[GRASS-SVN] r42761 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Sun Jul 11 12:57:57 EDT 2010
Author: aghisla
Date: 2010-07-11 16:57:57 +0000 (Sun, 11 Jul 2010)
New Revision: 42761
grass/trunk/imagery/i.atcorr/create_iwave.py
Improved print function, result is closer to cpp.
Modified: grass/trunk/imagery/i.atcorr/create_iwave.py
--- grass/trunk/imagery/i.atcorr/create_iwave.py 2010-07-11 13:33:38 UTC (rev 42760)
+++ grass/trunk/imagery/i.atcorr/create_iwave.py 2010-07-11 16:57:57 UTC (rev 42761)
@@ -117,32 +117,18 @@
Create pretty string out of filter function
8 values per line, with spaces, commas and all the rest
- nlines = int(len(filter_f)/8)
- rest = len(filter_f) - nlines*8
- pstring = ' '
- if rest == 0: # multiple of 8; special case
- for l in range(nlines):
- for i in range(8):
- if l == nlines-1 and i == 7: # last value
- pstring = pstring+' %.4f \n' % (filter_f[l*8+i])
- pstring = pstring+' };'
- else:
- pstring = pstring+' %.4f,' % (filter_f[l*8+i])
- pstring = pstring+'\n '
- else:
- # adding rest of values in filter_f
- for i in range(rest):
- if i == rest-1: # last value
- pstring = pstring+' %.4f \n' % (filter_f[nlines*8+i])
- else:
- pstring = pstring+' %.4f,' % (filter_f[nlines*8+i])
+ pstring = ''
+ for i in range(len(filter_f)):
+ if i%8 is 0:
+ if i is not 1:
+ # trim the trailing whitespace at the end of line
+ pstring = pstring.rstrip()
+ pstring += "\n\t\t"
+ else:
+ value_wo_leading_zero = ('%.4f' % (filter_f[i-1])).lstrip('0')
+ pstring += value_wo_leading_zero+', '
+ # trim starting \n and trailing ,
+ pstring = pstring.lstrip("\n").rstrip(", ")
return pstring
def write_cpp(bands, values, sensor, folder):
@@ -176,7 +162,7 @@
# single band case
if len(bands) == 1:
outfile.write(' /* %s of %s */\n' % (bands[0], sensor))
- outfile.write(' static const float sr[%i] = {\n' % (len(filter_f)))
+ outfile.write(' static const float sr[%i] = {' % (len(filter_f)))
filter_text = pretty_print(filter_f)
outfile.write(filter_text)
@@ -199,7 +185,7 @@
outfile.write(' /* %s of %s */\n' % (bands[b], sensor))
outfile.write(' static const float sr%i[%i] = {\n' % (b+1,len(filter_f[b])))
filter_text = pretty_print(filter_f[b])
- outfile.write(filter_text+'\n')
+ outfile.write(filter_text+'\n };\n\t\n')
# writing band limits
for b in range(len(bands)):
