[GRASS-SVN] r42793 - grass/trunk/gui/wxpython/docs
Thu Jul 15 04:59:51 EDT 2010
Author: mmetz
Date: 2010-07-15 08:59:51 +0000 (Thu, 15 Jul 2010)
New Revision: 42793
Added:
   grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
   grass/trunk/gui/wxpython/docs/wxGUI_GCP_Manager.jpg
   grass/trunk/gui/wxpython/docs/Makefile
   grass/trunk/gui/wxpython/docs/wxGUI.html
add manual for GCP Manager
Modified: grass/trunk/gui/wxpython/docs/Makefile
--- grass/trunk/gui/wxpython/docs/Makefile	2010-07-15 07:00:10 UTC (rev 42792)
+++ grass/trunk/gui/wxpython/docs/Makefile	2010-07-15 08:59:51 UTC (rev 42793)
@@ -6,6 +6,7 @@
 	wxGUI.Vector_Digitizing_Tool \
 	wxGUI.Attribute_Table_Manager \
 	wxGUI.Nviz \
+	wxGUI.GCP_Manager \
 	wxGUI.Icons \
 	wxGUI.Modeler
Added: grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html	                        (rev 0)
+++ grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html	2010-07-15 08:59:51 UTC (rev 42793)
@@ -0,0 +1,308 @@
+<h2>DESCRIPTION</h2>
+<p>
+The <b>GCP Manager</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
+extension which allows the user to create, edit, and manage
+Ground Control Points. It is available from the menu
+&quot;File | Manage Ground Control Points&quot;.
+<p>
+The <b>GCP Manager</b> provides an interactive graphical interface to
+manage and analyze Ground Control Points. A backup copy of the initial
+POINTS file is always maintained and updated only on request (Save GCPs
+to POINTS file). This guarantees that accidential changes are not
+permanent and can be undone by reloading the Ground Control Points.
+<p>
+The GCP Manager must be started in the target location, not in the
+source location.
+<p>
+The GCP Manager is structured into three panels:
+<ul>
+  <li>The topmost panel shows a list of Ground Control Points. Tools to
+  manipulate and analyze GCPs are provided in the toolbar. This panel can
+  be moved out of the GCP manager window by either dragging with the
+  caption or by clicking on the pin button on the right in the caption.
+  This panel can also be placed below the map displays by dragging.
+  <li>The two panels in the lower part are used for map and GCP display,
+  the left pane showing a map from the source location and the right
+  pane showing a reference map from the target location. Numbered Ground
+  Control Points are shown on both map displays.
+</ul>
+<h3>Components of the GCP Manager</h3>
+<center>
+  <br><img src="wxGUI_GCP_Manager.jpg" border="0" alt="GCP Manager"><br><br>
+</center>
+<p>
+<em>Toolbars</em>
+<p>
+Two toolbars are provided with the GCP Manager, one for managing the map
+displays and one for managing the GCP list.
+<p>
+<em>List of ground control points</em>
+<p>
+The list of Ground Control Points can be sorted by clicking on a column
+header. Clicking on a cloumn header will sort the GCPs ascending, a
+second click on the same column will sort the GCPs descending. Overall
+RMS error and individual RMS errors of all points are often improved if
+the GCP with the highest RMS error is adjusted. Individual coordinates
+can be edited by double-clicking on a row.
+<p>
+The first column holds a checkbox and displays the point number. A GCP
+is only used for RMS error calculation and georectification if its
+checkbox on the left is checked. Uncheck to deactivate a GCP (mark as
+unused GCP).
+<p>
+<em>Two panels for map display</em>
+<p>
+The left panel is used to display a map from the source location, the
+right panel to display a map from the target loaction. Zooming in and
+out is always possible with the mouse wheel and done for each map canvas
+separately.
+<p>
+GCPs are displayed in different colors, depending on whether a GCP has
+a high RMS error, is currently unused or is currently selected. Optionally,
+currently unused GCPs are not shown on the map display.
+<p>
+<em>Statusbar</em>
+<p>
+At the bottom of the GCP Manager is a statusbar providing several
+functions. The default is set to <em>Go to GCP No.</em> (see also below).
+Typing a number or using the up/down arrows will center the maps on the
+given GCP, useful with a high zoom.
+<h4>GCP Map Display Toolbar</h4>
+<dl>
+<dt><img src="icons/grass2/show.png">&nbsp;
+  <em>Display map</em></dt>
+<dd>Displays maps for source and target canvas and re-renders any layers
+that have changed since the last time the display was updated.</dd>
+<dt><img src="icons/grass2/layer-redraw.png">&nbsp;
+  <em>Re-render map</em></dt>
+<dd>Re-renders both source and target canvas regardless of whether they
+have changed or not.</dd>
+<dt><img src="icons/grass2/erase.png">&nbsp;
+  <em>Erase display</em></dt>
+<dd>Erases both source and target canvas to a white background.</dd>
+<dt><img src="icons/grass2/gcp-create.png">&nbsp;
+  <em>Define GCP (Ground Control Points)</em></dt>
+<dd>On left mouse click, coordinates are defined for the currently
+selected GCP.</dd>
+<dt><img src="icons/grass2/pan.png">&nbsp;
+  <em>Pan</em></dt>
+<dd>Interactive selection of a new center of view in the active
+display monitor. Drag the pan cursor while pressing the left mouse
+button to pan. Alternatively left-click on the new center. Panning
+changes the location of the region displayed but not the size of the
+area displayed or the resolution.</dd>
+<dt><img src="icons/grass2/zoom-in.png">&nbsp;
+  <em>Zoom in</em></dt>
+<dd>Interactive zooming with the mouse in the active map canvas (source
+or target). Drawing a box or just a left click with the mouse and zoom-in
+cursor causes the display to zoom in so that the area defined by the box
+fills the display. The map resolution is not changed. Clicking with the
+zoom-in cursor causes the display to zoom in by 30%, centered on the
+point where the mouse is clicked. Zooming changes the display region
+extents (both size and location of area displayed).</dd>
+<dt><img src="icons/grass2/zoom-out.png">&nbsp;
+  <em>Zoom out</em></dt>
+or target). Drawing a box or just a left click with the mouse and zoom-out
+cursor causes the display to zoom out so that the area displayed
+shrinks to fill the area defined by the box. The map resolution is not
+changed. Clicking with the zoom-out cursor causes the display to zoom
+out by 30%, centered on the point where the mouse is clicked. Zooming
+changes the display region extents (both size and location of area
+displayed).</dd>
+<dt><img src="icons/grass2/zoom-more.png">&nbsp;
+  <em>Adjust display zoom</em></dt>
+<dd>Source and target display are adjusted by using the current GCPs for
+coordinate transformation:
+<br><br>
+  <dl>
+    <dt><em>Adjust source display to target display</em>
+    <dd>The extends of the source display are adjusted to the current
+    extends of the target display.
+    <dt><em>Adjust target display to source display</em>
+  </dl>
+<dt><em>Set active map canvas</em></dt>
+<dd>Sets the currently active map canvas (source or target). Click
+to set active map canvas for <em>Return to previous zoom</em> or
+<em>Zoom to extend of currently displayed map</em>. Alternatively, move
+the mouse over the map canvas to be used as active canvas.</dd>
+<dt><img src="icons/grass2/zoom-last.png">&nbsp;
+  <em>Return to pervious zoom</em></dt>
+<dd>Returns to the previous zoom extent. Up to 10 levels of zoom back are
+maintained.</dd>
+<dt><img src="icons/grass2/zoom-extend.png">&nbsp;
+<em>Zoom to extend of currently displayed map</em></dt>
+<dd>Zoom to the extend of the currently displayed map in the active map
+canvas (source or target).</dd>
+<dt><img src="icons/grass2/settings.png">&nbsp;
+<em>Settings</em></dt>
+<dd>Shows a settings dialog for GCP management and display:<br><br>
+  <dl>
+    <dt><em>Symbology</em></dt>
+      <dd>Settings for map and GCP display:<br><br>
+      <dl>
+        <dt><em>Highlight highest RMS error only</em></dt>
+          <dd>Only the GCP with the highest RMS error will be displayed in
+          a different colour, both in the list of GCPs and the GCP Map Display.
+        <dt><em>Factor for RMS error threshold = M + SD * factor:</em></dt>
+          <dd>All GCPs with an RMS error larger than mean RMS + RMS standard
+          deviation * this factor will be displayed in a different colour,
+          both in the list of GCPs and the GCP Map Display. As a rule of
+          thumb, GCPs with an RMS error larger than <em>M + SD * 2</em> are
+          most probably wrong. GCPs with an RMS error larger than
+          <em>M + SD * 1</em> are worth closer inspection. This option is
+          only available if <em>Highlight highest RMS error only</em> is
+          unchecked.</dd>
+        <dt><em>Color</em></dt>
+          <dd>Set the color for GCPs on the GCP Map Display.</dd>
+        <dt><em>Color for high RMS error</em></dt>
+          <dd>Set the color for GCPs with a high RMS error on the GCP Map
+          Display.</dd>
+        <dt><em>Color for selected GCP</em></dt>
+          <dd>Set the color for the currently selected GCP on the GCP Map
+          Display.</dd>
+        <dt><em>Show unused GCPs</em></dt>
+          <dd>If unchecked, unused GCPs will not be shown on the GCP Map
+          Display.</dd>
+        <dt><em>Color for unused GCPs</em></dt>
+          <dd>Set the color for unused GCPs on the GCP Map Display.</dd>
+        <dt><em>Symbol size</em></dt>
+          <dd>Set the symbol size for GCPs on the GCP Map Display.</dd>
+        <dt><em>Line width</em></dt>
+          <dd>Set the line width for GCPs on the GCP Map Display.</dd>
+        <dt><em>Select source map to display</em></dt>
+          <dd>Select a source map for the left pane of the GCP Map Display.</dd>
+        <dt><em>Select target map to display</em></dt>
+          <dd>Select a target map for the right pane of the GCP Map Display.</dd>
+      </dl>
+      </dd>
+    <dt><br><em>Rectification</em></dt>
+      <dd>Settings for georectification:<br><br>
+      <dl>
+        <dt><em>Select rectification method</em></dt>
+          <dd>Set the polynomial order for georectification. This order will
+          also be used for RMS error calculation.</dd>
+        <dt><em>Clip to computational region in target location</em></dt>
+          <dd>Clip raster maps to the current computational region in the
+          target location when georectifying.</dd>
+        <dt><em>Extension for output maps</em></dt>
+          <dd>Change the extension for output map names when doing the actual
+          georectification.</dd>
+      </dl>
+      </dd>
+  </dl><br>
+</dd>
+<dt>
+<em>Show Help</em></dt>
+<dd>Show help page for the GCP Manager.
+<dt><img src="icons/grass2/quit.png">&nbsp;
+<em>Quit</em></dt>
+<dd>Quit the GCP Manager.
+</dl>
+<h4>Toolbar for the GCP list</h4>
+<dl>
+<dt><img src="icons/grass2/gcp-save.png">&nbsp;
+<em>Save GCPs to POINTS file</em></dt>
+<dd>The current list of GCPs is saved to the imagery group's POINTS file
+and to a backup copy.</dd>
+<dt><img src="icons/grass2/gcp-add.png">&nbsp;
+<em>Add new GCP</em></dt>
+<dd>Adds a new Ground Control Point to the list and selects it for editing.</dd>
+<dt><img src="icons/grass2/gcp-delete.png">&nbsp;
+<em>Delete selected GCP</em></dt>
+<dd>Deletes the currently selected GCP from the list.</dd>
+<dt><img src="icons/grass2/gcp-remove.png">&nbsp;
+<em>Clear selected GCP</em></dt>
+<dd>Resets all coordinates of the currently selected GCP to 0 (zero).</dd>
+<dt><img src="icons/grass2/reload.png">&nbsp;
+<em>Reload GCPs from POINTS file</em></dt>
+<dd>Reloads GCPs from the imagery group's POINTS file.</dd>
+<dt><img src="icons/grass2/gcp-rms.png">&nbsp;
+<em>Recalculate RMS error</em></dt>
+<dd>Recalculates forward and backward RMS error for all GCP marked for
+use (activated checkbox in first row).
+</dd>
+<dt><img src="icons/grass2/georectify.png">&nbsp;
+<em>Georectify</em></dt>
+<dd>Uses <em><a href="i.rectify.html">i.rectify</a></em> to georectify
+all images in the source imagery group.
+</dd>
+</dl>
+<h4>GCP Map Display Statusbar</h4>
+The GCP map display statusbar is similar to the statusbar in the regular
+GRASS GIS map display with two differences, <em>Go to</em> has been
+replaced with <em>Go to GCP No.</em> and <em>Projection</em> has been
+replaced with <em>RMS error</em>.
+<p>
+If <em>Go to GCP No.</em> is selected, a GCP number can be given in the
+left side of the statusbar and the source and target map canvas will be
+centered on the given GCP. Clicking on the map canvas will update
+coordinates for this GCP.
+<p>
+If <em>RMS error</em> is selected, the overall forward and backward RMS
+error is displayed.
+<h2>SEE ALSO</h2>
+<em>
+  <a href="wxGUI.html">wxGUI</a><br>
+  <a href="i.rectify.html">i.rectify</a><br>
+  <a href="g.transform.html">g.transform</a>
+</em>
+<h2>AUTHORS</h2>
+Markus Metz<br><br>
+<em>Based on the Georectifier by</em><br>
+Michael Barton<br>
+Martin Landa<br>
+<p>
+<i>$Date$</i>
Property changes on: grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html	2010-07-15 07:00:10 UTC (rev 42792)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html	2010-07-15 08:59:51 UTC (rev 42793)
@@ -517,10 +517,11 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="wxGUI.Vector_Digitizing_Tool.html">Vector Digitizer</a>,
-  <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a>,
-  <a href="wxGUI.Nviz.html">3D Viewer</a>,
-  <a href="wxGUI.Modeler.html">Graphical Modeler</a>,
+  <a href="wxGUI.Vector_Digitizing_Tool.html">Vector Digitizer</a><br>
+  <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
+  <a href="wxGUI.Nviz.html">3D Viewer</a><br>
+  <a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
+  <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
   <a href="wxGUI.Icons.html">Icon themes</a>
 </em>
Added: grass/trunk/gui/wxpython/docs/wxGUI_GCP_Manager.jpg
(Binary files differ)
Property changes on: grass/trunk/gui/wxpython/docs/wxGUI_GCP_Manager.jpg
   + image/jpeg
