,9 +24037,9 @@
msgstr "入力するファイル"
#: ../vector/v.to.rast/vect2rast.c:44
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is not 3D"
-msgstr "���"
+msgstr ""
#: ../vector/v.to.rast/vect2rast.c:64
#: ../vector/v.to.rast/support.c:311
@@ -24159,9 +24179,8 @@
msgstr "線に沿って点を補間"
#: ../vector/v.to.points/main.c:182
-#, fuzzy
msgid "Output vector map where points will be written"
-msgstr "���."
+msgstr ""
#: ../vector/v.to.points/main.c:194
#, fuzzy
@@ -24188,9 +24207,9 @@
msgstr ""
#: ../vector/v.to.points/main.c:384
-#, fuzzy, c-format
+#, c-format
msgid "%d points written to output vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.in.ascii/points.c:83
#, fuzzy
@@ -24256,9 +24275,9 @@
msgstr "出力するファイル"
#: ../vector/v.in.ascii/head.c:56
-#, fuzzy, c-format
+#, c-format
msgid "Unknown keyword <%s> in vector head"
-msgstr "���."
+msgstr ""
#: ../vector/v.in.ascii/in.c:50
#, fuzzy
@@ -24266,9 +24285,8 @@
msgstr "複数のベクトルマップを合成し新しいマップを作成します"
#: ../vector/v.in.ascii/in.c:56
-#, fuzzy
msgid "ASCII file to be imported, if not given reads from standard input"
-msgstr "���"
+msgstr ""
#: ../vector/v.in.ascii/in.c:67
msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
@@ -24326,9 +24344,8 @@
msgstr ""
#: ../vector/v.in.ascii/in.c:145
-#, fuzzy
msgid "Create a new empty vector map and exit. Nothing is read from input"
-msgstr "��."
+msgstr ""
#: ../vector/v.in.ascii/in.c:150
msgid "Don't expect a header when reading in standard format"
@@ -24503,9 +24520,8 @@
msgstr "出力するファイル"
#: ../vector/v.clean/main.c:44
-#, fuzzy
msgid "Toolset for cleaning topology of vector map."
-msgstr "���"
+msgstr ""
#: ../vector/v.clean/main.c:53
#, fuzzy
@@ -24605,9 +24621,8 @@
msgstr ""
#: ../vector/v.clean/main.c:273
-#, fuzzy
msgid "Copying vector lines..."
-msgstr "���."
+msgstr ""
#: ../vector/v.clean/main.c:295
#: ../vector/v.clean/main.c:305
@@ -24715,18 +24730,16 @@
msgstr ""
#: ../vector/v.surf.idw/main.c:86
-#, fuzzy
msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
-msgstr "���."
+msgstr ""
#: ../vector/v.surf.idw/main.c:106
msgid "Power parameter; greater values assign greater influence to closer points"
msgstr ""
#: ../vector/v.surf.idw/main.c:110
-#, fuzzy
msgid "If set to 0, z coordinates are used (3D vector only)"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.idw/main.c:118
#, fuzzy
@@ -24819,14 +24832,14 @@
msgstr "カテゴリー値の非表示"
#: ../vector/v.edit/main.c:148
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:163
-#, fuzzy, c-format
+#, c-format
msgid "Background vector map <%s> registered"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:203
#, fuzzy
@@ -24843,9 +24856,9 @@
msgstr ""
#: ../vector/v.edit/main.c:261
-#, fuzzy, c-format
+#, c-format
msgid "%d features added"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:263
#: ../vector/v.edit/main.c:284
@@ -24862,29 +24875,29 @@
msgstr "タイトル"
#: ../vector/v.edit/main.c:279
-#, fuzzy, c-format
+#, c-format
msgid "%d features deleted"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:287
-#, fuzzy, c-format
+#, c-format
msgid "%d features moved"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:296
-#, fuzzy, c-format
+#, c-format
msgid "%d vertices moved"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:300
-#, fuzzy, c-format
+#, c-format
msgid "%d vertices added"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:304
-#, fuzzy, c-format
+#, c-format
msgid "%d vertices removed"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:314
#, fuzzy, c-format
@@ -24892,20 +24905,20 @@
msgstr "タイトル"
#: ../vector/v.edit/main.c:320
-#, fuzzy, c-format
+#, c-format
msgid "%d lines connected"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:324
-#, fuzzy, c-format
+#, c-format
msgid "%d lines merged"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:332
#: ../vector/v.edit/main.c:336
-#, fuzzy, c-format
+#, c-format
msgid "%d features modified"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:341
#, c-format
@@ -24913,9 +24926,9 @@
msgstr ""
#: ../vector/v.edit/main.c:351
-#, fuzzy, c-format
+#, c-format
msgid "%d features copied"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:360
#, fuzzy, c-format
@@ -24928,14 +24941,13 @@
msgstr "タイトル"
#: ../vector/v.edit/main.c:387
-#, fuzzy, c-format
+#, c-format
msgid "%d features converted"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:390
-#, fuzzy
msgid "No feature modified"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/main.c:395
msgid "Operation not implemented"
@@ -24955,14 +24967,12 @@
msgstr ""
#: ../vector/v.edit/args.c:100
-#, fuzzy
msgid "ASCII file to be converted to binary vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/args.c:102
-#, fuzzy
msgid "If not given (or \"-\") reads from standard input"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/args.c:112
msgid "Difference in x,y direction for moving feature or vertex"
@@ -25030,9 +25040,8 @@
msgstr ""
#: ../vector/v.edit/args.c:211
-#, fuzzy
msgid "Do not expect header of input data"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/args.c:221
msgid "Modify only first found feature in bounding box"
@@ -25085,9 +25094,9 @@
msgstr "出力するファイル"
#: ../vector/v.edit/a2b.c:270
-#, fuzzy, c-format
+#, c-format
msgid "Unknown keyword '%s' in vector head"
-msgstr "���."
+msgstr ""
#: ../vector/v.edit/a2b.c:328
#: ../vector/v.edit/snap.c:111
@@ -25106,9 +25115,9 @@
msgstr "入力するファイル"
#: ../vector/v.edit/select.c:175
-#, fuzzy, c-format
+#, c-format
msgid "%d of %d features selected from vector map <%s>"
-msgstr "���"
+msgstr ""
#: ../vector/v.edit/select.c:500
msgid "Layer must be > 0 for 'where'"
@@ -25125,9 +25134,8 @@
msgstr "ベクトルマップの基礎情報を出力します"
#: ../vector/v.info/main.c:75
-#, fuzzy
msgid "Print vector history instead of info"
-msgstr "���"
+msgstr ""
#: ../vector/v.info/main.c:81
msgid "Print types/names of table columns for specified layer instead of info"
@@ -25265,9 +25273,8 @@
msgstr "対象マップ"
#: ../vector/v.extrude/main.c:70
-#, fuzzy
msgid "Extrudes flat vector object to 3D with defined height."
-msgstr "���"
+msgstr ""
#: ../vector/v.extrude/main.c:74
#, fuzzy
@@ -25275,23 +25282,20 @@
msgstr "標高に用いるラスターマップ"
#: ../vector/v.extrude/main.c:77
-#, fuzzy
msgid "Name of input 2D vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.extrude/main.c:80
-#, fuzzy
msgid "Name of resulting 3D vector map"
-msgstr "���"
+msgstr ""
#: ../vector/v.extrude/main.c:92
msgid "Elevation raster for height extraction"
msgstr ""
#: ../vector/v.extrude/main.c:99
-#, fuzzy
msgid "Fixed height for 3D vector objects"
-msgstr "���"
+msgstr ""
#: ../vector/v.extrude/main.c:104
#, fuzzy
@@ -25386,9 +25390,8 @@
msgstr "入力するファイル"
#: ../vector/v.category/main.c:190
-#, fuzzy
msgid "Output vector wasn't entered"
-msgstr "���."
+msgstr ""
#: ../vector/v.category/main.c:274
#, fuzzy, c-format
@@ -25446,23 +25449,21 @@
msgstr "統一する属性の値"
#: ../vector/v.category/main.c:531
-#, fuzzy, c-format
+#, c-format
msgid "%d features modified."
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:163
-#, fuzzy
msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr "��� ���� ����."
+msgstr ""
#: ../vector/v.surf.rst/main.c:190
msgid "Perform cross-validation procedure without raster approximation"
msgstr ""
#: ../vector/v.surf.rst/main.c:195
-#, fuzzy
msgid "Use scale dependent tension"
-msgstr "���� ����"
+msgstr ""
#: ../vector/v.surf.rst/main.c:202
#: ../vector/v.surf.rst/main.c:220
@@ -25485,14 +25486,12 @@
msgstr "標高を出力するファイル"
#: ../vector/v.surf.rst/main.c:225
-#, fuzzy
msgid "Output slope raster map"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:231
-#, fuzzy
msgid "Output aspect raster map"
-msgstr "�����"
+msgstr ""
#: ../vector/v.surf.rst/main.c:237
#, fuzzy
@@ -25510,19 +25509,16 @@
msgstr "断面曲率を出力するファイル"
#: ../vector/v.surf.rst/main.c:264
-#, fuzzy
msgid "Output cross-validation errors vector point file"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:271
-#, fuzzy
msgid "Output vector map showing quadtree segmentation"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:278
-#, fuzzy
msgid "Output vector map showing overlapping windows"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:292
#, fuzzy
@@ -25558,14 +25554,12 @@
msgstr "入力するファイル"
#: ../vector/v.surf.rst/main.c:430
-#, fuzzy
msgid "You are not outputting any raster or vector maps"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:443
-#, fuzzy
msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
-msgstr "���"
+msgstr ""
#: ../vector/v.surf.rst/main.c:446
msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
@@ -31859,3 +31853,7 @@
msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr ""
+#, fuzzy
+#~ msgid "%s' must be greater than zero; using %s=255"
+#~ msgstr "%s' must be greater than zero; using %s=255 "
