[GRASS-SVN] r42760 - grass-addons/gui/wxpython/wx.path
svn_grass at osgeo.org
Sun Jul 11 09:33:38 EDT 2010
Author: rashadkm
Date: 2010-07-11 13:33:38 +0000 (Sun, 11 Jul 2010)
New Revision: 42760
grass-addons/gui/wxpython/wx.path/wx.path.py
errors in display fixed
Modified: grass-addons/gui/wxpython/wx.path/wx.path.py
--- grass-addons/gui/wxpython/wx.path/wx.path.py 2010-07-11 05:06:27 UTC (rev 42759)
+++ grass-addons/gui/wxpython/wx.path/wx.path.py 2010-07-11 13:33:38 UTC (rev 42760)
@@ -256,7 +256,7 @@
# Re-use dialogs
self.mapname = 'roads@' + grass.gisenv()['MAPSET']
- self.cmd= ['d.vect', str("map=" + self.mapname),'width=4']
+ self.cmd= ['d.vect', str("map=" + self.mapname),'width=1']
self.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
self.MapWindow.UpdateMap(render=True)
@@ -269,6 +269,7 @@
self.decorationDialog = None # decoration/overlays
#self.Maximize()
+ self.coords = []
self.points = []
@@ -277,12 +278,6 @@
def OnButtonDClick(self,event):
- self.mapname = 'graph@' + grass.gisenv()['MAPSET']
- self.Map.RemoveLayer(name=self.mapname)
- self.MapWindow.UpdateMap(render=True)
- # precision = int(UserSettings.Get(group = 'projection', key = 'format',
- # subkey = 'precision'))
try:
e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
print e,n
@@ -290,50 +285,31 @@
return
self.counter = self.counter + 1
- point =("%f|%f" % ( e, n))
- self.points.append(point + '|point')
+ coord =("%f %f" % ( e, n))
+ self.coords.append(coord)
if self.counter == 2:
- f =open("tmp1",'w')
+ self.points.append("1 ")
+ for p in self.coords:
+ self.points.append(p)
+ f =open("tmp",'w')
for p in self.points:
- f.write("%s\n" % p)
+ f.write("%s " % p)
f.close()
- f =open("tmp2",'w')
- f.write("%d %d %d\n" %(1,1,2) )
- f.close()
+ command=["v.net.path", 'input=roads', 'output=path','file=tmp','--overwrite']
+ gcmd.CommandThread(command).run()
- command =["g.remove",'vect=path,vnet,startend']
- gcmd.CommandThread(command,stdout=None,stderr=None).run()
-# command =["v.in.ascii",'input=tmp1','output=startend']
- z =gcmd.RunCommand('v.in.ascii',input='tmp1',output='startend')
- if z == 1:
- print "error executing v.in.ascii"
- return 1
- #command=["v.net", "input=roads",'points=startend', 'output=vnet', 'op=connect', 'thresh=200']
- y=gcmd.RunCommand('v.net', input='roads',points='startend', output='vnet', op='connect', thresh='200')
- if y == 1:
- print "error executing v.net"
- return 1
- #command=["v.net.path", 'input=vnet', 'output=path','file=tmp2']
- x= gcmd.RunCommand('v.net.path', input='vnet', output='path', file='tmp2')
- if x == 1:
- print "error executing v.net.path"
- return 1
self.mapname = 'path@'+ grass.gisenv()['MAPSET']
self.cmd= ['d.vect', str("map=" + self.mapname),'col=red','width=2']
self.counter =0
- self.points=[]
+ self.coords=[]
+ self.points=[]
