[GRASS-SVN] r42794 - in grass/trunk/gui/wxpython: . gui_modules xml
    svn_grass at osgeo.org
    Thu Jul 15 05:03:39 EDT 2010
Author: mmetz
Date: 2010-07-15 09:03:38 +0000 (Thu, 15 Jul 2010)
New Revision: 42794
Added:
   grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
   grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
   grass/trunk/gui/wxpython/gui_modules/__init__.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/menudata.xml
add GCP Manager, wxGUI version of i.points
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -8,6 +8,8 @@
     "gcmd.py",
     "gdialogs.py",
     "georect.py",
+    "gcpmanager.py",
+    "gcpmapdisp.py",
     "ghelp.py"
     "globalvar.py",
     "goutput.py",
Added: grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmanager.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmanager.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -0,0 +1,2536 @@
+ at package gcpmanager.py
+ at brief Georectification module for GRASS GIS. Includes ground control
+point management and interactive point and click GCP creation
+Classes:
+ - GCPWizard
+ - LocationPage
+ - GroupPage
+ - DispMapPage
+ - GCP
+ - GCPList
+ - VectGroup
+ - EditGCP
+ - GrSettingsDialog
+(C) 2006-2010 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Markus Metz
+ at author Michael Barton
+ at author Updated by Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import tempfile
+import shutil
+import time
+import wx
+from wx.lib.mixins.listctrl import CheckListCtrlMixin, ColumnSorterMixin, ListCtrlAutoWidthMixin
+import wx.lib.colourselect as  csel
+import wx.wizard as wiz
+from wx.lib.embeddedimage import PyEmbeddedImage
+import grass.script as grass
+import globalvar
+import render
+import toolbars
+import menuform
+import gselect
+import gcmd
+import utils
+from debug import Debug as Debug
+from icon import Icons as Icons
+from location_wizard import TitledPage as TitledPage
+from preferences import globalSettings as UserSettings
+from gcpmapdisp import MapFrame
+from mapdisp_window import BufferedWindow
+try:
+    import subprocess # Not needed if GRASS commands could actually be quiet
+except:
+    CompatPath = globalvar.ETCWXDIR
+    sys.path.append(CompatPath)
+    from compat import subprocess
+gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
+sys.path.append(gmpath)
+# global variables
+global src_map
+global tgt_map
+global maptype
+src_map = ''
+tgt_map = ''
+maptype = 'cell'
+class GCPWizard(object):
+    Start wizard here and finish wizard here
+    def __init__(self, parent):
+        self.parent = parent # GMFrame
+        # get environmental variables
+        self.grassdatabase = grass.gisenv()['GISDBASE']
+        # read original environment settings
+        self.target_gisrc = os.environ['GISRC']
+        self.gisrc_dict = {}
+        try:
+            f = open(self.target_gisrc, 'r')
+            for line in f.readlines():
+                line = line.replace('\n', '').strip()
+                if len(line) < 1:
+                    continue
+                key, value = line.split(':', 1)
+                self.gisrc_dict[key.strip()] = value.strip()
+        finally:
+            f.close()
+        self.currentlocation = self.gisrc_dict['LOCATION_NAME']
+        self.currentmapset = self.gisrc_dict['MAPSET']
+        # location for xy map to georectify
+        self.newlocation = ''
+        # mapset for xy map to georectify
+        self.newmapset = ''
+        global maptype
+        global src_map
+        global tgt_map
+        src_map = ''
+        tgt_map = ''
+        maptype = 'cell'
+        # GISRC file for source location/mapset of map(s) to georectify
+        self.source_gisrc = ''
+        # define wizard pages
+        self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY, title=_("Setup for georectification"))
+        self.startpage = LocationPage(self.wizard, self)
+        self.grouppage = GroupPage(self.wizard, self)
+        self.mappage = DispMapPage(self.wizard, self)
+        # set the initial order of the pages
+        self.startpage.SetNext(self.grouppage)
+        self.grouppage.SetPrev(self.startpage)
+        self.grouppage.SetNext(self.mappage)
+        self.mappage.SetPrev(self.grouppage)
+        # do pages layout
+        self.startpage.DoLayout()
+        self.grouppage.DoLayout()
+        self.mappage.DoLayout()
+        self.wizard.FitToPage(self.startpage)
+        # self.Bind(wx.EVT_CLOSE,    self.Cleanup)
+        # self.parent.Bind(wx.EVT_ACTIVATE, self.OnGLMFocus)
+        success = False
+        # run wizard
+        if self.wizard.RunWizard(self.startpage):
+            success = self.OnWizFinished()
+            if success == False:
+                wx.MessageBox(parent=self.parent,
+                              message=_("Georectifying setup canceled."),
+                              caption=_("Georectify"),
+                              style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+                self.Cleanup()
+        else:
+            self.Cleanup()
+        # start GCP display
+        if success != False:
+            # instance of render.Map to be associated with display
+            self.SwitchEnv('source')
+            self.SrcMap = render.Map(gisrc=self.source_gisrc)
+            self.SwitchEnv('target')
+            self.TgtMap = render.Map(gisrc=self.target_gisrc)
+            self.Map = self.SrcMap
+            # add layer to source map
+            if maptype == 'cell':
+                rendertype = 'raster'
+                cmdlist = ['d.rast', 'map=%s' % src_map]
+            else: # -> vector layer
+                rendertype = 'vector'
+                cmdlist = ['d.vect', 'map=%s' % src_map]
+            self.SrcMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
+                              name=utils.GetLayerNameFromCmd(cmdlist),
+                              l_hidden=False, l_opacity=1.0, l_render=False)
+            # add layer to target map
+                cmdlist = ['d.rast', 'map=%s' % tgt_map]
+                cmdlist = ['d.vect', 'map=%s' % tgt_map]
+            self.TgtMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
+            # start GCP Manager
+            self.gcpmgr = GCP(self.parent, grwiz=self, size=globalvar.MAP_WINDOW_SIZE,
+                                               toolbars=["gcpdisp"],
+                                               Map=self.SrcMap, lmgr=self.parent)
+            # load GCPs
+            self.gcpmgr.InitMapDisplay()
+            self.gcpmgr.CenterOnScreen()
+            self.gcpmgr.Show()
+            #self.gcpmgr.Centre()
+            #self.gcpmgr.Raise()
+        else:
+            self.Cleanup()
+    def SetSrcEnv(self, location, mapset):
+        """!Create environment to use for location and mapset
+        that are the source of the file(s) to georectify
+        @param location source location
+        @param mapset source mapset
+        @return False on error
+        @return True on success
+        self.newlocation = location
+        self.newmapset = mapset
+        # check to see if we are georectifying map in current working location/mapset
+        if self.newlocation == self.currentlocation and self.newmapset == self.currentmapset:
+            return False
+        self.gisrc_dict['LOCATION_NAME'] = location
+        self.gisrc_dict['MAPSET'] = mapset
+        self.source_gisrc = utils.GetTempfile()
+        try:
+            f = open(self.source_gisrc, mode='w')
+            for line in self.gisrc_dict.items():
+                f.write(line[0] + ": " + line[1] + "\n")
+        finally:
+            f.close()
+        return True
+    def SwitchEnv(self, grc):
+        Switches between original working location/mapset and
+        location/mapset that is source of file(s) to georectify
+            return False
+        if grc == 'target':
+            os.environ["GISRC"] = str(self.target_gisrc)
+        elif grc == 'source':
+            os.environ["GISRC"] = str(self.source_gisrc)
+        return True
+    def OnWizFinished(self):
+        # self.Cleanup()
+        return True
+    def OnGLMFocus(self, event):
+        """!Layer Manager focus"""
+        # self.SwitchEnv('target')
+        event.Skip()
+    def Cleanup(self):
+        """!Return to current location and mapset"""
+        self.parent.gcpmanagement = None
+        self.wizard.Destroy()
+class LocationPage(TitledPage):
+    Set map type (raster or vector) to georectify and
+    select location/mapset of map(s) to georectify.
+    def __init__(self, wizard, parent):
+        TitledPage.__init__(self, wizard, _("Select map type and location/mapset"))
+        self.grassdatabase = self.parent.grassdatabase
+        self.xylocation = ''
+        self.xymapset = ''
+        # layout
+        self.sizer.AddGrowableCol(2)
+        # map type
+        self.rb_maptype = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                                      label=' %s ' % _("Map type to georectify"),
+                                      choices=[_('raster'), _('vector')],
+                                      majorDimension=wx.RA_SPECIFY_COLS)
+        self.sizer.Add(item=self.rb_maptype,
+                       flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
+                       pos=(1, 1), span=(1, 2))
+        # location
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source location:')),
+                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5,
+                       pos=(2, 1))
+        self.cb_location = gselect.LocationSelect(parent = self, gisdbase = self.grassdatabase)
+        self.sizer.Add(item=self.cb_location,
+                       pos=(2, 2))
+        # mapset
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source mapset:')),
+                       pos=(3, 1))
+        self.cb_mapset = gselect.MapsetSelect(parent = self, gisdbase = self.grassdatabase,
+                                              setItems = False)
+        self.sizer.Add(item=self.cb_mapset,
+                       pos=(3,2))
+        # bindings
+        self.Bind(wx.EVT_RADIOBOX, self.OnMaptype, self.rb_maptype)
+        self.Bind(wx.EVT_COMBOBOX, self.OnLocation, self.cb_location)
+        self.Bind(wx.EVT_COMBOBOX, self.OnMapset, self.cb_mapset)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+        # self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
+    def OnMaptype(self,event):
+        """!Change map type"""
+        global maptype
+        if event.GetInt() == 0:
+            maptype = 'cell'
+        else:
+            maptype = 'vector'
+    def OnLocation(self, event):
+        """!Sets source location for map(s) to georectify"""
+        self.xylocation = event.GetString()
+        #create a list of valid mapsets
+        tmplist = os.listdir(os.path.join(self.grassdatabase, self.xylocation))
+        self.mapsetList = []
+        for item in tmplist:
+            if os.path.isdir(os.path.join(self.grassdatabase, self.xylocation, item)) and \
+                os.path.exists(os.path.join(self.grassdatabase, self.xylocation, item, 'WIND')):
+                if item != 'PERMANENT':
+                    self.mapsetList.append(item)
+        self.xymapset = 'PERMANENT'
+        utils.ListSortLower(self.mapsetList)
+        self.mapsetList.insert(0, 'PERMANENT')
+        self.cb_mapset.SetItems(self.mapsetList)
+        self.cb_mapset.SetStringSelection(self.xymapset)
+        if not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
+            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+    def OnMapset(self, event):
+        """!Sets source mapset for map(s) to georectify"""
+        if self.xylocation == '':
+            wx.MessageBox(_('You must select a valid location before selecting a mapset'))
+            return
+        self.xymapset = event.GetString()
+    def OnPageChanging(self, event=None):
+        if event.GetDirection() and \
+               (self.xylocation == '' or self.xymapset == ''):
+            wx.MessageBox(_('You must select a valid location and mapset in order to continue'))
+            event.Veto()
+            return
+        self.parent.SetSrcEnv(self.xylocation, self.xymapset)
+    def OnEnterPage(self, event=None):
+        if self.xylocation == '' or self.xymapset == '':
+            wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+        else:
+class GroupPage(TitledPage):
+    Set group to georectify. Create group if desired.
+        TitledPage.__init__(self, wizard, _("Select image/map group to georectify"))
+        self.groupList = []
+        self.xygroup = ''
+        # default extension
+        self.extension = 'georect' + str(os.getpid())
+        # layout
+        # group
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select group:')),
+                       pos=(1, 1))
+        self.cb_group = wx.ComboBox(parent=self, id=wx.ID_ANY,
+                                    choices=self.groupList, size=(350, -1),
+                                    style=wx.CB_DROPDOWN | wx.CB_READONLY)
+        self.sizer.Add(item=self.cb_group,
+                       pos=(1, 2))
+        # create group
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Create group if none exists')),
+                       pos=(2, 1))
+        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.btn_mkgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Create/edit group..."))
+        self.btn_vgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Add vector map to group..."))
+        btnSizer.Add(item=self.btn_mkgroup,
+                     flag=wx.RIGHT, border=5)
+        btnSizer.Add(item=self.btn_vgroup,
+                     flag=wx.LEFT, border=5)
+        self.sizer.Add(item=btnSizer,
+                       pos=(2, 2))
+        # extension
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Extension for output maps:')),
+                       pos=(3, 1))
+        self.ext_txt = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(350,-1))
+        self.ext_txt.SetValue(self.extension)
+        self.sizer.Add(item=self.ext_txt,
+                       pos=(3, 2))
+        # bindings
+        self.Bind(wx.EVT_COMBOBOX, self.OnGroup, self.cb_group)
+        self.Bind(wx.EVT_TEXT, self.OnExtension, self.ext_txt)
+        self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
+        # hide vector group button by default
+        self.btn_vgroup.Hide()
+    def OnGroup(self, event):
+        self.xygroup = event.GetString()
+    def OnMkGroup(self, event):
+        """!Create new group in source location/mapset"""
+        menuform.GUI().ParseCommand(['i.group'],
+                                    completed=(self.GetOptData, None, ''),
+                                    parentframe=self.parent.parent, modal=True)
+    def OnVGroup(self, event):
+        """!Add vector maps to group"""
+        dlg = VectGroup(parent = self,
+                        id = wx.ID_ANY,
+                        grassdb = self.grassdatabase,
+                        location = self.xylocation,
+                        mapset = self.xymapset,
+                        group = self.xygroup)
+        if dlg.ShowModal() != wx.ID_OK:
+            return
+        dlg.MakeVGroup()
+        self.OnEnterPage()
+    def GetOptData(self, dcmd, layer, params, propwin):
+        """!Process i.group"""
+        # update the page
+        if dcmd:
+            gcmd.Command(dcmd)
+        self.Update()
+    def OnExtension(self, event):
+        self.extension = event.GetString()
+        if event.GetDirection() and self.xygroup == '':
+            wx.MessageBox(_('You must select a valid image/map group in order to continue'))
+            event.Veto()
+            return
+        if event.GetDirection() and self.extension == '':
+            wx.MessageBox(_('You must enter an map name extension in order to continue'))
+            event.Veto()
+            return
+        global maptype
+        self.xylocation = self.parent.gisrc_dict['LOCATION_NAME']
+        self.xymapset = self.parent.gisrc_dict['MAPSET']
+        # create a list of groups in selected mapset
+                                      self.xylocation,
+                                      self.xymapset,
+                                      'group')):
+                                              self.xylocation,
+                                              self.xymapset,
+                                              'group'))
+                                              self.xylocation,
+                                              self.xymapset,
+                                              'group',
+                                              item)):
+                    self.groupList.append(item)
+            self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
+        elif maptype == 'vector':
+            self.btn_vgroup.Show()
+            self.Bind(wx.EVT_BUTTON, self.OnVGroup, self.btn_vgroup)
+        utils.ListSortLower(self.groupList)
+        self.cb_group.SetItems(self.groupList)
+        if len(self.groupList) > 0 and \
+                self.xygroup == '':
+            self.cb_group.SetSelection(0)
+            self.xygroup = self.groupList[0]
+        if self.xygroup == '' or \
+                self.extension == '':
+        else:
+        # switch to source
+        self.parent.SwitchEnv('source')
+class DispMapPage(TitledPage):
+    Select ungeoreferenced map to display for interactively
+    setting ground control points (GCPs).
+                            _("Select maps to display for ground control point (GCP) creation"))
+        global maptype
+        # layout
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source map to display:')),
+                       pos=(1, 1))
+        self.srcselection = gselect.Select(self, id=wx.ID_ANY,
+                                        size=globalvar.DIALOG_GSELECT_SIZE, type='cell', updateOnPopup = False)
+        self.sizer.Add(item=self.srcselection,
+                       pos=(1, 2))
+        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select target map to display:')),
+                       pos=(2, 1))
+        self.tgtselection = gselect.Select(self, id=wx.ID_ANY,
+        self.sizer.Add(item=self.tgtselection,
+                       pos=(2, 2))
+        # bindings
+        self.srcselection.Bind(wx.EVT_TEXT, self.OnSrcSelection)
+        self.tgtselection.Bind(wx.EVT_TEXT, self.OnTgtSelection)
+    def OnSrcSelection(self,event):
+        """!Source map to display selected"""
+        global src_map
+        global maptype
+        src_map = event.GetString()
+        if src_map == '' or tgt_map == '':
+        else:
+        try:
+        # set computational region to match selected map and zoom display to region
+                p = gcmd.Command(['g.region', 'rast=src_map'])
+                p = gcmd.Command(['g.region', 'vect=src_map'])
+            if p.returncode == 0:
+                print 'returncode = ', str(p.returncode)
+                self.parent.Map.region = self.parent.Map.GetRegion()
+        except:
+            pass
+    def OnTgtSelection(self,event):
+        global tgt_map
+        tgt_map = event.GetString()
+        else:
+        global src_map
+        global tgt_map
+        if event.GetDirection() and (src_map == '' or tgt_map == ''):
+            wx.MessageBox(_('You must select maps in order to continue'))
+            event.Veto()
+            return
+        self.parent.SwitchEnv('target')
+        global maptype
+        global src_map
+        global tgt_map
+        self.srcselection.SetElementList(maptype,
+                                      mapsets = [self.parent.newmapset, ])
+        self.srcselection.GetElementList()
+        self.tgtselection.SetElementList(maptype)
+        self.tgtselection.GetElementList()
+        else:
+class GCP(MapFrame, wx.Frame, ColumnSorterMixin):
+    Manages ground control points for georectifying. Calculates RMS statics.
+    Calls i.rectify or v.transform to georectify map.
+    def __init__(self, parent, grwiz = None, mapdisp = None, id = wx.ID_ANY,
+                 title = _("Manage Ground Control Points"),
+                 size = (700, 300), toolbars=["gcpdisp"], Map=None, lmgr=None):
+        self.grwiz = grwiz # GR Wizard
+        #wx.Frame.__init__(self, parent, id, title, size = size, name = "GCPFrame")
+        MapFrame.__init__(self, parent, id, title, size = size,
+                            Map=Map, toolbars=["gcpdisp"], lmgr=lmgr, name='GCPMapWindow')
+        # init variables
+        self.parent.gcpmanagement = self
+        self.mapdisp = self # XY-location Map Display
+        self.grassdatabase = self.grwiz.grassdatabase
+        self.currentlocation = self.grwiz.currentlocation
+        self.currentmapset = self.grwiz.currentmapset
+        self.newlocation = self.grwiz.newlocation
+        self.newmapset = self.grwiz.newmapset
+        self.xylocation = self.grwiz.gisrc_dict['LOCATION_NAME']
+        self.xymapset = self.grwiz.gisrc_dict['MAPSET']
+        self.xygroup = self.grwiz.grouppage.xygroup
+        self.extension = self.grwiz.grouppage.extension
+        self.outname = ''
+        self.VectGRList = []
+        self.file = {
+            'points' : os.path.join(self.grassdatabase,
+                                    self.xylocation,
+                                    self.xymapset,
+                                    'group',
+                                    self.xygroup,
+                                    'POINTS'),
+            'points_bak' : os.path.join(self.grassdatabase,
+                                    self.xylocation,
+                                    self.xymapset,
+                                    'group',
+                                    self.xygroup,
+                                    'POINTS_BAK'),
+            'rgrp' : os.path.join(self.grassdatabase,
+                                  self.xylocation,
+                                  self.xymapset,
+                                  'group',
+                                  self.xygroup,
+                                  'REF'),
+            'vgrp' : os.path.join(self.grassdatabase,
+                                  self.xylocation,
+                                  self.xymapset,
+                                  'group',
+                                  self.xygroup,
+                                  'VREF'),
+            'target' : os.path.join(self.grassdatabase,
+                                    self.xylocation,
+                                    self.xymapset,
+                                    'group',
+                                    self.xygroup,
+                                    'TARGET'),
+        # make a backup of the current points file
+        shutil.copy(self.file['points'], self.file['points_bak'])
+        # polynomial order transformation for georectification
+        self.gr_order = 1
+        # number of GCPs selected to be used for georectification (checked)
+        self.GCPcount = 0
+        # forward RMS error
+        self.fwd_rmserror = 0.0
+        # backward RMS error
+        self.bkw_rmserror = 0.0
+        # list map coords and ID of map display they came from
+        self.mapcoordlist = []
+        self.mapcoordlist.append([ 0,        # GCP number
+                                   0.0,      # source east
+                                   0.0,      # source north
+                                   0.0,      # target east
+                                   0.0,      # target north
+                                   0.0,      # forward error
+                                   0.0 ] )   # backward error
+        # region clipping for georectified map
+        self.clip_to_region = False
+        # init vars to highlight high RMS errors
+        self.highest_only = True
+        self.show_unused =  True
+        self.highest_key = -1
+        self.rmsthresh = 0
+        self.rmsmean = 0
+        self.rmssd = 0
+        self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
+        self.itemDataMap = None
+        # images for column sorting
+        SmallUpArrow = PyEmbeddedImage(
+            "iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAABHNCSVQICAgIfAhkiAAAADxJ"
+            "REFUOI1jZGRiZqAEMFGke2gY8P/f3/9kGwDTjM8QnAaga8JlCG3CAJdt2MQxDCAUaOjyjKMp"
+            "cRAYAABS2CPsss3BWQAAAABJRU5ErkJggg==")
+        SmallDnArrow = PyEmbeddedImage(
+            "iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAABHNCSVQICAgIfAhkiAAAAEhJ"
+            "REFUOI1jZGRiZqAEMFGke9QABgYGBgYWdIH///7+J6SJkYmZEacLkCUJacZqAD5DsInTLhDR"
+            "bcPlKrwugGnCFy6Mo3mBAQChDgRlP4RC7wAAAABJRU5ErkJggg==")
+        # CheckListCtrlMixin must set an ImageList first
+        self.il = self.list.GetImageList(wx.IMAGE_LIST_SMALL)
+        self.sm_dn = self.il.Add(SmallDnArrow.GetBitmap())
+        self.sm_up = self.il.Add(SmallUpArrow.GetBitmap())
+        # set mouse characteristics
+        self.mapwin = self.SrcMapWindow
+        self.mapwin.mouse['box'] = 'point'
+        self.mapwin.mouse["use"] == "pointer"
+        self.mapwin.zoomtype = 0
+        self.mapwin.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
+        self.mapwin.SetCursor(self.cursors["cross"])
+        self.mapwin = self.TgtMapWindow
+        # show new display & draw map
+        self.MapWindow = self.TgtMapWindow
+        self.Map = self.TgtMap
+        self.OnZoomToMap(None)
+        self.MapWindow = self.SrcMapWindow
+        # bindings
+        self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
+        self.Bind(wx.EVT_CLOSE, self.OnQuit)
+    def __del__(self):
+        """!Disable GCP manager mode"""
+    def CreateGCPList(self):
+        """!Create GCP List Control"""
+        return GCPList(parent=self, gcp=self)
+    # Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py
+    def GetListCtrl(self):
+        return self.list
+    def GetSortImages(self):
+        return (self.sm_dn, self.sm_up)
+    def InitMapDisplay(self):
+        self.list.LoadData()
+        # initialize column sorter
+        self.itemDataMap = self.mapcoordlist
+        ColumnSorterMixin.__init__(self, self.list.GetColumnCount())
+    def SetTarget(self, tgroup, tlocation, tmapset):
+        Sets rectification target to current location and mapset
+            gcmd.RunCommand('i.target',
+                            parent = self,
+                            flags = 'c',
+                            group = tgroup)
+        else:
+            self.grwiz.SwitchEnv('source')
+                            parent = self,
+                            group = tgroup,
+                            location = tlocation,
+                            mapset = tmapset)
+            self.grwiz.SwitchEnv('target')
+    def AddGCP(self, event):
+        Appends an item to GCP list
+        keyval = self.list.AddGCPItem() + 1
+        # source east, source north, target east, target north, forward error, backward error
+        self.mapcoordlist.append([ keyval,             # GCP number
+        if self.mapdisp.statusbarWin['toggle'].GetSelection() == 7: # go to
+            self.mapdisp.StatusbarUpdate()
+    def DeleteGCP(self, event):
+        Deletes selected item in GCP list
+        minNumOfItems = self.OnGROrder(None)
+        if self.list.GetItemCount() <= minNumOfItems:
+            wx.MessageBox(parent=self, message=_("At least %d GCPs required. Operation cancelled.") % minNumOfItems,
+                          caption=_("Delete GCP"), style=wx.OK | wx.ICON_INFORMATION)
+            return
+        item = self.list.DeleteGCPItem()
+        del self.mapcoordlist[item]
+            self.statusbarWin['goto'].SetValue(0)
+    def ClearGCP(self, event):
+        Clears all values in selected item of GCP list and unchecks it
+        index = self.list.GetSelected()
+        for i in range(4):
+            self.list.SetStringItem(index, i, '0.0')
+        self.list.SetStringItem(index, 4, '')
+        self.list.SetStringItem(index, 5, '')
+        self.list.CheckItem(index, False)
+        key = self.list.GetItemData(index)
+        # GCP number, source E, source N, target E, target N, fwd error, bkwd error
+        self.mapcoordlist[key] = [key, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
+    def DrawGCP(self, coordtype):
+        Updates GCP and map coord maps and redraws
+        active (checked) GCP markers
+        self.highest_only = UserSettings.Get(group='gcpman', key='rms', subkey='highestonly')
+        self.show_unused =  UserSettings.Get(group='gcpman', key='symbol', subkey='unused')
+        col = UserSettings.Get(group='gcpman', key='symbol', subkey='color')
+        wxLowCol = wx.Colour(col[0], col[1], col[2], 255)
+        col = UserSettings.Get(group='gcpman', key='symbol', subkey='hcolor')
+        wxHiCol = wx.Colour(col[0], col[1], col[2], 255)
+        col = UserSettings.Get(group='gcpman', key='symbol', subkey='scolor')
+        wxSelCol = wx.Colour(col[0], col[1], col[2], 255)
+        col = UserSettings.Get(group='gcpman', key='symbol', subkey='ucolor')
+        wxUnCol = wx.Colour(col[0], col[1], col[2], 255)
+        spx = UserSettings.Get(group='gcpman', key='symbol', subkey='size')
+        wpx = UserSettings.Get(group='gcpman', key='symbol', subkey='width')
+        font = self.GetFont()
+        font.SetPointSize(int(spx) + 2)
+        penOrig = polypenOrig = None
+        mapWin = None
+        if coordtype == 'source':
+            mapWin = self.mapdisp.SrcMapWindow
+            e_idx = 1
+            n_idx = 2
+        elif coordtype == 'target':
+            mapWin = self.mapdisp.TgtMapWindow
+            e_idx = 3
+            n_idx = 4
+        if not mapWin:
+                  message="%s%s." % (_("mapwin not defined for "),
+                                 str(idx)),
+                  caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            return
+        #for gcp in self.mapcoordlist:
+        for idx in range(self.list.GetItemCount()):
+            key = self.list.GetItemData(idx)
+            gcp = self.mapcoordlist[key]
+            if not self.list.IsChecked(idx):
+                if self.show_unused:
+                    wxCol = wxUnCol
+                else:
+                    continue
+            else:
+                if self.highest_only == True:
+                    if key == self.highest_key:
+                        wxCol = wxHiCol
+                    else:
+                        wxCol = wxLowCol
+                elif self.rmsthresh > 0:
+                    if (gcp[5] > self.rmsthresh):
+                        wxCol = wxHiCol
+                    else:
+                        wxCol = wxLowCol
+            if idx == self.list.selected:
+                wxCol = wxSelCol
+            if not penOrig:
+                penOrig = mapWin.pen
+                polypenOrig = mapWin.polypen
+                mapWin.pen = wx.Pen(colour=wxCol, width=wpx, style=wx.SOLID)
+                mapWin.polypen = wx.Pen(colour=wxCol, width=wpx, style=wx.SOLID) # ?
+            mapWin.pen.SetColour(wxCol)
+            mapWin.polypen.SetColour(wxCol)
+            coord = mapWin.Cell2Pixel((gcp[e_idx], gcp[n_idx]))
+            mapWin.DrawCross(pdc=mapWin.pdcTmp, coords=coord,
+                             size=spx, text={ 'text' : '%s' % str(gcp[0]),
+                                            'active' : True,
+                                            'font' : font,
+                                            'color': wxCol,
+                                            'coords': [coord[0] + 5,
+                                                       coord[1] + 5,
+                                                       5,
+                                                       5]})
+        if penOrig:
+            mapWin.pen = penOrig
+            mapWin.polypen = polypenOrig
+    def SetGCPData(self, coordtype, coord, mapdisp=None, confirm=False):
+        Inserts coordinates from file, mouse click on map, or after editing
+        into selected item of GCP list and checks it for use
+        if index == wx.NOT_FOUND:
+            return
+        coord0 = coord[0]
+        coord1 = coord[1]
+        if confirm:
+            if self.mapdisp.MapWindow == self.mapdisp.SrcMapWindow:
+                currloc = _("source")
+            else:
+                currloc = _("target")
+            ret = wx.MessageBox(parent=self,
+                          caption=_("Set GCP coordinates"),
+                          message=_('Set %s coordinates for GCP No. %s? \n\n'
+                                    'East: %s \n'
+                                    'North: %s') % (currloc, str(key), str(coord0), str(coord1)),
+                          style=wx.ICON_QUESTION | wx.YES_NO | wx.CENTRE)
+            if ret == wx.NO:
+                return
+            self.list.SetStringItem(index, 1, str(coord0))
+            self.list.SetStringItem(index, 2, str(coord1))
+            self.mapcoordlist[key][1] = coord[0]
+            self.mapcoordlist[key][2] = coord[1]
+            self.list.SetStringItem(index, 3, str(coord0))
+            self.list.SetStringItem(index, 4, str(coord1))
+            self.mapcoordlist[key][3] = coord[0]
+            self.mapcoordlist[key][4] = coord[1]
+        self.list.SetStringItem(index, 5, '0')
+        self.list.SetStringItem(index, 6, '0')
+        self.mapcoordlist[key][5] = 0.0
+        self.mapcoordlist[key][6] = 0.0
+        # self.list.ResizeColumns()
+    def SaveGCPs(self, event):
+        Make a POINTS file or save GCP coordinates to existing POINTS file
+        self.GCPcount = 0
+        try:
+            f = open(self.file['points'], mode='w')
+            # use os.linesep or '\n' here ???
+            f.write('# Ground Control Points File\n')
+            f.write("# \n")
+            f.write("# target location: " + self.currentlocation + '\n')
+            f.write("# target mapset: " + self.currentmapset + '\n')
+            f.write("#\tsource\t\ttarget\t\tstatus\n")
+            f.write("#\teast\tnorth\teast\tnorth\t(1=ok, 0=ignore)\n")
+            f.write("#-----------------------     -----------------------     ---------------\n")
+            for index in range(self.list.GetItemCount()):
+                if self.list.IsChecked(index) == True:
+                    check = "1"
+                    self.GCPcount += 1
+                else:
+                    check = "0"
+                coord0 = self.list.GetItem(index, 1).GetText()
+                coord1 = self.list.GetItem(index, 2).GetText()
+                coord2 = self.list.GetItem(index, 3).GetText()
+                coord3 = self.list.GetItem(index, 4).GetText()
+                f.write(coord0 + ' ' + coord1 + '     ' + coord2 + ' ' + coord3 + '     ' + check + '\n')
+        except IOError, err:
+                          message="%s <%s>. %s%s" % (_("Writing POINTS file failed"),
+                                                     self.file['points'], os.linesep, err),
+            return
+        f.close()
+        # if event != None save also to backup file
+        if event:
+            self.parent.goutput.WriteLog(_('POINTS file saved for group <%s>') % self.xygroup)
+            #self.SetStatusText(_('POINTS file saved'))
+    def ReadGCPs(self):
+        Reads GCPs and georectified coordinates from POINTS file
+        self.GCPcount = 0
+        sourceMapWin = self.mapdisp.SrcMapWindow
+        targetMapWin = self.mapdisp.TgtMapWindow
+        #targetMapWin = self.parent.curr_page.maptree.mapdisplay.MapWindow
+        if not sourceMapWin:
+                          message="%s. %s%s" % (_("source mapwin not defined"),
+                                                     os.linesep, err),
+        if not targetMapWin:
+                          message="%s. %s%s" % (_("target mapwin not defined"),
+                                                     os.linesep, err),
+        try:
+            f = open(self.file['points'], 'r')
+            GCPcnt = 0
+                if line[0] == '#' or line =='':
+                    continue
+                coords = map(float, line.split())
+                if coords[4] == 1:
+                    check = True
+                    self.GCPcount +=1
+                else:
+                    check = False
+                self.AddGCP(event=None)
+                self.SetGCPData('source', (coords[0], coords[1]), sourceMapWin)
+                self.SetGCPData('target', (coords[2], coords[3]), targetMapWin)
+                if index != wx.NOT_FOUND:
+                    self.list.CheckItem(index, check)
+                GCPcnt += 1
+                          message="%s <%s>. %s%s" % (_("Reading POINTS file failed"),
+            return
+        f.close()
+        if GCPcnt == 0:
+            # 3 gcp is minimum
+            for i in range(3):
+                self.AddGCP(None)
+        if self.CheckGCPcount():
+            # calculate RMS
+            self.RMSError(self.xygroup, self.gr_order)
+        else:
+            # draw GCPs (source and target)
+            sourceMapWin.UpdateMap(render=False, renderVector=False)
+            targetMapWin.UpdateMap(render=False, renderVector=False)
+    def ReloadGCPs(self, event):
+        """!Reload data from file"""
+        # use backup
+        shutil.copy(self.file['points_bak'], self.file['points'])
+        # delete all items in mapcoordlist
+    def OnFocus(self, event):
+        # self.grwiz.SwitchEnv('source')
+        pass
+    def OnRMS(self, event):
+        RMS button handler
+        self.RMSError(self.xygroup,self.gr_order)
+    def CheckGCPcount(self, msg=False):
+        Checks to make sure that the minimum number of GCPs have been defined and
+        are active for the selected transformation order
+        if (self.GCPcount < 3 and self.gr_order == 1) or \
+            (self.GCPcount < 6 and self.gr_order == 2) or \
+            (self.GCPcount < 10 and self.gr_order == 3):
+            if msg:
+                              caption=_("RMS Error"),
+                              message=_('Insufficient points defined and active (checked) '
+                                        'for selected rectification method.\n'
+                                        '3+ points needed for 1st order,\n'
+                                        '6+ points for 2nd order, and\n'
+                                        '10+ points for 3rd order.'),
+                              style=wx.ICON_INFORMATION | wx.ID_OK | wx.CENTRE)
+                return False
+        else:
+            return True
+    def OnGeorect(self, event):
+        Georectifies map(s) in group using i.rectify or v.transform
+        global maptype
+        self.SaveGCPs(None)
+        if self.CheckGCPcount(msg=True) == False:
+            return
+            cmdlist = ['i.rectify','-a','group=%s' % self.xygroup,
+                       'extension=%s' % self.extension,'order=%s' % self.gr_order]
+            if self.clip_to_region:
+                cmdlist.append('-c')
+            self.parent.goutput.RunCmd(cmdlist, compReg=False,
+                                       switchPage=True)
+            time.sleep(.1)
+            outmsg = ''
+            # loop through all vectors in VREF
+            # and move resulting vector to target location
+            # make sure current mapset has a vector folder
+            if not os.path.isdir(os.path.join(self.grassdatabase,
+                                              self.currentlocation,
+                                              self.currentmapset,
+                                              'vector')):
+                os.mkdir(os.path.join(self.grassdatabase,
+                                      'vector'))
+            # make list of vectors to georectify from VREF
+            f = open(self.file['vgrp'])
+            vectlist = []
+            try:
+                for vect in f.readlines():
+                    vect = vect.strip('\n')
+                    if len(vect) < 1:
+                        continue
+                    vectlist.append(vect)
+            finally:
+                f.close()
+            # georectify each vector in VREF using v.transform
+            for vect in vectlist:
+                self.outname = vect + '_' + self.extension
+                self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
+                                             switchPage = True)
+                msg = err = ''
+                ret, out, err = gcmd.RunCommand('v.transform',
+                           flags = '-o',
+                           input=vect,
+                           output=self.outname,
+                           pointsfile=self.file['points'],
+                           getErrorMsg=True, read=True)
+                if ret == 0:
+                    self.VectGRList.append(self.outname)
+                    print err
+                    # note: WriteLog doesn't handle GRASS_INFO_PERCENT well, so using a print here
+#                    self.parent.goutput.WriteLog(text = _(err), switchPage = True)
+                    self.parent.goutput.WriteLog(text = _(out), switchPage = True)
+                else:
+                    self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
+                                                           self.outname)
+                    self.parent.goutput.WriteError(_(err))
+                # FIXME
+                # Copying database information not working.
+                # Does not copy from xy location to current location
+                # TODO: replace $GISDBASE etc with real paths
+#                xyLayer = []
+#                for layer in grass.vector_db(map = vect).itervalues():
+#                    xyLayer.append((layer['driver'],
+#                                    layer['database'],
+#                                    layer['table']))
+#                dbConnect = grass.db_connection()
+#                print 'db connection =', dbConnect
+#                for layer in xyLayer:
+#                    self.parent.goutput.RunCmd(['db.copy',
+#                                                '--q',
+#                                                '--o',
+#                                                'from_driver=%s' % layer[0],
+#                                                'from_database=%s' % layer[1],
+#                                                'from_table=%s' % layer[2],
+#                                                'to_driver=%s' % dbConnect['driver'],
+#                                                'to_database=%s' % dbConnect['database'],
+#                                                'to_table=%s' % layer[2] + '_' + self.extension])
+            # copy all georectified vectors from source location to current location
+            for name in self.VectGRList:
+                xyvpath = os.path.join(self.grassdatabase,
+                                       self.xylocation,
+                                       self.xymapset,
+                                       'vector',
+                                       name)
+                vpath = os.path.join(self.grassdatabase,
+                                     'vector',
+                                     name)
+                if os.path.isdir(vpath):
+                    self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
+                                                       'Change extension name and '
+                                                       'georectify again.') % self.outname)
+                    break
+                else:
+                    # use shutil.copytree() because shutil.move() deletes src dir
+                    shutil.copytree(xyvpath, vpath)
+                # TODO: connect vectors to copied tables with v.db.connect
+            wx.MessageBox('For all vector maps georectified successfully, ' + '\n' +
+                          'you will need to copy any attribute tables' + '\n' +
+                          'and reconnect them to the georectified vectors')
+    def OnGeorectDone(self, **kargs):
+        """!Print final message"""
+        global maptype
+            return
+        returncode = kargs['returncode']
+        if returncode == 0:
+            print '*****vector list = ' + str(self.VectGRList)
+        else:
+                                                   self.outname)
+    def OnSettings(self, event):
+        """!GCP Manager settings"""
+        dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('GCP Manager settings'))
+        if dlg.ShowModal() == wx.ID_OK:
+            pass
+        dlg.Destroy()
+    def UpdateColours(self, srcrender=False, srcrenderVector=False,
+                            tgtrender=False, tgtrenderVector=False):
+        """!update colours"""
+        highest_fwd_err = 0.0
+        self.highest_key = 0
+        highest_idx = 0
+            if self.list.IsChecked(index):
+                fwd_err = self.mapcoordlist[key][5]
+                    self.list.SetItemTextColour(index, wx.BLACK)
+                    if highest_fwd_err < fwd_err:
+                        highest_fwd_err = fwd_err
+                        self.highest_key = key
+                        highest_idx = index
+                    if (fwd_err > self.rmsthresh):
+                        self.list.SetItemTextColour(index, wx.RED)
+                    else:
+            else:
+        if self.highest_only and highest_fwd_err > 0.0:
+            self.list.SetItemTextColour(highest_idx, wx.RED)
+        sourceMapWin.UpdateMap(render=srcrender, renderVector=srcrenderVector)
+        targetMapWin.UpdateMap(render=tgtrender, renderVector=tgtrenderVector)
+    def OnQuit(self, event):
+        """!Quit georectifier"""
+                      caption=_("Quit GCP Manager"),
+                      message=_('Save ground control points?'),
+                      style=wx.ICON_QUESTION | wx.YES_NO | wx.CANCEL | wx.CENTRE)
+        if ret != wx.CANCEL:
+            if ret == wx.YES:
+            elif ret == wx.NO:
+                # restore POINTS file from backup
+            os.unlink(self.file['points_bak'])
+            self.grwiz.Cleanup()
+            self.Destroy()
+        #event.Skip()
+    def OnGROrder(self, event):
+        sets transformation order for georectifying
+        if event:
+            self.gr_order = event.GetInt() + 1
+        numOfItems = self.list.GetItemCount()
+        minNumOfItems = numOfItems
+        if self.gr_order == 1:
+            minNumOfItems = 3
+            # self.SetStatusText(_('Insufficient points, 3+ points needed for 1st order'))
+        elif self.gr_order == 2:
+            minNumOfItems = 6
+            diff = 6 - numOfItems
+            # self.SetStatusText(_('Insufficient points, 6+ points needed for 2nd order'))
+        elif self.gr_order == 3:
+            minNumOfItems = 10
+            # self.SetStatusText(_('Insufficient points, 10+ points needed for 3rd order'))
+        for i in range(minNumOfItems - numOfItems):
+            self.AddGCP(None)
+        return minNumOfItems
+    def RMSError(self, xygroup, order):
+        Uses g.transform to calculate forward and backward error for each used GCP
+        in POINTS file and insert error values into GCP list.
+        Calculates total forward and backward RMS error for all used points
+        # save GCPs to points file to make sure that all checked GCPs are used
+        #self.SetStatusText('')
+            return
+        # get list of forward and reverse rms error values for each point
+        ret = gcmd.RunCommand('g.transform',
+                              parent = self,
+                              read = True,
+                              group = xygroup,
+                              order = order)
+        if ret:
+            errlist = ret.splitlines()
+        else:
+                              message=_('Could not calculate RMS Error. \n'
+                                        'Possible error with g.transform.'),
+                              style=wx.ICON_ERROR | wx.ID_OK | wx.CENTRE)
+            return
+        # insert error values into GCP list for checked items
+        sdfactor = float(UserSettings.Get(group='gcpman', key='rms', subkey='sdfactor'))
+        GCPcount = 0
+        sumsq_fwd_err = 0.0
+        sumsq_bkw_err = 0.0
+        sum_fwd_err = 0.0
+        highest_idx = 0
+                fwd_err, bkw_err = errlist[GCPcount].split()
+                self.list.SetStringItem(index, 5, fwd_err)
+                self.list.SetStringItem(index, 6, bkw_err)
+                self.mapcoordlist[key][5] = float(fwd_err)
+                self.mapcoordlist[key][6] = float(bkw_err)
+                if self.highest_only:
+                    if highest_fwd_err < float(fwd_err):
+                        highest_fwd_err = float(fwd_err)
+                sumsq_fwd_err += float(fwd_err)**2
+                sumsq_bkw_err += float(bkw_err)**2
+                sum_fwd_err += float(fwd_err)
+                GCPcount += 1
+            else:
+                self.list.SetStringItem(index, 6, '')
+        # SD
+        if GCPcount > 0:
+            sum_fwd_err /= GCPcount
+            self.rmsmean = sum_fwd_err /GCPcount
+            self.rmssd = (((sumsq_fwd_err/GCPcount) - self.rmsmean**2)**0.5)
+            self.rmsthresh = self.rmsmean + sdfactor * self.rmssd
+        else:
+            self.rmsmean = 0
+            self.rmssd = 0
+        elif GCPcount > 0 and self.rmsthresh > 0 and not self.highest_only:
+                    if (self.mapcoordlist[key][5] > self.rmsthresh):
+        # calculate global RMS error (geometric mean)
+        self.fwd_rmserror = round((sumsq_fwd_err/GCPcount)**0.5,4)
+        self.bkw_rmserror = round((sumsq_bkw_err/GCPcount)**0.5,4)
+        self.list.ResizeColumns()
+    def GetNewExtend(self, region, map = None):
+        coord_file = utils.GetTempfile()
+        newreg = { 'n' : 0.0, 's' : 0.0, 'e' : 0.0, 'w' : 0.0,}
+        try:
+            f = open(coord_file, mode='w')
+            # NW corner
+            f.write(str(region['e']) + " " + str(region['n']) + "\n")
+            # NE corner
+            f.write(str(region['e']) + " " + str(region['s']) + "\n")
+            # SW corner
+            f.write(str(region['w']) + " " + str(region['n']) + "\n")
+            # SE corner
+            f.write(str(region['w']) + " " + str(region['s']) + "\n")
+        finally:
+            f.close()
+        order = self.gr_order
+        self.gr_order = 1
+            self.gr_order = order
+            return
+        if map == 'source':
+                                  parent = self,
+                                  read = True,
+                                  group = self.xygroup,
+                                  order = 1,
+                                  format = 'dst',
+                                  coords = coord_file)
+        elif map == 'target':
+                                  parent = self,
+                                  read = True,
+                                  order = 1,
+                                  flags = 'r',
+                                  format = 'src',
+        os.unlink(coord_file)
+        if ret:
+        else:
+                              caption=_("Adjust GCP Displays "),
+                              message=_('Could not calculate new extends. \n'
+            return
+        # fist corner
+        e, n = errlist[0].split()
+        fe = float(e)
+        fn = float(n)
+        newreg['n'] = fn
+        newreg['s'] = fn
+        newreg['e'] = fe
+        newreg['w'] = fe
+        # other three corners
+        for i in range(1, 4):
+            e, n = errlist[i].split()
+            fe = float(e)
+            fn = float(n)
+            if fe < newreg['w']:
+                newreg['w'] = fe
+            if fe > newreg['e']:
+                newreg['e'] = fe
+            if fn < newreg['s']:
+                newreg['s'] = fn
+            if fn > newreg['n']:
+                newreg['n'] = fn
+        return newreg
+    def OnHelp(self, event):
+        """!Show GCP Manager manual page"""
+        gcmd.RunCommand('g.manual',
+                        quiet = True,
+                        parent = self,
+                        entry = 'wxGUI.GCP_Manager')
+class GCPList(wx.ListCtrl,
+              CheckListCtrlMixin,
+              ListCtrlAutoWidthMixin):
+    def __init__(self, parent, gcp, id=wx.ID_ANY,
+                 pos=wx.DefaultPosition, size=wx.DefaultSize,
+                 style=wx.LC_REPORT | wx.SUNKEN_BORDER | wx.LC_HRULES |
+                 wx.LC_SINGLE_SEL | wx.LC_SORT_DESCENDING):
+        wx.ListCtrl.__init__(self, parent, id, pos, size, style)
+        self.gcp = gcp # GCP class
+        self.render = True
+        # Mixin settings
+        CheckListCtrlMixin.__init__(self)
+        ListCtrlAutoWidthMixin.__init__(self)
+        # TextEditMixin.__init__(self)
+        # tracks whether list items are checked or not
+        self.CheckList = []
+        self._Create()
+        self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
+        self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
+        self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick)
+        self.selected = wx.NOT_FOUND
+        self.selectedkey = -1
+    def _Create(self):
+        if 0:
+            # normal, simple columns
+            idx_col = 0
+            for col in (_('use'),
+                _('source E'),
+                _('source N'),
+                _('target E'),
+                _('target N'),
+                _('Forward error'),
+                _('Backward error')):
+                self.InsertColumn(idx_col, col)
+                idx_col += 1
+        else:
+            # the hard way: we want images on the column header
+            info = wx.ListItem()
+            info.SetMask(wx.LIST_MASK_TEXT | wx.LIST_MASK_IMAGE | wx.LIST_MASK_FORMAT)
+            info.SetImage(-1)
+            info.m_format = 0
+            idx_col = 0
+            for lbl in (_('use'),
+                _('source E'),
+                _('source N'),
+                _('target E'),
+                _('target N'),
+                info.SetText(lbl)
+                self.InsertColumnInfo(idx_col, info)
+                idx_col += 1
+    def LoadData(self):
+        """!Load data into list"""
+        self.DeleteAllItems()
+        self.render = False
+        if os.path.isfile(self.gcp.file['points']):
+            self.gcp.ReadGCPs()
+        else:
+                self.gcp.AddGCP(None)
+        # select first point by default
+        self.selected = 0
+        self.selectedkey = self.GetItemData(self.selected)
+        self.SetItemState(self.selected,
+                          wx.LIST_STATE_SELECTED,
+                          wx.LIST_STATE_SELECTED)
+        self.ResizeColumns()
+    def OnCheckItem(self, index, flag):
+        """!Item is checked/unchecked"""
+        if self.render:
+            # redraw points
+            sourceMapWin = self.gcp.mapdisp.SrcMapWindow
+            targetMapWin = self.gcp.mapdisp.TgtMapWindow
+        pass
+    def AddGCPItem(self):
+        self.selectedkey = self.GetItemCount() + 1
+        self.Append([str(self.selectedkey),    # GCP number
+                     '0.0',                # source E
+                     '0.0',                # source N
+                     '0.0',                # target E
+                     '0.0',                # target N
+                     '',                   # forward error
+                     ''])                  # backward error
+        self.selected = self.GetItemCount() - 1
+        self.SetItemData(self.selected, self.selectedkey)
+        return self.selected
+    def DeleteGCPItem(self):
+        if self.selected == wx.NOT_FOUND:
+            return
+        self.DeleteItem(self.selected)
+        if self.GetItemCount() > 0:
+        else:
+    def ResizeColumns(self):
+        """!Resize columns"""
+        minWidth = [90, 120]
+        for i in range(self.GetColumnCount()):
+            self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
+            # first column is checkbox, don't set to minWidth
+            if i > 0 and self.GetColumnWidth(i) < minWidth[i > 4]:
+                self.SetColumnWidth(i, minWidth[i > 4])
+        self.SendSizeEvent()
+    def GetSelected(self):
+        """!Get index of selected item"""
+    def OnItemSelected(self, event):
+        Item selected
+        if self.render and self.selected != event.GetIndex():
+            self.selected = event.GetIndex()
+        event.Skip()
+    def OnItemActivated(self, event):
+        When item double clicked, open editor to update coordinate values
+        coords = []
+        index = event.GetIndex()
+        key = self.GetItemData(index)
+        changed = False
+        for i in range(1, 5):
+            coords.append(self.GetItem(index, i).GetText())
+        dlg = EditGCP(parent=self, id=wx.ID_ANY, data=coords, gcpno=key)
+            values = dlg.GetValues() # string
+            if len(values) == 0:
+                              caption=_("Edit GCP"),
+                              message=_("Invalid coordinate value. Operation cancelled."),
+                              style=wx.CENTRE | wx.ICON_ERROR | wx.ID_OK)
+            else:
+                for i in range(len(values)):
+                    if values[i] != coords[i]:
+                        self.SetStringItem(index, i + 1, values[i])
+                        changed = True
+                if changed:
+                    # reset RMS and update mapcoordlist
+                    self.SetStringItem(index, 5, '')
+                    self.SetStringItem(index, 6, '')
+                    self.gcp.mapcoordlist[key] = [key,
+                                                  float(values[0]),
+                                                  float(values[1]),
+                                                  float(values[2]),
+                                                  float(values[3]),
+                                                  0.0,
+                                                  0.0]
+                    self.gcp.UpdateColours()
+    def OnColClick(self, event):
+        """!ListCtrl forgets selected item..."""
+        self.selected = self.FindItemData(-1, self.selectedkey)
+        event.Skip()
+class VectGroup(wx.Dialog):
+    Dialog to create a vector group (VREF file) for georectifying
+    @todo Replace by g.group
+    def __init__(self, parent, id, grassdb, location, mapset, group,
+                 style=wx.DEFAULT_DIALOG_STYLE):
+        wx.Dialog.__init__(self, parent, id, style=style,
+                           title = _("Create vector map group"))
+        self.grassdatabase = grassdb
+        self.xylocation = location
+        self.xymapset = mapset
+        self.xygroup = group
+        # get list of valid vector directories
+        vectlist = os.listdir(os.path.join(self.grassdatabase,
+                                           self.xylocation,
+                                           self.xymapset,
+                                           'vector'))
+        for dir in vectlist:
+            if not os.path.isfile(os.path.join(self.grassdatabase,
+                                           self.xylocation,
+                                           self.xymapset,
+                                           'vector',
+                                           dir,
+                                           'coor')):
+                vectlist.remove(dir)
+        utils.ListSortLower(vectlist)
+        # path to vref file
+        self.vgrpfile = os.path.join(self.grassdatabase,
+                                     self.xylocation,
+                                     self.xymapset,
+                                     'group',
+                                     self.xygroup,
+                                     'VREF')
+        # buttons
+        self.btnCancel = wx.Button(parent = self,
+                                   id = wx.ID_CANCEL)
+        self.btnOK = wx.Button(parent = self,
+                                   id = wx.ID_OK)
+        self.btnOK.SetDefault()
+        # list of vector maps
+        self.listMap = wx.CheckListBox(parent = self, id = wx.ID_ANY,
+                                      choices = vectlist)
+        if os.path.isfile(self.vgrpfile):
+            f = open(self.vgrpfile)
+            try:
+                checked = []
+                    if len(line) < 1:
+                        continue
+                    checked.append(line)
+                self.listMap.SetCheckedStrings(checked)
+            finally:
+                f.close()
+        line = wx.StaticLine(parent = self,
+                             id = wx.ID_ANY, size = (20, -1),
+                             style = wx.LI_HORIZONTAL)
+        # layout
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        box = wx.BoxSizer(wx.HORIZONTAL)
+        box.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                     label = _('Select vector map(s) to add to group:')),
+                flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
+                border = 5)
+        box.Add(item = self.listMap,
+                border = 5)
+        sizer.Add(box, flag = wx.ALIGN_RIGHT | wx.ALL,
+                  border = 3)
+        sizer.Add(item = line, proportion = 0,
+                  flag = wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+                  border = 5)
+        # buttons
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(self.btnCancel)
+        btnSizer.AddButton(self.btnOK)
+        btnSizer.Realize()
+        sizer.Add(item = btnSizer, proportion = 0,
+                  flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER,
+                  border = 5)
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+        self.Layout()
+    def MakeVGroup(self):
+        """!Create VREF file"""
+        vgrouplist = []
+        for item in range(self.listMap.GetCount()):
+            if not self.listMap.IsChecked(item):
+                continue
+            vgrouplist.append(self.listMap.GetString(item))
+        f = open(self.vgrpfile, mode='w')
+        try:
+            for vect in vgrouplist:
+                f.write(vect + '\n')
+        finally:
+            f.close()
+class EditGCP(wx.Dialog):
+    def __init__(self, parent, data, gcpno, id=wx.ID_ANY,
+                 title=_("Edit GCP"),
+        """!Dialog for editing GPC and map coordinates in list control"""
+        wx.Dialog.__init__(self, parent, id, title=title, style=style)
+        panel = wx.Panel(parent=self)
+        box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
+                            label=" %s %s " % (_("Ground Control Point No."), str(gcpno)))
+        boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        # source coordinates
+        gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+        self.xcoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        self.ycoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        self.ecoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        self.ncoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        # swap source N, target E
+        tmp_coord = data[1]
+        data[1] = data[2]
+        data[2] = tmp_coord
+        row = 0
+        col = 0
+        idx = 0
+        for label, win in ((_("source E:"), self.xcoord),
+                           (_("target E:"), self.ecoord),
+                           (_("source N:"), self.ycoord),
+                           (_("target N:"), self.ncoord)):
+            label = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                  label=label)
+            gridSizer.Add(item=label,
+                          flag=wx.ALIGN_CENTER_VERTICAL,
+                          pos=(row, col))
+            col += 1
+            win.SetValue(str(data[idx]))
+            gridSizer.Add(item=win,
+                          pos=(row, col))
+            col += 1
+            idx += 1
+            if col > 3:
+                row += 1
+                col = 0
+        boxSizer.Add(item=gridSizer, proportion=1,
+                  flag=wx.EXPAND | wx.ALL, border=5)
+        sizer.Add(item=boxSizer, proportion=1,
+        # buttons
+        self.btnCancel = wx.Button(panel, wx.ID_CANCEL)
+        self.btnOk = wx.Button(panel, wx.ID_OK)
+        self.btnOk.SetDefault()
+        btnSizer.AddButton(self.btnOk)
+        sizer.Add(item=btnSizer, proportion=0,
+                  flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
+        panel.SetSizer(sizer)
+        sizer.Fit(self)
+    def GetValues(self, columns=None):
+        """!Return list of values (as strings).
+        valuelist = []
+        try:
+            float(self.xcoord.GetValue())
+            float(self.ycoord.GetValue())
+            float(self.ecoord.GetValue())
+            float(self.ncoord.GetValue())
+        except ValueError:
+            return valuelist
+        valuelist.append(self.xcoord.GetValue())
+        valuelist.append(self.ycoord.GetValue())
+        valuelist.append(self.ecoord.GetValue())
+        valuelist.append(self.ncoord.GetValue())
+        return valuelist
+class GrSettingsDialog(wx.Dialog):
+    def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+        Dialog to set profile text options: font, title
+        and font size, axis labels and font size
+        # initialize variables
+        self.new_src_map = None
+        self.new_tgt_map = None
+        self.sdfactor = 0
+        self.symbol = {}
+        # notebook
+        notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        self.__CreateSymbologyPage(notebook)
+        self.__CreateRectificationPage(notebook)
+        # buttons
+        btnSave = wx.Button(self, wx.ID_SAVE)
+        btnApply = wx.Button(self, wx.ID_APPLY)
+        btnClose = wx.Button(self, wx.ID_CLOSE)
+        btnApply.SetDefault()
+        # bindings
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+        btnApply.SetToolTipString(_("Apply changes for the current session"))
+        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+        btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+        btnClose.Bind(wx.EVT_BUTTON, self.OnClose)
+        btnClose.SetToolTipString(_("Close dialog"))
+        # sizers
+        btnSizer.Add(btnApply, flag=wx.LEFT | wx.RIGHT, border=5)
+        btnSizer.Add(btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
+        btnSizer.Add(btnClose, flag=wx.LEFT | wx.RIGHT, border=5)
+        # sizers
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+        mainSizer.Add(item=btnSizer, proportion=0,
+        #              flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+    def __CreateSymbologyPage(self, notebook):
+        """!Create notebook page with symbology settings"""
+        panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
+        notebook.AddPage(page=panel, text=_("Symbology"))
+        rmsgridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+        rmsgridSizer.AddGrowableCol(1)
+        # highlight only highest forward RMS error
+        self.highlighthighest = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                label=_("Highlight highest RMS error only"))
+        hh = UserSettings.Get(group='gcpman', key='rms', subkey='highestonly')
+        self.highlighthighest.SetValue(hh)
+        rmsgridSizer.Add(item=self.highlighthighest, flag=wx.ALIGN_CENTER_VERTICAL, pos=(0, 0))
+        # RMS forward error threshold
+        rmslabel = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Highlight RMS error > M + SD * factor:"))
+        rmslabel.SetToolTip(wx.ToolTip(_("Highlight GCPs with an RMS error larger than \n"
+                              "mean + standard deviation * given factor. \n"
+                              "Recommended values for this factor are between 1 and 2.")))
+        rmsgridSizer.Add(item=rmslabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(1, 0))
+        sdfactor = UserSettings.Get(group='gcpman', key='rms', subkey='sdfactor')
+        self.rmsWin = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
+                       size=(70,-1), style=wx.TE_NOHIDESEL)
+        self.rmsWin.SetValue("%s" % str(sdfactor))
+        if (self.parent.highest_only == True):
+           self.rmsWin.Disable()
+        self.symbol['sdfactor'] = self.rmsWin.GetId()
+        rmsgridSizer.Add(item=self.rmsWin, flag=wx.ALIGN_RIGHT, pos=(1, 1))
+        sizer.Add(item=rmsgridSizer, flag=wx.EXPAND | wx.ALL, border=5)
+        box = wx.StaticBox(parent=panel, id=wx.ID_ANY,
+                           label=" %s " % _("Symbol settings"))
+        gridSizer.AddGrowableCol(1)
+        # general symbol color
+        row = 0
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Color:"))
+        gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+        colWin = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
+                                   colour=wx.Colour(col[0],
+                                                    col[1],
+                                                    col[2],
+                                                    255))
+        self.symbol['color'] = colWin.GetId()
+        gridSizer.Add(item=colWin,
+                      flag=wx.ALIGN_RIGHT,
+                      pos=(row, 1))
+        # symbol color for high forward RMS error
+        row += 1
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Color for high RMS error:"))
+        hcol = UserSettings.Get(group='gcpman', key='symbol', subkey='hcolor')
+        hcolWin = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
+                                   colour=wx.Colour(hcol[0],
+                                                    hcol[1],
+                                                    hcol[2],
+                                                    255))
+        self.symbol['hcolor'] = hcolWin.GetId()
+        gridSizer.Add(item=hcolWin,
+                      pos=(row, 1))
+        # symbol color for selected GCP
+        row += 1
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Color for selected GCP:"))
+        scol = UserSettings.Get(group='gcpman', key='symbol', subkey='scolor')
+        scolWin = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
+                                   colour=wx.Colour(scol[0],
+                                                    scol[1],
+                                                    scol[2],
+                                                    255))
+        self.symbol['scolor'] = scolWin.GetId()
+        gridSizer.Add(item=scolWin,
+                      pos=(row, 1))
+        # symbol color for unused GCP
+        row += 1
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Color for unused GCPs:"))
+        ucol = UserSettings.Get(group='gcpman', key='symbol', subkey='ucolor')
+        ucolWin = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
+                                   colour=wx.Colour(ucol[0],
+                                                    ucol[1],
+                                                    ucol[2],
+                                                    255))
+        self.symbol['ucolor'] = ucolWin.GetId()
+        gridSizer.Add(item=ucolWin,
+                      pos=(row, 1))
+        # show unused GCPs
+        row += 1
+        self.showunused = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                label=_("Show unused GCPs"))
+        shuu = UserSettings.Get(group='gcpman', key='symbol', subkey='unused')
+        self.showunused.SetValue(shuu)
+        gridSizer.Add(item=self.showunused, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+        # symbol size
+        row += 1
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Symbol size:"))
+        symsize = int(UserSettings.Get(group='gcpman', key='symbol', subkey='size'))
+        sizeWin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY,
+                             min=1, max=20)
+        sizeWin.SetValue(symsize)
+        self.symbol['size'] = sizeWin.GetId()
+        gridSizer.Add(item=sizeWin,
+                      pos=(row, 1))
+        # symbol width
+        row += 1
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width:"))
+        width = int(UserSettings.Get(group='gcpman', key='symbol', subkey='width'))
+        widWin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY,
+                             min=1, max=10)
+        widWin.SetValue(width)
+        self.symbol['width'] = widWin.GetId()
+        gridSizer.Add(item=widWin,
+                      pos=(row, 1))
+        boxSizer.Add(item=gridSizer, flag=wx.EXPAND)
+        sizer.Add(item=boxSizer, flag=wx.EXPAND | wx.ALL, border=5)
+        # maps to display
+        # source map to display
+        self.srcselection = gselect.Select(panel, id=wx.ID_ANY,
+        self.parent.grwiz.SwitchEnv('source')
+        # target map to display
+        self.tgtselection = gselect.Select(panel, id=wx.ID_ANY,
+        self.parent.grwiz.SwitchEnv('target')
+        sizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY, label=_('Select source map to display:')),
+                       proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5)
+        sizer.Add(item=self.srcselection, proportion=0,
+                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5)
+        self.srcselection.SetValue(src_map)
+        sizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY, label=_('Select target map to display:')),
+        sizer.Add(item=self.tgtselection, proportion=0,
+        self.tgtselection.SetValue(tgt_map)
+        # bindings
+        self.highlighthighest.Bind(wx.EVT_CHECKBOX, self.OnHighlight)
+        self.rmsWin.Bind(wx.EVT_TEXT, self.OnSDFactor)
+        return panel
+    def __CreateRectificationPage(self, notebook):
+        notebook.AddPage(page=panel, text=_("Rectification"))
+        # transformation order
+        self.rb_grmethod = wx.RadioBox(parent=panel, id=wx.ID_ANY,
+                                       label=" %s " % _("Select rectification method for rasters"),
+                                       choices=[_('1st order'), _('2nd order'), _('3rd order')],
+        sizer.Add(item=self.rb_grmethod, proportion=0,
+        self.rb_grmethod.SetSelection(self.parent.gr_order - 1)
+        # clip to region
+        self.check = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                label=_("clip to computational region in target location"))
+        sizer.Add(item=self.check, proportion=0,
+        self.check.SetValue(self.parent.clip_to_region)
+        # extension
+        sizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY, label=_('Extension for output maps:')),
+        self.ext_txt = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value="", size=(350,-1))
+        self.ext_txt.SetValue(self.parent.extension)
+        sizer.Add(item=self.ext_txt,
+        # bindings
+        self.ext_txt.Bind(wx.EVT_TEXT, self.OnExtension)
+        self.Bind(wx.EVT_RADIOBOX, self.parent.OnGROrder, self.rb_grmethod)
+        self.Bind(wx.EVT_CHECKBOX, self.OnClipRegion, self.check)
+        return panel
+    def OnHighlight(self, event):
+        """!Checkbox 'highlighthighest' checked/unchecked"""
+        if self.highlighthighest.IsChecked():
+            self.parent.highest_only = True
+        else:
+            self.parent.highest_only = False
+            self.rmsWin.Enable()
+    def OnSDFactor(self,event):
+        """!New factor for RMS threshold = M + SD * factor"""
+        self.sdfactor = float(event.GetString())
+        if self.sdfactor <= 0:
+                  caption=_("Update settings"),
+                  message=_('RMS threshold factor must be > 0'),
+        elif self.sdfactor < 1:
+                  message=_('RMS threshold factor is < 1\n'
+                            'Too many points might be highlighted'),
+                  style=wx.ICON_EXCLAMATION | wx.ID_OK | wx.CENTRE)
+        global src_map
+        tmp_map = event.GetString()
+        if not tmp_map == '' and not tmp_map == src_map:
+            self.new_src_map = tmp_map
+        """!Target map to display selected"""
+        global tgt_map
+        if not tmp_map == '' and not tmp_map == tgt_map:
+            self.new_tgt_map = tmp_map
+    def OnClipRegion(self, event):
+        self.parent.clip_to_region = event.IsChecked()
+        self.parent.extension = event.GetString()
+    def UpdateSettings(self):
+        global src_map
+        global tgt_map
+        layers = None
+        UserSettings.Set(group='gcpman', key='rms', subkey='highestonly',
+                         value=self.highlighthighest.GetValue())
+        if self.sdfactor > 0:
+            UserSettings.Set(group='gcpman', key='rms', subkey='sdfactor',
+                             value=self.sdfactor)
+            self.parent.sdfactor = self.sdfactor
+            if self.parent.rmsthresh > 0:
+                self.parent.rmsthresh = self.parent.mean + self.parent.sdfactor * self.parent.rmssd
+        UserSettings.Set(group='gcpman', key='symbol', subkey='color',
+                         value=tuple(wx.FindWindowById(self.symbol['color']).GetColour()))
+        UserSettings.Set(group='gcpman', key='symbol', subkey='hcolor',
+                         value=tuple(wx.FindWindowById(self.symbol['hcolor']).GetColour()))
+        UserSettings.Set(group='gcpman', key='symbol', subkey='scolor',
+                         value=tuple(wx.FindWindowById(self.symbol['scolor']).GetColour()))
+        UserSettings.Set(group='gcpman', key='symbol', subkey='ucolor',
+                         value=tuple(wx.FindWindowById(self.symbol['ucolor']).GetColour()))
+        UserSettings.Set(group='gcpman', key='symbol', subkey='unused',
+                         value=self.showunused.GetValue())
+        UserSettings.Set(group='gcpman', key='symbol', subkey='size',
+                         value=wx.FindWindowById(self.symbol['size']).GetValue())
+        UserSettings.Set(group='gcpman', key='symbol', subkey='width',
+                         value=wx.FindWindowById(self.symbol['width']).GetValue())
+        srcrender = False
+        srcrenderVector = False
+        tgtrender = False
+        tgtrenderVector = False
+        if self.new_src_map:
+            # remove old layer
+            layers = self.parent.grwiz.SrcMap.GetListOfLayers()
+            self.parent.grwiz.SrcMap.DeleteLayer(layers[0])
+            src_map = self.new_src_map
+            self.parent.grwiz.SrcMap.AddLayer(type='raster', command=cmdlist, l_active=True,
+            srcrender = True
+        if self.new_tgt_map:
+            layers = self.parent.grwiz.TgtMap.GetListOfLayers()
+            self.parent.grwiz.TgtMap.DeleteLayer(layers[0])
+            tgt_map = self.new_tgt_map
+            self.parent.grwiz.TgtMap.AddLayer(type='raster', command=cmdlist, l_active=True,
+            tgtrender = True
+        self.parent.UpdateColours(srcrender, srcrenderVector, tgtrender, tgtrenderVector)
+    def OnSave(self, event):
+        """!Button 'Save' pressed"""
+        self.UpdateSettings()
+        fileSettings = {}
+        UserSettings.ReadSettingsFile(settings=fileSettings)
+        fileSettings['gcpman'] = UserSettings.Get(group='gcpman')
+        file = UserSettings.SaveToFile(fileSettings)
+        self.parent.parent.goutput.WriteLog(_('GCP Manager settings saved to file \'%s\'.') % file)
+        #self.Close()
+    def OnApply(self, event):
+        """!Button 'Apply' pressed"""
+        #self.Close()
+    def OnClose(self, event):
+        """!Button 'Cancel' pressed"""
+        self.Close()
Property changes on: grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -0,0 +1,2385 @@
+ at package gcpmapdisp.py
+ at brief GIS map display canvas, with toolbar for various display
+management functions, and additional toolbars (vector digitizer, 3d
+view).
+Can be used either from Layer Manager or as p.mon backend.
+Classes:
+- MapFrame
+- MapApp
+Usage:
+python mapdisp.py monitor-identifier /path/to/command/file
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import glob
+import math
+import tempfile
+import copy
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+    globalvar.CheckForWx()
+import wx
+import wx.aui
+try:
+    import subprocess
+except:
+    CompatPath = os.path.join(globalvar.ETCWXDIR)
+grassPath = os.path.join(globalvar.ETCDIR, "python")
+sys.path.append(grassPath)
+import render
+import toolbars
+import menuform
+import gselect
+import disp_print
+import gcmd
+import dbm
+import dbm_dialogs
+import histogram
+import profile
+import globalvar
+import utils
+import gdialogs
+from grass.script import core as grass
+from mapdisp_command import Command
+import images
+imagepath = images.__path__[0]
+sys.path.append(imagepath)
+### global variables
+# for standalone app
+cmdfilename = None
+class MapFrame(wx.Frame):
+    """!Main frame for map display window. Drawing takes place in
+    child double buffered drawing window.
+    def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS GIS - Map display"),
+                 style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
+                 tree=None, notebook=None, lmgr=None, page=None,
+                 Map=None, auimgr=None, **kwargs):
+        """!Main map display window with toolbars, statusbar and
+        DrawWindow
+        @param toolbars array of activated toolbars, e.g. ['map', 'digit']
+        @param tree reference to layer tree
+        @param notebook control book ID in Layer Manager
+        @param lmgr Layer Manager
+        @param page notebook page with layer tree
+        @param Map instance of render.Map
+        @param auimgs AUI manager
+        @param kwargs wx.Frame attribures
+        self._layerManager = lmgr   # Layer Manager object
+        self.Map        = Map       # instance of render.Map
+        self.tree       = tree      # Layer Manager layer tree object
+        self.page       = page      # Notebook page holding the layer tree
+        self.layerbook  = notebook  # Layer Manager layer tree notebook
+        if not kwargs.has_key('name'):
+            kwargs['name'] = 'MapWindow'
+        wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
+        # available cursors
+        self.cursors = {
+            # default: cross
+            # "default" : wx.StockCursor(wx.CURSOR_DEFAULT),
+            "default" : wx.StockCursor(wx.CURSOR_ARROW),
+            "cross"   : wx.StockCursor(wx.CURSOR_CROSS),
+            "hand"    : wx.StockCursor(wx.CURSOR_HAND),
+            "pencil"  : wx.StockCursor(wx.CURSOR_PENCIL),
+            "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
+        # set the size & system icon
+        self.SetClientSize(self.GetSize())
+        self.iconsize = (16, 16)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+        # Fancy gui
+        self._mgr = wx.aui.AuiManager(self)
+        # Add toolbars
+        self.toolbars = { 'map' : None,
+                          'vdigit' : None,
+                          'georect' : None,
+                          'gcpdisp' : None,
+                          'gcpman' : None,
+                          'nviz' : None }
+        self.activemap = None
+        for toolb in toolbars:
+            self.AddToolbar(toolb)
+        if self.toolbars['gcpdisp']:
+            self.activemap = self.toolbars['gcpdisp'].togglemap
+            self.activemap.SetSelection(0)
+            self.SrcMap        = self.grwiz.SrcMap       # instance of render.Map
+            self.TgtMap        = self.grwiz.TgtMap       # instance of render.Map
+            self._mgr.SetDockSizeConstraint(0.5, 0.5)
+        # Add statusbar
+        self.statusbar = self.CreateStatusBar(number=4, style=0)
+        self.statusbar.SetStatusWidths([-5, -2, -1, -1])
+        self.statusbarWin = dict()
+            self.statusbarWin['toggle'] = wx.Choice(self.statusbar, wx.ID_ANY,
+                                      choices = [_("Coordinates"),
+                                                 _("Extent"),
+                                                 _("Comp. region"),
+                                                 _("Show comp. extent"),
+                                                 _("Display mode"),
+                                                 _("Display geometry"),
+                                                 _("Map scale"),
+                                                 _("Go to GCP No."),
+                                                 _("RMS error")])
+            # set StatusBar to Go to GCP No.
+            self.statusbarWin['toggle'].SetSelection(7)
+        else:
+                                                choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+            self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group='display',
+        key='statusbarMode',
+        subkey='selection'))
+        self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
+        # auto-rendering checkbox
+        self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                  label=_("Render"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
+        self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
+                                                              key='autoRendering',
+                                                              subkey='enabled'))
+        self.statusbarWin['render'].SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+        # show region
+        self.statusbarWin['region'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                  label=_("Show computational extent"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.statusbarWin['region'])
+        self.statusbarWin['region'].SetValue(False)
+        self.statusbarWin['region'].Hide()
+        self.statusbarWin['region'].SetToolTip(wx.ToolTip (_("Show/hide computational "
+                                                             "region extent (set with g.region). "
+                                                             "Display region drawn as a blue box inside the "
+                                                             "computational region, "
+                                                             "computational region inside a display region "
+                                                             "as a red box).")))
+        # set resolution
+        self.statusbarWin['resolution'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                      label=_("Constrain display resolution to computational settings"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.statusbarWin['resolution'])
+        self.statusbarWin['resolution'].SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+        self.statusbarWin['resolution'].Hide()
+        self.statusbarWin['resolution'].SetToolTip(wx.ToolTip (_("Constrain display resolution "
+        "to computational region settings. "
+        "Default value for new map displays can "
+        "be set up in 'User GUI settings' dialog.")))
+        # map scale
+        self.statusbarWin['mapscale'] = wx.ComboBox(parent = self.statusbar, id = wx.ID_ANY,
+                                                    style = wx.TE_PROCESS_ENTER,
+                                                    size=(150, -1))
+        self.statusbarWin['mapscale'].SetItems(['1:1000',
+                                                '1:5000',
+                                                '1:10000',
+                                                '1:25000',
+                                                '1:50000',
+                                                '1:100000',
+                                                '1:1000000'])
+        self.statusbarWin['mapscale'].Hide()
+        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+        self.statusbar.Bind(wx.EVT_COMBOBOX, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+        # go to
+            self.statusbarWin['goto'] = wx.SpinCtrl(parent=self.statusbar, id=wx.ID_ANY,
+                                 min=0)
+            self.statusbar.Bind(wx.EVT_SPINCTRL, self.OnGoTo, self.statusbarWin['goto'])
+        else:
+            self.statusbarWin['goto'] = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+                                                   value="", style=wx.TE_PROCESS_ENTER,
+                                                    size=(100, -1))
+        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
+        self.statusbarWin['goto'].Hide()
+        # projection
+        self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                      label=_("Use defined projection"))
+        self.statusbarWin['projection'].SetValue(False)
+        size = self.statusbarWin['projection'].GetSize()
+        self.statusbarWin['projection'].SetMinSize((size[0] + 150, size[1]))
+        self.statusbarWin['projection'].SetToolTip(wx.ToolTip (_("Reproject coordinates displayed "
+        "in the statusbar. Projection can be "
+        "defined in GUI preferences dialog "
+        "(tab 'Display')")))
+        self.statusbarWin['projection'].Hide()
+        # mask
+        self.statusbarWin['mask'] = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+                                                  label = '')
+        self.statusbarWin['mask'].SetForegroundColour(wx.Colour(255, 0, 0))
+        # on-render gauge
+        self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+                                      range=0, style=wx.GA_HORIZONTAL)
+        self.statusbarWin['progress'].Hide()
+        self.StatusbarReposition() # reposition statusbar
+        # Init map display (buffered DC & set default cursor)
+            self.SrcMapWindow = BufferedWindow(self, id=wx.ID_ANY,
+                                              Map=self.SrcMap, tree=self.tree, lmgr=self._layerManager)
+            self.TgtMapWindow = BufferedWindow(self, id=wx.ID_ANY,
+                                              Map=self.TgtMap, tree=self.tree, lmgr=self._layerManager)
+            self.Map = self.SrcMap
+            self.SrcMapWindow.SetCursor(self.cursors["default"])
+            self.TgtMapWindow.SetCursor(self.cursors["default"])
+            self.activemap.Bind(wx.EVT_CHOICE, self.OnUpdateActive)
+        else:
+            # default is 2D display mode
+            self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,
+                                          Map=self.Map, tree=self.tree, lmgr=self._layerManager)
+            self.MapWindow = self.MapWindow2D
+            self.MapWindow.SetCursor(self.cursors["default"])
+        # initialize region values
+        self.__InitDisplay()
+        # Bind various events
+        self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
+        self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
+            self.Bind(wx.EVT_SIZE,     self.OnDispResize)
+        # Update fancy gui style
+        #if (0):
+            # AuiManager wants a CentrePane , workaround to get two equally sized windows
+            self.list = self.CreateGCPList()
+            #self.SrcMapWindow.SetSize((300, 300))
+            #self.TgtMapWindow.SetSize((300, 300))
+            self.list.SetSize((100, 150))
+            self._mgr.AddPane(self.list, wx.aui.AuiPaneInfo().
+                      Name("gcplist").Caption(_("GCP List")).LeftDockable(False).
+                      RightDockable(False).PinButton().FloatingSize((600,200)).
+                      CloseButton(False).DestroyOnClose(True).
+                      Top().Layer(1).MinSize((200,100)))
+            self._mgr.AddPane(self.SrcMapWindow, wx.aui.AuiPaneInfo().
+                      Name("source").Caption(_("Source Display")).Dockable(False).
+                      CloseButton(False).DestroyOnClose(True).Floatable(False).
+                      Centre())
+            self._mgr.AddPane(self.TgtMapWindow, wx.aui.AuiPaneInfo().
+                      Name("target").Caption(_("Target Display")).Dockable(False).
+                      Right().Layer(0))
+            srcwidth, srcheight = self.SrcMapWindow.GetSize()
+            tgtwidth, tgtheight = self.TgtMapWindow.GetSize()
+            tgtwidth = (srcwidth + tgtwidth) / 2
+            self._mgr.GetPane("target").Hide()
+            self._mgr.Update()
+            self.TgtMapWindow.SetSize((tgtwidth, tgtheight))
+            self._mgr.GetPane("source").BestSize((tgtwidth, tgtheight))
+            self._mgr.GetPane("target").BestSize((tgtwidth, tgtheight))
+            self._mgr.GetPane("target").Show()
+        else:
+            self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
+                          Dockable(False).BestSize((-1,-1)).
+                          Layer(0))
+        # Init print module and classes
+        self.printopt = disp_print.PrintOptions(self, self.MapWindow)
+        # Initialization of digitization tool
+        self.digit = None
+            # set active map
+            # Init zoom history for TgtMapWindow
+            self.TgtMapWindow.ZoomHistory(self.Map.region['n'],
+                                       self.Map.region['s'],
+                                       self.Map.region['e'],
+                                       self.Map.region['w'])
+        self.MapWindow.ZoomHistory(self.Map.region['n'],
+        # Re-use dialogs
+        self.dialogs = {}
+        self.dialogs['attributes'] = None
+        self.dialogs['category'] = None
+        self.dialogs['barscale'] = None
+        self.dialogs['legend'] = None
+        self.decorationDialog = None # decoration/overlays
+    def AddToolbar(self, name):
+        """!Add defined toolbar to the window
+        Currently known toolbars are:
+         - 'map'     - basic map toolbar
+         - 'vdigit'  - vector digitizer
+         - 'gcpdisp'  - GCP Manager
+         - 'georect' - georectifier
+         - 'nviz'    - 3D view mode
+        # default toolbar
+        if name == "map":
+            self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
+            self._mgr.AddPane(self.toolbars['map'],
+                              wx.aui.AuiPaneInfo().
+                              Name("maptoolbar").Caption(_("Map Toolbar")).
+                              ToolbarPane().Top().
+                              LeftDockable(False).RightDockable(False).
+                              BottomDockable(False).TopDockable(True).
+                              CloseButton(False).Layer(2).
+                              BestSize((self.toolbars['map'].GetSize())))
+        # vector digitizer
+        elif name == "vdigit":
+            from vdigit import haveVDigit
+            if not haveVDigit:
+                from vdigit import errorMsg
+                msg = _("Unable to start vector digitizer.\nThe VDigit python extension "
+                        "was not found or loaded properly.\n"
+                        "Switching back to 2D display mode.\n\nDetails: %s" % errorMsg)
+                self.toolbars['map'].combo.SetValue (_("2D view"))
+                              message=msg,
+                              style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                return
+            if self._layerManager:
+                log = self._layerManager.goutput
+            else:
+                log = None
+            self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, mapcontent=self.Map,
+                                                             layerTree=self.tree,
+                                                             log=log)
+            self._mgr.AddPane(self.toolbars['vdigit'],
+                              Name("vdigittoolbar").Caption(_("Vector digitizer toolbar")).
+                              ToolbarPane().Top().Row(1).
+                              BestSize((self.toolbars['vdigit'].GetSize())))
+            # change mouse to draw digitized line
+            self.MapWindow.mouse['box'] = "point"
+            self.MapWindow.zoomtype = 0
+            self.MapWindow.pen     = wx.Pen(colour='red',   width=2, style=wx.SOLID)
+            self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SOLID)
+        # GCP display
+        elif name == "gcpdisp":
+            self.toolbars['gcpdisp'] = toolbars.GCPDisplayToolbar(self)
+            self._mgr.AddPane(self.toolbars['gcpdisp'],
+                              Name("gcpdisplaytoolbar").Caption(_("GCP Display toolbar")).
+                              CloseButton(False).Layer(2))
+            self.toolbars['gcpman'] = toolbars.GCPManToolbar(self)
+            self._mgr.AddPane(self.toolbars['gcpman'],
+                              Name("gcpmanagertoolbar").Caption(_("GCP Manager toolbar")).
+        # georectifier
+        elif name == "georect":
+            self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
+            self._mgr.AddPane(self.toolbars['georect'],
+                              Name("georecttoolbar").Caption(_("Georectification toolbar")).
+        # nviz
+        elif name == "nviz":
+            import nviz
+            # check for GLCanvas and OpenGL
+            msg = None
+            if not nviz.haveGLCanvas:
+                msg = _("Unable to switch to 3D display mode.\nThe GLCanvas class has not been "
+                        "included with this build "
+                        "of wxPython!\nSwitching back to "
+                        "2D display mode.\n\nDetails: %s" % nviz.errorMsg)
+            if not nviz.haveNviz:
+                msg = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
+                        "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg)
+            if msg:
+                              message=msg,
+                return
+            # add Nviz toolbar and disable 2D display mode tools
+            self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
+            self.toolbars['map'].Enable2D(False)
+            # update layer tree (-> enable 3d-rasters)
+            if self.tree:
+                self.tree.EnableItemType(type='3d-raster', enable=True)
+            # update status bar
+            self.statusbarWin['toggle'].Enable(False)
+            # erase map window
+            self.MapWindow.EraseMap()
+            self.statusbar.SetStatusText(_("Please wait, loading data..."), 0)
+            # create GL window & NVIZ toolbar
+            if not self.MapWindow3D:
+                self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
+                self.MapWindow = self.MapWindow3D
+                # add Nviz notebookpage
+                self._layerManager.AddNviz()
+                self.MapWindow3D.OnPaint(None) # -> LoadData
+                self.MapWindow3D.Show()
+                self.MapWindow3D.UpdateView(None)
+            else:
+            # switch from MapWindow to MapWindowGL
+            # add nviz toolbar
+            self._mgr.DetachPane(self.MapWindow2D)
+            self.MapWindow2D.Hide()
+            self._mgr.AddPane(self.MapWindow3D, wx.aui.AuiPaneInfo().CentrePane().
+                              Layer(0))
+            self._mgr.AddPane(self.toolbars['nviz'],
+                              Name("nviztoolbar").Caption(_("Nviz toolbar")).
+            self.SetStatusText("", 0)
+    def RemoveToolbar (self, name):
+        """!Removes toolbar from the window
+        @todo Only hide, activate by calling AddToolbar()
+        # cannot hide main toolbar
+        if name == "map":
+            return
+            # TODO: not destroy only hide
+            self._mgr.DetachPane(self.toolbars['vdigit'])
+            self.toolbars['vdigit'].Destroy()
+        else:
+            self._mgr.DetachPane (self.toolbars[name])
+            self.toolbars[name].Destroy()
+        self.toolbars[name] = None
+        if name == 'nviz':
+            # unload data
+            #            self.MapWindow3D.Reset()
+            # switch from MapWindowGL to MapWindow
+            self._mgr.DetachPane(self.MapWindow3D)
+            self.MapWindow3D.Hide()
+            self.MapWindow2D.Show()
+            self._mgr.AddPane(self.MapWindow2D, wx.aui.AuiPaneInfo().CentrePane().
+                              Layer(0))
+            # remove nviz notebook page
+            self._layerManager.RemoveNviz()
+            # update layer tree (-> disable 3d-rasters)
+            if self.tree:
+                self.tree.EnableItemType(type='3d-raster', enable=False)
+            self.MapWindow.UpdateMap()
+        self.toolbars['map'].Enable2D(True)
+        self.statusbarWin['toggle'].Enable(True)
+    def __InitDisplay(self):
+        Initialize map display, set dimensions and map region
+        self.width, self.height = self.GetClientSize()
+        Debug.msg(2, "MapFrame.__InitDisplay():")
+            self.SrcMap.ChangeMapSize(self.GetClientSize())
+            self.SrcMap.region = self.SrcMap.GetRegion() # g.region -upgc
+            self.TgtMap.ChangeMapSize(self.GetClientSize())
+            self.TgtMap.region = self.TgtMap.GetRegion() # g.region -upgc
+            # self.SrcMap.SetRegion() # adjust region to match display window
+            # self.TgtMap.SetRegion() # adjust region to match display window
+        else:
+            self.Map.ChangeMapSize(self.GetClientSize())
+            self.Map.region = self.Map.GetRegion() # g.region -upgc
+            # self.Map.SetRegion() # adjust region to match display window
+    def OnUpdateProgress(self, event):
+        Update progress bar info
+        self.statusbarWin['progress'].SetValue(event.value)
+        event.Skip()
+        Change choicebook page to match display.
+        Or set display for georectifying
+        if self._layerManager and \
+                self._layerManager.georectifying:
+            # in georectifying session; display used to get get geographic
+            # coordinates for GCPs
+            self.OnPointer(event)
+        else:
+            # change bookcontrol page to page associated with display
+            if self.page:
+                pgnum = self.layerbook.GetPageIndex(self.page)
+                if pgnum > -1:
+                    self.layerbook.SetSelection(pgnum)
+        event.Skip()
+    def OnDraw(self, event):
+        """!Re-display current map composition
+        self.MapWindow.UpdateMap(render = False)
+    def OnRender(self, event):
+        """!Re-render map composition (each map layer)
+        # delete tmp map layers (queries)
+        qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
+        for layer in qlayer:
+            self.Map.DeleteLayer(layer)
+        # delete tmp lines
+        if self.MapWindow.mouse["use"] in ("measure",
+                                           "profile"):
+            self.MapWindow.polycoords = []
+            self.MapWindow.ClearLines()
+        # deselect features in vdigit
+        if self.toolbars['vdigit'] and self.digit:
+            self.digit.driver.SetSelected([])
+            self.MapWindow.UpdateMap(render=True, renderVector=True)
+        else:
+            self.MapWindow.UpdateMap(render=True)
+        # update statusbar
+        self.StatusbarUpdate()
+    def OnDispResize(self, event):
+        """!GCP Map Display resized, adjust Map Windows
+            # FIXME: does not work when reducing Map Display width
+            # tried a lot of MinSize, BestSize, also for both source and target map window
+            self._mgr.GetPane("source").BestSize((tgtwidth, srcheight))
+        pass
+    def OnPointer(self, event):
+        """!Pointer button clicked
+        if self.toolbars['map']:
+            if event:
+                self.toolbars['map'].OnTool(event)
+            self.toolbars['map'].action['desc'] = ''
+        self.MapWindow.mouse['use'] = "pointer"
+        # change the cursor
+        if self.toolbars['vdigit']:
+            # digitization tool activated
+            self.MapWindow.SetCursor(self.cursors["cross"])
+            # reset mouse['box'] if needed
+            if self.toolbars['vdigit'].GetAction() in ['addLine']:
+                if self.toolbars['vdigit'].GetAction('type') in ['point', 'centroid']:
+                    self.MapWindow.mouse['box'] = 'point'
+                else: # line, boundary
+                    self.MapWindow.mouse['box'] = 'line'
+            elif self.toolbars['vdigit'].GetAction() in ['addVertex', 'removeVertex', 'splitLine',
+                                                         'editLine', 'displayCats', 'displayAttrs',
+                                                         'copyCats']:
+            else: # moveLine, deleteLine
+                self.MapWindow.mouse['box'] = 'box'
+        elif self._layerManager and self._layerManager.gcpmanagement:
+            self.SrcMapWindow.SetCursor(self.cursors["cross"])
+            self.SrcMapWindow.mouse['use'] = "pointer"
+            self.SrcMapWindow.mouse['box'] = "point"
+            self.TgtMapWindow.SetCursor(self.cursors["cross"])
+            self.TgtMapWindow.mouse['use'] = "pointer"
+            self.TgtMapWindow.mouse['box'] = "point"
+        elif self._layerManager and self._layerManager.georectifying:
+        else:
+    def OnZoomIn(self, event):
+        Zoom in the map.
+        Set mouse cursor, zoombox attributes, and zoom direction
+        self.MapWindow.mouse['use'] = "zoom"
+        self.MapWindow.mouse['box'] = "box"
+        self.MapWindow.zoomtype = 1
+        self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+        if self._layerManager and self._layerManager.gcpmanagement:
+            if self.MapWindow == self.SrcMapWindow:
+                win = self.TgtMapWindow
+            elif self.MapWindow == self.TgtMapWindow:
+                win = self.SrcMapWindow
+            win.mouse['use'] = "zoom"
+            win.mouse['box'] = "box"
+            win.zoomtype = 1
+            win.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+            win.SetCursor(self.cursors["cross"])
+    def OnZoomOut(self, event):
+        Zoom out the map.
+        self.MapWindow.zoomtype = -1
+            win.zoomtype = -1
+    def OnZoomBack(self, event):
+        Zoom last (previously stored position)
+        self.MapWindow.ZoomBack()
+    def OnPan(self, event):
+        Panning, set mouse to drag
+        self.MapWindow.mouse['use'] = "pan"
+        self.MapWindow.mouse['box'] = "pan"
+        self.MapWindow.SetCursor(self.cursors["hand"])
+            win.mouse['use'] = "pan"
+            win.mouse['box'] = "pan"
+            win.zoomtype = 0
+            win.SetCursor(self.cursors["hand"])
+    def OnErase(self, event):
+        Erase the canvas
+            win.EraseMap()
+    def OnZoomRegion(self, event):
+        Zoom to region
+        self.Map.getRegion()
+        self.Map.getResolution()
+        self.UpdateMap()
+        # event.Skip()
+    def OnAlignRegion(self, event):
+        Align region
+        if not self.Map.alignRegion:
+            self.Map.alignRegion = True
+        else:
+            self.Map.alignRegion = False
+        # event.Skip()
+    def OnToggleRender(self, event):
+        Enable/disable auto-rendering
+        if self.statusbarWin['render'].GetValue():
+            self.OnRender(None)
+    def OnToggleShowRegion(self, event):
+        Show/Hide extent in map canvas
+        if self.statusbarWin['region'].GetValue():
+            # show extent
+            self.MapWindow.regionCoords = []
+        else:
+            del self.MapWindow.regionCoords
+        # redraw map if auto-rendering is enabled
+    def OnToggleResolution(self, event):
+        Use resolution of computation region settings
+        for redering image instead of display resolution
+    def OnToggleStatus(self, event):
+        Toggle status text
+    def OnChangeMapScale(self, event):
+        Map scale changed by user
+        scale = event.GetString()
+        try:
+            if scale[:2] != '1:':
+                raise ValueError
+            value = int(scale[2:])
+            self.statusbarWin['mapscale'].SetValue('1:%ld' % int(self.mapScaleValue))
+            return
+        dEW = value * (self.Map.region['cols'] / self.ppm[0])
+        dNS = value * (self.Map.region['rows'] / self.ppm[1])
+        self.Map.region['n'] = self.Map.region['center_northing'] + dNS / 2.
+        self.Map.region['s'] = self.Map.region['center_northing'] - dNS / 2.
+        self.Map.region['w'] = self.Map.region['center_easting']  - dEW / 2.
+        self.Map.region['e'] = self.Map.region['center_easting']  + dEW / 2.
+        # add to zoom history
+        self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
+                                   self.Map.region['e'], self.Map.region['w'])
+        # redraw a map
+        self.statusbarWin['mapscale'].SetFocus()
+    def OnGoTo(self, event):
+        Go to position
+            #GCPNo = int(event.GetString())
+            GCPNo = self.statusbarWin['goto'].GetValue()
+            if GCPNo < 0 or GCPNo > len(self.mapcoordlist):
+                wx.MessageBox(parent=self,
+                      message="%s 1 - %s." % (_("Valid Range:"),
+                                     len(self.mapcoordlist)),
+                      caption=_("Invalid GCP Number"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                return
+            if GCPNo == 0:
+                return
+            self.list.selectedkey = GCPNo
+            self.list.selected = self.list.FindItemData(-1, GCPNo)
+            self.list.render = False
+            self.list.SetItemState(self.list.selected,
+            self.list.render = True
+            # Source MapWindow:
+            begin = (self.mapcoordlist[GCPNo][1], self.mapcoordlist[GCPNo][2])
+            begin = self.SrcMapWindow.Cell2Pixel(begin)
+            end = begin
+            self.SrcMapWindow.Zoom(begin, end, 0)
+            # redraw map
+            self.SrcMapWindow.UpdateMap()
+            # Target MapWindow:
+            begin = (self.mapcoordlist[GCPNo][3], self.mapcoordlist[GCPNo][4])
+            begin = self.TgtMapWindow.Cell2Pixel(begin)
+            end = begin
+            self.TgtMapWindow.Zoom(begin, end, 0)
+            # redraw map
+            self.TgtMapWindow.UpdateMap()
+        else:
+            try:
+                if self.statusbarWin['projection'].IsChecked():
+                    if not UserSettings.Get(group='projection', key='statusbar', subkey='proj4'):
+                        self.statusbar.SetStatusText(_("Projection not defined (check the settings)"), 0)
+                    else:
+                        # reproject values
+                        projIn = UserSettings.Get(group='projection',
+                                                  key='statusbar',
+                                                  subkey='proj4')
+                        projOut = gcmd.RunCommand('g.proj',
+                                                  flags = 'jf',
+                                                  read = True)
+                        proj = projIn.split(' ')[0].split('=')[1]
+                        if proj in ('ll', 'latlong', 'longlat'):
+                            e, n = self.statusbarWin['goto'].GetValue().split(';')
+                            e, n = utils.DMS2Deg(e, n)
+                            proj, coord1 = utils.ReprojectCoordinates(coord = (e, n),
+        projIn = projIn,
+        projOut = projOut, flags = 'd')
+                            e, n = coord1
+                        else:
+                            e, n = map(float, self.statusbarWin['goto'].GetValue().split(';'))
+        projIn = projIn,
+                            e, n = coord1
+                else:
+                    if self.Map.projinfo['proj'] == 'll':
+                    else:
+                region = self.Map.GetCurrentRegion()
+                    else:
+                        region['center_easting'], region['center_northing'] = e, n
+                else:
+                        region['center_easting'], region['center_northing'] = utils.DMS2Deg(e, n)
+                    else:
+                precision = int(UserSettings.Get(group = 'projection', key = 'format',
+                                                 subkey = 'precision'))
+                format = UserSettings.Get(group = 'projection', key = 'format',
+                                          subkey = 'll')
+                if self.Map.projinfo['proj'] == 'll' and format == 'DMS':
+                        self.statusbarWin['goto'].SetValue("%s" % utils.Deg2DMS(region['center_easting'],
+        region['center_northing'],
+        precision = precision))
+                else:
+                    self.statusbarWin['goto'].SetValue("%.*f; %.*f" % \
+                                                           (precision, region['center_easting'],
+                                                            precision, region['center_northing']))
+                return
+            dn = (region['nsres'] * region['rows']) / 2.
+            region['n'] = region['center_northing'] + dn
+            region['s'] = region['center_northing'] - dn
+            de = (region['ewres'] * region['cols']) / 2.
+            region['e'] = region['center_easting'] + de
+            region['w'] = region['center_easting'] - de
+            self.Map.AdjustRegion()
+            self.MapWindow.ZoomHistory(region['n'], region['s'],
+                                       region['e'], region['w'])
+            # redraw map
+        self.statusbarWin['goto'].SetFocus()
+    def StatusbarUpdate(self):
+        """!Update statusbar content"""
+        self.mapScaleValue = self.ppm = None
+        if self.statusbarWin['toggle'].GetSelection() == 0: # Coordinates
+            self.statusbar.SetStatusText("", 0)
+            # enable long help
+            self.StatusbarEnableLongHelp()
+        elif self.statusbarWin['toggle'].GetSelection() in (1, 2): # Extent
+            sel = self.statusbarWin['toggle'].GetSelection()
+            if sel == 1:
+                region = self.Map.region
+            else:
+                region = self.Map.GetRegion() # computation region
+                                      subkey = 'll')
+                else:
+                    projOut = UserSettings.Get(group='projection',
+                                               key='statusbar',
+                                               subkey='proj4')
+                    proj, coord1 = utils.ReprojectCoordinates(coord = (region["w"], region["s"]),
+                    proj, coord2 = utils.ReprojectCoordinates(coord = (region["e"], region["n"]),
+                    if sel == 2:
+                        proj, coord3 = utils.ReprojectCoordinates(coord = (0.0, 0.0),
+                        proj, coord4 = utils.ReprojectCoordinates(coord = (region["ewres"], region["nsres"]),
+                    if coord1 and coord2:
+                        if proj in ('ll', 'latlong', 'longlat') and format == 'DMS':
+                            w, s = utils.Deg2DMS(coord1[0], coord1[1], string = False,
+                            e, n = utils.Deg2DMS(coord2[0], coord2[1], string = False,
+                            if sel == 1:
+                                self.statusbar.SetStatusText("%s - %s, %s - %s" %
+                                                             (w, e, s, n), 0)
+                            else:
+                                ewres, nsres = utils.Deg2DMS(abs(coord3[0]) - abs(coord4[0]),
+                                                             abs(coord3[1]) - abs(coord4[1]),
+                                                             string = False, hemisphere = False,
+                                self.statusbar.SetStatusText("%s - %s, %s - %s (%s, %s)" %
+                                                             (w, e, s, n, ewres, nsres), 0)
+                        else:
+                            w, s = coord1
+                            e, n = coord2
+                            if sel == 1:
+                                self.statusbar.SetStatusText("%.*f - %.*f, %.*f - %.*f" %
+                                                         (precision, w, precision, e,
+                                                          precision, s, precision, n), 0)
+                            else:
+                                ewres, nsres = coord3
+                                self.statusbar.SetStatusText("%.*f - %.*f, %.*f - %.*f (%.*f, %.*f)" %
+                                                              precision, s, precision, n,
+                                                              precision, ewres, precision, nsres), 0)
+                    else:
+                        self.statusbar.SetStatusText(_("Error in projection (check the settings)"), 0)
+            else:
+                    w, s = utils.Deg2DMS(region["w"], region["s"],
+                                         string = False, precision = precision)
+                    e, n = utils.Deg2DMS(region["e"], region["n"],
+                    if sel == 1:
+                                                     (w, e, s, n), 0)
+                    else:
+                        ewres, nsres = utils.Deg2DMS(region['ewres'], region['nsres'],
+                else:
+                    w, s = region["w"], region["s"]
+                    e, n = region["e"], region["n"]
+                    if sel == 1:
+                    else:
+                        ewres, nsres = region['ewres'], region['nsres']
+        elif self.statusbarWin['toggle'].GetSelection() == 3: # Show comp. extent
+            self.statusbarWin['region'].Show()
+            # disable long help
+            self.StatusbarEnableLongHelp(False)
+        elif self.statusbarWin['toggle'].GetSelection() == 4: # Display mode
+            self.statusbarWin['resolution'].Show()
+        elif self.statusbarWin['toggle'].GetSelection() == 5: # Display geometry
+            self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
+                                         (self.Map.region["rows"], self.Map.region["cols"],
+                                          self.Map.region["nsres"], self.Map.region["ewres"]), 0)
+        elif self.statusbarWin['toggle'].GetSelection() == 6: # Map scale
+            # TODO: need to be fixed...
+            ### screen X region problem
+            ### user should specify ppm
+            dc = wx.ScreenDC()
+            dpSizePx = wx.DisplaySize()   # display size in pixels
+            dpSizeMM = wx.DisplaySizeMM() # display size in mm (system)
+            dpSizeIn = (dpSizeMM[0] / 25.4, dpSizeMM[1] / 25.4) # inches
+            sysPpi  = dc.GetPPI()
+            comPpi = (dpSizePx[0] / dpSizeIn[0],
+                      dpSizePx[1] / dpSizeIn[1])
+            ppi = comPpi                  # pixel per inch
+            self.ppm = ((ppi[0] / 2.54) * 100, # pixel per meter
+                        (ppi[1] / 2.54) * 100)
+            Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): size: px=%d,%d mm=%f,%f "
+                      "in=%f,%f ppi: sys=%d,%d com=%d,%d; ppm=%f,%f" % \
+                          (dpSizePx[0], dpSizePx[1], dpSizeMM[0], dpSizeMM[1],
+                           dpSizeIn[0], dpSizeIn[1],
+                           sysPpi[0], sysPpi[1], comPpi[0], comPpi[1],
+                           self.ppm[0], self.ppm[1]))
+            heightCm = region['rows'] / self.ppm[1] * 100
+            widthCm  = region['cols'] / self.ppm[0] * 100
+            Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): width_cm=%f, height_cm=%f" %
+                      (widthCm, heightCm))
+            xscale = (region['e'] - region['w']) / (region['cols'] / self.ppm[0])
+            yscale = (region['n'] - region['s']) / (region['rows'] / self.ppm[1])
+            scale = (xscale + yscale) / 2.
+            Debug.msg(3, "MapFrame.StatusbarUpdate(mapscale): xscale=%f, yscale=%f -> scale=%f" % \
+                          (xscale, yscale, scale))
+            self.statusbar.SetStatusText("")
+            try:
+                self.statusbarWin['mapscale'].SetValue("1:%ld" % (scale + 0.5))
+            except TypeError:
+                pass
+            self.mapScaleValue = scale
+            self.statusbarWin['mapscale'].Show()
+        elif self.statusbarWin['toggle'].GetSelection() == 7: # go to
+                max = self.list.GetItemCount()
+                if max < 1:
+                    max = 1
+                self.statusbarWin['goto'].SetRange(0, max)
+            else:
+                                          subkey = 'll')
+                    else:
+                        proj, coord  = utils.ReprojectCoordinates(coord = (region['center_easting'],
+        region['center_northing']),
+        key='statusbar',
+        subkey='proj4'),
+        flags = 'd')
+                        if coord:
+                                self.statusbarWin['goto'].SetValue("%s" % utils.Deg2DMS(coord[0],
+        coord[1],
+                            else:
+                                self.statusbarWin['goto'].SetValue("%.*f; %.*f" % (precision, coord[0],
+        precision, coord[1]))
+                        else:
+                else:
+                    else:
+                        self.statusbarWin['goto'].SetValue("%.*f; %.*f" % (precision, region['center_easting'],
+            self.statusbarWin['goto'].Show()
+        elif self.statusbarWin['toggle'].GetSelection() == 8: # projection
+            if self.toolbars['gcpdisp']: # RMS error, not projection
+                self.statusbar.SetStatusText(_("Forward: %s, Backward: %s") %
+                                             (self.fwd_rmserror, self.bkw_rmserror))
+            else:
+                epsg = UserSettings.Get(group='projection', key='statusbar', subkey='epsg')
+                if epsg:
+                    label = '%s (EPSG: %s)' % (_("Use defined projection"), epsg)
+                    self.statusbarWin['projection'].SetLabel(label)
+                else:
+                    self.statusbarWin['projection'].SetLabel(_("Use defined projection"))
+                self.statusbarWin['projection'].Show()
+        else:
+            self.statusbar.SetStatusText("", 1)
+    def StatusbarEnableLongHelp(self, enable=True):
+        """!Enable/disable toolbars long help"""
+        for toolbar in self.toolbars.itervalues():
+            if toolbar:
+                toolbar.EnableLongHelp(enable)
+    def StatusbarReposition(self):
+        """!Reposition checkbox in statusbar"""
+        # reposition checkbox
+        widgets = [(0, self.statusbarWin['region']),
+                   (0, self.statusbarWin['resolution']),
+                   (0, self.statusbarWin['mapscale']),
+                   (0, self.statusbarWin['progress']),
+                   (0, self.statusbarWin['projection']),
+                   (0, self.statusbarWin['goto']),
+                   (1, self.statusbarWin['toggle']),
+                   (2, self.statusbarWin['mask']),
+                   (3, self.statusbarWin['render'])]
+        for idx, win in widgets:
+            rect = self.statusbar.GetFieldRect(idx)
+            wWin, hWin = win.GetBestSize()
+            if idx == 0: # show region / mapscale / process bar
+                # -> size
+                if win == self.statusbarWin['progress']:
+                    wWin = rect.width - 6
+                # -> position
+                # if win == self.statusbarWin['region']:
+                # x, y = rect.x + rect.width - wWin, rect.y - 1
+                # align left
+                # else:
+                x, y = rect.x + 3, rect.y - 1
+                w, h = wWin, rect.height + 2
+            else: # choice || auto-rendering
+                x, y = rect.x, rect.y - 1
+                w, h = rect.width, rect.height + 2
+                if idx == 1: # choice
+                    h = hWin
+                elif idx == 2: # mask
+                    x += 5
+                    y += 4
+                elif idx == 3: # render
+                    x += 5
+            win.SetPosition((x, y))
+            win.SetSize((w, h))
+    def SaveToFile(self, event):
+        """!Save map to image
+        if self.toolbars['nviz']:
+            filetype = "PPM file (*.ppm)|*.ppm|TIF file (*.tif)|*.tif"
+            ltype = [{ 'ext' : 'ppm', 'type' : -1 },
+                     { 'ext' : 'tif', 'type' : wx.BITMAP_TYPE_TIF }]
+        else:
+            img = self.MapWindow.img
+            if not img:
+                gcmd.GMessage(parent = self,
+                              message = _("Nothing to render (empty map). Operation canceled."),
+                              msgType = 'info')
+                return
+            filetype, ltype = gdialogs.GetImageHandlers(img)
+        # get size
+        dlg = gdialogs.ImageSizeDialog(self)
+        dlg.CentreOnParent()
+        if dlg.ShowModal() != wx.ID_OK:
+            dlg.Destroy()
+            return
+        width, height = dlg.GetValues()
+        dlg.Destroy()
+        # get filename
+        dlg = wx.FileDialog(parent = self,
+                            message = _("Choose a file name to save the image "
+                                        "(no need to add extension)"),
+                            wildcard = filetype,
+                            style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+        if dlg.ShowModal() == wx.ID_OK:
+            path = dlg.GetPath()
+            if not path:
+                dlg.Destroy()
+                return
+            base, ext = os.path.splitext(path)
+            fileType = ltype[dlg.GetFilterIndex()]['type']
+            extType  = ltype[dlg.GetFilterIndex()]['ext']
+            if ext != extType:
+                path = base + '.' + extType
+            self.MapWindow.SaveToFile(path, fileType,
+                                      width, height)
+        dlg.Destroy()
+    def PrintMenu(self, event):
+        Print options and output menu for map display
+        point = wx.GetMousePosition()
+        printmenu = wx.Menu()
+        # Add items to the menu
+        setup = wx.MenuItem(printmenu, wx.ID_ANY, _('Page setup'))
+        printmenu.AppendItem(setup)
+        self.Bind(wx.EVT_MENU, self.printopt.OnPageSetup, setup)
+        preview = wx.MenuItem(printmenu, wx.ID_ANY, _('Print preview'))
+        printmenu.AppendItem(preview)
+        self.Bind(wx.EVT_MENU, self.printopt.OnPrintPreview, preview)
+        doprint = wx.MenuItem(printmenu, wx.ID_ANY, _('Print display'))
+        printmenu.AppendItem(doprint)
+        self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
+        # Popup the menu.  If an item is selected then its handler
+        # will be called before PopupMenu returns.
+        self.PopupMenu(printmenu)
+        printmenu.Destroy()
+    def OnCloseWindow(self, event):
+        """!Window closed.
+        Also close associated layer tree page
+        pgnum = None
+        self.Map.Clean()
+        # close edited map and 3D tools properly
+            maplayer = self.toolbars['vdigit'].GetLayer()
+            if maplayer:
+                self.toolbars['vdigit'].OnExit()
+                self.imgVectorMap = None
+            self.toolbars['nviz'].OnExit()
+        if not self._layerManager:
+            self.Destroy()
+        elif self.page:
+            if pgnum > -1:
+                self.layerbook.DeletePage(pgnum)
+    def GetRender(self):
+        """!Returns current instance of render.Map()
+        return self.Map
+    def GetWindow(self):
+        """!Get map window"""
+        return self.MapWindow
+    def OnQueryDisplay(self, event):
+        """!Query currrent raster/vector map layers (display mode)
+        if self.toolbars['map'].GetAction() == 'displayAttrb': # select previous action
+            self.toolbars['map'].SelectDefault(event)
+            return
+        self.toolbars['map'].action['desc'] = 'displayAttrb'
+        # switch GIS Manager to output console to show query results
+        self._layerManager.notebook.SetSelection(1)
+        self.MapWindow.mouse['use'] = "query"
+    def OnQueryModify(self, event):
+        Query vector map layer (edit mode)
+        if self.toolbars['map'].GetAction() == 'modifyAttrb': # select previous action
+            return
+        self.toolbars['map'].action['desc'] = 'modifyAttrb'
+        self.MapWindow.mouse['use'] = "queryVector"
+    def QueryMap(self, x, y):
+        """!Query map layer features
+        Currently only raster and vector map layers are supported.
+        @param x,y coordinates
+        #set query snap distance for v.what at mapunit equivalent of 10 pixels
+        qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
+        east, north = self.MapWindow.Pixel2Cell((x, y))
+        num = 0
+        for layer in self.tree.GetSelections():
+            type = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
+            if type in ('raster', 'rgb', 'his',
+                        'vector', 'thememap', 'themechart'):
+                num += 1
+        if num < 1:
+            dlg = wx.MessageDialog(parent = self,
+                                   message = _('No raster or vector map layer selected for querying.'),
+                                   caption = _('No map layer selected'),
+                                   style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+            dlg.ShowModal()
+            dlg.Destroy()
+            return
+        mapname = None
+        raststr = ''
+        vectstr = ''
+        rcmd = ['r.what', '--q']
+        vcmd = ['v.what', '--q']
+            dcmd = self.tree.GetPyData(layer)[0]['cmd']
+            name = utils.GetLayerNameFromCmd(dcmd)
+            if name == '':
+                continue
+            if type in ('raster', 'rgb', 'his'):
+                raststr += "%s," % name
+            elif type in ('vector', 'thememap', 'themechart'):
+                vectstr += "%s," % name
+        # use display region settings instead of computation region settings
+        self.tmpreg = os.getenv("GRASS_REGION")
+        os.environ["GRASS_REGION"] = self.Map.SetRegion(windres=False)
+        # build query commands for any selected rasters and vectors
+        if raststr != '':
+            rcmd.append('-f')
+            rcmd.append('input=%s' % raststr.rstrip(','))
+            rcmd.append('east_north=%f,%f' % (float(east), float(north)))
+        if vectstr != '':
+            # check for vector maps open to be edited
+            digitToolbar = self.toolbars['vdigit']
+            if digitToolbar:
+                map = digitToolbar.GetLayer().GetName()
+                vect = []
+                for vector in vectstr.split(','):
+                    if map == vector:
+                        self._layerManager.goutput.WriteWarning("Vector map <%s> "
+        "opened for editing - skipped." % map)
+                        continue
+                    vect.append(vector)
+                vectstr = ','.join(vect)
+            if len(vectstr) <= 1:
+                self._layerManager.goutput.WriteCmdLog("Nothing to query.")
+                return
+            vcmd.append('-a')
+            vcmd.append('map=%s' % vectstr.rstrip(','))
+            vcmd.append('east_north=%f,%f' % (float(east), float(north)))
+            vcmd.append('distance=%f' % float(qdist))
+        # parse query command(s)
+            if raststr:
+                self._layerManager.goutput.RunCmd(rcmd,
+                                                  compReg=False,
+                                                  onDone = self._QueryMapDone)
+            if vectstr:
+                self._layerManager.goutput.RunCmd(vcmd,
+        else:
+            if raststr:
+                gcmd.RunCommand(rcmd)
+            if vectstr:
+                gcmd.RunCommand(vcmd)
+    def _QueryMapDone(self, returncode):
+        """!Restore settings after querying (restore GRASS_REGION)
+        @param returncode command return code
+        if hasattr(self, "tmpreg"):
+            if self.tmpreg:
+                os.environ["GRASS_REGION"] = self.tmpreg
+            elif os.environ.has_key('GRASS_REGION'):
+                del os.environ["GRASS_REGION"]
+            del self.tmpreg
+    def QueryVector(self, x, y):
+        Query vector map layer features
+        Attribute data of selected vector object are displayed in GUI dialog.
+        Data can be modified (On Submit)
+        if not self.tree.layer_selected or \
+                self.tree.GetPyData(self.tree.layer_selected)[0]['type'] != 'vector':
+                          message=_("No vector map selected for querying."),
+                          caption=_("Vector querying"),
+                          style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+            return
+        if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
+                grass.gisenv()['MAPSET']:
+                          message=_("Only vector map from the current mapset can be modified."),
+            return
+        posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
+                                         y + self.MapWindow.dialogOffset))
+                        self.Map.width)
+        mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name
+        if self.dialogs['attributes'] is None:
+            self.dialogs['attributes'] = \
+                dbm_dialogs.DisplayAttributesDialog(parent=self.MapWindow,
+                                                    map=mapName,
+                                                    query=((east, north), qdist),
+                                                    pos=posWindow,
+                                                    action="update")
+        else:
+            # selection changed?
+            if not self.dialogs['attributes'].mapDBInfo or \
+                    self.dialogs['attributes'].mapDBInfo.map != mapName:
+                self.dialogs['attributes'].UpdateDialog(map=mapName, query=((east, north), qdist))
+            else:
+                self.dialogs['attributes'].UpdateDialog(query=((east, north), qdist))
+        cats = self.dialogs['attributes'].GetCats()
+        try:
+            qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)[0]
+        except IndexError:
+            qlayer = None
+        if self.dialogs['attributes'].mapDBInfo and cats:
+            # highlight feature & re-draw map
+            if qlayer:
+                qlayer.SetCmd(self.AddTmpVectorMapLayer(mapName, cats,
+                                                        useId=False,
+                                                        addLayer=False))
+            else:
+                qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId=False)
+            # set opacity based on queried layer
+            opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float=True)
+            qlayer.SetOpacity(opacity)
+            self.MapWindow.UpdateMap(render=False, renderVector=False)
+            if not self.dialogs['attributes'].IsShown():
+                self.dialogs['attributes'].Show()
+        else:
+            if qlayer:
+                self.Map.DeleteLayer(qlayer)
+            if self.dialogs['attributes'].IsShown():
+                self.dialogs['attributes'].Hide()
+    def OnQuery(self, event):
+        """!Query tools menu"""
+            action = self.toolbars['map'].GetAction()
+        toolsmenu = wx.Menu()
+        display = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
+                              text=_("Query raster/vector map(s) (display mode)"),
+                              kind=wx.ITEM_CHECK)
+        toolsmenu.AppendItem(display)
+        self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
+        numLayers = 0
+                numLayers += 1
+        if numLayers < 1:
+            display.Enable(False)
+        if action == "displayAttrb":
+            display.Check(True)
+        modify = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
+                             text=_("Query vector map (edit mode)"),
+        toolsmenu.AppendItem(modify)
+        self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
+        if self.tree.layer_selected:
+            layer_selected = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer']
+            if layer_selected.GetType() != 'vector' or \
+                    (digitToolbar and \
+                         digitToolbar.GetLayer() == layer_selected):
+                modify.Enable(False)
+            else:
+                if action == "modifyAttrb":
+                    modify.Check(True)
+        self.PopupMenu(toolsmenu)
+        toolsmenu.Destroy()
+    def AddTmpVectorMapLayer(self, name, cats, useId=False, addLayer=True):
+        Add temporal vector map layer to map composition
+        @param name name of map layer
+        @param useId use feature id instead of category
+        # color settings from ATM
+        color = UserSettings.Get(group='atm', key='highlight', subkey='color')
+        colorStr = str(color[0]) + ":" + \
+            str(color[1]) + ":" + \
+            str(color[2])
+        # icon used in vector display and its size
+        icon = ''
+        size = 0
+        vparam = self.tree.GetPyData(self.tree.layer_selected)[0]['cmd']
+        for p in vparam:
+            if '=' in p:
+                parg,pval = p.split('=')
+                if parg == 'icon': icon = pval
+                elif parg == 'size': size = int(pval)
+        pattern = ["d.vect",
+                   "map=%s" % name,
+                   "color=%s" % colorStr,
+                   "fcolor=%s" % colorStr,
+                   "width=%d"  % UserSettings.Get(group='atm', key='highlight', subkey='width')]
+        if icon != '':
+            pattern.append('icon=%s' % icon)
+        if size > 0:
+            pattern.append('size=%i' % size)
+        if useId:
+            cmd = pattern
+            cmd.append('-i')
+            cmd.append('cats=%s' % str(cats))
+        else:
+            cmd = []
+            for layer in cats.keys():
+                cmd.append(copy.copy(pattern))
+                lcats = cats[layer]
+                cmd[-1].append("layer=%d" % layer)
+                cmd[-1].append("cats=%s" % utils.ListOfCatsToRange(lcats))
+        #     if self.icon:
+        #         cmd.append("icon=%s" % (self.icon))
+        #     if self.pointsize:
+        #         cmd.append("size=%s" % (self.pointsize))
+        if addLayer:
+            if useId:
+                return self.Map.AddLayer(type='vector', name=globalvar.QUERYLAYER, command=cmd,
+                                         l_active=True, l_hidden=True, l_opacity=1.0)
+            else:
+                return self.Map.AddLayer(type='command', name=globalvar.QUERYLAYER, command=cmd,
+        else:
+            return cmd
+    def OnAnalyze(self, event):
+        Analysis tools menu
+        measure = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["measure"].GetLabel())
+        measure.SetBitmap(Icons["measure"].GetBitmap(self.iconsize))
+        toolsmenu.AppendItem(measure)
+        self.Bind(wx.EVT_MENU, self.OnMeasure, measure)
+        profile = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["profile"].GetLabel())
+        profile.SetBitmap(Icons["profile"].GetBitmap(self.iconsize))
+        toolsmenu.AppendItem(profile)
+        self.Bind(wx.EVT_MENU, self.Profile, profile)
+        histogram = wx.MenuItem(toolsmenu, wx.ID_ANY, Icons["histogram"].GetLabel())
+        histogram.SetBitmap(Icons["histogram"].GetBitmap(self.iconsize))
+        toolsmenu.AppendItem(histogram)
+        self.Bind(wx.EVT_MENU, self.Histogram, histogram)
+    def OnMeasure(self, event):
+        Init measurement routine that calculates
+        map distance along transect drawn on
+        map display
+        self.totaldist = 0.0 # total measured distance
+        # switch GIS Manager to output console to show measure results
+        # change mouse to draw line for measurement
+        self.MapWindow.mouse['use'] = "measure"
+        self.MapWindow.mouse['box'] = "line"
+        self.MapWindow.pen     = wx.Pen(colour='red', width=2, style=wx.SHORT_DASH)
+        self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SHORT_DASH)
+        self.MapWindow.SetCursor(self.cursors["pencil"])
+        # initiating output
+        style = self._layerManager.goutput.cmd_output.StyleWarning
+        self._layerManager.goutput.WriteLog(_('Click and drag with left mouse button '
+                                              'to measure.%s'
+                                              'Double click with left button to clear.') % \
+                                                (os.linesep), style)
+        if self.Map.projinfo['proj'] != 'xy':
+            units = self.Map.projinfo['units']
+            style = self._layerManager.goutput.cmd_output.StyleCommand
+            self._layerManager.goutput.WriteLog(_('Measuring distance') + ' ('
+                                                + units + '):',
+                                                style)
+        else:
+            self._layerManager.goutput.WriteLog(_('Measuring distance:'),
+                                                style)
+    def MeasureDist(self, beginpt, endpt):
+        """!Calculate map distance from screen distance
+        and print to output window
+        if self._layerManager.notebook.GetSelection() != 1:
+        dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
+        dist = round(dist, 3)
+        d, dunits = self.FormatDist(dist)
+        self.totaldist += dist
+        td, tdunits = self.FormatDist(self.totaldist)
+        strdist = str(d)
+        strtotdist = str(td)
+        if self.Map.projinfo['proj'] == 'xy' or 'degree' not in self.Map.projinfo['unit']:
+            angle = int(math.degrees(math.atan2(north,east)) + 0.5)
+            angle = 180 - angle
+            if angle < 0:
+                angle = 360+angle
+            mstring = 'segment = %s %s\ttotal distance = %s %s\tbearing = %d deg' \
+                % (strdist,dunits,strtotdist,tdunits,angle)
+        else:
+            mstring = 'segment = %s %s\ttotal distance = %s %s' \
+                % (strdist,dunits,strtotdist,tdunits)
+        self._layerManager.goutput.WriteLog(mstring)
+        return dist
+    def Profile(self, event):
+        Init profile canvas and tools
+        raster = []
+        if self.tree.layer_selected and \
+                self.tree.GetPyData(self.tree.layer_selected)[0]['type'] == 'raster':
+            raster.append(self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
+        self.profile = profile.ProfileFrame(self,
+                                            id=wx.ID_ANY, pos=wx.DefaultPosition, size=(700,300),
+                                            style=wx.DEFAULT_FRAME_STYLE, rasterList=raster)
+        self.profile.Show()
+        # Open raster select dialog to make sure that a raster (and the desired raster)
+        # is selected to be profiled
+        self.profile.OnSelectRaster(None)
+    def FormatDist(self, dist):
+        """!Format length numbers and units in a nice way,
+        as a function of length. From code by Hamish Bowman
+        Grass Development Team 2006"""
+        mapunits = self.Map.projinfo['units']
+        if mapunits == 'metres': mapunits = 'meters'
+        outunits = mapunits
+        dist = float(dist)
+        divisor = 1.0
+        # figure out which units to use
+        if mapunits == 'meters':
+            if dist > 2500.0:
+                outunits = 'km'
+                divisor = 1000.0
+            else: outunits = 'm'
+        elif mapunits == 'feet':
+            # nano-bug: we match any "feet", but US Survey feet is really
+            #  5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
+            #  miles the tick markers are rounded to the nearest 10th of a
+            #  mile (528'), the difference in foot flavours is ignored.
+            if dist > 5280.0:
+                outunits = 'miles'
+                divisor = 5280.0
+            else:
+                outunits = 'ft'
+        elif 'degree' in mapunits:
+            if dist < 1:
+                outunits = 'min'
+                divisor = (1/60.0)
+            else:
+                outunits = 'deg'
+        # format numbers in a nice way
+        if (dist/divisor) >= 2500.0:
+            outdist = round(dist/divisor)
+        elif (dist/divisor) >= 1000.0:
+            outdist = round(dist/divisor,1)
+        elif (dist/divisor) > 0.0:
+            outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
+        else:
+            outdist = float(dist/divisor)
+        return (outdist, outunits)
+    def Histogram(self, event):
+        Init histogram display canvas and tools
+        self.histogram = histogram.HistFrame(self,
+                                             id=wx.ID_ANY, size=globalvar.HIST_WINDOW_SIZE,
+                                             style=wx.DEFAULT_FRAME_STYLE)
+        #show new display
+        self.histogram.Show()
+        self.histogram.Refresh()
+        self.histogram.Update()
+    def OnDecoration(self, event):
+        Decorations overlay menu
+        decmenu = wx.Menu()
+        AddScale = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addbarscale"].GetLabel())
+        AddScale.SetBitmap(Icons["addbarscale"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddScale)
+        self.Bind(wx.EVT_MENU, self.OnAddBarscale, AddScale)
+        AddLegend = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addlegend"].GetLabel())
+        AddLegend.SetBitmap(Icons["addlegend"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddLegend)
+        self.Bind(wx.EVT_MENU, self.OnAddLegend, AddLegend)
+        AddText = wx.MenuItem(decmenu, wx.ID_ANY, Icons["addtext"].GetLabel())
+        AddText.SetBitmap(Icons["addtext"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddText)
+        self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
+        self.PopupMenu(decmenu)
+        decmenu.Destroy()
+    def OnAddBarscale(self, event):
+        Handler for scale/arrow map decoration menu selection.
+        if self.dialogs['barscale']:
+            return
+        id = 0 # unique index for overlay layer
+        # If location is latlon, only display north arrow (scale won't work)
+        #        proj = self.Map.projinfo['proj']
+        #        if proj == 'll':
+        #            barcmd = 'd.barscale -n'
+        #        else:
+        #            barcmd = 'd.barscale'
+        # decoration overlay control dialog
+        self.dialogs['barscale'] = \
+            gdialogs.DecorationDialog(parent=self, title=_('Scale and North arrow'),
+                                      size=(350, 200),
+                                      style=wx.DEFAULT_DIALOG_STYLE | wx.CENTRE,
+                                      cmd=['d.barscale', 'at=0,5'],
+                                      ovlId=id,
+                                      name='barscale',
+                                      checktxt = _("Show/hide scale and North arrow"),
+                                      ctrltxt = _("scale object"))
+        self.dialogs['barscale'].CentreOnParent()
+        ### dialog cannot be show as modal - in the result d.barscale is not selectable
+        ### self.dialogs['barscale'].ShowModal()
+        self.dialogs['barscale'].Show()
+        self.MapWindow.mouse['use'] = 'pointer'
+    def OnAddLegend(self, event):
+        Handler for legend map decoration menu selection.
+        if self.dialogs['legend']:
+            return
+        id = 1 # index for overlay layer in render
+        cmd = ['d.legend', 'at=5,50,2,5']
+            cmd.append('map=%s' % self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
+        # Decoration overlay control dialog
+        self.dialogs['legend'] = \
+            gdialogs.DecorationDialog(parent=self, title=('Legend'),
+                                      size=(350, 200),
+                                      cmd=cmd,
+                                      ovlId=id,
+                                      name='legend',
+                                      checktxt = _("Show/hide legend"),
+                                      ctrltxt = _("legend object"))
+        self.dialogs['legend'].CentreOnParent()
+        ### dialog cannot be show as modal - in the result d.legend is not selectable
+        ### self.dialogs['legend'].ShowModal()
+        self.dialogs['legend'].Show()
+    def OnAddText(self, event):
+        Handler for text decoration menu selection.
+        if self.MapWindow.dragid > -1:
+            id = self.MapWindow.dragid
+        else:
+            # index for overlay layer in render
+            if len(self.MapWindow.textdict.keys()) > 0:
+                id = self.MapWindow.textdict.keys()[-1] + 1
+            else:
+                id = 101
+        self.dialogs['text'] = gdialogs.TextLayerDialog(parent=self, ovlId=id,
+                                                        title=_('Add text layer'),
+                                                        size=(400, 200))
+        self.dialogs['text'].CenterOnParent()
+        # If OK button pressed in decoration control dialog
+        if self.dialogs['text'].ShowModal() == wx.ID_OK:
+            text = self.dialogs['text'].GetValues()['text']
+            active = self.dialogs['text'].GetValues()['active']
+            coords, w, h = self.MapWindow.TextBounds(self.dialogs['text'].GetValues())
+            # delete object if it has no text or is not active
+            if text == '' or active == False:
+                try:
+                    self.MapWindow.pdc.ClearId(id)
+                    self.MapWindow.pdc.RemoveId(id)
+                    del self.MapWindow.textdict[id]
+                except:
+                    pass
+                return
+            self.MapWindow.pdc.SetId(id)
+            self.MapWindow.textdict[id] = self.dialogs['text'].GetValues()
+            self.MapWindow.Draw(self.MapWindow.pdcDec, img=self.MapWindow.textdict[id],
+                                drawid=id, pdctype='text', coords=coords)
+    def GetOptData(self, dcmd, type, params, propwin):
+        Callback method for decoration overlay command generated by
+        dialog created in menuform.py
+        # Reset comand and rendering options in render.Map. Always render decoration.
+        # Showing/hiding handled by PseudoDC
+        self.Map.ChangeOverlay(ovltype=type, type='overlay', name='', command=dcmd,
+                               l_active=True, l_render=False)
+        self.params[type] = params
+        self.propwin[type] = propwin
+    def OnZoomToMap(self, event):
+        Set display extents to match selected raster (including NULLs)
+        or vector map.
+            self.MapWindow.ZoomToMap(layers = self.Map.GetListOfLayers())
+        else:
+            self.MapWindow.ZoomToMap()
+    def OnZoomToRaster(self, event):
+        Set display extents to match selected raster map (ignore NULLs)
+        self.MapWindow.ZoomToMap(ignoreNulls = True)
+    def OnZoomToWind(self, event):
+        """!Set display geometry to match computational region
+        settings (set with g.region)
+        self.MapWindow.ZoomToWind()
+    def OnZoomToDefault(self, event):
+        """!Set display geometry to match default region settings
+        self.MapWindow.ZoomToDefault()
+    def OnZoomToSaved(self, event):
+        """!Set display geometry to match extents in
+        saved region file
+        self.MapWindow.ZoomToSaved()
+    def OnDisplayToWind(self, event):
+        """!Set computational region (WIND file) to match display
+        extents
+        self.MapWindow.DisplayToWind()
+    def SaveDisplayRegion(self, event):
+        """!Save display extents to named region file.
+        self.MapWindow.SaveDisplayRegion()
+    def AdjustMap(self, newreg):
+        """!Adjust map window to new extents
+        # adjust map window
+        self.Map.region['n'] = newreg['n']
+        self.Map.region['s'] = newreg['s']
+        self.Map.region['e'] = newreg['e']
+        self.Map.region['w'] = newreg['w']
+        # LL locations
+            if newreg['n'] > 90.0:
+                newreg['n'] = 90.0
+            if newreg['s'] < -90.0:
+                newreg['s'] = -90.0
+        ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
+        cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
+        # calculate new center point and display resolution
+        self.Map.region['center_easting'] = ce
+        self.Map.region['center_northing'] = cn
+        self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
+        self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
+        self.Map.AlignExtentFromDisplay()
+        if self.MapWindow.redrawAll is False:
+            self.MapWindow.redrawAll = True
+    def OnZoomToSource(self, event):
+        """!Set target map window to match extents of source map window
+        if not self.MapWindow == self.TgtMapWindow:
+            self.MapWindow = self.TgtMapWindow
+            self.Map = self.TgtMap
+            self.UpdateActive(self.TgtMapWindow)
+        # get new N, S, E, W for target
+        newreg = self.GetNewExtend(self.SrcMap.region, 'source')
+        self.AdjustMap(newreg)
+    def OnZoomToTarget(self, event):
+        """!Set source map window to match extents of target map window
+        if not self.MapWindow == self.SrcMapWindow:
+            self.MapWindow = self.SrcMapWindow
+            self.UpdateActive(self.SrcMapWindow)
+        newreg = self.GetNewExtend(self.TgtMap.region, 'target')
+    def OnZoomMenu(self, event):
+        """!Popup Zoom menu
+        zoommenu = wx.Menu()
+        zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
+        zoommenu.AppendItem(zoomwind)
+        self.Bind(wx.EVT_MENU, self.OnZoomToWind, zoomwind)
+        zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
+        zoommenu.AppendItem(zoomdefault)
+        self.Bind(wx.EVT_MENU, self.OnZoomToDefault, zoomdefault)
+        zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
+        zoommenu.AppendItem(zoomsaved)
+        self.Bind(wx.EVT_MENU, self.OnZoomToSaved, zoomsaved)
+        savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display'))
+        zoommenu.AppendItem(savewind)
+        self.Bind(wx.EVT_MENU, self.OnDisplayToWind, savewind)
+        savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
+        zoommenu.AppendItem(savezoom)
+        self.Bind(wx.EVT_MENU, self.SaveDisplayRegion, savezoom)
+        self.PopupMenu(zoommenu)
+        zoommenu.Destroy()
+    def OnZoomMenuGCP(self, event):
+        zoomsource = wx.MenuItem(zoommenu, wx.ID_ANY, _('Adjust source display to target display'))
+        zoommenu.AppendItem(zoomsource)
+        self.Bind(wx.EVT_MENU, self.OnZoomToTarget, zoomsource)
+        zoomtarget = wx.MenuItem(zoommenu, wx.ID_ANY, _('Adjust target display to source display'))
+        zoommenu.AppendItem(zoomtarget)
+        self.Bind(wx.EVT_MENU, self.OnZoomToSource, zoomtarget)
+    def SetProperties(self, render=False, mode=0, showCompExtent=False,
+                      constrainRes=False, projection=False):
+        """!Set properies of map display window"""
+        self.statusbarWin['render'].SetValue(render)
+        self.statusbarWin['toggle'].SetSelection(mode)
+        self.statusbarWin['region'].SetValue(showCompExtent)
+        self.statusbarWin['resolution'].SetValue(constrainRes)
+        self.statusbarWin['projection'].SetValue(projection)
+        if showCompExtent:
+    def OnUpdateActive(self, event):
+        if self.activemap.GetSelection() == 0:
+        else:
+        self.UpdateActive(self.MapWindow)
+    def UpdateActive(self, win):
+        # optionally disable tool zoomback tool
+        self.toolbars['gcpdisp'].Enable('zoomback', enable = (len(self.MapWindow.zoomhistory) > 1))
+        self.activemap.SetSelection(win == self.TgtMapWindow)
+    def IsStandalone(self):
+        """!Check if Map display is standalone"""
+            return False
+        return True
+    def GetLayerManager(self):
+        """!Get reference to Layer Manager
+        @return window reference
+        @return None (if standalone)
+        return self._layerManager
+# end of class MapFrame
+class MapApp(wx.App):
+    MapApp class
+    def OnInit(self):
+        wx.InitAllImageHandlers()
+        if __name__ == "__main__":
+            Map = render.Map() # instance of Map class to render GRASS display output to PPM file
+        else:
+            Map = None
+        self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map,
+                               size=globalvar.MAP_WINDOW_SIZE)
+        #self.SetTopWindow(Map)
+        self.mapFrm.Show()
+            # redraw map, if new command appears
+            self.redraw = False
+            status = Command(self, Map, cmdfilename)
+            status.start()
+            self.timer = wx.PyTimer(self.watcher)
+            # check each 0.1s
+            self.timer.Start(100)
+        return 1
+    def OnExit(self):
+            # stop the timer
+            self.timer.Stop()
+            # terminate thread (a bit ugly)
+            os.system("""!echo "quit" >> %s""" % (cmdfilename))
+    def watcher(self):
+        """!Redraw, if new layer appears"""
+        if self.redraw:
+            self.mapFrm.OnDraw(None)
+        return
+# end of class MapApp
+if __name__ == "__main__":
+    ###### SET command variable
+    if len(sys.argv) != 3:
+        print __doc__
+        sys.exit()
+    title = sys.argv[1]
+    cmdfilename = sys.argv[2]
+    import gettext
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+    print >> sys.stderr, "\nStarting monitor <%s>...\n" % (title)
+    gm_map = MapApp(0)
+    # set title
+    gm_map.mapFrm.SetTitle(_("GRASS GIS Map Display: " +
+                             title +
+                             " - Location: " + grass.gisenv()["LOCATION_NAME"]))
+    gm_map.MainLoop()
+    os.remove(cmdfilename)
+    os.system("""!g.gisenv set="GRASS_PYCMDFILE" """)
+    print >> sys.stderr, "\nStopping monitor <%s>...\n" % (title)
+    sys.exit(0)
Property changes on: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -143,6 +143,7 @@
                           'vdigit' : None,
                           'georect' : None,
+                          'gcpdisp' : None,
                           'nviz' : None }
@@ -303,6 +304,7 @@
+         - 'gcpdisp' - GCP Manager Display
@@ -521,6 +523,11 @@
+        elif self._layerManager and \
+                self._layerManager.gcpmanagement:
         else:
             if self.page:
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -837,6 +837,17 @@
                 coordtype = 'mapcoord'
             self.parent.GetLayerManager().georectifying.DrawGCP(coordtype)
+        if not self.parent.IsStandalone() and \
+                self.parent.GetLayerManager().gcpmanagement:
+            # -> georectifier (redraw GCPs)
+            if self.parent.toolbars['gcpdisp']:
+                if self == self.parent.TgtMapWindow:
+                    coordtype = 'target'
+                else:
+                    coordtype = 'source'
+                self.parent.DrawGCP(coordtype)
         # clear measurement
@@ -1149,6 +1160,9 @@
         elif event.RightUp():
             self.OnRightUp(event)
+        elif event.Entering():
+            self.OnMouseEnter(event)
         elif event.Moving():
             self.OnMouseMoving(event)
@@ -1946,6 +1960,19 @@
             self.DrawLines(pdc=self.pdcTmp)
         elif self.mouse["use"] == "pointer" and \
+            # -> GCP manager
+                coord = self.Pixel2Cell(self.mouse['end'])
+                if self.parent.MapWindow == self.parent.SrcMapWindow:
+                else:
+                self.parent.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm=True)
+                self.UpdateMap(render=False, renderVector=False)
+        elif self.mouse["use"] == "pointer" and \
                 self.parent.GetLayerManager().georectifying:
             # -> georectifying
@@ -2365,6 +2392,19 @@
         # update statusbar
         self.parent.StatusbarUpdate()
+    def OnMouseEnter(self, event):
+        Mouse entered window and no mouse buttons were pressed
+        if self.parent.GetLayerManager().gcpmanagement:
+                if not self.parent.MapWindow == self:
+                    self.parent.MapWindow = self
+                    self.parent.Map = self.Map
+                    self.parent.UpdateActive(self)
+        else:
+            event.Skip()
     def OnMouseMoving(self, event):
         Motion event and no mouse buttons were pressed
@@ -2539,6 +2579,9 @@
         elif zoomtype == 0:
             dx = x1 - x2
             dy = y1 - y2
+            if dx == 0 and dy == 0:
+                dx = x1 - self.Map.width / 2
+                dy = y1 - self.Map.height / 2
             newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
             newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width  + dx,
                                                         self.Map.height + dy))
@@ -2597,6 +2640,8 @@
                 toolbar = self.parent.toolbars['map']
             elif self.parent.GetName() == 'GRMapWindow':
                 toolbar = self.parent.toolbars['georect']
+            elif self.parent.GetName() == 'GCPMapWindow':
+                toolbar = self.parent.toolbars['gcpdisp']
             toolbar.Enable('zoomback', enable = False)
@@ -2641,6 +2686,8 @@
         toolbar.Enable('zoomback', enable)
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -424,6 +424,21 @@
                     'enabled' : True
+            'gcpman' : {
+                'rms' : {
+                    'highestonly' : True,
+                    'sdfactor' : 1,
+                'symbol' : {
+                    'color' : (0, 0, 255, 255),
+                    'hcolor' : (255, 0, 0, 255),
+                    'scolor' : (0, 255, 0, 255),
+                    'ucolor' : (255, 165, 0, 255),
+                    'unused' : True,
+                    'size' : 8,
+                    'width' : 2,
             'georect' : {
                 'symbol' : {
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -311,6 +311,153 @@
                      self.printmap):
             self.EnableTool(tool, enabled)
+class GCPManToolbar(AbstractToolbar):
+    Toolbar for managing ground control points
+    @param parent reference to GCP widget
+    def __init__(self, parent):
+        AbstractToolbar.__init__(self, parent)
+        self.InitToolbar(self.ToolbarData())
+        # realize the toolbar
+        self.Realize()
+    def ToolbarData(self):
+        self.gcpSave = wx.NewId()
+        self.gcpReload = wx.NewId()
+        self.gcpAdd = wx.NewId()
+        self.gcpDelete = wx.NewId()
+        self.gcpClear = wx.NewId()
+        self.rms = wx.NewId()
+        self.georect = wx.NewId()
+        return (
+            (self.gcpSave, 'grGcpSave', Icons["grGcpSave"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpSave"].GetLabel(), Icons["grGcpSave"].GetDesc(),
+             self.parent.SaveGCPs),
+            (self.gcpReload, 'grGcpReload', Icons["grGcpReload"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpReload"].GetLabel(), Icons["grGcpReload"].GetDesc(),
+             self.parent.ReloadGCPs),
+            (self.gcpAdd, 'grGrGcpAdd', Icons["grGcpAdd"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpAdd"].GetLabel(), Icons["grGcpAdd"].GetDesc(),
+             self.parent.AddGCP),
+            (self.gcpDelete, 'grGrGcpDelete', Icons["grGcpDelete"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpDelete"].GetLabel(), Icons["grGcpDelete"].GetDesc(),
+             self.parent.DeleteGCP),
+            (self.gcpClear, 'grGcpClear', Icons["grGcpClear"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpClear"].GetLabel(), Icons["grGcpClear"].GetDesc(),
+             self.parent.ClearGCP),
+            (self.rms, 'grGcpRms', Icons["grGcpRms"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpRms"].GetLabel(), Icons["grGcpRms"].GetDesc(),
+             self.parent.OnRMS),
+            (self.georect, 'grGeorect', Icons["grGeorect"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGeorect"].GetLabel(), Icons["grGeorect"].GetDesc(),
+             self.parent.OnGeorect),
+class GCPDisplayToolbar(AbstractToolbar):
+    GCP Display toolbar
+        GCP Display toolbar constructor
+        # add tool to toggle active map window
+        self.togglemapid = wx.NewId()
+        self.togglemap = wx.Choice(parent=self, id=self.togglemapid,
+						    choices = [_('source'), _('target')],
+						    style=wx.CB_READONLY)
+        self.InsertControl(10, self.togglemap)
+        self.SetToolShortHelp(self.togglemapid, '%s %s %s' % (_('Set map canvas for '),
+                                                              Icons["zoom_back"].GetLabel(),
+                                                              _(' / Zoom to map')))
+        self.Realize()
+        self.action = { 'id' : self.gcpset }
+        self.defaultAction = { 'id' : self.gcpset,
+                               'bind' : self.parent.OnPointer }
+        self.OnTool(None)
+        self.EnableTool(self.zoomback, False)
+        """!Toolbar data"""
+        self.displaymap = wx.NewId()
+        self.rendermap = wx.NewId()
+        self.erase = wx.NewId()
+        self.gcpset = wx.NewId()
+        self.pan = wx.NewId()
+        self.zoomin = wx.NewId()
+        self.zoomout = wx.NewId()
+        self.zoomback = wx.NewId()
+        self.zoomtomap = wx.NewId()
+        self.zoommenu = wx.NewId()
+        self.settings = wx.NewId()
+        self.helpid = wx.NewId()
+        self.quit = wx.NewId()
+        # tool, label, bitmap, kind, shortHelp, longHelp, handler
+        return (
+            (self.displaymap, "displaymap", Icons["displaymap"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["displaymap"].GetLabel(), Icons["displaymap"].GetDesc(),
+             self.parent.OnDraw),
+            (self.rendermap, "rendermap", Icons["rendermap"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["rendermap"].GetLabel(), Icons["rendermap"].GetDesc(),
+             self.parent.OnRender),
+            (self.erase, "erase", Icons["erase"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
+             self.parent.OnErase),
+            (self.gcpset, "grGcpSet", Icons["grGcpSet"].GetBitmap(),
+             wx.ITEM_RADIO, Icons["grGcpSet"].GetLabel(), Icons["grGcpSet"].GetDesc(),
+             self.parent.OnPointer),
+            (self.pan, "pan", Icons["pan"].GetBitmap(),
+             wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+             self.parent.OnPan),
+            (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
+             wx.ITEM_RADIO, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+             self.parent.OnZoomIn),
+            (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
+             wx.ITEM_RADIO, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+             self.parent.OnZoomOut),
+            (self.zoommenu, "zoommenu", Icons["zoommenu"].GetBitmap(),
+             wx.ITEM_NORMAL, _("Adjust display zoom"), Icons["zoommenu"].GetDesc(),
+             self.parent.OnZoomMenuGCP),
+            (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
+             self.parent.OnZoomBack),
+            (self.zoomtomap, "zoomtomap", Icons["zoom_extent"].GetBitmap(),
+             wx.ITEM_NORMAL, _("Zoom to map"), _("Zoom to displayed map"),
+             self.parent.OnZoomToMap),
+            (self.settings, 'grSettings', Icons["grSettings"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grSettings"].GetLabel(), Icons["grSettings"].GetDesc(),
+             self.parent.OnSettings),
+            (self.helpid, 'grHelp', wx.ArtProvider.GetBitmap(id=wx.ART_HELP, client=wx.ART_TOOLBAR, size=globalvar.toolbarSize),
+             wx.ITEM_NORMAL, _('Show Help'), _('Show Help for GCP Manager'),
+             self.parent.OnHelp),
+            (self.quit, 'grGcpQuit', Icons["grGcpQuit"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpQuit"].GetLabel(), Icons["grGcpQuit"].GetDesc(),
+             self.parent.OnQuit)
 class GRToolbar(AbstractToolbar):
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/wxgui.py	2010-07-15 09:03:38 UTC (rev 42794)
@@ -71,6 +71,7 @@
 import gui_modules.mcalc_builder as mapcalculator
 import gui_modules.gcmd as gcmd
 import gui_modules.georect as georect
+import gui_modules.gcpmanager as gcpmanager
 import gui_modules.dbm as dbm
 import gui_modules.workspace as workspace
 import gui_modules.goutput as goutput
@@ -119,6 +120,7 @@
         self.workspaceFile = workspace    # workspace file
         self.workspaceChanged = False     # track changes in workspace
         self.georectifying = None         # reference to GCP class or None
+        self.gcpmanagement = None         # reference to GCP class or None
         # list of open dialogs
         self.dialogs        = dict()
         self.dialogs['preferences'] = None
@@ -250,6 +252,11 @@
         georect.GeorectWizard(self)
+    def OnGCPManager(self, event):
+        """!Launch georectifier module
+        gcpmanager.GCPWizard(self)
     def OnGModeler(self, event):
         """!Launch Graphical Modeler"""
         win = gmodeler.ModelFrame(parent = self)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2010-07-15 08:59:51 UTC (rev 42793)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2010-07-15 09:03:38 UTC (rev 42794)
@@ -614,6 +614,11 @@
 	</menu>
 	<separator />
 	<menuitem>
+	  <label>Manage Ground Control Points</label>
+	  <help>Manage Ground Control Points for Georectification</help>
+	  <handler>OnGCPManager</handler>
+	</menuitem>
+	<menuitem>
 	  <label>Georectify</label>
 	  <help>Georectify raster and vector maps</help>
 	  <handler>OnGeorectify</handler>
