[GRASS-SVN] r40622 - grass/trunk/raster/r.in.bin
svn_grass at osgeo.org
Fri Jan 22 09:33:02 EST 2010
Author: glynn
Date: 2010-01-22 09:33:02 -0500 (Fri, 22 Jan 2010)
New Revision: 40622
grass/trunk/raster/r.in.bin/main.c
Clean up, synchronise with r.out.bin
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c 2010-01-22 14:32:38 UTC (rev 40621)
+++ grass/trunk/raster/r.in.bin/main.c 2010-01-22 14:33:02 UTC (rev 40622)
@@ -15,106 +15,219 @@
#include <sys/stat.h>
#include <grass/gis.h>
#include <grass/raster.h>
-#include "gmt_grd.h"
#include <grass/glocale.h>
-typedef unsigned short uint16;
-typedef unsigned int uint32;
+#include "gmt_grd.h"
-static double nul_val;
+static void swap_2(void *p)
+ unsigned char *q = p;
+ unsigned char t;
+ t = q[0]; q[0] = q[1]; q[1] = t;
-static void SwabShort(uint16 * wp)
+static void swap_4(void *p)
- register char *cp = (char *)wp;
- int t;
+ unsigned char t;
+ t = q[0]; q[0] = q[3]; q[3] = t;
+ t = q[1]; q[1] = q[2]; q[2] = t;
- t = cp[1];
- cp[1] = cp[0];
- cp[0] = t;
+static void swap_8(void *p)
+ unsigned char t;
+ t = q[0]; q[0] = q[7]; q[7] = t;
+ t = q[1]; q[1] = q[6]; q[6] = t;
+ t = q[2]; q[2] = q[5]; q[5] = t;
+ t = q[3]; q[3] = q[4]; q[4] = t;
-static void SwabLong(uint32 * lp)
+static void read_int(FILE *fp, int swap_flag, int *x)
- register char *cp = (char *)lp;
- int t;
+ if (fread(x, 4, 1, fp) != 1)
+ G_fatal_error(_("Error reading data"));
- t = cp[3];
- cp[3] = cp[0];
- cp[0] = t;
- t = cp[2];
- cp[2] = cp[1];
- cp[1] = t;
+ if (swap_flag)
+ swap_4(x);
-static void SwabFloat(float *fp)
+static void read_double(FILE *fp, int swap_flag, double *x)
- SwabLong((uint32 *) fp);
+ if (fread(x, 8, 1, fp) != 1)
+ if (swap_flag)
+ swap_8(x);
-static void SwabDouble(double *dp)
+static void read_gmt_header(struct GRD_HEADER *header, int swap_flag, FILE *fp)
- register char *cp = (char *)dp;
- int t;
+ read_int(fp, swap_flag, &header->nx);
+ read_int(fp, swap_flag, &header->ny);
+ read_int(fp, swap_flag, &header->node_offset);
- t = cp[7];
- cp[7] = cp[0];
- cp[0] = t;
- t = cp[6];
- cp[6] = cp[1];
- cp[1] = t;
- t = cp[5];
- cp[5] = cp[2];
- cp[2] = t;
- t = cp[4];
- cp[4] = cp[3];
- cp[3] = t;
+ read_double(fp, swap_flag, &header->x_min);
+ read_double(fp, swap_flag, &header->x_max);
+ read_double(fp, swap_flag, &header->y_min);
+ read_double(fp, swap_flag, &header->y_max);
+ read_double(fp, swap_flag, &header->z_min);
+ read_double(fp, swap_flag, &header->z_max);
+ read_double(fp, swap_flag, &header->x_inc);
+ read_double(fp, swap_flag, &header->y_inc);
+ read_double(fp, swap_flag, &header->z_scale_factor);
+ read_double(fp, swap_flag, &header->z_add_offset);
+ fread(&header->x_units, sizeof(char[GRD_UNIT_LEN]), 1, fp);
+ fread(&header->y_units, sizeof(char[GRD_UNIT_LEN]), 1, fp);
+ fread(&header->z_units, sizeof(char[GRD_UNIT_LEN]), 1, fp);
+ fread(&header->title, sizeof(char[GRD_TITLE_LEN]), 1, fp);
+ fread(&header->command, sizeof(char[GRD_COMMAND_LEN]), 1, fp);
+ fread(&header->remark, sizeof(char[GRD_REMARK_LEN]), 1, fp);
+static void get_gmt_header(const struct GRD_HEADER *header, struct Cell_head *region)
+ region->cols = header->nx;
+ region->rows = header->ny;
+ region->west = header->x_min;
+ region->east = header->x_max;
+ region->south = header->y_min;
+ region->north = header->y_max;
+ region->ew_res = header->x_inc;
+ region->ns_res = header->y_inc;
+static void convert_cell(
+ DCELL *out_cell, unsigned char *in_cell,
+ int is_fp, int is_signed, int bytes, int swap_flag)
+ if (swap_flag) {
+ switch (bytes) {
+ case 1: break;
+ case 2: swap_2(in_cell); break;
+ case 4: swap_4(in_cell); break;
+ case 8: swap_8(in_cell); break;
+ if (is_fp) {
+ switch (bytes) {
+ case 4:
+ *out_cell = (DCELL) *(float *) in_cell;
+ break;
+ case 8:
+ *out_cell = (DCELL) *(double *) in_cell;
+ break;
+ else if (is_signed) {
+ switch (bytes) {
+ case 1:
+ *out_cell = (DCELL) *(signed char *) in_cell;
+ break;
+ case 2:
+ *out_cell = (DCELL) *(short *) in_cell;
+ break;
+ case 4:
+ *out_cell = (DCELL) *(int *) in_cell;
+ break;
+#ifdef HAVE_LONG_LONG_INT
+ case 8:
+ *out_cell = (DCELL) *(long long *) in_cell;
+ break;
+#endif
+ else {
+ switch (bytes) {
+ case 1:
+ *out_cell = (DCELL) *(unsigned char *) in_cell;
+ break;
+ case 2:
+ *out_cell = (DCELL) *(unsigned short *) in_cell;
+ break;
+ case 4:
+ *out_cell = (DCELL) *(unsigned int *) in_cell;
+ break;
+ case 8:
+ *out_cell = (DCELL) *(unsigned long long *) in_cell;
+ break;
+#endif
+static void convert_row(
+ DCELL *raster, unsigned char *in_buf, int ncols,
+ int is_fp, int is_signed, int bytes, int swap_flag,
+ double null_val)
+ unsigned char *ptr = in_buf;
+ int i;
+ for (i = 0; i < ncols; i++) {
+ DCELL x;
+ convert_cell(&x, ptr, is_fp, is_signed, bytes, swap_flag);
+ if (x == null_val)
+ Rast_set_d_null_value(&raster[i], 1);
+ else
+ raster[i] = x;
+ ptr += bytes;
int main(int argc, char *argv[])
- const char *input;
- const char *output;
- const char *title;
- FILE *fd;
- int cf;
- struct Cell_head cellhd;
- struct History history;
- CELL *cell;
- FCELL *fcell;
- DCELL *dcell;
- RASTER_MAP_TYPE map_type;
- int row, col;
- int nrows = 0, ncols = 0;
- int grass_nrows = 0, grass_ncols = 0;
- int bytes, sflag, swap;
- int no_coord = 0, no_dim = 0;
- void *x_v;
- char *x_c;
- uint16 *x_s;
- uint32 *x_i;
- float *x_f;
- double *x_d;
- struct stat fileinfo;
- int FILE_SIZE;
- const char *err;
- char dummy[2];
- struct GRD_HEADER header;
+ struct GModule *module;
struct
- struct Option *input, *output, *title, *bytes,
- *north, *south, *east, *west, *rows, *cols, *anull;
+ struct Option *input;
+ struct Option *output;
+ struct Option *null;
+ struct Option *bytes;
+ struct Option *order;
+ struct Option *title;
+ struct Option *north;
+ struct Option *south;
+ struct Option *east;
+ struct Option *west;
+ struct Option *rows;
+ struct Option *cols;
} parm;
struct
- struct Flag *s, *f, *d, *b, *gmt_hd;
+ struct Flag *float_in;
+ struct Flag *double_in;
+ struct Flag *gmt_hd;
+ struct Flag *sign;
+ struct Flag *swap;
} flag;
- struct GModule *module;
- union
- int testWord;
- char testByte[4];
- } endianTest;
- int swapFlag;
+ const char *input;
+ const char *output;
+ const char *title;
+ double null_val = 0;
+ int is_fp;
+ int is_signed;
+ int bytes;
+ int order;
+ int swap_flag;
+ struct Cell_head cellhd;
+ int nrows, ncols;
+ int grass_nrows, grass_ncols;
+ unsigned char *in_buf;
+ DCELL *out_buf;
+ RASTER_MAP_TYPE map_type;
+ int fd;
+ FILE *fp;
+ off_t file_size;
+ struct GRD_HEADER header;
+ int row;
+ struct History history;
+ const char *err;
+ off_t expected;
G_gisinit(argv[0]);
@@ -125,27 +238,26 @@
module->description =
_("Import a binary raster file into a GRASS raster map layer.");
+ flag.float_in = G_define_flag();
+ flag.float_in->key = 'f';
+ flag.float_in->description =
+ _("Import as floating-point data (default: integer)");
- flag.f = G_define_flag();
- flag.f->key = 'f';
- flag.f->description =
- _("Import as Floating Point Data (default: Integer)");
+ flag.double_in = G_define_flag();
+ flag.double_in->key = 'd';
+ flag.double_in->description =
+ _("Import as double-precision floating-point data (default: integer)");
- flag.d = G_define_flag();
- flag.d->key = 'd';
- flag.d->description =
- _("Import as Double Precision Data (default: Integer)");
+ flag.sign = G_define_flag();
+ flag.sign->key = 's';
+ flag.sign->description = _("Signed data (two's complement)");
+ flag.sign->guisection = _("Settings");
- flag.s = G_define_flag();
- flag.s->key = 's';
- flag.s->description = _("Signed data (high bit means negative value)");
- flag.s->guisection = _("Settings");
+ flag.swap = G_define_flag();
+ flag.swap->key = 'b';
+ flag.swap->description = _("Byte Swap the Data During Import");
+ flag.swap->guisection = _("Settings");
- flag.b = G_define_flag();
- flag.b->key = 'b';
- flag.b->description = _("Byte Swap the Data During Import");
- flag.b->guisection = _("Settings");
flag.gmt_hd = G_define_flag();
flag.gmt_hd->key = 'h';
flag.gmt_hd->description = _("Get region info from GMT style header");
@@ -170,11 +282,19 @@
parm.bytes = G_define_option();
parm.bytes->key = "bytes";
parm.bytes->type = TYPE_INTEGER;
- parm.bytes->answer = "1";
parm.bytes->required = NO;
- parm.bytes->description = _("Number of bytes per cell (1, 2, 4)");
+ parm.bytes->options = "1,2,4,8";
+ parm.bytes->description = _("Number of bytes per cell");
parm.bytes->guisection = _("Settings");
+ parm.order = G_define_option();
+ parm.order->key = "order";
+ parm.order->type = TYPE_STRING;
+ parm.order->required = NO;
+ parm.order->options = "big,little,native,swap";
+ parm.order->description = _("Output byte order");
+ parm.order->answer = "native";
parm.north = G_define_option();
parm.north->key = "north";
parm.north->type = TYPE_DOUBLE;
@@ -221,12 +341,12 @@
parm.cols->description = _("Number of columns");
parm.cols->guisection = _("Bounds");
- parm.anull = G_define_option();
- parm.anull->key = "anull";
- parm.anull->type = TYPE_DOUBLE;
- parm.anull->required = NO;
- parm.anull->description = _("Set Value to NULL");
- parm.anull->guisection = _("Settings");
+ parm.null = G_define_option();
+ parm.null->key = "anull";
+ parm.null->type = TYPE_DOUBLE;
+ parm.null->required = NO;
+ parm.null->description = _("Set Value to NULL");
+ parm.null->guisection = _("Settings");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -235,103 +355,83 @@
output = parm.output->answer;
title = parm.title->answer;
- if (flag.f->answer)
- bytes = 4;
- else if (flag.d->answer)
- bytes = 8;
- else if (sscanf(parm.bytes->answer, "%d%1s", &bytes, dummy) != 1)
- G_fatal_error(_("Parsing bytes per cell"));
- if (bytes <= 0)
- G_fatal_error(_("Bad number of bytes per cell"));
- sflag = flag.s->answer;
+ if (G_strcasecmp(parm.order->answer, "big") == 0)
+ order = 0;
+ else if (G_strcasecmp(parm.order->answer, "little") == 0)
+ order = 1;
+ else if (G_strcasecmp(parm.order->answer, "native") == 0)
+ order = G_is_little_endian() ? 1 : 0;
+ else if (G_strcasecmp(parm.order->answer, "swap") == 0)
+ order = G_is_little_endian() ? 0 : 1;
- swap = 0;
- if (flag.b->answer) {
- swap = 1;
- G_message(_("Byte Swapping Turned On."));
+ if (flag.swap->answer) {
+ if (strcmp(parm.order->answer, "native") != 0)
+ G_fatal_error(_("order= and -b are mutually exclusive"));
- /* Check Endian State of Host Computer */
- endianTest.testWord = 1;
- if (endianTest.testByte[0] == 1) {
- swapFlag = 1; /*true: little endian */
- if (swap == 1)
- swapFlag = 0; /* Swapping enabled */
+ swap_flag = order == (G_is_little_endian() ? 0 : 1);
+ is_signed = !!flag.sign->answer;
+ is_fp = 0;
+ bytes = 0;
+ if (parm.bytes->answer)
+ bytes = atoi(parm.bytes->answer);
+ if (flag.float_in->answer && flag.double_in->answer)
+ G_fatal_error(_("-f and -d are mutually exclusive"));
+ if (flag.float_in->answer) {
+ if (bytes && bytes < 4)
+ G_fatal_error(_("-f incompatible with bytes=%d; must be 4 or 8"), bytes);
+ if (!bytes)
+ bytes = 4;
+ is_fp = 1;
- else {
- swapFlag = 0;
- if (swap == 1)
- swapFlag = 1; /* Swapping enabled */
+ if (flag.double_in->answer) {
+ if (bytes && bytes != 8)
+ G_fatal_error(_("-d incompatible with bytes=%d; must be 8"), bytes);
+ if (!bytes)
+ bytes = 8;
+ is_fp = 1;
- cellhd.zone = G_zone();
- cellhd.proj = G_projection();
+ if (!is_fp && !bytes)
+ G_fatal_error(_("bytes= required for integer data"));
- if (!flag.gmt_hd->answer) { /* NO GMT header */
+#ifndef HAVE_LONG_LONG_INT
+ if (!is_fp && bytes > 4)
+ G_fatal_error(_("Integer input doesn't support size=8 in this build"));
+#endif
- /* Check for optional parameters */
- if (!parm.north->answer && !parm.south->answer && !parm.east->answer
- && !parm.west->answer) {
- no_coord = 1;
- /* No coordinates provided */
- if (!parm.rows->answer && !parm.cols->answer) {
- no_dim = 1;
- /* No dimensions provided */
- /* Done check */
+ if (bytes != 1 && bytes != 2 && bytes != 4 && bytes != 8)
+ G_fatal_error(_("bytes= must be 1, 2, 4 or 8"));
+ if (parm.null->answer)
+ null_val = atof(parm.null->answer);
- /* CASE 0 - Not enough parameters - exit */
- if (no_dim == 1 && no_coord == 1)
- G_fatal_error(_("Missing parameters ...\nMust provide at least"
- "[north= south= east= west=] OR [r= c=]"));
+ cellhd.zone = G_zone();
+ cellhd.proj = G_projection();
- /* CASE 1 - All parameters supplied */
- if (no_coord == 0 && no_dim == 0) { /* Get all parmameters */
- if (!parm.north->answer || !parm.south->answer ||
- !parm.west->answer || !parm.east->answer)
- G_fatal_error(_("You have to provide all limits of geographic region (n,s,e,w)"));
- if (!G_scan_northing(parm.north->answer, &cellhd.north, cellhd.proj))
- G_fatal_error(_("Illegal north coordinate <%s>"), parm.north->answer);
- if (!G_scan_northing(parm.south->answer, &cellhd.south, cellhd.proj))
- G_fatal_error(_("Illegal south coordinate <%s>"), parm.south->answer);
- if (!G_scan_easting(parm.east->answer, &cellhd.east, cellhd.proj))
- G_fatal_error(_("Illegal east coordinate <%s>"), parm.east->answer);
- if (!G_scan_easting(parm.west->answer, &cellhd.west, cellhd.proj))
- G_fatal_error(_("Illegal west coordinate <%s>"), parm.west->answer);
- if (sscanf(parm.rows->answer, "%d%1s", &cellhd.rows, dummy) != 1)
- G_fatal_error(_("Illegal number of rows <%s>"), parm.rows->answer);
- if (sscanf(parm.cols->answer, "%d%1s", &cellhd.cols, dummy) != 1)
- G_fatal_error(_("Illegal number of columns <%s>"), parm.cols->answer);
+ if (!flag.gmt_hd->answer) {
+ /* NO GMT header */
+ int num_bounds;
- /* CASE 2 - Get only rows and columns and calculate N S E W */
- /* Only works with resolution = 1 */
- if (no_dim == 0 && no_coord == 1) { /* Get rows and cols only */
- || cellhd.rows <= 0)
- || cellhd.cols <= 0)
- cellhd.north = (double)cellhd.rows;
- cellhd.south = 0.;
- cellhd.east = (double)cellhd.cols;
- cellhd.west = 0.;
- G_message(_("Using N=%f S=%f E=%f W=%f"), cellhd.north,
- cellhd.south, cellhd.east, cellhd.west);
+ if (!parm.rows->answer || !parm.cols->answer)
+ G_fatal_error(_("Either -h or rows= and cols= must be given"));
+ num_bounds = !!parm.north->answer + !!parm.south->answer +
+ !!parm.east->answer + !!parm.west->answer;
+ if (num_bounds != 0 && num_bounds != 4)
+ G_fatal_error(_("Either all or none of north=, south=, east= and west= must be given"));
- /* CASE 3 - Get only N S E & W */
- /* No rows and columns supplied - calculate from parameters */
- /* Assumes 1x1 resolution */
- if (no_coord == 0 && no_dim == 1) { /* Get n, s, e, w */
- G_fatal_error(
- _("You have to provide all limits of geographic region (n,s,e,w)"));
+ cellhd.rows = atoi(parm.rows->answer);
+ cellhd.cols = atoi(parm.cols->answer);
+ if (num_bounds > 0) {
@@ -340,248 +440,92 @@
- /* Calculate rows and cols */
- cellhd.rows = (int)cellhd.north - cellhd.south;
- cellhd.cols = (int)cellhd.east - cellhd.west;
- G_message(_("Using rows=%d cols=%d\n"), cellhd.rows, cellhd.cols);
- } /* DONE */
+ fp = fopen(input, "rb");
+ if (!fp)
+ G_fatal_error(_("Unable to open <%s>"), input);
- if (parm.anull->answer != NULL)
- sscanf(parm.anull->answer, "%lf", &nul_val);
+ /* Find File Size in Byte and Check against byte size */
+ G_fseek(fp, 0, SEEK_END);
+ file_size = G_ftell(fp);
+ G_fseek(fp, 0, SEEK_SET);
- fd = fopen(input, "r");
- if (fd == NULL) {
- perror(input);
- G_usage();
- exit(EXIT_FAILURE);
/* Read binary GMT style header */
if (flag.gmt_hd->answer) {
- fread(&header.nx, sizeof(int), 1, fd);
- fread(&header.ny, sizeof(int), 1, fd);
- fread(&header.node_offset, sizeof(int), 1, fd);
- if (swapFlag == 0)
+ read_gmt_header(&header, swap_flag, fp);
+ get_gmt_header(&header, &cellhd);
- fread(&header.x_min, sizeof(double), 1, fd);
- fread(&header.x_max, sizeof(double), 1, fd);
- fread(&header.y_min, sizeof(double), 1, fd);
- fread(&header.y_max, sizeof(double), 1, fd);
- fread(&header.z_min, sizeof(double), 1, fd);
- fread(&header.z_max, sizeof(double), 1, fd);
- fread(&header.x_inc, sizeof(double), 1, fd);
- fread(&header.y_inc, sizeof(double), 1, fd);
- fread(&header.z_scale_factor, sizeof(double), 1, fd);
- fread(&header.z_add_offset, sizeof(double), 1, fd);
+ /* Adjust Cell Header to New Values */
+ if (err = G_adjust_Cell_head(&cellhd, 1, 1))
+ G_fatal_error("%s", err);
- fread(&header.x_units, sizeof(char[GRD_UNIT_LEN]), 1, fd);
- fread(&header.y_units, sizeof(char[GRD_UNIT_LEN]), 1, fd);
- fread(&header.z_units, sizeof(char[GRD_UNIT_LEN]), 1, fd);
- fread(&header.title, sizeof(char[GRD_TITLE_LEN]), 1, fd);
- fread(&header.command, sizeof(char[GRD_COMMAND_LEN]), 1, fd);
- fread(&header.remark, sizeof(char[GRD_REMARK_LEN]), 1, fd);
+ if (cellhd.proj == PROJECTION_LL && cellhd.ew_res / cellhd.ns_res > 10.)
+ /* TODO: find a reasonable value */
+ G_warning(
+ _("East-West (ewres: %f) and North-South (nwres: %f) "
+ "resolution differ significantly. "
+ "Did you assign east= and west= correctly?"),
+ cellhd.ew_res, cellhd.ns_res);
- cellhd.cols = header.nx;
- cellhd.rows = header.ny;
- cellhd.west = header.x_min;
- cellhd.east = header.x_max;
- cellhd.south = header.y_min;
- cellhd.north = header.y_max;
- cellhd.ew_res = header.x_inc;
- cellhd.ns_res = header.y_inc;
+ grass_nrows = nrows = cellhd.rows;
+ grass_ncols = ncols = cellhd.cols;
- if (swap == 1) {
- /* Swapping Header Values */
- SwabLong((uint32 *) & cellhd.cols);
- SwabLong((uint32 *) & cellhd.rows);
- SwabDouble(&cellhd.west);
- SwabDouble(&cellhd.east);
- SwabDouble(&cellhd.south);
- SwabDouble(&cellhd.north);
- SwabDouble(&cellhd.ew_res);
- SwabDouble(&cellhd.ns_res);
- /* Adjust Cell Header to match resolution */
- if (err = G_adjust_Cell_head(&cellhd, 0, 0)) {
- G_fatal_error("%s", err);
- nrows = header.ny;
- ncols = header.nx;
- grass_nrows = cellhd.rows;
- grass_ncols = cellhd.cols;
- /* Adjust Cell Header to New Values */
- if (err = G_adjust_Cell_head(&cellhd, 1, 1)) {
- grass_nrows = nrows = cellhd.rows;
- grass_ncols = ncols = cellhd.cols;
if (Rast_set_window(&cellhd) < 0)
- exit(3);
+ G_fatal_error(_("Unable to set window"));
if (grass_nrows != G_window_rows())
- G_fatal_error("rows changed from %d to %d\n", grass_nrows,
- G_window_rows());
+ G_fatal_error("rows changed from %d to %d",
+ grass_nrows, G_window_rows());
if (grass_ncols != G_window_cols())
- G_fatal_error("cols changed from %d to %d\n", grass_ncols,
- G_window_cols());
+ G_fatal_error("cols changed from %d to %d",
+ grass_ncols, G_window_cols());
+ expected = (off_t) ncols * nrows * bytes;
+ if (flag.gmt_hd->answer)
+ expected += 892;
- /* Find File Size in Byte and Check against byte size */
- if (stat(input, &fileinfo) < 0) {
- perror("fstat");
- exit(1);
+ if (file_size != expected) {
+ G_warning(_("File Size "PRI_OFF_T" ... Total Bytes "PRI_OFF_T),
+ file_size, expected);
+ G_fatal_error(_("Bytes do not match file size"));
- FILE_SIZE = fileinfo.st_size;
- if (flag.gmt_hd->answer) {
- if (swapFlag == 0) {
- if (FILE_SIZE != (896 + (ncols * nrows * bytes))) {
- G_warning(_("Bytes do not match File size"));
- G_warning(_("File Size %d ... Total Bytes %d"), FILE_SIZE,
- 896 + (ncols * nrows * bytes));
- G_warning(_("Try bytes=%d or adjusting input parameters"),
- (FILE_SIZE - 896) / (ncols * nrows));
- else {
- if (FILE_SIZE != (892 + (ncols * nrows * bytes))) {
- 892 + (ncols * nrows * bytes));
- (FILE_SIZE - 892) / (ncols * nrows));
- else {
- /* No Header */
- if (FILE_SIZE != (ncols * nrows * bytes)) {
- ncols * nrows * bytes);
- FILE_SIZE / (ncols * nrows));
+ in_buf = G_malloc(ncols * bytes);
+ out_buf = Rast_allocate_d_buf();
- if (flag.f->answer) {
- map_type = FCELL_TYPE;
- fcell = Rast_allocate_f_buf();
- else if (flag.d->answer) {
- map_type = DCELL_TYPE;
- dcell = Rast_allocate_d_buf();
- else {
- cell = Rast_allocate_c_buf();
- map_type = CELL_TYPE;
+ map_type = is_fp
+ ? (bytes > 4
+ ? DCELL_TYPE
+ : FCELL_TYPE)
+ : CELL_TYPE;
- cf = Rast_open_new(output, map_type);
- x_v = G_malloc(ncols * bytes);
- x_f = (float *)x_v;
- x_d = (double *)x_v;
- x_i = (uint32 *) x_v;
- x_s = (uint16 *) x_v;
- x_c = (char *)x_v;
+ fd = Rast_open_new(output, map_type);
- if (cellhd.proj == PROJECTION_LL && cellhd.ew_res / cellhd.ns_res > 10.) /* TODO: find a reasonable value */
- G_warning(
- _("East-West (ewres: %f) and North-South (nwres: %f) "
- "resolution differ significantly. "
- "Did you assign east= and west= correctly?"),
- cellhd.ew_res, cellhd.ns_res);
for (row = 0; row < grass_nrows; row++) {
- if (fread(x_v, bytes * ncols, 1, fd) != 1) {
- Rast_unopen(cf);
- G_fatal_error(_("Conversion failed at row %d"), row);
+ G_percent(row, nrows, 2);
- for (col = 0; col < grass_ncols; col++) {
- /* Import Float */
- if (swap)
- SwabFloat(&x_f[col]);
- fcell[col] = (FCELL) x_f[col];
- /* Import Double */
- if (swap)
- SwabDouble(&x_d[col]);
- dcell[col] = (DCELL) x_d[col];
- else if (bytes == 1) {
- /* Import 1 byte Byte */
- if (sflag)
- cell[col] = (CELL) (signed char)x_c[col];
- else
- cell[col] = (CELL) (unsigned char)x_c[col];
- else if (bytes == 2) {
- /* Import 2 byte Short */
- if (swap)
- SwabShort(&x_s[col]);
- if (sflag)
- cell[col] = (CELL) (signed short)x_s[col];
- else
- cell[col] = (CELL) (unsigned short)x_s[col];
- else {
- /* Import 4 byte Int */
- if (swap)
- SwabLong(&x_i[col]);
- if (sflag)
- cell[col] = (CELL) (signed int)x_i[col];
- else
- cell[col] = (CELL) (unsigned int)x_i[col];
- if (parm.anull->answer) {
- if (flag.d->answer) {
- if (dcell[col] == nul_val)
- Rast_set_d_null_value(&dcell[col], 1);
- else if (flag.f->answer) {
- if (fcell[col] == (float)nul_val)
- Rast_set_f_null_value(&fcell[col], 1);
- else {
- if (cell[col] == (int)nul_val)
- Rast_set_c_null_value(&cell[col], 1);
+ if (fread(in_buf, bytes, ncols, fp) != ncols)
- Rast_put_f_row(cf, fcell);
- Rast_put_d_row(cf, dcell);
- else
- Rast_put_c_row(cf, cell);
+ convert_row(out_buf, in_buf, ncols, is_fp, is_signed,
+ bytes, swap_flag, null_val);
- G_percent(row + 1, nrows, 2);
+ Rast_put_d_row(fd, out_buf);
+ G_percent(row, nrows, 2); /* finish it off */
+ Rast_close(fd);
+ fclose(fp);
G_debug(1, "Creating support files for %s", output);
- Rast_close(cf);
if (title)
Rast_put_cell_title(output, title);
@@ -590,6 +534,5 @@
Rast_command_history(&history);
Rast_write_history(output, &history);
- exit(EXIT_SUCCESS);
+ return EXIT_SUCCESS;
