[GRASS-SVN] r42872 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 21 07:57:16 EDT 2010
Author: martinl
Date: 2010-07-21 11:57:16 +0000 (Wed, 21 Jul 2010)
New Revision: 42872
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
bug fix #628 (wingrass native: vdigit error on new map)
(merge r42871 trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-07-21 11:53:14 UTC (rev 42871)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-07-21 11:57:16 UTC (rev 42872)
@@ -508,28 +508,32 @@
return True
def OnStartEditing(self, event):
+ """!Start editing vector map layer requested by the user
- Start editing vector map layer requested by the user
+ try:
+ maplayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+ except:
+ event.Skip()
+ return
if not haveVDigit:
from vdigit import errorMsg
- msg = _("Unable to start vector digitizer.\nThe VDigit python extension "
- "was not found or loaded properly.\n"
- "Switching back to 2D display mode.\n\nDetails: %s" % errorMsg)
+ msg = _("Unable to start wxGUI vector digitizer.\nDo you want to start "
+ "TCL/TK digitizer (v.digit) instead?\n\n"
+ "Details: %s" % errorMsg)
self.mapdisplay.toolbars['map'].combo.SetValue (_("2D view"))
- wx.MessageBox(parent=self.mapdisplay,
- message=msg,
- caption=_("Error"),
- style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ dlg = wx.MessageDialog(parent = self.mapdisplay,
+ message = msg,
+ caption=_("Vector digitizer failed"),
+ style = wx.YES_NO | wx.CENTRE)
+ if dlg.ShowModal() == wx.ID_YES:
+ self.lmgr.goutput.RunCmd(['v.digit', 'map=%s' % maplayer.GetName()],
+ switchPage=False)
+ dlg.Destroy()
return
- try:
- maplayer = self.GetPyData(self.layer_selected)[0]['maplayer']
- except:
- event.Skip()
- return
if not self.mapdisplay.toolbars['vdigit']: # enable tool
self.mapdisplay.AddToolbar('vdigit')
else: # tool already enabled
@@ -1133,11 +1137,10 @@
if self.mapdisplay.toolbars['nviz'] and \
self.GetPyData(self.layer_selected) is not None:
if self.layer_selected.IsChecked():
# update Nviz tool window
type = self.GetPyData(self.layer_selected)[0]['maplayer'].type
if type == 'raster':
self.lmgr.nviz.UpdatePage('surface')
self.lmgr.nviz.SetPage('surface')
@@ -1147,14 +1150,7 @@
elif type == '3d-raster':
self.lmgr.nviz.UpdatePage('volume')
self.lmgr.nviz.SetPage('volume')
- else:
- for page in ('surface', 'vector', 'volume'):
- pageId = self.lmgr.nviz.page[page]['id']
- if pageId > -1:
- self.lmgr.nviz.notebook.RemovePage(pageId)
- self.lmgr.nviz.page[page]['id'] = -1
- self.lmgr.nviz.page['settings']['id'] = 1
def OnCollapseNode(self, event):
"""!Collapse node
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2010-07-21 11:53:14 UTC (rev 42871)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2010-07-21 11:57:16 UTC (rev 42872)
@@ -373,23 +373,14 @@
import nviz
# check for GLCanvas and OpenGL
- msg = None
- if not nviz.haveGLCanvas:
- msg = _("Unable to switch to 3D display mode.\nThe GLCanvas class has not been "
- "included with this build "
- "of wxPython!\nSwitching back to "
- "2D display mode.\n\nDetails: %s" % nviz.errorMsg)
if not nviz.haveNviz:
- msg = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
- "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg)
- if msg:
self.toolbars['map'].combo.SetValue (_("2D view"))
- wx.MessageBox(parent=self,
- message=msg,
+ wx.MessageBox(parent = self,
+ message = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
+ "was not found or loaded properly.\n"
+ "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg),
+ caption = _("Error"),
+ style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
return
# add Nviz toolbar and disable 2D display mode tools
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py 2010-07-21 11:53:14 UTC (rev 42871)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py 2010-07-21 11:57:16 UTC (rev 42872)
@@ -23,24 +23,20 @@
import sys
import wx
-try:
- from wx import glcanvas
- haveGLCanvas = True
-except ImportError, e:
- haveGLCanvas = False
- errorMsg = e
import globalvar
try:
+ from wx import glcanvas
import nviz_mapdisp
sys.path.append(os.path.join(globalvar.ETCWXDIR, "nviz"))
import grass6_wxnviz as wxnviz
haveNviz = True
haveNviz = False
- errorMsg = e
- print >> sys.stderr, "\nWARNING: Nviz extension (3D view) is not available (%s). " % e
+ errorMsg = _("3D view mode is not available.\n"
+ "Reason: %s\n"
+ "Note that the 3D view mode is currently not working under\nMS Windows "
+ "(hopefully this will be fixed soon). "
+ "Please keep\nan eye out for updated versions of GRASS." % e)
if haveNviz:
GLWindow = nviz_mapdisp.GLWindow
else:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py 2010-07-21 11:53:14 UTC (rev 42871)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py 2010-07-21 11:57:16 UTC (rev 42872)
@@ -40,8 +40,8 @@
import wxnviz
-wxUpdateProperties, EVT_UPDATE_PROP = NewEvent()
-wxUpdateView, EVT_UPDATE_VIEW = NewEvent()
+wxUpdateProperties, EVT_UPDATE_PROP = NewEvent()
+wxUpdateView, EVT_UPDATE_VIEW = NewEvent()
wxUpdateLight, EVT_UPDATE_LIGHT = NewEvent()
class NvizThread(Thread):
@@ -152,9 +152,9 @@
size.height)
event.Skip()
def OnPaint(self, event):
- Debug.msg(3, "GLCanvas.OnPaint()")
+ Debug.msg(1, "GLCanvas.OnPaint()")
dc = wx.PaintDC(self)
self.SetCurrent()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-07-21 11:53:14 UTC (rev 42871)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-07-21 11:57:16 UTC (rev 42872)
@@ -36,9 +36,10 @@
import gcmd
import gdialogs
import vdigit
-from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
-from debug import Debug as Debug
+from vdigit import VDigitSettingsDialog, haveVDigit
+from debug import Debug
from preferences import globalSettings as UserSettings
+from nviz import haveNviz
from nviz_preferences import NvizPreferencesDialog
gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
@@ -177,9 +178,23 @@
self.InitToolbar(self.ToolbarData())
# optional tools
- self.combo = wx.ComboBox(parent=self, id=wx.ID_ANY, value=_('2D view'),
- choices=[_('2D view'), _('3D view'), _('Digitize')],
+ choices = [_('2D view')]
+ lmgr = self.parent.GetLayerManager()
+ if haveNviz:
+ choices.append(_('3D view'))
+ else:
+ from nviz import errorMsg
+ lmgr.goutput.WriteWarning(errorMsg)
+ if haveVDigit:
+ choices.append(_('Digitize'))
+ else:
+ from vdigit import errorMsg
+ self.combo = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ choices = choices,
style=wx.CB_READONLY, size=(90, -1))
+ self.combo.SetSelection(0)
self.comboid = self.AddControl(self.combo)
self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2010-07-21 11:53:14 UTC (rev 42871)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2010-07-21 11:57:16 UTC (rev 42872)
@@ -1,14 +1,8 @@
@package vdigit
- at brief Vector digitizer extension
+ at brief wxGUI vector digitizer user interface
-Usage:
- at code
- from vdigit import VDigit as VDigit
- at endcode
Classes:
- AbstractDigit
- VDigit
@@ -60,17 +54,15 @@
haveVDigit = False
GV_LINES = None
PseudoDC = wx.PseudoDC
- errorMsg = err
- # is there a way to have this display on the terminal before the wx gui exits?
- print >> sys.stderr, "\nWARNING: Vector digitizer is not available (%s).\n\n" \
- "Note that the vector digitizer is currently not working under MS Windows " \
- "(hopefully this will be fixed soon). " \
- "Please keep an eye out for updated versions of GRASS." % err
+ errorMsg = _("Vector digitizer is not available.\n"
+ "Reason: %s\n"
+ "Note that the vector digitizer is currently not working under\nMS Windows "
+ "Please keep\nan eye out for updated versions of GRASS." % err)
class AbstractDigit:
+ """!Abstract digitization class
- Abstract digitization class
def __init__(self, mapwindow):
"""!Initialization
