[GRASS-SVN] r40621 - grass/trunk
Fri Jan 22 09:32:40 EST 2010
Author: glynn
Date: 2010-01-22 09:32:38 -0500 (Fri, 22 Jan 2010)
New Revision: 40621
   grass/trunk/configure
Define FSEEKO (file omitted from r40620)
Modified: grass/trunk/configure
--- grass/trunk/configure	2010-01-22 14:19:24 UTC (rev 40620)
+++ grass/trunk/configure	2010-01-22 14:32:38 UTC (rev 40621)
@@ -13908,11 +13908,89 @@
    fi
    fi
+echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
+echo "configure:13913: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+ac_cv_sys_largefile_source=no
+      cat > conftest.$ac_ext <<EOF
+#line 13917 "configure"
+#include "confdefs.h"
+#include <stdio.h>
+int main() {
+return !fseeko;
+; return 0; }
+EOF
+if { (eval echo configure:13924: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+#line 13931 "configure"
+#define _LARGEFILE_SOURCE 1
+#include <stdio.h>
+int main() {
+return !fseeko;
+; return 0; }
+EOF
+if { (eval echo configure:13940: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  ac_cv_sys_largefile_source=1
+else
+fi
+rm -f conftest*
+fi
+rm -f conftest*
+echo "$ac_t""$ac_cv_sys_largefile_source" 1>&6
+   if test "$ac_cv_sys_largefile_source" != no; then
+     cat >> confdefs.h <<EOF
+#define _LARGEFILE_SOURCE $ac_cv_sys_largefile_source
+EOF
+   fi
+   # We used to try defining _XOPEN_SOURCE=500 too, to work around a bug
+   # in glibc 2.1.3, but that breaks too many other things.
+   # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
+   echo $ac_n "checking for fseeko""... $ac_c" 1>&6
+echo "configure:13963: checking for fseeko" >&5
+ac_cv_func_fseeko=no
+#line 13967 "configure"
+#include <stdio.h>
+int main() {
+return fseeko && fseeko (stdin, 0, 0);
+; return 0; }
+EOF
+if { (eval echo configure:13974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  ac_cv_func_fseeko=yes
+else
+fi
+rm -f conftest*
+echo "$ac_t""$ac_cv_func_fseeko" 1>&6
+   if test $ac_cv_func_fseeko != no; then
+     cat >> confdefs.h <<\EOF
+#define HAVE_FSEEKO 1
+EOF
+   fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13913: checking if system supports Large Files at all" >&5
+echo "configure:13991: checking if system supports Large Files at all" >&5
-#line 13916 "configure"
+#line 13994 "configure"
 #include <stdio.h>
 #include <sys/types.h>
@@ -13944,7 +14022,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13948: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14026: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13973,7 +14051,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:13977: checking whether to use Python" >&5
+echo "configure:14055: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -13994,7 +14072,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13998: checking for $ac_word" >&5
+echo "configure:14076: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14036,15 +14114,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14040: checking for $ac_hdr" >&5
+echo "configure:14118: checking for $ac_hdr" >&5
-#line 14043 "configure"
+#line 14121 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -14092,7 +14170,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:14096: checking for $ac_word" >&5
+echo "configure:14174: checking for $ac_word" >&5
 case "$SWIG" in
@@ -14154,7 +14232,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14158: checking whether to use wxWidgets" >&5
+echo "configure:14236: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14175,7 +14253,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14179: checking for $ac_word" >&5
+echo "configure:14257: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14223,7 +14301,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14227: checking wxWidgets version" >&5
+echo "configure:14305: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14246,15 +14324,15 @@
 do
-echo "configure:14250: checking for $ac_hdr" >&5
+echo "configure:14328: checking for $ac_hdr" >&5
-#line 14253 "configure"
+#line 14331 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14336: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
